commit db0a6fb5d97afe01fd9c47d37c6daa82d4d4001d upstream.
The tty field was missing from AUDIT_LOGIN events.
Refactor code to create a new function audit_get_tty(), using it to
replace the call in audit_log_task_info() and to add it to
audit_log_set_loginuid(). Lock and bump the kref to protect it, adding
audit_put_tty() alias to decrement it.
Signed-off-by: Richard Guy Briggs <rgb@redhat.com>
Signed-off-by: Paul Moore <paul@paul-moore.com>
commit d170fe7dd992b313d4851ae5ab77ee7a51ed8c72 upstream.
This fixes the following clang warning when CONFIG_CPUMASK_OFFSTACK=n:
kernel/irq/manage.c:839:28: error: address of array
'desc->irq_common_data.affinity' will always evaluate to 'true'
[-Werror,-Wpointer-bool-conversion]
Signed-off-by: Matthias Kaehlcke <mka@chromium.org>
Cc: Grant Grundler <grundler@chromium.org>
Cc: Greg Hackmann <ghackmann@google.com>
Cc: Michael Davidson <md@google.com>
Link: http://lkml.kernel.org/r/20170412182030.83657-2-mka@chromium.org
Cc: Nathan Chancellor <natechancellor@gmail.com>
commit c93f5cf571e7795f97d49ef51b766cf25e328545 upstream.
Fix kprobes to set(recover) RWX bits correctly on trampoline
buffer before releasing it. Releasing readonly page to
module_memfree() crash the kernel.
Without this fix, if kprobes user register a bunch of kprobes
in function body (since kprobes on function entry usually
use ftrace) and unregister it, kernel hits a BUG and crash.
Link: http://lkml.kernel.org/r/149570868652.3518.14120169373590420503.stgit@devbox
Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org>
Fixes: d0381c81c2f7 ("kprobes/x86: Set kprobes pages read-only")
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
Cc: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit f67b15037a7a50c57f72e69a6d59941ad90a0f0f upstream.
Annoyingly, modify_user_hw_breakpoint() unnecessarily complicates the
modification of a breakpoint - simplify it and remove the pointless
local variables.
Also update the stale Docbook while at it.
Cc: <stable@vger.kernel.org>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Vince Weaver <vincent.weaver@maine.edu>
shared IRQs"
This reverts commit 9d0273bb1c4b645817eccfe5c5975ea29add3300 which is
commit 382bd4de61827dbaaf5fb4fb7b1f4be4a86505e7 upstream.
It causes too many problems with the stable tree, and would require too
many other things to be backported, so just revert it.
Reported-by: Guenter Roeck <linux@roeck-us.net>
Cc: Hans de Goede <hdegoede@redhat.com>
Cc: Marc Zyngier <marc.zyngier@arm.com>
Cc: Sasha Levin <alexander.levin@microsoft.com>
commit 0fa4fe85f4724fff89b09741c437cbee9cf8b008 upstream.
The current check statement in BPF syscall will do a capability check
for CAP_SYS_ADMIN before checking sysctl_unprivileged_bpf_disabled. This
code path will trigger unnecessary security hooks on capability checking
and cause false alarms on unprivileged process trying to get CAP_SYS_ADMIN
access. This can be resolved by simply switch the order of the statement
and CAP_SYS_ADMIN is not required anyway if unprivileged bpf syscall is
allowed.
Signed-off-by: Chenbo Feng <fengc@google.com>
Acked-by: Lorenzo Colitti <lorenzo@google.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
commit c5d343b6b7badd1f5fe0873eff2e8d63a193e732 upstream.
In Documentation/trace/kprobetrace.txt, it says
@SYM[+|-offs] : Fetch memory at SYM +|- offs (SYM should be a data symbol)
However, the parser doesn't parse minus offset correctly, since
commit 2fba0c8867af ("tracing/kprobes: Fix probe offset to be
unsigned") drops minus ("-") offset support for kprobe probe
address usage.
This fixes the traceprobe_split_symbol_offset() to parse minus
offset again with checking the offset range, and add a minus
offset check in kprobe probe address usage.
Link: http://lkml.kernel.org/r/152129028983.31874.13419301530285775521.stgit@devbox
Cc: Tom Zanussi <tom.zanussi@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Cc: Ravi Bangoria <ravi.bangoria@linux.vnet.ibm.com>
Cc: stable@vger.kernel.org
Fixes: 2fba0c8867af ("tracing/kprobes: Fix probe offset to be unsigned")
Acked-by: Namhyung Kim <namhyung@kernel.org>
[ Upstream commit 382bd4de61827dbaaf5fb4fb7b1f4be4a86505e7 ]
When requesting a shared irq with IRQF_TRIGGER_NONE then the irqaction
flags get filled with the trigger type from the irq_data:
if (!(new->flags & IRQF_TRIGGER_MASK))
new->flags |= irqd_get_trigger_type(&desc->irq_data);
On the first setup_irq() the trigger type in irq_data is NONE when the
above code executes, then the irq is started up for the first time and
then the actual trigger type gets established, but that's too late to fix
up new->flags.
When then a second user of the irq requests the irq with IRQF_TRIGGER_NONE
its irqaction's triggertype gets set to the actual trigger type and the
following check fails:
if (!((old->flags ^ new->flags) & IRQF_TRIGGER_MASK))
Resulting in the request_irq failing with -EBUSY even though both
users requested the irq with IRQF_SHARED | IRQF_TRIGGER_NONE
Fix this by comparing the new irqaction's trigger type to the trigger type
stored in the irq_data which correctly reflects the actual trigger type
being used for the irq.
Suggested-by: Thomas Gleixner <tglx@linutronix.de>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
Link: http://lkml.kernel.org/r/20170415100831.17073-1-hdegoede@redhat.com
[ Upstream commit d340266e19ddb70dbd608f9deedcfb35fdb9d419 ]
struct timespec is not y2038 safe on 32 bit machines.
The posix clocks apis use struct timespec directly and through struct
itimerspec.
Replace the posix clock interfaces to use struct timespec64 and struct
itimerspec64 instead. Also fix up their implementations accordingly.
Note that the clock_getres() interface has also been changed to use
timespec64 even though this particular interface is not affected by the
y2038 problem. This helps verification for internal kernel code for y2038
readiness by getting rid of time_t/ timeval/ timespec.
Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com>
Cc: arnd@arndb.de
Cc: y2038@lists.linaro.org
Cc: netdev@vger.kernel.org
Cc: Richard Cochran <richardcochran@gmail.com>
Cc: john.stultz@linaro.org
Link: http://lkml.kernel.org/r/1490555058-4603-3-git-send-email-deepa.kernel@gmail.com
commit 95a762e2c8c942780948091f8f2a4f32fce1ac6f upstream.
Distinguish between
BPF_ALU64|BPF_MOV|BPF_K (load 32-bit immediate, sign-extended to 64-bit)
and BPF_ALU|BPF_MOV|BPF_K (load 32-bit immediate, zero-padded to 64-bit);
only perform sign extension in the first case.
