commit a2140fc0cb0325bb6384e788edd27b9a568714e2 upstream.
Refcounting of fsnotify_mark in audit tree is broken. E.g:
refcount
create_chunk
alloc_chunk 1
fsnotify_add_mark 2
untag_chunk
fsnotify_get_mark 3
fsnotify_destroy_mark
audit_tree_freeing_mark 2
fsnotify_put_mark 1
fsnotify_put_mark 0
via destroy_list
fsnotify_mark_destroy -1
This was reported by various people as triggering Oops when stopping auditd.
We could just remove the put_mark from audit_tree_freeing_mark() but that would
break freeing via inode destruction. So this patch simply omits a put_mark
after calling destroy_mark or adds a get_mark before.
The additional get_mark is necessary where there's no other put_mark after
fsnotify_destroy_mark() since it assumes that the caller is holding a reference
(or the inode is keeping the mark pinned, not the case here AFAICS).
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Reported-by: Valentin Avram <aval13@gmail.com>
Reported-by: Peter Moody <pmoody@google.com>
Acked-by: Eric Paris <eparis@redhat.com>
commit 0fe33aae0e94b4097dd433c9399e16e17d638cd8 upstream.
Don't do free_chunk() after fsnotify_add_mark(). That one does a delayed unref
via the destroy list and this results in use-after-free.
commit c5857ccf293968348e5eb4ebedc68074de3dcda6 upstream.
With the new interrupt sampling system, we are no longer using the
timer_rand_state structure in the irq descriptor, so we can stop
initializing it now.
[ Merged in fixes from Sedat to find some last missing references to
rand_initialize_irq() ]
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Signed-off-by: Sedat Dilek <sedat.dilek@gmail.com>
commit 775f4b297b780601e61787b766f306ed3e1d23eb upstream.
We've been moving away from add_interrupt_randomness() for various
reasons: it's too expensive to do on every interrupt, and flooding the
CPU with interrupts could theoretically cause bogus floods of entropy
from a somewhat externally controllable source.
This solves both problems by limiting the actual randomness addition
to just once a second or after 64 interrupts, whicever comes first.
During that time, the interrupt cycle data is buffered up in a per-cpu
pool. Also, we make sure the the nonblocking pool used by urandom is
initialized before we start feeding the normal input pool. This
assures that /dev/urandom is returning unpredictable data as soon as
possible.
(Based on an original patch by Linus, but significantly modified by
tytso.)
Tested-by: Eric Wustrow <ewust@umich.edu>
Reported-by: Eric Wustrow <ewust@umich.edu>
Reported-by: Nadia Heninger <nadiah@cs.ucsd.edu>
Reported-by: Zakir Durumeric <zakir@umich.edu>
Reported-by: J. Alex Halderman <jhalderm@umich.edu>
commit 6f7b0a2a5c0fb03be7c25bd1745baa50582348ef upstream.
If uaddr == uaddr2, then we have broken the rule of only requeueing
from a non-pi futex to a pi futex with this call. If we attempt this,
as the trinity test suite manages to do, we miss early wakeups as
q.key is equal to key2 (because they are the same uaddr). We will then
attempt to dereference the pi_mutex (which would exist had the futex_q
been properly requeued to a pi futex) and trigger a NULL pointer
dereference.
Signed-off-by: Darren Hart <dvhart@linux.intel.com>
Cc: Dave Jones <davej@redhat.com>
Link: http://lkml.kernel.org/r/ad82bfe7f7d130247fbe2b5b4275654807774227.1342809673.git.dvhart@linux.intel.com
commit f27071cb7fe3e1d37a9dbe6c0dfc5395cd40fa43 upstream.
The WARN_ON in futex_wait_requeue_pi() for a NULL q.pi_state was testing
the address (&q.pi_state) of the pointer instead of the value
(q.pi_state) of the pointer. Correct it accordingly.
Link: http://lkml.kernel.org/r/1c85d97f6e5f79ec389a4ead3e367363c74bd09a.1342809673.git.dvhart@linux.intel.com
commit b6070a8d9853eda010a549fa9a09eb8d7269b929 upstream.
If fixup_pi_state_owner() faults, pi_mutex may be NULL. Test
for pi_mutex != NULL before testing the owner against current
and possibly unlocking it.
Cc: Dan Carpenter <dan.carpenter@oracle.com>
Link: http://lkml.kernel.org/r/dc59890338fc413606f04e5c5b131530734dae3d.1342809673.git.dvhart@linux.intel.com
commit 6575820221f7a4dd6eadecf7bf83cdd154335eda upstream.
Currently, all workqueue cpu hotplug operations run off
CPU_PRI_WORKQUEUE which is higher than normal notifiers. This is to
ensure that workqueue is up and running while bringing up a CPU before
other notifiers try to use workqueue on the CPU.
Per-cpu workqueues are supposed to remain working and bound to the CPU
for normal CPU_DOWN_PREPARE notifiers. This holds mostly true even
with workqueue offlining running with higher priority because
workqueue CPU_DOWN_PREPARE only creates a bound trustee thread which
runs the per-cpu workqueue without concurrency management without
explicitly detaching the existing workers.
However, if the trustee needs to create new workers, it creates
unbound workers which may wander off to other CPUs while
CPU_DOWN_PREPARE notifiers are in progress. Furthermore, if the CPU
down is cancelled, the per-CPU workqueue may end up with workers which
aren't bound to the CPU.
