commit b786c6a98ef6fa81114ba7b9fbfc0d67060775e3 upstream.
One fail path in relay_late_setup_files() omits
mutex_unlock(&relay_channels_mutex);
Add it.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
commit 9a055117d3d9cb562f83f8d4cd88772761f4cab0 upstream.
To keep the raw monotonic patch simple first introduce
clocksource_forward_now(), which takes care of the offset since the last
update_wall_time() call and adds it to the clock, so there is no need
anymore to deal with it explicitly at various places, which need to make
significant changes to the clock.
This is also gets rid of the timekeeping_suspend_nsecs, instead of
waiting until resume, the value is accumulated during suspend. In the end
there is only a single user of __get_nsec_offset() left, so I integrated
it back to getnstimeofday().
Signed-off-by: Roman Zippel <zippel@linux-m68k.org>
commit d25141a818383b3c3b09f065698c544a7a0ec6e7 upstream.
Currently "kill <sig> -1" kills processes in all namespaces and breaks the
isolation of namespaces. Earlier attempt to fix this was discussed at:
http://lkml.org/lkml/2008/7/23/148
As suggested by Oleg Nesterov in that thread, use "task_pid_vnr() > 1"
check since task_pid_vnr() returns 0 if process is outside the caller's
namespace.
Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com>
Acked-by: Eric W. Biederman <ebiederm@xmission.com>
Tested-by: Daniel Hokka Zakrisson <daniel@hozac.com>
commit d4e82042c4cfa87a7d51710b71f568fe80132551 upstream.
commit 836f92adf121f806e9beb5b6b88bd5c9c4ea3f24 upstream.
commit 6559eed8ca7db0531a207cd80be5e28cd6f213c5 upstream.
commit 1e7bfb2134dfec37ce04fb3a4ca89299e892d10c upstream.
commit c4ea37c26a691ad0b7e86aa5884aab27830e95c9 upstream.
commit e48fbb699f82ef1e80bd7126046394d2dc9ca7e6 upstream.
commit 5a8a82b1d306a325d899b67715618413657efda4 upstream.
commit 003d7ab479168132a2b2c6700fe682b08f08ab0c upstream.
commit a6b42e83f249aad723589b2bdf6d1dfb2b0997c8 upstream.
commit ca013e945b1ba5828b151ee646946f1297b67a4c upstream.
commit a5f8fa9e9ba5ef3305e147f41ad6e1e84ac1f0bd upstream.
commit 17da2bd90abf428523de0fb98f7075e00e3ed42e upstream.
commit 754fe8d297bfae7b77f7ce866e2fb0c5fb186506 upstream.
commit 5add95d4f7cf08f6f62510f19576992912387501 upstream.
commit 362e9c07c7220c0a78c88826fc0d2bf7e4a4bb68 upstream.
commit b290ebe2c46d01b742b948ce03f09e8a3efb9a92 upstream.
commit ae1251ab785f6da87219df8352ffdac68bba23e4 upstream.
commit dbf040d9d1cbf1ef6250bdb095c5c118950bcde8 upstream.
commit 58fd3aa288939d3097fa04505b25c2f5e6e144d1 upstream.
commit f627a741d24f12955fa2d9f8831c3b12860635bd upstream.
Remove the -ENOSYS implementation for !CONFIG_PRINTK and use
the cond_syscall infrastructure instead.
Acked-by: Kyle McMartin <kyle@redhat.com>
commit 2ed7c03ec17779afb4fcfa3b8c61df61bd4879ba upstream.
Convert all system calls to return a long. This should be a NOP since all
converted types should have the same size anyway.
With the exception of sys_exit_group which returned void. But that doesn't
matter since the system call doesn't return.
commit 1c5745aa380efb6417b5681104b007c8612fb496 upstream.
