path: root/kernel
2009-04-07kprobes: support per-kprobe disablingMasami Hiramatsu
Add disable_kprobe() and enable_kprobe() to disable/enable kprobes temporarily. disable_kprobe() asynchronously disables probe handlers of specified kprobe. So, after calling it, some handlers can be called at a while. enable_kprobe() enables specified kprobe. aggr_pre_handler and aggr_post_handler check disabled probes. On the other hand aggr_break_handler and aggr_fault_handler don't check it because these handlers will be called while executing pre or post handlers and usually those help error handling. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07kprobes: rename kprobe_enabled to kprobes_all_disarmedMasami Hiramatsu
Rename kprobe_enabled to kprobes_all_disarmed and invert logic due to avoiding naming confusion from per-probe disabling. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07kprobes: move EXPORT_SYMBOL_GPL just after function definitionsMasami Hiramatsu
Clean up positions of EXPORT_SYMBOL_GPL in kernel/kprobes.c according to checkpatch.pl. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07kprobes: cleanup aggr_kprobe related codeMasami Hiramatsu
Currently, kprobes can disable all probes at once, but can't disable it individually (not unregister, just disable an kprobe, because unregistering needs to wait for scheduler synchronization). These patches introduce APIs for on-the-fly per-probe disabling and re-enabling by dis-arming/re-arming its breakpoint instruction. This patch: Change old_p to ap in add_new_kprobe() for readability, copy flags member in add_aggr_kprobe(), and simplify the code flow of register_aggr_kprobe(). Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07mm: add /proc controls for pdflush threadsPeter W Morreale
Add /proc entries to give the admin the ability to control the minimum and maximum number of pdflush threads. This allows finer control of pdflush on both large and small machines. The rationale is simply one size does not fit all. Admins on large and/or small systems may want to tune the min/max pdflush thread count to best suit their needs. Right now the min/max is hardcoded to 2/8. While probably a fair estimate for smaller machines, large machines with large numbers of CPUs and large numbers of filesystems/block devices may benefit from larger numbers of threads working on different block devices. Even if the background flushing algorithm is radically changed, it is still likely that multiple threads will be involved and admins would still desire finer control on the min/max other than to have to recompile the kernel. The patch adds '/proc/sys/vm/nr_pdflush_threads_min' and '/proc/sys/vm/nr_pdflush_threads_max' with r/w permissions. The minimum value for nr_pdflush_threads_min is 1 and the maximum value is the current value of nr_pdflush_threads_max. This minimum is required since additional thread creation is performed in a pdflush thread itself. The minimum value for nr_pdflush_threads_max is the current value of nr_pdflush_threads_min and the maximum value can be 1000. Documentation/sysctl/vm.txt is also updated. [akpm@linux-foundation.org: fix comment, fix whitespace, use __read_mostly] Signed-off-by: Peter W Morreale <pmorreale@novell.com> Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Revert "module: remove the SHF_ALLOC flag on the __versions section."Rusty Russell
This reverts commit 9cb610d8e35fe3ec95a2fe2030b02f85aeea83c1. This was an impressively stupid patch. Firstly, we reset the SHF_ALLOC flag lower down in the same function, so the patch was useless. Even better, find_sec() ignores sections with SHF_ALLOC not set, so it breaks CONFIG_MODVERSIONS=y with CONFIG_MODULE_FORCE_LOAD=n, which refuses to load the module since it can't find the __versions section. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-04-06exit_notify: kill the wrong capable(CAP_KILL) checkOleg Nesterov