While reliably reproducible with a convoluted artificial test-case
involving scheduling and flushing CPU burning work items from CPU down
notifiers, this isn't very likely to happen in the wild, and, even
when it happens, the effects are likely to be hidden by the following
successful CPU down.
Fix it by using different priorities for up and down notifiers - high
priority for up operations and low priority for down operations.
Workqueue cpu hotplug operations will soon go through further cleanup.
Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl>
commit 443772d408a25af62498793f6f805ce3c559309a upstream.
If function tracing is enabled for some of the low-level suspend/resume
functions, it leads to triple fault during resume from suspend, ultimately
ending up in a reboot instead of a resume (or a total refusal to come out
of suspended state, on some machines).
This issue was explained in more detail in commit f42ac38c59e0a03d (ftrace:
disable tracing for suspend to ram). However, the changes made by that commit
got reverted by commit cbe2f5a6e84eebb (tracing: allow tracing of
suspend/resume & hibernation code again). So, unfortunately since things are
not yet robust enough to allow tracing of low-level suspend/resume functions,
suspend/resume is still broken when ftrace is enabled.
So fix this by disabling function tracing during suspend/resume & hibernation.
Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
commit cc9a6c8776615f9c194ccf0b63a0aa5628235545 upstream.
Stable note: Not tracked in Bugzilla. [get|put]_mems_allowed() is extremely
expensive and severely impacted page allocator performance. This
is part of a series of patches that reduce page allocator overhead.
Commit c0ff7453bb5c ("cpuset,mm: fix no node to alloc memory when
changing cpuset's mems") wins a super prize for the largest number of
memory barriers entered into fast paths for one commit.
[get|put]_mems_allowed is incredibly heavy with pairs of full memory
barriers inserted into a number of hot paths. This was detected while
investigating at large page allocator slowdown introduced some time
after 2.6.32. The largest portion of this overhead was shown by
oprofile to be at an mfence introduced by this commit into the page
allocator hot path.
For extra style points, the commit introduced the use of yield() in an
implementation of what looks like a spinning mutex.
This patch replaces the full memory barriers on both read and write
sides with a sequence counter with just read barriers on the fast path
side. This is much cheaper on some architectures, including x86. The
main bulk of the patch is the retry logic if the nodemask changes in a
manner that can cause a false failure.
While updating the nodemask, a check is made to see if a false failure
is a risk. If it is, the sequence number gets bumped and parallel
allocators will briefly stall while the nodemask update takes place.
In a page fault test microbenchmark, oprofile samples from
__alloc_pages_nodemask went from 4.53% of all samples to 1.15%. The
actual results were
3.3.0-rc3 3.3.0-rc3
rc3-vanilla nobarrier-v2r1
Clients 1 UserTime 0.07 ( 0.00%) 0.08 (-14.19%)
Clients 2 UserTime 0.07 ( 0.00%) 0.07 ( 2.72%)
Clients 4 UserTime 0.08 ( 0.00%) 0.07 ( 3.29%)
Clients 1 SysTime 0.70 ( 0.00%) 0.65 ( 6.65%)
Clients 2 SysTime 0.85 ( 0.00%) 0.82 ( 3.65%)
Clients 4 SysTime 1.41 ( 0.00%) 1.41 ( 0.32%)
Clients 1 WallTime 0.77 ( 0.00%) 0.74 ( 4.19%)
Clients 2 WallTime 0.47 ( 0.00%) 0.45 ( 3.73%)
Clients 4 WallTime 0.38 ( 0.00%) 0.37 ( 1.58%)
Clients 1 Flt/sec/cpu 497620.28 ( 0.00%) 520294.53 ( 4.56%)
Clients 2 Flt/sec/cpu 414639.05 ( 0.00%) 429882.01 ( 3.68%)
Clients 4 Flt/sec/cpu 257959.16 ( 0.00%) 258761.48 ( 0.31%)
Clients 1 Flt/sec 495161.39 ( 0.00%) 517292.87 ( 4.47%)
Clients 2 Flt/sec 820325.95 ( 0.00%) 850289.77 ( 3.65%)
Clients 4 Flt/sec 1020068.93 ( 0.00%) 1022674.06 ( 0.26%)
MMTests Statistics: duration
Sys Time Running Test (seconds) 135.68 132.17
User+Sys Time Running Test (seconds) 164.2 160.13
Total Elapsed Time (seconds) 123.46 120.87
The overall improvement is small but the System CPU time is much
improved and roughly in correlation to what oprofile reported (these
performance figures are without profiling so skew is expected). The
actual number of page faults is noticeably improved.
For benchmarks like kernel builds, the overall benefit is marginal but
the system CPU time is slightly reduced.
To test the actual bug the commit fixed I opened two terminals. The
first ran within a cpuset and continually ran a small program that
faulted 100M of anonymous data. In a second window, the nodemask of the
cpuset was continually randomised in a loop.
Without the commit, the program would fail every so often (usually
within 10 seconds) and obviously with the commit everything worked fine.
With this patch applied, it also worked fine so the fix should be
functionally equivalent.
