Pull NFS client updates from Trond Myklebust:
"Highlights include:
Stable fixes:
- fix an NFSv4.1 state renewal regression
- fix open/lock state recovery error handling
- fix lock recovery when CREATE_SESSION/SETCLIENTID_CONFIRM fails
- fix statd when reconnection fails
- don't wake tasks during connection abort
- don't start reboot recovery if lease check fails
- fix duplicate proc entries
Features:
- pNFS block driver fixes and clean ups from Christoph
- More code cleanups from Anna
- Improve mmap() writeback performance
- Replace use of PF_TRANS with a more generic mechanism for avoiding
deadlocks in nfs_release_page"
* tag 'nfs-for-3.18-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (66 commits)
NFSv4.1: Fix an NFSv4.1 state renewal regression
NFSv4: fix open/lock state recovery error handling
NFSv4: Fix lock recovery when CREATE_SESSION/SETCLIENTID_CONFIRM fails
NFS: Fabricate fscache server index key correctly
SUNRPC: Add missing support for RPC_CLNT_CREATE_NO_RETRANS_TIMEOUT
NFSv3: Fix missing includes of nfs3_fs.h
NFS/SUNRPC: Remove other deadlock-avoidance mechanisms in nfs_release_page()
NFS: avoid waiting at all in nfs_release_page when congested.
NFS: avoid deadlocks with loop-back mounted NFS filesystems.
MM: export page_wakeup functions
SCHED: add some "wait..on_bit...timeout()" interfaces.
NFS: don't use STABLE writes during writeback.
NFSv4: use exponential retry on NFS4ERR_DELAY for async requests.
rpc: Add -EPERM processing for xs_udp_send_request()
rpc: return sent and err from xs_sendpages()
lockd: Try to reconnect if statd has moved
SUNRPC: Don't wake tasks during connection abort
Fixing lease renewal
nfs: fix duplicate proc entries
pnfs/blocklayout: Fix a 64-bit division/remainder issue in bl_map_stripe
Pull crypto update from Herbert Xu:
- add multibuffer infrastructure (single_task_running scheduler helper,
OKed by Peter on lkml.
- add SHA1 multibuffer implementation for AVX2.
- reenable "by8" AVX CTR optimisation after fixing counter overflow.
- add APM X-Gene SoC RNG support.
- SHA256/SHA512 now handles unaligned input correctly.
- set lz4 decompressed length correctly.
- fix algif socket buffer allocation failure for 64K page machines.
- misc fixes
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (47 commits)
crypto: sha - Handle unaligned input data in generic sha256 and sha512.
Revert "crypto: aesni - disable "by8" AVX CTR optimization"
crypto: aesni - remove unused defines in "by8" variant
crypto: aesni - fix counter overflow handling in "by8" variant
hwrng: printk replacement
crypto: qat - Removed unneeded partial state
crypto: qat - Fix typo in name of tasklet_struct
crypto: caam - Dynamic allocation of addresses for various memory blocks in CAAM.
crypto: mcryptd - Fix typos in CRYPTO_MCRYPTD description
crypto: algif - avoid excessive use of socket buffer in skcipher
arm64: dts: add random number generator dts node to APM X-Gene platform.
Documentation: rng: Add X-Gene SoC RNG driver documentation
hwrng: xgene - add support for APM X-Gene SoC RNG support
crypto: mv_cesa - Add missing #define
crypto: testmgr - add test for lz4 and lz4hc
crypto: lz4,lz4hc - fix decompression
crypto: qat - Use pci_enable_msix_exact() instead of pci_enable_msix()
crypto: drbg - fix maximum value checks on 32 bit systems
crypto: drbg - fix sparse warning for cpu_to_be[32|64]
crypto: sha-mb - sha1_mb_alg_state can be static
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull arm64 updates from Catalin Marinas:
- eBPF JIT compiler for arm64
- CPU suspend backend for PSCI (firmware interface) with standard idle
states defined in DT (generic idle driver to be merged via a
different tree)
- Support for CONFIG_DEBUG_SET_MODULE_RONX
- Support for unmapped cpu-release-addr (outside kernel linear mapping)
- set_arch_dma_coherent_ops() implemented and bus notifiers removed
- EFI_STUB improvements when base of DRAM is occupied
- Typos in KGDB macros
- Clean-up to (partially) allow kernel building with LLVM
- Other clean-ups (extern keyword, phys_addr_t usage)
* tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (51 commits)
arm64: Remove unneeded extern keyword
ARM64: make of_device_ids const
arm64: Use phys_addr_t type for physical address
aarch64: filter $x from kallsyms
arm64: Use DMA_ERROR_CODE to denote failed allocation
arm64: Fix typos in KGDB macros
arm64: insn: Add return statements after BUG_ON()
arm64: debug: don't re-enable debug exceptions on return from el1_dbg
Revert "arm64: dmi: Add SMBIOS/DMI support"
arm64: Implement set_arch_dma_coherent_ops() to replace bus notifiers
of: amba: use of_dma_configure for AMBA devices
arm64: Correct ftrace calls to aarch64_insn_gen_branch_imm()
arm64:mm: initialize max_mapnr using function set_max_mapnr
setup: Move unmask of async interrupts after possible earlycon setup
arm64: LLVMLinux: Fix inline arm64 assembly for use with clang
arm64: pageattr: Correctly adjust unaligned start addresses
net: bpf: arm64: fix module memory leak when JIT image build fails
arm64: add PSCI CPU_SUSPEND based cpu_suspend support
arm64: kernel: introduce cpu_init_idle CPU operation
Pull ARM updates from Russell King:
"Included in these updates are:
- Performance optimisation to avoid writing the control register at
every exception.
- Use static inline instead of extern inline in ftrace code.
- Crypto ARM assembly updates for big endian
- Alignment of initrd/.init memory to page sizes when freeing to
ensure that we fully free the regions
- Add gcov support
- A couple of preparatory patches for VDSO support: use
_install_special_mapping, and randomize the sigpage placement above
stack.
- Add L2 ePAPR DT cache properties so that DT can specify the cache
geometry.
- Preparatory patch for FIQ (NMI) kernel C code for things like
spinlock lockup debug. Following on from this are a couple of my
patches cleaning up show_regs() and removing an unused (probably
since 1.x days) do_unexp_fiq() function.
- Use pr_warn() rather than pr_warning().
