commit d1c7d97ad58836affde6e39980b96527510b572e upstream.
audit_log_start() may return NULL, this is unchecked by the caller in
audit_log_link_denied() and could cause a NULL ptr deref.
Introduced by commit a51d9eaa ("fs: add link restriction audit reporting").
Cc: Dave Jones <davej@redhat.com>
commit 17b572e82032bc246324ce136696656b66d4e3f1 upstream.
It is possible to miss data when using the kdb pager. The kdb pager
does not pay attention to the maximum column constraint of the screen
or serial terminal. This result is not incrementing the shown lines
correctly and the pager will print more lines that fit on the screen.
Obviously that is less than useful when using a VGA console where you
cannot scroll back.
The pager will now look at the kdb_buffer string to see how many
characters are printed. It might not be perfect considering you can
output ASCII that might move the cursor position, but it is a
substantially better approximation for viewing dmesg and trace logs.
This also means that the vt screen needs to set the kdb COLUMNS
variable.
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
commit 2b17c545a4cdbbbadcd7f1e9684c2d7db8f085a6 upstream.
When we stop the tick in idle, we save the current jiffies value
in ts->idle_jiffies. This snapshot is substracted from the later
value of jiffies when the tick is restarted and the resulting
delta is accounted as idle cputime. This is how we handle the
idle cputime accounting without the tick.
But sometimes we need to schedule the next tick to some time in
the future instead of completely stopping it. In this case, a
tick may happen before we restart the periodic behaviour and
from that tick we account one jiffy to idle cputime as usual but
we also increment the ts->idle_jiffies snapshot by one so that
when we compute the delta to account, we substract the one jiffy
we just accounted.
To prepare for stopping the tick outside idle, we introduced a
check that prevents from fixing up that ts->idle_jiffies if we
are not running the idle task. But we use idle_cpu() for that
and this is a problem if we run the tick while another CPU
remotely enqueues a ttwu to our runqueue:
CPU 0: CPU 1:
tick_sched_timer() { ttwu_queue_remote()
if (idle_cpu(CPU 0))
ts->idle_jiffies++;
Here, idle_cpu() notes that &rq->wake_list is not empty and
hence won't consider the CPU as idle. As a result,
ts->idle_jiffies won't be incremented. But this is wrong because
we actually account the current jiffy to idle cputime. And that
jiffy won't get substracted from the nohz time delta. So in the
end, this jiffy is accounted twice.
Fix this by changing idle_cpu(smp_processor_id()) with
is_idle_task(current). This way the jiffy is substracted
correctly even if a ttwu operation is enqueued on the CPU.
Link: http://lkml.kernel.org/r/1349308004-3482-1-git-send-email-fweisbec@gmail.com
commit 26cff4e2aa4d666dc6a120ea34336b5057e3e187 upstream.
Adding two (or more) timers with large values for "expires" (they have
to reside within tv5 in the same list) leads to endless looping
between cascade() and internal_add_timer() in case CONFIG_BASE_SMALL
is one and jiffies are crossing the value 1 << 18. The bug was
introduced between 2.6.11 and 2.6.12 (and survived for quite some
time).
This patch ensures that when cascade() is called timers within tv5 are
not added endlessly to their own list again, instead they are added to
the next lower tv level tv4 (as expected).
Signed-off-by: Christian Hildner <christian.hildner@siemens.com>
Reviewed-by: Jan Kiszka <jan.kiszka@siemens.com>
Link: http://lkml.kernel.org/r/98673C87CB31274881CFFE0B65ECC87B0F5FC1963E@DEFTHW99EA4MSX.ww902.siemens.net
commit 5b3900cd409466c0070b234d941650685ad0c791 upstream.
We fixed a bunch of integer overflows in timekeeping code during the 3.6
cycle. I did an audit based on that and found this potential overflow.
Acked-by: John Stultz <johnstul@us.ibm.com>
Link: http://lkml.kernel.org/r/20121009071823.GA19159@elgon.mountain
commit c99af3752bb52ba3aece5315279a57a477edfaf1 upstream.
Cloudlinux have a product called lve that includes a kernel module. This
was previously GPLed but is now under a proprietary license, but the
module continues to declare MODULE_LICENSE("GPL") and makes use of some
EXPORT_SYMBOL_GPL symbols. Forcibly taint it in order to avoid this.
Signed-off-by: Matthew Garrett <mjg59@srcf.ucam.org>
Cc: Alex Lyashkov <umka@cloudlinux.com>
commit 08bedae1d0acd8c9baf514fb69fa199d0c8345f6 upstream.
Commit f319da0c68 ("sched: Fix load avg vs cpu-hotplug") was an
incomplete fix:
In particular, the problem is that at the point it calls
calc_load_migrate() nr_running := 1 (the stopper thread), so move the
call to CPU_DEAD where we're sure that nr_running := 0.
