path: root/kernel
2016-10-26Merge tag 'v4.1.35' into 4.1-2.0.x-imxOtavio Salvador
Linux 4.1.35 * tag 'v4.1.35': (98 commits) Linux 4.1.35 xhci: fix usb2 resume timing and races. mm: remove gup_flags FOLL_WRITE games from __get_user_pages() timekeeping: Fix __ktime_get_fast_ns() regression time: Add cycles to nanoseconds translation Linux 4.1.34 openrisc: fix the fix of copy_from_user() avr32: fix 'undefined reference to `___copy_from_user' fix memory leaks in tracing_buffers_splice_read() tracing: Move mutex to protect against resetting of seq data MIPS: SMP: Fix possibility of deadlock when bringing CPUs online MIPS: Fix pre-r6 emulation FPU initialisation btrfs: ensure that file descriptor used with subvol ioctls is a dir fix fault_in_multipages_...() on architectures with no-op access_ok() ocfs2: fix start offset to ocfs2_zero_range_for_truncate() fanotify: fix list corruption in fanotify_get_response() fsnotify: add a way to stop queueing events on group shutdown autofs: use dentry flags to block walks during expire autofs races ocfs2/dlm: fix race between convert and migration ... Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2016-10-23timekeeping: Fix __ktime_get_fast_ns() regressionJohn Stultz
[ Upstream commit 58bfea9532552d422bde7afa207e1a0f08dffa7d ] In commit 27727df240c7 ("Avoid taking lock in NMI path with CONFIG_DEBUG_TIMEKEEPING"), I changed the logic to open-code the timekeeping_get_ns() function, but I forgot to include the unit conversion from cycles to nanoseconds, breaking the function's output, which impacts users like perf. This results in bogus perf timestamps like: swapper 0 [000] 253.427536: 111111111 cpu-clock: ffffffff810a0de6 native_safe_halt+0x6 ([kernel.kallsyms]) swapper 0 [000] 254.426573: 111111111 cpu-clock: ffffffff810a0de6 native_safe_halt+0x6 ([kernel.kallsyms]) swapper 0 [000] 254.426687: 111111111 cpu-clock: ffffffff810a0de6 native_safe_halt+0x6 ([kernel.kallsyms]) swapper 0 [000] 254.426800: 111111111 cpu-clock: ffffffff810a0de6 native_safe_halt+0x6 ([kernel.kallsyms]) swapper 0 [000] 254.426905: 111111111 cpu-clock: ffffffff810a0de6 native_safe_halt+0x6 ([kernel.kallsyms]) swapper 0 [000] 254.427022: 111111111 cpu-clock: ffffffff810a0de6 native_safe_halt+0x6 ([kernel.kallsyms]) swapper 0 [000] 254.427127: 111111111 cpu-clock: ffffffff810a0de6 native_safe_halt+0x6 ([kernel.kallsyms]) swapper 0 [000] 254.427239: 111111111 cpu-clock: ffffffff810a0de6 native_safe_halt+0x6 ([kernel.kallsyms]) swapper 0 [000] 254.427346: 111111111 cpu-clock: ffffffff810a0de6 native_safe_halt+0x6 ([kernel.kallsyms]) swapper 0 [000] 254.427463: 111111111 cpu-clock: ffffffff810a0de6 native_safe_halt+0x6 ([kernel.kallsyms]) swapper 0 [000] 255.426572: 111111111 cpu-clock: ffffffff810a0de6 native_safe_halt+0x6 ([kernel.kallsyms]) Instead of more reasonable expected timestamps like: swapper 0 [000] 39.953768: 111111111 cpu-clock: ffffffff810a0de6 native_safe_halt+0x6 ([kernel.kallsyms]) swapper 0 [000] 40.064839: 111111111 cpu-clock: ffffffff810a0de6 native_safe_halt+0x6 ([kernel.kallsyms]) swapper 0 [000] 40.175956: 111111111 cpu-clock: ffffffff810a0de6 native_safe_halt+0x6 ([kernel.kallsyms]) swapper 0 [000] 40.287103: 111111111 cpu-clock: ffffffff810a0de6 native_safe_halt+0x6 ([kernel.kallsyms]) swapper 0 [000] 40.398217: 111111111 cpu-clock: ffffffff810a0de6 native_safe_halt+0x6 ([kernel.kallsyms]) swapper 0 [000] 40.509324: 111111111 cpu-clock: ffffffff810a0de6 native_safe_halt+0x6 ([kernel.kallsyms]) swapper 0 [000] 40.620437: 111111111 cpu-clock: ffffffff810a0de6 native_safe_halt+0x6 ([kernel.kallsyms]) swapper 0 [000] 40.731546: 111111111 cpu-clock: ffffffff810a0de6 native_safe_halt+0x6 ([kernel.kallsyms]) swapper 0 [000] 40.842654: 111111111 cpu-clock: ffffffff810a0de6 native_safe_halt+0x6 ([kernel.kallsyms]) swapper 0 [000] 40.953772: 111111111 cpu-clock: ffffffff810a0de6 native_safe_halt+0x6 ([kernel.kallsyms]) swapper 0 [000] 41.064881: 111111111 cpu-clock: ffffffff810a0de6 native_safe_halt+0x6 ([kernel.kallsyms]) Add the proper use of timekeeping_delta_to_ns() to convert the cycle delta to nanoseconds as needed. Thanks to Brendan and Alexei for finding this quickly after the v4.8 release. Unfortunately the problematic commit has landed in some -stable trees so they'll need this fix as well. Many apologies for this mistake. I'll be looking to add a perf-clock sanity test to the kselftest timers tests soon. Fixes: 27727df240c7 "timekeeping: Avoid taking lock in NMI path with CONFIG_DEBUG_TIMEKEEPING" Reported-by: Brendan Gregg <bgregg@netflix.com> Reported-by: Alexei Starovoitov <alexei.starovoitov@gmail.com> Tested-and-reviewed-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Signed-off-by: John Stultz <john.stultz@linaro.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: stable <stable@vger.kernel.org> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1475636148-26539-1-git-send-email-john.stultz@linaro.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-10-23time: Add cycles to nanoseconds translationChristopher S. Hall
[ Upstream commit 6bd58f09e1d8cc6c50a824c00bf0d617919986a1 ] The timekeeping code does not currently provide a way to translate externally provided clocksource cycles to system time. The cycle count is always provided by the result clocksource read() method internal to the timekeeping code. The added function timekeeping_cycles_to_ns() calculated a nanosecond value from a cycle count that can be added to tk_read_base.base value yielding the current system time. This allows clocksource cycle values external to the timekeeping code to provide a cycle count that can be transformed to system time. Cc: Prarit Bhargava <prarit@redhat.com> Cc: Richard Cochran <richardcochran@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@kernel.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: kevin.b.stanton@intel.com Cc: kevin.j.clarke@intel.com Cc: hpa@zytor.com Cc: jeffrey.t.kirsher@intel.com Cc: netdev@vger.kernel.org Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Christopher S. Hall <christopher.s.hall@intel.com> Signed-off-by: John Stultz <john.stultz@linaro.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-10-05Merge tag 'v4.1.33' into 4.1-2.0.x-imxOtavio Salvador
Linux 4.1.33 * tag 'v4.1.33': (1760 commits) Linux 4.1.33 Revert "ARC: mm: don't loose PTE_SPECIAL in pte_modify()" x86/AMD: Apply erratum 665 on machines without a BIOS fix x86/paravirt: Do not trace _paravirt_ident_*() functions ovl: listxattr: use strnlen() ovl: remove posix_acl_default from workdir serial: 8250: added acces i/o products quad and octal serial cards sysfs: correctly handle read offset on PREALLOC attrs sysfs: correctly handle short reads on PREALLOC attrs. kernfs: don't depend on d_find_any_alias() when generating notifications dm crypt: fix free of bad values after tfm allocation failure dm crypt: fix error with too large bios dm log writes: fix check of kthread_run() return value dm log writes: fix bug with too large bios dm log writes: move IO accounting earlier to fix error path NFSv4.x: Fix a refcount leak in nfs_callback_up_net xfs: prevent dropping ioend completions during buftarg wait xfs: fix superblock inprogress check USB: serial: option: add WeTelecom 0x6802 and 0x6803 products USB: avoid left shift by -1 ... Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2016-10-03fix memory leaks in tracing_buffers_splice_read()Al Viro
[ Upstream commit 1ae2293dd6d2f5c823cf97e60b70d03631cd622f ] Cc: stable@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-10-03tracing: Move mutex to protect against resetting of seq dataSteven Rostedt (Red Hat)
[ Upstream commit 1245800c0f96eb6ebb368593e251d66c01e61022 ] The iter->seq can be reset outside the protection of the mutex. So can reading of user data. Move the mutex up to the beginning of the function. Fixes: d7350c3f45694 ("tracing/core: make the read callbacks reentrants") Cc: stable@vger.kernel.org # 2.6.30+ Reported-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-10-02sched/core: Fix a race between try_to_wake_up() and a woken up taskBalbir Singh