- A number of cleanups (smp, footbridge, return_address)"
* 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (21 commits)
ARM: 8167/1: extend the reserved memory for initrd to be page aligned
ARM: 8168/1: extend __init_end to a page align address
ARM: 8169/1: l2c: parse cache properties from ePAPR definitions
ARM: 8160/1: drop warning about return_address not using unwind tables
ARM: 8161/1: footbridge: select machine dir based on ARCH_FOOTBRIDGE
ARM: 8158/1: LLVMLinux: use static inline in ARM ftrace.h
ARM: 8155/1: place sigpage at a random offset above stack
ARM: 8154/1: use _install_special_mapping for sigpage
ARM: 8153/1: Enable gcov support on the ARM architecture
ARM: Avoid writing to control register on every exception
ARM: 8152/1: Convert pr_warning to pr_warn
ARM: remove unused do_unexp_fiq() function
ARM: remove extraneous newline in show_regs()
ARM: 8150/3: fiq: Replace default FIQ handler
ARM: 8140/1: ep93xx: Enable DEBUG_LL_UART_PL01X
ARM: 8139/1: versatile: Enable DEBUG_LL_UART_PL01X
ARM: 8138/1: drop ISAR0 workaround for B15
ARM: 8136/1: sa1100: add Micro ASIC platform device
ARM: 8131/1: arm/smp: Absorb boot_secondary()
ARM: 8126/1: crypto: enable NEON SHA-384/SHA-512 for big endian
Pull "trivial tree" updates from Jiri Kosina:
"Usual pile from trivial tree everyone is so eagerly waiting for"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Remove MN10300_PROC_MN2WS0038
mei: fix comments
treewide: Fix typos in Kconfig
kprobes: update jprobe_example.c for do_fork() change
Documentation: change "&" to "and" in Documentation/applying-patches.txt
Documentation: remove obsolete pcmcia-cs from Changes
Documentation: update links in Changes
Documentation: Docbook: Fix generated DocBook/kernel-api.xml
score: Remove GENERIC_HAS_IOMAP
gpio: fix 'CONFIG_GPIO_IRQCHIP' comments
tty: doc: Fix grammar in serial/tty
dma-debug: modify check_for_stack output
treewide: fix errors in printk
genirq: fix reference in devm_request_threaded_irq comment
treewide: fix synchronize_rcu() in comments
checkstack.pl: port to AArch64
doc: queue-sysfs: minor fixes
init/do_mounts: better syntax description
MIPS: fix comment spelling
powerpc/simpleboot: fix comment
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/dmaengine
Pull dmaengine updates from Dan Williams:
"Even though this has fixes marked for -stable, given the size and the
needed conflict resolutions this is 3.18-rc1/merge-window material.
These patches have been languishing in my tree for a long while. The
fact that I do not have the time to do proper/prompt maintenance of
this tree is a primary factor in the decision to step down as
dmaengine maintainer. That and the fact that the bulk of drivers/dma/
activity is going through Vinod these days.
The net_dma removal has not been in -next. It has developed simple
conflicts against mainline and net-next (for-3.18).
Continuing thanks to Vinod for staying on top of drivers/dma/.
Summary:
1/ Step down as dmaengine maintainer see commit 08223d80df38
"dmaengine maintainer update"
2/ Removal of net_dma, as it has been marked 'broken' since 3.13
(commit 77873803363c "net_dma: mark broken"), without reports of
performance regression.
3/ Miscellaneous fixes"
* tag 'dmaengine-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/dmaengine:
net: make tcp_cleanup_rbuf private
net_dma: revert 'copied_early'
net_dma: simple removal
dmatest: prevent memory leakage on error path in thread
ioat: Use time_before_jiffies()
dmaengine: fix xor sources continuation
dma: mv_xor: Rename __mv_xor_slot_cleanup() to mv_xor_slot_cleanup()
dma: mv_xor: Remove all callers of mv_xor_slot_cleanup()
dma: mv_xor: Remove unneeded mv_xor_clean_completed_slots() call
ioat: Use pci_enable_msix_exact() instead of pci_enable_msix()
drivers: dma: Include appropriate header file in dca.c
drivers: dma: Mark functions as static in dma_v3.c
dma: mv_xor: Add DMA API error checks
ioat/dca: Use dev_is_pci() to check whether it is pci device
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull module update from Rusty Russell:
"Nothing major: support for compressing modules, and auto-tainting
params.
PS. My virtio-next tree is empty: DaveM took the patches I had. There
might be a virtio-rng starvation fix, but so far it's a bit voodoo
so I will get to that in the next two days or it will wait"
* tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
moduleparam: Resolve missing-field-initializer warning
kbuild: handle module compression while running 'make modules_install'.
modinst: wrap long lines in order to enhance cmd_modules_install
modsign: lookup lines ending in .ko in .mod files
modpost: simplify file name generation of *.mod.c files
modpost: reduce visibility of symbols and constify r/o arrays
param: check for tainting before calling set op.
drm/i915: taint the kernel if unsafe module parameters are set
module: add module_param_unsafe and module_param_named_unsafe
module: make it possible to have unsafe, tainting module params
module: rename KERNEL_PARAM_FL_NOARG to avoid confusion
git://git.kernel.org/pub/scm/linux/kernel/git/josh/linux
Pull "tinification" patches from Josh Triplett.
Work on making smaller kernels.
* tag 'tiny/for-3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/josh/linux:
bloat-o-meter: Ignore syscall aliases SyS_ and compat_SyS_
mm: Support compiling out madvise and fadvise
x86: Support compiling out human-friendly processor feature names
x86: Drop support for /proc files when !CONFIG_PROC_FS
x86, boot: Don't compile early_serial_console.c when !CONFIG_EARLY_PRINTK
x86, boot: Don't compile aslr.c when !CONFIG_RANDOMIZE_BASE
x86, boot: Use the usual -y -n mechanism for objects in vmlinux
x86: Add "make tinyconfig" to configure the tiniest possible kernel
x86, platform, kconfig: move kvmconfig functionality to a helper
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace
Pull trace ring buffer iterator fix from Steven Rostedt:
"While testing some new changes for 3.18, I kept hitting a bug every so
often in the ring buffer. At first I thought it had to do with some
of the changes I was working on, but then testing something else I
realized that the bug was in 3.17 itself. I ran several bisects as
the bug was not very reproducible, and finally came up with the commit
that I could reproduce easily within a few minutes, and without the
change I could run the tests over an hour without issue. The change
fit the bug and I figured out a fix. That bad commit was:
Commit 651e22f2701b "ring-buffer: Always reset iterator to reader page"
This commit fixed a bug, but in the process created another one. It
used the wrong value as the cached value that is used to see if things
changed while an iterator was in use. This made it look like a change
always happened, and could cause the iterator to go into an infinite
loop"
* tag 'trace-fixes-v3.17-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace:
ring-buffer: Fix infinite spin in reading buffer
Oleg noticed that a cleanup by Sylvain actually uncovered a bug; by
calling perf_event_free_task() when failing sched_fork() we will not yet
have done the memset() on ->perf_event_ctxp[] and will therefore try and
'free' the inherited contexts, which are still in use by the parent
process. This is bad..
