path: root/kernel
2010-08-13time: Workaround gcc loop optimization that causes 64bit div errorsJohn Stultz
Early 4.3 versions of gcc apparently aggressively optimize the raw time accumulation loop, replacing it with a divide. On 32bit systems, this causes the following link errors: undefined reference to `__umoddi3' undefined reference to `__udivdi3' The gcc issue has been fixed in 4.4 and greater. This patch replaces the accumulation loop with a do_div, as suggested by Linus. Signed-off-by: John Stultz <johnstul@us.ibm.com> CC: Jason Wessel <jason.wessel@windriver.com> CC: Larry Finger <Larry.Finger@lwfinger.net> CC: Ingo Molnar <mingo@elte.hu> CC: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-12Revert "fsnotify: store struct file not struct path"Linus Torvalds
This reverts commit 3bcf3860a4ff9bbc522820b4b765e65e4deceb3e (and the accompanying commit c1e5c954020e "vfs/fsnotify: fsnotify_close can delay the final work in fput" that was a horribly ugly hack to make it work at all). The 'struct file' approach not only causes that disgusting hack, it somehow breaks pulseaudio, probably due to some other subtlety with f_count handling. Fix up various conflicts due to later fsnotify work. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-12Merge branch 'params' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus * 'params' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: (22 commits) param: don't deref arg in __same_type() checks param: update drivers/acpi/debug.c to new scheme param: use module_param in drivers/message/fusion/mptbase.c ide: use module_param_named rather than module_param_call param: update drivers/char/ipmi/ipmi_watchdog.c to new scheme param: lock if_sdio's lbs_helper_name and lbs_fw_name against sysfs changes. param: lock myri10ge_fw_name against sysfs changes. param: simple locking for sysfs-writable charp parameters param: remove unnecessary writable charp param: add kerneldoc to moduleparam.h param: locking for kernel parameters param: make param sections const. param: use free hook for charp (fix leak of charp parameters) param: add a free hook to kernel_param_ops. param: silence .init.text references from param ops Add param ops struct for hvc_iucv driver. nfs: update for module_param_named API change AppArmor: update for module_param_named API change param: use ops in struct kernel_param, rather than get and set fns directly param: move the EXPORT_SYMBOL to after the definitions. ...
2010-08-12timekeeping: Fix overflow in rawtime tv_nsec on 32 bit archsJason Wessel
The tv_nsec is a long and when added to the shifted interval it can wrap and become negative which later causes looping problems in the getrawmonotonic(). The edge case occurs when the system has slept for a short period of time of ~2 seconds. A trace printk of the values in this patch illustrate the problem: ftrace time stamp: log 43.716079: logarithmic_accumulation: raw: 3d0913 tv_nsec d687faa 43.718513: logarithmic_accumulation: raw: 3d0913 tv_nsec da588bd 43.722161: logarithmic_accumulation: raw: 3d0913 tv_nsec de291d0 46.349925: logarithmic_accumulation: raw: 7a122600 tv_nsec e1f9ae3 46.349930: logarithmic_accumulation: raw: 1e848980 tv_nsec 8831c0e3 The kernel starts looping at 46.349925 in the getrawmonotonic() due to the negative value from adding the raw value to tv_nsec. A simple solution is to accumulate into a u64, and then normalize it to a timespec_t. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> [ Reworked variable names and simplified some of the code. - John ] Signed-off-by: John Stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-12Add a dummy printk function for the maintenance of unused printksDavid Howells
Add a dummy printk function for the maintenance of unused printks through gcc format checking, and also so that side-effect checking is maintained too. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-12block: add secure discardAdrian Hunter
Secure discard is the same as discard except that all copies of the discarded sectors (perhaps created by garbage collection) must also be erased. Signed-off-by: Adrian Hunter <adrian.hunter@nokia.com> Acked-by: Jens Axboe <axboe@kernel.dk> Cc: Kyungmin Park <kmpark@infradead.org> Cc: Madhusudhan Chikkature <madhu.cr@ti.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Ben Gardiner <bengardiner@nanometrics.ca> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-12kernel/kfifo.c: add handling of chained scatterlistsStefani Seibold
The current kfifo scatterlist implementation will not work with chained scatterlists. It assumes that struct scatterlist arrays are allocated contiguously, which is not the case when chained scatterlists (struct sg_table) are in use. Signed-off-by: Stefani Seibold <stefani@seibold.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: isofs: Fix lseek() to position beyond 4 GB vfs: remove unused MNT_STRICTATIME vfs: show unreachable paths in getcwd and proc vfs: only add " (deleted)" where necessary vfs: add prepend_path() helper vfs: __d_path: dont prepend the name of the root dentry ia64: perfmon: add d_dname method vfs: add helpers to get root and pwd cachefiles: use path_get instead of lone dget fs/sysv/super.c: add support for non-PDP11 v7 filesystems V7: Adjust sanity checks for some volumes Add v7 alias v9fs: fixup for inode_setattr being removed Manual merge to take Al's version of the fs/sysv/super.c file: it merged cleanly, but Al had removed an unnecessary header include, so his side was better.