[ Upstream commit 135e8c9250dd5c8c9aae5984fde6f230d0cbfeaf ] The origin of the issue I've seen is related to a missing memory barrier between check for task->state and the check for task->on_rq. The task being woken up is already awake from a schedule() and is doing the following: do { schedule() set_current_state(TASK_(UN)INTERRUPTIBLE); } while (!cond); The waker, actually gets stuck doing the following in try_to_wake_up(): while (p->on_cpu) cpu_relax(); Analysis: The instance I've seen involves the following race: CPU1 CPU2 while () { if (cond) break; do { schedule(); set_current_state(TASK_UN..) } while (!cond); wakeup_routine() spin_lock_irqsave(wait_lock) raw_spin_lock_irqsave(wait_lock) wake_up_process() } try_to_wake_up() set_current_state(TASK_RUNNING); .. list_del(&waiter.list); CPU2 wakes up CPU1, but before it can get the wait_lock and set current state to TASK_RUNNING the following occurs: CPU3 wakeup_routine() raw_spin_lock_irqsave(wait_lock) if (!list_empty) wake_up_process() try_to_wake_up() raw_spin_lock_irqsave(p->pi_lock) .. if (p->on_rq && ttwu_wakeup()) .. while (p->on_cpu) cpu_relax() .. CPU3 tries to wake up the task on CPU1 again since it finds it on the wait_queue, CPU1 is spinning on wait_lock, but immediately after CPU2, CPU3 got it. CPU3 checks the state of p on CPU1, it is TASK_UNINTERRUPTIBLE and the task is spinning on the wait_lock. Interestingly since p->on_rq is checked under pi_lock, I've noticed that try_to_wake_up() finds p->on_rq to be 0. This was the most confusing bit of the analysis, but p->on_rq is changed under runqueue lock, rq_lock, the p->on_rq check is not reliable without this fix IMHO. The race is visible (based on the analysis) only when ttwu_queue() does a remote wakeup via ttwu_queue_remote. In which case the p->on_rq change is not done uder the pi_lock. The result is that after a while the entire system locks up on the raw_spin_irqlock_save(wait_lock) and the holder spins infintely Reproduction of the issue: The issue can be reproduced after a long run on my system with 80 threads and having to tweak available memory to very low and running memory stress-ng mmapfork test. It usually takes a long time to reproduce. I am trying to work on a test case that can reproduce the issue faster, but thats work in progress. I am still testing the changes on my still in a loop and the tests seem OK thus far. Big thanks to Benjamin and Nick for helping debug this as well. Ben helped catch the missing barrier, Nick caught every missing bit in my theory. Signed-off-by: Balbir Singh <bsingharora@gmail.com> [ Updated comment to clarify matching barriers. Many architectures do not have a full barrier in switch_to() so that cannot be relied upon. ] Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Alexey Kardashevskiy <aik@ozlabs.ru> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Nicholas Piggin <nicholas.piggin@gmail.com> Cc: Nicholas Piggin <npiggin@gmail.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: <stable@vger.kernel.org> Link: http://lkml.kernel.org/r/e02cce7b-d9ca-1ad0-7a61-ea97c7582b37@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-09-12cpuset: make sure new tasks conform to the current config of the cpusetZefan Li
[ Upstream commit 06f4e94898918bcad00cdd4d349313a439d6911e ] A new task inherits cpus_allowed and mems_allowed masks from its parent, but if someone changes cpuset's config by writing to cpuset.cpus/cpuset.mems before this new task is inserted into the cgroup's task list, the new task won't be updated accordingly. Signed-off-by: Zefan Li <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: stable@vger.kernel.org Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-08-31timekeeping: Cap array access in timekeeping_debugJohn Stultz
[ Upstream commit a4f8f6667f099036c88f231dcad4cf233652c824 ] It was reported that hibernation could fail on the 2nd attempt, where the system hangs at hibernate() -> syscore_resume() -> i8237A_resume() -> claim_dma_lock(), because the lock has already been taken. However there is actually no other process would like to grab this lock on that problematic platform. Further investigation showed that the problem is triggered by setting /sys/power/pm_trace to 1 before the 1st hibernation. Since once pm_trace is enabled, the rtc becomes unmeaningful after suspend, and meanwhile some BIOSes would like to adjust the 'invalid' RTC (e.g, smaller than 1970) to the release date of that motherboard during POST stage, thus after resumed, it may seem that the system had a significant long sleep time which is a completely meaningless value. Then in timekeeping_resume -> tk_debug_account_sleep_time, if the bit31 of the sleep time happened to be set to 1, fls() returns 32 and we add 1 to sleep_time_bin[32], which causes an out of bounds array access and therefor memory being overwritten. As depicted by System.map: 0xffffffff81c9d080 b sleep_time_bin 0xffffffff81c9d100 B dma_spin_lock the dma_spin_lock.val is set to 1, which caused this problem. This patch adds a sanity check in tk_debug_account_sleep_time() to ensure we don't index past the sleep_time_bin array. [jstultz: Problem diagnosed and original patch by Chen Yu, I've solved the issue slightly differently, but borrowed his excelent explanation of the issue here.] Fixes: 5c83545f24ab "power: Add option to log time spent in suspend" Reported-by: Janek Kozicki <cosurgi@gmail.com> Reported-by: Chen Yu <yu.c.chen@intel.com> Signed-off-by: John Stultz <john.stultz@linaro.org> Cc: linux-pm@vger.kernel.org Cc: Peter Zijlstra <peterz@infradead.org> Cc: Xunlei Pang <xpang@redhat.com> Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net> Cc: stable <stable@vger.kernel.org> Cc: Zhang Rui <rui.zhang@intel.com> Link: http://lkml.kernel.org/r/1471993702-29148-3-git-send-email-john.stultz@linaro.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-08-31timekeeping: Avoid taking lock in NMI path with CONFIG_DEBUG_TIMEKEEPINGJohn Stultz
[ Upstream commit 27727df240c7cc84f2ba6047c6f18d5addfd25ef ] When I added some extra sanity checking in timekeeping_get_ns() under CONFIG_DEBUG_TIMEKEEPING, I missed that the NMI safe __ktime_get_fast_ns() method was using timekeeping_get_ns(). Thus the locking added to the debug checks broke the NMI-safety of __ktime_get_fast_ns(). This patch open-codes the timekeeping_get_ns() logic for __ktime_get_fast_ns(), so can avoid any deadlocks in NMI. Fixes: 4ca22c2648f9 "timekeeping: Add warnings when overflows or underflows are observed" Reported-by: Steven Rostedt <rostedt@goodmis.org> Reported-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: John Stultz <john.stultz@linaro.org> Cc: stable <stable@vger.kernel.org> Link: http://lkml.kernel.org/r/1471993702-29148-2-git-send-email-john.stultz@linaro.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-08-31uprobes: Fix the memcg accountingOleg Nesterov
[ Upstream commit 6c4687cc17a788a6dd8de3e27dbeabb7cbd3e066 ] __replace_page() wronlgy calls mem_cgroup_cancel_charge() in "success" path, it should only do this if page_check_address() fails. This means that every enable/disable leads to unbalanced mem_cgroup_uncharge() from put_page(old_page), it is trivial to underflow the page_counter->count and trigger OOM. Reported-and-tested-by: Brenden Blanco <bblanco@plumgrid.com> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Reviewed-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@kernel.org> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Alexei Starovoitov <alexei.starovoitov@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Vladimir Davydov <vdavydov@virtuozzo.com> Cc: stable@vger.kernel.org # 3.17+ Fixes: 00501b531c47 ("mm: memcontrol: rewrite charge API") Link: http://lkml.kernel.org/r/20160817153629.GB29724@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-08-19module: Invalidate signatures on force-loaded modulesBen Hutchings
[ Upstream commit bca014caaa6130e57f69b5bf527967aa8ee70fdd ] Signing a module should only make it trusted by the specific kernel it was built for, not anything else. Loading a signed module meant for a kernel with a different ABI could have interesting effects. Therefore, treat all signatures as invalid when a module is force-loaded. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Cc: stable@vger.kernel.org Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-08-19audit: fix a double fetch in audit_log_single_execve_arg()Paul Moore
