path: root/kernel
2016-10-16timekeeping: Fix __ktime_get_fast_ns() regressionJohn Stultz
commit 58bfea9532552d422bde7afa207e1a0f08dffa7d upstream. In commit 27727df240c7 ("Avoid taking lock in NMI path with CONFIG_DEBUG_TIMEKEEPING"), I changed the logic to open-code the timekeeping_get_ns() function, but I forgot to include the unit conversion from cycles to nanoseconds, breaking the function's output, which impacts users like perf. This results in bogus perf timestamps like: swapper 0 [000] 253.427536: 111111111 cpu-clock: ffffffff810a0de6 native_safe_halt+0x6 ([kernel.kallsyms]) swapper 0 [000] 254.426573: 111111111 cpu-clock: ffffffff810a0de6 native_safe_halt+0x6 ([kernel.kallsyms]) swapper 0 [000] 254.426687: 111111111 cpu-clock: ffffffff810a0de6 native_safe_halt+0x6 ([kernel.kallsyms]) swapper 0 [000] 254.426800: 111111111 cpu-clock: ffffffff810a0de6 native_safe_halt+0x6 ([kernel.kallsyms]) swapper 0 [000] 254.426905: 111111111 cpu-clock: ffffffff810a0de6 native_safe_halt+0x6 ([kernel.kallsyms]) swapper 0 [000] 254.427022: 111111111 cpu-clock: ffffffff810a0de6 native_safe_halt+0x6 ([kernel.kallsyms]) swapper 0 [000] 254.427127: 111111111 cpu-clock: ffffffff810a0de6 native_safe_halt+0x6 ([kernel.kallsyms]) swapper 0 [000] 254.427239: 111111111 cpu-clock: ffffffff810a0de6 native_safe_halt+0x6 ([kernel.kallsyms]) swapper 0 [000] 254.427346: 111111111 cpu-clock: ffffffff810a0de6 native_safe_halt+0x6 ([kernel.kallsyms]) swapper 0 [000] 254.427463: 111111111 cpu-clock: ffffffff810a0de6 native_safe_halt+0x6 ([kernel.kallsyms]) swapper 0 [000] 255.426572: 111111111 cpu-clock: ffffffff810a0de6 native_safe_halt+0x6 ([kernel.kallsyms]) Instead of more reasonable expected timestamps like: swapper 0 [000] 39.953768: 111111111 cpu-clock: ffffffff810a0de6 native_safe_halt+0x6 ([kernel.kallsyms]) swapper 0 [000] 40.064839: 111111111 cpu-clock: ffffffff810a0de6 native_safe_halt+0x6 ([kernel.kallsyms]) swapper 0 [000] 40.175956: 111111111 cpu-clock: ffffffff810a0de6 native_safe_halt+0x6 ([kernel.kallsyms]) swapper 0 [000] 40.287103: 111111111 cpu-clock: ffffffff810a0de6 native_safe_halt+0x6 ([kernel.kallsyms]) swapper 0 [000] 40.398217: 111111111 cpu-clock: ffffffff810a0de6 native_safe_halt+0x6 ([kernel.kallsyms]) swapper 0 [000] 40.509324: 111111111 cpu-clock: ffffffff810a0de6 native_safe_halt+0x6 ([kernel.kallsyms]) swapper 0 [000] 40.620437: 111111111 cpu-clock: ffffffff810a0de6 native_safe_halt+0x6 ([kernel.kallsyms]) swapper 0 [000] 40.731546: 111111111 cpu-clock: ffffffff810a0de6 native_safe_halt+0x6 ([kernel.kallsyms]) swapper 0 [000] 40.842654: 111111111 cpu-clock: ffffffff810a0de6 native_safe_halt+0x6 ([kernel.kallsyms]) swapper 0 [000] 40.953772: 111111111 cpu-clock: ffffffff810a0de6 native_safe_halt+0x6 ([kernel.kallsyms]) swapper 0 [000] 41.064881: 111111111 cpu-clock: ffffffff810a0de6 native_safe_halt+0x6 ([kernel.kallsyms]) Add the proper use of timekeeping_delta_to_ns() to convert the cycle delta to nanoseconds as needed. Thanks to Brendan and Alexei for finding this quickly after the v4.8 release. Unfortunately the problematic commit has landed in some -stable trees so they'll need this fix as well. Many apologies for this mistake. I'll be looking to add a perf-clock sanity test to the kselftest timers tests soon. Fixes: 27727df240c7 "timekeeping: Avoid taking lock in NMI path with CONFIG_DEBUG_TIMEKEEPING" Reported-by: Brendan Gregg <bgregg@netflix.com> Reported-by: Alexei Starovoitov <alexei.starovoitov@gmail.com> Tested-and-reviewed-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Signed-off-by: John Stultz <john.stultz@linaro.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1475636148-26539-1-git-send-email-john.stultz@linaro.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-16time: Add cycles to nanoseconds translationChristopher S. Hall
commit 6bd58f09e1d8cc6c50a824c00bf0d617919986a1 upstream. The timekeeping code does not currently provide a way to translate externally provided clocksource cycles to system time. The cycle count is always provided by the result clocksource read() method internal to the timekeeping code. The added function timekeeping_cycles_to_ns() calculated a nanosecond value from a cycle count that can be added to tk_read_base.base value yielding the current system time. This allows clocksource cycle values external to the timekeeping code to provide a cycle count that can be transformed to system time. Cc: Prarit Bhargava <prarit@redhat.com> Cc: Richard Cochran <richardcochran@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@kernel.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: kevin.b.stanton@intel.com Cc: kevin.j.clarke@intel.com Cc: hpa@zytor.com Cc: jeffrey.t.kirsher@intel.com Cc: netdev@vger.kernel.org Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Christopher S. Hall <christopher.s.hall@intel.com> Signed-off-by: John Stultz <john.stultz@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-07kernel/fork: fix CLONE_CHILD_CLEARTID regression in nscdMichal Hocko
commit 735f2770a770156100f534646158cb58cb8b2939 upstream. Commit fec1d0115240 ("[PATCH] Disable CLONE_CHILD_CLEARTID for abnormal exit") has caused a subtle regression in nscd which uses CLONE_CHILD_CLEARTID to clear the nscd_certainly_running flag in the shared databases, so that the clients are notified when nscd is restarted. Now, when nscd uses a non-persistent database, clients that have it mapped keep thinking the database is being updated by nscd, when in fact nscd has created a new (anonymous) one (for non-persistent databases it uses an unlinked file as backend). The original proposal for the CLONE_CHILD_CLEARTID change claimed (https://lkml.org/lkml/2006/10/25/233): : The NPTL library uses the CLONE_CHILD_CLEARTID flag on clone() syscalls : on behalf of pthread_create() library calls. This feature is used to : request that the kernel clear the thread-id in user space (at an address : provided in the syscall) when the thread disassociates itself from the : address space, which is done in mm_release(). : : Unfortunately, when a multi-threaded process incurs a core dump (such as : from a SIGSEGV), the core-dumping thread sends SIGKILL signals to all of : the other threads, which then proceed to clear their user-space tids : before synchronizing in exit_mm() with the start of core dumping. This : misrepresents the state of process's address space at the time of the : SIGSEGV and makes it more difficult for someone to debug NPTL and glibc : problems (misleading him/her to conclude that the threads had gone away : before the fault). : : The fix below is to simply avoid the CLONE_CHILD_CLEARTID action if a : core dump has been initiated. The resulting patch from Roland (https://lkml.org/lkml/2006/10/26/269) seems to have a larger scope than the original patch asked for. It seems that limitting the scope of the check to core dumping should work for SIGSEGV issue describe above. [Changelog partly based on Andreas' description] Fixes: fec1d0115240 ("[PATCH] Disable CLONE_CHILD_CLEARTID for abnormal exit") Link: http://lkml.kernel.org/r/1471968749-26173-1-git-send-email-mhocko@kernel.org Signed-off-by: Michal Hocko <mhocko@suse.com> Tested-by: William Preston <wpreston@suse.com> Acked-by: Oleg Nesterov <oleg@redhat.com> Cc: Roland McGrath <roland@hack.frob.com> Cc: Andreas Schwab <schwab@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-07sysctl: handle error writing UINT_MAX to u32 fieldsSubash Abhinov Kasiviswanathan
commit e7d316a02f683864a12389f8808570e37fb90aa3 upstream. We have scripts which write to certain fields on 3.18 kernels but this seems to be failing on 4.4 kernels. An entry which we write to here is xfrm_aevent_rseqth which is u32. echo 4294967295 > /proc/sys/net/core/xfrm_aevent_rseqth Commit 230633d109e3 ("kernel/sysctl.c: detect overflows when converting to int") prevented writing to sysctl entries when integer overflow occurs. However, this does not apply to unsigned integers. Heinrich suggested that we introduce a new option to handle 64 bit limits and set min as 0 and max as UINT_MAX. This might not work as it leads to issues similar to __do_proc_doulongvec_minmax. Alternatively, we would need to change the datatype of the entry to 64 bit. static int __do_proc_doulongvec_minmax(void *data, struct ctl_table { i = (unsigned long *) data; //This cast is causing to read beyond the size of data (u32) vleft = table->maxlen / sizeof(unsigned long); //vleft is 0 because maxlen is sizeof(u32) which is lesser than sizeof(unsigned long) on x86_64. Introduce a new proc handler proc_douintvec. Individual proc entries will need to be updated to use the new handler. [akpm@linux-foundation.org: coding-style fixes] Fixes: 230633d109e3 ("kernel/sysctl.c:detect overflows when converting to int") Link: http://lkml.kernel.org/r/1471479806-5252-1-git-send-email-subashab@codeaurora.org Signed-off-by: Subash Abhinov Kasiviswanathan <subashab@codeaurora.org> Cc: Heinrich Schuchardt <xypron.glpk@gmx.de> Cc: Kees Cook <keescook@chromium.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Ingo Molnar <mingo@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-07printk: fix parsing of "brl=" optionNicolas Iooss
