path: root/kernel
2010-05-30Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: mutex: Fix optimistic spinning vs. BKL
2010-05-30Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf tui: Fix last use_browser problem related to .perfconfig perf symbols: Add the build id cache to the vmlinux path perf tui: Reset use_browser if stdout is not a tty ring-buffer: Move zeroing out excess in page to ring buffer code ring-buffer: Reset "real_end" when page is filled
2010-05-30CPU: Avoid using unititialized error variable in disable_nonboot_cpus()Rafael J. Wysocki
If there's only one CPU online when disable_nonboot_cpus() is called, the error variable will not be initialized and that may lead to erroneous behavior. Fix this issue by initializing error in disable_nonboot_cpus() as appropriate. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-30Revert "cpusets: randomize node rotor used in cpuset_mem_spread_node()"Linus Torvalds
This reverts commit 0ac0c0d0f837c499afd02a802f9cf52d3027fa3b, which caused cross-architecture build problems for all the wrong reasons. IA64 already added its own version of __node_random(), but the fact is, there is nothing architectural about the function, and the original commit was just badly done. Revert it, since no fix is forthcoming. Requested-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: ceph: clean up on forwarded aborted mds request ceph: fix leak of osd authorizer ceph: close out mds, osd connections before stopping auth ceph: make lease code DN specific fs/ceph: Use ERR_CAST ceph: renew auth tickets before they expire ceph: do not resend mon requests on auth ticket renewal ceph: removed duplicated #includes ceph: avoid possible null dereference ceph: make mds requests killable, not interruptible sched: add wait_for_completion_killable_timeout
2010-05-29sched: add wait_for_completion_killable_timeoutSage Weil
Add missing _killable_timeout variant for wait_for_completion that will return when a timeout expires or the task is killed. CC: Ingo Molnar <mingo@elte.hu> CC: Andreas Herrmann <andreas.herrmann3@amd.com> CC: Thomas Gleixner <tglx@linutronix.de> CC: Mike Galbraith <efault@gmx.de> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-28Merge branch 'timers-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: posix_timer: Fix error path in timer_create hrtimer: Avoid double seqlock timers: Move local variable into else section timers: Fix slack calculation really
2010-05-27Fix racy use of anon_inode_getfd() in perf_event.cAl Viro
once anon_inode_getfd() is called, you can't expect *anything* about struct file that descriptor points to - another thread might be doing whatever it likes with descriptor table at that point. Cc: stable <stable@kernel.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (61 commits) tracing: Add __used annotation to event variable perf, trace: Fix !x86 build bug perf report: Support multiple events on the TUI perf annotate: Fix up usage of the build id cache x86/mmiotrace: Remove redundant instruction prefix checks perf annotate: Add TUI interface perf tui: Remove annotate from popup menu after failure perf report: Don't start the TUI if -D is used perf: Fix getline undeclared perf: Optimize perf_tp_event_match() perf: Remove more code from the fastpath perf: Optimize the !vmalloc backed buffer perf: Optimize perf_output_copy() perf: Fix wakeup storm for RO mmap()s perf-record: Share per-cpu buffers perf-record: Remove -M perf: Ensure that IOC_OUTPUT isn't used to create multi-writer buffers perf, trace: Optimize tracepoints by using per-tracepoint-per-cpu hlist to track events perf, trace: Optimize tracepoints by removing IRQ-disable from perf/tracepoint interaction perf tui: Allow disabling the TUI on a per command basis in ~/.perfconfig ...