Redo:
5b7dba4: sched_clock: prevent scd->clock from moving backwards
which had to be reverted due to s2ram hangs:
ca7e716: Revert "sched_clock: prevent scd->clock from moving backwards"
... this time with resume restoring GTOD later in the sequence
taken into account as well.
The "timekeeping_suspended" flag is not very nice but we cannot call into
GTOD before it has been properly resumed and the scheduler will run very
early in the resume sequence.
commit 7b574b7b0124ed344911f5d581e9bc2d83bbeb19 upstream.
The race is calling cgroup_clone() while umounting the ns cgroup subsys,
and thus cgroup_clone() might access invalid cgroup_fs, or kill_sb() is
called after cgroup_clone() created a new dir in it.
The BUG I triggered is BUG_ON(root->number_of_cgroups != 1);
kernel BUG at kernel/cgroup.c:1093!
invalid opcode: 0000 [#1] SMP
Process umount (pid: 5177, ti=e411e000 task=e40c4670 task.ti=e411e000)
Call Trace:
[<c0493df7>] ? deactivate_super+0x3f/0x51
[<c04a3600>] ? mntput_no_expire+0xb3/0xdd
[<c04a3ab2>] ? sys_umount+0x265/0x2ac
[<c04a3b06>] ? sys_oldumount+0xd/0xf
[<c0403911>] ? sysenter_do_call+0x12/0x31
EIP: [<c0456e76>] cgroup_kill_sb+0x23/0xe0 SS:ESP 0068:e411ef2c
---[ end trace c766c1be3bf944ac ]---
Cc: Serge E. Hallyn <serue@us.ibm.com>
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
Cc: Paul Menage <menage@google.com>
Cc: "Serge E. Hallyn" <serue@us.ibm.com>
Cc: Balbir Singh <balbir@in.ibm.com>
commit ca7e716c7833aeaeb8fedd6d004c5f5d5e14d325 upstream.
This reverts commit 5b7dba4ff834259a5623e03a565748704a8fe449, which
caused a regression in hibernate, reported by and bisected by Fabio
Comolli.
This revert fixes
http://bugzilla.kernel.org/show_bug.cgi?id=12155
http://bugzilla.kernel.org/show_bug.cgi?id=12149
Bisected-by: Fabio Comolli <fabio.comolli@gmail.com>
Requested-by: Rafael J. Wysocki <rjw@sisk.pl>
Acked-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
commit b88ed20594db2c685555b68c52b693b75738b2f5 upstream.
Lee Schermerhorn noticed yesterday that I broke the mapping_writably_mapped
test in 2.6.7! Bad bad bug, good good find.
The i_mmap_writable count must be incremented for VM_SHARED (just as
i_writecount is for VM_DENYWRITE, but while holding the i_mmap_lock)
when dup_mmap() copies the vma for fork: it has its own more optimal
version of __vma_link_file(), and I missed this out. So the count
was later going down to 0 (dangerous) when one end unmapped, then
wrapping negative (inefficient) when the other end unmapped.
The only impact on x86 would have been that setting a mandatory lock on
a file which has at some time been opened O_RDWR and mapped MAP_SHARED
(but not necessarily PROT_WRITE) across a fork, might fail with -EAGAIN
when it should succeed, or succeed when it should fail.
But those architectures which rely on flush_dcache_page() to flush
userspace modifications back into the page before the kernel reads it,
may in some cases have skipped the flush after such a fork - though any
repetitive test will soon wrap the count negative, in which case it will
flush_dcache_page() unnecessarily.
Fix would be a two-liner, but mapping variable added, and comment moved.
Reported-by: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
Signed-off-by: Hugh Dickins <hugh@veritas.com>
commit 9a2bd244e18ffbb96c8b783210fda4eded7c7e6f upstream.
Impact: fix possible deadlock in CPU hot-remove path
This patch fixes a possible deadlock scenario in the CPU remove path.
migration_call grabs rq->lock, then wakes up everything on rq->migration_queue
with the lock held. Then one of the tasks on the migration queue ends up
calling tg_shares_up which then also tries to acquire the same rq->lock.