commit ae6c33ba6e37eea3012fe2640b22400ef3f2d0f3 upstream. Commit bbeddf52adc1 ("printk: move braille console support into separate braille.[ch] files") moved the parsing of braille-related options into _braille_console_setup(), changing the type of variable str from char* to char**. In this commit, memcmp(str, "brl,", 4) was correctly updated to memcmp(*str, "brl,", 4) but not memcmp(str, "brl=", 4). Update the code to make "brl=" option work again and replace memcmp() with strncmp() to make the compiler able to detect such an issue. Fixes: bbeddf52adc1 ("printk: move braille console support into separate braille.[ch] files") Link: http://lkml.kernel.org/r/20160823165700.28952-1-nicolas.iooss_linux@m4x.org Signed-off-by: Nicolas Iooss <nicolas.iooss_linux@m4x.org> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-07perf/core: Fix pmu::filter_match for SW-led groupsMark Rutland
commit 2c81a6477081966fe80b8c6daa68459bca896774 upstream. The following commit: 66eb579e66ec ("perf: allow for PMU-specific event filtering") added the pmu::filter_match() callback. This was intended to avoid HW constraints on events from resulting in extremely pessimistic scheduling. However, pmu::filter_match() is only called for the leader of each event group. When the leader is a SW event, we do not filter the groups, and may fail at pmu::add() time, and when this happens we'll give up on scheduling any event groups later in the list until they are rotated ahead of the failing group. This can result in extremely sub-optimal event scheduling behaviour, e.g. if running the following on a big.LITTLE platform: $ taskset -c 0 ./perf stat \ -e 'a57{context-switches,armv8_cortex_a57/config=0x11/}' \ -e 'a53{context-switches,armv8_cortex_a53/config=0x11/}' \ ls <not counted> context-switches (0.00%) <not counted> armv8_cortex_a57/config=0x11/ (0.00%) 24 context-switches (37.36%) 57589154 armv8_cortex_a53/config=0x11/ (37.36%) Here the 'a53' event group was always eligible to be scheduled, but the 'a57' group never eligible to be scheduled, as the task was always affine to a Cortex-A53 CPU. The SW (group leader) event in the 'a57' group was eligible, but the HW event failed at pmu::add() time, resulting in ctx_flexible_sched_in giving up on scheduling further groups with HW events. One way of avoiding this is to check pmu::filter_match() on siblings as well as the group leader. If any of these fail their pmu::filter_match() call, we must skip the entire group before attempting to add any events. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Will Deacon <will.deacon@arm.com> Fixes: 66eb579e66ec ("perf: allow for PMU-specific event filtering") Link: http://lkml.kernel.org/r/1465917041-15339-1-git-send-email-mark.rutland@arm.com [ Small readability edits. ] Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-07cpuset: handle race between CPU hotplug and cpuset_hotplug_workJoonwoo Park
commit 28b89b9e6f7b6c8fef7b3af39828722bca20cfee upstream. A discrepancy between cpu_online_mask and cpuset's effective_cpus mask is inevitable during hotplug since cpuset defers updating of effective_cpus mask using a workqueue, during which time nothing prevents the system from more hotplug operations. For that reason guarantee_online_cpus() walks up the cpuset hierarchy until it finds an intersection under the assumption that top cpuset's effective_cpus mask intersects with cpu_online_mask even with such a race occurring. However a sequence of CPU hotplugs can open a time window, during which none of the effective CPUs in the top cpuset intersect with cpu_online_mask. For example when there are 4 possible CPUs 0-3 and only CPU0 is online: ======================== =========================== cpu_online_mask top_cpuset.effective_cpus ======================== =========================== echo 1 > cpu2/online. CPU hotplug notifier woke up hotplug work but not yet scheduled. [0,2] [0] echo 0 > cpu0/online. The workqueue is still runnable. [2] [0] ======================== =========================== Now there is no intersection between cpu_online_mask and top_cpuset.effective_cpus. Thus invoking sys_sched_setaffinity() at this moment can cause following: Unable to handle kernel NULL pointer dereference at virtual address 000000d0 ------------[ cut here ]------------ Kernel BUG at ffffffc0001389b0 [verbose debug info unavailable] Internal error: Oops - BUG: 96000005 [#1] PREEMPT SMP Modules linked in: CPU: 2 PID: 1420 Comm: taskset Tainted: G W 4.4.8+ #98 task: ffffffc06a5c4880 ti: ffffffc06e124000 task.ti: ffffffc06e124000 PC is at guarantee_online_cpus+0x2c/0x58 LR is at cpuset_cpus_allowed+0x4c/0x6c <snip> Process taskset (pid: 1420, stack limit = 0xffffffc06e124020) Call trace: [<ffffffc0001389b0>] guarantee_online_cpus+0x2c/0x58 [<ffffffc00013b208>] cpuset_cpus_allowed+0x4c/0x6c [<ffffffc0000d61f0>] sched_setaffinity+0xc0/0x1ac [<ffffffc0000d6374>] SyS_sched_setaffinity+0x98/0xac [<ffffffc000085cb0>] el0_svc_naked+0x24/0x28 The top cpuset's effective_cpus are guaranteed to be identical to cpu_online_mask eventually. Hence fall back to cpu_online_mask when there is no intersection between top cpuset's effective_cpus and cpu_online_mask. Signed-off-by: Joonwoo Park <joonwoop@codeaurora.org> Acked-by: Li Zefan <lizefan@huawei.com> Cc: Tejun Heo <tj@kernel.org> Cc: cgroups@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-30PM / hibernate: Fix rtree_next_node() to avoid walking off list endsJames Morse
commit 924d8696751c4b9e58263bc82efdafcf875596a6 upstream. rtree_next_node() walks the linked list of leaf nodes to find the next block of pages in the struct memory_bitmap. If it walks off the end of the list of nodes, it walks the list of memory zones to find the next region of memory. If it walks off the end of the list of zones, it returns false. This leaves the struct bm_position's node and zone pointers pointing at their respective struct list_heads in struct mem_zone_bm_rtree. memory_bm_find_bit() uses struct bm_position's node and zone pointers to avoid walking lists and trees if the next bit appears in the same node/zone. It handles these values being stale. Swap rtree_next_node()s 'step then test' to 'test-next then step', this means if we reach the end of memory we return false and leave the node and zone pointers as they were. This fixes a panic on resume using AMD Seattle with 64K pages: [ 6.868732] Freezing user space processes ... (elapsed 0.000 seconds) done. [ 6.875753] Double checking all user space processes after OOM killer disable... (elapsed 0.000 seconds) [ 6.896453] PM: Using 3 thread(s) for decompression. [ 6.896453] PM: Loading and decompressing image data (5339 pages)... [ 7.318890] PM: Image loading progress: 0% [ 7.323395] Unable to handle kernel paging request at virtual address 00800040 [ 7.330611] pgd = ffff000008df0000 [ 7.334003] [00800040] *pgd=00000083fffe0003, *pud=00000083fffe0003, *pmd=00000083fffd0003, *pte=0000000000000000 [ 7.344266] Internal error: Oops: 96000005 [#1] PREEMPT SMP [ 7.349825] Modules linked in: [ 7.352871] CPU: 2 PID: 1 Comm: swapper/0 Tainted: G W I 4.8.0-rc1 #4737 [ 7.360512] Hardware name: AMD Overdrive/Supercharger/Default string, BIOS ROD1002C 04/08/2016 [ 7.369109] task: ffff8003c0220000 task.stack: ffff8003c0280000 [ 7.375020] PC is at set_bit+0x18/0x30 [ 7.378758] LR is at memory_bm_set_bit+0x24/0x30 [ 7.383362] pc : [<ffff00000835bbc8>] lr : [<ffff0000080faf18>] pstate: 60000045 [ 7.390743] sp : ffff8003c0283b00 [ 7.473551] [ 7.475031] Process swapper/0 (pid: 1, stack limit = 0xffff8003c0280020) [ 7.481718] Stack: (0xffff8003c0283b00 to 0xffff8003c0284000) [ 7.800075] Call trace: [ 7.887097] [<ffff00000835bbc8>] set_bit+0x18/0x30 [ 7.891876] [<ffff0000080fb038>] duplicate_memory_bitmap.constprop.38+0x54/0x70 [ 7.899172] [<ffff0000080fcc40>] snapshot_write_next+0x22c/0x47c [ 7.905166] [<ffff0000080fe1b4>] load_image_lzo+0x754/0xa88 [ 7.910725] [<ffff0000080ff0a8>] swsusp_read+0x144/0x230 [ 7.916025] [<ffff0000080fa338>] load_image_and_restore+0x58/0x90 [ 7.922105] [<ffff0000080fa660>] software_resume+0x2f0/0x338 [ 7.927752] [<ffff000008083350>] do_one_initcall+0x38/0x11c [ 7.933314] [<ffff000008b40cc0>] kernel_init_freeable+0x14c/0x1ec [ 7.939395] [<ffff0000087ce564>] kernel_init+0x10/0xfc [ 7.944520] [<ffff000008082e90>] ret_from_fork+0x10/0x40 [ 7.949820] Code: d2800022 8b400c21 f9800031 9ac32043 (c85f7c22) [ 7.955909] ---[ end trace 0024a5986e6ff323 ]--- [ 7.960529] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b Here struct mem_zone_bm_rtree's start_pfn has been returned instead of struct rtree_node's addr as the node/zone pointers are corrupt after we walked off the end of the lists during mark_unsafe_pages(). This behaviour was exposed by commit 6dbecfd345a6 ("PM / hibernate: Simplify mark_unsafe_pages()"), which caused mark_unsafe_pages() to call duplicate_memory_bitmap(), which uses memory_bm_find_bit() after walking off the end of the memory bitmap. Fixes: 3a20cb177961 (PM / Hibernate: Implement position keeping in radix tree) Signed-off-by: James Morse <james.morse@arm.com> [ rjw: Subject ] Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-30PM / hibernate: Restore processor state before using per-CPU variablesThomas Garnier
