path: root/kernel
2007-04-09hrtimer: prevent overrun DoS in hrtimer_forward()Thomas Gleixner
hrtimer_forward() does not check for the possible overflow of timer->expires. This can happen on 64 bit machines with large interval values and results currently in an endless loop in the softirq because the expiry value becomes negative and therefor the timer is expired all the time. Check for this condition and set the expiry value to the max. expiry time in the future. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-04-08Fix reparenting to the same thread group. (take 2)Eric W. Biederman
This patch fixes the case when we reparent to a different thread in the same thread group. This modifies the code so that we do not send signals and do not change the signal to send to SIGCHLD unless we have change the thread group of our parents. It also suppresses sending pdeath_sig in this cas as well since the result of geppid doesn't change. Thanks to Oleg for spotting my bug of only fixing this for non-ptraced tasks. This fixes the issues identified by Albert Cahalan in thread http://lkml.org/lkml/2006/12/21/22 Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-03-21load_module: no BUG if module_subsys uninitializedEd Swierk
Invoking load_module() before param_sysfs_init() is called crashes in mod_sysfs_setup(), since the kset in module_subsys is not initialized yet. In my case, net-pf-1 is getting modprobed as a result of hotplug trying to create a UNIX socket. Calls to hotplug begin after the topology_init initcall. Another patch for the same symptom (module_subsys-initialize-earlier.patch) moves param_sysfs_init() to the subsys initcalls, but this is still not early enough in the boot process in some cases. In particular, topology_init() causes /sbin/hotplug to run, which requests net-pf-1 (the UNIX socket protocol) which can be compiled as a module. Moving param_sysfs_init() to the postcore initcalls fixes this particular race, but there might well be other cases where a usermodehelper causes a module to load earlier still. The patch makes load_module() return an error rather than crashing the kernel if invoked before module_subsys is initialized. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-15softirq: remove BUG_ONs which can incorrectly triggerZachary Amsden
It is possible to have tasklets get scheduled before softirqd has had a chance to spawn on all CPUs. This is totally harmless; after success during action CPU_UP_PREPARE, action CPU_ONLINE will be called, which immediately wakes softirqd on the appropriate CPU to process the already pending tasklets. So there is no danger of having a missed wakeup for any tasklets that were already pending. In particular, i386 is affected by this during startup, and is visible when using a very large initrd; during the time it takes for the initrd to be decompressed, a timer IRQ can come in and schedule RCU callbacks. It is also possible that resending of a hardware IRQ via a softirq triggers the same bug. Because of different timing conditions, this shows up in all emulators and virtual machines tested, including Xen, VMware, Virtual PC, and Qemu. It is also possible to trigger on native hardware with a large enough initrd, although I don't have a reliable case demonstrating that. Signed-off-by: Zachary Amsden <zach@vmware.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-04Remove redundant up() in stop_machine()Zhou Yingchao
An up() is called in kernel/stop_machine.c on failure, and also in the caller (unconditionally). Signed-off-by: Zhou Yingchao <yingchao.zhou@gmail.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-24fix sys_getppid oopses on debug kernelKirill Korotaev
sys_getppid() optimization can access a freed memory. On kernels with DEBUG_SLAB turned ON, this results in Oops. As Dave Hansen noted, this optimization is also unsafe for memory hotplug. So this patch always takes the lock to be safe. Signed-off-by: Kirill Korotaev <dev@openvz.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-11Fix longstanding load balancing bug in the schedulerChristoph Lameter
