commit 3d89e5478bf550a50c99e93adf659369798263b0 upstream.
Commit:
e9532e69b8d1 ("sched/cputime: Fix steal time accounting vs. CPU hotplug")
... set rq->prev_* to 0 after a CPU hotplug comes back, in order to
fix the case where (after CPU hotplug) steal time is smaller than
rq->prev_steal_time.
However, this should never happen. Steal time was only smaller because of the
KVM-specific bug fixed by the previous patch. Worse, the previous patch
triggers a bug on CPU hot-unplug/plug operation: because
rq->prev_steal_time is cleared, all of the CPU's past steal time will be
accounted again on hot-plug.
Since the root cause has been fixed, we can just revert commit e9532e69b8d1.
Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com>
Acked-by: Paolo Bonzini <pbonzini@redhat.com>
Cc: Radim Krčmář <rkrcmar@redhat.com>
Fixes: 'commit e9532e69b8d1 ("sched/cputime: Fix steal time accounting vs. CPU hotplug")'
Link: http://lkml.kernel.org/r/1465813966-3116-3-git-send-email-wanpeng.li@hotmail.com
Signed-off-by: Andres Oportus <andresoportus@google.com>
commit 51d7b120418e99d6b3bf8df9eb3cc31e8171dee4 upstream.
In commit c4004b02f8e5b ("x86: remove the kernel code/data/bss resources
from /proc/iomem") I was hoping to remove the phyiscal kernel address
data from /proc/iomem entirely, but that had to be reverted because some
system programs actually use it.
This limits all the detailed resource information to properly
credentialed users instead.
[sumits: this is used in Ubuntu as a fix for CVE-2015-8944]
Signed-off-by: Sumit Semwal <sumit.semwal@linaro.org>
commit 96b777452d8881480fd5be50112f791c17db4b6b upstream.
Commit:
2f5177f0fd7e ("sched/cgroup: Fix/cleanup cgroup teardown/init")
.. moved sched_online_group() from css_online() to css_alloc().
It exposes half-baked task group into global lists before initializing
generic cgroup stuff.
LTP testcase (third in cgroup_regression_test) written for testing
similar race in kernels 2.6.26-2.6.28 easily triggers this oops:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000008
IP: kernfs_path_from_node_locked+0x260/0x320
CPU: 1 PID: 30346 Comm: cat Not tainted 4.10.0-rc5-test #4
Call Trace:
? kernfs_path_from_node+0x4f/0x60
kernfs_path_from_node+0x3e/0x60
print_rt_rq+0x44/0x2b0
print_rt_stats+0x7a/0xd0
print_cpu+0x2fc/0xe80
? __might_sleep+0x4a/0x80
sched_debug_show+0x17/0x30
seq_read+0xf2/0x3b0
proc_reg_read+0x42/0x70
__vfs_read+0x28/0x130
? security_file_permission+0x9b/0xc0
? rw_verify_area+0x4e/0xb0
vfs_read+0xa5/0x170
SyS_read+0x46/0xa0
entry_SYSCALL_64_fastpath+0x1e/0xad
Here the task group is already linked into the global RCU-protected 'task_groups'
list, but the css->cgroup pointer is still NULL.
This patch reverts this chunk and moves online back to css_online().
Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Cc: Tejun Heo <tj@kernel.org>
Fixes: 2f5177f0fd7e ("sched/cgroup: Fix/cleanup cgroup teardown/init")
Link: http://lkml.kernel.org/r/148655324740.424917.5302984537258726349.stgit@buzz
Signed-off-by: Matt Fleming <matt@codeblueprint.co.uk>
Commit ff86bf0c65f1 ("alarmtimer: Rate limit periodic intervals") sets a
minimum bound on the alarm timer interval. This minimum bound shouldn't
be applied if the interval is 0. Otherwise, one-shot timers will be
converted into periodic ones.
Fixes: ff86bf0c65f1 ("alarmtimer: Rate limit periodic intervals")
Reported-by: Ben Fennema <fennema@google.com>
Signed-off-by: Greg Hackmann <ghackmann@google.com>
Cc: stable@vger.kernel.org
Cc: John Stultz <john.stultz@linaro.org>
commit db9108e054700c96322b0f0028546aa4e643cf0b upstream.
Hit the kmemleak when executing instance_rmdir, it forgot releasing
mem of tracing_cpumask. With this fix, the warn does not appear any
more.
unreferenced object 0xffff93a8dfaa7c18 (size 8):
comm "mkdir", pid 1436, jiffies 4294763622 (age 9134.308s)
hex dump (first 8 bytes):
ff ff ff ff ff ff ff ff ........
backtrace:
[<ffffffff88b6567a>] kmemleak_alloc+0x4a/0xa0
[<ffffffff8861ea41>] __kmalloc_node+0xf1/0x280
[<ffffffff88b505d3>] alloc_cpumask_var_node+0x23/0x30
[<ffffffff88b5060e>] alloc_cpumask_var+0xe/0x10
[<ffffffff88571ab0>] instance_mkdir+0x90/0x240
[<ffffffff886e5100>] tracefs_syscall_mkdir+0x40/0x70
[<ffffffff886565c9>] vfs_mkdir+0x109/0x1b0
[<ffffffff8865b1d0>] SyS_mkdir+0xd0/0x100
[<ffffffff88403857>] do_syscall_64+0x67/0x150
[<ffffffff88b710e7>] return_from_SYSCALL_64+0x0/0x6a
[<ffffffffffffffff>] 0xffffffffffffffff
Link: http://lkml.kernel.org/r/1500546969-12594-1-git-send-email-chuhu@redhat.com
Fixes: ccfe9e42e451 ("tracing: Make tracing_cpumask available for all instances")
Signed-off-by: Chunyu Hu <chuhu@redhat.com>
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
commit 6a8a75f3235724c5941a33e287b2f98966ad14c5 upstream.
This reverts commit cc1582c231ea041fbc68861dfaf957eaf902b829.
This commit introduced a regression that broke rr-project, which uses sampling
events to receive a signal on overflow (but does not care about the contents
of the sample). These signals are critical to the correct operation of rr.
There's been some back and forth about how to fix it - but to not keep
applications in limbo queue up a revert.
Reported-by: Kyle Huey <me@kylehuey.com>
Acked-by: Kyle Huey <me@kylehuey.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Cc: Jin Yao <yao.jin@linux.intel.com>
Cc: Vince Weaver <vincent.weaver@maine.edu>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/r/20170628105600.GC5981@leverpostej
commit 2e028c4fe12907f226b8221815f16c2486ad3aa7 upstream.
My static checker complains that if "func" is NULL then "clear_filter"
is uninitialized. This seems like it could be true, although it's
possible something subtle is happening that I haven't seen.
kernel/trace/ftrace.c:3844 match_records()
error: uninitialized symbol 'clear_filter'.
Link: http://lkml.kernel.org/r/20170712073556.h6tkpjcdzjaozozs@mwanda
Fixes: f0a3b154bd7 ("ftrace: Clarify code for mod command")
commit c59f29cb144a6a0dfac16ede9dc8eafc02dc56ca upstream.
The 's' flag is supposed to indicate that a softirq is running. This
can be detected by testing the preempt_count with SOFTIRQ_OFFSET.
