commit 021de3d904b88b1771a3a2cfc5b75023c391e646 upstream.
After writting a test to try to trigger the bug that caused the
ring buffer iterator to become corrupted, I hit another bug:
WARNING: CPU: 1 PID: 5281 at kernel/trace/ring_buffer.c:3766 rb_iter_peek+0x113/0x238()
Modules linked in: ipt_MASQUERADE sunrpc [...]
CPU: 1 PID: 5281 Comm: grep Tainted: G W 3.16.0-rc3-test+ #143
Hardware name: To Be Filled By O.E.M. To Be Filled By O.E.M./To be filled by O.E.M., BIOS SDBLI944.86P 05/08/2007
0000000000000000 ffffffff81809a80 ffffffff81503fb0 0000000000000000
ffffffff81040ca1 ffff8800796d6010 ffffffff810c138d ffff8800796d6010
ffff880077438c80 ffff8800796d6010 ffff88007abbe600 0000000000000003
Call Trace:
[<ffffffff81503fb0>] ? dump_stack+0x4a/0x75
[<ffffffff81040ca1>] ? warn_slowpath_common+0x7e/0x97
[<ffffffff810c138d>] ? rb_iter_peek+0x113/0x238
[<ffffffff810c14df>] ? ring_buffer_iter_peek+0x2d/0x5c
[<ffffffff810c6f73>] ? tracing_iter_reset+0x6e/0x96
[<ffffffff810c74a3>] ? s_start+0xd7/0x17b
[<ffffffff8112b13e>] ? kmem_cache_alloc_trace+0xda/0xea
[<ffffffff8114cf94>] ? seq_read+0x148/0x361
[<ffffffff81132d98>] ? vfs_read+0x93/0xf1
[<ffffffff81132f1b>] ? SyS_read+0x60/0x8e
[<ffffffff8150bf9f>] ? tracesys+0xdd/0xe2
Debugging this bug, which triggers when the rb_iter_peek() loops too
many times (more than 2 times), I discovered there's a case that can
cause that function to legitimately loop 3 times!
rb_iter_peek() is different than rb_buffer_peek() as the rb_buffer_peek()
only deals with the reader page (it's for consuming reads). The
rb_iter_peek() is for traversing the buffer without consuming it, and as
such, it can loop for one more reason. That is, if we hit the end of
the reader page or any page, it will go to the next page and try again.
That is, we have this:
1. iter->head > iter->head_page->page->commit
(rb_inc_iter() which moves the iter to the next page)
try again
2. event = rb_iter_head_event()
event->type_len == RINGBUF_TYPE_TIME_EXTEND
rb_advance_iter()
try again
3. read the event.
But we never get to 3, because the count is greater than 2 and we
cause the WARNING and return NULL.
Up the counter to 3.
Fixes: 69d1b839f7ee "ring-buffer: Bind time extend and data events together"
commit 651e22f2701b4113989237c3048d17337dd2185c upstream.
When performing a consuming read, the ring buffer swaps out a
page from the ring buffer with a empty page and this page that
was swapped out becomes the new reader page. The reader page
is owned by the reader and since it was swapped out of the ring
buffer, writers do not have access to it (there's an exception
to that rule, but it's out of scope for this commit).
When reading the "trace" file, it is a non consuming read, which
means that the data in the ring buffer will not be modified.
When the trace file is opened, a ring buffer iterator is allocated
and writes to the ring buffer are disabled, such that the iterator
will not have issues iterating over the data.
Although the ring buffer disabled writes, it does not disable other
reads, or even consuming reads. If a consuming read happens, then
the iterator is reset and starts reading from the beginning again.
My tests would sometimes trigger this bug on my i386 box:
WARNING: CPU: 0 PID: 5175 at kernel/trace/trace.c:1527 __trace_find_cmdline+0x66/0xaa()
Modules linked in:
CPU: 0 PID: 5175 Comm: grep Not tainted 3.16.0-rc3-test+ #8
Hardware name: /DG965MQ, BIOS MQ96510J.86A.0372.2006.0605.1717 06/05/2006
00000000 00000000 f09c9e1c c18796b3 c1b5d74c f09c9e4c c103a0e3 c1b5154b
f09c9e78 00001437 c1b5d74c 000005f7 c10bd85a c10bd85a c1cac57c f09c9eb0
ed0e0000 f09c9e64 c103a185 00000009 f09c9e5c c1b5154b f09c9e78 f09c9e80^M
Call Trace:
[<c18796b3>] dump_stack+0x4b/0x75
[<c103a0e3>] warn_slowpath_common+0x7e/0x95
[<c10bd85a>] ? __trace_find_cmdline+0x66/0xaa
[<c103a185>] warn_slowpath_fmt+0x33/0x35
[<c10bd85a>] __trace_find_cmdline+0x66/0xaa^M
[<c10bed04>] trace_find_cmdline+0x40/0x64
[<c10c3c16>] trace_print_context+0x27/0xec
[<c10c4360>] ? trace_seq_printf+0x37/0x5b
[<c10c0b15>] print_trace_line+0x319/0x39b
[<c10ba3fb>] ? ring_buffer_read+0x47/0x50
[<c10c13b1>] s_show+0x192/0x1ab
[<c10bfd9a>] ? s_next+0x5a/0x7c
[<c112e76e>] seq_read+0x267/0x34c
[<c1115a25>] vfs_read+0x8c/0xef
[<c112e507>] ? seq_lseek+0x154/0x154
[<c1115ba2>] SyS_read+0x54/0x7f
[<c188488e>] syscall_call+0x7/0xb
---[ end trace 3f507febd6b4cc83 ]---
>>>> ##### CPU 1 buffer started ####
Which was the __trace_find_cmdline() function complaining about the pid
in the event record being negative.
After adding more test cases, this would trigger more often. Strangely
enough, it would never trigger on a single test, but instead would trigger
only when running all the tests. I believe that was the case because it
required one of the tests to be shutting down via delayed instances while
a new test started up.
After spending several days debugging this, I found that it was caused by
the iterator becoming corrupted. Debugging further, I found out why
the iterator became corrupted. It happened with the rb_iter_reset().
As consuming reads may not read the full reader page, and only part
of it, there's a "read" field to know where the last read took place.
The iterator, must also start at the read position. In the rb_iter_reset()
code, if the reader page was disconnected from the ring buffer, the iterator
would start at the head page within the ring buffer (where writes still
happen). But the mistake there was that it still used the "read" field
to start the iterator on the head page, where it should always start
at zero because readers never read from within the ring buffer where
writes occur.
I originally wrote a patch to have it set the iter->head to 0 instead
of iter->head_page->read, but then I questioned why it wasn't always
setting the iter to point to the reader page, as the reader page is
still valid. The list_empty(reader_page->list) just means that it was
successful in swapping out. But the reader_page may still have data.
There was a bug report a long time ago that was not reproducible that
had something about trace_pipe (consuming read) not matching trace
(iterator read). This may explain why that happened.
Anyway, the correct answer to this bug is to always use the reader page
an not reset the iterator to inside the writable ring buffer.
Fixes: d769041f8653 "ring_buffer: implement new locking"
commit 618fde872163e782183ce574c77f1123e2be8887 upstream.
The rarely-executed memry-allocation-failed callback path generates a
WARN_ON_ONCE() when smp_call_function_single() succeeds. Presumably
it's supposed to warn on failures.
Cc: Christoph Lameter <cl@gentwo.org>
Cc: Gilad Ben-Yossef <gilad@benyossef.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Tejun Heo <htejun@gmail.com>
commit 7d8b6c63751cfbbe5eef81a48c22978b3407a3ad upstream.
This is effectively a revert of 7b9a7ec565505699f503b4fcf61500dceb36e744
plus fixing it a different way...
We found, when trying to run an application from an application which
had dropped privs that the kernel does security checks on undefined
capability bits. This was ESPECIALLY difficult to debug as those
undefined bits are hidden from /proc/$PID/status.
Consider a root application which drops all capabilities from ALL 4
capability sets. We assume, since the application is going to set
eff/perm/inh from an array that it will clear not only the defined caps
less than CAP_LAST_CAP, but also the higher 28ish bits which are
undefined future capabilities.
The BSET gets cleared differently. Instead it is cleared one bit at a
time. The problem here is that in security/commoncap.c::cap_task_prctl()
we actually check the validity of a capability being read. So any task
which attempts to 'read all things set in bset' followed by 'unset all
things set in bset' will not even attempt to unset the undefined bits
higher than CAP_LAST_CAP.
So the 'parent' will look something like:
CapInh: 0000000000000000
CapPrm: 0000000000000000
CapEff: 0000000000000000
CapBnd: ffffffc000000000
All of this 'should' be fine. Given that these are undefined bits that
aren't supposed to have anything to do with permissions. But they do...