The scheduler will stop load balancing if the most busy processor contains processes pinned via processor affinity. The scheduler currently only does one search for busiest cpu. If it cannot pull any tasks away from the busiest cpu because they were pinned then the scheduler goes into a corner and sulks leaving the idle processors idle. F.e. If you have processor 0 busy running four tasks pinned via taskset, there are none on processor 1 and one just started two processes on processor 2 then the scheduler will not move one of the two processes away from processor 2. This patch fixes that issue by forcing the scheduler to come out of its corner and retrying the load balancing by considering other processors for load balancing. This patch was originally developed by John Hawkes and discussed at http://marc.theaimsgroup.com/?l=linux-kernel&m=113901368523205&w=2. I have removed extraneous material and gone back to equipping struct rq with the cpu the queue is associated with since this makes the patch much easier and it is likely that others in the future will have the same difficulty of figuring out which processor owns which runqueue. The overhead added through these patches is a single word on the stack if the kernel is configured to support 32 cpus or less (32 bit). For 32 bit environments the maximum number of cpus that can be configued is 255 which would result in the use of 32 bytes additional on the stack. On IA64 up to 1k cpus can be configured which will result in the use of 128 additional bytes on the stack. The maximum additional cache footprint is one cacheline. Typically memory use will be much less than a cacheline and the additional cpumask will be placed on the stack in a cacheline that already contains other local variable. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-05posix-cpu-timers: prevent signal delivery starvationThomas Gleixner
The integer divisions in the timer accounting code can round the result down to 0. Adding 0 is without effect and the signal delivery stops. Clamp the division result to minimum 1 to avoid this. Problem was reported by Seongbae Park <spark@google.com>, who provided also an inital patch. Roland sayeth: I have had some more time to think about the problem, and to reproduce it using Toyo's test case. For the record, if my understanding of the problem is correct, this happens only in one very particular case. First, the expiry time has to be so soon that in cputime_t units (usually 1s/HZ ticks) it's < nthreads so the division yields zero. Second, it only affects each thread that is so new that its CPU time accumulation is zero so now+0 is still zero and ->it_*_expires winds up staying zero. For the VIRT and PROF clocks when cputime_t is tick granularity (or the SCHED clock on configurations where sched_clock's value only advances on clock ticks), this is not hard to arrange with new threads starting up and blocking before they accumulate a whole tick of CPU time. That's what happens in Toyo's test case. Note that in general it is fine for that division to round down to zero, and set each thread's expiry time to its "now" time. The problem only arises with thread's whose "now" value is still zero, so that now+0 winds up 0 and is interpreted as "not set" instead of ">= now". So it would be a sufficient and more precise fix to just use max(ticks, 1) inside the loop when setting each it_*_expires value. But, it does no harm to round the division up to one and always advance every thread's expiry time. If the thread didn't already fire timers for the expiry time of "now", there is no expectation that it will do so before the next tick anyway. So I followed Thomas's patch in lifting the max out of the loops. This patch also covers the reload cases, which are harder to write a test for (and I didn't try). I've tested it with Toyo's case and it fixes that. [toyoa@mvista.com: fix: min_t -> max_t] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-22kernel/kmod.c: fix a race condition in usermodehelper.Martin Schwidefsky
There is a race between call_usermodehelper_keys, __call_usermodehelper and wait_for_helper. It should only happen if preemption is enabled or on a virtualized system. If the cpu is preempted or put to sleep by the hypervisor in __call_usermodehelper between the creation of the wait_for_helper thread and the second check on sub_info->wait, the whole execution of wait_for_helper including the complete call and the continuation after the wait_for_completion in call_usermodehelper_keys can have happened before __call_usermodehelper checks sub_info->wait for the second time. Since sub_info can already have been clobbered, sub_info->wait could be zero and complete is called a second time with an invalid argument. This has happened on s390. It took me only three days to find out .. Thanks to Arnd Bergmann for his help to spot this bug. Kenneth Lee also sent the same patch independently. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-06fix misoptimization in futex unqueue_meChristian Borntraeger
