path: root/kernel
2012-11-26arm: workqueue: fix get_pool_nr_running()Marcel Ziswiler
Unfortunately when merging 15 patches NVIDIA missed 3 resp. 4 lines which failed UP case (e.g. on PXA). The offending commit in question is 9dfdd9ac17ac9955b431cb962df3d0492384ba0e The list of commits the above should have included is as follows: 974271c485a4d8bb801decc616748f90aafb07ec bd7bdd43dcb81bb08240b9401b36a104f77dc135: just some comments missing 63d95a9150ee3bbd4117fcd609dee40313b454d9 11ebea50dbc1ade5994b2c838a096078d4c02399 4ce62e9e30cacc26885cab133ad1de358dd79f21: 2 lines missing 3270476a6c0ce322354df8679652f060d66526dc: one line missing 6575820221f7a4dd6eadecf7bf83cdd154335eda f2d5a0ee06c1813f985bb9386f3ccc0d0315720f 403c821d452c03be4ced571ac91339a9d3631b17 6037315269d62bf967286ae2670fdd6b6acedab9 bc2ae0f5bb2f39e6db06a62f9d353e4601a332a1 25511a477657884d2164f338341fa89652610507 3ce63377305b694f53e7dd0c72907591c5344224 628c78e7ea19d5b70d2b6a59030362168cdbe1ad: just some comments missing 8db25e7891a47e03db6f04344a9c92be16e391bb
2012-08-22PM QoS: Add disable parameterAntti P Miettinen
For testing purposes it is useful to be able to disable PM Qos. Bug 1020898 Bug 917572 Change-Id: I266f5b5730cfe4705197d8b09db7f9eda6766c7c Signed-off-by: Antti P Miettinen <amiettinen@nvidia.com> Reviewed-on: http://git-master/r/124667 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
2012-08-13workqueue: CPU hotplug keep idle workersMitch Luban
This change merges two patchsets. The first set, containing 6 patches, reimplements WQ_HIGHPRI to use a seperate worker_pool. gcwq->pools[0] is used for normal priority work and pools[1] for high priority. The second patchset contains 9 patches and reimplements CPU hotplug to keep idle workers. Updates workqueue CPU hotplug path to use a disassociated global_cwq, which runs as an unbound one (WQ_UNBOUND). While this requires rebinding idle workers, overall hotplug path is much simpler. Original patchset: http://thread.gmane.org/gmane.linux.kernel/1329164 Bug 978010 Change-Id: Ic66ec8848a8d111b5278e63ef6a410846dfd8fcc Signed-off-by: Mitch Luban <mluban@nvidia.com> Reviewed-on: http://git-master/r/118387 Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com> Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Peter Boonstoppel <pboonstoppel@nvidia.com> GVS: Gerrit_Virtual_Submit Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2012-07-31kthread: disable preemption during complete()Peter Boonstoppel
After a kthread is created it signals the requester using complete() and enters TASK_UNINTERRUPTIBLE. However, since complete() wakes up the requesting thread this can cause a preemption. The preemption will not remove the task from the runqueue (for that schedule() has to be invoked directly). This is a problem if directly after kthread creation you try to do a kthread_bind(), which will block in HZ steps until the thread is off the runqueue. This patch disables preemption during complete(), since we call schedule() directly afterwards, so it will correctly enter TASK_UNINTERRUPTIBLE. This speeds up kthread creation/binding during cpu hotplug significantly. Change-Id: I856ddd4e01ebdb198ba90f343b4a0c5933fd2b23 Signed-off-by: Peter Boonstoppel <pboonstoppel@nvidia.com>
2012-07-11sched: unthrottle rt runqueues in __disable_runtime()Peter Boonstoppel
migrate_tasks() uses _pick_next_task_rt() to get tasks from the real-time runqueues to be migrated. When rt_rq is throttled _pick_next_task_rt() won't return anything, in which case migrate_tasks() can't move all threads over and gets stuck in an infinite loop. Instead unthrottle rt runqueues before migrating tasks. Bug 976709 Change-Id: Ie3696702abc560fe8ffa7d2fb5dc5d54d532cc0d Signed-off-by: Peter Boonstoppel <pboonstoppel@nvidia.com> (cherry picked from commit 4d18ba5765c206bf9f37634f532d97dabd507a58) Reviewed-on: http://git-master/r/103417 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Aleksandr Frid <afrid@nvidia.com> Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
2012-07-01scheduler: Re-compute time-average nr_running on readAlex Frid
Re-compute time-average nr_running when it is read. This would prevent reading stalled average value if there were no run-queue changes for a long time. New average value is returned to the reader, but not stored to avoid concurrent writes. Light-weight sequential counter synchronization is used to assure data consistency for re-computing average. Change-Id: I8e4ea1b28ea00b3ddaf6ef7cdcd27866f87d360b Signed-off-by: Alex Frid <afrid@nvidia.com> (cherry picked from commit 527a759d9b40bf57958eb002edd2bb82014dab99) Reviewed-on: http://git-master/r/111637 Reviewed-by: Sai Gurrappadi <sgurrappadi@nvidia.com> Tested-by: Sai Gurrappadi <sgurrappadi@nvidia.com> Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Peter Boonstoppel <pboonstoppel@nvidia.com> Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
