[ Upstream commit 86723c8640633bee4b4588d3c7784ee7a0032f65 ]
.ndo_xdp_xmit() assumes it is called under RCU. For example virtio_net
uses RCU to detect it has setup the resources for tx. The assumption
accidentally broke when introducing bulk queue in devmap.
Fixes: 5d053f9da431 ("bpf: devmap prepare xdp frames for bulking")
Reported-by: David Ahern <dsahern@gmail.com>
Signed-off-by: Toshiaki Makita <toshiaki.makita1@gmail.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
[ Upstream commit edabf4d9dd905acd60048ea1579943801e3a4876 ]
dev_map_free() forgot to free bulk queue when freeing its entries.
Acked-by: Jesper Dangaard Brouer <brouer@redhat.com>
[ Upstream commit d4dd153d551634683fccf8881f606fa9f3dfa1ef ]
dev_map_free() waits for flush_needed bitmap to be empty in order to
ensure all flush operations have completed before freeing its entries.
However the corresponding clear_bit() was called before using the
entries, so the entries could be used after free.
All access to the entries needs to be done before clearing the bit.
It seems commit a5e2da6e9787 ("bpf: netdev is never null in
__dev_map_flush") accidentally changed the clear_bit() and memory access
order.
Note that the problem happens only in __dev_map_flush(), not in
dev_map_flush_old(). dev_map_flush_old() is called only after nulling
out the corresponding netdev_map entry, so dev_map_free() never frees
the entry thus no such race happens there.
Fixes: a5e2da6e9787 ("bpf: netdev is never null in __dev_map_flush")
[ Upstream commit fdadd04931c2d7cd294dc5b2b342863f94be53a3 ]
Michael and Sandipan report:
Commit ede95a63b5 introduced a bpf_jit_limit tuneable to limit BPF
JIT allocations. At compile time it defaults to PAGE_SIZE * 40000,
and is adjusted again at init time if MODULES_VADDR is defined.
For ppc64 kernels, MODULES_VADDR isn't defined, so we're stuck with
the compile-time default at boot-time, which is 0x9c400000 when
using 64K page size. This overflows the signed 32-bit bpf_jit_limit
value:
root@ubuntu:/tmp# cat /proc/sys/net/core/bpf_jit_limit
-1673527296
and can cause various unexpected failures throughout the network
stack. In one case `strace dhclient eth0` reported:
setsockopt(5, SOL_SOCKET, SO_ATTACH_FILTER, {len=11, filter=0x105dd27f8},
16) = -1 ENOTSUPP (Unknown error 524)
and similar failures can be seen with tools like tcpdump. This doesn't
always reproduce however, and I'm not sure why. The more consistent
failure I've seen is an Ubuntu 18.04 KVM guest booted on a POWER9
host would time out on systemd/netplan configuring a virtio-net NIC
with no noticeable errors in the logs.
Given this and also given that in near future some architectures like
arm64 will have a custom area for BPF JIT image allocations we should
get rid of the BPF_JIT_LIMIT_DEFAULT fallback / default entirely. For
4.21, we have an overridable bpf_jit_alloc_exec(), bpf_jit_free_exec()
so therefore add another overridable bpf_jit_alloc_exec_limit() helper
function which returns the possible size of the memory area for deriving
the default heuristic in bpf_jit_charge_init().
Like bpf_jit_alloc_exec() and bpf_jit_free_exec(), the new
bpf_jit_alloc_exec_limit() assumes that module_alloc() is the default
JIT memory provider, and therefore in case archs implement their custom
module_alloc() we use MODULES_{END,_VADDR} for limits and otherwise for
vmalloc_exec() cases like on ppc64 we use VMALLOC_{END,_START}.
Additionally, for archs supporting large page sizes, we should change
the sysctl to be handled as long to not run into sysctl restrictions
in future.
Fixes: ede95a63b5e8 ("bpf: add bpf_jit_limit knob to restrict unpriv allocations")
Reported-by: Sandipan Das <sandipan@linux.ibm.com>
Reported-by: Michael Roth <mdroth@linux.vnet.ibm.com>
Tested-by: Michael Roth <mdroth@linux.vnet.ibm.com>
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
ftrace_run_update_code()
commit d5b844a2cf507fc7642c9ae80a9d585db3065c28 upstream.
The commit 9f255b632bf12c4dd7 ("module: Fix livepatch/ftrace module text
permissions race") causes a possible deadlock between register_kprobe()
and ftrace_run_update_code() when ftrace is using stop_machine().
The existing dependency chain (in reverse order) is:
-> #1 (text_mutex){+.+.}:
validate_chain.isra.21+0xb32/0xd70
__lock_acquire+0x4b8/0x928
lock_acquire+0x102/0x230
__mutex_lock+0x88/0x908
mutex_lock_nested+0x32/0x40
register_kprobe+0x254/0x658
init_kprobes+0x11a/0x168
do_one_initcall+0x70/0x318
kernel_init_freeable+0x456/0x508
kernel_init+0x22/0x150
ret_from_fork+0x30/0x34
kernel_thread_starter+0x0/0xc
-> #0 (cpu_hotplug_lock.rw_sem){++++}:
check_prev_add+0x90c/0xde0
cpus_read_lock+0x62/0xd0
stop_machine+0x2e/0x60
arch_ftrace_update_code+0x2e/0x40
ftrace_run_update_code+0x40/0xa0
ftrace_startup+0xb2/0x168
register_ftrace_function+0x64/0x88
klp_patch_object+0x1a2/0x290
klp_enable_patch+0x554/0x980
do_init_module+0x6e/0x250
load_module+0x1782/0x1990
__s390x_sys_finit_module+0xaa/0xf0
system_call+0xd8/0x2d0
Possible unsafe locking scenario:
CPU0 CPU1
lock(text_mutex);
lock(cpu_hotplug_lock.rw_sem);
lock(text_mutex);
It is similar problem that has been solved by the commit 2d1e38f56622b9b
("kprobes: Cure hotplug lock ordering issues"). Many locks are involved.
To be on the safe side, text_mutex must become a low level lock taken
after cpu_hotplug_lock.rw_sem.
This can't be achieved easily with the current ftrace design.
For example, arm calls set_all_modules_text_rw() already in
ftrace_arch_code_modify_prepare(), see arch/arm/kernel/ftrace.c.
This functions is called:
+ outside stop_machine() from ftrace_run_update_code()
+ without stop_machine() from ftrace_module_enable()
Fortunately, the problematic fix is needed only on x86_64. It is
the only architecture that calls set_all_modules_text_rw()
in ftrace path and supports livepatching at the same time.
Therefore it is enough to move text_mutex handling from the generic
kernel/trace/ftrace.c into arch/x86/kernel/ftrace.c:
ftrace_arch_code_modify_post_process()
This patch basically reverts the ftrace part of the problematic
text permissions race"). And provides x86_64 specific-fix.
Some refactoring of the ftrace code will be needed when livepatching
is implemented for arm or nds32. These architectures call
set_all_modules_text_rw() and use stop_machine() at the same time.
Link: http://lkml.kernel.org/r/20190627081334.12793-1-pmladek@suse.com
Fixes: 9f255b632bf12c4dd7 ("module: Fix livepatch/ftrace module text permissions race")
Reported-by: Miroslav Benes <mbenes@suse.cz>
Reviewed-by: Miroslav Benes <mbenes@suse.cz>
Reviewed-by: Josh Poimboeuf <jpoimboe@redhat.com>
Signed-off-by: Petr Mladek <pmladek@suse.com>
As reviewed by Miroslav Benes <mbenes@suse.cz>, removed return value of
ftrace_run_update_code() as it is a void function.
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
commit 46cc0b44428d0f0e81f11ea98217fc0edfbeab07 upstream.
Current snapshot implementation swaps two ring_buffers even though their
sizes are different from each other, that can cause an inconsistency
between the contents of buffer_size_kb file and the current buffer size.