2010-05-27posix_timer: Fix error path in timer_createAndrey Vagin
Move CLOCK_DISPATCH(which_clock, timer_create, (new_timer)) after all posible EFAULT erros. *_timer_create may allocate/get resources. (for example posix_cpu_timer_create does get_task_struct) [ tglx: fold the remove crappy comment patch into this ] Signed-off-by: Andrey Vagin <avagin@openvz.org> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: <stable@kernel.org> Reviewed-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-05-27Avoid warning when CPU hotplug isn't enabledLinus Torvalds
Commit e9fb7631ebcd ("cpu-hotplug: introduce cpu_notify(), __cpu_notify(), cpu_notify_nofail()") also introduced this annoying warning: kernel/cpu.c:157: warning: 'cpu_notify_nofail' defined but not used when CONFIG_HOTPLUG_CPU wasn't set. So move that helper inside the #ifdef CONFIG_HOTPLUG_CPU region, and simplify it while at it. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27numa: in-kernel profiling: use cpu_to_mem() for per cpu allocationsLee Schermerhorn
In kernel profiling requires that we be able to allocate "local" memory for each cpu. Use "cpu_to_mem()" instead of "cpu_to_node()" to support memoryless nodes. Depends on the "numa_mem_id()" patch. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Tejun Heo <tj@kernel.org> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Nick Piggin <npiggin@suse.de> Cc: David Rientjes <rientjes@google.com> Cc: Eric Whitney <eric.whitney@hp.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27panic: call console_verbose() in panicAnton Blanchard
Most distros turn the console verbosity down and that means a backtrace after a panic never makes it to the console. I assume we haven't seen this because a panic is often preceeded by an oops which will have called console_verbose. There are however a lot of places we call panic directly, and they are broken. Use console_verbose like we do in the oops path to ensure a directly called panic will print a backtrace. Signed-off-by: Anton Blanchard <anton@samba.org> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27pids: fix fork_idle() to setup ->pids correctlyOleg Nesterov
copy_process(pid => &init_struct_pid) doesn't do attach_pid/etc. It shouldn't, but this means that the idle threads run with the wrong pids copied from the caller's task_struct. In x86 case the caller is either kernel_init() thread or keventd. In particular, this means that after the series of cpu_up/cpu_down an idle thread (which never exits) can run with .pid pointing to nowhere. Change fork_idle() to initialize idle->pids[] correctly. We only set .pid = &init_struct_pid but do not add .node to list, INIT_TASK() does the same for the boot-cpu idle thread (swapper). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Eric Biederman <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Mathias Krause <Mathias.Krause@secunet.com> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27pids: increase pid_max based on num_possible_cpusHedi Berriche
On a system with a substantial number of processors, the early default pid_max of 32k will not be enough. A system with 1664 CPU's, there are 25163 processes started before the login prompt. It's estimated that with 2048 CPU's we will pass the 32k limit. With 4096, we'll reach that limit very early during the boot cycle, and processes would stall waiting for an available pid. This patch increases the early maximum number of pids available, and increases the minimum number of pids that can be set during runtime. [akpm@linux-foundation.org: fix warnings] Signed-off-by: Hedi Berriche <hedi@sgi.com> Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Robin Holt <holt@sgi.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Pavel Machek <pavel@ucw.cz> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Greg KH <gregkh@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: John Stoffel <john@stoffel.org> Cc: Jack Steiner <steiner@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27cpuhotplug: do not need cpu_hotplug_begin() when CONFIG_HOTPLUG_CPU=nLai Jiangshan
Since when CONFIG_HOTPLUG_CPU=n, get_online_cpus() do nothing, so we don't need cpu_hotplug_begin() either. This patch moves cpu_hotplug_begin()/cpu_hotplug_done() into the code block of CONFIG_HOTPLUG_CPU=y. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Gautham R Shenoy <ego@in.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27kernel/: convert cpu notifier to return encapsulate errno valueAkinobu Mita
By the previous modification, the cpu notifier can return encapsulate errno value. This converts the cpu notifiers for kernel/*.c Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27cpu-hotplug: return better errno on cpu hotplug failureAkinobu Mita