This patch adds a barrier() in futex unqueue_me to avoid aliasing of two pointers. On my s390x system I saw the following oops: Unable to handle kernel pointer dereference at virtual kernel address 0000000000000000 Oops: 0004 [#1] CPU: 0 Not tainted Process mytool (pid: 13613, task: 000000003ecb6ac0, ksp: 00000000366bdbd8) Krnl PSW : 0704d00180000000 00000000003c9ac2 (_spin_lock+0xe/0x30) Krnl GPRS: 00000000ffffffff 000000003ecb6ac0 0000000000000000 0700000000000000 0000000000000000 0000000000000000 000001fe00002028 00000000000c091f 000001fe00002054 000001fe00002054 0000000000000000 00000000366bddc0 00000000005ef8c0 00000000003d00e8 0000000000144f91 00000000366bdcb8 Krnl Code: ba 4e 20 00 12 44 b9 16 00 3e a7 84 00 08 e3 e0 f0 88 00 04 Call Trace: ([<0000000000144f90>] unqueue_me+0x40/0xe4) [<0000000000145a0c>] do_futex+0x33c/0xc40 [<000000000014643e>] sys_futex+0x12e/0x144 [<000000000010bb00>] sysc_noemu+0x10/0x16 [<000002000003741c>] 0x2000003741c The code in question is: static int unqueue_me(struct futex_q *q) { int ret = 0; spinlock_t *lock_ptr; /* In the common case we don't take the spinlock, which is nice. */ retry: lock_ptr = q->lock_ptr; if (lock_ptr != 0) { spin_lock(lock_ptr); /* * q->lock_ptr can change between reading it and * spin_lock(), causing us to take the wrong lock. This * corrects the race condition. [...] and my compiler (gcc 4.1.0) makes the following out of it: 00000000000003c8 <unqueue_me>: 3c8: eb bf f0 70 00 24 stmg %r11,%r15,112(%r15) 3ce: c0 d0 00 00 00 00 larl %r13,3ce <unqueue_me+0x6> 3d0: R_390_PC32DBL .rodata+0x2a 3d4: a7 f1 1e 00 tml %r15,7680 3d8: a7 84 00 01 je 3da <unqueue_me+0x12> 3dc: b9 04 00 ef lgr %r14,%r15 3e0: a7 fb ff d0 aghi %r15,-48 3e4: b9 04 00 b2 lgr %r11,%r2 3e8: e3 e0 f0 98 00 24 stg %r14,152(%r15) 3ee: e3 c0 b0 28 00 04 lg %r12,40(%r11) /* write q->lock_ptr in r12 */ 3f4: b9 02 00 cc ltgr %r12,%r12 3f8: a7 84 00 4b je 48e <unqueue_me+0xc6> /* if r12 is zero then jump over the code.... */ 3fc: e3 20 b0 28 00 04 lg %r2,40(%r11) /* write q->lock_ptr in r2 */ 402: c0 e5 00 00 00 00 brasl %r14,402 <unqueue_me+0x3a> 404: R_390_PC32DBL _spin_lock+0x2 /* use r2 as parameter for spin_lock */ So the code becomes more or less: if (q->lock_ptr != 0) spin_lock(q->lock_ptr) instead of if (lock_ptr != 0) spin_lock(lock_ptr) Which caused the oops from above. After adding a barrier gcc creates code without this problem: [...] (the same) 3ee: e3 c0 b0 28 00 04 lg %r12,40(%r11) 3f4: b9 02 00 cc ltgr %r12,%r12 3f8: b9 04 00 2c lgr %r2,%r12 3fc: a7 84 00 48 je 48c <unqueue_me+0xc4> 400: c0 e5 00 00 00 00 brasl %r14,400 <unqueue_me+0x38> 402: R_390_PC32DBL _spin_lock+0x2 As a general note, this code of unqueue_me seems a bit fishy. The retry logic of unqueue_me only works if we can guarantee, that the original value of q->lock_ptr is always a spinlock (Otherwise we overwrite kernel memory). We know that q->lock_ptr can change. I dont know what happens with the original spinlock, as I am not an expert with the futex code. Signed-off-by: Christian Borntraeger <borntrae@de.ibm.com> Acked-by: Ingo Molnar <mingo@redhat.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-08-03remove obsolete swsusp_encryptPavel Machek
Remove SWSUSP_ENCRYPT config option; it is no longer implemented. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-07-06fix prctl privilege escalation and suid_dumpable (CVE-2006-2451)Greg Kroah-Hartman
Based on a patch from Ernie Petrides During security research, Red Hat discovered a behavioral flaw in core dump handling. A local user could create a program that would cause a core file to be dumped into a directory they would not normally have permissions to write to. This could lead to a denial of service (disk consumption), or allow the local user to gain root privileges. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-20[PATCH] run_posix_cpu_timers: remove a bogus BUG_ON() (CVE-2006-2445)Oleg Nesterov
do_exit() clears ->it_##clock##_expires, but nothing prevents another cpu to attach the timer to exiting process after that. arm_timer() tries to protect against this race, but the check is racy. After exit_notify() does 'write_unlock_irq(&tasklist_lock)' and before do_exit() calls 'schedule() local timer interrupt can find tsk->exit_state != 0. If that state was EXIT_DEAD (or another cpu does sys_wait4) interrupted task has ->signal == NULL. At this moment exiting task has no pending cpu timers, they were cleanuped in __exit_signal()->posix_cpu_timers_exit{,_group}(), so we can just return from irq. John Stultz recently confirmed this bug, see http://marc.theaimsgroup.com/?l=linux-kernel&m=115015841413687 Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-20[PATCH] check_process_timers: fix possible lockupOleg Nesterov
