path: root/kernel
2014-11-23uprobes, x86: Fix _TIF_UPROBE vs _TIF_NOTIFY_RESUMEAndy Lutomirski
x86 call do_notify_resume on paranoid returns if TIF_UPROBE is set but not on non-paranoid returns. I suspect that this is a mistake and that the code only works because int3 is paranoid. Setting _TIF_NOTIFY_RESUME in the uprobe code was probably a workaround for the x86 bug. With that bug fixed, we can remove _TIF_NOTIFY_RESUME from the uprobes code. Reported-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Acked-by: Borislav Petkov <bp@suse.de> Signed-off-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-23sched: Provide update_curr callbacks for stop/idle scheduling classesThomas Gleixner
Chris bisected a NULL pointer deference in task_sched_runtime() to commit 6e998916dfe3 'sched/cputime: Fix clock_nanosleep()/clock_gettime() inconsistency'. Chris observed crashes in atop or other /proc walking programs when he started fork bombs on his machine. He assumed that this is a new exit race, but that does not make any sense when looking at that commit. What's interesting is that, the commit provides update_curr callbacks for all scheduling classes except stop_task and idle_task. While nothing can ever hit that via the clock_nanosleep() and clock_gettime() interfaces, which have been the target of the commit in question, the author obviously forgot that there are other code paths which invoke task_sched_runtime() do_task_stat(() thread_group_cputime_adjusted() thread_group_cputime() task_cputime() task_sched_runtime() if (task_current(rq, p) && task_on_rq_queued(p)) { update_rq_clock(rq); up->sched_class->update_curr(rq); } If the stats are read for a stomp machine task, aka 'migration/N' and that task is current on its cpu, this will happily call the NULL pointer of stop_task->update_curr. Ooops. Chris observation that this happens faster when he runs the fork bomb makes sense as the fork bomb will kick migration threads more often so the probability to hit the issue will increase. Add the missing update_curr callbacks to the scheduler classes stop_task and idle_task. While idle tasks cannot be monitored via /proc we have other means to hit the idle case. Fixes: 6e998916dfe3 'sched/cputime: Fix clock_nanosleep()/clock_gettime() inconsistency' Reported-by: Chris Mason <clm@fb.com> Reported-and-tested-by: Borislav Petkov <bp@alien8.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@kernel.org> Cc: Stanislaw Gruszka <sgruszka@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-21Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fixes from Ingo Molnar: "Misc fixes: two NUMA fixes, two cputime fixes and an RCU/lockdep fix" * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched/cputime: Fix clock_nanosleep()/clock_gettime() inconsistency sched/cputime: Fix cpu_timer_sample_group() double accounting sched/numa: Avoid selecting oneself as swap target sched/numa: Fix out of bounds read in sched_init_numa() sched: Remove lockdep check in sched_move_task()
2014-11-21Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Misc fixes: two Intel uncore driver fixes, a CPU-hotplug fix and a build dependencies fix" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf/x86/intel/uncore: Fix boot crash on SBOX PMU on Haswell-EP perf/x86/intel/uncore: Fix IRP uncore register offsets on Haswell EP perf: Fix corruption of sibling list with hotplug perf/x86: Fix embarrasing typo
2014-11-16sched/cputime: Fix clock_nanosleep()/clock_gettime() inconsistencyStanislaw Gruszka
Commit d670ec13178d0 "posix-cpu-timers: Cure SMP wobbles" fixes one glibc test case in cost of breaking another one. After that commit, calling clock_nanosleep(TIMER_ABSTIME, X) and then clock_gettime(&Y) can result of Y time being smaller than X time. Reproducer/tester can be found further below, it can be compiled and ran by: gcc -o tst-cpuclock2 tst-cpuclock2.c -pthread while ./tst-cpuclock2 ; do : ; done This reproducer, when running on a buggy kernel, will complain about "clock_gettime difference too small". Issue happens because on start in thread_group_cputimer() we initialize sum_exec_runtime of cputimer with threads runtime not yet accounted and then add the threads runtime to running cputimer again on scheduler tick, making it's sum_exec_runtime bigger than actual threads runtime. KOSAKI Motohiro posted a fix for this problem, but that patch was never applied: https://lkml.org/lkml/2013/5/26/191 . This patch takes different approach to cure the problem. It calls update_curr() when cputimer starts, that assure we will have updated stats of running threads and on the next schedule tick we will account only the runtime that elapsed from cputimer start. That also assure we have consistent state between cpu times of individual threads and cpu time of the process consisted by those threads. Full reproducer (tst-cpuclock2.c): #define _GNU_SOURCE #include <unistd.h> #include <sys/syscall.h> #include <stdio.h> #include <time.h> #include <pthread.h> #include <stdint.h> #include <inttypes.h> /* Parameters for the Linux kernel ABI for CPU clocks. */ #define CPUCLOCK_SCHED 2 #define MAKE_PROCESS_CPUCLOCK(pid, clock) \ ((~(clockid_t) (pid) << 3) | (clockid_t) (clock)) static pthread_barrier_t barrier; /* Help advance the clock. */ static void *chew_cpu(void *arg) { pthread_barrier_wait(&barrier); while (1) ; return NULL; } /* Don't use the glibc wrapper. */ static int do_nanosleep(int flags, const struct timespec *req) { clockid_t clock_id = MAKE_PROCESS_CPUCLOCK(0, CPUCLOCK_SCHED); return syscall(SYS_clock_nanosleep, clock_id, flags, req, NULL); } static int64_t tsdiff(const struct timespec *before, const struct timespec *after) { int64_t before_i = before->tv_sec * 1000000000ULL + before->tv_nsec; int64_t after_i = after->tv_sec * 1000000000ULL + after->tv_nsec; return after_i - before_i; } int main(void) { int result = 0; pthread_t th; pthread_barrier_init(&barrier, NULL, 2); if (pthread_create(&th, NULL, chew_cpu, NULL) != 0) { perror("pthread_create"); return 1; } pthread_barrier_wait(&barrier); /* The test. */ struct timespec before, after, sleeptimeabs; int64_t sleepdiff, diffabs; const struct timespec sleeptime = {.tv_sec = 0,.tv_nsec = 100000000 }; /* The relative nanosleep. Not sure why this is needed, but its presence seems to make it easier to reproduce the problem. */ if (do_nanosleep(0, &sleeptime) != 0) { perror("clock_nanosleep"); return 1; } /* Get the current time. */ if (clock_gettime(CLOCK_PROCESS_CPUTIME_ID, &before) < 0) { perror("clock_gettime[2]"); return 1; } /* Compute the absolute sleep time based on the current time. */ uint64_t nsec = before.tv_nsec + sleeptime.tv_nsec; sleeptimeabs.tv_sec = before.tv_sec + nsec / 1000000000; sleeptimeabs.tv_nsec = nsec % 1000000000; /* Sleep for the computed time. */ if (do_nanosleep(TIMER_ABSTIME, &sleeptimeabs) != 0) { perror("absolute clock_nanosleep"); return 1; } /* Get the time after the sleep. */ if (clock_gettime(CLOCK_PROCESS_CPUTIME_ID, &after) < 0) { perror("clock_gettime[3]"); return 1; } /* The time after sleep should always be equal to or after the absolute sleep time passed to clock_nanosleep. */ sleepdiff = tsdiff(&sleeptimeabs, &after); if (sleepdiff < 0) { printf("absolute clock_nanosleep woke too early: %" PRId64 "\n", sleepdiff); result = 1; printf("Before %llu.%09llu\n", before.tv_sec, before.tv_nsec); printf("After %llu.%09llu\n", after.tv_sec, after.tv_nsec); printf("Sleep %llu.%09llu\n", sleeptimeabs.tv_sec, sleeptimeabs.tv_nsec); } /* The difference between the timestamps taken before and after the clock_nanosleep call should be equal to or more than the duration of the sleep. */ diffabs = tsdiff(&before, &after); if (diffabs < sleeptime.tv_nsec) { printf("clock_gettime difference too small: %" PRId64 "\n", diffabs); result = 1; } pthread_cancel(th); return result; } Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/20141112155843.GA24803@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-11-16sched/cputime: Fix cpu_timer_sample_group() double accountingPeter Zijlstra
