path: root/kernel
2005-09-07[PATCH] Provide better printk() support for SMP machinesDavid Howells
The attached patch prevents oopses interleaving with characters from other printks on other CPUs by only breaking the lock if the oops is happening on the machine holding the lock. It might be better if the oops generator got the lock and then called an inner vprintk routine that assumed the caller holds the lock, thus making oops reports "atomic". Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] detect soft lockupsIngo Molnar
This patch adds a new kernel debug feature: CONFIG_DETECT_SOFTLOCKUP. When enabled then per-CPU watchdog threads are started, which try to run once per second. If they get delayed for more than 10 seconds then a callback from the timer interrupt detects this condition and prints out a warning message and a stack dump (once per lockup incident). The feature is otherwise non-intrusive, it doesnt try to unlock the box in any way, it only gets the debug info out, automatically, and on all CPUs affected by the lockup. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-Off-By: Matthias Urlichs <smurf@smurf.noris.de> Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] FUTEX_WAKE_OP: pthread_cond_signal() speedupJakub Jelinek
ATM pthread_cond_signal is unnecessarily slow, because it wakes one waiter (which at least on UP usually means an immediate context switch to one of the waiter threads). This waiter wakes up and after a few instructions it attempts to acquire the cv internal lock, but that lock is still held by the thread calling pthread_cond_signal. So it goes to sleep and eventually the signalling thread is scheduled in, unlocks the internal lock and wakes the waiter again. Now, before 2003-09-21 NPTL was using FUTEX_REQUEUE in pthread_cond_signal to avoid this performance issue, but it was removed when locks were redesigned to the 3 state scheme (unlocked, locked uncontended, locked contended). Following scenario shows why simply using FUTEX_REQUEUE in pthread_cond_signal together with using lll_mutex_unlock_force in place of lll_mutex_unlock is not enough and probably why it has been disabled at that time: The number is value in cv->__data.__lock. thr1 thr2 thr3 0 pthread_cond_wait 1 lll_mutex_lock (cv->__data.__lock) 0 lll_mutex_unlock (cv->__data.__lock) 0 lll_futex_wait (&cv->__data.__futex, futexval) 0 pthread_cond_signal 1 lll_mutex_lock (cv->__data.__lock) 1 pthread_cond_signal 2 lll_mutex_lock (cv->__data.__lock) 2 lll_futex_wait (&cv->__data.__lock, 2) 2 lll_futex_requeue (&cv->__data.__futex, 0, 1, &cv->__data.__lock) # FUTEX_REQUEUE, not FUTEX_CMP_REQUEUE 2 lll_mutex_unlock_force (cv->__data.__lock) 0 cv->__data.__lock = 0 0 lll_futex_wake (&cv->__data.__lock, 1) 1 lll_mutex_lock (cv->__data.__lock) 0 lll_mutex_unlock (cv->__data.__lock) # Here, lll_mutex_unlock doesn't know there are threads waiting # on the internal cv's lock Now, I believe it is possible to use FUTEX_REQUEUE in pthread_cond_signal, but it will cost us not one, but 2 extra syscalls and, what's worse, one of these extra syscalls will be done for every single waiting loop in pthread_cond_*wait. We would need to use lll_mutex_unlock_force in pthread_cond_signal after requeue and lll_mutex_cond_lock in pthread_cond_*wait after lll_futex_wait. Another alternative is to do the unlocking pthread_cond_signal needs to do (the lock can't be unlocked before lll_futex_wake, as that is racy) in the kernel. I have implemented both variants, futex-requeue-glibc.patch is the first one and futex-wake_op{,-glibc}.patch is the unlocking inside of the kernel. The kernel interface allows userland to specify how exactly an unlocking operation should look like (some atomic arithmetic operation with optional constant argument and comparison of the previous futex value with another constant). It has been implemented just for ppc*, x86_64 and i?86, for other architectures I'm including just a stub header which can be used as a starting point by maintainers to write support for their arches and ATM will just return -ENOSYS for FUTEX_WAKE_OP. The requeue patch has been (lightly) tested just on x86_64, the wake_op patch on ppc64 kernel running 32-bit and 64-bit NPTL and x86_64 kernel running 32-bit and 64-bit NPTL. With the following benchmark on UP x86-64 I get: for i in nptl-orig nptl-requeue nptl-wake_op; do echo time elf/ld.so --library-path .:$i /tmp/bench; \ for j in 1 2; do echo ( time elf/ld.so --library-path .:$i /tmp/bench ) 2>&1; done; done time elf/ld.so --library-path .:nptl-orig /tmp/bench real 0m0.655s user 0m0.253s sys 0m0.403s real 0m0.657s user 0m0.269s sys 0m0.388s time elf/ld.so --library-path .:nptl-requeue /tmp/bench real 0m0.496s user 0m0.225s sys 0m0.271s real 0m0.531s user 0m0.242s sys 0m0.288s time elf/ld.so --library-path .:nptl-wake_op /tmp/bench real 0m0.380s user 0m0.176s sys 0m0.204s real 0m0.382s user 0m0.175s sys 0m0.207s The benchmark is at: http://sourceware.org/ml/libc-alpha/2005-03/txt00001.txt Older futex-requeue-glibc.patch version is at: http://sourceware.org/ml/libc-alpha/2005-03/txt00002.txt Older futex-wake_op-glibc.patch version is at: http://sourceware.org/ml/libc-alpha/2005-03/txt00003.txt Will post a new version (just x86-64 fixes so that the patch applies against pthread_cond_signal.S) to libc-hacker ml soon. Attached is the kernel FUTEX_WAKE_OP patch as well as a simple-minded testcase that will not test the atomicity of the operation, but at least check if the threads that should have been woken up are woken up and whether the arithmetic operation in the kernel gave the expected results. Acked-by: Ingo Molnar <mingo@redhat.com> Cc: Ulrich Drepper <drepper@redhat.com> Cc: Jamie Lokier <jamie@shareable.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] swsusp: update documentationPavel Machek
This updates documentation a bit (mostly removing obsolete stuff), and marks swsusp as no longer experimental in config. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] x86/x86_64: deferred handling of writes to /proc/irqxx/smp_affinityAshok Raj
When handling writes to /proc/irq, current code is re-programming rte entries directly. This is not recommended and could potentially cause chipset's to lockup, or cause missing interrupts. CONFIG_IRQ_BALANCE does this correctly, where it re-programs only when the interrupt is pending. The same needs to be done for /proc/irq handling as well. Otherwise user space irq balancers are really not doing the right thing. - Changed pending_irq_balance_cpumask to pending_irq_migrate_cpumask for lack of a generic name. - added move_irq out of IRQ_BALANCE, and added this same to X86_64 - Added new proc handler for write, so we can do deferred write at irq handling time. - Display of /proc/irq/XX/smp_affinity used to display CPU_MASKALL, instead it now shows only active cpu masks, or exactly what was set. - Provided a common move_irq implementation, instead of duplicating when using generic irq framework. Tested on i386/x86_64 and ia64 with CONFIG_PCI_MSI turned on and off. Tested UP builds as well. MSI testing: tbd: I have cards, need to look for a x-over cable, although I did test an earlier version of this patch. Will test in a couple days. Signed-off-by: Ashok Raj <ashok.raj@intel.com> Acked-by: Zwane Mwaikambo <zwane@holomorphy.com> Grudgingly-acked-by: Andi Kleen <ak@muc.de> Signed-off-by: Coywolf Qi Hunt <coywolf@lovecn.org> Signed-off-by: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] UML Support - Ptrace: adds the host SYSEMU support, for UML and ↵Laurent Vivier
general usage Jeff Dike <jdike@addtoit.com>, Paolo 'Blaisorblade' Giarrusso <blaisorblade_spam@yahoo.it>, Bodo Stroesser <bstroesser@fujitsu-siemens.com> Adds a new ptrace(2) mode, called PTRACE_SYSEMU, resembling PTRACE_SYSCALL except that the kernel does not execute the requested syscall; this is useful to improve performance for virtual environments, like UML, which want to run the syscall on their own. In fact, using PTRACE_SYSCALL means stopping child execution twice, on entry and on exit, and each time you also have two context switches; with SYSEMU you avoid the 2nd stop and so save two context switches per syscall. Also, some architectures don't have support in the host for changing the syscall number via ptrace(), which is currently needed to skip syscall execution (UML turns any syscall into getpid() to avoid it being executed on the host). Fixing that is hard, while SYSEMU is easier to implement. * This version of the patch includes some suggestions of Jeff Dike to avoid adding any instructions to the syscall fast path, plus some other little changes, by myself, to make it work even when the syscall is executed with SYSENTER (but I'm unsure about them). It has been widely tested for quite a lot of time. * Various fixed were included to handle the various switches between various states, i.e. when for instance a syscall entry is traced with one of PT_SYSCALL / _SYSEMU / _SINGLESTEP and another one is used on exit. Basically, this is done by remembering which one of them was used even after the call to