If the local timer interrupt happens just after do_exit() sets PF_EXITING (and before it clears ->it_xxx_expires) run_posix_cpu_timers() will call check_process_timers() with tasklist_lock + ->siglock held and check_process_timers: t = tsk; do { .... do { t = next_thread(t); } while (unlikely(t->flags & PF_EXITING)); } while (t != tsk); the outer loop will never stop. Actually, the window is bigger. Another process can attach the timer after ->it_xxx_expires was cleared (see the next commit) and the 'if (PF_EXITING)' check in arm_timer() is racy (see the one after that). Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-05-20[PATCH] ptrace_attach: fix possible deadlock schenario with irqsLinus Torvalds
Eric Biederman points out that we can't take the task_lock while holding tasklist_lock for writing, because another CPU that holds the task lock might take an interrupt that then tries to take tasklist_lock for writing. Which would be a nasty deadlock, with one CPU spinning forever in an interrupt handler (although admittedly you need to really work at triggering it ;) Since the ptrace_attach() code is special and very unusual, just make it be extra careful, and use trylock+repeat to avoid the possible deadlock. Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-05-20[PATCH] Fix ptrace_attach()/ptrace_traceme()/de_thread() raceLinus Torvalds
This holds the task lock (and, for ptrace_attach, the tasklist_lock) over the actual attach event, which closes a race between attacking to a thread that is either doing a PTRACE_TRACEME or getting de-threaded. Thanks to Oleg Nesterov for reminding me about this, and Chris Wright for noticing a lost return value in my first version. Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-05-01[PATCH] make vm86 call audit_syscall_exitJason Baron
hi, The motivation behind the patch below was to address messages in /var/log/messages such as: Jan 31 10:54:15 mets kernel: audit(:0): major=252 name_count=0: freeing multiple contexts (1) Jan 31 10:54:15 mets kernel: audit(:0): major=113 name_count=0: freeing multiple contexts (2) I can reproduce by running 'get-edid' from: http://john.fremlin.de/programs/linux/read-edid/. These messages come about in the log b/c the vm86 calls do not exit via the normal system call exit paths and thus do not call 'audit_syscall_exit'. The next system call will then free the context for itself and for the vm86 context, thus generating the above messages. This patch addresses the issue by simply adding a call to 'audit_syscall_exit' from the vm86 code. Besides fixing the above error messages the patch also now allows vm86 system calls to become auditable. This is useful since strace does not appear to properly record the return values from sys_vm86. I think this patch is also a step in the right direction in terms of cleaning up some core auditing code. If we can correct any other paths that do not properly call the audit exit and entries points, then we can also eliminate the notion of context chaining. I've tested this patch by verifying that the log messages no longer appear, and that the audit records for sys_vm86 appear to be correct. Also, 'read_edid' produces itentical output. thanks, -Jason Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-24[PATCH] Add more prevent_tail_call()OGAWA Hirofumi
Those also break userland regs like following. 00000000 <sys_chown16>: 0: 0f b7 44 24 0c movzwl 0xc(%esp),%eax 5: 83 ca ff or $0xffffffff,%edx 8: 0f b7 4c 24 08 movzwl 0x8(%esp),%ecx d: 66 83 f8 ff cmp $0xffffffff,%ax 11: 0f 44 c2 cmove %edx,%eax 14: 66 83 f9 ff cmp $0xffffffff,%cx 18: 0f 45 d1 cmovne %ecx,%edx 1b: 89 44 24 0c mov %eax,0xc(%esp) 1f: 89 54 24 08 mov %edx,0x8(%esp) 23: e9 fc ff ff ff jmp 24 <sys_chown16+0x24> where the tailcall at the end overwrites the incoming stack-frame. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-17[PATCH] fix non-leader exec under ptraceRoland McGrath
This reverts most of commit 30e0fca6c1d7d26f3f2daa4dd2b12c51dadc778a. It broke the case of non-leader MT exec when ptraced. I think the bug it was intended to fix was already addressed by commit 788e05a67c343fa22f2ae1d3ca264e7f15c25eaf. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-17[PATCH] Fix suspend with traced tasksPavel Machek
strace /bin/bash misbehaves after resume; this fixes it. (akpm: it's scary calling refrigerator() in state TASK_TRACED, but it seems to do the right thing). Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-17[PATCH] RLIMIT_CPU: fix handling of a zero limitAndrew Morton
