path: root/kernel
2015-05-09Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq updates from Thomas Gleixner: "Two patches from the irq departement: - a simple fix to make dummy_irq_chip usable for wakeup scenarios - removal of the gic arch_extn hackery. Now that all users are converted we really want to get rid of the interface so people wont come up with new use cases" * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: irqchip: gic: Drop support for gic_arch_extn genirq: Set IRQCHIP_SKIP_SET_WAKE flag for dummy_irq_chip
2015-05-09Merge branch 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer fix from Thomas Gleixner: "A simple fix to actually shut down a detached device instead of keeping it active" * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: clockevents: Shutdown detached clockevent device
2015-05-08Merge tag 'trace-fixes-v4.1-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull tracing fix from Steven Rostedt: "The newly added ftrace_print_array_seq() function had a bug in it. Luckily, the only user of it didn't make the 4.1 merge window. But the helper function should be fixed before 4.2 when the users start coming in" * tag 'trace-fixes-v4.1-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: tracing: Make ftrace_print_array_seq compute buf_len
2015-05-06tracing: Make ftrace_print_array_seq compute buf_lenAlex Bennée
The only caller to this function (__print_array) was getting it wrong by passing the array length instead of buffer length. As the element size was already being passed for other reasons it seems reasonable to push the calculation of buffer length into the function. Link: http://lkml.kernel.org/r/1430320727-14582-1-git-send-email-alex.bennee@linaro.org Signed-off-by: Alex Bennée <alex.bennee@linaro.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-05-06Merge branch 'core-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull RCU fix from Ingo Molnar: "An RCU Kconfig fix that eliminates an annoying interactive kconfig question for CONFIG_RCU_TORTURE_TEST_SLOW_INIT" * 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: rcu: Control grace-period delays directly from value
2015-05-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Receive packet length needs to be adjust by 2 on RX to accomodate the two padding bytes in altera_tse driver. From Vlastimil Setka. 2) If rx frame is dropped due to out of memory in macb driver, we leave the receive ring descriptors in an undefined state. From Punnaiah Choudary Kalluri 3) Some netlink subsystems erroneously signal NLM_F_MULTI. That is only for dumps. Fix from Nicolas Dichtel. 4) Fix mis-use of raw rt->rt_pmtu value in ipv4, one must always go via the ipv4_mtu() helper. From Herbert Xu. 5) Fix null deref in bridge netfilter, and miscalculated lengths in jump/goto nf_tables verdicts. From Florian Westphal. 6) Unhash ping sockets properly. 7) Software implementation of BPF divide did 64/32 rather than 64/64 bit divide. The JITs got it right. Fix from Alexei Starovoitov. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (30 commits) ipv4: Missing sk_nulls_node_init() in ping_unhash(). net: fec: Fix RGMII-ID mode net/mlx4_en: Schedule napi when RX buffers allocation fails netxen_nic: use spin_[un]lock_bh around tx_clean_lock net/mlx4_core: Fix unaligned accesses mlx4_en: Use correct loop cursor in error path. cxgb4: Fix MC1 memory offset calculation bnx2x: Delay during kdump load net: Fix Kernel Panic in bonding driver debugfs file: rlb_hash_table net: dsa: Fix scope of eeprom-length property net: macb: Fix race condition in driver when Rx frame is dropped hv_netvsc: Fix a bug in netvsc_start_xmit() altera_tse: Correct rx packet length mlx4: Fix tx ring affinity_mask creation tipc: fix problem with parallel link synchronization mechanism tipc: remove wrong use of NLM_F_MULTI bridge/nl: remove wrong use of NLM_F_MULTI bridge/mdb: remove wrong use of NLM_F_MULTI net: sched: act_connmark: don't zap skb->nfct trivial: net: systemport: bcmsysport.h: fix 0x0x prefix ...
2015-04-30Merge tag 'pm+acpi-4.1-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management and ACPI fixes from Rafael Wysocki: "Three regression fixes this time, one for a recent regression in the cpuidle core affecting multiple systems, one for an inadvertently added duplicate typedef in ACPICA that breaks compilation with GCC 4.5 and one for an ACPI Smart Battery Subsystem driver regression introduced during the 3.18 cycle (stable-candidate). Specifics: - Fix for a regression in the cpuidle core introduced by one of the recent commits in the clockevents_notify() removal series that put a call to a function which had to be executed with disabled interrupts into a code path running with enabled interrupts (Rafael J Wysocki) - Fix for a build problem in ACPICA (with GCC 4.5) introduced by one of the recent ACPICA tools commits that added a duplicate typedef to one of the ACPICA's header files by mistake (Olaf Hering) - Fix for a regression in the ACPI SBS (Smart Battery Subsystem) driver introduced during the 3.18 development cycle causing the smart battery manager to be marked as not present when it should be marked as present (Chris Bainbridge)" * tag 'pm+acpi-4.1-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: cpuidle: Run tick_broadcast_exit() with disabled interrupts ACPI / SBS: Enable battery manager when present ACPICA: remove duplicate u8 typedef
2015-04-30Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull kvm changes from Paolo Bonzini: "Remove from guest code the handling of task migration during a pvclock read; instead use the correct protocol in KVM. This removes the need for task migration notifiers in core scheduler code" [ The scheduler people really hated the migration notifiers, so this was kind of required - Linus ] * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: x86: pvclock: Really remove the sched notifier for cross-cpu migrations kvm: x86: fix kvmclock update protocol
