commit 1fe4293f4b8de75824935f8d8e9a99c7fc6873da upstream.
The function_graph tracer does not show the interrupt return marker for the
leaf entry. On leaf entries, we see an unbalanced interrupt marker (the
interrupt was entered, but nevern left).
Before:
1) | SyS_write() {
1) | __fdget_pos() {
1) 0.061 us | __fget_light();
1) 0.289 us | }
1) | vfs_write() {
1) 0.049 us | rw_verify_area();
1) + 15.424 us | __vfs_write();
1) ==========> |
1) 6.003 us | smp_apic_timer_interrupt();
1) 0.055 us | __fsnotify_parent();
1) 0.073 us | fsnotify();
1) + 23.665 us | }
1) + 24.501 us | }
After:
0) | SyS_write() {
0) | __fdget_pos() {
0) 0.052 us | __fget_light();
0) 0.328 us | }
0) | vfs_write() {
0) 0.057 us | rw_verify_area();
0) | __vfs_write() {
0) ==========> |
0) 8.548 us | smp_apic_timer_interrupt();
0) <========== |
0) + 36.507 us | } /* __vfs_write */
0) 0.049 us | __fsnotify_parent();
0) 0.066 us | fsnotify();
0) + 50.064 us | }
0) + 50.952 us | }
Link: http://lkml.kernel.org/r/1517413729-20411-1-git-send-email-changbin.du@intel.com
Cc: stable@vger.kernel.org
Fixes: f8b755ac8e0cc ("tracing/function-graph-tracer: Output arrows signal on hardirq call/return")
Signed-off-by: Changbin Du <changbin.du@intel.com>
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
commit abcbcb80cd09cd40f2089d912764e315459b71f7 upstream.
For the common cases where 1000 is a multiple of HZ, or HZ is a multiple of
1000, jiffies_to_msecs() never returns zero when passed a non-zero time
period.
However, if HZ > 1000 and not an integer multiple of 1000 (e.g. 1024 or
1200, as used on alpha and DECstation), jiffies_to_msecs() may return zero
for small non-zero time periods. This may break code that relies on
receiving back a non-zero value.
jiffies_to_usecs() does not need such a fix: one jiffy can only be less
than one µs if HZ > 1000000, and such large values of HZ are already
rejected at build time, twice:
- include/linux/jiffies.h does #error if HZ >= 12288,
- kernel/time/time.c has BUILD_BUG_ON(HZ > USEC_PER_SEC).
Broken since forever.
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Cc: John Stultz <john.stultz@linaro.org>
Cc: Stephen Boyd <sboyd@kernel.org>
Cc: linux-alpha@vger.kernel.org
Cc: linux-mips@linux-mips.org
Link: https://lkml.kernel.org/r/20180622143357.7495-1-geert@linux-m68k.org
commit 86b389ff22bd6ad8fd3cb98e41cd271886c6d023 upstream.
If a instance has an event trigger enabled when it is freed, it could cause
an access of free memory. Here's the case that crashes:
# cd /sys/kernel/tracing
# mkdir instances/foo
# echo snapshot > instances/foo/events/initcall/initcall_start/trigger
# rmdir instances/foo
Would produce:
general protection fault: 0000 [#1] PREEMPT SMP PTI
Modules linked in: tun bridge ...
CPU: 5 PID: 6203 Comm: rmdir Tainted: G W 4.17.0-rc4-test+ #933
Hardware name: Hewlett-Packard HP Compaq Pro 6300 SFF/339A, BIOS K01 v03.03 07/14/2016
RIP: 0010:clear_event_triggers+0x3b/0x70
RSP: 0018:ffffc90003783de0 EFLAGS: 00010286
RAX: 0000000000000000 RBX: 6b6b6b6b6b6b6b2b RCX: 0000000000000000
RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffff8800c7130ba0
RBP: ffffc90003783e00 R08: ffff8801131993f8 R09: 0000000100230016
R10: ffffc90003783d80 R11: 0000000000000000 R12: ffff8800c7130ba0
R13: ffff8800c7130bd8 R14: ffff8800cc093768 R15: 00000000ffffff9c
FS: 00007f6f4aa86700(0000) GS:ffff88011eb40000(0000) knlGS:0000000000000000
CR2: 00007f6f4a5aed60 CR3: 00000000cd552001 CR4: 00000000001606e0
Call Trace:
event_trace_del_tracer+0x2a/0xc5
instance_rmdir+0x15c/0x200
tracefs_syscall_rmdir+0x52/0x90
vfs_rmdir+0xdb/0x160
do_rmdir+0x16d/0x1c0
__x64_sys_rmdir+0x17/0x20
do_syscall_64+0x55/0x1a0
entry_SYSCALL_64_after_hwframe+0x49/0xbe
This was due to the call the clears out the triggers when an instance is
being deleted not removing the trigger from the link list.
Fixes: 85f2b08268c01 ("tracing: Add basic event trigger framework")
[ Upstream commit 1e0ce03bf142454f38a5fc050bf4fd698d2d36d8 ]
The "mdr" command should repeat (continue) when only Enter/Return
is pressed, so make it do so.
Cc: Daniel Thompson <daniel.thompson@linaro.org>
Cc: Jason Wessel <jason.wessel@windriver.com>
Cc: kgdb-bugreport@lists.sourceforge.net
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
[ Upstream commit 23138ead270045f1b3e912e667967b6094244999 ]
If there is a memory allocation error when trying to change an audit
kernel feature value, the ignored allocation error will trigger a NULL
pointer dereference oops on subsequent use of that pointer. Return
instead.
Passes audit-testsuite.
See: https://github.com/linux-audit/audit-kernel/issues/76
Signed-off-by: Richard Guy Briggs <rgb@redhat.com>
[PM: not necessary (other funcs check for NULL), but a good practice]
Signed-off-by: Paul Moore <paul@paul-moore.com>
[ Upstream commit 9e5b127d6f33468143d90c8a45ca12410e4c3fa7 ]
Mark reported his arm64 perf fuzzer runs sometimes splat like:
armv8pmu_read_counter+0x1e8/0x2d8
armpmu_event_update+0x8c/0x188
armpmu_read+0xc/0x18
perf_output_read+0x550/0x11e8
perf_event_read_event+0x1d0/0x248
perf_event_exit_task+0x468/0xbb8
do_exit+0x690/0x1310
do_group_exit+0xd0/0x2b0
get_signal+0x2e8/0x17a8
do_signal+0x144/0x4f8
do_notify_resume+0x148/0x1e8
work_pending+0x8/0x14
which asserts that we only call pmu::read() on ACTIVE events.
The above callchain does:
perf_event_exit_task()
perf_event_exit_task_context()
task_ctx_sched_out() // INACTIVE
perf_event_exit_event()
perf_event_set_state(EXIT) // EXIT
sync_child_event()
perf_event_read_event()
perf_output_read()
perf_output_read_group()
leader->pmu->read()
Which results in doing a pmu::read() on an !ACTIVE event.