For example:
# cat buffer_size_kb
7 (expanded: 1408)
# echo 1 > events/enable
# grep bytes per_cpu/cpu0/stats
bytes: 1441020
# echo 1 > snapshot // current:1408, spare:1408
# echo 123 > buffer_size_kb // current:123, spare:1408
# echo 1 > snapshot // current:1408, spare:123
bytes: 1443700
123 // != current:1408
And also, a similar per-cpu case hits the following WARNING:
Reproducer:
# echo 1 > per_cpu/cpu0/snapshot
WARNING:
WARNING: CPU: 0 PID: 1946 at kernel/trace/trace.c:1607 update_max_tr_single.part.0+0x2b8/0x380
Modules linked in:
CPU: 0 PID: 1946 Comm: bash Not tainted 5.2.0-rc6 #20
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.12.0-2.fc30 04/01/2014
RIP: 0010:update_max_tr_single.part.0+0x2b8/0x380
Code: ff e8 dc da f9 ff 0f 0b e9 88 fe ff ff e8 d0 da f9 ff 44 89 ee bf f5 ff ff ff e8 33 dc f9 ff 41 83 fd f5 74 96 e8 b8 da f9 ff <0f> 0b eb 8d e8 af da f9 ff 0f 0b e9 bf fd ff ff e8 a3 da f9 ff 48
RSP: 0018:ffff888063e4fca0 EFLAGS: 00010093
RAX: ffff888066214380 RBX: ffffffff99850fe0 RCX: ffffffff964298a8
RDX: 0000000000000000 RSI: 00000000fffffff5 RDI: 0000000000000005
RBP: 1ffff1100c7c9f96 R08: ffff888066214380 R09: ffffed100c7c9f9b
R10: ffffed100c7c9f9a R11: 0000000000000003 R12: 0000000000000000
R13: 00000000ffffffea R14: ffff888066214380 R15: ffffffff99851060
FS: 00007f9f8173c700(0000) GS:ffff88806d000000(0000) knlGS:0000000000000000
CR2: 0000000000714dc0 CR3: 0000000066fa6000 CR4: 00000000000006f0
Call Trace:
? trace_array_printk_buf+0x140/0x140
? __mutex_lock_slowpath+0x10/0x10
tracing_snapshot_write+0x4c8/0x7f0
? trace_printk_init_buffers+0x60/0x60
? selinux_file_permission+0x3b/0x540
? tracer_preempt_off+0x38/0x506
__vfs_write+0x81/0x100
vfs_write+0x1e1/0x560
ksys_write+0x126/0x250
? __ia32_sys_read+0xb0/0xb0
? do_syscall_64+0x1f/0x390
do_syscall_64+0xc1/0x390
entry_SYSCALL_64_after_hwframe+0x49/0xbe
This patch adds resize_buffer_duplicate_size() to check if there is a
difference between current/spare buffer sizes and resize a spare buffer
if necessary.
Link: http://lkml.kernel.org/r/20190625012910.13109-1-devel@etsukata.com
Cc: stable@vger.kernel.org
Fixes: ad909e21bbe69 ("tracing: Add internal tracing_snapshot() functions")
Signed-off-by: Eiichi Tsukata <devel@etsukata.com>
commit 6994eefb0053799d2e07cd140df6c2ea106c41ee upstream.
Fix two issues:
When called for PTRACE_TRACEME, ptrace_link() would obtain an RCU
reference to the parent's objective credentials, then give that pointer
to get_cred(). However, the object lifetime rules for things like
struct cred do not permit unconditionally turning an RCU reference into
a stable reference.
PTRACE_TRACEME records the parent's credentials as if the parent was
acting as the subject, but that's not the case. If a malicious
unprivileged child uses PTRACE_TRACEME and the parent is privileged, and
at a later point, the parent process becomes attacker-controlled
(because it drops privileges and calls execve()), the attacker ends up
with control over two processes with a privileged ptrace relationship,
which can be abused to ptrace a suid binary and obtain root privileges.
Fix both of these by always recording the credentials of the process
that is requesting the creation of the ptrace relationship:
current_cred() can't change under us, and current is the proper subject
for access control.
This change is theoretically userspace-visible, but I am not aware of
any code that it will actually break.
Fixes: 64b875f7ac8a ("ptrace: Capture the ptracer's creds not PT_PTRACE_CAP")
Signed-off-by: Jann Horn <jannh@google.com>
Acked-by: Oleg Nesterov <oleg@redhat.com>
[ Upstream commit 04e03d9a616c19a47178eaca835358610e63a1dd ]
The mapper may be NULL when called from register_ftrace_function_probe()
with probe->data == NULL.
This issue can be reproduced as follow (it may be covered by compiler
optimization sometime):
/ # cat /sys/kernel/debug/tracing/set_ftrace_filter
#### all functions enabled ####
/ # echo foo_bar:dump > /sys/kernel/debug/tracing/set_ftrace_filter
[ 206.949100] Unable to handle kernel NULL pointer dereference at virtual address 0000000000000000
[ 206.952402] Mem abort info:
[ 206.952819] ESR = 0x96000006
[ 206.955326] Exception class = DABT (current EL), IL = 32 bits
[ 206.955844] SET = 0, FnV = 0
[ 206.956272] EA = 0, S1PTW = 0
[ 206.956652] Data abort info:
[ 206.957320] ISV = 0, ISS = 0x00000006
[ 206.959271] CM = 0, WnR = 0
[ 206.959938] user pgtable: 4k pages, 48-bit VAs, pgdp=0000000419f3a000
[ 206.960483] [0000000000000000] pgd=0000000411a87003, pud=0000000411a83003, pmd=0000000000000000
[ 206.964953] Internal error: Oops: 96000006 [#1] SMP
[ 206.971122] Dumping ftrace buffer:
[ 206.973677] (ftrace buffer empty)
[ 206.975258] Modules linked in:
[ 206.976631] Process sh (pid: 281, stack limit = 0x(____ptrval____))
[ 206.978449] CPU: 10 PID: 281 Comm: sh Not tainted 5.2.0-rc1+ #17
[ 206.978955] Hardware name: linux,dummy-virt (DT)
[ 206.979883] pstate: 60000005 (nZCv daif -PAN -UAO)
[ 206.980499] pc : free_ftrace_func_mapper+0x2c/0x118
[ 206.980874] lr : ftrace_count_free+0x68/0x80
[ 206.982539] sp : ffff0000182f3ab0
[ 206.983102] x29: ffff0000182f3ab0 x28: ffff8003d0ec1700
[ 206.983632] x27: ffff000013054b40 x26: 0000000000000001
[ 206.984000] x25: ffff00001385f000 x24: 0000000000000000
[ 206.984394] x23: ffff000013453000 x22: ffff000013054000
[ 206.984775] x21: 0000000000000000 x20: ffff00001385fe28
[ 206.986575] x19: ffff000013872c30 x18: 0000000000000000
[ 206.987111] x17: 0000000000000000 x16: 0000000000000000
[ 206.987491] x15: ffffffffffffffb0 x14: 0000000000000000
[ 206.987850] x13: 000000000017430e x12: 0000000000000580
[ 206.988251] x11: 0000000000000000 x10: cccccccccccccccc
[ 206.988740] x9 : 0000000000000000 x8 : ffff000013917550
[ 206.990198] x7 : ffff000012fac2e8 x6 : ffff000012fac000
[ 206.991008] x5 : ffff0000103da588 x4 : 0000000000000001
[ 206.991395] x3 : 0000000000000001 x2 : ffff000013872a28
[ 206.991771] x1 : 0000000000000000 x0 : 0000000000000000
[ 206.992557] Call trace:
[ 206.993101] free_ftrace_func_mapper+0x2c/0x118
[ 206.994827] ftrace_count_free+0x68/0x80
[ 206.995238] release_probe+0xfc/0x1d0
[ 206.995555] register_ftrace_function_probe+0x4a8/0x868
[ 206.995923] ftrace_trace_probe_callback.isra.4+0xb8/0x180
[ 206.996330] ftrace_dump_callback+0x50/0x70
[ 206.996663] ftrace_regex_write.isra.29+0x290/0x3a8
[ 206.997157] ftrace_filter_write+0x44/0x60
[ 206.998971] __vfs_write+0x64/0xf0
[ 206.999285] vfs_write+0x14c/0x2f0
[ 206.999591] ksys_write+0xbc/0x1b0
[ 206.999888] __arm64_sys_write+0x3c/0x58
[ 207.000246] el0_svc_common.constprop.0+0x408/0x5f0
[ 207.000607] el0_svc_handler+0x144/0x1c8
[ 207.000916] el0_svc+0x8/0xc
[ 207.003699] Code: aa0003f8 a9025bf5 aa0103f5 f946ea80 (f9400303)
[ 207.008388] ---[ end trace 7b6d11b5f542bdf1 ]---
[ 207.010126] Kernel panic - not syncing: Fatal exception
[ 207.011322] SMP: stopping secondary CPUs
[ 207.013956] Dumping ftrace buffer:
[ 207.014595] (ftrace buffer empty)
[ 207.015632] Kernel Offset: disabled
[ 207.017187] CPU features: 0x002,20006008
[ 207.017985] Memory Limit: none