Currently, onlining or offlining a CPU failure by one of the cpu notifiers error always cause -EINVAL error. (i.e. writing 0 or 1 to /sys/devices/system/cpu/cpuX/online gets EINVAL) To get better error reporting rather than always getting -EINVAL, This changes cpu_notify() to return -errno value with notifier_to_errno() and fix the callers. Now that cpu notifiers can return encapsulate errno value. Currently, all cpu hotplug notifiers return NOTIFY_OK, NOTIFY_BAD, or NOTIFY_DONE. So cpu_notify() can returns 0 or -EPERM with this change for now. (notifier_to_errno(NOTIFY_OK) == 0, notifier_to_errno(NOTIFY_DONE) == 0, notifier_to_errno(NOTIFY_BAD) == -EPERM) Forthcoming patches convert several cpu notifiers to return encapsulate errno value with notifier_from_errno(). Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27cpu-hotplug: introduce cpu_notify(), __cpu_notify(), cpu_notify_nofail()Akinobu Mita
No functional change. These are just wrappers of raw_cpu_notifier_call_chain. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27proc: turn signal_struct->count into "int nr_threads"Oleg Nesterov
No functional changes, just s/atomic_t count/int nr_threads/. With the recent changes this counter has a single user, get_nr_threads() And, none of its callers need the really accurate number of threads, not to mention each caller obviously races with fork/exit. It is only used to report this value to the user-space, except first_tid() uses it to avoid the unnecessary while_each_thread() loop in the unlikely case. It is a bit sad we need a word in struct signal_struct for this, perhaps we can change get_nr_threads() to approximate the number of threads using signal->live and kill ->nr_threads later. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27proc_sched_show_task(): use get_nr_threads()Oleg Nesterov
Trivial, use get_nr_threads() helper to read signal->count which we are going to change. Like other callers, proc_sched_show_task() doesn't need the exactly precise nr_threads. David said: : Note that get_nr_threads() isn't completely equivalent (it can return 0 : where proc_sched_show_task() will display a 1). But I don't think this : should be a problem. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Acked-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27check_unshare_flags: kill the bogus CLONE_SIGHAND/sig->count checkOleg Nesterov
check_unshare_flags(CLONE_SIGHAND) adds CLONE_THREAD to *flags_ptr if the task is multithreaded to ensure unshare_thread() will fail. Not only this is a bit strange way to return the error, this is absolutely meaningless. If signal->count > 1 then sighand->count must be also > 1, and unshare_sighand() will fail anyway. In fact, all CLONE_THREAD/SIGHAND/VM checks inside sys_unshare() do not look right. Fortunately this code doesn't really work anyway. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: Roland McGrath <roland@redhat.com> Cc: Veaceslav Falico <vfalico@redhat.com> Cc: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27exit: move taskstats_tgid_free() from __exit_signal() to free_signal_struct()Oleg Nesterov
Move taskstats_tgid_free() from __exit_signal() to free_signal_struct(). This way signal->stats never points to nowhere and we can read ->stats lockless. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Roland McGrath <roland@redhat.com> Cc: Veaceslav Falico <vfalico@redhat.com> Cc: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27kill the obsolete thread_group_cputime_free() helperOleg Nesterov
Kill the empty thread_group_cputime_free() helper. It was needed to free the per-cpu data which we no longer have. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Roland McGrath <roland@redhat.com> Cc: Veaceslav Falico <vfalico@redhat.com> Cc: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27exit: __exit_signal: use thread_group_leader() consistentlyOleg Nesterov
Cleanup: - Add the boolean, group_dead = thread_group_leader(), for clarity. - Do not test/set sig == NULL to detect the all-dead case, use this boolean. - Pass this boolen to __unhash_process() and use it instead of another thread_group_leader() call which needs ->group_leader. This can be considered as microoptimization, but hopefully this also allows us do do other cleanups later. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Roland McGrath <roland@redhat.com> Cc: Veaceslav Falico <vfalico@redhat.com> Cc: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27signals: kill the awful task_rq_unlock_wait() hackOleg Nesterov
Now that task->signal can't go away we can revert the horrible hack added by ad474caca3e2a0550b7ce0706527ad5ab389a4d4 ("fix for account_group_exec_runtime(), make sure ->signal can't be freed under rq->lock"). And we can do more cleanups sched_stats.h/posix-cpu-timers.c later. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Alan Cox <alan@linux.intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Acked-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27signals: clear signal->tty when the last thread exitsOleg Nesterov
