commit 6301cb95c119ebf324bb96ee226fa9ddffad80a7 upstream.
commit e3c8ca8336 (sched: do not count frozen tasks toward load) broke
the nr_uninterruptible accounting on freeze/thaw. On freeze the task
is excluded from accounting with a check for (task->flags &
PF_FROZEN), but that flag is cleared before the task is thawed. So
while we prevent that the task with state TASK_UNINTERRUPTIBLE
is accounted to nr_uninterruptible on freeze we decrement
nr_uninterruptible on thaw.
Use a separate flag which is handled by the freezing task itself. Set
it before calling the scheduler with TASK_UNINTERRUPTIBLE state and
clear it after we return from frozen state.
commit 04aef32d39cc4ef80087c0ce8ed113c6d64f1a6b upstream.
ftrace_trace_onoff_callback() will return an error even if we do the
right operation, for example:
# echo _spin_*:traceon:10 > set_ftrace_filter
-bash: echo: write error: Invalid argument
# cat set_ftrace_filter
#### all functions enabled ####
_spin_trylock_bh:traceon:count=10
_spin_unlock_irq:traceon:count=10
_spin_unlock_bh:traceon:count=10
_spin_lock_irq:traceon:count=10
_spin_unlock:traceon:count=10
_spin_trylock:traceon:count=10
_spin_unlock_irqrestore:traceon:count=10
_spin_lock_irqsave:traceon:count=10
_spin_lock_bh:traceon:count=10
_spin_lock:traceon:count=10
We want to set _spin_*:traceon:10 to set_ftrace_filter, it complains
with "Invalid argument", but the operation is successful.
This is because ftrace_process_regex() returns the number of functions that
matched the pattern. If the number is not 0, this value is returned
by ftrace_regex_write() whereas we want to return the number of bytes
virtually written.
Also the file offset pointer is not updated in this case.
If the number of matched functions is lower than the number of bytes written
by the user, this results to a reprocessing of the string given by the user with
a lower size, leading to a malformed ftrace regex and then a -EINVAL returned.
So, this patch fixes it by returning 0 if no error occured.
The fix also applies on 2.6.30
Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com>
Reviewed-by: Li Zefan <lizf@cn.fujitsu.com>
commit a1ba4d8ba9f06a397e97cbd67a93ee306860b40a upstream.
Fixes an easily triggerable BUG() when setting process affinities.
Make sure to count the number of migratable tasks in the same place:
the root rt_rq. Otherwise the number doesn't make sense and we'll hit
the BUG in set_cpus_allowed_rt().
Also, make sure we only count tasks, not groups (this is probably
already taken care of by the fact that rt_se->nr_cpus_allowed will be 0
for groups, but be more explicit)
Tested-by: Thomas Gleixner <tglx@linutronix.de>
Acked-by: Gregory Haskins <ghaskins@novell.com>
LKML-Reference: <1247067476.9777.57.camel@twins>
commit 8bc1ad7dd301b7ca7454013519fa92e8c53655ff upstream.
When the 32-bit signed quantities get assigned to the u64 resource_size_t,
they are incorrectly sign-extended.
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=13253
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=9905
Signed-off-by: Zhang Rui <rui.zhang@intel.com>
Reported-by: Leann Ogasawara <leann@ubuntu.com>
Cc: Pierre Ossman <drzeus@drzeus.cx>
Reported-by: <pablomme@googlemail.com>
Tested-by: <pablomme@googlemail.com>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
commit ce2ae53b750abfaa012ce408e93da131a5b5649b upstream.
get_futex_key() can infinitely loop if it is called on a
virtual address that is within a huge page but not aligned to
the beginning of that page. The call to get_user_pages_fast
will return the struct page for a sub-page within the huge page
and the check for page->mapping will always fail.
The fix is to call compound_head on the page before checking
that it's mapped.