commit 62822e2ec4ad091ba31f823f577ef80db52e3c2c upstream. Restore the processor state before calling any other functions to ensure per-CPU variables can be used with KASLR memory randomization. Tracing functions use per-CPU variables (GS based on x86) and one was called just before restoring the processor state fully. It resulted in a double fault when both the tracing & the exception handler functions tried to use a per-CPU variable. Fixes: bb3632c6101b (PM / sleep: trace events for suspend/resume) Reported-and-tested-by: Borislav Petkov <bp@suse.de> Reported-by: Jiri Kosina <jikos@kernel.org> Tested-by: Rafael J. Wysocki <rafael@kernel.org> Tested-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Thomas Garnier <thgarnie@google.com> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-30tracing: Move mutex to protect against resetting of seq dataSteven Rostedt (Red Hat)
commit 1245800c0f96eb6ebb368593e251d66c01e61022 upstream. The iter->seq can be reset outside the protection of the mutex. So can reading of user data. Move the mutex up to the beginning of the function. Fixes: d7350c3f45694 ("tracing/core: make the read callbacks reentrants") Reported-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-30fix memory leaks in tracing_buffers_splice_read()Al Viro
commit 1ae2293dd6d2f5c823cf97e60b70d03631cd622f upstream. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-30Makefile: Mute warning for __builtin_return_address(>0) for tracing onlySteven Rostedt
commit 377ccbb483738f84400ddf5840c7dd8825716985 upstream. With the latest gcc compilers, they give a warning if __builtin_return_address() parameter is greater than 0. That is because if it is used by a function called by a top level function (or in the case of the kernel, by assembly), it can try to access stack frames outside the stack and crash the system. The tracing system uses __builtin_return_address() of up to 2! But it is well aware of the dangers that it may have, and has even added precautions to protect against it (see the thunk code in arch/x86/entry/thunk*.S) Linus originally added KBUILD_CFLAGS that would suppress the warning for the entire kernel, as simply adding KBUILD_CFLAGS to the tracing directory wouldn't work. The tracing directory plays a bit with the CFLAGS and requires a little more logic. This adds that special logic to only suppress the warning for the tracing directory. If it is used anywhere else outside of tracing, the warning will still be triggered. Link: http://lkml.kernel.org/r/20160728223043.51996267@grimm.local.home Tested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-30Fix build warning in kernel/cpuset.cArnd Bergmann
> 2 ../kernel/cpuset.c:2101:11: warning: initialization from incompatible pointer type [-Wincompatible-pointer-types] > 1 ../kernel/cpuset.c:2101:2: warning: initialization from incompatible pointer type > 1 ../kernel/cpuset.c:2101:2: warning: (near initialization for 'cpuset_cgrp_subsys.fork') This got introduced by 06ec7a1d7646 ("cpuset: make sure new tasks conform to the current config of the cpuset"). In the upstream kernel, the function prototype was changed as of b53202e63089 ("cgroup: kill cgrp_ss_priv[CGROUP_CANFORK_COUNT] and friends"). That patch is not suitable for stable kernels, and fortunately the warning seems harmless as the prototypes only differ in the second argument that is unused. Adding that argument gets rid of the warning: Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-24genirq/msi: Fix broken debug outputThomas Gleixner
commit 4364e1a29be16b2783c0bcbc263f61236af64281 upstream. virq is not required to be the same for all msi descs. Use the base irq number from the desc in the debug printk. Reported-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-24kconfig: tinyconfig: provide whole choice blocks to avoid warningsArnd Bergmann
commit 236dec051078a8691950f56949612b4b74107e48 upstream. Using "make tinyconfig" produces a couple of annoying warnings that show up for build test machines all the time: .config:966:warning: override: NOHIGHMEM changes choice state .config:965:warning: override: SLOB changes choice state .config:963:warning: override: KERNEL_XZ changes choice state .config:962:warning: override: CC_OPTIMIZE_FOR_SIZE changes choice state .config:933:warning: override: SLOB changes choice state .config:930:warning: override: CC_OPTIMIZE_FOR_SIZE changes choice state .config:870:warning: override: SLOB changes choice state .config:868:warning: override: KERNEL_XZ changes choice state .config:867:warning: override: CC_OPTIMIZE_FOR_SIZE changes choice state I've made a previous attempt at fixing them and we discussed a number of alternatives. I tried changing the Makefile to use "merge_config.sh -n $(fragment-list)" but couldn't get that to work properly. This is yet another approach, based on the observation that we do want to see a warning for conflicting 'choice' options, and that we can simply make them non-conflicting by listing all other options as disabled. This is a trivial patch that we can apply independent of plans for other changes. Link: http://lkml.kernel.org/r/20160829214952.1334674-2-arnd@arndb.de Link: https://storage.kernelci.org/mainline/v4.7-rc6/x86-tinyconfig/build.log https://patchwork.kernel.org/patch/9212749/ Signed-off-by: Arnd Bergmann <arnd@arndb.de> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-24sched/core: Fix a race between try_to_wake_up() and a woken up taskBalbir Singh
commit 135e8c9250dd5c8c9aae5984fde6f230d0cbfeaf upstream. The origin of the issue I've seen is related to a missing memory barrier between check for task->state and the check for task->on_rq. The task being woken up is already awake from a schedule() and is doing the following: do { schedule() set_current_state(TASK_(UN)INTERRUPTIBLE); } while (!cond); The waker, actually gets stuck doing the following in try_to_wake_up(): while (p->on_cpu) cpu_relax(); Analysis: The instance I've seen involves the following race: CPU1 CPU2 while () { if (cond) break; do { schedule(); set_current_state(TASK_UN..) } while (!cond); wakeup_routine() spin_lock_irqsave(wait_lock) raw_spin_lock_irqsave(wait_lock) wake_up_process() } try_to_wake_up() set_current_state(TASK_RUNNING); .. list_del(&waiter.list); CPU2 wakes up CPU1, but before it can get the wait_lock and set current state to TASK_RUNNING the following occurs: CPU3 wakeup_routine() raw_spin_lock_irqsave(wait_lock) if (!list_empty) wake_up_process() try_to_wake_up() raw_spin_lock_irqsave(p->pi_lock) .. if (p->on_rq && ttwu_wakeup()) .. while (p->on_cpu) cpu_relax() .. CPU3 tries to wake up the task on CPU1 again since it finds it on the wait_queue, CPU1 is spinning on wait_lock, but immediately after CPU2, CPU3 got it. CPU3 checks the state of p on CPU1, it is TASK_UNINTERRUPTIBLE and the task is spinning on the wait_lock. Interestingly since p->on_rq is checked under pi_lock, I've noticed that try_to_wake_up() finds p->on_rq to be 0. This was the most confusing bit of the analysis, but p->on_rq is changed under runqueue lock, rq_lock, the p->on_rq check is not reliable without this fix IMHO. The race is visible (based on the analysis) only when ttwu_queue() does a remote wakeup via ttwu_queue_remote. In which case the p->on_rq change is not done uder the pi_lock. The result is that after a while the entire system locks up on the raw_spin_irqlock_save(wait_lock) and the holder spins infintely Reproduction of the issue: The issue can be reproduced after a long run on my system with 80 threads and having to tweak available memory to very low and running memory stress-ng mmapfork test. It usually takes a long time to reproduce. I am trying to work on a test case that can reproduce the issue faster, but thats work in progress. I am still testing the changes on my still in a loop and the tests seem OK thus far. Big thanks to Benjamin and Nick for helping debug this as well. Ben helped catch the missing barrier, Nick caught every missing bit in my theory. Signed-off-by: Balbir Singh <bsingharora@gmail.com> [ Updated comment to clarify matching barriers. Many architectures do not have a full barrier in switch_to() so that cannot be relied upon. ] Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Alexey Kardashevskiy <aik@ozlabs.ru> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Nicholas Piggin <nicholas.piggin@gmail.com> Cc: Nicholas Piggin <npiggin@gmail.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/e02cce7b-d9ca-1ad0-7a61-ea97c7582b37@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-24cpuset: make sure new tasks conform to the current config of the cpusetZefan Li