While looking over the cpu-timer code I found that we appear to add the delta for the calling task twice, through: cpu_timer_sample_group() thread_group_cputimer() thread_group_cputime() times->sum_exec_runtime += task_sched_runtime(); *sample = cputime.sum_exec_runtime + task_delta_exec(); Which would make the sample run ahead, making the sleep short. Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Stanislaw Gruszka <sgruszka@redhat.com> Cc: Christoph Lameter <cl@linux.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Rik van Riel <riel@redhat.com> Cc: Tejun Heo <tj@kernel.org> Link: http://lkml.kernel.org/r/20141112113737.GI10476@twins.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-11-16sched/numa: Avoid selecting oneself as swap targetPeter Zijlstra
Because the whole numa task selection stuff runs with preemption enabled (its long and expensive) we can end up migrating and selecting oneself as a swap target. This doesn't really work out well -- we end up trying to acquire the same lock twice for the swap migrate -- so avoid this. Reported-and-Tested-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/20141110100328.GF29390@twins.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-11-16perf: Fix corruption of sibling list with hotplugMark Rutland
When a CPU hotplugged out, we call perf_remove_from_context() (via perf_event_exit_cpu()) to rip each CPU-bound event out of its PMU's cpu context, but leave siblings grouped together. Freeing of these events is left to the mercy of the usual refcounting. When a CPU-bound event's refcount drops to zero we cross-call to __perf_remove_from_context() to clean it up, detaching grouped siblings. This works when the relevant CPU is online, but will fail if the CPU is currently offline, and we won't detach the event from its siblings before freeing the event, leaving the sibling list corrupt. If the sibling list is later walked (e.g. because the CPU cam online again before a remaining sibling's refcount drops to zero), we will walk the now corrupted siblings list, potentially dereferencing garbage values. Given that the events should never be scheduled again (as we removed them from their context), we can simply detatch siblings when the CPU goes down in the first place. If the CPU comes back online, the redundant call to __perf_remove_from_context() is safe. Reported-by: Drew Richardson <drew.richardson@arm.com> Signed-off-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: vincent.weaver@maine.edu Cc: Vince Weaver <vincent.weaver@maine.edu> Cc: Will Deacon <will.deacon@arm.com> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/1415203904-25308-2-git-send-email-mark.rutland@arm.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-11-14Merge tag 'pm+acpi-3.18-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management fixes from Rafael Wysocki: "These are three regression fixes, two recent (generic power domains, suspend-to-idle) and one older (cpufreq), an ACPI blacklist entry for one more machine having problems with Windows 8 compatibility, a minor cpufreq driver fix (cpufreq-dt) and a fixup for new callback definitions (generic power domains). Specifics: - Fix a crash in the suspend-to-idle code path introduced by a recent commit that forgot to check a pointer against NULL before dereferencing it (Dmitry Eremin-Solenikov). - Fix a boot crash on Exynos5 introduced by a recent commit making that platform use generic Device Tree bindings for power domains which exposed a weakness in the generic power domains framework leading to that crash (Ulf Hansson). - Fix a crash during system resume on systems where cpufreq depends on Operation Performance Points (OPP) for functionality, but CONFIG_OPP is not set. This leads the cpufreq driver registration to fail, but the resume code attempts to restore the pre-suspend cpufreq configuration (which does not exist) nevertheless and crashes. From Geert Uytterhoeven. - Add a new ACPI blacklist entry for Dell Vostro 3546 that has problems if it is reported as Windows 8 compatible to the BIOS (Adam Lee). - Fix swapped arguments in an error message in the cpufreq-dt driver (Abhilash Kesavan). - Fix up the prototypes of new callbacks in struct generic_pm_domain to make them more useful. Users of those callbacks will be added in 3.19 and it's better for them to be based on the correct struct definition in mainline from the start. From Ulf Hansson and Kevin Hilman" * tag 'pm+acpi-3.18-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: PM / Domains: Fix initial default state of the need_restore flag PM / sleep: Fix entering suspend-to-IDLE if no freeze_oops is set PM / Domains: Change prototype for the attach and detach callbacks cpufreq: Avoid crash in resume on SMP without OPP cpufreq: cpufreq-dt: Fix arguments in clock failure error message ACPI / blacklist: blacklist Win8 OSI for Dell Vostro 3546
2014-11-13kernel/panic.c: update comments for print_taintedXie XiuQi
Commit 69361eef9056 ("panic: add TAINT_SOFTLOCKUP") added the 'L' flag, but failed to update the comments for print_tainted(). So, update the comments. Signed-off-by: Xie XiuQi <xiexiuqi@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-13Merge branch 'stable-3.18' of git://git.infradead.org/users/pcmoore/auditLinus Torvalds
Pull audit fixes from Paul Moore: "After he sent the initial audit pull request for 3.18, Eric asked me to take over the management of the audit tree, hence this pull request to fix a couple of problems with audit. As you can see below, the changes are minimal: adding some whitespace to a string so userspace parses it correctly, and fixing a problem with audit's usage of fsnotify that was causing audit watch rules to be lost. Neither of these patches were very controversial on the mailing lists and they fix real problems, getting them into 3.18 would be a good thing" * 'stable-3.18' of git://git.infradead.org/users/pcmoore/audit: audit: keep inode pinned audit: AUDIT_FEATURE_CHANGE message format missing delimiting space
2014-11-11audit: keep inode pinnedMiklos Szeredi
Audit rules disappear when an inode they watch is evicted from the cache. This is likely not what we want. The guilty commit is "fsnotify: allow marks to not pin inodes in core", which didn't take into account that audit_tree adds watches with a zero mask. Adding any mask should fix this. Fixes: 90b1e7a57880 ("fsnotify: allow marks to not pin inodes in core") Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: stable@vger.kernel.org # 2.6.36+ Signed-off-by: Paul Moore <pmoore@redhat.com>
