[ Upstream commit cbdd96f5586151e48317d90a403941ec23f12660 ]
Instead of calling BUG_ON(), if we find a kprobe in use on free kprobe
list, just remove it from the list and keep it on kprobe hash list
as same as other in-use kprobes.
Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org>
Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com>
Cc: David S . Miller <davem@davemloft.net>
Cc: Naveen N . Rao <naveen.n.rao@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/153666126882.21306.10738207224288507996.stgit@devbox
[ Upstream commit 55a3235fc71bf34303e34a95eeee235b2d2a35dd ]
For userspace to tell the difference between a random signal and an
exception, the exception must include siginfo information.
Using SEND_SIG_FORCED for SIGILL is thus wrong, and it will result
in userspace seeing si_code == SI_USER (like a random signal) instead
of si_code == SI_KERNEL or a more specific si_code as all exceptions
deliver.
Therefore replace force_sig_info(SIGILL, SEND_SIG_FORCE, current)
with force_sig(SIG_ILL, current) which gets this right and is
shorter and easier to type.
Fixes: 014940bad8e4 ("uprobes/x86: Send SIGILL if arch_uprobe_post_xol() fails")
Fixes: 0b5256c7f173 ("uprobes: Send SIGILL if handle_trampoline() fails")
[ Upstream commit 86989c41b5ea08776c450cb759592532314a4ed6 ]
If the first process started (aka /sbin/init) receives a SIGKILL it
will panic the system if it is delivered. Making the system unusable
and undebugable. It isn't much better if the first process started
receives SIGSTOP.
So always ignore SIGSTOP and SIGKILL sent to init.
This is done in a separate clause in sig_task_ignored as force_sig_info
can clear SIG_UNKILLABLE and this protection should work even then.
commit 731dc9df975a5da21237a18c3384f811a7a41cc6 upstream.
A kernel module may need to check the value of the "mitigations=" kernel
command line parameter as part of its setup when the module needs
to perform software mitigations for a CPU flaw.
Uninline and export the helper functions surrounding the cpu_mitigations
enum to allow for their usage from a module.
Lastly, privatize the enum and cpu_mitigations variable since the value of
cpu_mitigations can be checked with the exported helper functions.
Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
Fix backport of commit f18ddc13af981ce3c7b7f26925f099e7c6929aba upstream.
Update backport to change ENOTSUPP to EOPNOTSUPP in
alarm_timer_{del,set}(), which were removed in
f2c45807d3992fe0f173f34af9c347d907c31686 in v4.13-rc1.
Fixes: 65b7a5a36afb11a6769a70308c1ef3a2afae6bf4
Signed-off-by: Petr Vorel <pvorel@suse.cz>
Acked-by: Thadeu Lima de Souza Cascardo <cascardo@canonical.com>
[ Upstream commit d303de1fcf344ff7c15ed64c3f48a991c9958775 ]
A customer reported the following softlockup:
[899688.160002] NMI watchdog: BUG: soft lockup - CPU#0 stuck for 22s! [test.sh:16464]
[899688.160002] CPU: 0 PID: 16464 Comm: test.sh Not tainted 4.12.14-6.23-azure #1 SLE12-SP4
[899688.160002] RIP: 0010:up_write+0x1a/0x30
[899688.160002] Kernel panic - not syncing: softlockup: hung tasks
[899688.160002] RSP: 0018:ffffa86784d4fde8 EFLAGS: 00000257 ORIG_RAX: ffffffffffffff12
[899688.160002] RAX: ffffffff970fea00 RBX: 0000000000000001 RCX: 0000000000000000
[899688.160002] RDX: ffffffff00000001 RSI: 0000000000000080 RDI: ffffffff970fea00
[899688.160002] RBP: ffffffffffffffff R08: ffffffffffffffff R09: 0000000000000000
[899688.160002] R10: 0000000000000000 R11: 0000000000000000 R12: ffff8b59014720d8
[899688.160002] R13: ffff8b59014720c0 R14: ffff8b5901471090 R15: ffff8b5901470000
[899688.160002] tracing_read_pipe+0x336/0x3c0
[899688.160002] __vfs_read+0x26/0x140
[899688.160002] vfs_read+0x87/0x130
[899688.160002] SyS_read+0x42/0x90
[899688.160002] do_syscall_64+0x74/0x160
It caught the process in the middle of trace_access_unlock(). There is
no loop. So, it must be looping in the caller tracing_read_pipe()
via the "waitagain" label.
Crashdump analyze uncovered that iter->seq was completely zeroed
at this point, including iter->seq.seq.size. It means that
print_trace_line() was never able to print anything and
there was no forward progress.
The culprit seems to be in the code:
/* reset all but tr, trace, and overruns */
memset(&iter->seq, 0,
sizeof(struct trace_iterator) -
offsetof(struct trace_iterator, seq));
It was added by the commit 53d0aa773053ab182877 ("ftrace:
add logic to record overruns"). It was v2.6.27-rc1.
It was the time when iter->seq looked like:
struct trace_seq {
unsigned char buffer[PAGE_SIZE];
unsigned int len;
There was no "size" variable and zeroing was perfectly fine.
The solution is to reinitialize the structure after or without
zeroing.
Link: http://lkml.kernel.org/r/20191011142134.11997-1-pmladek@suse.com
Signed-off-by: Petr Mladek <pmladek@suse.com>
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
commit 194c2c74f5532e62c218adeb8e2b683119503907 upstream.
As instances may have different tracers available, we need to look at the
trace_array descriptor that shows the list of the available tracers for the
instance. But there's a race between opening the file and an admin
deleting the instance. The trace_array_get() needs to be called before
accessing the trace_array.
Cc: stable@vger.kernel.org
Fixes: 607e2ea167e56 ("tracing: Set up infrastructure to allow tracers for instances")
commit fc64e4ad80d4b72efce116f87b3174f0b7196f8e upstream.
max_latency is intended to record the maximum ever observed hardware
latency, which may occur in either part of the loop (inner/outer). So
we need to also consider the outer-loop sample when updating
max_latency.
Link: http://lkml.kernel.org/r/157073345463.17189.18124025522664682811.stgit@srivatsa-ubuntu
Fixes: e7c15cd8a113 ("tracing: Added hardware latency tracer")
Signed-off-by: Srivatsa S. Bhat (VMware) <srivatsa@csail.mit.edu>
commit 98dc19c11470ee6048aba723d77079ad2cda8a52 upstream.
nmi_total_ts is supposed to record the total time spent in *all* NMIs
that occur on the given CPU during the (active portion of the)
sampling window. However, the code seems to be overwriting this
variable for each NMI, thereby only recording the time spent in the
most recent NMI. Fix it by accumulating the duration instead.
Link: http://lkml.kernel.org/r/157073343544.17189.13911783866738671133.stgit@srivatsa-ubuntu
Fixes: 7b2c86250122 ("tracing: Add NMI tracing in hwlat detector")
commit b0f53dbc4bc4c371f38b14c391095a3bb8a0bb40 upstream.
Partially revert 16db3d3f1170 ("kernel/sysctl.c: threads-max observe
limits") because the patch is causing a regression to any workload which
needs to override the auto-tuning of the limit provided by kernel.
set_max_threads is implementing a boot time guesstimate to provide a
sensible limit of the concurrently running threads so that runaways will
not deplete all the memory. This is a good thing in general but there
are workloads which might need to increase this limit for an application
to run (reportedly WebSpher MQ is affected) and that is simply not
possible after the mentioned change. It is also very dubious to
override an admin decision by an estimation that doesn't have any direct
relation to correctness of the kernel operation.