ptrace_notify(). * We're combining TIF_SYSCALL_EMU with TIF_SYSCALL_TRACE or TIF_SINGLESTEP to make do_syscall_trace() notice that the current syscall was started with SYSEMU on entry, so that no notification ought to be done in the exit path; this is a bit of a hack, so this problem is solved in another way in next patches. * Also, the effects of the patch: "Ptrace - i386: fix Syscall Audit interaction with singlestep" are cancelled; they are restored back in the last patch of this series. Detailed descriptions of the patches doing this kind of processing follow (but I've already summed everything up). * Fix behaviour when changing interception kind #1. In do_syscall_trace(), we check the status of the TIF_SYSCALL_EMU flag only after doing the debugger notification; but the debugger might have changed the status of this flag because he continued execution with PTRACE_SYSCALL, so this is wrong. This patch fixes it by saving the flag status before calling ptrace_notify(). * Fix behaviour when changing interception kind #2: avoid intercepting syscall on return when using SYSCALL again. A guest process switching from using PTRACE_SYSEMU to PTRACE_SYSCALL crashes. The problem is in arch/i386/kernel/entry.S. The current SYSEMU patch inhibits the syscall-handler to be called, but does not prevent do_syscall_trace() to be called after this for syscall completion interception. The appended patch fixes this. It reuses the flag TIF_SYSCALL_EMU to remember "we come from PTRACE_SYSEMU and now are in PTRACE_SYSCALL", since the flag is unused in the depicted situation. * Fix behaviour when changing interception kind #3: avoid intercepting syscall on return when using SINGLESTEP. When testing 2.6.9 and the skas3.v6 patch, with my latest patch and had problems with singlestepping on UML in SKAS with SYSEMU. It looped receiving SIGTRAPs without moving forward. EIP of the traced process was the same for all SIGTRAPs. What's missing is to handle switching from PTRACE_SYSCALL_EMU to PTRACE_SINGLESTEP in a way very similar to what is done for the change from PTRACE_SYSCALL_EMU to PTRACE_SYSCALL_TRACE. I.e., after calling ptrace(PTRACE_SYSEMU), on the return path, the debugger is notified and then wake ups the process; the syscall is executed (or skipped, when do_syscall_trace() returns 0, i.e. when using PTRACE_SYSEMU), and do_syscall_trace() is called again. Since we are on the return path of a SYSEMU'd syscall, if the wake up is performed through ptrace(PTRACE_SYSCALL), we must still avoid notifying the parent of the syscall exit. Now, this behaviour is extended even to resuming with PTRACE_SINGLESTEP. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] pm: clean up /sys/power/diskPavel Machek
Clean code up a bit, and only show suspend to disk as available when it is configured in. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] pm: fix process freezingPavel Machek
If process freezing fails, some processes are frozen, and rest are left in "were asked to be frozen" state. Thats wrong, we should leave it in some consistent state. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] swsusp: fix error handling and cleanupsPavel Machek
Drop printing during normal boot (when no image exists in swap), print message when drivers fail, fix error paths and consolidate near-identical functions in disk.c (and functions with just one statement). Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] swsusp: add locking to software_resumeShaohua Li
It is trying to protect swsusp_resume_device and software_resume() from two users banging it from userspace at the same time. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] swsusp: simpler calculation of number of pages in PBE listMichal Schmidt
The function calc_nr uses an iterative algorithm to calculate the number of pages needed for the image and the pagedir. Exactly the same result can be obtained with a one-line expression. Note that this was even proved correct ;-). Signed-off-by: Michal Schmidt <xschmi00@stud.feec.vutbr.cz> Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] encrypt suspend data for easy wipingAndreas Steinmetz
