When CONFIG_GENERIC_CLOCKEVENTS_MIN_ADJUST=n, the call path
hrtimer_reprogram -> clockevents_program_event ->
clockevents_program_min_delta will not retry if the clock event driver
returns -ETIME.
If the driver could not satisfy the program_min_delta for any reason, the
lack of a retry means the CPU may not receive a tick interrupt, potentially
until the counter does a full period. This leads to rcu_sched timeout
messages as the stalled CPU is detected by other CPUs, and other issues if
the CPU is holding locks or other resources at the point at which it
stalls.
There have been a couple of observed mechanisms through which a clock event
driver could not satisfy the requested min_delta and return -ETIME.
With the MIPS GIC driver, the shared execution resource within MT cores
means inconventient latency due to execution of instructions from other
hardware threads in the core, within gic_next_event, can result in an event
being set in the past.
Additionally under virtualisation it is possible to get unexpected latency
during a clockevent device's set_next_event() callback which can make it
return -ETIME even for a delta based on min_delta_ns.
It isn't appropriate to use MIN_ADJUST in the virtualisation case as
occasional hypervisor induced high latency will cause min_delta_ns to
quickly increase to the maximum.
Instead, borrow the retry pattern from the MIN_ADJUST case, but without
making adjustments. Retry up to 10 times, each time increasing the
attempted delta by min_delta, before giving up.
[ Matt: Reworked the loop and made retry increase the delta. ]
Signed-off-by: James Hogan <jhogan@kernel.org>
Signed-off-by: Matt Redfearn <matt.redfearn@mips.com>
Cc: linux-mips@linux-mips.org
Cc: Daniel Lezcano <daniel.lezcano@linaro.org>
Cc: "Martin Schwidefsky" <schwidefsky@de.ibm.com>
Cc: James Hogan <james.hogan@mips.com>
Link: https://lkml.kernel.org/r/1508422643-6075-1-git-send-email-matt.redfearn@mips.com
Now that we don't need the common flags to overflow outside the range
of a 32-bit type we can encode them the same way for both the bio and
request fields. This in addition allows us to place the operation
first (and make some room for more ops while we're at it) and to
stop having to shift around the operation values.
In addition this allows passing around only one value in the block layer
instead of two (and eventuall also in the file systems, but we can do
that later) and thus clean up a lot of code.
Last but not least this allows decreasing the size of the cmd_flags
field in struct request to 32-bits. Various functions passing this
value could also be updated, but I'd like to avoid the churn for now.
Signed-off-by: Jens Axboe <axboe@fb.com>
(cherry picked from commit ef295ecf090d3e86e5b742fc6ab34f1122a43773)
block/blk-mq.c
include/linux/blk_types.h
include/linux/blkdev.h
There is no need to always call blocking console_lock() in
console_cpu_notify(), it's quite possible that console_sem can
be locked by other CPU on the system, either already printing
or soon to begin printing the messages. console_lock() in this
case can simply block CPU hotplug for unknown period of time
(console_unlock() is time unbound). Not that hotplug is very
fast, but still, with other CPUs being online and doing
printk() console_cpu_notify() can stuck.
Use console_trylock() instead and opt-out if console_sem is
already acquired from another CPU, since that CPU will do
the printing for us.
Link: http://lkml.kernel.org/r/20170121104729.8585-1-sergey.senozhatsky@gmail.com
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Signed-off-by: Petr Mladek <pmladek@suse.com>
This patch also fixes a deadlock that happens if while holding the
console lock someone issues a call that eventually takes the cpu
hotplug lock, like in the case below, where the following happens:
* task Xorg issues an ioctl to the fb layer which takes the console
lock and calls the driver's ioctl routine
* at the same time, task bat-cpuhotplug issue a hotplug cpu enable
operation which takes the cpu hotplug lock and waits for the cpu
bringup operation to complete
* the fb driver calls dma_alloc_coherent which, on this platform,
eventually tries to take the cpu hotplug
* task cpuhp/2 tries to flush the console
* at this point task Xorg waits after task bat-cpuhotplug to release
the cpu hotplug lock which waits after task cpuhp/2 to signal that
the CPU is up which waits after the Xorg to release the console
lock
Linux version 4.9.11-02771-gd85d61b-dirty
CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
OF: fdt:Machine model: Freescale i.MX6 Quad SABRE Smart Device Board
sysrq: SysRq : Show Blocked State
task PC stack pid father
cpuhp/2 D 0 18 2 0x00000000
[<80a794ac>] (__schedule) from [<80a79904>] (schedule+0x4c/0xac)
[<80a79904>] (schedule) from [<80a7e680>] (schedule_timeout+0x1e8/0x2fc)
[<80a7e680>] (schedule_timeout) from [<80a7d208>] (__down+0x64/0x9c)
[<80a7d208>] (__down) from [<80174224>] (down+0x44/0x58)
[<80174224>] (down) from [<80181a6c>] (console_lock+0x2c/0x74)
[<80181a6c>] (console_lock) from [<801849b4>] (console_cpu_notify+0x28/0x34)
[<801849b4>] (console_cpu_notify) from [<80150e58>] (notifier_call_chain+0x44/0x84)
[<80150e58>] (notifier_call_chain) from [<8012ed34>] (__cpu_notify+0x38/0x50)
[<8012ed34>] (__cpu_notify) from [<8012ed64>] (notify_online+0x18/0x20)
[<8012ed64>] (notify_online) from [<8012ea4c>] (cpuhp_up_callbacks+0x24/0xd4)
[<8012ea4c>] (cpuhp_up_callbacks) from [<8012f4c8>] (cpuhp_thread_fun+0x13c/0x148)
[<8012f4c8>] (cpuhp_thread_fun) from [<80153544>] (smpboot_thread_fn+0x17c/0x2dc)
[<80153544>] (smpboot_thread_fn) from [<8014f7d8>] (kthread+0xf0/0x108)
[<8014f7d8>] (kthread) from [<801077d0>] (ret_from_fork+0x14/0x24)
bat-cpuhotplug. D 0 841 718 0x00000000
[<80a7e680>] (schedule_timeout) from [<80a7a47c>] (wait_for_common+0xb0/0x160)
[<80a7a47c>] (wait_for_common) from [<8012f600>] (bringup_cpu+0x50/0xa8)
[<8012f600>] (bringup_cpu) from [<8012ea4c>] (cpuhp_up_callbacks+0x24/0xd4)
[<8012ea4c>] (cpuhp_up_callbacks) from [<8012ff58>] (_cpu_up+0xa8/0xec)
[<8012ff58>] (_cpu_up) from [<80130010>] (do_cpu_up+0x74/0x9c)
[<80130010>] (do_cpu_up) from [<80520c88>] (device_online+0x68/0x8c)
[<80520c88>] (device_online) from [<80520d14>] (online_store+0x68/0x74)
[<80520d14>] (online_store) from [<8029842c>] (kernfs_fop_write+0xf4/0x1f8)
[<8029842c>] (kernfs_fop_write) from [<80223da0>] (__vfs_write+0x1c/0x114)
[<80223da0>] (__vfs_write) from [<80224c78>] (vfs_write+0xa4/0x168)
[<80224c78>] (vfs_write) from [<802259c4>] (SyS_write+0x3c/0x90)