[c000000058eab2e0] c000000000502078 ._spin_lock_irqsave+0x98/0xf0
[c000000058eab370] c00000000008011c .tg_shares_up+0x10c/0x20c
[c000000058eab430] c00000000007867c .walk_tg_tree+0xc4/0xfc
[c000000058eab4d0] c0000000000840c8 .try_to_wake_up+0xb0/0x3c4
[c000000058eab590] c0000000000799a0 .__wake_up_common+0x6c/0xe0
[c000000058eab640] c00000000007ada4 .complete+0x54/0x80
[c000000058eab6e0] c000000000509fa8 .migration_call+0x5fc/0x6f8
[c000000058eab7c0] c000000000504074 .notifier_call_chain+0x68/0xe0
[c000000058eab860] c000000000506568 ._cpu_down+0x2b0/0x3f4
[c000000058eaba60] c000000000506750 .cpu_down+0xa4/0x108
[c000000058eabb10] c000000000507e54 .store_online+0x44/0xa8
[c000000058eabba0] c000000000396260 .sysdev_store+0x3c/0x50
[c000000058eabc10] c0000000001a39b8 .sysfs_write_file+0x124/0x18c
[c000000058eabcd0] c00000000013061c .vfs_write+0xd0/0x1bc
[c000000058eabd70] c0000000001308a4 .sys_write+0x68/0x114
[c000000058eabe30] c0000000000086b4 syscall_exit+0x0/0x40
Signed-off-by: Brian King <brking@linux.vnet.ibm.com>
Acked-by: Peter Zijlstra <peterz@infradead.org>
commit f29c9b1ccb52904ee442a933cf3dee628f9f4e62 upstream.
Impact: re-add incorrectly eliminated sched domain layers
(1) on i386 with SCHED_SMT and SCHED_MC enabled
# mount -t cgroup -o cpuset xxx /mnt
# echo 0 > /mnt/cpuset.sched_load_balance
# mkdir /mnt/0
# echo 0 > /mnt/0/cpuset.cpus
# dmesg
CPU0 attaching sched-domain:
domain 0: span 0 level CPU
groups: 0
(2) on i386 with SCHED_MC enabled but SCHED_SMT disabled
# same with (1)
# dmesg
CPU0 attaching NULL sched-domain.
The bug is that some sched domains may be skipped unintentionally when
degenerating (optimizing) sched domains.
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Cc: Gregory Haskins <ghaskins@novell.com>
commit 65ecc14a30ad21bed9aabdfd6a2ae1a1aaaa6a00 upstream, tweaked to get
it to apply to 2.6.27
For some unknown reason at Steven Rostedt added in disabling of the SPE
instruction generation for e500 based PPC cores in commit
6ec562328fda585be2d7f472cfac99d3b44d362a.
We are removing it because:
1. It generates e500 kernels that don't work
2. its not the correct set of flags to do this
3. we handle this in the arch/powerpc/Makefile already
4. its unknown in talking to Steven why he did this
Tested-and-Acked-by: Steven Rostedt <srostedt@redhat.com>
commit 8f7b0ba1c853919b85b54774775f567f30006107 upstream.
Inotify watch removals suck violently.
To kick the watch out we need (in this order) inode->inotify_mutex and
ih->mutex. That's fine if we have a hold on inode; however, for all
other cases we need to make damn sure we don't race with umount. We can
*NOT* just grab a reference to a watch - inotify_unmount_inodes() will
happily sail past it and we'll end with reference to inode potentially
outliving its superblock.
Ideally we just want to grab an active reference to superblock if we
can; that will make sure we won't go into inotify_umount_inodes() until
we are done. Cleanup is just deactivate_super().
However, that leaves a messy case - what if we *are* racing with
umount() and active references to superblock can't be acquired anymore?