2010-08-11kfifo: replace the old non generic APIStefani Seibold
Simply replace the whole kfifo.c and kfifo.h files with the new generic version and fix the kerneldoc API template file. Signed-off-by: Stefani Seibold <stefani@seibold.net> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11kfifo: add the new generic kfifo APIStefani Seibold
Add the new version of the kfifo API files kfifo.c and kfifo.h. Signed-off-by: Stefani Seibold <stefani@seibold.net> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11kexec: return -EFAULT on copy_to_user() failuresDan Carpenter
copy_to/from_user() returns the number of bytes remaining to be copied. It never returns a negative value. The correct return code is -EFAULT and not -EIO. All the callers check for non-zero returns so that's Ok, but the return code is passed to the user so we should fix this. Signed-off-by: Dan Carpenter <error27@gmail.com> Cc: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Simon Kagstrom <simon.kagstrom@netinsight.net> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11lib/bug.c: add oops end marker to WARN implementationAnton Blanchard
We are missing the oops end marker for the exception based WARN implementation in lib/bug.c. This is useful for logfile analysis tools. Signed-off-by: Anton Blanchard <anton@samba.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Arjan van de Ven <arjan@infradead.org> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11panic: keep blinking in spite of long spin timer modeTAMUKI Shoichi
To keep panic_timeout accuracy when running under a hypervisor, the current implementation only spins on long time (1 second) calls to mdelay. That brings a good effect, but the problem is the keyboard LEDs don't blink at all on that situation. This patch changes to call to panic_blink_enter() between every mdelay and keeps blinking in spite of long spin timer mode. The time to call to mdelay is now 100ms. Even this change will keep panic_timeout accuracy enough when running under a hypervisor. Signed-off-by: TAMUKI Shoichi <tamuki@linet.gr.jp> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Russell King <linux@arm.linux.org.uk> Acked-by: Dmitry Torokhov <dtor@mail.ru> Cc: Anton Blanchard <anton@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11pids: alloc_pidmap: remove the unnecessary boundary checksOleg Nesterov
alloc_pidmap() calculates max_scan so that if the initial offset != 0 we inspect the first map->page twice. This is correct, we want to find the unused bits < offset in this bitmap block. Add the comment. But it doesn't make any sense to stop the find_next_offset() loop when we are looking into this map->page for the second time. We have already already checked the bits >= offset during the first attempt, it is fine to do this again, no matter if we succeed this time or not. Remove this hard-to-understand code. It optimizes the very unlikely case when we are going to fail, but slows down the more likely case. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Salman Qazi <sqazi@google.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11pids: fix a race in pid generation that causes pids to be reused immediatelySalman
A program that repeatedly forks and waits is susceptible to having the same pid repeated, especially when it competes with another instance of the same program. This is really bad for bash implementation. Furthermore, many shell scripts assume that pid numbers will not be used for some length of time. Race Description: A B // pid == offset == n // pid == offset == n + 1 test_and_set_bit(offset, map->page) test_and_set_bit(offset, map->page); pid_ns->last_pid = pid; pid_ns->last_pid = pid; // pid == n + 1 is freed (wait()) // Next fork()... last = pid_ns->last_pid; // == n pid = last + 1; Code to reproduce it (Running multiple instances is more effective): #include <errno.h> #include <sys/types.h> #include <sys/wait.h> #include <unistd.h> #include <stdio.h> #include <stdlib.h> // The distance mod 32768 between two pids, where the first pid is expected // to be smaller than the second. int PidDistance(pid_t