path: root/kernel
2013-09-03export handle_edge_irq,irq_set_chip_and_handler_nameTroy Kisky
2013-06-03ENGR00265061 System hang when running the game lsh.emu.apkguoyin.chen
The game will creat a lot of hr timer, and make cpu tick broadcast bit not been clear all time. It will cause user space thread not been scheduled. Signed-off-by: guoyin.chen <guoyin.chen@freescale.com>
2013-03-06ENGR00251209-8 usb: fix the build error when building usb as loadable modulePeter Chen
export usb_suspend, usb_resume, and pm_mutex Signed-off-by: Peter Chen <peter.chen@freescale.com>
2013-03-01timer: fix the too many reries on the per-cpu event deviceJason Liu
There are so many retries happen on the per-cpu event device when run the command 'cat /proc/timer_list', as following: root@~$ cat /proc/timer_list Timer List Version: v0.6 HRTIMER_MAX_CLOCK_BASES: 3 now at 3297691988044 nsecs Tick Device: mode: 1 Per CPU device: 0 Clock Event Device: local_timer max_delta_ns: 8624432320 min_delta_ns: 1000 mult: 2138893713 shift: 32 mode: 3 next_event: 3297700000000 nsecs set_next_event: twd_set_next_event set_mode: twd_set_mode event_handler: hrtimer_interrupt retries: 36383 the reason is that the local timer will stop when enter C3 state, we need switch the local timer to bc timer when enter the state and switch back when exit from the that state.The code is like this: void arch_idle(void) { .... clockevents_notify(CLOCK_EVT_NOTIFY_BROADCAST_ENTER, &cpu); enter_the_wait_mode(); clockevents_notify(CLOCK_EVT_NOTIFY_BROADCAST_EXIT, &cpu); } when the broadcast timer interrupt arrives(this interrupt just wakeup the ARM, and ARM has no chance to handle it since local irq is disabled. In fact it's disabled in cpu_idle() of arch/arm/kernel/process.c) the broadcast timer interrupt will wake up the CPU and run: clockevents_notify(CLOCK_EVT_NOTIFY_BROADCAST_EXIT, &cpu); -> tick_broadcast_oneshot_control(...); -> tick_program_event(dev->next_event, 1); -> tick_dev_program_event(dev, expires, force); -> for (i = 0;;) { int ret = clockevents_program_event(dev, expires, now); if (!ret || !force) return ret; dev->retries++; .... now = ktime_get(); expires = ktime_add_ns(now, dev->min_delta_ns); } clockevents_program_event(dev, expires, now); delta = ktime_to_ns(ktime_sub(expires, now)); if (delta <= 0) return -ETIME; when the bc timer interrupt arrives, which means the last local timer expires too. so, clockevents_program_event will return -ETIME, which will cause the dev->retries++ when retry to program the expired timer. Even under the worst case, after the re-program the expired timer, then CPU enter idle quickly before the re-progam timer expired, it will make system ping-pang forever if no interrupt happen. We have found the ping-pang issue during the video play-back test. system will freeze and video not playing for sometime until other interrupt occured to break the error condition. The detailed information, please refer to the LKML:https://lkml.org/lkml/2013/2/20/216 which posted by Jason Liu. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Jason Liu <r64343@freescale.com> Tested-by: Jason Liu <r64343@freescale.com> Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
2012-07-20nohz: Remove "Switched to NOHz mode" debugging messagesHeiko Carstens
When performing cpu hotplug tests the kernel printk log buffer gets flooded with pointless "Switched to NOHz mode..." messages. Especially when afterwards analyzing a dump this might have removed more interesting stuff out of the buffer. Assuming that switching to NOHz mode simply works just remove the printk. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Link: http://lkml.kernel.org/r/20110823112046.GB2540@osiris.boeblingen.de.ibm.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-07-20sched: Cleanup cpu_active madnessPeter Zijlstra
Stepan found: CPU0 CPUn _cpu_up() __cpu_up() boostrap() notify_cpu_starting() set_cpu_online() while (!cpu_active()) cpu_relax() <PREEMPT-out> smp_call_function(.wait=1) /* we find cpu_online() is true */ arch_send_call_function_ipi_mask() /* wait-forever-more */ <PREEMPT-in> local_irq_enable() cpu_notify(CPU_ONLINE) sched_cpu_active() set_cpu_active() Now the purpose of cpu_active is mostly with bringing down a cpu, where we mark it !active to avoid the load-balancer from moving tasks to it while we tear down the cpu. This is required because we only update the sched_domain tree after we brought the cpu-down. And this is needed so that some tasks can still run while we bring it down, we just don't want new tasks to appear. On cpu-up however the sched_domain tree doesn't yet include the new cpu, so its invisible to the load-balancer, regardless of the active state. So instead of setting the active state after we boot the new cpu (and consequently having to wait for it before enabling interrupts) set the cpu active before we set it online and avoid the whole mess. Reported-by: Stepan Moskovchenko <stepanm@codeaurora.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1323965362.18942.71.camel@twins Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-07-20futex: Simplify return logicThomas Gleixner
No need to assign ret in each case and break. Simply return the result of the handler function directly. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Darren Hart <dvhart@linux.intel.com> Signed-off-by: Huang Shijie <b32955@freescale.com>
2012-07-20ENGR00177745-1 Add interactive cpufreq governorAnson Huang