When the last thread exits signal->tty is freed, but the pointer is not cleared and points to nowhere. This is OK. Nobody should use signal->tty lockless, and it is no longer possible to take ->siglock. However this looks wrong even if correct, and the nice OOPS is better than subtle and hard to find bugs. Change __exit_signal() to clear signal->tty under ->siglock. Note: __exit_signal() needs more cleanups. It should not check "sig != NULL" to detect the all-dead case and we have the same issues with signal->stats. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Alan Cox <alan@linux.intel.com> Cc: Ingo Molnar <mingo@elte.hu> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27signals: make task_struct->signal immutable/refcountableOleg Nesterov
We have a lot of problems with accessing task_struct->signal, it can "disappear" at any moment. Even current can't use its ->signal safely after exit_notify(). ->siglock helps, but it is not convenient, not always possible, and sometimes it makes sense to use task->signal even after this task has already dead. This patch adds the reference counter, sigcnt, into signal_struct. This reference is owned by task_struct and it is dropped in __put_task_struct(). Perhaps it makes sense to export get/put_signal_struct() later, but currently I don't see the immediate reason. Rename __cleanup_signal() to free_signal_struct() and unexport it. With the previous changes it does nothing except kmem_cache_free(). Change __exit_signal() to not clear/free ->signal, it will be freed when the last reference to any thread in the thread group goes away. Note: - when the last thead exits signal->tty can point to nowhere, see the next patch. - with or without this patch signal_struct->count should go away, or at least it should be "int nr_threads" for fs/proc. This will be addressed later. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Alan Cox <alan@linux.intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Acked-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27fork/exit: move tty_kref_put() outside of __cleanup_signal()Oleg Nesterov
tty_kref_put() has two callsites in copy_process() paths, 1. if copy_process() suceeds it is called before we copy signal->tty from parent 2. otherwise it is called from __cleanup_signal() under bad_fork_cleanup_signal: label In both cases tty_kref_put() is not right and unneeded because we don't have the balancing tty_kref_get(). Fortunately, this is harmless because this can only happen without CLONE_THREAD, and in this case signal->tty must be NULL. Remove tty_kref_put() from copy_process() and __cleanup_signal(), and change another caller of __cleanup_signal(), __exit_signal(), to call tty_kref_put() by hand. I hope this change makes sense by itself, but it is also needed to make ->signal refcountable. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Alan Cox <alan@linux.intel.com> Acked-by: Roland McGrath <roland@redhat.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27posix-cpu-timers: avoid "task->signal != NULL" checksOleg Nesterov
Preparation to make task->signal immutable, no functional changes. posix-cpu-timers.c checks task->signal != NULL to ensure this task is alive and didn't pass __exit_signal(). This is correct but we are going to change the lifetime rules for ->signal and never reset this pointer. Change the code to check ->sighand instead, it doesn't matter which pointer we check under tasklist, they both are cleared simultaneously. As Roland pointed out, some of these changes are not strictly needed and probably it makes sense to revert them later, when ->signal will be pinned to task_struct. But this patch tries to ensure the subsequent changes in fork/exit can't make any visible impact on posix cpu timers. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Acked-by: Roland McGrath <roland@redhat.com> Cc: Stanislaw Gruszka <sgruszka@redhat.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27exit: avoid sig->count in __exit_signal() to detect the group-dead caseOleg Nesterov
Change __exit_signal() to check thread_group_leader() instead of atomic_dec_and_test(&sig->count). This must be equivalent, the group leader must be released only after all other threads have exited and passed __exit_signal(). Henceforth sig->count is not actually used, except in fs/proc for get_nr_threads/etc. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Roland McGrath <roland@redhat.com> Cc: Veaceslav Falico <vfalico@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27exit: avoid sig->count in de_thread/__exit_signal synchronizationOleg Nesterov
de_thread() and __exit_signal() use signal_struct->count/notify_count for synchronization. We can simplify the code and use ->notify_count only. Instead of comparing these two counters, we can change de_thread() to set ->notify_count = nr_of_sub_threads, then change __exit_signal() to dec-and-test this counter and notify group_exit_task. Note that __exit_signal() checks "notify_count > 0" just for symmetry with exit_notify(), we could just check it is != 0. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Roland McGrath <roland@redhat.com> Cc: Veaceslav Falico <vfalico@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27exit: change zap_other_threads() to count sub-threadsOleg Nesterov