I _think_ this is 'new' since we added attr.inherit_stat, which added
the perf_event_read_event() to the exit path, without that
perf_event_read_output() would only trigger from samples and for
@event to trigger a sample, it's leader _must_ be ACTIVE too.
Still, adding this check makes it consistent with the @sub case for
the siblings.
Reported-and-Tested-by: Mark Rutland <mark.rutland@arm.com>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Vince Weaver <vincent.weaver@maine.edu>
[ Upstream commit d29a20645d5e929aa7e8616f28e5d8e1c49263ec ]
While running rt-tests' pi_stress program I got the following splat:
rq->clock_update_flags < RQCF_ACT_SKIP
WARNING: CPU: 27 PID: 0 at kernel/sched/sched.h:960 assert_clock_updated.isra.38.part.39+0x13/0x20
<IRQ>
enqueue_top_rt_rq+0xf4/0x150
? cpufreq_dbs_governor_start+0x170/0x170
sched_rt_rq_enqueue+0x65/0x80
sched_rt_period_timer+0x156/0x360
? sched_rt_rq_enqueue+0x80/0x80
__hrtimer_run_queues+0xfa/0x260
hrtimer_interrupt+0xcb/0x220
smp_apic_timer_interrupt+0x62/0x120
apic_timer_interrupt+0xf/0x20
</IRQ>
do_idle+0x183/0x1e0
cpu_startup_entry+0x5f/0x70
start_secondary+0x192/0x1d0
secondary_startup_64+0xa5/0xb0
We can get rid of it be the "traditional" means of adding an
update_rq_clock() call after acquiring the rq->lock in
do_sched_rt_period_timer().
The case for the RT task throttling (which this workload also hits)
can be ignored in that the skip_update call is actually bogus and
quite the contrary (the request bits are removed/reverted).
By setting RQCF_UPDATED we really don't care if the skip is happening
or not and will therefore make the assert_clock_updated() check happy.
Signed-off-by: Davidlohr Bueso <dbueso@suse.de>
Reviewed-by: Matt Fleming <matt@codeblueprint.co.uk>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Cc: dave@stgolabs.net
Cc: rostedt@goodmis.org
Link: http://lkml.kernel.org/r/20180402164954.16255-1-dave@stgolabs.net
[ Upstream commit c917e0f259908e75bd2a65877e25f9d90c22c848 ]
When a perf_event is attached to parent cgroup, it should count events
for all children cgroups:
parent_group <---- perf_event
- child_group <---- process(es)
However, in our tests, we found this perf_event cannot report reliable
results. Here is an example case:
# create cgroups
mkdir -p /sys/fs/cgroup/p/c
# start perf for parent group
perf stat -e instructions -G "p"
# on another console, run test process in child cgroup:
stressapptest -s 2 -M 1000 & echo $! > /sys/fs/cgroup/p/c/cgroup.procs
# after the test process is done, stop perf in the first console shows
<not counted> instructions p
The instruction should not be "not counted" as the process runs in the
child cgroup.
We found this is because perf_event->cgrp and cpuctx->cgrp are not
identical, thus perf_event->cgrp are not updated properly.
This patch fixes this by updating perf_cgroup properly for ancestor
cgroup(s).
Reported-by: Ephraim Park <ephiepark@fb.com>
Signed-off-by: Song Liu <songliubraving@fb.com>
Cc: <jolsa@redhat.com>
Cc: <kernel-team@fb.com>
Link: http://lkml.kernel.org/r/20180312165943.1057894-1-songliubraving@fb.com
[ Upstream commit 537f4146c53c95aac977852b371bafb9c6755ee1 ]
Never directly free @dev after calling device_register(), even
if it returned an error! Always use put_device() to give up the
reference initialized in this function instead.
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
[ Upstream commit 88913bd8ea2a75d7e460a4bed5f75e1c32660d7e ]
chan->n_subbufs is set by the user and relay_create_buf() does a kmalloc()
of chan->n_subbufs * sizeof(size_t *).
kmalloc_slab() will generate a warning when this fails if
chan->subbufs * sizeof(size_t *) > KMALLOC_MAX_SIZE.
Limit chan->n_subbufs to the maximum allowed kmalloc() size.
Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1802061216100.122576@chino.kir.corp.google.com
Fixes: f6302f1bcd75 ("relay: prevent integer overflow in relay_open()")
Signed-off-by: David Rientjes <rientjes@google.com>
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Dave Jiang <dave.jiang@intel.com>
Cc: Dan Carpenter <dan.carpenter@oracle.com>
[ Upstream commit 11dc13224c975efcec96647a4768a6f1bb7a19a8 ]
When queuing on the qspinlock, the count field for the current CPU's head
node is incremented. This needn't be atomic because locking in e.g. IRQ
context is balanced and so an IRQ will return with node->count as it
found it.
However, the compiler could in theory reorder the initialisation of
node[idx] before the increment of the head node->count, causing an
IRQ to overwrite the initialised node and potentially corrupt the lock
state.
Avoid the potential for this harmful compiler reordering by placing a
barrier() between the increment of the head node->count and the subsequent
node initialisation.
Link: http://lkml.kernel.org/r/1518528177-19169-3-git-send-email-will.deacon@arm.com
[ Upstream commit 328008a72d38b5bde6491e463405c34a81a65d3e ]
The declaration for swsusp_arch_resume marks it as 'asmlinkage', but the
definition in x86-32 does not, and it fails to include the header with the
declaration. This leads to a warning when building with
link-time-optimizations:
kernel/power/power.h:108:23: error: type of 'swsusp_arch_resume' does not match original declaration [-Werror=lto-type-mismatch]
extern asmlinkage int swsusp_arch_resume(void);
arch/x86/power/hibernate_32.c:148:0: note: 'swsusp_arch_resume' was previously declared here
This moves the declaration into a globally visible header file and fixes up
both x86 definitions to match it.
Cc: Len Brown <len.brown@intel.com>
Cc: Nicolas Pitre <nico@linaro.org>
Cc: linux-pm@vger.kernel.org
Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: Bart Van Assche <bart.vanassche@wdc.com>
Link: https://lkml.kernel.org/r/20180202145634.200291-2-arnd@arndb.de
commit 4ea77014af0d6205b05503d1c7aac6eace11d473 upstream.
When running kill(72057458746458112, 0) in userspace I hit the following
issue.
UBSAN: Undefined behaviour in kernel/signal.c:1462:11
negation of -2147483648 cannot be represented in type 'int':
CPU: 226 PID: 9849 Comm: test Tainted: G B ---- ------- 3.10.0-327.53.58.70.x86_64_ubsan+ #116
Hardware name: Huawei Technologies Co., Ltd. RH8100 V3/BC61PBIA, BIOS BLHSV028 11/11/2014
Call Trace:
dump_stack+0x19/0x1b
ubsan_epilogue+0xd/0x50
__ubsan_handle_negate_overflow+0x109/0x14e
SYSC_kill+0x43e/0x4d0
SyS_kill+0xe/0x10
system_call_fastpath+0x16/0x1b
Add code to avoid the UBSAN detection.