2015-04-30modsign: change default key detailsDavid Howells
Change default key details to be more obviously unspecified. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-29cpuidle: Run tick_broadcast_exit() with disabled interruptsRafael J. Wysocki
Commit 335f49196fd6 (sched/idle: Use explicit broadcast oneshot control function) replaced clockevents_notify() invocations in cpuidle_idle_call() with direct calls to tick_broadcast_enter() and tick_broadcast_exit(), but it overlooked the fact that interrupts were already enabled before calling the latter which led to functional breakage on systems using idle states with the CPUIDLE_FLAG_TIMER_STOP flag set. Fix that by moving the invocations of tick_broadcast_enter() and tick_broadcast_exit() down into cpuidle_enter_state() where interrupts are still disabled when tick_broadcast_exit() is called. Also ensure that interrupts will be disabled before running tick_broadcast_exit() even if they have been enabled by the idle state's ->enter callback. Trigger a WARN_ON_ONCE() in that case, as we generally don't want that to happen for states with CPUIDLE_FLAG_TIMER_STOP set. Fixes: 335f49196fd6 (sched/idle: Use explicit broadcast oneshot control function) Reported-and-tested-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Acked-by: Daniel Lezcano <daniel.lezcano@linaro.org> Reported-and-tested-by: Sudeep Holla <sudeep.holla@arm.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-04-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 updates from Martin Schwidefsky: "One additional new feature for 4.1, a new PRNG based on SHA-512 for the zcrypt driver. Two memory management related changes, the page table reallocation for KVM is removed, and with file ptes gone the encoding of page table entries is improved. And three bug fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: s390/zcrypt: Introduce new SHA-512 based Pseudo Random Generator. s390/mm: change swap pte encoding and pgtable cleanup s390/mm: correct transfer of dirty & young bits in __pmd_to_pte s390/bpf: add dependency to z196 features s390/3215: free memory in error path s390/kvm: remove delayed reallocation of page tables for KVM kexec: allocate the kexec control page with KEXEC_CONTROL_MEMORY_GFP
2015-04-27bpf: fix 64-bit divideAlexei Starovoitov
ALU64_DIV instruction should be dividing 64-bit by 64-bit, whereas do_div() does 64-bit by 32-bit divide. x64 and arm64 JITs correctly implement 64 by 64 unsigned divide. llvm BPF backend emits code assuming that ALU64_DIV does 64 by 64. Fixes: 89aa075832b0 ("net: sock: allow eBPF programs to be attached to sockets") Reported-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-27x86: pvclock: Really remove the sched notifier for cross-cpu migrationsPaolo Bonzini
This reverts commits 0a4e6be9ca17c54817cf814b4b5aa60478c6df27 and 80f7fdb1c7f0f9266421f823964fd1962681f6ce. The task migration notifier was originally introduced in order to support the pvclock vsyscall with non-synchronized TSC, but KVM only supports it with synchronized TSC. Hence, on KVM the race condition is only needed due to a bad implementation on the host side, and even then it's so rare that it's mostly theoretical. As far as KVM is concerned it's possible to fix the host, avoiding the additional complexity in the vDSO and the (re)introduction of the task migration notifier. Xen, on the other hand, hasn't yet implemented vsyscall support at all, so we do not care about its plans for non-synchronized TSC. Reported-by: Peter Zijlstra <peterz@infradead.org> Suggested-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2015-04-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull fourth vfs update from Al Viro: "d_inode() annotations from David Howells (sat in for-next since before the beginning of merge window) + four assorted fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: RCU pathwalk breakage when running into a symlink overmounting something fix I_DIO_WAKEUP definition direct-io: only inc/dec inode->i_dio_count for file systems fs/9p: fix readdir() VFS: assorted d_backing_inode() annotations VFS: fs/inode.c helpers: d_inode() annotations VFS: fs/cachefiles: d_backing_inode() annotations VFS: fs library helpers: d_inode() annotations VFS: assorted weird filesystems: d_inode() annotations VFS: normal filesystems (and lustre): d_inode() annotations VFS: security/: d_inode() annotations VFS: security/: d_backing_inode() annotations VFS: net/: d_inode() annotations VFS: net/unix: d_backing_inode() annotations VFS: kernel/: d_inode() annotations VFS: audit: d_backing_inode() annotations VFS: Fix up some ->d_inode accesses in the chelsio driver VFS: Cachefiles should perform fs modifications on the top layer only VFS: AF_UNIX sockets should call mknod on the top layer only
2015-04-24clockevents: Shutdown detached clockevent deviceViresh Kumar
A clockevent device is marked DETACHED when it is replaced by another clockevent device. The device is shutdown properly for drivers that implement legacy ->set_mode() callback, as we call ->set_mode() for CLOCK_EVT_MODE_UNUSED as well. But for the new per-state callback interface, we skip shutting down the device, as we thought its an internal state change. That wasn't correct. The effect is that the device is left programmed in oneshot or periodic mode. Fall-back to 'case CLOCK_EVT_STATE_SHUTDOWN', to shutdown the device. Fixes: bd624d75db21 "clockevents: Introduce mode specific callbacks" Reported-by: Daniel Lezcano <daniel.lezcano@linaro.org> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Cc: linaro-kernel@lists.linaro.org Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/eef0a91c51b74d4e52c8e5a95eca27b5a0563f07.1428650683.git.viresh.kumar@linaro.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-04-24genirq: Set IRQCHIP_SKIP_SET_WAKE flag for dummy_irq_chipRoger Quadros
