path: root/kernel
2009-05-26kmod: Release sub_info on cred allocation failure.Tetsuo Handa
call_usermodehelper_setup() forgot to kfree(sub_info) when prepare_usermodehelper_creds() failed. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6: PM: Do not hold dpm_list_mtx while disabling/enabling nonboot CPUs
2009-05-24async: make sure independent async domains can't accidentally entangleJames Bottomley
The problem occurs when async_synchronize_full_domain() is called when the async_pending list is not empty. This will cause lowest_running() to return the cookie of the first entry on the async_pending list, which might be nothing at all to do with the domain being asked for and thus cause the domain synchronization to wait for an unrelated domain. This can cause a deadlock if domain synchronization is used from one domain to wait for another. Fix by running over the async_pending list to see if any pending items actually belong to our domain (and return their cookies if they do). Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-24PM: Do not hold dpm_list_mtx while disabling/enabling nonboot CPUsRafael J. Wysocki
We shouldn't hold dpm_list_mtx while executing [disable|enable]_nonboot_cpus(), because theoretically this may lead to a deadlock as shown by the following example (provided by Johannes Berg): CPU 3 CPU 2 CPU 1 suspend/hibernate something: rtnl_lock() device_pm_lock() -> mutex_lock(&dpm_list_mtx) mutex_lock(&dpm_list_mtx) linkwatch_work -> rtnl_lock() disable_nonboot_cpus() -> flush CPU 3 workqueue Fortunately, device drivers are supposed to stop any activities that might lead to the registration of new device objects way before disable_nonboot_cpus() is called, so it shouldn't be necessary to hold dpm_list_mtx over the entire late part of device suspend and early part of device resume. Thus, during the late suspend and the early resume of devices acquire dpm_list_mtx only when dpm_list is going to be traversed and release it right after that. This patch is reported to fix the regressions tracked as http://bugzilla.kernel.org/show_bug.cgi?id=13245. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Alan Stern <stern@rowland.harvard.edu> Reported-by: Miles Lane <miles.lane@gmail.com> Tested-by: Ming Lei <tom.leiming@gmail.com>
2009-05-19futex: setup writeable mapping for futex ops which modify user space dataThomas Gleixner
The futex code installs a read only mapping via get_user_pages_fast() even if the futex op function has to modify user space data. The eventual fault was fixed up by futex_handle_fault() which walked the VMA with mmap_sem held. After the cleanup patches which removed the mmap_sem dependency of the futex code commit 4dc5b7a36a49eff97050894cf1b3a9a02523717 (futex: clean up fault logic) removed the private VMA walk logic from the futex code. This change results in a stale RO mapping which is not fixed up. Instead of reintroducing the previous fault logic we set up the mapping in get_user_pages_fast() read/write for all operations which modify user space data. Also handle private futexes in the same way and make the current unconditional access_ok(VERIFY_WRITE) depend on the futex op. Reported-by: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> CC: stable@kernel.org
2009-05-18Merge branches 'sched-fixes-for-linus-2' and 'core-fixes-for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-fixes-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: Fix fallback sched_clock()'s offset when using jiffies * 'core-fixes-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: lockdep: increase MAX_LOCKDEP_ENTRIES and MAX_LOCKDEP_CHAINS
2009-05-18Merge branch 'tracing-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: tracing: Append prompt in /debug/tracing/README file x86/function-graph: fix constraint for recording old return value
2009-05-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6: PM: check sysdev_suspend(PMSG_FREEZE) return value
2009-05-16Fix caller information for warn_slowpath_nullLinus Torvalds
