This is the 4.1.5 stable release
commit e3eea1404f5ff7a2ceb7b5e7ba412a6fd94f2935 upstream.
Commit 4104d326b670 ("ftrace: Remove global function list and call function
directly") simplified the ftrace code by removing the global_ops list with a
new design. But this cleanup also broke the filtering of PIDs that are added
to the set_ftrace_pid file.
Add back the proper hooks to have pid filtering working once again.
Reported-by: Matt Fleming <matt@console-pimps.org>
Reported-by: Richard Weinberger <richard.weinberger@gmail.com>
Tested-by: Matt Fleming <matt@console-pimps.org>
commit 75a06189fc508a2acf470b0b12710362ffb2c4b1 upstream.
The resend mechanism happily calls the interrupt handler of interrupts
which are marked IRQ_NESTED_THREAD from softirq context. This can
result in crashes because the interrupt handler is not the proper way
to invoke the device handlers. They must be invoked via
handle_nested_irq.
Prevent the resend even if the interrupt has no valid parent irq
set. Its better to have a lost interrupt than a crashing machine.
Reported-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
This is the 4.1.4 stable release
commit d194e5d666225b04c7754471df0948f645b6ab3a upstream.
The final version of commit 637241a900cb ("kmsg: honor dmesg_restrict
sysctl on /dev/kmsg") lost few hooks, as result security_syslog() are
processed incorrectly:
- open of /dev/kmsg checks syslog access permissions by using
check_syslog_permissions() where security_syslog() is not called if
dmesg_restrict is set.
- syslog syscall and /proc/kmsg calls do_syslog() where security_syslog
can be executed twice (inside check_syslog_permissions() and then
directly in do_syslog())
With this patch security_syslog() is called once only in all
syslog-related operations regardless of dmesg_restrict value.
Fixes: 637241a900cb ("kmsg: honor dmesg_restrict sysctl on /dev/kmsg")
Signed-off-by: Vasily Averin <vvs@virtuozzo.com>
Cc: Josh Boyer <jwboyer@redhat.com>
Cc: Eric Paris <eparis@redhat.com>
commit fff3b16d2754a061a3549c4307a186423a0128fd upstream.
Many harddisks (mostly WD ones) have firmware problems and take too
long, more than 10 seconds, to resume from suspend. And this often
exceeds the default DPM watchdog timeout (12 seconds), resulting in a
kernel panic out of sudden.
Since most distros just take the default as is, we should give a bit
more safer value. This patch increases the default value from 12
seconds to one minute, which has been confirmed to be long enough for
such problematic disks.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=91921
Fixes: 70fea60d888d (PM / Sleep: Detect device suspend/resume lockup and log event)
commit 6224beb12e190ff11f3c7d4bf50cb2922878f600 upstream.
Fengguang Wu's tests triggered a bug in the branch tracer's start up
test when CONFIG_DEBUG_PREEMPT set. This was because that config
adds some debug logic in the per cpu field, which calls back into
the branch tracer.
The branch tracer has its own recursive checks, but uses a per cpu
variable to implement it. If retrieving the per cpu variable calls
back into the branch tracer, you can see how things will break.
Instead of using a per cpu variable, use the trace_recursion field
of the current task struct. Simply set a bit when entering the
branch tracing and clear it when leaving. If the bit is set on
entry, just don't do the tracing.
There's also the case with lockdep, as the local_irq_save() called
before the recursion can also trigger code that can call back into
the function. Changing that to a raw_local_irq_save() will protect
that as well.
This prevents the recursion and the inevitable crash that follows.
Link: http://lkml.kernel.org/r/20150630141803.GA28071@wfg-t540p.sh.intel.com
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Tested-by: Fengguang Wu <fengguang.wu@intel.com>
commit cc9e4bde03f2b4cfba52406c021364cbd2a4a0f3 upstream.
The trace.h header when called without CONFIG_EVENT_TRACING enabled
(seldom done), will not compile because of a typo in the protocol
of trace_event_enum_update().
commit 6b88f44e161b9ee2a803e5b2b1fbcf4e20e8b980 upstream.
While debugging a WARN_ON() for filtering, I found that it is possible
for the filter string to be referenced after its end. With the filter:
# echo '>' > /sys/kernel/debug/events/ext4/ext4_truncate_exit/filter
The filter_parse() function can call infix_get_op() which calls
infix_advance() that updates the infix filter pointers for the cnt
and tail without checking if the filter is already at the end, which
will put the cnt to zero and the tail beyond the end. The loop then calls
infix_next() that has
ps->infix.cnt--;
return ps->infix.string[ps->infix.tail++];
The cnt will now be below zero, and the tail that is returned is
already passed the end of the filter string. So far the allocation
of the filter string usually has some buffer that is zeroed out, but
if the filter string is of the exact size of the allocated buffer
there's no guarantee that the charater after the nul terminating
character will be zero.
Luckily, only root can write to the filter.
commit b4875bbe7e68f139bd3383828ae8e994a0df6d28 upstream.