Without this system suspend is broken on systems that have drivers calling enable/disable_irq_wake() for interrupts based off the dummy irq hook. (e.g. drivers/gpio/gpio-pcf857x.c) Signed-off-by: Roger Quadros <rogerq@ti.com> Cc: <cw00.choi@samsung.com> Cc: <balbi@ti.com> Cc: <tony@atomide.com> Cc: Gregory Clement <gregory.clement@free-electrons.com> Link: http://lkml.kernel.org/r/552E1DD3.4040106@ti.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-04-23kexec: allocate the kexec control page with KEXEC_CONTROL_MEMORY_GFPMartin Schwidefsky
Introduce KEXEC_CONTROL_MEMORY_GFP to allow the architecture code to override the gfp flags of the allocation for the kexec control page. The loop in kimage_alloc_normal_control_pages allocates pages with GFP_KERNEL until a page is found that happens to have an address smaller than the KEXEC_CONTROL_MEMORY_LIMIT. On systems with a large memory size but a small KEXEC_CONTROL_MEMORY_LIMIT the loop will keep allocating memory until the oom killer steps in. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2015-04-22Merge branch 'upstream' of git://git.infradead.org/users/pcmoore/auditLinus Torvalds
Pull audit fixes from Paul Moore: "Seven audit patches for v4.1, all bug fixes. The largest, and perhaps most significant commit helps resolve some memory pressure issues related to the inode cache and audit, there are also a few small commits which help resolve some timing issues with the audit log queue, and the rest fall into the always popular "code clean-up" category. In general, nothing really substantial, just a nice set of maintenance patches" * 'upstream' of git://git.infradead.org/users/pcmoore/audit: audit: Remove condition which always evaluates to false audit: reduce mmap_sem hold for mm->exe_file audit: consolidate handling of mm->exe_file audit: code clean up audit: don't reset working wait time accidentally with auditd audit: don't lose set wait time on first successful call to audit_log_start() audit: move the tree pruning to a dedicated thread
2015-04-22Merge tag 'trace-v4.1-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull tracing fixes from Steven Rostedt: "This adds three fixes for the tracing code. The first is a bug when ftrace_dump_on_oops is triggered in atomic context and function graph tracer is the tracer that is being reported. The second fix is bad parsing of the trace_events from the kernel command line, where it would ignore specific events if the system name is used with defining the event(it enables all events within the system). The last one is a fix to the TRACE_DEFINE_ENUM(), where a check was missing to see if the ptr was incremented to the end of the string, but the loop increments it again and can miss the nul delimiter to stop processing" * tag 'trace-v4.1-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: tracing: Fix possible out of bounds memory access when parsing enums tracing: Fix incorrect enabling of trace events by boot cmdline tracing: Handle ftrace_dump() atomic context in graph_trace_open()
2015-04-22Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module updates from Rusty Russell: "Quentin opened a can of worms by adding extable entry checking to modpost, but most architectures seem fixed now. Thanks to all involved. Last minute rebase because I noticed a "[PATCH]" had snuck into a commit message somehow" * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: modpost: don't emit section mismatch warnings for compiler optimizations modpost: expand pattern matching to support substring matches modpost: do not try to match the SHT_NUL section. modpost: fix extable entry size calculation. modpost: fix inverted logic in is_extable_fault_address(). modpost: handle -ffunction-sections modpost: Whitelist .text.fixup and .exception.text params: handle quotes properly for values not of form foo="bar". modpost: document the use of struct section_check. modpost: handle relocations mismatch in __ex_table. scripts: add check_extable.sh script. modpost: mismatch_handler: retrieve tosym information only when needed. modpost: factorize symbol pretty print in get_pretty_name(). modpost: add handler function pointer to sectioncheck. modpost: add .sched.text and .kprobes.text to the TEXT_SECTIONS list. modpost: add strict white-listing when referencing sections. module: do not print allocation-fail warning on bogus user buffer size kernel/module.c: fix typos in message about unused symbols
2015-04-21Merge tag 'char-misc-4.1-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver updates from Greg KH: "Here's the big char/misc driver patchset for 4.1-rc1. Lots of different driver subsystem updates here, nothing major, full details are in the shortlog. All of this has been in linux-next for a while" * tag 'char-misc-4.1-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (133 commits) mei: trace: remove unused TRACE_SYSTEM_STRING DTS: ARM: OMAP3-N900: Add lis3lv02d support Documentation: DT: lis302: update wakeup binding lis3lv02d: DT: add wakeup unit 2 and wakeup threshold lis3lv02d: DT: use s32 to support negative values Drivers: hv: hv_balloon: correctly handle num_pages>INT_MAX case Drivers: hv: hv_balloon: correctly handle val.freeram<num_pages case mei: replace check for connection instead of transitioning mei: use mei_cl_is_connected consistently mei: fix mei_poll operation hv_vmbus: Add gradually increased delay for retries in vmbus_post_msg() Drivers: hv: hv_balloon: survive ballooning request with num_pages=0 Drivers: hv: hv_balloon: eliminate jumps in piecewiese linear floor function Drivers: hv: hv_balloon: do not online pages in offline blocks hv: remove the per-channel workqueue hv: don't schedule new works in vmbus_onoffer()/vmbus_onoffer_rescind() hv: run non-blocking message handlers in the dispatch tasklet coresight: moving to new "hwtracing" directory coresight-tmc: Adding a status interface to sysfs coresight: remove the unnecessary configuration coresight-default-sink ...