This patch differs from the mainline one because the verifier's internals
have changed in the meantime. Mainline tracks register values as 64-bit
values; however, 4.4 still stores tracked register values as 32-bit
values with sign extension. Therefore, in the case of a 32-bit op with
negative immediate, the value can't be tracked; leave the register as
UNKNOWN_VALUE (set by the preceding check_reg_arg() call).
I have manually tested this patch on top of 4.4.122. For the following BPF
bytecode:
BPF_MOV64_IMM(BPF_REG_1, 1),
BPF_JMP_IMM(BPF_JEQ, BPF_REG_1, 1, 1),
BPF_EXIT_INSN(),
BPF_MOV32_IMM(BPF_REG_1, 1),
BPF_EXIT_INSN(),
BPF_MOV64_IMM(BPF_REG_1, -1),
BPF_JMP_IMM(BPF_JEQ, BPF_REG_1, -1, 1),
BPF_EXIT_INSN(),
BPF_MOV32_IMM(BPF_REG_1, -1),
BPF_JMP_IMM(BPF_JEQ, BPF_REG_1, -1, 2),
BPF_MOV32_IMM(BPF_REG_0, 42),
BPF_EXIT_INSN(),
BPF_MOV32_IMM(BPF_REG_0, 43),
BPF_EXIT_INSN()
Verifier output on 4.4.122 without this patch:
0: (b7) r1 = 1
1: (15) if r1 == 0x1 goto pc+1
3: (b4) (u32) r1 = (u32) 1
4: (15) if r1 == 0x1 goto pc+1
6: (b7) r1 = -1
7: (15) if r1 == 0xffffffff goto pc+1
9: (b4) (u32) r1 = (u32) -1
10: (15) if r1 == 0xffffffff goto pc+2
13: (b4) (u32) r0 = (u32) 43
14: (95) exit
Verifier output on 4.4.122+ with this patch:
0: (b7) r1 = 1
6: (b7) r1 = -1
R1=inv R10=fp
11: (b4) (u32) r0 = (u32) 42
12: (95) exit
from 10 to 13: R1=imm-1 R10=fp
14: (95) exit
Signed-off-by: Jann Horn <jannh@google.com>
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
[ Upstream commit a0982dfa03efca6c239c52cabebcea4afb93ea6b ]
The rcutorture test suite occasionally provokes a splat due to invoking
resched_cpu() on an offline CPU:
WARNING: CPU: 2 PID: 8 at /home/paulmck/public_git/linux-rcu/arch/x86/kernel/smp.c:128 native_smp_send_reschedule+0x37/0x40
Modules linked in:
CPU: 2 PID: 8 Comm: rcu_preempt Not tainted 4.14.0-rc4+ #1
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
task: ffff902ede9daf00 task.stack: ffff96c50010c000
RIP: 0010:native_smp_send_reschedule+0x37/0x40
RSP: 0018:ffff96c50010fdb8 EFLAGS: 00010096
RAX: 000000000000002e RBX: ffff902edaab4680 RCX: 0000000000000003
RDX: 0000000080000003 RSI: 0000000000000000 RDI: 00000000ffffffff
RBP: ffff96c50010fdb8 R08: 0000000000000000 R09: 0000000000000001
R10: 0000000000000000 R11: 00000000299f36ae R12: 0000000000000001
R13: ffffffff9de64240 R14: 0000000000000001 R15: ffffffff9de64240
FS: 0000000000000000(0000) GS:ffff902edfc80000(0000) knlGS:0000000000000000
CR2: 00000000f7d4c642 CR3: 000000001e0e2000 CR4: 00000000000006e0
Call Trace:
resched_curr+0x8f/0x1c0
resched_cpu+0x2c/0x40
rcu_implicit_dynticks_qs+0x152/0x220
force_qs_rnp+0x147/0x1d0
? sync_rcu_exp_select_cpus+0x450/0x450
rcu_gp_kthread+0x5a9/0x950
kthread+0x142/0x180
? force_qs_rnp+0x1d0/0x1d0
? kthread_create_on_node+0x40/0x40
ret_from_fork+0x27/0x40
Code: 14 01 0f 92 c0 84 c0 74 14 48 8b 05 14 4f f4 00 be fd 00 00 00 ff 90 a0 00 00 00 5d c3 89 fe 48 c7 c7 38 89 ca 9d e8 e5 56 08 00 <0f> ff 5d c3 0f 1f 44 00 00 8b 05 52 9e 37 02 85 c0 75 38 55 48
---[ end trace 26df9e5df4bba4ac ]---
This splat cannot be generated by expedited grace periods because they
always invoke resched_cpu() on the current CPU, which is good because
expedited grace periods require that resched_cpu() unconditionally
succeed. However, other parts of RCU can tolerate resched_cpu() acting
as a no-op, at least as long as it doesn't happen too often.
This commit therefore makes resched_cpu() invoke resched_curr() only if
the CPU is either online or is the current CPU.
[ Upstream commit 2fe2582649aa2355f79acddb86bd4d6c5363eb63 ]
rt_mutex_lock() which needs to boost the priority of a task currently
sitting on a runqueue that belongs to an offline CPU:
WARNING: CPU: 0 PID: 12 at /home/paulmck/public_git/linux-rcu/arch/x86/kernel/smp.c:128 native_smp_send_reschedule+0x37/0x40
Modules linked in:
CPU: 0 PID: 12 Comm: rcub/7 Not tainted 4.14.0-rc4+ #1
task: ffff9ed3de5f8cc0 task.stack: ffffbbf80012c000
RSP: 0018:ffffbbf80012fd10 EFLAGS: 00010082
RAX: 000000000000002f RBX: ffff9ed3dd9cb300 RCX: 0000000000000004
RDX: 0000000080000004 RSI: 0000000000000086 RDI: 00000000ffffffff
RBP: ffffbbf80012fd10 R08: 000000000009da7a R09: 0000000000007b9d
R10: 0000000000000001 R11: ffffffffbb57c2cd R12: 000000000000000d
R13: ffff9ed3de5f8cc0 R14: 0000000000000061 R15: ffff9ed3ded59200
FS: 0000000000000000(0000) GS:ffff9ed3dea00000(0000) knlGS:0000000000000000
CR2: 00000000080686f0 CR3: 000000001b9e0000 CR4: 00000000000006f0
Call Trace:
resched_curr+0x61/0xd0
switched_to_rt+0x8f/0xa0
rt_mutex_setprio+0x25c/0x410
task_blocks_on_rt_mutex+0x1b3/0x1f0
rt_mutex_slowlock+0xa9/0x1e0
rt_mutex_lock+0x29/0x30
rcu_boost_kthread+0x127/0x3c0
kthread+0x104/0x140
? rcu_report_unblock_qs_rnp+0x90/0x90
ret_from_fork+0x22/0x30
Code: f0 00 0f 92 c0 84 c0 74 14 48 8b 05 34 74 c5 00 be fd 00 00 00 ff 90 a0 00 00 00 5d c3 89 fe 48 c7 c7 a0 c6 fc b9 e8 d5 b5 06 00 <0f> ff 5d c3 0f 1f 44 00 00 8b 05 a2 d1 13 02 85 c0 75 38 55 48
But the target task's priority has already been adjusted, so the only
purpose of switched_to_rt() invoking resched_curr() is to wake up the
CPU running some task that needs to be preempted by the boosted task.