2014-11-10tracing: Do not risk busy looping in buffer spliceRabin Vincent
If the read loop in trace_buffers_splice_read() keeps failing due to memory allocation failures without reading even a single page then this function will keep busy looping. Remove the risk for that by exiting the function if memory allocation failures are seen. Link: http://lkml.kernel.org/r/1415309167-2373-2-git-send-email-rabin@rab.in Signed-off-by: Rabin Vincent <rabin@rab.in> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2014-11-10tracing: Do not busy wait in buffer spliceRabin Vincent
On a !PREEMPT kernel, attempting to use trace-cmd results in a soft lockup: # trace-cmd record -e raw_syscalls:* -F false NMI watchdog: BUG: soft lockup - CPU#0 stuck for 22s! [trace-cmd:61] ... Call Trace: [<ffffffff8105b580>] ? __wake_up_common+0x90/0x90 [<ffffffff81092e25>] wait_on_pipe+0x35/0x40 [<ffffffff810936e3>] tracing_buffers_splice_read+0x2e3/0x3c0 [<ffffffff81093300>] ? tracing_stats_read+0x2a0/0x2a0 [<ffffffff812d10ab>] ? _raw_spin_unlock+0x2b/0x40 [<ffffffff810dc87b>] ? do_read_fault+0x21b/0x290 [<ffffffff810de56a>] ? handle_mm_fault+0x2ba/0xbd0 [<ffffffff81095c80>] ? trace_event_buffer_lock_reserve+0x40/0x80 [<ffffffff810951e2>] ? trace_buffer_lock_reserve+0x22/0x60 [<ffffffff81095c80>] ? trace_event_buffer_lock_reserve+0x40/0x80 [<ffffffff8112415d>] do_splice_to+0x6d/0x90 [<ffffffff81126971>] SyS_splice+0x7c1/0x800 [<ffffffff812d1edd>] tracesys_phase2+0xd3/0xd8 The problem is this: tracing_buffers_splice_read() calls ring_buffer_wait() to wait for data in the ring buffers. The buffers are not empty so ring_buffer_wait() returns immediately. But tracing_buffers_splice_read() calls ring_buffer_read_page() with full=1, meaning it only wants to read a full page. When the full page is not available, tracing_buffers_splice_read() tries to wait again with ring_buffer_wait(), which again returns immediately, and so on. Fix this by adding a "full" argument to ring_buffer_wait() which will make ring_buffer_wait() wait until the writer has left the reader's page, i.e. until full-page reads will succeed. Link: http://lkml.kernel.org/r/1415645194-25379-1-git-send-email-rabin@rab.in Cc: stable@vger.kernel.org # 3.16+ Fixes: b1169cc69ba9 ("tracing: Remove mock up poll wait function") Signed-off-by: Rabin Vincent <rabin@rab.in> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2014-11-10sched/numa: Fix out of bounds read in sched_init_numa()Andrey Ryabinin
On latest mm + KASan patchset I've got this: ================================================================== BUG: AddressSanitizer: out of bounds access in sched_init_smp+0x3ba/0x62c at addr ffff88006d4bee6c ============================================================================= BUG kmalloc-8 (Not tainted): kasan error ----------------------------------------------------------------------------- Disabling lock debugging due to kernel taint INFO: Allocated in alloc_vfsmnt+0xb0/0x2c0 age=75 cpu=0 pid=0 __slab_alloc+0x4b4/0x4f0 __kmalloc_track_caller+0x15f/0x1e0 kstrdup+0x44/0x90 alloc_vfsmnt+0xb0/0x2c0 vfs_kern_mount+0x35/0x190 kern_mount_data+0x25/0x50 pid_ns_prepare_proc+0x19/0x50 alloc_pid+0x5e2/0x630 copy_process.part.41+0xdf5/0x2aa0 do_fork+0xf5/0x460 kernel_thread+0x21/0x30 rest_init+0x1e/0x90 start_kernel+0x522/0x531 x86_64_start_reservations+0x2a/0x2c x86_64_start_kernel+0x15b/0x16a INFO: Slab 0xffffea0001b52f80 objects=24 used=22 fp=0xffff88006d4befc0 flags=0x100000000004080 INFO: Object 0xffff88006d4bed20 @offset=3360 fp=0xffff88006d4bee70 Bytes b4 ffff88006d4bed10: 00 00 00 00 00 00 00 00 5a 5a 5a 5a 5a 5a 5a 5a ........ZZZZZZZZ Object ffff88006d4bed20: 70 72 6f 63 00 6b 6b a5 proc.kk. Redzone ffff88006d4bed28: cc cc cc cc cc cc cc cc ........ Padding ffff88006d4bee68: 5a 5a 5a 5a 5a 5a 5a 5a ZZZZZZZZ CPU: 0 PID: 1 Comm: swapper/0 Tainted: G B 3.18.0-rc3-mm1+ #108 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.7.5-0-ge51488c-20140602_164612-nilsson.home.kraxel.org 04/01/2014 ffff88006d4be000 0000000000000000 ffff88006d4bed20 ffff88006c86fd18 ffffffff81cd0a59 0000000000000058 ffff88006d404240 ffff88006c86fd48 ffffffff811fa3a8 ffff88006d404240 ffffea0001b52f80 ffff88006d4bed20 Call Trace: dump_stack (lib/dump_stack.c:52) print_trailer (mm/slub.c:645) object_err (mm/slub.c:652) ? sched_init_smp (kernel/sched/core.c:6552 kernel/sched/core.c:7063) kasan_report_error (mm/kasan/report.c:102 mm/kasan/report.c:178) ? kasan_poison_shadow (mm/kasan/kasan.c:48) ? kasan_unpoison_shadow (mm/kasan/kasan.c:54) ? kasan_poison_shadow (mm/kasan/kasan.c:48) ? kasan_kmalloc (mm/kasan/kasan.c:311) __asan_load4 (mm/kasan/kasan.c:371) ? sched_init_smp (kernel/sched/core.c:6552 kernel/sched/core.c:7063) sched_init_smp (kernel/sched/core.c:6552 kernel/sched/core.c:7063) kernel_init_freeable (init/main.c:869 init/main.c:997) ? finish_task_switch (kernel/sched/sched.h:1036 kernel/sched/core.c:2248) ? rest_init (init/main.c:924) kernel_init (init/main.c:929) ? rest_init (init/main.c:924) ret_from_fork (arch/x86/kernel/entry_64.S:348) ? rest_init (init/main.c:924) Read of size 4 by task swapper/0: Memory state around the buggy address: ffff88006d4beb80: fc fc fc fc fc fc fc fc fc fc 00 fc fc fc fc fc ffff88006d4bec00: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc ffff88006d4bec80: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc ffff88006d4bed00: fc fc fc fc 00 fc fc fc fc fc fc fc fc fc fc fc ffff88006d4bed80: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc >ffff88006d4bee00: fc fc fc fc fc fc fc fc fc fc fc fc fc fc 04 fc ^ ffff88006d4bee80: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc ffff88006d4bef00: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc ffff88006d4bef80: fc fc fc fc fc fc fc fc fb fb fb fb fb fb fb fb ffff88006d4bf000: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb ffff88006d4bf080: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb ================================================================== Zero 'level' (e.g. on non-NUMA system) causing out of bounds access in this line: sched_max_numa_distance = sched_domains_numa_distance[level - 1]; Fix this by exiting from sched_init_numa() earlier. Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Reviewed-by: Rik van Riel <riel@redhat.com> Fixes: 9942f79ba ("sched/numa: Export info needed for NUMA balancing on complex topologies") Cc: peterz@infradead.org Link: http://lkml.kernel.org/r/1415372020-1871-1-git-send-email-a.ryabinin@samsung.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-11-08PM / sleep: Fix entering suspend-to-IDLE if no freeze_oops is setDmitry Eremin-Solenikov
If no freeze_ops is set, trying to enter suspend-to-IDLE will cause a nice oops in platform_suspend_prepare_late(). Add respective checks to platform_suspend_prepare_late() and platform_resume_early() functions. Fixes: a8d46b9e4e48 (ACPI / sleep: Rework the handling of ACPI GPE wakeup ...) Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-11-04sched: Remove lockdep check in sched_move_task()Kirill Tkhai
