path: root/kernel
2014-01-15sched: Guarantee new group-entities always have weightPaul Turner
commit 0ac9b1c21874d2490331233b3242085f8151e166 upstream. Currently, group entity load-weights are initialized to zero. This admits some races with respect to the first time they are re-weighted in earlty use. ( Let g[x] denote the se for "g" on cpu "x". ) Suppose that we have root->a and that a enters a throttled state, immediately followed by a[0]->t1 (the only task running on cpu[0]) blocking: put_prev_task(group_cfs_rq(a[0]), t1) put_prev_entity(..., t1) check_cfs_rq_runtime(group_cfs_rq(a[0])) throttle_cfs_rq(group_cfs_rq(a[0])) Then, before unthrottling occurs, let a[0]->b[0]->t2 wake for the first time: enqueue_task_fair(rq[0], t2) enqueue_entity(group_cfs_rq(b[0]), t2) enqueue_entity_load_avg(group_cfs_rq(b[0]), t2) account_entity_enqueue(group_cfs_ra(b[0]), t2) update_cfs_shares(group_cfs_rq(b[0])) < skipped because b is part of a throttled hierarchy > enqueue_entity(group_cfs_rq(a[0]), b[0]) ... We now have b[0] enqueued, yet group_cfs_rq(a[0])->load.weight == 0 which violates invariants in several code-paths. Eliminate the possibility of this by initializing group entity weight. Signed-off-by: Paul Turner <pjt@google.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20131016181627.22647.47543.stgit@sword-of-the-dawn.mtv.corp.google.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Cc: Chris J Arges <chris.j.arges@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-15sched: Fix hrtimer_cancel()/rq->lock deadlockBen Segall
commit 927b54fccbf04207ec92f669dce6806848cbec7d upstream. __start_cfs_bandwidth calls hrtimer_cancel while holding rq->lock, waiting for the hrtimer to finish. However, if sched_cfs_period_timer runs for another loop iteration, the hrtimer can attempt to take rq->lock, resulting in deadlock. Fix this by ensuring that cfs_b->timer_active is cleared only if the _latest_ call to do_sched_cfs_period_timer is returning as idle. Then __start_cfs_bandwidth can just call hrtimer_try_to_cancel and wait for that to succeed or timer_active == 1. Signed-off-by: Ben Segall <bsegall@google.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: pjt@google.com Link: http://lkml.kernel.org/r/20131016181622.22647.16643.stgit@sword-of-the-dawn.mtv.corp.google.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Cc: Chris J Arges <chris.j.arges@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-15sched: Fix cfs_bandwidth misuse of hrtimer_expires_remainingBen Segall
commit db06e78cc13d70f10877e0557becc88ab3ad2be8 upstream. hrtimer_expires_remaining does not take internal hrtimer locks and thus must be guarded against concurrent __hrtimer_start_range_ns (but returning HRTIMER_RESTART is safe). Use cfs_b->lock to make it safe. Signed-off-by: Ben Segall <bsegall@google.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: pjt@google.com Link: http://lkml.kernel.org/r/20131016181617.22647.73829.stgit@sword-of-the-dawn.mtv.corp.google.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Cc: Chris J Arges <chris.j.arges@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-15sched: Fix race on toggling cfs_bandwidth_usedBen Segall
commit 1ee14e6c8cddeeb8a490d7b54cd9016e4bb900b4 upstream. When we transition cfs_bandwidth_used to false, any currently throttled groups will incorrectly return false from cfs_rq_throttled. While tg_set_cfs_bandwidth will unthrottle them eventually, currently running code (including at least dequeue_task_fair and distribute_cfs_runtime) will cause errors. Fix this by turning off cfs_bandwidth_used only after unthrottling all cfs_rqs. Tested: toggle bandwidth back and forth on a loaded cgroup. Caused crashes in minutes without the patch, hasn't crashed with it. Signed-off-by: Ben Segall <bsegall@google.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: pjt@google.com Link: http://lkml.kernel.org/r/20131016181611.22647.80365.stgit@sword-of-the-dawn.mtv.corp.google.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Cc: Chris J Arges <chris.j.arges@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09mm: fix TLB flush race between migration, and change_protection_rangeRik van Riel