The patch protects from leaking sensitive data after resume from suspend. During suspend a temporary key is created and this key is used to encrypt the data written to disk. When, during resume, the data was read back into memory the temporary key is destroyed which simply means that all data written to disk during suspend are then inaccessible so they can't be stolen lateron. Think of the following: you suspend while an application is running that keeps sensitive data in memory. The application itself prevents the data from being swapped out. Suspend, however, must write these data to swap to be able to resume lateron. Without suspend encryption your sensitive data are then stored in plaintext on disk. This means that after resume your sensitive data are accessible to all applications having direct access to the swap device which was used for suspend. If you don't need swap after resume these data can remain on disk virtually forever. Thus it can happen that your system gets broken in weeks later and sensitive data which you thought were encrypted and protected are retrieved and stolen from the swap device. Signed-off-by: Andreas Steinmetz <ast@domdv.de> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] remove busywait in refrigeratorPavel Machek
This should make refrigerator sleep properly, not busywait after the first schedule() returns. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] swap: update swsusp use of swap_infoHugh Dickins
Aha, swsusp dips into swap_info[], better update it to swap_lock. It's bitflipping flags with 0xFF, so get_swap_page will allocate from only the one chosen device: let's change that to flip SWP_WRITEOK. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-29[NET]: Fix sparse warningsArnaldo Carvalho de Melo
Of this type, mostly: CHECK net/ipv6/netfilter.c net/ipv6/netfilter.c:96:12: warning: symbol 'ipv6_netfilter_init' was not declared. Should it be static? net/ipv6/netfilter.c:101:6: warning: symbol 'ipv6_netfilter_fini' was not declared. Should it be static? Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETLINK]: Add "groups" argument to netlink_kernel_createPatrick McHardy
Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETLINK]: Add properly module refcounting for kernel netlink sockets.Harald Welte
- Remove bogus code for compiling netlink as module - Add module refcounting support for modules implementing a netlink protocol - Add support for autoloading modules that implement a netlink protocol as soon as someone opens a socket for that protocol Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-26[PATCH] completely disable cpu_exclusive sched domainPaul Jackson
At the suggestion of Nick Piggin and Dinakar, totally disable the facility to allow cpu_exclusive cpusets to define dynamic sched domains in Linux 2.6.13, in order to avoid problems first reported by John Hawkes (corrupt sched data structures and kernel oops). This has been built for ppc64, i386, ia64, x86_64, sparc, alpha. It has been built, booted and tested for cpuset functionality on an SN2 (ia64). Dinakar or Nick - could you verify that it for sure does avoid the problems Hawkes reported. Hawkes is out of town, and I don't have the recipe to reproduce what he found. Signed-off-by: Paul Jackson <pj@sgi.com> Acked-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-26[PATCH] undo partial cpu_exclusive sched domain disablingPaul Jackson
The partial disabling of Dinakar's new facility to allow cpu_exclusive cpusets to define dynamic sched domains doesn't go far enough. At the suggestion of Nick Piggin and Dinakar, let us instead totally disable this facility for 2.6.13, in order to avoid problems first reported by John Hawkes (corrupt sched data structures and kernel oops). This patch removes the partial disabling code in 2.6.13-rc7, in anticipation of the next patch, which will totally disable it instead. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-24[PATCH] cpu_exclusive sched domains build fixPaul Jackson
As reported by Paul Mackerras <paulus@samba.org>, the previous patch "cpu_exclusive sched domains fix" broke the ppc64 build with CONFIC_CPUSET, yielding error messages: kernel/cpuset.c: In function 'update_cpu_domains': kernel/cpuset.c:648: error: invalid lvalue in unary '&' kernel/cpuset.c:648: error: invalid lvalue in unary '&' On some arch's, the node_to_cpumask() is a function, returning a cpumask_t. But the for_each_cpu_mask() requires an lvalue mask. The following patch fixes this build failure by making a copy of the cpumask_t on the stack. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-23[PATCH] cpu_exclusive sched domains on partial nodes temp fixPaul Jackson