2012-07-01scheduler: compute time-average nr_running per run-queueDiwakar Tundlam
Compute the time-average number of running tasks per run-queue for a trailing window of a fixed time period. The detla add/sub to the average value is weighted by the amount of time per nr_running value relative to the total measurement period. Change-Id: I076e24ff4ed65bed3b8dd8d2b279a503318071ff Signed-off-by: Diwakar Tundlam <dtundlam@nvidia.com> (cherry picked from commit 3a12d7499cee352e8a46eaf700259ba3c733f0e3) Reviewed-on: http://git-master/r/111635 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Sai Gurrappadi <sgurrappadi@nvidia.com> Tested-by: Sai Gurrappadi <sgurrappadi@nvidia.com> Reviewed-by: Peter Boonstoppel <pboonstoppel@nvidia.com> Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
2012-06-26Fix gcov for GCC 4.6.Tuomas Tynkkynen
Gcov's internal data structures, on which the kernel depends on, have changed in GCC 4.6. This patch adds support for GCC 4.6 and should still work on GCC 4.4 too. For reference, look at 'struct gcov_fn_info' in GCC's 'gcc/gcov-io.h', near line 698: https://android.googlesource.com/toolchain/gcc/+/master/gcc-4.4.3/ https://android.googlesource.com/toolchain/gcc/+/master/gcc-4.6/ Bug 1003822 Change-Id: I527736f944c80b8b345d1685669c0b99eb38fb66 Signed-off-by: Tuomas Tynkkynen <ttynkkynen@nvidia.com> Reviewed-on: http://git-master/r/110073 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com> Tested-by: Juha Tukkinen <jtukkinen@nvidia.com>
2012-05-01tracing: Add tracepoints for hotplugAndy Park
Simple trace points for measuring hotplug up/down times. Bug 960310 Change-Id: I74dd3c5cddcc1ded02ad08a7ce38bacf3147ee3e Reviewed-on: http://git-master/r/99806 Reviewed-by: Andy Park <andyp@nvidia.com> Tested-by: Andy Park <andyp@nvidia.com> Reviewed-by: Prajakta Gudadhe <pgudadhe@nvidia.com>
2012-02-27PM Qos: Add min online cpus as PM QoS parameterGaurav Sarode
Bug 940061 Change-Id: Ibae842fdc3af3c92ec7e6125c602417110d8b55e Signed-off-by: Gaurav Sarode <gsarode@nvidia.com> Reviewed-on: http://git-master/r/84521 Reviewed-by: Sachin Nikam <snikam@nvidia.com> Tested-by: Aleksandr Frid <afrid@nvidia.com> Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
2012-02-09ftrace: Fix unregister ftrace_ops accountingJiri Olsa
commit 30fb6aa74011dcf595f306ca2727254d708b786e upstream. Multiple users of the function tracer can register their functions with the ftrace_ops structure. The accounting within ftrace will update the counter on each function record that is being traced. When the ftrace_ops filtering adds or removes functions, the function records will be updated accordingly if the ftrace_ops is still registered. When a ftrace_ops is removed, the counter of the function records, that the ftrace_ops traces, are decremented. When they reach zero the functions that they represent are modified to stop calling the mcount code. When changes are made, the code is updated via stop_machine() with a command passed to the function to tell it what to do. There is an ENABLE and DISABLE command that tells the called function to enable or disable the functions. But the ENABLE is really a misnomer as it should just update the records, as records that have been enabled and now have a count of zero should be disabled. The DISABLE command is used to disable all functions regardless of their counter values. This is the big off switch and is not the complement of the ENABLE command. To make matters worse, when a ftrace_ops is unregistered and there is another ftrace_ops registered, neither the DISABLE nor the ENABLE command are set when calling into the stop_machine() function and the records will not be updated to match their counter. A command is passed to that function that will update the mcount code to call the registered callback directly if it is the only one left. This means that the ftrace_ops that is still registered will have its callback called by all functions that have been set for it as well as the ftrace_ops that was just unregistered. Here's a way to trigger this bug. Compile the kernel with CONFIG_FUNCTION_PROFILER set and with CONFIG_FUNCTION_GRAPH not set: CONFIG_FUNCTION_PROFILER=y # CONFIG_FUNCTION_GRAPH is not set This will force the function profiler to use the function tracer instead of the function graph tracer. # cd /sys/kernel/debug/tracing # echo schedule > set_ftrace_filter # echo function > current_tracer # cat set_ftrace_filter schedule # cat trace # tracer: nop # # entries-in-buffer/entries-written: 692/68108025 #P:4 # # _-----=> irqs-off # / _----=> need-resched # | / _---=> hardirq/softirq # || / _--=> preempt-depth # ||| / delay # TASK-PID CPU# |||| TIMESTAMP FUNCTION # | | | |||| | | kworker/0:2-909 [000] .... 