sched_move_task() is the only interface to change sched_task_group: cpu_cgrp_subsys methods and autogroup_move_group() use it. Everything is synchronized by task_rq_lock(), so cpu_cgroup_attach() is ordered with other users of sched_move_task(). This means we do no need RCU here: if we've dereferenced a tg here, the .attach method hasn't been called for it yet. Thus, we should pass "true" to task_css_check() to silence lockdep warnings. Fixes: eeb61e53ea19 ("sched: Fix race between task_group and sched_task_group") Reported-by: Oleg Nesterov <oleg@redhat.com> Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Kirill Tkhai <ktkhai@parallels.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/1414473874.8574.2.camel@tkhai Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-10-31Merge tag 'pm+acpi-3.18-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management fixes from Rafael Wysocki: "These are fixes received after my previous pull request plus one that has been in the works for quite a while, but its previous version caused problems to happen, so it's been deferred till now. Fixed are two recent regressions (MFD enumeration and cpufreq-dt), ACPI EC regression introduced in 3.17, system suspend error code path regression introduced in 3.15, an older bug related to recovery from failing resume from hibernation and a cpufreq-dt driver issue related to operation performance points. Specifics: - Fix a crash on r8a7791/koelsch during resume from system suspend caused by a recent cpufreq-dt commit (Geert Uytterhoeven). - Fix an MFD enumeration problem introduced by a recent commit adding ACPI support to the MFD subsystem that exposed a weakness in the ACPI core causing ACPI enumeration to be applied to all devices associated with one ACPI companion object, although it should be used for one of them only (Mika Westerberg). - Fix an ACPI EC regression introduced during the 3.17 cycle causing some Samsung laptops to misbehave as a result of a workaround targeted at some Acer machines. That includes a revert of a commit that went too far and a quirk for the Acer machines in question. From Lv Zheng. - Fix a regression in the system suspend error code path introduced during the 3.15 cycle that causes it to fail to take errors from asychronous execution of "late" suspend callbacks into account (Imre Deak). - Fix a long-standing bug in the hibernation resume error code path that fails to roll back everything correcty on "freeze" callback errors and leaves some devices in a "suspended" state causing more breakage to happen subsequently (Imre Deak). - Make the cpufreq-dt driver disable operation performance points that are not supported by the VR connected to the CPU voltage plane with acceptable tolerance instead of constantly failing voltage scaling later on (Lucas Stach)" * tag 'pm+acpi-3.18-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: ACPI / EC: Fix regression due to conflicting firmware behavior between Samsung and Acer. Revert "ACPI / EC: Add support to disallow QR_EC to be issued before completing previous QR_EC" cpufreq: cpufreq-dt: Restore default cpumask_setall(policy->cpus) PM / Sleep: fix recovery during resuming from hibernation PM / Sleep: fix async suspend_late/freeze_late error handling ACPI: Use ACPI companion to match only the first physical device cpufreq: cpufreq-dt: disable unsupported OPPs
2014-10-31Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "A bit has accumulated, but it's been a week or so since my last batch of post-merge-window fixes, so... 1) Missing module license in netfilter reject module, from Pablo. Lots of people ran into this. 2) Off by one in mac80211 baserate calculation, from Karl Beldan. 3) Fix incorrect return value from ax88179_178a driver's set_mac_addr op, which broke use of it with bonding. From Ian Morgan. 4) Checking of skb_gso_segment()'s return value was not all encompassing, it can return an SKB pointer, a pointer error, or NULL. Fix from Florian Westphal. This is crummy, and longer term will be fixed to just return error pointers or a real SKB. 6) Encapsulation offloads not being handled by skb_gso_transport_seglen(). From Florian Westphal. 7) Fix deadlock in TIPC stack, from Ying Xue. 8) Fix performance regression from using rhashtable for netlink sockets. The problem was the synchronize_net() invoked for every socket destroy. From Thomas Graf. 9) Fix bug in eBPF verifier, and remove the strong dependency of BPF on NET. From Alexei Starovoitov. 10) In qdisc_create(), use the correct interface to allocate ->cpu_bstats, otherwise the u64_stats_sync member isn't initialized properly. From Sabrina Dubroca. 11) Off by one in ip_set_nfnl_get_byindex(), from Dan Carpenter. 12) nf_tables_newchain() was erroneously expecting error pointers from netdev_alloc_pcpu_stats(). It only returna a valid pointer or NULL. From Sabrina Dubroca. 13) Fix use-after-free in _decode_session6(), from Li RongQing. 14) When we set the TX flow hash on a socket, we mistakenly do so before we've nailed down the final source port. Move the setting deeper to fix this. From Sathya Perla. 15) NAPI budget accounting in amd-xgbe driver was counting descriptors instead of full packets, fix from Thomas Lendacky. 16) Fix total_data_buflen calculation in hyperv driver, from Haiyang Zhang. 17) Fix bcma driver build with OF_ADDRESS disabled, from Hauke Mehrtens. 18) Fix mis-use of per-cpu memory in TCP md5 code. The problem is that something that ends up being vmalloc memory can't be passed to the crypto hash routines via scatter-gather lists. From Eric Dumazet. 19) Fix regression in promiscuous mode enabling in cdc-ether, from Olivier Blin. 20) Bucket eviction and frag entry killing can race with eachother, causing an unlink of the object from the wrong list. Fix from Nikolay Aleksandrov. 21) Missing initialization of spinlock in cxgb4 driver, from Anish Bhatt. 22) Do not cache ipv4 routing failures, otherwise if the sysctl for forwarding is subsequently enabled this won't be seen. From Nicolas Cavallari" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (131 commits) drivers: net: cpsw: Support ALLMULTI and fix IFF_PROMISC in switch mode drivers: net: cpsw: Fix broken loop condition in switch mode net: ethtool: Return -EOPNOTSUPP if user space tries to read EEPROM with lengh 0 stmmac: pci: set default of the filter bins net: smc91x: Fix gpios for device tree based booting mpls: Allow mpls_gso to be built as module mpls: Fix mpls_gso handler. r8152: stop submitting intr for -EPROTO netfilter: nft_reject_bridge: restrict reject to prerouting and input netfilter: nft_reject_bridge: don't use IP stack to reject traffic netfilter: nf_reject_ipv6: split nf_send_reset6() in smaller functions netfilter: nf_reject_ipv4: split nf_send_reset() in smaller functions netfilter: nf_tables_bridge: update hook_mask to allow {pre,post}routing drivers/net: macvtap and tun depend on INET drivers/net, ipv6: Select IPv6 fragment idents for virtio UFO packets drivers/net: Disable UFO through virtio net: skb_fclone_busy() needs to detect orphaned skb gre: Use inner mac length when computing tunnel length mlx4: Avoid leaking steering rules on flow creation error flow net/mlx4_en: Don't attempt to TX offload the outer UDP checksum for VXLAN ...