Fix this by dropping set_max_threads from sysctl_max_threads so any
value is accepted as long as it fits into MAX_THREADS which is important
to check because allowing more threads could break internal robust futex
restriction. While at it, do not use MIN_THREADS as the lower boundary
because it is also only a heuristic for automatic estimation and admin
might have a good reason to stop new threads to be created even when
below this limit.
This became more severe when we switched x86 from 4k to 8k kernel
stacks. Starting since 6538b8ea886e ("x86_64: expand kernel stack to
16K") (3.16) we use THREAD_SIZE_ORDER = 2 and that halved the auto-tuned
value.
In the particular case
3.12
kernel.threads-max = 515561
4.4
kernel.threads-max = 200000
Neither of the two values is really insane on 32GB machine.
I am not sure we want/need to tune the max_thread value further. If
anything the tuning should be removed altogether if proven not useful in
general. But we definitely need a way to override this auto-tuning.
Link: http://lkml.kernel.org/r/20190922065801.GB18814@dhcp22.suse.cz
Fixes: 16db3d3f1170 ("kernel/sysctl.c: threads-max observe limits")
Signed-off-by: Michal Hocko <mhocko@suse.com>
Reviewed-by: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Heinrich Schuchardt <xypron.glpk@gmx.de>
Cc: <stable@vger.kernel.org>
commit 20bb759a66be52cf4a9ddd17fddaf509e11490cd upstream.
Calling 'panic()' on a kernel with CONFIG_PREEMPT=y can leave the
calling CPU in an infinite loop, but with interrupts and preemption
enabled. From this state, userspace can continue to be scheduled,
despite the system being "dead" as far as the kernel is concerned.
This is easily reproducible on arm64 when booting with "nosmp" on the
command line; a couple of shell scripts print out a periodic "Ping"
message whilst another triggers a crash by writing to
/proc/sysrq-trigger:
| sysrq: Trigger a crash
| Kernel panic - not syncing: sysrq triggered crash
| CPU: 0 PID: 1 Comm: init Not tainted 5.2.15 #1
| Hardware name: linux,dummy-virt (DT)
| Call trace:
| dump_backtrace+0x0/0x148
| show_stack+0x14/0x20
| dump_stack+0xa0/0xc4
| panic+0x140/0x32c
| sysrq_handle_reboot+0x0/0x20
| __handle_sysrq+0x124/0x190
| write_sysrq_trigger+0x64/0x88
| proc_reg_write+0x60/0xa8
| __vfs_write+0x18/0x40
| vfs_write+0xa4/0x1b8
| ksys_write+0x64/0xf0
| __arm64_sys_write+0x14/0x20
| el0_svc_common.constprop.0+0xb0/0x168
| el0_svc_handler+0x28/0x78
| el0_svc+0x8/0xc
| Kernel Offset: disabled
| CPU features: 0x0002,24002004
| Memory Limit: none
| ---[ end Kernel panic - not syncing: sysrq triggered crash ]---
| Ping 2!
| Ping 1!
| Ping 1!
| Ping 2!
The issue can also be triggered on x86 kernels if CONFIG_SMP=n,
otherwise local interrupts are disabled in 'smp_send_stop()'.
Disable preemption in 'panic()' before re-enabling interrupts.
Link: http://lkml.kernel.org/r/20191002123538.22609-1-will@kernel.org
Link: https://lore.kernel.org/r/BX1W47JXPMR8.58IYW53H6M5N@dragonstone
Signed-off-by: Will Deacon <will@kernel.org>
Reported-by: Xogium <contact@xogium.me>
Cc: Russell King <linux@armlinux.org.uk>
Cc: Petr Mladek <pmladek@suse.com>
Cc: Feng Tang <feng.tang@intel.com>
[ Upstream commit 0f74914071ab7e7b78731ed62bf350e3a344e0a5 ]
When building with W=1, gcc properly complains that there's no prototypes:
CC kernel/elfcore.o
kernel/elfcore.c:7:17: warning: no previous prototype for 'elf_core_extra_phdrs' [-Wmissing-prototypes]
7 | Elf_Half __weak elf_core_extra_phdrs(void)
kernel/elfcore.c:12:12: warning: no previous prototype for 'elf_core_write_extra_phdrs' [-Wmissing-prototypes]
12 | int __weak elf_core_write_extra_phdrs(struct coredump_params *cprm, loff_t offset)
kernel/elfcore.c:17:12: warning: no previous prototype for 'elf_core_write_extra_data' [-Wmissing-prototypes]
17 | int __weak elf_core_write_extra_data(struct coredump_params *cprm)
kernel/elfcore.c:22:15: warning: no previous prototype for 'elf_core_extra_data_size' [-Wmissing-prototypes]
22 | size_t __weak elf_core_extra_data_size(void)
Provide the include file so gcc is happy, and we don't have potential code drift
Link: http://lkml.kernel.org/r/29875.1565224705@turing-police
Signed-off-by: Valdis Kletnieks <valdis.kletnieks@vt.edu>
[ Upstream commit 714e501e16cd473538b609b3e351b2cc9f7f09ed ]
An oops can be triggered in the scheduler when running qemu on arm64:
Unable to handle kernel paging request at virtual address ffff000008effe40
Internal error: Oops: 96000007 [#1] SMP
Process migration/0 (pid: 12, stack limit = 0x00000000084e3736)
pstate: 20000085 (nzCv daIf -PAN -UAO)
pc : __ll_sc___cmpxchg_case_acq_4+0x4/0x20
lr : move_queued_task.isra.21+0x124/0x298
Call trace:
__migrate_task+0xc8/0xe0
migration_cpu_stop+0x170/0x180
cpu_stopper_thread+0xec/0x178
smpboot_thread_fn+0x1ac/0x1e8
kthread+0x134/0x138
ret_from_fork+0x10/0x18
__set_cpus_allowed_ptr() will choose an active dest_cpu in affinity mask to
migrage the process if process is not currently running on any one of the
CPUs specified in affinity mask. __set_cpus_allowed_ptr() will choose an
invalid dest_cpu (dest_cpu >= nr_cpu_ids, 1024 in my virtual machine) if
CPUS in an affinity mask are deactived by cpu_down after cpumask_intersects
check. cpumask_test_cpu() of dest_cpu afterwards is overflown and may pass if
corresponding bit is coincidentally set. As a consequence, kernel will
access an invalid rq address associate with the invalid CPU in
migration_cpu_stop->__migrate_task->move_queued_task and the Oops occurs.
The reproduce the crash:
1) A process repeatedly binds itself to cpu0 and cpu1 in turn by calling
sched_setaffinity.
2) A shell script repeatedly does "echo 0 > /sys/devices/system/cpu/cpu1/online"
and "echo 1 > /sys/devices/system/cpu/cpu1/online" in turn.
3) Oops appears if the invalid CPU is set in memory after tested cpumask.
Signed-off-by: KeMeng Shi <shikemeng@huawei.com>
Reviewed-by: Valentin Schneider <valentin.schneider@arm.com>
Link: https://lkml.kernel.org/r/1568616808-16808-1-git-send-email-shikemeng@huawei.com
commit e430d802d6a3aaf61bd3ed03d9404888a29b9bf9 upstream.
The timer delayed for more than 3 seconds warning was triggered during
testing.
Workqueue: events_unbound sched_tick_remote
RIP: 0010:sched_tick_remote+0xee/0x100
Call Trace:
process_one_work+0x18c/0x3a0
worker_thread+0x30/0x380
kthread+0x113/0x130
ret_from_fork+0x22/0x40
The reason is that the code in collect_expired_timers() uses jiffies
unprotected:
if (next_event > jiffies)
base->clk = jiffies;
As the compiler is allowed to reload the value base->clk can advance
between the check and the store and in the worst case advance farther than
next event. That causes the timer expiry to be delayed until the wheel
pointer wraps around.