So lets now consider a task which cleared the eff/perm/inh completely
and cleared all of the valid caps in the bset (but not the invalid caps
it couldn't read out of the kernel). We know that this is exactly what
the libcap-ng library does and what the go capabilities library does.
They both leave you in that above situation if you try to clear all of
you capapabilities from all 4 sets. If that root task calls execve()
the child task will pick up all caps not blocked by the bset. The bset
however does not block bits higher than CAP_LAST_CAP. So now the child
task has bits in eff which are not in the parent. These are
'meaningless' undefined bits, but still bits which the parent doesn't
have.
The problem is now in cred_cap_issubset() (or any operation which does a
subset test) as the child, while a subset for valid cap bits, is not a
subset for invalid cap bits! So now we set durring commit creds that
the child is not dumpable. Given it is 'more priv' than its parent. It
also means the parent cannot ptrace the child and other stupidity.
The solution here:
1) stop hiding capability bits in status
This makes debugging easier!
2) stop giving any task undefined capability bits. it's simple, it you
don't put those invalid bits in CAP_FULL_SET you won't get them in init
and you won't get them in any other task either.
This fixes the cap_issubset() tests and resulting fallout (which
made the init task in a docker container untraceable among other
things)
3) mask out undefined bits when sys_capset() is called as it might use
~0, ~0 to denote 'all capabilities' for backward/forward compatibility.
This lets 'capsh --caps="all=eip" -- -c /bin/bash' run.
4) mask out undefined bit when we read a file capability off of disk as
again likely all bits are set in the xattr for forward/backward
compatibility.
This lets 'setcap all+pe /bin/bash; /bin/bash' run
Signed-off-by: Eric Paris <eparis@redhat.com>
Cc: Andrew Vagin <avagin@openvz.org>
Cc: Andrew G. Morgan <morgan@kernel.org>
Cc: Serge E. Hallyn <serge.hallyn@canonical.com>
Cc: Steve Grubb <sgrubb@redhat.com>
Cc: Dan Walsh <dwalsh@redhat.com>
Signed-off-by: James Morris <james.l.morris@oracle.com>
commit 13c42c2f43b19aab3195f2d357db00d1e885eaa8 upstream.
futex_wait_requeue_pi() calls futex_wait_setup(). If
futex_wait_setup() succeeds it returns with hb->lock held and
preemption disabled. Now the sanity check after this does:
if (match_futex(&q.key, &key2)) {
ret = -EINVAL;
goto out_put_keys;
which releases the keys but does not release hb->lock.
So we happily return to user space with hb->lock held and therefor
Unlock hb->lock before taking the exit route.
Reported-by: Dave "Trinity" Jones <davej@redhat.com>
Reviewed-by: Darren Hart <dvhart@linux.intel.com>
Reviewed-by: Davidlohr Bueso <dave@stgolabs.net>
Cc: stable@vger.kernel.org
Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1409112318500.4178@nanos
commit 84c91b7ae07c62cf6dee7fde3277f4be21331f85 upstream.
When the machine doesn't well handle the e820 persistent when hibernate
resuming, then it may cause page fault when writing image to snapshot
buffer:
[ 17.929495] BUG: unable to handle kernel paging request at ffff880069d4f000
[ 17.933469] IP: [<ffffffff810a1cf0>] load_image_lzo+0x810/0xe40
[ 17.933469] PGD 2194067 PUD 77ffff067 PMD 2197067 PTE 0
[ 17.933469] Oops: 0002 [#1] SMP
The ffff880069d4f000 page is in e820 reserved region of resume boot
kernel:
[ 0.000000] BIOS-e820: [mem 0x0000000069d4f000-0x0000000069e12fff] reserved
[ 0.000000] PM: Registered nosave memory: [mem 0x69d4f000-0x69e12fff]
So snapshot.c mark the pfn to forbidden pages map. But, this
page is also in the memory bitmap in snapshot image because it's an
original page used by image kernel, so it will also mark as an
unsafe(free) page in prepare_image().
That means the page in e820 when resuming mark as "forbidden" and
"free", it causes get_buffer() treat it as an allocated unsafe page.
Then snapshot_write_next() return this page to load_image, load_image
writing content to this address, but this page didn't really allocated
. So, we got page fault.
Although the root cause is from BIOS, I think aggressive check and
significant message in kernel will better then a page fault for
issue tracking, especially when serial console unavailable.
This patch adds code in mark_unsafe_pages() for check does free pages in
nosave region. If so, then it print message and return fault to stop whole
S4 resume process:
[ 8.166004] PM: Image loading progress: 0%
[ 8.658717] PM: 0x6796c000 in e820 nosave region: [mem 0x6796c000-0x6796cfff]
[ 8.918737] PM: Read 2511940 kbytes in 1.04 seconds (2415.32 MB/s)
[ 8.926633] PM: Error -14 resuming
[ 8.933534] PM: Failed to load hibernation image, recovering.
Reviewed-by: Takashi Iwai <tiwai@suse.de>
Acked-by: Pavel Machek <pavel@ucw.cz>
Signed-off-by: Lee, Chun-Yi <jlee@suse.com>
[rjw: Subject]
commit 504d58745c9ca28d33572e2d8a9990b43e06075d upstream.
clockevents_increase_min_delta() calls printk() from under
hrtimer_bases.lock. That causes lock inversion on scheduler locks because
printk() can call into the scheduler. Lockdep puts it as:
[ INFO: possible circular locking dependency detected ]
3.15.0-rc8-06195-g939f04b #2 Not tainted
trinity-main/74 is trying to acquire lock:
(&port_lock_key){-.....}, at: [<811c60be>] serial8250_console_write+0x8c/0x10c
but task is already holding lock:
(hrtimer_bases.lock){-.-...}, at: [<8103caeb>] hrtimer_try_to_cancel+0x13/0x66
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #5 (hrtimer_bases.lock){-.-...}:
[<8104a942>] lock_acquire+0x92/0x101
[<8142f11d>] _raw_spin_lock_irqsave+0x2e/0x3e
[<8103c918>] __hrtimer_start_range_ns+0x1c/0x197
[<8107ec20>] perf_swevent_start_hrtimer.part.41+0x7a/0x85
[<81080792>] task_clock_event_start+0x3a/0x3f
[<810807a4>] task_clock_event_add+0xd/0x14
[<8108259a>] event_sched_in+0xb6/0x17a
[<810826a2>] group_sched_in+0x44/0x122
[<81082885>] ctx_sched_in.isra.67+0x105/0x11f
[<810828e6>] perf_event_sched_in.isra.70+0x47/0x4b
[<81082bf6>] __perf_install_in_context+0x8b/0xa3
[<8107eb8e>] remote_function+0x12/0x2a
[<8105f5af>] smp_call_function_single+0x2d/0x53
[<8107e17d>] task_function_call+0x30/0x36
[<8107fb82>] perf_install_in_context+0x87/0xbb
[<810852c9>] SYSC_perf_event_open+0x5c6/0x701
[<810856f9>] SyS_perf_event_open+0x17/0x19
[<8142f8ee>] syscall_call+0x7/0xb
-> #4 (&ctx->lock){......}:
[<8142f04c>] _raw_spin_lock+0x21/0x30
[<81081df3>] __perf_event_task_sched_out+0x1dc/0x34f
[<8142cacc>] __schedule+0x4c6/0x4cb
[<8142cae0>] schedule+0xf/0x11
[<8142f9a6>] work_resched+0x5/0x30
-> #3 (&rq->lock){-.-.-.}:
[<81040873>] __task_rq_lock+0x33/0x3a
[<8104184c>] wake_up_new_task+0x25/0xc2
[<8102474b>] do_fork+0x15c/0x2a0
[<810248a9>] kernel_thread+0x1a/0x1f
[<814232a2>] rest_init+0x1a/0x10e
[<817af949>] start_kernel+0x303/0x308
[<817af2ab>] i386_start_kernel+0x79/0x7d
-> #2 (&p->pi_lock){-.-...}:
[<810413dd>] try_to_wake_up+0x1d/0xd6
[<810414cd>] default_wake_function+0xb/0xd
[<810461f3>] __wake_up_common+0x39/0x59
[<81046346>] __wake_up+0x29/0x3b
[<811b8733>] tty_wakeup+0x49/0x51
[<811c3568>] uart_write_wakeup+0x17/0x19
[<811c5dc1>] serial8250_tx_chars+0xbc/0xfb
[<811c5f28>] serial8250_handle_irq+0x54/0x6a
[<811c5f57>] serial8250_default_handle_irq+0x19/0x1c
[<811c56d8>] serial8250_interrupt+0x38/0x9e
[<810510e7>] handle_irq_event_percpu+0x5f/0x1e2