cpufreq: interactive: New 'interactive' governor This governor is designed for latency-sensitive workloads, such as interactive user interfaces. The interactive governor aims to be significantly more responsive to ramp CPU quickly up when CPU-intensive activity begins. Existing governors sample CPU load at a particular rate, typically every X ms. This can lead to under-powering UI threads for the period of time during which the user begins interacting with a previously-idle system until the next sample period happens. The 'interactive' governor uses a different approach. Instead of sampling the CPU at a specified rate, the governor will check whether to scale the CPU frequency up soon after coming out of idle. When the CPU comes out of idle, a timer is configured to fire within 1-2 ticks. If the CPU is very busy from exiting idle to when the timer fires then we assume the CPU is underpowered and ramp to MAX speed. If the CPU was not sufficiently busy to immediately ramp to MAX speed, then the governor evaluates the CPU load since the last speed adjustment, choosing the highest value between that longer-term load or the short-term load since idle exit to determine the CPU speed to ramp to. A realtime thread is used for scaling up, giving the remaining tasks the CPU performance benefit, unlike existing governors which are more likely to schedule rampup work to occur after your performance starved tasks have completed. The tuneables for this governor are: /sys/devices/system/cpu/cpufreq/interactive/min_sample_time: The minimum amount of time to spend at the current frequency before ramping down. This is to ensure that the governor has seen enough historic CPU load data to determine the appropriate workload. /sys/devices/system/cpu/cpufreq/interactive/go_maxspeed_load The CPU load at which to ramp to max speed. Signed-off-by: Anson Huang <b20788@freescale.com>
2012-07-20futex: Fix spelling in a source code commentBart Van Assche
Change a single occurrence of "unlcoked" into "unlocked". Signed-off-by: Bart Van Assche <bvanassche@acm.org> Cc: Darren Hart <dvhltc@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-07-20futex: uninitialized warning correctionsVitaliy Ivanov
The variables here are really not used uninitialized. kernel/futex.c: In function 'fixup_pi_state_owner.clone.17': kernel/futex.c:1582:6: warning: 'curval' may be used uninitialized in this function kernel/futex.c: In function 'handle_futex_death': kernel/futex.c:2486:6: warning: 'nval' may be used uninitialized in this function kernel/futex.c: In function 'do_futex': kernel/futex.c:863:11: warning: 'curval' may be used uninitialized in this function kernel/futex.c:828:6: note: 'curval' was declared here kernel/futex.c:898:5: warning: 'oldval' may be used uninitialized in this function kernel/futex.c:890:6: note: 'oldval' was declared here Signed-off-by: Vitaliy Ivanov <vitalivanov@gmail.com> Acked-by: Darren Hart <dvhart@linux.intel.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-07-20plist: Remove the need to supply locks to plist headsDima Zavin
This was legacy code brought over from the RT tree and is no longer necessary. Signed-off-by: Dima Zavin <dima@android.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Daniel Walker <dwalker@codeaurora.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Andi Kleen <andi@firstfloor.org> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Link: http://lkml.kernel.org/r/1310084879-10351-2-git-send-email-dima@android.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-07-20ENGR00156637 [MX6]Reboot take long time on SMPAnson Huang
Add work around to the reboot issue of SMP, with SMP, all the CPUs need to do _rcu_barrier, if we enqueue an rcu callback, we need to make sure CPU tick to stay alive until we take care of those by completing the appropriate grace period. This work around only work when the reboot command issue, so it didn't impact normal kernel feature. Signed-off-by: Anson Huang <b20788@freescale.com>
2012-07-20ENGR00133978 PM: add time sensitive debug function to suspend & resumeZhang Jiejing
There was some driver is slow on suspend/resume, but some embeded system like eReader,Cellphone are time sensitive,this commit will report the slow driver on suspend/resume, the default value is 500us(0.5ms) Also, the threshold can be change by modify '/sys/power/device_suspend_time_threshold' to change the threshold, it is in microsecond. The output is like: PM: device platform:soc-audio.2 suspend too slow, takes 606.696 msecs PM: device platform:mxc_sdc_fb.1 suspend too slow, takes 7.708 msecs the default state of suspend driver is default off, if you want to debug the suspend time, echo time in microsecond(u Second) to /sys/powe/device_suspend_time_threshold eg: I want to know which driver suspend & resume takes more that 0.5 ms (500 us), you can just : ehco 500 > /sys/power/device_suspend_time_threshold Signed-off-by: Zhang Jiejing <jiejing.zhang@freescale.com>
2012-06-17sched: Fix the relax_domain_level boot parameterDimitri Sivanich
commit a841f8cef4bb124f0f5563314d0beaf2e1249d72 upstream. It does not get processed because sched_domain_level_max is 0 at the time that setup_relax_domain_level() is run. Simply accept the value as it is, as we don't know the value of sched_domain_level_max until sched domain construction is completed. Fix sched_relax_domain_level in cpuset. The build_sched_domain() routine calls the set_domain_attribute() routine prior to setting the sd->level, however, the set_domain_attribute() routine relies on the sd->level to decide whether idle load balancing will be off/on. Signed-off-by: Dimitri Sivanich <sivanich@sgi.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20120605184436.GA15668@sgi.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-01workqueue: skip nr_running sanity check in worker_enter_idle() if trustee is ↵Tejun Heo