But the CPU is offline, which presumably means that the task must be
migrated to some other CPU, and that this other CPU will undertake any
needed preemption at the time of migration. Because the runqueue lock
is held when resched_curr() is invoked, we know that the boosted task
cannot go anywhere, so it is not necessary to invoke resched_curr()
in this particular case.
This commit therefore makes switched_to_rt() refrain from invoking
resched_curr() when the target CPU is offline.
[ Upstream commit 2ed2b8621be2708c0f6d61fe9841e9ad8b9753f0 ]
commit bbeddf52adc1 ("printk: move braille console support into
separate braille.[ch] files") introduced _braille_console_setup()
to outline the braille initialization code. There was however some
confusion over the value it was supposed to return. commit 2cfe6c4ac7ee
("printk: Fix return of braille_register_console()") tried to fix it
but failed to.
This fixes and documents the returned value according to the use
in printk.c: non-zero return means a parsing error, and thus this
console configuration should be ignored.
Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org>
Cc: Aleksey Makarov <aleksey.makarov@linaro.org>
Cc: Joe Perches <joe@perches.com>
Cc: Ming Lei <ming.lei@canonical.com>
Acked-by: Petr Mladek <pmladek@suse.com>
[ Upstream commit 0107042768658fea9f5f5a9c00b1c90f5dab6a06 ]
On systems with a large number of CPUs, running sysrq-<q> can cause
watchdog timeouts. There are two slow sections of code in the sysrq-<q>
path in timer_list.c.
1. print_active_timers() - This function is called by print_cpu() and
contains a slow goto loop. On a machine with hundreds of CPUs, this
loop took approximately 100ms for the first CPU in a NUMA node.
(Subsequent CPUs in the same node ran much quicker.) The total time
to print all of the CPUs is ultimately long enough to trigger the
soft lockup watchdog.
2. print_tickdevice() - This function outputs a large amount of textual
information. This function also took approximately 100ms per CPU.
Since sysrq-<q> is not a performance critical path, there should be no
harm in touching the nmi watchdog in both slow sections above. Touching
it in just one location was insufficient on systems with hundreds of
CPUs as occasional timeouts were still observed during testing.
This issue was observed on an Oracle T7 machine with 128 CPUs, but I
anticipate it may affect other systems with similarly large numbers of
CPUs.
Signed-off-by: Tom Hromatka <tom.hromatka@oracle.com>
Reviewed-by: Rob Gardner <rob.gardner@oracle.com>
Signed-off-by: John Stultz <john.stultz@linaro.org>
[ Upstream commit 1b8955bc5ac575009835e371ae55e7f3af2197a9 ]
The scheduler clock framework may not use the correct timeout for the clock
wrap. This happens when a new clock driver calls sched_clock_register()
after the kernel called sched_clock_postinit(). In this case the clock wrap
timeout is too long thus sched_clock_poll() is called too late and the clock
already wrapped.
On my ARM system the scheduler was no longer scheduling any other task than
the idle task because the sched_clock() wrapped.
Signed-off-by: David Engraf <david.engraf@sysgo.com>
commit 27d4ee03078aba88c5e07dcc4917e8d01d046f38 upstream.
Introduce a helper to retrieve the current task's work struct if it is
a workqueue worker.
This allows us to fix a long-standing deadlock in several DRM drivers
wherein the ->runtime_suspend callback waits for a specific worker to
finish and that worker in turn calls a function which waits for runtime
suspend to finish. That function is invoked from multiple call sites
and waiting for runtime suspend to finish is the correct thing to do
except if it's executing in the context of the worker.
Cc: Lai Jiangshan <jiangshanlai@gmail.com>
Cc: Dave Airlie <airlied@redhat.com>
Cc: Ben Skeggs <bskeggs@redhat.com>
Cc: Alex Deucher <alexander.deucher@amd.com>
Acked-by: Tejun Heo <tj@kernel.org>
Reviewed-by: Lyude Paul <lyude@redhat.com>
Signed-off-by: Lukas Wunner <lukas@wunner.de>
Link: https://patchwork.freedesktop.org/patch/msgid/2d8f603074131eb87e588d2b803a71765bd3a2fd.1518338788.git.lukas@wunner.de
commit 48d0c9becc7f3c66874c100c126459a9da0fdced upstream.
The POSIX specification defines that relative CLOCK_REALTIME timers are not
affected by clock modifications. Those timers have to use CLOCK_MONOTONIC
to ensure POSIX compliance.
The introduction of the additional HRTIMER_MODE_PINNED mode broke this
requirement for pinned timers.
There is no user space visible impact because user space timers are not
using pinned mode, but for consistency reasons this needs to be fixed.
Check whether the mode has the HRTIMER_MODE_REL bit set instead of
comparing with HRTIMER_MODE_ABS.
Signed-off-by: Anna-Maria Gleixner <anna-maria@linutronix.de>
Cc: John Stultz <john.stultz@linaro.org>
Cc: keescook@chromium.org
Fixes: 597d0275736d ("timers: Framework for identifying pinned timers")
Link: http://lkml.kernel.org/r/20171221104205.7269-7-anna-maria@linutronix.de
(cherry picked from commit caf7501a1b4ec964190f31f9c3f163de252273b8)
There's a risk that a kernel which has full retpoline mitigations becomes
vulnerable when a module gets loaded that hasn't been compiled with the
right compiler or the right option.
To enable detection of that mismatch at module load time, add a module info
string "retpoline" at build time when the module was compiled with
retpoline support. This only covers compiled C source, but assembler source
or prebuilt object files are not checked.
If a retpoline enabled kernel detects a non retpoline protected module at
load time, print a warning and report it in the sysfs vulnerability file.
[ tglx: Massaged changelog ]
Cc: gregkh@linuxfoundation.org
Cc: torvalds@linux-foundation.org
Cc: jeyu@kernel.org
Cc: arjan@linux.intel.com
Link: https://lkml.kernel.org/r/20180125235028.31211-1-andi@firstfloor.org
Signed-off-by: David Woodhouse <dwmw@amazon.co.uk>
[jwang: port to 4.4]
Signed-off-by: Jack Wang <jinpu.wang@profitbricks.com>
commit ade356b99a4187578609f2a91c4d2ed88e4e70dc upstream.