[<81051296>] handle_irq_event+0x2c/0x43
[<81052cee>] handle_level_irq+0x57/0x80
[<81002a72>] handle_irq+0x46/0x5c
[<810027df>] do_IRQ+0x32/0x89
[<8143036e>] common_interrupt+0x2e/0x33
[<8142f23c>] _raw_spin_unlock_irqrestore+0x3f/0x49
[<811c25a4>] uart_start+0x2d/0x32
[<811c2c04>] uart_write+0xc7/0xd6
[<811bc6f6>] n_tty_write+0xb8/0x35e
[<811b9beb>] tty_write+0x163/0x1e4
[<811b9cd9>] redirected_tty_write+0x6d/0x75
[<810b6ed6>] vfs_write+0x75/0xb0
[<810b7265>] SyS_write+0x44/0x77
-> #1 (&tty->write_wait){-.....}:
[<81046332>] __wake_up+0x15/0x3b
-> #0 (&port_lock_key){-.....}:
[<8104a62d>] __lock_acquire+0x9ea/0xc6d
[<8104e402>] call_console_drivers.constprop.31+0x87/0x118
[<8104f5d5>] console_unlock+0x1d7/0x398
[<8104fb70>] vprintk_emit+0x3da/0x3e4
[<81425f76>] printk+0x17/0x19
[<8105bfa0>] clockevents_program_min_delta+0x104/0x116
[<8105c548>] clockevents_program_event+0xe7/0xf3
[<8105cc1c>] tick_program_event+0x1e/0x23
[<8103c43c>] hrtimer_force_reprogram+0x88/0x8f
[<8103c49e>] __remove_hrtimer+0x5b/0x79
[<8103cb21>] hrtimer_try_to_cancel+0x49/0x66
[<8103cb4b>] hrtimer_cancel+0xd/0x18
[<8107f102>] perf_swevent_cancel_hrtimer.part.60+0x2b/0x30
[<81080705>] task_clock_event_stop+0x20/0x64
[<81080756>] task_clock_event_del+0xd/0xf
[<81081350>] event_sched_out+0xab/0x11e
[<810813e0>] group_sched_out+0x1d/0x66
[<81081682>] ctx_sched_out+0xaf/0xbf
[<81081e04>] __perf_event_task_sched_out+0x1ed/0x34f
Chain exists of:
&port_lock_key --> &ctx->lock --> hrtimer_bases.lock
Possible unsafe locking scenario:
CPU0 CPU1
lock(hrtimer_bases.lock);
lock(&ctx->lock);
lock(&port_lock_key);
*** DEADLOCK ***
4 locks held by trinity-main/74:
#0: (&rq->lock){-.-.-.}, at: [<8142c6f3>] __schedule+0xed/0x4cb
#1: (&ctx->lock){......}, at: [<81081df3>] __perf_event_task_sched_out+0x1dc/0x34f
#2: (hrtimer_bases.lock){-.-...}, at: [<8103caeb>] hrtimer_try_to_cancel+0x13/0x66
#3: (console_lock){+.+...}, at: [<8104fb5d>] vprintk_emit+0x3c7/0x3e4
stack backtrace:
CPU: 0 PID: 74 Comm: trinity-main Not tainted 3.15.0-rc8-06195-g939f04b #2
00000000 81c3a310 8b995c14 81426f69 8b995c44 81425a99 8161f671 8161f570
8161f538 8161f559 8161f538 8b995c78 8b142bb0 00000004 8b142fdc 8b142bb0
8b995ca8 8104a62d 8b142fac 000016f2 81c3a310 00000001 00000001 00000003
Call Trace:
[<81426f69>] dump_stack+0x16/0x18
[<81425a99>] print_circular_bug+0x18f/0x19c
[<811c60be>] ? serial8250_console_write+0x8c/0x10c
[<811c6032>] ? wait_for_xmitr+0x76/0x76
[<8104af87>] ? lock_release+0x191/0x223
[<8104416d>] ? __dequeue_entity+0x23/0x27
[<81044505>] ? pick_next_task_fair+0xb1/0x120
[<81047574>] ? trace_hardirqs_off_caller+0xd7/0x108
[<810475b0>] ? trace_hardirqs_off+0xb/0xd
[<81056346>] ? rcu_irq_exit+0x64/0x77
Fix the problem by using printk_deferred() which does not call into the
scheduler.
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
commit aac74dc495456412c4130a1167ce4beb6c1f0b38 upstream.
After learning we'll need some sort of deferred printk functionality in
the timekeeping core, Peter suggested we rename the printk_sched function
so it can be reused by needed subsystems.
This only changes the function name. No logic changes.
Signed-off-by: John Stultz <john.stultz@linaro.org>
Reviewed-by: Steven Rostedt <rostedt@goodmis.org>
Cc: Jan Kara <jack@suse.cz>
Cc: Jiri Bohac <jbohac@suse.cz>
commit 58d4e21e50ff3cc57910a8abc20d7e14375d2f61 upstream.
The "uptime" trace clock added in:
commit 8aacf017b065a805d27467843490c976835eb4a5
tracing: Add "uptime" trace clock that uses jiffies
has wraparound problems when the system has been up more
than 1 hour 11 minutes and 34 seconds. It converts jiffies
to nanoseconds using:
(u64)jiffies_to_usecs(jiffy) * 1000ULL
but since jiffies_to_usecs() only returns a 32-bit value, it
truncates at 2^32 microseconds. An additional problem on 32-bit
systems is that the argument is "unsigned long", so fixing the
return value only helps until 2^32 jiffies (49.7 days on a HZ=1000
system).
Avoid these problems by using jiffies_64 as our basis, and
not converting to nanoseconds (we do convert to clock_t because
user facing API must not be dependent on internal kernel
HZ values).
Link: http://lkml.kernel.org/p/99d63c5bfe9b320a3b428d773825a37095bf6a51.1405708254.git.tony.luck@intel.com
Fixes: 8aacf017b065 "tracing: Add "uptime" trace clock that uses jiffies"
Signed-off-by: Tony Luck <tony.luck@intel.com>
commit b0ab99e7736af88b8ac1b7ae50ea287fffa2badc upstream.
proc_sched_show_task() does:
if (nr_switches)
do_div(avg_atom, nr_switches);
nr_switches is unsigned long and do_div truncates it to 32 bits, which
means it can test non-zero on e.g. x86-64 and be truncated to zero for
division.
Fix the problem by using div64_ul() instead.
As a side effect calculations of avg_atom for big nr_switches are now correct.
Signed-off-by: Mateusz Guzik <mguzik@redhat.com>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/1402750809-31991-1-git-send-email-mguzik@redhat.com
commit 4badad352a6bb202ec68afa7a574c0bb961e5ebc upstream.
The optimistic spin code assumes regular stores and cmpxchg() play nice;
this is found to not be true for at least: parisc, sparc32, tile32,
metag-lock1, arc-!llsc and hexagon.
There is further wreckage, but this in particular seemed easy to
trigger, so blacklist this.
Opt in for known good archs.
Reported-by: Mikulas Patocka <mpatocka@redhat.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Cc: James Bottomley <James.Bottomley@hansenpartnership.com>
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Jason Low <jason.low2@hp.com>
Cc: Waiman Long <waiman.long@hp.com>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Paul McKenney <paulmck@linux.vnet.ibm.com>
Cc: John David Anglin <dave.anglin@bell.net>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: Davidlohr Bueso <davidlohr@hp.com>
Cc: linuxppc-dev@lists.ozlabs.org
Cc: sparclinux@vger.kernel.org
Link: http://lkml.kernel.org/r/20140606175316.GV13930@laptop.programming.kicks-ass.net
commit 4320f6b1d9db4ca912c5eb6ecb328b2e090e1586 upstream.
The commit [247bc037: PM / Sleep: Mitigate race between the freezer
and request_firmware()] introduced the finer state control, but it
also leads to a new bug; for example, a bug report regarding the
firmware loading of intel BT device at suspend/resume:
https://bugzilla.novell.com/show_bug.cgi?id=873790
The root cause seems to be a small window between the process resume
and the clear of usermodehelper lock. The request_firmware() function
checks the UMH lock and gives up when it's in UMH_DISABLE state. This
is for avoiding the invalid f/w loading during suspend/resume phase.
The problem is, however, that usermodehelper_enable() is called at the
end of thaw_processes(). Thus, a thawed process in between can kick
off the f/w loader code path (in this case, via btusb_setup_intel())
even before the call of usermodehelper_enable(). Then
usermodehelper_read_trylock() returns an error and request_firmware()
spews WARN_ON() in the end.
This oneliner patch fixes the issue just by setting to UMH_FREEZING
state again before restarting tasks, so that the call of
request_firmware() will be blocked until the end of this function
instead of returning an error.
Fixes: 247bc0374254 (PM / Sleep: Mitigate race between the freezer and request_firmware())
Link: https://bugzilla.novell.com/show_bug.cgi?id=873790
commit 16927776ae757d0d132bdbfabbfe2c498342bd59 upstream.