Signed-off-by: Sonny Rao <sonnyrao@us.ibm.com>
Cc: anton@samba.org
Cc: rajamony@us.ibm.com
Cc: speight@us.ibm.com
Cc: mstephen@us.ibm.com
Cc: grimm@us.ibm.com
Cc: mikey@ozlabs.au.ibm.com
LKML-Reference: <20090710231313.GA23572@us.ibm.com>
commit d0725992c8a6fb63a16bc9e8b2a50094cc4db3cd and aa715284b4d28cabde6c25c568d769a6be712bc8 upstream
commit 64d1304a64 (futex: setup writeable mapping for futex ops which
modify user space data) did address only half of the problem of write
access faults.
The patch was made on two wrong assumptions:
1) access_ok(VERIFY_WRITE,...) would actually check write access.
On x86 it does _NOT_. It's a pure address range check.
2) a RW mapped region can not go away under us.
That's wrong as well. Nobody can prevent another thread to call
mprotect(PROT_READ) on that region where the futex resides. If that
call hits between the get_user_pages_fast() verification and the
actual write access in the atomic region we are toast again.
The solution is to not rely on access_ok and get_user() for any write
access related fault on private and shared futexes. Instead we need to
fault it in with verification of write access.
There is no generic non destructive write mechanism which would fault
the user page in trough a #PF, but as we already know that we will
fault we can as well call get_user_pages() directly and avoid the #PF
overhead.
If get_user_pages() returns -EFAULT we know that we can not fix it
anymore and need to bail out to user space.
Remove a bunch of confusing comments on this issue as well.
commit e0a94c2a63f2644826069044649669b5e7ca75d3 upstream.
This patch removes the dependency of mmap_min_addr on CONFIG_SECURITY.
It also sets a default mmap_min_addr of 4096.
mmapping of addresses below 4096 will only be possible for processes
with CAP_SYS_RAWIO.
Signed-off-by: Christoph Lameter <cl@linux-foundation.org>
Acked-by: Eric Paris <eparis@redhat.com>
Looks-ok-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: James Morris <jmorris@namei.org>
commit df279ca8966c3de83105428e3391ab17690802a9 upstream.
The file opened in acct_on and freshly stored in the ns->bacct struct can
be closed in acct_file_reopen by a concurrent call after we release
acct_lock and before we call mntput(file->f_path.mnt).
Record file->f_path.mnt in a local variable and use this variable only.
Signed-off-by: Renaud Lottiaux <renaud.lottiaux@kerlabs.com>
Signed-off-by: Louis Rilling <louis.rilling@kerlabs.com>
commit c85a17e22695969aa24a7ffa40cf26d6e6fcfd50 upstream.
Perfcounter reports the following stats for a wide system
profiling:
# (2364 samples)
# Overhead Symbol
15.40% [k] mwait_idle_with_hints
8.29% [k] read_hpet
5.75% [k] ftrace_caller
3.60% [k] ftrace_call
This snapshot has been taken while neither the function tracer nor
the function graph tracer was running.
With dynamic ftrace, such results show a wrong ftrace behaviour
because all calls to ftrace_caller or ftrace_graph_caller (the patched
calls to mcount) are supposed to be patched into nop if none of those
tracers are running.
The problem occurs after the first run of the function tracer. Once we
launch it a second time, the callsites will never be nopped back,
unless you set custom filters.
For example it happens during the self tests at boot time.
The function tracer selftest runs, and then the dynamic tracing is
tested too. After that, the callsites are left un-nopped.
This is because the reset callback of the function tracer tries to
unregister two ftrace callbacks in once: the common function tracer
and the function tracer with stack backtrace, regardless of which
one is currently in use.
It then creates an unbalance on ftrace_start_up value which is expected
to be zero when the last ftrace callback is unregistered. When it
reaches zero, the FTRACE_DISABLE_CALLS is set on the next ftrace
command, triggering the patching into nop. But since it becomes
unbalanced, ie becomes lower than zero, if the kernel functions
are patched again (as in every further function tracer runs), they
won't ever be nopped back.
Note that ftrace_call and ftrace_graph_call are still patched back
to ftrace_stub in the off case, but not the callers of ftrace_call
and ftrace_graph_caller. It means that the tracing is well deactivated
but we waste a useless call into every kernel function.
This patch just unregisters the right ftrace_ops for the function
tracer on its reset callback and ignores the other one which is
not registered, fixing the unbalance. The problem also happens
is .30
These are defined as static cpumask_var_t so if MAXSMP is not used,
they are cleared already. Avoid surprises when MAXSMP is enabled.