A couple of functions and variables in the profile implementation are
used only on SMP systems by the procfs code, but are unused if either
procfs is disabled or in uniprocessor kernels. gcc prints a harmless
warning about the unused symbols:
kernel/profile.c:243:13: error: 'profile_flip_buffers' defined but not used [-Werror=unused-function]
static void profile_flip_buffers(void)
kernel/profile.c:266:13: error: 'profile_discard_flip_buffers' defined but not used [-Werror=unused-function]
static void profile_discard_flip_buffers(void)
kernel/profile.c:330:12: error: 'profile_cpu_callback' defined but not used [-Werror=unused-function]
static int profile_cpu_callback(struct notifier_block *info,
This adds further #ifdef to the file, to annotate exactly in which cases
they are used. I have done several thousand ARM randconfig kernels with
this patch applied and no longer get any warnings in this file.
Cc: Robin Holt <robinmholt@gmail.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Tejun Heo <tj@kernel.org>
commit a6da0024ffc19e0d47712bb5ca4fd083f76b07df upstream.
We need to ensure that tracepoints are registered and unregistered
with the users of them. The existing atomic count isn't enough for
that. Add a lock around the tracepoints, so we serialize access
to them.
This fixes cases where we have multiple users setting up and
tearing down tracepoints, like this:
CPU: 0 PID: 2995 Comm: syzkaller857118 Not tainted
4.14.0-rc5-next-20171018+ #36
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS
Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:16 [inline]
dump_stack+0x194/0x257 lib/dump_stack.c:52
panic+0x1e4/0x41c kernel/panic.c:183
__warn+0x1c4/0x1e0 kernel/panic.c:546
report_bug+0x211/0x2d0 lib/bug.c:183
fixup_bug+0x40/0x90 arch/x86/kernel/traps.c:177
do_trap_no_signal arch/x86/kernel/traps.c:211 [inline]
do_trap+0x260/0x390 arch/x86/kernel/traps.c:260
do_error_trap+0x120/0x390 arch/x86/kernel/traps.c:297
do_invalid_op+0x1b/0x20 arch/x86/kernel/traps.c:310
invalid_op+0x18/0x20 arch/x86/entry/entry_64.S:905
RIP: 0010:tracepoint_add_func kernel/tracepoint.c:210 [inline]
RIP: 0010:tracepoint_probe_register_prio+0x397/0x9a0 kernel/tracepoint.c:283
RSP: 0018:ffff8801d1d1f6c0 EFLAGS: 00010293
RAX: ffff8801d22e8540 RBX: 00000000ffffffef RCX: ffffffff81710f07
RDX: 0000000000000000 RSI: ffffffff85b679c0 RDI: ffff8801d5f19818
RBP: ffff8801d1d1f7c8 R08: ffffffff81710c10 R09: 0000000000000004
R10: ffff8801d1d1f6b0 R11: 0000000000000003 R12: ffffffff817597f0
R13: 0000000000000000 R14: 00000000ffffffff R15: ffff8801d1d1f7a0
tracepoint_probe_register+0x2a/0x40 kernel/tracepoint.c:304
register_trace_block_rq_insert include/trace/events/block.h:191 [inline]
blk_register_tracepoints+0x1e/0x2f0 kernel/trace/blktrace.c:1043
do_blk_trace_setup+0xa10/0xcf0 kernel/trace/blktrace.c:542
blk_trace_setup+0xbd/0x180 kernel/trace/blktrace.c:564
sg_ioctl+0xc71/0x2d90 drivers/scsi/sg.c:1089
vfs_ioctl fs/ioctl.c:45 [inline]
do_vfs_ioctl+0x1b1/0x1520 fs/ioctl.c:685
SYSC_ioctl fs/ioctl.c:700 [inline]
SyS_ioctl+0x8f/0xc0 fs/ioctl.c:691
entry_SYSCALL_64_fastpath+0x1f/0xbe
RIP: 0033:0x444339
RSP: 002b:00007ffe05bb5b18 EFLAGS: 00000206 ORIG_RAX: 0000000000000010
RAX: ffffffffffffffda RBX: 00000000006d66c0 RCX: 0000000000444339
RDX: 000000002084cf90 RSI: 00000000c0481273 RDI: 0000000000000009
RBP: 0000000000000082 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000206 R12: ffffffffffffffff
R13: 00000000c0481273 R14: 0000000000000000 R15: 0000000000000000
since we can now run these in parallel. Ensure that the exported helpers
for doing this are grabbing the queue trace mutex.
Reported-by: Steven Rostedt <rostedt@goodmis.org>
Tested-by: Dmitry Vyukov <dvyukov@google.com>
commit 7b6586562708d2b3a04fe49f217ddbadbbbb0546 upstream.
__unregister_ftrace_function_probe() will incorrectly parse the glob filter
because it resets the search variable that was setup by filter_parse_regex().
Al Viro reported this:
After that call of filter_parse_regex() we could have func_g.search not
equal to glob only if glob started with '!' or '*'. In the former case
we would've buggered off with -EINVAL (not = 1). In the latter we
would've set func_g.search equal to glob + 1, calculated the length of
that thing in func_g.len and proceeded to reset func_g.search back to
glob.
Suppose the glob is e.g. *foo*. We end up with
func_g.type = MATCH_MIDDLE_ONLY;
func_g.len = 3;
func_g.search = "*foo";
Feeding that to ftrace_match_record() will not do anything sane - we
will be looking for names containing "*foo" (->len is ignored for that
one).
Link: http://lkml.kernel.org/r/20180127031706.GE13338@ZenIV.linux.org.uk
Fixes: 3ba009297149f ("ftrace: Introduce ftrace_glob structure")
Reviewed-by: Dmitry Safonov <0x7f454c46@gmail.com>
Reviewed-by: Masami Hiramatsu <mhiramat@kernel.org>
Reported-by: Al Viro <viro@ZenIV.linux.org.uk>
commit 4f7e988e63e336827f4150de48163bed05d653bd upstream.
This reverts commit 92266d6ef60c ("async: simplify lowest_in_progress()")
which was simply wrong: In the case where domain is NULL, we now use the
wrong offsetof() in the list_first_entry macro, so we don't actually
fetch the ->cookie value, but rather the eight bytes located
sizeof(struct list_head) further into the struct async_entry.
On 64 bit, that's the data member, while on 32 bit, that's a u64 built
from func and data in some order.
I think the bug happens to be harmless in practice: It obviously only
affects callers which pass a NULL domain, and AFAICT the only such
caller is
async_synchronize_full() ->
async_synchronize_full_domain(NULL) ->
async_synchronize_cookie_domain(ASYNC_COOKIE_MAX, NULL)
and the ASYNC_COOKIE_MAX means that in practice we end up waiting for
the async_global_pending list to be empty - but it would break if
somebody happened to pass (void*)-1 as the data element to
async_schedule, and of course also if somebody ever does a
async_synchronize_cookie_domain(, NULL) with a "finite" cookie value.
Maybe the "harmless in practice" means this isn't -stable material. But
I'm not completely confident my quick git grep'ing is enough, and there
might be affected code in one of the earlier kernels that has since been
removed, so I'll leave the decision to the stable guys.
Link: http://lkml.kernel.org/r/20171128104938.3921-1-linux@rasmusvillemoes.dk
Fixes: 92266d6ef60c "async: simplify lowest_in_progress()"
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: Adam Wallis <awallis@codeaurora.org>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
commit 364f56653708ba8bcdefd4f0da2a42904baa8eeb upstream.