Also note that we can call calc_load_migrate() without serialization, we
know the state of rq is stable since its cpu is dead, and we modify the
global state using appropriate atomic ops.
Suggested-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/1346882630.2600.59.camel@twins
commit a10d206ef1a83121ab7430cb196e0376a7145b22 upstream.
Each grace period is supposed to have at least one callback waiting
for that grace period to complete. However, if CONFIG_NO_HZ=n, an
extra callback-free grace period is no big problem -- it will chew up
a tiny bit of CPU time, but it will complete normally. In contrast,
CONFIG_NO_HZ=y kernels have the potential for all the CPUs to go to
sleep indefinitely, in turn indefinitely delaying completion of the
callback-free grace period. Given that nothing is waiting on this grace
period, this is also not a problem.
That is, unless RCU CPU stall warnings are also enabled, as they are
in recent kernels. In this case, if a CPU wakes up after at least one
minute of inactivity, an RCU CPU stall warning will result. The reason
that no one noticed until quite recently is that most systems have enough
OS noise that they will never remain absolutely idle for a full minute.
But there are some embedded systems with cut-down userspace configurations
that consistently get into this situation.
All this begs the question of exactly how a callback-free grace period
gets started in the first place. This can happen due to the fact that
CPUs do not necessarily agree on which grace period is in progress.
If a CPU still believes that the grace period that just completed is
still ongoing, it will believe that it has callbacks that need to wait for
another grace period, never mind the fact that the grace period that they
were waiting for just completed. This CPU can therefore erroneously
decide to start a new grace period. Note that this can happen in
TREE_RCU and TREE_PREEMPT_RCU even on a single-CPU system: Deadlock
considerations mean that the CPU that detected the end of the grace
period is not necessarily officially informed of this fact for some time.
Once this CPU notices that the earlier grace period completed, it will
invoke its callbacks. It then won't have any callbacks left. If no
other CPU has any callbacks, we now have a callback-free grace period.
This commit therefore makes CPUs check more carefully before starting a
new grace period. This new check relies on an array of tail pointers
into each CPU's list of callbacks. If the CPU is up to date on which
grace periods have completed, it checks to see if any callbacks follow
the RCU_DONE_TAIL segment, otherwise it checks to see if any callbacks
follow the RCU_WAIT_TAIL segment. The reason that this works is that
the RCU_WAIT_TAIL segment will be promoted to the RCU_DONE_TAIL segment
as soon as the CPU is officially notified that the old grace period
has ended.
This change is to cpu_needs_another_gp(), which is called in a number
of places. The only one that really matters is in rcu_start_gp(), where
the root rcu_node structure's ->lock is held, which prevents any
other CPU from starting or completing a grace period, so that the
comparison that determines whether the CPU is missing the completion
of a grace period is stable.
Reported-by: Becky Bruce <bgillbruce@gmail.com>
Reported-by: Subodh Nijsure <snijsure@grid-net.com>
Reported-by: Paul Walmsley <paul@pwsan.com>
Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org>
Tested-by: Paul Walmsley <paul@pwsan.com> # OMAP3730, OMAP4430
commit 3aa62497594430ea522050b75c033f71f2c60ee6 upstream.
Currently, when try_to_grab_pending() grabs a delayed work item, it
leaves its linked work items alone on the delayed_works. The linked
work items are always NO_COLOR and will cause future
cwq_activate_first_delayed() increase cwq->nr_active incorrectly, and
may cause the whole cwq to stall. For example,
state: cwq->max_active = 1, cwq->nr_active = 1
one work in cwq->pool, many in cwq->delayed_works.
step1: try_to_grab_pending() removes a work item from delayed_works
but leaves its NO_COLOR linked work items on it.
step2: Later on, cwq_activate_first_delayed() activates the linked
work item increasing ->nr_active.
step3: cwq->nr_active = 1, but all activated work items of the cwq are
NO_COLOR. When they finish, cwq->nr_active will not be
decreased due to NO_COLOR, and no further work items will be
activated from cwq->delayed_works. the cwq stalls.
Fix it by ensuring the target work item is activated before stealing
PENDING in try_to_grab_pending(). This ensures that all the linked
work items are activated without incorrectly bumping cwq->nr_active.
tj: Updated comment and description.
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
commit 959d1af8cffc8fd38ed53e8be1cf4ab8782f9c00 upstream.
WORK_STRUCT_PENDING is used to claim ownership of a work item and
process_one_work() releases it before starting execution. When
someone else grabs PENDING, all pre-release updates to the work item
should be visible and all updates made by the new owner should happen
afterwards.