This keeps the kernel/cpuset.c routine update_cpu_domains() from invoking the sched.c routine partition_sched_domains() if the cpuset in question doesn't fall on node boundaries. I have boot tested this on an SN2, and with the help of a couple of ad hoc printk's, determined that it does indeed avoid calling the partition_sched_domains() routine on partial nodes. I did not directly verify that this avoids setting up bogus sched domains or avoids the oops that Hawkes saw. This patch imposes a silent artificial constraint on which cpusets can be used to define dynamic sched domains. This patch should allow proceeding with this new feature in 2.6.13 for the configurations in which it is useful (node alligned sched domains) while avoiding trying to setup sched domains in the less useful cases that can cause the kernel corruption and oops. Signed-off-by: Paul Jackson <pj@sgi.com> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Dinakar Guniguntala <dino@in.ibm.com> Acked-by: John Hawkes <hawkes@sgi.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-23[PATCH] preempt race in getppidDavid Meybohm
With CONFIG_PREEMPT && !CONFIG_SMP, it's possible for sys_getppid to return a bogus value if the parent's task_struct gets reallocated after current->group_leader->real_parent is read: asmlinkage long sys_getppid(void) { int pid; struct task_struct *me = current; struct task_struct *parent; parent = me->group_leader->real_parent; RACE HERE => for (;;) { pid = parent->tgid; #ifdef CONFIG_SMP { struct task_struct *old = parent; /* * Make sure we read the pid before re-reading the * parent pointer: */ smp_rmb(); parent = me->group_leader->real_parent; if (old != parent) continue; } #endif break; } return pid; } If the process gets preempted at the indicated point, the parent process can go ahead and call exit() and then get wait()'d on to reap its task_struct. When the preempted process gets resumed, it will not do any further checks of the parent pointer on !CONFIG_SMP: it will read the bad pid and return. So, the same algorithm used when SMP is enabled should be used when preempt is enabled, which will recheck ->real_parent in this case. Signed-off-by: David Meybohm <dmeybohmlkml@bellsouth.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-18[PATCH] Make RLIMIT_NICE ranges consistent with getpriority(2)Matt Mackall
As suggested by Michael Kerrisk <mtk-manpages@gmx.net>, make RLIMIT_NICE consistent with getpriority before it becomes available in released glibc. Signed-off-by: Matt Mackall <mpm@selenic.com> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Chris Wright <chrisw@osdl.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-17[PATCH] NPTL signal delivery deadlock fixBhavesh P. Davda
This bug is quite subtle and only happens in a very interesting situation where a real-time threaded process is in the middle of a coredump when someone whacks it with a SIGKILL. However, this deadlock leaves the system pretty hosed and you have to reboot to recover. Not good for real-time priority-preemption applications like our telephony application, with 90+ real-time (SCHED_FIFO and SCHED_RR) processes, many of them multi-threaded, interacting with each other for high volume call processing. Acked-by: Roland McGrath <roland@redhat.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-10[PATCH] remove name length check in a workqueueJames Bottomley
We have a chek in there to make sure that the name won't overflow task_struct.comm[], but it's triggering for scsi with lots of HBAs, only scsi is using single-threaded workqueues which don't append the "/%d" anyway. All too hard. Just kill the BUG_ON. Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> [ kthread_create() uses vsnprintf() and limits the thing, so no actual overflow can actually happen regardless ] Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-09[PATCH] cpuset release ABBA deadlock fixPaul Jackson
Fix possible cpuset_sem ABBA deadlock if 'notify_on_release' set. For a particular usage pattern, creating and destroying cpusets fairly frequently using notify_on_release, on a very large system, this deadlock can be seen every few days. If you are not using the cpuset notify_on_release feature, you will never see this deadlock. The existing code, on task exit (or cpuset deletion) did: get cpuset_sem if cpuset marked notify_on_release and is ready to release: compute cpuset path relative to /dev/cpuset mount point call_usermodehelper() forks /sbin/cpuset_release_agent with path drop cpuset_sem Unfortunately, the fork in call_usermodehelper can allocate memory, and allocating memory can require cpuset_sem, if the mems_generation values changed in the interim. This results in an ABBA deadlock, trying to obtain cpuset_sem when it is already held by the current task. To fix this, I put the cpuset path (which must be