The current code tests the preempt_count with SOFTIRQ_MASK, which
would be true even when softirqs are disabled but not serving a
softirq.
Link: http://lkml.kernel.org/r/1481300417-3564-1-git-send-email-pkondeti@codeaurora.org
Signed-off-by: Pavankumar Kondeti <pkondeti@codeaurora.org>
Signed-off-by: Amit Pundir <amit.pundir@linaro.org>
commit f32d782e31bf079f600dcec126ed117b0577e85c upstream.
The group mask is always used in intersection with the group CPUs. So,
when building the group mask, we don't have to care about CPUs that are
not part of the group.
Signed-off-by: Lauro Ramos Venancio <lvenanci@redhat.com>
Cc: lwang@redhat.com
Cc: riel@redhat.com
Link: http://lkml.kernel.org/r/1492717903-5195-2-git-send-email-lvenanci@redhat.com
commit 73bb059f9b8a00c5e1bf2f7ca83138c05d05e600 upstream.
The point of sched_group_mask is to select those CPUs from
sched_group_cpus that can actually arrive at this balance domain.
The current code gets it wrong, as can be readily demonstrated with a
topology like:
node 0 1 2 3
0: 10 20 30 20
1: 20 10 20 30
2: 30 20 10 20
3: 20 30 20 10
Where (for example) domain 1 on CPU1 ends up with a mask that includes
CPU0:
[] CPU1 attaching sched-domain:
[] domain 0: span 0-2 level NUMA
[] groups: 1 (mask: 1), 2, 0
[] domain 1: span 0-3 level NUMA
[] groups: 0-2 (mask: 0-2) (cpu_capacity: 3072), 0,2-3 (cpu_capacity: 3072)
This causes sched_balance_cpu() to compute the wrong CPU and
consequently should_we_balance() will terminate early resulting in
missed load-balance opportunities.
The fixed topology looks like:
[] groups: 0-2 (mask: 1) (cpu_capacity: 3072), 0,2-3 (cpu_capacity: 3072)
(note: this relies on OVERLAP domains to always have children, this is
true because the regular topology domains are still here -- this is
before degenerate trimming)
Debugged-by: Lauro Ramos Venancio <lvenanci@redhat.com>
Fixes: e3589f6c81e4 ("sched: Allow for overlapping sched_domain spans")
commit c0d80ddab89916273cb97114889d3f337bc370ae upstream.
core_kernel_text is used by MIPS in its function graph trace processing,
so having this method traced leads to an infinite set of recursive calls
such as:
Call Trace:
ftrace_return_to_handler+0x50/0x128
core_kernel_text+0x10/0x1b8
prepare_ftrace_return+0x6c/0x114
ftrace_graph_caller+0x20/0x44
return_to_handler+0x10/0x30
return_to_handler+0x0/0x30
ftrace_ops_no_ops+0x114/0x1bc
Mark the function notrace to avoid it being traced.
Link: http://lkml.kernel.org/r/1498028607-6765-1-git-send-email-marcin.nowakowski@imgtec.com
Signed-off-by: Marcin Nowakowski <marcin.nowakowski@imgtec.com>
Reviewed-by: Masami Hiramatsu <mhiramat@kernel.org>
Cc: Thomas Meyer <thomas@m3y3r.de>
Cc: Daniel Borkmann <daniel@iogearbox.net>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
commit 6bdf6abc56b53103324dfd270a86580306e1a232 upstream.
Leaking kernel addresses on unpriviledged is generally disallowed,
for example, verifier rejects the following:
0: (b7) r0 = 0
1: (18) r2 = 0xffff897e82304400
3: (7b) *(u64 *)(r1 +48) = r2
R2 leaks addr into ctx
Doing pointer arithmetic on them is also forbidden, so that they
don't turn into unknown value and then get leaked out. However,
there's xadd as a special case, where we don't check the src reg
for being a pointer register, e.g. the following will pass:
0: (b7) r0 = 0
1: (7b) *(u64 *)(r1 +48) = r0
2: (18) r2 = 0xffff897e82304400 ; map
4: (db) lock *(u64 *)(r1 +48) += r2
5: (95) exit
We could store the pointer into skb->cb, loose the type context,
and then read it out from there again to leak it eventually out
of a map value. Or more easily in a different variant, too:
0: (bf) r6 = r1
1: (7a) *(u64 *)(r10 -8) = 0
2: (bf) r2 = r10
3: (07) r2 += -8
4: (18) r1 = 0x0
6: (85) call bpf_map_lookup_elem#1
7: (15) if r0 == 0x0 goto pc+3
R0=map_value(ks=8,vs=8,id=0),min_value=0,max_value=0 R6=ctx R10=fp
8: (b7) r3 = 0
9: (7b) *(u64 *)(r0 +0) = r3
10: (db) lock *(u64 *)(r0 +0) += r6
11: (b7) r0 = 0
12: (95) exit
from 7 to 11: R0=inv,min_value=0,max_value=0 R6=ctx R10=fp
11: (b7) r0 = 0
12: (95) exit
Prevent this by checking xadd src reg for pointer types. Also
add a couple of test cases related to this.
Fixes: 1be7f75d1668 ("bpf: enable non-root eBPF programs")
Fixes: 17a5267067f3 ("bpf: verifier (add verifier core)")
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Acked-by: Alexei Starovoitov <ast@kernel.org>
Acked-by: Martin KaFai Lau <kafai@fb.com>
Acked-by: Edward Cree <ecree@solarflare.com>
commit 425fffd886bae3d127a08fa6a17f2e31e24ed7ff upstream.
Currently, inputting the following command will succeed but actually the
value will be truncated:
# echo 0x12ffffffff > /proc/sys/net/ipv4/tcp_notsent_lowat
This is not friendly to the user, so instead, we should report error
when the value is larger than UINT_MAX.
Fixes: e7d316a02f68 ("sysctl: handle error writing UINT_MAX to u32 fields")
Signed-off-by: Liping Zhang <zlpnobody@gmail.com>
Cc: Subash Abhinov Kasiviswanathan <subashab@codeaurora.org>
Cc: Eric W. Biederman <ebiederm@xmission.com>
commit 5380e5644afbba9e3d229c36771134976f05c91e upstream.
I saw some very confusing sysctl output on my system:
# cat /proc/sys/net/core/xfrm_aevent_rseqth
-2
# cat /proc/sys/net/core/xfrm_aevent_etime
-10
# cat /proc/sys/net/ipv4/tcp_notsent_lowat
-4294967295
Because we forget to set the *negp flag in proc_douintvec, so it will
become a garbage value.
Since the value related to proc_douintvec is always an unsigned integer,
so we can set *negp to false explictily to fix this issue.
commit 9e52b32567126fe146f198971364f68d3bc5233f upstream.
Always try to parse an address, since kstrtoul() will safely fail when
given a symbol as input. If that fails (which will be the case for a
symbol), try to parse a symbol instead.