When testing the fix for the trace filter, I could not come up with
a scenario where the operand count goes below zero, so I added a
WARN_ON_ONCE(cnt < 0) to the logic. But there is legitimate case
that it can happen (although the filter would be wrong).
That is, a single operation without any operands will hit the path
where the WARN_ON_ONCE() can trigger. Although this is harmless,
and the filter is reported as a error. But instead of spitting out
a warning to the kernel dmesg, just fail nicely and report it via
the proper channels.
Link: http://lkml.kernel.org/r/558C6082.90608@oracle.com
Reported-by: Vince Weaver <vincent.weaver@maine.edu>
Reported-by: Sasha Levin <sasha.levin@oracle.com>
commit 63781394c540dd9e666a6b21d70b64dd52bce76e upstream.
request_any_context_irq() returns a negative value on failure.
It returns either IRQC_IS_HARDIRQ or IRQC_IS_NESTED on success.
So fix testing return value of request_any_context_irq().
Also fixup the return value of devm_request_any_context_irq() to make it
consistent with request_any_context_irq().
Fixes: 0668d3065128 ("genirq: Add devm_request_any_context_irq()")
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
Link: http://lkml.kernel.org/r/1431334978.17783.4.camel@ingics.com
commit 9a1bd63cdae4b623494c4ebaf723a91c35ec49fb upstream.
The list of loaded modules is walked through in
module_kallsyms_on_each_symbol (called by kallsyms_on_each_symbol). The
module_mutex lock should be acquired to prevent potential corruptions
in the list.
This was uncovered with new lockdep asserts in module code introduced by
the commit 0be964be0d45 ("module: Sanitize RCU usage and locking") in
recent next- trees.
Signed-off-by: Miroslav Benes <mbenes@suse.cz>
Acked-by: Josh Poimboeuf <jpoimboe@redhat.com>
commit 6e91f8cb138625be96070b778d9ba71ce520ea7e upstream.
If, at the time __rcu_process_callbacks() is invoked, there are callbacks
in Tiny RCU's callback list, but none of them are ready to be invoked,
the current list-management code will knit the non-ready callbacks out
of the list. This can result in hangs and possibly worse. This commit
therefore inserts a check for there being no callbacks that can be
invoked immediately.
This bug is unlikely to occur -- you have to get a new callback between
the time rcu_sched_qs() or rcu_bh_qs() was called, but before we get to
__rcu_process_callbacks(). It was detected by the addition of RCU-bh
testing to rcutorture, which in turn was instigated by Iftekhar Ahmed's
mutation testing. Although this bug was made much more likely by
915e8a4fe45e (rcu: Remove fastpath from __rcu_process_callbacks()), this
did not cause the bug, but rather made it much more probable. That
said, it takes more than 40 hours of rcutorture testing, on average,
for this bug to appear, so this fix cannot be considered an emergency.
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
commit f9bb48825a6b5d02f4cabcc78967c75db903dcdc upstream.
This allows for better documentation in the code and
it allows for a simpler and fully correct version of
fs_fully_visible to be written.
The mount points converted and their filesystems are:
/sys/hypervisor/s390/ s390_hypfs
/sys/kernel/config/ configfs
/sys/kernel/debug/ debugfs
/sys/firmware/efi/efivars/ efivarfs
/sys/fs/fuse/connections/ fusectl
/sys/fs/pstore/ pstore
/sys/kernel/tracing/ tracefs
/sys/fs/cgroup/ cgroup
/sys/kernel/security/ securityfs
/sys/fs/selinux/ selinuxfs
/sys/fs/smackfs/ smackfs
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
commit f9bd6733d3f11e24f3949becf277507d422ee1eb upstream.
Add a magic sysctl table sysctl_mount_point that when used to
create a directory forces that directory to be permanently empty.
Update the code to use make_empty_dir_inode when accessing permanently
empty directories.
Update the code to not allow adding to permanently empty directories.
Update /proc/sys/fs/binfmt_misc to be a permanently empty directory.
commit 2f993cf093643b98477c421fa2b9a98dcc940323 upstream.
While looking for other users of get_state/cond_sync. I Found
ring_buffer_attach() and it looks obviously buggy?
Don't we need to ensure that we have "synchronize" _between_
list_del() and list_add() ?
IOW. Suppose that ring_buffer_attach() preempts right_after
get_state_synchronize_rcu() and gp completes before spin_lock().
In this case cond_synchronize_rcu() does nothing and we reuse
->rb_entry without waiting for gp in between?
It also moves the ->rcu_pending check under "if (rb)", to make it
more readable imo.
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: dave@stgolabs.net
Cc: der.herr@hofr.at
Cc: josh@joshtriplett.org
Cc: tj@kernel.org
Fixes: b69cf53640da ("perf: Fix a race between ring_buffer_detach() and ring_buffer_attach()")
Link: http://lkml.kernel.org/r/20150530200425.GA15748@redhat.com
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace
Pull tracing filter fix from Steven Rostedt:
"Vince Weaver reported a warning when he added perf event filters into
his fuzzer tests. There's a missing check of balanced operations when
parenthesis are used, and this triggers a WARN_ON() and when reading
the failure, the filter reports no failure occurred.