first, pid_t second) { return (second + 32768 - first) % 32768; } int main(int argc, char* argv[]) { int failed = 0; pid_t last_pid = 0; int i; printf("%d\n", sizeof(pid_t)); for (i = 0; i < 10000000; ++i) { if (i % 32786 == 0) printf("Iter: %d\n", i/32768); int child_exit_code = i % 256; pid_t pid = fork(); if (pid == -1) { fprintf(stderr, "fork failed, iteration %d, errno=%d", i, errno); exit(1); } if (pid == 0) { // Child exit(child_exit_code); } else { // Parent if (i > 0) { int distance = PidDistance(last_pid, pid); if (distance == 0 || distance > 30000) { fprintf(stderr, "Unexpected pid sequence: previous fork: pid=%d, " "current fork: pid=%d for iteration=%d.\n", last_pid, pid, i); failed = 1; } } last_pid = pid; int status; int reaped = wait(&status); if (reaped != pid) { fprintf(stderr, "Wait return value: expected pid=%d, " "got %d, iteration %d\n", pid, reaped, i); failed = 1; } else if (WEXITSTATUS(status) != child_exit_code) { fprintf(stderr, "Unexpected exit status %x, iteration %d\n", WEXITSTATUS(status), i); failed = 1; } } } exit(failed); } Thanks to Ted Tso for the key ideas of this implementation. Signed-off-by: Salman Qazi <sqazi@google.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Theodore Ts'o <tytso@mit.edu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11ptrace: optimize exit_ptrace() for the likely caseOleg Nesterov
exit_ptrace() takes tasklist_lock unconditionally. We need this lock to avoid the race with ptrace_traceme(), it acts as a barrier. Change its caller, forget_original_parent(), to call exit_ptrace() under tasklist_lock. Change exit_ptrace() to drop and reacquire this lock if needed. This allows us to add the fastpath list_empty(ptraced) check. In the likely no-tracees case exit_ptrace() just returns and we avoid the lock() + unlock() sequence. "Zhang, Yanmin" <yanmin_zhang@linux.intel.com> suggested to add this check, and he reports that this change adds about 11% improvement in some tests. Suggested-and-tested-by: "Zhang, Yanmin" <yanmin_zhang@linux.intel.com> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11cgroups: save space for the terminatorDan Carpenter
The original code didn't leave enough space for a NULL terminator. These strings are copied with strcpy() into fixed length buffers in cgroup_root_from_opts(). Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Serge E. Hallyn <serge@hallyn.com> Reviewd-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Ben Blum <bblum@andrew.cmu.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11param: locking for kernel parametersRusty Russell
There may be cases (most obviously, sysfs-writable charp parameters) where a module needs to prevent sysfs access to parameters. Rather than express this in terms of a big lock, the functions are expressed in terms of what they protect against. This is clearer, esp. if the implementation changes to a module-level or even param-level lock. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: Takashi Iwai <tiwai@suse.de> Tested-by: Phil Carmody <ext-phil.2.carmody@nokia.com>
2010-08-11param: make param sections const.Rusty Russell
Since this section can be read-only (they're in .rodata), they should always have been const. Minor flow-through various functions. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Tested-by: Phil Carmody <ext-phil.2.carmody@nokia.com>
2010-08-11param: use free hook for charp (fix leak of charp parameters)Rusty Russell
Instead of using a "I kmalloced this" flag, we keep track of the kmalloced strings and use that list to check if we need to kfree (in practice, the list is very short). This means that kparams can be const again, and plugs a leak. This is important for drivers/usb/gadget/nokia.c which gets modprobe/rmmod'ed frequently on the N9000. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: Takashi Iwai <tiwai@suse.de> Cc: Artem Bityutskiy <dedekind1@gmail.com> Tested-by: Phil Carmody <ext-phil.2.carmody@nokia.com>
2010-08-11param: add a free hook to kernel_param_ops.Rusty Russell