Ian Campbell noticed that since "Eliminate thousands of warnings with gcc 3.2 build" (commit 57adc4d2dbf968fdbe516359688094eef4d46581) all WARN_ON()'s currently appear to come from warn_slowpath_null(), eg: WARNING: at kernel/softirq.c:143 warn_slowpath_null+0x1c/0x20() because now that warn_slowpath_null() is in the call path, the __builtin_return_address(0) returns that, rather than the place that caused the warning. Fix this by splitting up the warn_slowpath_null/fmt cases differently, using a common helper function, and getting the return address in the right place. This also happens to avoid the unnecessary stack usage for the non-stdargs case, and just generally cleans things up. Make the function name printout use %pS while at it. Cc: Ian Campbell <ian.campbell@citrix.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-15PM: check sysdev_suspend(PMSG_FREEZE) return valueBjorn Helgaas
Check the return value of sysdev_suspend(). I think this was a typo. Without this change, the following "if" check is always false. I also changed the error message so it's distinguishable from the similar message a few lines above. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2009-05-15tracing: Append prompt in /debug/tracing/README fileGeunSik Lim
append prompt in /debug/tracing/README file. This is trivial issue. Fix typo Mini Howto file(README) for ftrace. [ Impact: cleanup ] Signed-off-by: GeunSik Lim <geunsik.lim@samsung.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: williams <williams@redhat.com> LKML-Reference: <1242289418.31161.45.camel@centos51> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-05-15Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb: kgdb: gdb documentation fix kgdb,i386: use address that SP register points to in the exception frame sysrq, intel_fb: fix sysrq g collision
2009-05-15sysrq, intel_fb: fix sysrq g collisionJason Wessel
Commit 79e539453b34e35f39299a899d263b0a1f1670bd introduced a regression where you cannot use sysrq 'g' to enter kgdb. The solution is to move the intel fb sysrq over to V for video instead of G for graphics. The SMP VOYAGER code to register for the sysrq-v is not anywhere to be found in the mainline kernel, so the comments in the code were cleaned up as well. This patch also cleans up the sysrq definitions for kgdb to make it generic for the kernel debugger, such that the sysrq 'g' can be used in the future to enter a gdbstub or another kernel debugger. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2009-05-15Revert "mm: add /proc controls for pdflush threads"Jens Axboe
This reverts commit fafd688e4c0c34da0f3de909881117d374e4c7af. Work is progressing to switch away from pdflush as the process backing for flushing out dirty data. So it seems pointless to add more knobs to control pdflush threads. The original author of the patch did not have any specific use cases for adding the knobs, so we can easily revert this before 2.6.30 to avoid having to maintain this API forever. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-12lockdep: increase MAX_LOCKDEP_ENTRIES and MAX_LOCKDEP_CHAINSIngo Molnar
Now that lockdep coverage has increased it has become easier to run out of entries: [ 21.401387] BUG: MAX_LOCKDEP_ENTRIES too low! [ 21.402007] turning off the locking correctness validator. [ 21.402007] Pid: 1555, comm: S99local Not tainted 2.6.30-rc5-tip #2 [ 21.402007] Call Trace: [ 21.402007] [<ffffffff81069789>] add_lock_to_list+0x53/0xba [ 21.402007] [<ffffffff810eb615>] ? lookup_mnt+0x19/0x53 [ 21.402007] [<ffffffff8106be14>] check_prev_add+0x14b/0x1c7 [ 21.402007] [<ffffffff8106c304>] validate_chain+0x474/0x52a [ 21.402007] [<ffffffff8106c6fc>] __lock_acquire+0x342/0x3c7 [ 21.402007] [<ffffffff8106c842>] lock_acquire+0xc1/0xe5 [ 21.402007] [<ffffffff810eb615>] ? lookup_mnt+0x19/0x53 [ 21.402007] [<ffffffff8153aedc>] _spin_lock+0x31/0x66 Double the size - as we've done in the past. [ Impact: allow lockdep to cover more locks ] Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-05-09Convert obvious places to deactivate_locked_super()Al Viro
2009-05-09sched: Fix fallback sched_clock()'s offset when using jiffiesRon
Account for the initial offset to the jiffy count. [ Impact: fix printk timestamps on architectures using fallback sched_clock() ] Signed-off-by: Ron Lee <ron@debian.org> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-05-08kprobes: fix to use text_mutex around arm/disarm kprobeMasami Hiramatsu
Fix kprobes to lock text_mutex around some arch_arm/disarm_kprobe() which are newly added by commit de5bd88d5a5cce3cacea904d3503e5ebdb3852a2. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-06Eliminate thousands of warnings with gcc 3.2 buildAndi Kleen