The operands were not being checked if they match, this adds that"
* tag 'trace-fix-filter-4.1-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace:
tracing: Have filter check for balanced ops
When the following filter is used it causes a warning to trigger:
# cd /sys/kernel/debug/tracing
# echo "((dev==1)blocks==2)" > events/ext4/ext4_truncate_exit/filter
-bash: echo: write error: Invalid argument
# cat events/ext4/ext4_truncate_exit/filter
((dev==1)blocks==2)
parse_error: No error
WARNING: CPU: 2 PID: 1223 at kernel/trace/trace_events_filter.c:1640 replace_preds+0x3c5/0x990()
Modules linked in: bnep lockd grace bluetooth ...
CPU: 3 PID: 1223 Comm: bash Tainted: G W 4.1.0-rc3-test+ #450
Hardware name: Hewlett-Packard HP Compaq Pro 6300 SFF/339A, BIOS K01 v02.05 05/07/2012
0000000000000668 ffff8800c106bc98 ffffffff816ed4f9 ffff88011ead0cf0
0000000000000000 ffff8800c106bcd8 ffffffff8107fb07 ffffffff8136b46c
ffff8800c7d81d48 ffff8800d4c2bc00 ffff8800d4d4f920 00000000ffffffea
Call Trace:
[<ffffffff816ed4f9>] dump_stack+0x4c/0x6e
[<ffffffff8107fb07>] warn_slowpath_common+0x97/0xe0
[<ffffffff8136b46c>] ? _kstrtoull+0x2c/0x80
[<ffffffff8107fb6a>] warn_slowpath_null+0x1a/0x20
[<ffffffff81159065>] replace_preds+0x3c5/0x990
[<ffffffff811596b2>] create_filter+0x82/0xb0
[<ffffffff81159944>] apply_event_filter+0xd4/0x180
[<ffffffff81152bbf>] event_filter_write+0x8f/0x120
[<ffffffff811db2a8>] __vfs_write+0x28/0xe0
[<ffffffff811dda43>] ? __sb_start_write+0x53/0xf0
[<ffffffff812e51e0>] ? security_file_permission+0x30/0xc0
[<ffffffff811dc408>] vfs_write+0xb8/0x1b0
[<ffffffff811dc72f>] SyS_write+0x4f/0xb0
[<ffffffff816f5217>] system_call_fastpath+0x12/0x6a
---[ end trace e11028bd95818dcd ]---
Worse yet, reading the error message (the filter again) it says that
there was no error, when there clearly was. The issue is that the
code that checks the input does not check for balanced ops. That is,
having an op between a closed parenthesis and the next token.
This would only cause a warning, and fail out before doing any real
harm, but it should still not caues a warning, and the error reported
should work:
((dev==1)blocks==2)
parse_error: Meaningless filter expression
And give no kernel warning.
Link: http://lkml.kernel.org/r/20150615175025.7e809215@gandalf.local.home
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Cc: stable@vger.kernel.org # 2.6.31+
Tested-by: Vince Weaver <vincent.weaver@maine.edu>
Pull lockdep fix from Ingo Molnar:
"A lockdep/modules unload race fix that can oops"
* 'locking-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
lockdep: Fix a race between /proc/lock_stat and module unload
Pull ring buffer benchmark buglet fix from Steven Rostedt:
"Wang Long fixed a minor bug in the module parameter for the ring
buffer benchmark, where the produce_fifo was being ignored and the
producer thread's priority was being set with the consumer_fifo
parameter"
* tag 'trace-rb-bm-fix-4.1-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace:
ring-buffer-benchmark: Fix the wrong sched_priority of producer
The producer should be used producer_fifo as its sched_priority,
so correct it.
Link: http://lkml.kernel.org/r/1433923957-67842-1-git-send-email-long.wanglong@huawei.com
Cc: stable@vger.kernel.org # 2.6.33+
Signed-off-by: Wang Long <long.wanglong@huawei.com>
Jovi Zhangwei reported the following problem
Below kernel vm bug can be triggered by tcpdump which mmaped a lot of pages
with GFP_COMP flag.
[Mon May 25 05:29:33 2015] page:ffffea0015414000 count:66 mapcount:1 mapping: (null) index:0x0
[Mon May 25 05:29:33 2015] flags: 0x20047580004000(head)
[Mon May 25 05:29:33 2015] page dumped because: VM_BUG_ON_PAGE(compound_order(page) && !PageTransHuge(page))
[Mon May 25 05:29:33 2015] ------------[ cut here ]------------
[Mon May 25 05:29:33 2015] kernel BUG at mm/migrate.c:1661!