[<802259c4>] (SyS_write) from [<80107740>] (ret_fast_syscall+0x0/0x1c)
Xorg D 0 860 832 0x00000000
[<80a79904>] (schedule) from [<80a79d98>] (schedule_preempt_disabled+0x14/0x20)
[<80a79d98>] (schedule_preempt_disabled) from [<80a7ab10>] (mutex_lock_nested+0x1f8/0x4a4)
[<80a7ab10>] (mutex_lock_nested) from [<8012ef94>] (get_online_cpus+0x78/0xbc)
[<8012ef94>] (get_online_cpus) from [<801e7858>] (lru_add_drain_all+0x48/0x1b4)
[<801e7858>] (lru_add_drain_all) from [<8021f65c>] (migrate_prep+0x8/0x10)
[<8021f65c>] (migrate_prep) from [<801e1bc8>] (alloc_contig_range+0xd0/0x320)
[<801e1bc8>] (alloc_contig_range) from [<80220ec4>] (cma_alloc+0xb8/0x1a8)
[<80220ec4>] (cma_alloc) from [<80113b38>] (__alloc_from_contiguous+0x38/0xd8)
[<80113b38>] (__alloc_from_contiguous) from [<80113c0c>] (cma_allocator_alloc+0x34/0x3c)
[<80113c0c>] (cma_allocator_alloc) from [<80113d88>] (__dma_alloc+0x174/0x338)
[<80113d88>] (__dma_alloc) from [<80113fc8>] (arm_dma_alloc+0x40/0x48)
[<80113fc8>] (arm_dma_alloc) from [<80478a88>] (mxcfb_set_par+0x8ec/0xd7c)
[<80478a88>] (mxcfb_set_par) from [<8045f200>] (fb_set_var+0x1d4/0x358)
[<8045f200>] (fb_set_var) from [<8045f9e8>] (do_fb_ioctl+0x4e4/0x704)
[<8045f9e8>] (do_fb_ioctl) from [<8023773c>] (do_vfs_ioctl+0xa0/0xa10)
[<8023773c>] (do_vfs_ioctl) from [<802380e0>] (SyS_ioctl+0x34/0x5c)
[<802380e0>] (SyS_ioctl) from [<80107740>] (ret_fast_syscall+0x0/0x1c)
Signed-off-by: Octavian Purdila <octavian.purdila@nxp.com>
Reviewed-by: Leonard Crestez <leonard.crestez@nxp.com>
When the tick is stopped and we reach the dynticks evaluation code on
IRQ exit, we perform a soft tick restart if we observe an expired timer
from there. It means we program the nearest possible tick but we stay in
dynticks mode (ts->tick_stopped = 1) because we may need to stop the tick
again after that expired timer is handled.
Now this solution works most of the time but if we suffer an IRQ storm
and those interrupts trigger faster than the hardware clockevents min
delay, our tick won't fire until that IRQ storm is finished.
Here is the problem: on IRQ exit we reprog the timer to at least
NOW() + min_clockevents_delay. Another IRQ fires before the tick so we
reschedule again to NOW() + min_clockevents_delay, etc... The tick
is eternally rescheduled min_clockevents_delay ahead.
A solution is to simply remove this soft tick restart. After all
the normal dynticks evaluation path can handle 0 delay just fine. And
by doing that we benefit from the optimization branch which avoids
clock reprogramming if the clockevents deadline hasn't changed since
the last reprog. This fixes our issue because we don't do repetitive
clock reprog that always add hardware min delay.
As a side effect it should even optimize the 0 delay path in general.
Reported-and-tested-by: Octavian Purdila <octavian.purdila@nxp.com>
Move the x86_64 idle notifiers originally by Andi Kleen and Venkatesh
Pallipadi to generic.
Change-Id: Idf29cda15be151f494ff245933c12462643388d5
Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Signed-off-by: Todd Poynor <toddpoynor@google.com>
These macros can be reused by governors which don't use the common
governor code present in cpufreq_governor.c and should be moved to the
relevant header.
Now that they are getting moved to the right header file, reuse them in
schedutil governor as well (that required rename of show/store
routines).
Also create gov_attr_wo() macro for write-only sysfs files, this will be
used by Interactive governor in a later patch.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
commit 269777aa530f3438ec1781586cdac0b5fe47b061 upstream.
Commit 0cc3cd21657b ("cpu/hotplug: Boot HT siblings at least once")
breaks non-SMP builds.
[ I suspect the 'bool' fields should just be made to be bitfields and be
exposed regardless of configuration, but that's a separate cleanup
that I'll leave to the owners of this file for later. - Linus ]
Fixes: 0cc3cd21657b ("cpu/hotplug: Boot HT siblings at least once")
Signed-off-by: Abel Vesa <abelvesa@linux.com>
commit bc2d8d262cba5736332cbc866acb11b1c5748aa9 upstream
Josh reported that the late SMT evaluation in cpu_smt_state_init() sets
cpu_smt_control to CPU_SMT_NOT_SUPPORTED in case that 'nosmt' was supplied
on the kernel command line as it cannot differentiate between SMT disabled
by BIOS and SMT soft disable via 'nosmt'. That wreckages the state and
makes the sysfs interface unusable.
Rework this so that during bringup of the non boot CPUs the availability of
SMT is determined in cpu_smt_allowed(). If a newly booted CPU is not a
'primary' thread then set the local cpu_smt_available marker and evaluate
this explicitely right after the initial SMP bringup has finished.
SMT evaulation on x86 is a trainwreck as the firmware has all the
information _before_ booting the kernel, but there is no interface to query
it.
Fixes: 73d5e2b47264 ("cpu/hotplug: detect SMT disabled by BIOS")
Reported-by: Josh Poimboeuf <jpoimboe@redhat.com>
Signed-off-by: David Woodhouse <dwmw@amazon.co.uk>
commit 73d5e2b472640b1fcdb61ae8be389912ef211bda upstream
If SMT is disabled in BIOS, the CPU code doesn't properly detect it.
The /sys/devices/system/cpu/smt/control file shows 'on', and the 'l1tf'
vulnerabilities file shows SMT as vulnerable.
Fix it by forcing 'cpu_smt_control' to CPU_SMT_NOT_SUPPORTED in such a
case. Unfortunately the detection can only be done after bringing all
the CPUs online, so we have to overwrite any previous writes to the
variable.
Reported-by: Joe Mario <jmario@redhat.com>
Tested-by: Jiri Kosina <jkosina@suse.cz>
Fixes: f048c399e0f7 ("x86/topology: Provide topology_smt_supported()")
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
commit fee0aede6f4739c87179eca76136f83210953b86 upstream
The CPU_SMT_NOT_SUPPORTED state is set (if the processor does not support
SMT) when the sysfs SMT control file is initialized.
That was fine so far as this was only required to make the output of the
control file correct and to prevent writes in that case.
With the upcoming l1tf command line parameter, this needs to be set up
before the L1TF mitigation selection and command line parsing happens.
Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Reviewed-by: Josh Poimboeuf <jpoimboe@redhat.com>
Link: https://lkml.kernel.org/r/20180713142323.121795971@linutronix.de
commit 8e1b706b6e819bed215c0db16345568864660393 upstream
The L1TF mitigation will gain a commend line parameter which allows to set
a combination of hypervisor mitigation and SMT control.