Convert the code to use READ_ONCE()
Fixes: 236968383cf5 ("timers: Optimize collect_expired_timers() for NOHZ")
Signed-off-by: Li RongQing <lirongqing@baidu.com>
Signed-off-by: Liang ZhiCheng <liangzhicheng@baidu.com>
Link: https://lkml.kernel.org/r/1568894687-14499-1-git-send-email-lirongqing@baidu.com
ENOTSUPP is not supposed to be returned to userspace. This was found on an
OpenPower machine, where the RTC does not support set_alarm.
On that system, a clock_nanosleep(CLOCK_REALTIME_ALARM, ...) results in
"524 Unknown error 524"
Replace it with EOPNOTSUPP which results in the expected "95 Operation not
supported" error.
Fixes: 1c6b39ad3f01 (alarmtimers: Return -ENOTSUPP if no RTC device is present)
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@canonical.com>
Link: https://lkml.kernel.org/r/20190903171802.28314-1-cascardo@canonical.com
[ Upstream commit b46eff55ad5bd98e746c0a7022fe7ee071de5fee ]
kmsg_dump_get_buffer() is supposed to select all the youngest log
messages which fit into the provided buffer. It determines the correct
start index by using msg_print_text() with a NULL buffer to calculate
the size of each entry. However, when performing the actual writes,
msg_print_text() only writes the entry to the buffer if the written len
is lesser than the size of the buffer. So if the lengths of the
selected youngest log messages happen to precisely fill up the provided
buffer, the last log message is not included.
We don't want to modify msg_print_text() to fill up the buffer and start
returning a length which is equal to the size of the buffer, since
callers of its other users, such as kmsg_dump_get_line(), depend upon
the current behaviour.
Instead, fix kmsg_dump_get_buffer() to compensate for this.
For example, with the following two final prints:
[ 6.427502] AAAAAAAAAAAAA
[ 6.427769] BBBBBBBB12345
A dump of a 64-byte buffer filled by kmsg_dump_get_buffer(), before this
patch:
00000000: 3c 30 3e 5b 20 20 20 20 36 2e 35 32 32 31 39 37 <0>[ 6.522197
00000010: 5d 20 41 41 41 41 41 41 41 41 41 41 41 41 41 0a ] AAAAAAAAAAAAA.
00000020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
After this patch:
00000000: 3c 30 3e 5b 20 20 20 20 36 2e 34 35 36 36 37 38 <0>[ 6.456678
00000010: 5d 20 42 42 42 42 42 42 42 42 31 32 33 34 35 0a ] BBBBBBBB12345.
Link: http://lkml.kernel.org/r/20190711142937.4083-1-vincent.whitchurch@axis.com
Fixes: e2ae715d66bf4bec ("kmsg - kmsg_dump() use iterator to receive log buffer content")
To: rostedt@goodmis.org
Cc: <stable@vger.kernel.org> # v3.5+
Signed-off-by: Vincent Whitchurch <vincent.whitchurch@axis.com>
Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
[ Upstream commit 5aa068ea4082b39eafc356c27c9ecd155b0895f6 ]
The record logging code looks at the previous record flags in various
ways, and they are all wrong.
You can't use the previous record flags to determine anything about the
next record, because they may simply not be related. In particular, the
reason the previous record was a continuation record may well be exactly
_because_ the new record was printed by a different process, which is
why the previous record was flushed.
So all those games are simply wrong, and make the code hard to
understand (because the code fundamentally cdoes not make sense).
So remove it.
[ Upstream commit e336b4027775cb458dc713745e526fa1a1996b2a ]
Since BUG() and WARN() may use a trap (e.g. UD2 on x86) to
get the address where the BUG() has occurred, kprobes can not
do single-step out-of-line that instruction. So prohibit
probing on such address.
Without this fix, if someone put a kprobe on WARN(), the
kernel will crash with invalid opcode error instead of
outputing warning message, because kernel can not find
correct bug address.
Acked-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
Acked-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
Cc: Naveen N . Rao <naveen.n.rao@linux.ibm.com>
Link: https://lkml.kernel.org/r/156750890133.19112.3393666300746167111.stgit@devnote2
[ Upstream commit a07db5c0865799ebed1f88be0df50c581fb65029 ]
On !CONFIG_RT_GROUP_SCHED configurations it is currently not possible to
move RT tasks between cgroups to which CPU controller has been attached;
but it is oddly possible to first move tasks around and then make them
RT (setschedule to FIFO/RR).
E.g.:
# mkdir /sys/fs/cgroup/cpu,cpuacct/group1
# chrt -fp 10 $$
# echo $$ > /sys/fs/cgroup/cpu,cpuacct/group1/tasks
bash: echo: write error: Invalid argument
# chrt -op 0 $$
# chrt -fp 10 $$
# cat /sys/fs/cgroup/cpu,cpuacct/group1/tasks
2345
2598
# chrt -p 2345
pid 2345's current scheduling policy: SCHED_FIFO
pid 2345's current scheduling priority: 10
Also, as Michal noted, it is currently not possible to enable CPU
controller on unified hierarchy with !CONFIG_RT_GROUP_SCHED (if there
are any kernel RT threads in root cgroup, they can't be migrated to the
newly created CPU controller's root in cgroup_update_dfl_csses()).
Existing code comes with a comment saying the "we don't support RT-tasks
being in separate groups". Such comment is however stale and belongs to
pre-RT_GROUP_SCHED times. Also, it doesn't make much sense for
!RT_GROUP_ SCHED configurations, since checks related to RT bandwidth
are not performed at all in these cases.
Make moving RT tasks between CPU controller groups viable by removing
special case check for RT (and DEADLINE) tasks.
Signed-off-by: Juri Lelli <juri.lelli@redhat.com>
Reviewed-by: Michal Koutný <mkoutny@suse.com>
Reviewed-by: Daniel Bristot de Oliveira <bristot@redhat.com>
Acked-by: Tejun Heo <tj@kernel.org>
Cc: lizefan@huawei.com
Cc: longman@redhat.com
Cc: luca.abeni@santannapisa.it
Cc: rostedt@goodmis.org
Link: https://lkml.kernel.org/r/20190719063455.27328-1-juri.lelli@redhat.com
[ Upstream commit f6cad8df6b30a5d2bbbd2e698f74b4cafb9fb82b ]
The load_balance() has a dedicated mecanism to detect when an imbalance
is due to CPU affinity and must be handled at parent level. In this case,
the imbalance field of the parent's sched_group is set.
The description of sg_imbalanced() gives a typical example of two groups
of 4 CPUs each and 4 tasks each with a cpumask covering 1 CPU of the first
group and 3 CPUs of the second group. Something like:
{ 0 1 2 3 } { 4 5 6 7 }
But the load_balance fails to fix this UC on my octo cores system
made of 2 clusters of quad cores.
Whereas the load_balance is able to detect that the imbalanced is due to
CPU affinity, it fails to fix it because the imbalance field is cleared
before letting parent level a chance to run. In fact, when the imbalance is
detected, the load_balance reruns without the CPU with pinned tasks. But
there is no other running tasks in the situation described above and
everything looks balanced this time so the imbalance field is immediately
cleared.
The imbalance field should not be cleared if there is no other task to move
when the imbalance is detected.
Signed-off-by: Vincent Guittot <vincent.guittot@linaro.org>
Link: https://lkml.kernel.org/r/1561996022-28829-1-git-send-email-vincent.guittot@linaro.org
[ Upstream commit 513e1073d52e55b8024b4f238a48de7587c64ccf ]
Tetsuo Handa had reported he saw an incorrect "downgrading a read lock"
warning right after a previous lockdep warning. It is likely that the
previous warning turned off lock debugging causing the lockdep to have
inconsistency states leading to the lock downgrade warning.
