commit 88be12c440cfa2fa3f5be83507360aac9ea1c54e upstream.
Otherwise we can get an oops if the user has no get_ref/put_ref
requirement.
Cc: Kurt Garloff <garloff@suse.de>
commit cd8ad40de36c2fe75f3b731bd70198b385895246 upstream.
When setting the weight for a per-cpu task-group, we have to put in a
phantom weight when there is no work on that cpu, otherwise we'll not
service that cpu when new work gets placed there until we again update
the per-cpu weights.
We used to add these phantom weights to the total, so that the idle
per-cpu shares don't get inflated, this however causes the non-idle
parts to get deflated, causing unexpected weight distibutions.
Reverse this, so that the non-idle shares are correct but the idle
shares are inflated.
Reported-by: Yasunori Goto <y-goto@jp.fujitsu.com>
Tested-by: Yasunori Goto <y-goto@jp.fujitsu.com>
LKML-Reference: <1257934048.23203.76.camel@twins>
commit 7a0ea09ad5352efce8fe79ed853150449903b9f5 upstream.
futex_find_get_task is currently used (through lookup_pi_state) from two
contexts, futex_requeue and futex_lock_pi_atomic. None of the paths
looks it needs the credentials check, though. Different (e)uids
shouldn't matter at all because the only thing that is important for
shared futex is the accessibility of the shared memory.
The credentail check results in glibc assert failure or process hang (if
glibc is compiled without assert support) for shared robust pthread
mutex with priority inheritance if a process tries to lock already held
lock owned by a process with a different euid:
pthread_mutex_lock.c:312: __pthread_mutex_lock_full: Assertion `(-(e)) != 3 || !robust' failed.
The problem is that futex_lock_pi_atomic which is called when we try to
lock already held lock checks the current holder (tid is stored in the
futex value) to get the PI state. It uses lookup_pi_state which in turn
gets task struct from futex_find_get_task. ESRCH is returned either
when the task is not found or if credentials check fails.
futex_lock_pi_atomic simply returns if it gets ESRCH. glibc code,
however, doesn't expect that robust lock returns with ESRCH because it
should get either success or owner died.
Acked-by: Darren Hart <dvhltc@us.ibm.com>
Cc: Nick Piggin <npiggin@suse.de>
Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
commit 4673247562e39a17e09440fa1400819522ccd446 upstream.
The set_type() function can change the chip implementation when the
trigger mode changes. That might result in using an non-initialized
irq chip when called from __setup_irq() or when called via
set_irq_type() on an already enabled irq.
The set_irq_type() function should not be called on an enabled irq,
but because we forgot to put a check into it, we have a bunch of users
which grew the habit of doing that and it never blew up as the
function is serialized via desc->lock against all users of desc->chip
and they never hit the non-initialized irq chip issue.
The easy fix for the __setup_irq() issue would be to move the
irq_chip_set_defaults(desc->chip) call after the trigger setting to
make sure that a chip change is covered.
But as we have already users, which do the type setting after
request_irq(), the safe fix for now is to call irq_chip_set_defaults()
from __irq_set_trigger() when desc->set_type() changed the irq chip.
It needs a deeper analysis whether we should refuse to change the chip
on an already enabled irq, but that'd be a large scale change to fix
all the existing users. So that's neither stable nor 2.6.35 material.
Reported-by: Esben Haabendal <eha@doredevelopment.dk>
Cc: linuxppc-dev <linuxppc-dev@ozlabs.org>
commit 3c93717cfa51316e4dbb471e7c0f9d243359d5f8 upstream.
Commit e70971591 ("sched: Optimize unused cgroup configuration") introduced
an imbalanced scheduling bug.
If we do not use CGROUP, function update_h_load won't update h_load. When the
system has a large number of tasks far more than logical CPU number, the
incorrect cfs_rq[cpu]->h_load value will cause load_balance() to pull too
many tasks to the local CPU from the busiest CPU. So the busiest CPU keeps
going in a round robin. That will hurt performance.
The issue was found originally by a scientific calculation workload that
developed by Yanmin. With that commit, the workload performance drops
about 40%.
CPU before after
00 : 2 : 7
01 : 1 : 7
02 : 11 : 6
03 : 12 : 7
04 : 6 : 6
05 : 11 : 7
06 : 10 : 6
07 : 12 : 7
08 : 11 : 6
09 : 12 : 6
10 : 1 : 6
11 : 1 : 6
12 : 6 : 6
13 : 2 : 6
14 : 2 : 6
15 : 1 : 6
Reviewed-by: Yanmin zhang <yanmin.zhang@intel.com>
Signed-off-by: Alex Shi <alex.shi@intel.com>
LKML-Reference: <1276754893.9452.5442.camel@debian>
commit 0d98bb2656e9bd2dfda2d089db1fe1dbdab41504 upstream.
GCC 4.4.1 on ARM has been observed to replace the while loop in
sched_avg_update with a call to uldivmod, resulting in the
following build failure at link-time:
kernel/built-in.o: In function `sched_avg_update':
kernel/sched.c:1261: undefined reference to `__aeabi_uldivmod'
make: *** [.tmp_vmlinux1] Error 1
This patch introduces a fake data hazard to the loop body to
prevent the compiler optimising the loop away.
Acked-by: Peter Zijlstra <peterz@infradead.org>
commit b82bab4bbe9efa7bc7177fc20620fff19bd95484 upstream.
The command
echo "file ec.c +p" >/sys/kernel/debug/dynamic_debug/control
causes an oops.
Move the call to ddebug_remove_module() down into free_module(). In this
way it should be called from all error paths. Currently, we are missing
the remove if the module init routine fails.
Signed-off-by: Jason Baron <jbaron@redhat.com>
Reported-by: Thomas Renninger <trenn@suse.de>
Tested-by: Thomas Renninger <trenn@suse.de>
commit 065add3941bdca54fe04ed3471a96bce9af88793 upstream.