Expose cpu_smt_disable() so the command line parser can tweak SMT settings.
[ tglx: Split out of larger patch and made it preserve an already existing
force off state ]
Link: https://lkml.kernel.org/r/20180713142323.039715135@linutronix.de
commit 215af5499d9e2b55f111d2431ea20218115f29b3 upstream
Writing 'off' to /sys/devices/system/cpu/smt/control offlines all SMT
siblings. Writing 'on' merily enables the abilify to online them, but does
not online them automatically.
Make 'on' more useful by onlining all offline siblings.
commit 26acfb666a473d960f0fd971fe68f3e3ad16c70b upstream
If the L1TF CPU bug is present we allow the KVM module to be loaded as the
major of users that use Linux and KVM have trusted guests and do not want a
broken setup.
Cloud vendors are the ones that are uncomfortable with CVE 2018-3620 and as
such they are the ones that should set nosmt to one.
Setting 'nosmt' means that the system administrator also needs to disable
SMT (Hyper-threading) in the BIOS, or via the 'nosmt' command line
parameter, or via the /sys/devices/system/cpu/smt/control. See commit
05736e4ac13c ("cpu/hotplug: Provide knobs to control SMT").
Other mitigations are to use task affinity, cpu sets, interrupt binding,
etc - anything to make sure that _only_ the same guests vCPUs are running
on sibling threads.
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit 0cc3cd21657be04cb0559fe8063f2130493f92cf upstream
Due to the way Machine Check Exceptions work on X86 hyperthreads it's
required to boot up _all_ logical cores at least once in order to set the
CR4.MCE bit.
So instead of ignoring the sibling threads right away, let them boot up
once so they can configure themselves. After they came out of the initial
boot stage check whether its a "secondary" sibling and cancel the operation
which puts the CPU back into offline state.
[dwmw2: Backport to 4.9]
Reported-by: Dave Hansen <dave.hansen@intel.com>
Tested-by: Tony Luck <tony.luck@intel.com>
commit 05736e4ac13c08a4a9b1ef2de26dd31a32cbee57 upstream
Provide a command line and a sysfs knob to control SMT.
The command line options are:
'nosmt': Enumerate secondary threads, but do not online them
'nosmt=force': Ignore secondary threads completely during enumeration
via MP table and ACPI/MADT.
The sysfs control file has the following states (read/write):
'on': SMT is enabled. Secondary threads can be freely onlined
'off': SMT is disabled. Secondary threads, even if enumerated
cannot be onlined
'forceoff': SMT is permanentely disabled. Writes to the control
file are rejected.
'notsupported': SMT is not supported by the CPU
The command line option 'nosmt' sets the sysfs control to 'off'. This
can be changed to 'on' to reenable SMT during runtime.
The command line option 'nosmt=force' sets the sysfs control to
'forceoff'. This cannot be changed during runtime.
When SMT is 'on' and the control file is changed to 'off' then all online
secondary threads are offlined and attempts to online a secondary thread
later on are rejected.
When SMT is 'off' and the control file is changed to 'on' then secondary
threads can be onlined again. The 'off' -> 'on' transition does not
automatically online the secondary threads.
When the control file is set to 'forceoff', the behaviour is the same as
setting it to 'off', but the operation is irreversible and later writes to
the control file are rejected.
When the control status is 'notsupported' then writes to the control file
are rejected.
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Acked-by: Ingo Molnar <mingo@kernel.org>
commit cc1fe215e1efa406b03aa4389e6269b61342dec5 upstream
Split out the inner workings of do_cpu_down() to allow reuse of that
function for the upcoming SMT disabling mechanism.
No functional change.
commit c4de65696d865c225fda3b9913b31284ea65ea96 upstream
The asymmetry caused a warning to trigger if the bootup was stopped in state
CPUHP_AP_ONLINE_IDLE. The warning no longer triggers as kthread_park() can
now be invoked on already or still parked threads. But there is still no
reason to have this be asymmetric.
commit b5b1404d0815894de0690de8a1ab58269e56eae6 upstream.
This is purely a preparatory patch for upcoming changes during the 4.19
merge window.
We have a function called "boot_cpu_state_init()" that isn't really
about the bootup cpu state: that is done much earlier by the similarly
named "boot_cpu_init()" (note lack of "state" in name).
This function initializes some hotplug CPU state, and needs to run after
the percpu data has been properly initialized. It even has a comment to
that effect.
Except it _doesn't_ actually run after the percpu data has been properly
initialized. On x86 it happens to do that, but on at least arm and
arm64, the percpu base pointers are initialized by the arch-specific
'smp_prepare_boot_cpu()' hook, which ran _after_ boot_cpu_state_init().
This had some unexpected results, and in particular we have a patch
pending for the merge window that did the obvious cleanup of using
'this_cpu_write()' in the cpu hotplug init code:
- per_cpu_ptr(&cpuhp_state, smp_processor_id())->state = CPUHP_ONLINE;
+ this_cpu_write(cpuhp_state.state, CPUHP_ONLINE);
which is obviously the right thing to do. Except because of the
ordering issue, it actually failed miserably and unexpectedly on arm64.
So this just fixes the ordering, and changes the name of the function to
be 'boot_cpu_hotplug_init()' to make it obvious that it's about cpu
hotplug state, because the core CPU state was supposed to have already
been done earlier.
Marked for stable, since the (not yet merged) patch that will show this
problem is marked for stable.
Reported-by: Vlastimil Babka <vbabka@suse.cz>
Reported-by: Mian Yousaf Kaukab <yousaf.kaukab@suse.com>
Suggested-by: Catalin Marinas <catalin.marinas@arm.com>
Cc: stable@kernel.org
commit 3c53776e29f81719efcf8f7a6e30cdf753bee94d upstream.
Way back in 4.9, we committed 4cd13c21b207 ("softirq: Let ksoftirqd do
its job"), and ever since we've had small nagging issues with it. For
example, we've had:
1ff688209e2e ("watchdog: core: make sure the watchdog_worker is not deferred")
8d5755b3f77b ("watchdog: softdog: fire watchdog even if softirqs do not get to run")
217f69743681 ("net: busy-poll: allow preemption in sk_busy_loop()")
all of which worked around some of the effects of that commit.
The DVB people have also complained that the commit causes excessive USB
URB latencies, which seems to be due to the USB code using tasklets to
schedule USB traffic. This seems to be an issue mainly when already
living on the edge, but waiting for ksoftirqd to handle it really does
seem to cause excessive latencies.
Now Hanna Hawa reports that this issue isn't just limited to USB URB and
DVB, but also causes timeout problems for the Marvell SoC team:
"I'm facing kernel panic issue while running raid 5 on sata disks
connected to Macchiatobin (Marvell community board with Armada-8040
SoC with 4 ARMv8 cores of CA72) Raid 5 built with Marvell DMA engine
and async_tx mechanism (ASYNC_TX_DMA [=y]); the DMA driver (mv_xor_v2)
uses a tasklet to clean the done descriptors from the queue"
The latency problem causes a panic:
mv_xor_v2 f0400000.xor: dma_sync_wait: timeout!