Fix that by add a check for debug_locks at the beginning of
__lock_downgrade().
Reported-by: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp>
Reported-by: syzbot+53383ae265fb161ef488@syzkaller.appspotmail.com
Signed-off-by: Waiman Long <longman@redhat.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Link: https://lkml.kernel.org/r/1547093005-26085-1-git-send-email-longman@redhat.com
commit eddf3e9c7c7e4d0707c68d1bb22cc6ec8aef7d4a upstream.
The following crash was observed:
Unable to handle kernel NULL pointer dereference at 0000000000000158
Internal error: Oops: 96000004 [#1] SMP
pc : resend_irqs+0x68/0xb0
lr : resend_irqs+0x64/0xb0
Call trace:
tasklet_action_common.isra.6+0x84/0x138
tasklet_action+0x2c/0x38
__do_softirq+0x120/0x324
run_ksoftirqd+0x44/0x60
kthread+0x134/0x138
The reason for this is that the interrupt resend mechanism happens in soft
interrupt context, which is a asynchronous mechanism versus other
operations on interrupts. free_irq() does not take resend handling into
account. Thus, the irq descriptor might be already freed before the resend
tasklet is executed. resend_irqs() does not check the return value of the
interrupt descriptor lookup and derefences the return value
unconditionally.
1):
__setup_irq
irq_startup
check_irq_resend // activate softirq to handle resend irq
2):
irq_domain_free_irqs
irq_free_descs
free_desc
call_rcu(&desc->rcu, delayed_free_desc)
3):
__do_softirq
tasklet_action
resend_irqs
desc = irq_to_desc(irq)
desc->handle_irq(desc) // desc is NULL --> Ooops
Fix this by adding a NULL pointer check in resend_irqs() before derefencing
the irq descriptor.
Fixes: a4633adcdbc1 ("[PATCH] genirq: add genirq sw IRQ-retrigger")
Signed-off-by: Yunfeng Ye <yeyunfeng@huawei.com>
Reviewed-by: Zhiqiang Liu <liuzhiqiang26@huawei.com>
Link: https://lkml.kernel.org/r/1630ae13-5c8e-901e-de09-e740b6a426a7@huawei.com
commit 5e2d2cc2588bd3307ce3937acbc2ed03c830a861 upstream.
do_sched_cfs_period_timer() will refill cfs_b runtime and call
distribute_cfs_runtime to unthrottle cfs_rq, sometimes cfs_b->runtime
will allocate all quota to one cfs_rq incorrectly, then other cfs_rqs
attached to this cfs_b can't get runtime and will be throttled.
We find that one throttled cfs_rq has non-negative
cfs_rq->runtime_remaining and cause an unexpetced cast from s64 to u64
in snippet:
distribute_cfs_runtime() {
runtime = -cfs_rq->runtime_remaining + 1;
The runtime here will change to a large number and consume all
cfs_b->runtime in this cfs_b period.
According to Ben Segall, the throttled cfs_rq can have
account_cfs_rq_runtime called on it because it is throttled before
idle_balance, and the idle_balance calls update_rq_clock to add time
that is accounted to the task.
This commit prevents cfs_rq to be assgined new runtime if it has been
throttled until that distribute_cfs_runtime is called.
Signed-off-by: Liangyan <liangyan.peng@linux.alibaba.com>
Reviewed-by: Ben Segall <bsegall@google.com>
Cc: shanpeic@linux.alibaba.com
Cc: xlpang@linux.alibaba.com
Fixes: d3d9dc330236 ("sched: Throttle entities exceeding their allowed bandwidth")
Link: https://lkml.kernel.org/r/20190826121633.6538-1-liangyan.peng@linux.alibaba.com
commit d0ff14fdc987303aeeb7de6f1bd72c3749ae2a9b upstream.
If alloc_descs() fails before irq_sysfs_init() has run, free_desc() in the
cleanup path will call kobject_del() even though the kobject has not been
added with kobject_add().
Fix this by making the call to kobject_del() conditional on whether
irq_sysfs_init() has run.
This problem surfaced because commit aa30f47cf666 ("kobject: Add support
for default attribute groups to kobj_type") makes kobject_del() stricter
about pairing with kobject_add(). If the pairing is incorrrect, a WARNING
and backtrace occur in sysfs_remove_group() because there is no parent.
[ tglx: Add a comment to the code and make it work with CONFIG_SYSFS=n ]
Fixes: ecb3f394c5db ("genirq: Expose interrupt information through sysfs")
Signed-off-by: Michael Kelley <mikelley@microsoft.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Link: https://lkml.kernel.org/r/1564703564-4116-1-git-send-email-mikelley@microsoft.com
[ Upstream commit fdadd04931c2d7cd294dc5b2b342863f94be53a3 ]
Michael and Sandipan report:
Commit ede95a63b5 introduced a bpf_jit_limit tuneable to limit BPF
JIT allocations. At compile time it defaults to PAGE_SIZE * 40000,
and is adjusted again at init time if MODULES_VADDR is defined.
For ppc64 kernels, MODULES_VADDR isn't defined, so we're stuck with
the compile-time default at boot-time, which is 0x9c400000 when
using 64K page size. This overflows the signed 32-bit bpf_jit_limit
value:
root@ubuntu:/tmp# cat /proc/sys/net/core/bpf_jit_limit
-1673527296
and can cause various unexpected failures throughout the network
stack. In one case `strace dhclient eth0` reported:
setsockopt(5, SOL_SOCKET, SO_ATTACH_FILTER, {len=11, filter=0x105dd27f8},
16) = -1 ENOTSUPP (Unknown error 524)
and similar failures can be seen with tools like tcpdump. This doesn't
always reproduce however, and I'm not sure why. The more consistent
failure I've seen is an Ubuntu 18.04 KVM guest booted on a POWER9
host would time out on systemd/netplan configuring a virtio-net NIC
with no noticeable errors in the logs.
Given this and also given that in near future some architectures like
arm64 will have a custom area for BPF JIT image allocations we should
get rid of the BPF_JIT_LIMIT_DEFAULT fallback / default entirely. For
4.21, we have an overridable bpf_jit_alloc_exec(), bpf_jit_free_exec()
so therefore add another overridable bpf_jit_alloc_exec_limit() helper
function which returns the possible size of the memory area for deriving
the default heuristic in bpf_jit_charge_init().
Like bpf_jit_alloc_exec() and bpf_jit_free_exec(), the new
bpf_jit_alloc_exec_limit() assumes that module_alloc() is the default
JIT memory provider, and therefore in case archs implement their custom
module_alloc() we use MODULES_{END,_VADDR} for limits and otherwise for
vmalloc_exec() cases like on ppc64 we use VMALLOC_{END,_START}.
Additionally, for archs supporting large page sizes, we should change
the sysctl to be handled as long to not run into sysctl restrictions
in future.
Fixes: ede95a63b5e8 ("bpf: add bpf_jit_limit knob to restrict unpriv allocations")
Reported-by: Sandipan Das <sandipan@linux.ibm.com>
Reported-by: Michael Roth <mdroth@linux.vnet.ibm.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Tested-by: Michael Roth <mdroth@linux.vnet.ibm.com>
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
commit ede95a63b5e84ddeea6b0c473b36ab8bfd8c6ce3 upstream.
Rick reported that the BPF JIT could potentially fill the entire module
space with BPF programs from unprivileged users which would prevent later
attempts to load normal kernel modules or privileged BPF programs, for
example. If JIT was enabled but unsuccessful to generate the image, then
before commit 290af86629b2 ("bpf: introduce BPF_JIT_ALWAYS_ON config")
we would always fall back to the BPF interpreter. Nowadays in the case
where the CONFIG_BPF_JIT_ALWAYS_ON could be set, then the load will abort
with a failure since the BPF interpreter was compiled out.
