Some modules may need to know cpu idle status and take
actions before and after cpu idle, so we can add
notification callback when enter/exit cpu idle, then
modules only need to register this notification callback,
everytime cpu enter/exit idle, the callback chain will be
executed.
Currently only cpufreq interactive governor use this
notification, as it wants to save power, the timers of
interactive governor are only enabled when cpu is not in idle.
Signed-off-by: Anson Huang <b20788@freescale.com>
commit ded797547548a5b8e7b92383a41e4c0e6b0ecb7f upstream.
The commit facd8b80c67a3cf64a467c4a2ac5fb31f2e6745b
("irq: Sanitize invoke_softirq") converted irq exit
calls of do_softirq() to __do_softirq() on all architectures,
assuming it was only used there for its irq disablement
properties.
But as a side effect, the softirqs processed in the end
of the hardirq are always called on the inline current
stack that is used by irq_exit() instead of the softirq
stack provided by the archs that override do_softirq().
The result is mostly safe if the architecture runs irq_exit()
on a separate irq stack because then softirqs are processed
on that same stack that is near empty at this stage (assuming
hardirq aren't nesting).
Otherwise irq_exit() runs in the task stack and so does the softirq
too. The interrupted call stack can be randomly deep already and
the softirq can dig through it even further. To add insult to the
injury, this softirq can be interrupted by a new hardirq, maximizing
the chances for a stack overrun as reported in powerpc for example:
do_IRQ: stack overflow: 1920
CPU: 0 PID: 1602 Comm: qemu-system-ppc Not tainted 3.10.4-300.1.fc19.ppc64p7 #1
Call Trace:
[c0000000050a8740] .show_stack+0x130/0x200 (unreliable)
[c0000000050a8810] .dump_stack+0x28/0x3c
[c0000000050a8880] .do_IRQ+0x2b8/0x2c0
[c0000000050a8930] hardware_interrupt_common+0x154/0x180
--- Exception: 501 at .cp_start_xmit+0x3a4/0x820 [8139cp]
LR = .cp_start_xmit+0x390/0x820 [8139cp]
[c0000000050a8d40] .dev_hard_start_xmit+0x394/0x640
[c0000000050a8e00] .sch_direct_xmit+0x110/0x260
[c0000000050a8ea0] .dev_queue_xmit+0x260/0x630
[c0000000050a8f40] .br_dev_queue_push_xmit+0xc4/0x130 [bridge]
[c0000000050a8fc0] .br_dev_xmit+0x198/0x270 [bridge]
[c0000000050a9070] .dev_hard_start_xmit+0x394/0x640
[c0000000050a9130] .dev_queue_xmit+0x428/0x630
[c0000000050a91d0] .ip_finish_output+0x2a4/0x550
[c0000000050a9290] .ip_local_out+0x50/0x70
[c0000000050a9310] .ip_queue_xmit+0x148/0x420
[c0000000050a93b0] .tcp_transmit_skb+0x4e4/0xaf0
[c0000000050a94a0] .__tcp_ack_snd_check+0x7c/0xf0
[c0000000050a9520] .tcp_rcv_established+0x1e8/0x930
[c0000000050a95f0] .tcp_v4_do_rcv+0x21c/0x570
[c0000000050a96c0] .tcp_v4_rcv+0x734/0x930
[c0000000050a97a0] .ip_local_deliver_finish+0x184/0x360
[c0000000050a9840] .ip_rcv_finish+0x148/0x400
[c0000000050a98d0] .__netif_receive_skb_core+0x4f8/0xb00
[c0000000050a99d0] .netif_receive_skb+0x44/0x110
[c0000000050a9a70] .br_handle_frame_finish+0x2bc/0x3f0 [bridge]
[c0000000050a9b20] .br_nf_pre_routing_finish+0x2ac/0x420 [bridge]
[c0000000050a9bd0] .br_nf_pre_routing+0x4dc/0x7d0 [bridge]
[c0000000050a9c70] .nf_iterate+0x114/0x130
[c0000000050a9d30] .nf_hook_slow+0xb4/0x1e0
[c0000000050a9e00] .br_handle_frame+0x290/0x330 [bridge]
[c0000000050a9ea0] .__netif_receive_skb_core+0x34c/0xb00
[c0000000050a9fa0] .netif_receive_skb+0x44/0x110
[c0000000050aa040] .napi_gro_receive+0xe8/0x120
[c0000000050aa0c0] .cp_rx_poll+0x31c/0x590 [8139cp]
[c0000000050aa1d0] .net_rx_action+0x1dc/0x310
[c0000000050aa2b0] .__do_softirq+0x158/0x330
[c0000000050aa3b0] .irq_exit+0xc8/0x110
[c0000000050aa430] .do_IRQ+0xdc/0x2c0
[c0000000050aa4e0] hardware_interrupt_common+0x154/0x180
--- Exception: 501 at .bad_range+0x1c/0x110
LR = .get_page_from_freelist+0x908/0xbb0
[c0000000050aa7d0] .list_del+0x18/0x50 (unreliable)
[c0000000050aa850] .get_page_from_freelist+0x908/0xbb0
[c0000000050aa9e0] .__alloc_pages_nodemask+0x21c/0xae0
[c0000000050aaba0] .alloc_pages_vma+0xd0/0x210
[c0000000050aac60] .handle_pte_fault+0x814/0xb70
[c0000000050aad50] .__get_user_pages+0x1a4/0x640
[c0000000050aae60] .get_user_pages_fast+0xec/0x160
[c0000000050aaf10] .__gfn_to_pfn_memslot+0x3b0/0x430 [kvm]
[c0000000050aafd0] .kvmppc_gfn_to_pfn+0x64/0x130 [kvm]
[c0000000050ab070] .kvmppc_mmu_map_page+0x94/0x530 [kvm]
[c0000000050ab190] .kvmppc_handle_pagefault+0x174/0x610 [kvm]
[c0000000050ab270] .kvmppc_handle_exit_pr+0x464/0x9b0 [kvm]
[c0000000050ab320] kvm_start_lightweight+0x1ec/0x1fc [kvm]
[c0000000050ab4f0] .kvmppc_vcpu_run_pr+0x168/0x3b0 [kvm]
[c0000000050ab9c0] .kvmppc_vcpu_run+0xc8/0xf0 [kvm]
[c0000000050aba50] .kvm_arch_vcpu_ioctl_run+0x5c/0x1a0 [kvm]
[c0000000050abae0] .kvm_vcpu_ioctl+0x478/0x730 [kvm]
[c0000000050abc90] .do_vfs_ioctl+0x4ec/0x7c0
[c0000000050abd80] .SyS_ioctl+0xd4/0xf0
[c0000000050abe30] syscall_exit+0x0/0x98
Since this is a regression, this patch proposes a minimalistic
and low-risk solution by blindly forcing the hardirq exit processing of
softirqs on the softirq stack. This way we should reduce significantly
the opportunities for task stack overflow dug by softirqs.
Longer term solutions may involve extending the hardirq stack coverage to
irq_exit(), etc...
Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Paul Mackerras <paulus@au1.ibm.com>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: James E.J. Bottomley <jejb@parisc-linux.org>
Cc: Helge Deller <deller@gmx.de>
commit 8ac1c8d5deba65513b6a82c35e89e73996c8e0d6 upstream.
After commit 829199197a43 ("kernel/audit.c: avoid negative sleep
durations") audit emitters will block forever if userspace daemon cannot
handle backlog.
After the timeout the waiting loop turns into busy loop and runs until
daemon dies or returns back to work. This is a minimal patch for that
bug.
Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org>
Cc: Luiz Capitulino <lcapitulino@redhat.com>
Cc: Richard Guy Briggs <rgb@redhat.com>
Cc: Eric Paris <eparis@redhat.com>
Cc: Chuck Anderson <chuck.anderson@oracle.com>
Cc: Dan Duval <dan.duval@oracle.com>
Cc: Dave Kleikamp <dave.kleikamp@oracle.com>
Cc: Jonghwan Choi <jhbird.choi@samsung.com>
invalid ones
commit 6c9a27f5da9609fca46cb2b183724531b48f71ad upstream.
There is a small race between copy_process() and cgroup_attach_task()
where child->se.parent,cfs_rq points to invalid (old) ones.
parent doing fork() | someone moving the parent to another cgroup
copy_process()
+ dup_task_struct()
-> parent->se is copied to child->se.
se.parent,cfs_rq of them point to old ones.
+ cgroup_task_migrate()
-> parent->cgroup is updated.
+ cpu_cgroup_attach()
+ sched_move_task()
+ task_move_group_fair()
+- set_task_rq()
-> se.parent,cfs_rq of parent
are updated.
+ cgroup_fork()
-> parent->cgroup is copied to child->cgroup. (*1)
+ sched_fork()
+ task_fork_fair()
-> se.parent,cfs_rq of child are accessed
while they point to old ones. (*2)
In the worst case, this bug can lead to "use-after-free" and cause a panic,
because it's new cgroup's refcount that is incremented at (*1),
so the old cgroup(and related data) can be freed before (*2).
In fact, a panic caused by this bug was originally caught in RHEL6.4.
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<ffffffff81051e3e>] sched_slice+0x6e/0xa0
Call Trace:
[<ffffffff81051f25>] place_entity+0x75/0xa0
[<ffffffff81056a3a>] task_fork_fair+0xaa/0x160
[<ffffffff81063c0b>] sched_fork+0x6b/0x140
[<ffffffff8106c3c2>] copy_process+0x5b2/0x1450
[<ffffffff81063b49>] ? wake_up_new_task+0xd9/0x130
[<ffffffff8106d2f4>] do_fork+0x94/0x460
[<ffffffff81072a9e>] ? sys_wait4+0xae/0x100
[<ffffffff81009598>] sys_clone+0x28/0x30
[<ffffffff8100b393>] stub_clone+0x13/0x20
[<ffffffff8100b072>] ? system_call_fastpath+0x16/0x1b
Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/039601ceae06$733d3130$59b79390$@mxp.nes.nec.co.jp
commit 5a8e01f8fa51f5cbce8f37acc050eb2319d12956 upstream.
scale_stime() silently assumes that stime < rtime, otherwise
when stime == rtime and both values are big enough (operations
on them do not fit in 32 bits), the resulting scaling stime can
be bigger than rtime. In consequence utime = rtime - stime
results in negative value.
User space visible symptoms of the bug are overflowed TIME
values on ps/top, for example:
$ ps aux | grep rcu
root 8 0.0 0.0 0 0 ? S 12:42 0:00 [rcuc/0]
root 9 0.0 0.0 0 0 ? S 12:42 0:00 [rcub/0]
root 10 62422329 0.0 0 0 ? R 12:42 21114581:37 [rcu_preempt]
root 11 0.1 0.0 0 0 ? S 12:42 0:02 [rcuop/0]
root 12 62422329 0.0 0 0 ? S 12:42 21114581:35 [rcuop/1]
or overflowed utime values read directly from /proc/$PID/stat
Reference:
https://lkml.org/lkml/2013/8/20/259
Reported-and-tested-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
Cc: stable@vger.kernel.org
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/20130904131602.GC2564@redhat.com
commit 7bd36014460f793c19e7d6c94dab67b0afcfcb7f upstream.
Gerlando Falauto reported that when HRTICK is enabled, it is
possible to trigger system deadlocks. These were hard to
reproduce, as HRTICK has been broken in the past, but seemed
to be connected to the timekeeping_seq lock.
Since seqlock/seqcount's aren't supported w/ lockdep, I added
some extra spinlock based locking and triggered the following
lockdep output:
[ 15.849182] ntpd/4062 is trying to acquire lock:
[ 15.849765] (&(&pool->lock)->rlock){..-...}, at: [<ffffffff810aa9b5>] __queue_work+0x145/0x480
[ 15.850051]
[ 15.850051] but task is already holding lock:
[ 15.850051] (timekeeper_lock){-.-.-.}, at: [<ffffffff810df6df>] do_adjtimex+0x7f/0x100
<snip>
[ 15.850051] Chain exists of: &(&pool->lock)->rlock --> &p->pi_lock --> timekeeper_lock
[ 15.850051] Possible unsafe locking scenario:
[ 15.850051]
[ 15.850051] CPU0 CPU1
[ 15.850051] ---- ----
[ 15.850051] lock(timekeeper_lock);
[ 15.850051] lock(&p->pi_lock);
[ 15.850051] lock(&(&pool->lock)->rlock);
[ 15.850051]
[ 15.850051] *** DEADLOCK ***
The deadlock was introduced by 06c017fdd4dc48451a ("timekeeping:
Hold timekeepering locks in do_adjtimex and hardpps") in 3.10
This patch avoids this deadlock, by moving the call to
schedule_delayed_work() outside of the timekeeper lock
critical section.
Reported-by: Gerlando Falauto <gerlando.falauto@keymile.com>
Tested-by: Lin Ming <minggr@gmail.com>
Signed-off-by: John Stultz <john.stultz@linaro.org>
Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Link: http://lkml.kernel.org/r/1378943457-27314-1-git-send-email-john.stultz@linaro.org
commit e79f525e99b04390ca4d2366309545a836c03bf1 upstream.
Commit 8382fcac1b81 ("pidns: Outlaw thread creation after
unshare(CLONE_NEWPID)") nacks CLONE_VM if the forking process unshared
pid_ns, this obviously breaks vfork:
int main(void)
assert(unshare(CLONE_NEWUSER | CLONE_NEWPID) == 0);
assert(vfork() >= 0);
_exit(0);
return 0;
fails without this patch.
Change this check to use CLONE_SIGHAND instead. This also forbids
CLONE_THREAD automatically, and this is what the comment implies.
We could probably even drop CLONE_SIGHAND and use CLONE_THREAD, but it
would be safer to not do this. The current check denies CLONE_SIGHAND
implicitely and there is no reason to change this.
Eric said "CLONE_SIGHAND is fine. CLONE_THREAD would be even better.
Having shared signal handling between two different pid namespaces is
the case that we are fundamentally guarding against."