Cc: Miao Xie <miaox@cn.fujitsu.com>
Cc: Christoph Lameter <cl@linux.com>
commit b246272ecc5ac68c743b15c9e41a2275f7ce70e2 upstream.
expensive and severely impacted page allocator performance. This is
Kernels where MAX_NUMNODES > BITS_PER_LONG may temporarily see an empty
nodemask in a tsk's mempolicy if its previous nodemask is remapped onto a
new set of allowed cpuset nodes where the two nodemasks, as a result of
the remap, are now disjoint.
c0ff7453bb5c ("cpuset,mm: fix no node to alloc memory when changing
cpuset's mems") adds get_mems_allowed() to prevent the set of allowed
nodes from changing for a thread. This causes any update to a set of
allowed nodes to stall until put_mems_allowed() is called.
This stall is unncessary, however, if at least one node remains unchanged
in the update to the set of allowed nodes. This was addressed by
89e8a244b97e ("cpusets: avoid looping when storing to mems_allowed if one
node remains set"), but it's still possible that an empty nodemask may be
read from a mempolicy because the old nodemask may be remapped to the new
nodemask during rebind. To prevent this, only avoid the stall if there is
no mempolicy for the thread being changed.
This is a temporary solution until all reads from mempolicy nodemasks can
be guaranteed to not be empty without the get_mems_allowed()
synchronization.
Also moves the check for nodemask intersection inside task_lock() so that
tsk->mems_allowed cannot change. This ensures that nothing can set this
tsk's mems_allowed out from under us and also protects tsk->mempolicy.
Reported-by: Miao Xie <miaox@cn.fujitsu.com>
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Paul Menage <paul@paulmenage.org>
commit 89e8a244b97e48f1f30e898b6f32acca477f2a13 upstream.
extremely expensive and severely impacted page allocator performance.
This is part of a series of patches that reduce page allocator
overhead.
{get,put}_mems_allowed() exist so that general kernel code may locklessly
access a task's set of allowable nodes without having the chance that a
concurrent write will cause the nodemask to be empty on configurations
where MAX_NUMNODES > BITS_PER_LONG.
This could incur a significant delay, however, especially in low memory
conditions because the page allocator is blocking and reclaim requires
get_mems_allowed() itself. It is not atypical to see writes to
cpuset.mems take over 2 seconds to complete, for example. In low memory
conditions, this is problematic because it's one of the most imporant
times to change cpuset.mems in the first place!
The only way a task's set of allowable nodes may change is through cpusets
by writing to cpuset.mems and when attaching a task to a generic code is
not reading the nodemask with get_mems_allowed() at the same time, and
then clearing all the old nodes. This prevents the possibility that a
reader will see an empty nodemask at the same time the writer is storing a
new nodemask.
If at least one node remains unchanged, though, it's possible to simply
set all new nodes and then clear all the old nodes. Changing a task's
nodemask is protected by cgroup_mutex so it's guaranteed that two threads
are not changing the same task's nodemask at the same time, so the
nodemask is guaranteed to be stored before another thread changes it and
determines whether a node remains set or not.
Cc: Nick Piggin <npiggin@kernel.dk>
commit 6b1859dba01c7d512b72d77e3fd7da8354235189 upstream.
In commit 6b43ae8a619d17c4935c3320d2ef9e92bdeed05d, I
introduced a bug that kept the STA_INS or STA_DEL bit
from being cleared from time_status via adjtimex()
without forcing STA_PLL first.
Usually once the STA_INS is set, it isn't cleared
until the leap second is applied, so its unlikely this
affected anyone. However during testing I noticed it
took some effort to cancel a leap second once STA_INS
was set.
Signed-off-by: John Stultz <johnstul@us.ibm.com>
Cc: Richard Cochran <richardcochran@gmail.com>
Cc: Prarit Bhargava <prarit@redhat.com>
Link: http://lkml.kernel.org/r/1342156917-25092-2-git-send-email-john.stultz@linaro.org
This is a backport of 3e997130bd2e8c6f5aaa49d6e3161d4d29b43ab0
The leap second rework unearthed another issue of inconsistent data.
On timekeeping_resume() the timekeeper data is updated, but nothing
calls timekeeping_update(), so now the update code in the timer
interrupt sees stale values.
This has been the case before those changes, but then the timer
interrupt was using stale data as well so this went unnoticed for quite
some time.
Add the missing update call, so all the data is consistent everywhere.
Reported-by: Andreas Schwab <schwab@linux-m68k.org>
Reported-and-tested-by: "Rafael J. Wysocki" <rjw@sisk.pl>
Reported-and-tested-by: Martin Steigerwald <Martin@lichtvoll.de>
Cc: John Stultz <johnstul@us.ibm.com>
Cc: Peter Zijlstra <a.p.zijlstra@chello.nl>,
This is a backport of 5baefd6d84163443215f4a99f6a20f054ef11236
The update of the hrtimer base offsets on all cpus cannot be made
atomically from the timekeeper.lock held and interrupt disabled region
as smp function calls are not allowed there.
clock_was_set(), which enforces the update on all cpus, is called
either from preemptible process context in case of do_settimeofday()
or from the softirq context when the offset modification happened in
the timer interrupt itself due to a leap second.
In both cases there is a race window for an hrtimer interrupt between
dropping timekeeper lock, enabling interrupts and clock_was_set()
issuing the updates. Any interrupt which arrives in that window will
see the new time but operate on stale offsets.
So we need to make sure that an hrtimer interrupt always sees a
consistent state of time and offsets.
ktime_get_update_offsets() allows us to get the current monotonic time
and update the per cpu hrtimer base offsets from hrtimer_interrupt()
to capture a consistent state of monotonic time and the offsets. The
function replaces the existing ktime_get() calls in hrtimer_interrupt().