Add a global limit and enforce it for unprivileged users such that in case
of BPF interpreter compiled out we fail once the limit has been reached
or we fall back to BPF interpreter earlier w/o using module mem if latter
was compiled in. In a next step, fair share among unprivileged users can
be resolved in particular for the case where we would fail hard once limit
is reached.
Fixes: 290af86629b2 ("bpf: introduce BPF_JIT_ALWAYS_ON config")
Fixes: 0a14842f5a3c ("net: filter: Just In Time compiler for x86-64")
Co-Developed-by: Rick Edgecombe <rick.p.edgecombe@intel.com>
Acked-by: Alexei Starovoitov <ast@kernel.org>
Cc: Jann Horn <jannh@google.com>
Cc: LKML <linux-kernel@vger.kernel.org>
[bwh: Backported to 4.9: adjust context]
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit fa9dd599b4dae841924b022768354cfde9affecb upstream.
Having a pure_initcall() callback just to permanently enable BPF
JITs under CONFIG_BPF_JIT_ALWAYS_ON is unnecessary and could leave
a small race window in future where JIT is still disabled on boot.
Since we know about the setting at compilation time anyway, just
initialize it properly there. Also consolidate all the individual
bpf_jit_enable variables into a single one and move them under one
location. Moreover, don't allow for setting unspecified garbage
values on them.
[bwh: Backported to 4.9 as dependency of commit 2e4a30983b0f
"bpf: restrict access to core bpf sysctls":
- Drop change in arch/mips/net/ebpf_jit.c
- Drop change to bpf_jit_kallsyms
- Adjust filenames, context]
[ Upstream commit 4ce54af8b33d3e21ca935fc1b89b58cbba956051 ]
Some hardware PMU drivers will override perf_event.cpu inside their
event_init callback. This causes a lockdep splat when initialized through
the kernel API:
WARNING: CPU: 0 PID: 250 at kernel/events/core.c:2917 ctx_sched_out+0x78/0x208
pc : ctx_sched_out+0x78/0x208
Call trace:
__perf_install_in_context+0x160/0x248
remote_function+0x58/0x68
generic_exec_single+0x100/0x180
smp_call_function_single+0x174/0x1b8
perf_install_in_context+0x178/0x188
perf_event_create_kernel_counter+0x118/0x160
Fix this by calling perf_install_in_context with event->cpu, just like
perf_event_open
Signed-off-by: Leonard Crestez <leonard.crestez@nxp.com>
Reviewed-by: Mark Rutland <mark.rutland@arm.com>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Cc: Frank Li <Frank.li@nxp.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Will Deacon <will@kernel.org>
Link: https://lkml.kernel.org/r/c4ebe0503623066896d7046def4d6b1e06e0eb2e.1563972056.git.leonard.crestez@nxp.com
[ Upstream commit 6e6de3dee51a439f76eb73c22ae2ffd2c9384712 ]
Microsoft HyperV disables the X86_FEATURE_SMCA bit on AMD systems, and
linux guests boot with repeated errors:
amd64_edac_mod: Unknown symbol amd_unregister_ecc_decoder (err -2)
amd64_edac_mod: Unknown symbol amd_register_ecc_decoder (err -2)
amd64_edac_mod: Unknown symbol amd_report_gart_errors (err -2)
The warnings occur because the module code erroneously returns -EEXIST
for modules that have failed to load and are in the process of being
removed from the module list.
module amd64_edac_mod has a dependency on module edac_mce_amd. Using
modules.dep, systemd will load edac_mce_amd for every request of
amd64_edac_mod. When the edac_mce_amd module loads, the module has
state MODULE_STATE_UNFORMED and once the module load fails and the state
becomes MODULE_STATE_GOING. Another request for edac_mce_amd module
executes and add_unformed_module() will erroneously return -EEXIST even
though the previous instance of edac_mce_amd has MODULE_STATE_GOING.
Upon receiving -EEXIST, systemd attempts to load amd64_edac_mod, which
fails because of unknown symbols from edac_mce_amd.
add_unformed_module() must wait to return for any case other than
MODULE_STATE_LIVE to prevent a race between multiple loads of
dependent modules.
Signed-off-by: Prarit Bhargava <prarit@redhat.com>
Signed-off-by: Barret Rhoden <brho@google.com>
Cc: David Arcari <darcari@redhat.com>
Cc: Jessica Yu <jeyu@kernel.org>
Signed-off-by: Jessica Yu <jeyu@kernel.org>
[ Upstream commit a124692b698b00026a58d89831ceda2331b2e1d0 ]
Custom trampolines can only be enabled if there is only a single ops
attached to it. If there's only a single callback registered to a function,
and the ops has a trampoline registered for it, then we can call the
trampoline directly. This is very useful for improving the performance of
ftrace and livepatch.
If more than one callback is registered to a function, the general
trampoline is used, and the custom trampoline is not restored back to the
direct call even if all the other callbacks were unregistered and we are
back to one callback for the function.
To fix this, set FTRACE_FL_TRAMP flag if rec count is decremented
to one, and the ops that left has a trampoline.
Testing After this patch :
insmod livepatch_unshare_files.ko
cat /sys/kernel/debug/tracing/enabled_functions
unshare_files (1) R I tramp: 0xffffffffc0000000(klp_ftrace_handler+0x0/0xa0) ->ftrace_ops_assist_func+0x0/0xf0
echo unshare_files > /sys/kernel/debug/tracing/set_ftrace_filter
echo function > /sys/kernel/debug/tracing/current_tracer
unshare_files (2) R I ->ftrace_ops_list_func+0x0/0x150
echo nop > /sys/kernel/debug/tracing/current_tracer
Link: http://lkml.kernel.org/r/1556969979-111047-1-git-send-email-cj.chengjian@huawei.com
Signed-off-by: Cheng Jian <cj.chengjian@huawei.com>
commit 16d51a590a8ce3befb1308e0e7ab77f3b661af33 upstream.
When going through execve(), zero out the NUMA fault statistics instead of
freeing them.
During execve, the task is reachable through procfs and the scheduler. A
concurrent /proc/*/sched reader can read data from a freed ->numa_faults
allocation (confirmed by KASAN) and write it back to userspace.
I believe that it would also be possible for a use-after-free read to occur
through a race between a NUMA fault and execve(): task_numa_fault() can
lead to task_numa_compare(), which invokes task_weight() on the currently
running task of a different CPU.
Another way to fix this would be to make ->numa_faults RCU-managed or add
extra locking, but it seems easier to wipe the NUMA fault statistics on
execve.
Signed-off-by: Jann Horn <jannh@google.com>
Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Fixes: 82727018b0d3 ("sched/numa: Call task_numa_free() from do_execve()")
Link: https://lkml.kernel.org/r/20190716152047.14424-1-jannh@google.com
commit d7852fbd0f0423937fa287a598bfde188bb68c22 upstream.
It turns out that 'access()' (and 'faccessat()') can cause a lot of RCU
work because it installs a temporary credential that gets allocated and
freed for each system call.
The allocation and freeing overhead is mostly benign, but because
credentials can be accessed under the RCU read lock, the freeing
involves a RCU grace period.
Which is not a huge deal normally, but if you have a lot of access()
calls, this causes a fair amount of seconday damage: instead of having a
nice alloc/free patterns that hits in hot per-CPU slab caches, you have
all those delayed free's, and on big machines with hundreds of cores,
the RCU overhead can end up being enormous.
