path: root/kernel
2011-04-08signal.c: fix erroneous syscall kernel-docRandy Dunlap
Fix erroneous syscall kernel-doc comments in kernel/signal.c. Reported-by: Matt Fleming <matt@console-pimps.org> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-07Merge branches 'x86-fixes-for-linus', 'sched-fixes-for-linus', ↵Linus Torvalds
'timers-fixes-for-linus', 'irq-fixes-for-linus' and 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86-32, fpu: Fix FPU exception handling on non-SSE systems x86, hibernate: Initialize mmu_cr4_features during boot x86-32, NUMA: Fix ACPI NUMA init broken by recent x86-64 change x86: visws: Fixup irq overhaul fallout * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: Clean up rebalance_domains() load-balance interval calculation * 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86/mrst/vrtc: Fix boot crash in mrst_rtc_init() rtc, x86/mrst/vrtc: Fix boot crash in rtc_read_alarm() * 'irq-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: genirq: Fix cpumask leak in __setup_irq() * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf probe: Fix listing incorrect line number with inline function perf probe: Fix to find recursively inlined function perf probe: Fix multiple --vars options behavior perf probe: Fix to remove redundant close perf probe: Fix to ensure function declared file
2011-04-07Merge branch 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6Linus Torvalds
* 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6: Fix common misspellings
2011-04-05sched: Clean up rebalance_domains() load-balance interval calculationPeter Zijlstra
Instead of the possible multiple-evaluation of num_online_cpus() in rebalance_domains() that Linus reported, avoid it altogether in the normal case since it's implemented with a Hamming weight function over a cpu bitmask which can be darn expensive for those with big iron. This also makes it cleaner, smaller and documents the code. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1301991265.2225.12.camel@twins> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-04-04kernel/signal.c: add kernel-doc notation to syscallsRandy Dunlap
Add kernel-doc to syscalls in signal.c. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-04kernel/signal.c: fix typos and coding styleRandy Dunlap
General coding style and comment fixes; no code changes: - Use multi-line-comment coding style. - Put some function signatures completely on one line. - Hyphenate some words. - Spell Posix as POSIX. - Correct typos & spellos in some comments. - Drop trailing whitespace. - End sentences with periods. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-04Merge branch 'sched-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: Fix rebalance interval calculation sched, doc: Beef up load balancing description sched: Leave sched_setscheduler() earlier if possible, do not disturb SCHED_FIFO tasks
2011-04-04Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf: Fix task_struct reference leak perf: Fix task context scheduling perf: mmap 512 kiB by default perf: Rebase max unprivileged mlock threshold on top of page size perf tools: Fix NO_NEWT=1 python build error perf symbols: Properly align symbol_conf.priv_size perf tools: Emit clearer message for sys_perf_event_open ENOENT return perf tools: Fixup exit path when not able to open events perf symbols: Fix vsyscall symbol lookup oprofile, x86: Allow setting EDGE/INV/CMASK for counter events
2011-04-04ntp: fix non privileged system time shiftingRichard Cochran
The ADJ_SETOFFSET bit added in commit 094aa188 ("ntp: Add ADJ_SETOFFSET mode bit") also introduced a way for any user to change the system time. Sneaky or buggy calls to adjtimex() could set ADJ_OFFSET_SS_READ | ADJ_SETOFFSET which would result in a successful call to timekeeping_inject_offset(). This patch fixes the issue by adding the capability check. Signed-off-by: Richard Cochran <richard.cochran@omicron.at> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-02genirq: Fix cpumask leak in __setup_irq()Xiaotian Feng
The allocated cpumask should be freed in __setup_irq(). Signed-off-by: Xiaotian Feng <dfeng@redhat.com> LKML-Reference: <1301744375-6812-1-git-send-email-dfeng@redhat.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-04-01kdump: Allow shrinking of kdump region to be overriddenAnton Blanchard
On ppc64 the crashkernel region almost always overlaps an area of firmware. This works fine except when using the sysfs interface to reduce the kdump region. If we free the firmware area we are guaranteed to crash. Rename free_reserved_phys_range to crash_free_reserved_phys_range and make it a weak function so we can override it. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-03-31perf: Fix task_struct reference leakPeter Zijlstra