[akpm@linux-foundation.org: tweak comment]
Link: http://lkml.kernel.org/r/1496670008-59084-1-git-send-email-zhongjiang@huawei.com
Signed-off-by: zhongjiang <zhongjiang@huawei.com>
Cc: Michal Hocko <mhocko@kernel.org>
Cc: Xishi Qiu <qiuxishi@huawei.com>
commit 23d6aef74da86a33fa6bb75f79565e0a16ee97c2 upstream.
`resource' can be controlled by user-space, hence leading to a potential
exploitation of the Spectre variant 1 vulnerability.
This issue was detected with the help of Smatch:
kernel/sys.c:1474 __do_compat_sys_old_getrlimit() warn: potential spectre issue 'get_current()->signal->rlim' (local cap)
kernel/sys.c:1455 __do_sys_old_getrlimit() warn: potential spectre issue 'get_current()->signal->rlim' (local cap)
Fix this by sanitizing *resource* before using it to index
current->signal->rlim
Notice that given that speculation windows are large, the policy is to
kill the speculation on the first load and not worry if it can be
completed with a dependent load/store [1].
[1] https://marc.info/?l=linux-kernel&m=152449131114778&w=2
Link: http://lkml.kernel.org/r/20180515030038.GA11822@embeddedor.com
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
Cc: Alexei Starovoitov <ast@kernel.org>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: <stable@vger.kernel.org>
commit 3d88d56c5873f6eebe23e05c3da701960146b801 upstream.
Due to how the MONOTONIC_RAW accumulation logic was handled,
there is the potential for a 1ns discontinuity when we do
accumulations. This small discontinuity has for the most part
gone un-noticed, but since ARM64 enabled CLOCK_MONOTONIC_RAW
in their vDSO clock_gettime implementation, we've seen failures
with the inconsistency-check test in kselftest.
This patch addresses the issue by using the same sub-ns
accumulation handling that CLOCK_MONOTONIC uses, which avoids
the issue for in-kernel users.
Since the ARM64 vDSO implementation has its own clock_gettime
calculation logic, this patch reduces the frequency of errors,
but failures are still seen. The ARM64 vDSO will need to be
updated to include the sub-nanosecond xtime_nsec values in its
calculation for this issue to be completely fixed.
Signed-off-by: John Stultz <john.stultz@linaro.org>
Tested-by: Daniel Mentz <danielmentz@google.com>
Cc: Prarit Bhargava <prarit@redhat.com>
Cc: Kevin Brodsky <kevin.brodsky@arm.com>
Cc: Richard Cochran <richardcochran@gmail.com>
Cc: Stephen Boyd <stephen.boyd@linaro.org>
Cc: "stable #4 . 8+" <stable@vger.kernel.org>
Cc: Miroslav Lichvar <mlichvar@redhat.com>
Link: http://lkml.kernel.org/r/1496965462-20003-3-git-send-email-john.stultz@linaro.org
[fabrizio: cherry-pick to 4.4. Kept cycle_t type for function
logarithmic_accumulation local variable "interval". Dropped
casting of "interval" variable]
Signed-off-by: Fabrizio Castro <fabrizio.castro@bp.renesas.com>
Signed-off-by: Biju Das <biju.das@bp.renesas.com>
commit 5596fe34495cf0f645f417eb928ef224df3e3cb4 upstream.
for_each_cpu() unintuitively reports CPU0 as set independent of the actual
cpumask content on UP kernels. This causes an unexpected PIT interrupt
storm on a UP kernel running in an SMP virtual machine on Hyper-V, and as
a result, the virtual machine can suffer from a strange random delay of 1~20
minutes during boot-up, and sometimes it can hang forever.
Protect if by checking whether the cpumask is empty before entering the
for_each_cpu() loop.
[ tglx: Use !IS_ENABLED(CONFIG_SMP) instead of #ifdeffery ]
Signed-off-by: Dexuan Cui <decui@microsoft.com>
Cc: Josh Poulson <jopoulso@microsoft.com>
Cc: "Michael Kelley (EOSG)" <Michael.H.Kelley@microsoft.com>
Cc: Rakib Mullick <rakib.mullick@gmail.com>
Cc: Jork Loeser <Jork.Loeser@microsoft.com>
Cc: KY Srinivasan <kys@microsoft.com>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Link: https://lkml.kernel.org/r/KL1P15301MB000678289FE55BA365B3279ABF990@KL1P15301MB0006.APCP153.PROD.OUTLOOK.COM
Link: https://lkml.kernel.org/r/KL1P15301MB0006FA63BC22BEB64902EAA0BF930@KL1P15301MB0006.APCP153.PROD.OUTLOOK.COM
commit c7be96af89d4b53211862d8599b2430e8900ed92 upstream.
When running certain database workload on a high-end system with many
CPUs, it was found that spinlock contention in the sigprocmask syscalls
became a significant portion of the overall CPU cycles as shown below.
9.30% 9.30% 905387 dataserver /proc/kcore 0x7fff8163f4d2
[k] _raw_spin_lock_irq
---_raw_spin_lock_irq
|--99.34%-- __set_current_blocked
| sigprocmask
| sys_rt_sigprocmask
| |--50.63%-- __swapcontext
| | |--99.91%-- upsleepgeneric
| |--49.36%-- __setcontext
| | ktskRun
Looking further into the swapcontext function in glibc, it was found that
the function always call sigprocmask() without checking if there are
changes in the signal mask.
A check was added to the __set_current_blocked() function to avoid taking
the sighand->siglock spinlock if there is no change in the signal mask.
This will prevent unneeded spinlock contention when many threads are
trying to call sigprocmask().
With this patch applied, the spinlock contention in sigprocmask() was
gone.
Link: http://lkml.kernel.org/r/1474979209-11867-1-git-send-email-Waiman.Long@hpe.com
Signed-off-by: Waiman Long <Waiman.Long@hpe.com>
Acked-by: Oleg Nesterov <oleg@redhat.com>
Cc: Stas Sergeev <stsp@list.ru>
Cc: Scott J Norton <scott.norton@hpe.com>
Cc: Douglas Hatch <doug.hatch@hpe.com>
commit dd83c161fbcc5d8be637ab159c0de015cbff5ba4 upstream.
wait4(-2147483648, 0x20, 0, 0xdd0000) triggers:
UBSAN: Undefined behaviour in kernel/exit.c:1651:9
The related calltrace is as follows:
CPU: 9 PID: 16482 Comm: zj Tainted: G B ---- ------- 3.10.0-327.53.58.71.x86_64+ #66
Hardware name: Huawei Technologies Co., Ltd. Tecal RH2285 /BC11BTSA , BIOS CTSAV036 04/27/2011
Call Trace:
SyS_wait4+0x1cb/0x1e0
Exclude the overflow to avoid the UBSAN warning.
Link: http://lkml.kernel.org/r/1497264618-20212-1-git-send-email-zhongjiang@huawei.com
Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
commit d70ef22892ed6c066e51e118b225923c9b74af34 upstream.
sign_extend32 counts the sign bit parameter from 0, not from 1. So we
have to use "11" for 12th bit, not "12".