Grabbing PENDING uses test_and_set_bit() and thus has a full barrier;
however, clearing doesn't have a matching wmb. Given the preceding
spin_unlock and use of clear_bit, I don't believe this can be a
problem on an actual machine and there hasn't been any related report
but it still is theretically possible for clear_pending to permeate
upwards and happen before work->entry update.
Add an explicit smp_wmb() before work_clear_pending().
commit f96972f2dc6365421cf2366ebd61ee4cf060c8d5 upstream.
As kernel_power_off() calls disable_nonboot_cpus(), we may also want to
have kernel_restart() call disable_nonboot_cpus(). Doing so can help
machines that require boot cpu be the last alive cpu during reboot to
survive with kernel restart.
This fixes one reboot issue seen on imx6q (Cortex-A9 Quad). The machine
requires that the restart routine be run on the primary cpu rather than
secondary ones. Otherwise, the secondary core running the restart
routine will fail to come to online after reboot.
Pull timer fix from Ingo Molnar:
"One more timekeeping fix for v3.6"
* 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
time: Fix timeekeping_get_ns overflow on 32bit systems
git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq
Pull workqueue / powernow-k8 fix from Tejun Heo:
"This is the fix for the bug where cpufreq/powernow-k8 was tripping
BUG_ON() in try_to_wake_up_local() by migrating workqueue worker to a
different CPU.
https://bugzilla.kernel.org/show_bug.cgi?id=47301
As discussed, the fix is now two parts - one to reimplement
work_on_cpu() so that it doesn't create a new kthread each time and
the actual fix which makes powernow-k8 use work_on_cpu() instead of
performing manual migration.
While pretty late in the merge cycle, both changes are on the safer
side. Jiri and I verified two existing users of work_on_cpu() and
Duncan confirmed that the powernow-k8 fix survived about 18 hours of
testing."
* 'for-3.6-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq:
cpufreq/powernow-k8: workqueue user shouldn't migrate the kworker to another CPU
workqueue: reimplement work_on_cpu() using system_wq
The existing work_on_cpu() implementation is hugely inefficient. It
creates a new kthread, execute that single function and then let the
kthread die on each invocation.
Now that system_wq can handle concurrent executions, there's no
advantage of doing this. Reimplement work_on_cpu() using system_wq
which makes it simpler and way more efficient.
stable: While this isn't a fix in itself, it's needed to fix a
workqueue related bug in cpufreq/powernow-k8. AFAICS, this
shouldn't break other existing users.
Acked-by: Jiri Kosina <jkosina@suse.cz>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Len Brown <lenb@kernel.org>
Cc: Rafael J. Wysocki <rjw@sisk.pl>
Cc: stable@vger.kernel.org
Pull another workqueue fix from Tejun Heo:
"Unfortunately, yet another late fix. This too is discovered and fixed
by Lai. This bug was introduced during this merge window by commit
25511a477657 ("workqueue: reimplement CPU online rebinding to handle
idle workers") which started using WORKER_REBIND flag for idle rebind
too.
The bug is relatively easy to trigger if the CPU rapidly goes through
off, on and then off (and stay off). The fix is on the safer side.
This hasn't been on linux-next yet but I'm pushing early so that it
can get more exposure before v3.6 release."
workqueue: always clear WORKER_REBIND in busy_worker_rebind_fn()
busy_worker_rebind_fn() didn't clear WORKER_REBIND if rebinding failed
(CPU is down again). This used to be okay because the flag wasn't
used for anything else.
However, after 25511a477 "workqueue: reimplement CPU online rebinding
to handle idle workers", WORKER_REBIND is also used to command idle
workers to rebind. If not cleared, the worker may confuse the next
CPU_UP cycle by having REBIND spuriously set or oops / get stuck by
prematurely calling idle_worker_rebind().