Reported-by: Colin Walters <walters@redhat.com>
Acked-by: Andy Lutomirski <luto@amacapital.net>
Reviewed-by: "Eric W. Biederman" <ebiederm@xmission.com>
commit a606488513543312805fab2b93070cefe6a3016c upstream.
Serge Hallyn <serge.hallyn@ubuntu.com> writes:
> Since commit af4b8a83add95ef40716401395b44a1b579965f4 it's been
> possible to get into a situation where a pidns reaper is
> <defunct>, reparented to host pid 1, but never reaped. How to
> reproduce this is documented at
> https://bugs.launchpad.net/ubuntu/+source/lxc/+bug/1168526
> (and see
> https://bugs.launchpad.net/ubuntu/+source/lxc/+bug/1168526/comments/13)
> In short, run repeated starts of a container whose init is
> Process.exit(0);
> sysrq-t when such a task is playing zombie shows:
> [ 131.132978] init x ffff88011fc14580 0 2084 2039 0x00000000
> [ 131.132978] ffff880116e89ea8 0000000000000002 ffff880116e89fd8 0000000000014580
> [ 131.132978] ffff880116e89fd8 0000000000014580 ffff8801172a0000 ffff8801172a0000
> [ 131.132978] ffff8801172a0630 ffff88011729fff0 ffff880116e14650 ffff88011729fff0
> [ 131.132978] Call Trace:
> [ 131.132978] [<ffffffff816f6159>] schedule+0x29/0x70
> [ 131.132978] [<ffffffff81064591>] do_exit+0x6e1/0xa40
> [ 131.132978] [<ffffffff81071eae>] ? signal_wake_up_state+0x1e/0x30
> [ 131.132978] [<ffffffff8106496f>] do_group_exit+0x3f/0xa0
> [ 131.132978] [<ffffffff810649e4>] SyS_exit_group+0x14/0x20
> [ 131.132978] [<ffffffff8170102f>] tracesys+0xe1/0xe6
> Further debugging showed that every time this happened, zap_pid_ns_processes()
> started with nr_hashed being 3, while we were expecting it to drop to 2.
> Any time it didn't happen, nr_hashed was 1 or 2. So the reaper was
> waiting for nr_hashed to become 2, but free_pid() only wakes the reaper
> if nr_hashed hits 1.
The issue is that when the task group leader of an init process exits
before other tasks of the init process when the init process finally
exits it will be a secondary task sleeping in zap_pid_ns_processes and
waiting to wake up when the number of hashed pids drops to two. This
case waits forever as free_pid only sends a wake up when the number of
hashed pids drops to 1.
To correct this the simple strategy of sending a possibly unncessary
wake up when the number of hashed pids drops to 2 is adopted.
Sending one extraneous wake up is relatively harmless, at worst we
waste a little cpu time in the rare case when a pid namespace
appropaches exiting.
We can detect the case when the pid namespace drops to just two pids
hashed race free in free_pid.
Dereferencing pid_ns->child_reaper with the pidmap_lock held is safe
without out the tasklist_lock because it is guaranteed that the
detach_pid will be called on the child_reaper before it is freed and
detach_pid calls __change_pid which calls free_pid which takes the
pidmap_lock. __change_pid only calls free_pid if this is the
last use of the pid. For a thread that is not the thread group leader
the threads pid will only ever have one user because a threads pid
is not allowed to be the pid of a process, of a process group or
a session. For a thread that is a thread group leader all of
the other threads of that process will be reaped before it is allowed
for the thread group leader to be reaped ensuring there will only
be one user of the threads pid as a process pid. Furthermore
because the thread is the init process of a pid namespace all of the
other processes in the pid namespace will have also been already freed
leading to the fact that the pid will not be used as a session pid or
a process group pid for any other running process.
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Tested-by: Serge Hallyn <serge.hallyn@canonical.com>
Reported-by: Serge Hallyn <serge.hallyn@ubuntu.com>
commit 878b5a6efd38030c7a90895dc8346e8fb1e09b4c upstream.
Currently utask->depth is simply the number of allocated/pending
return_instance's in uprobe_task->return_instances list.
handle_trampoline() should decrement this counter every time we
handle/free an instance, but due to typo it does this only if
->chained == T. This means that in the likely case this counter
is never decremented and the probed task can't report more than
MAX_URETPROBE_DEPTH events.
Reported-by: Mikhail Kulemin <Mikhail.Kulemin@ru.ibm.com>
Reported-by: Hemant Kumar Shaw <hkshaw@linux.vnet.ibm.com>
Acked-by: Anton Arapov <anton@redhat.com>
Cc: masami.hiramatsu.pt@hitachi.com
Cc: srikar@linux.vnet.ibm.com
Cc: systemtap@sourceware.org
Link: http://lkml.kernel.org/r/20130911154726.GA8093@redhat.com
commit b22ce2785d97423846206cceec4efee0c4afd980 upstream.
If !PREEMPT, a kworker running work items back to back can hog CPU.
This becomes dangerous when a self-requeueing work item which is
waiting for something to happen races against stop_machine. Such
self-requeueing work item would requeue itself indefinitely hogging
the kworker and CPU it's running on while stop_machine would wait for
that CPU to enter stop_machine while preventing anything else from
happening on all other CPUs. The two would deadlock.
Jamie Liu reports that this deadlock scenario exists around
scsi_requeue_run_queue() and libata port multiplier support, where one
port may exclude command processing from other ports. With the right
timing, scsi_requeue_run_queue() can end up requeueing itself trying
to execute an IO which is asked to be retried while another device has
an exclusive access, which in turn can't make forward progress due to
stop_machine.
Fix it by invoking cond_resched() after executing each work item.
Reported-by: Jamie Liu <jamieliu@google.com>
References: http://thread.gmane.org/gmane.linux.kernel/1552567
commit 84a78a6504f5c5394a8e558702e5b54131f01d14 upstream.
Correct an issue with /proc/timer_list reported by Holger.
When reading from the proc file with a sufficiently small buffer, 2k so
not really that small, there was one could get hung trying to read the
file a chunk at a time.
The timer_list_start function failed to account for the possibility that
the offset was adjusted outside the timer_list_next.
Signed-off-by: Nathan Zimmer <nzimmer@sgi.com>
Reported-by: Holger Hans Peter Freyther <holger@freyther.de>
Cc: John Stultz <john.stultz@linaro.org>
Cc: Berke Durak <berke.durak@xiphos.com>
Cc: Jeff Layton <jlayton@redhat.com>
Tested-by: Al Viro <viro@zeniv.linux.org.uk>
commit 8c4f3c3fa9681dc549cd35419b259496082fef8b upstream.
There's been a nasty bug that would show up and not give much info.