The CAP_KILL check in exit_notify() looks just wrong, kill it. Whatever logic we have to reset ->exit_signal, the malicious user can bypass it if it execs the setuid application before exiting. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Roland McGrath <roland@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-06kernel/sysctl.c: avoid annoying warningsLinus Torvalds
Some of the limit constants are used only depending on some complex configuration dependencies, yet it's not worth making the simple variables depend on those configuration details. Just mark them as perhaps not being unused, and avoid the warning. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-06Merge branch 'locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: lockdep: add stack dumps to asserts hrtimer: fix rq->lock inversion (again)
2009-04-06Merge branch 'kmemtrace-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'kmemtrace-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: kmemtrace: trace kfree() calls with NULL or zero-length objects kmemtrace: small cleanups kmemtrace: restore original tracing data binary format, improve ABI kmemtrace: kmemtrace_alloc() must fill type_id kmemtrace: use tracepoints kmemtrace, rcu: don't include unnecessary headers, allow kmemtrace w/ tracepoints kmemtrace, rcu: fix rcupreempt.c data structure dependencies kmemtrace, rcu: fix rcu_tree_trace.c data structure dependencies kmemtrace, rcu: fix linux/rcutree.h and linux/rcuclassic.h dependencies kmemtrace, mm: fix slab.h dependency problem in mm/failslab.c kmemtrace, kbuild: fix slab.h dependency problem in lib/decompress_unlzma.c kmemtrace, kbuild: fix slab.h dependency problem in lib/decompress_bunzip2.c kmemtrace, kbuild: fix slab.h dependency problem in lib/decompress_inflate.c kmemtrace, squashfs: fix slab.h dependency problem in squasfs kmemtrace, befs: fix slab.h dependency problem kmemtrace, security: fix linux/key.h header file dependencies kmemtrace, fs: fix linux/fdtable.h header file dependencies kmemtrace, fs: uninline simple_transaction_set() kmemtrace, fs, security: move alloc_secdata() and free_secdata() to linux/security.h
2009-04-05Merge branch 'audit.b62' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit-current * 'audit.b62' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit-current: Audit: remove spaces from audit_log_d_path audit: audit_set_auditable defined but not used audit: incorrect ref counting in audit tree tag_chunk audit: Fix possible return value truncation in audit_get_context() audit: ignore terminating NUL in AUDIT_USER_TTY messages Audit: fix handling of 'strings' with NULL characters make the e->rule.xxx shorter in kernel auditfilter.c auditsc: fix kernel-doc notation audit: EXECVE record - removed bogus newline
2009-04-05Merge branch 'tracing-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (413 commits) tracing, net: fix net tree and tracing tree merge interaction tracing, powerpc: fix powerpc tree and tracing tree interaction ring-buffer: do not remove reader page from list on ring buffer free function-graph: allow unregistering twice trace: make argument 'mem' of trace_seq_putmem() const tracing: add missing 'extern' keywords to trace_output.h tracing: provide trace_seq_reserve() blktrace: print out BLK_TN_MESSAGE properly blktrace: extract duplidate code blktrace: fix memory leak when freeing struct blk_io_trace blktrace: fix blk_probes_ref chaos blktrace: make classic output more classic blktrace: fix off-by-one bug blktrace: fix the original blktrace blktrace: fix a race when creating blk_tree_root in debugfs blktrace: fix timestamp in binary output tracing, Text Edit Lock: cleanup tracing: filter fix for TRACE_EVENT_FORMAT events ftrace: Using FTRACE_WARN_ON() to check "freed record" in ftrace_release() x86: kretprobe-booster interrupt emulation code fix ... Fix up trivial conflicts in arch/parisc/include/asm/ftrace.h include/linux/memory.h kernel/extable.c kernel/module.c
2009-04-05Audit: remove spaces from audit_log_d_pathEric Paris
