Makes low-level printk work.
If an interrupt occurs while the irq is masked, the irq is marked
as pending. For a level triggered interrupt, the pending flag
is only cleared when the interrupt is handled. If the interrupt
is never handled because the irq is deasserted before being
enabled it will stay pending, and suspend may be blocked by
check_wakeup_irqs.
Change check_irq_resend to always clear the pending flag,
including for level interrupts.
Signed-off-by: Colin Cross <ccross@android.com>
commit c75d720fca8a91ce99196d33adea383621027bf2 upstream.
commit d05c65fff0 ("genirq: spurious: Run only one poller at a time")
introduced a regression, leaving the boot options 'irqfixup' and
'irqpoll' non-functional. The patch placed tests in each function, to
exit if the function is already running. The test in 'misrouted_irq'
exited when it should have proceeded, effectively disabling
'misrouted_irq' and 'poll_spurious_irqs'.
The check for an already running poller needs to be "!= 1" not "== 1"
as "1" is the value when the first poller starts running.
Signed-off-by: Edward Donovan <edward.donovan@numble.net>
Cc: maciej.rutecki@gmail.com
Link: http://lkml.kernel.org/r/1320175784-6745-1-git-send-email-edward.donovan@numble.net
commit 528f7ce6e439edeac38f6b3f8561f1be129b5e91 upstream.
In enter_state() we use "state" as an offset for the pm_states[]
array. The pm_states[] array only has PM_SUSPEND_MAX elements so
this test is off by one.
commit 9bab0b7fbaceec47d32db51cd9e59c82fb071f5a upstream.
This adds a mechanism to resume selected IRQs during syscore_resume
instead of dpm_resume_noirq.
Under Xen we need to resume IRQs associated with IPIs early enough
that the resched IPI is unmasked and we can therefore schedule
ourselves out of the stop_machine where the suspend/resume takes
place.
This issue was introduced by 676dc3cf5bc3 "xen: Use IRQF_FORCE_RESUME".
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Cc: Rafael J. Wysocki <rjw@sisk.pl>
Cc: Jeremy Fitzhardinge <Jeremy.Fitzhardinge@citrix.com>
Cc: xen-devel <xen-devel@lists.xensource.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Link: http://lkml.kernel.org/r/1318713254.11016.52.camel@dagon.hellion.org.uk
commit 436fc280261dcfce5af38f08b89287750dc91cd2 upstream.
The trace_pipe_raw handler holds a cached page from the time the file
is opened to the time it is closed. The cached page is used to handle
the case of the user space buffer being smaller than what was read from
the ring buffer. The left over buffer is held in the cache so that the
next read will continue where the data left off.
After EOF is returned (no more data in the buffer), the index of
the cached page is set to zero. If a user app reads the page again
after EOF, the check in the buffer will see that the cached page
is less than page size and will return the cached page again. This
will cause reading the trace_pipe_raw again after EOF to return
duplicate data, making the output look like the time went backwards
but instead data is just repeated.
The fix is to not reset the index right after all data is read
from the cache, but to reset it after all data is read and more
data exists in the ring buffer.
Reported-by: Jeremy Eder <jeder@redhat.com>
commit 02ca1521ad404cf566e0075848f80d064c0a0503 upstream.
Fix kprobe-tracer not to delete a probe if the probe is in use.
In that case, delete operation will return -EBUSY.
This bug can cause a kernel panic if enabled probes are deleted
during perf record.
(Add some probes on functions)
sh-4.2# perf probe --del probe:\*
sh-4.2# exit
(kernel panic)
This is originally reported on the fedora bugzilla:
https://bugzilla.redhat.com/show_bug.cgi?id=742383
I've also checked that this problem doesn't happen on
tracepoints when module removing because perf event
locks target module.
$ sudo ./perf record -e xfs:\* -aR sh
sh-4.2# rmmod xfs
ERROR: Module xfs is in use
sh-4.2# exit
[ perf record: Woken up 1 times to write data ]
[ perf record: Captured and wrote 0.203 MB perf.data (~8862 samples) ]
Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Frank Ch. Eigler <fche@redhat.com>
Link: http://lkml.kernel.org/r/20111004104438.14591.6553.stgit@fedora15
commit cbbc719fccdb8cbd87350a05c0d33167c9b79365 upstream.
The parameter's origin type is long. On an i386 architecture, it can
easily be larger than 0x80000000, causing this function to convert it
to a sign-extended u64 type.
Change the type to unsigned long so we get the correct result.