The bug displayed the following warning:
WARNING: at kernel/trace/ftrace.c:1529 __ftrace_hash_rec_update+0x1e3/0x230()
Pid: 20903, comm: bash Tainted: G O 3.6.11+ #38405.trunk
Call Trace:
[<ffffffff8103e5ff>] warn_slowpath_common+0x7f/0xc0
[<ffffffff8103e65a>] warn_slowpath_null+0x1a/0x20
[<ffffffff810c2ee3>] __ftrace_hash_rec_update+0x1e3/0x230
[<ffffffff810c4f28>] ftrace_hash_move+0x28/0x1d0
[<ffffffff811401cc>] ? kfree+0x2c/0x110
[<ffffffff810c68ee>] ftrace_regex_release+0x8e/0x150
[<ffffffff81149f1e>] __fput+0xae/0x220
[<ffffffff8114a09e>] ____fput+0xe/0x10
[<ffffffff8105fa22>] task_work_run+0x72/0x90
[<ffffffff810028ec>] do_notify_resume+0x6c/0xc0
[<ffffffff8126596e>] ? trace_hardirqs_on_thunk+0x3a/0x3c
[<ffffffff815c0f88>] int_signal+0x12/0x17
---[ end trace 793179526ee09b2c ]---
It was finally narrowed down to unloading a module that was being traced.
It was actually more than that. When functions are being traced, there's
a table of all functions that have a ref count of the number of active
tracers attached to that function. When a function trace callback is
registered to a function, the function's record ref count is incremented.
When it is unregistered, the function's record ref count is decremented.
If an inconsistency is detected (ref count goes below zero) the above
warning is shown and the function tracing is permanently disabled until
reboot.
The ftrace callback ops holds a hash of functions that it filters on
(and/or filters off). If the hash is empty, the default means to filter
all functions (for the filter_hash) or to disable no functions (for the
notrace_hash).
When a module is unloaded, it frees the function records that represent
the module functions. These records exist on their own pages, that is
function records for one module will not exist on the same page as
function records for other modules or even the core kernel.
Now when a module unloads, the records that represents its functions are
freed. When the module is loaded again, the records are recreated with
a default ref count of zero (unless there's a callback that traces all
functions, then they will also be traced, and the ref count will be
incremented).
The problem is that if an ftrace callback hash includes functions of the
module being unloaded, those hash entries will not be removed. If the
module is reloaded in the same location, the hash entries still point
to the functions of the module but the module's ref counts do not reflect
that.
With the help of Steve and Joern, we found a reproducer:
Using uinput module and uinput_release function.
cd /sys/kernel/debug/tracing
modprobe uinput
echo uinput_release > set_ftrace_filter
echo function > current_tracer
rmmod uinput
modprobe uinput
# check /proc/modules to see if loaded in same addr, otherwise try again
echo nop > current_tracer
[BOOM]
The above loads the uinput module, which creates a table of functions that
can be traced within the module.
We add uinput_release to the filter_hash to trace just that function.
Enable function tracincg, which increments the ref count of the record
associated to uinput_release.
Remove uinput, which frees the records including the one that represents
uinput_release.
Load the uinput module again (and make sure it's at the same address).
This recreates the function records all with a ref count of zero,
including uinput_release.
Disable function tracing, which will decrement the ref count for uinput_release
which is now zero because of the module removal and reload, and we have
a mismatch (below zero ref count).
The solution is to check all currently tracing ftrace callbacks to see if any
are tracing any of the module's functions when a module is loaded (it already does
that with callbacks that trace all functions). If a callback happens to have
a module function being traced, it increments that records ref count and starts
tracing that function.
There may be a strange side effect with this, where tracing module functions
on unload and then reloading a new module may have that new module's functions
being traced. This may be something that confuses the user, but it's not
a big deal. Another approach is to disable all callback hashes on module unload,
but this leaves some ftrace callbacks that may not be registered, but can
still have hashes tracing the module's function where ftrace doesn't know about
it. That situation can cause the same bug. This solution solves that case too.
Another benefit of this solution, is it is possible to trace a module's
function on unload and load.
Link: http://lkml.kernel.org/r/20130705142629.GA325@redhat.com
Reported-by: Jörn Engel <joern@logfs.org>
Reported-by: Dave Jones <davej@redhat.com>
Reported-by: Steve Hodgson <steve@purestorage.com>
Tested-by: Steve Hodgson <steve@purestorage.com>
commit c6c2401d8bbaf9edc189b4c35a8cb2780b8b988e upstream.
Uprobes suffer the same problem that kprobes have. There's a race between
writing to the "enable" file and removing the probe. The probe checks for
it being in use and if it is not, goes about deleting the probe and the
event that represents it. But the problem with that is, after it checks
if it is in use it can be enabled, and the deletion of the event (access
to the probe) will fail, as it is in use. But the uprobe will still be
deleted. This is a problem as the event can reference the uprobe that
was deleted.
The fix is to remove the event first, and check to make sure the event
removal succeeds. Then it is safe to remove the probe.
When the event exists, either ftrace or perf can enable the probe and
prevent the event from being removed.
Link: http://lkml.kernel.org/r/20130704034038.991525256@goodmis.org
Acked-by: Oleg Nesterov <oleg@redhat.com>
commit 40c32592668b727cbfcf7b1c0567f581bd62a5e4 upstream.
When a probe is being removed, it cleans up the event files that correspond
to the probe. But there is a race between writing to one of these files
and deleting the probe. This is especially true for the "enable" file.
CPU 0 CPU 1
fd = open("enable",O_WRONLY);
probes_open()
release_all_trace_probes()
unregister_trace_probe()
if (trace_probe_is_enabled(tp))
return -EBUSY
write(fd, "1", 1)
__ftrace_set_clr_event()
call->class->reg()
(kprobe_register)
enable_trace_probe(tp)
__unregister_trace_probe(tp);
list_del(&tp->list)
unregister_probe_event(tp) <-- fails!
free_trace_probe(tp)
write(fd, "0", 1)
call->class->unreg
(kprobe_register)
disable_trace_probe(tp) <-- BOOM!