At present the kernel doesn't honour an attempt to set RLIMIT_CPU to zero seconds. But the spec says it should, and that's what 2.4.x does. Fixing this for real would involve some complexity (such as adding a new it-has-been-set flag to the task_struct, and testing that everwhere, instead of overloading the value of it_prof_expires). Given that a 2.4 kernel won't actually send the signal until one second has expired anyway, let's just handle this case by treating the caller's zero-seconds as one second. Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Ulrich Weigand <uweigand@de.ibm.com> Cc: Cliff Wickman <cpw@sgi.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] RCU signal handlingOleg Nesterov
made this BUG_ON() unsafe. This code runs under ->siglock, while switch_exec_pids() takes tasklist_lock. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-07[PATCH] Fix module refcount leak in __set_personality()Sergey Vlasov
If the change of personality does not lead to change of exec domain, __set_personality() returned without releasing the module reference acquired by lookup_exec_domain(). This patch was already included in Linus' tree. Signed-off-by: Sergey Vlasov <vsu@altlinux.ru> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-07[PATCH] wrong error path in dup_fd() leading to oopses in RCUKirill Korotaev
Wrong error path in dup_fd() - it should return NULL on error, not an address of already freed memory :/ Triggered by OpenVZ stress test suite. What is interesting is that it was causing different oopses in RCU like below: Call Trace: [<c013492c>] rcu_do_batch+0x2c/0x80 [<c0134bdd>] rcu_process_callbacks+0x3d/0x70 [<c0126cf3>] tasklet_action+0x73/0xe0 [<c01269aa>] __do_softirq+0x10a/0x130 [<c01058ff>] do_softirq+0x4f/0x60 ======================= [<c0113817>] smp_apic_timer_interrupt+0x77/0x110 [<c0103b54>] apic_timer_interrupt+0x1c/0x24 Code: Bad EIP value. <0>Kernel panic - not syncing: Fatal exception in interrupt Signed-Off-By: Pavel Emelianov <xemul@sw.ru> Signed-Off-By: Dmitry Mishin <dim@openvz.org> Signed-Off-By: Kirill Korotaev <dev@openvz.org> Signed-Off-By: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-27[PATCH] fix scheduler deadlockAnton Blanchard
We have noticed lockups during boot when stress testing kexec on ppc64. Two cpus would deadlock in scheduler code trying to grab already taken spinlocks. The double_rq_lock code uses the address of the runqueue to order the taking of multiple locks. This address is a per cpu variable: if (rq1 < rq2) { spin_lock(&rq1->lock); spin_lock(&rq2->lock); } else { spin_lock(&rq2->lock); spin_lock(&rq1->lock); } On the other hand, the code in wake_sleeping_dependent uses the cpu id order to grab locks: for_each_cpu_mask(i, sibling_map) spin_lock(&cpu_rq(i)->lock); This means we rely on the address of per cpu data increasing as cpu ids increase. While this will be true for the generic percpu implementation it may not be true for arch specific implementations. One way to solve this is to always take runqueues in cpu id order. To do this we add a cpu variable to the runqueue and check it in the double runqueue locking functions. Signed-off-by: Anton Blanchard <anton@samba.org> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-18[PATCH] disable unshare(CLONE_VM) for nowOleg Nesterov
sys_unshare() does mmput(new_mm). This is not enough if we have mm->core_waiters. This patch is a temporary fix for soon to be released 2.6.16. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> [ Checked with Uli: "I'm not planning to use unshare(CLONE_VM). It's not needed for any functionality planned so far. What we (as in Red Hat) need unshare() for now is the filesystem side." ] Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-17[PATCH] posix-timers: fix requeue accounting when signal is ignoredRoman Zippel
When the posix-timer signal is ignored then the timer is rearmed by the callback function. The requeue pending accounting has to be fixed up else the state might be wrong. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-17[PATCH] time_interpolator: add __read_mostlyChristoph Lameter
The pointer to the current time interpolator and the current list of time interpolators are typically only changed during bootup. Adding __read_mostly takes them away from possibly hot cachelines. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-17[PATCH] unshare: Use rcu_assign_pointer when setting sighandEric W. Biederman
The sighand pointer only needs the rcu_read_lock on the read side. So only depending on task_lock protection when setting this pointer is not enough. We also need a memory barrier to ensure the initialization is seen first. Use rcu_assign_pointer as it does this for us, and clearly documents that we are setting an rcu readable pointer. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Paul E. McKenney <paulmck@us.ibm.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-14[PATCH] Fix sigaltstack corruption among cloned threadsGOTO Masanori