[Mon May 25 05:29:33 2015] invalid opcode: 0000 [#1] SMP
In this case it was triggered by running tcpdump but it's not necessary
reproducible on all systems.
sudo tcpdump -i bond0.100 'tcp port 4242' -c 100000000000 -w 4242.pcap
Compound pages cannot be migrated and it was not expected that such pages
be marked for NUMA balancing. This did not take into account that drivers
such as net/packet/af_packet.c may insert compound pages into userspace
with vm_insert_page. This patch tells the NUMA balancing protection
scanner to skip all VM_MIXEDMAP mappings which avoids the possibility that
compound pages are marked for migration.
Reported-by: Jovi Zhangwei <jovi@cloudflare.com>
Cc: <stable@vger.kernel.org>
The lock_class iteration of /proc/lock_stat is not serialized against
the lockdep_free_key_range() call from module unload.
Therefore it can happen that we find a class of which ->name/->key are
no longer valid.
There is a further bug in zap_class() that left ->name dangling. Cure
this. Use RCU_INIT_POINTER() because NULL.
Since lockdep_free_key_range() is rcu_sched serialized, we can read
both ->name and ->key under rcu_read_lock_sched() (preempt-disable)
and be assured that if we observe a !NULL value it stays safe to use
for as long as we hold that lock.
If we observe both NULL, skip the entry.
Reported-by: Jerome Marchand <jmarchan@redhat.com>
Tested-by: Jerome Marchand <jmarchan@redhat.com>
Link: http://lkml.kernel.org/r/20150602105013.GS3644@twins.programming.kicks-ass.net
Pull perf fixes from Ingo Molnar:
"The biggest chunk of the changes are two regression fixes: a HT
workaround fix and an event-group scheduling fix. It's been verified
with 5 days of fuzzer testing.
Other fixes:
- eBPF fix
- a BIOS breakage detection fix
- PMU driver fixes"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf/x86/intel/pt: Fix a refactoring bug
perf/x86: Tweak broken BIOS rules during check_hw_exists()
perf/x86/intel/pt: Untangle pt_buffer_reset_markers()
perf: Disallow sparse AUX allocations for non-SG PMUs in overwrite mode
perf/x86: Improve HT workaround GP counter constraint
perf/x86: Fix event/group validation
perf: Fix race in BPF program unregister
In the functions compat_get_bitmap() and compat_put_bitmap() the
variable nr_compat_longs stores how many compat_ulong_t words should be
copied in a loop.
The copy loop itself is this:
if (nr_compat_longs-- > 0) {
if (__get_user(um, umask)) return -EFAULT;
} else {
um = 0;
Since nr_compat_longs gets unconditionally decremented in each loop and
since it's type is unsigned this could theoretically lead to out of
bounds accesses to userspace if nr_compat_longs wraps around to
(unsigned)(-1).
Although the callers currently do not trigger out-of-bounds accesses, we
should better implement the loop in a safe way to completely avoid such
warp-arounds.
Signed-off-by: Helge Deller <deller@gmx.de>
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull fixes for cpumask and modules from Rusty Russell:
"** NOW WITH TESTING! **
Two fixes which got lost in my recent distraction. One is a weird
cpumask function which needed to be rewritten, the other is a module
bug which is cc:stable"
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
cpumask_set_cpu_local_first => cpumask_local_spread, lament
module: Call module notifier on failure after complete_formation()
PMUs that don't support hardware scatter tables require big contiguous
chunks of memory and a PMI to switch between them. However, in overwrite
using a PMI for this purpose adds extra overhead that the users would
like to avoid. Thus, in overwrite mode for such PMUs we can only allow
one contiguous chunk for the entire requested buffer.
This patch changes the behavior accordingly, so that if the buddy allocator
fails to come up with a single high-order chunk for the entire requested
buffer, the allocation will fail.
Signed-off-by: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: acme@infradead.org
Cc: adrian.hunter@intel.com
Cc: hpa@zytor.com
Link: http://lkml.kernel.org/r/1432308626-18845-2-git-send-email-alexander.shishkin@linux.intel.com
there is a race between perf_event_free_bpf_prog() and free_trace_kprobe():
__free_event()
event->destroy(event)
tp_perf_event_destroy()
perf_trace_destroy()
perf_trace_event_unreg()
which is dropping event->tp_event->perf_refcount and allows to proceed in:
unregister_trace_kprobe()
unregister_kprobe_event()
trace_remove_event_call()
probe_remove_event_call()
free_trace_kprobe()
while __free_event does:
call_rcu(&event->rcu_head, free_event_rcu);
free_event_rcu()
To fix the race simply move perf_event_free_bpf_prog() before
event->destroy(), since event->tp_event is still valid at that point.
Note, perf_trace_destroy() is not racing with trace_remove_event_call()
since they both grab event_mutex.
Reported-by: Wang Nan <wangnan0@huawei.com>
Signed-off-by: Alexei Starovoitov <ast@plumgrid.com>
Cc: Arnaldo Carvalho de Melo <acme@infradead.org>
Cc: lizefan@huawei.com
Cc: pi3orama@163.com
Fixes: 2541517c32be ("tracing, perf: Implement BPF programs attached to kprobes")
Link: http://lkml.kernel.org/r/1431717321-28772-1-git-send-email-ast@plumgrid.com
Pull timer fix from Thomas Gleixner:
"One more fix from the timer departement:
- Handle division of negative nanosecond values proper on 32bit.