Signed-off-by: hank <pyu@redhat.com>
Cc: John Stultz <john.stultz@linaro.org>
[ build fix ]
commit 37252db6aa576c34fd794a5a54fb32d7a8b3a07a upstream.
Due to post-increment in condition of kmod_loop_msg in __request_module(),
the system log can be spammed by much more than 5 instances of the 'runaway
loop' message if the number of events triggering it makes the kmod_loop_msg
to overflow.
Fix that by making sure we never increment it past the threshold.
There's a lock inversion between the cputimer->lock and rq->lock;
notably the two callchains involved are:
update_rlimit_cpu()
sighand->siglock
set_process_cpu_timer()
cpu_timer_sample_group()
thread_group_cputimer()
cputimer->lock
thread_group_cputime()
task_sched_runtime()
->pi_lock
rq->lock
scheduler_tick()
rq->lock
task_tick_fair()
update_curr()
account_group_exec()
cputimer->lock
Where the first one is enabling a CLOCK_PROCESS_CPUTIME_ID timer, and
the second one is keeping up-to-date.
This problem was introduced by e8abccb7193 ("posix-cpu-timers: Cure
SMP accounting oddities").
Cure the problem by removing the cputimer->lock and rq->lock nesting,
this leaves concurrent enablers doing duplicate work, but the time
wasted should be on the same order otherwise wasted spinning on the
lock and the greater-than assignment filter should ensure we preserve
monotonicity.
Reported-by: Dave Jones <davej@redhat.com>
Reported-by: Simon Kirby <sim@hostway.ca>
Cc: stable@kernel.org
Link: http://lkml.kernel.org/r/1318928713.21167.4.camel@twins
The size is always valid, but variable-length arrays generate worse code
for no good reason (unless the function happens to be inlined and the
compiler sees the length for the simple constant it is).
Also, there seems to be some code generation problem on POWER, where
Henrik Bakken reports that register r28 can get corrupted under some
subtle circumstances (interrupt happening at the wrong time?). That all
indicates some seriously broken compiler issues, but since variable
length arrays are bad regardless, there's little point in trying to
chase it down.
"Just don't do that, then".
Reported-by: Henrik Grindal Bakken <henribak@cisco.com>
'sched-urgent-for-linus' of git://tesla.tglx.de/git/linux-2.6-tip
* 'irq-urgent-for-linus' of git://tesla.tglx.de/git/linux-2.6-tip:
irq: Fix check for already initialized irq_domain in irq_domain_add
irq: Add declaration of irq_domain_simple_ops to irqdomain.h
* 'x86-urgent-for-linus' of git://tesla.tglx.de/git/linux-2.6-tip:
x86/rtc: Don't recursively acquire rtc_lock
* 'sched-urgent-for-linus' of git://tesla.tglx.de/git/linux-2.6-tip:
posix-cpu-timers: Cure SMP wobbles
sched: Fix up wchan borkage
sched/rt: Migrate equal priority tasks to available CPUs
David reported:
Attached below is a watered-down version of rt/tst-cpuclock2.c from
GLIBC. Just build it with "gcc -o test test.c -lpthread -lrt" or
similar.
Run it several times, and you will see cases where the main thread
will measure a process clock difference before and after the nanosleep
which is smaller than the cpu-burner thread's individual thread clock
difference. This doesn't make any sense since the cpu-burner thread
is part of the top-level process's thread group.
I've reproduced this on both x86-64 and sparc64 (using both 32-bit and
64-bit binaries).
For example:
[davem@boricha build-x86_64-linux]$ ./test
process: before(0.001221967) after(0.498624371) diff(497402404)
thread: before(0.000081692) after(0.498316431) diff(498234739)
self: before(0.001223521) after(0.001240219) diff(16698)
The diff of 'process' should always be >= the diff of 'thread'.
I make sure to wrap the 'thread' clock measurements the most tightly
around the nanosleep() call, and that the 'process' clock measurements
are the outer-most ones.