This allows creating a probe such as:
p:probe/vlan_gro_receive 8021q:vlan_gro_receive+0
Which is necessary for this command to work:
perf probe -m 8021q -a vlan_gro_receive
Link: http://lkml.kernel.org/r/fd72d666f45b114e2c5b9cf7e27b91de1ec966f1.1498122881.git.sd@queasysnail.net
Fixes: 413d37d1e ("tracing: Add kprobe-based event tracer")
Acked-by: Masami Hiramatsu <mhiramat@kernel.org>
Signed-off-by: Sabrina Dubroca <sd@queasysnail.net>
commit 6e5f32f7a43f45ee55c401c0b9585eb01f9629a8 upstream.
If we crossed a sample window while in NO_HZ we will add LOAD_FREQ to
the pending sample window time on exit, setting the next update not
one window into the future, but two.
This situation on exiting NO_HZ is described by:
this_rq->calc_load_update < jiffies < calc_load_update
In this scenario, what we should be doing is:
this_rq->calc_load_update = calc_load_update [ next window ]
But what we actually do is:
this_rq->calc_load_update = calc_load_update + LOAD_FREQ [ next+1 window ]
This has the effect of delaying load average updates for potentially
up to ~9seconds.
This can result in huge spikes in the load average values due to
per-cpu uninterruptible task counts being out of sync when accumulated
across all CPUs.
It's safe to update the per-cpu active count if we wake between sample
windows because any load that we left in 'calc_load_idle' will have
been zero'd when the idle load was folded in calc_global_load().
This issue is easy to reproduce before,
commit 9d89c257dfb9 ("sched/fair: Rewrite runnable load and utilization average tracking")
just by forking short-lived process pipelines built from ps(1) and
grep(1) in a loop. I'm unable to reproduce the spikes after that
commit, but the bug still seems to be present from code review.
Cc: Mike Galbraith <umgwanakikbuti@gmail.com>
Cc: Morten Rasmussen <morten.rasmussen@arm.com>
Cc: Vincent Guittot <vincent.guittot@linaro.org>
Fixes: commit 5167e8d ("sched/nohz: Rewrite and fix load-avg computation -- again")
Link: http://lkml.kernel.org/r/20170217120731.11868-2-matt@codeblueprint.co.uk
[ Upstream commit ff7a28a074ccbea999dadbb58c46212cf90984c6 ]
When a system panics, the "Rebooting in X seconds.." message is never
printed because it lacks a new line. Fix it.
Link: http://lkml.kernel.org/r/20170119114751.2724-1-jslaby@suse.cz
commit 41662f5cc55335807d39404371cfcbb1909304c4 upstream.
SYSCTL_WRITES_WARN was added in commit f4aacea2f5d1 ("sysctl: allow for
strict write position handling"), and released in v3.16 in August of
2014. Since then I can find only 1 instance of non-zero offset
writing[1], and it was fixed immediately in CRIU[2]. As such, it
appears safe to flip this to the strict state now.
[1] https://www.google.com/search?q="when%20file%20position%20was%20not%200"
[2] http://lists.openvz.org/pipermail/criu/2015-April/019819.html
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Sumit Semwal <sumit.semwal@linaro.org>
commit ceea5e3771ed2378668455fa21861bead7504df5 upstream.
In tests, which excercise switching of clocksources, a NULL
pointer dereference can be observed on AMR64 platforms in the
clocksource read() function:
u64 clocksource_mmio_readl_down(struct clocksource *c)
return ~(u64)readl_relaxed(to_mmio_clksrc(c)->reg) & c->mask;
This is called from the core timekeeping code via:
cycle_now = tkr->read(tkr->clock);
tkr->read is the cached tkr->clock->read() function pointer.
When the clocksource is changed then tkr->clock and tkr->read
are updated sequentially. The code above results in a sequential
load operation of tkr->read and tkr->clock as well.
If the store to tkr->clock hits between the loads of tkr->read
and tkr->clock, then the old read() function is called with the
new clock pointer. As a consequence the read() function
dereferences a different data structure and the resulting 'reg'
pointer can point anywhere including NULL.
This problem was introduced when the timekeeping code was
switched over to use struct tk_read_base. Before that, it was
theoretically possible as well when the compiler decided to
reload clock in the code sequence:
now = tk->clock->read(tk->clock);
Add a helper function which avoids the issue by reading
tk_read_base->clock once into a local variable clk and then issue
the read function via clk->read(clk). This guarantees that the
read() function always gets the proper clocksource pointer handed
in.
Since there is now no use for the tkr.read pointer, this patch
also removes it, and to address stopping the fast timekeeper
during suspend/resume, it introduces a dummy clocksource to use
rather then just a dummy read function.
Signed-off-by: John Stultz <john.stultz@linaro.org>
Acked-by: Ingo Molnar <mingo@kernel.org>
Cc: Prarit Bhargava <prarit@redhat.com>
Cc: Richard Cochran <richardcochran@gmail.com>
Cc: Stephen Boyd <stephen.boyd@linaro.org>
Cc: Miroslav Lichvar <mlichvar@redhat.com>
Cc: Daniel Mentz <danielmentz@google.com>
Link: http://lkml.kernel.org/r/1496965462-20003-2-git-send-email-john.stultz@linaro.org
commit 57db7e4a2d92c2d3dfbca4ef8057849b2682436b upstream.
Thomas Gleixner wrote:
> The CRIU support added a 'feature' which allows a user space task to send
> arbitrary (kernel) signals to itself. The changelog says:
> The kernel prevents sending of siginfo with positive si_code, because
> these codes are reserved for kernel. I think we can allow a task to
> send such a siginfo to itself. This operation should not be dangerous.
> Quite contrary to that claim, it turns out that it is outright dangerous
> for signals with info->si_code == SI_TIMER. The following code sequence in
> a user space task allows to crash the kernel:
> id = timer_create(CLOCK_XXX, ..... signo = SIGX);
> timer_set(id, ....);
> info->si_signo = SIGX;
> info->si_code = SI_TIMER:
> info->_sifields._timer._tid = id;
> info->_sifields._timer._sys_private = 2;
> rt_[tg]sigqueueinfo(..., SIGX, info);
> sigemptyset(&sigset);
> sigaddset(&sigset, SIGX);
> rt_sigtimedwait(sigset, info);
> For timers based on CLOCK_PROCESS_CPUTIME_ID, CLOCK_THREAD_CPUTIME_ID this
> results in a kernel crash because sigwait() dequeues the signal and the
> dequeue code observes:
> info->si_code == SI_TIMER && info->_sifields._timer._sys_private != 0
> which triggers the following callchain:
> do_schedule_next_timer() -> posix_cpu_timer_schedule() -> arm_timer()
> arm_timer() executes a list_add() on the timer, which is already armed via
> the timer_set() syscall. That's a double list add which corrupts the posix
> cpu timer list. As a consequence the kernel crashes on the next operation
> touching the posix cpu timer list.
> Posix clocks which are internally implemented based on hrtimers are not
> affected by this because hrtimer_start() can handle already armed timers
> nicely, but it's a reliable way to trigger the WARN_ON() in
> hrtimer_forward(), which complains about calling that function on an
> already armed timer.
This problem has existed since the posix timer code was merged into
2.5.63. A few releases earlier in 2.5.60 ptrace gained the ability to
inject not just a signal (which linux has supported since 1.0) but the
full siginfo of a signal.
The core problem is that the code will reschedule in response to
signals getting dequeued not just for signals the timers sent but
for other signals that happen to a si_code of SI_TIMER.