commit 06f4e94898918bcad00cdd4d349313a439d6911e upstream. A new task inherits cpus_allowed and mems_allowed masks from its parent, but if someone changes cpuset's config by writing to cpuset.cpus/cpuset.mems before this new task is inserted into the cgroup's task list, the new task won't be updated accordingly. Signed-off-by: Zefan Li <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-24audit: fix exe_file access in audit_exe_compareMateusz Guzik
commit 5efc244346f9f338765da3d592f7947b0afdc4b5 upstream. Prior to the change the function would blindly deference mm, exe_file and exe_file->f_inode, each of which could have been NULL or freed. Use get_task_exe_file to safely obtain stable exe_file. Signed-off-by: Mateusz Guzik <mguzik@redhat.com> Acked-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Acked-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Paul Moore <paul@paul-moore.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-24mm: introduce get_task_exe_fileMateusz Guzik
commit cd81a9170e69e018bbaba547c1fd85a585f5697a upstream. For more convenient access if one has a pointer to the task. As a minor nit take advantage of the fact that only task lock + rcu are needed to safely grab ->exe_file. This saves mm refcount dance. Use the helper in proc_exe_link. Signed-off-by: Mateusz Guzik <mguzik@redhat.com> Acked-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Acked-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Paul Moore <paul@paul-moore.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-24kexec: fix double-free when failing to relocate the purgatoryThiago Jung Bauermann
commit 070c43eea5043e950daa423707ae3c77e2f48edb upstream. If kexec_apply_relocations fails, kexec_load_purgatory frees pi->sechdrs and pi->purgatory_buf. This is redundant, because in case of error kimage_file_prepare_segments calls kimage_file_post_load_cleanup, which will also free those buffers. This causes two warnings like the following, one for pi->sechdrs and the other for pi->purgatory_buf: kexec-bzImage64: Loading purgatory failed ------------[ cut here ]------------ WARNING: CPU: 1 PID: 2119 at mm/vmalloc.c:1490 __vunmap+0xc1/0xd0 Trying to vfree() nonexistent vm area (ffffc90000e91000) Modules linked in: CPU: 1 PID: 2119 Comm: kexec Not tainted 4.8.0-rc3+ #5 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011 Call Trace: dump_stack+0x4d/0x65 __warn+0xcb/0xf0 warn_slowpath_fmt+0x4f/0x60 ? find_vmap_area+0x19/0x70 ? kimage_file_post_load_cleanup+0x47/0xb0 __vunmap+0xc1/0xd0 vfree+0x2e/0x70 kimage_file_post_load_cleanup+0x5e/0xb0 SyS_kexec_file_load+0x448/0x680 ? putname+0x54/0x60 ? do_sys_open+0x190/0x1f0 entry_SYSCALL_64_fastpath+0x13/0x8f ---[ end trace 158bb74f5950ca2b ]--- Fix by setting pi->sechdrs an pi->purgatory_buf to NULL, since vfree won't try to free a NULL pointer. Link: http://lkml.kernel.org/r/1472083546-23683-1-git-send-email-bauerman@linux.vnet.ibm.com Signed-off-by: Thiago Jung Bauermann <bauerman@linux.vnet.ibm.com> Acked-by: Baoquan He <bhe@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Dave Young <dyoung@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-15uprobes: Fix the memcg accountingOleg Nesterov
commit 6c4687cc17a788a6dd8de3e27dbeabb7cbd3e066 upstream. __replace_page() wronlgy calls mem_cgroup_cancel_charge() in "success" path, it should only do this if page_check_address() fails. This means that every enable/disable leads to unbalanced mem_cgroup_uncharge() from put_page(old_page), it is trivial to underflow the page_counter->count and trigger OOM. Reported-and-tested-by: Brenden Blanco <bblanco@plumgrid.com> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Reviewed-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@kernel.org> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Alexei Starovoitov <alexei.starovoitov@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Vladimir Davydov <vdavydov@virtuozzo.com> Fixes: 00501b531c47 ("mm: memcontrol: rewrite charge API") Link: http://lkml.kernel.org/r/20160817153629.GB29724@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-15timekeeping: Avoid taking lock in NMI path with CONFIG_DEBUG_TIMEKEEPINGJohn Stultz
commit 27727df240c7cc84f2ba6047c6f18d5addfd25ef upstream. When I added some extra sanity checking in timekeeping_get_ns() under CONFIG_DEBUG_TIMEKEEPING, I missed that the NMI safe __ktime_get_fast_ns() method was using timekeeping_get_ns(). Thus the locking added to the debug checks broke the NMI-safety of __ktime_get_fast_ns(). This patch open-codes the timekeeping_get_ns() logic for __ktime_get_fast_ns(), so can avoid any deadlocks in NMI. Fixes: 4ca22c2648f9 "timekeeping: Add warnings when overflows or underflows are observed" Reported-by: Steven Rostedt <rostedt@goodmis.org> Reported-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: John Stultz <john.stultz@linaro.org> Link: http://lkml.kernel.org/r/1471993702-29148-2-git-send-email-john.stultz@linaro.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-15timekeeping: Cap array access in timekeeping_debugJohn Stultz
commit a4f8f6667f099036c88f231dcad4cf233652c824 upstream. It was reported that hibernation could fail on the 2nd attempt, where the system hangs at hibernate() -> syscore_resume() -> i8237A_resume() -> claim_dma_lock(), because the lock has already been taken. However there is actually no other process would like to grab this lock on that problematic platform. Further investigation showed that the problem is triggered by setting /sys/power/pm_trace to 1 before the 1st hibernation. Since once pm_trace is enabled, the rtc becomes unmeaningful after suspend, and meanwhile some BIOSes would like to adjust the 'invalid' RTC (e.g, smaller than 1970) to the release date of that motherboard during POST stage, thus after resumed, it may seem that the system had a significant long sleep time which is a completely meaningless value. Then in timekeeping_resume -> tk_debug_account_sleep_time, if the bit31 of the sleep time happened to be set to 1, fls() returns 32 and we add 1 to sleep_time_bin[32], which causes an out of bounds array access and therefor memory being overwritten. As depicted by System.map: 0xffffffff81c9d080 b sleep_time_bin 0xffffffff81c9d100 B dma_spin_lock the dma_spin_lock.val is set to 1, which caused this problem. This patch adds a sanity check in tk_debug_account_sleep_time() to ensure we don't index past the sleep_time_bin array. [jstultz: Problem diagnosed and original patch by Chen Yu, I've solved the issue slightly differently, but borrowed his excelent explanation of the issue here.] Fixes: 5c83545f24ab "power: Add option to log time spent in suspend" Reported-by: Janek Kozicki <cosurgi@gmail.com> Reported-by: Chen Yu <yu.c.chen@intel.com> Signed-off-by: John Stultz <john.stultz@linaro.org> Cc: linux-pm@vger.kernel.org Cc: Peter Zijlstra <peterz@infradead.org> Cc: Xunlei Pang <xpang@redhat.com> Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net> Cc: Zhang Rui <rui.zhang@intel.com> Link: http://lkml.kernel.org/r/1471993702-29148-3-git-send-email-john.stultz@linaro.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-15cgroup: reduce read locked section of cgroup_threadgroup_rwsem during forkBalbir Singh