active commit 544ecf310f0e7f51fa057ac2a295fc1b3b35a9d3 upstream. worker_enter_idle() has WARN_ON_ONCE() which triggers if nr_running isn't zero when every worker is idle. This can trigger spuriously while a cpu is going down due to the way trustee sets %WORKER_ROGUE and zaps nr_running. It first sets %WORKER_ROGUE on all workers without updating nr_running, releases gcwq->lock, schedules, regrabs gcwq->lock and then zaps nr_running. If the last running worker enters idle inbetween, it would see stale nr_running which hasn't been zapped yet and trigger the WARN_ON_ONCE(). Fix it by performing the sanity check iff the trustee is idle. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21compat: Fix RT signal mask corruption via sigprocmaskJan Kiszka
commit b7dafa0ef3145c31d7753be0a08b3cbda51f0209 upstream. compat_sys_sigprocmask reads a smaller signal mask from userspace than sigprogmask accepts for setting. So the high word of blocked.sig[0] will be cleared, releasing any potentially blocked RT signal. This was discovered via userspace code that relies on get/setcontext. glibc's i386 versions of those functions use sigprogmask instead of rt_sigprogmask to save/restore signal mask and caused RT signal unblocking this way. As suggested by Linus, this replaces the sys_sigprocmask based compat version with one that open-codes the required logic, including the merge of the existing blocked set with the new one provided on SIG_SETMASK. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21namespaces, pid_ns: fix leakage on fork() failureMike Galbraith
commit 5e2bf0142231194d36fdc9596b36a261ed2b9fe7 upstream. Fork() failure post namespace creation for a child cloned with CLONE_NEWPID leaks pid_namespace/mnt_cache due to proc being mounted during creation, but not unmounted during cleanup. Call pid_ns_release_proc() during cleanup. Signed-off-by: Mike Galbraith <efault@gmx.de> Acked-by: Oleg Nesterov <oleg@redhat.com> Reviewed-by: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Louis Rilling <louis.rilling@kerlabs.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-07sched: Fix nohz load accounting -- again!Peter Zijlstra
commit c308b56b5398779cd3da0f62ab26b0453494c3d4 upstream. [ backported to 3.0 by Kerin Millar <kerframil@gmail.com>] Various people reported nohz load tracking still being wrecked, but Doug spotted the actual problem. We fold the nohz remainder in too soon, causing us to loose samples and under-account. So instead of playing catch-up up-front, always do a single load-fold with whatever state we encounter and only then fold the nohz remainder and play catch-up. Reported-by: Doug Smythies <dsmythies@telus.net> Reported-by: LesÅ=82aw Kope=C4=87 <leslaw.kopec@nasza-klasa.pl> Reported-by: Aman Gupta <aman@tmm1.net> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/n/tip-4v31etnhgg9kwd6ocgx3rxl8@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Kerin Millar <kerframil@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-22futex: Do not leak robust list to unprivileged processKees Cook
commit bdbb776f882f5ad431aa1e694c69c1c3d6a4a5b8 upstream. It was possible to extract the robust list head address from a setuid process if it had used set_robust_list(), allowing an ASLR info leak. This changes the permission checks to be the same as those used for similar info that comes out of /proc. Running a setuid program that uses robust futexes would have had: cred->euid != pcred->euid cred->euid == pcred->uid so the old permissions check would allow it. I'm not aware of any setuid programs that use robust futexes, so this is just a preventative measure. (This patch is based on changes from grsecurity.) Signed-off-by: Kees Cook <keescook@chromium.org> Cc: Darren Hart <dvhart@linux.intel.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: David Howells <dhowells@redhat.com> Cc: Serge E. Hallyn <serge.hallyn@canonical.com> Cc: kernel-hardening@lists.openwall.com Cc: spender@grsecurity.net Link: http://lkml.kernel.org/r/20120319231253.GA20893@www.outflux.net Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-22nohz: Fix stale jiffies update in tick_nohz_restart()Neal Cardwell
commit 6f103929f8979d2638e58d7f7fda0beefcb8ee7e upstream. Fix tick_nohz_restart() to not use a stale ktime_t "now" value when calling tick_do_update_jiffies64(now). If we reach this point in the loop it means that we crossed a tick boundary since we grabbed the "now" timestamp, so at this point "now" refers to a time in the old jiffy, so using the old value for "now" is incorrect, and is likely to give us a stale jiffies value. In particular, the first time through the loop the tick_do_update_jiffies64(now) call is always a no-op, since the caller, tick_nohz_restart_sched_tick(), will have already called tick_do_update_jiffies64(now) with that "now" value. Note that tick_nohz_stop_sched_tick() already uses the correct approach: when we notice we cross a jiffy boundary, grab a new timestamp with ktime_get(), and *then* update jiffies. Signed-off-by: Neal Cardwell <ncardwell@google.com> Cc: Ben Segall <bsegall@google.com> Cc: Ingo Molnar <mingo@elte.hu> Link: http://lkml.kernel.org/r/1332875377-23014-1-git-send-email-ncardwell@google.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13cred: copy_process() should clear child->replacement_session_keyringOleg Nesterov
commit 79549c6dfda0603dba9a70a53467ce62d9335c33 upstream. keyctl_session_to_parent(task) sets ->replacement_session_keyring, it should be processed and cleared by key_replace_session_keyring(). However, this task can fork before it notices TIF_NOTIFY_RESUME and the new child gets the bogus ->replacement_session_keyring copied by dup_task_struct(). This is obviously wrong and, if nothing else, this leads to put_cred(already_freed_cred). change copy_creds() to clear this member. If copy_process() fails before this point the wrong ->replacement_session_keyring doesn't matter, exit_creds() won't be called. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13sysctl: fix write access to dmesg_restrict/kptr_restrictKees Cook