sys_perf_event_open() had an imbalance in the number of task refs it took causing memory leakage Cc: Jiri Olsa <jolsa@redhat.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: stable@kernel.org # .37+ Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-03-31perf: Rebase max unprivileged mlock threshold on top of page sizeFrederic Weisbecker
Ensure we allow 512 kiB + 1 page for user control without assuming a 4096 bytes page size. Reported-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Stephane Eranian <eranian@google.com> Cc: <stable@kernel.org> LKML-Reference: <1301535209-9679-1-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-03-31sched: Fix rebalance interval calculationSisir Koppaka
The interval for checking scheduling domains if they are due to be balanced currently depends on boot state NR_CPUS, which may not accurately reflect the number of online CPUs at the time of check. Thus replace NR_CPUS with num_online_cpus(). (ed: Should only affect those who set NR_CPUS really high, such as 4096 or so :-) Signed-off-by: Sisir Koppaka <sisir.koppaka@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <AANLkTikqHWid2Q93F5U5Qw5snJH8C5PXoa7J6=6hYO94@mail.gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-03-31sched: Leave sched_setscheduler() earlier if possible, do not disturb ↵Dario Faggioli
SCHED_FIFO tasks sched_setscheduler() (in sched.c) is called in order of changing the scheduling policy and/or the real-time priority of a task. Thus, if we find out that neither of those are actually being modified, it is possible to return earlier and save the overhead of a full deactivate+activate cycle of the task in question. Beside that, if we have more than one SCHED_FIFO task with the same priority on the same rq (which means they share the same priority queue) having one of them changing its position in the priority queue because of a sched_setscheduler (as it happens by means of the deactivate+activate) that does not actually change the priority violates POSIX which states, for SCHED_FIFO: "If a thread whose policy or priority has been modified by pthread_setschedprio() is a running thread or is runnable, the effect on its position in the thread list depends on the direction of the modification, as follows: a. <...> b. If the priority is unchanged, the thread does not change position in the thread list. c. <...>" http://pubs.opengroup.org/onlinepubs/009695399/functions/xsh_chap02_08.html (ed: And the POSIX specification here does, briefly and somewhat unexpectedly, match what common sense tells us as well. ) Signed-off-by: Dario Faggioli <raistlin@linux.it> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1300971618.3960.82.camel@Palantir> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-03-30genirq: Remove the now obsolete config options and select statementsThomas Gleixner
2011-03-29genirq: Fix misnamed label in handle_edge_eoi_irqThomas Gleixner
Reported-by: michael@ellerman.id.au Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: linuxppc-dev@lists.ozlabs.org
2011-03-29genirq: Remove move_*irq leftoversThomas Gleixner
All users converted to new interface. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29genirq: Remove compat codeThomas Gleixner
2011-03-29alpha: Use generic show_interrupts()Thomas Gleixner
The only subtle difference is that alpha uses ACTUAL_NR_IRQS and prints the IRQF_DISABLED flag. Change the generic implementation to deal with ACTUAL_NR_IRQS if defined. The IRQF_DISABLED printing is pointless, as we nowadays run all interrupts with irqs disabled. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29genirq: Fix harmless typoThomas Gleixner
The late night fixup missed to convert the data type from irq_desc to irq_data, which results in a harmless but annoying warning. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-28Merge branches 'irq-cleanup-for-linus' and 'irq-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: vlynq: Convert irq functions * 'irq-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: genirq; Fix cleanup fallout genirq: Fix typo and remove unused variable genirq: Fix new kernel-doc warnings genirq: Add setter for AFFINITY_SET in irq_data state genirq: Provide setter inline for IRQD_IRQ_INPROGRESS genirq: Remove handle_IRQ_event arm: Ns9xxx: Remove private irq flow handler powerpc: cell: Use the core flow handler genirq: Provide edge_eoi flow handler genirq: Move INPROGRESS, MASKED and DISABLED state flags to irq_data genirq: Split irq_set_affinity() so it can be called with lock held. genirq: Add chip flag for restricting cpu_on/offline calls genirq: Add chip hooks for taking CPUs on/off line. genirq: Add irq disabled flag to irq_data state genirq: Reserve the irq when calling irq_set_chip()