Andrew Tridgell reports that aio_read(SIGEV_SIGNAL) can fail if the
notification from the helper thread races with setresuid(), see
http://samba.org/~tridge/junkcode/aio_uid.c
This happens because check_kill_permission() doesn't permit sending a
signal to the task with the different cred->xids. But there is not any
security reason to check ->cred's when the task sends a signal (private or
group-wide) to its sub-thread. Whatever we do, any thread can bypass all
security checks and send SIGKILL to all threads, or it can block a signal
SIG and do kill(gettid(), SIG) to deliver this signal to another
sub-thread. Not to mention that CLONE_THREAD implies CLONE_VM.
Change check_kill_permission() to avoid the credentials check when the
sender and the target are from the same thread group.
Also, move "cred = current_cred()" down to avoid calling get_current()
twice.
Note: David Howells pointed out we could relax this even more, the
CLONE_SIGHAND (without CLONE_THREAD) case probably does not need
these checks too.
Roland said:
: The glibc (libpthread) that does set*id across threads has
: been in use for a while (2.3.4?), probably in distro's using kernels as old
: or older than any active -stable streams. In the race in question, this
: kernel bug is breaking valid POSIX application expectations.
Reported-by: Andrew Tridgell <tridge@samba.org>
Acked-by: Roland McGrath <roland@redhat.com>
Cc: Eric Paris <eparis@parisplace.org>
Cc: Jakub Jelinek <jakub@redhat.com>
Cc: Roland McGrath <roland@redhat.com>
Cc: Stephen Smalley <sds@tycho.nsa.gov>
commit fd6be105b883244127a734ac9f14ae94a022dcc0 upstream.
Currently, we can hit a nasty case with optimistic
spinning on mutexes:
CPU A tries to take a mutex, while holding the BKL
CPU B tried to take the BLK while holding the mutex
This looks like a AB-BA scenario but in practice, is
allowed and happens due to the auto-release on
schedule() nature of the BKL.
In that case, the optimistic spinning code can get us
into a situation where instead of going to sleep, A
will spin waiting for B who is spinning waiting for
A, and the only way out of that loop is the
need_resched() test in mutex_spin_on_owner().
This patch fixes it by completely disabling spinning
if we own the BKL. This adds one more detail to the
extensive list of reasons why it's a bad idea for
kernel code to be holding the BKL.
Signed-off-by: Tony Breeds <tony@bakeyournoodle.com>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
LKML-Reference: <20100519054636.GC12389@ozlabs.org>
[ added an unlikely() attribute to the branch ]
commit 45e0fffc8a7778282e6a1514a6ae3e7ae6545111 upstream.
Move CLOCK_DISPATCH(which_clock, timer_create, (new_timer)) after all
posible EFAULT erros.
*_timer_create may allocate/get resources.
(for example posix_cpu_timer_create does get_task_struct)
[ tglx: fold the remove crappy comment patch into this ]
Signed-off-by: Andrey Vagin <avagin@openvz.org>
Cc: Oleg Nesterov <oleg@tv-sign.ru>
Cc: Pavel Emelyanov <xemul@openvz.org>
Reviewed-by: Stanislaw Gruszka <sgruszka@redhat.com>
commit ea635c64e007061f6468ece5cc9cc62d41d4ecf2 upstream.
once anon_inode_getfd() is called, you can't expect *anything* about
struct file that descriptor points to - another thread might be doing
whatever it likes with descriptor table at that point.
commit fa9dc265ace9774e62f0e31108e5f47911124bda upstream.
Commit a45185d2d "cpumask: convert kernel/compat.c" broke libnuma, which
abuses sched_getaffinity to find out NR_CPUS in order to parse
/sys/devices/system/node/node*/cpumap.
On NUMA systems with less than 32 possibly CPUs, the current
compat_sys_sched_getaffinity now returns '4' instead of the actual
NR_CPUS/8, which makes libnuma bail out when parsing the cpumap.
The libnuma call sched_getaffinity(0, bitmap, 4096) at first. It mean
the libnuma expect the return value of sched_getaffinity() is either len
argument or NR_CPUS. But it doesn't expect to return nr_cpu_ids.
Strictly speaking, userland requirement are
1) Glibc assume the return value mean the lengh of initialized
of mask argument. E.g. if sched_getaffinity(1024) return 128,
glibc make zero fill rest 896 byte.
2) Libnuma assume the return value can be used to guess NR_CPUS
in kernel. It assume len-arg<NR_CPUS makes -EINVAL. But
it try len=4096 at first and 4096 is always bigger than
NR_CPUS. Then, if we remove strange min_length normalization,
we never hit -EINVAL case.
sched_getaffinity() already solved this issue. This patch adapts
compat_sys_sched_getaffinity() to match the non-compat case.
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
Reported-by: Ken Werner <ken.werner@web.de>
This reverts commit ea0a09acd81c6d52c77d80f0d4089795df7bcb58.
It should not have been applied to the .32 kernel tree.
This reverts commit b6b3dcd55e2327a968833ff3f22eda3b8dd7ef9e.
commit 34441427aab4bdb3069a4ffcda69a99357abcb2e upstream.
Originally, commit d899bf7b ("procfs: provide stack information for
threads") attempted to introduce a new feature for showing where the
threadstack was located and how many pages are being utilized by the
stack.
Commit c44972f1 ("procfs: disable per-task stack usage on NOMMU") was
applied to fix the NO_MMU case.
Commit 89240ba0 ("x86, fs: Fix x86 procfs stack information for threads on
64-bit") was applied to fix a bug in ia32 executables being loaded.
Commit 9ebd4eba7 ("procfs: fix /proc/<pid>/stat stack pointer for kernel
threads") was applied to fix a bug which had kernel threads printing a
userland stack address.