When issuing an IPI RT push, where an IPI is sent to each CPU that has more
than one RT task scheduled on it, it references the root domain's rto_mask,
that contains all the CPUs within the root domain that has more than one RT
task in the runable state. The problem is, after the IPIs are initiated, the
rq->lock is released. This means that the root domain that is associated to
the run queue could be freed while the IPIs are going around.
Add a sched_get_rd() and a sched_put_rd() that will increment and decrement
the root domain's ref count respectively. This way when initiating the IPIs,
the scheduler will up the root domain's ref count before releasing the
rq->lock, ensuring that the root domain does not go away until the IPI round
is complete.
Reported-by: Pavan Kondeti <pkondeti@codeaurora.org>
Fixes: 4bdced5c9a292 ("sched/rt: Simplify the IPI based RT balancing logic")
Link: http://lkml.kernel.org/r/CAEU1=PkiHO35Dzna8EQqNSKW1fr1y1zRQ5y66X117MG06sQtNA@mail.gmail.com
commit ad0f1d9d65938aec72a698116cd73a980916895e upstream.
When the rto_push_irq_work_func() is called, it looks at the RT overloaded
bitmask in the root domain via the runqueue (rq->rd). The problem is that
during CPU up and down, nothing here stops rq->rd from changing between
taking the rq->rd->rto_lock and releasing it. That means the lock that is
released is not the same lock that was taken.
Instead of using this_rq()->rd to get the root domain, as the irq work is
part of the root domain, we can simply get the root domain from the irq work
that is passed to the routine:
container_of(work, struct root_domain, rto_push_work)
This keeps the root domain consistent.
commit cef31d9af908243421258f1df35a4a644604efbe upstream.
timer_create() specifies via sigevent->sigev_notify the signal delivery for
the new timer. The valid modes are SIGEV_NONE, SIGEV_SIGNAL, SIGEV_THREAD
and (SIGEV_SIGNAL | SIGEV_THREAD_ID).
The sanity check in good_sigevent() is only checking the valid combination
for the SIGEV_THREAD_ID bit, i.e. SIGEV_SIGNAL, but if SIGEV_THREAD_ID is
not set it accepts any random value.
This has no real effects on the posix timer and signal delivery code, but
it affects show_timer() which handles the output of /proc/$PID/timers. That
function uses a string array to pretty print sigev_notify. The access to
that array has no bound checks, so random sigev_notify cause access beyond
the array bounds.
Add proper checks for the valid notify modes and remove the SIGEV_THREAD_ID
masking from various code pathes as SIGEV_NONE can never be set in
combination with SIGEV_THREAD_ID.
Reported-by: Eric Biggers <ebiggers3@gmail.com>
Reported-by: Alexey Dobriyan <adobriyan@gmail.com>
[ upstream commit f37a8cb84cce18762e8f86a70bd6a49a66ab964c ]
Alexei found that verifier does not reject stores into context
via BPF_ST instead of BPF_STX. And while looking at it, we
also should not allow XADD variant of BPF_STX.
The context rewriter is only assuming either BPF_LDX_MEM- or
BPF_STX_MEM-type operations, thus reject anything other than
that so that assumptions in the rewriter properly hold. Add
test cases as well for BPF selftests.
Fixes: d691f9e8d440 ("bpf: allow programs to write to certain skb fields")
Reported-by: Alexei Starovoitov <ast@kernel.org>
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
[ upstream commit 68fda450a7df51cff9e5a4d4a4d9d0d5f2589153 ]
due to some JITs doing if (src_reg == 0) check in 64-bit mode
for div/mod operations mask upper 32-bits of src register
before doing the check
Fixes: 622582786c9e ("net: filter: x86: internal BPF JIT")
Fixes: 7a12b5031c6b ("sparc64: Add eBPF JIT.")
Reported-by: syzbot+48340bb518e88849e2e3@syzkaller.appspotmail.com
[ upstream commit c366287ebd698ef5e3de300d90cd62ee9ee7373e ]
Divides by zero are not nice, lets avoid them if possible.
Also do_div() seems not needed when dealing with 32bit operands,
but this seems a minor detail.
Fixes: bd4cf0ed331a ("net: filter: rework/optimize internal BPF interpreter's instruction set")
Reported-by: syzbot <syzkaller@googlegroups.com>
[ upstream commit 7891a87efc7116590eaba57acc3c422487802c6f ]
The following snippet was throwing an 'unknown opcode cc' warning
in BPF interpreter:
0: (18) r0 = 0x0
2: (7b) *(u64 *)(r10 -16) = r0
3: (cc) (u32) r0 s>>= (u32) r0
4: (95) exit
Although a number of JITs do support BPF_ALU | BPF_ARSH | BPF_{K,X}
generation, not all of them do and interpreter does neither. We can
leave existing ones and implement it later in bpf-next for the
remaining ones, but reject this properly in verifier for the time
being.
Fixes: 17a5267067f3 ("bpf: verifier (add verifier core)")
Reported-by: syzbot+93c4904c5c70348a6890@syzkaller.appspotmail.com
[ upstream commit 290af86629b25ffd1ed6232c4e9107da031705cb ]
The BPF interpreter has been used as part of the spectre 2 attack CVE-2017-5715.
A quote from goolge project zero blog:
"At this point, it would normally be necessary to locate gadgets in
the host kernel code that can be used to actually leak data by reading
from an attacker-controlled location, shifting and masking the result
appropriately and then using the result of that as offset to an
attacker-controlled address for a load. But piecing gadgets together
and figuring out which ones work in a speculation context seems annoying.
So instead, we decided to use the eBPF interpreter, which is built into
the host kernel - while there is no legitimate way to invoke it from inside
a VM, the presence of the code in the host kernel's text section is sufficient
to make it usable for the attack, just like with ordinary ROP gadgets."
To make attacker job harder introduce BPF_JIT_ALWAYS_ON config
option that removes interpreter from the kernel in favor of JIT-only mode.
So far eBPF JIT is supported by:
x64, arm64, arm32, sparc64, s390, powerpc64, mips64
The start of JITed program is randomized and code page is marked as read-only.
In addition "constant blinding" can be turned on with net.core.bpf_jit_harden
v2->v3:
- move __bpf_prog_ret0 under ifdef (Daniel)
v1->v2:
- fix init order, test_bpf and cBPF (Daniel's feedback)
- fix offloaded bpf (Jakub's feedback)
- add 'return 0' dummy in case something can invoke prog->bpf_func
- retarget bpf tree. For bpf-next the patch would need one extra hunk.
It will be sent when the trees are merged back to net-next
Considered doing:
int bpf_jit_enable __read_mostly = BPF_EBPF_JIT_DEFAULT;
but it seems better to land the patch as-is and in bpf-next remove
bpf_jit_enable global variable from all JITs, consolidate in one place
and remove this jit_init() function.
[ upstream commit 90caccdd8cc0215705f18b92771b449b01e2474a ]
- bpf prog_array just like all other types of bpf array accepts 32-bit index.