[ 207.019825] ---[ end Kernel panic - not syncing: Fatal exception ]---
Link: http://lkml.kernel.org/r/20190606031754.10798-1-liwei391@huawei.com
Signed-off-by: Wei Li <liwei391@huawei.com>
[ Upstream commit 9f255b632bf12c4dd7fc31caee89aa991ef75176 ]
It's possible for livepatch and ftrace to be toggling a module's text
permissions at the same time, resulting in the following panic:
BUG: unable to handle page fault for address: ffffffffc005b1d9
#PF: supervisor write access in kernel mode
#PF: error_code(0x0003) - permissions violation
PGD 3ea0c067 P4D 3ea0c067 PUD 3ea0e067 PMD 3cc13067 PTE 3b8a1061
Oops: 0003 [#1] PREEMPT SMP PTI
CPU: 1 PID: 453 Comm: insmod Tainted: G O K 5.2.0-rc1-a188339ca5 #1
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.12.0-20181126_142135-anatol 04/01/2014
RIP: 0010:apply_relocate_add+0xbe/0x14c
Code: fa 0b 74 21 48 83 fa 18 74 38 48 83 fa 0a 75 40 eb 08 48 83 38 00 74 33 eb 53 83 38 00 75 4e 89 08 89 c8 eb 0a 83 38 00 75 43 <89> 08 48 63 c1 48 39 c8 74 2e eb 48 83 38 00 75 32 48 29 c1 89 08
RSP: 0018:ffffb223c00dbb10 EFLAGS: 00010246
RAX: ffffffffc005b1d9 RBX: 0000000000000000 RCX: ffffffff8b200060
RDX: 000000000000000b RSI: 0000004b0000000b RDI: ffff96bdfcd33000
RBP: ffffb223c00dbb38 R08: ffffffffc005d040 R09: ffffffffc005c1f0
R10: ffff96bdfcd33c40 R11: ffff96bdfcd33b80 R12: 0000000000000018
R13: ffffffffc005c1f0 R14: ffffffffc005e708 R15: ffffffff8b2fbc74
FS: 00007f5f447beba8(0000) GS:ffff96bdff900000(0000) knlGS:0000000000000000
CR2: ffffffffc005b1d9 CR3: 000000003cedc002 CR4: 0000000000360ea0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Call Trace:
klp_init_object_loaded+0x10f/0x219
? preempt_latency_start+0x21/0x57
klp_enable_patch+0x662/0x809
? virt_to_head_page+0x3a/0x3c
? kfree+0x8c/0x126
patch_init+0x2ed/0x1000 [livepatch_test02]
? 0xffffffffc0060000
do_one_initcall+0x9f/0x1c5
? kmem_cache_alloc_trace+0xc4/0xd4
? do_init_module+0x27/0x210
do_init_module+0x5f/0x210
load_module+0x1c41/0x2290
? fsnotify_path+0x3b/0x42
? strstarts+0x2b/0x2b
? kernel_read+0x58/0x65
__do_sys_finit_module+0x9f/0xc3
? __do_sys_finit_module+0x9f/0xc3
__x64_sys_finit_module+0x1a/0x1c
do_syscall_64+0x52/0x61
entry_SYSCALL_64_after_hwframe+0x44/0xa9
The above panic occurs when loading two modules at the same time with
ftrace enabled, where at least one of the modules is a livepatch module:
CPU0 CPU1
klp_enable_patch()
klp_init_object_loaded()
module_disable_ro()
set_all_modules_text_ro()
klp_write_object_relocations()
apply_relocate_add()
*patches read-only code* - BOOM
A similar race exists when toggling ftrace while loading a livepatch
module.
Fix it by ensuring that the livepatch and ftrace code patching
operations -- and their respective permissions changes -- are protected
by the text_mutex.
Link: http://lkml.kernel.org/r/ab43d56ab909469ac5d2520c5d944ad6d4abd476.1560474114.git.jpoimboe@redhat.com
Reported-by: Johannes Erdfelt <johannes@erdfelt.com>
Fixes: 444d13ff10fb ("modules: add ro_after_init support")
Acked-by: Jessica Yu <jeyu@kernel.org>
Reviewed-by: Petr Mladek <pmladek@suse.com>
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
[ Upstream commit cbdaeaf050b730ea02e9ab4ff844ce54d85dbe1d ]
Selecting HAVE_NOP_MCOUNT enables -mnop-mcount (if gcc supports it)
and sets CC_USING_NOP_MCOUNT. Reuse __is_defined (which is suitable for
testing CC_USING_* defines) to avoid conditional compilation and fix
the following gcc 9 warning on s390:
kernel/trace/ftrace.c:2514:1: warning: ‘ftrace_code_disable’ defined
but not used [-Wunused-function]
Link: http://lkml.kernel.org/r/patch.git-1a82d13f33ac.your-ad-here.call-01559732716-ext-6629@work.hours
Fixes: 2f4df0017baed ("tracing: Add -mcount-nop option support")
Signed-off-by: Vasily Gorbik <gor@linux.ibm.com>
[ Upstream commit d477f8c202d1f0d4791ab1263ca7657bbe5cf79e ]
In the case that a process is constrained by taskset(1) (i.e.
sched_setaffinity(2)) to a subset of available cpus, and all of those are
subsequently offlined, the scheduler will set tsk->cpus_allowed to
the current value of task_cs(tsk)->effective_cpus.
This is done via a call to do_set_cpus_allowed() in the context of
cpuset_cpus_allowed_fallback() made by the scheduler when this case is
detected. This is the only call made to cpuset_cpus_allowed_fallback()
in the latest mainline kernel.
However, this is not sane behavior.
I will demonstrate this on a system running the latest upstream kernel
with the following initial configuration:
# grep -i cpu /proc/$$/status
Cpus_allowed: ffffffff,fffffff
Cpus_allowed_list: 0-63
(Where cpus 32-63 are provided via smt.)
If we limit our current shell process to cpu2 only and then offline it
and reonline it:
# taskset -p 4 $$
pid 2272's current affinity mask: ffffffffffffffff
pid 2272's new affinity mask: 4
# echo off > /sys/devices/system/cpu/cpu2/online
# dmesg | tail -3
[ 2195.866089] process 2272 (bash) no longer affine to cpu2
[ 2195.872700] IRQ 114: no longer affine to CPU2
[ 2195.879128] smpboot: CPU 2 is now offline
# echo on > /sys/devices/system/cpu/cpu2/online
# dmesg | tail -1
[ 2617.043572] smpboot: Booting Node 0 Processor 2 APIC 0x4
We see that our current process now has an affinity mask containing
every cpu available on the system _except_ the one we originally
constrained it to:
Cpus_allowed: ffffffff,fffffffb
Cpus_allowed_list: 0-1,3-63
This is not sane behavior, as the scheduler can now not only place the
process on previously forbidden cpus, it can't even schedule it on
the cpu it was originally constrained to!
Other cases result in even more exotic affinity masks. Take for instance
a process with an affinity mask containing only cpus provided by smt at
the moment that smt is toggled, in a configuration such as the following:
# taskset -p f000000000 $$
Cpus_allowed: 000000f0,00000000
Cpus_allowed_list: 36-39
A double toggle of smt results in the following behavior:
# echo off > /sys/devices/system/cpu/smt/control
# echo on > /sys/devices/system/cpu/smt/control
# grep -i cpus /proc/$$/status
Cpus_allowed: ffffff00,ffffffff
Cpus_allowed_list: 0-31,40-63
This is even less sane than the previous case, as the new affinity mask
excludes all smt-provided cpus with ids less than those that were
previously in the affinity mask, as well as those that were actually in
the mask.
With this patch applied, both of these cases end in the following state:
Cpus_allowed: ffffffff,ffffffff
The original policy is discarded. Though not ideal, it is the simplest way
to restore sanity to this fallback case without reinventing the cpuset
wheel that rolls down the kernel just fine in cgroup v2. A user who wishes
for the previous affinity mask to be restored in this fallback case can use
that mechanism instead.
This patch modifies scheduler behavior by instead resetting the mask to
task_cs(tsk)->cpus_allowed by default, and cpu_possible mask in legacy
mode. I tested the cases above on both modes.
Note that the scheduler uses this fallback mechanism if and only if
_every_ other valid avenue has been traveled, and it is the last resort
before calling BUG().