Commit 1306d603f ('proc: partially revert "procfs: provide stack
information for threads"') was then applied to revert the stack pages
being used to solve a significant performance regression.
This patch nearly undoes the effect of all these patches.
The reason for reverting these is it provides an unusable value in
field 28. For x86_64, a fork will result in the task->stack_start
value being updated to the current user top of stack and not the stack
start address. This unpredictability of the stack_start value makes
it worthless. That includes the intended use of showing how much stack
space a thread has.
Other architectures will get different values. As an example, ia64
gets 0. The do_fork() and copy_process() functions appear to treat the
stack_start and stack_size parameters as architecture specific.
I only partially reverted c44972f1 ("procfs: disable per-task stack usage
on NOMMU") . If I had completely reverted it, I would have had to change
mm/Makefile only build pagewalk.o when CONFIG_PROC_PAGE_MONITOR is
configured. Since I could not test the builds without significant effort,
I decided to not change mm/Makefile.
I only partially reverted 89240ba0 ("x86, fs: Fix x86 procfs stack
information for threads on 64-bit") . I left the KSTK_ESP() change in
place as that seemed worthwhile.
Signed-off-by: Robin Holt <holt@sgi.com>
Cc: Stefani Seibold <stefani@seibold.net>
commit 16a2164bb03612efe79a76c73da6da44445b9287 upstream.
If the kernel is large or the profiling step small, /proc/profile
leaks data and readprofile shows silly stats, until readprofile -r
has reset the buffer: clear the prof_buffer when it is vmalloc()ed.
commit 86c38a31aa7f2dd6e74a262710bf8ebf7455acc5 upstream.
GCC 4.5 introduces behavior that forces the alignment of structures to
use the largest possible value. The default value is 32 bytes, so if
some structures are defined with a 4-byte alignment and others aren't
declared with an alignment constraint at all - it will align at 32-bytes.
For things like the ftrace events, this results in a non-standard array.
When initializing the ftrace subsystem, we traverse the _ftrace_events
section and call the initialization callback for each event. When the
structures are misaligned, we could be treating another part of the
structure (or the zeroed out space between them) as a function pointer.
This patch forces the alignment for all the ftrace_event_call structures
to 4 bytes.
Without this patch, the kernel fails to boot very early when built with
gcc 4.5.
It's trivial to check the alignment of the members of the array, so it
might be worthwhile to add something to the build system to do that
automatically. Unfortunately, that only covers this case. I've asked one
of the gcc developers about adding a warning when this condition is seen.
Cc: stable@kernel.org
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
LKML-Reference: <4B85770B.6010901@suse.com>
Cc: Andreas Radke <a.radke@arcor.de>
commit e134d200d57d43b171dcb0b55c178a1a0c7db14a upstream.
creds_are_invalid() reads both cred->usage and cred->subscribers and then
compares them to make sure the number of processes subscribed to a cred struct
never exceeds the refcount of that cred struct.
The problem is that this can cause a race with both copy_creds() and
exit_creds() as the two counters, whilst they are of atomic_t type, are only
atomic with respect to themselves, and not atomic with respect to each other.
This means that if creds_are_invalid() can read the values on one CPU whilst
they're being modified on another CPU, and so can observe an evolving state in
which the subscribers count now is greater than the usage count a moment
before.
Switching the order in which the counts are read cannot help, so the thing to
do is to remove that particular check.
I had considered rechecking the values to see if they're in flux if the test
fails, but I can't guarantee they won't appear the same, even if they've
changed several times in the meantime.
Note that this can only happen if CONFIG_DEBUG_CREDENTIALS is enabled.
The problem is only likely to occur with multithreaded programs, and can be
tested by the tst-eintr1 program from glibc's "make check". The symptoms look
like:
CRED: Invalid credentials
CRED: At include/linux/cred.h:240
CRED: Specified credentials: ffff88003dda5878 [real][eff]
CRED: ->magic=43736564, put_addr=(null)
CRED: ->usage=766, subscr=766
CRED: ->*uid = { 0,0,0,0 }
CRED: ->*gid = { 0,0,0,0 }
CRED: ->security is ffff88003d72f538
CRED: ->security {359, 359}
kernel BUG at kernel/cred.c:850!
RIP: 0010:[<ffffffff81049889>] [<ffffffff81049889>] __invalid_creds+0x4e/0x52
Call Trace:
[<ffffffff8104a37b>] copy_creds+0x6b/0x23f
Note the ->usage=766 and subscr=766. The values appear the same because
they've been re-read since the check was made.
Reported-by: Roland McGrath <roland@redhat.com>
Signed-off-by: James Morris <jmorris@namei.org>
commit 048c852051d2bd5da54a4488bc1f16b0fc74c695 upstream.
perf_event_open() kfrees event after init failure which doesn't
release all resources allocated by perf_event_alloc(). Use
free_event() instead.
Cc: Paul Mackerras <paulus@au1.ibm.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
LKML-Reference: <4BDBE237.1040809@kernel.org>
commit 8bc037fb89bb3104b9ae290d18c877624cd7d9cc upstream.
Using the proper type fixes the following compiler warning:
kernel/sched.c:4850: warning: comparison of distinct pointer types lacks a cast
Cc: torvalds@linux-foundation.org
Cc: travis@sgi.com
Cc: peterz@infradead.org
Cc: drepper@redhat.com
Cc: rja@sgi.com
Cc: sharyath@in.ibm.com
Cc: steiner@sgi.com
LKML-Reference: <20100317090046.4C79.A69D9226@jp.fujitsu.com>
The mainline kernel as of 2.6.34-rc5 is not affected by this problem because
commit 10fad5e46f6c7bdfb01b1a012380a38e3c6ab346 fixed it by refactoring.
lockdep fix incorrect percpu usage
Should use per_cpu_ptr() to obfuscate the per cpu pointers (RELOC_HIDE is needed
for per cpu pointers).
git blame points to commit:
lockdep.c: commit 8e18257d29238311e82085152741f0c3aa18b74d
But it's really just moving the code around. But it's enough to say that the
problems appeared before Jul 19 01:48:54 2007, which brings us back to 2.6.23.