Kernel panic - not syncing: async_tx_quiesce: DMA error waiting for transaction
We've discussed simply just reverting the original commit entirely, and
also much more involved solutions (with per-softirq threads etc). This
patch is intentionally stupid and fairly limited, because the issue
still remains, and the other solutions either got sidetracked or had
other issues.
We should probably also consider the timer softirqs to be synchronous
and not be delayed to ksoftirqd (since they were the issue with the
earlier watchdog problems), but that should be done as a separate patch.
This does only the tasklet cases.
Reported-and-tested-by: Hanna Hawa <hannah@marvell.com>
Reported-and-tested-by: Josef Griebichler <griebichler.josef@gmx.at>
Reported-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Eric Dumazet <edumazet@google.com>
commit e01e80634ecdde1dd113ac43b3adad21b47f3957 upstream.
One of the classes of kernel stack content leaks[1] is exposing the
contents of prior heap or stack contents when a new process stack is
allocated. Normally, those stacks are not zeroed, and the old contents
remain in place. In the face of stack content exposure flaws, those
contents can leak to userspace.
Fixing this will make the kernel no longer vulnerable to these flaws, as
the stack will be wiped each time a stack is assigned to a new process.
There's not a meaningful change in runtime performance; it almost looks
like it provides a benefit.
Performing back-to-back kernel builds before:
Run times: 157.86 157.09 158.90 160.94 160.80
Mean: 159.12
Std Dev: 1.54
and after:
Run times: 159.31 157.34 156.71 158.15 160.81
Mean: 158.46
Std Dev: 1.46
Instead of making this a build or runtime config, Andy Lutomirski
recommended this just be enabled by default.
[1] A noisy search for many kinds of stack content leaks can be seen here:
https://cve.mitre.org/cgi-bin/cvekey.cgi?keyword=linux+kernel+stack+leak
I did some more with perf and cycle counts on running 100,000 execs of
/bin/true.
before:
Cycles: 218858861551 218853036130 214727610969 227656844122 224980542841
Mean: 221015379122.60
Std Dev: 4662486552.47
after:
Cycles: 213868945060 213119275204 211820169456 224426673259 225489986348
Mean: 217745009865.40
Std Dev: 5935559279.99
It continues to look like it's faster, though the deviation is rather
wide, but I'm not sure what I could do that would be less noisy. I'm
open to ideas!
Link: http://lkml.kernel.org/r/20180221021659.GA37073@beast
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Laura Abbott <labbott@redhat.com>
Cc: Rasmus Villemoes <rasmus.villemoes@prevas.dk>
Cc: Mel Gorman <mgorman@techsingularity.net>
[ Srivatsa: Backported to 4.9.y ]
Signed-off-by: Srivatsa S. Bhat <srivatsa@csail.mit.edu>
Reviewed-by: Srinidhi Rao <srinidhir@vmware.com>
commit ca182551857cc2c1e6a2b7f1e72090a137a15008 upstream.
Kmemleak considers any pointers on task stacks as references. This
patch clears newly allocated and reused vmap stacks.
Link: http://lkml.kernel.org/r/150728990124.744199.8403409836394318684.stgit@buzz
Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
commit 73c8d8945505acdcbae137c2e00a1232e0be709f upstream.
Maintain the tracing on/off setting of the ring_buffer when switching
to the trace buffer snapshot.
Taking a snapshot is done by swapping the backup ring buffer
(max_tr_buffer). But since the tracing on/off setting is defined
by the ring buffer, when swapping it, the tracing on/off setting
can also be changed. This causes a strange result like below:
/sys/kernel/debug/tracing # cat tracing_on
1
/sys/kernel/debug/tracing # echo 0 > tracing_on
0
/sys/kernel/debug/tracing # echo 1 > snapshot
1
0
We don't touch tracing_on, but snapshot changes tracing_on
setting each time. This is an anomaly, because user doesn't know
that each "ring_buffer" stores its own tracing-enable state and
the snapshot is done by swapping ring buffers.
Link: http://lkml.kernel.org/r/153149929558.11274.11730609978254724394.stgit@devbox
Cc: Shuah Khan <shuah@kernel.org>
Cc: Tom Zanussi <tom.zanussi@linux.intel.com>
Cc: Hiraku Toyooka <hiraku.toyooka@cybertrust.co.jp>
Cc: stable@vger.kernel.org
Fixes: debdd57f5145 ("tracing: Make a snapshot feature available from userspace")
Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org>
[ Updated commit log and comment in the code ]
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
Signed-off-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
commit 80d20d35af1edd632a5e7a3b9c0ab7ceff92769e upstream.
local_timer_softirq_pending() checks whether the timer softirq is
pending with: local_softirq_pending() & TIMER_SOFTIRQ.
This is wrong because TIMER_SOFTIRQ is the softirq number and not a
bitmask. So the test checks for the wrong bit.
Use BIT(TIMER_SOFTIRQ) instead.
Fixes: 5d62c183f9e9 ("nohz: Prevent a timer interrupt storm in tick_nohz_stop_sched_tick()")
Signed-off-by: Anna-Maria Gleixner <anna-maria@linutronix.de>
Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Reviewed-by: Daniel Bristot de Oliveira <bristot@redhat.com>
Acked-by: Frederic Weisbecker <frederic@kernel.org>
Cc: bigeasy@linutronix.de
Cc: peterz@infradead.org
Link: https://lkml.kernel.org/r/20180731161358.29472-1-anna-maria@linutronix.de
commit d1f0301b3333eef5efbfa1fe0f0edbea01863d5d upstream.
The support of force threading interrupts which are set up with both a
primary and a threaded handler wreckaged the setup of regular requested
threaded interrupts (primary handler == NULL).
The reason is that it does not check whether the primary handler is set to
the default handler which wakes the handler thread. Instead it replaces the
thread handler with the primary handler as it would do with force threaded
interrupts which have been requested via request_irq(). So both the primary
and the thread handler become the same which then triggers the warnon that
the thread handler tries to wakeup a not configured secondary thread.
Fortunately this only happens when the driver omits the IRQF_ONESHOT flag
when requesting the threaded interrupt, which is normaly caught by the
sanity checks when force irq threading is disabled.
Fix it by skipping the force threading setup when a regular threaded
interrupt is requested. As a consequence the interrupt request which lacks
the IRQ_ONESHOT flag is rejected correctly instead of silently wreckaging
it.
Fixes: 2a1d3ab8986d ("genirq: Handle force threading of irqs with primary and thread handler")
Reported-by: Kurt Kanzenbach <kurt.kanzenbach@linutronix.de>
Tested-by: Kurt Kanzenbach <kurt.kanzenbach@linutronix.de>
commit 35a2897c2a306cca344ca5c0b43416707018f434 upstream.
Steven Rostedt reported a potential race in RCU core because of
swake_up():
CPU0 CPU1
__call_rcu_core() {
spin_lock(rnp_root)
need_wake = __rcu_start_gp() {
rcu_start_gp_advanced() {
gp_flags = FLAG_INIT
rcu_gp_kthread() {
swait_event_interruptible(wq,
gp_flags & FLAG_INIT) {
spin_lock(q->lock)
*fetch wq->task_list here! *
list_add(wq->task_list, q->task_list)
spin_unlock(q->lock);
*fetch old value of gp_flags here *
spin_unlock(rnp_root)
rcu_gp_kthread_wake() {
swake_up(wq) {
swait_active(wq) {
list_empty(wq->task_list)
} * return false *
if (condition) * false *
schedule();
In this case, a wakeup is missed, which could cause the rcu_gp_kthread
waits for a long time.