commit 20841405940e7be0617612d521e206e4b6b325db upstream. There are a few subtle races, between change_protection_range (used by mprotect and change_prot_numa) on one side, and NUMA page migration and compaction on the other side. The basic race is that there is a time window between when the PTE gets made non-present (PROT_NONE or NUMA), and the TLB is flushed. During that time, a CPU may continue writing to the page. This is fine most of the time, however compaction or the NUMA migration code may come in, and migrate the page away. When that happens, the CPU may continue writing, through the cached translation, to what is no longer the current memory location of the process. This only affects x86, which has a somewhat optimistic pte_accessible. All other architectures appear to be safe, and will either always flush, or flush whenever there is a valid mapping, even with no permissions (SPARC). The basic race looks like this: CPU A CPU B CPU C load TLB entry make entry PTE/PMD_NUMA fault on entry read/write old page start migrating page change PTE/PMD to new page read/write old page [*] flush TLB reload TLB from new entry read/write new page lose data [*] the old page may belong to a new user at this point! The obvious fix is to flush remote TLB entries, by making sure that pte_accessible aware of the fact that PROT_NONE and PROT_NUMA memory may still be accessible if there is a TLB flush pending for the mm. This should fix both NUMA migration and compaction. [mgorman@suse.de: fix build] Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: Alex Thorlton <athorlton@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09sched: fix the theoretical signal_wake_up() vs schedule() raceOleg Nesterov
commit e0acd0a68ec7dbf6b7a81a87a867ebd7ac9b76c4 upstream. This is only theoretical, but after try_to_wake_up(p) was changed to check p->state under p->pi_lock the code like __set_current_state(TASK_INTERRUPTIBLE); schedule(); can miss a signal. This is the special case of wait-for-condition, it relies on try_to_wake_up/schedule interaction and thus it does not need mb() between __set_current_state() and if(signal_pending). However, this __set_current_state() can move into the critical section protected by rq->lock, now that try_to_wake_up() takes another lock we need to ensure that it can't be reordered with "if (signal_pending(current))" check inside that section. The patch is actually one-liner, it simply adds smp_wmb() before spin_lock_irq(rq->lock). This is what try_to_wake_up() already does by the same reason. We turn this wmb() into the new helper, smp_mb__before_spinlock(), for better documentation and to allow the architectures to change the default implementation. While at it, kill smp_mb__after_lock(), it has no callers. Perhaps we can also add smp_mb__before/after_spinunlock() for prepare_to_wait(). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09libata, freezer: avoid block device removal while system is frozenTejun Heo
commit 85fbd722ad0f5d64d1ad15888cd1eb2188bfb557 upstream. Freezable kthreads and workqueues are fundamentally problematic in that they effectively introduce a big kernel lock widely used in the kernel and have already been the culprit of several deadlock scenarios. This is the latest occurrence. During resume, libata rescans all the ports and revalidates all pre-existing devices. If it determines that a device has gone missing, the device is removed from the system which involves invalidating block device and flushing bdi while holding driver core layer locks. Unfortunately, this can race with the rest of device resume. Because freezable kthreads and workqueues are thawed after device resume is complete and block device removal depends on freezable workqueues and kthreads (e.g. bdi_wq, jbd2) to make progress, this can lead to deadlock - block device removal can't proceed because kthreads are frozen and kthreads can't be thawed because device resume is blocked behind block device removal. 