It should be applied to stable 2.6.23.x to 2.6.33.x (or whichever of these
stable branches are still maintained).
(tested on 2.6.33.1 x86_64)
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
CC: Randy Dunlap <randy.dunlap@oracle.com>
CC: Eric Dumazet <dada1@cosmosbay.com>
CC: Rusty Russell <rusty@rustcorp.com.au>
CC: Peter Zijlstra <a.p.zijlstra@chello.nl>
CC: Tejun Heo <tj@kernel.org>
CC: Ingo Molnar <mingo@elte.hu>
CC: Andrew Morton <akpm@linux-foundation.org>
CC: Linus Torvalds <torvalds@linux-foundation.org>
CC: Greg Kroah-Hartman <gregkh@suse.de>
CC: Steven Rostedt <rostedt@goodmis.org>
Mainline does not need this fix, as commit
259354deaaf03d49a02dbb9975d6ec2a54675672 fixed the problem by refactoring.
Introduced by commit:
module.c: commit 6b588c18f8dacfa6d7957c33c5ff832096e752d3
This patch should be queued for the stable branch, for kernels 2.6.29.x to
2.6.33.x. (tested on 2.6.33.1 x86_64)
Based on commit e2912009fb7b715728311b0d8fe327a1432b3f79 upstream, but
done differently as this issue is not present in .33 or .34 kernels due
to rework in this area.
If a task is in the TASK_WAITING state, then try_to_wake_up() is working
on it, and it will place it on the correct cpu.
This commit ensures that neither migrate_task() nor __migrate_task()
calls set_task_cpu(p) while p is in the TASK_WAKING state. Otherwise,
there could be two concurrent calls to set_task_cpu(p), resulting in
the task's cfs_rq being inconsistent with its cpu.
Signed-off-by: John Wright <john.wright@hp.com>
commit 84fba5ec91f11c0efb27d0ed6098f7447491f0df upstream.
taskset on 2.6.34-rc3 fails on one of my ppc64 test boxes with
the following error:
sched_getaffinity(0, 16, 0x10029650030) = -1 EINVAL (Invalid argument)
This box has 128 threads and 16 bytes is enough to cover it.
Commit cd3d8031eb4311e516329aee03c79a08333141f1 (sched:
sched_getaffinity(): Allow less than NR_CPUS length) is
comparing this 16 bytes agains nr_cpu_ids.
Fix it by comparing nr_cpu_ids to the number of bits in the
cpumask we pass in.
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Cc: Sharyathi Nagesh <sharyath@in.ibm.com>
Cc: Ulrich Drepper <drepper@redhat.com>
Cc: Jack Steiner <steiner@sgi.com>
Cc: Russ Anderson <rja@sgi.com>
Cc: Mike Travis <travis@sgi.com>
LKML-Reference: <20100406070218.GM5594@kryten>
commit cd3d8031eb4311e516329aee03c79a08333141f1 upstream.
[ Note, this commit changes the syscall ABI for > 1024 CPUs systems. ]
Recently, some distro decided to use NR_CPUS=4096 for mysterious reasons.
Unfortunately, glibc sched interface has the following definition:
# define __CPU_SETSIZE 1024
# define __NCPUBITS (8 * sizeof (__cpu_mask))
typedef unsigned long int __cpu_mask;
typedef struct
__cpu_mask __bits[__CPU_SETSIZE / __NCPUBITS];
} cpu_set_t;
It mean, if NR_CPUS is bigger than 1024, cpu_set_t makes an
ABI issue ...
More recently, Sharyathi Nagesh reported following test program makes
misterious syscall failure:
#define _GNU_SOURCE
#include<stdio.h>
#include<errno.h>
#include<sched.h>
int main()
cpu_set_t set;
if (sched_getaffinity(0, sizeof(cpu_set_t), &set) < 0)
printf("\n Call is failing with:%d", errno);
Because the kernel assumes len argument of sched_getaffinity() is bigger
than NR_CPUS. But now it is not correct.
Now we are faced with the following annoying dilemma, due to
the limitations of the glibc interface built in years ago:
(1) if we change glibc's __CPU_SETSIZE definition, we lost
binary compatibility of _all_ application.
(2) if we don't change it, we also lost binary compatibility of
Sharyathi's use case.
Then, I would propse to change the rule of the len argument of
sched_getaffinity().
Old:
len should be bigger than NR_CPUS
New:
len should be bigger than maximum possible cpu id
This creates the following behavior:
(A) In the real 4096 cpus machine, the above test program still
return -EINVAL.
(B) NR_CPUS=4096 but the machine have less than 1024 cpus (almost
all machines in the world), the above can run successfully.
Fortunatelly, BIG SGI machine is mainly used for HPC use case. It means
they can rebuild their programs.
IOW we hope they are not annoyed by this issue ...
Reported-by: Sharyathi Nagesh <sharyath@in.ibm.com>
Acked-by: Ulrich Drepper <drepper@redhat.com>
LKML-Reference: <20100312161316.9520.A69D9226@jp.fujitsu.com>
commit 753649dbc49345a73a2454c770a3f2d54d11aec6 upstream.
Network folks reported that directing all MSI-X vectors of their multi
queue NICs to a single core can cause interrupt stack overflows when
enough interrupts fire at the same time.
This is caused by the fact that we run interrupt handlers by default
with interrupts enabled unless the driver reuqests the interrupt with
the IRQF_DISABLED set. The NIC handlers do not set this flag, so
simultaneous interrupts can nest unlimited and cause the stack
overflow.
The only safe counter measure is to run the interrupt handlers with
interrupts disabled. We can't switch to this mode in general right
now, but it is safe to do so for MSI interrupts.