Change zap_other_threads() to return the number of other sub-threads found on ->thread_group list. Other changes are cosmetic: - change the code to use while_each_thread() helper - remove the obsolete comment about SIGKILL/SIGSTOP Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Roland McGrath <roland@redhat.com> Cc: Veaceslav Falico <vfalico@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27exit: exit_notify() can trust signal->notify_count < 0Oleg Nesterov
signal_struct->count in its current form must die. - it has no reasons to be atomic_t - it looks like a reference counter, but it is not - otoh, we really need to make task->signal refcountable, just look at the extremely ugly task_rq_unlock_wait() called from __exit_signals(). - we should change the lifetime rules for task->signal, it should be pinned to task_struct. We have a lot of code which can be simplified after that. - it is not needed! while the code is correct, any usage of this counter is artificial, except fs/proc uses it correctly to show the number of threads. This series removes the usage of sig->count from exit pathes. This patch: Now that Veaceslav changed copy_signal() to use zalloc(), exit_notify() can just check notify_count < 0 to ensure the execing sub-threads needs the notification from us. No need to do other checks, notify_count != 0 must always mean ->group_exit_task != NULL is waiting for us. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Roland McGrath <roland@redhat.com> Cc: Veaceslav Falico <vfalico@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27call_usermodehelper: UMH_WAIT_EXEC ignores kernel_thread() failureOleg Nesterov
UMH_WAIT_EXEC should report the error if kernel_thread() fails, like UMH_WAIT_PROC does. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27call_usermodehelper: simplify/fix UMH_NO_WAIT caseOleg Nesterov
__call_usermodehelper(UMH_NO_WAIT) has 2 problems: - if kernel_thread() fails, call_usermodehelper_freeinfo() is not called. - for unknown reason UMH_NO_WAIT has UMH_WAIT_PROC logic, we spawn yet another thread which waits until the user mode application exits. Change the UMH_NO_WAIT code to use ____call_usermodehelper() instead of wait_for_helper(), and do call_usermodehelper_freeinfo() unconditionally. We can rely on CLONE_VFORK, do_fork(CLONE_VFORK) until the child exits or execs. With or without this patch UMH_NO_WAIT does not report the error if kernel_thread() fails, this is correct since the caller doesn't wait for result. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27wait_for_helper: SIGCHLD from user-space can lead to use-after-freeOleg Nesterov
1. wait_for_helper() calls allow_signal(SIGCHLD) to ensure the child can't autoreap itself. However, this means that a spurious SIGCHILD from user-space can set TIF_SIGPENDING and: - kernel_thread() or sys_wait4() can fail due to signal_pending() - worse, wait4() can fail before ____call_usermodehelper() execs or exits. In this case the caller may kfree(subprocess_info) while the child still uses this memory. Change the code to use SIG_DFL instead of magic "(void __user *)2" set by allow_signal(). This means that SIGCHLD won't be delivered, yet the child won't autoreap itsefl. The problem is minor, only root can send a signal to this kthread. 2. If sys_wait4(&ret) fails it doesn't populate "ret", in this case wait_for_helper() reports a random value from uninitialized var. With this patch sys_wait4() should never fail, but still it makes sense to initialize ret = -ECHILD so that the caller can notice the problem. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27call_usermodehelper: no need to unblock signalsOleg Nesterov
____call_usermodehelper() correctly calls flush_signal_handlers() to set SIG_DFL, but sigemptyset(->blocked) and recalc_sigpending() are not needed. This kthread was forked by workqueue thread, all signals must be unblocked and ignored, no pending signal is possible. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27umh: creds: kill subprocess_info->cred logicOleg Nesterov
Now that nobody ever changes subprocess_info->cred we can kill this member and related code. ____call_usermodehelper() always runs in the context of freshly forked kernel thread, it has the proper ->cred copied from its parent kthread, keventd. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27umh: creds: convert call_usermodehelper_keys() to use subprocess_info->init()Oleg Nesterov
call_usermodehelper_keys() uses call_usermodehelper_setkeys() to change subprocess_info->cred in advance. Now that we have info->init() we can change this code to set tgcred->session_keyring in context of execing kernel thread. Note: since currently call_usermodehelper_keys() is never called with UMH_NO_WAIT, call_usermodehelper_keys()->key_get() and umh_keys_cleanup() are not really needed, we could rely on install_session_keyring_to_cred() which does key_get() on success. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27exec: replace call_usermodehelper_pipe with use of umh init function and ↵Neil Horman