But it turns out that all of this is entirely unnecessary. Exactly
because access() only installs the credential as the thread-local
subjective credential, the temporary cred pointer doesn't actually need
to be RCU free'd at all. Once we're done using it, we can just free it
synchronously and avoid all the RCU overhead.
So add a 'non_rcu' flag to 'struct cred', which can be set by users that
know they only use it in non-RCU context (there are other potential
users for this). We can make it a union with the rcu freeing list head
that we need for the RCU case, so this doesn't need any extra storage.
Note that this also makes 'get_current_cred()' clear the new non_rcu
flag, in case we have filesystems that take a long-term reference to the
cred and then expect the RCU delayed freeing afterwards. It's not
entirely clear that this is required, but it makes for clear semantics:
the subjective cred remains non-RCU as long as you only access it
synchronously using the thread-local accessors, but you _can_ use it as
a generic cred if you want to.
It is possible that we should just remove the whole RCU markings for
->cred entirely. Only ->real_cred is really supposed to be accessed
through RCU, and the long-term cred copies that nfs uses might want to
explicitly re-enable RCU freeing if required, rather than have
get_current_cred() do it implicitly.
But this is a "minimal semantic changes" change for the immediate
problem.
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Acked-by: Paul E. McKenney <paulmck@linux.ibm.com>
Cc: Jan Glauber <jglauber@marvell.com>
Cc: Jiri Kosina <jikos@kernel.org>
Cc: Jayachandran Chandrasekharan Nair <jnair@marvell.com>
Cc: Greg KH <greg@kroah.com>
Cc: Miklos Szeredi <miklos@szeredi.hu>
[ Upstream commit 68037aa78208f34bda4e5cd76c357f718b838cbb ]
The usage is now hidden in an #ifdef, so we need to move
the variable itself in there as well to avoid this warning:
kernel/locking/lockdep_proc.c:203:21: error: unused variable 'class' [-Werror,-Wunused-variable]
Cc: Bart Van Assche <bvanassche@acm.org>
Cc: Qian Cai <cai@lca.pw>
Cc: Waiman Long <longman@redhat.com>
Cc: Yuyang Du <duyuyang@gmail.com>
Cc: frederic@kernel.org
Fixes: 68d41d8c94a3 ("locking/lockdep: Fix lock used or unused stats error")
Link: https://lkml.kernel.org/r/20190715092809.736834-1-arnd@arndb.de
[ Upstream commit 68d41d8c94a31dfb8233ab90b9baf41a2ed2da68 ]
The stats variable nr_unused_locks is incremented every time a new lock
class is register and decremented when the lock is first used in
__lock_acquire(). And after all, it is shown and checked in lockdep_stats.
However, under configurations that either CONFIG_TRACE_IRQFLAGS or
CONFIG_PROVE_LOCKING is not defined:
The commit:
091806515124b20 ("locking/lockdep: Consolidate lock usage bit initialization")
missed marking the LOCK_USED flag at IRQ usage initialization because
as mark_usage() is not called. And the commit:
886532aee3cd42d ("locking/lockdep: Move mark_lock() inside CONFIG_TRACE_IRQFLAGS && CONFIG_PROVE_LOCKING")
further made mark_lock() not defined such that the LOCK_USED cannot be
marked at all when the lock is first acquired.
As a result, we fix this by not showing and checking the stats under such
configurations for lockdep_stats.
Reported-by: Qian Cai <cai@lca.pw>
Signed-off-by: Yuyang Du <duyuyang@gmail.com>
Cc: arnd@arndb.de
Link: https://lkml.kernel.org/r/20190709101522.9117-1-duyuyang@gmail.com
commit cf144f81a99d1a3928f90b0936accfd3f45c9a0a upstream.
Testing padata with the tcrypt module on a 5.2 kernel...
# modprobe tcrypt alg="pcrypt(rfc4106(gcm(aes)))" type=3
# modprobe tcrypt mode=211 sec=1
...produces this splat:
INFO: task modprobe:10075 blocked for more than 120 seconds.
Not tainted 5.2.0-base+ #16
modprobe D 0 10075 10064 0x80004080
Call Trace:
? __schedule+0x4dd/0x610
? ring_buffer_unlock_commit+0x23/0x100
schedule+0x6c/0x90
schedule_timeout+0x3b/0x320
? trace_buffer_unlock_commit_regs+0x4f/0x1f0
wait_for_common+0x160/0x1a0
? wake_up_q+0x80/0x80
{ crypto_wait_req } # entries in braces added by hand
{ do_one_aead_op }
{ test_aead_jiffies }
test_aead_speed.constprop.17+0x681/0xf30 [tcrypt]
do_test+0x4053/0x6a2b [tcrypt]
? 0xffffffffa00f4000
tcrypt_mod_init+0x50/0x1000 [tcrypt]
The second modprobe command never finishes because in padata_reorder,
CPU0's load of reorder_objects is executed before the unlocking store in
spin_unlock_bh(pd->lock), causing CPU0 to miss CPU1's increment:
CPU0 CPU1
padata_reorder padata_do_serial
LOAD reorder_objects // 0
INC reorder_objects // 1
padata_reorder
TRYLOCK pd->lock // failed
UNLOCK pd->lock
CPU0 deletes the timer before returning from padata_reorder and since no
other job is submitted to padata, modprobe waits indefinitely.
Add a pair of full barriers to guarantee proper ordering:
CPU0 CPU1
UNLOCK pd->lock
smp_mb()
INC reorder_objects
smp_mb__after_atomic()
padata_reorder
TRYLOCK pd->lock
smp_mb__after_atomic is needed so the read part of the trylock operation
comes after the INC, as Andrea points out. Thanks also to Andrea for
help with writing a litmus test.
Fixes: 16295bec6398 ("padata: Generic parallelization/serialization interface")
Signed-off-by: Daniel Jordan <daniel.m.jordan@oracle.com>
Cc: Andrea Parri <andrea.parri@amarulasolutions.com>
Cc: Boqun Feng <boqun.feng@gmail.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Paul E. McKenney <paulmck@linux.ibm.com>
Cc: Steffen Klassert <steffen.klassert@secunet.com>
Cc: linux-crypto@vger.kernel.org
commit 46cc0b44428d0f0e81f11ea98217fc0edfbeab07 upstream.
Current snapshot implementation swaps two ring_buffers even though their
sizes are different from each other, that can cause an inconsistency
between the contents of buffer_size_kb file and the current buffer size.