This mistake means we have not allowed negative op and cmp args since
commit 30d6e0a4190d ("futex: Remove duplicated code and fix undefined
behaviour") till now.
Fixes: 30d6e0a4190d ("futex: Remove duplicated code and fix undefined behaviour")
Cc: Darren Hart <dvhart@infradead.org>
commit 30d6e0a4190d37740e9447e4e4815f06992dd8c3 upstream.
There is code duplicated over all architecture's headers for
futex_atomic_op_inuser. Namely op decoding, access_ok check for uaddr,
and comparison of the result.
Remove this duplication and leave up to the arches only the needed
assembly which is now in arch_futex_atomic_op_inuser.
This effectively distributes the Will Deacon's arm64 fix for undefined
behaviour reported by UBSAN to all architectures. The fix was done in
commit 5f16a046f8e1 (arm64: futex: Fix undefined behaviour with
FUTEX_OP_OPARG_SHIFT usage). Look there for an example dump.
And as suggested by Thomas, check for negative oparg too, because it was
also reported to cause undefined behaviour report.
Note that s390 removed access_ok check in d12a29703 ("s390/uaccess:
remove pointless access_ok() checks") as access_ok there returns true.
We introduce it back to the helper for the sake of simplicity (it gets
optimized away anyway).
Acked-by: Russell King <rmk+kernel@armlinux.org.uk>
Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> [s390]
Acked-by: Chris Metcalf <cmetcalf@mellanox.com> [for tile]
Reviewed-by: Darren Hart (VMware) <dvhart@infradead.org>
Reviewed-by: Will Deacon <will.deacon@arm.com> [core/arm64]
Cc: Rich Felker <dalias@libc.org>
Cc: linux-ia64@vger.kernel.org
Cc: linux-sh@vger.kernel.org
Cc: peterz@infradead.org
Cc: Max Filippov <jcmvbkbc@gmail.com>
Cc: sparclinux@vger.kernel.org
Cc: Jonas Bonn <jonas@southpole.se>
Cc: linux-s390@vger.kernel.org
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: linux-hexagon@vger.kernel.org
Cc: Helge Deller <deller@gmx.de>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Matt Turner <mattst88@gmail.com>
Cc: linux-snps-arc@lists.infradead.org
Cc: linux-xtensa@linux-xtensa.org
Cc: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
Cc: openrisc@lists.librecores.org
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Stafford Horne <shorne@gmail.com>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Chris Zankel <chris@zankel.net>
Cc: linux-parisc@vger.kernel.org
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Richard Kuo <rkuo@codeaurora.org>
Cc: linuxppc-dev@lists.ozlabs.org
Link: http://lkml.kernel.org/r/20170824073105.3901-1-jslaby@suse.cz
Cc: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit 48fb6f4db940e92cfb16cd878cddd59ea6120d06 upstream.
Commit 65d8fc777f6d ("futex: Remove requirement for lock_page() in
get_futex_key()") removed an unnecessary lock_page() with the
side-effect that page->mapping needed to be treated very carefully.
Two defensive warnings were added in case any assumption was missed and
the first warning assumed a correct application would not alter a
mapping backing a futex key. Since merging, it has not triggered for
any unexpected case but Mark Rutland reported the following bug
triggering due to the first warning.
kernel BUG at kernel/futex.c:679!
Internal error: Oops - BUG: 0 [#1] PREEMPT SMP
Modules linked in:
CPU: 0 PID: 3695 Comm: syz-executor1 Not tainted 4.13.0-rc3-00020-g307fec773ba3 #3
Hardware name: linux,dummy-virt (DT)
task: ffff80001e271780 task.stack: ffff000010908000
PC is at get_futex_key+0x6a4/0xcf0 kernel/futex.c:679
LR is at get_futex_key+0x6a4/0xcf0 kernel/futex.c:679
pc : [<ffff00000821ac14>] lr : [<ffff00000821ac14>] pstate: 80000145
The fact that it's a bug instead of a warning was due to an unrelated
arm64 problem, but the warning itself triggered because the underlying
mapping changed.
This is an application issue but from a kernel perspective it's a
recoverable situation and the warning is unnecessary so this patch
removes the warning. The warning may potentially be triggered with the
following test program from Mark although it may be necessary to adjust
NR_FUTEX_THREADS to be a value smaller than the number of CPUs in the
system.
#include <linux/futex.h>
#include <pthread.h>
#include <stdio.h>
#include <stdlib.h>
#include <sys/mman.h>
#include <sys/syscall.h>
#include <sys/time.h>
#include <unistd.h>
#define NR_FUTEX_THREADS 16
pthread_t threads[NR_FUTEX_THREADS];
void *mem;
#define MEM_PROT (PROT_READ | PROT_WRITE)
#define MEM_SIZE 65536
static int futex_wrapper(int *uaddr, int op, int val,
const struct timespec *timeout,
int *uaddr2, int val3)
syscall(SYS_futex, uaddr, op, val, timeout, uaddr2, val3);
void *poll_futex(void *unused)
for (;;) {
futex_wrapper(mem, FUTEX_CMP_REQUEUE_PI, 1, NULL, mem + 4, 1);
int main(int argc, char *argv[])
int i;
mem = mmap(NULL, MEM_SIZE, MEM_PROT,
MAP_SHARED | MAP_ANONYMOUS, -1, 0);
printf("Mapping @ %p\n", mem);
printf("Creating futex threads...\n");
for (i = 0; i < NR_FUTEX_THREADS; i++)
pthread_create(&threads[i], NULL, poll_futex, NULL);
printf("Flipping mapping...\n");
for (;;) {
mmap(mem, MEM_SIZE, MEM_PROT,
MAP_FIXED | MAP_SHARED | MAP_ANONYMOUS, -1, 0);
return 0;
Reported-and-tested-by: Mark Rutland <mark.rutland@arm.com>
Cc: stable@vger.kernel.org # 4.7+
commit 76a658c20efd541a62838d9ff68ce94170d7a549 upstream.
Move the calculations of values after the allocation in case the
allocation fails. This avoids wasting effort in the rare case that it
fails, but more importantly saves us extra logic to release the tty
ref.
commit 4411ec1d1993e8dbff2898390e3fed280d88e446 upstream.
> kernel/events/ring_buffer.c:871 perf_mmap_to_page() warn: potential spectre issue 'rb->aux_pages'
Userspace controls @pgoff through the fault address. Sanitize the
array index before doing the array dereference.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Cc: <stable@kernel.org>
commit 50268a3d266ecfdd6c5873d62b2758d9732fc598 upstream.
Fix string fetch function to terminate with NUL.
It is OK to drop the rest of string.
Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org>
Cc: Song Liu <songliubraving@fb.com>
Cc: security@kernel.org
Cc: 范龙飞 <long7573@126.com>
Fixes: 5baaa59ef09e ("tracing/probes: Implement 'memory' fetch method for uprobes")
commit dc432c3d7f9bceb3de6f5b44fb9c657c9810ed6d upstream.