This patch fixes alternate signal stack corruption among cloned threads with CLONE_SIGHAND (and CLONE_VM) for linux-2.6.16-rc6. The value of alternate signal stack is currently inherited after a call of clone(... CLONE_SIGHAND | CLONE_VM). But if sigaltstack is set by a parent thread, and then if multiple cloned child threads (+ parent threads) call signal handler at the same time, some threads may be conflicted - because they share to use the same alternative signal stack region. Finally they get sigsegv. It's an undesirable race condition. Note that child threads created from NPTL pthread_create() also hit this conflict when the parent thread uses sigaltstack, without my patch. To fix this problem, this patch clears the child threads' sigaltstack information like exec(). This behavior follows the SUSv3 specification. In SUSv3, pthread_create() says "The alternate stack shall not be inherited (when new threads are initialized)". It means that sigaltstack should be cleared when sigaltstack memory space is shared by cloned threads with CLONE_SIGHAND. Note that I chose "if (clone_flags & CLONE_SIGHAND)" line because: - If clone_flags line is not existed, fork() does not inherit sigaltstack. - CLONE_VM is another choice, but vfork() does not inherit sigaltstack. - CLONE_SIGHAND implies CLONE_VM, and it looks suitable. - CLONE_THREAD is another candidate, and includes CLONE_SIGHAND + CLONE_VM, but this flag has a bit different semantics. I decided to use CLONE_SIGHAND. [ Changed to test for CLONE_VM && !CLONE_VFORK after discussion --Linus ] Signed-off-by: GOTO Masanori <gotom@sanori.org> Cc: Roland McGrath <roland@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Acked-by: Linus Torvalds <torvalds@osdl.org> Cc: Ulrich Drepper <drepper@redhat.com> Cc: Jakub Jelinek <jakub@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-11[PATCH] remove __put_task_struct_cb export againChristoph Hellwig
The patch '[PATCH] RCU signal handling' [1] added an export for __put_task_struct_cb, a put_task_struct helper newly introduced in that patch. But the put_task_struct couldn't be used modular previously as __put_task_struct wasn't exported. There are not callers of it in modular code, and it shouldn't be exported because we don't want drivers to hold references to task_structs. This patch removes the export and folds __put_task_struct into __put_task_struct_cb as there's no other caller. [1] http://www2.kernel.org/git/gitweb.cgi?p=linux/kernel/git/torvalds/linux-2.6.git;a=commit;h=e56d090310d7625ecb43a1eeebd479f04affb48b Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Paul E. McKenney <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-08[PATCH] fix file countingDipankar Sarma
I have benchmarked this on an x86_64 NUMA system and see no significant performance difference on kernbench. Tested on both x86_64 and powerpc. The way we do file struct accounting is not very suitable for batched freeing. For scalability reasons, file accounting was constructor/destructor based. This meant that nr_files was decremented only when the object was removed from the slab cache. This is susceptible to slab fragmentation. With RCU based file structure, consequent batched freeing and a test program like Serge's, we just speed this up and end up with a very fragmented slab - llm22:~ # cat /proc/sys/fs/file-nr 587730 0 758844 At the same time, I see only a 2000+ objects in filp cache. The following patch I fixes this problem. This patch changes the file counting by removing the filp_count_lock. Instead we use a separate percpu counter, nr_files, for now and all accesses to it are through get_nr_files() api. In the sysctl handler for nr_files, we populate files_stat.nr_files before returning to user. Counting files as an when they are created and destroyed (as opposed to inside slab) allows us to correctly count open files with RCU. Signed-off-by: Dipankar Sarma <dipankar@in.ibm.com> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-08[PATCH] rcu batch tuningDipankar Sarma
This patch adds new tunables for RCU queue and finished batches. There are two types of controls - number of completed RCU updates invoked in a batch (blimit) and monitoring for high rate of incoming RCUs on a cpu (qhimark, qlowmark). By default, the per-cpu batch limit is set to a small value. If the input RCU rate exceeds the high watermark, we do two things - force quiescent state on all cpus and set the batch limit of the CPU to INTMAX. Setting batch limit to INTMAX forces all finished RCUs to be processed in one shot. If we have more than INTMAX RCUs queued up, then we have bigger problems anyway. Once the incoming queued RCUs fall below the low watermark, the batch limit is set to the default. Signed-off-by: Dipankar Sarma <dipankar@in.ibm.com> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-08[PATCH] idle threads should have a sane ->timestamp valueIngo Molnar