A test program was written that used two threads to simulate the
above scenario adding a nanosleep() interval to change the timings
and after several thousand runs, it was able to trigger this bug
and crash:
BUG: unable to handle kernel paging request at 00000005000000f9
IP: [<ffffffff810dee70>] probes_open+0x3b/0xa7
PGD 7808a067 PUD 0
Oops: 0000 [#1] PREEMPT SMP
Dumping ftrace buffer:
Modules linked in: ipt_MASQUERADE sunrpc ip6t_REJECT nf_conntrack_ipv6
CPU: 1 PID: 2070 Comm: test-kprobe-rem Not tainted 3.11.0-rc3-test+ #47
Hardware name: To Be Filled By O.E.M. To Be Filled By O.E.M./To be filled by O.E.M., BIOS SDBLI944.86P 05/08/2007
task: ffff880077756440 ti: ffff880076e52000 task.ti: ffff880076e52000
RIP: 0010:[<ffffffff810dee70>] [<ffffffff810dee70>] probes_open+0x3b/0xa7
RSP: 0018:ffff880076e53c38 EFLAGS: 00010203
RAX: 0000000500000001 RBX: ffff88007844f440 RCX: 0000000000000003
RDX: 0000000000000003 RSI: 0000000000000003 RDI: ffff880076e52000
RBP: ffff880076e53c58 R08: ffff880076e53bd8 R09: 0000000000000000
R10: ffff880077756440 R11: 0000000000000006 R12: ffffffff810dee35
R13: ffff880079250418 R14: 0000000000000000 R15: ffff88007844f450
FS: 00007f87a276f700(0000) GS:ffff88007d480000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 00000005000000f9 CR3: 0000000077262000 CR4: 00000000000007e0
Stack:
ffff880076e53c58 ffffffff81219ea0 ffff88007844f440 ffffffff810dee35
ffff880076e53ca8 ffffffff81130f78 ffff8800772986c0 ffff8800796f93a0
ffffffff81d1b5d8 ffff880076e53e04 0000000000000000 ffff88007844f440
Call Trace:
[<ffffffff81219ea0>] ? security_file_open+0x2c/0x30
[<ffffffff810dee35>] ? unregister_trace_probe+0x4b/0x4b
[<ffffffff81130f78>] do_dentry_open+0x162/0x226
[<ffffffff81131186>] finish_open+0x46/0x54
[<ffffffff8113f30b>] do_last+0x7f6/0x996
[<ffffffff8113cc6f>] ? inode_permission+0x42/0x44
[<ffffffff8113f6dd>] path_openat+0x232/0x496
[<ffffffff8113fc30>] do_filp_open+0x3a/0x8a
[<ffffffff8114ab32>] ? __alloc_fd+0x168/0x17a
[<ffffffff81131f4e>] do_sys_open+0x70/0x102
[<ffffffff8108f06e>] ? trace_hardirqs_on_caller+0x160/0x197
[<ffffffff81131ffe>] SyS_open+0x1e/0x20
[<ffffffff81522742>] system_call_fastpath+0x16/0x1b
Code: e5 41 54 53 48 89 f3 48 83 ec 10 48 23 56 78 48 39 c2 75 6c 31 f6 48 c7
RIP [<ffffffff810dee70>] probes_open+0x3b/0xa7
RSP <ffff880076e53c38>
---[ end trace 35f17d68fc569897 ]---
The unregister_trace_probe() must be done first, and if it fails it must
fail the removal of the kprobe.
Several changes have already been made by Oleg Nesterov and Masami Hiramatsu
to allow moving the unregister_probe_event() before the removal of
the probe and exit the function if it fails. This prevents the tp
structure from being used after it is freed.
Link: http://lkml.kernel.org/r/20130704034038.819592356@goodmis.org
Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
commit 2816c551c796ec14620325b2c9ed75b9979d3125 upstream.
Change trace_remove_event_call(call) to return the error if this
call is active. This is what the callers assume but can't verify
outside of the tracing locks. Both trace_kprobe.c/trace_uprobe.c
need the additional changes, unregister_trace_probe() should abort
if trace_remove_event_call() fails.
The caller is going to free this call/file so we must ensure that
nobody can use them after trace_remove_event_call() succeeds.
debugfs should be fine after the previous changes and event_remove()
does TRACE_REG_UNREGISTER, but still there are 2 reasons why we need
the additional checks:
- There could be a perf_event(s) attached to this tp_event, so the
patch checks ->perf_refcount.
- TRACE_REG_UNREGISTER can be suppressed by FTRACE_EVENT_FL_SOFT_MODE,
so we simply check FTRACE_EVENT_FL_ENABLED protected by event_mutex.
Link: http://lkml.kernel.org/r/20130729175033.GB26284@redhat.com
Reviewed-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
commit bf682c3159c4d298d1126a56793ed3f5e80395f7 upstream.
Change remove_event_file_dir() to clear ->i_private for every
file we are going to remove.
We need to check file->dir != NULL because event_create_dir()
can fail. debugfs_remove_recursive(NULL) is fine but the patch
moves it under the same check anyway for readability.
spin_lock(d_lock) and "d_inode != NULL" check are not needed
afaics, but I do not understand this code enough.
tracing_open_generic_file() and tracing_release_generic_file()
can go away, ftrace_enable_fops and ftrace_event_filter_fops()
use tracing_open_generic() but only to check tracing_disabled.
This fixes all races with event_remove() or instance_delete().
f_op->read/write/whatever can never use the freed file/call,
all event/* files were changed to check and use ->i_private
under event_mutex.
Note: this doesn't not fix other problems, event_remove() can
destroy the active ftrace_event_call, we need more changes but
those changes are completely orthogonal.
Link: http://lkml.kernel.org/r/20130728183527.GB16723@redhat.com
commit f6a84bdc75b5c11621dec58db73fe102cbaf40cc upstream.
Preparation for the next patch. Extract the common code from
remove_event_from_tracers() and __trace_remove_event_dirs()
into the new helper, remove_event_file_dir().
The patch looks more complicated than it actually is, it also
moves remove_subsystem() up to avoid the forward declaration.
Link: http://lkml.kernel.org/r/20130726172547.GA3629@redhat.com
commit c5a44a1200c6eda2202434f25325e8ad19533fca upstream.
trace_format_open() and trace_format_seq_ops are racy, nothing
protects ftrace_event_call from trace_remove_event_call().
Change f_start() to take event_mutex and verify i_private != NULL,
change f_stop() to drop this lock.
This fixes nothing, but now we can change debugfs_remove("format")
callers to nullify ->i_private and fix the the problem.
Note: the usage of event_mutex is sub-optimal but simple, we can
change this later.
Link: http://lkml.kernel.org/r/20130726172543.GA3622@redhat.com
commit e2912b091c26b8ea95e5e00a43a7ac620f6c94a6 upstream.
event_filter_read/write() are racy, ftrace_event_call can be already
freed by trace_remove_event_call() callers.
1. Shift mutex_lock(event_mutex) from print/apply_event_filter to
the callers.
2. Change the callers, event_filter_read() and event_filter_write()
to read i_private under this mutex and abort if it is NULL.
This fixes nothing, but now we can change debugfs_remove("filter")
Link: http://lkml.kernel.org/r/20130726172540.GA3619@redhat.com
commit bc6f6b08dee5645770efb4b76186ded313f23752 upstream.
tracing_open_generic_file() is racy, ftrace_event_file can be
already freed by rmdir or trace_remove_event_call().
Change event_enable_read() and event_disable_read() to read and
verify "file = i_private" under event_mutex.
This fixes nothing, but now we can change debugfs_remove("enable")
Link: http://lkml.kernel.org/r/20130726172536.GA3612@redhat.com
commit 1a11126bcb7c93c289bf3218fa546fd3b0c0df8b upstream.
event_id_read() is racy, ftrace_event_call can be already freed
Change event_create_dir() to pass "data = call->event.type", this
is all event_id_read() needs. ftrace_event_id_fops no longer needs
tracing_open_generic().
We add the new helper, event_file_data(), to read ->i_private, it
will have more users.
Note: currently ACCESS_ONCE() and "id != 0" check are not needed,
but we are going to change event_remove/rmdir to clear ->i_private.
Link: http://lkml.kernel.org/r/20130726172532.GA3605@redhat.com
commit 195a8afc7ac962f8da795549fe38e825f1372b0d upstream.
If a ftrace ops is registered with the SAVE_REGS flag set, and there's
already a ops registered to one of its functions but without the
SAVE_REGS flag, there's a small race window where the SAVE_REGS ops gets
added to the list of callbacks to call for that function before the
callback trampoline gets set to save the regs.
The problem is, the function is not currently saving regs, which opens
a small race window where the ops that is expecting regs to be passed
to it, wont. This can cause a crash if the callback were to reference
the regs, as the SAVE_REGS guarantees that regs will be set.