This allows us to generalize the KPARAM_KMALLOCED flag, by calling a function on every parameter when a module is unloaded. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: Takashi Iwai <tiwai@suse.de> Tested-by: Phil Carmody <ext-phil.2.carmody@nokia.com>
2010-08-11param: use ops in struct kernel_param, rather than get and set fns directlyRusty Russell
This is more kernel-ish, saves some space, and also allows us to expand the ops without breaking all the callers who are happy for the new members to be NULL. The few places which defined their own param types are changed to the new scheme (more which crept in recently fixed in following patches). Since we're touching them anyway, we change get() and set() to take a const struct kernel_param (which they really are). This causes some harmless warnings until we fix them (in following patches). To reduce churn, module_param_call creates the ops struct so the callers don't have to change (and casts the functions to reduce warnings). The modern version which takes an ops struct is called module_param_cb. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: Takashi Iwai <tiwai@suse.de> Tested-by: Phil Carmody <ext-phil.2.carmody@nokia.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Ville Syrjala <syrjala@sci.fi> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: Alessandro Rubini <rubini@ipvvis.unipv.it> Cc: Michal Januszewski <spock@gentoo.org> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Cc: linux-kernel@vger.kernel.org Cc: linux-input@vger.kernel.org Cc: linux-fbdev-devel@lists.sourceforge.net Cc: linux-nfs@vger.kernel.org Cc: netdev@vger.kernel.org
2010-08-11param: move the EXPORT_SYMBOL to after the definitions.Rusty Russell
This is modern style, and good to do before we start changing things. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: Takashi Iwai <tiwai@suse.de> Tested-by: Phil Carmody <ext-phil.2.carmody@nokia.com>
2010-08-11params: don't hand NULL values to param.set callbacks.Rusty Russell
An audit by Dongdong Deng revealed that most driver-author-written param calls don't handle val == NULL (which happens when parameters are specified with no =, eg "foo" instead of "foo=1"). The only real case to use this is boolean, so handle it specially for that case and remove a source of bugs for everyone else. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Dongdong Deng <dongdong.deng@windriver.com> Cc: Américo Wang <xiyou.wangcong@gmail.com>
2010-08-11vfs: add helpers to get root and pwdMiklos Szeredi
Add three helpers that retrieve a refcounted copy of the root and cwd from the supplied fs_struct. get_fs_root() get_fs_pwd() get_fs_root_and_pwd() Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-10kernel/timer.c: fix kernel-doc function parameter warningRandy Dunlap
Fix kernel-doc warning, add @timer description: Warning(kernel/timer.c:335): No description found for parameter 'timer' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-10Merge branch 'for-2.6.36' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.36' of git://git.kernel.dk/linux-2.6-block: (149 commits) block: make sure that REQ_* types are seen even with CONFIG_BLOCK=n xen-blkfront: fix missing out label blkdev: fix blkdev_issue_zeroout return value block: update request stacking methods to support discards block: fix missing export of blk_types.h writeback: fix bad _bh spinlock nesting drbd: revert "delay probes", feature is being re-implemented differently drbd: Initialize all members of sync_conf to their defaults [Bugz 315] drbd: Disable delay probes for the upcomming release writeback: cleanup bdi_register writeback: add new tracepoints writeback: remove unnecessary init_timer call writeback: optimize periodic bdi thread wakeups writeback: prevent unnecessary bdi threads wakeups writeback: move bdi threads exiting logic to the forker thread writeback: restructure bdi forker loop a little writeback: move last_active to bdi writeback: do not remove bdi from bdi_list writeback: simplify bdi code a little writeback: do not lose wake-ups in bdi threads ... Fixed up pretty trivial conflicts in drivers/block/virtio_blk.c and drivers/scsi/scsi_error.c as per Jens.