2015-04-21Merge tag 'tty-4.1-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty/serial updates from Greg KH: "Here's the big tty/serial driver update for 4.1-rc1. It was delayed for a bit due to some questions surrounding some of the console command line parsing changes that are in here. There's still one tiny regression for people who were previously putting multiple console command lines and expecting them all to be ignored for some odd reason, but Peter is working on fixing that. If not, I'll send a revert for the offending patch, but I have faith that Peter can address it. Other than the console work here, there's the usual serial driver updates and changes, and a buch of 8250 reworks to try to make that driver easier to maintain over time, and have it support more devices in the future. All of these have been in linux-next for a while" * tag 'tty-4.1-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (119 commits) n_gsm: Drop unneeded cast on netdev_priv sc16is7xx: expose RTS inversion in RS-485 mode serial: 8250_pci: port failed after wakeup from S3 earlycon: 8250: Document kernel command line options earlycon: 8250: Fix command line regression earlycon: Fix __earlycon_table stride tty: clean up the tty time logic a bit serial: 8250_dw: only get the clock rate in one place serial: 8250_dw: remove useless ACPI ID check dmaengine: hsu: move memory allocation to GFP_NOWAIT dmaengine: hsu: remove redundant pieces of code serial: 8250_pci: add Intel Tangier support dmaengine: hsu: add Intel Tangier PCI ID serial: 8250_pci: replace switch-case by formula for Intel MID serial: 8250_pci: replace switch-case by formula tty: cpm_uart: replace CONFIG_8xx by CONFIG_CPM1 serial: jsm: some off by one bugs serial: xuartps: Fix check in console_setup(). serial: xuartps: Get rid of register access macros. serial: xuartps: Fix iobase use. ...
2015-04-19smp: Fix error case handling in smp_call_function_*()Linus Torvalds
Commit 8053871d0f7f ("smp: Fix smp_call_function_single_async() locking") fixed the locking for the asynchronous smp-call case, but in the process of moving the lock handling around, one of the error cases ended up not unlocking the call data at all. This went unnoticed on x86, because this is a "caller is buggy" case, where the caller is trying to call a non-existent CPU. But apparently ARM does that (at least under qemu-arm). Bindly doing cross-cpu calls to random CPU's that aren't even online seems a bit fishy, but the error handling was clearly not correct. Simply add the missing "csd_unlock()" to the error path. Reported-and-tested-by: Guenter Roeck <linux@roeck-us.net> Analyzed-by: Rabin Vincent <rabin@rab.in> Acked-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-18Merge branch 'locking-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull locking fixes from Ingo Molnar: "Two fixes: an smp-call fix and a lockdep fix" * 'locking-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: smp: Fix smp_call_function_single_async() locking lockdep: Make print_lock() robust against concurrent release
2015-04-18Merge branch 'for-mingo' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-rcu into core/urgent Pull RCU fix from Paul E. McKenney: "This series contains a single change that fixes Kconfig asking pointless questions." Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-04-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Fix verifier memory corruption and other bugs in BPF layer, from Alexei Starovoitov. 2) Add a conservative fix for doing BPF properly in the BPF classifier of the packet scheduler on ingress. Also from Alexei. 3) The SKB scrubber should not clear out the packet MARK and security label, from Herbert Xu. 4) Fix oops on rmmod in stmmac driver, from Bryan O'Donoghue. 5) Pause handling is not correct in the stmmac driver because it doesn't take into consideration the RX and TX fifo sizes. From Vince Bridgers. 6) Failure path missing unlock in FOU driver, from Wang Cong. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (44 commits) net: dsa: use DEVICE_ATTR_RW to declare temp1_max netns: remove BUG_ONs from net_generic() IB/ipoib: Fix ndo_get_iflink sfc: Fix memcpy() with const destination compiler warning. altera tse: Fix network-delays and -retransmissions after high throughput. net: remove unused 'dev' argument from netif_needs_gso() act_mirred: Fix bogus header when redirecting from VLAN inet_diag: fix access to tcp cc information tcp: tcp_get_info() should fetch socket fields once net: dsa: mv88e6xxx: Add missing initialization in mv88e6xxx_set_port_state() skbuff: Do not scrub skb mark within the same name space Revert "net: Reset secmark when scrubbing packet" bpf: fix two bugs in verification logic when accessing 'ctx' pointer bpf: fix bpf helpers to use skb->mac_header relative offsets stmmac: Configure Flow Control to work correctly based on rxfifo size stmmac: Enable unicast pause frame detect in GMAC Register 6 stmmac: Read tx-fifo-depth and rx-fifo-depth from the devicetree stmmac: Add defines and documentation for enabling flow control stmmac: Add properties for transmit and receive fifo sizes stmmac: fix oops on rmmod after assigning ip addr ...