commit 568ac888215c7fb2fabe8ea739b00ec3c1f5d440 upstream. cgroup_threadgroup_rwsem is acquired in read mode during process exit and fork. It is also grabbed in write mode during __cgroups_proc_write(). I've recently run into a scenario with lots of memory pressure and OOM and I am beginning to see systemd __switch_to+0x1f8/0x350 __schedule+0x30c/0x990 schedule+0x48/0xc0 percpu_down_write+0x114/0x170 __cgroup_procs_write.isra.12+0xb8/0x3c0 cgroup_file_write+0x74/0x1a0 kernfs_fop_write+0x188/0x200 __vfs_write+0x6c/0xe0 vfs_write+0xc0/0x230 SyS_write+0x6c/0x110 system_call+0x38/0xb4 This thread is waiting on the reader of cgroup_threadgroup_rwsem to exit. The reader itself is under memory pressure and has gone into reclaim after fork. There are times the reader also ends up waiting on oom_lock as well. __switch_to+0x1f8/0x350 __schedule+0x30c/0x990 schedule+0x48/0xc0 jbd2_log_wait_commit+0xd4/0x180 ext4_evict_inode+0x88/0x5c0 evict+0xf8/0x2a0 dispose_list+0x50/0x80 prune_icache_sb+0x6c/0x90 super_cache_scan+0x190/0x210 shrink_slab.part.15+0x22c/0x4c0 shrink_zone+0x288/0x3c0 do_try_to_free_pages+0x1dc/0x590 try_to_free_pages+0xdc/0x260 __alloc_pages_nodemask+0x72c/0xc90 alloc_pages_current+0xb4/0x1a0 page_table_alloc+0xc0/0x170 __pte_alloc+0x58/0x1f0 copy_page_range+0x4ec/0x950 copy_process.isra.5+0x15a0/0x1870 _do_fork+0xa8/0x4b0 ppc_clone+0x8/0xc In the meanwhile, all processes exiting/forking are blocked almost stalling the system. This patch moves the threadgroup_change_begin from before cgroup_fork() to just before cgroup_canfork(). There is no nee to worry about threadgroup changes till the task is actually added to the threadgroup. This avoids having to call reclaim with cgroup_threadgroup_rwsem held. tj: Subject and description edits. Signed-off-by: Balbir Singh <bsingharora@gmail.com> Acked-by: Zefan Li <lizefan@huawei.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-15kernel: Add noaudit variant of ns_capable()Tyler Hicks
commit 98f368e9e2630a3ce3e80fb10fb2e02038cf9578 upstream. When checking the current cred for a capability in a specific user namespace, it isn't always desirable to have the LSMs audit the check. This patch adds a noaudit variant of ns_capable() for when those situations arise. The common logic between ns_capable() and the new ns_capable_noaudit() is moved into a single, shared function to keep duplicated code to a minimum and ease maintainability. Signed-off-by: Tyler Hicks <tyhicks@canonical.com> Acked-by: Serge E. Hallyn <serge.hallyn@ubuntu.com> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-15cred: Reject inodes with invalid ids in set_create_file_as()Seth Forshee
[ Upstream commit 5f65e5ca286126a60f62c8421b77c2018a482b8a ] Using INVALID_[UG]ID for the LSM file creation context doesn't make sense, so return an error if the inode passed to set_create_file_as() has an invalid id. Signed-off-by: Seth Forshee <seth.forshee@canonical.com> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-15clocksource: Allow unregistering the watchdogVitaly Kuznetsov
[ Upstream commit bbf66d897adf2bb0c310db96c97e8db6369f39e1 ] Hyper-V vmbus module registers TSC page clocksource when loaded. This is the clocksource with the highest rating and thus it becomes the watchdog making unloading of the vmbus module impossible. Separate clocksource_select_watchdog() from clocksource_enqueue_watchdog() and use it on clocksource register/rating change/unregister. After all, lobotomized monkeys may need some love too. Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com> Cc: John Stultz <john.stultz@linaro.org> Cc: Dexuan Cui <decui@microsoft.com> Cc: K. Y. Srinivasan <kys@microsoft.com> Link: http://lkml.kernel.org/r/1453483913-25672-1-git-send-email-vkuznets@redhat.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-15ntp: Fix ADJ_SETOFFSET being used w/ ADJ_NANOJohn Stultz
[ Upstream commit dd4e17ab704269bce71402285f5e8b9ac24b1eff ] Recently, in commit 37cf4dc3370f I forgot to check if the timeval being passed was actually a timespec (as is signaled with ADJ_NANO). This resulted in that patch breaking ADJ_SETOFFSET users who set ADJ_NANO, by rejecting valid timespecs that were compared with valid timeval ranges. This patch addresses this by checking for the ADJ_NANO flag and using the timepsec check instead in that case. Reported-by: Harald Hoyer <harald@redhat.com> Reported-by: Kay Sievers <kay@vrfy.org> Fixes: 37cf4dc3370f "time: Verify time values in adjtimex ADJ_SETOFFSET to avoid overflow" Signed-off-by: John Stultz <john.stultz@linaro.org> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Richard Cochran <richardcochran@gmail.com> Cc: Prarit Bhargava <prarit@redhat.com> Cc: David Herrmann <dh.herrmann@gmail.com> Link: http://lkml.kernel.org/r/1453417415-19110-2-git-send-email-john.stultz@linaro.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-15time: Verify time values in adjtimex ADJ_SETOFFSET to avoid overflowJohn Stultz
[ Upstream commit 37cf4dc3370fbca0344e23bb96446eb2c3548ba7 ] For adjtimex()'s ADJ_SETOFFSET, make sure the tv_usec value is sane. We might multiply them later which can cause an overflow and undefined behavior. This patch introduces new helper functions to simplify the checking code and adds comments to clarify Orginally this patch was by Sasha Levin, but I've basically rewritten it, so he should get credit for finding the issue and I should get the blame for any mistakes made since. Also, credit to Richard Cochran for the phrasing used in the comment for what is considered valid here. Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Richard Cochran <richardcochran@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Reported-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: John Stultz <john.stultz@linaro.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-15sched/numa: Fix use-after-free bug in the task_numa_compareGavin Guo
[ Upstream commit 1dff76b92f69051e579bdc131e01500da9fa2a91 ] The following message can be observed on the Ubuntu v3.13.0-65 with KASan backported: ================================================================== BUG: KASan: use after free in task_numa_find_cpu+0x64c/0x890 at addr ffff880dd393ecd8 Read of size 8 by task qemu-system-x86/3998900 ============================================================================= BUG kmalloc-128 (Tainted: G B ): kasan: bad access detected ----------------------------------------------------------------------------- INFO: Allocated in task_numa_fault+0xc1b/0xed0 age=41980 cpu=18 pid=3998890 __slab_alloc+0x4f8/0x560 __kmalloc+0x1eb/0x280 task_numa_fault+0xc1b/0xed0 do_numa_page+0x192/0x200 handle_mm_fault+0x808/0x1160 __do_page_fault+0x218/0x750 do_page_fault+0x1a/0x70 page_fault+0x28/0x30 SyS_poll+0x66/0x1a0 system_call_fastpath+0x1a/0x1f INFO: Freed in task_numa_free+0x1d2/0x200 age=62 cpu=18 pid=0 __slab_free+0x2ab/0x3f0 kfree+0x161/0x170 task_numa_free+0x1d2/0x200 finish_task_switch+0x1d2/0x210 __schedule+0x5d4/0xc60 schedule_preempt_disabled+0x40/0xc0 cpu_startup_entry+0x2da/0x340 start_secondary+0x28f/0x360 Call Trace: [<ffffffff81a6ce35>] dump_stack+0x45/0x56 [<ffffffff81244aed>] print_trailer+0xfd/0x170 [<ffffffff8124ac36>] object_err+0x36/0x40 [<ffffffff8124cbf9>] kasan_report_error+0x1e9/0x3a0 [<ffffffff8124d260>] kasan_report+0x40/0x50 [<ffffffff810dda7c>] ? task_numa_find_cpu+0x64c/0x890 [<ffffffff8124bee9>] __asan_load8+0x69/0xa0 [<ffffffff814f5c38>] ? find_next_bit+0xd8/0x120 [<ffffffff810dda7c>] task_numa_find_cpu+0x64c/0x890 [<ffffffff810de16c>] task_numa_migrate+0x4ac/0x7b0 [<ffffffff810de523>] numa_migrate_preferred+0xb3/0xc0 [<ffffffff810e0b88>] task_numa_fault+0xb88/0xed0 [<ffffffff8120ef02>] do_numa_page+0x192/0x200 [<ffffffff81211038>] handle_mm_fault+0x808/0x1160 [<ffffffff810d7dbd>] ? sched_clock_cpu+0x10d/0x160 [<ffffffff81068c52>] ? native_load_tls+0x82/0xa0 [<ffffffff81a7bd68>] __do_page_fault+0x218/0x750 [<ffffffff810c2186>] ? hrtimer_try_to_cancel+0x76/0x160 [<ffffffff81a6f5e7>] ? schedule_hrtimeout_range_clock.part.24+0xf7/0x1c0 [<ffffffff81a7c2ba>] do_page_fault+0x1a/0x70 [<ffffffff81a772e8>] page_fault+0x28/0x30 [<ffffffff8128cbd4>] ? do_sys_poll+0x1c4/0x6d0 [<ffffffff810e64f6>] ? enqueue_task_fair+0x4b6/0xaa0 [<ffffffff810233c9>] ? sched_clock+0x9/0x10 [<ffffffff810cf70a>] ? resched_task+0x7a/0xc0 [<ffffffff810d0663>] ? check_preempt_curr+0xb3/0x130 [<ffffffff8128b5c0>] ? poll_select_copy_remaining+0x170/0x170 [<ffffffff810d3bc0>] ? wake_up_state+0x10/0x20 [<ffffffff8112a28f>] ? drop_futex_key_refs.isra.14+0x1f/0x90 [<ffffffff8112d40e>] ? futex_requeue+0x3de/0xba0 [<ffffffff8112e49e>] ? do_futex+0xbe/0x8f0 [<ffffffff81022c89>] ? read_tsc+0x9/0x20 [<ffffffff8111bd9d>] ? ktime_get_ts+0x12d/0x170 [<ffffffff8108f699>] ? timespec_add_safe+0x59/0xe0 [<ffffffff8128d1f6>] SyS_poll+0x66/0x1a0 [<ffffffff81a830dd>] system_call_fastpath+0x1a/0x1f As commit 1effd9f19324 ("sched/numa: Fix unsafe get_task_struct() in task_numa_assign()") points out, the rcu_read_lock() cannot protect the task_struct from being freed in the finish_task_switch(). And the bug happens in the process of calculation of imp which requires the access of p->numa_faults being freed in the following path: do_exit() current->flags |= PF_EXITING; release_task() ~~delayed_put_task_struct()~~ schedule() ... ... rq->curr = next; context_switch() finish_task_switch() put_task_struct() __put_task_struct() task_numa_free() The fix here to get_task_struct() early before end of dst_rq->lock to protect the calculation process and also put_task_struct() in the corresponding point if finally the dst_rq->curr somehow cannot be assigned. Additional credit to Liang Chen who helped fix the error logic and add the put_task_struct() to the place it missed. Signed-off-by: Gavin Guo <gavin.guo@canonical.