[ Upstream commit 43761473c254b45883a64441dd0bc85a42f3645c ] There is a double fetch problem in audit_log_single_execve_arg() where we first check the execve(2) argumnets for any "bad" characters which would require hex encoding and then re-fetch the arguments for logging in the audit record[1]. Of course this leaves a window of opportunity for an unsavory application to munge with the data. This patch reworks things by only fetching the argument data once[2] into a buffer where it is scanned and logged into the audit records(s). In addition to fixing the double fetch, this patch improves on the original code in a few other ways: better handling of large arguments which require encoding, stricter record length checking, and some performance improvements (completely unverified, but we got rid of some strlen() calls, that's got to be a good thing). As part of the development of this patch, I've also created a basic regression test for the audit-testsuite, the test can be tracked on GitHub at the following link: * https://github.com/linux-audit/audit-testsuite/issues/25 [1] If you pay careful attention, there is actually a triple fetch problem due to a strnlen_user() call at the top of the function. [2] This is a tiny white lie, we do make a call to strnlen_user() prior to fetching the argument data. I don't like it, but due to the way the audit record is structured we really have no choice unless we copy the entire argument at once (which would require a rather wasteful allocation). The good news is that with this patch the kernel no longer relies on this strnlen_user() value for anything beyond recording it in the log, we also update it with a trustworthy value whenever possible. Reported-by: Pengfei Wang <wpengfeinudt@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Paul Moore <paul@paul-moore.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-08-19Fix broken audit tests for exec arg lenLinus Torvalds
[ Upstream commit 45820c294fe1b1a9df495d57f40585ef2d069a39 ] The "fix" in commit 0b08c5e5944 ("audit: Fix check of return value of strnlen_user()") didn't fix anything, it broke things. As reported by Steven Rostedt: "Yes, strnlen_user() returns 0 on fault, but if you look at what len is set to, than you would notice that on fault len would be -1" because we just subtracted one from the return value. So testing against 0 doesn't test for a fault condition, it tests against a perfectly valid empty string. Also fix up the usual braindamage wrt using WARN_ON() inside a conditional - make it part of the conditional and remove the explicit unlikely() (which is already part of the WARN_ON*() logic, exactly so that you don't have to write unreadable code. Reported-and-tested-by: Steven Rostedt <rostedt@goodmis.org> Cc: Jan Kara <jack@suse.cz> Cc: Paul Moore <pmoore@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-08-19audit: Fix check of return value of strnlen_user()Jan Kara
[ Upstream commit 0b08c5e59441d08ab4b5e72afefd5cd98a4d83df ] strnlen_user() returns 0 when it hits fault, not -1. Fix the test in audit_log_single_execve_arg(). Luckily this shouldn't ever happen unless there's a kernel bug so it's mostly a cosmetic fix. CC: Paul Moore <pmoore@redhat.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-08-06posix_cpu_timer: Exit early when process has been reapedAlexey Dobriyan
[ Upstream commit 2c13ce8f6b2f6fd9ba2f9261b1939fc0f62d1307 ] Variable "now" seems to be genuinely used unintialized if branch if (CPUCLOCK_PERTHREAD(timer->it_clock)) { is not taken and branch if (unlikely(sighand == NULL)) { is taken. In this case the process has been reaped and the timer is marked as disarmed anyway. So none of the postprocessing of the sample is required. Return right away. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: stable@vger.kernel.org Link: http://lkml.kernel.org/r/20160707223911.GA26483@p183.telecom.by Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-07-10pipe: limit the per-user amount of pages allocated in pipesWilly Tarreau
[ Upstream commit 759c01142a5d0f364a462346168a56de28a80f52 ] On no-so-small systems, it is possible for a single process to cause an OOM condition by filling large pipes with data that are never read. A typical process filling 4000 pipes with 1 MB of data will use 4 GB of memory. On small systems it may be tricky to set the pipe max size to prevent this from happening. This patch makes it possible to enforce a per-user soft limit above which new pipes will be limited to a single page, effectively limiting them to 4 kB each, as well as a hard limit above which no new pipes may be created for this user. This has the effect of protecting the system against memory abuse without hurting other users, and still allowing pipes to work correctly though with less data at once. The limit are controlled by two new sysctls : pipe-user-pages-soft, and pipe-user-pages-hard. Both may be disabled by setting them to zero. The default soft limit allows the default number of FDs per process (1024) to create pipes of the default size (64kB), thus reaching a limit of 64MB before starting to create only smaller pipes. With 256 processes limited to 1024 FDs each, this results in 1024*64kB + (256*1024 - 1024) * 4kB = 1084 MB of memory allocated for a user. The hard limit is disabled by default to avoid breaking existing applications that make intensive use of pipes (eg: for splicing). Reported-by: socketpair@gmail.com Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Mitigates: CVE-2013-4312 (Linux 2.0+) Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Willy Tarreau <w@1wt.eu> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-07-10bpf: fix double-fdput in replace_map_fd_with_map_ptr()Jann Horn
[ Upstream commit 8358b02bf67d3a5d8a825070e1aa73f25fb2e4c7 ] When bpf(BPF_PROG_LOAD, ...) was invoked with a BPF program whose bytecode references a non-map file descriptor as a map file descriptor, the error handling code called fdput() twice instead of once (in __bpf_map_get() and in replace_map_fd_with_map_ptr()). If the file descriptor table of the current task is shared, this causes f_count to be decremented too much, allowing the struct file to be freed while it is still in use (use-after-free). This can be exploited to gain root privileges by an unprivileged user. This bug was introduced in commit 0246e64d9a5f ("bpf: handle pseudo BPF_LD_IMM64 insn"), but is only exploitable since commit 1be7f75d1668 ("bpf: enable non-root eBPF programs") because previously, CAP_SYS_ADMIN was required to reach the vulnerable code. (posted publicly according to request by maintainer) Signed-off-by: Jann Horn <jannh@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: Alexei Starovoitov <ast@kernel.org> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-07-10bpf/verifier: reject invalid LD_ABS | BPF_DW instructionAlexei Starovoitov
[ Upstream commit d82bccc69041a51f7b7b9b4a36db0772f4cdba21 ] verifier must check for reserved size bits in instruction opcode and reject BPF_LD | BPF_ABS | BPF_DW and BPF_LD | BPF_IND | BPF_DW instructions, otherwise interpreter will WARN_RATELIMIT on them during execution. Fixes: ddd872bc3098 ("bpf: verifier: add checks for BPF_ABS | BPF_IND instructions") Signed-off-by: Alexei Starovoitov <ast@kernel.org> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-07-10cgroup: make sure a parent css isn't freed before its childrenTejun Heo
[ Upstream commit 8bb5ef79bc0f4016ecf79e8dce6096a3c63603e4 ] There are three subsystem callbacks in css shutdown path - css_offline(), css_released() and css_free(). Except for css_released(), cgroup core didn't guarantee the order of invocation. css_offline() or css_free() could be called on a parent css before its children. This behavior is unexpected and led to bugs in cpu and memory controller. The previous patch updated ordering for css_offline() which fixes the cpu controller issue. While there currently isn't a known bug caused by misordering of css_free() invocations, let's fix it too for consistency. css_free() ordering can be trivially fixed by moving putting of the parent css below css_free() invocation. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-07-10futex: Acknowledge a new waiter in counter before plistDavidlohr Bueso
[ Upstream commit fe1bce9e2107ba3a8faffe572483b6974201a0e6 ] Otherwise an incoming waker on the dest hash bucket can miss the waiter adding itself to the plist during the lockless check optimization (small window but still the correct way of doing this); similarly to the decrement counterpart. Suggested-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Davidlohr Bueso <dbueso@suse.de> Cc: Davidlohr Bueso <dave@stgolabs.net> Cc: bigeasy@linutronix.de Cc: dvhart@infradead.org Cc: stable@kernel.org Link: http://lkml.kernel.org/r/1461208164-29150-1-git-send-email-dave@stgolabs.net Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-07-10tracing: Handle NULL formats in hold_module_trace_bprintk_format()Steven Rostedt (Red Hat)