Force IRQF_DISABLED for MSI interrupt handlers.
Cc: Linus Torvalds <torvalds@osdl.org>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
commit 5a7aadfe2fcb0f69e2acc1fbefe22a096e792fc9 upstream.
When the cgroup freezer is used to freeze tasks we do not want to thaw
those tasks during resume. Currently we test the cgroup freezer
state of the resuming tasks to see if the cgroup is FROZEN. If so
then we don't thaw the task. However, the FREEZING state also indicates
that the task should remain frozen.
This also avoids a problem pointed out by Oren Ladaan: the freezer state
transition from FREEZING to FROZEN is updated lazily when userspace reads
or writes the freezer.state file in the cgroup filesystem. This means that
resume will thaw tasks in cgroups which should be in the FROZEN state if
there is no read/write of the freezer.state file to trigger this
transition before suspend.
NOTE: Another "simple" solution would be to always update the cgroup
freezer state during resume. However it's a bad choice for several reasons:
Updating the cgroup freezer state is somewhat expensive because it requires
walking all the tasks in the cgroup and checking if they are each frozen.
Worse, this could easily make resume run in N^2 time where N is the number
of tasks in the cgroup. Finally, updating the freezer state from this code
path requires trickier locking because of the way locks must be ordered.
Instead of updating the freezer state we rely on the fact that lazy
updates only manage the transition from FREEZING to FROZEN. We know that
a cgroup with the FREEZING state may actually be FROZEN so test for that
state too. This makes sense in the resume path even for partially-frozen
cgroups -- those that really are FREEZING but not FROZEN.
Reported-by: Oren Ladaan <orenl@cs.columbia.edu>
Signed-off-by: Matt Helsley <matthltc@us.ibm.com>
commit 8c2eb4805d422bdbf60ba00ff233c794d23c3c00 upstream.
Ensure additions on touch_ts do not overflow. This can occur
when the top 32 bits of the TSC reach 0xffffffff causing
additions to touch_ts to overflow and this in turn generates
spurious softlockup warnings.
LKML-Reference: <1268994482.1798.6.camel@lenovo>
commit 5ab116c9349ef52d6fbd2e2917a53f13194b048e upstream.
cpuset_mem_spread_node() returns an offline node, and causes an oops.
This patch fixes it by initializing task->mems_allowed to
node_states[N_HIGH_MEMORY], and updating task->mems_allowed when doing
memory hotplug.
Signed-off-by: Miao Xie <miaox@cn.fujitsu.com>
Acked-by: David Rientjes <rientjes@google.com>
Reported-by: Nick Piggin <npiggin@suse.de>
Tested-by: Nick Piggin <npiggin@suse.de>
Cc: Paul Menage <menage@google.com>
Cc: Li Zefan <lizf@cn.fujitsu.com>
commit 220b140b52ab6cc133f674a7ffec8fa792054f25 upstream.
Anton Blanchard found that he could reliably make the kernel hit a
BUG_ON in the slab allocator by taking a cpu offline and then online
while a system-wide perf record session was running.
The reason is that when the cpu comes up, we completely reinitialize
the ctx field of the struct perf_cpu_context for the cpu. If there is
a system-wide perf record session running, then there will be a struct
perf_event that has a reference to the context, so its refcount will
be 2. (The perf_event has been removed from the context's group_entry
and event_entry lists by perf_event_exit_cpu(), but that doesn't
remove the perf_event's reference to the context and doesn't decrement
the context's refcount.)
When the cpu comes up, perf_event_init_cpu() gets called, and it calls
__perf_event_init_context() on the cpu's context. That resets the
refcount to 1. Then when the perf record session finishes and the
perf_event is closed, the refcount gets decremented to 0 and the
context gets kfreed after an RCU grace period. Since the context
wasn't kmalloced -- it's part of a per-cpu variable -- bad things
happen.
In fact we don't need to completely reinitialize the context when the
cpu comes up. It's sufficient to initialize the context once at boot,
but we need to do it for all possible cpus.
This moves the context initialization to happen at boot time. With
this, we don't trash the refcount and the context never gets kfreed,
and we don't hit the BUG_ON.
Reported-by: Anton Blanchard <anton@samba.org>
Tested-by: Anton Blanchard <anton@samba.org>
commit dd5feea14a7de4edbd9f36db1a2db785de91b88d upstream
On platforms like dual socket quad-core platform, the scheduler load
balancer is not detecting the load imbalances in certain scenarios. This
is leading to scenarios like where one socket is completely busy (with
all the 4 cores running with 4 tasks) and leaving another socket
completely idle. This causes performance issues as those 4 tasks share
the memory controller, last-level cache bandwidth etc. Also we won't be
taking advantage of turbo-mode as much as we would like, etc.
Some of the comparisons in the scheduler load balancing code are
comparing the "weighted cpu load that is scaled wrt sched_group's
cpu_power" with the "weighted average load per task that is not scaled
wrt sched_group's cpu_power". While this has probably been broken for a
longer time (for multi socket numa nodes etc), the problem got aggrevated
via this recent change:
| commit f93e65c186ab3c05ce2068733ca10e34fd00125e
| Author: Peter Zijlstra <a.p.zijlstra@chello.nl>
| Date: Tue Sep 1 10:34:32 2009 +0200
| sched: Restore __cpu_power to a straight sum of power
Also with this change, the sched group cpu power alone no longer reflects
the group capacity that is needed to implement MC, MT performance
(default) and power-savings (user-selectable) policies.
We need to use the computed group capacity (sgs.group_capacity, that is
computed using the SD_PREFER_SIBLING logic in update_sd_lb_stats()) to
find out if the group with the max load is above its capacity and how
much load to move etc.