computed while holding cpuset_sem) in a temporary buffer, to be used in the call_usermodehelper call of /sbin/cpuset_release_agent only _after_ dropping cpuset_sem. So the new logic is: get cpuset_sem if cpuset marked notify_on_release and is ready to release: compute cpuset path relative to /dev/cpuset mount point stash path in kmalloc'd buffer drop cpuset_sem call_usermodehelper() forks /sbin/cpuset_release_agent with path free path The sharp eyed reader might notice that this patch does not contain any calls to kmalloc. The existing code in the check_for_release() routine was already kmalloc'ing a buffer to hold the cpuset path. In the old code, it just held the buffer for a few lines, over the cpuset_release_agent() call that in turn invoked call_usermodehelper(). In the new code, with the application of this patch, it returns that buffer via the new char **ppathbuf parameter, for later use and freeing in cpuset_release_agent(), which is called after cpuset_sem is dropped. Whereas the old code has just one call to cpuset_release_agent(), right in the check_for_release() routine, the new code has three calls to cpuset_release_agent(), from the various places that a cpuset can be released. This patch has been build and booted on SN2, and passed a stress test that previously hit the deadlock within a few seconds. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-04[PATCH] revert "timer exit cleanup"Andrew Morton
Revert this June 17 patch: it broke persistence of timers across execve(). Cc: Roland McGrath <roland@redhat.com> Cc: george anzinger <george@mvista.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-04[PATCH] Remove suspend() calls from shutdown pathBenjamin Herrenschmidt
This removes the calls to device_suspend() from the shutdown path that were added sometime during 2.6.13-rc*. They aren't working properly on a number of configs (I got reports from both ppc powerbook users and x86 users) causing the system to not shutdown anymore. I think it isn't the right approach at the moment anyway. We have already a shutdown() callback for the drivers that actually care about shutdown and the suspend() code isn't yet in a good enough shape to be so much generalized. Also, the semantics of suspend and shutdown are slightly different on a number of setups and the way this was patched in provides little way for drivers to cleanly differenciate. It should have been at least a different message. For 2.6.13, I think we should revert to 2.6.12 behaviour and have a working suspend back. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-01[PATCH] Module per-cpu alignment cannot always be metRusty Russell
The module code assumes noone will ever ask for a per-cpu area more than SMP_CACHE_BYTES aligned. However, as these cases show, gcc asks sometimes asks for 32-byte alignment for the per-cpu section on a module, and if CONFIG_X86_L1_CACHE_SHIFT is 4, we hit that BUG_ON(). This is obviously an unusual combination, as there have been few reports, but better to warn than die. See: http://www.ussg.iu.edu/hypermail/linux/kernel/0409.0/0768.html And more recently: http://bugs.gentoo.org/show_bug.cgi?id=97006 Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-01[PATCH] remove sys_set_zone_reclaim()Ingo Molnar
This removes sys_set_zone_reclaim() for now. While i'm sure Martin is trying to solve a real problem, we must not hard-code an incomplete and insufficient approach into a syscall, because syscalls are pretty much for eternity. I am quite strongly convinced that this syscall must not hit v2.6.13 in its current form. Firstly, the syscall lacks basic syscall design: e.g. it allows the global setting of VM policy for unprivileged users. (!) [ Imagine an Oracle installation and a SAP installation on the same NUMA box fighting over the 'optimal' setting for this flag. What will they do? Will they try to set the flag to their own preferred value every second or so? ] Secondly, it was added based on a single datapoint from Martin: http://marc.theaimsgroup.com/?l=linux-mm&m=111763597218177&w=2 where Martin characterizes the numbers the following way: ' Run-to-run variability for "make -j" is huge, so these numbers aren't terribly useful except to see that with reclaim the benchmark still finishes in a reasonable amount of time. ' in other words: the fundamental problem has likely not been solved, only a tendential move into the right direction has been observed, and a handful of numbers were picked out of a set of hugely variable results, without showing the variability data. How much