Suggested-by: Oleg Nesterov <oleg@redhat.com>
Reported-by: Oleg Nesterov <oleg@redhat.com>
Reported-by: Sylvain 'ythier' Hitier <sylvain.hitier@gmail.com>
Cc: <stable@vger.kernel.org>
fixed one bug but in the process caused another one. The reset is to
update the header page, but that fix also changed the way the cached
reads were updated. The cache reads are used to test if an iterator
needs to be updated or not.
A ring buffer iterator, when created, disables writes to the ring buffer
but does not stop other readers or consuming reads from happening.
Although all readers are synchronized via a lock, they are only
synchronized when in the ring buffer functions. Those functions may
be called by any number of readers. The iterator continues down when
its not interrupted by a consuming reader. If a consuming read
occurs, the iterator starts from the beginning of the buffer.
The way the iterator sees that a consuming read has happened since
its last read is by checking the reader "cache". The cache holds the
last counts of the read and the reader page itself.
Commit 651e22f2701b changed what was saved by the cache_read when
the rb_iter_reset() occurred, making the iterator never match the cache.
Then if the iterator calls rb_iter_reset(), it will go into an
infinite loop by checking if the cache doesn't match, doing the reset
and retrying, just to see that the cache still doesn't match! Which
should never happen as the reset is suppose to set the cache to the
current value and there's locks that keep a consuming reader from
having access to the data.
Fixes: 651e22f2701b "ring-buffer: Always reset iterator to reader page"
into for-next
Similar to ARM, AArch64 is generating $x and $d syms... which isn't
terribly helpful when looking at %pF output and the like. Filter those
out in kallsyms, modpost and when looking at module symbols.
Seems simplest since none of these check EM_ARM anyway, to just add it
to the strchr used, rather than trying to make things overly
complicated.
initcall_debug improves:
dmesg_before.txt: initcall $x+0x0/0x154 [sg] returned 0 after 26331 usecs
dmesg_after.txt: initcall init_sg+0x0/0x154 [sg] returned 0 after 15461 usecs
Signed-off-by: Kyle McMartin <kyle@redhat.com>
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
Per commit "77873803363c net_dma: mark broken" net_dma is no longer used
and there is no plan to fix it.
This is the mechanical removal of bits in CONFIG_NET_DMA ifdef guards.
Reverting the remainder of the net_dma induced changes is deferred to
subsequent patches.
Marked for stable due to Roman's report of a memory leak in
dma_pin_iovec_pages():
https://lkml.org/lkml/2014/9/3/177
Cc: Dave Jiang <dave.jiang@intel.com>
Cc: Vinod Koul <vinod.koul@intel.com>
Cc: David Whipple <whipple@securedatainnovations.ch>
Cc: Alexander Duyck <alexander.h.duyck@intel.com>
Reported-by: Roman Gushchin <klamm@yandex-team.ru>
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup
Pull cgroup fixes from Tejun Heo:
"This is quite late but these need to be backported anyway.
This is the fix for a long-standing cpuset bug which existed from
2009. cpuset makes use of PF_SPREAD_{PAGE|SLAB} flags to modify the
task's memory allocation behavior according to the settings of the
cpuset it belongs to; unfortunately, when those flags have to be
changed, cpuset did so directly even whlie the target task is running,
which is obviously racy as task->flags may be modified by the task
itself at any time. This obscure bug manifested as corrupt
PF_USED_MATH flag leading to a weird crash.
The bug is fixed by moving the flag to task->atomic_flags. The first
two are prepatory ones to help defining atomic_flags accessors and the
third one is the actual fix"
* 'for-3.17-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup:
cpuset: PF_SPREAD_PAGE and PF_SPREAD_SLAB should be atomic flags
sched: add macros to define bitops for task atomic flags
sched: fix confusing PFA_NO_NEW_PRIVS constant
Enable gcov support for ARM based on original patches by David
Singleton and George G. Davis
Riku - updated to patch to current mainline kernel. The patch
has been submitted in 2010, 2012 - for symmetry, now in 2014 too.
https://lwn.net/Articles/390419/
http://marc.info/?l=linux-arm-kernel&m=133823081813044
v2: remove arch/arm/kernel from gcov disabled files
Cc: Andrey Ryabinin <a.ryabinin@samsung.com>
Cc: Naresh Kamboju <naresh.kamboju@linaro.org>
Signed-off-by: Riku Voipio <riku.voipio@linaro.org>
Signed-off-by: Vincent Sanders <vincent.sanders@collabora.co.uk>
Pull ACPI and power management fixes from Rafael Wysocki:
"These are regression fixes (ACPI hotplug, cpufreq, hibernation, ACPI
LPSS driver), fixes for stuff that never worked correctly (ACPI GPIO
support in some cases and a wrong sign of an error code in the ACPI
core in one place), and one blacklist item for ACPI backlight
handling.
Specifics:
- Revert of a recent hibernation core commit that introduced a NULL
pointer dereference during resume for at least one user (Rafael J
Wysocki).
- Fix for the ACPI LPSS (Low-Power Subsystem) driver to disable
asynchronous PM callback execution for LPSS devices during system
suspend/resume (introduced in 3.16) which turns out to break
ordering expectations on some systems. From Fu Zhonghui.
- cpufreq core fix related to the handling of sysfs nodes during
system suspend/resume that has been broken for intel_pstate since
3.15 from Lan Tianyu.
- Restore the generation of "online" uevents for ACPI container
devices that was removed in 3.14, but some user space utilities
turn out to need them (Rafael J Wysocki).
- The cpufreq core fails to release a lock in an error code path
after changes made in 3.14. Fix from Prarit Bhargava.
- ACPICA and ACPI/GPIO fixes to make the handling of ACPI GPIO
operation regions (which means AML using GPIOs) work correctly in
all cases from Bob Moore and Srinivas Pandruvada.
- Fix for a wrong sign of the ACPI core's create_modalias() return
value in case of an error from Mika Westerberg.
- ACPI backlight blacklist entry for ThinkPad X201s from Aaron Lu"
* tag 'pm+acpi-3.17-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
Revert "PM / Hibernate: Iterate over set bits instead of PFNs in swsusp_free()"
gpio / ACPI: Use pin index and bit length
ACPICA: Update to GPIO region handler interface.
ACPI / platform / LPSS: disable async suspend/resume of LPSS devices
cpufreq: release policy->rwsem on error
cpufreq: fix cpufreq suspend/resume for intel_pstate
ACPI / scan: Correct error return value of create_modalias()
ACPI / video: disable native backlight for ThinkPad X201s
ACPI / hotplug: Generate online uevents for ACPI containers
In commit c1221321b7c25b53204447cff9949a6d5a7ddddc
sched: Allow wait_on_bit_action() functions to support a timeout
I suggested that a "wait_on_bit_timeout()" interface would not meet my
need. This isn't true - I was just over-engineering.