WARNING: at /work/os/wq/kernel/workqueue.c:1323 worker_thread+0x4cd/0x5
00()
Hardware name: Bochs
Modules linked in: test_wq(O-)
Pid: 33, comm: kworker/1:1 Tainted: G O 3.6.0-rc1-work+ #3
Call Trace:
[<ffffffff8109039f>] warn_slowpath_common+0x7f/0xc0
[<ffffffff810903fa>] warn_slowpath_null+0x1a/0x20
[<ffffffff810b3f1d>] worker_thread+0x4cd/0x500
[<ffffffff810bc16e>] kthread+0xbe/0xd0
[<ffffffff81bd2664>] kernel_thread_helper+0x4/0x10
---[ end trace e977cf20f4661968 ]---
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<ffffffff810b3db0>] worker_thread+0x360/0x500
PGD 0
Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC
CPU 0
Pid: 33, comm: kworker/1:1 Tainted: G W O 3.6.0-rc1-work+ #3 Bochs Bochs
RIP: 0010:[<ffffffff810b3db0>] [<ffffffff810b3db0>] worker_thread+0x360/0x500
RSP: 0018:ffff88001e1c9de0 EFLAGS: 00010086
RAX: 0000000000000000 RBX: ffff88001e633e00 RCX: 0000000000004140
RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000000000009
RBP: ffff88001e1c9ea0 R08: 0000000000000000 R09: 0000000000000001
R10: 0000000000000002 R11: 0000000000000000 R12: ffff88001fc8d580
R13: ffff88001fc8d590 R14: ffff88001e633e20 R15: ffff88001e1c6900
FS: 0000000000000000(0000) GS:ffff88001fc00000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 0000000000000000 CR3: 00000000130e8000 CR4: 00000000000006f0
Process kworker/1:1 (pid: 33, threadinfo ffff88001e1c8000, task ffff88001e1c6900)
Stack:
ffff880000000000 ffff88001e1c9e40 0000000000000001 ffff88001e1c8010
ffff88001e519c78 ffff88001e1c9e58 ffff88001e1c6900 ffff88001e1c6900
ffff88001e1c6900 ffff88001e1c6900 ffff88001fc8d340 ffff88001fc8d340
Call Trace:
Code: b1 00 f6 43 48 02 0f 85 91 01 00 00 48 8b 43 38 48 89 df 48 8b 00 48 89 45 90 e8 ac f0 ff ff 3c 01 0f 85 60 01 00 00 48 8b 53 50 <8b> 02 83 e8 01 85 c0 89 02 0f 84 3b 01 00 00 48 8b 43 38 48 8b
RIP [<ffffffff810b3db0>] worker_thread+0x360/0x500
RSP <ffff88001e1c9de0>
There was no reason to keep WORKER_REBIND on failure in the first
place - WORKER_UNBOUND is guaranteed to be set in such cases
preventing incorrectly activating concurrency management. Always
clear WORKER_REBIND.
The kernel doesn't check the pid for negative values, so if you try to
write -2 to /proc/sys/kernel/ns_last_pid, you will get a kernel panic.
The crash happens because the next pid is -1, and alloc_pidmap() will
try to access to a nonexistent pidmap.
map = &pid_ns->pidmap[pid/BITS_PER_PAGE];
Signed-off-by: Andrew Vagin <avagin@openvz.org>
Acked-by: Cyrill Gorcunov <gorcunov@openvz.org>
Acked-by: Oleg Nesterov <oleg@redhat.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Pavel Emelyanov <xemul@parallels.com>
perturbations"
This reverts commit 970e178985cadbca660feb02f4d2ee3a09f7fdda.
Nikolay Ulyanitsky reported thatthe 3.6-rc5 kernel has a 15-20%
performance drop on PostgreSQL 9.2 on his machine (running "pgbench").
Borislav Petkov was able to reproduce this, and bisected it to this
commit 970e178985ca ("sched: Improve scalability via 'CPU buddies' ...")
apparently because the new single-idle-buddy model simply doesn't find
idle CPU's to reschedule on aggressively enough.
Mike Galbraith suspects that it is likely due to the user-mode spinlocks
in PostgreSQL not reacting well to preemption, but we don't really know
the details - I'll just revert the commit for now.
There are hopefully other approaches to improve scheduler scalability
without it causing these kinds of downsides.
Reported-by: Nikolay Ulyanitsky <lystor@gmail.com>
Bisected-by: Borislav Petkov <bp@alien8.de>
Acked-by: Mike Galbraith <efault@gmx.de>
Pull scheduler fixes from Ingo Molnar:
"Smaller fixlets"
* 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
sched: Fix kernel-doc warnings in kernel/sched/fair.c
sched: Unthrottle rt runqueues in __disable_runtime()
sched: Add missing call to calc_load_exit_idle()
Pull perf fixes from Ingo Molnar:
"This tree includes various fixes"
Ingo really needs to improve on the whole "explain git pull" part.
"Various fixes" indeed.
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf/hwpb: Invoke __perf_event_disable() if interrupts are already disabled
perf/x86: Enable Intel Cedarview Atom suppport
perf_event: Switch to internal refcount, fix race with close()
oprofile, s390: Fix uninitialized memory access when writing to oprofilefs
perf/x86: Fix microcode revision check for SNB-PEBS
Daniel Lezcano reported seeing multi-second stalls from
keyboard input on his T61 laptop when NOHZ and CPU_IDLE
were enabled on a 32bit kernel.
He bisected the problem down to commit
1e75fa8be9fb6 ("time: Condense timekeeper.xtime into xtime_sec").
After reproducing this issue, I narrowed the problem down
to the fact that timekeeping_get_ns() returns a 64bit
nsec value that hasn't been accumulated. In some cases
this value was being then stored in timespec.tv_nsec
(which is a long).