The regex match function regex_match_front() in the tracing filter logic,
was fixed to test just the pattern length from testing the entire test
string. That is, it went from strncmp(str, r->pattern, len) to
strcmp(str, r->pattern, r->len).
The issue is that str is not guaranteed to be nul terminated, and if r->len
is greater than the length of str, it can access more memory than is
allocated.
The solution is to add a simple test if (len < r->len) return 0.
Fixes: 285caad415f45 ("tracing/filters: Fix MATCH_FRONT_ONLY filter matching")
commit bfb3d7b8b906b66551424d7636182126e1d134c8 upstream.
If the get_callchain_buffers fails to allocate the buffer it will
decrease the nr_callchain_events right away.
There's no point of checking the allocation error for
nr_callchain_events > 1. Removing that check.
Signed-off-by: Jiri Olsa <jolsa@kernel.org>
Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: syzkaller-bugs@googlegroups.com
Cc: x86@kernel.org
Link: http://lkml.kernel.org/r/20180415092352.12403-3-jolsa@kernel.org
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
commit d66a270be3310d7aa132fec0cea77d3d32a0ff75 upstream.
Tracepoint should only warn when a kernel API user does not respect the
required preconditions (e.g. same tracepoint enabled twice, or called
to remove a tracepoint that does not exist).
Silence warning in out-of-memory conditions, given that the error is
returned to the caller.
This ensures that out-of-memory error-injection testing does not trigger
warnings in tracepoint.c, which were seen by syzbot.
Link: https://lkml.kernel.org/r/001a114465e241a8720567419a72@google.com
Link: https://lkml.kernel.org/r/001a1140e0de15fc910567464190@google.com
Link: http://lkml.kernel.org/r/20180315124424.32319-1-mathieu.desnoyers@efficios.com
CC: Peter Zijlstra <peterz@infradead.org>
CC: Jiri Olsa <jolsa@redhat.com>
CC: Arnaldo Carvalho de Melo <acme@kernel.org>
CC: Alexander Shishkin <alexander.shishkin@linux.intel.com>
CC: Namhyung Kim <namhyung@kernel.org>
CC: stable@vger.kernel.org
Fixes: de7b2973903c6 ("tracepoint: Use struct pointer instead of name hash for reg/unreg tracepoints")
Reported-by: syzbot+9c0d616860575a73166a@syzkaller.appspotmail.com
Reported-by: syzbot+4e9ae7fa46233396f64d@syzkaller.appspotmail.com
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
commit 8fe45924387be6b5c1be59a7eb330790c61d5d10 upstream.
When iterating through a map, we need to find a key that does not exist
in the map so map_get_next_key will give us the first key of the map.
This often requires a lot of guessing in production systems.
This patch makes map_get_next_key return the first key when the key
pointer in the parameter is NULL.
Signed-off-by: Teng Qin <qinteng@fb.com>
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
Signed-off-by: Chenbo Feng <fengc@google.com>
Cc: Lorenzo Colitti <lorenzo@google.com>
commit 1572e45a924f254d9570093abde46430c3172e3d upstream.
Use "proc_dointvec_minmax" instead of "proc_dointvec" to check the input
value from user-space.
If not, we can set a big value and some vars will overflow like
"sysctl_perf_event_sample_rate" which will cause a lot of unexpected
problems.
Signed-off-by: Tan Xiaojun <tanxiaojun@huawei.com>
Cc: <acme@kernel.org>
Cc: <alexander.shishkin@linux.intel.com>
Link: http://lkml.kernel.org/r/1487829879-56237-1-git-send-email-tanxiaojun@huawei.com
commit 78b562fbfa2cf0a9fcb23c3154756b690f4905c1 upstream.
Return immediately when we find issue in the user stack checks. The
error value could get overwritten by following check for
PERF_SAMPLE_REGS_INTR.
Cc: x86@kernel.org
Fixes: 60e2364e60e8 ("perf: Add ability to sample machine state on interrupt")
Link: http://lkml.kernel.org/r/20180415092352.12403-1-jolsa@kernel.org
commit 60bb83b81169820c691fbfa33a6a4aef32aa4b0b upstream.
We've got a bug report indicating a kernel panic at booting on an x86-32
system, and it turned out to be the invalid PCI resource assigned after
reallocation. __find_resource() first aligns the resource start address
and resets the end address with start+size-1 accordingly, then checks
whether it's contained. Here the end address may overflow the integer,
although resource_contains() still returns true because the function
validates only start and end address. So this ends up with returning an
invalid resource (start > end).
There was already an attempt to cover such a problem in the commit
47ea91b4052d ("Resource: fix wrong resource window calculation"), but
this case is an overseen one.
This patch adds the validity check of the newly calculated resource for
avoiding the integer overflow problem.
Bugzilla: http://bugzilla.opensuse.org/show_bug.cgi?id=1086739
Link: http://lkml.kernel.org/r/s5hpo37d5l8.wl-tiwai@suse.de
Fixes: 23c570a67448 ("resource: ability to resize an allocated resource")
Reported-by: Michael Henders <hendersm@shaw.ca>
Tested-by: Michael Henders <hendersm@shaw.ca>
Cc: Ram Pai <linuxram@us.ibm.com>
Cc: Bjorn Helgaas <bhelgaas@google.com>
commit 65d8fc777f6dcfee12785c057a6b57f679641c90 upstream.
When dealing with key handling for shared futexes, we can drastically reduce
the usage/need of the page lock. 1) For anonymous pages, the associated futex
object is the mm_struct which does not require the page lock. 2) For inode
based, keys, we can check under RCU read lock if the page mapping is still
valid and take reference to the inode. This just leaves one rare race that
requires the page lock in the slow path when examining the swapcache.
Additionally realtime users currently have a problem with the page lock being
contended for unbounded periods of time during futex operations.
Task A
get_futex_key()
lock_page()
---> preempted
Now any other task trying to lock that page will have to wait until
task A gets scheduled back in, which is an unbound time.
With this patch, we pretty much have a lockless futex_get_key().
Experiments show that this patch can boost/speedup the hashing of shared
futexes with the perf futex benchmarks (which is good for measuring such
change) by up to 45% when there are high (> 100) thread counts on a 60 core
Westmere. Lower counts are pretty much in the noise range or less than 10%,
but mid range can be seen at over 30% overall throughput (hash ops/sec).
This makes anon-mem shared futexes much closer to its private counterpart.