Suggested-by: Waiman Long <longman@redhat.com>
Suggested-by: Phil Auld <pauld@redhat.com>
Signed-off-by: Joel Savitz <jsavitz@redhat.com>
Acked-by: Phil Auld <pauld@redhat.com>
Acked-by: Waiman Long <longman@redhat.com>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
commit 983695fa676568fc0fe5ddd995c7267aabc24632 upstream.
Intention of cgroup bind/connect/sendmsg BPF hooks is to act transparently
to applications as also stated in original motivation in 7828f20e3779 ("Merge
branch 'bpf-cgroup-bind-connect'"). When recently integrating the latter
two hooks into Cilium to enable host based load-balancing with Kubernetes,
I ran into the issue that pods couldn't start up as DNS got broken. Kubernetes
typically sets up DNS as a service and is thus subject to load-balancing.
Upon further debugging, it turns out that the cgroupv2 sendmsg BPF hooks API
is currently insufficient and thus not usable as-is for standard applications
shipped with most distros. To break down the issue we ran into with a simple
example:
# cat /etc/resolv.conf
nameserver 147.75.207.207
nameserver 147.75.207.208
For the purpose of a simple test, we set up above IPs as service IPs and
transparently redirect traffic to a different DNS backend server for that
node:
# cilium service list
ID Frontend Backend
1 147.75.207.207:53 1 => 8.8.8.8:53
2 147.75.207.208:53 1 => 8.8.8.8:53
The attached BPF program is basically selecting one of the backends if the
service IP/port matches on the cgroup hook. DNS breaks here, because the
hooks are not transparent enough to applications which have built-in msg_name
address checks:
# nslookup 1.1.1.1
;; reply from unexpected source: 8.8.8.8#53, expected 147.75.207.207#53
;; reply from unexpected source: 8.8.8.8#53, expected 147.75.207.208#53
;; connection timed out; no servers could be reached
# dig 1.1.1.1
; <<>> DiG 9.11.3-1ubuntu1.7-Ubuntu <<>> 1.1.1.1
;; global options: +cmd
For comparison, if none of the service IPs is used, and we tell nslookup
to use 8.8.8.8 directly it works just fine, of course:
# nslookup 1.1.1.1 8.8.8.8
1.1.1.1.in-addr.arpa name = one.one.one.one.
In order to fix this and thus act more transparent to the application,
this needs reverse translation on recvmsg() side. A minimal fix for this
API is to add similar recvmsg() hooks behind the BPF cgroups static key
such that the program can track state and replace the current sockaddr_in{,6}
with the original service IP. From BPF side, this basically tracks the
service tuple plus socket cookie in an LRU map where the reverse NAT can
then be retrieved via map value as one example. Side-note: the BPF cgroups
static key should be converted to a per-hook static key in future.
Same example after this fix:
ID Frontend Backend
Lookups work fine now:
# nslookup 1.1.1.1
Authoritative answers can be found from:
# dig 1.1.1.1
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 51550
;; flags: qr rd ra ad; QUERY: 1, ANSWER: 0, AUTHORITY: 1, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 512
;; QUESTION SECTION:
;1.1.1.1. IN A
;; AUTHORITY SECTION:
. 23426 IN SOA a.root-servers.net. nstld.verisign-grs.com. 2019052001 1800 900 604800 86400
;; Query time: 17 msec
;; SERVER: 147.75.207.207#53(147.75.207.207)
;; WHEN: Tue May 21 12:59:38 UTC 2019
;; MSG SIZE rcvd: 111
And from an actual packet level it shows that we're using the back end
server when talking via 147.75.207.20{7,8} front end:
# tcpdump -i any udp
12:59:52.698732 IP foo.42011 > google-public-dns-a.google.com.domain: 18803+ PTR? 1.1.1.1.in-addr.arpa. (38)
12:59:52.698735 IP foo.42011 > google-public-dns-a.google.com.domain: 18803+ PTR? 1.1.1.1.in-addr.arpa. (38)
12:59:52.701208 IP google-public-dns-a.google.com.domain > foo.42011: 18803 1/0/0 PTR one.one.one.one. (67)
In order to be flexible and to have same semantics as in sendmsg BPF
programs, we only allow return codes in [1,1] range. In the sendmsg case
the program is called if msg->msg_name is present which can be the case
in both, connected and unconnected UDP.
The former only relies on the sockaddr_in{,6} passed via connect(2) if
passed msg->msg_name was NULL. Therefore, on recvmsg side, we act in similar
way to call into the BPF program whenever a non-NULL msg->msg_name was
passed independent of sk->sk_state being TCP_ESTABLISHED or not. Note
that for TCP case, the msg->msg_name is ignored in the regular recvmsg
path and therefore not relevant.
For the case of ip{,v6}_recv_error() paths, picked up via MSG_ERRQUEUE,
the hook is not called. This is intentional as it aligns with the same
semantics as in case of TCP cgroup BPF hooks right now. This might be
better addressed in future through a different bpf_attach_type such
that this case can be distinguished from the regular recvmsg paths,
for example.
Fixes: 1cedee13d25a ("bpf: Hooks for sys_sendmsg")
Acked-by: Andrey Ignatov <rdna@fb.com>
Acked-by: Martin KaFai Lau <kafai@fb.com>
Acked-by: Martynas Pumputis <m@lambda.lt>
commit 9594dc3c7e71b9f52bee1d7852eb3d4e3aea9e99 upstream.
BPF_PROG_TYPE_RAW_TRACEPOINTs can be executed nested on the same CPU, as
they do not increment bpf_prog_active while executing.
This enables three levels of nesting, to support
- a kprobe or raw tp or perf event,
- another one of the above that irq context happens to call, and
- another one in nmi context
(at most one of which may be a kprobe or perf event).
Fixes: 20b9d7ac4852 ("bpf: avoid excessive stack usage for perf_sample_data")
Signed-off-by: Matt Mullins <mmullins@fb.com>
Acked-by: Andrii Nakryiko <andriin@fb.com>
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
commit da2577fdd0932ea4eefe73903f1130ee366767d2 upstream.
If the leftmost parent node of the tree has does not have a child
on the left side, then trie_get_next_key (and bpftool map dump) will
not look at the child on the right. This leads to the traversal
missing elements.
Lookup is not affected.
Update selftest to handle this case.
Reproducer:
bpftool map create /sys/fs/bpf/lpm type lpm_trie key 6 \
value 1 entries 256 name test_lpm flags 1
bpftool map update pinned /sys/fs/bpf/lpm key 8 0 0 0 0 0 value 1
bpftool map update pinned /sys/fs/bpf/lpm key 16 0 0 0 0 128 value 2
bpftool map dump pinned /sys/fs/bpf/lpm
Returns only 1 element. (2 expected)
Fixes: b471f2f1de8b ("bpf: implement MAP_GET_NEXT_KEY command for LPM_TRIE")
Signed-off-by: Jonathan Lemon <jonathan.lemon@gmail.com>
commit 1bf72720281770162c87990697eae1ba2f1d917a upstream.
Currently, if the user specifies an unsupported mitigation strategy on the
kernel command line, it will be ignored silently. The code will fall back
to the default strategy, possibly leaving the system more vulnerable than
expected.
This may happen due to e.g. a simple typo, or, for a stable kernel release,
because not all mitigation strategies have been backported.
Inform the user by printing a message.
Fixes: 98af8452945c5565 ("cpu/speculation: Add 'mitigations=' cmdline option")
Acked-by: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Ben Hutchings <ben@decadent.org.uk>
Link: https://lkml.kernel.org/r/20190516070935.22546-1-geert@linux-m68k.org
This reverts commit 1a3188d737ceb922166d8fe78a5fc4f89907e31b, which was
upstream commit 4a6c91fbdef846ec7250b82f2eeeb87ac5f18cf9.
On Tue, Jun 25, 2019 at 09:39:45AM +0200, Sebastian Andrzej Siewior wrote:
>Please backport commit e74deb11931ff682b59d5b9d387f7115f689698e to
>stable _or_ revert the backport of commit 4a6c91fbdef84 ("x86/uaccess,
>ftrace: Fix ftrace_likely_update() vs. SMAP"). It uses
>user_access_{save|restore}() which has been introduced in the following
>commit.
commit 0c97bf863efce63d6ab7971dad811601e6171d2f upstream.
Starting with GCC 9, -Warray-bounds detects cases when memset is called
starting on a member of a struct but the size to be cleared ends up
writing over further members.