Reported-by: Ma Ling <ling.ma@intel.com>
Initial-Analysis-by: Zhang, Yanmin <yanmin_zhang@linux.intel.com>
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
[ -v2: build fix ]
LKML-Reference: <1266970432.11588.22.camel@sbs-t61.sc.intel.com>
commit 41d2e494937715d3150e5c75d01f0e75ae899337 upstream.
The hrtimer_interrupt hang logic adjusts min_delta_ns based on the
execution time of the hrtimer callbacks.
This is error-prone for virtual machines, where a guest vcpu can be
scheduled out during the execution of the callbacks (and the callbacks
themselves can do operations that translate to blocking operations in
the hypervisor), which in can lead to large min_delta_ns rendering the
system unusable.
Replace the current heuristics with something more reliable. Allow the
interrupt code to try 3 times to catch up with the lost time. If that
fails use the total time spent in the interrupt handler to defer the
next timer interrupt so the system can catch up with other things
which got delayed. Limit that deferment to 100ms.
The retry events and the maximum time spent in the interrupt handler
are recorded and exposed via /proc/timer_list
Inspired by a patch from Marcelo.
Reported-by: Michael Tokarev <mjt@tls.msk.ru>
Tested-by: Marcelo Tosatti <mtosatti@redhat.com>
Cc: kvm@vger.kernel.org
commit b6345879ccbd9b92864fbd7eb8ac48acdb4d6b15 upstream.
A bug was found with Li Zefan's ftrace_stress_test that caused applications
to segfault during the test.
Placing a tracing_off() in the segfault code, and examining several
traces, I found that the following was always the case. The lock tracer
was enabled (lockdep being required) and userstack was enabled. Testing
this out, I just enabled the two, but that was not good enough. I needed
to run something else that could trigger it. Running a load like hackbench
did not work, but executing a new program would. The following would
trigger the segfault within seconds:
# echo 1 > /debug/tracing/options/userstacktrace
# echo 1 > /debug/tracing/events/lock/enable
# while :; do ls > /dev/null ; done
Enabling the function graph tracer and looking at what was happening
I finally noticed that all cashes happened just after an NMI.
1) | copy_user_handle_tail() {
1) | bad_area_nosemaphore() {
1) | __bad_area_nosemaphore() {
1) | no_context() {
1) | fixup_exception() {
1) 0.319 us | search_exception_tables();
1) 0.873 us | }
1) 0.314 us | __rcu_read_unlock();
1) 0.325 us | native_apic_mem_write();
1) 0.943 us | }
1) 0.304 us | rcu_nmi_exit();
1) 0.479 us | find_vma();
1) | bad_area() {
1) | __bad_area() {
After capturing several traces of failures, all of them happened
after an NMI. Curious about this, I added a trace_printk() to the NMI
handler to read the regs->ip to see where the NMI happened. In which I
found out it was here:
ffffffff8135b660 <page_fault>:
ffffffff8135b660: 48 83 ec 78 sub $0x78,%rsp
ffffffff8135b664: e8 97 01 00 00 callq ffffffff8135b800 <error_entry>
What was happening is that the NMI would happen at the place that a page
fault occurred. It would call rcu_read_lock() which was traced by
the lock events, and the user_stack_trace would run. This would trigger
a page fault inside the NMI. I do not see where the CR2 register is
saved or restored in NMI handling. This means that it would corrupt
the page fault handling that the NMI interrupted.
The reason the while loop of ls helped trigger the bug, was that
each execution of ls would cause lots of pages to be faulted in, and
increase the chances of the race happening.
The simple solution is to not allow user stack traces in NMI context.
After this patch, I ran the above "ls" test for a couple of hours
without any issues. Without this patch, the bug would trigger in less
than a minute.
Reported-by: Li Zefan <lizf@cn.fujitsu.com>
commit a2f8071428ed9a0f06865f417c962421c9a6b488 upstream.
When the trace iterator is read, tracing_start() and tracing_stop()
is called to stop tracing while the iterator is processing the trace
output.
These functions disable both the standard buffer and the max latency
buffer. But if the wakeup tracer is running, it can switch these
buffers between the two disables:
buffer = global_trace.buffer;
if (buffer)
ring_buffer_record_disable(buffer);
<<<--------- swap happens here
buffer = max_tr.buffer;
if (buffer)
What happens is that we disabled the same buffer twice. On tracing_start()
we can enable the same buffer twice. All ring_buffer_record_disable()
must be matched with a ring_buffer_record_enable() or the buffer
can be disable permanently, or enable prematurely, and cause a bug
where a reset happens while a trace is commiting.
This patch protects these two by taking the ftrace_max_lock to prevent
a switch from occurring.
Found with Li Zefan's ftrace_stress_test.
Reported-by: Lai Jiangshan <laijs@cn.fujitsu.com>
commit 283740c619d211e34572cc93c8cdba92ccbdb9cc upstream.
In the ftrace code that resets the ring buffer it references the
buffer with a local variable, but then uses the tr->buffer as the
parameter to reset. If the wakeup tracer is running, which can
switch the tr->buffer with the max saved buffer, this can break
the requirement of disabling the buffer before the reset.
buffer = tr->buffer;
synchronize_sched();
__tracing_reset(tr->buffer, cpu);
If the tr->buffer is swapped, then the reset is not happening to the
buffer that was disabled. This will cause the ring buffer to fail.
commit ea14eb714041d40fcc5180b5a586034503650149 upstream.
If the graph tracer is active, and a task is forked but the allocating of
the processes graph stack fails, it can cause crash later on.
This is due to the temporary stack being NULL, but the curr_ret_stack
variable is copied from the parent. If it is not -1, then in
ftrace_graph_probe_sched_switch() the following:
for (index = next->curr_ret_stack; index >= 0; index--)
next->ret_stack[index].calltime += timestamp;
Will cause a kernel OOPS.
commit 52fbe9cde7fdb5c6fac196d7ebd2d92d05ef3cd4 upstream.