531.235574: schedule <-worker_thread <idle>-0 [001] .N.. 531.235575: schedule <-cpu_idle kworker/0:2-909 [000] .... 531.235597: schedule <-worker_thread sshd-2563 [001] .... 531.235647: schedule <-schedule_hrtimeout_range_clock # echo 1 > function_profile_enabled # echo 0 > function_porfile_enabled # cat set_ftrace_filter schedule # cat trace # tracer: function # # entries-in-buffer/entries-written: 159701/118821262 #P:4 # # _-----=> irqs-off # / _----=> need-resched # | / _---=> hardirq/softirq # || / _--=> preempt-depth # ||| / delay # TASK-PID CPU# |||| TIMESTAMP FUNCTION # | | | |||| | | <idle>-0 [002] ...1 604.870655: local_touch_nmi <-cpu_idle <idle>-0 [002] d..1 604.870655: enter_idle <-cpu_idle <idle>-0 [002] d..1 604.870656: atomic_notifier_call_chain <-enter_idle <idle>-0 [002] d..1 604.870656: __atomic_notifier_call_chain <-atomic_notifier_call_chain The same problem could have happened with the trace_probe_ops, but they are modified with the set_frace_filter file which does the update at closure of the file. The simple solution is to change ENABLE to UPDATE and call it every time an ftrace_ops is unregistered. Link: http://lkml.kernel.org/r/1323105776-26961-3-git-send-email-jolsa@redhat.com Change-Id: Ifdc1c97df0d069226d6818648aade1519106950d Signed-off-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: http://git-master/r/79658
2012-02-03tracedump: Fix build errorPrashant Gaikwad
Change-Id: Ica22a3f92c8ca33a5779a74d3afad775736b1663 Signed-off-by: Prashant Gaikwad <pgaikwad@nvidia.com> Reviewed-on: http://git-master/r/78450 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com> Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
2012-01-30scheduler: domain: init next_balance in nohz_idle_balancer with jiffiesDiwakar Tundlam
Bug 878165 The next_balance parameter of nohz_idle_balancer should be initialized to jiffies since jiffies itself is initialized to 300 seconds shy of overflow. Otherwise, nohz_idle_balancer does not run for the first 5 mins after bootup. Change-Id: I18334451f394ead8ddad3b94d725635a31e0173b Signed-off-by: Diwakar Tundlam <dtundlam@nvidia.com> Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: http://git-master/r/77300 Reviewed-by: Automatic_Commit_Validation_User
2012-01-19cpufreq: Enforce PM QoS min/max limitsAntti P Miettinen
Observe PM QoS CPU frequency minimum and maximum in addition to policy settings. Bug 888312 Change-Id: Ia4f60a1649a9952e02f6847c8add3b2ea5d47524 Reviewed-on: http://git-master/r/72207 Signed-off-by: Antti P Miettinen <amiettinen@nvidia.com> Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: http://git-master/r/75884 Reviewed-by: Automatic_Commit_Validation_User
2012-01-19PM QoS: Add CPU frequency min/max as PM QoS paramsAntti P Miettinen
Add minimum and maximum CPU frequency as PM QoS parameters. Bug 888312 Change-Id: I18abddded35a044a6ad8365035e31d1a2213a329 Reviewed-on: http://git-master/r/72206 Signed-off-by: Antti P Miettinen <amiettinen@nvidia.com> Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: http://git-master/r/75883 Reviewed-by: Automatic_Commit_Validation_User
2012-01-16Merge branch 'linux-3.1.y' into android-tegra-nv-3.1Varun Wadekar
Linux 3.1.9 Conflicts: Makefile Change-Id: I22227ab33ba7ddaba8e6fe049393c58a83d73648 Signed-off-by: Varun Wadekar <vwadekar@nvidia.com>
2012-01-12PM / Sleep: Fix race between CPU hotplug and freezerSrivatsa S. Bhat
commit 79cfbdfa87e84992d509e6c1648a18e1d7e68c20 upstream. The CPU hotplug notifications sent out by the _cpu_up() and _cpu_down() functions depend on the value of the 'tasks_frozen' argument passed to them (which indicates whether tasks have been frozen or not). (Examples for such CPU hotplug notifications: CPU_ONLINE, CPU_ONLINE_FROZEN, CPU_DEAD, CPU_DEAD_FROZEN). Thus, it is essential that while the callbacks for those notifications are running, the state of the system with respect to the tasks being frozen or not remains unchanged, *throughout that duration*. Hence there is a need for synchronizing the CPU hotplug code with the freezer subsystem. Since the freezer is involved only in the Suspend/Hibernate call paths, this patch hooks the CPU hotplug code to the suspend/hibernate notifiers PM_[SUSPEND|HIBERNATE]_PREPARE and PM_POST_[SUSPEND|HIBERNATE] to prevent the race between CPU hotplug and freezer, thus ensuring that CPU hotplug notifications will always be run with the state of the system really being what the notifications indicate, _throughout_ their execution time. Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-12cgroup: fix to allow mounting a hierarchy by nameLi Zefan