The reason of this is that we do a lockless swait_active() check in
swake_up(). To fix this, we can either 1) add a smp_mb() in swake_up()
before swait_active() to provide the proper order or 2) simply remove
the swait_active() in swake_up().
The solution 2 not only fixes this problem but also keeps the swait and
wait API as close as possible, as wake_up() doesn't provide a full
barrier and doesn't do a lockless check of the wait queue either.
Moreover, there are users already using swait_active() to do their quick
checks for the wait queues, so it make less sense that swake_up() and
swake_up_all() do this on their own.
This patch then removes the lockless swait_active() check in swake_up()
and swake_up_all().
Reported-by: Steven Rostedt <rostedt@goodmis.org>
Signed-off-by: Boqun Feng <boqun.feng@gmail.com>
Cc: Krister Johansen <kjlx@templeofstupid.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Link: http://lkml.kernel.org/r/20170615041828.zk3a3sfyudm5p6nl@tardis
Cc: David Chen <david.chen@nutanix.com>
[ Upstream commit 23bcc480dac204c7dbdf49d96b2c918ed98223c2 ]
Current implementation of auditing by executable name only implements
the 'equal' operator. This patch extends it to also support the 'not
equal' operator.
See: https://github.com/linux-audit/audit-kernel/issues/53
Signed-off-by: Ondrej Mosnacek <omosnace@redhat.com>
Reviewed-by: Richard Guy Briggs <rgb@redhat.com>
Signed-off-by: Paul Moore <paul@paul-moore.com>
[ Upstream commit de5b55c1d4e30740009864eb35ce4ed856aac01d ]
Use raw-locks in stop_machine() to allow locking in irq-off and
preempt-disabled regions on -RT. This also documents the possible locking
context in general.
[bigeasy: update patch description.]
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Link: https://lkml.kernel.org/r/20180423191635.6014-1-bigeasy@linutronix.de
[ Upstream commit ab7f5bf0928be2f148d000a6eaa6c0a36e74750e ]
Comments in the verifier refer to free_bpf_prog_info() which
seems to have never existed in tree. Replace it with
free_used_maps().
Signed-off-by: Jakub Kicinski <jakub.kicinski@netronome.com>
Reviewed-by: Quentin Monnet <quentin.monnet@netronome.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
[ Upstream commit c9484b986ef03492357fddd50afbdd02929cfa72 ]
Patch series "kcov: fix unexpected faults".
These patches fix a few issues where KCOV code could trigger recursive
faults, discovered while debugging a patch enabling KCOV for arch/arm:
* On CONFIG_PREEMPT kernels, there's a small race window where
__sanitizer_cov_trace_pc() can see a bogus kcov_area.
* Lazy faulting of the vmalloc area can cause mutual recursion between
fault handling code and __sanitizer_cov_trace_pc().
* During the context switch, switching the mm can cause the kcov_area to
be transiently unmapped.
These are prerequisites for enabling KCOV on arm, but the issues
themsevles are generic -- we just happen to avoid them by chance rather
than design on x86-64 and arm64.
This patch (of 3):
For kernels built with CONFIG_PREEMPT, some C code may execute before or
after the interrupt handler, while the hardirq count is zero. In these
cases, in_task() can return true.
A task can be interrupted in the middle of a KCOV_DISABLE ioctl while it
resets the task's kcov data via kcov_task_init(). Instrumented code
executed during this period will call __sanitizer_cov_trace_pc(), and as
in_task() returns true, will inspect t->kcov_mode before trying to write
to t->kcov_area.
In kcov_init_task() we update t->kcov_{mode,area,size} with plain stores,
which may be re-ordered, torn, etc. Thus __sanitizer_cov_trace_pc() may
see bogus values for any of these fields, and may attempt to write to
memory which is not mapped.
Let's avoid this by using WRITE_ONCE() to set t->kcov_mode, with a
barrier() to ensure this is ordered before we clear t->kov_{area,size}.
This ensures that any code execute while kcov_init_task() is preempted
will either see valid values for t->kcov_{area,size}, or will see that
t->kcov_mode is KCOV_MODE_DISABLED, and bail out without touching
t->kcov_area.
Link: http://lkml.kernel.org/r/20180504135535.53744-2-mark.rutland@arm.com
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Acked-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
commit 2519c1bbe38d7acacc9aacba303ca6f97482ed53 upstream.
Commit 57ea2a34adf4 ("tracing/kprobes: Fix trace_probe flags on
enable_trace_kprobe() failure") added an if statement that depends on another
if statement that gcc doesn't see will initialize the "link" variable and
gives the warning:
"warning: 'link' may be used uninitialized in this function"
It is really a false positive, but to quiet the warning, and also to make
sure that it never actually is used uninitialized, initialize the "link"
variable to NULL and add an if (!WARN_ON_ONCE(!link)) where the compiler
thinks it could be used uninitialized.
Fixes: 57ea2a34adf4 ("tracing/kprobes: Fix trace_probe flags on enable_trace_kprobe() failure")
Reported-by: kbuild test robot <lkp@intel.com>
commit 57ea2a34adf40f3a6e88409aafcf803b8945619a upstream.
If enable_trace_kprobe fails to enable the probe in enable_k(ret)probe
it returns an error, but does not unset the tp flags it set previously.
This results in a probe being considered enabled and failures like being
unable to remove the probe through kprobe_events file since probes_open()
expects every probe to be disabled.
Link: http://lkml.kernel.org/r/20180725102826.8300-1-asavkov@redhat.com
Link: http://lkml.kernel.org/r/20180725142038.4765-1-asavkov@redhat.com
Fixes: 41a7dd420c57 ("tracing/kprobes: Support ftrace_event_file base multibuffer")
Acked-by: Masami Hiramatsu <mhiramat@kernel.org>
Signed-off-by: Artem Savkov <asavkov@redhat.com>
commit 3e536e222f2930534c252c1cc7ae799c725c5ff9 upstream.
There is a window for racing when printing directly to task->comm,
allowing other threads to see a non-terminated string. The vsnprintf
function fills the buffer, counts the truncated chars, then finally
writes the \0 at the end.
creator other
vsnprintf:
fill (not terminated)
count the rest trace_sched_waking(p):
... memcpy(comm, p->comm, TASK_COMM_LEN)
write \0
The consequences depend on how 'other' uses the string. In our case,
it was copied into the tracing system's saved cmdlines, a buffer of
adjacent TASK_COMM_LEN-byte buffers (note the 'n' where 0 should be):
crash-arm64> x/1024s savedcmd->saved_cmdlines | grep 'evenk'
0xffffffd5b3818640: "irq/497-pwr_evenkworker/u16:12"
...and a strcpy out of there would cause stack corruption:
[224761.522292] Kernel panic - not syncing: stack-protector:
Kernel stack is corrupted in: ffffff9bf9783c78
crash-arm64> kbt | grep 'comm\|trace_print_context'
#6 0xffffff9bf9783c78 in trace_print_context+0x18c(+396)
comm (char [16]) = "irq/497-pwr_even"
crash-arm64> rd 0xffffffd4d0e17d14 8
ffffffd4d0e17d14: 2f71726900000000 5f7277702d373934 ....irq/497-pwr_
ffffffd4d0e17d24: 726f776b6e657665 3a3631752f72656b evenkworker/u16:
ffffffd4d0e17d34: f9780248ff003231 cede60e0ffffff9b 12..H.x......`..
ffffffd4d0e17d44: cede60c8ffffffd4 00000fffffffffd4 .....`..........