commit 620f6e8e855d6d447688a5f67a4e176944a084e8 upstream. Commit bfdc0b4 adds code to restrict access to dmesg_restrict, however, it incorrectly alters kptr_restrict rather than dmesg_restrict. The original patch from Richard Weinberger (https://lkml.org/lkml/2011/3/14/362) alters dmesg_restrict as expected, and so the patch seems to have been misapplied. This adds the CAP_SYS_ADMIN check to both dmesg_restrict and kptr_restrict, since both are sensitive. Reported-by: Phillip Lougher <plougher@redhat.com> Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Acked-by: Richard Weinberger <richard@nod.at> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13kgdb,debug_core: pass the breakpoint struct instead of address and memoryJason Wessel
commit 98b54aa1a2241b59372468bd1e9c2d207bdba54b upstream. There is extra state information that needs to be exposed in the kgdb_bpt structure for tracking how a breakpoint was installed. The debug_core only uses the the probe_kernel_write() to install breakpoints, but this is not enough for all the archs. Some arch such as x86 need to use text_poke() in order to install a breakpoint into a read only page. Passing the kgdb_bpt structure to kgdb_arch_set_breakpoint() and kgdb_arch_remove_breakpoint() allows other archs to set the type variable which indicates how the breakpoint was installed. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13tracing: Fix ftrace stack trace entriesWolfgang Mauerer
commit 01de982abf8c9e10fc3089e10585cd2cc914bdab upstream. 8 hex characters tell only half the tale for 64 bit CPUs, so use the appropriate length. Link: http://lkml.kernel.org/r/1332411501-8059-2-git-send-email-wolfgang.mauerer@siemens.com Signed-off-by: Wolfgang Mauerer <wolfgang.mauerer@siemens.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13genirq: Adjust irq thread affinity on IRQ_SET_MASK_OK_NOCOPY return valueJiang Liu
commit f5cb92ac82d06cb583c1f66666314c5c0a4d7913 upstream. irq_move_masked_irq() checks the return code of chip->irq_set_affinity() only for 0, but IRQ_SET_MASK_OK_NOCOPY is also a valid return code, which is there to avoid a redundant copy of the cpumask. But in case of IRQ_SET_MASK_OK_NOCOPY we not only avoid the redundant copy, we also fail to adjust the thread affinity of an eventually threaded interrupt handler. Handle IRQ_SET_MASK_OK (==0) and IRQ_SET_MASK_OK_NOCOPY(==1) return values correctly by checking the valid return values seperately. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Cc: Jiang Liu <liuj97@gmail.com> Cc: Keping Chen <chenkeping@huawei.com> Link: http://lkml.kernel.org/r/1333120296-13563-2-git-send-email-jiang.liu@huawei.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02module: Remove module size limitSasha Levin
commit f946eeb9313ff1470758e171a60fe7438a2ded3f upstream. Module size was limited to 64MB, this was legacy limitation due to vmalloc() which was removed a while ago. Limiting module size to 64MB is both pointless and affects real world use cases. Cc: Tim Abbott <tim.abbott@oracle.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02PM / Hibernate: Enable usermodehelpers in hibernate() error pathSrivatsa S. Bhat
commit 05b4877f6a4f1ba4952d1222213d262bf8c132b7 upstream. If create_basic_memory_bitmaps() fails, usermodehelpers are not re-enabled before returning. Fix this. And while at it, reword the goto labels so that they look more meaningful. Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02genirq: Fix incorrect check for forced IRQ thread handlerAlexander Gordeev
commit 540b60e24f3f4781d80e47122f0c4486a03375b8 upstream. We do not want a bitwise AND between boolean operands Signed-off-by: Alexander Gordeev <agordeev@redhat.com> Cc: Oleg Nesterov <oleg@redhat.com> Link: http://lkml.kernel.org/r/20120309135912.GA2114@dhcp-26-207.brq.redhat.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02genirq: Fix long-term regression in genirq irq_set_irq_type() handlingRussell King
commit a09b659cd68c10ec6a30cb91ebd2c327fcd5bfe5 upstream. In 2008, commit 0c5d1eb77a8be ("genirq: record trigger type") modified the way set_irq_type() handles the 'no trigger' condition. However, this has an adverse effect on PCMCIA support on Intel StrongARM and probably PXA platforms. PCMCIA has several status signals on the socket which can trigger interrupts; some of these status signals depend on the card's mode (whether it is configured in memory or IO mode). For example, cards have a 'Ready/IRQ' signal: in memory mode, this provides an indication to PCMCIA that the card has finished its power up initialization. In IO mode, it provides the device interrupt signal. Other status signals switch between on-board battery status and loud speaker output. In classical PCMCIA implementations, where you have a specific socket controller, the controller provides a method to mask interrupts from the socket, and importantly ignore any state transitions on the pins which correspond with interrupts once masked. This masking prevents unwanted events caused by the removal and application of socket power being forwarded. However, on platforms where there is no socket controller, the PCMCIA status and interrupt signals are routed to standard edge-triggered GPIOs. These GPIOs can be configured to interrupt on rising edge, falling edge, or never. This is where the problems start. Edge triggered interrupts are required to record events while disabled via the usual methods of {free,request,disable,enable}_irq() to prevent problems with dropped