Such a call happens in the trace code to clear, at once, all members
after and including `seq` on struct trace_iterator:
In function 'memset',
inlined from 'ftrace_dump' at kernel/trace/trace.c:8914:3:
./include/linux/string.h:344:9: warning: '__builtin_memset' offset
[8505, 8560] from the object at 'iter' is out of the bounds of
referenced subobject 'seq' with type 'struct trace_seq' at offset
4368 [-Warray-bounds]
344 | return __builtin_memset(p, c, size);
In order to avoid GCC complaining about it, we compute the address
ourselves by adding the offsetof distance instead of referring
directly to the member.
Since there are two places doing this clear (trace.c and trace_kdb.c),
take the chance to move the workaround into a single place in
the internal header.
Link: http://lkml.kernel.org/r/20190523124535.GA12931@gmail.com
Signed-off-by: Miguel Ojeda <miguel.ojeda.sandonis@gmail.com>
[ Removed unnecessary parenthesis around "iter" ]
[ Upstream commit 4d839dd9e4356bbacf3eb0ab13a549b83b008c21 ]
We must use {READ,WRITE}_ONCE() on rb->user_page data such that
concurrent usage will see whole values. A few key sites were missing
this.
Suggested-by: Yabin Cui <yabinc@google.com>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Vince Weaver <vincent.weaver@maine.edu>
Cc: acme@kernel.org
Cc: mark.rutland@arm.com
Cc: namhyung@kernel.org
Fixes: 7b732a750477 ("perf_counter: new output ABI - part 1")
Link: http://lkml.kernel.org/r/20190517115418.394192145@infradead.org
[ Upstream commit 3f9fbe9bd86c534eba2faf5d840fd44c6049f50e ]
Similar to how decrementing rb->next too early can cause data_head to
(temporarily) be observed to go backward, so too can this happen when
we increment too late.
This barrier() ensures the rb->head load happens after the increment,
both the one in the 'goto again' path, as the one from
perf_output_get_handle() -- albeit very unlikely to matter for the
latter.
Cc: acme@kernel.org
Fixes: ef60777c9abd ("perf: Optimize the perf_output() path by removing IRQ-disables")
Link: http://lkml.kernel.org/r/20190517115418.309516009@infradead.org
[ Upstream commit 1b038c6e05ff70a1e66e3e571c2e6106bdb75f53 ]
In perf_output_put_handle(), an IRQ/NMI can happen in below location and
write records to the same ring buffer:
local_dec_and_test(&rb->nest)
... <-- an IRQ/NMI can happen here
rb->user_page->data_head = head;
In this case, a value A is written to data_head in the IRQ, then a value
B is written to data_head after the IRQ. And A > B. As a result,
data_head is temporarily decreased from A to B. And a reader may see
data_head < data_tail if it read the buffer frequently enough, which
creates unexpected behaviors.
This can be fixed by moving dec(&rb->nest) to after updating data_head,
which prevents the IRQ/NMI above from updating data_head.
[ Split up by peterz. ]
Signed-off-by: Yabin Cui <yabinc@google.com>
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Cc: Namhyung Kim <namhyung@kernel.org>
Link: http://lkml.kernel.org/r/20190517115418.224478157@infradead.org
commit e3ff9c3678b4d80e22d2557b68726174578eaf52 upstream.
Jason reported that the coarse ktime based time getters advance only once
per second and not once per tick as advertised.
The code reads only the monotonic base time, which advances once per
second. The nanoseconds are accumulated on every tick in xtime_nsec up to
a second and the regular time getters take this nanoseconds offset into
account, but the ktime_get_coarse*() implementation fails to do so.
Add the accumulated xtime_nsec value to the monotonic base time to get the
proper per tick advancing coarse tinme.
Fixes: b9ff604cff11 ("timekeeping: Add ktime_get_coarse_with_offset")
Reported-by: Jason A. Donenfeld <Jason@zx2c4.com>
Tested-by: Jason A. Donenfeld <Jason@zx2c4.com>
Cc: Clemens Ladisch <clemens@ladisch.de>
Cc: Sultan Alsawaf <sultan@kerneltoast.com>
Cc: Waiman Long <longman@redhat.com>
Link: https://lkml.kernel.org/r/alpine.DEB.2.21.1906132136280.1791@nanos.tec.linutronix.de
[ Upstream commit 55267c88c003a3648567beae7c90512d3e2ab15e ]
hist_field_var_ref() is an implementation of hist_field_fn_t(), which
can be called with a null tracing_map_elt elt param when assembling a
key in event_hist_trigger().
In the case of hist_field_var_ref() this doesn't make sense, because a
variable can only be resolved by looking it up using an already
assembled key i.e. a variable can't be used to assemble a key since
the key is required in order to access the variable.
Upper layers should prevent the user from constructing a key using a
variable in the first place, but in case one slips through, it
shouldn't cause a NULL pointer dereference. Also if one does slip
through, we want to know about it, so emit a one-time warning in that
case.
Link: http://lkml.kernel.org/r/64ec8dc15c14d305295b64cdfcc6b2b9dd14753f.1555597045.git.tom.zanussi@linux.intel.com
Reported-by: Vincent Bernat <vincent@bernat.ch>
Signed-off-by: Tom Zanussi <tom.zanussi@linux.intel.com>
[ Upstream commit 40ea97290b08be2e038b31cbb33097d1145e8169 ]
New tooling noticed this mishap:
kernel/kcov.o: warning: objtool: write_comp_data()+0x138: call to __stack_chk_fail() with UACCESS enabled
kernel/kcov.o: warning: objtool: __sanitizer_cov_trace_pc()+0xd9: call to __stack_chk_fail() with UACCESS enabled
All the other instrumentation (KASAN,UBSAN) also have stack protector
disabled.
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
commit f6581f5b55141a95657ef5742cf6a6bfa20a109f upstream.
Restore the read memory barrier in __ptrace_may_access() that was deleted
a couple years ago. Also add comments on this barrier and the one it pairs
with to explain why they're there (as far as I understand).
Fixes: bfedb589252c ("mm: Add a user_ns owner to mm_struct and fix ptrace permission checks")
[ Upstream commit f6e2aa91a46d2bc79fce9b93a988dbe7655c90c0 ]
Recently syzbot in conjunction with KMSAN reported that
ptrace_peek_siginfo can copy an uninitialized siginfo to userspace.
Inspecting ptrace_peek_siginfo confirms this.
The problem is that off when initialized from args.off can be
initialized to a negaive value. At which point the "if (off >= 0)"
test to see if off became negative fails because off started off
negative.
Prevent the core problem by adding a variable found that is only true
if a siginfo is found and copied to a temporary in preparation for
being copied to userspace.
Prevent args.off from being truncated when being assigned to off by
testing that off is <= the maximum possible value of off. Convert off
to an unsigned long so that we should not have to truncate args.off,
we have well defined overflow behavior so if we add another check we
won't risk fighting undefined compiler behavior, and so that we have a
type whose maximum value is easy to test for.
Cc: Andrei Vagin <avagin@gmail.com>
Reported-by: syzbot+0d602a1b0d8c95bdf299@syzkaller.appspotmail.com
Fixes: 84c751bd4aeb ("ptrace: add ability to retrieve signals without removing from a queue (v4)")
[ Upstream commit fdc6bae940ee9eb869e493990540098b8c0fd6ab ]
The ADJ_TAI adjtimex mode sets the TAI-UTC offset of the system clock.
It is typically set by NTP/PTP implementations and it is automatically
updated by the kernel on leap seconds. The initial value is zero (which
applications may interpret as unknown), but this value cannot be set by
adjtimex. This limitation seems to go back to the original "nanokernel"
implementation by David Mills.
Change the ADJ_TAI check to accept zero as a valid TAI-UTC offset in
order to allow setting it back to the initial value.
Fixes: 153b5d054ac2 ("ntp: support for TAI")
Suggested-by: Ondrej Mosnacek <omosnace@redhat.com>
Signed-off-by: Miroslav Lichvar <mlichvar@redhat.com>
Cc: John Stultz <john.stultz@linaro.org>
Cc: Richard Cochran <richardcochran@gmail.com>
Cc: Prarit Bhargava <prarit@redhat.com>
Link: https://lkml.kernel.org/r/20190417084833.7401-1-mlichvar@redhat.com
[ Upstream commit e2f7fc0ac6957cabff4cecf6c721979b571af208 ]
Commit 31fd85816dbe ("bpf: permits narrower load from bpf program
context fields") made the verifier add AND instructions to clear the
unwanted bits with a mask when doing a narrow load. The mask is
computed with
(1 << size * 8) - 1
where "size" is the size of the narrow load. When doing a 4 byte load
of a an 8 byte field the verifier shifts the literal 1 by 32 places to
the left. This results in an overflow of a signed integer, which is an
undefined behavior. Typically, the computed mask was zero, so the
result of the narrow load ended up being zero too.