Including a 'private' field in wait_bit_key instead of a focused
"timeout" field was just premature generalization. If some other
use is ever found, it can be generalized or added later.
So this patch renames "private" to "timeout" with a meaning "stop
waiting when "jiffies" reaches or passes "timeout",
and adds two of the many possible wait..bit..timeout() interfaces:
wait_on_page_bit_killable_timeout(), which is the one I want to use,
and out_of_line_wait_on_bit_timeout() which is a reasonably general
example. Others can be added as needed.
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Signed-off-by: NeilBrown <neilb@suse.de>
Acked-by: Ingo Molnar <mingo@kernel.org>
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
When we change cpuset.memory_spread_{page,slab}, cpuset will flip
PF_SPREAD_{PAGE,SLAB} bit of tsk->flags for each task in that cpuset.
This should be done using atomic bitops, but currently we don't,
which is broken.
Tetsuo reported a hard-to-reproduce kernel crash on RHEL6, which happened
when one thread tried to clear PF_USED_MATH while at the same time another
thread tried to flip PF_SPREAD_PAGE/PF_SPREAD_SLAB. They both operate on
the same task.
Here's the full report:
https://lkml.org/lkml/2014/9/19/230
To fix this, we make PF_SPREAD_PAGE and PF_SPREAD_SLAB atomic flags.
v4:
- updated mm/slab.c. (Fengguang Wu)
- updated Documentation.
Cc: Miao Xie <miaox@cn.fujitsu.com>
Fixes: 950592f7b991 ("cpusets: update tasks' page/slab spread flags in time")
Cc: <stable@vger.kernel.org> # 2.6.31+
Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Signed-off-by: Zefan Li <lizefan@huawei.com>
Revert commit 6efde38f0769 (PM / Hibernate: Iterate over set bits
instead of PFNs in swsusp_free()) that introduced a NULL pointer
dereference during system resume from hibernation:
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<ffffffff810a8cc1>] swsusp_free+0x21/0x190
PGD b39c2067 PUD b39c1067 PMD 0
Oops: 0000 [#1] SMP
Modules linked in: <irrelevant list of modules>
CPU: 1 PID: 4898 Comm: s2disk Tainted: G C 3.17-rc5-amd64 #1 Debian 3.17~rc5-1~exp1
Hardware name: LENOVO 2776LEG/2776LEG, BIOS 6EET55WW (3.15 ) 12/19/2011
task: ffff88023155ea40 ti: ffff8800b3b14000 task.ti: ffff8800b3b14000
RIP: 0010:[<ffffffff810a8cc1>] [<ffffffff810a8cc1>]
RSP: 0018:ffff8800b3b17ea8 EFLAGS: 00010246
RAX: 0000000000000000 RBX: ffff8800b39bab00 RCX: 0000000000000001
RDX: ffff8800b39bab10 RSI: ffff8800b39bab00 RDI: 0000000000000000
RBP: 0000000000000010 R08: 0000000000000000 R09: 0000000000000000
R10: ffff8800b39bab10 R11: 0000000000000246 R12: ffffea0000000000
R13: ffff880232f485a0 R14: ffff88023ac27cd8 R15: ffff880232927590
FS: 00007f406d83b700(0000) GS:ffff88023bc80000(0000)
knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 0000000000000000 CR3: 00000000b3a62000 CR4: 00000000000007e0
Stack:
ffff8800b39bab00 0000000000000010 ffff880232927590 ffffffff810acb4a
ffff8800b39bab00 ffffffff811a955a ffff8800b39bab10 0000000000000000
ffff88023155f098 ffffffff81a6b8c0 ffff88023155ea40 0000000000000007
Call Trace:
[<ffffffff810acb4a>] ? snapshot_release+0x2a/0xb0
[<ffffffff811a955a>] ? __fput+0xca/0x1d0
[<ffffffff81080627>] ? task_work_run+0x97/0xd0
[<ffffffff81012d89>] ? do_notify_resume+0x69/0xa0
[<ffffffff8151452a>] ? int_signal+0x12/0x17
Code: 66 2e 0f 1f 84 00 00 00 00 00 66 66 66 66 90 41 54 48 8b 05 ba 62 9c 00 49 bc 00 00 00 00 00 ea ff ff 48 8b 3d a1 62 9c 00 55 53 <48> 8b 10 48 89 50 18 48 8b 52 20 48 c7 40 28 00 00 00 00 c7 40
RIP [<ffffffff810a8cc1>] swsusp_free+0x21/0x190
RSP <ffff8800b3b17ea8>
---[ end trace f02be86a1ec0cccb ]---
due to forbidden_pages_map being NULL in swsusp_free().
Fixes: 6efde38f0769 "PM / Hibernate: Iterate over set bits instead of PFNs in swsusp_free()"
Reported-by: Bjørn Mork <bjorn@mork.no>
Pull cgroup fix from Tejun Heo:
"One late fix for cgroup.
I was waiting for another set of fixes for a long-standing obscure
cpuset bug but am not sure whether they'll be ready before v3.17
release. This one is a simple fix for a mutex unlock balance bug in
an allocation failure path in pidlist_array_load().
The bug was introduced in v3.14 and the fix is tagged for -stable"
cgroup: fix unbalanced locking
'tiny/no-advice', 'tiny/tinyconfig' and 'tiny/x86-boot-compressed-use-yn' into tiny/next
Pull perf fixes from Ingo Molnar:
"Two kernel side fixes: a kprobes fix and a perf_remove_from_context()
fix (which does not yet fix the migration bug which is WIP)"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf: Fix a race condition in perf_remove_from_context()
kprobes/x86: Free 'optinsn' cache when range check fails
cgroup_pidlist_start() holds cgrp->pidlist_mutex and then calls
pidlist_array_load(), and cgroup_pidlist_stop() releases the mutex.
It is wrong that we release the mutex in the failure path in
pidlist_array_load(), because cgroup_pidlist_stop() will be called
no matter if cgroup_pidlist_start() returns errno or not.
Fixes: 4bac00d16a8760eae7205e41d2c246477d42a210
Cc: <stable@vger.kernel.org> # 3.14+
Acked-by: Cong Wang <xiyou.wangcong@gmail.com>
Pull futex and timer fixes from Thomas Gleixner:
"A oneliner bugfix for the jinxed futex code:
- Drop hash bucket lock in the error exit path. I really could slap
myself for intruducing that bug while fixing all the other horror
in that code three month ago ...
and the timer department is not too proud about the following fixes:
- Deal with a long standing rounding bug in the timeval to jiffies
conversion. It's a real issue and this fix fell through the cracks
for quite some time.