2015-04-17tracing: Fix possible out of bounds memory access when parsing enumsSteven Rostedt (Red Hat)
The code that replaces the enum names with the enum values in the tracepoints' format files could possible miss the end of string nul character. This was caused by processing things like backslashes, quotes and other tokens. After processing the tokens, a check for the nul character needed to be done before continuing the loop, because the loop incremented the pointer before doing the check, which could bypass the nul character. Link: http://lkml.kernel.org/r/552E661D.5060502@oracle.com Reported-by: Sasha Levin <sasha.levin@oracle.com> # via KASan Tested-by: Andrey Ryabinin <a.ryabinin@samsung.com> Fixes: 0c564a538aa9 "tracing: Add TRACE_DEFINE_ENUM() macro to map enums to their values" Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-04-17oprofile: reduce mmap_sem hold for mm->exe_fileDavidlohr Bueso
sync_buffer() needs the mmap_sem for two distinct operations, both only occurring upon user context switch handling: 1) Dealing with the exe_file. 2) Adding the dcookie data as we need to lookup the vma that backs it. This is done via add_sample() and add_data(). This patch isolates 1), for it will no longer need the mmap_sem for serialization. However, for now, make of the more standard get_mm_exe_file(), requiring only holding the mmap_sem to read the value, and relying on reference counting to make sure that the exe file won't dissappear underneath us while doing the get dcookie. As a consequence, for 2) we move the mmap_sem locking into where we really need it, in lookup_dcookie(). The benefits are twofold: reduce mmap_sem hold times, and cleaner code. [akpm@linux-foundation.org: export get_mm_exe_file for arch/x86/oprofile/oprofile.ko] Signed-off-by: Davidlohr Bueso <dbueso@suse.de> Cc: Robert Richter <rric@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17gcov: fix softlockupsAndrey Ryabinin
gcov profiling if enabled with other heavy compile-time instrumentation like KASan could trigger following softlockups: NMI watchdog: BUG: soft lockup - CPU#0 stuck for 22s! [swapper/0:1] Modules linked in: irq event stamp: 22823276 hardirqs last enabled at (22823275): [<ffffffff86e8d10d>] mutex_lock_nested+0x7d9/0x930 hardirqs last disabled at (22823276): [<ffffffff86e9521d>] apic_timer_interrupt+0x6d/0x80 softirqs last enabled at (22823172): [<ffffffff811ed969>] __do_softirq+0x4db/0x729 softirqs last disabled at (22823167): [<ffffffff811edfcf>] irq_exit+0x7d/0x15b CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 3.19.0-05245-gbb33326-dirty #3 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.7.5.1-0-g8936dbb-20141113_115728-nilsson.home.kraxel.org 04/01/2014 task: ffff88006cba8000 ti: ffff88006cbb0000 task.ti: ffff88006cbb0000 RIP: kasan_mem_to_shadow+0x1e/0x1f Call Trace: strcmp+0x28/0x70 get_node_by_name+0x66/0x99 gcov_event+0x4f/0x69e gcov_enable_events+0x54/0x7b gcov_fs_init+0xf8/0x134 do_one_initcall+0x1b2/0x288 kernel_init_freeable+0x467/0x580 kernel_init+0x15/0x18b ret_from_fork+0x7c/0xb0 Kernel panic - not syncing: softlockup: hung tasks Fix this by sticking cond_resched() in gcov_enable_events(). Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Reported-by: Fengguang Wu <fengguang.wu@intel.com> Cc: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17kernel/sysctl.c: detect overflows when converting to intHeinrich Schuchardt
When converting unsigned long to int overflows may occur. These currently are not detected when writing to the sysctl file system. E.g. on a system where int has 32 bits and long has 64 bits echo 0x800001234 > /proc/sys/kernel/threads-max has the same effect as echo 0x1234 > /proc/sys/kernel/threads-max The patch adds the missing check in do_proc_dointvec_conv. With the patch an overflow will result in an error EINVAL when writing to the the sysctl file system. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17prctl: avoid using mmap_sem for exe_file serializationDavidlohr Bueso
Oleg cleverly suggested using xchg() to set the new mm->exe_file instead of calling set_mm_exe_file() which requires some form of serialization -- mmap_sem in this case. For archs that do not have atomic rmw instructions we still fallback to a spinlock alternative, so this should always be safe. As such, we only need the mmap_sem for looking up the backing vm_file, which can be done sharing the lock. Naturally, this means we need to manually deal with both the new and old file reference counting, and we need not worry about the MMF_EXE_FILE_CHANGED bits, which can probably be deleted in the future anyway. Signed-off-by: Davidlohr Bueso <dbueso@suse.de> Suggested-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Oleg Nesterov <oleg@redhat.com> Reviewed-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17mm: rcu-protected get_mm_exe_file()Konstantin Khlebnikov
This patch removes mm->mmap_sem from mm->exe_file read side. Also it kills dup_mm_exe_file() and moves exe_file duplication into dup_mmap() where both mmap_sems are locked. [akpm@linux-foundation.org: fix comment typo] Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Cc: Davidlohr Bueso <dbueso@suse.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Oleg Nesterov <oleg@redhat.com> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17kernel/sysctl.c: threads-max observe limitsHeinrich Schuchardt
Users can change the maximum number of threads by writing to /proc/sys/kernel/threads-max. With the patch the value entered is checked against the same limits that apply when fork_init is called. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17kernel/fork.c: avoid division by zeroHeinrich Schuchardt