Idle threads should have a sane ->timestamp value, to avoid init kernel thread(s) from inheriting it and causing miscalculations in try_to_wake_up(). Reported-by: Mike Galbraith <efault@gmx.de>. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-06[PATCH] time: add barrier after updating jiffies_64Atsushi Nemoto
Add a compiler barrier so that we don't read jiffies before updating jiffies_64. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-06[PATCH] fix next_timer_interrupt() for hrtimerTony Lindgren
Also from Thomas Gleixner <tglx@linutronix.de> Function next_timer_interrupt() got broken with a recent patch 6ba1b91213e81aa92b5cf7539f7d2a94ff54947c as sys_nanosleep() was moved to hrtimer. This broke things as next_timer_interrupt() did not check hrtimer tree for next event. Function next_timer_interrupt() is needed with dyntick (CONFIG_NO_IDLE_HZ, VST) implementations, as the system can be in idle when next hrtimer event was supposed to happen. At least ARM and S390 currently use next_timer_interrupt(). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-06Add early-boot-safety check to cond_resched()Linus Torvalds
Just to be safe, we should not trigger a conditional reschedule during the early boot sequence. We've historically done some questionable early on, and the safety warnings in __might_sleep() are generally turned off during that period, so there might be problems lurking. This affects CONFIG_PREEMPT_VOLUNTARY, which takes over might_sleep() to cause a voluntary conditional reschedule. Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-02[PATCH] time_interpolator: Use readq_relaxed() instead of readq().Christoph Lameter
On some platforms readq performs additional work to make sure I/O is done in a coherent way. This is not needed for time retrieval as done by the time interpolator. So we can use readq_relaxed instead which will improve performance. It affects sparc64 and ia64 only. Apparently it makes a significant difference on ia64. Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: john stultz <johnstul@us.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-02[PATCH] fix acpi_video_flags on x86-64Stefan Seyfried
acpi_video_flags variable is unsigned long, so it should be set as such. This actually matters on x86-64. Signed-off-by: Stefan Seyfried <seife@suse.de> Signed-off-by: Pavel Machek <pavel@suse.cz> Cc: "Brown, Len" <len.brown@intel.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-28[IA64] sysctl option to silence unaligned trap warningsJes Sorensen
Allow sysadmin to disable all warnings about userland apps making unaligned accesses by using: # echo 1 > /proc/sys/kernel/ignore-unaligned-usertrap Rather than having to use prctl on a process by process basis. Default behaivour leaves the warnings enabled. Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-02-20[PATCH] kjournald keeps reference to namespaceBjörn Steinbrink
In daemonize() a new thread gets cleaned up and 'merged' with init_task. The current fs_struct is handled there, but not the current namespace. This adds the namespace part. [ Eric Biederman pointed out the namespace wrappers, and also notes that we can't ever count on using our parents namespace because we already have called exit_fs(), which is the only way to the namespace from a process. ] Signed-off-by: Björn Steinbrink <B.Steinbrink@gmx.de> Acked-by: Eric Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-20Merge branch 'fixes.b8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/bird
2006-02-20[PATCH] Fix compile for CONFIG_SYSVIPC=n or CONFIG_SYSCTL=nStephen Rothwell
The compat syscalls are added to sys_ni.c since they are not defined if the above CONFIG options are off. Also, nfs would not build with CONFIG_SYSCTL off. Noticed by Arthur Othieno. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: "David S. Miller" <davem@davemloft.net> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-20[PATCH] Fix undefined symbols for nommu architectureLuke Yang
Signed-off-by: Luke Yang <luke.adi@gmail.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-20[PATCH] suspend-to-ram: allow video options to be set at runtimePavel Machek