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Hugh Dickins <hughd@google.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: jay.vosburgh@canonical.com Cc: liang.chen@canonical.com Link: http://lkml.kernel.org/r/1453264618-17645-1-git-send-email-gavin.guo@canonical.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-15hrtimer: Catch illegal clockidsMarc Zyngier
[ Upstream commit 9006a01829a50cfd6bbd4980910ed46e895e93d7 ] It is way too easy to take any random clockid and feed it to the hrtimer subsystem. At best, it gets mapped to a monotonic base, but it would be better to just catch illegal values as early as possible. This patch does exactly that, mapping illegal clockids to an illegal base index, and panicing when we detect the illegal condition. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Cc: Tomasz Nowicki <tn@semihalf.com> Cc: Christoffer Dall <christoffer.dall@linaro.org> Link: http://lkml.kernel.org/r/1452879670-16133-3-git-send-email-marc.zyngier@arm.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-07sched/nohz: Fix affine unpinned timers messWanpeng Li
commit 444969223c81c7d0a95136b7b4cfdcfbc96ac5bd upstream. The following commit: 9642d18eee2c ("nohz: Affine unpinned timers to housekeepers")' intended to affine unpinned timers to housekeepers: unpinned timers(full dynaticks, idle) => nearest busy housekeepers(otherwise, fallback to any housekeepers) unpinned timers(full dynaticks, busy) => nearest busy housekeepers(otherwise, fallback to any housekeepers) unpinned timers(houserkeepers, idle) => nearest busy housekeepers(otherwise, fallback to itself) However, the !idle_cpu(i) && is_housekeeping_cpu(cpu) check modified the intention to: unpinned timers(full dynaticks, idle) => any housekeepers(no mattter cpu topology) unpinned timers(full dynaticks, busy) => any housekeepers(no mattter cpu topology) unpinned timers(housekeepers, idle) => any busy cpus(otherwise, fallback to any housekeepers) This patch fixes it by checking if there are busy housekeepers nearby, otherwise falls to any housekeepers/itself. After the patch: unpinned timers(full dynaticks, idle) => nearest busy housekeepers(otherwise, fallback to any housekeepers) unpinned timers(full dynaticks, busy) => nearest busy housekeepers(otherwise, fallback to any housekeepers) unpinned timers(housekeepers, idle) => nearest busy housekeepers(otherwise, fallback to itself) Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> [ Fixed the changelog. ] Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Fixes: 'commit 9642d18eee2c ("nohz: Affine unpinned timers to housekeepers")' Link: http://lkml.kernel.org/r/1462344334-8303-1-git-send-email-wanpeng.li@hotmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-07sched/cputime: Fix NO_HZ_FULL getrusage() monotonicity regressionPeter Zijlstra
commit 173be9a14f7b2e901cf77c18b1aafd4d672e9d9e upstream. Mike reports: Roughly 10% of the time, ltp testcase getrusage04 fails: getrusage04 0 TINFO : Expected timers granularity is 4000 us getrusage04 0 TINFO : Using 1 as multiply factor for max [us]time increment (1000+4000us)! getrusage04 0 TINFO : utime: 0us; stime: 179us getrusage04 0 TINFO : utime: 3751us; stime: 0us getrusage04 1 TFAIL : getrusage04.c:133: stime increased > 5000us: And tracked it down to the case where the task simply doesn't get _any_ [us]time ticks. Update the code to assume all rtime is utime when we lack information, thus ensuring a task that elides the tick gets time accounted. Reported-by: Mike Galbraith <umgwanakikbuti@gmail.com> Tested-by: Mike Galbraith <umgwanakikbuti@gmail.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Fredrik Markstrom <fredrik.markstrom@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Radim <rkrcmar@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Stephane Eranian <eranian@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Vince Weaver <vincent.weaver@maine.edu> Cc: Wanpeng Li <wanpeng.li@hotmail.com> Fixes: 9d7fb0427648 ("sched/cputime: Guarantee stime + utime == rtime") Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-07genirq/msi: Make sure PCI MSIs are activated earlyMarc Zyngier
commit f3b0946d629c8bfbd3e5f038e30cb9c711a35f10 upstream. Bharat Kumar Gogada reported issues with the generic MSI code, where the end-point ended up with garbage in its MSI configuration (both for the vector and the message). It turns out that the two MSI paths in the kernel are doing slightly different things: generic MSI: disable MSI -> allocate MSI -> enable MSI -> setup EP PCI MSI: disable MSI -> allocate MSI -> setup EP -> enable MSI And it turns out that end-points are allowed to latch the content of the MSI configuration registers as soon as MSIs are enabled. In Bharat's case, the end-point ends up using whatever was there already, which is not what you want. In order to make things converge, we introduce a new MSI domain flag (MSI_FLAG_ACTIVATE_EARLY) that is unconditionally set for PCI/MSI. When set, this flag forces the programming of the end-point as soon as the MSIs are allocated. A consequence of this is that we have an extra activate in irq_startup, but that should be without much consequence. tglx: - Several people reported a VMWare regression with PCI/MSI-X passthrough. It turns out that the patch also cures that issue. - We need to have a look at the MSI disable interrupt path, where we write the msg to all zeros without disabling MSI in the PCI device. Is that correct? Fixes: 52f518a3a7c2 "x86/MSI: Use hierarchical irqdomains to manage MSI interrupts" Reported-and-tested-by: Bharat Kumar Gogada <bharat.kumar.gogada@xilinx.com> Reported-and-tested-by: Foster Snowhill <forst@forstwoof.ru> Reported-by: Matthias Prager <linux@matthiasprager.de> Reported-by: Jason Taylor <jason.taylor@simplivity.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Acked-by: Bjorn Helgaas <bhelgaas@google.com> Cc: linux-pci@vger.kernel.org Link: http://lkml.kernel.org/r/1468426713-31431-1-git-send-email-marc.zyngier@arm.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-07genirq/msi: Remove unused MSI_FLAG_IDENTITY_MAPThomas Gleixner
commit b6140914fd079e43ea75a53429b47128584f033a upstream. No user and we definitely don't want to grow one. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com> Cc: Christoph Hellwig <hch@lst.de> Cc: linux-block@vger.kernel.org Cc: linux-pci@vger.kernel.org Cc: linux-nvme@lists.infradead.org Cc: axboe@fb.com Cc: agordeev@redhat.com Link: http://lkml.kernel.org/r/1467621574-8277-2-git-send-email-hch@lst.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-20module: Invalidate signatures on force-loaded modulesBen Hutchings
commit bca014caaa6130e57f69b5bf527967aa8ee70fdd upstream. Signing a module should only make it trusted by the specific kernel it was built for, not anything else. Loading a signed module meant for a kernel with a different ABI could have interesting effects. Therefore, treat all signatures as invalid when a module is force-loaded. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-20audit: fix a double fetch in audit_log_single_execve_arg()Paul Moore