2014-10-31Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fixes from Ingo Molnar: "Various scheduler fixes all over the place: three SCHED_DL fixes, three sched/numa fixes, two generic race fixes and a comment fix" * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched/dl: Fix preemption checks sched: Update comments for CLONE_NEWNS sched: stop the unbound recursion in preempt_schedule_context() sched/fair: Fix division by zero sysctl_numa_balancing_scan_size sched/fair: Care divide error in update_task_scan_period() sched/numa: Fix unsafe get_task_struct() in task_numa_assign() sched/deadline: Fix races between rt_mutex_setprio() and dl_task_timer() sched/deadline: Don't replenish from a !SCHED_DEADLINE entity sched: Fix race between task_group and sched_task_group
2014-10-31Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Mostly tooling fixes, plus on the kernel side: - a revert for a newly introduced PMU driver which isn't complete yet and where we ran out of time with fixes (to be tried again in v3.19) - this makes up for a large chunk of the diffstat. - compilation warning fixes - a printk message fix - event_idx usage fixes/cleanups" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf probe: Trivial typo fix for --demangle perf tools: Fix report -F dso_from for data without branch info perf tools: Fix report -F dso_to for data without branch info perf tools: Fix report -F symbol_from for data without branch info perf tools: Fix report -F symbol_to for data without branch info perf tools: Fix report -F mispredict for data without branch info perf tools: Fix report -F in_tx for data without branch info perf tools: Fix report -F abort for data without branch info perf tools: Make CPUINFO_PROC an array to support different kernel versions perf callchain: Use global caching provided by libunwind perf/x86/intel: Revert incomplete and undocumented Broadwell client support perf/x86: Fix compile warnings for intel_uncore perf: Fix typos in sample code in the perf_event.h header perf: Fix and clean up initialization of pmu::event_idx perf: Fix bogus kernel printk perf diff: Add missing hists__init() call at tool start
2014-10-31Merge branch 'locking-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull futex fixes from Ingo Molnar: "This contains two futex fixes: one fixes a race condition, the other clarifies shared/private futex comments" * 'locking-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: futex: Fix a race condition between REQUEUE_PI and task death futex: Mention key referencing differences between shared and private futexes
2014-10-31Merge branch 'core-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull core fixes from Ingo Molnar: "The tree contains two RCU fixes and a compiler quirk comment fix" * 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: rcu: Make rcu_barrier() understand about missing rcuo kthreads compiler/gcc4+: Remove inaccurate comment about 'asm goto' miscompiles rcu: More on deadlock between CPU hotplug and expedited grace periods
2014-10-31Merge branch 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer fixes from Thomas Gleixner: "As you requested in the rc2 release mail the timer department serves you a few real bug fixes: - Fix the probe logic of the architected arm/arm64 timer - Plug a stack info leak in posix-timers - Prevent a shift out of bounds issue in the clockevents core" * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: ARM/ARM64: arch-timer: fix arch_timer_probed logic clockevents: Prevent shift out of bounds posix-timers: Fix stack info leak in timer_create()
2014-10-31Merge tag 'trace-fixes-v3.18-rc1-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull tracing fix from Steven Rostedt: "ARM has system calls outside the NR_syscalls range, and the generic tracing system does not support that and without checks, it can cause an oops to be reported. Rabin Vincent added checks in the return code on syscall events to make sure that the system call number is within the range that tracing knows about, and if not, simply ignores the system call. The system call tracing infrastructure needs to be rewritten to handle these cases better, but for now, to keep from oopsing, this patch will do" * tag 'trace-fixes-v3.18-rc1-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: tracing/syscalls: Ignore numbers outside NR_syscalls' range
2014-10-30tracing/syscalls: Ignore numbers outside NR_syscalls' rangeRabin Vincent
ARM has some private syscalls (for example, set_tls(2)) which lie outside the range of NR_syscalls. If any of these are called while syscall tracing is being performed, out-of-bounds array access will occur in the ftrace and perf sys_{enter,exit} handlers. # trace-cmd record -e raw_syscalls:* true && trace-cmd report ... true-653 [000] 384.675777: sys_enter: NR 192 (0, 1000, 3, 4000022, ffffffff, 0) true-653 [000] 384.675812: sys_exit: NR 192 = 1995915264 true-653 [000] 384.675971: sys_enter: NR 983045 (76f74480, 76f74000, 76f74b28, 76f74480, 76f76f74, 1) true-653 [000] 384.675988: sys_exit: NR 983045 = 0 ... # trace-cmd record -e syscalls:* true [ 17.289329] Unable to handle kernel paging request at virtual address aaaaaace [ 17.289590] pgd = 9e71c000 [ 17.289696] [aaaaaace] *pgd=00000000 [ 17.289985] Internal error: Oops: 5 [#1] PREEMPT SMP ARM [ 17.290169] Modules linked in: [ 17.290391] CPU: 0 PID: 704 Comm: true Not tainted 3.18.0-rc2+ #21 [ 17.290585] task: 9f4dab00 ti: 9e710000 task.ti: 9e710000 [ 17.290747] PC is at ftrace_syscall_enter+0x48/0x1f8 [ 17.290866] LR is at syscall_trace_enter+0x124/0x184 Fix this by ignoring out-of-NR_syscalls-bounds syscall numbers. Commit cd0980fc8add "tracing: Check invalid syscall nr while tracing syscalls" added the check for less than zero, but it should have also checked for greater than NR_syscalls. Link: http://lkml.kernel.org/p/1414620418-29472-1-git-send-email-rabin@rab.in Fixes: cd0980fc8add "tracing: Check invalid syscall nr while tracing syscalls" Cc: stable@vger.kernel.org # 2.6.33+ Signed-off-by: Rabin Vincent <rabin@rab.in> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2014-10-30audit: AUDIT_FEATURE_CHANGE message format missing delimiting spaceRichard Guy Briggs
Add a space between subj= and feature= fields to make them parsable. Signed-off-by: Richard Guy Briggs <rgb@redhat.com> Cc: stable@vger.kernel.org Signed-off-by: Paul Moore <pmoore@redhat.com>
2014-10-30Merge branch 'urgent-for-mingo' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-rcu into core/urgent Pull two RCU fixes from Paul E. McKenney: " - Complete the work of commit dd56af42bd82 (rcu: Eliminate deadlock between CPU hotplug and expedited grace periods), which was intended to allow synchronize_sched_expedited() to be safely used when holding locks acquired by CPU-hotplug notifiers. This commit makes the put_online_cpus() avoid the deadlock instead of just handling the get_online_cpus(). - Complete the work of commit 35ce7f29a44a (rcu: Create rcuo kthreads only for onlined CPUs), which was intended to allow RCU to avoid allocating unneeded kthreads on systems where the firmware says that there are more CPUs than are really present. This commit makes rcu_barrier() aware of the mismatch, so that it doesn't hang waiting for non-existent CPUs. " Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-10-29kernel/kmod: fix use-after-free of the sub_info structureMartin Schwidefsky