Clarify that in the comment.
- fix x64 JIT of bpf_tail_call which was incorrectly loading 8 instead of 4 bytes
- tighten corresponding check in the interpreter to stay consistent
The JIT bug can be triggered after introduction of BPF_F_NUMA_NODE flag
in commit 96eabe7a40aa in 4.14. Before that the map_flags would stay zero and
though JIT code is wrong it will check bounds correctly.
Hence two fixes tags. All other JITs don't have this problem.
Fixes: 96eabe7a40aa ("bpf: Allow selecting numa node during map creation")
Fixes: b52f00e6a715 ("x86: bpf_jit: implement bpf_tail_call() helper")
Acked-by: Martin KaFai Lau <kafai@fb.com>
Reviewed-by: Eric Dumazet <edumazet@google.com>
[ Upstream commit c131187db2d3fa2f8bf32fdf4e9a4ef805168467 ]
when the verifier detects that register contains a runtime constant
and it's compared with another constant it will prune exploration
of the branch that is guaranteed not to be taken at runtime.
This is all correct, but malicious program may be constructed
in such a way that it always has a constant comparison and
the other branch is never taken under any conditions.
In this case such path through the program will not be explored
by the verifier. It won't be taken at run-time either, but since
all instructions are JITed the malicious program may cause JITs
to complain about using reserved fields, etc.
To fix the issue we have to track the instructions explored by
the verifier and sanitize instructions that are dead at run time
with NOPs. We cannot reject such dead code, since llvm generates
it for valid C code, since it doesn't do as much data flow
analysis as the verifier does.
commit d5421ea43d30701e03cadc56a38854c36a8b4433 upstream.
The hrtimer interrupt code contains a hang detection and mitigation
mechanism, which prevents that a long delayed hrtimer interrupt causes a
continous retriggering of interrupts which prevent the system from making
progress. If a hang is detected then the timer hardware is programmed with
a certain delay into the future and a flag is set in the hrtimer cpu base
which prevents newly enqueued timers from reprogramming the timer hardware
prior to the chosen delay. The subsequent hrtimer interrupt after the delay
clears the flag and resumes normal operation.
If such a hang happens in the last hrtimer interrupt before a CPU is
unplugged then the hang_detected flag is set and stays that way when the
CPU is plugged in again. At that point the timer hardware is not armed and
it cannot be armed because the hang_detected flag is still active, so
nothing clears that flag. As a consequence the CPU does not receive hrtimer
interrupts and no timers expire on that CPU which results in RCU stalls and
other malfunctions.
Clear the flag along with some other less critical members of the hrtimer
cpu base to ensure starting from a clean state when a CPU is plugged in.
Thanks to Paul, Sebastian and Anna-Maria for their help to get down to the
root cause of that hard to reproduce heisenbug. Once understood it's
trivial and certainly justifies a brown paperbag.
Fixes: 41d2e4949377 ("hrtimer: Tune hrtimer_interrupt hang logic")
Reported-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Sebastian Sewior <bigeasy@linutronix.de>
Cc: Anna-Maria Gleixner <anna-maria@linutronix.de>
Link: https://lkml.kernel.org/r/alpine.DEB.2.20.1801261447590.2067@nanos
commit b831275a3553c32091222ac619cfddd73a5553fb upstream.
Linus noticed that lock_timer_base() lacks a READ_ONCE() for accessing the
timer flags. As a consequence the compiler is allowed to reload the flags
between the initial check for TIMER_MIGRATION and the following timer base
computation and the spin lock of the base.
While this has not been observed (yet), we need to make sure that it never
happens.
Fixes: 0eeda71bc30d ("timer: Replace timer base by a cpu index")
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Link: http://lkml.kernel.org/r/alpine.DEB.2.20.1610241711220.4983@nanos
Signed-off-by: Mike Galbraith <mgalbraith@suse.de>
commit 979515c5645830465739254abc1b1648ada41518 upstream.
I ran into this:
UBSAN: Undefined behaviour in kernel/time/hrtimer.c:310:16
signed integer overflow:
9223372036854775807 + 50000 cannot be represented in type 'long long int'
CPU: 2 PID: 4798 Comm: trinity-c2 Not tainted 4.8.0-rc1+ #91
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.9.3-0-ge2fc41e-prebuilt.qemu-project.org 04/01/2014
0000000000000000 ffff88010ce6fb88 ffffffff82344740 0000000041b58ab3
ffffffff84f97a20 ffffffff82344694 ffff88010ce6fbb0 ffff88010ce6fb60
000000000000c350 ffff88010ce6f968 dffffc0000000000 ffffffff857bc320
Call Trace:
[<ffffffff82344740>] dump_stack+0xac/0xfc
[<ffffffff82344694>] ? _atomic_dec_and_lock+0xc4/0xc4
[<ffffffff8242df78>] ubsan_epilogue+0xd/0x8a
[<ffffffff8242e6b4>] handle_overflow+0x202/0x23d
[<ffffffff8242e4b2>] ? val_to_string.constprop.6+0x11e/0x11e
[<ffffffff8236df71>] ? timerqueue_add+0x151/0x410
[<ffffffff81485c48>] ? hrtimer_start_range_ns+0x3b8/0x1380
[<ffffffff81795631>] ? memset+0x31/0x40
[<ffffffff8242e6fd>] __ubsan_handle_add_overflow+0xe/0x10
[<ffffffff81488ac9>] hrtimer_nanosleep+0x5d9/0x790
[<ffffffff814884f0>] ? hrtimer_init_sleeper+0x80/0x80
[<ffffffff813a9ffb>] ? __might_sleep+0x5b/0x260
[<ffffffff8148be10>] common_nsleep+0x20/0x30
[<ffffffff814906c7>] SyS_clock_nanosleep+0x197/0x210
[<ffffffff81490530>] ? SyS_clock_getres+0x150/0x150
[<ffffffff823c7113>] ? __this_cpu_preempt_check+0x13/0x20
[<ffffffff8162ef60>] ? __context_tracking_exit.part.3+0x30/0x1b0
[<ffffffff81007bd3>] do_syscall_64+0x1b3/0x4b0
[<ffffffff845f85aa>] entry_SYSCALL64_slow_path+0x25/0x25
Add a new ktime_add_unsafe() helper which doesn't check for overflow, but
doesn't throw a UBSAN warning when it does overflow either.
Cc: Prarit Bhargava <prarit@redhat.com>
Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com>
commit 3effcb4247e74a51f5d8b775a1ee4abf87cc089a upstream.
We have been facing some problems with self-suspending constrained
deadline tasks. The main reason is that the original CBS was not
designed for such sort of tasks.
One problem reported by Xunlei Pang takes place when a task
suspends, and then is awakened before the deadline, but so close
to the deadline that its remaining runtime can cause the task
to have an absolute density higher than allowed. In such situation,
the original CBS assumes that the task is facing an early activation,
and so it replenishes the task and set another deadline, one deadline
in the future. This rule works fine for implicit deadline tasks.