[ Upstream commit 70c8217acd4383e069fe1898bbad36ea4fcdbdcc ] If a task uses a non constant string for the format parameter in trace_printk(), then the trace_printk_fmt variable is set to NULL. This variable is then saved in the __trace_printk_fmt section. The function hold_module_trace_bprintk_format() checks to see if duplicate formats are used by modules, and reuses them if so (saves them to the list if it is new). But this function calls lookup_format() that does a strcmp() to the value (which is now NULL) and can cause a kernel oops. This wasn't an issue till 3debb0a9ddb ("tracing: Fix trace_printk() to print when not using bprintk()") which added "__used" to the trace_printk_fmt variable, and before that, the kernel simply optimized it out (no NULL value was saved). The fix is simply to handle the NULL pointer in lookup_format() and have the caller ignore the value if it was NULL. Link: http://lkml.kernel.org/r/1464769870-18344-1-git-send-email-zhengjun.xing@intel.com Reported-by: xingzhen <zhengjun.xing@intel.com> Acked-by: Namhyung Kim <namhyung@kernel.org> Fixes: 3debb0a9ddb ("tracing: Fix trace_printk() to print when not using bprintk()") Cc: stable@vger.kernel.org # v3.5+ Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-07-10cgroup: set css->id to -1 during initTejun Heo
[ Upstream commit 8fa3b8d689a54d6d04ff7803c724fb7aca6ce98e ] If percpu_ref initialization fails during css_create(), the free path can end up trying to free css->id of zero. As ID 0 is unused, it doesn't cause a critical breakage but it does trigger a warning message. Fix it by setting css->id to -1 from init_and_link_css(). Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Wenwei Tao <ww.tao0320@gmail.com> Fixes: 01e586598b22 ("cgroup: release css->id after css_free") Cc: stable@vger.kernel.org # v4.0+ Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-07-10kernel/sysrq, watchdog, sched/core: Reset watchdog on all CPUs while ↵Andrey Ryabinin
processing sysrq-w [ Upstream commit 57675cb976eff977aefb428e68e4e0236d48a9ff ] Lengthy output of sysrq-w may take a lot of time on slow serial console. Currently we reset NMI-watchdog on the current CPU to avoid spurious lockup messages. Sometimes this doesn't work since softlockup watchdog might trigger on another CPU which is waiting for an IPI to proceed. We reset softlockup watchdogs on all CPUs, but we do this only after listing all tasks, and this may be too late on a busy system. So, reset watchdogs CPUs earlier, in for_each_process_thread() loop. Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: <stable@vger.kernel.org> Link: http://lkml.kernel.org/r/1465474805-14641-1-git-send-email-aryabinin@virtuozzo.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-07-10cgroup: remove redundant cleanup in css_createWenwei Tao
[ Upstream commit b00c52dae6d9ee8d0f2407118ef6544ae5524781 ] When create css failed, before call css_free_rcu_fn, we remove the css id and exit the percpu_ref, but we will do these again in css_free_work_fn, so they are redundant. Especially the css id, that would cause problem if we remove it twice, since it may be assigned to another css after the first remove. tj: This was broken by two commits updating the free path without synchronizing the creation failure path. This can be easily triggered by trying to create more than 64k memory cgroups. Signed-off-by: Wenwei Tao <ww.tao0320@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Vladimir Davydov <vdavydov@parallels.com> Fixes: 9a1049da9bd2 ("percpu-refcount: require percpu_ref to be exited explicitly") Fixes: 01e586598b22 ("cgroup: release css->id after css_free") Cc: stable@vger.kernel.org # v3.17+ Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-06-17locking/ww_mutex: Report recursive ww_mutex locking earlyChris Wilson
[ Upstream commit 0422e83d84ae24b933e4b0d4c1e0f0b4ae8a0a3b ] Recursive locking for ww_mutexes was originally conceived as an exception. However, it is heavily used by the DRM atomic modesetting code. Currently, the recursive deadlock is checked after we have queued up for a busy-spin and as we never release the lock, we spin until kicked, whereupon the deadlock is discovered and reported. A simple solution for the now common problem is to move the recursive deadlock discovery to the first action when taking the ww_mutex. Suggested-by: Maarten Lankhorst <maarten.lankhorst@linux.intel.com> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Reviewed-by: Maarten Lankhorst <maarten.lankhorst@linux.intel.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: stable@vger.kernel.org Link: http://lkml.kernel.org/r/1464293297-19777-1-git-send-email-chris@chris-wilson.co.uk Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-06-06wait/ptrace: assume __WALL if the child is tracedOleg Nesterov
[ Upstream commit bf959931ddb88c4e4366e96dd22e68fa0db9527c ] The following program (simplified version of generated by syzkaller) #include <pthread.h> #include <unistd.h> #include <sys/ptrace.h> #include <stdio.h> #include <signal.h> void *thread_func(void *arg) { ptrace(PTRACE_TRACEME, 0,0,0); return 0; } int main(void) { pthread_t thread; if (fork()) return 0; while (getppid() != 1) ; pthread_create(&thread, NULL, thread_func, NULL); pthread_join(thread, NULL); return 0; } creates an unreapable zombie if /sbin/init doesn't use __WALL. This is not a kernel bug, at least in a sense that everything works as expected: debugger should reap a traced sub-thread before it can reap the leader, but without __WALL/__WCLONE do_wait() ignores sub-threads. Unfortunately, it seems that /sbin/init in most (all?) distributions doesn't use it and we have to change the kernel to avoid the problem. Note also that most init's use sys_waitid() which doesn't allow __WALL, so the necessary user-space fix is not that trivial. This patch just adds the "ptrace" check into eligible_child(). To some degree this matches the "tsk->ptrace" in exit_notify(), ->exit_signal is mostly ignored when the tracee reports to debugger. Or WSTOPPED, the tracer doesn't need to set this flag to wait for the stopped tracee. This obviously means the user-visible change: __WCLONE and __WALL no longer have any meaning for debugger. And I can only hope that this won't break something, but at least strace/gdb won't suffer. We could make a more conservative change. Say, we can take __WCLONE into account, or !thread_group_leader(). But it would be nice to not complicate these historical/confusing checks. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Reported-by: Dmitry Vyukov <dvyukov@google.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Jan Kratochvil <jan.kratochvil@redhat.com> Cc: "Michael Kerrisk (man-pages)" <mtk.manpages@gmail.com> Cc: Pedro Alves <palves@redhat.com> Cc: Roland McGrath <roland@hack.frob.com> Cc: <syzkaller@googlegroups.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-06-06ring-buffer: Prevent overflow of size in ring_buffer_resize()Steven Rostedt (Red Hat)
[ Upstream commit 59643d1535eb220668692a5359de22545af579f6 ] If the size passed to ring_buffer_resize() is greater than MAX_LONG - BUF_PAGE_SIZE then the DIV_ROUND_UP() will return zero. Here's the details: # echo 18014398509481980 > /sys/kernel/debug/tracing/buffer_size_kb tracing_entries_write() processes this and converts kb to bytes. 18014398509481980 << 10 = 18446744073709547520 and this is passed to ring_buffer_resize() as unsigned long size. size = DIV_ROUND_UP(size, BUF_PAGE_SIZE); Where DIV_ROUND_UP(a, b) is (a + b - 1)/b BUF_PAGE_SIZE is 4080 and here 18446744073709547520 + 4080 - 1 = 18446744073709551599 where 18446744073709551599 is still smaller than 2^64 2^64 - 18446744073709551599 = 17 But now 18446744073709551599 / 4080 = 4521260802379792 and size = size * 4080 = 18446744073709551360 This is checked to make sure its still greater than 2 * 4080, which it is. Then we convert to the number of buffer pages needed. nr_page = DIV_ROUND_UP(size, BUF_PAGE_SIZE) but this time size is 18446744073709551360 and 2^64 - (18446744073709551360 + 4080 - 1) = -3823 Thus it overflows and the resulting number is less than 4080, which makes 3823 / 4080 = 0 an nr_pages is set to this. As we already checked against the minimum that nr_pages may be, this causes the logic to fail as well, and we crash the kernel. There's no reason to have the two DIV_ROUND_UP() (that's just result of historical code changes), clean up the code and fix this bug. Cc: stable@vger.kernel.org # 3.5+ Fixes: 83f40318dab00 ("ring-buffer: Make removal of ring buffer pages atomic") Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-06-06ring-buffer: Use long for nr_pages to avoid overflow failuresSteven Rostedt (Red Hat)