When building with gcc 3.2 I get thousands of warnings such as include/linux/gfp.h: In function `allocflags_to_migratetype': include/linux/gfp.h:105: warning: null format string due to passing a NULL format string to warn_slowpath() in #define __WARN() warn_slowpath(__FILE__, __LINE__, NULL) Split this case out into a separate call. This also shrinks the kernel slightly: text data bss dec hex filename 4802274 707668 712704 6222646 5ef336 vmlinux text data bss dec hex filename 4799027 703572 712704 6215303 5ed687 vmlinux due to removeing one argument from the commonly-called __WARN(). [akpm@linux-foundation.org: reduce scope of `empty'] Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-06inotify: use GFP_NOFS in kernel_event() to work around a lockdep false-positiveWu Fengguang
There is what we believe to be a false positive reported by lockdep. inotify_inode_queue_event() => take inotify_mutex => kernel_event() => kmalloc() => SLOB => alloc_pages_node() => page reclaim => slab reclaim => dcache reclaim => inotify_inode_is_dead => take inotify_mutex => deadlock The plan is to fix this via lockdep annotation, but that is proving to be quite involved. The patch flips the allocation over to GFP_NFS to shut the warning up, for the 2.6.30 release. Hopefully we will fix this for real in 2.6.31. I'll queue a patch in -mm to switch it back to GFP_KERNEL so we don't forget. ================================= [ INFO: inconsistent lock state ] 2.6.30-rc2-next-20090417 #203 --------------------------------- inconsistent {RECLAIM_FS-ON-W} -> {IN-RECLAIM_FS-W} usage. kswapd0/380 [HC0[0]:SC0[0]:HE1:SE1] takes: (&inode->inotify_mutex){+.+.?.}, at: [<ffffffff8112f1b5>] inotify_inode_is_dead+0x35/0xb0 {RECLAIM_FS-ON-W} state was registered at: [<ffffffff81079188>] mark_held_locks+0x68/0x90 [<ffffffff810792a5>] lockdep_trace_alloc+0xf5/0x100 [<ffffffff810f5261>] __kmalloc_node+0x31/0x1e0 [<ffffffff81130652>] kernel_event+0xe2/0x190 [<ffffffff81130826>] inotify_dev_queue_event+0x126/0x230 [<ffffffff8112f096>] inotify_inode_queue_event+0xc6/0x110 [<ffffffff8110444d>] vfs_create+0xcd/0x140 [<ffffffff8110825d>] do_filp_open+0x88d/0xa20 [<ffffffff810f6b68>] do_sys_open+0x98/0x140 [<ffffffff810f6c50>] sys_open+0x20/0x30 [<ffffffff8100c272>] system_call_fastpath+0x16/0x1b [<ffffffffffffffff>] 0xffffffffffffffff irq event stamp: 690455 hardirqs last enabled at (690455): [<ffffffff81564fe4>] _spin_unlock_irqrestore+0x44/0x80 hardirqs last disabled at (690454): [<ffffffff81565372>] _spin_lock_irqsave+0x32/0xa0 softirqs last enabled at (690178): [<ffffffff81052282>] __do_softirq+0x202/0x220 softirqs last disabled at (690157): [<ffffffff8100d50c>] call_softirq+0x1c/0x50 other info that might help us debug this: 2 locks held by kswapd0/380: #0: (shrinker_rwsem){++++..}, at: [<ffffffff810d0bd7>] shrink_slab+0x37/0x180 #1: (&type->s_umount_key#17){++++..}, at: [<ffffffff8110cfbf>] shrink_dcache_memory+0x11f/0x1e0 stack backtrace: Pid: 380, comm: kswapd0 Not tainted 2.6.30-rc2-next-20090417 #203 Call Trace: [<ffffffff810789ef>] print_usage_bug+0x19f/0x200 [<ffffffff81018bff>] ? save_stack_trace+0x2f/0x50 [<ffffffff81078f0b>] mark_lock+0x4bb/0x6d0 [<ffffffff810799e0>] ? check_usage_forwards+0x0/0xc0 [<ffffffff8107b142>] __lock_acquire+0xc62/0x1ae0 [<ffffffff810f478c>] ? slob_free+0x10c/0x370 [<ffffffff8107c0a1>] lock_acquire+0xe1/0x120 [<ffffffff8112f1b5>] ? inotify_inode_is_dead+0x35/0xb0 [<ffffffff81562d43>] mutex_lock_nested+0x63/0x420 [<ffffffff8112f1b5>] ? inotify_inode_is_dead+0x35/0xb0 [<ffffffff8112f1b5>] ? inotify_inode_is_dead+0x35/0xb0 [<ffffffff81012fe9>] ? sched_clock+0x9/0x10 [<ffffffff81077165>] ? lock_release_holdtime+0x35/0x1c0 [<ffffffff8112f1b5>] inotify_inode_is_dead+0x35/0xb0 [<ffffffff8110c9dc>] dentry_iput+0xbc/0xe0 [<ffffffff8110cb23>] d_kill+0x33/0x60 [<ffffffff8110ce23>] __shrink_dcache_sb+0x2d3/0x350 [<ffffffff8110cffa>] shrink_dcache_memory+0x15a/0x1e0 [<ffffffff810d0cc5>] shrink_slab+0x125/0x180 [<ffffffff810d1540>] kswapd+0x560/0x7a0 [<ffffffff810ce160>] ? isolate_pages_global+0x0/0x2c0 [<ffffffff81065a30>] ? autoremove_wake_function+0x0/0x40 [<ffffffff8107953d>] ? trace_hardirqs_on+0xd/0x10 [<ffffffff810d0fe0>] ? kswapd+0x0/0x7a0 [<ffffffff8106555b>] kthread+0x5b/0xa0 [<ffffffff8100d40a>] child_rip+0xa/0x20 [<ffffffff8100cdd0>] ? restore_args+0x0/0x30 [<ffffffff81065500>] ? kthread+0x0/0xa0 [<ffffffff8100d400>] ? child_rip+0x0/0x20 [eparis@redhat.com: fix audit too] Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Matt Mackall <mpm@selenic.com> Cc: Christoph Lameter <clameter@sgi.com> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Eric Paris <eparis@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-05Merge branch 'timers/urgent' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers/urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: clockevents: prevent endless loop in tick_handle_periodic()