Sharvil noticed with the posix timer_settime interface, using the
CLOCK_REALTIME_ALARM or CLOCK_BOOTTIME_ALARM clockid, if the users
tried to specify a relative time timer, it would incorrectly be
treated as absolute regardless of the state of the flags argument.
This patch corrects this, properly checking the absolute/relative flag,
as well as adds further error checking that no invalid flag bits are set.
Reported-by: Sharvil Nanavati <sharvil@google.com>
Cc: Prarit Bhargava <prarit@redhat.com>
Cc: Sharvil Nanavati <sharvil@google.com>
Link: http://lkml.kernel.org/r/1404767171-6902-1-git-send-email-john.stultz@linaro.org
commit 97b8ee845393701edc06e27ccec2876ff9596019 upstream.
ring_buffer_poll_wait() should always put the poll_table to its wait_queue
even there is immediate data available. Otherwise, the following epoll and
read sequence will eventually hang forever:
1. Put some data to make the trace_pipe ring_buffer read ready first
2. epoll_ctl(efd, EPOLL_CTL_ADD, trace_pipe_fd, ee)
3. epoll_wait()
4. read(trace_pipe_fd) till EAGAIN
5. Add some more data to the trace_pipe ring_buffer
6. epoll_wait() -> this epoll_wait() will block forever
~ During the epoll_ctl(efd, EPOLL_CTL_ADD,...) call in step 2,
ring_buffer_poll_wait() returns immediately without adding poll_table,
which has poll_table->_qproc pointing to ep_poll_callback(), to its
wait_queue.
~ During the epoll_wait() call in step 3 and step 6,
ring_buffer_poll_wait() cannot add ep_poll_callback() to its wait_queue
because the poll_table->_qproc is NULL and it is how epoll works.
~ When there is new data available in step 6, ring_buffer does not know
it has to call ep_poll_callback() because it is not in its wait queue.
Hence, block forever.
Other poll implementation seems to call poll_wait() unconditionally as the very
first thing to do. For example, tcp_poll() in tcp.c.
Link: http://lkml.kernel.org/p/20140610060637.GA14045@devbig242.prn2.facebook.com
Fixes: 2a2cc8f7c4d0 "ftrace: allow the event pipe to be polled"
Reviewed-by: Chris Mason <clm@fb.com>
Signed-off-by: Martin Lau <kafai@fb.com>
commit f0160a5a2912267c02cfe692eac955c360de5fdf upstream.
The TRACE_ITER_PRINTK check in __trace_puts/__trace_bputs is missing,
so add it, to be consistent with __trace_printk/__trace_bprintk.
Those functions are all called by the same function: trace_printk().
Link: http://lkml.kernel.org/p/51E7A7D6.8090900@huawei.com
Signed-off-by: zhangwei(Jovi) <jovi.zhangwei@huawei.com>
commit 8abfb8727f4a724d31f9ccfd8013fbd16d539445 upstream.
Currently trace option stacktrace is not applicable for
trace_printk with constant string argument, the reason is
in __trace_puts/__trace_bputs ftrace_trace_stack is missing.
In contrast, when using trace_printk with non constant string
argument(will call into __trace_printk/__trace_bprintk), then
trace option stacktrace is workable, this inconstant result
will confuses users a lot.
Link: http://lkml.kernel.org/p/51E7A7C9.9040401@huawei.com
commit 5f8bf2d263a20b986225ae1ed7d6759dc4b93af9 upstream.
Running my ftrace tests on PowerPC, it failed the test that checks
if function_graph tracer is affected by the stack tracer. It was.
Looking into this, I found that the update_function_graph_func()
must be called even if the trampoline function is not changed.
This is because archs like PowerPC do not support ftrace_ops being
passed by assembly and instead uses a helper function (what the
trampoline function points to). Since this function is not changed
even when multiple ftrace_ops are added to the code, the test that
falls out before calling update_function_graph_func() will miss that
the update must still be done.
Call update_function_graph_function() for all calls to
update_ftrace_function()
commit 8b8b36834d0fff67fc8668093f4312dd04dcf21d upstream.
The per_cpu buffers are created one per possible CPU. But these do
not mean that those CPUs are online, nor do they even exist.
With the addition of the ring buffer polling, it assumes that the
caller polls on an existing buffer. But this is not the case if
the user reads trace_pipe from a CPU that does not exist, and this
causes the kernel to crash.
Simple fix is to check the cpu against buffer bitmask against to see
if the buffer was allocated or not and return -ENODEV if it is
not.
More updates were done to pass the -ENODEV back up to userspace.
Link: http://lkml.kernel.org/r/5393DB61.6060707@oracle.com
Reported-by: Sasha Levin <sasha.levin@oracle.com>
commit 5a6024f1604eef119cf3a6fa413fe0261a81a8f3 upstream.
When hot-adding and onlining CPU, kernel panic occurs, showing following
call trace.
BUG: unable to handle kernel paging request at 0000000000001d08
IP: [<ffffffff8114acfd>] __alloc_pages_nodemask+0x9d/0xb10
PGD 0
Oops: 0000 [#1] SMP
Call Trace:
[<ffffffff812b8745>] ? cpumask_next_and+0x35/0x50
[<ffffffff810a3283>] ? find_busiest_group+0x113/0x8f0
[<ffffffff81193bc9>] ? deactivate_slab+0x349/0x3c0
[<ffffffff811926f1>] new_slab+0x91/0x300
[<ffffffff815de95a>] __slab_alloc+0x2bb/0x482
[<ffffffff8105bc1c>] ? copy_process.part.25+0xfc/0x14c0
[<ffffffff810a3c78>] ? load_balance+0x218/0x890
[<ffffffff8101a679>] ? sched_clock+0x9/0x10
[<ffffffff81105ba9>] ? trace_clock_local+0x9/0x10
[<ffffffff81193d1c>] kmem_cache_alloc_node+0x8c/0x200
[<ffffffff8105bc1c>] copy_process.part.25+0xfc/0x14c0
[<ffffffff81114d0d>] ? trace_buffer_unlock_commit+0x4d/0x60
[<ffffffff81085a80>] ? kthread_create_on_node+0x140/0x140
[<ffffffff8105d0ec>] do_fork+0xbc/0x360
[<ffffffff8105d3b6>] kernel_thread+0x26/0x30
[<ffffffff81086652>] kthreadd+0x2c2/0x300
[<ffffffff81086390>] ? kthread_create_on_cpu+0x60/0x60
[<ffffffff815f20ec>] ret_from_fork+0x7c/0xb0
In my investigation, I found the root cause is wq_numa_possible_cpumask.
All entries of wq_numa_possible_cpumask is allocated by
alloc_cpumask_var_node(). And these entries are used without initializing.
So these entries have wrong value.
When hot-adding and onlining CPU, wq_update_unbound_numa() is called.
wq_update_unbound_numa() calls alloc_unbound_pwq(). And alloc_unbound_pwq()
calls get_unbound_pool(). In get_unbound_pool(), worker_pool->node is set
as follow:
3592 /* if cpumask is contained inside a NUMA node, we belong to that node */
3593 if (wq_numa_enabled) {
3594 for_each_node(node) {
3595 if (cpumask_subset(pool->attrs->cpumask,
3596 wq_numa_possible_cpumask[node])) {
3597 pool->node = node;
3598 break;
3599 }
3600 }
3601 }
But wq_numa_possible_cpumask[node] does not have correct cpumask. So, wrong
node is selected. As a result, kernel panic occurs.
By this patch, all entries of wq_numa_possible_cpumask are allocated by
zalloc_cpumask_var_node to initialize them. And the panic disappeared.
Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Fixes: bce903809ab3 ("workqueue: add wq_numa_tbl_len and wq_numa_possible_cpumask[]")
commit 391acf970d21219a2a5446282d3b20eace0c0d7a upstream.
When runing with the kernel(3.15-rc7+), the follow bug occurs:
[ 9969.258987] BUG: sleeping function called from invalid context at kernel/locking/mutex.c:586
[ 9969.359906] in_atomic(): 1, irqs_disabled(): 0, pid: 160655, name: python
[ 9969.441175] INFO: lockdep is turned off.