interrupts (eg, the 8390 driver uses disable_irq() to defer the delivery of interrupts). As a result, these interfaces can not be used to implement the desired behaviour. The side effect of this is that if the 'Ready/IRQ' GPIO is disabled via disable_irq() on suspend, and enabled via enable_irq() after resume, we will record the state transitions caused by powering events as valid interrupts, and foward them to the card driver, which may attempt to access a card which is not powered up. This leads delays resume while drivers spin in their interrupt handlers, and complaints from drivers before they realize what's happened. Moreover, in the case of the 'Ready/IRQ' signal, this is requested and freed by the card driver itself; the PCMCIA core has no idea whether the interrupt is requested, and, therefore, whether a call to disable_irq() would be valid. (We tried this around 2.4.17 / 2.5.1 kernel era, and ended up throwing it out because of this problem.) Therefore, it was decided back in around 2002 to disable the edge triggering instead, resulting in all state transitions on the GPIO being ignored. That's what we actually need the hardware to do. The commit above changes this behaviour; it explicitly prevents the 'no trigger' state being selected. The reason that request_irq() does not accept the 'no trigger' state is for compatibility with existing drivers which do not provide their desired triggering configuration. The set_irq_type() function is 'new' and not used by non-trigger aware drivers. Therefore, revert this change, and restore previously working platforms back to their former state. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Cc: linux@arm.linux.org.uk Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02ntp: Fix integer overflow when setting timeSasha Levin
commit a078c6d0e6288fad6d83fb6d5edd91ddb7b6ab33 upstream. 'long secs' is passed as divisor to div_s64, which accepts a 32bit divisor. On 64bit machines that value is trimmed back from 8 bytes back to 4, causing a divide by zero when the number is bigger than (1 << 32) - 1 and all 32 lower bits are 0. Use div64_long() instead. Signed-off-by: Sasha Levin <levinsasha928@gmail.com> Cc: johnstul@us.ibm.com Link: http://lkml.kernel.org/r/1331829374-31543-2-git-send-email-levinsasha928@gmail.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02futex: Cover all PI opcodes with cmpxchg enabled checkThomas Gleixner
commit 59263b513c11398cd66a52d4c5b2b118ce1e0359 upstream. Some of the newer futex PI opcodes do not check the cmpxchg enabled variable and call unconditionally into the handling functions. Cover all PI opcodes in a separate check. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Darren Hart <dvhart@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19Block: use a freezable workqueue for disk-event pollingAlan Stern
commit 62d3c5439c534b0e6c653fc63e6d8c67be3a57b1 upstream. This patch (as1519) fixes a bug in the block layer's disk-events polling. The polling is done by a work routine queued on the system_nrt_wq workqueue. Since that workqueue isn't freezable, the polling continues even in the middle of a system sleep transition. Obviously, polling a suspended drive for media changes and such isn't a good thing to do; in the case of USB mass-storage devices it can lead to real problems requiring device resets and even re-enumeration. The patch fixes things by creating a new system-wide, non-reentrant, freezable workqueue and using it for disk-events polling. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12kprobes: adjust "fix a memory leak in function pre_handler_kretprobe()"Jan Beulich
3.0.21's 603b63484725a6e88e4ae5da58716efd88154b1e directly used the upstream patch, yet kprobes locking in 3.0.x uses spin_lock...() rather than raw_spin_lock...(). Signed-off-by: Jan Beulich <jbeulich@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12genirq: Clear action->thread_mask if IRQ_ONESHOT is not setThomas Gleixner
commit 52abb700e16a9aa4cbc03f3d7f80206cbbc80680 upstream. Xommit ac5637611(genirq: Unmask oneshot irqs when thread was not woken) fails to unmask when a !IRQ_ONESHOT threaded handler is handled by handle_level_irq. This happens because thread_mask is or'ed unconditionally in irq_wake_thread(), but for !IRQ_ONESHOT interrupts never cleared. So the check for !desc->thread_active fails and keeps the interrupt disabled. Keep the thread_mask zero for !IRQ_ONESHOT interrupts. Document the thread_mask magic while at it. Reported-and-tested-by: Sven Joachim <svenjoac@gmx.de> Reported-and-tested-by: Stefan Lippers-Hollmann <s.l-h@gmx.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29epoll: introduce POLLFREE to flush ->signalfd_wqh before kfree()Oleg Nesterov
commit d80e731ecab420ddcb79ee9d0ac427acbc187b4b upstream. This patch is intentionally incomplete to simplify the review. It ignores ep_unregister_pollwait() which plays with the same wqh. See the next change. epoll assumes that the EPOLL_CTL_ADD'ed file controls everything f_op->poll() needs. In particular it assumes that the wait queue can't go away until eventpoll_release(). This is not true in case of signalfd, the task which does EPOLL_CTL_ADD uses its ->sighand which is not connected to the file. This patch adds the special event, POLLFREE, currently only for epoll. It expects that init_poll_funcptr()'ed hook should do the necessary cleanup. Perhaps it should be defined as EPOLLFREE in eventpoll. __cleanup_sighand() is changed to do wake_up_poll(POLLFREE) if ->signalfd_wqh is not empty, we add the new signalfd_cleanup() helper. ep_poll_callback(POLLFREE) simply does list_del_init(task_list). This make this poll entry inconsistent, but we don't care. If you share epoll fd which