To fix this, we add a check in the loop case where it checks if the ops
has the SAVE_REGS flag set, and if so, it will ignore it if regs is
not set.
commit 6484c71cbc170634fa131b6d022d86d61686b88b upstream.
tracing_open() and tracing_snapshot_open() are racy, the memory
inode->i_private points to can be already freed.
Convert these last users of "inode->i_private == trace_cpu" to
use "i_private = trace_array" and rely on tracing_get_cpu().
v2: incorporate the fix from Steven, tracing_release() must not
blindly dereference file->private_data unless we know that
the file was opened for reading.
Link: http://lkml.kernel.org/r/20130723152610.GA23737@redhat.com
commit 0bc392ee46d0fd8e6b678457ef71f074f19a03c5 upstream.
tracing_open_generic_tc() is racy, the memory inode->i_private
1. Change its last user, tracing_entries_fops, to use
tracing_*_generic_tr() instead.
2. Change debugfs_create_file("buffer_size_kb", data) callers
to pass "data = tr".
3. Change tracing_entries_read() and tracing_entries_write() to
use tracing_get_cpu().
4. Kill the no longer used tracing_open_generic_tc() and
tracing_release_generic_tc().
Link: http://lkml.kernel.org/r/20130723152606.GA23730@redhat.com
commit 4d3435b8a4c3357695e09c5e7a3bf73a19fca5b0 upstream.
1. Change one of its users, tracing_stats_fops, to use
2. Change trace_create_cpu_file("stats", data) to pass "data = tr".
3. Change tracing_stats_read() to use tracing_get_cpu().
Link: http://lkml.kernel.org/r/20130723152603.GA23727@redhat.com
commit 46ef2be0d1d5ccea0c41bb606143586daadd537c upstream.
tracing_buffers_open() is racy, the memory inode->i_private points
Change debugfs_create_file("trace_pipe_raw", data) caller to pass
"data = tr", tracing_buffers_open() can use tracing_get_cpu().
Change debugfs_create_file("snapshot_raw_fops", data) caller too,
this file uses tracing_buffers_open/release.
Link: http://lkml.kernel.org/r/20130723152600.GA23720@redhat.com
commit 15544209cb0b5312e5220a9337a1fe61d1a1f2d9 upstream.
tracing_open_pipe() is racy, the memory inode->i_private points to
Change debugfs_create_file("trace_pipe", data) callers to to pass
"data = tr", tracing_open_pipe() can use tracing_get_cpu().
Link: http://lkml.kernel.org/r/20130723152557.GA23717@redhat.com
commit 649e9c70da6bfbeb563193a35d3424a5aa7c0d38 upstream.
Every "file_operations" used by tracing_init_debugfs_percpu is buggy.
f_op->open/etc does:
1. struct trace_cpu *tc = inode->i_private;
struct trace_array *tr = tc->tr;
2. trace_array_get(tr) or fail;
3. do_something(tc);
But tc (and tr) can be already freed before trace_array_get() is called.
And it doesn't matter whether this file is per-cpu or it was created by
init_tracer_debugfs(), free_percpu() or kfree() are equally bad.
Note that even 1. is not safe, the freed memory can be unmapped. But even
if it was safe trace_array_get() can wrongly succeed if we also race with
the next new_instance_create() which can re-allocate the same tr, or tc
was overwritten and ->tr points to the valid tr. In this case 3. uses the
freed/reused memory.
Add the new trivial helper, trace_create_cpu_file() which simply calls
trace_create_file() and encodes "cpu" in "struct inode". Another helper,
tracing_get_cpu() will be used to read cpu_nr-or-RING_BUFFER_ALL_CPUS.
The patch abuses ->i_cdev to encode the number, it is never used unless
the file is S_ISCHR(). But we could use something else, say, i_bytes or
even ->d_fsdata. In any case this hack is hidden inside these 2 helpers,
it would be trivial to change them if needed.
This patch only changes tracing_init_debugfs_percpu() to use the new
trace_create_cpu_file(), the next patches will change file_operations.
Note: tracing_get_cpu(inode) is always safe but you can't trust the
result unless trace_array_get() was called, without trace_types_lock
which acts as a barrier it can wrongly return RING_BUFFER_ALL_CPUS.
Link: http://lkml.kernel.org/r/20130723152554.GA23710@redhat.com
commit a232e270dcb55a70ad3241bc6fc160fd9b5c9e6c upstream.
Wait for disabling all running kprobe handlers when a kprobe
event is disabled, since the caller, trace_remove_event_call()
supposes that a removing event is disabled completely by
disabling the event.
With this change, ftrace can ensure that there is no running
event handlers after disabling it.
Link: http://lkml.kernel.org/r/20130709093526.20138.93100.stgit@mhiramat-M0-7522
Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
commit aaf6ac0f0871cb7fc0f28f3a00edf329bc7adc29 upstream.
There's no point calling it when _alloc() failed.
Link: http://lkml.kernel.org/r/1370585268-29169-1-git-send-email-namhyung@kernel.org
Signed-off-by: Namhyung Kim <namhyung@kernel.org>
commit a903f0865a190f8778c73df1a810ea6e25e5d7cf upstream.
Writing to this file always returns -ENODEV:
# echo 1 > cpuset.memory_pressure_enabled
-bash: echo: write error: No such device
Signed-off-by: Li Zefan <lizefan@huawei.com>
commit 40fea92ffb5fa0ef26d10ae0fe5688bc8e61c791 upstream.
pm_qos_update_request_timeout() updates a qos and then schedules
a delayed work item to bring the qos back down to the default
after the timeout. When the work item runs, pm_qos_work_fn() will
call pm_qos_update_request() and deadlock because it tries to
cancel itself via cancel_delayed_work_sync(). Future callers of
that qos will also hang waiting to cancel the work that is
canceling itself. Let's extract the little bit of code that does
the real work of pm_qos_update_request() and call it from the
work function so that we don't deadlock.
Before ed1ac6e (PM: don't use [delayed_]work_pending()) this didn't
happen because the work function wouldn't try to cancel itself.
[backport to 3.10 - gregkh]
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Reviewed-by: Tejun Heo <tj@kernel.org>
continuously-running tasks
commit bf0bd948d1682e3996adc093b43021ed391983e6 upstream.
We typically update a task_group's shares within the dequeue/enqueue
path. However, continuously running tasks sharing a CPU are not
subject to these updates as they are only put/picked. Unfortunately,
when we reverted f269ae046 (in 17bc14b7), we lost the augmenting
periodic update that was supposed to account for this; resulting in a
potential loss of fairness.
To fix this, re-introduce the explicit update in
update_cfs_rq_blocked_load() [called via entity_tick()].
Reported-by: Max Hailperin <max@gustavus.edu>
Reviewed-by: Paul Turner <pjt@google.com>
Link: http://lkml.kernel.org/n/tip-9545m3apw5d93ubyrotrj31y@git.kernel.org
commit dfa9771a7c4784bafd0673bc7abcee3813088b77 upstream.
Fix inadvertent breakage in the clone syscall ABI for Microblaze that
was introduced in commit f3268edbe6fe ("microblaze: switch to generic
fork/vfork/clone").