On 32bit systems, with idle times larger then 4 seconds
(or less, depending on the value of xtime_nsec), the
returned nsec value would overflow 32bits. This limited
kept time from increasing, causing timers to not expire.
The fix is to make sure we don't directly store the
result of timekeeping_get_ns() into a tv_nsec field,
instead using a 64bit nsec value which can then be
added into the timespec via timespec_add_ns().
Reported-and-bisected-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Tested-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Signed-off-by: John Stultz <john.stultz@linaro.org>
Acked-by: Prarit Bhargava <prarit@redhat.com>
Cc: Richard Cochran <richardcochran@gmail.com>
Link: http://lkml.kernel.org/r/1347405963-35715-1-git-send-email-john.stultz@linaro.org
Pull workqueue fixes from Tejun Heo:
"It's later than I'd like but well the timing just didn't work out this
time.
There are three bug fixes. One from before 3.6-rc1 and two from the
new CPU hotplug code. Kudos to Lai for discovering all of them and
providing fixes.
* Atomicity bug when clearing a flag and setting another. The two
operation should have been atomic but wasn't. This bug has existed
for a long time but is unlikely to have actually happened. Fix is
safe. Marked for -stable.
* If CPU hotplug cycles happen back-to-back before workers finish the
previous cycle, the states could get out of sync and it could get
stuck. Fixed by waiting for workers to complete before finishing
hotplug cycle.
* While CPU hotplug is in progress, idle workers could be depleted
which can then lead to deadlock. I think both happening together
is highly unlikely but still better to fix it and the fix isn't too
scary.
There's another workqueue related regression which reported a few days
ago:
It's a bit of head scratcher but there is a semi-reliable reproduce
case, so I'm hoping to resolve it soonish."
workqueue: fix possible idle worker depletion across CPU hotplug
workqueue: restore POOL_MANAGING_WORKERS
workqueue: fix possible deadlock in idle worker rebinding
workqueue: move WORKER_REBIND clearing in rebind_workers() to the end of the function
workqueue: UNBOUND -> REBIND morphing in rebind_workers() should be atomic
To simplify both normal and CPU hotplug paths, worker management is
prevented while CPU hoplug is in progress. This is achieved by CPU
hotplug holding the same exclusion mechanism used by workers to ensure
there's only one manager per pool.
If someone else seems to be performing the manager role, workers
proceed to execute work items. CPU hotplug using the same mechanism
can lead to idle worker depletion because all workers could proceed to
execute work items while CPU hotplug is in progress and CPU hotplug
itself wouldn't actually perform the worker management duty - it
doesn't guarantee that there's an idle worker left when it releases
management.
This idle worker depletion, under extreme circumstances, can break
forward-progress guarantee and thus lead to deadlock.
This patch fixes the bug by using separate mechanisms for manager
exclusion among workers and hotplug exclusion. For manager exclusion,
POOL_MANAGING_WORKERS which was restored by the previous patch is
used. pool->manager_mutex is now only used for exclusion between the
elected manager and CPU hotplug. The elected manager won't proceed
without holding pool->manager_mutex.
This ensures that the worker which won the manager position can't skip
managing while CPU hotplug is in progress. It will block on
manager_mutex and perform management after CPU hotplug is complete.
Note that hotplug may happen while waiting for manager_mutex. A
manager isn't either on idle or busy list and thus the hoplug code
can't unbind/rebind it. Make the manager handle its own un/rebinding.
This patch restores POOL_MANAGING_WORKERS which was replaced by
pool->manager_mutex by 6037315269 "workqueue: use mutex for global_cwq
manager exclusion".
There's a subtle idle worker depletion bug across CPU hotplug events
and we need to distinguish an actual manager and CPU hotplug
preventing management. POOL_MANAGING_WORKERS will be used for the
former and manager_mutex the later.
This patch just lays POOL_MANAGING_WORKERS on top of the existing
manager_mutex and doesn't introduce any synchronization changes. The
next patch will update it.
Note that this patch fixes a non-critical anomaly where
too_many_workers() may return %true spuriously while CPU hotplug is in
progress. While the issue could schedule idle timer spuriously, it
didn't trigger any actual misbehavior.
tj: Rewrote patch description.
Currently, rebind_workers() and idle_worker_rebind() are two-way
interlocked. rebind_workers() waits for idle workers to finish
rebinding and rebound idle workers wait for rebind_workers() to finish
rebinding busy workers before proceeding.
Unfortunately, this isn't enough. The second wait from idle workers
is implemented as follows.
wait_event(gcwq->rebind_hold, !(worker->flags & WORKER_REBIND));
rebind_workers() clears WORKER_REBIND, wakes up the idle workers and
then returns. If CPU hotplug cycle happens again before one of the
idle workers finishes the above wait_event(), rebind_workers() will
repeat the first part of the handshake - set WORKER_REBIND again and
wait for the idle worker to finish rebinding - and this leads to
deadlock because the idle worker would be waiting for WORKER_REBIND to
clear.