[ 9969.488184] CPU: 26 PID: 160655 Comm: python Tainted: G A 3.15.0-rc7+ #85
[ 9969.581032] Hardware name: FUJITSU-SV PRIMEQUEST 1800E/SB, BIOS PRIMEQUEST 1000 Series BIOS Version 1.39 11/16/2012
[ 9969.706052] ffffffff81a20e60 ffff8803e941fbd0 ffffffff8162f523 ffff8803e941fd18
[ 9969.795323] ffff8803e941fbe0 ffffffff8109995a ffff8803e941fc58 ffffffff81633e6c
[ 9969.884710] ffffffff811ba5dc ffff880405c6b480 ffff88041fdd90a0 0000000000002000
[ 9969.974071] Call Trace:
[ 9970.003403] [<ffffffff8162f523>] dump_stack+0x4d/0x66
[ 9970.065074] [<ffffffff8109995a>] __might_sleep+0xfa/0x130
[ 9970.130743] [<ffffffff81633e6c>] mutex_lock_nested+0x3c/0x4f0
[ 9970.200638] [<ffffffff811ba5dc>] ? kmem_cache_alloc+0x1bc/0x210
[ 9970.272610] [<ffffffff81105807>] cpuset_mems_allowed+0x27/0x140
[ 9970.344584] [<ffffffff811b1303>] ? __mpol_dup+0x63/0x150
[ 9970.409282] [<ffffffff811b1385>] __mpol_dup+0xe5/0x150
[ 9970.471897] [<ffffffff811b1303>] ? __mpol_dup+0x63/0x150
[ 9970.536585] [<ffffffff81068c86>] ? copy_process.part.23+0x606/0x1d40
[ 9970.613763] [<ffffffff810bf28d>] ? trace_hardirqs_on+0xd/0x10
[ 9970.683660] [<ffffffff810ddddf>] ? monotonic_to_bootbased+0x2f/0x50
[ 9970.759795] [<ffffffff81068cf0>] copy_process.part.23+0x670/0x1d40
[ 9970.834885] [<ffffffff8106a598>] do_fork+0xd8/0x380
[ 9970.894375] [<ffffffff81110e4c>] ? __audit_syscall_entry+0x9c/0xf0
[ 9970.969470] [<ffffffff8106a8c6>] SyS_clone+0x16/0x20
[ 9971.030011] [<ffffffff81642009>] stub_clone+0x69/0x90
[ 9971.091573] [<ffffffff81641c29>] ? system_call_fastpath+0x16/0x1b
The cause is that cpuset_mems_allowed() try to take
mutex_lock(&callback_mutex) under the rcu_read_lock(which was hold in
__mpol_dup()). And in cpuset_mems_allowed(), the access to cpuset is
under rcu_read_lock, so in __mpol_dup, we can reduce the rcu_read_lock
protection region to protect the access to cpuset only in
current_cpuset_is_being_rebound(). So that we can avoid this bug.
This patch is a temporary solution that just addresses the bug
mentioned above, can not fix the long-standing issue about cpuset.mems
rebinding on fork():
"When the forker's task_struct is duplicated (which includes
->mems_allowed) and it races with an update to cpuset_being_rebound
in update_tasks_nodemask() then the task's mems_allowed doesn't get
updated. And the child task's mems_allowed can be wrong if the
cpuset's nodemask changes before the child has been added to the
cgroup's tasklist."
Signed-off-by: Gu Zheng <guz.fnst@cn.fujitsu.com>
Acked-by: Li Zefan <lizefan@huawei.com>
commit bddbceb688c6d0decaabc7884fede319d02f96c8 upstream.
Uevents are suppressed during attributes registration, but never
restored, so kobject_uevent() does nothing.
Signed-off-by: Maxime Bizon <mbizon@freebox.fr>
Fixes: 226223ab3c4118ddd10688cc2c131135848371ab
commit 099ed151675cd1d2dbeae1dac697975f6a68716d upstream.
Disabling reading and writing to the trace file should not be able to
disable all function tracing callbacks. There's other users today
(like kprobes and perf). Reading a trace file should not stop those
from happening.
Reviewed-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
commit 7cd2b0a34ab8e4db971920eef8982f985441adfb upstream.
Oleg reports a division by zero error on zero-length write() to the
percpu_pagelist_fraction sysctl:
divide error: 0000 [#1] SMP DEBUG_PAGEALLOC
CPU: 1 PID: 9142 Comm: badarea_io Not tainted 3.15.0-rc2-vm-nfs+ #19
Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
task: ffff8800d5aeb6e0 ti: ffff8800d87a2000 task.ti: ffff8800d87a2000
RIP: 0010: percpu_pagelist_fraction_sysctl_handler+0x84/0x120
RSP: 0018:ffff8800d87a3e78 EFLAGS: 00010246
RAX: 0000000000000f89 RBX: ffff88011f7fd000 RCX: 0000000000000000
RDX: 0000000000000000 RSI: 0000000000000001 RDI: 0000000000000010
RBP: ffff8800d87a3e98 R08: ffffffff81d002c8 R09: ffff8800d87a3f50
R10: 000000000000000b R11: 0000000000000246 R12: 0000000000000060
R13: ffffffff81c3c3e0 R14: ffffffff81cfddf8 R15: ffff8801193b0800
FS: 00007f614f1e9740(0000) GS:ffff88011f440000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 00007f614f1fa000 CR3: 00000000d9291000 CR4: 00000000000006e0
Call Trace:
proc_sys_call_handler+0xb3/0xc0
proc_sys_write+0x14/0x20
vfs_write+0xba/0x1e0
SyS_write+0x46/0xb0
tracesys+0xe1/0xe6
However, if the percpu_pagelist_fraction sysctl is set by the user, it
is also impossible to restore it to the kernel default since the user
cannot write 0 to the sysctl.
This patch allows the user to write 0 to restore the default behavior.
It still requires a fraction equal to or larger than 8, however, as
stated by the documentation for sanity. If a value in the range [1, 7]
is written, the sysctl will return EINVAL.
This successfully solves the divide by zero issue at the same time.
Signed-off-by: David Rientjes <rientjes@google.com>
Reported-by: Oleg Drokin <green@linuxhacker.ru>
commit 4af4206be2bd1933cae20c2b6fb2058dbc887f7c upstream.
syscall_regfunc() and syscall_unregfunc() should set/clear
TIF_SYSCALL_TRACEPOINT system-wide, but do_each_thread() can race
with copy_process() and miss the new child which was not added to
the process/thread lists yet.
Change copy_process() to update the child's TIF_SYSCALL_TRACEPOINT
under tasklist.
Link: http://lkml.kernel.org/p/20140413185854.GB20668@redhat.com
Fixes: a871bd33a6c0 "tracing: Add syscall tracepoints"
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
commit 379cfdac37923653c9d4242d10052378b7563005 upstream.
In order to prevent the saved cmdline cache from being filled when
tracing is not active, the comms are only recorded after a trace event
is recorded.
The problem is, a comm can fail to be recorded if the trace_cmdline_lock
is held. That lock is taken via a trylock to allow it to happen from
any context (including NMI). If the lock fails to be taken, the comm
is skipped. No big deal, as we will try again later.
But! Because of the code that was added to only record after an event,
we may not try again later as the recording is made as a oneshot per
event per CPU.
Only disable the recording of the comm if the comm is actually recorded.
Fixes: 7ffbd48d5cab "tracing: Cache comms only after an event occurred"
commit 27e35715df54cbc4f2d044f681802ae30479e7fb upstream.
When the rtmutex fast path is enabled the slow unlock function can
create the following situation:
spin_lock(foo->m->wait_lock);
foo->m->owner = NULL;
rt_mutex_lock(foo->m); <-- fast path
free = atomic_dec_and_test(foo->refcnt);
rt_mutex_unlock(foo->m); <-- fast path
if (free)
kfree(foo);
spin_unlock(foo->m->wait_lock); <--- Use after free.
Plug the race by changing the slow unlock to the following scheme:
while (!rt_mutex_has_waiters(m)) {
/* Clear the waiters bit in m->owner */
clear_rt_mutex_waiters(m);
owner = rt_mutex_owner(m);
spin_unlock(m->wait_lock);
if (cmpxchg(m->owner, owner, 0) == owner)
return;
spin_lock(m->wait_lock);
So in case of a new waiter incoming while the owner tries the slow
path unlock we have two situations:
unlock(wait_lock);
lock(wait_lock);
cmpxchg(p, owner, 0) == owner
mark_rt_mutex_waiters(lock);
acquire(lock);
Or:
unlock(wait_lock);
lock(wait_lock);
cmpxchg(p, owner, 0) != owner
enqueue_waiter();
unlock(wait_lock);
lock(wait_lock);
wakeup_next waiter();
unlock(wait_lock);
lock(wait_lock);
acquire(lock);
If the fast path is disabled, then the simple
m->owner = NULL;
is sufficient as all access to m->owner is serialized via
m->wait_lock;
Also document and clarify the wakeup_next_waiter function as suggested
by Oleg Nesterov.
Reported-by: Steven Rostedt <rostedt@goodmis.org>
Link: http://lkml.kernel.org/r/20140611183852.937945560@linutronix.de
Signed-off-by: Mike Galbraith <umgwanakikbuti@gmail.com>
commit 3d5c9340d1949733eb37616abd15db36aef9a57c upstream.