audit_log_d_path had spaces in the strings which would be emitted on the error paths. This patch simply replaces those spaces with an _ or removes the needless spaces entirely. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-04-05audit: audit_set_auditable defined but not usedEric Paris
after 0590b9335a1c72a3f0defcc6231287f7817e07c8 audit_set_auditable() is now only used by the audit tree code. If CONFIG_AUDIT_TREE is unset it will be defined but unused. This patch simply moves the function inside a CONFIG_AUDIT_TREE block. cc1: warnings being treated as errors /home/acme_unencrypted/git/linux-2.6-tip/kernel/auditsc.c:745: error: ‘audit_set_auditable’ defined but not used make[2]: *** [kernel/auditsc.o] Error 1 make[1]: *** [kernel] Error 2 make[1]: *** Waiting for unfinished jobs.... Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-04-05audit: incorrect ref counting in audit tree tag_chunkEric Paris
tag_chunk has bad exit paths in which the inotify ref counting is wrong. At the top of the function we found &old_watch using inotify_find_watch(). inotify_find_watch takes a reference to the watch. This is never dropped on an error path. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-04-05audit: Fix possible return value truncation in audit_get_context()Paul Moore
The audit subsystem treats syscall return codes as type long, unfortunately the audit_get_context() function mistakenly converts the return code to an int type in the parameters which could cause problems on systems where the sizeof(int) != sizeof(long). Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-04-05audit: ignore terminating NUL in AUDIT_USER_TTY messagesMiloslav Trmac
AUDIT_USER_TTY, like all other messages sent from user-space, is sent NUL-terminated. Unlike other user-space audit messages, which come only from trusted sources, AUDIT_USER_TTY messages are processed using audit_log_n_untrustedstring(). This patch modifies AUDIT_USER_TTY handling to ignore the trailing NUL and use the "quoted_string" representation of the message if possible. Signed-off-by: Miloslav Trmac <mitr@redhat.com> Cc: Eric Paris <eparis@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Steve Grubb <sgrubb@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-04-05Audit: fix handling of 'strings' with NULL charactersMiloslav Trmac
currently audit_log_n_untrustedstring() uses audit_string_contains_control() to check if the 'string' has any control characters. If the 'string' has an embedded NULL audit_string_contains_control() will return that the data has no control characters and will then pass the string to audit_log_n_string with the total length, not the length up to the first NULL. audit_log_n_string() does a memcpy of the entire length and so the actual audit record emitted may then contain a NULL and then whatever random memory is after the NULL. Since we want to log the entire octet stream (if we can't trust the data to be a string we can't trust that a NULL isn't actually a part of it) we should just consider NULL as a control character. If the caller is certain they want to stop at the first NULL they should be using audit_log_untrustedstring. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-04-05make the e->rule.xxx shorter in kernel auditfilter.cZhenwen Xu
make the e->rule.xxx shorter in kernel/auditfilter.c -- --------------------------------- Zhenwen Xu - Open and Free Home Page: http://zhwen.org My Studio: http://dim4.cn >From 99692dc640b278f1cb1a15646ce42f22e89c0f77 Mon Sep 17 00:00:00 2001 From: Zhenwen Xu <Helight.Xu@gmail.com> Date: Thu, 12 Mar 2009 22:04:59 +0800 Subject: [PATCH] make the e->rule.xxx shorter in kernel/auditfilter.c Signed-off-by: Zhenwen Xu <Helight.Xu@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-04-05auditsc: fix kernel-doc notationRandy Dunlap