This is fixed by adding another interlocking step at the end -
rebind_workers() now waits for all the idle workers to finish the
above WORKER_REBIND wait before returning. This ensures that all
rebinding steps are complete on all idle workers before the next
hotplug cycle can happen.
This problem was diagnosed by Lai Jiangshan who also posted a patch to
fix the issue, upon which this patch is based.
This is the minimal fix and further patches are scheduled for the next
merge window to simplify the CPU hotplug path.
Original-patch-by: Lai Jiangshan <laijs@cn.fujitsu.com>
LKML-Reference: <1346516916-1991-3-git-send-email-laijs@cn.fujitsu.com>
function
This doesn't make any functional difference and is purely to help the
next patch to be simpler.
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
The compiler may compile the following code into TWO write/modify
instructions.
worker->flags &= ~WORKER_UNBOUND;
worker->flags |= WORKER_REBIND;
so the other CPU may temporarily see worker->flags which doesn't have
either WORKER_UNBOUND or WORKER_REBIND set and perform local wakeup
prematurely.
Fix it by using single explicit assignment via ACCESS_ONCE().
Because idle workers have another WORKER_NOT_RUNNING flag, this bug
doesn't exist for them; however, update it to use the same pattern for
consistency.
tj: Applied the change to idle workers too and updated comments and
patch description a bit.
While debugging a warning message on PowerPC while using hardware
breakpoints, it was discovered that when perf_event_disable is invoked
through hw_breakpoint_handler function with interrupts disabled, a
subsequent IPI in the code path would trigger a WARN_ON_ONCE message in
smp_call_function_single function.
This patch calls __perf_event_disable() when interrupts are already
disabled, instead of perf_event_disable().
Reported-by: Edjunior Barbosa Machado <emachado@linux.vnet.ibm.com>
Signed-off-by: K.Prasad <Prasad.Krishnan@gmail.com>
[naveen.n.rao@linux.vnet.ibm.com: v3: Check to make sure we target current task]
Signed-off-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
Link: http://lkml.kernel.org/r/20120802081635.5811.17737.stgit@localhost.localdomain
[ Fixed build error on MIPS. ]
Don't mess with file refcounts (or keep a reference to file, for
that matter) in perf_event. Use explicit refcount of its own
instead. Deal with the race between the final reference to event
going away and new children getting created for it by use of
atomic_long_inc_not_zero() in inherit_event(); just have the
latter free what it had allocated and return NULL, that works
out just fine (children of siblings of something doomed are
created as singletons, same as if the child of leader had been
created and immediately killed).
Cc: stable@kernel.org
Link: http://lkml.kernel.org/r/20120820135925.GG23464@ZenIV.linux.org.uk
Fix two kernel-doc warnings in kernel/sched/fair.c:
Warning(kernel/sched/fair.c:3660): Excess function parameter 'cpus' description in 'update_sg_lb_stats'
Warning(kernel/sched/fair.c:3806): Excess function parameter 'cpus' description in 'update_sd_lb_stats'
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Link: http://lkml.kernel.org/r/50303714.3090204@xenotime.net
migrate_tasks() uses _pick_next_task_rt() to get tasks from the
real-time runqueues to be migrated. When rt_rq is throttled
_pick_next_task_rt() won't return anything, in which case
migrate_tasks() can't move all threads over and gets stuck in an
infinite loop.
Instead unthrottle rt runqueues before migrating tasks.
Additionally: move unthrottle_offline_cfs_rqs() to rq_offline_fair()
Signed-off-by: Peter Boonstoppel <pboonstoppel@nvidia.com>
Cc: Paul Turner <pjt@google.com>
Link: http://lkml.kernel.org/r/5FBF8E85CA34454794F0F7ECBA79798F379D3648B7@HQMAIL04.nvidia.com
Azat Khuzhin reported high loadavg in Linux v3.6
After checking the upstream scheduler code, I found Peter's commit:
5167e8d5417b sched/nohz: Rewrite and fix load-avg computation -- again
not fully applied, missing the call to calc_load_exit_idle().
After that idle exit in sampling window will always be calculated
to non-idle, and the load will be higher than normal.
This patch adds the missing call to calc_load_exit_idle().
Signed-off-by: Charles Wang <muming.wq@taobao.com>
Link: http://lkml.kernel.org/r/1345449754-27130-1-git-send-email-muming.wq@gmail.com
Rabik and Paul reported two different issues related to the same few
lines of code.
Rabik's issue is that the nr_uninterruptible migration code is wrong in
that he sees artifacts due to this (Rabik please do expand in more
detail).
Paul's issue is that this code as it stands relies on us using
stop_machine() for unplug, we all would like to remove this assumption
so that eventually we can remove this stop_machine() usage altogether.