[ Upstream commit 9b94a8fba501f38368aef6ac1b30e7335252a220 ] The size variable to change the ring buffer in ftrace is a long. The nr_pages used to update the ring buffer based on the size is int. On 64 bit machines this can cause an overflow problem. For example, the following will cause the ring buffer to crash: # cd /sys/kernel/debug/tracing # echo 10 > buffer_size_kb # echo 8556384240 > buffer_size_kb Then you get the warning of: WARNING: CPU: 1 PID: 318 at kernel/trace/ring_buffer.c:1527 rb_update_pages+0x22f/0x260 Which is: RB_WARN_ON(cpu_buffer, nr_removed); Note each ring buffer page holds 4080 bytes. This is because: 1) 10 causes the ring buffer to have 3 pages. (10kb requires 3 * 4080 pages to hold) 2) (2^31 / 2^10 + 1) * 4080 = 8556384240 The value written into buffer_size_kb is shifted by 10 and then passed to ring_buffer_resize(). 8556384240 * 2^10 = 8761737461760 3) The size passed to ring_buffer_resize() is then divided by BUF_PAGE_SIZE which is 4080. 8761737461760 / 4080 = 2147484672 4) nr_pages is subtracted from the current nr_pages (3) and we get: 2147484669. This value is saved in a signed integer nr_pages_to_update 5) 2147484669 is greater than 2^31 but smaller than 2^32, a signed int turns into the value of -2147482627 6) As the value is a negative number, in update_pages_handler() it is negated and passed to rb_remove_pages() and 2147482627 pages will be removed, which is much larger than 3 and it causes the warning because not all the pages asked to be removed were removed. Link: https://bugzilla.kernel.org/show_bug.cgi?id=118001 Cc: stable@vger.kernel.org # 2.6.28+ Fixes: 7a8e76a3829f1 ("tracing: unified trace buffer") Reported-by: Hao Qin <QEver.cn@gmail.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-06-06ring-buffer: Move recursive check to per_cpu descriptorSteven Rostedt (Red Hat)
[ Upstream commit 58a09ec6e3ec88c9c7e061479f1ef7fe93324a87 ] Instead of using a global per_cpu variable to perform the recursive checks into the ring buffer, use the already existing per_cpu descriptor that is part of the ring buffer itself. Not only does this simplify the code, it also allows for one ring buffer to be used within the guts of the use of another ring buffer. For example trace_printk() can now be used within the ring buffer to record changes done by an instance into the main ring buffer. The recursion checks will prevent the trace_printk() itself from causing recursive issues with the main ring buffer (it is just ignored), but the recursive checks wont prevent the trace_printk() from recording other ring buffers. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-06-06ring-buffer: Add unlikelys to make fast path the defaultSteven Rostedt (Red Hat)
[ Upstream commit 3205f8063b6cc54b20d5080fb79dfcbd9c39e93d ] I was running the trace_event benchmark and noticed that the times to record a trace_event was all over the place. I looked at the assembly of the ring_buffer_lock_reserver() and saw this: <ring_buffer_lock_reserve>: 31 c0 xor %eax,%eax 48 83 3d 76 47 bd 00 cmpq $0x1,0xbd4776(%rip) # ffffffff81d10d60 <ring_buffer_flags> 01 55 push %rbp 48 89 e5 mov %rsp,%rbp 75 1d jne ffffffff8113c60d <ring_buffer_lock_reserve+0x2d> 65 ff 05 69 e3 ec 7e incl %gs:0x7eece369(%rip) # a960 <__preempt_count> 8b 47 08 mov 0x8(%rdi),%eax 85 c0 test %eax,%eax +---- 74 12 je ffffffff8113c610 <ring_buffer_lock_reserve+0x30> | 65 ff 0d 5b e3 ec 7e decl %gs:0x7eece35b(%rip) # a960 <__preempt_count> | 0f 84 85 00 00 00 je ffffffff8113c690 <ring_buffer_lock_reserve+0xb0> | 31 c0 xor %eax,%eax | 5d pop %rbp | c3 retq | 90 nop +---> 65 44 8b 05 48 e3 ec mov %gs:0x7eece348(%rip),%r8d # a960 <__preempt_count> 7e 41 81 e0 ff ff ff 7f and $0x7fffffff,%r8d b0 08 mov $0x8,%al 65 8b 0d 58 36 ed 7e mov %gs:0x7eed3658(%rip),%ecx # fc80 <current_context> 41 f7 c0 00 ff 1f 00 test $0x1fff00,%r8d 74 1e je ffffffff8113c64f <ring_buffer_lock_reserve+0x6f> 41 f7 c0 00 00 10 00 test $0x100000,%r8d b0 01 mov $0x1,%al 75 13 jne ffffffff8113c64f <ring_buffer_lock_reserve+0x6f> 41 81 e0 00 00 0f 00 and $0xf0000,%r8d 49 83 f8 01 cmp $0x1,%r8 19 c0 sbb %eax,%eax 83 e0 02 and $0x2,%eax 83 c0 02 add $0x2,%eax 85 c8 test %ecx,%eax 75 ab jne ffffffff8113c5fe <ring_buffer_lock_reserve+0x1e> 09 c8 or %ecx,%eax 65 89 05 24 36 ed 7e mov %eax,%gs:0x7eed3624(%rip) # fc80 <current_context> The arrow is the fast path. After adding the unlikely's, the fast path looks a bit better: <ring_buffer_lock_reserve>: 31 c0 xor %eax,%eax 48 83 3d 76 47 bd 00 cmpq $0x1,0xbd4776(%rip) # ffffffff81d10d60 <ring_buffer_flags> 01 55 push %rbp 48 89 e5 mov %rsp,%rbp 75 7b jne ffffffff8113c66b <ring_buffer_lock_reserve+0x8b> 65 ff 05 69 e3 ec 7e incl %gs:0x7eece369(%rip) # a960 <__preempt_count> 8b 47 08 mov 0x8(%rdi),%eax 85 c0 test %eax,%eax 0f 85 9f 00 00 00 jne ffffffff8113c6a1 <ring_buffer_lock_reserve+0xc1> 65 8b 0d 57 e3 ec 7e mov %gs:0x7eece357(%rip),%ecx # a960 <__preempt_count> 81 e1 ff ff ff 7f and $0x7fffffff,%ecx b0 08 mov $0x8,%al 65 8b 15 68 36 ed 7e mov %gs:0x7eed3668(%rip),%edx # fc80 <current_context> f7 c1 00 ff 1f 00 test $0x1fff00,%ecx 75 50 jne ffffffff8113c670 <ring_buffer_lock_reserve+0x90> 85 d0 test %edx,%eax 75 7d jne ffffffff8113c6a1 <ring_buffer_lock_reserve+0xc1> 09 d0 or %edx,%eax 65 89 05 53 36 ed 7e mov %eax,%gs:0x7eed3653(%rip) # fc80 <current_context> 65 8b 05 fc da ec 7e mov %gs:0x7eecdafc(%rip),%eax # a130 <cpu_number> 89 c2 mov %eax,%edx Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-06-06sched/loadavg: Fix loadavg artifacts on fully idle and on fully loaded systemsSasha Levin
[ Upstream commit 20878232c52329f92423d27a60e48b6a6389e0dd ] Systems show a minimal load average of 0.00, 0.01, 0.05 even when they have no load at all. Uptime and /proc/loadavg on all systems with kernels released during the last five years up until kernel version 4.6-rc5, show a 5- and 15-minute minimum loadavg of 0.01 and 0.05 respectively. This should be 0.00 on idle systems, but the way the kernel calculates this value prevents it from getting lower than the mentioned values. Likewise but not as obviously noticeable, a fully loaded system with no processes waiting, shows a maximum 1/5/15 loadavg of 1.00, 0.99, 0.95 (multiplied by number of cores). Once the (old) load becomes 93 or higher, it mathematically can never get lower than 93, even when the active (load) remains 0 forever. This results in the strange 0.00, 0.01, 0.05 uptime values on idle systems. Note: 93/2048 = 0.0454..., which rounds up to 0.05. It is not correct to add a 0.5 rounding (=1024/2048) here, since the result from this function is fed back into the next iteration again, so the result of that +0.5 rounding value then gets multiplied by (2048-2037), and then rounded again, so there is a virtual "ghost" load created, next to the old and active load terms. By changing the way the internally kept value is rounded, that internal value equivalent now can reach 0.00 on idle, and 1.00 on full load. Upon increasing load, the internally kept load value is rounded up, when the load is decreasing, the load value is rounded down. The modified code was tested on nohz=off and nohz kernels. It was tested on vanilla kernel 4.6-rc5 and on centos 7.1 kernel 3.10.0-327. It was tested on single, dual, and octal cores system. It was tested on virtual hosts and bare hardware. No unwanted effects have been observed, and the problems that the patch intended to fix were indeed gone. Tested-by: Damien Wyart <damien.wyart@free.fr> Signed-off-by: Vik Heyndrickx <vik.heyndrickx@veribox.net> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: <stable@vger.kernel.org> Cc: Doug Smythies <dsmythies@telus.net> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Fixes: 0f004f5a696a ("sched: Cure more NO_HZ load average woes") Link: http://lkml.kernel.org/r/e8d32bff-d544-7748-72b5-3c86cc71f09f@veribox.net Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-05-17workqueue: fix rebind bound workers warningWanpeng Li