The ring buffer resizing and resetting relies on a schedule RCU
action. The buffers are disabled, a synchronize_sched() is called
and then the resize or reset takes place.
But this only works if the disabling of the buffers are within the
preempt disabled section, otherwise a window exists that the buffers
can be written to while a reset or resize takes place.
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
LKML-Reference: <4B949E43.2010906@cn.fujitsu.com>
commit ad6759fbf35d104dbf573cd6f4c6784ad6823f7e upstream.
Aaro Koskinen reported an issue in kernel.org bugzilla #15366, where
on non-GENERIC_TIME systems, accessing
/sys/devices/system/clocksource/clocksource0/current_clocksource
results in an oops.
It seems the timekeeper/clocksource rework missed initializing the
curr_clocksource value in the !GENERIC_TIME case.
Thanks to Aaro for reporting and diagnosing the issue as well as
testing the fix!
Reported-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Signed-off-by: John Stultz <johnstul@us.ibm.com>
LKML-Reference: <1267475683.4216.61.camel@localhost.localdomain>
commit 83ab0aa0d5623d823444db82c3b3c34d7ec364ae upstream.
setscheduler() saves task->sched_class outside of the rq->lock held
region for a check after the setscheduler changes have become
effective. That might result in checking a stale value.
rtmutex_setprio() has the same problem, though it is protected by
p->pi_lock against setscheduler(), but for correctness sake (and to
avoid bad examples) it needs to be fixed as well.
Retrieve task->sched_class inside of the rq->lock held region.
commit 9000f05c6d1607f79c0deacf42b09693be673f4c upstream.
Fix a SMT scheduler performance regression that is leading to a scenario
where SMT threads in one core are completely idle while both the SMT threads
in another core (on the same socket) are busy.
This is caused by this commit (with the problematic code highlighted)
commit bdb94aa5dbd8b55e75f5a50b61312fe589e2c2d1
Date: Tue Sep 1 10:34:38 2009 +0200
sched: Try to deal with low capacity
@@ -4203,15 +4223,18 @@ find_busiest_queue()
for_each_cpu(i, sched_group_cpus(group)) {
+ unsigned long power = power_of(i);
- wl = weighted_cpuload(i);
+ wl = weighted_cpuload(i) * SCHED_LOAD_SCALE;
+ wl /= power;
- if (rq->nr_running == 1 && wl > imbalance)
+ if (capacity && rq->nr_running == 1 && wl > imbalance)
continue;
On a SMT system, power of the HT logical cpu will be 589 and
the scheduler load imbalance (for scenarios like the one mentioned above)
can be approximately 1024 (SCHED_LOAD_SCALE). The above change of scaling
the weighted load with the power will result in "wl > imbalance" and
ultimately resulting in find_busiest_queue() return NULL, causing
load_balance() to think that the load is well balanced. But infact
one of the tasks can be moved to the idle core for optimal performance.
We don't need to use the weighted load (wl) scaled by the cpu power to
compare with imabalance. In that condition, we already know there is only a
single task "rq->nr_running == 1" and the comparison between imbalance,
wl is to make sure that we select the correct priority thread which matches
imbalance. So we really need to compare the imabalnce with the original
weighted load of the cpu and not the scaled load.
But in other conditions where we want the most hammered(busiest) cpu, we can
use scaled load to ensure that we consider the cpu power in addition to the
actual load on that cpu, so that we can move the load away from the
guy that is getting most hammered with respect to the actual capacity,
as compared with the rest of the cpu's in that busiest group.
Fix it.
LKML-Reference: <1266023662.2808.118.camel@sbs-t61.sc.intel.com>
commit ced5b697a76d325e7a7ac7d382dbbb632c765093 upstream.
Keep chip_data in create_irq_nr and destroy_irq.
When two drivers are setting up MSI-X at the same time via
pci_enable_msix() there is a race. See this dmesg excerpt:
[ 85.170610] ixgbe 0000:02:00.1: irq 97 for MSI/MSI-X
[ 85.170611] alloc irq_desc for 99 on node -1
[ 85.170613] igb 0000:08:00.1: irq 98 for MSI/MSI-X
[ 85.170614] alloc kstat_irqs on node -1
[ 85.170616] alloc irq_2_iommu on node -1
[ 85.170617] alloc irq_desc for 100 on node -1
[ 85.170619] alloc kstat_irqs on node -1
[ 85.170621] alloc irq_2_iommu on node -1
[ 85.170625] ixgbe 0000:02:00.1: irq 99 for MSI/MSI-X
[ 85.170626] alloc irq_desc for 101 on node -1
[ 85.170628] igb 0000:08:00.1: irq 100 for MSI/MSI-X
[ 85.170630] alloc kstat_irqs on node -1
[ 85.170631] alloc irq_2_iommu on node -1
[ 85.170635] alloc irq_desc for 102 on node -1
[ 85.170636] alloc kstat_irqs on node -1
[ 85.170639] alloc irq_2_iommu on node -1
[ 85.170646] BUG: unable to handle kernel NULL pointer dereference
at 0000000000000088
As you can see igb and ixgbe are both alternating on create_irq_nr()
via pci_enable_msix() in their probe function.
ixgbe: While looping through irq_desc_ptrs[] via create_irq_nr() ixgbe
choses irq_desc_ptrs[102] and exits the loop, drops vector_lock and
calls dynamic_irq_init. Then it sets irq_desc_ptrs[102]->chip_data =
NULL via dynamic_irq_init().
igb: Grabs the vector_lock now and starts looping over irq_desc_ptrs[]
via create_irq_nr(). It gets to irq_desc_ptrs[102] and does this:
cfg_new = irq_desc_ptrs[102]->chip_data;
if (cfg_new->vector != 0)
continue;
This hits the NULL deref.