resolve limit The first patch in this series introduced an init function to the call_usermodehelper api so that processes could be customized by caller. This patch takes advantage of that fact, by customizing the helper in do_coredump to create the pipe and set its core limit to one (for our recusrsion check). This lets us clean up the previous uglyness in the usermodehelper internals and factor call_usermodehelper out entirely. While I'm at it, we can also modify the helper setup to look for a core limit value of 1 rather than zero for our recursion check Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27kmod: add init function to usermodehelperNeil Horman
About 6 months ago, I made a set of changes to how the core-dump-to-a-pipe feature in the kernel works. We had reports of several races, including some reports of apps bypassing our recursion check so that a process that was forked as part of a core_pattern setup could infinitely crash and refork until the system crashed. We fixed those by improving our recursion checks. The new check basically refuses to fork a process if its core limit is zero, which works well. Unfortunately, I've been getting grief from maintainer of user space programs that are inserted as the forked process of core_pattern. They contend that in order for their programs (such as abrt and apport) to work, all the running processes in a system must have their core limits set to a non-zero value, to which I say 'yes'. I did this by design, and think thats the right way to do things. But I've been asked to ease this burden on user space enough times that I thought I would take a look at it. The first suggestion was to make the recursion check fail on a non-zero 'special' number, like one. That way the core collector process could set its core size ulimit to 1, and enable the kernel's recursion detection. This isn't a bad idea on the surface, but I don't like it since its opt-in, in that if a program like abrt or apport has a bug and fails to set such a core limit, we're left with a recursively crashing system again. So I've come up with this. What I've done is modify the call_usermodehelper api such that an extra parameter is added, a function pointer which will be called by the user helper task, after it forks, but before it exec's the required process. This will give the caller the opportunity to get a call back in the processes context, allowing it to do whatever it needs to to the process in the kernel prior to exec-ing the user space code. In the case of do_coredump, this callback is ues to set the core ulimit of the helper process to 1. This elimnates the opt-in problem that I had above, as it allows the ulimit for core sizes to be set to the value of 1, which is what the recursion check looks for in do_coredump. This patch: Create new function call_usermodehelper_fns() and allow it to assign both an init and cleanup function, as we'll as arbitrary data. The init function is called from the context of the forked process and allows for customization of the helper process prior to calling exec. Its return code gates the continuation of the process, or causes its exit. Also add an arbitrary data pointer to the subprocess_info struct allowing for data to be passed from the caller to the new process, and the subsequent cleanup process Also, use this patch to cleanup the cleanup function. It currently takes an argp and envp pointer for freeing, which is ugly. Lets instead just make the subprocess_info structure public, and pass that to the cleanup and init routines Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27signals: check_kill_permission(): don't check creds if same_thread_group()Oleg Nesterov
Andrew Tridgell reports that aio_read(SIGEV_SIGNAL) can fail if the notification from the helper thread races with setresuid(), see http://samba.org/~tridge/junkcode/aio_uid.c This happens because check_kill_permission() doesn't permit sending a signal to the task with the different cred->xids. But there is not any security reason to check ->cred's when the task sends a signal (private or group-wide) to its sub-thread. Whatever we do, any thread can bypass all security checks and send SIGKILL to all threads, or it can block a signal SIG and do kill(gettid(), SIG) to deliver this signal to another sub-thread. Not to mention that CLONE_THREAD implies CLONE_VM. Change check_kill_permission() to avoid the credentials check when the sender and the target are from the same thread group. Also, move "cred = current_cred()" down to avoid calling get_current() twice. Note: David Howells pointed out we could relax this even more, the CLONE_SIGHAND (without CLONE_THREAD) case probably does not need these checks too. Roland said: : The glibc (libpthread) that does set*id across threads has : been in use for a while (2.3.4?), probably in distro's using kernels as old : or older than any active -stable streams. In the race in question, this : kernel bug is breaking valid POSIX application expectations. Reported-by: Andrew Tridgell <tridge@samba.org> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Cc: Eric Paris <eparis@parisplace.org> Cc: Jakub Jelinek <jakub@redhat.com> Cc: James Morris <jmorris@namei.org> Cc: Roland McGrath <roland@redhat.com> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: <stable@kernel.org> [all kernel versions] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27ptrace: PTRACE_GETFDPIC: fix the unsafe usage of child->mmOleg Nesterov