Found this in the message log on a s390 system: BUG kmalloc-192 (Not tainted): Poison overwritten Disabling lock debugging due to kernel taint INFO: 0x00000000684761f4-0x00000000684761f7. First byte 0xff instead of 0x6b INFO: Allocated in call_usermodehelper_setup+0x70/0x128 age=71 cpu=2 pid=648 __slab_alloc.isra.47.constprop.56+0x5f6/0x658 kmem_cache_alloc_trace+0x106/0x408 call_usermodehelper_setup+0x70/0x128 call_usermodehelper+0x62/0x90 cgroup_release_agent+0x178/0x1c0 process_one_work+0x36e/0x680 worker_thread+0x2f0/0x4f8 kthread+0x10a/0x120 kernel_thread_starter+0x6/0xc kernel_thread_starter+0x0/0xc INFO: Freed in call_usermodehelper_exec+0x110/0x1b8 age=71 cpu=2 pid=648 __slab_free+0x94/0x560 kfree+0x364/0x3e0 call_usermodehelper_exec+0x110/0x1b8 cgroup_release_agent+0x178/0x1c0 process_one_work+0x36e/0x680 worker_thread+0x2f0/0x4f8 kthread+0x10a/0x120 kernel_thread_starter+0x6/0xc kernel_thread_starter+0x0/0xc There is a use-after-free bug on the subprocess_info structure allocated by the user mode helper. In case do_execve() returns with an error ____call_usermodehelper() stores the error code to sub_info->retval, but sub_info can already have been freed. Regarding UMH_NO_WAIT, the sub_info structure can be freed by __call_usermodehelper() before the worker thread returns from do_execve(), allowing memory corruption when do_execve() failed after exec_mmap() is called. Regarding UMH_WAIT_EXEC, the call to umh_complete() allows call_usermodehelper_exec() to continue which then frees sub_info. To fix this race the code needs to make sure that the call to call_usermodehelper_freeinfo() is always done after the last store to sub_info->retval. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Cc: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-29gcov: add ARM64 to GCOV_PROFILE_ALLRiku Voipio
Following up the arm testing of gcov, turns out gcov on ARM64 works fine as well. Only change needed is adding ARM64 to Kconfig depends. Tested with qemu and mach-virt Signed-off-by: Riku Voipio <riku.voipio@linaro.org> Acked-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-28Merge tag 'trace-fixes-v3.18-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull ftrace trampoline accounting fixes from Steven Rostedt: "Adding the new code for 3.19, I discovered a couple of minor bugs with the accounting of the ftrace_ops trampoline logic. One was that the old hash was not updated before calling the modify code for an ftrace_ops. The second bug was what let the first bug go unnoticed, as the update would check the current hash for all ftrace_ops (where it should only check the old hash for modified ones). This let things work when only one ftrace_ops was registered to a function, but could break if more than one was registered depending on the order of the look ups. The worse thing that can happen if this bug triggers is that the ftrace self checks would find an anomaly and shut itself down" * tag 'trace-fixes-v3.18-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: ftrace: Fix checking of trampoline ftrace_ops in finding trampoline ftrace: Set ops->old_hash on modifying what an ops hooks to
2014-10-28rcu: Make rcu_barrier() understand about missing rcuo kthreadsPaul E. McKenney
Commit 35ce7f29a44a (rcu: Create rcuo kthreads only for onlined CPUs) avoids creating rcuo kthreads for CPUs that never come online. This fixes a bug in many instances of firmware: Instead of lying about their age, these systems instead lie about the number of CPUs that they have. Before commit 35ce7f29a44a, this could result in huge numbers of useless rcuo kthreads being created. It appears that experience indicates that I should have told the people suffering from this problem to fix their broken firmware, but I instead produced what turned out to be a partial fix. The missing piece supplied by this commit makes sure that rcu_barrier() knows not to post callbacks for no-CBs CPUs that have not yet come online, because otherwise rcu_barrier() will hang on systems having firmware that lies about the number of CPUs. It is tempting to simply have rcu_barrier() refuse to post a callback on any no-CBs CPU that does not have an rcuo kthread. This unfortunately does not work because rcu_barrier() is required to wait for all pending callbacks. It is therefore required to wait even for those callbacks that cannot possibly be invoked. Even if doing so hangs the system. Given that posting a callback to a no-CBs CPU that does not yet have an rcuo kthread can hang rcu_barrier(), It is tempting to report an error in this case. Unfortunately, this will result in false positives at boot time, when it is perfectly legal to post callbacks to the boot CPU before the scheduler has started, in other words, before it is legal to invoke rcu_barrier(). So this commit instead has rcu_barrier() avoid posting callbacks to CPUs having neither rcuo kthread nor pending callbacks, and has it complain bitterly if it finds CPUs having no rcuo kthread but some pending callbacks. And when rcu_barrier() does find CPUs having no rcuo kthread but pending callbacks, as noted earlier, it has no choice but to hang indefinitely. Reported-by: Yanko Kaneti <yaneti@declera.com> Reported-by: Jay Vosburgh <jay.vosburgh@canonical.com> Reported-by: Meelis Roos <mroos@linux.ee> Reported-by: Eric B Munson <emunson@akamai.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Tested-by: Eric B Munson <emunson@akamai.com> Tested-by: Jay Vosburgh <jay.vosburgh@canonical.com> Tested-by: Yanko Kaneti <yaneti@declera.com> Tested-by: Kevin Fenzi <kevin@scrye.com> Tested-by: Meelis Roos <mroos@linux.ee>
2014-10-28perf: Fix and clean up initialization of pmu::event_idxPeter Zijlstra
Andy reported that the current state of event_idx is rather confused. So remove all but the x86_pmu implementation and change the default to return 0 (the safe option). Reported-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Christoph Lameter <cl@linux.com> Cc: Cody P Schafer <cody@linux.vnet.ibm.com> Cc: Cody P Schafer <dev@codyps.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Hendrik Brueckner <brueckner@linux.vnet.ibm.com> Cc: Himangi Saraogi <himangi774@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Paul Mackerras <paulus@samba.org> Cc: sukadev@linux.vnet.ibm.com <sukadev@linux.vnet.ibm.com> Cc: Thomas Huth <thuth@linux.vnet.ibm.com> Cc: Vince Weaver <vincent.weaver@maine.edu> Cc: linux390@de.ibm.com Cc: linuxppc-dev@lists.ozlabs.org Cc: linux-s390@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-10-28sched/dl: Fix preemption checksKirill Tkhai
1) switched_to_dl() check is wrong. We reschedule only if rq->curr is deadline task, and we do not reschedule if it's a lower priority task. But we must always preempt a task of other classes. 2) dl_task_timer(): Policy does not change in case of priority inheritance. rt_mutex_setprio() changes prio, while policy remains old. So we lose some balancing logic in dl_task_timer() and switched_to_dl() when we check policy instead of priority. Boosted task may be rq->curr. (I didn't change switched_from_dl() because no check is necessary there at all). I've looked at this place(switched_to_dl) several times and even fixed this function, but found just now... I suppose some performance tests may work better after this. Signed-off-by: Kirill Tkhai <ktkhai@parallels.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Juri Lelli <juri.lelli@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/1413909356.19914.128.camel@tkhai Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-10-28sched: stop the unbound recursion in preempt_schedule_context()Oleg Nesterov
preempt_schedule_context() does preempt_enable_notrace() at the end and this can call the same function again; exception_exit() is heavy and it is quite possible that need-resched is true again. 1. Change this code to dec preempt_count() and check need_resched() by hand. 2. As Linus suggested, we can use the PREEMPT_ACTIVE bit and avoid the enable/disable dance around __schedule(). But in this case we need to move into sched/core.c. 3. Cosmetic, but x86 forgets to declare this function. This doesn't really matter because it is only called by asm helpers, still it make sense to add the declaration into asm/preempt.h to match preempt_schedule(). Reported-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Alexander Graf <agraf@suse.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Christoph Lameter <cl@linux.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Anvin <hpa@zytor.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Chuck Ebbert <cebbert.lkml@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Link: http://lkml.kernel.org/r/20141005202322.GB27962@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-10-28sched/fair: Fix division by zero sysctl_numa_balancing_scan_sizeKirill Tkhai