[ Ported on top of thp refcount rework, changelog, comments, fixes. ]
Cc: Chris Mason <clm@fb.com>
Cc: Darren Hart <dvhart@linux.intel.com>
Cc: Mel Gorman <mgorman@techsingularity.net>
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Link: http://lkml.kernel.org/r/1455045314-8305-3-git-send-email-dave@stgolabs.net
[ Upstream commit ba5213ae6b88fb170c4771fef6553f759c7d8cdd ]
Andi was asking about PERF_FORMAT_GROUP vs inherited events, which led
to the discovery of a bug from commit:
3dab77fb1bf8 ("perf: Rework/fix the whole read vs group stuff")
- PERF_SAMPLE_GROUP = 1U << 4,
+ PERF_SAMPLE_READ = 1U << 4,
- if (attr->inherit && (attr->sample_type & PERF_SAMPLE_GROUP))
+ if (attr->inherit && (attr->read_format & PERF_FORMAT_GROUP))
is a clear fail :/
While this changes user visible behaviour; it was previously possible
to create an inherited event with PERF_SAMPLE_READ; this is deemed
acceptible because its results were always incorrect.
Reported-by: Andi Kleen <ak@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Cc: Jiri Olsa <jolsa@kernel.org>
Cc: Vince Weaver <vince@deater.net>
Fixes: 3dab77fb1bf8 ("perf: Rework/fix the whole read vs group stuff")
Link: http://lkml.kernel.org/r/20170530094512.dy2nljns2uq7qa3j@hirez.programming.kicks-ass.net
[ Upstream commit 8655d5497735b288f8a9b458bd22e7d1bf95bb61 ]
A customer has reported a soft-lockup when running an intensive
memory stress test, where the trace on multiple CPU's looks like this:
RIP: 0010:[<ffffffff810c53fe>]
[<ffffffff810c53fe>] native_queued_spin_lock_slowpath+0x10e/0x190
Call Trace:
[<ffffffff81182d07>] queued_spin_lock_slowpath+0x7/0xa
[<ffffffff811bc331>] change_protection_range+0x3b1/0x930
[<ffffffff811d4be8>] change_prot_numa+0x18/0x30
[<ffffffff810adefe>] task_numa_work+0x1fe/0x310
[<ffffffff81098322>] task_work_run+0x72/0x90
Further investigation showed that the lock contention here is pmd_lock().
The task_numa_work() function makes sure that only one thread is let to perform
the work in a single scan period (via cmpxchg), but if there's a thread with
mmap_sem locked for writing for several periods, multiple threads in
task_numa_work() can build up a convoy waiting for mmap_sem for read and then
all get unblocked at once.
This patch changes the down_read() to the trylock version, which prevents the
build up. For a workload experiencing mmap_sem contention, it's probably better
to postpone the NUMA balancing work anyway. This seems to have fixed the soft
lockups involving pmd_lock(), which is in line with the convoy theory.
Signed-off-by: Vlastimil Babka <vbabka@suse.cz>
Acked-by: Mel Gorman <mgorman@techsingularity.net>
Link: http://lkml.kernel.org/r/20170515131316.21909-1-vbabka@suse.cz
[ Upstream commit 8896c23d2ef803f1883fea73117a435925c2b4c4 ]
alloc_pidmap() advances pid_namespace::last_pid. When first pid
allocation fails, then next created process will have pid 2 and
pid_ns_prepare_proc() won't be called. So, pid_namespace::proc_mnt will
never be initialized (not to mention that there won't be a child
reaper).
I saw crash stack of such case on kernel 3.10:
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: proc_flush_task+0x8f/0x1b0
Call Trace:
release_task+0x3f/0x490
wait_consider_task.part.10+0x7ff/0xb00
do_wait+0x11f/0x280
SyS_wait4+0x7d/0x110
We may fix this by restore of last_pid in 0 or by prohibiting of futher
allocations. Since there was a similar issue in Oleg Nesterov's commit
314a8ad0f18a ("pidns: fix free_pid() to handle the first fork failure").
and it was fixed via prohibiting allocation, let's follow this way, and
do the same.
Link: http://lkml.kernel.org/r/149201021004.4863.6762095011554287922.stgit@localhost.localdomain
Signed-off-by: Kirill Tkhai <ktkhai@virtuozzo.com>
Acked-by: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Andrei Vagin <avagin@virtuozzo.com>
Cc: Andreas Gruenbacher <agruenba@redhat.com>
Cc: Michael Kerrisk <mtk.manpages@googlemail.com>
Cc: Paul Moore <paul@paul-moore.com>
Cc: Eric Biederman <ebiederm@xmission.com>
Cc: Serge Hallyn <serge@hallyn.com>
commit db0a6fb5d97afe01fd9c47d37c6daa82d4d4001d upstream.
The tty field was missing from AUDIT_LOGIN events.
Refactor code to create a new function audit_get_tty(), using it to
replace the call in audit_log_task_info() and to add it to
audit_log_set_loginuid(). Lock and bump the kref to protect it, adding
audit_put_tty() alias to decrement it.
commit d170fe7dd992b313d4851ae5ab77ee7a51ed8c72 upstream.
This fixes the following clang warning when CONFIG_CPUMASK_OFFSTACK=n:
kernel/irq/manage.c:839:28: error: address of array
'desc->irq_common_data.affinity' will always evaluate to 'true'
[-Werror,-Wpointer-bool-conversion]
Signed-off-by: Matthias Kaehlcke <mka@chromium.org>
Cc: Grant Grundler <grundler@chromium.org>
Cc: Greg Hackmann <ghackmann@google.com>
Cc: Michael Davidson <md@google.com>
Link: http://lkml.kernel.org/r/20170412182030.83657-2-mka@chromium.org
Cc: Nathan Chancellor <natechancellor@gmail.com>
commit c93f5cf571e7795f97d49ef51b766cf25e328545 upstream.
Fix kprobes to set(recover) RWX bits correctly on trampoline
buffer before releasing it. Releasing readonly page to
module_memfree() crash the kernel.
Without this fix, if kprobes user register a bunch of kprobes
in function body (since kprobes on function entry usually
use ftrace) and unregister it, kernel hits a BUG and crash.
Link: http://lkml.kernel.org/r/149570868652.3518.14120169373590420503.stgit@devbox
Fixes: d0381c81c2f7 ("kprobes/x86: Set kprobes pages read-only")
commit f67b15037a7a50c57f72e69a6d59941ad90a0f0f upstream.
Annoyingly, modify_user_hw_breakpoint() unnecessarily complicates the
modification of a breakpoint - simplify it and remove the pointless
local variables.
Also update the stale Docbook while at it.
shared IRQs"
This reverts commit 9d0273bb1c4b645817eccfe5c5975ea29add3300 which is
commit 382bd4de61827dbaaf5fb4fb7b1f4be4a86505e7 upstream.
It causes too many problems with the stable tree, and would require too
many other things to be backported, so just revert it.
Reported-by: Guenter Roeck <linux@roeck-us.net>
Cc: Hans de Goede <hdegoede@redhat.com>
Cc: Marc Zyngier <marc.zyngier@arm.com>
Cc: Sasha Levin <alexander.levin@microsoft.com>
commit 0fa4fe85f4724fff89b09741c437cbee9cf8b008 upstream.
The current check statement in BPF syscall will do a capability check
for CAP_SYS_ADMIN before checking sysctl_unprivileged_bpf_disabled. This
code path will trigger unnecessary security hooks on capability checking
and cause false alarms on unprivileged process trying to get CAP_SYS_ADMIN
access. This can be resolved by simply switch the order of the statement
and CAP_SYS_ADMIN is not required anyway if unprivileged bpf syscall is
allowed.