[ Upstream commit f7c17d26f43d5cc1b7a6b896cd2fa24a079739b9 ] ------------[ cut here ]------------ WARNING: CPU: 0 PID: 16 at kernel/workqueue.c:4559 rebind_workers+0x1c0/0x1d0 Modules linked in: CPU: 0 PID: 16 Comm: cpuhp/0 Not tainted 4.6.0-rc4+ #31 Hardware name: IBM IBM System x3550 M4 Server -[7914IUW]-/00Y8603, BIOS -[D7E128FUS-1.40]- 07/23/2013 0000000000000000 ffff881037babb58 ffffffff8139d885 0000000000000010 0000000000000000 0000000000000000 0000000000000000 ffff881037babba8 ffffffff8108505d ffff881037ba0000 000011cf3e7d6e60 0000000000000046 Call Trace: dump_stack+0x89/0xd4 __warn+0xfd/0x120 warn_slowpath_null+0x1d/0x20 rebind_workers+0x1c0/0x1d0 workqueue_cpu_up_callback+0xf5/0x1d0 notifier_call_chain+0x64/0x90 ? trace_hardirqs_on_caller+0xf2/0x220 ? notify_prepare+0x80/0x80 __raw_notifier_call_chain+0xe/0x10 __cpu_notify+0x35/0x50 notify_down_prepare+0x5e/0x80 ? notify_prepare+0x80/0x80 cpuhp_invoke_callback+0x73/0x330 ? __schedule+0x33e/0x8a0 cpuhp_down_callbacks+0x51/0xc0 cpuhp_thread_fun+0xc1/0xf0 smpboot_thread_fn+0x159/0x2a0 ? smpboot_create_threads+0x80/0x80 kthread+0xef/0x110 ? wait_for_completion+0xf0/0x120 ? schedule_tail+0x35/0xf0 ret_from_fork+0x22/0x50 ? __init_kthread_worker+0x70/0x70 ---[ end trace eb12ae47d2382d8f ]--- notify_down_prepare: attempt to take down CPU 0 failed This bug can be reproduced by below config w/ nohz_full= all cpus: CONFIG_BOOTPARAM_HOTPLUG_CPU0=y CONFIG_DEBUG_HOTPLUG_CPU0=y CONFIG_NO_HZ_FULL=y As Thomas pointed out: | If a down prepare callback fails, then DOWN_FAILED is invoked for all | callbacks which have successfully executed DOWN_PREPARE. | | But, workqueue has actually two notifiers. One which handles | UP/DOWN_FAILED/ONLINE and one which handles DOWN_PREPARE. | | Now look at the priorities of those callbacks: | | CPU_PRI_WORKQUEUE_UP = 5 | CPU_PRI_WORKQUEUE_DOWN = -5 | | So the call order on DOWN_PREPARE is: | | CB 1 | CB ... | CB workqueue_up() -> Ignores DOWN_PREPARE | CB ... | CB X ---> Fails | | So we call up to CB X with DOWN_FAILED | | CB 1 | CB ... | CB workqueue_up() -> Handles DOWN_FAILED | CB ... | CB X-1 | | So the problem is that the workqueue stuff handles DOWN_FAILED in the up | callback, while it should do it in the down callback. Which is not a good idea | either because it wants to be called early on rollback... | | Brilliant stuff, isn't it? The hotplug rework will solve this problem because | the callbacks become symetric, but for the existing mess, we need some | workaround in the workqueue code. The boot CPU handles housekeeping duty(unbound timers, workqueues, timekeeping, ...) on behalf of full dynticks CPUs. It must remain online when nohz full is enabled. There is a priority set to every notifier_blocks: workqueue_cpu_up > tick_nohz_cpu_down > workqueue_cpu_down So tick_nohz_cpu_down callback failed when down prepare cpu 0, and notifier_blocks behind tick_nohz_cpu_down will not be called any more, which leads to workers are actually not unbound. Then hotplug state machine will fallback to undo and online cpu 0 again. Workers will be rebound unconditionally even if they are not unbound and trigger the warning in this progress. This patch fix it by catching !DISASSOCIATED to avoid rebind bound workers. Cc: Tejun Heo <tj@kernel.org> Cc: Lai Jiangshan <jiangshanlai@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: stable@vger.kernel.org Suggested-by: Lai Jiangshan <jiangshanlai@gmail.com> Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-05-17perf/core: Disable the event on a truncated AUX recordAlexander Shishkin
[ Upstream commit 9f448cd3cbcec8995935e60b27802ae56aac8cc0 ] When the PMU driver reports a truncated AUX record, it effectively means that there is no more usable room in the event's AUX buffer (even though there may still be some room, so that perf_aux_output_begin() doesn't take action). At this point the consumer still has to be woken up and the event has to be disabled, otherwise the event will just keep spinning between perf_aux_output_begin() and perf_aux_output_end() until its context gets unscheduled. Again, for cpu-wide events this means never, so once in this condition, they will be forever losing data. Fix this by disabling the event and waking up the consumer in case of a truncated AUX record. Reported-by: Markus Metzger <markus.t.metzger@intel.com> Signed-off-by: Alexander Shishkin <alexander.shishkin@linux.intel.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: <stable@vger.kernel.org> Cc: Arnaldo Carvalho de Melo <acme@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Vince Weaver <vincent.weaver@maine.edu> Cc: vince@deater.net Link: http://lkml.kernel.org/r/1462886313-13660-3-git-send-email-alexander.shishkin@linux.intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-05-17tracing: Don't display trigger file for events that can't be enabledChunyu Hu
[ Upstream commit 854145e0a8e9a05f7366d240e2f99d9c1ca6d6dd ] Currently register functions for events will be called through the 'reg' field of event class directly without any check when seting up triggers. Triggers for events that don't support register through debug fs (events under events/ftrace are for trace-cmd to read event format, and most of them don't have a register function except events/ftrace/functionx) can't be enabled at all, and an oops will be hit when setting up trigger for those events, so just not creating them is an easy way to avoid the oops. Link: http://lkml.kernel.org/r/1462275274-3911-1-git-send-email-chuhu@redhat.com Cc: stable@vger.kernel.org # 3.14+ Fixes: 85f2b08268c01 ("tracing: Add basic event trigger framework") Signed-off-by: Chunyu Hu <chuhu@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-05-17workqueue: fix ghost PENDING flag while doing MQ IORoman Pen
[ Upstream commit 346c09f80459a3ad97df1816d6d606169a51001a ] The bug in a workqueue leads to a stalled IO request in MQ ctx->rq_list with the following backtrace: [ 601.347452] INFO: task kworker/u129:5:1636 blocked for more than 120 seconds. [ 601.347574] Tainted: G O 4.4.5-1-storage+ #6 [ 601.347651] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message. [ 601.348142] kworker/u129:5 D ffff880803077988 0 1636 2 0x00000000 [ 601.348519] Workqueue: ibnbd_server_fileio_wq ibnbd_dev_file_submit_io_worker [ibnbd_server] [ 601.348999] ffff880803077988 ffff88080466b900 ffff8808033f9c80 ffff880803078000 [ 601.349662] ffff880807c95000 7fffffffffffffff ffffffff815b0920 ffff880803077ad0 [ 601.350333] ffff8808030779a0 ffffffff815b01d5 0000000000000000 ffff880803077a38 [ 601.350965] Call Trace: [ 601.351203] [<ffffffff815b0920>] ? bit_wait+0x60/0x60 [ 601.351444] [<ffffffff815b01d5>] schedule+0x35/0x80 [ 601.351709] [<ffffffff815b2dd2>] schedule_timeout+0x192/0x230 [ 601.351958] [<ffffffff812d43f7>] ? blk_flush_plug_list+0xc7/0x220 [ 601.352208] [<ffffffff810bd737>] ? ktime_get+0x37/0xa0 [ 601.352446] [<ffffffff815b0920>] ? bit_wait+0x60/0x60 [ 601.352688] [<ffffffff815af784>] io_schedule_timeout+0xa4/0x110 [ 601.352951] [<ffffffff815b3a4e>] ? _raw_spin_unlock_irqrestore+0xe/0x10 [ 601.353196] [<ffffffff815b093b>] bit_wait_io+0x1b/0x70 [ 601.353440] [<ffffffff815b056d>] __wait_on_bit+0x5d/0x90 [ 601.353689] [<ffffffff81127bd0>] wait_on_page_bit+0xc0/0xd0 [ 601.353958] [<ffffffff81096db0>] ? autoremove_wake_function+0x40/0x40 [ 601.354200] [<ffffffff81127cc4>] __filemap_fdatawait_range+0xe4/0x140 [ 601.354441] [<ffffffff81127d34>] filemap_fdatawait_range+0x14/0x30 [ 601.354688] [<ffffffff81129a9f>] filemap_write_and_wait_range+0x3f/0x70 [ 601.354932] [<ffffffff811ced3b>] blkdev_fsync+0x1b/0x50 [ 601.355193] [<ffffffff811c82d9>] vfs_fsync_range+0x49/0xa0 [ 601.355432] [<ffffffff811cf45a>] blkdev_write_iter+0xca/0x100 [ 601.355679] [<ffffffff81197b1a>] __vfs_write+0xaa/0xe0 [ 601.355925] [<ffffffff81198379>] vfs_write+0xa9/0x1a0 [ 601.356164] [<ffffffff811c59d8>] kernel_write+0x38/0x50 The underlying device is a null_blk, with default parameters: queue_mode = MQ submit_queues = 1 Verification that nullb0 has something inflight: root@pserver8:~# cat /sys/block/nullb0/inflight 0 1 root@pserver8:~# find /sys/block/nullb0/mq/0/cpu* -name rq_list -print -exec cat {} \; ... /sys/block/nullb0/mq/0/cpu2/rq_list CTX pending: ffff8838038e2400 ... During debug it became clear that stalled request is always inserted in the rq_list from the following path: save_stack_trace_tsk + 34 blk_mq_insert_requests + 231 blk_mq_flush_plug_list + 281 blk_flush_plug_list + 199 wait_on_page_bit + 192 __filemap_fdatawait_range + 228 filemap_fdatawait_range + 20 filemap_write_and_wait_range + 63 blkdev_fsync + 27 vfs_fsync_range + 73 blkdev_write_iter + 202 __vfs_write + 170 vfs_write + 169 kernel_write + 56 So blk_flush_plug_list() was called with from_schedule == true. If from_schedule is true, that means that finally blk_mq_insert_requests() offloads execution of __blk_mq_run_hw_queue() and uses kblockd workqueue, i.e. it calls kblockd_schedule_delayed_work_on(). That means, that we race with another CPU, which is about to execute __blk_mq_run_hw_queue() work. Further debugging shows the following traces from different CPUs: CPU#0 CPU#1 ---------------------------------- ------------------------------- reqeust A inserted STORE hctx->ctx_map[0] bit marked kblockd_schedule...() returns 1 <schedule to kblockd workqueue> request B inserted STORE hctx->ctx_map[1] bit marked kblockd_schedule...() returns 0 *** WORK PENDING bit is cleared *** flush_busy_ctxs() is executed, but bit 1, set by CPU#1, is not observed As a result request B pended forever. This behaviour can be explained by speculative LOAD of hctx->ctx_map on CPU#0, which is reordered with clear of PENDING bit and executed _before_ actual STORE of bit 1 on CPU#1. The proper fix is an explicit full barrier <mfence>, which guarantees that clear of PENDING bit is to be executed before all possible speculative LOADS or STORES inside actual work function. Signed-off-by: Roman Pen <roman.penyaev@profitbricks.com> Cc: Gioh Kim <gi-oh.kim@profitbricks.com> Cc: Michael Wang <yun.wang@profitbricks.com> Cc: Tejun Heo <tj@kernel.org> Cc: Jens Axboe <axboe@kernel.dk> Cc: linux-block@vger.kernel.org Cc: linux-kernel@vger.kernel.org Cc: stable@vger.kernel.org Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-05-10futex: Handle unlock_pi race gracefullySebastian Andrzej Siewior