commit 0d19ea866562e46989412a0676412fa0983c9ce7 upstream. If we mount a hierarchy with a specified name, the name is unique, and we can use it to mount the hierarchy without specifying its set of subsystem names. This feature is documented is Documentation/cgroups/cgroups.txt section 2.3 Here's an example: # mount -t cgroup -o cpuset,name=myhier xxx /cgroup1 # mount -t cgroup -o name=myhier xxx /cgroup2 But it was broken by commit 32a8cf235e2f192eb002755076994525cdbaa35a (cgroup: make the mount options parsing more accurate) This fixes the regression. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-11ptrace: ensure JOBCTL_STOP_SIGMASK is not zero after detachOleg Nesterov
commit 8a88951b5878dc475dcd841cefc767e36397d14e upstream. This is the temporary simple fix for 3.2, we need more changes in this area. 1. do_signal_stop() assumes that the running untraced thread in the stopped thread group is not possible. This was our goal but it is not yet achieved: a stopped-but-resumed tracee can clone the running thread which can initiate another group-stop. Remove WARN_ON_ONCE(!current->ptrace). 2. A new thread always starts with ->jobctl = 0. If it is auto-attached and this group is stopped, __ptrace_unlink() sets JOBCTL_STOP_PENDING but JOBCTL_STOP_SIGMASK part is zero, this triggers WANR_ON(!signr) in do_jobctl_trap() if another debugger attaches. Change __ptrace_unlink() to set the artificial SIGSTOP for report. Alternatively we could change ptrace_init_task() to copy signr from current, but this means we can copy it for no reason and hide the possible similar problems. Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Change-Id: I2c60e18b07e8e08c7e3b6cc8288b0e04e18844f7 Reviewed-on: http://git-master/r/74233 Reviewed-by: Varun Wadekar <vwadekar@nvidia.com> Tested-by: Varun Wadekar <vwadekar@nvidia.com>
2012-01-11ptrace: partially fix the do_wait(WEXITED) vs EXIT_DEAD->EXIT_ZOMBIE raceOleg Nesterov
commit 50b8d257486a45cba7b65ca978986ed216bbcc10 upstream. Test-case: int main(void) { int pid, status; pid = fork(); if (!pid) { for (;;) { if (!fork()) return 0; if (waitpid(-1, &status, 0) < 0) { printf("ERR!! wait: %m\n"); return 0; } } } assert(ptrace(PTRACE_ATTACH, pid, 0,0) == 0); assert(waitpid(-1, NULL, 0) == pid); assert(ptrace(PTRACE_SETOPTIONS, pid, 0, PTRACE_O_TRACEFORK) == 0); do { ptrace(PTRACE_CONT, pid, 0, 0); pid = waitpid(-1, NULL, 0); } while (pid > 0); return 1; } It fails because ->real_parent sees its child in EXIT_DEAD state while the tracer is going to change the state back to EXIT_ZOMBIE in wait_task_zombie(). The offending commit is 823b018e which moved the EXIT_DEAD check, but in fact we should not blame it. The original code was not correct as well because it didn't take ptrace_reparented() into account and because we can't really trust ->ptrace. This patch adds the additional check to close this particular race but it doesn't solve the whole problem. We simply can't rely on ->ptrace in this case, it can be cleared if the tracer is multithreaded by the exiting ->parent. I think we should kill EXIT_DEAD altogether, we should always remove the soon-to-be-reaped child from ->children or at least we should never do the DEAD->ZOMBIE transition. But this is too complex for 3.2. Reported-and-tested-by: Denys Vlasenko <vda.linux@googlemail.com> Tested-by: Lukasz Michalik <lmi@ift.uni.wroc.pl> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Change-Id: I9e83ca1fcff0eee2ea7ef2508de95691a0cdeb0c Reviewed-on: http://git-master/r/74232 Reviewed-by: Varun Wadekar <vwadekar@nvidia.com> Tested-by: Varun Wadekar <vwadekar@nvidia.com>
2012-01-11hung_task: fix false positive during vforkMandeep Singh Baines
commit f9fab10bbd768b0e5254e53a4a8477a94bfc4b96 upstream. vfork parent uninterruptibly and unkillably waits for its child to exec/exit. This wait is of unbounded length. Ignore such waits in the hung_task detector. Signed-off-by: Mandeep Singh Baines <msb@chromium.org> Reported-by: Sasha Levin <levinsasha928@gmail.com> LKML-Reference: <1325344394.28904.43.camel@lappy> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: John Kacur <jkacur@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Change-Id: I12ed227da1fb7099978c73b65a756caf51a95553 Reviewed-on: http://git-master/r/74230 Reviewed-by: Varun Wadekar <vwadekar@nvidia.com> Tested-by: Varun Wadekar <vwadekar@nvidia.com>