The overhead of the new function vs. ktime_get() is minimal as it just
adds two store operations.
This ensures that any changes to realtime or boottime offsets are
noticed and stored into the per-cpu hrtimer base structures, prior to
any hrtimer expiration and guarantees that timers are not expired early.
Reviewed-by: Ingo Molnar <mingo@kernel.org>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Acked-by: Prarit Bhargava <prarit@redhat.com>
Link: http://lkml.kernel.org/r/1341960205-56738-8-git-send-email-johnstul@us.ibm.com
This is a backport of f6c06abfb3972ad4914cef57d8348fcb2932bc3b
To finally fix the infamous leap second issue and other race windows
caused by functions which change the offsets between the various time
bases (CLOCK_MONOTONIC, CLOCK_REALTIME and CLOCK_BOOTTIME) we need a
function which atomically gets the current monotonic time and updates
the offsets of CLOCK_REALTIME and CLOCK_BOOTTIME with minimalistic
overhead. The previous patch which provides ktime_t offsets allows us
to make this function almost as cheap as ktime_get() which is going to
be replaced in hrtimer_interrupt().
Link: http://lkml.kernel.org/r/1341960205-56738-7-git-send-email-johnstul@us.ibm.com
This is a backport of 196951e91262fccda81147d2bcf7fdab08668b40
We need to update the base offsets from this code and we need to do
that under base->lock. Move the lock held region around the
ktime_get() calls. The ktime_get() calls are going to be replaced with
a function which gets the time and the offsets atomically.
Link: http://lkml.kernel.org/r/1341960205-56738-6-git-send-email-johnstul@us.ibm.com
This is a backport of 5b9fe759a678e05be4937ddf03d50e950207c1c0
We need to update the hrtimer clock offsets from the hrtimer interrupt
context. To avoid conversions from timespec to ktime_t maintain a
ktime_t based representation of those offsets in the timekeeper. This
puts the conversion overhead into the code which updates the
underlying offsets and provides fast accessible values in the hrtimer
interrupt.
Link: http://lkml.kernel.org/r/1341960205-56738-4-git-send-email-johnstul@us.ibm.com
This is a backport of 4873fa070ae84a4115f0b3c9dfabc224f1bc7c51
The timekeeping code misses an update of the hrtimer subsystem after a
leap second happened. Due to that timers based on CLOCK_REALTIME are
either expiring a second early or late depending on whether a leap
second has been inserted or deleted until an operation is initiated
which causes that update. Unless the update happens by some other
means this discrepancy between the timekeeping and the hrtimer data
stays forever and timers are expired either early or late.
The reported immediate workaround - $ data -s "`date`" - is causing a
call to clock_was_set() which updates the hrtimer data structures.
See: http://www.sheeri.com/content/mysql-and-leap-second-high-cpu-and-fix
Add the missing clock_was_set() call to update_wall_time() in case of
a leap second event. The actual update is deferred to softirq context
as the necessary smp function call cannot be invoked from hard
interrupt context.
Reported-by: Jan Engelhardt <jengelh@inai.de>
Link: http://lkml.kernel.org/r/1341960205-56738-3-git-send-email-johnstul@us.ibm.com
This is a backport of f55a6faa384304c89cfef162768e88374d3312cb
clock_was_set() cannot be called from hard interrupt context because
it calls on_each_cpu().
For fixing the widely reported leap seconds issue it is necessary to
call it from hard interrupt context, i.e. the timer tick code, which
does the timekeeping updates.
Provide a new function which denotes it in the hrtimer cpu base
structure of the cpu on which it is called and raise the hrtimer
softirq. We then execute the clock_was_set() notificiation from
softirq context in run_hrtimer_softirq(). The hrtimer softirq is
rarely used, so polling the flag there is not a performance issue.
[ tglx: Made it depend on CONFIG_HIGH_RES_TIMERS. We really should get
rid of all this ifdeffery ASAP ]
Link: http://lkml.kernel.org/r/1341960205-56738-2-git-send-email-johnstul@us.ibm.com
This is a backport of cc06268c6a87db156af2daed6e96a936b955cc82
While not a bugfix itself, it allows following fixes to backport
in a more straightforward manner.
CC: Thomas Gleixner <tglx@linutronix.de>
CC: Eric Dumazet <eric.dumazet@gmail.com>
CC: Richard Cochran <richardcochran@gmail.com>
Signed-off-by: John Stultz <john.stultz@linaro.org>
This is a backport of fad0c66c4bb836d57a5f125ecd38bed653ca863a
which resolves a bug the previous commit.
Commit 6b43ae8a61 (ntp: Fix leap-second hrtimer livelock) broke the
leapsecond update of CLOCK_MONOTONIC. The missing leapsecond update to
wall_to_monotonic causes discontinuities in CLOCK_MONOTONIC.
Adjust wall_to_monotonic when NTP inserted a leapsecond.
Reported-by: Richard Cochran <richardcochran@gmail.com>
Tested-by: Richard Cochran <richardcochran@gmail.com>
Link: http://lkml.kernel.org/r/1338400497-12420-1-git-send-email-john.stultz@linaro.org
This is a backport of dd48d708ff3e917f6d6b6c2b696c3f18c019feed
When repeating a UTC time value during a leap second (when the UTC
time should be 23:59:60), the TAI timescale should not stop. The kernel
NTP code increments the TAI offset one second too late. This patch fixes
the issue by incrementing the offset during the leap second itself.