We can bump ->s_count, grab ->s_umount, which will almost certainly wait
until the superblock is shut down and the watch in question is pining
for fjords. That's fine, but there is a problem - we might have hit the
window between ->s_active getting to 0 / ->s_count - below S_BIAS (i.e.
the moment when superblock is past the point of no return and is heading
for shutdown) and the moment when deactivate_super() acquires
->s_umount.
We could just do drop_super() yield() and retry, but that's rather
antisocial and this stuff is luser-triggerable. OTOH, having grabbed
->s_umount and having found that we'd got there first (i.e. that
->s_root is non-NULL) we know that we won't race with
inotify_umount_inodes().
So we could grab a reference to watch and do the rest as above, just
with drop_super() instead of deactivate_super(), right? Wrong. We had
to drop ih->mutex before we could grab ->s_umount. So the watch
could've been gone already.
That still can be dealt with - we need to save watch->wd, do idr_find()
and compare its result with our pointer. If they match, we either have
the damn thing still alive or we'd lost not one but two races at once,
the watch had been killed and a new one got created with the same ->wd
at the same address. That couldn't have happened in inotify_destroy(),
but inotify_rm_wd() could run into that. Still, "new one got created"
is not a problem - we have every right to kill it or leave it alone,
whatever's more convenient.
So we can use idr_find(...) == watch && watch->inode->i_sb == sb as
"grab it and kill it" check. If it's been our original watch, we are
fine, if it's a newcomer - nevermind, just pretend that we'd won the
race and kill the fscker anyway; we are safe since we know that its
superblock won't be going away.
And yes, this is far beyond mere "not very pretty"; so's the entire
concept of inotify to start with.
Acked-by: Greg KH <greg@kroah.com>
commit 7ef9964e6d1b911b78709f144000aacadd0ebc21 upstream.
It has been thought that the per-user file descriptors limit would also
limit the resources that a normal user can request via the epoll
interface. Vegard Nossum reported a very simple program (a modified
version attached) that can make a normal user to request a pretty large
amount of kernel memory, well within the its maximum number of fds. To
solve such problem, default limits are now imposed, and /proc based
configuration has been introduced. A new directory has been created,
named /proc/sys/fs/epoll/ and inside there, there are two configuration
max_user_instances = Maximum number of devices - per user
max_user_watches = Maximum number of "watched" fds - per user
The current default for "max_user_watches" limits the memory used by epoll
to store "watches", to 1/32 of the amount of the low RAM. As example, a
256MB 32bit machine, will have "max_user_watches" set to roughly 90000.
That should be enough to not break existing heavy epoll users. The
default value for "max_user_instances" is set to 128, that should be
enough too.
This also changes the userspace, because a new error code can now come out
from EPOLL_CTL_ADD (-ENOSPC). The EMFILE from epoll_create() was already
listed, so that should be ok.
[akpm@linux-foundation.org: use get_current_user()]
Signed-off-by: Davide Libenzi <davidel@xmailserver.org>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Cc: Cyrill Gorcunov <gorcunov@gmail.com>
Reported-by: Vegard Nossum <vegardno@ifi.uio.no>
commit 33d283bef23132c48195eafc21449f8ba88fce6b upstream.
Try this, and you'll get oops immediately:
# cd Documentation/accounting/
# gcc -o getdelays getdelays.c
# mount -t cgroup -o debug xxx /mnt
# ./getdelays -C /mnt/tasks
Because a normal file's dentry->d_fsdata is a pointer to struct cftype,
not struct cgroup.
After the patch, it returns EINVAL if we try to get cgroupstats
from a normal file.
Cc: Balbir Singh <balbir@linux.vnet.ibm.com>
Acked-by: Paul Menage <menage@google.com>
commit 700018e0a77b4113172257fcdaa1c58e27a5074f upstream.