[ Upstream commit 89e9e66ba1b3bde9d8ea90566c2aee20697ad681 ] If userspace calls UNLOCK_PI unconditionally without trying the TID -> 0 transition in user space first then the user space value might not have the waiters bit set. This opens the following race: CPU0 CPU1 uval = get_user(futex) lock(hb) lock(hb) futex |= FUTEX_WAITERS .... unlock(hb) cmpxchg(futex, uval, newval) So the cmpxchg fails and returns -EINVAL to user space, which is wrong because the futex value is valid. To handle this (yes, yet another) corner case gracefully, check for a flag change and retry. [ tglx: Massaged changelog and slightly reworked implementation ] Fixes: ccf9e6a80d9e ("futex: Make unlock_pi more robust") Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: stable@vger.kernel.org Cc: Davidlohr Bueso <dave@stgolabs.net> Cc: Darren Hart <dvhart@linux.intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1460723739-5195-1-git-send-email-bigeasy@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-04-18fs/coredump: prevent fsuid=0 dumps into user-controlled directoriesJann Horn
[ Upstream commit 378c6520e7d29280f400ef2ceaf155c86f05a71a ] This commit fixes the following security hole affecting systems where all of the following conditions are fulfilled: - The fs.suid_dumpable sysctl is set to 2. - The kernel.core_pattern sysctl's value starts with "/". (Systems where kernel.core_pattern starts with "|/" are not affected.) - Unprivileged user namespace creation is permitted. (This is true on Linux >=3.8, but some distributions disallow it by default using a distro patch.) Under these conditions, if a program executes under secure exec rules, causing it to run with the SUID_DUMP_ROOT flag, then unshares its user namespace, changes its root directory and crashes, the coredump will be written using fsuid=0 and a path derived from kernel.core_pattern - but this path is interpreted relative to the root directory of the process, allowing the attacker to control where a coredump will be written with root privileges. To fix the security issue, always interpret core_pattern for dumps that are written under SUID_DUMP_ROOT relative to the root directory of init. Signed-off-by: Jann Horn <jann@thejh.net> Acked-by: Kees Cook <keescook@chromium.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-04-18tracing: Fix trace_printk() to print when not using bprintk()Steven Rostedt (Red Hat)
[ Upstream commit 3debb0a9ddb16526de8b456491b7db60114f7b5e ] The trace_printk() code will allocate extra buffers if the compile detects that a trace_printk() is used. To do this, the format of the trace_printk() is saved to the __trace_printk_fmt section, and if that section is bigger than zero, the buffers are allocated (along with a message that this has happened). If trace_printk() uses a format that is not a constant, and thus something not guaranteed to be around when the print happens, the compiler optimizes the fmt out, as it is not used, and the __trace_printk_fmt section is not filled. This means the kernel will not allocate the special buffers needed for the trace_printk() and the trace_printk() will not write anything to the tracing buffer. Adding a "__used" to the variable in the __trace_printk_fmt section will keep it around, even though it is set to NULL. This will keep the string from being printed in the debugfs/tracing/printk_formats section as it is not needed. Reported-by: Vlastimil Babka <vbabka@suse.cz> Fixes: 07d777fe8c398 "tracing: Add percpu buffers for trace_printk()" Cc: stable@vger.kernel.org # v3.5+ Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-04-18tracing: Fix crash from reading trace_pipe with sendfileSteven Rostedt (Red Hat)
[ Upstream commit a29054d9478d0435ab01b7544da4f674ab13f533 ] If tracing contains data and the trace_pipe file is read with sendfile(), then it can trigger a NULL pointer dereference and various BUG_ON within the VM code. There's a patch to fix this in the splice_to_pipe() code, but it's also a good idea to not let that happen from trace_pipe either. Link: http://lkml.kernel.org/r/1457641146-9068-1-git-send-email-rabin@rab.in Cc: stable@vger.kernel.org # 2.6.30+ Reported-by: Rabin Vincent <rabin.vincent@gmail.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-04-18watchdog: don't run proc_watchdog_update if new value is same as oldJoshua Hunt
[ Upstream commit a1ee1932aa6bea0bb074f5e3ced112664e4637ed ] While working on a script to restore all sysctl params before a series of tests I found that writing any value into the /proc/sys/kernel/{nmi_watchdog,soft_watchdog,watchdog,watchdog_thresh} causes them to call proc_watchdog_update(). NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter. NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter. NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter. NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter. There doesn't appear to be a reason for doing this work every time a write occurs, so only do it when the values change. Signed-off-by: Josh Hunt <johunt@akamai.com> Acked-by: Don Zickus <dzickus@redhat.com> Reviewed-by: Aaron Tomlin <atomlin@redhat.com> Cc: Ulrich Obergfell <uobergfe@redhat.com> Cc: <stable@vger.kernel.org> [4.1.x+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-04-18sched/cputime: Fix steal_account_process_tick() to always return jiffiesChris Friesen
[ Upstream commit f9c904b7613b8b4c85b10cd6b33ad41b2843fa9d ] The callers of steal_account_process_tick() expect it to return whether a jiffy should be considered stolen or not. Currently the return value of steal_account_process_tick() is in units of cputime, which vary between either jiffies or nsecs depending on CONFIG_VIRT_CPU_ACCOUNTING_GEN. If cputime has nsecs granularity and there is a tiny amount of stolen time (a few nsecs, say) then we will consider the entire tick stolen and will not account the tick on user/system/idle, causing /proc/stats to show invalid data. The fix is to change steal_account_process_tick() to accumulate the stolen time and only account it once it's worth a jiffy. (Thanks to Frederic Weisbecker for suggestions to fix a bug in my first version of the patch.) Signed-off-by: Chris Friesen <chris.friesen@windriver.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Cc: <stable@vger.kernel.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/56DBBDB8.40305@mail.usask.ca Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-04-13modules: fix longstanding /proc/kallsyms vs module insertion race.Rusty Russell
[ Upstream commit 8244062ef1e54502ef55f54cced659913f244c3e ] For CONFIG_KALLSYMS, we keep two symbol tables and two string tables. There's one full copy, marked SHF_ALLOC and laid out at the end of the module's init section. There's also a cut-down version that only contains core symbols and strings, and lives in the module's core section. After module init (and before we free the module memory), we switch the mod->symtab, mod->num_symtab and mod->strtab to point to the core versions. We do this under the module_mutex. However, kallsyms doesn't take the module_mutex: it uses preempt_disable() and rcu tricks to walk through the modules, because it's used in the oops path. It's also used in /proc/kallsyms. There's nothing atomic about the change of these variables, so we can get the old (larger!) num_symtab and the new symtab pointer; in fact this is what I saw when trying to reproduce. By grouping these variables together, we can use a carefully-dereferenced pointer to ensure we always get one or the other (the free of the module init section is already done in an RCU callback, so that's safe). We allocate the init one at the end of the module init section, and keep the core one inside the struct module itself (it could also have been allocated at the end of the module core, but that's probably overkill). Reported-by: Weilong Chen <chenweilong@huawei.com> Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=111541 Cc: stable@kernel.org Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-04-13kernel/resource.c: fix muxed resource handling in __request_region()Simon Guinot