2010-08-10Merge branch 'writable_limits' of git://decibel.fi.muni.cz/~xslaby/linuxLinus Torvalds
* 'writable_limits' of git://decibel.fi.muni.cz/~xslaby/linux: unistd: add __NR_prlimit64 syscall numbers rlimits: implement prlimit64 syscall rlimits: switch more rlimit syscalls to do_prlimit rlimits: redo do_setrlimit to more generic do_prlimit rlimits: add rlimit64 structure rlimits: do security check under task_lock rlimits: allow setrlimit to non-current tasks rlimits: split sys_setrlimit rlimits: selinux, do rlimits changes under task_lock rlimits: make sure ->rlim_max never grows in sys_setrlimit rlimits: add task_struct to update_rlimit_cpu rlimits: security, add task_struct to setrlimit Fix up various system call number conflicts. We not only added fanotify system calls in the meantime, but asm-generic/unistd.h added a wait4 along with a range of reserved per-architecture system calls.
2010-08-10Merge branch 'for-linus' of git://git.infradead.org/users/eparis/notifyLinus Torvalds
* 'for-linus' of git://git.infradead.org/users/eparis/notify: (132 commits) fanotify: use both marks when possible fsnotify: pass both the vfsmount mark and inode mark fsnotify: walk the inode and vfsmount lists simultaneously fsnotify: rework ignored mark flushing fsnotify: remove global fsnotify groups lists fsnotify: remove group->mask fsnotify: remove the global masks fsnotify: cleanup should_send_event fanotify: use the mark in handler functions audit: use the mark in handler functions dnotify: use the mark in handler functions inotify: use the mark in handler functions fsnotify: send fsnotify_mark to groups in event handling functions fsnotify: Exchange list heads instead of moving elements fsnotify: srcu to protect read side of inode and vfsmount locks fsnotify: use an explicit flag to indicate fsnotify_destroy_mark has been called fsnotify: use _rcu functions for mark list traversal fsnotify: place marks on object in order of group memory address vfs/fsnotify: fsnotify_close can delay the final work in fput fsnotify: store struct file not struct path ... Fix up trivial delete/modify conflict in fs/notify/inotify/inotify.c.
2010-08-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (96 commits) no need for list_for_each_entry_safe()/resetting with superblock list Fix sget() race with failing mount vfs: don't hold s_umount over close_bdev_exclusive() call sysv: do not mark superblock dirty on remount sysv: do not mark superblock dirty on mount btrfs: remove junk sb_dirt change BFS: clean up the superblock usage AFFS: wait for sb synchronization when needed AFFS: clean up dirty flag usage cifs: truncate fallout mbcache: fix shrinker function return value mbcache: Remove unused features add f_flags to struct statfs(64) pass a struct path to vfs_statfs update VFS documentation for method changes. All filesystems that need invalidate_inode_buffers() are doing that explicitly convert remaining ->clear_inode() to ->evict_inode() Make ->drop_inode() just return whether inode needs to be dropped fs/inode.c:clear_inode() is gone fs/inode.c:evict() doesn't care about delete vs. non-delete paths now ... Fix up trivial conflicts in fs/nilfs2/super.c
2010-08-09gcc-4.6: printk: use stable variable to dump kmsg bufferAndi Kleen
kmsg_dump takes care to sample the global variables inside a spinlock, but then goes on to use the same variables outside the spinlock region too. Use the correct variable. This will make the race window smaller. Found by gcc 4.6's new warnings. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09stop_machine: struct cpu_stopper, remove alignment padding on 64 bitsRichard Kennedy
Reorder elements in structure cpu_stopper to remove alignment padding on 64 bit builds, this shrinks its size from 40 to 32 bytes saving 8 bytes per cpu. Signed-off-by: Richard Kennedy <richard@rsk.demon.co.uk> Acked-by: Tejun Heo <tj@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09kernel/range: remove unused definition of ARRAY_SIZE()Geert Uytterhoeven
Remove duplicate definition of ARRAY_SIZE(), which was never used anyway. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Yinghai Lu <yinghai@kernel.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09sys_personality: remove the bogus checks in ↵Oleg Nesterov