The workaround in e09e28671 (use strlcpy in __trace_find_cmdline) was
likely needed because of this same bug.
Solved by vsnprintf:ing to a local buffer, then using set_task_comm().
This way, there won't be a window where comm is not terminated.
Link: http://lkml.kernel.org/r/20180726071539.188015-1-snild@sony.com
Fixes: bc0c38d139ec7 ("ftrace: latency tracer infrastructure")
Reviewed-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
Signed-off-by: Snild Dolkow <snild@sony.com>
commit 15cc78644d0075e76d59476a4467e7143860f660 upstream.
There was a case that triggered a double free in event_trigger_callback()
due to the called reg() function freeing the trigger_data and then it
getting freed again by the error return by the caller. The solution there
was to up the trigger_data ref count.
Code inspection found that event_enable_trigger_func() has the same issue,
but is not as easy to trigger (requires harder to trigger failures). It
needs to be solved slightly different as it needs more to clean up when the
reg() function fails.
Link: http://lkml.kernel.org/r/20180725124008.7008e586@gandalf.local.home
Fixes: 7862ad1846e99 ("tracing: Add 'enable_event' and 'disable_event' event trigger commands")
Reivewed-by: Masami Hiramatsu <mhiramat@kernel.org>
commit 1863c387259b629e4ebfb255495f67cd06aa229b upstream.
Running the following:
# cd /sys/kernel/debug/tracing
# echo 500000 > buffer_size_kb
[ Or some other number that takes up most of memory ]
# echo snapshot > events/sched/sched_switch/trigger
Triggers the following bug:
kernel BUG at mm/slub.c:296!
invalid opcode: 0000 [#1] SMP DEBUG_PAGEALLOC PTI
CPU: 6 PID: 6878 Comm: bash Not tainted 4.18.0-rc6-test+ #1066
Hardware name: Hewlett-Packard HP Compaq Pro 6300 SFF/339A, BIOS K01 v03.03 07/14/2016
RIP: 0010:kfree+0x16c/0x180
Code: 05 41 0f b6 72 51 5b 5d 41 5c 4c 89 d7 e9 ac b3 f8 ff 48 89 d9 48 89 da 41 b8 01 00 00 00 5b 5d 41 5c 4c 89 d6 e9 f4 f3 ff ff <0f> 0b 0f 0b 48 8b 3d d9 d8 f9 00 e9 c1 fe ff ff 0f 1f 40 00 0f 1f
RSP: 0018:ffffb654436d3d88 EFLAGS: 00010246
RAX: ffff91a9d50f3d80 RBX: ffff91a9d50f3d80 RCX: ffff91a9d50f3d80
RDX: 00000000000006a4 RSI: ffff91a9de5a60e0 RDI: ffff91a9d9803500
RBP: ffffffff8d267c80 R08: 00000000000260e0 R09: ffffffff8c1a56be
R10: fffff0d404543cc0 R11: 0000000000000389 R12: ffffffff8c1a56be
R13: ffff91a9d9930e18 R14: ffff91a98c0c2890 R15: ffffffff8d267d00
FS: 00007f363ea64700(0000) GS:ffff91a9de580000(0000) knlGS:0000000000000000
CR2: 000055c1cacc8e10 CR3: 00000000d9b46003 CR4: 00000000001606e0
Call Trace:
event_trigger_callback+0xee/0x1d0
event_trigger_write+0xfc/0x1a0
__vfs_write+0x33/0x190
? handle_mm_fault+0x115/0x230
? _cond_resched+0x16/0x40
vfs_write+0xb0/0x190
ksys_write+0x52/0xc0
do_syscall_64+0x5a/0x160
entry_SYSCALL_64_after_hwframe+0x49/0xbe
RIP: 0033:0x7f363e16ab50
Code: 73 01 c3 48 8b 0d 38 83 2c 00 f7 d8 64 89 01 48 83 c8 ff c3 66 0f 1f 44 00 00 83 3d 79 db 2c 00 00 75 10 b8 01 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 31 c3 48 83 ec 08 e8 1e e3 01 00 48 89 04 24
RSP: 002b:00007fff9a4c6378 EFLAGS: 00000246 ORIG_RAX: 0000000000000001
RAX: ffffffffffffffda RBX: 0000000000000009 RCX: 00007f363e16ab50
RDX: 0000000000000009 RSI: 000055c1cacc8e10 RDI: 0000000000000001
RBP: 000055c1cacc8e10 R08: 00007f363e435740 R09: 00007f363ea64700
R10: 0000000000000073 R11: 0000000000000246 R12: 0000000000000009
R13: 0000000000000001 R14: 00007f363e4345e0 R15: 00007f363e4303c0
Modules linked in: ip6table_filter ip6_tables snd_hda_codec_hdmi snd_hda_codec_realtek snd_hda_codec_generic snd_hda_intel snd_hda_codec snd_hwdep snd_hda_core snd_seq snd_seq_device i915 snd_pcm snd_timer i2c_i801 snd soundcore i2c_algo_bit drm_kms_helper
86_pkg_temp_thermal video kvm_intel kvm irqbypass wmi e1000e
---[ end trace d301afa879ddfa25 ]---
The cause is because the register_snapshot_trigger() call failed to
allocate the snapshot buffer, and then called unregister_trigger()
which freed the data that was passed to it. Then on return to the
function that called register_snapshot_trigger(), as it sees it
failed to register, it frees the trigger_data again and causes
a double free.
By calling event_trigger_init() on the trigger_data (which only ups
the reference counter for it), and then event_trigger_free() afterward,
the trigger_data would not get freed by the registering trigger function
as it would only up and lower the ref count for it. If the register
trigger function fails, then the event_trigger_free() called after it
will free the trigger data normally.
Link: http://lkml.kernel.org/r/20180724191331.738eb819@gandalf.local.home
Cc: stable@vger.kerne.org
Fixes: 93e31ffbf417 ("tracing: Add 'snapshot' event trigger command")
Reported-by: Masami Hiramatsu <mhiramat@kernel.org>
Reviewed-by: Masami Hiramatsu <mhiramat@kernel.org>
commit fc14eebfc20854a38fd9f1d93a42b1783dad4d17 upstream.
syzbot is reporting NULL pointer dereference at snapshot_write() [1].
This is because data->handle is zero-cleared by ioctl(SNAPSHOT_FREE).
Fix this by checking data_of(data->handle) != NULL before using it.
[1] https://syzkaller.appspot.com/bug?id=828a3c71bd344a6de8b6a31233d51a72099f27fd
Reported-by: syzbot <syzbot+ae590932da6e45d6564d@syzkaller.appspotmail.com>
commit 1fe4293f4b8de75824935f8d8e9a99c7fc6873da upstream.