Signed-off-by: Yinghai Lu <yinghai.lu@kernel.org>
Our async work synchronization was broken by "async: make sure
independent async domains can't accidentally entangle" (commit
d5a877e8dd409d8c702986d06485c374b705d340), because it would report
the wrong lowest active async ID when there was both running and
pending async work.
This caused things like no being able to read the root filesystem,
resulting in missing console devices and inability to run 'init',
causing a boot-time panic.
This fixes it by properly returning the lowest pending async ID: if
there is any running async work, that will have a lower ID than any
pending work, and we should _not_ look at the pending work list.
There were alternative patches from Jaswinder and James, but this one
also cleans up the code by removing the pointless 'ret' variable and
the unnecesary testing for an empty list around 'for_each_entry()' (if
the list is empty, the for_each_entry() thing just won't execute).
Fixes-bug: http://bugzilla.kernel.org/show_bug.cgi?id=13474
Reported-and-tested-by: Chris Clayton <chris2553@googlemail.com>
Cc: Jaswinder Singh Rajput <jaswinder@kernel.org>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Commit 95a3540da9c81a5987be810e1d9a83640a366bd5 ("ptrace_detach: the wrong
wakeup breaks the ERESTARTxxx logic") removed the "extra"
wake_up_process() from ptrace_detach(), but as Jan pointed out this breaks
the compatibility.
I believe the changelog is right and this wake_up() is wrong in many
ways, but GDB assumes that ptrace(PTRACE_DETACH, child, 0, 0) always
wakes up the tracee.
Despite the fact this breaks SIGNAL_STOP_STOPPED/group_stop_count logic,
and despite the fact this wake_up_process() can break another
assumption: PTRACE_DETACH with SIGSTOP should leave the tracee in
TASK_STOPPED case. Because the untraced child can dequeue SIGSTOP and
call do_signal_stop() before ptrace_detach() calls wake_up_process().
Revert this change for now. We need some fixes even if we we want to keep
the current behaviour, but these fixes are not for 2.6.30.
Acked-by: Roland McGrath <roland@redhat.com>
Cc: Jan Kratochvil <jan.kratochvil@redhat.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
The "trace || CLONE_PTRACE" check in tracehook_report_clone() is not right,
- If the untraced task does clone(CLONE_PTRACE) the new child is not traced,
we must not queue SIGSTOP.
- If we forked the traced task, but the tracer exits and untraces both the
forking task and the new child (after copy_process() drops tasklist_lock),
we should not queue SIGSTOP too.
Change the code to check task_ptrace() != 0 instead. This is still racy, but
the race is harmless.
We can race with another tracer attaching to this child, or the tracer can
exit and detach in parallel. But giwen that we didn't do wake_up_new_task()
yet, the child must have the pending SIGSTOP anyway.
call_usermodehelper_setup() forgot to kfree(sub_info)
when prepare_usermodehelper_creds() failed.
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6:
PM: Do not hold dpm_list_mtx while disabling/enabling nonboot CPUs
The problem occurs when async_synchronize_full_domain() is called when
the async_pending list is not empty. This will cause lowest_running()
to return the cookie of the first entry on the async_pending list, which
might be nothing at all to do with the domain being asked for and thus
cause the domain synchronization to wait for an unrelated domain. This
can cause a deadlock if domain synchronization is used from one domain
to wait for another.
Fix by running over the async_pending list to see if any pending items
actually belong to our domain (and return their cookies if they do).
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
We shouldn't hold dpm_list_mtx while executing
[disable|enable]_nonboot_cpus(), because theoretically this may lead
to a deadlock as shown by the following example (provided by Johannes
Berg):
CPU 3 CPU 2 CPU 1
suspend/hibernate
something:
rtnl_lock() device_pm_lock()
-> mutex_lock(&dpm_list_mtx)
linkwatch_work
-> rtnl_lock()
disable_nonboot_cpus()
-> flush CPU 3 workqueue
Fortunately, device drivers are supposed to stop any activities that
might lead to the registration of new device objects way before
disable_nonboot_cpus() is called, so it shouldn't be necessary to
hold dpm_list_mtx over the entire late part of device suspend and
early part of device resume.