Signed-off-by: Richard Cochran <richardcochran@gmail.com>
This is a backport of 6b43ae8a619d17c4935c3320d2ef9e92bdeed05d
This should have been backported when it was commited, but I
mistook the problem as requiring the ntp_lock changes
that landed in 3.4 in order for it to occur.
Unfortunately the same issue can happen (with only one cpu)
as follows:
do_adjtimex()
write_seqlock_irq(&xtime_lock);
process_adjtimex_modes()
process_adj_status()
ntp_start_leap_timer()
hrtimer_start()
hrtimer_reprogram()
tick_program_event()
clockevents_program_event()
ktime_get()
seq = req_seqbegin(xtime_lock); [DEADLOCK]
This deadlock will no always occur, as it requires the
leap_timer to force a hrtimer_reprogram which only happens
if its set and there's no sooner timer to expire.
NOTE: This patch, being faithful to the original commit,
introduces a bug (we don't update wall_to_monotonic),
which will be resovled by backporting a following fix.
Original commit message below:
Since commit 7dffa3c673fbcf835cd7be80bb4aec8ad3f51168 the ntp
subsystem has used an hrtimer for triggering the leapsecond
adjustment. However, this can cause a potential livelock.
Thomas diagnosed this as the following pattern:
CPU 0 CPU 1
do_adjtimex()
spin_lock_irq(&ntp_lock);
process_adjtimex_modes(); timer_interrupt()
process_adj_status(); do_timer()
ntp_start_leap_timer(); write_lock(&xtime_lock);
hrtimer_start(); update_wall_time();
hrtimer_reprogram(); ntp_tick_length()
tick_program_event() spin_lock(&ntp_lock);
ktime_get()
This patch tries to avoid the problem by reverting back to not using
an hrtimer to inject leapseconds, and instead we handle the leapsecond
processing in the second_overflow() function.
The downside to this change is that on systems that support highres
timers, the leap second processing will occur on a HZ tick boundary,
(ie: ~1-10ms, depending on HZ) after the leap second instead of
possibly sooner (~34us in my tests w/ x86_64 lapic).
This patch applies on top of tip/timers/core.
CC: Sasha Levin <levinsasha928@gmail.com>
Reported-by: Sasha Levin <levinsasha928@gmail.com>
Diagnoised-by: Thomas Gleixner <tglx@linutronix.de>
Tested-by: Sasha Levin <levinsasha928@gmail.com>
commit 71babb2705e2203a64c27ede13ae3508a0d2c16c upstream.
According to Documentation/trace/ftrace.txt:
tracing_cpumask:
This is a mask that lets the user only trace
on specified CPUS. The format is a hex string
representing the CPUS.
The tracing_cpumask currently doesn't affect the tracing state of
per-CPU ring buffers.
This patch enables/disables CPU recording as its corresponding bit in
tracing_cpumask is set/unset.
Link: http://lkml.kernel.org/r/1336096792-25373-3-git-send-email-vnagarnaik@google.com
Cc: Laurent Chavey <chavey@google.com>
Cc: Justin Teravest <teravest@google.com>
Cc: David Sharp <dhsharp@google.com>
Signed-off-by: Vaibhav Nagarnaik <vnagarnaik@google.com>
commit a841f8cef4bb124f0f5563314d0beaf2e1249d72 upstream.
It does not get processed because sched_domain_level_max is 0 at the
time that setup_relax_domain_level() is run.
Simply accept the value as it is, as we don't know the value of
sched_domain_level_max until sched domain construction is completed.
Fix sched_relax_domain_level in cpuset. The build_sched_domain() routine calls
the set_domain_attribute() routine prior to setting the sd->level, however,
the set_domain_attribute() routine relies on the sd->level to decide whether
idle load balancing will be off/on.
Signed-off-by: Dimitri Sivanich <sivanich@sgi.com>
Link: http://lkml.kernel.org/r/20120605184436.GA15668@sgi.com
active
commit 544ecf310f0e7f51fa057ac2a295fc1b3b35a9d3 upstream.
worker_enter_idle() has WARN_ON_ONCE() which triggers if nr_running
isn't zero when every worker is idle. This can trigger spuriously
while a cpu is going down due to the way trustee sets %WORKER_ROGUE
and zaps nr_running.
It first sets %WORKER_ROGUE on all workers without updating
nr_running, releases gcwq->lock, schedules, regrabs gcwq->lock and
then zaps nr_running. If the last running worker enters idle
inbetween, it would see stale nr_running which hasn't been zapped yet
and trigger the WARN_ON_ONCE().
Fix it by performing the sanity check iff the trustee is idle.
Reported-by: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
commit b7dafa0ef3145c31d7753be0a08b3cbda51f0209 upstream.
compat_sys_sigprocmask reads a smaller signal mask from userspace than
sigprogmask accepts for setting. So the high word of blocked.sig[0]
will be cleared, releasing any potentially blocked RT signal.
This was discovered via userspace code that relies on get/setcontext.
glibc's i386 versions of those functions use sigprogmask instead of
rt_sigprogmask to save/restore signal mask and caused RT signal
unblocking this way.
As suggested by Linus, this replaces the sys_sigprocmask based compat
version with one that open-codes the required logic, including the merge
of the existing blocked set with the new one provided on SIG_SETMASK.