Moreover, it allows the system to adapt the period of a task in which
the external event source suffered from a clock drift.
However, this opens the window for bandwidth leakage for constrained
deadline tasks. For instance, a task with the following parameters:
runtime = 5 ms
deadline = 7 ms
[density] = 5 / 7 = 0.71
period = 1000 ms
If the task runs for 1 ms, and then suspends for another 1ms,
it will be awakened with the following parameters:
remaining runtime = 4
laxity = 5
presenting a absolute density of 4 / 5 = 0.80.
In this case, the original CBS would assume the task had an early
wakeup. Then, CBS will reset the runtime, and the absolute deadline will
be postponed by one relative deadline, allowing the task to run.
The problem is that, if the task runs this pattern forever, it will keep
receiving bandwidth, being able to run 1ms every 2ms. Following this
behavior, the task would be able to run 500 ms in 1 sec. Thus running
more than the 5 ms / 1 sec the admission control allowed it to run.
Trying to address the self-suspending case, Luca Abeni, Giuseppe
Lipari, and Juri Lelli [1] revisited the CBS in order to deal with
self-suspending tasks. In the new approach, rather than
replenishing/postponing the absolute deadline, the revised wakeup rule
adjusts the remaining runtime, reducing it to fit into the allowed
density.
A revised version of the idea is:
At a given time t, the maximum absolute density of a task cannot be
higher than its relative density, that is:
runtime / (deadline - t) <= dl_runtime / dl_deadline
Knowing the laxity of a task (deadline - t), it is possible to move
it to the other side of the equality, thus enabling to define max
remaining runtime a task can use within the absolute deadline, without
over-running the allowed density:
runtime = (dl_runtime / dl_deadline) * (deadline - t)
For instance, in our previous example, the task could still run:
runtime = ( 5 / 7 ) * 5
runtime = 3.57 ms
Without causing damage for other deadline tasks. It is note worthy
that the laxity cannot be negative because that would cause a negative
runtime. Thus, this patch depends on the patch:
df8eac8cafce ("sched/deadline: Throttle a constrained deadline task activated after the deadline")
Which throttles a constrained deadline task activated after the
deadline.
Finally, it is also possible to use the revised wakeup rule for
all other tasks, but that would require some more discussions
about pros and cons.
[The main difference from the original commit is that
the BW_SHIFT define was not present yet. As BW_SHIFT was
introduced in a new feature, I just used the value (20),
likewise we used to use before the #define.
Other changes were required because of comments. - bistrot]
Reported-by: Xunlei Pang <xpang@redhat.com>
Signed-off-by: Daniel Bristot de Oliveira <bristot@redhat.com>
[peterz: replaced dl_is_constrained with dl_is_implicit]
Cc: Juri Lelli <juri.lelli@arm.com>
Cc: Luca Abeni <luca.abeni@santannapisa.it>
Cc: Romulo Silva de Oliveira <romulo.deoliveira@ufsc.br>
Cc: Tommaso Cucinotta <tommaso.cucinotta@sssup.it>
Link: http://lkml.kernel.org/r/5c800ab3a74a168a84ee5f3f84d12a02e11383be.1495803804.git.bristot@redhat.com
commit 1ebe1eaf2f02784921759992ae1fde1a9bec8fd0 upstream.
Since enums do not get converted by the TRACE_EVENT macro into their values,
the event format displaces the enum name and not the value. This breaks
tools like perf and trace-cmd that need to interpret the raw binary data. To
solve this, an enum map was created to convert these enums into their actual
numbers on boot up. This is done by TRACE_EVENTS() adding a
TRACE_DEFINE_ENUM() macro.
Some enums were not being converted. This was caused by an optization that
had a bug in it.
All calls get checked against this enum map to see if it should be converted
or not, and it compares the call's system to the system that the enum map
was created under. If they match, then they call is processed.
To cut down on the number of iterations needed to find the maps with a
matching system, since calls and maps are grouped by system, when a match is
made, the index into the map array is saved, so that the next call, if it
belongs to the same system as the previous call, could start right at that
array index and not have to scan all the previous arrays.
The problem was, the saved index was used as the variable to know if this is
a call in a new system or not. If the index was zero, it was assumed that
the call is in a new system and would keep incrementing the saved index
until it found a matching system. The issue arises when the first matching
system was at index zero. The next map, if it belonged to the same system,
would then think it was the first match and increment the index to one. If
the next call belong to the same system, it would begin its search of the
maps off by one, and miss the first enum that should be converted. This left
a single enum not converted properly.
Also add a comment to describe exactly what that index was for. It took me a
bit too long to figure out what I was thinking when debugging this issue.
Link: http://lkml.kernel.org/r/717BE572-2070-4C1E-9902-9F2E0FEDA4F8@oracle.com
Fixes: 0c564a538aa93 ("tracing: Add TRACE_DEFINE_ENUM() macro to map enums to their values")
Reported-by: Chuck Lever <chuck.lever@oracle.com>
Teste-by: Chuck Lever <chuck.lever@oracle.com>
commit ae83b56a56f8d9643dedbee86b457fa1c5d42f59 upstream.
When a contrained task is throttled by dl_check_constrained_dl(),
it may carry the remaining positive runtime, as a result when
dl_task_timer() fires and calls replenish_dl_entity(), it will
not be replenished correctly due to the positive dl_se->runtime.
This patch assigns its runtime to 0 if positive after throttling.
Signed-off-by: Xunlei Pang <xlpang@redhat.com>
Acked-by: Daniel Bristot de Oliveira <bristot@redhat.com>
Fixes: df8eac8cafce ("sched/deadline: Throttle a constrained deadline task activated after the deadline)
Link: http://lkml.kernel.org/r/1494421417-27550-1-git-send-email-xlpang@redhat.com
commit fbe0e839d1e22d88810f3ee3e2f1479be4c0aa4a upstream.
UBSAN reports signed integer overflow in kernel/futex.c:
UBSAN: Undefined behaviour in kernel/futex.c:2041:18
0 - -2147483648 cannot be represented in type 'int'
Add a sanity check to catch negative values of nr_wake and nr_requeue.
Signed-off-by: Li Jinyue <lijinyue@huawei.com>
Cc: peterz@infradead.org
Cc: dvhart@infradead.org
Link: https://lkml.kernel.org/r/1513242294-31786-1-git-send-email-lijinyue@huawei.com
commit cc622420798c4bcf093785d872525087a7798db9 upstream.
Enabling gcov is counterproductive to compile testing: it significantly
increases the kernel image size, compile time, and it produces lots
of false positive "may be used uninitialized" warnings as the result
of missed optimizations.
This is in line with how UBSAN_SANITIZE_ALL and PROFILE_ALL_BRANCHES
work, both of which have similar problems.
With an ARM allmodconfig kernel, I see the build time drop from
283 minutes CPU time to 225 minutes, and the vmlinux size drops
from 43MB to 26MB.