Thus, during the late suspend and the early resume of devices acquire
dpm_list_mtx only when dpm_list is going to be traversed and release
it right after that.
This patch is reported to fix the regressions tracked as
http://bugzilla.kernel.org/show_bug.cgi?id=13245.
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Reported-by: Miles Lane <miles.lane@gmail.com>
Tested-by: Ming Lei <tom.leiming@gmail.com>
The futex code installs a read only mapping via get_user_pages_fast()
even if the futex op function has to modify user space data. The
eventual fault was fixed up by futex_handle_fault() which walked the
VMA with mmap_sem held.
After the cleanup patches which removed the mmap_sem dependency of the
futex code commit 4dc5b7a36a49eff97050894cf1b3a9a02523717 (futex:
clean up fault logic) removed the private VMA walk logic from the
futex code. This change results in a stale RO mapping which is not
fixed up.
Instead of reintroducing the previous fault logic we set up the
mapping in get_user_pages_fast() read/write for all operations which
modify user space data. Also handle private futexes in the same way
and make the current unconditional access_ok(VERIFY_WRITE) depend on
the futex op.
Reported-by: Andreas Schwab <schwab@linux-m68k.org>
CC: stable@kernel.org
* 'sched-fixes-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
sched: Fix fallback sched_clock()'s offset when using jiffies
* 'core-fixes-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
lockdep: increase MAX_LOCKDEP_ENTRIES and MAX_LOCKDEP_CHAINS
* 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
tracing: Append prompt in /debug/tracing/README file
x86/function-graph: fix constraint for recording old return value
PM: check sysdev_suspend(PMSG_FREEZE) return value
Ian Campbell noticed that since "Eliminate thousands of warnings with
gcc 3.2 build" (commit 57adc4d2dbf968fdbe516359688094eef4d46581) all
WARN_ON()'s currently appear to come from warn_slowpath_null(), eg:
WARNING: at kernel/softirq.c:143 warn_slowpath_null+0x1c/0x20()
because now that warn_slowpath_null() is in the call path, the
__builtin_return_address(0) returns that, rather than the place that
caused the warning.
Fix this by splitting up the warn_slowpath_null/fmt cases differently,
using a common helper function, and getting the return address in the
right place. This also happens to avoid the unnecessary stack usage for
the non-stdargs case, and just generally cleans things up.
Make the function name printout use %pS while at it.
Cc: Ian Campbell <ian.campbell@citrix.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Hugh Dickins <hugh@veritas.com>
Check the return value of sysdev_suspend(). I think this was a typo.
Without this change, the following "if" check is always false.
I also changed the error message so it's distinguishable from the
similar message a few lines above.
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
Acked-by: Pavel Machek <pavel@ucw.cz>
append prompt in /debug/tracing/README file.
This is trivial issue. Fix typo Mini Howto file(README) for ftrace.
[ Impact: cleanup ]
Signed-off-by: GeunSik Lim <geunsik.lim@samsung.com>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Cc: williams <williams@redhat.com>
LKML-Reference: <1242289418.31161.45.camel@centos51>
git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb:
kgdb: gdb documentation fix
kgdb,i386: use address that SP register points to in the exception frame
sysrq, intel_fb: fix sysrq g collision
Commit 79e539453b34e35f39299a899d263b0a1f1670bd introduced a
regression where you cannot use sysrq 'g' to enter kgdb. The solution
is to move the intel fb sysrq over to V for video instead of G for
graphics. The SMP VOYAGER code to register for the sysrq-v is not
anywhere to be found in the mainline kernel, so the comments in the
code were cleaned up as well.
This patch also cleans up the sysrq definitions for kgdb to make it
generic for the kernel debugger, such that the sysrq 'g' can be used
in the future to enter a gdbstub or another kernel debugger.
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
This reverts commit fafd688e4c0c34da0f3de909881117d374e4c7af.
Work is progressing to switch away from pdflush as the process backing
for flushing out dirty data. So it seems pointless to add more knobs
to control pdflush threads. The original author of the patch did not
have any specific use cases for adding the knobs, so we can easily
revert this before 2.6.30 to avoid having to maintain this API
forever.