2009-05-05Merge branch 'irq/urgent' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq/urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: Revert "genirq: assert that irq handlers are indeed running in hardirq context"
2009-05-05Merge branch 'sched-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: account system time properly
2009-05-05Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: kernel/posix-cpu-timers.c: fix sparse warning dma-debug: remove broken dma memory leak detection for 2.6.30 locking: Documentation: lockdep-design.txt, fix note of state bits
2009-05-05Merge branch 'tracing-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: tracing: x86, mmiotrace: fix range test tracing: fix ref count in splice pages
2009-05-02mm: prevent divide error for small values of vm_dirty_bytesAndrea Righi
Avoid setting less than two pages for vm_dirty_bytes: this is necessary to avoid potential division by 0 (like the following) in get_dirty_limits(). [ 49.951610] divide error: 0000 [#1] PREEMPT SMP [ 49.952195] last sysfs file: /sys/devices/pci0000:00/0000:00:01.1/host0/target0:0:0/0:0:0:0/block/sda/uevent [ 49.952195] CPU 1 [ 49.952195] Modules linked in: pcspkr [ 49.952195] Pid: 3064, comm: dd Not tainted 2.6.30-rc3 #1 [ 49.952195] RIP: 0010:[<ffffffff802d39a9>] [<ffffffff802d39a9>] get_dirty_limits+0xe9/0x2c0 [ 49.952195] RSP: 0018:ffff88001de03a98 EFLAGS: 00010202 [ 49.952195] RAX: 00000000000000c0 RBX: ffff88001de03b80 RCX: 28f5c28f5c28f5c3 [ 49.952195] RDX: 0000000000000000 RSI: 00000000000000c0 RDI: 0000000000000000 [ 49.952195] RBP: ffff88001de03ae8 R08: 0000000000000000 R09: 0000000000000000 [ 49.952195] R10: ffff88001ddda9a0 R11: 0000000000000001 R12: 0000000000000001 [ 49.952195] R13: ffff88001fbc8218 R14: ffff88001de03b70 R15: ffff88001de03b78 [ 49.952195] FS: 00007fe9a435b6f0(0000) GS:ffff8800025d9000(0000) knlGS:0000000000000000 [ 49.952195] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 49.952195] CR2: 00007fe9a39ab000 CR3: 000000001de38000 CR4: 00000000000006e0 [ 49.952195] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [ 49.952195] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [ 49.952195] Process dd (pid: 3064, threadinfo ffff88001de02000, task ffff88001ddda250) [ 49.952195] Stack: [ 49.952195] ffff88001fa0de00 ffff88001f2dbd70 ffff88001f9fe800 000080b900000000 [ 49.952195] 00000000000000c0 ffff8800027a6100 0000000000000400 ffff88001fbc8218 [ 49.952195] 0000000000000000 0000000000000600 ffff88001de03bb8 ffffffff802d3ed7 [ 49.952195] Call Trace: [ 49.952195] [<ffffffff802d3ed7>] balance_dirty_pages_ratelimited_nr+0x1d7/0x3f0 [ 49.952195] [<ffffffff80368f8e>] ? ext3_writeback_write_end+0x9e/0x120 [ 49.952195] [<ffffffff802cc7df>] generic_file_buffered_write+0x12f/0x330 [ 49.952195] [<ffffffff802cce8d>] __generic_file_aio_write_nolock+0x26d/0x460 [ 49.952195] [<ffffffff802cda32>] ? generic_file_aio_write+0x52/0xd0 [ 49.952195] [<ffffffff802cda49>] generic_file_aio_write+0x69/0xd0 [ 49.952195] [<ffffffff80365fa6>] ext3_file_write+0x26/0xc0 [ 49.952195] [<ffffffff803034d1>] do_sync_write+0xf1/0x140 [ 49.952195] [<ffffffff80290d1a>] ? get_lock_stats+0x2a/0x60 [ 49.952195] [<ffffffff80280730>] ? autoremove_wake_function+0x0/0x40 [ 49.952195] [<ffffffff8030411b>] vfs_write+0xcb/0x190 [ 49.952195] [<ffffffff803042d0>] sys_write+0x50/0x90 [ 49.952195] [<ffffffff8022ff6b>] system_call_fastpath+0x16/0x1b [ 49.952195] Code: 00 00 00 2b 05 09 1c 17 01 48 89 c6 49 0f af f4 48 c1 ee 02 48 89 f0 48 f7 e1 48 89 d6 31 d2 48 c1 ee 02 48 0f af 75 d0 48 89 f0 <48> f7 f7 41 8b 95 ac 01 00 00 48 89 c7 49 0f af d4 48 c1 ea 02 [ 49.952195] RIP [<ffffffff802d39a9>] get_dirty_limits+0xe9/0x2c0 [ 49.952195] RSP <ffff88001de03a98> [ 50.096523] ---[ end trace 008d7aa02f244d7b ]--- Signed-off-by: Andrea Righi <righi.andrea@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: David Rientjes <rientjes@google.com> Cc: Dave Chinner <david@fromorbit.com> Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-02clockevents: prevent endless loop in tick_handle_periodic()john stultz