#include <unistd.h>
#include <stdio.h>
#include <stdlib.h>
#include <time.h>
#include <fcntl.h>
#include <string.h>
#include <errno.h>
#include <pthread.h>
static pthread_barrier_t barrier;
static void *chew_cpu(void *arg)
pthread_barrier_wait(&barrier);
while (1)
__asm__ __volatile__("" : : : "memory");
return NULL;
int main(void)
clockid_t process_clock, my_thread_clock, th_clock;
struct timespec process_before, process_after;
struct timespec me_before, me_after;
struct timespec th_before, th_after;
struct timespec sleeptime;
unsigned long diff;
pthread_t th;
int err;
err = clock_getcpuclockid(0, &process_clock);
if (err)
return 1;
err = pthread_getcpuclockid(pthread_self(), &my_thread_clock);
if (err)
return 1;
pthread_barrier_init(&barrier, NULL, 2);
err = pthread_create(&th, NULL, chew_cpu, NULL);
if (err)
return 1;
err = pthread_getcpuclockid(th, &th_clock);
if (err)
return 1;
err = clock_gettime(process_clock, &process_before);
if (err)
return 1;
err = clock_gettime(my_thread_clock, &me_before);
if (err)
return 1;
err = clock_gettime(th_clock, &th_before);
if (err)
return 1;
sleeptime.tv_sec = 0;
sleeptime.tv_nsec = 500000000;
nanosleep(&sleeptime, NULL);
err = clock_gettime(th_clock, &th_after);
if (err)
return 1;
err = clock_gettime(my_thread_clock, &me_after);
if (err)
return 1;
err = clock_gettime(process_clock, &process_after);
if (err)
return 1;
diff = process_after.tv_nsec - process_before.tv_nsec;
printf("process: before(%lu.%.9lu) after(%lu.%.9lu) diff(%lu)\n",
process_before.tv_sec, process_before.tv_nsec,
process_after.tv_sec, process_after.tv_nsec, diff);
diff = th_after.tv_nsec - th_before.tv_nsec;
printf("thread: before(%lu.%.9lu) after(%lu.%.9lu) diff(%lu)\n",
th_before.tv_sec, th_before.tv_nsec,
th_after.tv_sec, th_after.tv_nsec, diff);
diff = me_after.tv_nsec - me_before.tv_nsec;
printf("self: before(%lu.%.9lu) after(%lu.%.9lu) diff(%lu)\n",
me_before.tv_sec, me_before.tv_nsec,
me_after.tv_sec, me_after.tv_nsec, diff);
return 0;
This is due to us using p->se.sum_exec_runtime in
thread_group_cputime() where we iterate the thread group and sum all
data. This does not take time since the last schedule operation (tick
or otherwise) into account. We can cure this by using
task_sched_runtime() at the cost of having to take locks.
This also means we can (and must) do away with
thread_group_sched_runtime() since the modified thread_group_cputime()
is now more accurate and would deadlock when called from
thread_group_sched_runtime().
Aside of that it makes the function safe on 32 bit systems. The old
code added t->se.sum_exec_runtime unprotected. sum_exec_runtime is a
64bit value and could be changed on another cpu at the same time.
Reported-by: David Miller <davem@davemloft.net>
Link: http://lkml.kernel.org/r/1314874459.7945.22.camel@twins
Tested-by: David Miller <davem@davemloft.net>
__find_resource() incorrectly returns a resource window which overlaps
an existing allocated window. This happens when the parent's
resource-window spans 0x00000000 to 0xffffffff and is entirely allocated
to all its children resource-windows.
__find_resource() looks for gaps in resource allocation among the
children resource windows. When it encounters the last child window it
blindly tries the range next to one allocated to the last child. Since
the last child's window ends at 0xffffffff the calculation overflows,
leading the algorithm to believe that any window in the range 0x0000000
to 0xfffffff is available for allocation. This leads to a conflicting
window allocation.
Michal Ludvig reported this issue seen on his platform. The following
patch fixes the problem and has been verified by Michal. I believe this
bug has been there for ages. It got exposed by git commit 2bbc6942273b
("PCI : ability to relocate assigned pci-resources")
Signed-off-by: Ram Pai <linuxram@us.ibm.com>
Tested-by: Michal Ludvig <mludvig@logix.net.nz>
Commit c259e01a1ec ("sched: Separate the scheduler entry for
preemption") contained a boo-boo wrecking wchan output. It forgot to
put the new schedule() function in the __sched section and thereby
doesn't get properly ignored for things like wchan.
Tested-by: Simon Kirby <sim@hostway.ca>
Cc: stable@kernel.org # 2.6.39+
Link: http://lkml.kernel.org/r/20110923000346.GA25425@hostway.ca
If PTRACE_LISTEN fails after lock_task_sighand() it doesn't drop ->siglock.
Reported-by: Matt Fleming <matt.fleming@intel.com>
The sanity check in irq_domain_add() tests desc->irq_data != NULL or
irq_data->domain != NULL. This prevents adding an irq_domain to a irq
descriptor when irq_data exists, which true when the irq descriptor
exists.