Acked-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com>
Signed-off-by: Michal Marek <mmarek@suse.com>
commit bbeb6e4323dad9b5e0ee9f60c223dd532e2403b1 upstream.
syzkaller tried to alloc a map with 0xfffffffd entries out of a userns,
and thus unprivileged. With the recently added logic in b2157399cc98
("bpf: prevent out-of-bounds speculation") we round this up to the next
power of two value for max_entries for unprivileged such that we can
apply proper masking into potentially zeroed out map slots.
However, this will generate an index_mask of 0xffffffff, and therefore
a + 1 will let this overflow into new max_entries of 0. This will pass
allocation, etc, and later on map access we still enforce on the original
attr->max_entries value which was 0xfffffffd, therefore triggering GPF
all over the place. Thus bail out on overflow in such case.
Moreover, on 32 bit archs roundup_pow_of_two() can also not be used,
since fls_long(max_entries - 1) can result in 32 and 1UL << 32 in 32 bit
space is undefined. Therefore, do this by hand in a 64 bit variable.
This fixes all the issues triggered by syzkaller's reproducers.
Fixes: b2157399cc98 ("bpf: prevent out-of-bounds speculation")
Reported-by: syzbot+b0efb8e572d01bce1ae0@syzkaller.appspotmail.com
Reported-by: syzbot+6c15e9744f75f2364773@syzkaller.appspotmail.com
Reported-by: syzbot+d2f5524fb46fd3b312ee@syzkaller.appspotmail.com
Reported-by: syzbot+61d23c95395cc90dbc2b@syzkaller.appspotmail.com
Reported-by: syzbot+0d363c942452cca68c01@syzkaller.appspotmail.com
commit b2157399cc9898260d6031c5bfe45fe137c1fbe7 upstream.
Under speculation, CPUs may mis-predict branches in bounds checks. Thus,
memory accesses under a bounds check may be speculated even if the
bounds check fails, providing a primitive for building a side channel.
To avoid leaking kernel data round up array-based maps and mask the index
after bounds check, so speculated load with out of bounds index will load
either valid value from the array or zero from the padded area.
Unconditionally mask index for all array types even when max_entries
are not rounded to power of 2 for root user.
When map is created by unpriv user generate a sequence of bpf insns
that includes AND operation to make sure that JITed code includes
the same 'index & index_mask' operation.
If prog_array map is created by unpriv user replace
bpf_tail_call(ctx, map, index);
with
if (index >= max_entries) {
index &= map->index_mask;
(along with roundup to power 2) to prevent out-of-bounds speculation.
There is secondary redundant 'if (index >= max_entries)' in the interpreter
and in all JITs, but they can be optimized later if necessary.
Other array-like maps (cpumap, devmap, sockmap, perf_event_array, cgroup_array)
cannot be used by unpriv, so no changes there.
That fixes bpf side of "Variant 1: bounds check bypass (CVE-2017-5753)" on
all architectures with and without JIT.
v2->v3:
Daniel noticed that attack potentially can be crafted via syscall commands
without loading the program, so add masking to those paths as well.
Acked-by: John Fastabend <john.fastabend@gmail.com>
commit 8041902dae5299c1f194ba42d14383f734631009 upstream.
convert_ctx_accesses() replaces single bpf instruction with a set of
instructions. Adjust corresponding insn_aux_data while patching.
It's needed to make sure subsequent 'for(all insn)' loops
have matching insn and insn_aux_data.
commit 79741b3bdec01a8628368fbcfccc7d189ed606cb upstream.
reduce indent and make it iterate over instructions similar to
convert_ctx_accesses(). Also convert hard BUG_ON into soft verifier error.
commit e245c5c6a5656e4d61aa7bb08e9694fd6e5b2b9d upstream.
no functional change.
move fixup_bpf_calls() to verifier.c
it's being refactored in the next patch
commit 3df126f35f88dc76eea33769f85a3c3bb8ce6c6b upstream.
Storing state in reserved fields of instructions makes
it impossible to run verifier on programs already
marked as read-only. Allocate and use an array of
per-instruction state instead.
While touching the error path rename and move existing
jump target.
Suggested-by: Alexei Starovoitov <ast@kernel.org>
Signed-off-by: Jakub Kicinski <jakub.kicinski@netronome.com>
Acked-by: Alexei Starovoitov <ast@kernel.org>
commit c237ee5eb33bf19fe0591c04ff8db19da7323a83 upstream.
Move the functionality to patch instructions out of the verifier
code and into the core as the new bpf_patch_insn_single() helper
will be needed later on for blinding as well. No changes in
functionality.
commit 1329ce6fbbe4536592dfcfc8d64d61bfeb598fe6 upstream.
Make use of wake-queues and enable the wakeup to occur after releasing the
wait_lock. This is similar to what we do with rtmutex top waiter,
slightly shortening the critical region and allow other waiters to
acquire the wait_lock sooner. In low contention cases it can also help
the recently woken waiter to find the wait_lock available (fastpath)
when it continues execution.
Reviewed-by: Waiman Long <Waiman.Long@hpe.com>
Signed-off-by: Davidlohr Bueso <dbueso@suse.de>
Cc: Ding Tianhong <dingtianhong@huawei.com>
Cc: Jason Low <jason.low2@hp.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Paul E. McKenney <paulmck@us.ibm.com>
Cc: Tim Chen <tim.c.chen@linux.intel.com>
Cc: Waiman Long <waiman.long@hpe.com>
Cc: Will Deacon <Will.Deacon@arm.com>
Link: http://lkml.kernel.org/r/20160125022343.GA3322@linux-uzut.site
commit 29b75eb2d56a714190a93d7be4525e617591077a upstream.
Commit e91467ecd1ef ("bug in futex unqueue_me") introduced a barrier() in
unqueue_me() to prevent the compiler from rereading the lock pointer which
might change after a check for NULL.
Replace the barrier() with a READ_ONCE() for the following reasons:
1) READ_ONCE() is a weaker form of barrier() that affects only the specific
load operation, while barrier() is a general compiler level memory barrier.
READ_ONCE() was not available at the time when the barrier was added.
2) Aside of that READ_ONCE() is descriptive and self explainatory while a
barrier without comment is not clear to the casual reader.
No functional change.
Signed-off-by: Jianyu Zhan <nasa4836@gmail.com>
Acked-by: Christian Borntraeger <borntraeger@de.ibm.com>
Acked-by: Darren Hart <dvhart@linux.intel.com>
Cc: dave@stgolabs.net
Cc: linux@rasmusvillemoes.dk
Cc: akpm@linux-foundation.org
Cc: fengguang.wu@intel.com
Cc: bigeasy@linutronix.de
Link: http://lkml.kernel.org/r/1457314344-5685-1-git-send-email-nasa4836@gmail.com
commit 3205c36cf7d96024626f92d65f560035df1abcb2 upstream.
While most of the locations where a kernel taint bit is set are accompanied
with a warning message, there are two which set their bits silently. If
the tainting module gets unloaded later on, it is almost impossible to tell
what was the reason for setting the flag.
Signed-off-by: Libor Pechacek <lpechacek@suse.com>