variance is there run-to-run? I'd really suggest to first walk the walk and see what's needed to get stable & predictable kernel compilation numbers on that NUMA box, before adding random syscalls to tune a particular aspect of the VM ... which approach might not even matter once the whole picture has been analyzed and understood! The third, most important point is that the syscall exposes VM tuning internals in a completely unstructured way. What sense does it make to have a _GLOBAL_ per-node setting for 'should we go to another node for reclaim'? If then it might make sense to do this per-app, via numalib or so. The change is minimalistic in that it doesnt remove the syscall and the underlying infrastructure changes, only the user-visible changes. We could perhaps add a CAP_SYS_ADMIN-only sysctl for this hack, a'ka /proc/sys/vm/swappiness, but even that looks quite counterproductive when the generic approach is that we are trying to reduce the number of external factors in the VM balance picture. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-30[PATCH] revert bogus softirq changesAndrew Morton
This snuck in with an x86_64 change. Thanks to Richard Purdie <rpurdie@rpsys.net> for spotting it. Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-29[PATCH] reboot: remove device_suspend(PMSG_FREEZE) from kernel_kexecEric W. Biederman
If device_suspend(PMSG_FREEZE) is not ready to be called in kernel_restart it is definitely not ready to be called in the even more fickle kernel_kexec. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-28[PATCH] posix timers: fix normalization problemGeorge Anzinger
(We found this (after a customer complained) and it is in the kernel.org kernel. Seems that for CLOCK_MONOTONIC absolute timers and clock_nanosleep calls both the request time and wall_to_monotonic are subtracted prior to the normalize resulting in an overflow in the existing normalize test. This causes the result to be shifted ~4 seconds ahead instead of ~2 seconds back in time.) The normalize code in posix-timers.c fails when the tv_nsec member is ~1.2 seconds negative. This can happen on absolute timers (and clock_nanosleeps) requested on CLOCK_MONOTONIC (both the request time and wall_to_monotonic are subtracted resulting in the possibility of a number close to -2 seconds.) This fix uses the set_normalized_timespec() (which does not have an overflow problem) to fix the problem and as a side effect makes the code cleaner. Signed-off-by: George Anzinger <george@mvista.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-28[PATCH] x86_64: Switch to the interrupt stack when running a softirq in ↵Andi Kleen
local_bh_enable() This avoids some potential stack overflows with very deep softirq callchains. i386 does this too. TOADD CFI annotation Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-27[PATCH] Avoid device suspend on rebootAndrew Morton
My fairly ordinary x86 test box gets stuck during reboot on the wait_for_completion() in ide_do_drive_cmd(): Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-27[PATCH] clean up inline static vs static inlineJesper Juhl
`gcc -W' likes to complain if the static keyword is not at the beginning of the declaration. This patch fixes all remaining occurrences of "inline static" up with "static inline" in the entire kernel tree (140 occurrences in 47 files). While making this change I came across a few lines with trailing whitespace that I also fixed up, I have also added or removed a blank line or two here and there, but there are no functional changes in the patch. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-27[PATCH] kernel/crash_dump.c: add kerneldocRandy Dunlap
Add kerneldoc to kernel/crash_dump.c Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-27[PATCH] kernel/cpuset.c: add kerneldoc, fix typosRandy Dunlap
Add kerneldoc to kernel/cpuset.c Fix cpuset typos in init/Kconfig Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-27[PATCH] kernel/capability.c: add kerneldocRandy Dunlap
Add kerneldoc to kernel/capability.c Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-27[PATCH] s390: spin lock retryMartin Schwidefsky
Split spin lock and r/w lock implementation into a single try which is done inline and an out of line function that repeatedly tries to get the lock before doing the cpu_relax(). Add a system control to set the number of retries before a cpu is yielded. The reason for the spin lock retry is that the diagnose 0x44 that is used to give up the virtual cpu is quite expensive. For spin locks that are held only for a short period of time the costs of the diagnoses outweights the savings for spin locks that are held for a longer timer. The default retry count is 1000. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-27[PATCH] itimer fixesGeorge Anzinger