839a8e8660b6 ("writeback: replace custom worker pool implementation with unbound workqueue") made this particular deadlock scenario more visible but the underlying problem has always been there - the original forker task and jbd2 are freezable too. In fact, this is highly likely just one of many possible deadlock scenarios given that freezer behaves as a big kernel lock and we don't have any debug mechanism around it. I believe the right thing to do is getting rid of freezable kthreads and workqueues. This is something fundamentally broken. For now, implement a funny workaround in libata - just avoid doing block device hot[un]plug while the system is frozen. Kernel engineering at its finest. :( v2: Add EXPORT_SYMBOL_GPL(pm_freezing) for cases where libata is built as a module. v3: Comment updated and polling interval changed to 10ms as suggested by Rafael. v4: Add #ifdef CONFIG_FREEZER around the hack as pm_freezing is not defined when FREEZER is not configured thus breaking build. Reported by kbuild test robot. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Tomaž Šolc <tomaz.solc@tablix.org> Reviewed-by: "Rafael J. Wysocki" <rjw@rjwysocki.net> Link: https://bugzilla.kernel.org/show_bug.cgi?id=62801 Link: http://lkml.kernel.org/r/20131213174932.GA27070@htj.dyndns.org Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Len Brown <len.brown@intel.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09sched/rt: Fix rq's cpupri leak while enqueue/dequeue child RT entitiesKirill Tkhai
commit 757dfcaa41844595964f1220f1d33182dae49976 upstream. This patch touches the RT group scheduling case. Functions inc_rt_prio_smp() and dec_rt_prio_smp() change (global) rq's priority, while rt_rq passed to them may be not the top-level rt_rq. This is wrong, because changing of priority on a child level does not guarantee that the priority is the highest all over the rq. So, this leak makes RT balancing unusable. The short example: the task having the highest priority among all rq's RT tasks (no one other task has the same priority) are waking on a throttle rt_rq. The rq's cpupri is set to the task's priority equivalent, but real rq->rt.highest_prio.curr is less. The patch below fixes the problem. Signed-off-by: Kirill Tkhai <tkhai@yandex.ru> Signed-off-by: Peter Zijlstra <peterz@infradead.org> CC: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/49231385567953@web4m.yandex.ru Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09sched: numa: skip inaccessible VMAsMel Gorman
commit 3c67f474558748b604e247d92b55dfe89654c81d upstream. Inaccessible VMA should not be trapping NUMA hint faults. Skip them. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Alex Thorlton <athorlton@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09ftrace: Initialize the ftrace profiler for each possible cpuMiao Xie
commit c4602c1c818bd6626178d6d3fcc152d9f2f48ac0 upstream. Ftrace currently initializes only the online CPUs. This implementation has two problems: - If we online a CPU after we enable the function profile, and then run the test, we will lose the trace information on that CPU. Steps to reproduce: # echo 0 > /sys/devices/system/cpu/cpu1/online # cd <debugfs>/tracing/ # echo <some function name> >> set_ftrace_filter # echo 1 > function_profile_enabled # echo 1 > /sys/devices/system/cpu/cpu1/online # run test - If we offline a CPU before we enable the function profile, we will not clear the trace information when we enable the function profile. It will trouble the users. Steps to reproduce: # cd <debugfs>/tracing/ # echo <some function name> >> set_ftrace_filter # echo 1 > function_profile_enabled # run test # cat trace_stat/function* # echo 0 > /sys/devices/system/cpu/cpu1/online # echo 0 > function_profile_enabled # echo 1 > function_profile_enabled # cat trace_stat/function* # run test # cat trace_stat/function* So it is better that we initialize the ftrace profiler for each possible cpu every time we enable the function profile instead of just the online ones. Link: http://lkml.kernel.org/r/1387178401-10619-1-git-send-email-miaox@cn.fujitsu.com Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-20sched: Avoid throttle_cfs_rq() racing with period_timer stoppingBen Segall