Now that lockdep coverage has increased it has become easier to
run out of entries:
[ 21.401387] BUG: MAX_LOCKDEP_ENTRIES too low!
[ 21.402007] turning off the locking correctness validator.
[ 21.402007] Pid: 1555, comm: S99local Not tainted 2.6.30-rc5-tip #2
[ 21.402007] Call Trace:
[ 21.402007] [<ffffffff81069789>] add_lock_to_list+0x53/0xba
[ 21.402007] [<ffffffff810eb615>] ? lookup_mnt+0x19/0x53
[ 21.402007] [<ffffffff8106be14>] check_prev_add+0x14b/0x1c7
[ 21.402007] [<ffffffff8106c304>] validate_chain+0x474/0x52a
[ 21.402007] [<ffffffff8106c6fc>] __lock_acquire+0x342/0x3c7
[ 21.402007] [<ffffffff8106c842>] lock_acquire+0xc1/0xe5
[ 21.402007] [<ffffffff8153aedc>] _spin_lock+0x31/0x66
Double the size - as we've done in the past.
[ Impact: allow lockdep to cover more locks ]
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
LKML-Reference: <new-submission>
Account for the initial offset to the jiffy count.
[ Impact: fix printk timestamps on architectures using fallback sched_clock() ]
Signed-off-by: Ron Lee <ron@debian.org>
Fix kprobes to lock text_mutex around some arch_arm/disarm_kprobe() which
are newly added by commit de5bd88d5a5cce3cacea904d3503e5ebdb3852a2.
Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com>
Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
Cc: Jim Keniston <jkenisto@us.ibm.com>
When building with gcc 3.2 I get thousands of warnings such as
include/linux/gfp.h: In function `allocflags_to_migratetype':
include/linux/gfp.h:105: warning: null format string
due to passing a NULL format string to warn_slowpath() in
#define __WARN() warn_slowpath(__FILE__, __LINE__, NULL)
Split this case out into a separate call. This also shrinks the kernel
slightly:
4802274 707668 712704 6222646 5ef336 vmlinux
4799027 703572 712704 6215303 5ed687 vmlinux
due to removeing one argument from the commonly-called __WARN().
[akpm@linux-foundation.org: reduce scope of `empty']
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
Acked-by: Arjan van de Ven <arjan@linux.intel.com>
There is what we believe to be a false positive reported by lockdep.
inotify_inode_queue_event() => take inotify_mutex => kernel_event() =>
kmalloc() => SLOB => alloc_pages_node() => page reclaim => slab reclaim =>
dcache reclaim => inotify_inode_is_dead => take inotify_mutex => deadlock
The plan is to fix this via lockdep annotation, but that is proving to be
quite involved.
The patch flips the allocation over to GFP_NFS to shut the warning up, for
the 2.6.30 release.
Hopefully we will fix this for real in 2.6.31. I'll queue a patch in -mm
to switch it back to GFP_KERNEL so we don't forget.
[ INFO: inconsistent lock state ]
2.6.30-rc2-next-20090417 #203
inconsistent {RECLAIM_FS-ON-W} -> {IN-RECLAIM_FS-W} usage.