commit 43761473c254b45883a64441dd0bc85a42f3645c upstream. There is a double fetch problem in audit_log_single_execve_arg() where we first check the execve(2) argumnets for any "bad" characters which would require hex encoding and then re-fetch the arguments for logging in the audit record[1]. Of course this leaves a window of opportunity for an unsavory application to munge with the data. This patch reworks things by only fetching the argument data once[2] into a buffer where it is scanned and logged into the audit records(s). In addition to fixing the double fetch, this patch improves on the original code in a few other ways: better handling of large arguments which require encoding, stricter record length checking, and some performance improvements (completely unverified, but we got rid of some strlen() calls, that's got to be a good thing). As part of the development of this patch, I've also created a basic regression test for the audit-testsuite, the test can be tracked on GitHub at the following link: * https://github.com/linux-audit/audit-testsuite/issues/25 [1] If you pay careful attention, there is actually a triple fetch problem due to a strnlen_user() call at the top of the function. [2] This is a tiny white lie, we do make a call to strnlen_user() prior to fetching the argument data. I don't like it, but due to the way the audit record is structured we really have no choice unless we copy the entire argument at once (which would require a rather wasteful allocation). The good news is that with this patch the kernel no longer relies on this strnlen_user() value for anything beyond recording it in the log, we also update it with a trustworthy value whenever possible. Reported-by: Pengfei Wang <wpengfeinudt@gmail.com> Signed-off-by: Paul Moore <paul@paul-moore.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-10posix_cpu_timer: Exit early when process has been reapedAlexey Dobriyan
commit 2c13ce8f6b2f6fd9ba2f9261b1939fc0f62d1307 upstream. Variable "now" seems to be genuinely used unintialized if branch if (CPUCLOCK_PERTHREAD(timer->it_clock)) { is not taken and branch if (unlikely(sighand == NULL)) { is taken. In this case the process has been reaped and the timer is marked as disarmed anyway. So none of the postprocessing of the sample is required. Return right away. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Link: http://lkml.kernel.org/r/20160707223911.GA26483@p183.telecom.by Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-10sched/fair: Fix effective_load() to consistently use smoothed loadPeter Zijlstra
commit 7dd4912594daf769a46744848b05bd5bc6d62469 upstream. Starting with the following commit: fde7d22e01aa ("sched/fair: Fix overly small weight for interactive group entities") calc_tg_weight() doesn't compute the right value as expected by effective_load(). The difference is in the 'correction' term. In order to ensure \Sum rw_j >= rw_i we cannot use tg->load_avg directly, since that might be lagging a correction on the current cfs_rq->avg.load_avg value. Therefore we use tg->load_avg - cfs_rq->tg_load_avg_contrib + cfs_rq->avg.load_avg. Now, per the referenced commit, calc_tg_weight() doesn't use cfs_rq->avg.load_avg, as is later used in @w, but uses cfs_rq->load.weight instead. So stop using calc_tg_weight() and do it explicitly. The effects of this bug are wake_affine() making randomly poor choices in cgroup-intense workloads. Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Fixes: fde7d22e01aa ("sched/fair: Fix overly small weight for interactive group entities") Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-10cgroup: set css->id to -1 during initTejun Heo
commit 8fa3b8d689a54d6d04ff7803c724fb7aca6ce98e upstream. If percpu_ref initialization fails during css_create(), the free path can end up trying to free css->id of zero. As ID 0 is unused, it doesn't cause a critical breakage but it does trigger a warning message. Fix it by setting css->id to -1 from init_and_link_css(). Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Wenwei Tao <ww.tao0320@gmail.com> Fixes: 01e586598b22 ("cgroup: release css->id after css_free") Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-10kernel/sysrq, watchdog, sched/core: Reset watchdog on all CPUs while ↵Andrey Ryabinin
processing sysrq-w commit 57675cb976eff977aefb428e68e4e0236d48a9ff upstream. Lengthy output of sysrq-w may take a lot of time on slow serial console. Currently we reset NMI-watchdog on the current CPU to avoid spurious lockup messages. Sometimes this doesn't work since softlockup watchdog might trigger on another CPU which is waiting for an IPI to proceed. We reset softlockup watchdogs on all CPUs, but we do this only after listing all tasks, and this may be too late on a busy system. So, reset watchdogs CPUs earlier, in for_each_process_thread() loop. Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1465474805-14641-1-git-send-email-aryabinin@virtuozzo.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-07-27tracing: Handle NULL formats in hold_module_trace_bprintk_format()Steven Rostedt (Red Hat)
commit 70c8217acd4383e069fe1898bbad36ea4fcdbdcc upstream. If a task uses a non constant string for the format parameter in trace_printk(), then the trace_printk_fmt variable is set to NULL. This variable is then saved in the __trace_printk_fmt section. The function hold_module_trace_bprintk_format() checks to see if duplicate formats are used by modules, and reuses them if so (saves them to the list if it is new). But this function calls lookup_format() that does a strcmp() to the value (which is now NULL) and can cause a kernel oops. This wasn't an issue till 3debb0a9ddb ("tracing: Fix trace_printk() to print when not using bprintk()") which added "__used" to the trace_printk_fmt variable, and before that, the kernel simply optimized it out (no NULL value was saved). The fix is simply to handle the NULL pointer in lookup_format() and have the caller ignore the value if it was NULL. Link: http://lkml.kernel.org/r/1464769870-18344-1-git-send-email-zhengjun.xing@intel.com Reported-by: xingzhen <zhengjun.xing@intel.com> Acked-by: Namhyung Kim <namhyung@kernel.org> Fixes: 3debb0a9ddb ("tracing: Fix trace_printk() to print when not using bprintk()") Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-07-27sched/fair: Fix cfs_rq avg tracking underflowPeter Zijlstra
commit 8974189222159154c55f24ddad33e3613960521a upstream. As per commit: b7fa30c9cc48 ("sched/fair: Fix post_init_entity_util_avg() serialization") > the code generated from update_cfs_rq_load_avg(): > > if (atomic_long_read(&cfs_rq->removed_load_avg)) { > s64 r = atomic_long_xchg(&cfs_rq->removed_load_avg, 0); > sa->load_avg = max_t(long, sa->load_avg - r, 0); > sa->load_sum = max_t(s64, sa->load_sum - r * LOAD_AVG_MAX, 0); > removed_load = 1; > } > > turns into: > > ffffffff81087064: 49 8b 85 98 00 00 00 mov 0x98(%r13),%rax > ffffffff8108706b: 48 85 c0 test %rax,%rax > ffffffff8108706e: 74 40 je ffffffff810870b0 <update_blocked_averages+0xc0> > ffffffff81087070: 4c 89 f8 mov %r15,%rax > ffffffff81087073: 49 87 85 98 00 00 00 xchg %rax,0x98(%r13) > ffffffff8108707a: 49 29 45 70 sub %rax,0x70(%r13) > ffffffff8108707e: 4c 89 f9 mov %r15,%rcx > ffffffff81087081: bb 01 00 00 00 mov $0x1,%ebx > ffffffff81087086: 49 83 7d 70 00 cmpq $0x0,0x70(%r13) > ffffffff8108708b: 49 0f 49 4d 70 cmovns 0x70(%r13),%rcx > > Which you'll note ends up with sa->load_avg -= r in memory at > ffffffff8108707a. So I _should_ have looked at other unserialized users of ->load_avg, but alas. Luckily nikbor reported a similar /0 from task_h_load() which instantly triggered recollection of this here problem. Aside from the intermediate value hitting memory and causing problems, there's another problem: the underflow detection relies on the signed bit. This reduces the effective width of the variables, IOW its effectively the same as having these variables be of signed type. This patch changes to a different means of unsigned underflow detection to not rely on the signed bit. This allows the variables to use the 'full' unsigned range. And it does so with explicit LOAD - STORE to ensure any intermediate value will never be visible in memory, allowing these unserialized loads. Note: GCC generates crap code for this, might warrant a look later. Note2: I say 'full' above, if we end up at U*_MAX we'll still explode; maybe we should do clamping on add too. Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Chris Wilson <chris@chris-wilson.co.uk> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Yuyang Du <yuyang.du@intel.com> Cc: bsegall@google.com Cc: kernel@kyup.com Cc: morten.rasmussen@arm.com Cc: pjt@google.com Cc: steve.muckle@linaro.org Fixes: 9d89c257dfb9 ("sched/fair: Rewrite runnable load and utilization average tracking") Link: http://lkml.kernel.org/r/20160617091948.GJ30927@twins.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-07-27locking/static_key: Fix concurrent static_key_slow_inc()Paolo Bonzini