2011-03-29genirq; Fix cleanup falloutThomas Gleixner
I missed the CONFIG_GENERIC_PENDING_IRQ dependency in the affinity related functions and the IRQ_LEVEL propagation into irq_data state. Did not pop up on my main test platforms. :( Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: David Daney <ddaney@caviumnetworks.com>
2011-03-28Relax si_code check in rt_sigqueueinfo and rt_tgsigqueueinfoRoland Dreier
Commit da48524eb206 ("Prevent rt_sigqueueinfo and rt_tgsigqueueinfo from spoofing the signal code") made the check on si_code too strict. There are several legitimate places where glibc wants to queue a negative si_code different from SI_QUEUE: - This was first noticed with glibc's aio implementation, which wants to queue a signal with si_code SI_ASYNCIO; the current kernel causes glibc's tst-aio4 test to fail because rt_sigqueueinfo() fails with EPERM. - Further examination of the glibc source shows that getaddrinfo_a() wants to use SI_ASYNCNL (which the kernel does not even define). The timer_create() fallback code wants to queue signals with SI_TIMER. As suggested by Oleg Nesterov <oleg@redhat.com>, loosen the check to forbid only the problematic SI_TKILL case. Reported-by: Klaus Dittrich <kladit@arcor.de> Acked-by: Julien Tinnes <jln@google.com> Cc: <stable@kernel.org> Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-28genirq: Fix typo and remove unused variableThomas Gleixner
Sigh, I'm overworked. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-28genirq: Fix new kernel-doc warningsRandy Dunlap
Fix new irq-related kernel-doc warnings in 2.6.38: Warning(kernel/irq/manage.c:149): No description found for parameter 'mask' Warning(kernel/irq/manage.c:149): Excess function parameter 'cpumask' description in 'irq_set_affinity' Warning(include/linux/irq.h:161): No description found for parameter 'state_use_accessors' Warning(include/linux/irq.h:161): Excess struct/union/enum/typedef member 'state_use_accessor' description in 'irq_data' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> LKML-Reference: <20110318093356.b939558d.randy.dunlap@oracle.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-28genirq: Remove handle_IRQ_eventThomas Gleixner
Last user gone. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-28genirq: Provide edge_eoi flow handlerThomas Gleixner
This is a replacment for the cell flow handler which is in the way of cleanups. Must be selected to avoid general bloat. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-28genirq: Move INPROGRESS, MASKED and DISABLED state flags to irq_dataThomas Gleixner
We really need these flags for some of the interrupt chips. Move it from internal state to irq_data and provide proper accessors. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: David Daney <ddaney@caviumnetworks.com>
2011-03-27genirq: Split irq_set_affinity() so it can be called with lock held.David Daney
The .irq_cpu_online() and .irq_cpu_offline() functions may need to adjust affinity, but they are called with the descriptor lock held. Create __irq_set_affinity_locked() which is called with the lock held. Make irq_set_affinity() just a wrapper that acquires the lock. [ tglx: Changed the argument to irq_data, added a !desc check and moved the !irq_set_affinity check where it belongs ] Signed-off-by: David Daney <ddaney@caviumnetworks.com> Cc: linux-mips@linux-mips.org Cc: ralf@linux-mips.org LKML-Reference: <1301081931-11240-4-git-send-email-ddaney@caviumnetworks.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-27genirq: Add chip flag for restricting cpu_on/offline callsThomas Gleixner
Add a flag which indicates that the on/offline callback should only be called on enabled interrupts. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-27genirq: Add chip hooks for taking CPUs on/off line.David Daney
[ tglx: Removed the enabled argument as this is now available in irq_data ] Signed-off-by: David Daney <ddaney@caviumnetworks.com> Cc: linux-mips@linux-mips.org Cc: ralf@linux-mips.org LKML-Reference: <1301081931-11240-3-git-send-email-ddaney@caviumnetworks.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-27genirq: Add irq disabled flag to irq_data stateThomas Gleixner