kswapd0/380 [HC0[0]:SC0[0]:HE1:SE1] takes:
(&inode->inotify_mutex){+.+.?.}, at: [<ffffffff8112f1b5>] inotify_inode_is_dead+0x35/0xb0
{RECLAIM_FS-ON-W} state was registered at:
[<ffffffff81079188>] mark_held_locks+0x68/0x90
[<ffffffff810792a5>] lockdep_trace_alloc+0xf5/0x100
[<ffffffff810f5261>] __kmalloc_node+0x31/0x1e0
[<ffffffff81130652>] kernel_event+0xe2/0x190
[<ffffffff81130826>] inotify_dev_queue_event+0x126/0x230
[<ffffffff8112f096>] inotify_inode_queue_event+0xc6/0x110
[<ffffffff8110444d>] vfs_create+0xcd/0x140
[<ffffffff8110825d>] do_filp_open+0x88d/0xa20
[<ffffffff810f6b68>] do_sys_open+0x98/0x140
[<ffffffff810f6c50>] sys_open+0x20/0x30
[<ffffffff8100c272>] system_call_fastpath+0x16/0x1b
[<ffffffffffffffff>] 0xffffffffffffffff
irq event stamp: 690455
hardirqs last enabled at (690455): [<ffffffff81564fe4>] _spin_unlock_irqrestore+0x44/0x80
hardirqs last disabled at (690454): [<ffffffff81565372>] _spin_lock_irqsave+0x32/0xa0
softirqs last enabled at (690178): [<ffffffff81052282>] __do_softirq+0x202/0x220
softirqs last disabled at (690157): [<ffffffff8100d50c>] call_softirq+0x1c/0x50
2 locks held by kswapd0/380:
#0: (shrinker_rwsem){++++..}, at: [<ffffffff810d0bd7>] shrink_slab+0x37/0x180
#1: (&type->s_umount_key#17){++++..}, at: [<ffffffff8110cfbf>] shrink_dcache_memory+0x11f/0x1e0
stack backtrace:
Pid: 380, comm: kswapd0 Not tainted 2.6.30-rc2-next-20090417 #203
Call Trace:
[<ffffffff810789ef>] print_usage_bug+0x19f/0x200
[<ffffffff81018bff>] ? save_stack_trace+0x2f/0x50
[<ffffffff81078f0b>] mark_lock+0x4bb/0x6d0
[<ffffffff810799e0>] ? check_usage_forwards+0x0/0xc0
[<ffffffff8107b142>] __lock_acquire+0xc62/0x1ae0
[<ffffffff810f478c>] ? slob_free+0x10c/0x370
[<ffffffff8107c0a1>] lock_acquire+0xe1/0x120
[<ffffffff8112f1b5>] ? inotify_inode_is_dead+0x35/0xb0
[<ffffffff81562d43>] mutex_lock_nested+0x63/0x420
[<ffffffff81012fe9>] ? sched_clock+0x9/0x10
[<ffffffff81077165>] ? lock_release_holdtime+0x35/0x1c0
[<ffffffff8110c9dc>] dentry_iput+0xbc/0xe0
[<ffffffff8110cb23>] d_kill+0x33/0x60
[<ffffffff8110ce23>] __shrink_dcache_sb+0x2d3/0x350
[<ffffffff8110cffa>] shrink_dcache_memory+0x15a/0x1e0
[<ffffffff810d0cc5>] shrink_slab+0x125/0x180
[<ffffffff810d1540>] kswapd+0x560/0x7a0
[<ffffffff810ce160>] ? isolate_pages_global+0x0/0x2c0
[<ffffffff81065a30>] ? autoremove_wake_function+0x0/0x40
[<ffffffff8107953d>] ? trace_hardirqs_on+0xd/0x10
[<ffffffff810d0fe0>] ? kswapd+0x0/0x7a0
[<ffffffff8106555b>] kthread+0x5b/0xa0
[<ffffffff8100d40a>] child_rip+0xa/0x20
[<ffffffff8100cdd0>] ? restore_args+0x0/0x30
[<ffffffff81065500>] ? kthread+0x0/0xa0
[<ffffffff8100d400>] ? child_rip+0x0/0x20
[eparis@redhat.com: fix audit too]
Cc: Matt Mackall <mpm@selenic.com>
Cc: Christoph Lameter <clameter@sgi.com>
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
Signed-off-by: Eric Paris <eparis@redhat.com>
* 'timers/urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
clockevents: prevent endless loop in tick_handle_periodic()
* 'irq/urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
Revert "genirq: assert that irq handlers are indeed running in hardirq context"
* 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
sched: account system time properly
* 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
kernel/posix-cpu-timers.c: fix sparse warning
dma-debug: remove broken dma memory leak detection for 2.6.30
locking: Documentation: lockdep-design.txt, fix note of state bits
tracing: x86, mmiotrace: fix range test
tracing: fix ref count in splice pages
Avoid setting less than two pages for vm_dirty_bytes: this is necessary to
avoid potential division by 0 (like the following) in get_dirty_limits().