commit 4c5ea0a9cd02d6aa8adc86e100b2a4cff8d614ff upstream. The following scenario is possible: CPU 1 CPU 2 static_key_slow_inc() atomic_inc_not_zero() -> key.enabled == 0, no increment jump_label_lock() atomic_inc_return() -> key.enabled == 1 now static_key_slow_inc() atomic_inc_not_zero() -> key.enabled == 1, inc to 2 return ** static key is wrong! jump_label_update() jump_label_unlock() Testing the static key at the point marked by (**) will follow the wrong path for jumps that have not been patched yet. This can actually happen when creating many KVM virtual machines with userspace LAPIC emulation; just run several copies of the following program: #include <fcntl.h> #include <unistd.h> #include <sys/ioctl.h> #include <linux/kvm.h> int main(void) { for (;;) { int kvmfd = open("/dev/kvm", O_RDONLY); int vmfd = ioctl(kvmfd, KVM_CREATE_VM, 0); close(ioctl(vmfd, KVM_CREATE_VCPU, 1)); close(vmfd); close(kvmfd); } return 0; } Every KVM_CREATE_VCPU ioctl will attempt a static_key_slow_inc() call. The static key's purpose is to skip NULL pointer checks and indeed one of the processes eventually dereferences NULL. As explained in the commit that introduced the bug: 706249c222f6 ("locking/static_keys: Rework update logic") jump_label_update() needs key.enabled to be true. The solution adopted here is to temporarily make key.enabled == -1, and use go down the slow path when key.enabled <= 0. Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Fixes: 706249c222f6 ("locking/static_keys: Rework update logic") Link: http://lkml.kernel.org/r/1466527937-69798-1-git-send-email-pbonzini@redhat.com [ Small stylistic edits to the changelog and the code. ] Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-07-27locking/qspinlock: Fix spin_unlock_wait() some morePeter Zijlstra
commit 2c610022711675ee908b903d242f0b90e1db661f upstream. While this prior commit: 54cf809b9512 ("locking,qspinlock: Fix spin_is_locked() and spin_unlock_wait()") ... fixes spin_is_locked() and spin_unlock_wait() for the usage in ipc/sem and netfilter, it does not in fact work right for the usage in task_work and futex. So while the 2 locks crossed problem: spin_lock(A) spin_lock(B) if (!spin_is_locked(B)) spin_unlock_wait(A) foo() foo(); ... works with the smp_mb() injected by both spin_is_locked() and spin_unlock_wait(), this is not sufficient for: flag = 1; smp_mb(); spin_lock() spin_unlock_wait() if (!flag) // add to lockless list // iterate lockless list ... because in this scenario, the store from spin_lock() can be delayed past the load of flag, uncrossing the variables and loosing the guarantee. This patch reworks spin_is_locked() and spin_unlock_wait() to work in both cases by exploiting the observation that while the lock byte store can be delayed, the contender must have registered itself visibly in other state contained in the word. It also allows for architectures to override both functions, as PPC and ARM64 have an additional issue for which we currently have no generic solution. Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Boqun Feng <boqun.feng@gmail.com> Cc: Davidlohr Bueso <dave@stgolabs.net> Cc: Giovanni Gherdovich <ggherdovich@suse.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Pan Xinhui <xinhui.pan@linux.vnet.ibm.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Waiman Long <waiman.long@hpe.com> Cc: Will Deacon <will.deacon@arm.com> Fixes: 54cf809b9512 ("locking,qspinlock: Fix spin_is_locked() and spin_unlock_wait()") Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-07-27locking/ww_mutex: Report recursive ww_mutex locking earlyChris Wilson
commit 0422e83d84ae24b933e4b0d4c1e0f0b4ae8a0a3b upstream. Recursive locking for ww_mutexes was originally conceived as an exception. However, it is heavily used by the DRM atomic modesetting code. Currently, the recursive deadlock is checked after we have queued up for a busy-spin and as we never release the lock, we spin until kicked, whereupon the deadlock is discovered and reported. A simple solution for the now common problem is to move the recursive deadlock discovery to the first action when taking the ww_mutex. Suggested-by: Maarten Lankhorst <maarten.lankhorst@linux.intel.com> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Reviewed-by: Maarten Lankhorst <maarten.lankhorst@linux.intel.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1464293297-19777-1-git-send-email-chris@chris-wilson.co.uk Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-07-11bpf, perf: delay release of BPF prog after grace periodDaniel Borkmann
[ Upstream commit ceb56070359b7329b5678b5d95a376fcb24767be ] Commit dead9f29ddcc ("perf: Fix race in BPF program unregister") moved destruction of BPF program from free_event_rcu() callback to __free_event(), which is problematic if used with tail calls: if prog A is attached as trace event directly, but at the same time present in a tail call map used by another trace event program elsewhere, then we need to delay destruction via RCU grace period since it can still be in use by the program doing the tail call (the prog first needs to be dropped from the tail call map, then trace event with prog A attached destroyed, so we get immediate destruction). Fixes: dead9f29ddcc ("perf: Fix race in BPF program unregister") Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Alexei Starovoitov <ast@kernel.org> Cc: Jann Horn <jann@thejh.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-06-24sched: panic on corrupted stack endJann Horn
commit 29d6455178a09e1dc340380c582b13356227e8df upstream. Until now, hitting this BUG_ON caused a recursive oops (because oops handling involves do_exit(), which calls into the scheduler, which in turn raises an oops), which caused stuff below the stack to be overwritten until a panic happened (e.g. via an oops in interrupt context, caused by the overwritten CPU index in the thread_info). Just panic directly. Signed-off-by: Jann Horn <jannh@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-06-24bpf, inode: disallow userns mountsDaniel Borkmann
[ Upstream commit 612bacad78ba6d0a91166fc4487af114bac172a8 ] Follow-up to commit e27f4a942a0e ("bpf: Use mount_nodev not mount_ns to mount the bpf filesystem"), which removes the FS_USERNS_MOUNT flag. The original idea was to have a per mountns instance instead of a single global fs instance, but that didn't work out and we had to switch to mount_nodev() model. The intent of that middle ground was that we avoid users who don't play nice to create endless instances of bpf fs which are difficult to control and discover from an admin point of view, but at the same time it would have allowed us to be more flexible with regard to namespaces. Therefore, since we now did the switch to mount_nodev() as a fix where individual instances are created, we also need to remove userns mount flag along with it to avoid running into mentioned situation. I don't expect any breakage at this early point in time with removing the flag and we can revisit this later should the requirement for this come up with future users. This and commit e27f4a942a0e have been split to facilitate tracking should any of them run into the unlikely case of causing a regression. Fixes: b2197755b263 ("bpf: add support for persistent maps/progs") Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-06-24bpf: Use mount_nodev not mount_ns to mount the bpf filesystemEric W. Biederman
[ Upstream commit e27f4a942a0ee4b84567a3c6cfa84f273e55cbb7 ] While reviewing the filesystems that set FS_USERNS_MOUNT I spotted the bpf filesystem. Looking at the code I saw a broken usage of mount_ns with current->nsproxy->mnt_ns. As the code does not acquire a reference to the mount namespace it can not possibly be correct to store the mount namespace on the superblock as it does. Replace mount_ns with mount_nodev so that each mount of the bpf filesystem returns a distinct instance, and the code is not buggy. In discussion with Hannes Frederic Sowa it was reported that the use of mount_ns was an attempt to have one bpf instance per mount namespace, in an attempt to keep resources that pin resources from hiding. That intent simply does not work, the vfs is not built to allow that kind of behavior. Which means that the bpf filesystem really is buggy both semantically and in it's implemenation as it does not nor can it implement the original intent. This change is userspace visible, but my experience with similar filesystems leads me to believe nothing will break with a model of each mount of the bpf filesystem is distinct from all others. Fixes: b2197755b263 ("bpf: add support for persistent maps/progs") Cc: Hannes Frederic Sowa <hannes@stressinduktion.org> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