Cast the literal to long long to avoid overflows. Note that narrow
load of the 4 byte fields does not have the undefined behavior,
because the load size can only be either 1 or 2 bytes, so shifting 1
by 8 or 16 places will not overflow it. And reading 4 bytes would not
be a narrow load of a 4 bytes field.
Fixes: 31fd85816dbe ("bpf: permits narrower load from bpf program context fields")
Reviewed-by: Alban Crequy <alban@kinvolk.io>
Reviewed-by: Iago López Galeiras <iago@kinvolk.io>
Signed-off-by: Krzesimir Nowak <krzesimir@kinvolk.io>
Cc: Yonghong Song <yhs@fb.com>
[ Upstream commit a9e73998f9d705c94a8dca9687633adc0f24a19a ]
While validating new map we require the @start_data to be strictly less
than @end_data, which is fine for regular applications (this is why this
nit didn't trigger for that long). These members are set from executable
loaders such as elf handers, still it is pretty valid to have a loadable
data section with zero size in file, in such case the start_data is equal
to end_data once kernel loader finishes.
As a result when we're trying to restore such programs the procedure fails
and the kernel returns -EINVAL. From the image dump of a program:
| "mm_start_code": "0x400000",
| "mm_end_code": "0x8f5fb4",
| "mm_start_data": "0xf1bfb0",
| "mm_end_data": "0xf1bfb0",
Thus we need to change validate_prctl_map from strictly less to less or
equal operator use.
Link: http://lkml.kernel.org/r/20190408143554.GY1421@uranus.lan
Fixes: f606b77f1a9e3 ("prctl: PR_SET_MM -- introduce PR_SET_MM_MAP operation")
Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com>
Cc: Andrey Vagin <avagin@gmail.com>
Cc: Dmitry Safonov <0x7f454c46@gmail.com>
Cc: Pavel Emelyanov <xemul@virtuozzo.com>
[ Upstream commit e260ad01f0aa9e96b5386d5cd7184afd949dc457 ]
Currently when userspace gives us a values that overflow e.g. file-max
and other callers of __do_proc_doulongvec_minmax() we simply ignore the
new value and leave the current value untouched.
This can be problematic as it gives the illusion that the limit has
indeed be bumped when in fact it failed. This commit makes sure to
return EINVAL when an overflow is detected. Please note that this is a
userspace facing change.
Link: http://lkml.kernel.org/r/20190210203943.8227-4-christian@brauner.io
Signed-off-by: Christian Brauner <christian@brauner.io>
Acked-by: Luis Chamberlain <mcgrof@kernel.org>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: Dominik Brodowski <linux@dominikbrodowski.net>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Joe Lawrence <joe.lawrence@redhat.com>
commit ec527c318036a65a083ef68d8ba95789d2212246 upstream.
As explained in
0cc3cd21657b ("cpu/hotplug: Boot HT siblings at least once")
we always, no matter what, have to bring up x86 HT siblings during boot at
least once in order to avoid first MCE bringing the system to its knees.
That means that whenever 'nosmt' is supplied on the kernel command-line,
all the HT siblings are as a result sitting in mwait or cpudile after
going through the online-offline cycle at least once.
This causes a serious issue though when a kernel, which saw 'nosmt' on its
commandline, is going to perform resume from hibernation: if the resume
from the hibernated image is successful, cr3 is flipped in order to point
to the address space of the kernel that is being resumed, which in turn
means that all the HT siblings are all of a sudden mwaiting on address
which is no longer valid.
That results in triple fault shortly after cr3 is switched, and machine
reboots.
Fix this by always waking up all the SMT siblings before initiating the
'restore from hibernation' process; this guarantees that all the HT
siblings will be properly carried over to the resumed kernel waiting in
resume_play_dead(), and acted upon accordingly afterwards, based on the
target kernel configuration.
Symmetricaly, the resumed kernel has to push the SMT siblings to mwait
again in case it has SMT disabled; this means it has to online all
the siblings when resuming (so that they come out of hlt) and offline
them again to let them reach mwait.
Cc: 4.19+ <stable@vger.kernel.org> # v4.19+
Debugged-by: Thomas Gleixner <tglx@linutronix.de>
Fixes: 0cc3cd21657b ("cpu/hotplug: Boot HT siblings at least once")
Acked-by: Pavel Machek <pavel@ucw.cz>
commit 98af37d624ed8c83f1953b1b6b2f6866011fc064 upstream.
In the fixes commit, removing SIGKILL from each thread signal mask and
executing "goto fatal" directly will skip the call to
"trace_signal_deliver". At this point, the delivery tracking of the
SIGKILL signal will be inaccurate.
Therefore, we need to add trace_signal_deliver before "goto fatal" after
executing sigdelset.
Note: SEND_SIG_NOINFO matches the fact that SIGKILL doesn't have any info.
Link: http://lkml.kernel.org/r/20190425025812.91424-1-weizhenliang@huawei.com
Fixes: cf43a757fd4944 ("signal: Restore the stop PTRACE_EVENT_EXIT")
Signed-off-by: Zhenliang Wei <weizhenliang@huawei.com>
Reviewed-by: Christian Brauner <christian@brauner.io>
Reviewed-by: Oleg Nesterov <oleg@redhat.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Ivan Delalande <colona@arista.com>
Cc: Deepa Dinamani <deepa.kernel@gmail.com>
Cc: <stable@vger.kernel.org>
commit dfb4a6f2191a80c8b790117d0ff592fd712d3296 upstream.
In case of errors, predicate_parse() goes to the out_free label
to free memory and to return an error code.
However, predicate_parse() does not free the predicates of the
temporary prog_stack array, thence leaking them.
Link: http://lkml.kernel.org/r/20190528154338.29976-1-tomasbortoli@gmail.com
Fixes: 80765597bc587 ("tracing: Rewrite filter logic to be simpler and faster")
Reported-by: syzbot+6b8e0fb820e570c59e19@syzkaller.appspotmail.com
Signed-off-by: Tomas Bortoli <tomasbortoli@gmail.com>
[ Added protection around freeing prog_stack[i].pred ]
commit e9666d10a5677a494260d60d1fa0b73cc7646eb3 upstream.
Currently, CONFIG_JUMP_LABEL just means "I _want_ to use jump label".
The jump label is controlled by HAVE_JUMP_LABEL, which is defined
like this:
#if defined(CC_HAVE_ASM_GOTO) && defined(CONFIG_JUMP_LABEL)
# define HAVE_JUMP_LABEL
#endif
We can improve this by testing 'asm goto' support in Kconfig, then
make JUMP_LABEL depend on CC_HAS_ASM_GOTO.
Ugly #ifdef HAVE_JUMP_LABEL will go away, and CONFIG_JUMP_LABEL will
match to the real kernel capability.
Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Tested-by: Sedat Dilek <sedat.dilek@gmail.com>
[nc: Fix trivial conflicts in 4.19
arch/xtensa/kernel/jump_label.c doesn't exist yet
Ensured CC_HAVE_ASM_GOTO and HAVE_JUMP_LABEL were sufficiently
eliminated]
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
[ Upstream commit ad092c027713a68a34168942a5ef422e42e039f4 ]
If the specified rcuperf.perf_type is not in the rcu_perf_init()
function's perf_ops[] array, rcuperf prints some console messages and
then invokes rcu_perf_cleanup() to set state so that a future torture
test can run. However, rcu_perf_cleanup() also attempts to end the
test that didn't actually start, and in doing so relies on the value
of cur_ops, a value that is not particularly relevant in this case.
This can result in confusing output or even follow-on failures due to
attempts to use facilities that have not been properly initialized.
This commit therefore sets the value of cur_ops to NULL in this case and
inserts a check near the beginning of rcu_perf_cleanup(), thus avoiding
relying on an irrelevant cur_ops value.
Signed-off-by: Paul E. McKenney <paulmck@linux.ibm.com>
[ Upstream commit b813afae7ab6a5e91b4e16cc567331d9c2ae1f04 ]
If the specified rcutorture.torture_type is not in the rcu_torture_init()
function's torture_ops[] array, rcutorture prints some console messages
and then invokes rcu_torture_cleanup() to set state so that a future
torture test can run. However, rcu_torture_cleanup() also attempts to
end the test that didn't actually start, and in doing so relies on the
value of cur_ops, a value that is not particularly relevant in this case.
and inserts a check near the beginning of rcu_torture_cleanup(),
thus avoiding relying on an irrelevant cur_ops value.