tick_handle_periodic() can lock up hard when a one shot clock event device is used in combination with jiffies clocksource. Avoid an endless loop issue by requiring that a highres valid clocksource be installed before we call tick_periodic() in a loop when using ONESHOT mode. The result is we will only increment jiffies once per interrupt until a continuous hardware clocksource is available. Without this, we can run into a endless loop, where each cycle through the loop, jiffies is updated which increments time by tick_period or more (due to clock steering), which can cause the event programming to think the next event was before the newly incremented time and fail causing tick_periodic() to be called again and the whole process loops forever. [ Impact: prevent hard lock up ] Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: stable@kernel.org
2009-05-01Revert "genirq: assert that irq handlers are indeed running in hardirq context"Thomas Gleixner
This reverts commit 044d408409cc4e1bc75c886e27ca85c270db104c. The commit added a warning when handle_IRQ_event() is called outside of hard interrupt context. This breaks the generic tasklet based interrupt resend mechanism which is used when the hardware has no way to retrigger the interrupt. So we get a warning for a use case which is correct and worked for years. Remove it. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-04-30kernel/posix-cpu-timers.c: fix sparse warningH Hartley Sweeten
Sparse reports the following in kernel/posix-cpu-timers.c: warning: symbol 'firing' shadows an earlier one Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Cc: Subrata Modak <subrata@linux.vnet.ibm.com> LKML-Reference: <BD79186B4FD85F4B8E60E381CAEE1909016C1AFE@mi8nycmail19.Mi8.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-29sched: account system time properlyEric Dumazet
Andrew Gallatin reported that IRQ and SOFTIRQ times were sometime not reported correctly on recent kernels, and even bisected to commit 457533a7d3402d1d91fbc125c8bd1bd16dcd3cd4 ([PATCH] fix scaled & unscaled cputime accounting) as the first bad commit. Further analysis pointed that commit 79741dd35713ff4f6fd0eafd59fa94e8a4ba922d ([PATCH] idle cputime accounting) was the real cause of the problem. account_process_tick() was not taking into account timer IRQ interrupting the idle task servicing a hard or soft irq. On mostly idle cpu, irqs were thus not accounted and top or mpstat could tell user/admin that cpu was 100 % idle, 0.00 % irq, 0.00 % softirq, while it was not. [ Impact: fix occasionally incorrect CPU statistics in top/mpstat ] Reported-by: Andrew Gallatin <gallatin@myri.com> Re-reported-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: rick.jones2@hp.com Cc: brice@myri.com Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> LKML-Reference: <49F84BC1.7080602@cosmosbay.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-29tracing: fix ref count in splice pagesSteven Rostedt
The pages allocated for the splice binary buffer did not initialize the ref count correctly. This caused pages not to be freed and causes a drastic memory leak. Thanks to logdev I was able to trace the tracer to find where the leak was. [ Impact: stop memory leak when using splice ] Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: ptrace: ptrace_attach: fix the usage of ->cred_exec_mutex
2009-04-27ptrace: ptrace_attach: fix the usage of ->cred_exec_mutexOleg Nesterov
ptrace_attach() needs task->cred_exec_mutex, not current->cred_exec_mutex. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-04-26Merge branch 'irq-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86/irq: mark NUMA_MIGRATE_IRQ_DESC broken x86, irq: Remove IRQ_DISABLED check in process context IRQ move
2009-04-26Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: locking: clarify kernel-taint warning message lockdep, x86: account for irqs enabled in paranoid_exit lockdep: more robust lockdep_map init sequence