Even in the case when deadlock detection is not requested by the
caller, we can detect deadlocks. Right now the code stops the lock
chain walk and keeps the waiter enqueued, even on itself. Silly not to
yell when such a scenario is detected and to keep the waiter enqueued.
Return -EDEADLK unconditionally and handle it at the call sites.
The futex calls return -EDEADLK. The non futex ones dequeue the
waiter, throw a warning and put the task into a schedule loop.
Tagged for stable as it makes the code more robust.
Cc: Brad Mouring <bmouring@ni.com>
Link: http://lkml.kernel.org/r/20140605152801.836501969@linutronix.de
commit 82084984383babe728e6e3c9a8e5c46278091315 upstream.
When we walk the lock chain, we drop all locks after each step. So the
lock chain can change under us before we reacquire the locks. That's
harmless in principle as we just follow the wrong lock path. But it
can lead to a false positive in the dead lock detection logic:
T0 holds L0
T0 blocks on L1 held by T1
T1 blocks on L2 held by T2
T2 blocks on L3 held by T3
T4 blocks on L4 held by T4
Now we walk the chain
lock T1 -> lock L2 -> adjust L2 -> unlock T1 ->
lock T2 -> adjust T2 -> drop locks
T2 times out and blocks on L0
Now we continue:
lock T2 -> lock L0 -> deadlock detected, but it's not a deadlock at all.
Brad tried to work around that in the deadlock detection logic itself,
but the more I looked at it the less I liked it, because it's crystal
ball magic after the fact.
We actually can detect a chain change very simple:
lock T1 -> lock L2 -> adjust L2 -> unlock T1 -> lock T2 -> adjust T2 ->
next_lock = T2->pi_blocked_on->lock;
drop locks
Now we continue:
lock T2 ->
if (next_lock != T2->pi_blocked_on->lock)
return;
So if we detect that T2 is now blocked on a different lock we stop the
chain walk. That's also correct in the following scenario:
drop locks
T3 times out and drops L3
T2 acquires L3 and blocks on L4 now
Now we continue:
lock T2 ->
return;
We don't have to follow up the chain at that point, because T2
propagated our priority up to T4 already.
[ Folded a cleanup patch from peterz ]
Reported-by: Brad Mouring <bmouring@ni.com>
Link: http://lkml.kernel.org/r/20140605152801.930031935@linutronix.de
commit 397335f004f41e5fcf7a795e94eb3ab83411a17c upstream.
The current deadlock detection logic does not work reliably due to the
following early exit path:
* Drop out, when the task has no waiters. Note,
* top_waiter can be NULL, when we are in the deboosting
* mode!
if (top_waiter && (!task_has_pi_waiters(task) ||
top_waiter != task_top_pi_waiter(task)))
goto out_unlock_pi;
So this not only exits when the task has no waiters, it also exits
unconditionally when the current waiter is not the top priority waiter
of the task.
So in a nested locking scenario, it might abort the lock chain walk
and therefor miss a potential deadlock.
Simple fix: Continue the chain walk, when deadlock detection is
enabled.
We also avoid the whole enqueue, if we detect the deadlock right away
(A-A). It's an optimization, but also prevents that another waiter who
comes in after the detection and before the task has undone the damage
observes the situation and detects the deadlock and returns
-EDEADLOCK, which is wrong as the other task is not in a deadlock
situation.
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
Link: http://lkml.kernel.org/r/20140522031949.725272460@linutronix.de
commit 1e77d0a1ed7417d2a5a52a7b8d32aea1833faa6c upstream.
Till reported that the spurious interrupt detection of threaded
interrupts is broken in two ways:
- note_interrupt() is called for each action thread of a shared
interrupt line. That's wrong as we are only interested whether none
of the device drivers felt responsible for the interrupt, but by
calling multiple times for a single interrupt line we account
IRQ_NONE even if one of the drivers felt responsible.
- note_interrupt() when called from the thread handler is not
serialized. That leaves the members of irq_desc which are used for
the spurious detection unprotected.
To solve this we need to defer the spurious detection of a threaded
interrupt to the next hardware interrupt context where we have
implicit serialization.
If note_interrupt is called with action_ret == IRQ_WAKE_THREAD, we
check whether the previous interrupt requested a deferred check. If
not, we request a deferred check for the next hardware interrupt and
return.
If set, we check whether one of the interrupt threads signaled
success. Depending on this information we feed the result into the
spurious detector.
If one primary handler of a shared interrupt returns IRQ_HANDLED we
disable the deferred check of irq threads on the same line, as we have
found at least one device driver who cared.
Reported-by: Till Straumann <strauman@slac.stanford.edu>
Tested-by: Austin Schuh <austin@peloton-tech.com>
Cc: Oliver Hartkopp <socketcan@hartkopp.net>
Cc: Wolfgang Grandegger <wg@grandegger.com>
Cc: Pavel Pisa <pisa@cmp.felk.cvut.cz>
Cc: Marc Kleine-Budde <mkl@pengutronix.de>
Cc: linux-can@vger.kernel.org
Link: http://lkml.kernel.org/r/alpine.LFD.2.02.1303071450130.22263@ionos
commit 4e52365f279564cef0ddd41db5237f0471381093 upstream.
When tracing a process in another pid namespace, it's important for fork
event messages to contain the child's pid as seen from the tracer's pid
namespace, not the parent's. Otherwise, the tracer won't be able to
correlate the fork event with later SIGTRAP signals it receives from the
child.
We still risk a race condition if a ptracer from a different pid
namespace attaches after we compute the pid_t value. However, sending a
bogus fork event message in this unlikely scenario is still a vast
improvement over the status quo where we always send bogus fork event
messages to debuggers in a different pid namespace than the forking
process.
Signed-off-by: Matthew Dempsky <mdempsky@chromium.org>
Acked-by: Oleg Nesterov <oleg@redhat.com>
Cc: Julien Tinnes <jln@chromium.org>
Cc: Roland McGrath <mcgrathr@chromium.org>
Cc: Jan Kratochvil <jan.kratochvil@redhat.com>
commit cadefd3d6cc914d95163ba1eda766bfe7ce1e5b7 upstream.
Mike reported that, while unlikely, its entirely possible for
scale_rt_power() to see the time go backwards. This yields rather
'interesting' results.
So like all other sites that deal with clocks; make this one ignore
backward clock movement too.
Reported-by: Mike Galbraith <bitbucket@online.de>
Link: http://lkml.kernel.org/r/20140227094035.GZ9987@twins.programming.kicks-ass.net
commit 27630532ef5ead28b98cfe28d8f95222ef91c2b7 upstream.
Since commit d689fe222 (NOHZ: Check for nohz active instead of nohz
enabled) the tick_nohz_switch_to_nohz() function returns because it
checks for the tick_nohz_active flag. This can't be set, because the
function itself sets it.
Undo the change in tick_nohz_switch_to_nohz().
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Cc: linaro-kernel@lists.linaro.org
Cc: fweisbec@gmail.com
Cc: Arvind.Chauhan@arm.com
Cc: linaro-networking@linaro.org
Cc: <stable@vger.kernel.org> # 3.13+
Link: http://lkml.kernel.org/r/40939c05f2d65d781b92b20302b02243d0654224.1397537987.git.viresh.kumar@linaro.org
commit 9390675af0835ae1d654d33bfcf16096028550ad upstream.
This reverts commit 282cf499f03ec1754b6c8c945c9674b02631fb0f.
With the current implementation, the load average statistics of a sched entity
change according to other activity on the CPU even if this activity is done
between the running window of the sched entity and have no influence on the
running duration of the task.
When a task wakes up on the same CPU, we currently update last_runnable_update
with the return of __synchronize_entity_decay without updating the
runnable_avg_sum and runnable_avg_period accordingly. In fact, we have to sync
the load_contrib of the se with the rq's blocked_load_contrib before removing
it from the latter (with __synchronize_entity_decay) but we must keep
last_runnable_update unchanged for updating runnable_avg_sum/period during the
next update_entity_load_avg.
Signed-off-by: Vincent Guittot <vincent.guittot@linaro.org>
Reviewed-by: Ben Segall <bsegall@google.com>
Cc: pjt@google.com
Cc: alex.shi@linaro.org
Link: http://lkml.kernel.org/r/1390376734-6800-1-git-send-email-vincent.guittot@linaro.org
[ Upstream commit 90f62cf30a78721641e08737bda787552428061e ]
It is possible by passing a netlink socket to a more privileged
executable and then to fool that executable into writing to the socket
data that happens to be valid netlink message to do something that
privileged executable did not intend to do.
To keep this from happening replace bare capable and ns_capable calls
with netlink_capable, netlink_net_calls and netlink_ns_capable calls.
Which act the same as the previous calls except they verify that the
opener of the socket had the desired permissions as well.
Reported-by: Andy Lutomirski <luto@amacapital.net>
commit a3c54931199565930d6d84f4c3456f6440aefd41 upstream.