Fix auditsc kernel-doc notation: Warning(linux-2.6.28-git7//kernel/auditsc.c:2156): No description found for parameter 'attr' Warning(linux-2.6.28-git7//kernel/auditsc.c:2156): Excess function parameter 'u_attr' description in '__audit_mq_open' Warning(linux-2.6.28-git7//kernel/auditsc.c:2204): No description found for parameter 'notification' Warning(linux-2.6.28-git7//kernel/auditsc.c:2204): Excess function parameter 'u_notification' description in '__audit_mq_notify' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> cc: Al Viro <viro@zeniv.linux.org.uk> cc: Eric Paris <eparis@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-04-05audit: EXECVE record - removed bogus newlineJiri Pirko
(updated) Added hunk that changes the comment, the rest is the same. EXECVE records contain a newline after every argument. auditd converts "\n" to " " so you cannot see newlines even in raw logs, but they're there nevertheless. If you're not using auditd, you need to work round them. These '\n' chars are can be easily replaced by spaces when creating record in kernel. Note there is no need for trailing '\n' in an audit record. record before this patch: "type=EXECVE msg=audit(1231421801.566:31): argc=4 a0=\"./test\"\na1=\"a\"\na2=\"b\"\na3=\"c\"\n" record after this patch: "type=EXECVE msg=audit(1231421801.566:31): argc=4 a0=\"./test\" a1=\"a\" a2=\"b\" a3=\"c\"" Signed-off-by: Jiri Pirko <jpirko@redhat.com> Acked-by: Eric Paris <eparis@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-04-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-cpumaskLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-cpumask: (36 commits) cpumask: remove cpumask allocation from idle_balance, fix numa, cpumask: move numa_node_id default implementation to topology.h, fix cpumask: remove cpumask allocation from idle_balance x86: cpumask: x86 mmio-mod.c use cpumask_var_t for downed_cpus x86: cpumask: update 32-bit APM not to mug current->cpus_allowed x86: microcode: cleanup x86: cpumask: use work_on_cpu in arch/x86/kernel/microcode_core.c cpumask: fix CONFIG_CPUMASK_OFFSTACK=y cpu hotunplug crash numa, cpumask: move numa_node_id default implementation to topology.h cpumask: convert node_to_cpumask_map[] to cpumask_var_t cpumask: remove x86 cpumask_t uses. cpumask: use cpumask_var_t in uv_flush_tlb_others. cpumask: remove cpumask_t assignment from vector_allocation_domain() cpumask: make Xen use the new operators. cpumask: clean up summit's send_IPI functions cpumask: use new cpumask functions throughout x86 x86: unify cpu_callin_mask/cpu_callout_mask/cpu_initialized_mask/cpu_sibling_setup_mask cpumask: convert struct cpuinfo_x86's llc_shared_map to cpumask_var_t cpumask: convert node_to_cpumask_map[] to cpumask_var_t x86: unify 32 and 64-bit node_to_cpumask_map ...
2009-04-05Merge ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-module-and-param * git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-module-and-param: module: use strstarts() strstarts: helper function for !strncmp(str, prefix, strlen(prefix)) arm: allow usage of string functions in linux/string.h module: don't use stop_machine on module load module: create a request_module_nowait() module: include other structures in module version check module: remove the SHF_ALLOC flag on the __versions section. module: clarify the force-loading taint message. module: Export symbols needed for Ksplice Ksplice: Add functions for walking kallsyms symbols module: remove module_text_address() module: __module_address module: Make find_symbol return a struct kernel_symbol kernel/module.c: fix an unused goto label param: fix charp parameters set via sysfs Fix trivial conflicts in kernel/extable.c manually.
2009-04-05Merge branch 'printk-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'printk-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: printk: correct the behavior of printk_timed_ratelimit() vsprintf: unify the format decoding layer for its 3 users, cleanup fix regression from "vsprintf: unify the format decoding layer for its 3 users" vsprintf: fix bug in negative value printing vsprintf: unify the format decoding layer for its 3 users vsprintf: add binary printf printk: introduce printk_once() Fix trivial conflicts (printk_once vs log_buf_kexec_setup() added near each other) in include/linux/kernel.h.