commit f9f9ffc237dd924f048204e8799da74f9ecf40cf upstream. throttle_cfs_rq() doesn't check to make sure that period_timer is running, and while update_curr/assign_cfs_runtime does, a concurrently running period_timer on another cpu could cancel itself between this cpu's update_curr and throttle_cfs_rq(). If there are no other cfs_rqs running in the tg to restart the timer, this causes the cfs_rq to be stranded forever. Fix this by calling __start_cfs_bandwidth() in throttle if the timer is inactive. (Also add some sched_debug lines for cfs_bandwidth.) Tested: make a run/sleep task in a cgroup, loop switching the cgroup between 1ms/100ms quota and unlimited, checking for timer_active=0 and throttled=1 as a failure. With the throttle_cfs_rq() change commented out this fails, with the full patch it passes. Signed-off-by: Ben Segall <bsegall@google.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: pjt@google.com Link: http://lkml.kernel.org/r/20131016181632.22647.84174.stgit@sword-of-the-dawn.mtv.corp.google.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Cc: Chris J Arges <chris.j.arges@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-20futex: fix handling of read-only-mapped hugepagesLinus Torvalds
commit f12d5bfceb7e1f9051563381ec047f7f13956c3c upstream. The hugepage code had the exact same bug that regular pages had in commit 7485d0d3758e ("futexes: Remove rw parameter from get_futex_key()"). The regular page case was fixed by commit 9ea71503a8ed ("futex: Fix regression with read only mappings"), but the transparent hugepage case (added in a5b338f2b0b1: "thp: update futex compound knowledge") case remained broken. Found by Dave Jones and his trinity tool. Reported-and-tested-by: Dave Jones <davej@fedoraproject.org> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Mel Gorman <mgorman@suse.de> Cc: Darren Hart <dvhart@linux.intel.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-20PCI: Disable Bus Master only on kexec rebootKhalid Aziz
commit 4fc9bbf98fd66f879e628d8537ba7c240be2b58e upstream. Add a flag to tell the PCI subsystem that kernel is shutting down in preparation to kexec a kernel. Add code in PCI subsystem to use this flag to clear Bus Master bit on PCI devices only in case of kexec reboot. This fixes a power-off problem on Acer Aspire V5-573G and likely other machines and avoids any other issues caused by clearing Bus Master bit on PCI devices in normal shutdown path. The problem was introduced by b566a22c2332 ("PCI: disable Bus Master on PCI device shutdown"). This patch is based on discussion at http://marc.info/?l=linux-pci&m=138425645204355&w=2 Link: https://bugzilla.kernel.org/show_bug.cgi?id=63861 Reported-by: Chang Liu <cl91tp@gmail.com> Signed-off-by: Khalid Aziz <khalid.aziz@oracle.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Konstantin Khlebnikov <koct9i@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-11irq: Enable all irqs unconditionally in irq_resumeLaxman Dewangan
commit ac01810c9d2814238f08a227062e66a35a0e1ea2 upstream. When the system enters suspend, it disables all interrupts in suspend_device_irqs(), including the interrupts marked EARLY_RESUME. On the resume side things are different. The EARLY_RESUME interrupts are reenabled in sys_core_ops->resume and the non EARLY_RESUME interrupts are reenabled in the normal system resume path. When suspend_noirq() failed or suspend is aborted for any other reason, we might omit the resume side call to sys_core_ops->resume() and therefor the interrupts marked EARLY_RESUME are not reenabled and stay disabled forever. To solve this, enable all irqs unconditionally in irq_resume() regardless whether interrupts marked EARLY_RESUMEhave been already enabled or not. This might try to reenable already enabled interrupts in the non failure case, but the only affected platform is XEN and it has been confirmed that it does not cause any side effects. [ tglx: Massaged changelog. ] Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Acked-by-and-tested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Acked-by: Heiko Stuebner <heiko@sntech.de> Reviewed-by: Pavel Machek <pavel@ucw.cz> Cc: <ian.campbell@citrix.com> Cc: <rjw@rjwysocki.net> Cc: <len.brown@intel.com> Cc: <gregkh@linuxfoundation.org> Link: http://lkml.kernel.org/r/1385388587-16442-1-git-send-email-ldewangan@nvidia.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-11time: Fix 1ns/tick drift w/ GENERIC_TIME_VSYSCALL_OLDMartin Schwidefsky