The Microblaze syscall ABI for clone takes the parent tid address in the
4th argument; the third argument slot is used for the stack size. The
incorrectly-used CLONE_BACKWARDS type assigned parent tid to the 3rd
slot.
This commit restores the original ABI so that existing userspace libc
code will work correctly.
All kernel versions from v3.8-rc1 were affected.
commit 9457158bbc0ee04ecef76862d73eecd8076e9c7b upstream.
Fixed two issues with changing the timestamp clock with trace_clock:
- The global buffer was reset on instance clock changes. Change this to pass
the correct per-instance buffer
- ftrace_now() is used to set buf->time_start in tracing_reset_online_cpus().
This was incorrect because ftrace_now() used the global buffer's clock to
return the current time. Change this to use buffer_ftrace_now() which
returns the current time for the correct per-instance buffer.
Also removed tracing_reset_current() because it is not used anywhere
Link: http://lkml.kernel.org/r/1375493777-17261-2-git-send-email-azl@google.com
Signed-off-by: Alexander Z Lam <azl@google.com>
Cc: Vaibhav Nagarnaik <vnagarnaik@google.com>
Cc: David Sharp <dhsharp@google.com>
Cc: Alexander Z Lam <lambchop468@gmail.com>
commit 10246fa35d4ffdfe472185d4cbf9c2dfd9a9f023 upstream.
If the ring buffer is disabled and the irqsoff tracer records a trace it
will clear out its buffer and lose the data it had previously recorded.
Currently there's a callback when writing to the tracing_of file, but if
tracing is disabled via the function tracer trigger, it will not inform
the irqsoff tracer to stop recording.
By using the "mirror" flag (buffer_disabled) in the trace_array, that keeps
track of the status of the trace_array's buffer, it gives the irqsoff
tracer a fast way to know if it should record a new trace or not.
The flag may be a little behind the real state of the buffer, but it
should not affect the trace too much. It's more important for the irqsoff
tracer to be fast.
commit 711e124379e0f889e40e2f01d7f5d61936d3cd23 upstream.
Releasing the free_buffer file in an instance causes the global buffer
to be stopped when TRACE_ITER_STOP_ON_FREE is enabled. Operate on the
correct buffer.
Link: http://lkml.kernel.org/r/1375493777-17261-1-git-send-email-azl@google.com
commit ed5467da0e369e65b247b99eb6403cb79172bcda upstream.
tracing_read_pipe zeros all fields bellow "seq". The declaration contains
a comment about that, but it doesn't help.
The first field is "snapshot", it's true when current open file is
snapshot. Looks obvious, that it should not be zeroed.
The second field is "started". It was converted from cpumask_t to
cpumask_var_t (v2.6.28-4983-g4462344), in other words it was
converted from cpumask to pointer on cpumask.
Currently the reference on "started" memory is lost after the first read
from tracing_read_pipe and a proper object will never be freed.
The "started" is never dereferenced for trace_pipe, because trace_pipe
can't have the TRACE_FILE_ANNOTATE options.
Link: http://lkml.kernel.org/r/1375463803-3085183-1-git-send-email-avagin@openvz.org
Signed-off-by: Andrew Vagin <avagin@openvz.org>
commit 8742f229b635bf1c1c84a3dfe5e47c814c20b5c8 upstream.
Ensure that user_namespace->parent chain can't grow too much.
Currently we use the hardroded 32 as limit.
Reported-by: Andy Lutomirski <luto@amacapital.net>
commit 6160968cee8b90a5dd95318d716e31d7775c4ef3 upstream.
unshare_userns(new_cred) does *new_cred = prepare_creds() before
create_user_ns() which can fail. However, the caller expects that
it doesn't need to take care of new_cred if unshare_userns() fails.
We could change the single caller, sys_unshare(), but I think it
would be more clean to avoid the side effects on failure, so with
this patch unshare_userns() does put_cred() itself and initializes
*new_cred only if create_user_ns() succeeeds.
Reviewed-by: Andy Lutomirski <luto@amacapital.net>
commit 2865a8fb44cc32420407362cbda80c10fa09c6b2 upstream.
$echo '0' > /sys/bus/workqueue/devices/xxx/numa
$cat /sys/bus/workqueue/devices/xxx/numa
I got 1. It should be 0, the reason is copy_workqueue_attrs() called
in apply_workqueue_attrs() doesn't copy no_numa field.
Fix it by making copy_workqueue_attrs() copy ->no_numa too. This
would also make get_unbound_pool() set a pool's ->no_numa attribute
according to the workqueue attributes used when the pool was created.
While harmelss, as ->no_numa isn't a pool attribute, this is a bit
confusing. Clear it explicitly.
tj: Updated description and comments a bit.
Signed-off-by: Shaohua Li <shli@fusionio.com>
commit 084457f284abf6789d90509ee11dae383842b23b upstream.
cgroup_cfts_commit() uses dget() to keep cgroup alive after cgroup_mutex
is dropped, but dget() won't prevent cgroupfs from being umounted. When
the race happens, vfs will see some dentries with non-zero refcnt while
umount is in process.
Keep running this:
mount -t cgroup -o blkio xxx /cgroup
umount /cgroup
And this:
modprobe cfq-iosched
rmmod cfs-iosched
After a while, the BUG() in shrink_dcache_for_umount_subtree() may
be triggered:
BUG: Dentry xxx{i=0,n=blkio.yyy} still in use (1) [umount of cgroup cgroup]
commit 148519120c6d1f19ad53349683aeae9f228b0b8d upstream.
Revert commit 69a37bea (cpuidle: Quickly notice prediction failure for
repeat mode), because it has been identified as the source of a
significant performance regression in v3.8 and later as explained by
Jeremy Eder:
We believe we've identified a particular commit to the cpuidle code
that seems to be impacting performance of variety of workloads.
The simplest way to reproduce is using netperf TCP_RR test, so
we're using that, on a pair of Sandy Bridge based servers. We also
have data from a large database setup where performance is also
measurably/positively impacted, though that test data isn't easily
share-able.
Included below are test results from 3 test kernels:
kernel reverts
1) vanilla upstream (no reverts)
2) perfteam2 reverts e11538d1f03914eb92af5a1a378375c05ae8520c
3) test reverts 69a37beabf1f0a6705c08e879bdd5d82ff6486c4
In summary, netperf TCP_RR numbers improve by approximately 4%
after reverting 69a37beabf1f0a6705c08e879bdd5d82ff6486c4. When
69a37beabf1f0a6705c08e879bdd5d82ff6486c4 is included, C0 residency
never seems to get above 40%. Taking that patch out gets C0 near
100% quite often, and performance increases.
The below data are histograms representing the %c0 residency @
1-second sample rates (using turbostat), while under netperf test.
- If you look at the first 4 histograms, you can see %c0 residency
almost entirely in the 30,40% bin.
- The last pair, which reverts 69a37beabf1f0a6705c08e879bdd5d82ff6486c4,
shows %c0 in the 80,90,100% bins.