- Another round of alarmtimer fixes. Finally this code gets used
more widely and the subtle issues hidden for quite some time are
noticed and fixed. Nothing really exciting, just the itty bitty
details which bite the serious users here and there"
* 'locking-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
futex: Unlock hb->lock in futex_wait_requeue_pi() error path
* 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
alarmtimer: Lock k_itimer during timer callback
alarmtimer: Do not signal SIGEV_NONE timers
alarmtimer: Return relative times in timer_gettime
jiffies: Fix timeval conversion to jiffies
Locks the k_itimer's it_lock member when handling the alarm timer's
expiry callback.
The regular posix timers defined in posix-timers.c have this lock held
during timout processing because their callbacks are routed through
posix_timer_fn(). The alarm timers follow a different path, so they
ought to grab the lock somewhere else.
Cc: stable@vger.kernel.org
Cc: Richard Cochran <richardcochran@gmail.com>
Cc: Prarit Bhargava <prarit@redhat.com>
Cc: Sharvil Nanavati <sharvil@google.com>
Signed-off-by: Richard Larocque <rlarocque@google.com>
Signed-off-by: John Stultz <john.stultz@linaro.org>
Avoids sending a signal to alarm timers created with sigev_notify set to
SIGEV_NONE by checking for that special case in the timeout callback.
The regular posix timers avoid sending signals to SIGEV_NONE timers by
not scheduling any callbacks for them in the first place. Although it
would be possible to do something similar for alarm timers, it's simpler
to handle this as a special case in the timeout.
Prior to this patch, the alarm timer would ignore the sigev_notify value
and try to deliver signals to the process anyway. Even worse, the
sanity check for the value of sigev_signo is skipped when SIGEV_NONE was
specified, so the signal number could be bogus. If sigev_signo was an
unitialized value (as it often would be if SIGEV_NONE is used), then
it's hard to predict which signal will be sent.
Returns the time remaining for an alarm timer, rather than the time at
which it is scheduled to expire. If the timer has already expired or it
is not currently scheduled, the it_value's members are set to zero.
This new behavior matches that of the other posix-timers and the POSIX
specifications.
This is a change in user-visible behavior, and may break existing
applications. Hopefully, few users rely on the old incorrect behavior.
[jstultz: minor style tweak]
timeval_to_jiffies tried to round a timeval up to an integral number
of jiffies, but the logic for doing so was incorrect: intervals
corresponding to exactly N jiffies would become N+1. This manifested
itself particularly repeatedly stopping/starting an itimer:
setitimer(ITIMER_PROF, &val, NULL);
setitimer(ITIMER_PROF, NULL, &val);
would add a full tick to val, _even if it was exactly representable in
terms of jiffies_ (say, the result of a previous rounding.) Doing
this repeatedly would cause unbounded growth in val. So fix the math.
Here's what was wrong with the conversion: we essentially computed
(eliding seconds)
jiffies = usec * (NSEC_PER_USEC/TICK_NSEC)
by using scaling arithmetic, which took the best approximation of
NSEC_PER_USEC/TICK_NSEC with denominator of 2^USEC_JIFFIE_SC =
x/(2^USEC_JIFFIE_SC), and computed:
jiffies = (usec * x) >> USEC_JIFFIE_SC
and rounded this calculation up in the intermediate form (since we
can't necessarily exactly represent TICK_NSEC in usec.) But the
scaling arithmetic is a (very slight) *over*approximation of the true
value; that is, instead of dividing by (1 usec/ 1 jiffie), we
effectively divided by (1 usec/1 jiffie)-epsilon (rounding
down). This would normally be fine, but we want to round timeouts up,
and we did so by adding 2^USEC_JIFFIE_SC - 1 before the shift; this
would be fine if our division was exact, but dividing this by the
slightly smaller factor was equivalent to adding just _over_ 1 to the
final result (instead of just _under_ 1, as desired.)
In particular, with HZ=1000, we consistently computed that 10000 usec
was 11 jiffies; the same was true for any exact multiple of
TICK_NSEC.
We could possibly still round in the intermediate form, adding
something less than 2^USEC_JIFFIE_SC - 1, but easier still is to
convert usec->nsec, round in nanoseconds, and then convert using
time*spec*_to_jiffies. This adds one constant multiplication, and is
not observably slower in microbenchmarks on recent x86 hardware.
Tested: the following program:
int main() {
struct itimerval zero = {{0, 0}, {0, 0}};
/* Initially set to 10 ms. */
struct itimerval initial = zero;
initial.it_interval.tv_usec = 10000;
setitimer(ITIMER_PROF, &initial, NULL);
/* Save and restore several times. */
for (size_t i = 0; i < 10; ++i) {
struct itimerval prev;
setitimer(ITIMER_PROF, &zero, &prev);
/* on old kernels, this goes up by TICK_USEC every iteration */
printf("previous value: %ld %ld %ld %ld\n",
prev.it_interval.tv_sec, prev.it_interval.tv_usec,
prev.it_value.tv_sec, prev.it_value.tv_usec);
setitimer(ITIMER_PROF, &prev, NULL);
return 0;
Cc: Paul Turner <pjt@google.com>
Reviewed-by: Paul Turner <pjt@google.com>
Reported-by: Aaron Jacobs <jacobsa@google.com>
Signed-off-by: Andrew Hunter <ahh@google.com>
[jstultz: Tweaked to apply to 3.17-rc]
futex_wait_requeue_pi() calls futex_wait_setup(). If
futex_wait_setup() succeeds it returns with hb->lock held and
preemption disabled. Now the sanity check after this does:
if (match_futex(&q.key, &key2)) {
ret = -EINVAL;
goto out_put_keys;
which releases the keys but does not release hb->lock.
So we happily return to user space with hb->lock held and therefor
Unlock hb->lock before taking the exit route.
Reported-by: Dave "Trinity" Jones <davej@redhat.com>
Reviewed-by: Darren Hart <dvhart@linux.intel.com>
Reviewed-by: Davidlohr Bueso <dave@stgolabs.net>
Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1409112318500.4178@nanos
The C operator <= defines a perfectly fine total ordering on the set of
values representable in a long. However, unlike its namesake in the
integers, it is not translation invariant, meaning that we do not have
"b <= c" iff "a+b <= a+c" for all a,b,c.
This means that it is always wrong to try to boil down the relationship
between two longs to a question about the sign of their difference,
because the resulting relation [a LEQ b iff a-b <= 0] is neither
anti-symmetric or transitive. The former is due to -LONG_MIN==LONG_MIN
(take any two a,b with a-b = LONG_MIN; then a LEQ b and b LEQ a, but a !=
b). The latter can either be seen observing that x LEQ x+1 for all x,
implying x LEQ x+1 LEQ x+2 ... LEQ x-1 LEQ x; or more directly with the
simple example a=LONG_MIN, b=0, c=1, for which a-b < 0, b-c < 0, but a-c >
0.