For example:
# cat buffer_size_kb
7 (expanded: 1408)
# echo 1 > events/enable
# grep bytes per_cpu/cpu0/stats
bytes: 1441020
# echo 1 > snapshot // current:1408, spare:1408
# echo 123 > buffer_size_kb // current:123, spare:1408
# echo 1 > snapshot // current:1408, spare:123
bytes: 1443700
123 // != current:1408
And also, a similar per-cpu case hits the following WARNING:
Reproducer:
# echo 1 > per_cpu/cpu0/snapshot
WARNING:
WARNING: CPU: 0 PID: 1946 at kernel/trace/trace.c:1607 update_max_tr_single.part.0+0x2b8/0x380
Modules linked in:
CPU: 0 PID: 1946 Comm: bash Not tainted 5.2.0-rc6 #20
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.12.0-2.fc30 04/01/2014
RIP: 0010:update_max_tr_single.part.0+0x2b8/0x380
Code: ff e8 dc da f9 ff 0f 0b e9 88 fe ff ff e8 d0 da f9 ff 44 89 ee bf f5 ff ff ff e8 33 dc f9 ff 41 83 fd f5 74 96 e8 b8 da f9 ff <0f> 0b eb 8d e8 af da f9 ff 0f 0b e9 bf fd ff ff e8 a3 da f9 ff 48
RSP: 0018:ffff888063e4fca0 EFLAGS: 00010093
RAX: ffff888066214380 RBX: ffffffff99850fe0 RCX: ffffffff964298a8
RDX: 0000000000000000 RSI: 00000000fffffff5 RDI: 0000000000000005
RBP: 1ffff1100c7c9f96 R08: ffff888066214380 R09: ffffed100c7c9f9b
R10: ffffed100c7c9f9a R11: 0000000000000003 R12: 0000000000000000
R13: 00000000ffffffea R14: ffff888066214380 R15: ffffffff99851060
FS: 00007f9f8173c700(0000) GS:ffff88806d000000(0000) knlGS:0000000000000000
CR2: 0000000000714dc0 CR3: 0000000066fa6000 CR4: 00000000000006f0
Call Trace:
? trace_array_printk_buf+0x140/0x140
? __mutex_lock_slowpath+0x10/0x10
tracing_snapshot_write+0x4c8/0x7f0
? trace_printk_init_buffers+0x60/0x60
? selinux_file_permission+0x3b/0x540
? tracer_preempt_off+0x38/0x506
__vfs_write+0x81/0x100
vfs_write+0x1e1/0x560
ksys_write+0x126/0x250
? __ia32_sys_read+0xb0/0xb0
? do_syscall_64+0x1f/0x390
do_syscall_64+0xc1/0x390
entry_SYSCALL_64_after_hwframe+0x49/0xbe
This patch adds resize_buffer_duplicate_size() to check if there is a
difference between current/spare buffer sizes and resize a spare buffer
if necessary.
Link: http://lkml.kernel.org/r/20190625012910.13109-1-devel@etsukata.com
Fixes: ad909e21bbe69 ("tracing: Add internal tracing_snapshot() functions")
Signed-off-by: Eiichi Tsukata <devel@etsukata.com>
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro1.iwamatsu@toshiba.co.jp>
[ Upstream commit a9314773a91a1d3b36270085246a6715a326ff00 ]
With CONFIG_PROC_FS=n the following warning is emitted:
kernel/time/timer_list.c:361:36: warning: unused variable
'timer_list_sops' [-Wunused-const-variable]
static const struct seq_operations timer_list_sops = {
Add #ifdef guard around procfs specific code.
Signed-off-by: Nathan Huckleberry <nhuck@google.com>
Reviewed-by: Nick Desaulniers <ndesaulniers@google.com>
Cc: john.stultz@linaro.org
Cc: sboyd@kernel.org
Cc: clang-built-linux@googlegroups.com
Link: https://github.com/ClangBuiltLinux/linux/issues/534
Link: https://lkml.kernel.org/r/20190614181604.112297-1-nhuck@google.com
[ Upstream commit d897a4ab11dc8a9fda50d2eccc081a96a6385998 ]
Don't allow the TAI-UTC offset of the system clock to be set by adjtimex()
to a value larger than 100000 seconds.
This prevents an overflow in the conversion to int, prevents the CLOCK_TAI
clock from getting too far ahead of the CLOCK_REALTIME clock, and it is
still large enough to allow leap seconds to be inserted at the maximum rate
currently supported by the kernel (once per day) for the next ~270 years,
however unlikely it is that someone can survive a catastrophic event which
slowed down the rotation of the Earth so much.
Reported-by: Weikang shi <swkhack@gmail.com>
Signed-off-by: Miroslav Lichvar <mlichvar@redhat.com>
Cc: John Stultz <john.stultz@linaro.org>
Cc: Prarit Bhargava <prarit@redhat.com>
Cc: Richard Cochran <richardcochran@gmail.com>
Cc: Stephen Boyd <sboyd@kernel.org>
Link: https://lkml.kernel.org/r/20190618154713.20929-1-mlichvar@redhat.com
[ Upstream commit aee450cbe482a8c2f6fa5b05b178ef8b8ff107ca ]
Compiling kernel/bpf/core.c with W=1 causes a flood of warnings:
kernel/bpf/core.c:1198:65: warning: initialized field overwritten [-Woverride-init]
1198 | #define BPF_INSN_3_TBL(x, y, z) [BPF_##x | BPF_##y | BPF_##z] = true
kernel/bpf/core.c:1087:2: note: in expansion of macro 'BPF_INSN_3_TBL'
1087 | INSN_3(ALU, ADD, X), \
kernel/bpf/core.c:1202:3: note: in expansion of macro 'BPF_INSN_MAP'
1202 | BPF_INSN_MAP(BPF_INSN_2_TBL, BPF_INSN_3_TBL),
kernel/bpf/core.c:1198:65: note: (near initialization for 'public_insntable[12]')
98 copies of the above.
The attached patch silences the warnings, because we *know* we're overwriting
the default initializer. That leaves bpf/core.c with only 6 other warnings,
which become more visible in comparison.
Acked-by: Andrii Nakryiko <andriin@fb.com>
[ Upstream commit d9349850e188b8b59e5322fda17ff389a1c0cd7d ]
The sequence
static DEFINE_WW_CLASS(test_ww_class);
struct ww_acquire_ctx ww_ctx;
struct ww_mutex ww_lock_a;
struct ww_mutex ww_lock_b;
struct ww_mutex ww_lock_c;
struct mutex lock_c;
ww_acquire_init(&ww_ctx, &test_ww_class);
ww_mutex_init(&ww_lock_a, &test_ww_class);
ww_mutex_init(&ww_lock_b, &test_ww_class);
ww_mutex_init(&ww_lock_c, &test_ww_class);
mutex_init(&lock_c);
ww_mutex_lock(&ww_lock_a, &ww_ctx);
mutex_lock(&lock_c);
ww_mutex_lock(&ww_lock_b, &ww_ctx);
ww_mutex_lock(&ww_lock_c, &ww_ctx);
mutex_unlock(&lock_c); (*)
ww_mutex_unlock(&ww_lock_c);
ww_mutex_unlock(&ww_lock_b);
ww_mutex_unlock(&ww_lock_a);
ww_acquire_fini(&ww_ctx); (**)
will trigger the following error in __lock_release() when calling
mutex_release() at **:
DEBUG_LOCKS_WARN_ON(depth <= 0)
The problem is that the hlock merging happening at * updates the
references for test_ww_class incorrectly to 3 whereas it should've
updated it to 4 (representing all the instances for ww_ctx and
ww_lock_[abc]).
Fix this by updating the references during merging correctly taking into
account that we can have non-zero references (both for the hlock that we
merge into another hlock or for the hlock we are merging into).
Signed-off-by: Imre Deak <imre.deak@intel.com>
Cc: =?UTF-8?q?Ville=20Syrj=C3=A4l=C3=A4?= <ville.syrjala@linux.intel.com>
Link: https://lkml.kernel.org/r/20190524201509.9199-2-imre.deak@intel.com
[ Upstream commit f9070dc94542093fd516ae4ccea17ef46a4362c5 ]
The locking in force_sig_info is not prepared to deal with a task that
exits or execs (as sighand may change). The is not a locking problem
in force_sig as force_sig is only built to handle synchronous
exceptions.
Further the function force_sig_info changes the signal state if the
signal is ignored, or blocked or if SIGNAL_UNKILLABLE will prevent the
delivery of the signal. The signal SIGKILL can not be ignored and can
not be blocked and SIGNAL_UNKILLABLE won't prevent it from being
delivered.
So using force_sig rather than send_sig for SIGKILL is confusing
and pointless.
Because it won't impact the sending of the signal and and because
using force_sig is wrong, replace force_sig with send_sig.