2012-01-11futex: Fix uninterruptible loop due to gate_areaHugh Dickins
commit e6780f7243eddb133cc20ec37fa69317c218b709 upstream. It was found (by Sasha) that if you use a futex located in the gate area we get stuck in an uninterruptible infinite loop, much like the ZERO_PAGE issue. While looking at this problem, PeterZ realized you'll get into similar trouble when hitting any install_special_pages() mapping. And are there still drivers setting up their own special mmaps without page->mapping, and without special VM or pte flags to make get_user_pages fail? In most cases, if page->mapping is NULL, we do not need to retry at all: Linus points out that even /proc/sys/vm/drop_caches poses no problem, because it ends up using remove_mapping(), which takes care not to interfere when the page reference count is raised. But there is still one case which does need a retry: if memory pressure called shmem_writepage in between get_user_pages_fast dropping page table lock and our acquiring page lock, then the page gets switched from filecache to swapcache (and ->mapping set to NULL) whatever the refcount. Fault it back in to get the page->mapping needed for key->shared.inode. Reported-by: Sasha Levin <levinsasha928@gmail.com> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Change-Id: I04a763aed3c611460ef4888d14a1f5101e8373bc Reviewed-on: http://git-master/r/74198 Reviewed-by: Varun Wadekar <vwadekar@nvidia.com> Tested-by: Varun Wadekar <vwadekar@nvidia.com>
2012-01-11cgroups: fix a css_set not found bug in cgroup_attach_procMandeep Singh Baines
commit e0197aae59e55c06db172bfbe1a1cdb8c0e1cab3 upstream. There is a BUG when migrating a PF_EXITING proc. Since css_set_prefetch() is not called for the PF_EXITING case, find_existing_css_set() will return NULL inside cgroup_task_migrate() causing a BUG. This bug is easy to reproduce. Create a zombie and echo its pid to cgroup.procs. $ cat zombie.c \#include <unistd.h> int main() { if (fork()) pause(); return 0; } $ We are hitting this bug pretty regularly on ChromeOS. This bug is already fixed by Tejun Heo's cgroup patchset which is targetted for the next merge window: https://lkml.org/lkml/2011/11/1/356 I've create a smaller patch here which just fixes this bug so that a fix can be merged into the current release and stable. Signed-off-by: Mandeep Singh Baines <msb@chromium.org> Downstream-Bug-Report: http://crosbug.com/23953 Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: containers@lists.linux-foundation.org Cc: cgroups@vger.kernel.org Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Paul Menage <paul@paulmenage.org> Cc: Olof Johansson <olofj@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Change-Id: I61bf2d48574d6ce5418b988e9547937c2efdd084 Reviewed-on: http://git-master/r/74185 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com> Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
2012-01-11binary_sysctl(): fix memory leakMichel Lespinasse
commit 3d3c8f93a237b64580c5c5e138edeb1377e98230 upstream. binary_sysctl() calls sysctl_getname() which allocates from names_cache slab usin __getname() The matching function to free the name is __putname(), and not putname() which should be used only to match getname() allocations. This is because when auditing is enabled, putname() calls audit_putname *instead* (not in addition) to __putname(). Then, if a syscall is in progress, audit_putname does not release the name - instead, it expects the name to get released when the syscall completes, but that will happen only if audit_getname() was called previously, i.e. if the name was allocated with getname() rather than the naked __getname(). So, __getname() followed by putname() ends up leaking memory. Signed-off-by: Michel Lespinasse <walken@google.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@infradead.org> Cc: Eric Paris <eparis@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Change-Id: Ia6c066b0703eeafc61eafdd5addf157ee671bd68 Reviewed-on: http://git-master/r/74175 Reviewed-by: Varun Wadekar <vwadekar@nvidia.com> Tested-by: Varun Wadekar <vwadekar@nvidia.com>
2012-01-06ptrace: ensure JOBCTL_STOP_SIGMASK is not zero after detachOleg Nesterov
2012-01-06ptrace: partially fix the do_wait(WEXITED) vs EXIT_DEAD->EXIT_ZOMBIE raceOleg Nesterov
2012-01-06hung_task: fix false positive during vforkMandeep Singh Baines
2012-01-06futex: Fix uninterruptible loop due to gate_areaHugh Dickins