Avoid this confusion by testing to see if the queued signal was
preallocated as all timer signals are preallocated, and so far
only the timer code preallocates signals.
Move the check for if a timer needs to be rescheduled up into
collect_signal where the preallocation check must be performed,
and pass the result back to dequeue_signal where the code reschedules
timers. This makes it clear why the code cares about preallocated
timers.
Reported-by: Thomas Gleixner <tglx@linutronix.de>
History Tree: https://git.kernel.org/pub/scm/linux/kernel/git/tglx/history.git
Reference: 66dd34ad31e5 ("signal: allow to send any siginfo to itself")
Reference: 1669ce53e2ff ("Add PTRACE_GETSIGINFO and PTRACE_SETSIGINFO")
Fixes: db8b50ba75f2 ("[PATCH] POSIX clocks & timers")
commit ff86bf0c65f14346bf2440534f9ba5ac232c39a0 upstream.
The alarmtimer code has another source of potentially rearming itself too
fast. Interval timers with a very samll interval have a similar CPU hog
effect as the previously fixed overflow issue.
The reason is that alarmtimers do not implement the normal protection
against this kind of problem which the other posix timer use:
timer expires -> queue signal -> deliver signal -> rearm timer
This scheme brings the rearming under scheduler control and prevents
permanently firing timers which hog the CPU.
Bringing this scheme to the alarm timer code is a major overhaul because it
lacks all the necessary mechanisms completely.
So for a quick fix limit the interval to one jiffie. This is not
problematic in practice as alarmtimers are usually backed by an RTC for
suspend which have 1 second resolution. It could be therefor argued that
the resolution of this clock should be set to 1 second in general, but
that's outside the scope of this fix.
Cc: Kostya Serebryany <kcc@google.com>
Cc: syzkaller <syzkaller@googlegroups.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Link: http://lkml.kernel.org/r/20170530211655.896767100@linutronix.de
commit f4781e76f90df7aec400635d73ea4c35ee1d4765 upstream.
Andrey reported a alartimer related RCU stall while fuzzing the kernel with
syzkaller.
The reason for this is an overflow in ktime_add() which brings the
resulting time into negative space and causes immediate expiry of the
timer. The following rearm with a small interval does not bring the timer
back into positive space due to the same issue.
This results in a permanent firing alarmtimer which hogs the CPU.
Use ktime_add_safe() instead which detects the overflow and clamps the
result to KTIME_SEC_MAX.
Reported-by: Andrey Konovalov <andreyknvl@google.com>
Link: http://lkml.kernel.org/r/20170530211655.802921648@linutronix.de
commit fa07ab72cbb0d843429e61bf179308aed6cbe0dd upstream.
In case __irq_set_trigger() fails the resources requested via
irq_request_resources() are not released.
Add the missing release call into the error handling path.
Fixes: c1bacbae8192 ("genirq: Provide irq_request/release_resources chip callbacks")
Signed-off-by: Heiner Kallweit <hkallweit1@gmail.com>
Link: http://lkml.kernel.org/r/655538f5-cb20-a892-ff15-fbd2dd1fa4ec@gmail.com
commit cc1582c231ea041fbc68861dfaf957eaf902b829 upstream.
When doing sampling, for example:
perf record -e cycles:u ...
On workloads that do a lot of kernel entry/exits we see kernel
samples, even though :u is specified. This is due to skid existing.
This might be a security issue because it can leak kernel addresses even
though kernel sampling support is disabled.
The patch drops the kernel samples if exclude_kernel is specified.
For example, test on Haswell desktop:
perf record -e cycles:u <mgen>
perf report --stdio
Before patch applied:
99.77% mgen mgen [.] buf_read
0.20% mgen mgen [.] rand_buf_init
0.01% mgen [kernel.vmlinux] [k] apic_timer_interrupt
0.00% mgen mgen [.] last_free_elem
0.00% mgen libc-2.23.so [.] __random_r
0.00% mgen libc-2.23.so [.] _int_malloc
0.00% mgen mgen [.] rand_array_init
0.00% mgen [kernel.vmlinux] [k] page_fault
0.00% mgen libc-2.23.so [.] __strcasestr
0.00% mgen ld-2.23.so [.] strcmp
0.00% mgen ld-2.23.so [.] _dl_start
0.00% mgen libc-2.23.so [.] sched_setaffinity@@GLIBC_2.3.4
0.00% mgen ld-2.23.so [.] _start
We can see kernel symbols apic_timer_interrupt and page_fault.
After patch applied:
99.79% mgen mgen [.] buf_read
0.19% mgen mgen [.] rand_buf_init
0.00% mgen libc-2.23.so [.] vfprintf
0.00% mgen libc-2.23.so [.] rand
0.00% mgen libc-2.23.so [.] _IO_doallocbuf
0.00% mgen ld-2.23.so [.] do_lookup_x
0.00% mgen ld-2.23.so [.] open_verify.constprop.7
0.00% mgen ld-2.23.so [.] _dl_important_hwcaps
There are only userspace symbols.
Signed-off-by: Jin Yao <yao.jin@linux.intel.com>
Cc: acme@kernel.org
Cc: jolsa@kernel.org
Cc: kan.liang@intel.com
Cc: mark.rutland@arm.com
Cc: will.deacon@arm.com
Cc: yao.jin@intel.com
Link: http://lkml.kernel.org/r/1495706947-3744-1-git-send-email-yao.jin@linux.intel.com
commit 41c25707d21716826e3c1f60967f5550610ec1c9 upstream.
In most cases, a cgroup controller don't care about the liftimes of
cgroups. For the controller, a css becomes online when ->css_online()
is called on it and offline when ->css_offline() is called.
However, cpuset is special in that the user interface it exposes cares
whether certain cgroups exist or not. Combined with the RCU delay
between cgroup removal and css offlining, this can lead to user
visible behavior oddities where operations which should succeed after
cgroup removals fail for some time period. The effects of cgroup
removals are delayed when seen from userland.
This patch adds css_is_dying() which tests whether offline is pending
and updates is_cpuset_online() so that the function returns false also
while offline is pending. This gets rid of the userland visible
delays.
Reported-by: Daniel Jordan <daniel.m.jordan@oracle.com>
Link: http://lkml.kernel.org/r/327ca1f5-7957-fbb9-9e5f-9ba149d40ba2@oracle.com
bits to 64 bits on 64-bit platforms
commit 5ea30e4e58040cfd6434c2f33dc3ea76e2c15b05 upstream.
The stack canary is an 'unsigned long' and should be fully initialized to
random data rather than only 32 bits of random data.
Signed-off-by: Daniel Micay <danielmicay@gmail.com>
Acked-by: Arjan van de Ven <arjan@linux.intel.com>
Cc: Arjan van Ven <arjan@linux.intel.com>
Cc: kernel-hardening@lists.openwall.com
Link: http://lkml.kernel.org/r/20170504133209.3053-1-danielmicay@gmail.com
commit c70d9d809fdeecedb96972457ee45c49a232d97f upstream.
When I introduced ptracer_cred I failed to consider the weirdness of
fork where the task_struct copies the old value by default. This
winds up leaving ptracer_cred set even when a process forks and
the child process does not wind up being ptraced.