This went unnoticed so far as the simple domain code did not enter
this code path because domain->nr_irqs is always 0 for the simple domains.
Split the check for irq_data == NULL out and have a separate warning
for it.
[ tglx: Made the check for irq_data == NULL separate ]
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: marc.zyngier@arm.com
Cc: thomas.abraham@linaro.org
Cc: jamie@jamieiles.com
Cc: b-cousson@ti.com
Cc: shawn.guo@linaro.org
Cc: devicetree-discuss@lists.ozlabs.org
Link: http://lkml.kernel.org/r/1316017900-19918-3-git-send-email-robherring2@gmail.com
* 'irq-fixes-for-linus' of git://tesla.tglx.de/git/linux-2.6-tip:
x86, iommu: Mark DMAR IRQ as non-threaded
genirq: Make irq_shutdown() symmetric vs. irq_startup again
Even with just the interface limited to admin, there really is little to
reason to give byte-per-byte counts for taskstats. So round it down to
something less intrusive.
Acked-by: Balbir Singh <bsingharora@gmail.com>
Ok, this isn't optimal, since it means that 'iotop' needs admin
capabilities, and we may have to work on this some more. But at the
same time it is very much not acceptable to let anybody just read
anybody elses IO statistics quite at this level.
Use of the GENL_ADMIN_PERM suggested by Johannes Berg as an alternative
to checking the capabilities by hand.
Reported-by: Vasiliy Kulikov <segoon@openwall.com>
Cc: Johannes Berg <johannes.berg@intel.com>
Commit 43fa5460fe60dea5c610490a1d263415419c60f6 ("sched: Try not to
migrate higher priority RT tasks") also introduced a change in behavior
which keeps RT tasks on the same CPU if there is an equal priority RT
task currently running even if there are empty CPUs available.
This can cause unnecessary wakeup latencies, and can prevent the
scheduler from balancing all RT tasks across available CPUs.
This change causes an RT task to search for a new CPU if an equal
priority RT task is already running on wakeup. Lower priority tasks
will still have to wait on higher priority tasks, but the system should
still balance out because there is always the possibility that if there
are both a high and low priority RT tasks on a given CPU that the high
priority task could wakeup while the low priority task is running and
force it to search for a better runqueue.
Signed-off-by: Shawn Bohrer <sbohrer@rgmadvisors.com>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Tested-by: Steven Rostedt <rostedt@goodmis.org>
Cc: stable@kernel.org # 37+
Link: http://lkml.kernel.org/r/1315837684-18733-1-git-send-email-sbohrer@rgmadvisors.com
Take cwq->gcwq->lock to avoid racing between drain_workqueue checking to
make sure the workqueues are empty and cwq_dec_nr_in_flight decrementing
and then incrementing nr_active when it activates a delayed work.
We discovered this when a corner case in one of our drivers resulted in
us trying to destroy a workqueue in which the remaining work would
always requeue itself again in the same workqueue. We would hit this
race condition and trip the BUG_ON on workqueue.c:3080.
Signed-off-by: Thomas Tuttle <ttuttle@chromium.org>
Acked-by: Tejun Heo <tj@kernel.org>
Cc: <stable@kernel.org>
If an irq_chip provides .irq_shutdown(), but neither of .irq_disable() or
.irq_mask(), free_irq() crashes when jumping to NULL.
Fix this by only trying .irq_disable() and .irq_mask() if there's no
.irq_shutdown() provided.
This revives the symmetry with irq_startup(), which tries .irq_startup(),
.irq_enable(), and irq_unmask(), and makes it consistent with the comment for
irq_chip.irq_shutdown() in <linux/irq.h>, which says:
* @irq_shutdown: shut down the interrupt (defaults to ->disable if NULL)
This is also how __free_irq() behaved before the big overhaul, cfr. e.g.
3b56f0585fd4c02d047dc406668cb40159b2d340 ("genirq: Remove bogus conditional"),
where the core interrupt code always overrode .irq_shutdown() to
.irq_disable() if .irq_shutdown() was NULL.