contains our sigfd with another process you should blame yourself. signalfd is "really special". I simply do not know how we can define the "right" semantics if it used with epoll. The main problem is, epoll calls signalfd_poll() once to establish the connection with the wait queue, after that signalfd_poll(NULL) returns the different/inconsistent results depending on who does EPOLL_CTL_MOD/signalfd_read/etc. IOW: apart from sigmask, signalfd has nothing to do with the file, it works with the current thread. In short: this patch is the hack which tries to fix the symptoms. It also assumes that nobody can take tasklist_lock under epoll locks, this seems to be true. Note: - we do not have wake_up_all_poll() but wake_up_poll() is fine, poll/epoll doesn't use WQ_FLAG_EXCLUSIVE. - signalfd_cleanup() uses POLLHUP along with POLLFREE, we need a couple of simple changes in eventpoll.c to make sure it can't be "lost". Reported-by: Maxime Bizon <mbizon@freebox.fr> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29genirq: Handle pending irqs in irq_startup()Thomas Gleixner
commit b4bc724e82e80478cba5fe9825b62e71ddf78757 upstream. An interrupt might be pending when irq_startup() is called, but the startup code does not invoke the resend logic. In some cases this prevents the device from issuing another interrupt which renders the device non functional. Call the resend function in irq_startup() to keep things going. Reported-and-tested-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29genirq: Unmask oneshot irqs when thread was not wokenThomas Gleixner
commit ac5637611150281f398bb7a47e3fcb69a09e7803 upstream. When the primary handler of an interrupt which is marked IRQ_ONESHOT returns IRQ_HANDLED or IRQ_NONE, then the interrupt thread is not woken and the unmask logic of the interrupt line is never invoked. This keeps the interrupt masked forever. This was not noticed as most IRQ_ONESHOT users wake the thread unconditionally (usually because they cannot access the underlying device from hard interrupt context). Though this behaviour was nowhere documented and not necessarily intentional. Some drivers can avoid the thread wakeup in certain cases and run into the situation where the interrupt line s kept masked. Handle it gracefully. Reported-and-tested-by: Lothar Wassmann <lw@karo-electronics.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-20relay: prevent integer overflow in relay_open()Dan Carpenter
commit f6302f1bcd75a042df69866d98b8d775a668f8f1 upstream. "subbuf_size" and "n_subbufs" come from the user and they need to be capped to prevent an integer overflow. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-13lockdep, bug: Exclude TAINT_FIRMWARE_WORKAROUND from disabling lockdepPeter Zijlstra
commit df754e6af2f237a6c020c0daff55a1a609338e31 upstream. It's unlikely that TAINT_FIRMWARE_WORKAROUND causes false lockdep messages, so do not disable lockdep in that case. We still want to keep lockdep disabled in the TAINT_OOT_MODULE case: - bin-only modules can cause various instabilities in their and in unrelated kernel code - they are impossible to debug for kernel developers - they also typically do not have the copyright license permission to link to the GPL-ed lockdep code. Suggested-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/n/tip-xopopjjens57r0i13qnyh2yo@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-13sched/rt: Fix task stack corruption under __ARCH_WANT_INTERRUPTS_ON_CTXSWChanho Min
commit cb297a3e433dbdcf7ad81e0564e7b804c941ff0d upstream. This issue happens under the following conditions: 1. preemption is off 2. __ARCH_WANT_INTERRUPTS_ON_CTXSW is defined 3. RT scheduling class 4. SMP system Sequence is as follows: 1.suppose current task is A. start schedule() 2.task A is enqueued pushable task at the entry of schedule() __schedule prev = rq->curr; ... put_prev_task put_prev_task_rt enqueue_pushable_task 4.pick the task B as next task. next = pick_next_task(rq); 3.rq->curr set to task B and context_switch is started. rq->curr = next; 4.At the entry of context_swtich, release this cpu's rq->lock. context_switch prepare_task_switch prepare_lock_switch raw_spin_unlock_irq(&rq->lock); 5.Shortly after rq->lock is released, interrupt is occurred and start IRQ context 6.try_to_wake_up() which called by ISR acquires rq->lock try_to_wake_up ttwu_remote rq = __task_rq_lock(p) ttwu_do_wakeup(rq, p, wake_flags); task_woken_rt 7.push_rt_task picks the task A which is enqueued before. task_woken_rt push_rt_tasks(rq) next_task = pick_next_pushable_task(rq) 8.At find_lock_lowest_rq(), If double_lock_balance() returns 0, lowest_rq can be the remote rq. (But,If preemption is on, double_lock_balance always return 1 and it does't happen.) push_rt_task find_lock_lowest_rq if (double_lock_balance(rq, lowest_rq)).. 9.find_lock_lowest_rq return the available rq. task A is migrated to the remote cpu/rq. push_rt_task ... deactivate_task(rq, next_task, 0); set_task_cpu(next_task, lowest_rq->cpu); activate_task(lowest_rq, next_task, 0); 10. But, task A is on irq context at this cpu. So, task A is scheduled by two cpus at the same time until restore from IRQ. Task A's stack is corrupted. To fix it, don't migrate an RT task if it's still running. Signed-off-by: Chanho Min <chanho.min@lge.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/CAOAMb1BHA=5fm7KTewYyke6u-8DP0iUuJMpgQw54vNeXFsGpoQ@mail.gmail.com Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-13kprobes: fix a memory leak in function pre_handler_kretprobe()Jiang Liu