Some irq_chip implementation require to know the disabled state of the interrupt in certain callbacks. Add a state flag and accessor to irq_data. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-27genirq: Reserve the irq when calling irq_set_chip()David Daney
The helper macros and functions like for_each_active_irq() don't work unless the irq is in the allocated_irqs set. In the case of !CONFIG_SPARSE_IRQ, instead of forcing all users of the irq infrastructure to explicitly call irq_reserve_irq(), do it for them. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Cc: linux-mips@linux-mips.org Cc: ralf@linux-mips.org LKML-Reference: <1301081931-11240-2-git-send-email-ddaney@caviumnetworks.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-25Merge branch 'syscore' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6 * 'syscore' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6: Introduce ARCH_NO_SYSDEV_OPS config option (v2) cpufreq: Use syscore_ops for boot CPU suspend/resume (v2) KVM: Use syscore_ops instead of sysdev class and sysdev PCI / Intel IOMMU: Use syscore_ops instead of sysdev class and sysdev timekeeping: Use syscore_ops instead of sysdev class and sysdev x86: Use syscore_ops instead of sysdev classes and sysdevs
2011-03-25Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb: kdb: add usage string of 'per_cpu' command kgdb,x86_64: fix compile warning found with sparse kdb: code cleanup to use macro instead of value kgdboc,kgdbts: strlen() doesn't count the terminator
2011-03-25Merge branch 'irq-cleanup-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (23 commits) genirq: Expand generic show_interrupts() gpio: Fold irq_set_chip/irq_set_handler to irq_set_chip_and_handler gpio: Cleanup genirq namespace arm: ep93xx: Add basic interrupt info arm/gpio: Remove three copies of broken and racy debug code xtensa: Use generic show_interrupts() xtensa: Convert genirq namespace xtensa: Use generic IRQ Kconfig and set GENERIC_HARDIRQS_NO_DEPRECATED xtensa: Convert s6000 gpio irq_chip to new functions xtensa: Convert main irq_chip to new functions um: Use generic show_interrupts() um: Convert genirq namespace m32r: Use generic show_interrupts() m32r: Convert genirq namespace h8300: Use generic show_interrupts() h8300: Convert genirq namespace avr32: Cleanup eic_set_irq_type() avr32: Use generic show_interrupts() avr: Cleanup genirq namespace avr32: Use generic IRQ config, enable GENERIC_HARDIRQS_NO_DEPRECATED ... Fix up trivial conflict in drivers/gpio/timbgpio.c
2011-03-25Merge branch 'sched-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched, doc: Update sched-design-CFS.txt sched: Remove unused 'rq' variable and cpu_rq() call from alloc_fair_sched_group() sched.h: Fix a typo ("its") sched: Fix yield_to kernel-doc
2011-03-25Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf, x86: Complain louder about BIOSen corrupting CPU/PMU state and continue perf, x86: P4 PMU - Read proper MSR register to catch unflagged overflows perf symbols: Look at .dynsym again if .symtab not found perf build-id: Add quirk to deal with perf.data file format breakage perf session: Pass evsel in event_ops->sample() perf: Better fit max unprivileged mlock pages for tools needs perf_events: Fix stale ->cgrp pointer in update_cgrp_time_from_cpuctx() perf top: Fix uninitialized 'counter' variable tracing: Fix set_ftrace_filter probe function display perf, x86: Fix Intel fixed counters base initialization
2011-03-25Merge branch 'irq-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: genirq: Provide locked setter for chip, handler, name genirq: Provide a lockdep helper genirq; Remove the last leftovers of the old sparse irq code
2011-03-25Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: futex: Fix WARN_ON() test for UP WARN_ON_SMP(): Allow use in if() statements on UP x86, dumpstack: Use %pB format specifier for stack trace vsprintf: Introduce %pB format specifier lockdep: Remove unused 'factor' variable from lockdep_stats_show()
2011-03-25kdb: add usage string of 'per_cpu' commandNamhyung Kim
Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2011-03-25kdb: code cleanup to use macro instead of valueJovi Zhang
It's better to use macro KDB_BASE_CMD_MAX instead of 50 Signed-off-by: Jovi Zhang <bookjovi@gmail.com> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2011-03-25genirq: Expand generic show_interrupts()Thomas Gleixner
Some archs want to print extra information for certain irq_chips which is per irq and not per chip. Allow them to provide a chip callback to print the chip name and the extra information. PowerPC wants to print the LEVEL/EDGE type information. Make it configurable. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-25futex: Fix WARN_ON() test for UPSteven Rostedt