Cc: linux-m68k@lists.linux-m68k.org
Link: http://lkml.kernel.org/r/1315742394-16036-2-git-send-email-geert@linux-m68k.org
* 'timers-fixes-for-linus' of git://tesla.tglx.de/git/linux-2.6-tip:
rtc: twl: Fix registration vs. init order
rtc: Initialized rtc_time->tm_isdst
rtc: Fix RTC PIE frequency limit
rtc: rtc-twl: Remove lockdep related local_irq_enable()
rtc: rtc-twl: Switch to using threaded irq
rtc: ep93xx: Fix 'rtc' may be used uninitialized warning
alarmtimers: Avoid possible denial of service with high freq periodic timers
alarmtimers: Memset itimerspec passed into alarm_timer_get
alarmtimers: Avoid possible null pointer traversal
* 'sched-fixes-for-linus' of git://tesla.tglx.de/git/linux-2.6-tip:
sched: Fix a memory leak in __sdt_free()
sched: Move blk_schedule_flush_plug() out of __schedule()
sched: Separate the scheduler entry for preemption
We detected a serious issue with PERF_SAMPLE_READ and
timing information when events were being multiplexing.
Samples would have time_running > time_enabled. That
was easy to reproduce with a libpfm4 example (ran 3
times to cause multiplexing on Core 2):
$ syst_smpl -e uops_retired:freq=1 &
IIP:0x0000000040062d ... PERIOD:2355332948 ENA=40144625315 RUN=60014875184
syst_smpl: WARNING: time_running > time_enabled
63277537998 uops_retired:freq=1 , scaled
The bug was not present in kernel up to (and including) 3.0. It turns
out the bug was introduced by the following commit:
commit c4794295917ebeda8013b6cb9c8d71ab4f74a1fa
events: Move lockless timer calculation into helper function
The parameters of the function got reversed yet the call sites
were not updated to reflect the change. That lead to time_running
and time_enabled being swapped. That had no effect when there was
no multiplexing because in that case time_running = time_enabled
but it would show up in any other scenario.
Signed-off-by: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/r/20110829124112.GA4828@quad
The current cgroup context switch code was incorrect leading
to bogus counts. Furthermore, as soon as there was an active
cgroup event on a CPU, the context switch cost on that CPU
would increase by a significant amount as demonstrated by a
simple ping/pong example:
$ ./pong
Both processes pinned to CPU1, running for 10s
10684.51 ctxsw/s
Now start a cgroup perf stat:
$ perf stat -e cycles,cycles -A -a -G test -C 1 -- sleep 100
$ ./pong
6674.61 ctxsw/s
That's a 37% penalty.
Note that pong is not even in the monitored cgroup.
The results shown by perf stat are bogus:
Performance counter stats for 'sleep 100':
CPU1 <not counted> cycles test
CPU1 16,984,189,138 cycles # 0.000 GHz
The second 'cycles' event should report a count @ CPU clock
(here 2.4GHz) as it is counting across all cgroups.
The patch below fixes the bogus accounting and bypasses any
cgroup switches in case the outgoing and incoming tasks are
in the same cgroup.
With this patch the same test now yields:
$ ./pong
10775.30 ctxsw/s
Start perf stat with cgroup:
Run pong outside the cgroup:
$ /pong
10687.80 ctxsw/s
The penalty is now less than 2%.
And the results for perf stat are correct:
Performance counter stats for 'sleep 10':
CPU1 <not counted> cycles test # 0.000 GHz
CPU1 23,933,981,448 cycles # 0.000 GHz
Now perf stat reports the correct counts for
for the non cgroup event.
If we run pong inside the cgroup, then we also get the
correct counts:
CPU1 22,297,726,205 cycles test # 0.000 GHz
10.001457237 seconds time elapsed
Link: http://lkml.kernel.org/r/20110825135803.GA4697@quad
This patch fixes the following memory leak:
unreferenced object 0xffff880107266800 (size 512):
comm "sched-powersave", pid 3718, jiffies 4323097853 (age 27495.450s)
hex dump (first 32 bytes):
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
backtrace:
[<ffffffff81133940>] create_object+0x187/0x28b
[<ffffffff814ac103>] kmemleak_alloc+0x73/0x98
[<ffffffff811232ba>] __kmalloc_node+0x104/0x159
[<ffffffff81044b98>] kzalloc_node.clone.97+0x15/0x17
[<ffffffff8104cb90>] build_sched_domains+0xb7/0x7f3
[<ffffffff8104d4df>] partition_sched_domains+0x1db/0x24a
[<ffffffff8109ee4a>] do_rebuild_sched_domains+0x3b/0x47
[<ffffffff810a00c7>] rebuild_sched_domains+0x10/0x12
[<ffffffff8104d5ba>] sched_power_savings_store+0x6c/0x7b
[<ffffffff8104d5df>] sched_mc_power_savings_store+0x16/0x18
[<ffffffff8131322c>] sysdev_class_store+0x20/0x22
[<ffffffff81193876>] sysfs_write_file+0x108/0x144
[<ffffffff81135b10>] vfs_write+0xaf/0x102
[<ffffffff81135d23>] sys_write+0x4d/0x74
[<ffffffff814c8a42>] system_call_fastpath+0x16/0x1b
[<ffffffffffffffff>] 0xffffffffffffffff
Signed-off-by: WANG Cong <amwang@redhat.com>
Cc: stable@kernel.org # 3.0
Link: http://lkml.kernel.org/r/1313671017-4112-1-git-send-email-amwang@redhat.com
There is no real reason to run blk_schedule_flush_plug() with
interrupts and preemption disabled.