2009-04-24PM/Hibernate: Fix waiting for image device to appear on resumeRafael J. Wysocki
Commit c751085943362143f84346d274e0011419c84202 ("PM/Hibernate: Wait for SCSI devices scan to complete during resume") added a call to scsi_complete_async_scans() to software_resume(), so that it waited for the SCSI scanning to complete, but the call was added at a wrong place. Namely, it should have been added after wait_for_device_probe(), which is called only if the image partition hasn't been specified yet. Also, it's reasonable to check if the image partition is present and only wait for the device probing and SCSI scanning to complete if it is not the case. Additionally, since noresume is checked right at the beginning of software_resume() and the function returns immediately if it's set, it doesn't make sense to check it once again later. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-24Delete slow-work timers properlyJonathan Corbet
Slow-work appears to delete its timer as soon as the first user unregisters, even though other users could be active. At the same time, it never seems to delete slow_work_oom_timer. Arrange for both to happen in the shutdown path. Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-23locking: clarify kernel-taint warning messageIngo Molnar
Andi Kleen reported this message triggering on non-lockdep kernels: Disabling lockdep due to kernel taint Clarify the message to say 'lock debugging' - debug_locks_off() turns off all things lock debugging, not just lockdep. [ Impact: change kernel warning message text ] Reported-by: Andi Kleen <andi@firstfloor.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-21clocksource: add enable() and disable() callbacksMagnus Damm
Add enable() and disable() callbacks for clocksources. This allows us to put unused clocksources in power save mode. The functions clocksource_enable() and clocksource_disable() wrap the callbacks and are inserted in the timekeeping code to enable before use and disable after switching to a new clocksource. Signed-off-by: Magnus Damm <damm@igel.co.jp> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21clocksource: pass clocksource to read() callbackMagnus Damm
Pass clocksource pointer to the read() callback for clocksources. This allows us to share the callback between multiple instances. [hugh@veritas.com: fix powerpc build of clocksource pass clocksource mods] [akpm@linux-foundation.org: cleanup] Signed-off-by: Magnus Damm <damm@igel.co.jp> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-20No need for crossing to mountpoint in audit_tag_tree()Al Viro
is_under() will DTRT anyway. And yes, is_subdir() behaviour is intentional. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-04-19PM/Suspend: Introduce two new platform callbacks to avoid breakageRafael J. Wysocki
Commit 900af0d973856d6feb6fc088c2d0d3fde57707d3 (PM: Change suspend code ordering) changed the ordering of suspend code in such a way that the platform .prepare() callback is now executed after the device drivers' late suspend callbacks have run. Unfortunately, this turns out to break ARM platforms that need to talk via I2C to power control devices during the .prepare() callback. For this reason introduce two new platform suspend callbacks, .prepare_late() and .wake(), that will be called just prior to disabling non-boot CPUs and right after bringing them back on line, respectively, and use them instead of .prepare() and .finish() for ACPI suspend. Make the PM core execute the .prepare() and .finish() platform suspend callbacks where they were executed previously (that is, right after calling the regular suspend methods provided by device drivers and right before executing their regular resume methods, respectively). It is not necessary to make analogous changes to the hibernation code and data structures at the moment, because they are only used by ACPI platforms. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reported-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Len Brown <len.brown@intel.com>
2009-04-18Remove 'recurse into child resources' logic from 'reserve_region_with_split()'Linus Torvalds