Because ptracer_cred is not set on non-ptraced processes whose
parents were ptraced this has broken the ability of the enlightenment
window manager to start setuid children.
Fix this by properly initializing ptracer_cred in ptrace_init_task
This must be done with a little bit of care to preserve the current value
of ptracer_cred when ptrace carries through fork. Re-reading the
ptracer_cred from the ptracing process at this point is inconsistent
with how PT_PTRACE_CAP has been maintained all of these years.
Tested-by: Takashi Iwai <tiwai@suse.de>
Fixes: 64b875f7ac8a ("ptrace: Capture the ptracer's creds not PT_PTRACE_CAP")
commit 30e7d894c1478c88d50ce94ddcdbd7f9763d9cdd upstream.
Enabling the tracer selftest triggers occasionally the warning in
text_poke(), which warns when the to be modified page is not marked
reserved.
The reason is that the tracer selftest installs kprobes on functions marked
__init for testing. These probes are removed after the tests, but that
removal schedules the delayed kprobes_optimizer work, which will do the
actual text poke. If the work is executed after the init text is freed,
then the warning triggers. The bug can be reproduced reliably when the work
delay is increased.
Flush the optimizer work and wait for the optimizing/unoptimizing lists to
become empty before returning from the kprobes tracer selftest. That
ensures that all operations which were queued due to the probes removal
have completed.
Link: http://lkml.kernel.org/r/20170516094802.76a468bb@gandalf.local.home
Fixes: 6274de498 ("kprobes: Support delayed unoptimizing")
commit 2c4569ca26986d18243f282dd727da27e9adae4c upstream.
irq_set_chained_handler_and_data() sets up the chained interrupt and then
stores the handler data.
That's racy against an immediate interrupt which gets handled before the
store of the handler data happened. The handler will dereference a NULL
pointer and crash.
Cure it by storing handler data before installing the chained handler.
Reported-by: Borislav Petkov <bp@alien8.de>
commit 094f469172e00d6ab0a3130b0e01c83b3cf3a98d upstream.
Cgroup created inside throttled group must inherit current throttle_count.
Broken throttle_count allows to nominate throttled entries as a next buddy,
later this leads to null pointer dereference in pick_next_task_fair().
This patch initialize cfs_rq->throttle_count at first enqueue: laziness
allows to skip locking all rq at group creation. Lazy approach also allows
to skip full sub-tree scan at throttling hierarchy (not in this patch).
Cc: bsegall@google.com
Link: http://lkml.kernel.org/r/146608182119.21870.8439834428248129633.stgit@buzz
Cc: Ben Pineau <benjamin.pineau@mirakl.com>
commit 754bd598be9bbc953bc709a9e8ed7f3188bfb9d7 upstream.
Hierarchy could be already throttled at this point. Throttled next
buddy could trigger a NULL pointer dereference in pick_next_task_fair().
Reviewed-by: Ben Segall <bsegall@google.com>
Link: http://lkml.kernel.org/r/146608183552.21905.15924473394414832071.stgit@buzz
commit 3fd37226216620c1a468afa999739d5016fbc349 upstream.
Imagine we have a pid namespace and a task from its parent's pid_ns,
which made setns() to the pid namespace. The task is doing fork(),
while the pid namespace's child reaper is dying. We have the race
between them:
Task from parent pid_ns Child reaper
copy_process() ..
alloc_pid() ..
.. zap_pid_ns_processes()
.. disable_pid_allocation()
.. read_lock(&tasklist_lock)
.. iterate over pids in pid_ns
.. kill tasks linked to pids
.. read_unlock(&tasklist_lock)
write_lock_irq(&tasklist_lock); ..
attach_pid(p, PIDTYPE_PID); ..
So, just created task p won't receive SIGKILL signal,
and the pid namespace will be in contradictory state.
Only manual kill will help there, but does the userspace
care about this? I suppose, the most users just inject
a task into a pid namespace and wait a SIGCHLD from it.
The patch fixes the problem. It simply checks for
(pid_ns->nr_hashed & PIDNS_HASH_ADDING) in copy_process().
We do it under the tasklist_lock, and can't skip
PIDNS_HASH_ADDING as noted by Oleg:
"zap_pid_ns_processes() does disable_pid_allocation()
and then takes tasklist_lock to kill the whole namespace.
Given that copy_process() checks PIDNS_HASH_ADDING
under write_lock(tasklist) they can't race;
if copy_process() takes this lock first, the new child will
be killed, otherwise copy_process() can't miss
the change in ->nr_hashed."
If allocation is disabled, we just return -ENOMEM
like it's made for such cases in alloc_pid().
v2: Do not move disable_pid_allocation(), do not
introduce a new variable in copy_process() and simplify
the patch as suggested by Oleg Nesterov.
Account the problem with double irq enabling
found by Eric W. Biederman.
Fixes: c876ad768215 ("pidns: Stop pid allocation when init dies")
Signed-off-by: Kirill Tkhai <ktkhai@virtuozzo.com>
CC: Andrew Morton <akpm@linux-foundation.org>
CC: Ingo Molnar <mingo@kernel.org>
CC: Peter Zijlstra <peterz@infradead.org>
CC: Oleg Nesterov <oleg@redhat.com>
CC: Mike Rapoport <rppt@linux.vnet.ibm.com>
CC: Michal Hocko <mhocko@suse.com>
CC: Andy Lutomirski <luto@kernel.org>
CC: "Eric W. Biederman" <ebiederm@xmission.com>
CC: Andrei Vagin <avagin@openvz.org>
CC: Cyrill Gorcunov <gorcunov@openvz.org>
CC: Serge Hallyn <serge@hallyn.com>
Acked-by: Oleg Nesterov <oleg@redhat.com>
commit b9a985db98961ae1ba0be169f19df1c567e4ffe0 upstream.
The code can potentially sleep for an indefinite amount of time in
zap_pid_ns_processes triggering the hung task timeout, and increasing
the system average. This is undesirable. Sleep with a task state of
TASK_INTERRUPTIBLE instead of TASK_UNINTERRUPTIBLE to remove these
undesirable side effects.
Apparently under heavy load this has been allowing Chrome to trigger
the hung time task timeout error and cause ChromeOS to reboot.
Reported-by: Vovo Yang <vovoy@google.com>
Reported-by: Guenter Roeck <linux@roeck-us.net>
Tested-by: Guenter Roeck <linux@roeck-us.net>
Fixes: 6347e9009104 ("pidns: guarantee that the pidns init will be the last pidns process reaped")
commit 07a77929ba672d93642a56dc2255dd21e6e2290b upstream.
The author meant to free the variable that was just allocated, instead
of the one that failed to be allocated, but made a simple typo. This
patch rectifies that.
Signed-off-by: Jason A. Donenfeld <Jason@zx2c4.com>
commit 321027c1fe77f892f4ea07846aeae08cefbbb290 upstream.
Di Shen reported a race between two concurrent sys_perf_event_open()
calls where both try and move the same pre-existing software group
into a hardware context.
The problem is exactly that described in commit:
f63a8daa5812 ("perf: Fix event->ctx locking")
... where, while we wait for a ctx->mutex acquisition, the event->ctx
relation can have changed under us.