commit 55ca6140e9bb307efc97a9301a4f501de02a6fd6 upstream. In function pre_handler_kretprobe(), the allocated kretprobe_instance object will get leaked if the entry_handler callback returns non-zero. This may cause all the preallocated kretprobe_instance objects exhausted. This issue can be reproduced by changing samples/kprobes/kretprobe_example.c to probe "mutex_unlock". And the fix is straightforward: just put the allocated kretprobe_instance object back onto the free_instances list. [akpm@linux-foundation.org: use raw_spin_lock/unlock] Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Acked-by: Jim Keniston <jkenisto@us.ibm.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03cap_syslog: don't use WARN_ONCE for CAP_SYS_ADMIN deprecation warningJonathan Nieder
commit f2c0d0266cc5eb36a4aa44944b4096ec121490aa upstream. syslog-ng versions before 3.3.0beta1 (2011-05-12) assume that CAP_SYS_ADMIN is sufficient to access syslog, so ever since CAP_SYSLOG was introduced (2010-11-25) they have triggered a warning. Commit ee24aebffb75 ("cap_syslog: accept CAP_SYS_ADMIN for now") improved matters a little by making syslog-ng work again, just keeping the WARN_ONCE(). But still, this is a warning that writes a stack trace we don't care about to syslog, sets a taint flag, and alarms sysadmins when nothing worse has happened than use of an old userspace with a recent kernel. Convert the WARN_ONCE to a printk_once to avoid that while continuing to give userspace developers a hint that this is an unwanted backward-compatibility feature and won't be around forever. Reported-by: Ralf Hildebrandt <ralf.hildebrandt@charite.de> Reported-by: Niels <zorglub_olsen@hotmail.com> Reported-by: Paweł Sikora <pluto@agmk.net> Signed-off-by: Jonathan Nieder <jrnieder@gmail.com> Liked-by: Gergely Nagy <algernon@madhouse-project.org> Acked-by: Serge Hallyn <serge@hallyn.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Christoph Biedl <linux-kernel.bfrz@manchmal.in-ulm.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03ftrace: Fix unregister ftrace_ops accountingJiri Olsa
commit 30fb6aa74011dcf595f306ca2727254d708b786e upstream. Multiple users of the function tracer can register their functions with the ftrace_ops structure. The accounting within ftrace will update the counter on each function record that is being traced. When the ftrace_ops filtering adds or removes functions, the function records will be updated accordingly if the ftrace_ops is still registered. When a ftrace_ops is removed, the counter of the function records, that the ftrace_ops traces, are decremented. When they reach zero the functions that they represent are modified to stop calling the mcount code. When changes are made, the code is updated via stop_machine() with a command passed to the function to tell it what to do. There is an ENABLE and DISABLE command that tells the called function to enable or disable the functions. But the ENABLE is really a misnomer as it should just update the records, as records that have been enabled and now have a count of zero should be disabled. The DISABLE command is used to disable all functions regardless of their counter values. This is the big off switch and is not the complement of the ENABLE command. To make matters worse, when a ftrace_ops is unregistered and there is another ftrace_ops registered, neither the DISABLE nor the ENABLE command are set when calling into the stop_machine() function and the records will not be updated to match their counter. A command is passed to that function that will update the mcount code to call the registered callback directly if it is the only one left. This means that the ftrace_ops that is still registered will have its callback called by all functions that have been set for it as well as the ftrace_ops that was just unregistered. Here's a way to trigger this bug. Compile the kernel with CONFIG_FUNCTION_PROFILER set and with CONFIG_FUNCTION_GRAPH not set: CONFIG_FUNCTION_PROFILER=y # CONFIG_FUNCTION_GRAPH is not set This will force the function profiler to use the function tracer instead of the function graph tracer. # cd /sys/kernel/debug/tracing # echo schedule > set_ftrace_filter # echo function > current_tracer # cat set_ftrace_filter schedule # cat trace # tracer: nop # # entries-in-buffer/entries-written: 692/68108025 #P:4 # # _-----=> irqs-off # / _----=> need-resched # | / _---=> hardirq/softirq # || / _--=> preempt-depth # ||| / delay # TASK-PID CPU# |||| TIMESTAMP FUNCTION # | | | |||| | | kworker/0:2-909 [000] .... 531.235574: schedule <-worker_thread <idle>-0 [001] .N.. 531.235575: schedule <-cpu_idle kworker/0:2-909 [000] .... 531.235597: schedule <-worker_thread sshd-2563 [001] .... 531.235647: schedule <-schedule_hrtimeout_range_clock # echo 1 > function_profile_enabled # echo 0 > function_porfile_enabled # cat set_ftrace_filter schedule # cat trace # tracer: function # # entries-in-buffer/entries-written: 159701/118821262 #P:4 # # _-----=> irqs-off # / _----=> need-resched # | / _---=> hardirq/softirq # || / _--=> preempt-depth # ||| / delay # TASK-PID CPU# |||| TIMESTAMP FUNCTION # | | | |||| | | <idle>-0 [002] ...1 604.870655: local_touch_nmi <-cpu_idle <idle>-0 [002] d..1 604.870655: enter_idle <-cpu_idle <idle>-0 [002] d..1 604.870656: atomic_notifier_call_chain <-enter_idle <idle>-0 [002] d..1 604.870656: __atomic_notifier_call_chain <-atomic_notifier_call_chain The same problem could have happened with the trace_probe_ops, but they are modified with the set_frace_filter file which does the update at closure of the file. The simple solution is to change ENABLE to UPDATE and call it every time an ftrace_ops is unregistered. Link: http://lkml.kernel.org/r/1323105776-26961-3-git-send-email-jolsa@redhat.com Signed-off-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03ftrace: Update filter when tracing enabled in set_ftrace_filter()Steven Rostedt