Acked-by: Lorenzo Colitti <lorenzo@google.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
commit c5d343b6b7badd1f5fe0873eff2e8d63a193e732 upstream.
In Documentation/trace/kprobetrace.txt, it says
@SYM[+|-offs] : Fetch memory at SYM +|- offs (SYM should be a data symbol)
However, the parser doesn't parse minus offset correctly, since
commit 2fba0c8867af ("tracing/kprobes: Fix probe offset to be
unsigned") drops minus ("-") offset support for kprobe probe
address usage.
This fixes the traceprobe_split_symbol_offset() to parse minus
offset again with checking the offset range, and add a minus
offset check in kprobe probe address usage.
Link: http://lkml.kernel.org/r/152129028983.31874.13419301530285775521.stgit@devbox
Cc: Tom Zanussi <tom.zanussi@linux.intel.com>
Cc: Ravi Bangoria <ravi.bangoria@linux.vnet.ibm.com>
Fixes: 2fba0c8867af ("tracing/kprobes: Fix probe offset to be unsigned")
Acked-by: Namhyung Kim <namhyung@kernel.org>
[ Upstream commit 382bd4de61827dbaaf5fb4fb7b1f4be4a86505e7 ]
When requesting a shared irq with IRQF_TRIGGER_NONE then the irqaction
flags get filled with the trigger type from the irq_data:
if (!(new->flags & IRQF_TRIGGER_MASK))
new->flags |= irqd_get_trigger_type(&desc->irq_data);
On the first setup_irq() the trigger type in irq_data is NONE when the
above code executes, then the irq is started up for the first time and
then the actual trigger type gets established, but that's too late to fix
up new->flags.
When then a second user of the irq requests the irq with IRQF_TRIGGER_NONE
its irqaction's triggertype gets set to the actual trigger type and the
following check fails:
if (!((old->flags ^ new->flags) & IRQF_TRIGGER_MASK))
Resulting in the request_irq failing with -EBUSY even though both
users requested the irq with IRQF_SHARED | IRQF_TRIGGER_NONE
Fix this by comparing the new irqaction's trigger type to the trigger type
stored in the irq_data which correctly reflects the actual trigger type
being used for the irq.
Suggested-by: Thomas Gleixner <tglx@linutronix.de>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
Link: http://lkml.kernel.org/r/20170415100831.17073-1-hdegoede@redhat.com
[ Upstream commit d340266e19ddb70dbd608f9deedcfb35fdb9d419 ]
struct timespec is not y2038 safe on 32 bit machines.
The posix clocks apis use struct timespec directly and through struct
itimerspec.
Replace the posix clock interfaces to use struct timespec64 and struct
itimerspec64 instead. Also fix up their implementations accordingly.
Note that the clock_getres() interface has also been changed to use
timespec64 even though this particular interface is not affected by the
y2038 problem. This helps verification for internal kernel code for y2038
readiness by getting rid of time_t/ timeval/ timespec.
Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com>
Cc: arnd@arndb.de
Cc: y2038@lists.linaro.org
Cc: netdev@vger.kernel.org
Cc: john.stultz@linaro.org
Link: http://lkml.kernel.org/r/1490555058-4603-3-git-send-email-deepa.kernel@gmail.com
commit 95a762e2c8c942780948091f8f2a4f32fce1ac6f upstream.
Distinguish between
BPF_ALU64|BPF_MOV|BPF_K (load 32-bit immediate, sign-extended to 64-bit)
and BPF_ALU|BPF_MOV|BPF_K (load 32-bit immediate, zero-padded to 64-bit);
only perform sign extension in the first case.
This patch differs from the mainline one because the verifier's internals
have changed in the meantime. Mainline tracks register values as 64-bit
values; however, 4.4 still stores tracked register values as 32-bit
values with sign extension. Therefore, in the case of a 32-bit op with
negative immediate, the value can't be tracked; leave the register as
UNKNOWN_VALUE (set by the preceding check_reg_arg() call).
I have manually tested this patch on top of 4.4.122. For the following BPF
bytecode:
BPF_MOV64_IMM(BPF_REG_1, 1),
BPF_JMP_IMM(BPF_JEQ, BPF_REG_1, 1, 1),
BPF_EXIT_INSN(),
BPF_MOV32_IMM(BPF_REG_1, 1),
BPF_EXIT_INSN(),
BPF_MOV64_IMM(BPF_REG_1, -1),
BPF_JMP_IMM(BPF_JEQ, BPF_REG_1, -1, 1),
BPF_EXIT_INSN(),
BPF_MOV32_IMM(BPF_REG_1, -1),
BPF_JMP_IMM(BPF_JEQ, BPF_REG_1, -1, 2),
BPF_MOV32_IMM(BPF_REG_0, 42),
BPF_EXIT_INSN(),
BPF_MOV32_IMM(BPF_REG_0, 43),
BPF_EXIT_INSN()
Verifier output on 4.4.122 without this patch:
0: (b7) r1 = 1
1: (15) if r1 == 0x1 goto pc+1
3: (b4) (u32) r1 = (u32) 1
4: (15) if r1 == 0x1 goto pc+1
6: (b7) r1 = -1
7: (15) if r1 == 0xffffffff goto pc+1
9: (b4) (u32) r1 = (u32) -1
10: (15) if r1 == 0xffffffff goto pc+2
13: (b4) (u32) r0 = (u32) 43
14: (95) exit
Verifier output on 4.4.122+ with this patch:
0: (b7) r1 = 1
6: (b7) r1 = -1
R1=inv R10=fp
11: (b4) (u32) r0 = (u32) 42
12: (95) exit
from 10 to 13: R1=imm-1 R10=fp
14: (95) exit
Signed-off-by: Jann Horn <jannh@google.com>
[ Upstream commit a0982dfa03efca6c239c52cabebcea4afb93ea6b ]
The rcutorture test suite occasionally provokes a splat due to invoking
resched_cpu() on an offline CPU:
WARNING: CPU: 2 PID: 8 at /home/paulmck/public_git/linux-rcu/arch/x86/kernel/smp.c:128 native_smp_send_reschedule+0x37/0x40
Modules linked in:
CPU: 2 PID: 8 Comm: rcu_preempt Not tainted 4.14.0-rc4+ #1
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
task: ffff902ede9daf00 task.stack: ffff96c50010c000
RIP: 0010:native_smp_send_reschedule+0x37/0x40
RSP: 0018:ffff96c50010fdb8 EFLAGS: 00010096
RAX: 000000000000002e RBX: ffff902edaab4680 RCX: 0000000000000003
RDX: 0000000080000003 RSI: 0000000000000000 RDI: 00000000ffffffff
RBP: ffff96c50010fdb8 R08: 0000000000000000 R09: 0000000000000001
R10: 0000000000000000 R11: 00000000299f36ae R12: 0000000000000001
R13: ffffffff9de64240 R14: 0000000000000001 R15: ffffffff9de64240
FS: 0000000000000000(0000) GS:ffff902edfc80000(0000) knlGS:0000000000000000
CR2: 00000000f7d4c642 CR3: 000000001e0e2000 CR4: 00000000000006e0
Call Trace:
resched_curr+0x8f/0x1c0
resched_cpu+0x2c/0x40
rcu_implicit_dynticks_qs+0x152/0x220
force_qs_rnp+0x147/0x1d0
? sync_rcu_exp_select_cpus+0x450/0x450
rcu_gp_kthread+0x5a9/0x950
kthread+0x142/0x180
? force_qs_rnp+0x1d0/0x1d0
? kthread_create_on_node+0x40/0x40
ret_from_fork+0x27/0x40
Code: 14 01 0f 92 c0 84 c0 74 14 48 8b 05 14 4f f4 00 be fd 00 00 00 ff 90 a0 00 00 00 5d c3 89 fe 48 c7 c7 38 89 ca 9d e8 e5 56 08 00 <0f> ff 5d c3 0f 1f 44 00 00 8b 05 52 9e 37 02 85 c0 75 38 55 48
---[ end trace 26df9e5df4bba4ac ]---
This splat cannot be generated by expedited grace periods because they
always invoke resched_cpu() on the current CPU, which is good because
expedited grace periods require that resched_cpu() unconditionally
succeed. However, other parts of RCU can tolerate resched_cpu() acting
as a no-op, at least as long as it doesn't happen too often.