Another possible race exists via pci_disable_msix() in a driver or in
the number of error paths that call free_msi_irqs():
destroy_irq()
dynamic_irq_cleanup() which sets desc->chip_data = NULL
...race window...
desc->chip_data = cfg;
Remove the save and restore code for cfg in create_irq_nr() and
destroy_irq() and take the desc->lock when checking the irq_cfg.
Reported-and-analyzed-by: Brandon Philips <bphilips@suse.de>
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
LKML-Reference: <1265793639-15071-3-git-send-email-yinghai@kernel.org>
Signed-off-by: Brandon Phililps <bphilips@suse.de>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
commit a9c9b4429df437982d2fbfab1f4b46b01329e9ed upstream.
The hibernate memory preallocation code allocates memory to push some
user space data out of physical RAM, so that the hibernation image is
not too large. It allocates more memory than necessary for creating
the image, so it has to release some pages to make room for
allocations made while suspending devices and disabling nonboot CPUs,
or the system will hang due to the lack of free pages to allocate
from. Unfortunately, the function used for freeing these pages,
free_unnecessary_pages(), contains a bug that prevents it from doing
the job on all systems without highmem.
Fix this problem, which is a regression from the 2.6.30 kernel, by
using the right condition for the termination of the loop in
free_unnecessary_pages().
Reported-and-tested-by: Alan Jenkins <sourcejedi.lkml@googlemail.com>
commit c93d89f3dbf0202bf19c07960ca8602b48c2f9a0 upstream.
Export getboottime and monotonic_to_bootbased in order to let them
could be used by following patch.
Signed-off-by: Jason Wang <jasowang@redhat.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
commit 59647b6ac3050dd964bc556fe6ef22f4db5b935c upstream.
The WARN_ON in lookup_pi_state which complains about a mismatch
between pi_state->owner->pid and the pid which we retrieved from the
user space futex is completely bogus.
The code just emits the warning and then continues despite the fact
that it detected an inconsistent state of the futex. A conveniant way
for user space to spam the syslog.
Replace the WARN_ON by a consistency check. If the values do not match
return -EINVAL and let user space deal with the mess it created.
This also fixes the missing task_pid_vnr() when we compare the
pi_state->owner pid with the futex value.
Reported-by: Jermome Marchand <jmarchan@redhat.com>
commit 51246bfd189064079c54421507236fd2723b18f3 upstream.
If the owner of a PI futex dies we fix up the pi_state and set
pi_state->owner to NULL. When a malicious or just sloppy programmed
user space application sets the futex value to 0 e.g. by calling
pthread_mutex_init(), then the futex can be acquired again. A new
waiter manages to enqueue itself on the pi_state w/o damage, but on
unlock the kernel dereferences pi_state->owner and oopses.
Prevent this by checking pi_state->owner in the unlock path. If
pi_state->owner is not current we know that user space manipulated the
futex value. Ignore the mess and return -EINVAL.
This catches the above case and also the case where a task hijacks the
futex by setting the tid value and then tries to unlock it.
commit 5ecb01cfdf96c5f465192bdb2a4fd4a61a24c6cc upstream.
This fixes a futex key reference count bug in futex_lock_pi(),
where a key's reference count is incremented twice but decremented
only once, causing the backing object to not be released.
If the futex is created in a temporary file in an ext3 file system,
this bug causes the file's inode to become an "undead" orphan,
which causes an oops from a BUG_ON() in ext3_put_super() when the
file system is unmounted. glibc's test suite is known to trigger this,
see <http://bugzilla.kernel.org/show_bug.cgi?id=14256>.
The bug is a regression from 2.6.28-git3, namely Peter Zijlstra's
38d47c1b7075bd7ec3881141bb3629da58f88dab "[PATCH] futex: rely on
get_user_pages() for shared futexes". That commit made get_futex_key()
also increment the reference count of the futex key, and updated its
callers to decrement the key's reference count before returning.
Unfortunately the normal exit path in futex_lock_pi() wasn't corrected:
the reference count is incremented by get_futex_key() and queue_lock(),
but the normal exit path only decrements once, via unqueue_me_pi().
The fix is to put_futex_key() after unqueue_me_pi(), since 2.6.31
this is easily done by 'goto out_put_key' rather than 'goto out'.
Signed-off-by: Mikael Pettersson <mikpe@it.uu.se>
This fixes the boot time oops on the 2.6.32-stable tree. It is needed
only in this tree due to the divergance from upstream.
commit b8a1d37c5f981cdd2e83c9fd98198832324cd57a upstream.
Free memory allocated using kmem_cache_zalloc using kmem_cache_free rather
than kfree.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
expression x,E,c;
x = \(kmem_cache_alloc\|kmem_cache_zalloc\|kmem_cache_alloc_node\)(c,...)
... when != x = E
when != &x
?-kfree(x)
+kmem_cache_free(c,x)
// </smpl>
Cc: Steve Dickson <steved@redhat.com>
commit a362c638bdf052bf424bce7645d39b101090f6ba upstream
Commit a9238ce3bb0fda6e760780b702c6cbd3793087d3 broke compilation on
platforms that do not implement GENERIC_TIME (e.g. iop32x):
kernel/time/clocksource.c: In function 'clocksource_register':
kernel/time/clocksource.c:556: error: implicit declaration of function 'clocksource_max_deferment'
Provide the implementation of clocksource_max_deferment() also for
such platforms.
Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi>
commit feae3203d711db0a9965300ee6d592257fdaae4f upstream.
Limit the number of per cpu calibration messages by only
printing out results for the first cpu to boot.
Also, don't print "CPUx is down" as this is expected, and we
don't need 4096 reminders... ;-)
Signed-off-by: Mike Travis <travis@sgi.com>
Cc: Roland Dreier <rdreier@cisco.com>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Cc: Tejun Heo <tj@kernel.org>
Cc: Yinghai Lu <yhlu.kernel@gmail.com>
Cc: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
LKML-Reference: <20091118002219.889552000@alcatraz.americas.sgi.com>