That very same commit failed to recognise sys_perf_event_context() as an
external access vector to the events and thereby didn't apply the
established locking rules correctly.
So while one sys_perf_event_open() call is stuck waiting on
mutex_lock_double(), the other (which owns said locks) moves the group
about. So by the time the former sys_perf_event_open() acquires the
locks, the context we've acquired is stale (and possibly dead).
Apply the established locking rules as per perf_event_ctx_lock_nested()
to the mutex_lock_double() for the 'move_group' case. This obviously means
we need to validate state after we acquire the locks.
Reported-by: Di Shen (Keen Lab)
Tested-by: John Dias <joaodias@google.com>
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Cc: Min Chong <mchong@google.com>
Fixes: f63a8daa5812 ("perf: Fix event->ctx locking")
Link: http://lkml.kernel.org/r/20170106131444.GZ3174@twins.programming.kicks-ass.net
[bwh: Backported to 4.4:
- Test perf_event::group_flags instead of group_caps
- Adjust context]
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit d29216842a85c7970c536108e093963f02714498 upstream.
CAI Qian <caiqian@redhat.com> pointed out that the semantics
of shared subtrees make it possible to create an exponentially
increasing number of mounts in a mount namespace.
mkdir /tmp/1 /tmp/2
mount --make-rshared /
for i in $(seq 1 20) ; do mount --bind /tmp/1 /tmp/2 ; done
Will create create 2^20 or 1048576 mounts, which is a practical problem
as some people have managed to hit this by accident.
As such CVE-2016-6213 was assigned.
Ian Kent <raven@themaw.net> described the situation for autofs users
as follows:
> The number of mounts for direct mount maps is usually not very large because of
> the way they are implemented, large direct mount maps can have performance
> problems. There can be anywhere from a few (likely case a few hundred) to less
> than 10000, plus mounts that have been triggered and not yet expired.
> Indirect mounts have one autofs mount at the root plus the number of mounts that
> The number of autofs indirect map entries can range from a few to the common
> case of several thousand and in rare cases up to between 30000 and 50000. I've
> not heard of people with maps larger than 50000 entries.
> The larger the number of map entries the greater the possibility for a large
> number of active mounts so it's not hard to expect cases of a 1000 or somewhat
> more active mounts.
So I am setting the default number of mounts allowed per mount
namespace at 100,000. This is more than enough for any use case I
know of, but small enough to quickly stop an exponential increase
in mounts. Which should be perfect to catch misconfigurations and
malfunctioning programs.
For anyone who needs a higher limit this can be changed by writing
to the new /proc/sys/fs/mount-max sysctl.
Tested-by: CAI Qian <caiqian@redhat.com>
[bwh: Backported to 4.4: adjust context]
commit 78f7a45dac2a2d2002f98a3a95f7979867868d73 upstream.
I noticed that reading the snapshot file when it is empty no longer gives a
status. It suppose to show the status of the snapshot buffer as well as how
to allocate and use it. For example:
># cat snapshot
# tracer: nop
# * Snapshot is allocated *
# Snapshot commands:
# echo 0 > snapshot : Clears and frees snapshot buffer
# echo 1 > snapshot : Allocates snapshot buffer, if not already allocated.
# Takes a snapshot of the main buffer.
# echo 2 > snapshot : Clears snapshot buffer (but does not allocate or free)
# (Doesn't have to be '2' works with any number that
# is not a '0' or '1')
But instead it just showed an empty buffer:
># cat snapshot
# tracer: nop
# entries-in-buffer/entries-written: 0/0 #P:4
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
What happened was that it was using the ring_buffer_iter_empty() function to
see if it was empty, and if it was, it showed the status. But that function
was returning false when it was empty. The reason was that the iter header
page was on the reader page, and the reader page was empty, but so was the
buffer itself. The check only tested to see if the iter was on the commit
page, but the commit page was no longer pointing to the reader page, but as
all pages were empty, the buffer is also.
Fixes: 651e22f2701b ("ring-buffer: Always reset iterator to reader page")
commit df62db5be2e5f070ecd1a5ece5945b590ee112e0 upstream.
Currently the snapshot trigger enables the probe and then allocates the
snapshot. If the probe triggers before the allocation, it could cause the
snapshot to fail and turn tracing off. It's best to allocate the snapshot
buffer first, and then enable the trigger. If something goes wrong in the
enabling of the trigger, the snapshot buffer is still allocated, but it can
also be freed by the user by writting zero into the snapshot buffer file.
Also add a check of the return status of alloc_snapshot().
Fixes: 77fd5c15e3 ("tracing: Add snapshot trigger to function probes")
commit 82cc4fc2e70ec5baeff8f776f2773abc8b2cc0ae upstream.
When two function probes are added to set_ftrace_filter, and then one of
them is removed, the update to the function locations is not performed, and
the record keeping of the function states are corrupted, and causes an
ftrace_bug() to occur.
This is easily reproducable by adding two probes, removing one, and then
adding it back again.
# cd /sys/kernel/debug/tracing
# echo schedule:traceoff > set_ftrace_filter
# echo do_IRQ:traceoff > set_ftrace_filter
# echo \!do_IRQ:traceoff > /debug/tracing/set_ftrace_filter
Causes:
WARNING: CPU: 2 PID: 1098 at kernel/trace/ftrace.c:2369 ftrace_get_addr_curr+0x143/0x220
Modules linked in: [...]
CPU: 2 PID: 1098 Comm: bash Not tainted 4.10.0-test+ #405
Hardware name: Hewlett-Packard HP Compaq Pro 6300 SFF/339A, BIOS K01 v02.05 05/07/2012
Call Trace:
dump_stack+0x68/0x9f
__warn+0x111/0x130
? trace_irq_work_interrupt+0xa0/0xa0
warn_slowpath_null+0x1d/0x20
? __fentry__+0x10/0x10
ftrace_replace_code+0xe3/0x4f0
? ftrace_int3_handler+0x90/0x90
? printk+0x99/0xb5
? 0xffffffff81000000
ftrace_modify_all_code+0x97/0x110
arch_ftrace_update_code+0x10/0x20
ftrace_run_update_code+0x1c/0x60
ftrace_run_modify_code.isra.48.constprop.62+0x8e/0xd0
register_ftrace_function_probe+0x4b6/0x590
? ftrace_startup+0x310/0x310
? debug_lockdep_rcu_enabled.part.4+0x1a/0x30
? update_stack_state+0x88/0x110
? ftrace_regex_write.isra.43.part.44+0x1d3/0x320
? preempt_count_sub+0x18/0xd0
? mutex_lock_nested+0x104/0x800
? __unwind_start+0x1c0/0x1c0
? _mutex_lock_nest_lock+0x800/0x800
ftrace_trace_probe_callback.isra.3+0xc0/0x130
? func_set_flag+0xe0/0xe0
? __lock_acquire+0x642/0x1790
? __might_fault+0x1e/0x20
? trace_get_user+0x398/0x470
? strcmp+0x35/0x60
ftrace_trace_onoff_callback+0x48/0x70
ftrace_regex_write.isra.43.part.44+0x251/0x320
? match_records+0x420/0x420
ftrace_filter_write+0x2b/0x30
__vfs_write+0xd7/0x330
? do_loop_readv_writev+0x120/0x120
? locks_remove_posix+0x90/0x2f0
? do_lock_file_wait+0x160/0x160
? __lock_is_held+0x93/0x100
? rcu_read_lock_sched_held+0x5c/0xb0
? __sb_start_write+0x10a/0x230
? vfs_write+0x222/0x240
vfs_write+0xef/0x240
SyS_write+0xab/0x130
? SyS_read+0x130/0x130
? trace_hardirqs_on_caller+0x182/0x280
? trace_hardirqs_on_thunk+0x1a/0x1c
entry_SYSCALL_64_fastpath+0x18/0xad
RIP: 0033:0x7fe61c157c30
RSP: 002b:00007ffe87890258 EFLAGS: 00000246 ORIG_RAX: 0000000000000001
RAX: ffffffffffffffda RBX: ffffffff8114a410 RCX: 00007fe61c157c30
RDX: 0000000000000010 RSI: 000055814798f5e0 RDI: 0000000000000001
RBP: ffff8800c9027f98 R08: 00007fe61c422740 R09: 00007fe61ca53700
R10: 0000000000000073 R11: 0000000000000246 R12: 0000558147a36400
R13: 00007ffe8788f160 R14: 0000000000000024 R15: 00007ffe8788f15c
? trace_hardirqs_off_caller+0xc0/0x110
---[ end trace 99fa09b3d9869c2c ]---
Bad trampoline accounting at: ffffffff81cc3b00 (do_IRQ+0x0/0x150)
Fixes: 59df055f1991 ("ftrace: trace different functions with a different tracer")
non-root cgroups
commit 77f88796cee819b9c4562b0b6b44691b3b7755b1 upstream.