This commit therefore makes resched_cpu() invoke resched_curr() only if
the CPU is either online or is the current CPU.
[ Upstream commit 2fe2582649aa2355f79acddb86bd4d6c5363eb63 ]
rt_mutex_lock() which needs to boost the priority of a task currently
sitting on a runqueue that belongs to an offline CPU:
WARNING: CPU: 0 PID: 12 at /home/paulmck/public_git/linux-rcu/arch/x86/kernel/smp.c:128 native_smp_send_reschedule+0x37/0x40
Modules linked in:
CPU: 0 PID: 12 Comm: rcub/7 Not tainted 4.14.0-rc4+ #1
task: ffff9ed3de5f8cc0 task.stack: ffffbbf80012c000
RSP: 0018:ffffbbf80012fd10 EFLAGS: 00010082
RAX: 000000000000002f RBX: ffff9ed3dd9cb300 RCX: 0000000000000004
RDX: 0000000080000004 RSI: 0000000000000086 RDI: 00000000ffffffff
RBP: ffffbbf80012fd10 R08: 000000000009da7a R09: 0000000000007b9d
R10: 0000000000000001 R11: ffffffffbb57c2cd R12: 000000000000000d
R13: ffff9ed3de5f8cc0 R14: 0000000000000061 R15: ffff9ed3ded59200
FS: 0000000000000000(0000) GS:ffff9ed3dea00000(0000) knlGS:0000000000000000
CR2: 00000000080686f0 CR3: 000000001b9e0000 CR4: 00000000000006f0
Call Trace:
resched_curr+0x61/0xd0
switched_to_rt+0x8f/0xa0
rt_mutex_setprio+0x25c/0x410
task_blocks_on_rt_mutex+0x1b3/0x1f0
rt_mutex_slowlock+0xa9/0x1e0
rt_mutex_lock+0x29/0x30
rcu_boost_kthread+0x127/0x3c0
kthread+0x104/0x140
? rcu_report_unblock_qs_rnp+0x90/0x90
ret_from_fork+0x22/0x30
Code: f0 00 0f 92 c0 84 c0 74 14 48 8b 05 34 74 c5 00 be fd 00 00 00 ff 90 a0 00 00 00 5d c3 89 fe 48 c7 c7 a0 c6 fc b9 e8 d5 b5 06 00 <0f> ff 5d c3 0f 1f 44 00 00 8b 05 a2 d1 13 02 85 c0 75 38 55 48
But the target task's priority has already been adjusted, so the only
purpose of switched_to_rt() invoking resched_curr() is to wake up the
CPU running some task that needs to be preempted by the boosted task.
But the CPU is offline, which presumably means that the task must be
migrated to some other CPU, and that this other CPU will undertake any
needed preemption at the time of migration. Because the runqueue lock
is held when resched_curr() is invoked, we know that the boosted task
cannot go anywhere, so it is not necessary to invoke resched_curr()
in this particular case.
This commit therefore makes switched_to_rt() refrain from invoking
resched_curr() when the target CPU is offline.
[ Upstream commit 2ed2b8621be2708c0f6d61fe9841e9ad8b9753f0 ]
commit bbeddf52adc1 ("printk: move braille console support into
separate braille.[ch] files") introduced _braille_console_setup()
to outline the braille initialization code. There was however some
confusion over the value it was supposed to return. commit 2cfe6c4ac7ee
("printk: Fix return of braille_register_console()") tried to fix it
but failed to.
This fixes and documents the returned value according to the use
in printk.c: non-zero return means a parsing error, and thus this
console configuration should be ignored.
Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org>
Cc: Aleksey Makarov <aleksey.makarov@linaro.org>
Cc: Joe Perches <joe@perches.com>
Cc: Ming Lei <ming.lei@canonical.com>
Acked-by: Petr Mladek <pmladek@suse.com>
[ Upstream commit 0107042768658fea9f5f5a9c00b1c90f5dab6a06 ]
On systems with a large number of CPUs, running sysrq-<q> can cause
watchdog timeouts. There are two slow sections of code in the sysrq-<q>
path in timer_list.c.
1. print_active_timers() - This function is called by print_cpu() and
contains a slow goto loop. On a machine with hundreds of CPUs, this
loop took approximately 100ms for the first CPU in a NUMA node.
(Subsequent CPUs in the same node ran much quicker.) The total time
to print all of the CPUs is ultimately long enough to trigger the
soft lockup watchdog.
2. print_tickdevice() - This function outputs a large amount of textual
information. This function also took approximately 100ms per CPU.
Since sysrq-<q> is not a performance critical path, there should be no
harm in touching the nmi watchdog in both slow sections above. Touching
it in just one location was insufficient on systems with hundreds of
CPUs as occasional timeouts were still observed during testing.
This issue was observed on an Oracle T7 machine with 128 CPUs, but I
anticipate it may affect other systems with similarly large numbers of
CPUs.
Signed-off-by: Tom Hromatka <tom.hromatka@oracle.com>
Reviewed-by: Rob Gardner <rob.gardner@oracle.com>
[ Upstream commit 1b8955bc5ac575009835e371ae55e7f3af2197a9 ]
The scheduler clock framework may not use the correct timeout for the clock
wrap. This happens when a new clock driver calls sched_clock_register()
after the kernel called sched_clock_postinit(). In this case the clock wrap
timeout is too long thus sched_clock_poll() is called too late and the clock
already wrapped.
On my ARM system the scheduler was no longer scheduling any other task than
the idle task because the sched_clock() wrapped.
Signed-off-by: David Engraf <david.engraf@sysgo.com>