2012-01-06cgroups: fix a css_set not found bug in cgroup_attach_procMandeep Singh Baines
2012-01-06binary_sysctl(): fix memory leakMichel Lespinasse
2012-01-05Linux 3.1.7Varun Wadekar
Change-Id: I99507d7cfdcee064f808856dc2ce99d806fd864f
2012-01-03Revert "clockevents: Set noop handler in clockevents_exchange_device()"Linus Torvalds
commit 3b87487ac5008072f138953b07505a7e3493327f upstream. This reverts commit de28f25e8244c7353abed8de0c7792f5f883588c. It results in resume problems for various people. See for example http://thread.gmane.org/gmane.linux.kernel/1233033 http://thread.gmane.org/gmane.linux.kernel/1233389 http://thread.gmane.org/gmane.linux.kernel/1233159 http://thread.gmane.org/gmane.linux.kernel/1227868/focus=1230877 and the fedora and ubuntu bug reports https://bugzilla.redhat.com/show_bug.cgi?id=767248 https://bugs.launchpad.net/ubuntu/+source/linux/+bug/904569 which got bisected down to the stable version of this commit. Reported-by: Jonathan Nieder <jrnieder@gmail.com> Reported-by: Phil Miller <mille121@illinois.edu> Reported-by: Philip Langdale <philipl@overt.org> Reported-by: Tim Gardner <tim.gardner@canonical.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-26cpu-hotplug: CPUx should be active before it is marked onlineVarun Wadekar
CPU0 CPUn _cpu_up() __cpu_up() boostrap() notify_cpu_starting() set_cpu_online() while (!cpu_active()) cpu_relax() <PREEMPT-out> smp_call_function(.wait=1) /* we find cpu_online() is true */ arch_send_call_function_ipi_mask() /* wait-forever-more */ <PREEMPT-in> local_irq_enable() cpu_notify(CPU_ONLINE) sched_cpu_active() set_cpu_active() Now the purpose of cpu_active is mostly with bringing down a cpu, where we mark it !active to avoid the load-balancer from moving tasks to it while we tear down the cpu. This is required because we only update the sched_domain tree after we brought the cpu-down. And this is needed so that some tasks can still run while we bring it down, we just don't want new tasks to appear. On cpu-up however the sched_domain tree doesn't yet include the new cpu, so its invisible to the load-balancer, regardless of the active state. So instead of setting the active state after we boot the new cpu (and consequently having to wait for it before enabling interrupts) set the cpu active before we set it online and avoid the whole mess. Bug 916986 Original Patch: https://lkml.org/lkml/2011/12/15/255 Change-Id: Ia1c07bdc1b3eb07a7cd4d69756fa7bec509c9400 Reported-by: Stepan Moskovchenko <stepanm@codeaurora.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: http://git-master/r/72130 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
2011-12-22PM QoS: Add max online cpus as PM QoS parameterAlex Frid
Bug 894200 Change-Id: Ieb009a13c6ef9bca2388e234eb973d65a4e3a58b Signed-off-by: Alex Frid <afrid@nvidia.com> Reviewed-on: http://git-master/r/71034 Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com> Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
2011-12-22PM QoS: Simplify PM QoS expansion/mergeAlex Frid
- Replace class ID #define with enumeration - Loop through PM QoS objects during initialization (rather than initializing them one-by-one) Change-Id: I185b700b52c752c62e7550fe739adc498fc989ef Signed-off-by: Alex Frid <afrid@nvidia.com> Reviewed-on: http://git-master/r/70603 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Antti Miettinen <amiettinen@nvidia.com> Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com> Reviewed-by: Scott Williams <scwilliams@nvidia.com> Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
2011-12-22tracedump: Dump ftrace ring buffer dataAlon Farchy
Add a new module that will dump the contents of the ftrace ring buffer. Data is compressed and can be in ascii or binary form. Data will automatically dump on kernel panic to console. Data can be dumped by reading /proc/tracedump. See tracedump.h for details. Change-Id: I7b7afc3def0b88629dd120d17e43858306a8f357 Signed-off-by: Liang Cheng <licheng@nvidia.com> Reviewed-on: http://git-master/r/69494 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
2011-12-21lockdep, kmemcheck: Annotate ->lock in lockdep_init_map()Yong Zhang