2009-04-03Merge branch 'core-cleanups-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-cleanups-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: ptrace: remove a useless goto
2009-04-03Merge branch 'stacktrace-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'stacktrace-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: symbols, stacktrace: look up init symbols after module symbols
2009-04-03Merge branch 'rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: rcu: rcu_barrier VS cpu_hotplug: Ensure callbacks in dead cpu are migrated to online cpu
2009-04-03Merge branch 'ipi-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'ipi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: s390: remove arch specific smp_send_stop() panic: clean up kernel/panic.c panic, smp: provide smp_send_stop() wrapper on UP too panic: decrease oops_in_progress only after having done the panic generic-ipi: eliminate WARN_ON()s during oops/panic generic-ipi: cleanups generic-ipi: remove CSD_FLAG_WAIT generic-ipi: remove kmalloc() generic IPI: simplify barriers and locking
2009-04-03Merge branch 'locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: locking: rename trace_softirq_[enter|exit] => lockdep_softirq_[enter|exit] lockdep: remove duplicate CONFIG_DEBUG_LOCKDEP definitions lockdep: require framepointers for x86 lockdep: remove extra "irq" string lockdep: fix incorrect state name
2009-04-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (28 commits) trivial: Update my email address trivial: NULL noise: drivers/mtd/tests/mtd_*test.c trivial: NULL noise: drivers/media/dvb/frontends/drx397xD_fw.h trivial: Fix misspelling of "Celsius". trivial: remove unused variable 'path' in alloc_file() trivial: fix a pdlfush -> pdflush typo in comment trivial: jbd header comment typo fix for JBD_PARANOID_IOFAIL trivial: wusb: Storage class should be before const qualifier trivial: drivers/char/bsr.c: Storage class should be before const qualifier trivial: h8300: Storage class should be before const qualifier trivial: fix where cgroup documentation is not correctly referred to trivial: Give the right path in Documentation example trivial: MTD: remove EOL from MODULE_DESCRIPTION trivial: Fix typo in bio_split()'s documentation trivial: PWM: fix of #endif comment trivial: fix typos/grammar errors in Kconfig texts trivial: Fix misspelling of firmware trivial: cgroups: documentation typo and spelling corrections trivial: Update contact info for Jochen Hein trivial: fix typo "resgister" -> "register" ...
2009-04-03Document the slow work thread poolDavid Howells
Document the slow work thread pool. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
2009-04-03Make the slow work pool configurableDavid Howells
Make the slow work pool configurable through /proc/sys/kernel/slow-work. (*) /proc/sys/kernel/slow-work/min-threads The minimum number of threads that should be in the pool as long as it is in use. This may be anywhere between 2 and max-threads. (*) /proc/sys/kernel/slow-work/max-threads The maximum number of threads that should in the pool. This may be anywhere between min-threads and 255 or NR_CPUS * 2, whichever is greater. (*) /proc/sys/kernel/slow-work/vslow-percentage The percentage of active threads in the pool that may be used to execute very slow work items. This may be between 1 and 99. The resultant number is bounded to between 1 and one fewer than the number of active threads. This ensures there is always at least one thread that can process very slow work items, and always at least one thread that won't. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
2009-04-03Make slow-work thread pool actually dynamicDavid Howells
Make the slow-work thread pool actually dynamic in the number of threads it contains. With this patch, it will both create additional threads when it has extra work to do, and cull excess threads that aren't doing anything. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
2009-04-03Create a dynamically sized pool of threads for doing very slow work itemsDavid Howells
Create a dynamically sized pool of threads for doing very slow work items, such as invoking mkdir() or rmdir() - things that may take a long time and may sleep, holding mutexes/semaphores and hogging a thread, and are thus unsuitable for workqueues. The number of threads is always at least a settable minimum, but more are started when there's more work to do, up to a limit. Because of the nature of the load, it's not suitable for a 1-thread-per-CPU type pool. A system with one CPU may well want several threads. This is used by FS-Cache to do slow caching operations in the background, such as looking up, creating or deleting cache objects. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
2009-04-03kmemtrace: small cleanupsIngo Molnar
Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> LKML-Reference: <161be9ca8a27b432c4a6ab79f47788c4521652ae.1237813499.git.eduard.munteanu@linux360.ro> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-03kmemtrace: restore original tracing data binary format, improve ABIEduard - Gabriel Munteanu
When kmemtrace was ported to ftrace, the marker strings were taken as an indication of how the traced data was being exposed to the userspace. However, the actual format had been binary, not text. This restores the original binary format, while also adding an origin CPU field (since ftrace doesn't expose the data per-CPU to userspace), and re-adding the timestamp field. It also drops arch-independent field sizing where it didn't make sense, so pointers won't always be 64 bits wide like they used to. Signed-off-by: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> LKML-Reference: <161be9ca8a27b432c4a6ab79f47788c4521652ae.1237813499.git.eduard.munteanu@linux360.ro> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-03kmemtrace: kmemtrace_alloc() must fill type_idEduard - Gabriel Munteanu
Impact: fix trace output kmemtrace_alloc() was not filling type_id, which allowed garbage to make it into tracing data. Signed-off-by: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> LKML-Reference: <284dba2732a144849d5aa82258fe0de2ad8dcb0b.1237813499.git.eduard.munteanu@linux360.ro> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-03kmemtrace: use tracepointsEduard - Gabriel Munteanu
kmemtrace now uses tracepoints instead of markers. We no longer need to use format specifiers to pass arguments. Signed-off-by: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> [ folded: Use the new TP_PROTO and TP_ARGS to fix the build. ] [ folded: fix build when CONFIG_KMEMTRACE is disabled. ] [ folded: define tracepoints when CONFIG_TRACEPOINTS is enabled. ] Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> LKML-Reference: <ae61c0f37156db8ec8dc0d5778018edde60a92e3.1237813499.git.eduard.munteanu@linux360.ro> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-03kmemtrace, rcu: fix rcupreempt.c data structure dependenciesIngo Molnar
Impact: cleanup We want to remove percpu.h from rcupreempt.h, but if we do that the percpu primitives there wont build anymore. Move them to the .c file instead. Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Cc: paulmck@linux.vnet.ibm.com LKML-Reference: <1237898630.25315.83.camel@penberg-laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-03kmemtrace, rcu: fix rcu_tree_trace.c data structure dependenciesIngo Molnar
Impact: cleanup We want to remove rcutree internals from the public rcutree.h file for upcoming kmemtrace changes - but kernel/rcutree_trace.c depends on them. Introduce kernel/rcutree.h for internal definitions. (Probably all the other data types from include/linux/rcutree.h could be moved here too - except rcu_data.) Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Cc: paulmck@linux.vnet.ibm.com LKML-Reference: <1237898630.25315.83.camel@penberg-laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-03kmemtrace, rcu: fix linux/rcutree.h and linux/rcuclassic.h dependenciesIngo Molnar
Impact: build fix for all non-x86 architectures We want to remove percpu.h from rcuclassic.h/rcutree.h (for upcoming kmemtrace changes) but that would break the DECLARE_PER_CPU based declarations in these files. Move the quiescent counter management functions to their respective RCU implementation .c files - they were slightly above the inlining limit anyway. Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Cc: paulmck@linux.vnet.ibm.com LKML-Reference: <1237898630.25315.83.camel@penberg-laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: Remove two unneeded exports and make two symbols static in fs/mpage.c Cleanup after commit 585d3bc06f4ca57f975a5a1f698f65a45ea66225 Trim includes of fdtable.h Don't crap into descriptor table in binfmt_som Trim includes in binfmt_elf Don't mess with descriptor table in load_elf_binary() Get rid of indirect include of fs_struct.h New helper - current_umask() check_unsafe_exec() doesn't care about signal handlers sharing New locking/refcounting for fs_struct Take fs_struct handling to new file (fs/fs_struct.c) Get rid of bumping fs_struct refcount in pivot_root(2) Kill unsharing fs_struct in __set_personality()
2009-04-02Allow rwlocks to re-enable interruptsRobin Holt
Pass the original flags to rwlock arch-code, so that it can re-enable interrupts if implemented for that architecture. Initially, make __raw_read_lock_flags and __raw_write_lock_flags stubs which just do the same thing as non-flags variants. Signed-off-by: Petr Tesarik <ptesarik@suse.cz> Signed-off-by: Robin Holt <holt@sgi.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: <linux-arch@vger.kernel.org> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02Factor out #ifdefs from kernel/spinlock.c to LOCK_CONTENDED_FLAGSRobin Holt