Below each kernel name are netperf TCP_RR trans/s numbers for the
particular kernel that can be disclosed publicly, comparing the 3
test kernels. We ran a 4th test with the vanilla kernel where
we've also set /dev/cpu_dma_latency=0 to show overall impact
boosting single-threaded TCP_RR performance over 11% above
baseline.
3.10-rc2 vanilla RX + c0 lock (/dev/cpu_dma_latency=0):
TCP_RR trans/s 54323.78
3.10-rc2 vanilla RX (no reverts)
TCP_RR trans/s 48192.47
Receiver %c0
0.0000 - 10.0000 [ 1]: *
10.0000 - 20.0000 [ 0]:
20.0000 - 30.0000 [ 0]:
30.0000 - 40.0000 [ 59]:
40.0000 - 50.0000 [ 1]: *
50.0000 - 60.0000 [ 0]:
60.0000 - 70.0000 [ 0]:
70.0000 - 80.0000 [ 0]:
80.0000 - 90.0000 [ 0]:
90.0000 - 100.0000 [ 0]:
Sender %c0
30.0000 - 40.0000 [ 11]: ***********
40.0000 - 50.0000 [ 49]:
3.10-rc2 perfteam2 RX (reverts commit
e11538d1f03914eb92af5a1a378375c05ae8520c)
TCP_RR trans/s 49698.69
Receiver %c0
10.0000 - 20.0000 [ 1]: *
40.0000 - 50.0000 [ 0]:
Sender %c0
30.0000 - 40.0000 [ 2]: **
40.0000 - 50.0000 [ 58]:
3.10-rc2 test RX (reverts 69a37beabf1f0a6705c08e879bdd5d82ff6486c4
and e11538d1f03914eb92af5a1a378375c05ae8520c)
TCP_RR trans/s 47766.95
Receiver %c0
30.0000 - 40.0000 [ 27]: ***************************
40.0000 - 50.0000 [ 2]: **
60.0000 - 70.0000 [ 2]: **
90.0000 - 100.0000 [ 28]: ****************************
Sender:
50.0000 - 60.0000 [ 1]: *
70.0000 - 80.0000 [ 3]: ***
80.0000 - 90.0000 [ 7]: *******
90.0000 - 100.0000 [ 38]: **************************************
These results demonstrate gaining back the tendency of the CPU to
stay in more responsive, performant C-states (and thus yield
measurably better performance), by reverting commit
Requested-by: Jeremy Eder <jeder@redhat.com>
Tested-by: Len Brown <len.brown@intel.com>
commit 09d8091c024ec88d1541d93eb8ddb2bd5cf10c39 upstream.
Commit a82274151af "tracing: Protect ftrace_trace_arrays list in trace_events.c"
added taking the trace_types_lock mutex in trace_events.c as there were
several locations that needed it for protection. Unfortunately, it also
encapsulated a call to tracing_reset_all_online_cpus() which also takes
the trace_types_lock, causing a deadlock.
This happens when a module has tracepoints and has been traced. When the
module is removed, the trace events module notifier will grab the
trace_types_lock, do a bunch of clean ups, and also clears the buffer
by calling tracing_reset_all_online_cpus. This doesn't happen often
which explains why it wasn't caught right away.
Commit a82274151af was marked for stable, which means this must be
sent to stable too.
Link: http://lkml.kernel.org/r/51EEC646.7070306@broadcom.com
Reported-by: Arend van Spril <arend@broadcom.com>
Tested-by: Arend van Spriel <arend@broadcom.com>
Cc: Alexander Z Lam <azl@google.com>
commit e70e78e3c83b536730e31231dd9b979768d8df3c upstream.
tracing_buffers_open() does trace_array_get() and then it wrongly
inrcements tr->ref again under trace_types_lock. This means that
every caller leaks trace_array:
# cd /sys/kernel/debug/tracing/
# mkdir instances/X
# true < instances/X/per_cpu/cpu0/trace_pipe_raw
# rmdir instances/X
rmdir: failed to remove `instances/X': Device or resource busy
Link: http://lkml.kernel.org/r/20130719153644.GA18899@redhat.com
Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
commit f77d09a384676bde6445413949d9d2c508ff3e62 upstream.
Some error paths did not handle ref counting properly, and some trace files need
ref counting.
Link: http://lkml.kernel.org/r/1374171524-11948-1-git-send-email-azl@google.com
commit 609e85a70bcd0eedf4ec60639dbcfb1ab011e054 upstream.
Remove debugfs directories for tracing instances during creation if an error
occurs causing the trace_array for that instance to not be added to
ftrace_trace_arrays. If the directory continues to exist after the error, it
cannot be removed because the respective trace_array is not in
Link: http://lkml.kernel.org/r/1373502874-1706-2-git-send-email-azl@google.com
commit 5ec2481b7b47a4005bb446d176e5d0257400c77d upstream.
smp_call_function_* must not be called from softirq context.
But clock_was_set() which calls on_each_cpu() is called from softirq
context to implement a delayed clock_was_set() for the timer interrupt
handler. Though that almost never gets invoked. A recent change in the
resume code uses the softirq based delayed clock_was_set to support
Xens resume mechanism.
linux-next contains a new warning which warns if smp_call_function_*
is called from softirq context which gets triggered by that Xen
change.
Fix this by moving the delayed clock_was_set() call to a work context.
Reported-and-tested-by: Artem Savkov <artem.savkov@gmail.com>
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Cc: David Vrabel <david.vrabel@citrix.com>
Cc: H. Peter Anvin <hpa@zytor.com>,
Cc: Konrad Wilk <konrad.wilk@oracle.com>
Cc: xen-devel@lists.xen.org
commit e5248a111bf4048a9f3fab1a9c94c4630a10592a upstream.
Prevent automatic system suspend from happening during system
shutdown by making try_to_suspend() check system_state and return
immediately if it is not SYSTEM_RUNNING.
This prevents the following breakage from happening (scenario from
Zhang Yanmin):
Kernel starts shutdown and calls all device driver's shutdown
callback. When a driver's shutdown is called, the last wakelock is
released and suspend-to-ram starts. However, as some driver's shut
down callbacks already shut down devices and disabled runtime pm,
the suspend-to-ram calls driver's suspend callback without noticing
that device is already off and causes crash.
[rjw: Changelog]
Signed-off-by: Liu ShuoX <shuox.liu@intel.com>
commit 8e2e2fa47129532a30cff6c25a47078dc97d9260 upstream.
Commit a695cb58162 "tracing: Prevent deleting instances when they are being read"
tried to fix a race between deleting a trace instance and reading contents
of a trace file. But it wasn't good enough. The following could crash the kernel:
# cd /sys/kernel/debug/tracing/instances
# ( while :; do mkdir foo; rmdir foo; done ) &
# ( while :; do echo 1 > foo/events/sched/sched_switch 2> /dev/null; done ) &
Luckily this can only be done by root user, but it should be fixed regardless.
The problem is that a delete of the file can happen after the write to the event
is opened, but before the enabling happens.
The solution is to make sure the trace_array is available before succeeding in
opening for write, and incerment the ref counter while opened.
Now the instance can be deleted when the events are writing to the buffer,
but the deletion of the instance will disable all events before the instance
is actually deleted.
Reported-by: Alexander Lam <azl@google.com>