Note that it makes absolutely no difference that a transmogrying bijection
has been applied before the comparison is done. In fact, had the
obfuscation not been done, one could probably not observe the bug
(assuming all values being compared always lie in one half of the address
space, the mathematical value of a-b is always representable in a long).
As it stands, one can easily obtain three file descriptors exhibiting the
non-transitivity of kcmp().
Side note 1: I can't see that ensuring the MSB of the multiplier is
set serves any purpose other than obfuscating the obfuscating code.
Side note 2:
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <fcntl.h>
#include <unistd.h>
#include <assert.h>
#include <sys/syscall.h>
enum kcmp_type {
KCMP_FILE,
KCMP_VM,
KCMP_FILES,
KCMP_FS,
KCMP_SIGHAND,
KCMP_IO,
KCMP_SYSVSEM,
KCMP_TYPES,
pid_t pid;
int kcmp(pid_t pid1, pid_t pid2, int type,
unsigned long idx1, unsigned long idx2)
return syscall(SYS_kcmp, pid1, pid2, type, idx1, idx2);
int cmp_fd(int fd1, int fd2)
int c = kcmp(pid, pid, KCMP_FILE, fd1, fd2);
if (c < 0) {
perror("kcmp");
exit(1);
assert(0 <= c && c < 3);
return c;
int cmp_fdp(const void *a, const void *b)
static const int normalize[] = {0, -1, 1};
return normalize[cmp_fd(*(int*)a, *(int*)b)];
#define MAX 100 /* This is plenty; I've seen it trigger for MAX==3 */
int main(int argc, char *argv[])
int r, s, count = 0;
int REL[3] = {0,0,0};
int fd[MAX];
pid = getpid();
while (count < MAX) {
r = open("/dev/null", O_RDONLY);
if (r < 0)
break;
fd[count++] = r;
printf("opened %d file descriptors\n", count);
for (r = 0; r < count; ++r) {
for (s = r+1; s < count; ++s) {
REL[cmp_fd(fd[r], fd[s])]++;
printf("== %d\t< %d\t> %d\n", REL[0], REL[1], REL[2]);
qsort(fd, count, sizeof(fd[0]), cmp_fdp);
memset(REL, 0, sizeof(REL));
return (REL[0] + REL[2] != 0);
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Reviewed-by: Cyrill Gorcunov <gorcunov@openvz.org>
"Eric W. Biederman" <ebiederm@xmission.com>
We shouldn't set text_len in the code path that detects printk recursion
because text_len corresponds to the length of the string inside textbuf.
A few lines down from the line
text_len = strlen(recursion_msg);
is the line
text_len += vscnprintf(text + text_len, ...);
So if printk detects recursion, it sets text_len to 29 (the length of
recursion_msg) and logs an error. Then the message supplied by the
caller of printk is stored inside textbuf but offset by 29 bytes. This
means that the output of the recursive call to printk will contain 29
bytes of garbage in front of it.
This defect is caused by commit 458df9fd4815 ("printk: remove separate
printk_sched buffers and use printk buf instead") which turned the line
text_len = vscnprintf(text, ...);
into
To fix this, this patch avoids setting text_len when logging the printk
recursion error. This patch also marks unlikely() the branch leading up
to this code.
Fixes: 458df9fd4815b478 ("printk: remove separate printk_sched buffers and use printk buf instead")
Signed-off-by: Patrick Palka <patrick@parcs.ath.cx>
Reviewed-by: Petr Mladek <pmladek@suse.cz>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
This patch fix spelling typo found in DocBook/kernel-api.xml.
It is because the file is generated from the source comments,
I have to fix the comments in source codes.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Acked-by: Randy Dunlap <rdunlap@infradead.org>
We saw a kernel soft lockup in perf_remove_from_context(),
it looks like the `perf` process, when exiting, could not go
out of the retry loop. Meanwhile, the target process was forking
a child. So either the target process should execute the smp
function call to deactive the event (if it was running) or it should
do a context switch which deactives the event.
It seems we optimize out a context switch in perf_event_context_sched_out(),
and what's more important, we still test an obsolete task pointer when
retrying, so no one actually would deactive that event in this situation.
Fix it directly by reloading the task pointer in perf_remove_from_context().
This should cure the above soft lockup.
Signed-off-by: Cong Wang <cwang@twopensource.com>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Link: http://lkml.kernel.org/r/1409696840-843-1-git-send-email-xiyou.wangcong@gmail.com
"This pull request includes Alban's patch to disallow '\n' in cgroup
names.
Two other patches from Li to fix a possible oops when cgroup
destruction races against other file operations and one from Vivek to
fix a unified hierarchy devel behavior"
cgroup: check cgroup liveliness before unbreaking kernfs
cgroup: delay the clearing of cgrp->kn->priv
cgroup: Display legacy cgroup files on default hierarchy
cgroup: reject cgroup names with '\n'
"These are regression fixes (ACPI sysfs, ACPI video, suspend test),
ACPI cpuidle deadlock fix, missing runtime validation of ACPI _DSD
output, a fix and a new CPU ID for the RAPL driver, new blacklist
entry for the ACPI EC driver and a couple of trivial cleanups
(intel_pstate and generic PM domains).
Specifics:
- Fix for recently broken test_suspend= command line argument (Rafael
Wysocki).
- Fixes for regressions related to the ACPI video driver caused by
switching the default to native backlight handling in 3.16 from
Hans de Goede.
- Fix for a sysfs attribute of ACPI device objects that returns stale
values sometimes due to the fact that they are cached instead of
executing the appropriate method (_SUN) every time (broken in
3.14). From Yasuaki Ishimatsu.
- Fix for a deadlock between cpuidle_lock and cpu_hotplug.lock in the
ACPI processor driver from Jiri Kosina.
- Runtime output validation for the ACPI _DSD device configuration
object missing from the support for it that has been introduced
recently. From Mika Westerberg.
- Fix for an unuseful and misleading RAPL (Running Average Power
Limit) domain detection message in the RAPL driver from Jacob Pan.
- New Intel Haswell CPU ID for the RAPL driver from Jason Baron.
- New Clevo W350etq blacklist entry for the ACPI EC driver from Lan
Tianyu.
- Cleanup for the intel_pstate driver and the core generic PM domains
code from Gabriele Mazzotta and Geert Uytterhoeven"
* tag 'pm+acpi-3.17-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
ACPI / cpuidle: fix deadlock between cpuidle_lock and cpu_hotplug.lock
ACPI / scan: not cache _SUN value in struct acpi_device_pnp
cpufreq: intel_pstate: Remove unneeded variable
powercap / RAPL: change domain detection message
powercap / RAPL: add support for CPU model 0x3f
PM / domains: Make generic_pm_domain.name const
PM / sleep: Fix test_suspend= command line option
ACPI / EC: Add msi quirk for Clevo W350etq
ACPI / video: Disable native_backlight on HP ENVY 15 Notebook PC
ACPI / video: Add a disable_native_backlight quirk
ACPI / video: Fix use_native_backlight selection logic
ACPICA: ACPI 5.1: Add support for runtime validation of _DSD package.