Fixes an easy DoS and possible information disclosure.
This does nothing about the broken state of x32 auditing.
eparis: If the admin has enabled auditd and has specifically loaded
audit rules. This bug has been around since before git. Wow...
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
commit 23adbe12ef7d3d4195e80800ab36b37bee28cd03 upstream.
The kernel has no concept of capabilities with respect to inodes; inodes
exist independently of namespaces. For example, inode_capable(inode,
CAP_LINUX_IMMUTABLE) would be nonsense.
This patch changes inode_capable to check for uid and gid mappings and
renames it to capable_wrt_inode_uidgid, which should make it more
obvious what it does.
Fixes CVE-2014-4014.
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Serge Hallyn <serge.hallyn@ubuntu.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
commit 6acbfb96976fc3350e30d964acb1dbbdf876d55e upstream.
Lai found that:
WARNING: CPU: 1 PID: 13 at arch/x86/kernel/smp.c:124 native_smp_send_reschedule+0x2d/0x4b()
migration_cpu_stop+0x1d/0x22
was caused by set_cpus_allowed_ptr() assuming that cpu_active_mask is
always a sub-set of cpu_online_mask.
This isn't true since 5fbd036b552f ("sched: Cleanup cpu_active madness").
So set active and online at the same time to avoid this particular
problem.
Fixes: 5fbd036b552f ("sched: Cleanup cpu_active madness")
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: Gautham R. Shenoy <ego@linux.vnet.ibm.com>
Cc: Michael wang <wangyun@linux.vnet.ibm.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
Cc: Toshi Kani <toshi.kani@hp.com>
Link: http://lkml.kernel.org/r/53758B12.8060609@cn.fujitsu.com
commit 46ce0fe97a6be7532ce6126bb26ce89fed81528c upstream.
When removing a (sibling) event we do:
raw_spin_lock_irq(&ctx->lock);
perf_group_detach(event);
raw_spin_unlock_irq(&ctx->lock);
<hole>
perf_remove_from_context(event);
Now, assuming the event is a sibling, it will be 'unreachable' for
things like ctx_sched_out() because that iterates the
groups->siblings, and we just unhooked the sibling.
So, if during <hole> we get ctx_sched_out(), it will miss the event
and not call event_sched_out() on it, leaving it programmed on the
PMU.
The subsequent perf_remove_from_context() call will find the ctx is
inactive and only call list_del_event() to remove the event from all
other lists.
Hereafter we can proceed to free the event; while still programmed!
Close this hole by moving perf_group_detach() inside the same
ctx->lock region(s) perf_remove_from_context() has.
The condition on inherited events only in __perf_event_exit_task() is
likely complete crap because non-inherited events are part of groups
too and we're tearing down just the same. But leave that for another
patch.
Most-likely-Fixes: e03a9a55b4e ("perf: Change close() semantics for group events")
Reported-by: Vince Weaver <vincent.weaver@maine.edu>
Tested-by: Vince Weaver <vincent.weaver@maine.edu>
Much-staring-at-traces-by: Vince Weaver <vincent.weaver@maine.edu>
Much-staring-at-traces-by: Thomas Gleixner <tglx@linutronix.de>
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Link: http://lkml.kernel.org/r/20140505093124.GN17778@laptop.programming.kicks-ass.net
commit 0819b2e30ccb93edf04876237b6205eef84ec8d2 upstream.
Vince reported that using a large sample_period (one with bit 63 set)
results in wreckage since while the sample_period is fundamentally
unsigned (negative periods don't make sense) the way we implement
things very much rely on signed logic.
So limit sample_period to 63 bits to avoid tripping over this.
Link: http://lkml.kernel.org/n/tip-p25fhunibl4y3qi0zuqmyf4b@git.kernel.org
commit 39af6b1678afa5880dda7e375cf3f9d395087f6d upstream.
The perf cpu offline callback takes down all cpu context
events and releases swhash->swevent_hlist.
This could race with task context software event being just
scheduled on this cpu via perf_swevent_add while cpu hotplug
code already cleaned up event's data.
The race happens in the gap between the cpu notifier code
and the cpu being actually taken down. Note that only cpu
ctx events are terminated in the perf cpu hotplug code.
It's easily reproduced with:
$ perf record -e faults perf bench sched pipe
while putting one of the cpus offline:
# echo 0 > /sys/devices/system/cpu/cpu1/online
Console emits following warning:
WARNING: CPU: 1 PID: 2845 at kernel/events/core.c:5672 perf_swevent_add+0x18d/0x1a0()
Modules linked in:
CPU: 1 PID: 2845 Comm: sched-pipe Tainted: G W 3.14.0+ #256
Hardware name: Intel Corporation Montevina platform/To be filled by O.E.M., BIOS AMVACRB1.86C.0066.B00.0805070703 05/07/2008
0000000000000009 ffff880077233ab8 ffffffff81665a23 0000000000200005
0000000000000000 ffff880077233af8 ffffffff8104732c 0000000000000046
ffff88007467c800 0000000000000002 ffff88007a9cf2a0 0000000000000001
Call Trace:
[<ffffffff81665a23>] dump_stack+0x4f/0x7c
[<ffffffff8104732c>] warn_slowpath_common+0x8c/0xc0
[<ffffffff8104737a>] warn_slowpath_null+0x1a/0x20
[<ffffffff8110fb3d>] perf_swevent_add+0x18d/0x1a0
[<ffffffff811162ae>] event_sched_in.isra.75+0x9e/0x1f0
[<ffffffff8111646a>] group_sched_in+0x6a/0x1f0
[<ffffffff81083dd5>] ? sched_clock_local+0x25/0xa0
[<ffffffff811167e6>] ctx_sched_in+0x1f6/0x450
[<ffffffff8111757b>] perf_event_sched_in+0x6b/0xa0
[<ffffffff81117a4b>] perf_event_context_sched_in+0x7b/0xc0
[<ffffffff81117ece>] __perf_event_task_sched_in+0x43e/0x460
[<ffffffff81096f1e>] ? put_lock_stats.isra.18+0xe/0x30
[<ffffffff8107b3c8>] finish_task_switch+0xb8/0x100
[<ffffffff8166a7de>] __schedule+0x30e/0xad0
[<ffffffff81172dd2>] ? pipe_read+0x3e2/0x560
[<ffffffff8166b45e>] ? preempt_schedule_irq+0x3e/0x70
[<ffffffff8166b464>] preempt_schedule_irq+0x44/0x70
[<ffffffff816707f0>] retint_kernel+0x20/0x30
[<ffffffff8109e60a>] ? lockdep_sys_exit+0x1a/0x90
[<ffffffff812a4234>] lockdep_sys_exit_thunk+0x35/0x67
[<ffffffff81679321>] ? sysret_check+0x5/0x56
Fixing this by tracking the cpu hotplug state and displaying
the WARN only if current cpu is initialized properly.
Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Signed-off-by: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/r/1396861448-10097-1-git-send-email-jolsa@redhat.com
commit 2d513868e2a33e1d5315490ef4c861ee65babd65 upstream.
Russell reported, that irqtime_account_idle_ticks() takes ages due to:
for (i = 0; i < ticks; i++)
irqtime_account_process_tick(current, 0, rq);
It's sad, that this code was written way _AFTER_ the NOHZ idle
functionality was available. I charge myself guitly for not paying
attention when that crap got merged with commit abb74cefa ("sched:
Export ns irqtimes through /proc/stat")
So instead of looping nr_ticks times just apply the whole thing at
once.
As a side note: The whole cputime_t vs. u64 business in that context
wants to be cleaned up as well. There is no point in having all these
back and forth conversions. Lets standardise on u64 nsec for all
kernel internal accounting and be done with it. Everything else does
not make sense at all for fine grained accounting. Frederic, can you
please take care of that?
Reported-by: Russell King <rmk+kernel@arm.linux.org.uk>
Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Venkatesh Pallipadi <venki@google.com>
Cc: Shaun Ruffell <sruffell@digium.com>
Link: http://lkml.kernel.org/r/alpine.DEB.2.02.1405022307000.6261@ionos.tec.linutronix.de
commit 6227cb00cc120f9a43ce8313bb0475ddabcb7d01 upstream.
The check at the beginning of cpupri_find() makes sure that the task_pri
variable does not exceed the cp->pri_to_cpu array length. But that length
is CPUPRI_NR_PRIORITIES not MAX_RT_PRIO, where it will miss the last two
priorities in that array.
As task_pri is computed from convert_prio() which should never be bigger
than CPUPRI_NR_PRIORITIES, if the check should cause a panic if it is
hit.
Reported-by: Mike Galbraith <umgwanakikbuti@gmail.com>
Link: http://lkml.kernel.org/r/1397015410.5212.13.camel@marge.simpson.net
commit 54a217887a7b658e2650c3feff22756ab80c7339 upstream.