File /proc/sys/kernel/numa_balancing_scan_size_mb allows writing of zero. This bash command reproduces problem: $ while :; do echo 0 > /proc/sys/kernel/numa_balancing_scan_size_mb; \ echo 256 > /proc/sys/kernel/numa_balancing_scan_size_mb; done divide error: 0000 [#1] SMP Modules linked in: CPU: 0 PID: 24112 Comm: bash Not tainted 3.17.0+ #8 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011 task: ffff88013c852600 ti: ffff880037a68000 task.ti: ffff880037a68000 RIP: 0010:[<ffffffff81074191>] [<ffffffff81074191>] task_scan_min+0x21/0x50 RSP: 0000:ffff880037a6bce0 EFLAGS: 00010246 RAX: 0000000000000a00 RBX: 00000000000003e8 RCX: 0000000000000000 RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffff88013c852600 RBP: ffff880037a6bcf0 R08: 0000000000000001 R09: 0000000000015c90 R10: ffff880239bf6c00 R11: 0000000000000016 R12: 0000000000003fff R13: ffff88013c852600 R14: ffffea0008d1b000 R15: 0000000000000003 FS: 00007f12bb048700(0000) GS:ffff88007da00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 0000000001505678 CR3: 0000000234770000 CR4: 00000000000006f0 Stack: ffff88013c852600 0000000000003fff ffff880037a6bd18 ffffffff810741d1 ffff88013c852600 0000000000003fff 000000000002bfff ffff880037a6bda8 ffffffff81077ef7 ffffea0008a56d40 0000000000000001 0000000000000001 Call Trace: [<ffffffff810741d1>] task_scan_max+0x11/0x40 [<ffffffff81077ef7>] task_numa_fault+0x1f7/0xae0 [<ffffffff8115a896>] ? migrate_misplaced_page+0x276/0x300 [<ffffffff81134a4d>] handle_mm_fault+0x62d/0xba0 [<ffffffff8103e2f1>] __do_page_fault+0x191/0x510 [<ffffffff81030122>] ? native_smp_send_reschedule+0x42/0x60 [<ffffffff8106dc00>] ? check_preempt_curr+0x80/0xa0 [<ffffffff8107092c>] ? wake_up_new_task+0x11c/0x1a0 [<ffffffff8104887d>] ? do_fork+0x14d/0x340 [<ffffffff811799bb>] ? get_unused_fd_flags+0x2b/0x30 [<ffffffff811799df>] ? __fd_install+0x1f/0x60 [<ffffffff8103e67c>] do_page_fault+0xc/0x10 [<ffffffff8150d322>] page_fault+0x22/0x30 RIP [<ffffffff81074191>] task_scan_min+0x21/0x50 RSP <ffff880037a6bce0> ---[ end trace 9a826d16936c04de ]--- Also fix race in task_scan_min (it depends on compiler behaviour). Signed-off-by: Kirill Tkhai <ktkhai@parallels.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Aaron Tomlin <atomlin@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Dario Faggioli <raistlin@linux.it> Cc: David Rientjes <rientjes@google.com> Cc: Jens Axboe <axboe@fb.com> Cc: Kees Cook <keescook@chromium.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Rik van Riel <riel@redhat.com> Link: http://lkml.kernel.org/r/1413455977.24793.78.camel@tkhai Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-10-28sched/fair: Care divide error in update_task_scan_period()Yasuaki Ishimatsu
While offling node by hot removing memory, the following divide error occurs: divide error: 0000 [#1] SMP [...] Call Trace: [...] handle_mm_fault [...] ? try_to_wake_up [...] ? wake_up_state [...] __do_page_fault [...] ? do_futex [...] ? put_prev_entity [...] ? __switch_to [...] do_page_fault [...] page_fault [...] RIP [<ffffffff810a7081>] task_numa_fault RSP <ffff88084eb2bcb0> The issue occurs as follows: 1. When page fault occurs and page is allocated from node 1, task_struct->numa_faults_buffer_memory[] of node 1 is incremented and p->numa_faults_locality[] is also incremented as follows: o numa_faults_buffer_memory[] o numa_faults_locality[] NR_NUMA_HINT_FAULT_TYPES | 0 | 1 | ---------------------------------- ---------------------- node 0 | 0 | 0 | remote | 0 | node 1 | 0 | 1 | locale | 1 | ---------------------------------- ---------------------- 2. node 1 is offlined by hot removing memory. 3. When page fault occurs, fault_types[] is calculated by using p->numa_faults_buffer_memory[] of all online nodes in task_numa_placement(). But node 1 was offline by step 2. So the fault_types[] is calculated by using only p->numa_faults_buffer_memory[] of node 0. So both of fault_types[] are set to 0. 4. The values(0) of fault_types[] pass to update_task_scan_period(). 5. numa_faults_locality[1] is set to 1. So the following division is calculated. static void update_task_scan_period(struct task_struct *p, unsigned long shared, unsigned long private){ ... ratio = DIV_ROUND_UP(private * NUMA_PERIOD_SLOTS, (private + shared)); } 6. But both of private and shared are set to 0. So divide error occurs here. The divide error is rare case because the trigger is node offline. This patch always increments denominator for avoiding divide error. Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/54475703.8000505@jp.fujitsu.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-10-28sched/numa: Fix unsafe get_task_struct() in task_numa_assign()Kirill Tkhai
Unlocked access to dst_rq->curr in task_numa_compare() is racy. If curr task is exiting this may be a reason of use-after-free: task_numa_compare() do_exit() ... current->flags |= PF_EXITING; ... release_task() ... ~~delayed_put_task_struct()~~ ... schedule() rcu_read_lock() ... cur = ACCESS_ONCE(dst_rq->curr) ... ... rq->curr = next; ... context_switch() ... finish_task_switch() ... put_task_struct() ... __put_task_struct() ... free_task_struct() task_numa_assign() ... get_task_struct() ... As noted by Oleg: <<The lockless get_task_struct(tsk) is only safe if tsk == current and didn't pass exit_notify(), or if this tsk was found on a rcu protected list (say, for_each_process() or find_task_by_vpid()). IOW, it is only safe if release_task() was not called before we take rcu_read_lock(), in this case we can rely on the fact that delayed_put_pid() can not drop the (potentially) last reference until rcu_read_unlock(). And as Kirill pointed out task_numa_compare()->task_numa_assign() path does get_task_struct(dst_rq->curr) and this is not safe. The task_struct itself can't go away, but rcu_read_lock() can't save us from the final put_task_struct() in finish_task_switch(); this reference goes away without rcu gp>> The patch provides simple check of PF_EXITING flag. If it's not set, this guarantees that call_rcu() of delayed_put_task_struct() callback hasn't happened yet, so we can safely do get_task_struct() in task_numa_assign(). Locked dst_rq->lock protects from concurrency with the last schedule(). Reusing or unmapping of cur's memory may happen without it. Suggested-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Kirill Tkhai <ktkhai@parallels.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/1413962231.19914.130.camel@tkhai Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-10-28sched/deadline: Fix races between rt_mutex_setprio() and dl_task_timer()Juri Lelli
dl_task_timer() is racy against several paths. Daniel noticed that the replenishment timer may experience a race condition against an enqueue_dl_entity() called from rt_mutex_setprio(). With his own words: rt_mutex_setprio() resets p->dl.dl_throttled. So the pattern is: start_dl_timer() throttled = 1, rt_mutex_setprio() throlled = 0, sched_switch() -> enqueue_task(), dl_task_timer-> enqueue_task() throttled is 0 => BUG_ON(on_dl_rq(dl_se)) fires as the scheduling entity is already enqueued on the -deadline runqueue. As we do for the other races, we just bail out in the replenishment timer code. Reported-by: Daniel Wagner <daniel.wagner@bmw-carit.de> Tested-by: Daniel Wagner <daniel.wagner@bmw-carit.de> Signed-off-by: Juri Lelli <juri.lelli@arm.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: vincent@legout.info Cc: Dario Faggioli <raistlin@linux.it> Cc: Michael Trimarchi <michael@amarulasolutions.com> Cc: Fabio Checconi <fchecconi@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/1414142198-18552-5-git-send-email-juri.lelli@arm.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-10-28sched/deadline: Don't replenish from a !SCHED_DEADLINE entityJuri Lelli