A recent cleanup wrecked the sign handling of the dividend and
dropped the check for negative divisors"
* 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
ktime: Fix ktime_divns to do signed division
Pull block fixes from Jens Axboe:
"Three small fixes that have been picked up the last few weeks.
Specifically:
- Fix a memory corruption issue in NVMe with malignant user
constructed request. From Christoph.
- Kill (now) unused blk_queue_bio(), dm was changed to not need this
anymore. From Mike Snitzer.
- Always use blk_schedule_flush_plug() from the io_schedule() path
when flushing a plug, fixing a !TASK_RUNNING warning with md. From
Shaohua"
* 'for-linus' of git://git.kernel.dk/linux-block:
sched: always use blk_schedule_flush_plug in io_schedule_out
nvme: fix kernel memory corruption with short INQUIRY buffers
block: remove export for blk_queue_bio
Commit ab992dc38f9a ("watchdog: Fix merge 'conflict'") has introduced an
obvious deadlock because of a typo. watchdog_proc_mutex should be
unlocked on exit.
Thanks to Miroslav Benes who was staring at the code with me and noticed
this.
Duh-by: Peter Zijlstra <peterz@infradead.org>
block plug callback could sleep, so we introduce a parameter
'from_schedule' and corresponding drivers can use it to destinguish a
schedule plug flush or a plug finish. Unfortunately io_schedule_out
still uses blk_flush_plug(). This causes below output (Note, I added a
might_sleep() in raid1_unplug to make it trigger faster, but the whole
thing doesn't matter if I add might_sleep). In raid1/10, this can cause
deadlock.
This patch makes io_schedule_out always uses blk_schedule_flush_plug.
This should only impact drivers (as far as I know, raid 1/10) which are
sensitive to the 'from_schedule' parameter.
[ 370.817949] ------------[ cut here ]------------
[ 370.817960] WARNING: CPU: 7 PID: 145 at ../kernel/sched/core.c:7306 __might_sleep+0x7f/0x90()
[ 370.817969] do not call blocking ops when !TASK_RUNNING; state=2 set at [<ffffffff81092fcf>] prepare_to_wait+0x2f/0x90
[ 370.817971] Modules linked in: raid1
[ 370.817976] CPU: 7 PID: 145 Comm: kworker/u16:9 Tainted: G W 4.0.0+ #361
[ 370.817977] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.7.5-20140709_153802- 04/01/2014
[ 370.817983] Workqueue: writeback bdi_writeback_workfn (flush-9:1)
[ 370.817985] ffffffff81cd83be ffff8800ba8cb298 ffffffff819dd7af 0000000000000001
[ 370.817988] ffff8800ba8cb2e8 ffff8800ba8cb2d8 ffffffff81051afc ffff8800ba8cb2c8
[ 370.817990] ffffffffa00061a8 000000000000041e 0000000000000000 ffff8800ba8cba28
[ 370.817993] Call Trace:
[ 370.817999] [<ffffffff819dd7af>] dump_stack+0x4f/0x7b
[ 370.818002] [<ffffffff81051afc>] warn_slowpath_common+0x8c/0xd0
[ 370.818004] [<ffffffff81051b86>] warn_slowpath_fmt+0x46/0x50
[ 370.818006] [<ffffffff81092fcf>] ? prepare_to_wait+0x2f/0x90
[ 370.818008] [<ffffffff81092fcf>] ? prepare_to_wait+0x2f/0x90
[ 370.818010] [<ffffffff810776ef>] __might_sleep+0x7f/0x90
[ 370.818014] [<ffffffffa0000c03>] raid1_unplug+0xd3/0x170 [raid1]
[ 370.818024] [<ffffffff81421d9a>] blk_flush_plug_list+0x8a/0x1e0
[ 370.818028] [<ffffffff819e3550>] ? bit_wait+0x50/0x50
[ 370.818031] [<ffffffff819e21b0>] io_schedule_timeout+0x130/0x140
[ 370.818033] [<ffffffff819e3586>] bit_wait_io+0x36/0x50
[ 370.818034] [<ffffffff819e31b5>] __wait_on_bit+0x65/0x90
[ 370.818041] [<ffffffff8125b67c>] ? ext4_read_block_bitmap_nowait+0xbc/0x630
[ 370.818043] [<ffffffff819e3550>] ? bit_wait+0x50/0x50
[ 370.818045] [<ffffffff819e3302>] out_of_line_wait_on_bit+0x72/0x80
[ 370.818047] [<ffffffff810935e0>] ? autoremove_wake_function+0x40/0x40
[ 370.818050] [<ffffffff811de744>] __wait_on_buffer+0x44/0x50
[ 370.818053] [<ffffffff8125ae80>] ext4_wait_block_bitmap+0xe0/0xf0
[ 370.818058] [<ffffffff812975d6>] ext4_mb_init_cache+0x206/0x790
[ 370.818062] [<ffffffff8114bc6c>] ? lru_cache_add+0x1c/0x50