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
commit 5e2bf0142231194d36fdc9596b36a261ed2b9fe7 upstream.
Fork() failure post namespace creation for a child cloned with
CLONE_NEWPID leaks pid_namespace/mnt_cache due to proc being mounted
during creation, but not unmounted during cleanup. Call
pid_ns_release_proc() during cleanup.
Signed-off-by: Mike Galbraith <efault@gmx.de>
Acked-by: Oleg Nesterov <oleg@redhat.com>
Reviewed-by: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Pavel Emelyanov <xemul@parallels.com>
Cc: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Louis Rilling <louis.rilling@kerlabs.com>
commit c308b56b5398779cd3da0f62ab26b0453494c3d4 upstream.
[ backported to 3.0 by Kerin Millar <kerframil@gmail.com>]
Various people reported nohz load tracking still being wrecked, but Doug
spotted the actual problem. We fold the nohz remainder in too soon,
causing us to loose samples and under-account.
So instead of playing catch-up up-front, always do a single load-fold
with whatever state we encounter and only then fold the nohz remainder
and play catch-up.
Reported-by: Doug Smythies <dsmythies@telus.net>
Reported-by: LesÅ=82aw Kope=C4=87 <leslaw.kopec@nasza-klasa.pl>
Reported-by: Aman Gupta <aman@tmm1.net>
Link: http://lkml.kernel.org/n/tip-4v31etnhgg9kwd6ocgx3rxl8@git.kernel.org
Cc: Kerin Millar <kerframil@gmail.com>
commit bdbb776f882f5ad431aa1e694c69c1c3d6a4a5b8 upstream.
It was possible to extract the robust list head address from a setuid
process if it had used set_robust_list(), allowing an ASLR info leak. This
changes the permission checks to be the same as those used for similar
info that comes out of /proc.
Running a setuid program that uses robust futexes would have had:
cred->euid != pcred->euid
cred->euid == pcred->uid
so the old permissions check would allow it. I'm not aware of any setuid
programs that use robust futexes, so this is just a preventative measure.
(This patch is based on changes from grsecurity.)
Cc: Darren Hart <dvhart@linux.intel.com>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Serge E. Hallyn <serge.hallyn@canonical.com>
Cc: kernel-hardening@lists.openwall.com
Cc: spender@grsecurity.net
Link: http://lkml.kernel.org/r/20120319231253.GA20893@www.outflux.net
commit 6f103929f8979d2638e58d7f7fda0beefcb8ee7e upstream.
Fix tick_nohz_restart() to not use a stale ktime_t "now" value when
calling tick_do_update_jiffies64(now).
If we reach this point in the loop it means that we crossed a tick
boundary since we grabbed the "now" timestamp, so at this point "now"
refers to a time in the old jiffy, so using the old value for "now" is
incorrect, and is likely to give us a stale jiffies value.
In particular, the first time through the loop the
tick_do_update_jiffies64(now) call is always a no-op, since the
caller, tick_nohz_restart_sched_tick(), will have already called
tick_do_update_jiffies64(now) with that "now" value.
Note that tick_nohz_stop_sched_tick() already uses the correct
approach: when we notice we cross a jiffy boundary, grab a new
timestamp with ktime_get(), and *then* update jiffies.
Signed-off-by: Neal Cardwell <ncardwell@google.com>
Cc: Ben Segall <bsegall@google.com>
Link: http://lkml.kernel.org/r/1332875377-23014-1-git-send-email-ncardwell@google.com
commit 79549c6dfda0603dba9a70a53467ce62d9335c33 upstream.
keyctl_session_to_parent(task) sets ->replacement_session_keyring,
it should be processed and cleared by key_replace_session_keyring().
However, this task can fork before it notices TIF_NOTIFY_RESUME and
the new child gets the bogus ->replacement_session_keyring copied by
dup_task_struct(). This is obviously wrong and, if nothing else, this
leads to put_cred(already_freed_cred).
change copy_creds() to clear this member. If copy_process() fails
before this point the wrong ->replacement_session_keyring doesn't
matter, exit_creds() won't be called.
commit 620f6e8e855d6d447688a5f67a4e176944a084e8 upstream.
Commit bfdc0b4 adds code to restrict access to dmesg_restrict,
however, it incorrectly alters kptr_restrict rather than
dmesg_restrict.
The original patch from Richard Weinberger
(https://lkml.org/lkml/2011/3/14/362) alters dmesg_restrict as
expected, and so the patch seems to have been misapplied.
This adds the CAP_SYS_ADMIN check to both dmesg_restrict and
kptr_restrict, since both are sensitive.
Reported-by: Phillip Lougher <plougher@redhat.com>
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Acked-by: Richard Weinberger <richard@nod.at>
Signed-off-by: James Morris <james.l.morris@oracle.com>
commit 98b54aa1a2241b59372468bd1e9c2d207bdba54b upstream.
There is extra state information that needs to be exposed in the
kgdb_bpt structure for tracking how a breakpoint was installed. The
debug_core only uses the the probe_kernel_write() to install
breakpoints, but this is not enough for all the archs. Some arch such
as x86 need to use text_poke() in order to install a breakpoint into a
read only page.
Passing the kgdb_bpt structure to kgdb_arch_set_breakpoint() and
kgdb_arch_remove_breakpoint() allows other archs to set the type
variable which indicates how the breakpoint was installed.
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
commit 01de982abf8c9e10fc3089e10585cd2cc914bdab upstream.