sys_personality()->__set_personality() path Cleanup, no functional changes. - __set_personality() always changes ->exec_domain/personality, the special case when ->exec_domain remains the same buys nothing but complicates the code. Unify both cases to simplify the code. - The -EINVAL check in sys_personality() was never right. If we assume that set_personality() can fail we should check the value it returns instead of verifying that task->personality was actually changed. Remove it. Before the previous patch it was possible to hit this case due to overflow problems, but this -EINVAL just indicated the kernel bug. OTOH, probably it makes sense to change lookup_exec_domain() to return ERR_PTR() instead of default_exec_domain if the search in exec_domains list fails, and report this error to the user-space. But this means another user-space change, and we have in-kernel users which need fixes. For example, PER_OSF4 falls into PER_MASK for unkown reason and nobody cares to register this domain. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Wenming Zhang <wezhang@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09hibernation: freeze swap at hibernationKAMEZAWA Hiroyuki
When taking a memory snapshot in hibernate_snapshot(), all (directly called) memory allocations use GFP_ATOMIC. Hence swap misusage during hibernation never occurs. But from a pessimistic point of view, there is no guarantee that no page allcation has __GFP_WAIT. It is better to have a global indication "we enter hibernation, don't use swap!". This patch tries to freeze new-swap-allocation during hibernation. (All user processes are frozenm so swapin is not a concern). This way, no updates will happen to swap_map[] between hibernate_snapshot() and save_image(). Swap is thawed when swsusp_free() is called. We can be assured that swap corruption will not occur. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Hugh Dickins <hughd@google.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Ondrej Zary <linux@rainbow-software.org> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09oom: badness heuristic rewriteDavid Rientjes
This a complete rewrite of the oom killer's badness() heuristic which is used to determine which task to kill in oom conditions. The goal is to make it as simple and predictable as possible so the results are better understood and we end up killing the task which will lead to the most memory freeing while still respecting the fine-tuning from userspace. Instead of basing the heuristic on mm->total_vm for each task, the task's rss and swap space is used instead. This is a better indication of the amount of memory that will be freeable if the oom killed task is chosen and subsequently exits. This helps specifically in cases where KDE or GNOME is chosen for oom kill on desktop systems instead of a memory hogging task. The baseline for the heuristic is a proportion of memory that each task is currently using in memory plus swap compared to the amount of "allowable" memory. "Allowable," in this sense, means the system-wide resources for unconstrained oom conditions, the set of mempolicy nodes, the mems attached to current's cpuset, or a memory controller's limit. The proportion is given on a scale of 0 (never kill) to 1000 (always kill), roughly meaning that if a task has a badness() score of 500 that the task consumes approximately 50% of allowable memory resident in RAM or in swap space. The proportion is always relative to the amount of "allowable" memory and not the total amount of RAM systemwide so that mempolicies and cpusets may operate in isolation; they shall not need to know the true size of the machine on which they are running if they are bound to a specific set of nodes or mems, respectively. Root tasks are given 3% extra memory just like __vm_enough_memory() provides in LSMs. In the event of two tasks consuming similar amounts of memory, it is generally better to save root's task. Because of the change in the badness() heuristic's baseline, it is also necessary to introduce a new user interface to tune it. It's not possible to redefine the meaning of /proc/pid/oom_adj with a new scale since the ABI cannot be changed for backward compatability. Instead, a new tunable, /proc/pid/oom_score_adj, is added that ranges from -1000 to +1000. It may be used to polarize the heuristic such that certain tasks are never considered for oom kill while others may always be considered. The value is added directly into the badness() score so a value of -500, for example, means to discount 50% of its memory consumption in comparison to other tasks either on the system, bound to the mempolicy, in the cpuset, or sharing the same memory controller. /proc/pid/oom_adj is changed so that its meaning is rescaled into the units used by /proc/pid/oom_score_adj, and vice versa. Changing one of these per-task tunables will rescale the value of the other to an equivalent meaning. Although /proc/pid/oom_adj was originally defined as a bitshift on the badness score, it now shares the same linear growth as /proc/pid/oom_score_adj but with different granularity. This is required so the ABI is not broken with userspace applications and allows oom_adj to be deprecated for future removal. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Nick Piggin <npiggin@suse.de> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09oom: move sysctl declarations to oom.hDavid Rientjes