Fix the recent off-by-one fix in the itimer code: 1. The repeating timer is figured using the requested time (not +1 as we know where we are in the jiffie). 2. The tests for interval too large are left to the time_val to jiffie code. Signed-off-by: George Anzinger <george@mvista.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-27[PATCH] Address BUG: using smp_processor_id() in preemptible [00000001] codeNigel Cunningham
This patch fixes a warning in the disable_nonboot_cpus call in kernel/power/smp.c. Signed-off by: Nigel Cunningham <nigel@suspend2.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-26[PATCH] fix MAX_USER_RT_PRIO and MAX_RT_PRIOSteven Rostedt
Here's the patch again to fix the code to handle if the values between MAX_USER_RT_PRIO and MAX_RT_PRIO are different. Without this patch, an SMP system will crash if the values are different. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-26[PATCH] Fix RLIMIT_RTPRIO breakageAndreas Steinmetz
RLIMIT_RTPRIO is supposed to grant non privileged users the right to use SCHED_FIFO/SCHED_RR scheduling policies with priorites bounded by the RLIMIT_RTPRIO value via sched_setscheduler(). This is usually used by audio users. Unfortunately this is broken in 2.6.13rc3 as you can see in the excerpt from sched_setscheduler below: /* * Allow unprivileged RT tasks to decrease priority: */ if (!capable(CAP_SYS_NICE)) { /* can't change policy */ if (policy != p->policy) return -EPERM; After the above unconditional test which causes sched_setscheduler to fail with no regard to the RLIMIT_RTPRIO value the following check is made: /* can't increase priority */ if (policy != SCHED_NORMAL && param->sched_priority > p->rt_priority && param->sched_priority > p->signal->rlim[RLIMIT_RTPRIO].rlim_cur) return -EPERM; Thus I do believe that the RLIMIT_RTPRIO value must be taken into account for the policy check, especially as the RLIMIT_RTPRIO limit is of no use without this change. The attached patch fixes this problem. Signed-off-by: Andreas Steinmetz <ast@domdv.de> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-26[PATCH] swpsuspend: Have suspend to disk use factors of sys_rebootEric W. Biederman
The suspend to disk code was a poor copy of the code in sys_reboot now that we have kernel_power_off, kernel_restart and kernel_halt use them instead of poorly duplicating them inline. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-26[PATCH] Call emergency_reboot from panicEric W. Biederman
We know the system is in trouble so there is no question if this is an emergecy :) Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-26[PATCH] Use kernel_power_off in sysrq-oEric W. Biederman
We already do all of the gymnastics to run from process context to call the power off code so call into the power off code cleanly. This especially helps acpi as part of it's shutdown logic should run acpi_shutdown called from device_shutdown which was not being called from here. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-26[PATCH] Add emergency_restart()Eric W. Biederman
When the kernel is working well and we want to restart cleanly kernel_restart is the function to use. But in many instances the kernel wants to reboot when thing are expected to be working very badly such as from panic or a software watchdog handler. This patch adds the function emergency_restart() so that callers can be clear what semantics they expect when calling restart. emergency_restart() is expected to be callable from interrupt context and possibly reliable in even more trying circumstances. This is an initial generic implementation for all architectures. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-26[PATCH] Make ctrl_alt_del call kernel_restart to get a proper reboot.Eric W. Biederman
It is obvious we wanted to call kernel_restart here but since we don't have it the code was expanded inline and hasn't been correct since sometime in 2.4. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-26[PATCH] Refactor sys_reboot into reusable partsEric W. Biederman
Because the factors of sys_reboot don't exist people calling into the reboot path duplicate the code badly, leading to inconsistent expectations of code in the reboot path. This patch should is just code motion. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