PAGE_SIZE is not guaranteed to be equal to or less than 8 times the THREAD_SIZE. E.g. architecture hexagon may have page size 1M and thread size 4096. This would lead to a division by zero in the calculation of max_threads. With 32-bit calculation there is no solution which delivers valid results for all possible combinations of the parameters. The code is only called once. Hence a 64-bit calculation can be used as solution. [akpm@linux-foundation.org: use clamp_t(), per Oleg] Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17kernel/fork.c: new function for max_threadsHeinrich Schuchardt
PAGE_SIZE is not guaranteed to be equal to or less than 8 times the THREAD_SIZE. E.g. architecture hexagon may have page size 1M and thread size 4096. This would lead to a division by zero in the calculation of max_threads. With this patch the buggy code is moved to a separate function set_max_threads. The error is not fixed. After fixing the problem in a separate patch the new function can be reused to adjust max_threads after adding or removing memory. Argument mempages of function fork_init() is removed as totalram_pages is an exported symbol. The creation of separate patches for refactoring to a new function and for fixing the logic was suggested by Ingo Molnar. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17fork_init: update max_threads commentJean Delvare
The comment explaining what value max_threads is set to is outdated. The maximum memory consumption ratio for thread structures was 1/2 until February 2002, then it was briefly changed to 1/16 before being set to 1/8 which we still use today. The comment was never updated to reflect that change, it's about time. Signed-off-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17fork: report pid reservation failure properlyMichal Hocko
copy_process will report any failure in alloc_pid as ENOMEM currently which is misleading because the pid allocation might fail not only when the memory is short but also when the pid space is consumed already. The current man page even mentions this case: : EAGAIN : : A system-imposed limit on the number of threads was encountered. : There are a number of limits that may trigger this error: the : RLIMIT_NPROC soft resource limit (set via setrlimit(2)), which : limits the number of processes and threads for a real user ID, was : reached; the kernel's system-wide limit on the number of processes : and threads, /proc/sys/kernel/threads-max, was reached (see : proc(5)); or the maximum number of PIDs, /proc/sys/kernel/pid_max, : was reached (see proc(5)). so the current behavior is also incorrect wrt. documentation. POSIX man page also suggest returing EAGAIN when the process count limit is reached. This patch simply propagates error code from alloc_pid and makes sure we return -EAGAIN due to reservation failure. This will make behavior of fork closer to both our documentation and POSIX. alloc_pid might alsoo fail when the reaper in the pid namespace is dead (the namespace basically disallows all new processes) and there is no good error code which would match documented ones. We have traditionally returned ENOMEM for this case which is misleading as well but as per Eric W. Biederman this behavior is documented in man pid_namespaces(7) : If the "init" process of a PID namespace terminates, the kernel : terminates all of the processes in the namespace via a SIGKILL signal. : This behavior reflects the fact that the "init" process is essential for : the correct operation of a PID namespace. In this case, a subsequent : fork(2) into this PID namespace will fail with the error ENOMEM; it is : not possible to create a new processes in a PID namespace whose "init" : process has terminated. and introducing a new error code would be too risky so let's stick to ENOMEM for this case. Signed-off-by: Michal Hocko <mhocko@suse.cz> Cc: Oleg Nesterov <oleg@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17signal: remove warning about using SI_TKILL in rt_[tg]sigqueueinfoVladimir Davydov
Sending SI_TKILL from rt_[tg]sigqueueinfo was deprecated, so now we issue a warning on the first attempt of doing it. We use WARN_ON_ONCE, which is not informative and, what is worse, taints the kernel, making the trinity syscall fuzzer complain false-positively from time to time. It does not look like we need this warning at all, because the behaviour changed quite a long time ago (2.6.39), and if an application relies on the old API, it gets EPERM anyway and can issue a warning by itself. So let us zap the warning in kernel. Signed-off-by: Vladimir Davydov <vdavydov@parallels.com> Acked-by: Oleg Nesterov <oleg@redhat.com> Cc: Richard Weinberger <richard@nod.at> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17ptrace: ptrace_detach() can no longer race with SIGKILLOleg Nesterov
ptrace_detach() re-checks ->ptrace under tasklist lock and calls release_task() if __ptrace_detach() returns true. This was needed because the __TASK_TRACED tracee could be killed/untraced, and it could even pass exit_notify() before we take tasklist_lock. But this is no longer possible after 9899d11f6544 "ptrace: ensure arch_ptrace/ptrace_request can never race with SIGKILL". We can turn these checks into WARN_ON() and remove release_task(). While at it, document the setting of child->exit_code. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Pavel Labath <labath@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17ptrace: fix race between ptrace_resume() and wait_task_stopped()Oleg Nesterov