[ 370.818064] [<ffffffff81297c7e>] ext4_mb_init_group+0x11e/0x200
[ 370.818066] [<ffffffff81298231>] ext4_mb_load_buddy+0x341/0x360
[ 370.818068] [<ffffffff8129a1a3>] ext4_mb_find_by_goal+0x93/0x2f0
[ 370.818070] [<ffffffff81295b54>] ? ext4_mb_normalize_request+0x1e4/0x5b0
[ 370.818072] [<ffffffff8129ab67>] ext4_mb_regular_allocator+0x67/0x460
[ 370.818074] [<ffffffff81295b54>] ? ext4_mb_normalize_request+0x1e4/0x5b0
[ 370.818076] [<ffffffff8129ca4b>] ext4_mb_new_blocks+0x4cb/0x620
[ 370.818079] [<ffffffff81290956>] ext4_ext_map_blocks+0x4c6/0x14d0
[ 370.818081] [<ffffffff812a4d4e>] ? ext4_es_lookup_extent+0x4e/0x290
[ 370.818085] [<ffffffff8126399d>] ext4_map_blocks+0x14d/0x4f0
[ 370.818088] [<ffffffff81266fbd>] ext4_writepages+0x76d/0xe50
[ 370.818094] [<ffffffff81149691>] do_writepages+0x21/0x50
[ 370.818097] [<ffffffff811d5c00>] __writeback_single_inode+0x60/0x490
[ 370.818099] [<ffffffff811d630a>] writeback_sb_inodes+0x2da/0x590
[ 370.818103] [<ffffffff811abf4b>] ? trylock_super+0x1b/0x50
[ 370.818105] [<ffffffff811abf4b>] ? trylock_super+0x1b/0x50
[ 370.818107] [<ffffffff811d665f>] __writeback_inodes_wb+0x9f/0xd0
[ 370.818109] [<ffffffff811d69db>] wb_writeback+0x34b/0x3c0
[ 370.818111] [<ffffffff811d70df>] bdi_writeback_workfn+0x23f/0x550
[ 370.818116] [<ffffffff8106bbd8>] process_one_work+0x1c8/0x570
[ 370.818117] [<ffffffff8106bb5b>] ? process_one_work+0x14b/0x570
[ 370.818119] [<ffffffff8106c09b>] worker_thread+0x11b/0x470
[ 370.818121] [<ffffffff8106bf80>] ? process_one_work+0x570/0x570
[ 370.818124] [<ffffffff81071868>] kthread+0xf8/0x110
[ 370.818126] [<ffffffff81071770>] ? kthread_create_on_node+0x210/0x210
[ 370.818129] [<ffffffff819e9322>] ret_from_fork+0x42/0x70
[ 370.818131] [<ffffffff81071770>] ? kthread_create_on_node+0x210/0x210
[ 370.818132] ---[ end trace 7b4deb71e68b6605 ]---
V2: don't change ->in_iowait
Cc: NeilBrown <neilb@suse.de>
Signed-off-by: Shaohua Li <shli@fb.com>
Reviewed-by: Jeff Moyer <jmoyer@redhat.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
Two watchdog changes that came through different trees had a non
conflicting conflict, that is, one changed the semantics of a variable
but no actual code conflict happened. So the merge appeared fine, but
the resulting code did not behave as expected.
Commit 195daf665a62 ("watchdog: enable the new user interface of the
watchdog mechanism") changes the semantics of watchdog_user_enabled,
which thereafter is only used by the functions introduced by
b3738d293233 ("watchdog: Add watchdog enable/disable all functions").
There further appears to be a distinct lack of serialization between
setting and using watchdog_enabled, so perhaps we should wrap the
{en,dis}able_all() things in watchdog_proc_mutex.
This patch fixes a s2r failure reported by Michal; which I cannot
readily explain. But this does make the code internally consistent
again.
Reported-and-tested-by: Michal Hocko <mhocko@suse.cz>
Use the new helper function irq_domain_set_info to make sure the
function irq_domain_set_hwirq_and_chip is being called, which is
crucial to save irqdomain specific data to irq_data.
Signed-off-by: Stefan Agner <stefan@agner.ch>
Cc: marc.zyngier@arm.com
Cc: linux@arm.linux.org.uk
Cc: u.kleine-koenig@pengutronix.de
Cc: olof@lixom.net
Cc: arnd@arndb.de
Cc: daniel.lezcano@linaro.org
Cc: mark.rutland@arm.com
Cc: pawel.moll@arm.com
Cc: robh+dt@kernel.org
Cc: ijc+devicetree@hellion.org.uk
Cc: galak@codeaurora.org
Cc: mcoquelin.stm32@gmail.com
Cc: shawn.guo@linaro.org
Cc: kernel@pengutronix.de
Cc: jason@lakedaemon.net
Link: http://lkml.kernel.org/r/1431769465-26867-4-git-send-email-stefan@agner.ch
Add helper irq_chip_enable_parent and irq_chip_disable_parent. The
helper implement the default behavior in case irq_enable or irq_disable
is not implemented for the parent interrupt chip, which is calling the
irq_mask or irq_unmask respectively.