[ 49.951610] divide error: 0000 [#1] PREEMPT SMP
[ 49.952195] last sysfs file: /sys/devices/pci0000:00/0000:00:01.1/host0/target0:0:0/0:0:0:0/block/sda/uevent
[ 49.952195] CPU 1
[ 49.952195] Modules linked in: pcspkr
[ 49.952195] Pid: 3064, comm: dd Not tainted 2.6.30-rc3 #1
[ 49.952195] RIP: 0010:[<ffffffff802d39a9>] [<ffffffff802d39a9>] get_dirty_limits+0xe9/0x2c0
[ 49.952195] RSP: 0018:ffff88001de03a98 EFLAGS: 00010202
[ 49.952195] RAX: 00000000000000c0 RBX: ffff88001de03b80 RCX: 28f5c28f5c28f5c3
[ 49.952195] RDX: 0000000000000000 RSI: 00000000000000c0 RDI: 0000000000000000
[ 49.952195] RBP: ffff88001de03ae8 R08: 0000000000000000 R09: 0000000000000000
[ 49.952195] R10: ffff88001ddda9a0 R11: 0000000000000001 R12: 0000000000000001
[ 49.952195] R13: ffff88001fbc8218 R14: ffff88001de03b70 R15: ffff88001de03b78
[ 49.952195] FS: 00007fe9a435b6f0(0000) GS:ffff8800025d9000(0000) knlGS:0000000000000000
[ 49.952195] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 49.952195] CR2: 00007fe9a39ab000 CR3: 000000001de38000 CR4: 00000000000006e0
[ 49.952195] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 49.952195] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[ 49.952195] Process dd (pid: 3064, threadinfo ffff88001de02000, task ffff88001ddda250)
[ 49.952195] Stack:
[ 49.952195] ffff88001fa0de00 ffff88001f2dbd70 ffff88001f9fe800 000080b900000000
[ 49.952195] 00000000000000c0 ffff8800027a6100 0000000000000400 ffff88001fbc8218
[ 49.952195] 0000000000000000 0000000000000600 ffff88001de03bb8 ffffffff802d3ed7
[ 49.952195] Call Trace:
[ 49.952195] [<ffffffff802d3ed7>] balance_dirty_pages_ratelimited_nr+0x1d7/0x3f0
[ 49.952195] [<ffffffff80368f8e>] ? ext3_writeback_write_end+0x9e/0x120
[ 49.952195] [<ffffffff802cc7df>] generic_file_buffered_write+0x12f/0x330
[ 49.952195] [<ffffffff802cce8d>] __generic_file_aio_write_nolock+0x26d/0x460
[ 49.952195] [<ffffffff802cda32>] ? generic_file_aio_write+0x52/0xd0
[ 49.952195] [<ffffffff802cda49>] generic_file_aio_write+0x69/0xd0
[ 49.952195] [<ffffffff80365fa6>] ext3_file_write+0x26/0xc0
[ 49.952195] [<ffffffff803034d1>] do_sync_write+0xf1/0x140
[ 49.952195] [<ffffffff80290d1a>] ? get_lock_stats+0x2a/0x60
[ 49.952195] [<ffffffff80280730>] ? autoremove_wake_function+0x0/0x40
[ 49.952195] [<ffffffff8030411b>] vfs_write+0xcb/0x190
[ 49.952195] [<ffffffff803042d0>] sys_write+0x50/0x90
[ 49.952195] [<ffffffff8022ff6b>] system_call_fastpath+0x16/0x1b
[ 49.952195] Code: 00 00 00 2b 05 09 1c 17 01 48 89 c6 49 0f af f4 48 c1 ee 02 48 89 f0 48 f7 e1 48 89 d6 31 d2 48 c1 ee 02 48 0f af 75 d0 48 89 f0 <48> f7 f7 41 8b 95 ac 01 00 00 48 89 c7 49 0f af d4 48 c1 ea 02
[ 49.952195] RIP [<ffffffff802d39a9>] get_dirty_limits+0xe9/0x2c0
[ 49.952195] RSP <ffff88001de03a98>
[ 50.096523] ---[ end trace 008d7aa02f244d7b ]---
Signed-off-by: Andrea Righi <righi.andrea@gmail.com>
tick_handle_periodic() can lock up hard when a one shot clock event
device is used in combination with jiffies clocksource.