ptrace_resume() is called when the tracee is still __TASK_TRACED. We set tracee->exit_code and then wake_up_state() changes tracee->state. If the tracer's sub-thread does wait() in between, task_stopped_code(ptrace => T) wrongly looks like another report from tracee. This confuses debugger, and since wait_task_stopped() clears ->exit_code the tracee can miss a signal. Test-case: #include <stdio.h> #include <unistd.h> #include <sys/wait.h> #include <sys/ptrace.h> #include <pthread.h> #include <assert.h> int pid; void *waiter(void *arg) { int stat; for (;;) { assert(pid == wait(&stat)); assert(WIFSTOPPED(stat)); if (WSTOPSIG(stat) == SIGHUP) continue; assert(WSTOPSIG(stat) == SIGCONT); printf("ERR! extra/wrong report:%x\n", stat); } } int main(void) { pthread_t thread; pid = fork(); if (!pid) { assert(ptrace(PTRACE_TRACEME, 0,0,0) == 0); for (;;) kill(getpid(), SIGHUP); } assert(pthread_create(&thread, NULL, waiter, NULL) == 0); for (;;) ptrace(PTRACE_CONT, pid, 0, SIGCONT); return 0; } Note for stable: the bug is very old, but without 9899d11f6544 "ptrace: ensure arch_ptrace/ptrace_request can never race with SIGKILL" the fix should use lock_task_sighand(child). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Reported-by: Pavel Labath <labath@google.com> Tested-by: Pavel Labath <labath@google.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17smp: Fix smp_call_function_single_async() lockingLinus Torvalds
The current smp_function_call code suffers a number of problems, most notably smp_call_function_single_async() is broken. The problem is that flush_smp_call_function_queue() does csd_unlock() _after_ calling csd->func(). This means that a caller cannot properly synchronize the csd usage as it has to. Change the code to release the csd before calling ->func() for the async case, and put a WARN_ON_ONCE(csd->flags & CSD_FLAG_LOCK) in smp_call_function_single_async() to warn us of improper serialization, because any waiting there can results in deadlocks when called with IRQs disabled. Rename the (currently) unused WAIT flag to SYNCHRONOUS and (re)use it such that we know what to do in flush_smp_call_function_queue(). Rework csd_{,un}lock() to use smp_load_acquire() / smp_store_release() to avoid some full barriers while more clearly providing lock semantics. Finally move the csd maintenance out of generic_exec_single() into its callers for clearer code. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> [ Added changelog. ] Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Rafael David Tinoco <inaddy@ubuntu.com> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/CA+55aFz492bzLFhdbKN-Hygjcreup7CjMEYk3nTSfRWjppz-OA@mail.gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-04-17lockdep: Make print_lock() robust against concurrent releasePeter Zijlstra
During sysrq's show-held-locks command it is possible that hlock_class() returns NULL for a given lock. The result is then (after the warning): |BUG: unable to handle kernel NULL pointer dereference at 0000001c |IP: [<c1088145>] get_usage_chars+0x5/0x100 |Call Trace: | [<c1088263>] print_lock_name+0x23/0x60 | [<c1576b57>] print_lock+0x5d/0x7e | [<c1088314>] lockdep_print_held_locks+0x74/0xe0 | [<c1088652>] debug_show_all_locks+0x132/0x1b0 | [<c1315c48>] sysrq_handle_showlocks+0x8/0x10 This *might* happen because the thread on the other CPU drops the lock after we are looking ->lockdep_depth and ->held_locks points no longer to a lock that is held. The fix here is to simply ignore it and continue. Reported-by: Andreas Messerschmid <andreas@linutronix.de> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-04-16bpf: fix two bugs in verification logic when accessing 'ctx' pointerAlexei Starovoitov
1. first bug is a silly mistake. It broke tracing examples and prevented simple bpf programs from loading. In the following code: if (insn->imm == 0 && BPF_SIZE(insn->code) == BPF_W) { } else if (...) { // this part should have been executed when // insn->code == BPF_W and insn->imm != 0 } Obviously it's not doing that. So simple instructions like: r2 = *(u64 *)(r1 + 8) will be rejected. Note the comments in the code around these branches were and still valid and indicate the true intent. Replace it with: if (BPF_SIZE(insn->code) != BPF_W) continue; if (insn->imm == 0) { } else if (...) { // now this code will be executed when // insn->code == BPF_W and insn->imm != 0 } 2. second bug is more subtle. If malicious code is using the same dest register as source register, the checks designed to prevent the same instruction to be used with different pointer types will fail to trigger, since we were assigning src_reg_type when it was already overwritten by check_mem_access(). The fix is trivial. Just move line: src_reg_type = regs[insn->src_reg].type; before check_mem_access(). Add new 'access skb fields bad4' test to check this case. Fixes: 9bac3d6d548e ("bpf: allow extended BPF programs access skb fields") Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-16bpf: fix verifier memory corruptionAlexei Starovoitov
Due to missing bounds check the DAG pass of the BPF verifier can corrupt the memory which can cause random crashes during program loading: [8.449451] BUG: unable to handle kernel paging request at ffffffffffffffff [8.451293] IP: [<ffffffff811de33d>] kmem_cache_alloc_trace+0x8d/0x2f0 [8.452329] Oops: 0000 [#1] SMP [8.452329] Call Trace: [8.452329] [<ffffffff8116cc82>] bpf_check+0x852/0x2000 [8.452329] [<ffffffff8116b7e4>] bpf_prog_load+0x1e4/0x310 [8.452329] [<ffffffff811b190f>] ? might_fault+0x5f/0xb0 [8.452329] [<ffffffff8116c206>] SyS_bpf+0x806/0xa30 Fixes: f1bca824dabb ("bpf: add search pruning optimization to verifier") Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-16tracing: Fix incorrect enabling of trace events by boot cmdlineJoonsoo Kim
There is a problem that trace events are not properly enabled with boot cmdline. The problem is that if we pass "trace_event=kmem:mm_page_alloc" to the boot cmdline, it enables all kmem trace events, and not just the page_alloc event. This is caused by the parsing mechanism. When we parse the cmdline, the buffer contents is modified due to tokenization. And, if we use this buffer again, we will get the wrong result. Unfortunately, this buffer is be accessed three times to set trace events properly at boot time. So, we need to handle this situation. There is already code handling ",", but we need another for ":". This patch adds it. Link: http://lkml.kernel.org/r/1429159484-22977-1-git-send-email-iamjoonsoo.kim@lge.com Cc: stable@vger.kernel.org # 3.19+ Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> [ added missing return ret; ] Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-04-16tracing: Handle ftrace_dump() atomic context in graph_trace_open()Rabin Vincent