Cc: Daniel Lezcano <daniel.lezcano@free.fr>
Cc: Serge Hallyn <serge@hallyn.com>
Fixes: cf3f89214ef6 ("pidns: add reboot_pid_ns() to handle the reboot syscall")
[ Upstream commit 085ebfe937d7a7a5df1729f35a12d6d655fea68c ]
perf_sample_regs_user() uses 'current->mm' to test for the presence of
userspace, but this is insufficient, consider use_mm().
A better test is: '!(current->flags & PF_KTHREAD)', exec() clears
PF_KTHREAD after it sets the new ->mm but before it drops to userspace
for the first time.
Possibly obsoletes: bf05fc25f268 ("powerpc/perf: Fix oops when kthread execs user process")
Reported-by: Ravi Bangoria <ravi.bangoria@linux.vnet.ibm.com>
Reported-by: Young Xiao <92siuyang@gmail.com>
Acked-by: Will Deacon <will.deacon@arm.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
Cc: Stephane Eranian <eranian@google.com>
Fixes: 4018994f3d87 ("perf: Add ability to attach user level registers dump to sample")
commit 6994eefb0053799d2e07cd140df6c2ea106c41ee upstream.
Fix two issues:
When called for PTRACE_TRACEME, ptrace_link() would obtain an RCU
reference to the parent's objective credentials, then give that pointer
to get_cred(). However, the object lifetime rules for things like
struct cred do not permit unconditionally turning an RCU reference into
a stable reference.
PTRACE_TRACEME records the parent's credentials as if the parent was
acting as the subject, but that's not the case. If a malicious
unprivileged child uses PTRACE_TRACEME and the parent is privileged, and
at a later point, the parent process becomes attacker-controlled
(because it drops privileges and calls execve()), the attacker ends up
with control over two processes with a privileged ptrace relationship,
which can be abused to ptrace a suid binary and obtain root privileges.
Fix both of these by always recording the credentials of the process
that is requesting the creation of the ptrace relationship:
current_cred() can't change under us, and current is the proper subject
for access control.
This change is theoretically userspace-visible, but I am not aware of
any code that it will actually break.
Fixes: 64b875f7ac8a ("ptrace: Capture the ptracer's creds not PT_PTRACE_CAP")
Acked-by: Oleg Nesterov <oleg@redhat.com>
commit 1bf72720281770162c87990697eae1ba2f1d917a upstream.
Currently, if the user specifies an unsupported mitigation strategy on the
kernel command line, it will be ignored silently. The code will fall back
to the default strategy, possibly leaving the system more vulnerable than
expected.
This may happen due to e.g. a simple typo, or, for a stable kernel release,
because not all mitigation strategies have been backported.
Inform the user by printing a message.
Fixes: 98af8452945c5565 ("cpu/speculation: Add 'mitigations=' cmdline option")
Acked-by: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Ben Hutchings <ben@decadent.org.uk>
Link: https://lkml.kernel.org/r/20190516070935.22546-1-geert@linux-m68k.org
commit 0c97bf863efce63d6ab7971dad811601e6171d2f upstream.
Starting with GCC 9, -Warray-bounds detects cases when memset is called
starting on a member of a struct but the size to be cleared ends up
writing over further members.
Such a call happens in the trace code to clear, at once, all members
after and including `seq` on struct trace_iterator:
In function 'memset',
inlined from 'ftrace_dump' at kernel/trace/trace.c:8914:3:
./include/linux/string.h:344:9: warning: '__builtin_memset' offset
[8505, 8560] from the object at 'iter' is out of the bounds of
referenced subobject 'seq' with type 'struct trace_seq' at offset
4368 [-Warray-bounds]
344 | return __builtin_memset(p, c, size);
In order to avoid GCC complaining about it, we compute the address
ourselves by adding the offsetof distance instead of referring
directly to the member.
Since there are two places doing this clear (trace.c and trace_kdb.c),
take the chance to move the workaround into a single place in
the internal header.
Link: http://lkml.kernel.org/r/20190523124535.GA12931@gmail.com
Signed-off-by: Miguel Ojeda <miguel.ojeda.sandonis@gmail.com>
[ Removed unnecessary parenthesis around "iter" ]
[ Upstream commit 3f9fbe9bd86c534eba2faf5d840fd44c6049f50e ]
Similar to how decrementing rb->next too early can cause data_head to
(temporarily) be observed to go backward, so too can this happen when
we increment too late.
This barrier() ensures the rb->head load happens after the increment,
both the one in the 'goto again' path, as the one from
perf_output_get_handle() -- albeit very unlikely to matter for the
latter.
Suggested-by: Yabin Cui <yabinc@google.com>
Cc: Vince Weaver <vincent.weaver@maine.edu>
Cc: acme@kernel.org
Cc: mark.rutland@arm.com
Cc: namhyung@kernel.org
Fixes: ef60777c9abd ("perf: Optimize the perf_output() path by removing IRQ-disables")
Link: http://lkml.kernel.org/r/20190517115418.309516009@infradead.org
[ Upstream commit 1b038c6e05ff70a1e66e3e571c2e6106bdb75f53 ]
In perf_output_put_handle(), an IRQ/NMI can happen in below location and
write records to the same ring buffer:
local_dec_and_test(&rb->nest)
... <-- an IRQ/NMI can happen here
rb->user_page->data_head = head;
In this case, a value A is written to data_head in the IRQ, then a value
B is written to data_head after the IRQ. And A > B. As a result,
data_head is temporarily decreased from A to B. And a reader may see
data_head < data_tail if it read the buffer frequently enough, which
creates unexpected behaviors.
This can be fixed by moving dec(&rb->nest) to after updating data_head,
which prevents the IRQ/NMI above from updating data_head.
[ Split up by peterz. ]
Signed-off-by: Yabin Cui <yabinc@google.com>
Link: http://lkml.kernel.org/r/20190517115418.224478157@infradead.org
[ Upstream commit 40ea97290b08be2e038b31cbb33097d1145e8169 ]
New tooling noticed this mishap:
kernel/kcov.o: warning: objtool: write_comp_data()+0x138: call to __stack_chk_fail() with UACCESS enabled
kernel/kcov.o: warning: objtool: __sanitizer_cov_trace_pc()+0xd9: call to __stack_chk_fail() with UACCESS enabled
All the other instrumentation (KASAN,UBSAN) also have stack protector
disabled.
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
commit f6581f5b55141a95657ef5742cf6a6bfa20a109f upstream.
Restore the read memory barrier in __ptrace_may_access() that was deleted
a couple years ago. Also add comments on this barrier and the one it pairs
with to explain why they're there (as far as I understand).
Fixes: bfedb589252c ("mm: Add a user_ns owner to mm_struct and fix ptrace permission checks")
[ Upstream commit f6e2aa91a46d2bc79fce9b93a988dbe7655c90c0 ]
Recently syzbot in conjunction with KMSAN reported that
ptrace_peek_siginfo can copy an uninitialized siginfo to userspace.
Inspecting ptrace_peek_siginfo confirms this.
The problem is that off when initialized from args.off can be
initialized to a negaive value. At which point the "if (off >= 0)"
test to see if off became negative fails because off started off
negative.
Prevent the core problem by adding a variable found that is only true
if a siginfo is found and copied to a temporary in preparation for
being copied to userspace.
Prevent args.off from being truncated when being assigned to off by
testing that off is <= the maximum possible value of off. Convert off
to an unsigned long so that we should not have to truncate args.off,
we have well defined overflow behavior so if we add another check we
won't risk fighting undefined compiler behavior, and so that we have a
type whose maximum value is easy to test for.
Cc: Andrei Vagin <avagin@gmail.com>
Reported-by: syzbot+0d602a1b0d8c95bdf299@syzkaller.appspotmail.com
Fixes: 84c751bd4aeb ("ptrace: add ability to retrieve signals without removing from a queue (v4)")