Impact: properly rebuild sched-domains on kmalloc() failure
When cpuset failed to generate sched domains due to kmalloc()
failure, the scheduler should fallback to the single partition
'fallback_doms' and rebuild sched domains, but now it only
destroys but not rebuilds sched domains.
The regression was introduced by:
| commit dfb512ec4834116124da61d6c1ee10fd0aa32bd6
| Author: Max Krasnyansky <maxk@qualcomm.com>
| Date: Fri Aug 29 13:11:41 2008 -0700
| sched: arch_reinit_sched_domains() must destroy domains to force rebuild
After the above commit, partition_sched_domains(0, NULL, NULL) will
only destroy sched domains and partition_sched_domains(1, NULL, NULL)
will create the default sched domain.
Cc: Max Krasnyansky <maxk@qualcomm.com>
commit 24eb089950ce44603b30a3145a2c8520e2b55bb1 upstream
This fixes an oops when reading /proc/sched_debug.
A cgroup won't be removed completely until finishing cgroup_diput(), so we
shouldn't invalidate cgrp->dentry in cgroup_rmdir(). Otherwise, when a
group is being removed while cgroup_path() gets called, we may trigger
NULL dereference BUG.
The bug can be reproduced:
# cat test.sh
#!/bin/sh
mount -t cgroup -o cpu xxx /mnt
for (( ; ; ))
mkdir /mnt/sub
rmdir /mnt/sub
# ./test.sh &
# cat /proc/sched_debug
BUG: unable to handle kernel NULL pointer dereference at 00000038
IP: [<c045a47f>] cgroup_path+0x39/0x90
Call Trace:
[<c0420344>] ? print_cfs_rq+0x6e/0x75d
[<c0421160>] ? sched_debug_show+0x72d/0xc1e
commit 5b7dba4ff834259a5623e03a565748704a8fe449 upstream
When sched_clock_cpu() couples the clocks between two cpus, it may
increment scd->clock beyond the GTOD tick window that __update_sched_clock()
uses to clamp the clock. A later call to __update_sched_clock() may move
the clock back to scd->tick_gtod + TICK_NSEC, violating the clock's
monotonic property.
This patch ensures that scd->clock will not be set backward.
Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
Cc: Chuck Ebbert <cebbert@redhat.com>
commit 0c4b83da58ec2e96ce9c44c211d6eac5f9dae478 upstream
sched: disable the hrtick for now
David Miller reported that hrtick update overhead has tripled the
wakeup overhead on Sparc64.
That is too much - disable the HRTICK feature for now by default,
until a faster implementation is found.
Reported-by: David Miller <davem@davemloft.net>
commit c851c8676bd7ae456e9b3af8e6bb2c434eddcc75 upstream
If NR_CPUS isn't a multiple of 32, we get a truncated string of sched
domains by catting /proc/schedstat. This is caused by the wrong mask_len.
This patch fixes it.
Signed-off-by: Miao Xie <miaox@cn.fujitsu.com>
commit e94320939f44e0cbaccc3f259a5778abced4949c upstream
Fix "notes" kobject leak
It happens every rmmod if KALLSYMS=y and SYSFS=y.
# modprobe foo
kobject: 'foo' (ffffffffa00743d0): kobject_add_internal: parent: 'module', set: 'module'
kobject: 'holders' (ffff88017e7c5770): kobject_add_internal: parent: 'foo', set: '<NULL>'
kobject: 'foo' (ffffffffa00743d0): kobject_uevent_env
kobject: 'foo' (ffffffffa00743d0): fill_kobj_path: path = '/module/foo'
kobject: 'notes' (ffff88017fa9b668): kobject_add_internal: parent: 'foo', set: '<NULL>'
# rmmod foo
kobject: 'holders' (ffff88017e7c5770): kobject_cleanup
kobject: 'holders' (ffff88017e7c5770): auto cleanup kobject_del
kobject: 'holders' (ffff88017e7c5770): calling ktype release
kobject: (ffff88017e7c5770): dynamic_kobj_release
kobject: 'holders': free name
kobject: 'foo' (ffffffffa00743d0): kobject_cleanup
kobject: 'foo' (ffffffffa00743d0): does not have a release() function, it is broken and must be fixed.