The only reason we'd have to migrate nr_uninterruptible is so that we
could use for_each_online_cpu() loops in favour of
for_each_possible_cpu() loops, however since nr_uninterruptible() is the
only such loop and its using possible lets not bother at all.
The problem Rabik sees is (probably) caused by the fact that by
migrating nr_uninterruptible we screw rq->calc_load_active for both rqs
involved.
So don't bother with fancy migration schemes (meaning we now have to
keep using for_each_possible_cpu()) and instead fold any nr_active delta
after we migrate all tasks away to make sure we don't have any skewed
nr_active accounting.
Reported-by: Rakib Mullick <rakib.mullick@gmail.com>
Reported-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/1345454817.23018.27.camel@twins
Andreas Bombe reported that the added ktime_t overflow checking added to
timespec_valid in commit 4e8b14526ca7 ("time: Improve sanity checking of
timekeeping inputs") was causing problems with X.org because it caused
timeouts larger then KTIME_T to be invalid.
Previously, these large timeouts would be clamped to KTIME_MAX and would
never expire, which is valid.
This patch splits the ktime_t overflow checking into a new
timespec_valid_strict function, and converts the timekeeping codes
internal checking to use this more strict function.
Reported-and-tested-by: Andreas Bombe <aeb@debian.org>
Cc: Zhouping Liu <zliu@redhat.com>
Cc: Prarit Bhargava <prarit@redhat.com>
"This tree contains misc fixlets: a perf script python binding fix, a
uprobes fix and a syscall tracing fix."
perf tools: Add missing files to build the python binding
uprobes: Fix mmap_region()'s mm->mm_rb corruption if uprobe_mmap() fails
tracing/syscalls: Fix perf syscall tracing when syscall_nr == -1
Pull timer fixes from Thomas Gleixner:
"Mostly small fixes for the fallout of the timekeeping overhaul in 3.6
along with stable fixes to address an accumulation problem and missing
sanity checks for RTC readouts and user space provided values."
time: Avoid making adjustments if we haven't accumulated anything
time: Avoid potential shift overflow with large shift values
time: Fix casting issue in timekeeping_forward_now
time: Ensure we normalize the timekeeper in tk_xtime_add
time: Improve sanity checking of timekeeping inputs
If update_wall_time() is called and the current offset isn't large
enough to accumulate, avoid re-calling timekeeping_adjust which may
change the clock freq and can cause 1ns inconsistencies with
CLOCK_REALTIME_COARSE/CLOCK_MONOTONIC_COARSE.
Link: http://lkml.kernel.org/r/1345595449-34965-5-git-send-email-john.stultz@linaro.org
Andreas Schwab noticed that the 1 << tk->shift could overflow if the
shift value was greater than 30, since 1 would be a 32bit long on
32bit architectures. This issue was introduced by 1e75fa8be (time:
Condense timekeeper.xtime into xtime_sec)
Use 1ULL instead to ensure we don't overflow on the shift.
Reported-by: Andreas Schwab <schwab@linux-m68k.org>
Link: http://lkml.kernel.org/r/1345595449-34965-4-git-send-email-john.stultz@linaro.org
arch_gettimeoffset returns a u32 value which when shifted by tk->shift
can overflow. This issue was introduced with 1e75fa8be (time: Condense
Cast it to u64 first.
Signed-off-by: Andreas Schwab <schwab@linux-m68k.org>
Link: http://lkml.kernel.org/r/1345595449-34965-3-git-send-email-john.stultz@linaro.org
Andreas noticed problems with resume on specific hardware after commit
1e75fa8b (time: Condense timekeeper.xtime into xtime_sec) combined
with commit b44d50dca (time: Fix casting issue in tk_set_xtime and
tk_xtime_add)
After some digging I realized we aren't normalizing the timekeeper
after the add. Add the missing normalize call.
Tested-by: Andreas Schwab <schwab@linux-m68k.org>
Link: http://lkml.kernel.org/r/1345595449-34965-2-git-send-email-john.stultz@linaro.org
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs
Pull audit-tree fixes from Miklos Szeredi:
"The audit subsystem maintainers (Al and Eric) are not responding to
repeated resends. Eric did ack them a while ago, but no response
since then. So I'm sending these directly to you."
* 'audit-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs:
audit: clean up refcounting in audit-tree
audit: fix refcounting in audit-tree
audit: don't free_chunk() after fsnotify_add_mark()
It seems commit 4a9d4b024a31 ("switch fput to task_work_add") re-
introduced the problem addressed in 944be0b22472 ("close_files(): add
scheduling point")
If a server process with a lot of files (say 2 million tcp sockets) is
killed, we can spend a lot of time in task_work_run() and trigger a soft
lockup.