Avoid an endless loop issue by requiring that a highres valid
clocksource be installed before we call tick_periodic() in a loop when
using ONESHOT mode. The result is we will only increment jiffies once
per interrupt until a continuous hardware clocksource is available.
Without this, we can run into a endless loop, where each cycle through
the loop, jiffies is updated which increments time by tick_period or
more (due to clock steering), which can cause the event programming to
think the next event was before the newly incremented time and fail
causing tick_periodic() to be called again and the whole process loops
forever.
[ Impact: prevent hard lock up ]
Signed-off-by: John Stultz <johnstul@us.ibm.com>
Cc: stable@kernel.org
This reverts commit 044d408409cc4e1bc75c886e27ca85c270db104c.
The commit added a warning when handle_IRQ_event() is called outside
of hard interrupt context. This breaks the generic tasklet based
interrupt resend mechanism which is used when the hardware has no way
to retrigger the interrupt. So we get a warning for a use case which
is correct and worked for years. Remove it.
Sparse reports the following in kernel/posix-cpu-timers.c:
warning: symbol 'firing' shadows an earlier one
Cc: Subrata Modak <subrata@linux.vnet.ibm.com>
LKML-Reference: <BD79186B4FD85F4B8E60E381CAEE1909016C1AFE@mi8nycmail19.Mi8.com>
Andrew Gallatin reported that IRQ and SOFTIRQ times were
sometime not reported correctly on recent kernels, and even
bisected to commit 457533a7d3402d1d91fbc125c8bd1bd16dcd3cd4
([PATCH] fix scaled & unscaled cputime accounting) as the first
bad commit.
Further analysis pointed that commit
79741dd35713ff4f6fd0eafd59fa94e8a4ba922d ([PATCH] idle cputime
accounting) was the real cause of the problem.
account_process_tick() was not taking into account timer IRQ
interrupting the idle task servicing a hard or soft irq.
On mostly idle cpu, irqs were thus not accounted and top or
mpstat could tell user/admin that cpu was 100 % idle, 0.00 %
irq, 0.00 % softirq, while it was not.
[ Impact: fix occasionally incorrect CPU statistics in top/mpstat ]
Reported-by: Andrew Gallatin <gallatin@myri.com>
Re-reported-by: Andrew Morton <akpm@linux-foundation.org>
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
Cc: rick.jones2@hp.com
Cc: brice@myri.com
LKML-Reference: <49F84BC1.7080602@cosmosbay.com>
The pages allocated for the splice binary buffer did not initialize
the ref count correctly. This caused pages not to be freed and causes
a drastic memory leak.
Thanks to logdev I was able to trace the tracer to find where the leak
was.
[ Impact: stop memory leak when using splice ]
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6:
ptrace: ptrace_attach: fix the usage of ->cred_exec_mutex
ptrace_attach() needs task->cred_exec_mutex, not current->cred_exec_mutex.
* 'irq-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86/irq: mark NUMA_MIGRATE_IRQ_DESC broken
x86, irq: Remove IRQ_DISABLED check in process context IRQ move
locking: clarify kernel-taint warning message
lockdep, x86: account for irqs enabled in paranoid_exit
lockdep: more robust lockdep_map init sequence
Commit c751085943362143f84346d274e0011419c84202 ("PM/Hibernate: Wait for
SCSI devices scan to complete during resume") added a call to
scsi_complete_async_scans() to software_resume(), so that it waited for
the SCSI scanning to complete, but the call was added at a wrong place.
Namely, it should have been added after wait_for_device_probe(), which
is called only if the image partition hasn't been specified yet. Also,
it's reasonable to check if the image partition is present and only wait
for the device probing and SCSI scanning to complete if it is not the
case.
Additionally, since noresume is checked right at the beginning of
software_resume() and the function returns immediately if it's set, it
doesn't make sense to check it once again later.
Slow-work appears to delete its timer as soon as the first user
unregisters, even though other users could be active. At the same time, it
never seems to delete slow_work_oom_timer. Arrange for both to happen in
the shutdown path.
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