The function_graph tracer does not show the interrupt return marker for the
leaf entry. On leaf entries, we see an unbalanced interrupt marker (the
interrupt was entered, but nevern left).
Before:
1) | SyS_write() {
1) | __fdget_pos() {
1) 0.061 us | __fget_light();
1) 0.289 us | }
1) | vfs_write() {
1) 0.049 us | rw_verify_area();
1) + 15.424 us | __vfs_write();
1) ==========> |
1) 6.003 us | smp_apic_timer_interrupt();
1) 0.055 us | __fsnotify_parent();
1) 0.073 us | fsnotify();
1) + 23.665 us | }
1) + 24.501 us | }
After:
0) | SyS_write() {
0) | __fdget_pos() {
0) 0.052 us | __fget_light();
0) 0.328 us | }
0) | vfs_write() {
0) 0.057 us | rw_verify_area();
0) | __vfs_write() {
0) ==========> |
0) 8.548 us | smp_apic_timer_interrupt();
0) <========== |
0) + 36.507 us | } /* __vfs_write */
0) 0.049 us | __fsnotify_parent();
0) 0.066 us | fsnotify();
0) + 50.064 us | }
0) + 50.952 us | }
Link: http://lkml.kernel.org/r/1517413729-20411-1-git-send-email-changbin.du@intel.com
Fixes: f8b755ac8e0cc ("tracing/function-graph-tracer: Output arrows signal on hardirq call/return")
Signed-off-by: Changbin Du <changbin.du@intel.com>
commit abcbcb80cd09cd40f2089d912764e315459b71f7 upstream.
For the common cases where 1000 is a multiple of HZ, or HZ is a multiple of
1000, jiffies_to_msecs() never returns zero when passed a non-zero time
period.
However, if HZ > 1000 and not an integer multiple of 1000 (e.g. 1024 or
1200, as used on alpha and DECstation), jiffies_to_msecs() may return zero
for small non-zero time periods. This may break code that relies on
receiving back a non-zero value.
jiffies_to_usecs() does not need such a fix: one jiffy can only be less
than one µs if HZ > 1000000, and such large values of HZ are already
rejected at build time, twice:
- include/linux/jiffies.h does #error if HZ >= 12288,
- kernel/time/time.c has BUILD_BUG_ON(HZ > USEC_PER_SEC).
Broken since forever.
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Cc: John Stultz <john.stultz@linaro.org>
Cc: Stephen Boyd <sboyd@kernel.org>
Cc: linux-alpha@vger.kernel.org
Link: https://lkml.kernel.org/r/20180622143357.7495-1-geert@linux-m68k.org
commit 988a35f8da1dec5a8cd2788054d1e717be61bf25 upstream.
I noticed that there is a possibility that printk_safe_log_store() causes
kernel oops because "args" parameter is passed to vsnprintf() again when
atomic_cmpxchg() detected that we raced. Fix this by using va_copy().
Link: http://lkml.kernel.org/r/201805112002.GIF21216.OFVHFOMLJtQFSO@I-love.SAKURA.ne.jp
Cc: dvyukov@google.com
Cc: syzkaller@googlegroups.com
Cc: fengguang.wu@intel.com
Fixes: 42a0bb3f71383b45 ("printk/nmi: generic solution for safe printk in NMI")
Cc: 4.7+ <stable@vger.kernel.org> # v4.7+
Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
commit 86b389ff22bd6ad8fd3cb98e41cd271886c6d023 upstream.
If a instance has an event trigger enabled when it is freed, it could cause
an access of free memory. Here's the case that crashes:
# cd /sys/kernel/tracing
# mkdir instances/foo
# echo snapshot > instances/foo/events/initcall/initcall_start/trigger
# rmdir instances/foo
Would produce:
general protection fault: 0000 [#1] PREEMPT SMP PTI
Modules linked in: tun bridge ...
CPU: 5 PID: 6203 Comm: rmdir Tainted: G W 4.17.0-rc4-test+ #933
RIP: 0010:clear_event_triggers+0x3b/0x70
RSP: 0018:ffffc90003783de0 EFLAGS: 00010286
RAX: 0000000000000000 RBX: 6b6b6b6b6b6b6b2b RCX: 0000000000000000
RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffff8800c7130ba0
RBP: ffffc90003783e00 R08: ffff8801131993f8 R09: 0000000100230016
R10: ffffc90003783d80 R11: 0000000000000000 R12: ffff8800c7130ba0
R13: ffff8800c7130bd8 R14: ffff8800cc093768 R15: 00000000ffffff9c
FS: 00007f6f4aa86700(0000) GS:ffff88011eb40000(0000) knlGS:0000000000000000
CR2: 00007f6f4a5aed60 CR3: 00000000cd552001 CR4: 00000000001606e0
Call Trace:
event_trace_del_tracer+0x2a/0xc5
instance_rmdir+0x15c/0x200
tracefs_syscall_rmdir+0x52/0x90
vfs_rmdir+0xdb/0x160
do_rmdir+0x16d/0x1c0
__x64_sys_rmdir+0x17/0x20
do_syscall_64+0x55/0x1a0
This was due to the call the clears out the triggers when an instance is
being deleted not removing the trigger from the link list.
Fixes: 85f2b08268c01 ("tracing: Add basic event trigger framework")
commit c207aee48037abca71c669cbec407b9891965c34 upstream.
In preparation for an objtool rewrite which will have broader checks,
whitelist functions and files which cause problems because they do
unusual things with the stack.
These whitelists serve as a TODO list for which functions and files
don't yet have undwarf unwinder coverage. Eventually most of the
whitelists can be removed in favor of manual CFI hint annotations or
objtool improvements.
Cc: Jiri Slaby <jslaby@suse.cz>
Cc: live-patching@vger.kernel.org
Link: http://lkml.kernel.org/r/7f934a5d707a574bda33ea282e9478e627fb1829.1498659915.git.jpoimboe@redhat.com
[ Upstream commit 1e0ce03bf142454f38a5fc050bf4fd698d2d36d8 ]
The "mdr" command should repeat (continue) when only Enter/Return
is pressed, so make it do so.
Cc: Daniel Thompson <daniel.thompson@linaro.org>
Cc: Jason Wessel <jason.wessel@windriver.com>
Cc: kgdb-bugreport@lists.sourceforge.net
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
[ Upstream commit 3caa973b7a260e7a2a69edc94c300ab9c65148c3 ]
When RCU stall warning triggers, it can print out a lot of messages
while holding spinlocks. If the console device is slow (e.g. an
actual or IPMI serial console), it may end up triggering NMI hard
lockup watchdog like the following.
[ Upstream commit 23138ead270045f1b3e912e667967b6094244999 ]
If there is a memory allocation error when trying to change an audit
kernel feature value, the ignored allocation error will trigger a NULL
pointer dereference oops on subsequent use of that pointer. Return
instead.
Passes audit-testsuite.