commit 072126f4529196f71a97960248bca54fd4554c2d upstream. Currently, if set_ftrace_filter() is called when the ftrace_ops is active, the function filters will not be updated. They will only be updated when tracing is disabled and re-enabled. Update the functions immediately during set_ftrace_filter(). Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03ftrace: Balance records when updating the hashSteven Rostedt
commit 41fb61c2d08107ce96a5dcb3a6289b2afd3e135c upstream. Whenever the hash of the ftrace_ops is updated, the record counts must be balance. This requires disabling the records that are set in the original hash, and then enabling the records that are set in the updated hash. Moving the update into ftrace_hash_move() removes the bug where the hash was updated but the records were not, which results in ftrace triggering a warning and disabling itself because the ftrace_ops filter is updated while the ftrace_ops was registered, and then the failure happens when the ftrace_ops is unregistered. The current code will not trigger this bug, but new code will. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-01-25kprobes: initialize before using a hlistAnanth N Mavinakayanahalli
commit d496aab567e7e52b3e974c9192a5de6e77dce32c upstream. Commit ef53d9c5e ("kprobes: improve kretprobe scalability with hashed locking") introduced a bug where we can potentially leak kretprobe_instances since we initialize a hlist head after having used it. Initialize the hlist head before using it. Reported by: Jim Keniston <jkenisto@us.ibm.com> Acked-by: Jim Keniston <jkenisto@us.ibm.com> Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Srinivasa D S <srinivasa@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-12PM / Sleep: Fix race between CPU hotplug and freezerSrivatsa S. Bhat
commit 79cfbdfa87e84992d509e6c1648a18e1d7e68c20 upstream. The CPU hotplug notifications sent out by the _cpu_up() and _cpu_down() functions depend on the value of the 'tasks_frozen' argument passed to them (which indicates whether tasks have been frozen or not). (Examples for such CPU hotplug notifications: CPU_ONLINE, CPU_ONLINE_FROZEN, CPU_DEAD, CPU_DEAD_FROZEN). Thus, it is essential that while the callbacks for those notifications are running, the state of the system with respect to the tasks being frozen or not remains unchanged, *throughout that duration*. Hence there is a need for synchronizing the CPU hotplug code with the freezer subsystem. Since the freezer is involved only in the Suspend/Hibernate call paths, this patch hooks the CPU hotplug code to the suspend/hibernate notifiers PM_[SUSPEND|HIBERNATE]_PREPARE and PM_POST_[SUSPEND|HIBERNATE] to prevent the race between CPU hotplug and freezer, thus ensuring that CPU hotplug notifications will always be run with the state of the system really being what the notifications indicate, _throughout_ their execution time. Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-12cgroup: fix to allow mounting a hierarchy by nameLi Zefan
commit 0d19ea866562e46989412a0676412fa0983c9ce7 upstream. If we mount a hierarchy with a specified name, the name is unique, and we can use it to mount the hierarchy without specifying its set of subsystem names. This feature is documented is Documentation/cgroups/cgroups.txt section 2.3 Here's an example: # mount -t cgroup -o cpuset,name=myhier xxx /cgroup1 # mount -t cgroup -o name=myhier xxx /cgroup2 But it was broken by commit 32a8cf235e2f192eb002755076994525cdbaa35a (cgroup: make the mount options parsing more accurate) This fixes the regression. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-06ptrace: partially fix the do_wait(WEXITED) vs EXIT_DEAD->EXIT_ZOMBIE raceOleg Nesterov
commit 50b8d257486a45cba7b65ca978986ed216bbcc10 upstream. Test-case: int main(void) { int pid, status; pid = fork(); if (!pid) { for (;;) { if (!fork()) return 0; if (waitpid(-1, &status, 0) < 0) { printf("ERR!! wait: %m\n"); return 0; } } } assert(ptrace(PTRACE_ATTACH, pid, 0,0) == 0); assert(waitpid(-1, NULL, 0) == pid); assert(ptrace(PTRACE_SETOPTIONS, pid, 0, PTRACE_O_TRACEFORK) == 0); do { ptrace(PTRACE_CONT, pid, 0, 0); pid = waitpid(-1, NULL, 0); } while (pid > 0); return 1; } It fails because ->real_parent sees its child in EXIT_DEAD state while the tracer is going to change the state back to EXIT_ZOMBIE in wait_task_zombie(). The offending commit is 823b018e which moved the EXIT_DEAD check, but in fact we should not blame it. The original code was not correct as well because it didn't take ptrace_reparented() into account and because we can't really trust ->ptrace. This patch adds the additional check to close this particular race but it doesn't solve the whole problem. We simply can't rely on ->ptrace in this case, it can be cleared if the tracer is multithreaded by the exiting ->parent. I think we should kill EXIT_DEAD altogether, we should always remove the soon-to-be-reaped child from ->children or at least we should never do the DEAD->ZOMBIE transition. But this is too complex for 3.2. Reported-and-tested-by: Denys Vlasenko <vda.linux@googlemail.com> Tested-by: Lukasz Michalik <lmi@ift.uni.wroc.pl> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-06hung_task: fix false positive during vforkMandeep Singh Baines
commit f9fab10bbd768b0e5254e53a4a8477a94bfc4b96 upstream. vfork parent uninterruptibly and unkillably waits for its child to exec/exit. This wait is of unbounded length. Ignore such waits in the hung_task detector. Signed-off-by: Mandeep Singh Baines <msb@chromium.org> Reported-by: Sasha Levin <levinsasha928@gmail.com> LKML-Reference: <1325344394.28904.43.camel@lappy> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: John Kacur <jkacur@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