commit a33caeb118198286309859f014c0662f3ed54ed4 upstream. Since commit f59de89 ("lockdep: Clear whole lockdep_map on initialization"), lockdep_init_map() will clear all the struct. But it will break lock_set_class()/lock_set_subclass(). A typical race condition is like below: CPU A CPU B lock_set_subclass(lockA); lock_set_class(lockA); lockdep_init_map(lockA); /* lockA->name is cleared */ memset(lockA); __lock_acquire(lockA); /* lockA->class_cache[] is cleared */ register_lock_class(lockA); look_up_lock_class(lockA); WARN_ON_ONCE(class->name != lock->name); lock->name = name; So restore to what we have done before commit f59de89 but annotate ->lock with kmemcheck_mark_initialized() to suppress the kmemcheck warning reported in commit f59de89. Reported-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Reported-by: Borislav Petkov <bp@alien8.de> Suggested-by: Vegard Nossum <vegard.nossum@gmail.com> Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> Cc: Tejun Heo <tj@kernel.org> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20111109080451.GB8124@zhy Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-21alarmtimers: Fix time comparisonThomas Gleixner
commit c9c024b3f3e07d087974db4c0dc46217fff3a6c0 upstream. The expiry function compares the timer against current time and does not expire the timer when the expiry time is >= now. That's wrong. If the timer is set for now, then it must expire. Make the condition expiry > now for breaking out the loop. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: John Stultz <john.stultz@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-14Merge branch 'linux-3.1.5' into android-tegra-nv-3.1Varun Wadekar
Conflicts: arch/arm/Kconfig Change-Id: If8aaaf3efcbbf6c9017b38efb6d76ef933f147fa Signed-off-by: Varun Wadekar <vwadekar@nvidia.com>
2011-12-09clockevents: Set noop handler in clockevents_exchange_device()Thomas Gleixner
commit de28f25e8244c7353abed8de0c7792f5f883588c upstream. If a device is shutdown, then there might be a pending interrupt, which will be processed after we reenable interrupts, which causes the original handler to be run. If the old handler is the (broadcast) periodic handler the shutdown state might hang the kernel completely. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09clocksource: Fix bug with max_deferment margin calculationYang Honggang (Joseph)
commit b1f919664d04a8d0ba29cb76673c7ca3325a2006 upstream. In order to leave a margin of 12.5% we should >> 3 not >> 5. Signed-off-by: Yang Honggang (Joseph) <eagle.rtlinux@gmail.com> [jstultz: Modified commit subject] Signed-off-by: John Stultz <john.stultz@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09jump_label: jump_label_inc may return before the code is patchedGleb Natapov
commit bbbf7af4bf8fc69bc751818cf30521080fa47dcb upstream. If cpu A calls jump_label_inc() just after atomic_add_return() is called by cpu B, atomic_inc_not_zero() will return value greater then zero and jump_label_inc() will return to a caller before jump_label_update() finishes its job on cpu B. Link: http://lkml.kernel.org/r/20111018175551.GH17571@redhat.com Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09tick-broadcast: Stop active broadcast device when replacing itThomas Gleixner
commit c1be84309c58b1e7c6d626e28fba41a22b364c3d upstream. When a better rated broadcast device is installed, then the current active device is not disabled, which results in two running broadcast devices. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09tracing: fix event_subsystem ref countingIlya Dryomov
commit cb59974742aea24adf6637eb0c4b8e7b48bca6fb upstream. Fix a bug introduced by e9dbfae5, which prevents event_subsystem from ever being released. Ref_count was added to keep track of subsystem users, not for counting events. Subsystem is created with ref_count = 1, so there is no need to increment it for every event, we have nr_events for that. Fix this by touching ref_count only when we actually have a new user - subsystem_open(). Signed-off-by: Ilya Dryomov <idryomov@gmail.com> Link: http://lkml.kernel.org/r/1320052062-7846-1-git-send-email-idryomov@gmail.com Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09trace_events_filter: Use rcu_assign_pointer() when setting ↵Tejun Heo
ftrace_event_call->filter commit d3d9acf646679c1981032b0985b386d12fccc60c upstream. ftrace_event_call->filter is sched RCU protected but didn't use rcu_assign_pointer(). Use it. TODO: Add proper __rcu annotation to call->filter and all its users. -v2: Use RCU_INIT_POINTER() for %NULL clearing as suggested by Eric. Link: http://lkml.kernel.org/r/20111123164949.GA29639@google.com Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09ftrace: Remove force undef config value left for testingSteven Rostedt