In the deboost path, right after the dl_boosted flag has been reset, we can currently end up replenishing using -deadline parameters of a !SCHED_DEADLINE entity. This of course causes a bug, as those parameters are empty. In the case depicted above it is safe to simply bail out, as the deboosted task is going to be back to its original scheduling class anyway. Reported-by: Daniel Wagner <daniel.wagner@bmw-carit.de> Tested-by: Daniel Wagner <daniel.wagner@bmw-carit.de> Signed-off-by: Juri Lelli <juri.lelli@arm.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: vincent@legout.info Cc: Dario Faggioli <raistlin@linux.it> Cc: Michael Trimarchi <michael@amarulasolutions.com> Cc: Fabio Checconi <fchecconi@gmail.com> Link: http://lkml.kernel.org/r/1414142198-18552-4-git-send-email-juri.lelli@arm.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-10-28sched: Fix race between task_group and sched_task_groupKirill Tkhai
The race may happen when somebody is changing task_group of a forking task. Child's cgroup is the same as parent's after dup_task_struct() (there just memory copying). Also, cfs_rq and rt_rq are the same as parent's. But if parent changes its task_group before it's called cgroup_post_fork(), we do not reflect this situation on child. Child's cfs_rq and rt_rq remain the same, while child's task_group changes in cgroup_post_fork(). To fix this we introduce fork() method, which calls sched_move_task() directly. This function changes sched_task_group on appropriate (also its logic has no problem with freshly created tasks, so we shouldn't introduce something special; we are able just to use it). Possibly, this decides the Burke Libbey's problem: https://lkml.org/lkml/2014/10/24/456 Signed-off-by: Kirill Tkhai <ktkhai@parallels.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/1414405105.19914.169.camel@tkhai Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-10-27bpf: split eBPF out of NETAlexei Starovoitov
introduce two configs: - hidden CONFIG_BPF to select eBPF interpreter that classic socket filters depend on - visible CONFIG_BPF_SYSCALL (default off) that tracing and sockets can use that solves several problems: - tracing and others that wish to use eBPF don't need to depend on NET. They can use BPF_SYSCALL to allow loading from userspace or select BPF to use it directly from kernel in NET-less configs. - in 3.18 programs cannot be attached to events yet, so don't force it on - when the rest of eBPF infra is there in 3.19+, it's still useful to switch it off to minimize kernel size bloat-o-meter on x64 shows: add/remove: 0/60 grow/shrink: 0/2 up/down: 0/-15601 (-15601) tested with many different config combinations. Hopefully didn't miss anything. Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Acked-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-27PM / Sleep: fix recovery during resuming from hibernationImre Deak
If a device's dev_pm_ops::freeze callback fails during the QUIESCE phase, we don't rollback things correctly calling the thaw and complete callbacks. This could leave some devices in a suspended state in case of an error during resuming from hibernation. Signed-off-by: Imre Deak <imre.deak@intel.com> Cc: All applicable <stable@vger.kernel.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-10-26futex: Fix a race condition between REQUEUE_PI and task deathBrian Silverman
free_pi_state and exit_pi_state_list both clean up futex_pi_state's. exit_pi_state_list takes the hb lock first, and most callers of free_pi_state do too. requeue_pi doesn't, which means free_pi_state can free the pi_state out from under exit_pi_state_list. For example: task A | task B exit_pi_state_list | pi_state = | curr->pi_state_list->next | | futex_requeue(requeue_pi=1) | // pi_state is the same as | // the one in task A | free_pi_state(pi_state) | list_del_init(&pi_state->list) | kfree(pi_state) list_del_init(&pi_state->list) | Move the free_pi_state calls in requeue_pi to before it drops the hb locks which it's already holding. [ tglx: Removed a pointless free_pi_state() call and the hb->lock held debugging. The latter comes via a seperate patch ] Signed-off-by: Brian Silverman <bsilver16384@gmail.com> Cc: austin.linux@gmail.com Cc: darren@dvhart.com Cc: peterz@infradead.org Cc: stable@vger.kernel.org Link: http://lkml.kernel.org/r/1414282837-23092-1-git-send-email-bsilver16384@gmail.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-10-26futex: Mention key referencing differences between shared and private futexesDavidlohr Bueso
Update our documentation as of fix 76835b0ebf8 (futex: Ensure get_futex_key_refs() always implies a barrier). Explicitly state that we don't do key referencing for private futexes. Signed-off-by: Davidlohr Bueso <dbueso@suse.de> Cc: Matteo Franchin <Matteo.Franchin@arm.com> Cc: Davidlohr Bueso <davidlohr@hp.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Darren Hart <dvhart@linux.intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Link: http://lkml.kernel.org/r/1414121220.817.0.camel@linux-t7sj.site Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-10-25clockevents: Prevent shift out of boundsThomas Gleixner
Andrey reported that on a kernel with UBSan enabled he found: UBSan: Undefined behaviour in ../kernel/time/clockevents.c:75:34 I guess it should be 1ULL here instead of 1U: (!ismax || evt->mult <= (1U << evt->shift))) That's indeed the correct solution because shift might be 32. Reported-by: Andrey Ryabinin <a.ryabinin@samsung.com> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-10-25posix-timers: Fix stack info leak in timer_create()Mathias Krause
If userland creates a timer without specifying a sigevent info, we'll create one ourself, using a stack local variable. Particularly will we use the timer ID as sival_int. But as sigev_value is a union containing a pointer and an int, that assignment will only partially initialize sigev_value on systems where the size of a pointer is bigger than the size of an int. On such systems we'll copy the uninitialized stack bytes from the timer_create() call to userland when the timer actually fires and we're going to deliver the signal. Initialize sigev_value with 0 to plug the stack info leak. Found in the PaX patch, written by the PaX Team. Fixes: 5a9fa7307285 ("posix-timers: kill ->it_sigev_signo and...") Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Brad Spengler <spender@grsecurity.net> Cc: PaX Team <pageexec@freemail.hu> Cc: <stable@vger.kernel.org> # v2.6.28+ Link: http://lkml.kernel.org/r/1412456799-32339-1-git-send-email-minipli@googlemail.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-10-24ftrace: Fix checking of trampoline ftrace_ops in finding trampolineSteven Rostedt (Red Hat)
When modifying code, ftrace has several checks to make sure things are being done correctly. One of them is to make sure any code it modifies is exactly what it expects it to be before it modifies it. In order to do so with the new trampoline logic, it must be able to find out what trampoline a function is hooked to in order to see if the code that hooks to it is what's expected. The logic to find the trampoline from a record (accounting descriptor for a function that is hooked) needs to only look at the "old_hash" of an ops that is being modified. The old_hash is the list of function an ops is hooked to before its update. Since a record would only be pointing to an ops that is being modified if it was already hooked before. Currently, it can pick a modified ops based on its new functions it will be hooked to, and this picks the wrong trampoline and causes the check to fail, disabling ftrace. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> ftrace: squash into ordering of ops for modification
2014-10-24ftrace: Set ops->old_hash on modifying what an ops hooks toSteven Rostedt (Red Hat)
The code that checks for trampolines when modifying function hooks tests against a modified ops "old_hash". But the ops old_hash pointer is not being updated before the changes are made, making it possible to not find the right hash to the callback and possibly causing ftrace to break in accounting and disable itself. Have the ops set its old_hash before the modifying takes place. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2014-10-23Merge branch 'freezer'Rafael J. Wysocki
* freezer: PM / freezer: Clean up code after recent fixes PM: convert do_each_thread to for_each_process_thread OOM, PM: OOM killed task shouldn't escape PM suspend freezer: remove obsolete comments in __thaw_task() freezer: Do not freeze tasks killed by OOM killer