kobject: 'foo' (ffffffffa00743d0): auto cleanup 'remove' event
kobject: 'foo' (ffffffffa00743d0): auto cleanup kobject_del
kobject: 'foo': free name
[whooops]
commit f6121f4f8708195e88cbdf8dd8d171b226b3f858 upstream
While working on the new version of the code for SCHED_SPORADIC I
noticed something strange in the present throttling mechanism. More
specifically in the throttling timer handler in sched_rt.c
(do_sched_rt_period_timer()) and in rt_rq_enqueue().
The problem is that, when unthrottling a runqueue, rt_rq_enqueue() only
asks for rescheduling if the runqueue has a sched_entity associated to
it (i.e., rt_rq->rt_se != NULL).
Now, if the runqueue is the root rq (which has a rt_se = NULL)
rescheduling does not take place, and it is delayed to some undefined
instant in the future.
This imply some random bandwidth usage by the RT tasks under throttling.
For instance, setting rt_runtime_us/rt_period_us = 950ms/1000ms an RT
task will get less than 95%. In our tests we got something varying
between 70% to 95%.
Using smaller time values, e.g., 95ms/100ms, things are even worse, and
I can see values also going down to 20-25%!!
The tests we performed are simply running 'yes' as a SCHED_FIFO task,
and checking the CPU usage with top, but we can investigate thoroughly
if you think it is needed.
Things go much better, for us, with the attached patch... Don't know if
it is the best approach, but it solved the issue for us.
Signed-off-by: Dario Faggioli <raistlin@linux.it>
Signed-off-by: Michael Trimarchi <trimarchimichael@yahoo.it>
While debugging the e1000e corruption bug with Intel, we discovered
today that the dynamic ftrace code in mainline is the likely source of
this bug.
For the stable kernel we are providing the only viable fix patch: labeling
CONFIG_DYNAMIC_FTRACE as broken. (see the patch below)
We will follow up with a backport patch that contains the fixes. But since
the fixes are not a one liner, the safest approach for now is to
disable the code in question.
The cause of the bug is due to the way the current code in mainline
handles dynamic ftrace. When dynamic ftrace is turned on, it also
turns on CONFIG_FTRACE which enables the -pg config in gcc that places
a call to mcount at every function call. With just CONFIG_FTRACE this
causes a noticeable overhead. CONFIG_DYNAMIC_FTRACE works to ease this
overhead by dynamically updating the mcount call sites into nops.
The problem arises when we trace functions and modules are unloaded.
The first time a function is called, it will call mcount and the mcount
call will call ftrace_record_ip. This records the calling site and
stores it in a preallocated hash table. Later on a daemon will
wake up and call kstop_machine and convert any mcount callers into
nops.
The evolution of this code first tried to do this without the kstop_machine
and used cmpxchg to update the callers as they were called. But I
was informed that this is dangerous to do on SMP machines if another
CPU is running that same code. The solution was to do this with
kstop_machine.
We still used cmpxchg to test if the code that we are modifying is
indeed code that we expect to be before updating it - as a final
line of defense.
But on 32bit machines, ioremapped memory and modules share the same
address space. When a module would load its code into memory and execute
some code, that would register the function.
On module unload, ftrace incorrectly did not zap these functions from
its hash (this was the bug). The cmpxchg could have saved us in most
cases (via luck) - but with ioremap-ed memory that was exactly the wrong
thing to do - the results of cmpxchg on device memory are undefined.
(and will likely result in a write)
The pending .28 ftrace tree does not have this bug anymore, as a general push
towards more robustness of code patching, this is done differently: we do not
use cmpxchg and we do a WARN_ON and turn the tracer off if anything deviates
from its expected state. Furthermore, patch sites are statically identified
during build time so there's no runtime discovery of dynamic code areas
anymore, and no room for code unmaps to cause the hash to become out of date.