commit c7c6ec8becaf742b223c7b491f4893014be23a07 upstream. A forced undef of a config value was used for testing and was accidently left in during the final commit. This causes x86 to run slower than needed while running function tracing as well as causes the function graph selftest to fail when DYNMAIC_FTRACE is not set. This is because the code in MCOUNT expects the ftrace code to be processed with the config value set that happened to be forced not set. The forced config option was left in by: commit 6331c28c962561aee59e5a493b7556a4bb585957 ftrace: Fix dynamic selftest failure on some archs Link: http://lkml.kernel.org/r/20111102150255.GA6973@debian Reported-by: Rabin Vincent <rabin@rab.in> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09genirq: Fix race condition when stopping the irq threadIdo Yariv
commit 550acb19269d65f32e9ac4ddb26c2b2070e37f1c upstream. In irq_wait_for_interrupt(), the should_stop member is verified before setting the task's state to TASK_INTERRUPTIBLE and calling schedule(). In case kthread_stop sets should_stop and wakes up the process after should_stop is checked by the irq thread but before the task's state is changed, the irq thread might never exit: kthread_stop irq_wait_for_interrupt ------------ ---------------------- ... ... while (!kthread_should_stop()) { kthread->should_stop = 1; wake_up_process(k); wait_for_completion(&kthread->exited); ... set_current_state(TASK_INTERRUPTIBLE); ... schedule(); } Fix this by checking if the thread should stop after modifying the task's state. [ tglx: Simplified it a bit ] Signed-off-by: Ido Yariv <ido@wizery.com> Link: http://lkml.kernel.org/r/1322740508-22640-1-git-send-email-ido@wizery.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09clocksource: Avoid selecting mult values that might overflow when adjustedJohn Stultz
commit d65670a78cdbfae94f20a9e05ec705871d7cdf2b upstream. For some frequencies, the clocks_calc_mult_shift() function will unfortunately select mult values very close to 0xffffffff. This has the potential to overflow when NTP adjusts the clock, adding to the mult value. This patch adds a clocksource.maxadj value, which provides an approximation of an 11% adjustment(NTP limits adjustments to 500ppm and the tick adjustment is limited to 10%), which could be made to the clocksource.mult value. This is then used to both check that the current mult value won't overflow/underflow, as well as warning us if the timekeeping_adjust() code pushes over that 11% boundary. v2: Fix max_adjustment calculation, and improve WARN_ONCE messages. v3: Don't warn before maxadj has actually been set CC: Yong Zhang <yong.zhang0@gmail.com> CC: David Daney <ddaney.cavm@gmail.com> CC: Thomas Gleixner <tglx@linutronix.de> CC: Chen Jie <chenj@lemote.com> CC: zhangfx <zhangfx@lemote.com> Reported-by: Chen Jie <chenj@lemote.com> Reported-by: zhangfx <zhangfx@lemote.com> Tested-by: Yong Zhang <yong.zhang0@gmail.com> Signed-off-by: John Stultz <john.stultz@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09hrtimer: Fix extra wakeups from __remove_hrtimer()Jeff Ohlstein
commit 27c9cd7e601632b3794e1c3344d37b86917ffb43 upstream. __remove_hrtimer() attempts to reprogram the clockevent device when the timer being removed is the next to expire. However, __remove_hrtimer() reprograms the clockevent *before* removing the timer from the timerqueue and thus when hrtimer_force_reprogram() finds the next timer to expire it finds the timer we're trying to remove. This is especially noticeable when the system switches to NOHz mode and the system tick is removed. The timer tick is removed from the system but the clockevent is programmed to wakeup in another HZ anyway. Silence the extra wakeup by removing the timer from the timerqueue before calling hrtimer_force_reprogram() so that we actually program the clockevent for the next timer to expire. This was broken by 998adc3 "hrtimers: Convert hrtimers to use timerlist infrastructure". Signed-off-by: Jeff Ohlstein <johlstei@codeaurora.org> Link: http://lkml.kernel.org/r/1321660030-8520-1-git-send-email-johlstei@codeaurora.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09timekeeping: add arch_offset hook to ktime_get functionsHector Palacios
commit d004e024058a0eaca097513ce62cbcf978913e0a upstream. ktime_get and ktime_get_ts were calling timekeeping_get_ns() but later they were not calling arch_gettimeoffset() so architectures using this mechanism returned 0 ns when calling these functions. This happened for example when running Busybox's ping which calls syscall(__NR_clock_gettime, CLOCK_MONOTONIC, ts) which eventually calls ktime_get. As a result the returned ping travel time was zero. Signed-off-by: Hector Palacios <hector.palacios@digi.com> Signed-off-by: John Stultz <john.stultz@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