Cc: olof@lixom.net
Cc: arnd@arndb.de
Link: http://lkml.kernel.org/r/1431769465-26867-3-git-send-email-stefan@agner.ch
This adds the helper irq_domain_set_info() in a non-domain hierarchy
variant. This allows to use the helper for generic chip since not
all chips using generic chip support domain hierarchy.
Cc: olof@lixom.net
Cc: arnd@arndb.de
Link: http://lkml.kernel.org/r/1431769465-26867-2-git-send-email-stefan@agner.ch
Pull scheduler fixes from Ingo Molnar:
"Two fixes: a suspend/resume related regression fix, and an RT priority
boosting fix"
* 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
sched/core: Fix regression in cpuset_cpu_inactive() for suspend
sched: Handle priority boosted tasks proper in setscheduler()
"Mostly tooling fixes, but also a lockdep annotation fix, a PMU event
list fix and a new model addition"
tools/liblockdep: Fix compilation error
tools/liblockdep: Fix linker error in case of cross compile
perf tools: Use getconf to determine number of online CPUs
tools: Fix tools/vm build
perf/x86/rapl: Enable Broadwell-U RAPL support
perf/x86/intel: Fix SLM cache event list
perf: Annotate inherited event ctx->mutex recursion
It was noted that the 32bit implementation of ktime_divns()
was doing unsigned division and didn't properly handle
negative values.
And when a ktime helper was changed to utilize
ktime_divns, it caused a regression on some IR blasters.
See the following bugzilla for details:
https://bugzilla.redhat.com/show_bug.cgi?id=1200353
This patch fixes the problem in ktime_divns by checking
and preserving the sign bit, and then reapplying it if
appropriate after the division, it also changes the return
type to a s64 to make it more obvious this is expected.
Nicolas also pointed out that negative dividers would
cause infinite loops on 32bit systems, negative dividers
is unlikely for users of this function, but out of caution
this patch adds checks for negative dividers for both
32-bit (BUG_ON) and 64-bit(WARN_ON) versions to make sure
no such use cases creep in.
[ tglx: Hand an u64 to do_div() to avoid the compiler warning ]
Fixes: 166afb64511e 'ktime: Sanitize ktime_to_us/ms conversion'
Reported-and-tested-by: Trevor Cordes <trevor@tecnopolis.ca>
Signed-off-by: John Stultz <john.stultz@linaro.org>
Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Cc: One Thousand Gnomes <gnomes@lxorguk.ukuu.org.uk>
Link: http://lkml.kernel.org/r/1431118043-23452-1-git-send-email-john.stultz@linaro.org
Pull irq updates from Thomas Gleixner:
"Two patches from the irq departement:
- a simple fix to make dummy_irq_chip usable for wakeup scenarios
- removal of the gic arch_extn hackery. Now that all users are
converted we really want to get rid of the interface so people wont
come up with new use cases"
* 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
irqchip: gic: Drop support for gic_arch_extn
genirq: Set IRQCHIP_SKIP_SET_WAKE flag for dummy_irq_chip
"A simple fix to actually shut down a detached device instead of
keeping it active"
clockevents: Shutdown detached clockevent device
Pull tracing fix from Steven Rostedt:
"The newly added ftrace_print_array_seq() function had a bug in it.
Luckily, the only user of it didn't make the 4.1 merge window.
But the helper function should be fixed before 4.2 when the users
start coming in"
* tag 'trace-fixes-v4.1-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace:
tracing: Make ftrace_print_array_seq compute buf_len
The module notifier call chain for MODULE_STATE_COMING was moved up before
the parsing of args, into the complete_formation() call. But if the module failed
to load after that, the notifier call chain for MODULE_STATE_GOING was
never called and that prevented the users of those call chains from
cleaning up anything that was allocated.
Link: http://lkml.kernel.org/r/554C52B9.9060700@gmail.com
Reported-by: Pontus Fuchs <pontus.fuchs@gmail.com>
Fixes: 4982223e51e8 "module: set nx before marking module MODULE_STATE_COMING"
Cc: stable@vger.kernel.org # 3.16+
While fuzzing Sasha tripped over another ctx->mutex recursion lockdep
splat. Annotate this.
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Vince Weaver <vincent.weaver@maine.edu>
Commit 3c18d447b3b3 ("sched/core: Check for available DL bandwidth in
cpuset_cpu_inactive()"), a SCHED_DEADLINE bugfix, had a logic error that
caused a regression in setting a CPU inactive during suspend. I ran into
this when a program was failing pthread_setaffinity_np() with EINVAL after
a suspend+wake up.