Reported-by: kernel test robot <rong.a.chen@intel.com>
[ Upstream commit 7a8e61f8478639072d402a26789055a4a4de8f77 ]
Several people reported testing failures after setting CLOCK_REALTIME close
to the limits of the kernel internal representation in nanoseconds,
i.e. year 2262.
The failures are exposed in subsequent operations, i.e. when arming timers
or when the advancing CLOCK_MONOTONIC makes the calculation of
CLOCK_REALTIME overflow into negative space.
Now people start to paper over the underlying problem by clamping
calculations to the valid range, but that's just wrong because such
workarounds will prevent detection of real issues as well.
It is reasonable to force an upper bound for the various methods of setting
CLOCK_REALTIME. Year 2262 is the absolute upper bound. Assume a maximum
uptime of 30 years which is plenty enough even for esoteric embedded
systems. That results in an upper bound of year 2232 for setting the time.
Once that limit is reached in reality this limit is only a small part of
the problem space. But until then this stops people from trying to paper
over the problem at the wrong places.
Reported-by: Xiongfeng Wang <wangxiongfeng2@huawei.com>
Reported-by: Hongbo Yao <yaohongbo@huawei.com>
Cc: Stephen Boyd <sboyd@kernel.org>
Cc: Miroslav Lichvar <mlichvar@redhat.com>
Link: https://lkml.kernel.org/r/alpine.DEB.2.21.1903231125480.2157@nanos.tec.linutronix.de
[ Upstream commit 4a6c91fbdef846ec7250b82f2eeeb87ac5f18cf9 ]
For CONFIG_TRACE_BRANCH_PROFILING=y the likely/unlikely things get
overloaded and generate callouts to this code, and thus also when
AC=1.
Make it safe.
[ Upstream commit 471ba0e686cb13752bc1ff3216c54b69a2d250ea ]
The QEMU PowerPC/PSeries machine model was not expecting a self-IPI,
and it may be a bit surprising thing to do, so have irq_work_queue_on
do local queueing when target is the current CPU.
Suggested-by: Steven Rostedt <rostedt@goodmis.org>
Reported-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Tested-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Signed-off-by: Nicholas Piggin <npiggin@gmail.com>
Reviewed-by: Frederic Weisbecker <frederic@kernel.org>
Cc: =?UTF-8?q?C=C3=A9dric=20Le=20Goater?= <clg@kaod.org>
Cc: Suraj Jitindar Singh <sjitindarsingh@gmail.com>
Link: https://lkml.kernel.org/r/20190409093403.20994-1-npiggin@gmail.com
[ Simplified the preprocessor comments.
Fixed unbalanced curly brackets pointed out by Thomas. ]
[ Upstream commit 5b61d50ab4ef590f5e1d4df15cd2cea5f5715308 ]
Bit shift in scale_load() could overflow shares. This patch saturates
it to MAX_SHARES like following sched_group_set_shares().
Example:
# echo 9223372036854776832 > cpu.shares
# cat cpu.shares
Before patch: 1024
After pattch: 262144
Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Link: http://lkml.kernel.org/r/155125501891.293431.3345233332801109696.stgit@buzz
[ Upstream commit 1a010e29cfa00fee2888fd2fd4983f848cbafb58 ]
Example of unhandled overflows:
# echo 18446744073709651 > cpu.rt_runtime_us
# cat cpu.rt_runtime_us
99
# echo 18446744073709900 > cpu.rt_period_us
# cat cpu.rt_period_us
348
After this patch they will fail with -EINVAL.
Link: http://lkml.kernel.org/r/155125501739.293431.5252197504404771496.stgit@buzz
[ Upstream commit 1a8b4540db732ca16c9e43ac7c08b1b8f0b252d8 ]
Large values could overflow u64 and pass following sanity checks.
# echo 18446744073750000 > cpu.cfs_period_us
# cat cpu.cfs_period_us
40448
# echo 18446744073750000 > cpu.cfs_quota_us
# cat cpu.cfs_quota_us
40448
Link: http://lkml.kernel.org/r/155125502079.293431.3947497929372138600.stgit@buzz
[ Upstream commit 4dcabece4c3a9f9522127be12cc12cc120399b2f ]
The number of descendant cgroups and the number of dying
descendant cgroups are currently synchronized using the cgroup_mutex.
The number of descendant cgroups will be required by the cgroup v2
freezer, which will use it to determine if a cgroup is frozen
(depending on total number of descendants and number of frozen
descendants). It's not always acceptable to grab the cgroup_mutex,
especially from quite hot paths (e.g. exit()).
To avoid this, let's additionally synchronize these counters using
the css_set_lock.
So, it's safe to read these counters with either cgroup_mutex or
css_set_lock locked, and for changing both locks should be acquired.
Signed-off-by: Roman Gushchin <guro@fb.com>
Cc: kernel-team@fb.com
[ Upstream commit 70c4cf17e445264453bc5323db3e50aa0ac9e81f ]
In audit_rule_change(), audit_data_to_entry() is firstly invoked to
translate the payload data to the kernel's rule representation. In
audit_data_to_entry(), depending on the audit field type, an audit tree may
be created in audit_make_tree(), which eventually invokes kmalloc() to
allocate the tree. Since this tree is a temporary tree, it will be then
freed in the following execution, e.g., audit_add_rule() if the message
type is AUDIT_ADD_RULE or audit_del_rule() if the message type is
AUDIT_DEL_RULE. However, if the message type is neither AUDIT_ADD_RULE nor
AUDIT_DEL_RULE, i.e., the default case of the switch statement, this
temporary tree is not freed.
To fix this issue, only allocate the tree when the type is AUDIT_ADD_RULE
or AUDIT_DEL_RULE.
Signed-off-by: Wenwen Wang <wang6495@umn.edu>
Reviewed-by: Richard Guy Briggs <rgb@redhat.com>
Signed-off-by: Paul Moore <paul@paul-moore.com>
[ Upstream commit 9b019acb72e4b5741d88e8936d6f200ed44b66b2 ]
The NOHZ idle balancer runs on the lowest idle CPU. This can
interfere with isolated CPUs, so confine it to HK_FLAG_MISC
housekeeping CPUs.
HK_FLAG_SCHED is not used for this because it is not set anywhere
at the moment. This could be folded into HK_FLAG_SCHED once that
option is fixed.
The problem was observed with increased jitter on an application
running on CPU0, caused by NOHZ idle load balancing being run on
CPU1 (an SMT sibling).
Link: https://lkml.kernel.org/r/20190412042613.28930-1-npiggin@gmail.com
[ Upstream commit f2c65fb3221adc6b73b0549fc7ba892022db9797 ]
When modules and BPF filters are loaded, there is a time window in
which some memory is both writable and executable. An attacker that has
already found another vulnerability (e.g., a dangling pointer) might be
able to exploit this behavior to overwrite kernel code. Prevent having
writable executable PTEs in this stage.
In addition, avoiding having W+X mappings can also slightly simplify the
patching of modules code on initialization (e.g., by alternatives and
static-key), as would be done in the next patch. This was actually the
main motivation for this patch.
To avoid having W+X mappings, set them initially as RW (NX) and after
they are set as RO set them as X as well. Setting them as executable is
done as a separate step to avoid one core in which the old PTE is cached
(hence writable), and another which sees the updated PTE (executable),
which would break the W^X protection.
Suggested-by: Thomas Gleixner <tglx@linutronix.de>
Suggested-by: Andy Lutomirski <luto@amacapital.net>
Signed-off-by: Nadav Amit <namit@vmware.com>
Signed-off-by: Rick Edgecombe <rick.p.edgecombe@intel.com>
Cc: <akpm@linux-foundation.org>
Cc: <ard.biesheuvel@linaro.org>
Cc: <deneen.t.dock@intel.com>
Cc: <kernel-hardening@lists.openwall.com>
Cc: <kristen@linux.intel.com>
Cc: <linux_dti@icloud.com>
Cc: <will.deacon@arm.com>
Cc: Jessica Yu <jeyu@kernel.org>
Cc: Masami Hiramatsu <mhiramat@kernel.org>
Cc: Rik van Riel <riel@surriel.com>
Link: https://lkml.kernel.org/r/20190426001143.4983-12-namit@vmware.com
commit 9419a3191dcb27f24478d288abaab697228d28e6 upstream.
What happens there is that we are replacing file->path.mnt of
a file we'd just opened with a clone and we need the write
count contribution to be transferred from original mount to
new one. That's it. We do *NOT* want any kind of freeze
protection for the duration of switchover.