Currently, acpi video options can only be set on kernel command line. That's little inflexible; I'd like userland s2ram application that just works, and modifying kernel command line according to whitelist is not fun. It is better to just allow s2ram application to set video options just before suspend (according to the whitelist). This implements sysctl to allow setting suspend video options without reboot. (akpm: Documentation updates for this new sysctl are pending..) Signed-off-by: Pavel Machek <pavel@suse.cz> Cc: "Brown, Len" <len.brown@intel.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-18[PATCH] GFP_KERNEL allocations in atomic (auditsc)Al Viro
audit_log_exit() is called from atomic contexts and gets explicit gfp_mask argument; it should use it for all allocations rather than doing some with gfp_mask and some with GFP_KERNEL. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-02-17[PATCH] swsusp: fix breakage with swap on LVMRafael J. Wysocki
Restore the compatibility with the older code and make it possible to suspend if the kernel command line doesn't contain the "resume=" argument Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-17[PATCH] Introduce CONFIG_DEFAULT_MIGRATION_COSTIngo Molnar
Heiko Carstens <heiko.carstens@de.ibm.com> wrote: The boot sequence on s390 sometimes takes ages and we spend a very long time (up to one or two minutes) in calibrate_migration_costs. The time spent there differs from boot to boot. Also the calculated costs differ a lot. I've seen differences by up to a factor of 15 (yes, factor not percent). Also I doubt that making these measurements make much sense on a completely virtualized architecture where you cannot tell how much cpu time you will get anyway. So introduce the CONFIG_DEFAULT_MIGRATION_COST method for an architecture to set the scheduler migration costs. This turns off automatic detection of migration costs. Makes sense on virtual platforms, where migration costs are hard to measure accurately. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-17[PATCH] Provide an interface for getting the current tick lengthPaul Mackerras
This provides an interface for arch code to find out how many nanoseconds are going to be added on to xtime by the next call to do_timer. The value returned is a fixed-point number in 52.12 format in nanoseconds. The reason for this format is that it gives the full precision that the timekeeping code is using internally. The motivation for this is to fix a problem that has arisen on 32-bit powerpc in that the value returned by do_gettimeofday drifts apart from xtime if NTP is being used. PowerPC is now using a lockless do_gettimeofday based on reading the timebase register and performing some simple arithmetic. (This method of getting the time is also exported to userspace via the VDSO.) However, the factor and offset it uses were calculated based on the nominal tick length and weren't being adjusted when NTP varied the tick length. Note that 64-bit powerpc has had the lockless do_gettimeofday for a long time now. It also had an extremely hairy routine that got called from the 32-bit compat routine for adjtimex, which adjusted the factor and offset according to what it thought the timekeeping code was going to do. Not only was this only called if a 32-bit task did adjtimex (i.e. not if a 64-bit task did adjtimex), it was also duplicating computations from kernel/timer.c and it wasn't clear that it was (still) correct. The simple solution is to ask the timekeeping code how long the current jiffy will be on each timer interrupt, after calling do_timer. If this jiffy will be a different length from the last one, we then need to compute new values for the factor and offset used in the lockless do_gettimeofday. In this way we can keep xtime and do_gettimeofday in sync, even when NTP is varying the tick length. Note that when adjtimex varies the tick length, it almost always introduces the variation from the next tick on. The only case I could see where adjtimex would vary the length of the current tick is when an old-style adjtime adjustment is being cancelled. (It's not clear to me why the adjustment has to be cancelled immediately rather than from the next tick on.) Thus I don't see any real need for a hook in adjtimex; the rare case of an old-style adjustment being cancelled can be fixed up at the next tick. Signed-off-by: Paul Mackerras <paulus@samba.org> Acked-by: john stultz <johnstul@us.ibm.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-17[PATCH] x86_64: Add boot option to disable randomized mappings and cleanupAndi Kleen
AMD SimNow!'s JIT doesn't like them at all in the guest. For distribution installation it's easiest if it's a boot time option. Also I moved the variable to a more appropiate place and make it independent from sysctl And marked __read_mostly which it is. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