Move it into schedule() and call it when the task is going voluntarily
to sleep. There might be false positives when the task is woken
between that call and actually scheduling, but that's not really
different from being woken immediately after switching away.
This fixes a deadlock in the scheduler where the
blk_schedule_flush_plug() callchain enables interrupts and thereby
allows a wakeup to happen of the task that's going to sleep.
Cc: Tejun Heo <tj@kernel.org>
Link: http://lkml.kernel.org/n/tip-dwfxtra7yg1b5r65m32ywtct@git.kernel.org
Block-IO and workqueues call into notifier functions from the
scheduler core code with interrupts and preemption disabled. These
calls should be made before entering the scheduler core.
To simplify this, separate the scheduler core code into
__schedule(). __schedule() is directly called from the places which
set PREEMPT_ACTIVE and from schedule(). This allows us to add the work
checks into schedule(), so they are only called when a task voluntary
goes to sleep.
Link: http://lkml.kernel.org/r/20110622174918.813258321@linutronix.de
The nfsservctl system call is now gone, so we should remove all
linkage for it.
Signed-off-by: NeilBrown <neilb@suse.de>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
It seems that 7bf693951a8e ("console: allow to retain boot console via
boot option keep_bootcon") doesn't always achieve what it aims, as when
printk_late_init() runs it unconditionally turns off all boot consoles.
With this patch, I am able to see more messages on the boot console in
KVM guests than I can without, when keep_bootcon is specified.
I think it is appropriate for the relevant -stable trees. However, it's
more of an annoyance than a serious bug (ideally you don't need to keep
the boot console around as console handover should be working -- I was
encountering a situation where the console handover wasn't working and
not having the boot console available meant I couldn't see why).
Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Greg KH <gregkh@suse.de>
Acked-by: Fabio M. Di Nitto <fdinitto@redhat.com>
Cc: <stable@kernel.org> [2.6.39.x, 3.0.x]
I ran into a couple of programs which broke with the new Linux 3.0
version. Some of those were binary only. I tried to use LD_PRELOAD to
work around it, but it was quite difficult and in one case impossible
because of a mix of 32bit and 64bit executables.
For example, all kind of management software from HP doesnt work, unless
we pretend to run a 2.6 kernel.
$ uname -a
Linux svivoipvnx001 3.0.0-08107-g97cd98f #1062 SMP Fri Aug 12 18:11:45 CEST 2011 i686 i686 i386 GNU/Linux
$ hpacucli ctrl all show
Error: No controllers detected.
$ rpm -qf /usr/sbin/hpacucli
hpacucli-8.75-12.0
Another notable case is that Python now reports "linux3" from
sys.platform(); which in turn can break things that were checking
sys.platform() == "linux2":
https://bugzilla.mozilla.org/show_bug.cgi?id=664564
It seems pretty clear to me though it's a bug in the apps that are using
'==' instead of .startswith(), but this allows us to unbreak broken
programs.
This patch adds a UNAME26 personality that makes the kernel report a
2.6.40+x version number instead. The x is the x in 3.x.
I know this is somewhat ugly, but I didn't find a better workaround, and
compatibility to existing programs is important.
Some programs also read /proc/sys/kernel/osrelease. This can be worked
around in user space with mount --bind (and a mount namespace)
To use:
wget ftp://ftp.kernel.org/pub/linux/kernel/people/ak/uname26/uname26.c
gcc -o uname26 uname26.c
./uname26 program
* 'for-linus' of git://oss.sgi.com/xfs/xfs:
xfs: fix tracing builds inside the source tree
xfs: remove subdirectories
xfs: don't expect xfs headers to be in subdirectories
This reverts commit f3637a5f2e2eb391ff5757bc83fb5de8f9726464.