The three oom killer sysctl variables (sysctl_oom_dump_tasks, sysctl_oom_kill_allocating_task, and sysctl_panic_on_oom) are better declared in include/linux/oom.h rather than kernel/sysctl.c. Signed-off-by: David Rientjes <rientjes@google.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09pass a struct path to vfs_statfsChristoph Hellwig
We'll need the path to implement the flags field for statvfs support. We do have it available in all callers except: - ecryptfs_statfs. This one doesn't actually need vfs_statfs but just needs to do a caller to the lower filesystem statfs method. - sys_ustat. Add a non-exported statfs_by_dentry helper for it which doesn't won't be able to fill out the flags field later on. In addition rename the helpers for statfs vs fstatfs to do_*statfs instead of the misleading vfs prefix. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09workqueue: workqueue_cpu_callback() should be cpu_notifier instead of ↵Tejun Heo
hotcpu_notifier Commit 6ee0578b (workqueue: mark init_workqueues as early_initcall) made workqueue SMP initialization depend on workqueue_cpu_callback(), which however was registered as hotcpu_notifier() and didn't get called if CONFIG_HOTPLUG_CPU is not set. This made gcwqs on non-boot CPUs not create their initial workers leading to boot failures. Fix it by making it a cpu_notifier. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-and-bisected-by: walt <w41ter@gmail.com> Tested-by: Markus Trippelsdorf <markus@trippelsdorf.de>
2010-08-08workqueue: add missing __percpu markup in kernel/workqueue.cNamhyung Kim
works in schecule_on_each_cpu() is a percpu pointer but was missing __percpu markup. Add it. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2010-08-07Merge branch 'bkl/core' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing * 'bkl/core' of git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing: do_coredump: Do not take BKL init: Remove the BKL from startup code
2010-08-07Merge branch 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (55 commits) workqueue: mark init_workqueues() as early_initcall() workqueue: explain for_each_*cwq_cpu() iterators fscache: fix build on !CONFIG_SYSCTL slow-work: kill it gfs2: use workqueue instead of slow-work drm: use workqueue instead of slow-work cifs: use workqueue instead of slow-work fscache: drop references to slow-work fscache: convert operation to use workqueue instead of slow-work fscache: convert object to use workqueue instead of slow-work workqueue: fix how cpu number is stored in work->data workqueue: fix mayday_mask handling on UP workqueue: fix build problem on !CONFIG_SMP workqueue: fix locking in retry path of maybe_create_worker() async: use workqueue for worker pool workqueue: remove WQ_SINGLE_CPU and use WQ_UNBOUND instead workqueue: implement unbound workqueue workqueue: prepare for WQ_UNBOUND implementation libata: take advantage of cmwq and remove concurrency limitations workqueue: fix worker management invocation without pending works ... Fixed up conflicts in fs/cifs/* as per Tejun. Other trivial conflicts in include/linux/workqueue.h, kernel/trace/Kconfig and kernel/workqueue.c
2010-08-07block: push BKL into blktrace ioctlsArnd Bergmann
The blktrace driver currently needs the BKL, but we should not need to take that in the block layer, so just push it down into the driver itself. It is quite likely that the BKL is not actually required in blktrace code and could be removed in a follow-on patch. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: unify flags for struct bio and struct requestChristoph Hellwig
Remove the current bio flags and reuse the request flags for the bio, too. This allows to more easily trace the type of I/O from the filesystem down to the block driver. There were two flags in the bio that were missing in the requests: BIO_RW_UNPLUG and BIO_RW_AHEAD. Also I've renamed two request flags that had a superflous RW in them. Note that the flags are in bio.h despite having the REQ_ name - as blkdev.h includes bio.h that is the only way to go for now. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: remove wrappers for request type/flagsChristoph Hellwig