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace into perf/urgent
Pull syscall tracing fix from Steve Rostedt.
This patch fixes:
https://bugzilla.redhat.com/show_bug.cgi?id=843640
If mmap_region()->uprobe_mmap() fails, unmap_and_free_vma path
does unmap_region() but does not remove the soon-to-be-freed vma
from rb tree. Actually there are more problems but this is how
William noticed this bug.
Perhaps we could do do_munmap() + return in this case, but in
fact it is simply wrong to abort if uprobe_mmap() fails. Until
at least we move the !UPROBE_COPY_INSN code from
install_breakpoint() to uprobe_register().
For example, uprobe_mmap()->install_breakpoint() can fail if the
probed insn is not supported (remember, uprobe_register()
succeeds if nobody mmaps inode/offset), mmap() should not fail
in this case.
dup_mmap()->uprobe_mmap() is wrong too by the same reason,
fork() can race with uprobe_register() and fail for no reason if
it wins the race and does install_breakpoint() first.
And, if nothing else, both mmap_region() and dup_mmap() return
success if uprobe_mmap() fails. Change them to ignore the error
code from uprobe_mmap().
Reported-and-tested-by: William Cohen <wcohen@redhat.com>
Acked-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Cc: <stable@vger.kernel.org> # v3.5
Cc: Anton Arapov <anton@redhat.com>
Cc: William Cohen <wcohen@redhat.com>
Link: http://lkml.kernel.org/r/20120819171042.GB26957@redhat.com
Pull scheduler fixes from Ingo Molnar.
sched: Fix migration thread runtime bogosity
sched,rt: fix isolated CPUs leaving root_task_group indefinitely throttled
sched,cgroup: Fix up task_groups list
sched: fix divide by zero at {thread_group,task}_times
sched, cgroup: Reduce rq->lock hold times for large cgroup hierarchies
Merge alpha architecture update from Michael Cree:
"The Alpha Maintainer, Matt Turner, is currently unavailable, so I have
collected up patches that have been posted to the linux-alpha mailing
list over the last couple of months, and are forwarding them to you in
the hope that you are prepared to accept them via me.
The patches by Al Viro and myself I have been running against kernels
for two months now so have had quite a bit of testing. All except one
patch were intended for the 3.5 kernel but because of Matt's
unavailability never got forwarded to you."
* emailed patches from Michael Cree <mcree@orcon.net.nz>: (9 commits)
alpha: Fix fall-out from disintegrating asm/system.h
Redefine ATOMIC_INIT and ATOMIC64_INIT to drop the casts
alpha: fix fpu.h usage in userspace
alpha/mm/fault.c: Port OOM changes to do_page_fault
alpha: take kernel_execve() out of entry.S
alpha: take a bunch of syscalls into osf_sys.c
alpha: Use new generic strncpy_from_user() and strnlen_user()
alpha: Wire up cross memory attach syscalls
alpha: Don't export SOCK_NONBLOCK to user space.
New helper: current_thread_info(). Allows to do a bunch of odd syscalls
in C. While we are at it, there had never been a reason to do
osf_getpriority() in assembler. We also get "namespace"-aware (read:
consistent with getuid(2), etc.) behaviour from getx?id() syscalls now.
Signed-off-by: Michael Cree <mcree@orcon.net.nz>
Acked-by: Matt Turner <mattst88@gmail.com>
syscall_get_nr can return -1 in the case that the task is not executing
a system call.
This patch fixes perf_syscall_{enter,exit} to check that the syscall
number is valid before using it as an index into a bitmap.
Link: http://lkml.kernel.org/r/1345137254-7377-1-git-send-email-will.deacon@arm.com
Cc: Jason Baron <jbaron@redhat.com>
Cc: Wade Farnsworth <wade_farnsworth@mentor.com>
Unexpected behavior could occur if the time is set to a value large
enough to overflow a 64bit ktime_t (which is something larger then the
year 2262).
Also unexpected behavior could occur if large negative offsets are
injected via adjtimex.
So this patch improves the sanity check timekeeping inputs by
improving the timespec_valid() check, and then makes better use of
timespec_valid() to make sure we don't set the time to an invalid
negative value or one that overflows ktime_t.
Note: This does not protect from setting the time close to overflowing
ktime_t and then letting natural accumulation cause the overflow.
Reported-by: CAI Qian <caiqian@redhat.com>
Reported-by: Sasha Levin <levinsasha928@gmail.com>
Link: http://lkml.kernel.org/r/1344454580-17031-1-git-send-email-john.stultz@linaro.org
Drop the initial reference by fsnotify_init_mark early instead of
audit_tree_freeing_mark() at destroy time.
In the cases we destroy the mark before we drop the initial reference we need to
get rid of the get_mark that balances the put_mark in audit_tree_freeing_mark().
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