Creation of a kthread goes through a couple interlocked stages between
the kthread itself and its creator. Once the new kthread starts
running, it initializes itself and wakes up the creator. The creator
then can further configure the kthread and then let it start doing its
job by waking it up.
In this configuration-by-creator stage, the creator is the only one
that can wake it up but the kthread is visible to userland. When
altering the kthread's attributes from userland is allowed, this is
fine; however, for cases where CPU affinity is critical,
kthread_bind() is used to first disable affinity changes from userland
and then set the affinity. This also prevents the kthread from being
migrated into non-root cgroups as that can affect the CPU affinity and
many other things.
Unfortunately, the cgroup side of protection is racy. While the
PF_NO_SETAFFINITY flag prevents further migrations, userland can win
the race before the creator sets the flag with kthread_bind() and put
the kthread in a non-root cgroup, which can lead to all sorts of
problems including incorrect CPU affinity and starvation.
This bug got triggered by userland which periodically tries to migrate
all processes in the root cpuset cgroup to a non-root one. Per-cpu
workqueue workers got caught while being created and ended up with
incorrected CPU affinity breaking concurrency management and sometimes
stalling workqueue execution.
This patch adds task->no_cgroup_migration which disallows the task to
be migrated by userland. kthreadd starts with the flag set making
every child kthread start in the root cgroup with migration
disallowed. The flag is cleared after the kthread finishes
initialization by which time PF_NO_SETAFFINITY is set if the kthread
should stay in the root cgroup.
It'd be better to wait for the initialization instead of failing but I
couldn't think of a way of implementing that without adding either a
new PF flag, or sleeping and retrying from waiting side. Even if
userland depends on changing cgroup membership of a kthread, it either
has to be synchronized with kthread_create() or periodically repeat,
so it's unlikely that this would break anything.
v2: Switch to a simpler implementation using a new task_struct bit
field suggested by Oleg.
Suggested-by: Oleg Nesterov <oleg@redhat.com>
Cc: Peter Zijlstra (Intel) <peterz@infradead.org>
Reported-and-debugged-by: Chris Mason <clm@fb.com>
commit 62277de758b155dc04b78f195a1cb5208c37b2df upstream.
In case of error, the function kthread_run() returns ERR_PTR()
and never returns NULL. The NULL test in the return value check
should be replaced with IS_ERR().
Link: http://lkml.kernel.org/r/1466184839-14927-1-git-send-email-weiyj_lk@163.com
Fixes: 6c43e554a ("ring-buffer: Add ring buffer startup selftest")
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
commit 5402e97af667e35e54177af8f6575518bf251d51 upstream.
In PT_SEIZED + LISTEN mode STOP/CONT signals cause a wakeup against
__TASK_TRACED. If this races with the ptrace_unfreeze_traced at the end
of a PTRACE_LISTEN, this can wake the task /after/ the check against
__TASK_TRACED, but before the reset of state to TASK_TRACED. This
causes it to instead clobber TASK_WAKING, allowing a subsequent wakeup
against TRACED while the task is still on the rq wake_list, corrupting
it.
Oleg said:
"The kernel can crash or this can lead to other hard-to-debug problems.
In short, "task->state = TASK_TRACED" in ptrace_unfreeze_traced()
assumes that nobody else can wake it up, but PTRACE_LISTEN breaks the
contract. Obviusly it is very wrong to manipulate task->state if this
task is already running, or WAKING, or it sleeps again"
Fixes: 9899d11f ("ptrace: ensure arch_ptrace/ptrace_request can never race with SIGKILL")
Link: http://lkml.kernel.org/r/xm26y3vfhmkp.fsf_-_@bsegall-linux.mtv.corp.google.com
Signed-off-by: Ben Segall <bsegall@google.com>
commit de5540d088fe97ad583cc7d396586437b32149a5 upstream.
Under extremely heavy uses of padata, crashes occur, and with list
debugging turned on, this happens instead:
[87487.298728] WARNING: CPU: 1 PID: 882 at lib/list_debug.c:33
__list_add+0xae/0x130
[87487.301868] list_add corruption. prev->next should be next
(ffffb17abfc043d0), but was ffff8dba70872c80. (prev=ffff8dba70872b00).
[87487.339011] [<ffffffff9a53d075>] dump_stack+0x68/0xa3
[87487.342198] [<ffffffff99e119a1>] ? console_unlock+0x281/0x6d0
[87487.345364] [<ffffffff99d6b91f>] __warn+0xff/0x140
[87487.348513] [<ffffffff99d6b9aa>] warn_slowpath_fmt+0x4a/0x50
[87487.351659] [<ffffffff9a58b5de>] __list_add+0xae/0x130
[87487.354772] [<ffffffff9add5094>] ? _raw_spin_lock+0x64/0x70
[87487.357915] [<ffffffff99eefd66>] padata_reorder+0x1e6/0x420
[87487.361084] [<ffffffff99ef0055>] padata_do_serial+0xa5/0x120
padata_reorder calls list_add_tail with the list to which its adding
locked, which seems correct:
spin_lock(&squeue->serial.lock);
list_add_tail(&padata->list, &squeue->serial.list);
spin_unlock(&squeue->serial.lock);
This therefore leaves only place where such inconsistency could occur:
if padata->list is added at the same time on two different threads.