Pull RCU fix from Ingo Molnar:
"A boot hang fix for the offloaded callback RCU model (RCU_NOCB_CPU=y
&& (TREE_CPU=y || TREE_PREEMPT_RC)) in certain bootup scenarios"
* 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
rcu: Make nocb leader kthreads process pending callbacks after spawning
Pull timer fixes from Thomas Gleixner:
"Three fixlets from the timer departement:
- Update the timekeeper before updating vsyscall and pvclock. This
fixes the kvm-clock regression reported by Chris and Paolo.
- Use the proper irq work interface from NMI. This fixes the
regression reported by Catalin and Dave.
- Clarify the compat_nanosleep error handling mechanism to avoid
future confusion"
timekeeping: Update timekeeper before updating vsyscall and pvclock
compat: nanosleep: Clarify error handling
nohz: Restore NMI safe local irq work for local nohz kick
The update_walltime() code works on the shadow timekeeper to make the
seqcount protected region as short as possible. But that update to the
shadow timekeeper does not update all timekeeper fields because it's
sufficient to do that once before it becomes life. One of these fields
is tkr.base_mono. That stays stale in the shadow timekeeper unless an
operation happens which copies the real timekeeper to the shadow.
The update function is called after the update calls to vsyscall and
pvclock. While not correct, it did not cause any problems because none
of the invoked update functions used base_mono.
commit cbcf2dd3b3d4 (x86: kvm: Make kvm_get_time_and_clockread()
nanoseconds based) changed that in the kvm pvclock update function, so
the stale mono_base value got used and caused kvm-clock to malfunction.
Put the update where it belongs and fix the issue.
Reported-by: Chris J Arges <chris.j.arges@canonical.com>
Reported-by: Paolo Bonzini <pbonzini@redhat.com>
Cc: Gleb Natapov <gleb@kernel.org>
Cc: John Stultz <john.stultz@linaro.org>
Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1409050000570.3333@nanos
The error handling in compat_sys_nanosleep() is correct, but
completely non obvious. Document it and restrict it to the
-ERESTART_RESTARTBLOCK return value for clarity.
Reported-by: Kees Cook <keescook@chromium.org>
The local nohz kick is currently used by perf which needs it to be
NMI-safe. Recent commit though (7d1311b93e58ed55f3a31cc8f94c4b8fe988a2b9)
changed its implementation to fire the local kick using the remote kick
API. It was convenient to make the code more generic but the remote kick
isn't NMI-safe.
As a result:
WARNING: CPU: 3 PID: 18062 at kernel/irq_work.c:72 irq_work_queue_on+0x11e/0x140()
CPU: 3 PID: 18062 Comm: trinity-subchil Not tainted 3.16.0+ #34
0000000000000009 00000000903774d1 ffff880244e06c00 ffffffff9a7f1e37
0000000000000000 ffff880244e06c38 ffffffff9a0791dd ffff880244fce180
0000000000000003 ffff880244e06d58 ffff880244e06ef8 0000000000000000
Call Trace:
<NMI> [<ffffffff9a7f1e37>] dump_stack+0x4e/0x7a
[<ffffffff9a0791dd>] warn_slowpath_common+0x7d/0xa0
[<ffffffff9a07930a>] warn_slowpath_null+0x1a/0x20
[<ffffffff9a17ca1e>] irq_work_queue_on+0x11e/0x140
[<ffffffff9a10a2c7>] tick_nohz_full_kick_cpu+0x57/0x90
[<ffffffff9a186cd5>] __perf_event_overflow+0x275/0x350
[<ffffffff9a184f80>] ? perf_event_task_disable+0xa0/0xa0
[<ffffffff9a01a4cf>] ? x86_perf_event_set_period+0xbf/0x150
[<ffffffff9a187934>] perf_event_overflow+0x14/0x20
[<ffffffff9a020386>] intel_pmu_handle_irq+0x206/0x410
[<ffffffff9a0b54d3>] ? arch_vtime_task_switch+0x63/0x130
[<ffffffff9a01937b>] perf_event_nmi_handler+0x2b/0x50
[<ffffffff9a007b72>] nmi_handle+0xd2/0x390
[<ffffffff9a007aa5>] ? nmi_handle+0x5/0x390
[<ffffffff9a0d131b>] ? lock_release+0xab/0x330
[<ffffffff9a008062>] default_do_nmi+0x72/0x1c0
[<ffffffff9a0c925f>] ? cpuacct_account_field+0xcf/0x200
[<ffffffff9a008268>] do_nmi+0xb8/0x100
Lets fix this by restoring the use of local irq work for the nohz local
kick.
Reported-by: Catalin Iacob <iacobcatalin@gmail.com>
Reported-and-tested-by: Dave Jones <davej@redhat.com>
When cgroup_kn_lock_live() is called through some kernfs operation and
another thread is calling cgroup_rmdir(), we'll trigger the warning in
cgroup_get().
WARNING: CPU: 1 PID: 1228 at kernel/cgroup.c:1034 cgroup_get+0x89/0xa0()
Call Trace:
[<c16ee73d>] dump_stack+0x41/0x52
[<c10468ef>] warn_slowpath_common+0x7f/0xa0
[<c104692d>] warn_slowpath_null+0x1d/0x20
[<c10bb999>] cgroup_get+0x89/0xa0
[<c10bbe58>] cgroup_kn_lock_live+0x28/0x70
[<c10be3c1>] __cgroup_procs_write.isra.26+0x51/0x230
[<c10be5b2>] cgroup_tasks_write+0x12/0x20
[<c10bb7b0>] cgroup_file_write+0x40/0x130
[<c11aee71>] kernfs_fop_write+0xd1/0x160
[<c1148e58>] vfs_write+0x98/0x1e0
[<c114934d>] SyS_write+0x4d/0xa0
[<c16f656b>] sysenter_do_call+0x12/0x12
---[ end trace 6f2e0c38c2108a74 ]---
Fix this by calling css_tryget() instead of cgroup_get().
v2:
- move cgroup_tryget() right below cgroup_get() definition. (Tejun)
Cc: <stable@vger.kernel.org> # 3.15+
Reported-by: Toralf Förster <toralf.foerster@gmx.de>
Run these two scripts concurrently:
for ((; ;))
mkdir /cgroup/sub
rmdir /cgroup/sub
for ((; ;))
echo $$ > /cgroup/sub/cgroup.procs
echo $$ > /cgroup/cgroup.procs
A kernel bug will be triggered:
BUG: unable to handle kernel NULL pointer dereference at 00000038
IP: [<c10bbd69>] cgroup_put+0x9/0x80
Call Trace:
[<c10bbe19>] cgroup_kn_unlock+0x39/0x50
[<c10bbe91>] cgroup_kn_lock_live+0x61/0x70
We clear cgrp->kn->priv in the end of cgroup_rmdir(), but another
concurrent thread can access kn->priv after the clearing.