IOW, we should just use __mnt_{want,drop}_write() for that
switchover; no need to bother with mnt_{want,drop}_write()
there.
Tested-by: Amir Goldstein <amir73il@gmail.com>
Reported-by: syzbot+2a73a6ea9507b7112141@syzkaller.appspotmail.com
commit 2baae3545327632167c0180e9ca1d467416f1919 upstream.
synchronize_rcu() is fine when the rcu callbacks only need
to free memory (kfree_rcu() or direct kfree() call rcu call backs)
__dev_map_entry_free() is a bit more complex, so we need to make
sure that call queued __dev_map_entry_free() callbacks have completed.
sysbot report:
BUG: KASAN: use-after-free in dev_map_flush_old kernel/bpf/devmap.c:365
[inline]
BUG: KASAN: use-after-free in __dev_map_entry_free+0x2a8/0x300
kernel/bpf/devmap.c:379
Read of size 8 at addr ffff8801b8da38c8 by task ksoftirqd/1/18
CPU: 1 PID: 18 Comm: ksoftirqd/1 Not tainted 4.17.0+ #39
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS
Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0x1b9/0x294 lib/dump_stack.c:113
print_address_description+0x6c/0x20b mm/kasan/report.c:256
kasan_report_error mm/kasan/report.c:354 [inline]
kasan_report.cold.7+0x242/0x2fe mm/kasan/report.c:412
__asan_report_load8_noabort+0x14/0x20 mm/kasan/report.c:433
dev_map_flush_old kernel/bpf/devmap.c:365 [inline]
__dev_map_entry_free+0x2a8/0x300 kernel/bpf/devmap.c:379
__rcu_reclaim kernel/rcu/rcu.h:178 [inline]
rcu_do_batch kernel/rcu/tree.c:2558 [inline]
invoke_rcu_callbacks kernel/rcu/tree.c:2818 [inline]
__rcu_process_callbacks kernel/rcu/tree.c:2785 [inline]
rcu_process_callbacks+0xe9d/0x1760 kernel/rcu/tree.c:2802
__do_softirq+0x2e0/0xaf5 kernel/softirq.c:284
run_ksoftirqd+0x86/0x100 kernel/softirq.c:645
smpboot_thread_fn+0x417/0x870 kernel/smpboot.c:164
kthread+0x345/0x410 kernel/kthread.c:240
ret_from_fork+0x3a/0x50 arch/x86/entry/entry_64.S:412
Allocated by task 6675:
save_stack+0x43/0xd0 mm/kasan/kasan.c:448
set_track mm/kasan/kasan.c:460 [inline]
kasan_kmalloc+0xc4/0xe0 mm/kasan/kasan.c:553
kmem_cache_alloc_trace+0x152/0x780 mm/slab.c:3620
kmalloc include/linux/slab.h:513 [inline]
kzalloc include/linux/slab.h:706 [inline]
dev_map_alloc+0x208/0x7f0 kernel/bpf/devmap.c:102
find_and_alloc_map kernel/bpf/syscall.c:129 [inline]
map_create+0x393/0x1010 kernel/bpf/syscall.c:453
__do_sys_bpf kernel/bpf/syscall.c:2351 [inline]
__se_sys_bpf kernel/bpf/syscall.c:2328 [inline]
__x64_sys_bpf+0x303/0x510 kernel/bpf/syscall.c:2328
do_syscall_64+0x1b1/0x800 arch/x86/entry/common.c:290
Freed by task 26:
__kasan_slab_free+0x11a/0x170 mm/kasan/kasan.c:521
kasan_slab_free+0xe/0x10 mm/kasan/kasan.c:528
__cache_free mm/slab.c:3498 [inline]
kfree+0xd9/0x260 mm/slab.c:3813
dev_map_free+0x4fa/0x670 kernel/bpf/devmap.c:191
bpf_map_free_deferred+0xba/0xf0 kernel/bpf/syscall.c:262
process_one_work+0xc64/0x1b70 kernel/workqueue.c:2153
worker_thread+0x181/0x13a0 kernel/workqueue.c:2296
The buggy address belongs to the object at ffff8801b8da37c0
which belongs to the cache kmalloc-512 of size 512
The buggy address is located 264 bytes inside of
512-byte region [ffff8801b8da37c0, ffff8801b8da39c0)
The buggy address belongs to the page:
page:ffffea0006e368c0 count:1 mapcount:0 mapping:ffff8801da800940
index:0xffff8801b8da3540
flags: 0x2fffc0000000100(slab)
raw: 02fffc0000000100 ffffea0007217b88 ffffea0006e30cc8 ffff8801da800940
raw: ffff8801b8da3540 ffff8801b8da3040 0000000100000004 0000000000000000
page dumped because: kasan: bad access detected
Memory state around the buggy address:
ffff8801b8da3780: fc fc fc fc fc fc fc fc fb fb fb fb fb fb fb fb
ffff8801b8da3800: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
> ffff8801b8da3880: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff8801b8da3900: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff8801b8da3980: fb fb fb fb fb fb fb fb fc fc fc fc fc fc fc fc
Fixes: 546ac1ffb70d ("bpf: add devmap, a map for storing net device references")
Reported-by: syzbot+457d3e2ffbcf31aee5c0@syzkaller.appspotmail.com
Acked-by: Toke Høiland-Jørgensen <toke@redhat.com>
commit ede95a63b5e84ddeea6b0c473b36ab8bfd8c6ce3 upstream.
Rick reported that the BPF JIT could potentially fill the entire module
space with BPF programs from unprivileged users which would prevent later
attempts to load normal kernel modules or privileged BPF programs, for
example. If JIT was enabled but unsuccessful to generate the image, then
before commit 290af86629b2 ("bpf: introduce BPF_JIT_ALWAYS_ON config")
we would always fall back to the BPF interpreter. Nowadays in the case
where the CONFIG_BPF_JIT_ALWAYS_ON could be set, then the load will abort
with a failure since the BPF interpreter was compiled out.
Add a global limit and enforce it for unprivileged users such that in case
of BPF interpreter compiled out we fail once the limit has been reached
or we fall back to BPF interpreter earlier w/o using module mem if latter
was compiled in. In a next step, fair share among unprivileged users can
be resolved in particular for the case where we would fail hard once limit
is reached.
Fixes: 290af86629b2 ("bpf: introduce BPF_JIT_ALWAYS_ON config")
Fixes: 0a14842f5a3c ("net: filter: Just In Time compiler for x86-64")
Co-Developed-by: Rick Edgecombe <rick.p.edgecombe@intel.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Acked-by: Alexei Starovoitov <ast@kernel.org>
Cc: Jann Horn <jannh@google.com>
Cc: LKML <linux-kernel@vger.kernel.org>
Cc: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit 50b045a8c0ccf44f76640ac3eea8d80ca53979a3 upstream.
One of the biggest issues we face right now with picking LRU map over
regular hash table is that a map walk out of user space, for example,
to just dump the existing entries or to remove certain ones, will
completely mess up LRU eviction heuristics and wrong entries such
as just created ones will get evicted instead. The reason for this
is that we mark an entry as "in use" via bpf_lru_node_set_ref() from
system call lookup side as well. Thus upon walk, all entries are
being marked, so information of actual least recently used ones
are "lost".
In case of Cilium where it can be used (besides others) as a BPF
based connection tracker, this current behavior causes disruption
upon control plane changes that need to walk the map from user space
to evict certain entries. Discussion result from bpfconf [0] was that
we should simply just remove marking from system call side as no
good use case could be found where it's actually needed there.
Therefore this patch removes marking for regular LRU and per-CPU
flavor. If there ever should be a need in future, the behavior could
be selected via map creation flag, but due to mentioned reason we
avoid this here.
[0] http://vger.kernel.org/bpfconf.html
Fixes: 29ba732acbee ("bpf: Add BPF_MAP_TYPE_LRU_HASH")
Fixes: 8f8449384ec3 ("bpf: Add BPF_MAP_TYPE_LRU_PERCPU_HASH")
commit c6110222c6f49ea68169f353565eb865488a8619 upstream.
Add a callback map_lookup_elem_sys_only() that map implementations
could use over map_lookup_elem() from system call side in case the
map implementation needs to handle the latter differently than from
the BPF data path. If map_lookup_elem_sys_only() is set, this will
be preferred pick for map lookups out of user space. This hook is
used in a follow-up fix for LRU map, but once development window
opens, we can convert other map types from map_lookup_elem() (here,
the one called upon BPF_MAP_LOOKUP_ELEM cmd is meant) over to use
the callback to simplify and clean up the latter.