This pdata pointer comes from the function call to
padata_get_next(pd), which has in it the following block:
next_queue = per_cpu_ptr(pd->pqueue, cpu);
padata = NULL;
reorder = &next_queue->reorder;
if (!list_empty(&reorder->list)) {
padata = list_entry(reorder->list.next,
struct padata_priv, list);
spin_lock(&reorder->lock);
list_del_init(&padata->list);
atomic_dec(&pd->reorder_objects);
spin_unlock(&reorder->lock);
pd->processed++;
goto out;
out:
return padata;
I strongly suspect that the problem here is that two threads can race
on reorder list. Even though the deletion is locked, call to
list_entry is not locked, which means it's feasible that two threads
pick up the same padata object and subsequently call list_add_tail on
them at the same time. The fix is thus be hoist that lock outside of
that block.
Acked-by: Steffen Klassert <steffen.klassert@secunet.com>
commit 619bd4a71874a8fd78eb6ccf9f272c5e98bcc7b7 upstream.
Since the change in commit:
fd7a4bed1835 ("sched, rt: Convert switched_{from, to}_rt() / prio_changed_rt() to balance callbacks")
... we don't reschedule a task under certain circumstances:
Lets say task-A, SCHED_OTHER, is running on CPU0 (and it may run only on
CPU0) and holds a PI lock. This task is removed from the CPU because it
used up its time slice and another SCHED_OTHER task is running. Task-B on
CPU1 runs at RT priority and asks for the lock owned by task-A. This
results in a priority boost for task-A. Task-B goes to sleep until the
lock has been made available. Task-A is already runnable (but not active),
so it receives no wake up.
The reality now is that task-A gets on the CPU once the scheduler decides
to remove the current task despite the fact that a high priority task is
enqueued and waiting. This may take a long time.
The desired behaviour is that CPU0 immediately reschedules after the
priority boost which made task-A the task with the lowest priority.
Suggested-by: Peter Zijlstra <peterz@infradead.org>
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Fixes: fd7a4bed1835 ("sched, rt: Convert switched_{from, to}_rt() prio_changed_rt() to balance callbacks")
Link: http://lkml.kernel.org/r/20170124144006.29821-1-bigeasy@linutronix.de
commit e7cc4865f0f31698ef2f7aac01a50e78968985b7 upstream.
While hunting for clues to a use-after-free, Oleg spotted that
perf_event_init_context() can loose an error value with the result
that fork() can succeed even though we did not fully inherit the perf
event context.
Spotted-by: Oleg Nesterov <oleg@redhat.com>
Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Cc: oleg@redhat.com
Fixes: 889ff0150661 ("perf/core: Split context's event group list into pinned and non-pinned lists")
Link: http://lkml.kernel.org/r/20170316125823.190342547@infradead.org
commit 725fc629ff2545b061407305ae51016c9f928fce upstream.
Linux preallocates the task structs of the idle tasks for all possible
CPUs. This currently means they all end up on node 0. This also
implies that the cache line of MWAIT, which is around the flags field in
the task struct, are all located in node 0.
We see a noticeable performance improvement on Knights Landing CPUs when
the cache lines used for MWAIT are located in the local nodes of the
CPUs using them. I would expect this to give a (likely slight)
improvement on other systems too.
The patch implements placing the idle task in the node of its CPUs, by
passing the right target node to copy_process()
[akpm@linux-foundation.org: use NUMA_NO_NODE, not a bare -1]
Link: http://lkml.kernel.org/r/1463492694-15833-1-git-send-email-andi@firstfloor.org
commit 9bbb25afeb182502ca4f2c4f3f88af0681b34cae upstream.
Thomas spotted that fixup_pi_state_owner() can return errors and we
fail to unlock the rt_mutex in that case.
Reviewed-by: Darren Hart <dvhart@linux.intel.com>
Cc: juri.lelli@arm.com
Cc: bigeasy@linutronix.de
Cc: xlpang@redhat.com
Cc: rostedt@goodmis.org
Cc: mathieu.desnoyers@efficios.com
Cc: jdesfossez@efficios.com
Cc: dvhart@infradead.org
Cc: bristot@redhat.com
Link: http://lkml.kernel.org/r/20170304093558.867401760@infradead.org
commit c236c8e95a3d395b0494e7108f0d41cf36ec107c upstream.
While working on the futex code, I stumbled over this potential
use-after-free scenario. Dmitry triggered it later with syzkaller.
pi_mutex is a pointer into pi_state, which we drop the reference on in
unqueue_me_pi(). So any access to that pointer after that is bad.
Since other sites already do rt_mutex_unlock() with hb->lock held, see
for example futex_lock_pi(), simply move the unlock before
unqueue_me_pi().
Link: http://lkml.kernel.org/r/20170304093558.801744246@infradead.org
commit 907565337ebf998a68cb5c5b2174ce5e5da065eb upstream.
Userspace applications should be allowed to expect the membarrier system
call with MEMBARRIER_CMD_SHARED command to issue memory barriers on
nohz_full CPUs, but synchronize_sched() does not take those into
account.
Given that we do not want unrelated processes to be able to affect
real-time sensitive nohz_full CPUs, simply return ENOSYS when membarrier
is invoked on a kernel with enabled nohz_full CPUs.
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
CC: Josh Triplett <josh@joshtriplett.org>
CC: Steven Rostedt <rostedt@goodmis.org>
Cc: Chris Metcalf <cmetcalf@mellanox.com>
Acked-by: Lai Jiangshan <jiangshanlai@gmail.com>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
commit fc98c3c8c9dcafd67adcce69e6ce3191d5306c9c upstream.
Use rcuidle console tracepoint because, apparently, it may be issued
from an idle CPU:
hw-breakpoint: Failed to enable monitor mode on CPU 0.
hw-breakpoint: CPU 0 failed to disable vector catch
[ ERR: suspicious RCU usage. ]
4.10.0-rc8-next-20170215+ #119 Not tainted
./include/trace/events/printk.h:32 suspicious rcu_dereference_check() usage!
RCU used illegally from idle CPU!
rcu_scheduler_active = 2, debug_locks = 0
RCU used illegally from extended quiescent state!
2 locks held by swapper/0/0:
#0: (cpu_pm_notifier_lock){......}, at: [<c0237e2c>] cpu_pm_exit+0x10/0x54
#1: (console_lock){+.+.+.}, at: [<c01ab350>] vprintk_emit+0x264/0x474
stack backtrace:
CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.10.0-rc8-next-20170215+ #119
Hardware name: Generic OMAP4 (Flattened Device Tree)
console_unlock
vprintk_emit
vprintk_default
printk
reset_ctrl_regs
dbg_cpu_pm_notify
notifier_call_chain
cpu_pm_exit
omap_enter_idle_coupled
cpuidle_enter_state
cpuidle_enter_state_coupled
do_idle
cpu_startup_entry
start_kernel
This RCU warning, however, is suppressed by lockdep_off() in printk().
lockdep_off() increments the ->lockdep_recursion counter and thus
disables RCU_LOCKDEP_WARN() and debug_lockdep_rcu_enabled(), which want
lockdep to be enabled "current->lockdep_recursion == 0".
Link: http://lkml.kernel.org/r/20170217015932.11898-1-sergey.senozhatsky@gmail.com
Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Reported-by: Tony Lindgren <tony@atomide.com>
Tested-by: Tony Lindgren <tony@atomide.com>
Acked-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
Cc: Petr Mladek <pmladek@suse.com>
Cc: Tony Lindgren <tony@atomide.com>
Cc: Russell King <rmk@armlinux.org.uk>