This function is not actually used right now, since the original use case for it was done with insert_resource_expand_to_fit() instead. However, we now have another usage case that wants to basically do a "reserve IO resource, splitting around existing resources", however that one doesn't actually want the "recurse into the conflicting resource" logic at all. And since recursing into the conflicting resource was the most complex part, and isn't wanted, just remove it. Maybe we'll some day want both versions, but we can just resurrect the logic then. Tested-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-17lockdep: more robust lockdep_map init sequencePeter Zijlstra
Steven Rostedt reported: > OK, I think I figured this bug out. This is a lockdep issue with respect > to tracepoints. > > The trace points in lockdep are called all the time. Outside the lockdep > logic. But if lockdep were to trigger an error / warning (which this run > did) we might be in trouble. For new locks, like the dentry->d_lock, that > are created, they will not get a name: > > void lockdep_init_map(struct lockdep_map *lock, const char *name, > struct lock_class_key *key, int subclass) > { > if (unlikely(!debug_locks)) > return; > > When a problem is found by lockdep, debug_locks becomes false. Thus we > stop allocating names for locks. This dentry->d_lock I had, now has no > name. Worse yet, I have CONFIG_DEBUG_VM set, that scrambles non > initialized memory. Thus, when the trace point was hit, it had junk for > the lock->name, and the machine crashed. Ah, nice catch. I think we should put at least the name in regardless. Ensure we at least initialize the trivial entries of the depmap so that they can be relied upon, even when lockdep itself decided to pack up and go home. [ Impact: fix lock tracing after lockdep warnings. ] Reported-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <1239954049.23397.4156.camel@laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-16Merge branch 'tracing-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: tracing: Fix branch tracer header tracing: Fix power tracer header
2009-04-16Merge branch 'sched-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: Avoid printing sched_group::__cpu_power for default case tracing, sched: mark get_parent_ip() notrace
2009-04-16Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: kernel/softirq.c: fix sparse warning rcu: Make hierarchical RCU less IPI-happy
2009-04-17kernel/softirq.c: fix sparse warningH Hartley Sweeten
Fix sparse warning in kernel/softirq.c. warning: do-while statement is not a compound statement Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> LKML-Reference: <BD79186B4FD85F4B8E60E381CAEE1909015F9033@mi8nycmail19.Mi8.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-17sched: Avoid printing sched_group::__cpu_power for default caseGautham R Shenoy
Commit 46e0bb9c12f4 ("sched: Print sched_group::__cpu_power in sched_domain_debug") produces a messy dmesg output while attempting to print the sched_group::__cpu_power for each group in the sched_domain hierarchy. Fix this by avoid printing the __cpu_power for default cases. (i.e, __cpu_power == SCHED_LOAD_SCALE). [ Impact: reduce syslog clutter ] Reported-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Gautham R Shenoy <ego@in.ibm.com> Fixed-by: Tony Luck <tony.luck@intel.com> Cc: a.p.zijlstra@chello.nl LKML-Reference: <20090414033936.GA534@in.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-15RCU: Don't try and predeclare inline funcs as it upsets some versions of gccDavid Howells
Don't try and predeclare inline funcs like this: static inline void wait_migrated_callbacks(void) ... static void _rcu_barrier(enum rcu_barrier type) { ... wait_migrated_callbacks(); } ... static inline void wait_migrated_callbacks(void) { wait_event(rcu_migrate_wq, !atomic_read(&rcu_migrate_type_count)); } as it upsets some versions of gcc under some circumstances: kernel/rcupdate.c: In function `_rcu_barrier': kernel/rcupdate.c:125: sorry, unimplemented: inlining failed in call to 'wait_migrated_callbacks': function body not available kernel/rcupdate.c:152: sorry, unimplemented: called from here This can be dealt with by simply putting the static variables (rcu_migrate_*) at the top, and moving the implementation of the function up so that it replaces its forward declaration. Signed-off-by: David Howells <dhowells@redhat.com> Cc: Dipankar Sarma <dipankar@in.ibm.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