Remove all the trivial wrappers for the cmd_type and cmd_flags fields in struct requests. This allows much easier grepping for different request types instead of unwinding through macros. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-06Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: xen: Do not suspend IPI IRQs. powerpc: Use IRQF_NO_SUSPEND not IRQF_TIMER for non-timer interrupts ixp4xx-beeper: Use IRQF_NO_SUSPEND not IRQF_TIMER for non-timer interrupt irq: Add new IRQ flag IRQF_NO_SUSPEND
2010-08-06Merge branch 'timers-timekeeping-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-timekeeping-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: um: Fix read_persistent_clock fallout kgdb: Do not access xtime directly powerpc: Clean up obsolete code relating to decrementer and timebase powerpc: Rework VDSO gettimeofday to prevent time going backwards clocksource: Add __clocksource_updatefreq_hz/khz methods x86: Convert common clocksources to use clocksource_register_hz/khz timekeeping: Make xtime and wall_to_monotonic static hrtimer: Cleanup direct access to wall_to_monotonic um: Convert to use read_persistent_clock timkeeping: Fix update_vsyscall to provide wall_to_monotonic offset powerpc: Cleanup xtime usage powerpc: Simplify update_vsyscall time: Kill off CONFIG_GENERIC_TIME time: Implement timespec_add x86: Fix vtime/file timestamp inconsistencies Trivial conflicts in Documentation/feature-removal-schedule.txt Much less trivial conflicts in arch/powerpc/kernel/time.c resolved as per Thomas' earlier merge commit 47916be4e28c ("Merge branch 'powerpc.cherry-picks' into timers/clocksource")
2010-08-06Merge branch 'timers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: Documentation: Add timers/timers-howto.txt timer: Added usleep_range timer Revert "timer: Added usleep[_range] timer" clockevents: Remove the per cpu tick skew posix_timer: Move copy_to_user(created_timer_id) down in timer_create() timer: Added usleep[_range] timer timers: Document meaning of deferrable timer
2010-08-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (28 commits) driver core: device_rename's new_name can be const sysfs: Remove owner field from sysfs struct attribute powerpc/pci: Remove owner field from attribute initialization in PCI bridge init regulator: Remove owner field from attribute initialization in regulator core driver leds: Remove owner field from attribute initialization in bd2802 driver scsi: Remove owner field from attribute initialization in ARCMSR driver scsi: Remove owner field from attribute initialization in LPFC driver cgroupfs: create /sys/fs/cgroup to mount cgroupfs on Driver core: Add BUS_NOTIFY_BIND_DRIVER driver core: fix memory leak on one error path in bus_register() debugfs: no longer needs to depend on SYSFS sysfs: Fix one more signature discrepancy between sysfs implementation and docs. sysfs: fix discrepancies between implementation and documentation dcdbas: remove a redundant smi_data_buf_free in dcdbas_exit dmi-id: fix a memory leak in dmi_id_init error path sysfs: sysfs_chmod_file's attr can be const firmware: Update hotplug script Driver core: move platform device creation helpers to .init.text (if MODULE=n) Driver core: reduce duplicated code for platform_device creation Driver core: use kmemdup in platform_device_add_resources ...
2010-08-06Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (27 commits) sched: Use correct macro to display sched_child_runs_first in /proc/sched_debug sched: No need for bootmem special cases sched: Revert nohz_ratelimit() for now sched: Reduce update_group_power() calls sched: Update rq->clock for nohz balanced cpus sched: Fix spelling of sibling sched, cpuset: Drop __cpuexit from cpu hotplug callbacks sched: Fix the racy usage of thread_group_cputimer() in fastpath_timer_check() sched: run_posix_cpu_timers: Don't check ->exit_state, use lock_task_sighand() sched: thread_group_cputime: Simplify, document the "alive" check sched: Remove the obsolete exit_state/signal hacks sched: task_tick_rt: Remove the obsolete ->signal != NULL check sched: __sched_setscheduler: Read the RLIMIT_RTPRIO value lockless sched: Fix comments to make them DocBook happy sched: Fix fix_small_capacity powerpc: Exclude arch_sd_sibiling_asym_packing() on UP powerpc: Enable asymmetric SMT scheduling on POWER7 sched: Add asymmetric group packing option for sibling domain sched: Fix capacity calculations for SMT4 sched: Change nohz idle load balancing logic to push model ...