We should move the clearing to css_release_work_fn(). At that time
no one is holding reference to the cgroup and no one can gain a new
reference to access it.
v2:
- move RCU_INIT_POINTER() into the else block. (Tejun)
- remove the cgroup_parent() check. (Tejun)
- update the comment in css_tryget_online_from_dir().
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-rcu into core/urgent
Pull an RCU fix from Paul E. McKenney:
"This series contains a single commit fixing an initialization bug
reported by Amit Shah and fixed by Pranith Kumar (and tested by Amit).
This bug results in a boot-time hang in callback-offloaded configurations
where callbacks were posted before the offloading ('rcuo') kthreads
were created."
After commit d431cbc53cb7 (PM / sleep: Simplify sleep states sysfs
interface code) the pm_states[] array is not populated initially,
which causes setup_test_suspend() to always fail and the suspend
testing during boot doesn't work any more.
Fix the problem by using pm_labels[] instead of pm_states[] in
setup_test_suspend() and storing a pointer to the label of the
sleep state to test rather than the number representing it,
because the connection between the state numbers and labels is
only established by suspend_set_ops().
Fixes: d431cbc53cb7 (PM / sleep: Simplify sleep states sysfs interface code)
Reported-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
Pull irq handling fixlet from Thomas Gleixner:
"Just an export for an interrupt flow handler which is now used in gpio
modules"
* 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
irq: Export handle_fasteoi_irq
Currently new system call kexec_file_load() and all the associated code
compiles if CONFIG_KEXEC=y. But new syscall also compiles purgatory
code which currently uses gcc option -mcmodel=large. This option seems
to be available only gcc 4.4 onwards.
Hiding new functionality behind a new config option will not break
existing users of old gcc. Those who wish to enable new functionality
will require new gcc. Having said that, I am trying to figure out how
can I move away from using -mcmodel=large but that can take a while.
I think there are other advantages of introducing this new config
option. As this option will be enabled only on x86_64, other arches
don't have to compile generic kexec code which will never be used. This
new code selects CRYPTO=y and CRYPTO_SHA256=y. And all other arches had
to do this for CONFIG_KEXEC. Now with introduction of new config
option, we can remove crypto dependency from other arches.
Now CONFIG_KEXEC_FILE is available only on x86_64. So whereever I had
CONFIG_X86_64 defined, I got rid of that.
For CONFIG_KEXEC_FILE, instead of doing select CRYPTO=y, I changed it to
"depends on CRYPTO=y". This should be safer as "select" is not
recursive.
Signed-off-by: Vivek Goyal <vgoyal@redhat.com>
Cc: Eric Biederman <ebiederm@xmission.com>
Tested-by: Shaun Ruffell <sruffell@digium.com>
Richard and Daniel reported that UML is broken due to changes to
resource traversal functions. Problem is that iomem_resource.child can
be null and new code does not consider that possibility. Old code used
a for loop and that loop will not even execute if p was null.
Revert back to for() loop logic and bail out if p is null.
I also moved sibling_only check out of resource_lock. There is no
reason to keep it inside the lock.
Following is backtrace of the UML crash.
RIP: 0033:[<0000000060039b9f>]
RSP: 0000000081459da0 EFLAGS: 00010202
RAX: 0000000000000000 RBX: 00000000219b3fff RCX: 000000006010d1d9
RDX: 0000000000000001 RSI: 00000000602dfb94 RDI: 0000000081459df8
RBP: 0000000081459de0 R08: 00000000601b59f4 R09: ffffffff0000ff00
R10: ffffffff0000ff00 R11: 0000000081459e88 R12: 0000000081459df8
R13: 00000000219b3fff R14: 00000000602dfb94 R15: 0000000000000000
Kernel panic - not syncing: Segfault with no mm
CPU: 0 PID: 1 Comm: swapper Not tainted 3.16.0-10454-g58d08e3 #13
Stack:
00000000 000080d0 81459df0 219b3fff
81459e70 6010d1d9 ffffffff 6033e010
81459e50 6003a269 81459e30 00000000
Call Trace:
[<6010d1d9>] ? kclist_add_private+0x0/0xe7
[<6003a269>] walk_system_ram_range+0x61/0xb7
[<6000e859>] ? proc_kcore_init+0x0/0xf1
[<6010d574>] kcore_update_ram+0x4c/0x168
[<6010d72e>] ? kclist_add+0x0/0x2e
[<6000e943>] proc_kcore_init+0xea/0xf1
[<600189f0>] do_one_initcall+0x13c/0x204
[<6004ca46>] ? parse_args+0x1df/0x2e0
[<6004c82d>] ? parameq+0x0/0x3a
[<601b5990>] ? strcpy+0x0/0x18
[<60001e1a>] kernel_init_freeable+0x240/0x31e
[<6026f1c0>] kernel_init+0x12/0x148
[<60019fad>] new_thread_handler+0x81/0xa3
Fixes 8c86e70acead629aacb4a ("resource: provide new functions to walk
through resources").
Reported-by: Daniel Walter <sahne@0x90.at>
Tested-by: Richard Weinberger <richard@nod.at>
Tested-by: Toralf Förster <toralf.foerster@gmx.de>
Tested-by: Daniel Walter <sahne@0x90.at>
It should be request_threaded_irq, not request_irq
[jkosina@suse.cz: not that it would matter, as both have the same
set of arguments anyway, but for sake of consistency ...]
Signed-off-by: Emilio López <emilio@elopez.com.ar>
The nocb callbacks generated before the nocb kthreads are spawned are
enqueued in the nocb queue for later processing. Commit fbce7497ee5af ("rcu:
Parallelize and economize NOCB kthread wakeups") introduced nocb leader kthreads
which checked the nocb_leader_wake flag to see if there were any such pending
callbacks. A case was reported in which newly spawned leader kthreads were not
processing the pending callbacks as this flag was not set, which led to a boot
hang.
The following commit ensures that the newly spawned nocb kthreads process the
pending callbacks by allowing the kthreads to run immediately after spawning
instead of waiting. This is done by inverting the logic of nocb_leader_wake
tests to nocb_leader_sleep which allows us to use the default initialization of
this flag to 0 to let the kthreads run.
Reported-by: Amit Shah <amit.shah@redhat.com>
Signed-off-by: Pranith Kumar <bobby.prani@gmail.com>
Link: http://www.spinics.net/lists/kernel/msg1802899.html
[ paulmck: Backported to v3.17-rc2. ]
Tested-by: Amit Shah <amit.shah@redhat.com>