We believe the fragility of dynamic patching has been sufficiently
addressed in the development code via the static patching method, but further
suggestions to make it more robust are welcome.
Signed-off-by: Steven Rostedt <srostedt@goodmis.org>
The softlockup watchdog needs to be touched when resuming the from the
kgdb stopped state to avoid the printk that a CPU is stuck if the
debugger was active for longer than the softlockup threshold.
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
Impact: jiffies increment too fast.
Hugh Dickins noted that with NOHZ=n and HIGHRES=n jiffies get
incremented too fast. The reason is a wrong check in the broadcast
enter/exit code, which keeps the local apic timer in periodic mode
when the switch happens.
Found by static checker (http://repo.or.cz/w/smatch.git).
* 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
hrtimer: prevent migration of per CPU hrtimers
hrtimer: mark migration state
hrtimer: fix migration of CB_IRQSAFE_NO_SOFTIRQ hrtimers
hrtimer: migrate pending list on cpu offline
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Tested-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
There's a race between mm->owner assignment and swapoff, more easily
seen when task slab poisoning is turned on. The condition occurs when
try_to_unuse() runs in parallel with an exiting task. A similar race
can occur with callers of get_task_mm(), such as /proc/<pid>/<mmstats>
or ptrace or page migration.
CPU0 CPU1
try_to_unuse
looks at mm = task0->mm
increments mm->mm_users
task 0 exits
mm->owner needs to be updated, but no
new owner is found (mm_users > 1, but
no other task has task->mm = task0->mm)
mm_update_next_owner() leaves
mmput(mm) decrements mm->mm_users
task0 freed
dereferencing mm->owner fails
The fix is to notify the subsystem via mm_owner_changed callback(),
if no new owner is found, by specifying the new task as NULL.
Jiri Slaby:
mm->owner was set to NULL prior to calling cgroup_mm_owner_callbacks(), but
must be set after that, so as not to pass NULL as old owner causing oops.
Daisuke Nishimura:
mm_update_next_owner() may set mm->owner to NULL, but mem_cgroup_from_task()
and its callers need to take account of this situation to avoid oops.
Hugh Dickins:
Lockdep warning and hang below exec_mmap() when testing these patches.
exit_mm() up_reads mmap_sem before calling mm_update_next_owner(),
so exec_mmap() now needs to do the same. And with that repositioning,
there's now no point in mm_need_new_owner() allowing for NULL mm.
Reported-by: Hugh Dickins <hugh@veritas.com>
Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com>
Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Impact: per CPU hrtimers can be migrated from a dead CPU
The hrtimer code has no knowledge about per CPU timers, but we need to
prevent the migration of such timers and warn when such a timer is
active at migration time.
Explicitely mark the timers as per CPU and use a more understandable
mode descriptor for the interrupts safe unlocked callback mode, which
is used by hrtimer_sleeper and the scheduler code.
Impact: during migration active hrtimers can be seen as inactive
The migration code removes the hrtimers from the queues of the dead
CPU and sets the state temporary to INACTIVE. The enqueue code sets it
to ACTIVE/PENDING again.
Prevent that the wrong state can be seen by using a separate migration
state bit.
Impact: Stale timers after a CPU went offline.
commit 37bb6cb4097e29ffee970065b74499cbf10603a3
hrtimer: unlock hrtimer_wakeup
changed the hrtimer sleeper callback mode to CB_IRQSAFE_NO_SOFTIRQ due
to locking problems. A result of this change is that when enqueue is
called for an already expired hrtimer the callback function is not
longer called directly from the enqueue code. The normal callers have
been fixed in the code, but the migration code which moves hrtimers
from a dead CPU to a live CPU was not made aware of this.
This can be fixed by checking the timer state after the call to
enqueue in the migration code.