A simple reproducer:
$ ./a.out
sched_setaffinity: Success
$ systemctl suspend
$ ./a.out
sched_setaffinity: Invalid argument
... where ./a.out is:
#define _GNU_SOURCE
#include <errno.h>
#include <sched.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
int main(void)
long num_cores;
cpu_set_t cpu_set;
int ret;
num_cores = sysconf(_SC_NPROCESSORS_ONLN);
CPU_ZERO(&cpu_set);
CPU_SET(num_cores - 1, &cpu_set);
errno = 0;
ret = sched_setaffinity(getpid(), sizeof(cpu_set), &cpu_set);
perror("sched_setaffinity");
return ret ? EXIT_FAILURE : EXIT_SUCCESS;
The mistake is that suspend is handled in the action ==
CPU_DOWN_PREPARE_FROZEN case of the switch statement in
cpuset_cpu_inactive().
However, the commit in question masked out CPU_TASKS_FROZEN
from the action, making this case dead.
The fix is straightforward.
Signed-off-by: Omar Sandoval <osandov@osandov.com>
Cc: Juri Lelli <juri.lelli@arm.com>
Fixes: 3c18d447b3b3 ("sched/core: Check for available DL bandwidth in cpuset_cpu_inactive()")
Link: http://lkml.kernel.org/r/1cb5ecb3d6543c38cce5790387f336f54ec8e2bc.1430733960.git.osandov@osandov.com
Ronny reported that the following scenario is not handled correctly:
T1 (prio = 10)
lock(rtmutex);
T2 (prio = 20)
lock(rtmutex)
boost T1
T1 (prio = 20)
sys_set_scheduler(prio = 30)
T1 prio = 30
sys_set_scheduler(prio = 10)
T1 prio = 30
The last step is wrong as T1 should now be back at prio 20.
Commit c365c292d059 ("sched: Consider pi boosting in setscheduler()")
only handles the case where a boosted tasks tries to lower its
priority.
Fix it by taking the new effective priority into account for the
decision whether a change of the priority is required.
Reported-by: Ronny Meeus <ronny.meeus@gmail.com>
Tested-by: Steven Rostedt <rostedt@goodmis.org>
Reviewed-by: Steven Rostedt <rostedt@goodmis.org>
Cc: Mike Galbraith <umgwanakikbuti@gmail.com>
Fixes: c365c292d059 ("sched: Consider pi boosting in setscheduler()")
Link: http://lkml.kernel.org/r/alpine.DEB.2.11.1505051806060.4225@nanos
The only caller to this function (__print_array) was getting it wrong by
passing the array length instead of buffer length. As the element size
was already being passed for other reasons it seems reasonable to push
the calculation of buffer length into the function.
Link: http://lkml.kernel.org/r/1430320727-14582-1-git-send-email-alex.bennee@linaro.org
Signed-off-by: Alex Bennée <alex.bennee@linaro.org>
Pull RCU fix from Ingo Molnar:
"An RCU Kconfig fix that eliminates an annoying interactive kconfig
question for CONFIG_RCU_TORTURE_TEST_SLOW_INIT"
* 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
rcu: Control grace-period delays directly from value
Pull networking fixes from David Miller:
1) Receive packet length needs to be adjust by 2 on RX to accomodate
the two padding bytes in altera_tse driver. From Vlastimil Setka.
2) If rx frame is dropped due to out of memory in macb driver, we leave
the receive ring descriptors in an undefined state. From Punnaiah
Choudary Kalluri
3) Some netlink subsystems erroneously signal NLM_F_MULTI. That is
only for dumps. Fix from Nicolas Dichtel.
4) Fix mis-use of raw rt->rt_pmtu value in ipv4, one must always go via
the ipv4_mtu() helper. From Herbert Xu.
5) Fix null deref in bridge netfilter, and miscalculated lengths in
jump/goto nf_tables verdicts. From Florian Westphal.
6) Unhash ping sockets properly.
7) Software implementation of BPF divide did 64/32 rather than 64/64
bit divide. The JITs got it right. Fix from Alexei Starovoitov.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (30 commits)
ipv4: Missing sk_nulls_node_init() in ping_unhash().
net: fec: Fix RGMII-ID mode
net/mlx4_en: Schedule napi when RX buffers allocation fails
netxen_nic: use spin_[un]lock_bh around tx_clean_lock
net/mlx4_core: Fix unaligned accesses
mlx4_en: Use correct loop cursor in error path.
cxgb4: Fix MC1 memory offset calculation
bnx2x: Delay during kdump load
net: Fix Kernel Panic in bonding driver debugfs file: rlb_hash_table
net: dsa: Fix scope of eeprom-length property
net: macb: Fix race condition in driver when Rx frame is dropped
hv_netvsc: Fix a bug in netvsc_start_xmit()
altera_tse: Correct rx packet length
mlx4: Fix tx ring affinity_mask creation
tipc: fix problem with parallel link synchronization mechanism
tipc: remove wrong use of NLM_F_MULTI
bridge/nl: remove wrong use of NLM_F_MULTI
bridge/mdb: remove wrong use of NLM_F_MULTI
net: sched: act_connmark: don't zap skb->nfct
trivial: net: systemport: bcmsysport.h: fix 0x0x prefix