SGI has observed that on large systems, interrupts are not serviced for a long period of time when waiting for a rwlock. The following patch series re-enables irqs while waiting for the lock, resembling the code which is already there for spinlocks. I only made the ia64 version, because the patch adds some overhead to the fast path. I assume there is currently no demand to have this for other architectures, because the systems are not so large. Of course, the possibility to implement raw_{read|write}_lock_flags for any architecture is still there. This patch: The new macro LOCK_CONTENDED_FLAGS expands to the correct implementation depending on the config options, so that IRQ's are re-enabled when possible, but they remain disabled if CONFIG_LOCKDEP is set. Signed-off-by: Petr Tesarik <ptesarik@suse.cz> Signed-off-by: Robin Holt <holt@sgi.com> Cc: <linux-arch@vger.kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02relay: fix for possible loss/corruption of produced subbufsAravind Srinivasan
Fix possible loss/corruption of produced subbufs in relay_subbufs_consumed(). When buf->subbufs_produced wraps around after UINT_MAX and buf->subbufs_consumed is still < UINT_MAX, the condition if (buf->subbufs_consumed > buf->subbufs_produced) will be true even for certain valid values of subbufs_consumed. This may lead to loss or corruption of produced subbufs. Signed-off-by: Aravind Srinivasan <raa.aars@gmail.com> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Tom Zanussi <zanussi@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02kexec: vmcoreinfo_data[] can become staticDmitri Vorobiev
The vmcoreinfo_data[] array is not used outside of kernel/kexec.c, and can therefore become static. This patch adds the relevant keyword to the definition of the array. Noticed by sparse. Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@movial.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02kexec: add dmesg log symbols to /proc/vmcoreinfo listsNeil Horman
It would be nice to be able to extract the dmesg log from a vmcore file without needing to keep the debug symbols for the running kernel handy all the time. We have a facility to do this in /proc/vmcore. This patch adds the log_buf and log_end symbols to the vmcoreinfo area so that tools (like makedumpfile) can easily extract the dmesg logs from a vmcore image. [akpm@linux-foundation.org: several fixes and cleanups] [akpm@linux-foundation.org: fix unused log_buf_kexec_setup()] [akpm@linux-foundation.org: build fix] Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Cc: Simon Horman <horms@verge.net.au> Acked-by: Vivek Goyal <vgoyal@redhat.com> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: Simon Horman <horms@verge.net.au> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02pids: kill signal_struct-> __pgrp/__session and friendsOleg Nesterov
We are wasting 2 words in signal_struct without any reason to implement task_pgrp_nr() and task_session_nr(). task_session_nr() has no callers since 2e2ba22ea4fd4bb85f0fa37c521066db6775cbef, we can remove it. task_pgrp_nr() is still (I believe wrongly) used in fs/autofsX and fs/coda. This patch reimplements task_pgrp_nr() via task_pgrp_nr_ns(), and kills __pgrp/__session and the related helpers. The change in drivers/char/tty_io.c is cosmetic, but hopefully makes sense anyway. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Alan Cox <number6@the-village.bc.nu> [tty parts] Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Eric Biederman <ebiederm@xmission.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Serge Hallyn <serue@us.ibm.com> Cc: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02pids: refactor vnr/nr_ns helpers to make them safeOleg Nesterov
Inho, the safety rules for vnr/nr_ns helpers are horrible and buggy. task_pid_nr_ns(task) needs rcu/tasklist depending on task == current. As for "special" pids, vnr/nr_ns helpers always need rcu. However, if task != current, they are unsafe even under rcu lock, we can't trust task->group_leader without the special checks. And almost every helper has a callsite which needs a fix. Also, it is a bit annoying that the implementations of, say, task_pgrp_vnr() and task_pgrp_nr_ns() are not "symmetrical". This patch introduces the new helper, __task_pid_nr_ns(), which is always safe to use, and turns all other helpers into the trivial wrappers. After this I'll send another patch which converts task_tgid_xxx() as well, they're are a bit special. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Louis Rilling <Louis.Rilling@kerlabs.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02pids: improve get_task_pid() to fix the unsafe sys_wait4()->task_pgrp()Oleg Nesterov
sys_wait4() does get_pid(task_pgrp(current)), this is not safe. We can add rcu lock/unlock around, but we already have get_task_pid() which can be improved to handle the special pids in more reliable manner. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Louis Rilling <Louis.Rilling@kerlabs.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