8 hex characters tell only half the tale for 64 bit CPUs,
so use the appropriate length.
Link: http://lkml.kernel.org/r/1332411501-8059-2-git-send-email-wolfgang.mauerer@siemens.com
Signed-off-by: Wolfgang Mauerer <wolfgang.mauerer@siemens.com>
commit f5cb92ac82d06cb583c1f66666314c5c0a4d7913 upstream.
irq_move_masked_irq() checks the return code of
chip->irq_set_affinity() only for 0, but IRQ_SET_MASK_OK_NOCOPY is
also a valid return code, which is there to avoid a redundant copy of
the cpumask. But in case of IRQ_SET_MASK_OK_NOCOPY we not only avoid
the redundant copy, we also fail to adjust the thread affinity of an
eventually threaded interrupt handler.
Handle IRQ_SET_MASK_OK (==0) and IRQ_SET_MASK_OK_NOCOPY(==1) return
values correctly by checking the valid return values seperately.
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
Cc: Jiang Liu <liuj97@gmail.com>
Cc: Keping Chen <chenkeping@huawei.com>
Link: http://lkml.kernel.org/r/1333120296-13563-2-git-send-email-jiang.liu@huawei.com
commit f946eeb9313ff1470758e171a60fe7438a2ded3f upstream.
Module size was limited to 64MB, this was legacy limitation due to vmalloc()
which was removed a while ago.
Limiting module size to 64MB is both pointless and affects real world use
cases.
Cc: Tim Abbott <tim.abbott@oracle.com>
commit 05b4877f6a4f1ba4952d1222213d262bf8c132b7 upstream.
If create_basic_memory_bitmaps() fails, usermodehelpers are not re-enabled
before returning. Fix this. And while at it, reword the goto labels so that
they look more meaningful.
commit 540b60e24f3f4781d80e47122f0c4486a03375b8 upstream.
We do not want a bitwise AND between boolean operands
Signed-off-by: Alexander Gordeev <agordeev@redhat.com>
Link: http://lkml.kernel.org/r/20120309135912.GA2114@dhcp-26-207.brq.redhat.com
commit a09b659cd68c10ec6a30cb91ebd2c327fcd5bfe5 upstream.
In 2008, commit 0c5d1eb77a8be ("genirq: record trigger type") modified the
way set_irq_type() handles the 'no trigger' condition. However, this has
an adverse effect on PCMCIA support on Intel StrongARM and probably PXA
platforms.
PCMCIA has several status signals on the socket which can trigger
interrupts; some of these status signals depend on the card's mode
(whether it is configured in memory or IO mode). For example, cards have
a 'Ready/IRQ' signal: in memory mode, this provides an indication to
PCMCIA that the card has finished its power up initialization. In IO
mode, it provides the device interrupt signal. Other status signals
switch between on-board battery status and loud speaker output.
In classical PCMCIA implementations, where you have a specific socket
controller, the controller provides a method to mask interrupts from the
socket, and importantly ignore any state transitions on the pins which
correspond with interrupts once masked. This masking prevents unwanted
events caused by the removal and application of socket power being
forwarded.
However, on platforms where there is no socket controller, the PCMCIA
status and interrupt signals are routed to standard edge-triggered GPIOs.
These GPIOs can be configured to interrupt on rising edge, falling edge,
or never. This is where the problems start.
Edge triggered interrupts are required to record events while disabled via
the usual methods of {free,request,disable,enable}_irq() to prevent
problems with dropped interrupts (eg, the 8390 driver uses disable_irq()
to defer the delivery of interrupts). As a result, these interfaces can
not be used to implement the desired behaviour.
The side effect of this is that if the 'Ready/IRQ' GPIO is disabled via
disable_irq() on suspend, and enabled via enable_irq() after resume, we
will record the state transitions caused by powering events as valid
interrupts, and foward them to the card driver, which may attempt to
access a card which is not powered up.
This leads delays resume while drivers spin in their interrupt handlers,
and complaints from drivers before they realize what's happened.
Moreover, in the case of the 'Ready/IRQ' signal, this is requested and
freed by the card driver itself; the PCMCIA core has no idea whether the
interrupt is requested, and, therefore, whether a call to disable_irq()
would be valid. (We tried this around 2.4.17 / 2.5.1 kernel era, and
ended up throwing it out because of this problem.)
Therefore, it was decided back in around 2002 to disable the edge
triggering instead, resulting in all state transitions on the GPIO being
ignored. That's what we actually need the hardware to do.
The commit above changes this behaviour; it explicitly prevents the 'no
trigger' state being selected.
The reason that request_irq() does not accept the 'no trigger' state is
for compatibility with existing drivers which do not provide their desired
triggering configuration. The set_irq_type() function is 'new' and not
used by non-trigger aware drivers.
Therefore, revert this change, and restore previously working platforms
back to their former state.
Cc: linux@arm.linux.org.uk
commit a078c6d0e6288fad6d83fb6d5edd91ddb7b6ab33 upstream.
'long secs' is passed as divisor to div_s64, which accepts a 32bit
divisor. On 64bit machines that value is trimmed back from 8 bytes
back to 4, causing a divide by zero when the number is bigger than
(1 << 32) - 1 and all 32 lower bits are 0.
Use div64_long() instead.