The current implementation of lookup_pi_state has ambigous handling of
the TID value 0 in the user space futex. We can get into the kernel
even if the TID value is 0, because either there is a stale waiters bit
or the owner died bit is set or we are called from the requeue_pi path
or from user space just for fun.
The current code avoids an explicit sanity check for pid = 0 in case
that kernel internal state (waiters) are found for the user space
address. This can lead to state leakage and worse under some
circumstances.
Handle the cases explicit:
Waiter | pi_state | pi->owner | uTID | uODIED | ?
[1] NULL | --- | --- | 0 | 0/1 | Valid
[2] NULL | --- | --- | >0 | 0/1 | Valid
[3] Found | NULL | -- | Any | 0/1 | Invalid
[4] Found | Found | NULL | 0 | 1 | Valid
[5] Found | Found | NULL | >0 | 1 | Invalid
[6] Found | Found | task | 0 | 1 | Valid
[7] Found | Found | NULL | Any | 0 | Invalid
[8] Found | Found | task | ==taskTID | 0/1 | Valid
[9] Found | Found | task | 0 | 0 | Invalid
[10] Found | Found | task | !=taskTID | 0/1 | Invalid
[1] Indicates that the kernel can acquire the futex atomically. We
came came here due to a stale FUTEX_WAITERS/FUTEX_OWNER_DIED bit.
[2] Valid, if TID does not belong to a kernel thread. If no matching
thread is found then it indicates that the owner TID has died.
[3] Invalid. The waiter is queued on a non PI futex
[4] Valid state after exit_robust_list(), which sets the user space
value to FUTEX_WAITERS | FUTEX_OWNER_DIED.
[5] The user space value got manipulated between exit_robust_list()
and exit_pi_state_list()
[6] Valid state after exit_pi_state_list() which sets the new owner in
the pi_state but cannot access the user space value.
[7] pi_state->owner can only be NULL when the OWNER_DIED bit is set.
[8] Owner and user space value match
[9] There is no transient state which sets the user space TID to 0
except exit_robust_list(), but this is indicated by the
FUTEX_OWNER_DIED bit. See [4]
[10] There is no transient state which leaves owner and user space
TID out of sync.
Cc: Will Drewry <wad@chromium.org>
Cc: Darren Hart <dvhart@linux.intel.com>
commit 13fbca4c6ecd96ec1a1cfa2e4f2ce191fe928a5e upstream.
If the owner died bit is set at futex_unlock_pi, we currently do not
cleanup the user space futex. So the owner TID of the current owner
(the unlocker) persists. That's observable inconsistant state,
especially when the ownership of the pi state got transferred.
Clean it up unconditionally.
commit b3eaa9fc5cd0a4d74b18f6b8dc617aeaf1873270 upstream.
We need to protect the atomic acquisition in the kernel against rogue
user space which sets the user space futex to 0, so the kernel side
acquisition succeeds while there is existing state in the kernel
associated to the real owner.
Verify whether the futex has waiters associated with kernel state. If
it has, return -EINVAL. The state is corrupted already, so no point in
cleaning it up. Subsequent calls will fail as well. Not our problem.
[ tglx: Use futex_top_waiter() and explain why we do not need to try
restoring the already corrupted user space state. ]
Signed-off-by: Darren Hart <dvhart@linux.intel.com>
in futex_requeue(..., requeue_pi=1)
commit e9c243a5a6de0be8e584c604d353412584b592f8 upstream.
If uaddr == uaddr2, then we have broken the rule of only requeueing from
a non-pi futex to a pi futex with this call. If we attempt this, then
dangling pointers may be left for rt_waiter resulting in an exploitable
condition.
This change brings futex_requeue() in line with futex_wait_requeue_pi()
which performs the same check as per commit 6f7b0a2a5c0f ("futex: Forbid
uaddr == uaddr2 in futex_wait_requeue_pi()")
[ tglx: Compare the resulting keys as well, as uaddrs might be
different depending on the mapping ]
Fixes CVE-2014-3153.
Reported-by: Pinkie Pie
Signed-off-by: Will Drewry <wad@chromium.org>
commit 011e4b02f1da156ac7fea28a9da878f3c23af739 upstream.
If we try to perform a kexec when the machine is in ST (Single-Threaded) mode
(ppc64_cpu --smt=off), the kexec operation doesn't succeed properly, and we
get the following messages during boot:
[ 0.089866] POWER8 performance monitor hardware support registered
[ 0.089985] power8-pmu: PMAO restore workaround active.
[ 5.095419] Processor 1 is stuck.
[ 10.097933] Processor 2 is stuck.
[ 15.100480] Processor 3 is stuck.
[ 20.102982] Processor 4 is stuck.
[ 25.105489] Processor 5 is stuck.
[ 30.108005] Processor 6 is stuck.
[ 35.110518] Processor 7 is stuck.
[ 40.113369] Processor 9 is stuck.
[ 45.115879] Processor 10 is stuck.
[ 50.118389] Processor 11 is stuck.
[ 55.120904] Processor 12 is stuck.
[ 60.123425] Processor 13 is stuck.
[ 65.125970] Processor 14 is stuck.
[ 70.128495] Processor 15 is stuck.
[ 75.131316] Processor 17 is stuck.
Note that only the sibling threads are stuck, while the primary threads (0, 8,
16 etc) boot just fine. Looking closer at the previous step of kexec, we observe
that kexec tries to wakeup (bring online) the sibling threads of all the cores,
before performing kexec:
[ 9464.131231] Starting new kernel
[ 9464.148507] kexec: Waking offline cpu 1.
[ 9464.148552] kexec: Waking offline cpu 2.
[ 9464.148600] kexec: Waking offline cpu 3.
[ 9464.148636] kexec: Waking offline cpu 4.
[ 9464.148671] kexec: Waking offline cpu 5.
[ 9464.148708] kexec: Waking offline cpu 6.
[ 9464.148743] kexec: Waking offline cpu 7.
[ 9464.148779] kexec: Waking offline cpu 9.
[ 9464.148815] kexec: Waking offline cpu 10.
[ 9464.148851] kexec: Waking offline cpu 11.
[ 9464.148887] kexec: Waking offline cpu 12.
[ 9464.148922] kexec: Waking offline cpu 13.
[ 9464.148958] kexec: Waking offline cpu 14.
[ 9464.148994] kexec: Waking offline cpu 15.
[ 9464.149030] kexec: Waking offline cpu 17.
Instrumenting this piece of code revealed that the cpu_up() operation actually
fails with -EBUSY. Thus, only the primary threads of all the cores are online
during kexec, and hence this is a sure-shot receipe for disaster, as explained
in commit e8e5c2155b (powerpc/kexec: Fix orphaned offline CPUs across kexec),
as well as in the comment above wake_offline_cpus().
It turns out that cpu_up() was returning -EBUSY because the variable
'cpu_hotplug_disabled' was set to 1; and this disabling of CPU hotplug was done
by migrate_to_reboot_cpu() inside kernel_kexec().
Now, migrate_to_reboot_cpu() was originally written with the assumption that
any further code will not need to perform CPU hotplug, since we are anyway in
the reboot path. However, kexec is clearly not such a case, since we depend on
onlining CPUs, atleast on powerpc.
So re-enable cpu-hotplug after returning from migrate_to_reboot_cpu() in the
kexec path, to fix this regression in kexec on powerpc.
Also, wrap the cpu_up() in powerpc kexec code within a WARN_ON(), so that we
can catch such issues more easily in the future.
Fixes: c97102ba963 (kexec: migrate to reboot cpu)
Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
commit 4d595b866d2c653dc90a492b9973a834eabfa354 upstream.
After a @pwq is scheduled for emergency execution, other workers may
consume the affectd work items before the rescuer gets to them. This
means that a workqueue many have pwqs queued on @wq->maydays list
while not having any work item pending or in-flight. If
destroy_workqueue() executes in such condition, the rescuer may exit
without emptying @wq->maydays.
This currently doesn't cause any actual harm. destroy_workqueue() can
safely destroy all the involved data structures whether @wq->maydays
is populated or not as nobody access the list once the rescuer exits.
However, this is nasty and makes future development difficult. Let's
update rescuer_thread() so that it empties @wq->maydays after seeing
should_stop to guarantee that the list is empty on rescuer exit.
tj: Updated comment and patch description.
commit 77668c8b559e4fe2acf2a0749c7c83cde49a5025 upstream.
There is a race condition between rescuer_thread() and
pwq_unbound_release_workfn().
Even after a pwq is scheduled for rescue, the associated work items
may be consumed by any worker. If all of them are consumed before the
rescuer gets to them and the pwq's base ref was put due to attribute
change, the pwq may be released while still being linked on
@wq->maydays list making the rescuer dereference already freed pwq
later.
Make send_mayday() pin the target pwq until the rescuer is done with
it.