It turns out that this breaks several drivers, one example being OMAP
boards which use the on-board OMAP UARTs and the omap-serial driver that
will not boot to userspace after the commit.
Paul Walmsley reports that enabling CONFIG_DEBUG_SHIRQ reveals 'IRQ
handler type mismatch' errors:
IRQ handler type mismatch for IRQ 74
current handler: serial idle
and the reason is that setting IRQF_ONESHOT will now result in those
interrupt handlers having different IRQF flags, and thus being
unsharable. So the commit log in the reverted commit:
"Since it is required for those users and
there is no difference for others it makes sense to add this flag
unconditionally."
is simply not true: there may not be any difference from a "actions at
irq time", but there is a *big* difference wrt this flag testing irq
management (see __setup_irq() in kernel/irq/manage.c).
One solution may be to stop verifying IRQF_ONESHOT in __setup_irq(), but
right now the safe course of action is to revert the change. Let's
revisit this in a later merge window.
Reported-by: Paul Walmsley <paul@pwsan.com>
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Requested-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
* 'for-linus' of git://git.kernel.dk/linux-block: (23 commits)
Revert "cfq: Remove special treatment for metadata rqs."
block: fix flush machinery for stacking drivers with differring flush flags
block: improve rq_affinity placement
blktrace: add FLUSH/FUA support
Move some REQ flags to the common bio/request area
allow blk_flush_policy to return REQ_FSEQ_DATA independent of *FLUSH
xen/blkback: Make description more obvious.
cfq-iosched: Add documentation about idling
block: Make rq_affinity = 1 work as expected
block: swim3: fix unterminated of_device_id table
block/genhd.c: remove useless cast in diskstats_show()
drivers/cdrom/cdrom.c: relax check on dvd manufacturer value
drivers/block/drbd/drbd_nl.c: use bitmap_parse instead of __bitmap_parse
bsg-lib: add module.h include
cfq-iosched: Reduce linked group count upon group destruction
blk-throttle: correctly determine sync bio
loop: fix deadlock when sysfs and LOOP_CLR_FD race against each other
loop: add BLK_DEV_LOOP_MIN_COUNT=%i to allow distros 0 pre-allocated loop devices
loop: add management interface for on-demand device allocation
loop: replace linked list of allocated devices with an idr index
Fix kernel-doc warning in irqdesc.c:
Warning(kernel/irq/irqdesc.c:353): No description found for parameter 'owner'
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
* 'pm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
PM / Domains: Fix build for CONFIG_PM_RUNTIME unset
* 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
lockdep: Fix wrong assumption in match_held_lock
* 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
irq: Track the owner of irq descriptor
irq: Always set IRQF_ONESHOT if no primary handler is specified
genirq: Fix wrong bit operation
Function genpd_queue_power_off_work() is not defined for
CONFIG_PM_RUNTIME, so pm_genpd_poweroff_unused() causes a build
error to happen in that case. Fix the problem by making
pm_genpd_poweroff_unused() depend on CONFIG_PM_RUNTIME too.
Use the move from Linux 2.6 to Linux 3.x as an excuse to kill the
annoying subdirectories in the XFS source code. Besides the large
amount of file rename the only changes are to the Makefile, a few
files including headers with the subdirectory prefix, and the binary
sysctl compat code that includes a header under fs/xfs/ from
kernel/.
Signed-off-by: Alex Elder <aelder@sgi.com>
The patch http://lkml.org/lkml/2003/7/13/226 introduced an RLIMIT_NPROC
check in set_user() to check for NPROC exceeding via setuid() and
similar functions.
Before the check there was a possibility to greatly exceed the allowed
number of processes by an unprivileged user if the program relied on
rlimit only. But the check created new security threat: many poorly
written programs simply don't check setuid() return code and believe it
cannot fail if executed with root privileges. So, the check is removed
in this patch because of too often privilege escalations related to
buggy programs.
The NPROC can still be enforced in the common code flow of daemons
spawning user processes. Most of daemons do fork()+setuid()+execve().
The check introduced in execve() (1) enforces the same limit as in
setuid() and (2) doesn't create similar security issues.
Neil Brown suggested to track what specific process has exceeded the
limit by setting PF_NPROC_EXCEEDED process flag. With the change only
this process would fail on execve(), and other processes' execve()
behaviour is not changed.
Solar Designer suggested to re-check whether NPROC limit is still
exceeded at the moment of execve(). If the process was sleeping for
days between set*uid() and execve(), and the NPROC counter step down
under the limit, the defered execve() failure because NPROC limit was
exceeded days ago would be unexpected. If the limit is not exceeded
anymore, we clear the flag on successful calls to execve() and fork().