Signed-off-by: Sasha Levin <levinsasha928@gmail.com>
Cc: johnstul@us.ibm.com
Link: http://lkml.kernel.org/r/1331829374-31543-2-git-send-email-levinsasha928@gmail.com
commit 59263b513c11398cd66a52d4c5b2b118ce1e0359 upstream.
Some of the newer futex PI opcodes do not check the cmpxchg enabled
variable and call unconditionally into the handling functions. Cover
all PI opcodes in a separate check.
commit 62d3c5439c534b0e6c653fc63e6d8c67be3a57b1 upstream.
This patch (as1519) fixes a bug in the block layer's disk-events
polling. The polling is done by a work routine queued on the
system_nrt_wq workqueue. Since that workqueue isn't freezable, the
polling continues even in the middle of a system sleep transition.
Obviously, polling a suspended drive for media changes and such isn't
a good thing to do; in the case of USB mass-storage devices it can
lead to real problems requiring device resets and even re-enumeration.
The patch fixes things by creating a new system-wide, non-reentrant,
freezable workqueue and using it for disk-events polling.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Acked-by: Tejun Heo <tj@kernel.org>
Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
3.0.21's 603b63484725a6e88e4ae5da58716efd88154b1e directly used
the upstream patch, yet kprobes locking in 3.0.x uses spin_lock...()
rather than raw_spin_lock...().
Signed-off-by: Jan Beulich <jbeulich@suse.com>
commit 52abb700e16a9aa4cbc03f3d7f80206cbbc80680 upstream.
Xommit ac5637611(genirq: Unmask oneshot irqs when thread was not woken)
fails to unmask when a !IRQ_ONESHOT threaded handler is handled by
handle_level_irq.
This happens because thread_mask is or'ed unconditionally in
irq_wake_thread(), but for !IRQ_ONESHOT interrupts never cleared. So
the check for !desc->thread_active fails and keeps the interrupt
disabled.
Keep the thread_mask zero for !IRQ_ONESHOT interrupts.
Document the thread_mask magic while at it.
Reported-and-tested-by: Sven Joachim <svenjoac@gmx.de>
Reported-and-tested-by: Stefan Lippers-Hollmann <s.l-h@gmx.de>
commit d80e731ecab420ddcb79ee9d0ac427acbc187b4b upstream.
This patch is intentionally incomplete to simplify the review.
It ignores ep_unregister_pollwait() which plays with the same wqh.
See the next change.
epoll assumes that the EPOLL_CTL_ADD'ed file controls everything
f_op->poll() needs. In particular it assumes that the wait queue
can't go away until eventpoll_release(). This is not true in case
of signalfd, the task which does EPOLL_CTL_ADD uses its ->sighand
which is not connected to the file.
This patch adds the special event, POLLFREE, currently only for
epoll. It expects that init_poll_funcptr()'ed hook should do the
necessary cleanup. Perhaps it should be defined as EPOLLFREE in
eventpoll.
__cleanup_sighand() is changed to do wake_up_poll(POLLFREE) if
->signalfd_wqh is not empty, we add the new signalfd_cleanup()
helper.
ep_poll_callback(POLLFREE) simply does list_del_init(task_list).
This make this poll entry inconsistent, but we don't care. If you
share epoll fd which contains our sigfd with another process you
should blame yourself. signalfd is "really special". I simply do
not know how we can define the "right" semantics if it used with
epoll.
The main problem is, epoll calls signalfd_poll() once to establish
the connection with the wait queue, after that signalfd_poll(NULL)
returns the different/inconsistent results depending on who does
EPOLL_CTL_MOD/signalfd_read/etc. IOW: apart from sigmask, signalfd
has nothing to do with the file, it works with the current thread.
In short: this patch is the hack which tries to fix the symptoms.
It also assumes that nobody can take tasklist_lock under epoll
locks, this seems to be true.
Note:
- we do not have wake_up_all_poll() but wake_up_poll()
is fine, poll/epoll doesn't use WQ_FLAG_EXCLUSIVE.
- signalfd_cleanup() uses POLLHUP along with POLLFREE,
we need a couple of simple changes in eventpoll.c to
make sure it can't be "lost".
Reported-by: Maxime Bizon <mbizon@freebox.fr>
commit b4bc724e82e80478cba5fe9825b62e71ddf78757 upstream.
An interrupt might be pending when irq_startup() is called, but the
startup code does not invoke the resend logic. In some cases this
prevents the device from issuing another interrupt which renders the
device non functional.
Call the resend function in irq_startup() to keep things going.
Reported-and-tested-by: Russell King <rmk+kernel@arm.linux.org.uk>
commit ac5637611150281f398bb7a47e3fcb69a09e7803 upstream.
When the primary handler of an interrupt which is marked IRQ_ONESHOT
returns IRQ_HANDLED or IRQ_NONE, then the interrupt thread is not
woken and the unmask logic of the interrupt line is never
invoked. This keeps the interrupt masked forever.
This was not noticed as most IRQ_ONESHOT users wake the thread
unconditionally (usually because they cannot access the underlying
device from hard interrupt context). Though this behaviour was nowhere
documented and not necessarily intentional. Some drivers can avoid the
thread wakeup in certain cases and run into the situation where the
interrupt line s kept masked.
Handle it gracefully.
Reported-and-tested-by: Lothar Wassmann <lw@karo-electronics.de>
commit f6302f1bcd75a042df69866d98b8d775a668f8f1 upstream.
"subbuf_size" and "n_subbufs" come from the user and they need to be
capped to prevent an integer overflow.