See: https://github.com/linux-audit/audit-kernel/issues/76
Signed-off-by: Richard Guy Briggs <rgb@redhat.com>
[PM: not necessary (other funcs check for NULL), but a good practice]
[ Upstream commit 9e5b127d6f33468143d90c8a45ca12410e4c3fa7 ]
Mark reported his arm64 perf fuzzer runs sometimes splat like:
armv8pmu_read_counter+0x1e8/0x2d8
armpmu_event_update+0x8c/0x188
armpmu_read+0xc/0x18
perf_output_read+0x550/0x11e8
perf_event_read_event+0x1d0/0x248
perf_event_exit_task+0x468/0xbb8
do_exit+0x690/0x1310
do_group_exit+0xd0/0x2b0
get_signal+0x2e8/0x17a8
do_signal+0x144/0x4f8
do_notify_resume+0x148/0x1e8
work_pending+0x8/0x14
which asserts that we only call pmu::read() on ACTIVE events.
The above callchain does:
perf_event_exit_task()
perf_event_exit_task_context()
task_ctx_sched_out() // INACTIVE
perf_event_exit_event()
perf_event_set_state(EXIT) // EXIT
sync_child_event()
perf_event_read_event()
perf_output_read()
perf_output_read_group()
leader->pmu->read()
Which results in doing a pmu::read() on an !ACTIVE event.
I _think_ this is 'new' since we added attr.inherit_stat, which added
the perf_event_read_event() to the exit path, without that
perf_event_read_output() would only trigger from samples and for
@event to trigger a sample, it's leader _must_ be ACTIVE too.
Still, adding this check makes it consistent with the @sub case for
the siblings.
Reported-and-Tested-by: Mark Rutland <mark.rutland@arm.com>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Vince Weaver <vincent.weaver@maine.edu>
[ Upstream commit d29a20645d5e929aa7e8616f28e5d8e1c49263ec ]
While running rt-tests' pi_stress program I got the following splat:
rq->clock_update_flags < RQCF_ACT_SKIP
WARNING: CPU: 27 PID: 0 at kernel/sched/sched.h:960 assert_clock_updated.isra.38.part.39+0x13/0x20
<IRQ>
enqueue_top_rt_rq+0xf4/0x150
? cpufreq_dbs_governor_start+0x170/0x170
sched_rt_rq_enqueue+0x65/0x80
sched_rt_period_timer+0x156/0x360
? sched_rt_rq_enqueue+0x80/0x80
__hrtimer_run_queues+0xfa/0x260
hrtimer_interrupt+0xcb/0x220
smp_apic_timer_interrupt+0x62/0x120
apic_timer_interrupt+0xf/0x20
</IRQ>
do_idle+0x183/0x1e0
cpu_startup_entry+0x5f/0x70
start_secondary+0x192/0x1d0
secondary_startup_64+0xa5/0xb0
We can get rid of it be the "traditional" means of adding an
update_rq_clock() call after acquiring the rq->lock in
do_sched_rt_period_timer().
The case for the RT task throttling (which this workload also hits)
can be ignored in that the skip_update call is actually bogus and
quite the contrary (the request bits are removed/reverted).
By setting RQCF_UPDATED we really don't care if the skip is happening
or not and will therefore make the assert_clock_updated() check happy.
Signed-off-by: Davidlohr Bueso <dbueso@suse.de>
Reviewed-by: Matt Fleming <matt@codeblueprint.co.uk>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Cc: dave@stgolabs.net
Cc: rostedt@goodmis.org
Link: http://lkml.kernel.org/r/20180402164954.16255-1-dave@stgolabs.net
[ Upstream commit c917e0f259908e75bd2a65877e25f9d90c22c848 ]
When a perf_event is attached to parent cgroup, it should count events
for all children cgroups:
parent_group <---- perf_event
- child_group <---- process(es)
However, in our tests, we found this perf_event cannot report reliable
results. Here is an example case:
# create cgroups
mkdir -p /sys/fs/cgroup/p/c
# start perf for parent group
perf stat -e instructions -G "p"
# on another console, run test process in child cgroup:
stressapptest -s 2 -M 1000 & echo $! > /sys/fs/cgroup/p/c/cgroup.procs
# after the test process is done, stop perf in the first console shows
<not counted> instructions p
The instruction should not be "not counted" as the process runs in the
child cgroup.
We found this is because perf_event->cgrp and cpuctx->cgrp are not
identical, thus perf_event->cgrp are not updated properly.
This patch fixes this by updating perf_cgroup properly for ancestor
cgroup(s).
Reported-by: Ephraim Park <ephiepark@fb.com>
Signed-off-by: Song Liu <songliubraving@fb.com>
Cc: <jolsa@redhat.com>
Cc: <kernel-team@fb.com>
Link: http://lkml.kernel.org/r/20180312165943.1057894-1-songliubraving@fb.com
[ Upstream commit 537f4146c53c95aac977852b371bafb9c6755ee1 ]
Never directly free @dev after calling device_register(), even
if it returned an error! Always use put_device() to give up the
reference initialized in this function instead.
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
[ Upstream commit 88913bd8ea2a75d7e460a4bed5f75e1c32660d7e ]
chan->n_subbufs is set by the user and relay_create_buf() does a kmalloc()
of chan->n_subbufs * sizeof(size_t *).
kmalloc_slab() will generate a warning when this fails if
chan->subbufs * sizeof(size_t *) > KMALLOC_MAX_SIZE.
Limit chan->n_subbufs to the maximum allowed kmalloc() size.
Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1802061216100.122576@chino.kir.corp.google.com
Fixes: f6302f1bcd75 ("relay: prevent integer overflow in relay_open()")
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Dave Jiang <dave.jiang@intel.com>
Cc: Dan Carpenter <dan.carpenter@oracle.com>
[ Upstream commit 11dc13224c975efcec96647a4768a6f1bb7a19a8 ]
When queuing on the qspinlock, the count field for the current CPU's head
node is incremented. This needn't be atomic because locking in e.g. IRQ
context is balanced and so an IRQ will return with node->count as it
found it.
However, the compiler could in theory reorder the initialisation of
node[idx] before the increment of the head node->count, causing an
IRQ to overwrite the initialised node and potentially corrupt the lock
state.
Avoid the potential for this harmful compiler reordering by placing a
barrier() between the increment of the head node->count and the subsequent
node initialisation.
Link: http://lkml.kernel.org/r/1518528177-19169-3-git-send-email-will.deacon@arm.com
[ Upstream commit 328008a72d38b5bde6491e463405c34a81a65d3e ]
The declaration for swsusp_arch_resume marks it as 'asmlinkage', but the
definition in x86-32 does not, and it fails to include the header with the
declaration. This leads to a warning when building with
link-time-optimizations:
kernel/power/power.h:108:23: error: type of 'swsusp_arch_resume' does not match original declaration [-Werror=lto-type-mismatch]
extern asmlinkage int swsusp_arch_resume(void);
arch/x86/power/hibernate_32.c:148:0: note: 'swsusp_arch_resume' was previously declared here
This moves the declaration into a globally visible header file and fixes up
both x86 definitions to match it.
Cc: Len Brown <len.brown@intel.com>
Cc: Nicolas Pitre <nico@linaro.org>
Cc: linux-pm@vger.kernel.org
Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: Bart Van Assche <bart.vanassche@wdc.com>
Link: https://lkml.kernel.org/r/20180202145634.200291-2-arnd@arndb.de