Now that Mike Frysinger unified the FDPIC ptrace code, we can fix the unsafe usage of child->mm in ptrace_request(PTRACE_GETFDPIC). We have the reference to task_struct, and ptrace_check_attach() verified the tracee is stopped. But nothing can protect from SIGKILL after that, we must not assume child->mm != NULL. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Mike Frysinger <vapier.adi@gmail.com> Acked-by: David Howells <dhowells@redhat.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Greg Ungerer <gerg@snapgear.com> Acked-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27ptrace: unify FDPIC implementationsMike Frysinger
The Blackfin/FRV/SuperH guys all have the same exact FDPIC ptrace code in their arch handlers (since they were probably copied & pasted). Since these ptrace interfaces are an arch independent aspect of the FDPIC code, unify them in the common ptrace code so new FDPIC ports don't need to copy and paste this fundamental stuff yet again. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27cpusets: randomize node rotor used in cpuset_mem_spread_node()Jack Steiner
Some workloads that create a large number of small files tend to assign too many pages to node 0 (multi-node systems). Part of the reason is that the rotor (in cpuset_mem_spread_node()) used to assign nodes starts at node 0 for newly created tasks. This patch changes the rotor to be initialized to a random node number of the cpuset. [akpm@linux-foundation.org: fix layout] [Lee.Schermerhorn@hp.com: Define stub numa_random() for !NUMA configuration] Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Paul Menage <menage@google.com> Cc: Jack Steiner <steiner@sgi.com> Cc: Robin Holt <holt@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27cpusets: new round-robin rotor for SLAB allocationsJack Steiner
We have observed several workloads running on multi-node systems where memory is assigned unevenly across the nodes in the system. There are numerous reasons for this but one is the round-robin rotor in cpuset_mem_spread_node(). For example, a simple test that writes a multi-page file will allocate pages on nodes 0 2 4 6 ... Odd nodes are skipped. (Sometimes it allocates on odd nodes & skips even nodes). An example is shown below. The program "lfile" writes a file consisting of 10 pages. The program then mmaps the file & uses get_mempolicy(..., MPOL_F_NODE) to determine the nodes where the file pages were allocated. The output is shown below: # ./lfile allocated on nodes: 2 4 6 0 1 2 6 0 2 There is a single rotor that is used for allocating both file pages & slab pages. Writing the file allocates both a data page & a slab page (buffer_head). This advances the RR rotor 2 nodes for each page allocated. A quick confirmation seems to confirm this is the cause of the uneven allocation: # echo 0 >/dev/cpuset/memory_spread_slab # ./lfile allocated on nodes: 6 7 8 9 0 1 2 3 4 5 This patch introduces a second rotor that is used for slab allocations. Signed-off-by: Jack Steiner <steiner@sgi.com> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Paul Menage <menage@google.com> Cc: Jack Steiner <steiner@sgi.com> Cc: Robin Holt <holt@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27cgroups: make cftype.unregister_event() void-returningKirill A. Shutemov
Since we are unable to handle an error returned by cftype.unregister_event() properly, let's make the callback void-returning. mem_cgroup_unregister_event() has been rewritten to be a "never fail" function. On mem_cgroup_usage_register_event() we save old buffer for thresholds array and reuse it in mem_cgroup_usage_unregister_event() to avoid allocation. Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Phil Carmody <ext-phil.2.carmody@nokia.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-26hrtimer: Avoid double seqlockStanislaw Gruszka
hrtimer_get_softirq_time() has it's own xtime lock protection, so it's safe to use plain __current_kernel_time() and avoid the double seqlock loop. Signed-off-by: Stanislaw Gruszka <stf_xl@wp.pl> LKML-Reference: <20100525214912.GA1934@r2bh72.net.upc.cz> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-05-26timers: Move local variable into else sectionThomas Gleixner
Fix nit-picking coding style detail. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