The flag is also cleared on successful calls to set_user() as the limit
was exceeded for the previous user, not the current one.
Similar check was introduced in -ow patches (without the process flag).
v3 - clear PF_NPROC_EXCEEDED on successful calls to set_user().
Reviewed-by: James Morris <jmorris@namei.org>
Signed-off-by: Vasiliy Kulikov <segoon@openwall.com>
Acked-by: NeilBrown <neilb@suse.de>
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
perf symbols: Check '/tmp/perf-' symbol file ownership
perf sched: Usage leftover from trace -> script rename
perf sched: Do not delete session object prematurely
perf tools: Check $HOME/.perfconfig ownership
perf, x86: Add model 45 SandyBridge support
perf tools: Add support to install perf python extension
perf tools: do not look at ./config for configuration
perf tools: Make clean leaves some files
perf lock: Dropping unsupported ':r' modifier
perf probe: Fix coredump introduced by probe module option
jump label: Reduce the cycle count by changing the link order
perf report: Use ui__warning in some more places
perf python: Add PERF_RECORD_{LOST,READ,SAMPLE} routine tables
perf evlist: Introduce 'disable' method
trace events: Update version number reference to new 3.x scheme for EVENT_POWER_TRACING_DEPRECATED
perf buildid-cache: Zero out buffer of filenames when adding/removing buildid
Add FLUSH/FUA support to blktrace. As FLUSH precedes WRITE and/or
FUA follows WRITE, use the same 'F' flag for both cases and
distinguish them by their (relative) position. The end results
look like (other flags might be shown also):
- WRITE: W
- WRITE_FLUSH: FW
- WRITE_FUA: WF
- WRITE_FLUSH_FUA: FWF
Note that we reuse TC_BARRIER due to lack of bit space of act_mask
so that the older versions of blktrace tools will report flush
requests as barriers from now on.
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
Reviewed-by: Jeff Moyer <jmoyer@redhat.com>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
Its possible to jam up the alarm timers by setting very small interval
timers, which will cause the alarmtimer subsystem to spend all of its time
firing and restarting timers. This can effectivly lock up a box.
A deeper fix is needed, closely mimicking the hrtimer code, but for now
just cap the interval to 100us to avoid userland hanging the system.
CC: Thomas Gleixner <tglx@linutronix.de>
CC: stable@kernel.org
Signed-off-by: John Stultz <john.stultz@linaro.org>
Following common_timer_get, zero out the itimerspec passed in.
We don't check if old_setting is non null before assigning it, so
correct this.
syslog-ng versions before 3.3.0beta1 (2011-05-12) assume that
CAP_SYS_ADMIN is sufficient to access syslog, so ever since CAP_SYSLOG
was introduced (2010-11-25) they have triggered a warning.
Commit ee24aebffb75 ("cap_syslog: accept CAP_SYS_ADMIN for now")
improved matters a little by making syslog-ng work again, just keeping
the WARN_ONCE(). But still, this is a warning that writes a stack trace
we don't care about to syslog, sets a taint flag, and alarms sysadmins
when nothing worse has happened than use of an old userspace with a
recent kernel.
Convert the WARN_ONCE to a printk_once to avoid that while continuing to
give userspace developers a hint that this is an unwanted
backward-compatibility feature and won't be around forever.
Reported-by: Ralf Hildebrandt <ralf.hildebrandt@charite.de>
Reported-by: Niels <zorglub_olsen@hotmail.com>
Reported-by: Paweł Sikora <pluto@agmk.net>
Signed-off-by: Jonathan Nieder <jrnieder@gmail.com>
Liked-by: Gergely Nagy <algernon@madhouse-project.org>
Acked-by: Serge Hallyn <serge@hallyn.com>
Acked-by: James Morris <jmorris@namei.org>
match_held_lock() was assuming it was being called on a lock class
that had already seen usage.
This condition was true for bug-free code using lockdep_assert_held(),
since you're in fact holding the lock when calling it. However the
assumption fails the moment you assume the assertion can fail, which
is the whole point of having the assertion in the first place.
Anyway, now that there's more lockdep_is_held() users, notably
__rcu_dereference_check(), its much easier to trigger this since we
test for a number of locks and we only need to hold any one of them to
be good.
Reported-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Link: http://lkml.kernel.org/r/1312547787.28695.2.camel@twins