[ Upstream commit 59ceeaaf355fa0fb16558ef7c24413c804932ada ] In __request_region, if a conflict with a BUSY and MUXED resource is detected, then the caller goes to sleep and waits for the resource to be released. A pointer on the conflicting resource is kept. At wake-up this pointer is used as a parent to retry to request the region. A first problem is that this pointer might well be invalid (if for example the conflicting resource have already been freed). Another problem is that the next call to __request_region() fails to detect a remaining conflict. The previously conflicting resource is passed as a parameter and __request_region() will look for a conflict among the children of this resource and not at the resource itself. It is likely to succeed anyway, even if there is still a conflict. Instead, the parent of the conflicting resource should be passed to __request_region(). As a fix, this patch doesn't update the parent resource pointer in the case we have to wait for a muxed region right after. Reported-and-tested-by: Vincent Pelletier <plr.vincent@gmail.com> Signed-off-by: Simon Guinot <simon.guinot@sequanux.org> Tested-by: Vincent Donnefort <vdonnefort@gmail.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-04-11module: wrapper for symbol name.Rusty Russell
[ Upstream commit 2e7bac536106236104e9e339531ff0fcdb7b8147 ] This trivial wrapper adds clarity and makes the following patch smaller. Cc: stable@kernel.org Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-04-11ptrace: use fsuid, fsgid, effective creds for fs access checksJann Horn
[ Upstream commit caaee6234d05a58c5b4d05e7bf766131b810a657 ] By checking the effective credentials instead of the real UID / permitted capabilities, ensure that the calling process actually intended to use its credentials. To ensure that all ptrace checks use the correct caller credentials (e.g. in case out-of-tree code or newly added code omits the PTRACE_MODE_*CREDS flag), use two new flags and require one of them to be set. The problem was that when a privileged task had temporarily dropped its privileges, e.g. by calling setreuid(0, user_uid), with the intent to perform following syscalls with the credentials of a user, it still passed ptrace access checks that the user would not be able to pass. While an attacker should not be able to convince the privileged task to perform a ptrace() syscall, this is a problem because the ptrace access check is reused for things in procfs. In particular, the following somewhat interesting procfs entries only rely on ptrace access checks: /proc/$pid/stat - uses the check for determining whether pointers should be visible, useful for bypassing ASLR /proc/$pid/maps - also useful for bypassing ASLR /proc/$pid/cwd - useful for gaining access to restricted directories that contain files with lax permissions, e.g. in this scenario: lrwxrwxrwx root root /proc/13020/cwd -> /root/foobar drwx------ root root /root drwxr-xr-x root root /root/foobar -rw-r--r-- root root /root/foobar/secret Therefore, on a system where a root-owned mode 6755 binary changes its effective credentials as described and then dumps a user-specified file, this could be used by an attacker to reveal the memory layout of root's processes or reveal the contents of files he is not allowed to access (through /proc/$pid/cwd). [akpm@linux-foundation.org: fix warning] Signed-off-by: Jann Horn <jann@thejh.net> Acked-by: Kees Cook <keescook@chromium.org> Cc: Casey Schaufler <casey@schaufler-ca.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: James Morris <james.l.morris@oracle.com> Cc: "Serge E. Hallyn" <serge.hallyn@ubuntu.com> Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Willy Tarreau <w@1wt.eu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-04-06sched: Fix crash in sched_init_numa()Raghavendra K T
[ Upstream commit 9c03ee147193645be4c186d3688232fa438c57c7 ] The following PowerPC commit: c118baf80256 ("arch/powerpc/mm/numa.c: do not allocate bootmem memory for non existing nodes") avoids allocating bootmem memory for non existent nodes. But when DEBUG_PER_CPU_MAPS=y is enabled, my powerNV system failed to boot because in sched_init_numa(), cpumask_or() operation was done on unallocated nodes. Fix that by making cpumask_or() operation only on existing nodes. [ Tested with and w/o DEBUG_PER_CPU_MAPS=y on x86 and PowerPC. ] Reported-by: Jan Stancek <jstancek@redhat.com> Tested-by: Jan Stancek <jstancek@redhat.com> Signed-off-by: Raghavendra K T <raghavendra.kt@linux.vnet.ibm.com> Cc: <gkurz@linux.vnet.ibm.com> Cc: <grant.likely@linaro.org> Cc: <nikunj@linux.vnet.ibm.com> Cc: <vdavydov@parallels.com> Cc: <linuxppc-dev@lists.ozlabs.org> Cc: <linux-mm@kvack.org> Cc: <peterz@infradead.org> Cc: <benh@kernel.crashing.org> Cc: <paulus@samba.org> Cc: <mpe@ellerman.id.au> Cc: <anton@samba.org> Link: http://lkml.kernel.org/r/1452884483-11676-1-git-send-email-raghavendra.kt@linux.vnet.ibm.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-03-24perf/core: Fix perf_sched_count derailmentAlexander Shishkin
[ Upstream commit 927a5570855836e5d5859a80ce7e91e963545e8f ] The error path in perf_event_open() is such that asking for a sampling event on a PMU that doesn't generate interrupts will end up in dropping the perf_sched_count even though it hasn't been incremented for this event yet. Given a sufficient amount of these calls, we'll end up disabling scheduler's jump label even though we'd still have active events in the system, thereby facilitating the arrival of the infernal regions upon us. I'm fixing this by moving account_event() inside perf_event_alloc(). Signed-off-by: Alexander Shishkin <alexander.shishkin@linux.intel.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: <stable@vger.kernel.org> Cc: Arnaldo Carvalho de Melo <acme@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Vince Weaver <vincent.weaver@maine.edu> Cc: vince@deater.net Link: http://lkml.kernel.org/r/1456917854-29427-1-git-send-email-alexander.shishkin@linux.intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: He Kuang <hekuang@huawei.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-03-24perf: Cure event->pending_disable racePeter Zijlstra
[ Upstream commit 28a967c3a2f99fa3b5f762f25cb2a319d933571b ] Because event_sched_out() checks event->pending_disable _before_ actually disabling the event, it can happen that the event fires after it checks but before it gets disabled. This would leave event->pending_disable set and the queued irq_work will try and process it. However, if the event trigger was during schedule(), the event might have been de-scheduled by the time the irq_work runs, and perf_event_disable_local() will fail. Fix this by checking event->pending_disable _after_ we call event->pmu->del(). This depends on the latter being a compiler barrier, such that the compiler does not lift the load and re-creates the problem. Tested-by: Alexander Shishkin <alexander.shishkin@linux.intel.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Reviewed-by: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: dvyukov@google.com Cc: eranian@google.com Cc: oleg@redhat.com Cc: panand@redhat.com Cc: sasha.levin@oracle.com Cc: vince@deater.net Link: http://lkml.kernel.org/r/20160224174948.040469884@infradead.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: He Kuang <hekuang@huawei.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-03-24perf: Do not double freePeter Zijlstra
[ Upstream commit 130056275ade730e7a79c110212c8815202773ee ] In case of: err_file: fput(event_file), we'll end up calling perf_release() which in turn will free the event. Do not then free the event _again_. Tested-by: Alexander Shishkin <alexander.shishkin@linux.intel.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Reviewed-by: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: dvyukov@google.com Cc: eranian@google.com Cc: oleg@redhat.com Cc: panand@redhat.com Cc: sasha.levin@oracle.com Cc: vince@deater.net Link: http://lkml.kernel.org/r/20160224174947.697350349@infradead.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: He Kuang <hekuang@huawei.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