graph_trace_open() can be called in atomic context from ftrace_dump(). Use GFP_ATOMIC for the memory allocations when that's the case, in order to avoid the following splat. BUG: sleeping function called from invalid context at mm/slab.c:2849 in_atomic(): 1, irqs_disabled(): 128, pid: 0, name: swapper/0 Backtrace: .. [<8004dc94>] (__might_sleep) from [<801371f4>] (kmem_cache_alloc_trace+0x160/0x238) r7:87800040 r6:000080d0 r5:810d16e8 r4:000080d0 [<80137094>] (kmem_cache_alloc_trace) from [<800cbd60>] (graph_trace_open+0x30/0xd0) r10:00000100 r9:809171a8 r8:00008e28 r7:810d16f0 r6:00000001 r5:810d16e8 r4:810d16f0 [<800cbd30>] (graph_trace_open) from [<800c79c4>] (trace_init_global_iter+0x50/0x9c) r8:00008e28 r7:808c853c r6:00000001 r5:810d16e8 r4:810d16f0 r3:800cbd30 [<800c7974>] (trace_init_global_iter) from [<800c7aa0>] (ftrace_dump+0x90/0x2ec) r4:810d2580 r3:00000000 [<800c7a10>] (ftrace_dump) from [<80414b2c>] (sysrq_ftrace_dump+0x1c/0x20) r10:00000100 r9:809171a8 r8:808f6e7c r7:00000001 r6:00000007 r5:0000007a r4:808d5394 [<80414b10>] (sysrq_ftrace_dump) from [<800169b8>] (return_to_handler+0x0/0x18) [<80415498>] (__handle_sysrq) from [<800169b8>] (return_to_handler+0x0/0x18) r8:808c8100 r7:808c8444 r6:00000101 r5:00000010 r4:84eb3210 [<80415668>] (handle_sysrq) from [<800169b8>] (return_to_handler+0x0/0x18) [<8042a760>] (pl011_int) from [<800169b8>] (return_to_handler+0x0/0x18) r10:809171bc r9:809171a8 r8:00000001 r7:00000026 r6:808c6000 r5:84f01e60 r4:8454fe00 [<8007782c>] (handle_irq_event_percpu) from [<80077b44>] (handle_irq_event+0x4c/0x6c) r10:808c7ef0 r9:87283e00 r8:00000001 r7:00000000 r6:8454fe00 r5:84f01e60 r4:84f01e00 [<80077af8>] (handle_irq_event) from [<8007aa28>] (handle_fasteoi_irq+0xf0/0x1ac) r6:808f52a4 r5:84f01e60 r4:84f01e00 r3:00000000 [<8007a938>] (handle_fasteoi_irq) from [<80076dc0>] (generic_handle_irq+0x3c/0x4c) r6:00000026 r5:00000000 r4:00000026 r3:8007a938 [<80076d84>] (generic_handle_irq) from [<80077128>] (__handle_domain_irq+0x8c/0xfc) r4:808c1e38 r3:0000002e [<8007709c>] (__handle_domain_irq) from [<800087b8>] (gic_handle_irq+0x34/0x6c) r10:80917748 r9:00000001 r8:88802100 r7:808c7ef0 r6:808c8fb0 r5:00000015 r4:8880210c r3:808c7ef0 [<80008784>] (gic_handle_irq) from [<80014044>] (__irq_svc+0x44/0x7c) Link: http://lkml.kernel.org/r/1428953721-31349-1-git-send-email-rabin@rab.in Link: http://lkml.kernel.org/r/1428957012-2319-1-git-send-email-rabin@rab.in Cc: stable@vger.kernel.org # 3.13+ Signed-off-by: Rabin Vincent <rabin@rab.in> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-04-15Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge second patchbomb from Andrew Morton: - the rest of MM - various misc bits - add ability to run /sbin/reboot at reboot time - printk/vsprintf changes - fiddle with seq_printf() return value * akpm: (114 commits) parisc: remove use of seq_printf return value lru_cache: remove use of seq_printf return value tracing: remove use of seq_printf return value cgroup: remove use of seq_printf return value proc: remove use of seq_printf return value s390: remove use of seq_printf return value cris fasttimer: remove use of seq_printf return value cris: remove use of seq_printf return value openrisc: remove use of seq_printf return value ARM: plat-pxa: remove use of seq_printf return value nios2: cpuinfo: remove use of seq_printf return value microblaze: mb: remove use of seq_printf return value ipc: remove use of seq_printf return value rtc: remove use of seq_printf return value power: wakeup: remove use of seq_printf return value x86: mtrr: if: remove use of seq_printf return value linux/bitmap.h: improve BITMAP_{LAST,FIRST}_WORD_MASK MAINTAINERS: CREDITS: remove Stefano Brivio from B43 .mailmap: add Ricardo Ribalda CREDITS: add Ricardo Ribalda Delgado ...
2015-04-15tracing: remove use of seq_printf return valueJoe Perches
The seq_printf return value, because it's frequently misused, will eventually be converted to void. See: commit 1f33c41c03da ("seq_file: Rename seq_overflow() to seq_has_overflowed() and make public") Miscellanea: o Remove unused return value from trace_lookup_stack Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-15cgroup: remove use of seq_printf return valueJoe Perches
The seq_printf return value, because it's frequently misused, will eventually be converted to void. See: commit 1f33c41c03da ("seq_file: Rename seq_overflow() to seq_has_overflowed() and make public") Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-15kernel/reboot.c: add orderly_reboot for graceful rebootJoel Stanley
The kernel has orderly_poweroff which allows the kernel to initiate a graceful shutdown of userspace, by running /sbin/poweroff. This adds orderly_reboot that will cause userspace to shut itself down by calling /sbin/reboot. This will be used for shutdown initiated by a system controller on platforms that do not use ACPI. orderly_reboot() should be used when the system wants to allow userspace to gracefully shut itself down. For cases where the system may imminently catch on fire, the existing emergency_restart() provides an immediate reboot without involving userspace. Signed-off-by: Joel Stanley <joel@jms.id.au> Cc: Fabian Frederick <fabf@skynet.be> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jeremy Kerr <jk@ozlabs.org> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