An update of the futex code had a WARN_ON(!spin_is_locked(q->lock_ptr)) But on UP, spin_is_locked() is always false, and will trigger this warning, and even worse, it will exit the function without doing the necessary work. Converting this to a WARN_ON_SMP() fixes the problem. Reported-by: Richard Weinberger <richard@nod.at> Tested-by: Richard Weinberger <richard@nod.at> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Darren Hart <dvhart@linux.intel.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> LKML-Reference: <20110317192208.682654502@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-03-24Merge branch 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits) Documentation/iostats.txt: bit-size reference etc. cfq-iosched: removing unnecessary think time checking cfq-iosched: Don't clear queue stats when preempt. blk-throttle: Reset group slice when limits are changed blk-cgroup: Only give unaccounted_time under debug cfq-iosched: Don't set active queue in preempt block: fix non-atomic access to genhd inflight structures block: attempt to merge with existing requests on plug flush block: NULL dereference on error path in __blkdev_get() cfq-iosched: Don't update group weights when on service tree fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away block: Require subsystems to explicitly allocate bio_set integrity mempool jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging fs: make fsync_buffers_list() plug mm: make generic_writepages() use plugging blk-cgroup: Add unaccounted time to timeslice_used. block: fixup plugging stubs for !CONFIG_BLOCK block: remove obsolete comments for blkdev_issue_zeroout. blktrace: Use rq->cmd_flags directly in blk_add_trace_rq. ... Fix up conflicts in fs/{aio.c,super.c}
2011-03-24Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-mn10300 * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-mn10300: MN10300: gcc 4.6 vs am33 inline assembly MN10300: Deprecate gdbstub MN10300: Allow KGDB to use the MN10300 serial ports MN10300: Emulate single stepping in KGDB on MN10300 MN10300: Generalise kernel debugger kernel halt, reboot or power off hook KGDB: Notify GDB of machine halt, reboot or power off MN10300: Use KGDB MN10300: Create generic kernel debugger hooks MN10300: Create general kernel debugger cache flushing MN10300: Introduce a general config option for kernel debugger hooks MN10300: The icache invalidate functions should disable the icache first MN10300: gdbstub: Restrict single-stepping to non-preemptable non-SMP configs
2011-03-24vsprintf: Introduce %pB format specifierNamhyung Kim
The %pB format specifier is for stack backtrace. Its handler sprint_backtrace() does symbol lookup using (address-1) to ensure the address will not point outside of the function. If there is a tail-call to the function marked "noreturn", gcc optimized out the code after the call then causes saved return address points outside of the function (i.e. the start of the next function), so pollutes call trace somewhat. This patch adds the %pB printk mechanism that allows architecture call-trace printout functions to improve backtrace printouts. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: linux-arch@vger.kernel.org LKML-Reference: <1300934550-21394-1-git-send-email-namhyung@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-03-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: deal with races in /proc/*/{syscall,stack,personality} proc: enable writing to /proc/pid/mem proc: make check_mem_permission() return an mm_struct on success proc: hold cred_guard_mutex in check_mem_permission() proc: disable mem_write after exec mm: implement access_remote_vm mm: factor out main logic of access_process_vm mm: use mm_struct to resolve gate vma's in __get_user_pages mm: arch: rename in_gate_area_no_task to in_gate_area_no_mm mm: arch: make in_gate_area take an mm_struct instead of a task_struct mm: arch: make get_gate_vma take an mm_struct instead of a task_struct x86: mark associated mm when running a task in 32 bit compatibility mode x86: add context tag to mark mm when running a task in 32-bit compatibility mode auxv: require the target to be tracable (or yourself) close race in /proc/*/environ report errors in /proc/*/*map* sanely pagemap: close races with suid execve make sessionid permissions in /proc/*/task/* match those in /proc/* fix leaks in path_lookupat() Fix up trivial conflicts in fs/proc/base.c