commit 4be77398ac9d948773116b6be4a3c91b3d6ea18c upstream. Since commit 1e75fa8be9f (time: Condense timekeeper.xtime into xtime_sec - merged in v3.6), there has been an problem with the error accounting in the timekeeping code, such that when truncating to nanoseconds, we round up to the next nsec, but the balancing adjustment to the ntp_error value was dropped. This causes 1ns per tick drift forward of the clock. In 3.7, this logic was isolated to only GENERIC_TIME_VSYSCALL_OLD architectures (s390, ia64, powerpc). The fix is simply to balance the accounting and to subtract the added nanosecond from ntp_error. This allows the internal long-term clock steering to keep the clock accurate. While this fix removes the regression added in 1e75fa8be9f, the ideal solution is to move away from GENERIC_TIME_VSYSCALL_OLD and use the new VSYSCALL method, which avoids entirely the nanosecond granular rounding, and the resulting short-term clock adjustment oscillation needed to keep long term accurate time. [ jstultz: Many thanks to Martin for his efforts identifying this subtle bug, and providing the fix. ] Originally-from: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Paul Turner <pjt@google.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Richard Cochran <richardcochran@gmail.com> Cc: Prarit Bhargava <prarit@redhat.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1385149491-20307-1-git-send-email-john.stultz@linaro.org Signed-off-by: John Stultz <john.stultz@linaro.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-08ntp: Make periodic RTC update more reliableMiroslav Lichvar
commit a97ad0c4b447a132a322cedc3a5f7fa4cab4b304 upstream. The current code requires that the scheduled update of the RTC happens in the closest tick to the half of the second. This seems to be difficult to achieve reliably. The scheduled work may be missing the target time by a tick or two and be constantly rescheduled every second. Relax the limit to 10 ticks. As a typical RTC drifts in the 11-minute update interval by several milliseconds, this shouldn't affect the overall accuracy of the RTC much. Signed-off-by: Miroslav Lichvar <mlichvar@redhat.com> Signed-off-by: John Stultz <john.stultz@linaro.org> Cc: Josh Boyer <jwboyer@fedoraproject.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-08clockevents: Prefer CPU local devices over global devicesStephen Boyd
commit 70e5975d3a04be5479a28eec4a2fb10f98ad2785 upstream. On an SMP system with only one global clockevent and a dummy clockevent per CPU we run into problems. We want the dummy clockevents to be registered as the per CPU tick devices, but we can only achieve that if we register the dummy clockevents before the global clockevent or if we artificially inflate the rating of the dummy clockevents to be higher than the rating of the global clockevent. Failure to do so leads to boot hangs when the dummy timers are registered on all other CPUs besides the CPU that accepted the global clockevent as its tick device and there is no broadcast timer to poke the dummy devices. If we're registering multiple clockevents and one clockevent is global and the other is local to a particular CPU we should choose to use the local clockevent regardless of the rating of the device. This way, if the clockevent is a dummy it will take the tick device duty as long as there isn't a higher rated tick device and any global clockevent will be bumped out into broadcast mode, fixing the problem described above. Reported-and-tested-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Tested-by: soren.brinkmann@xilinx.com Cc: John Stultz <john.stultz@linaro.org> Cc: Daniel Lezcano <daniel.lezcano@linaro.org> Cc: linux-arm-kernel@lists.infradead.org Cc: John Stultz <john.stultz@linaro.org> Link: http://lkml.kernel.org/r/20130613183950.GA32061@codeaurora.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Kim Phillips <kim.phillips@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-08clockevents: Split out selection logicThomas Gleixner
commit 45cb8e01b2ecef1c2afb18333e95793fa1a90281 upstream. Split out the clockevent device selection logic. Preparatory patch to allow unbinding active clockevent devices. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: John Stultz <john.stultz@linaro.org> Cc: Magnus Damm <magnus.damm@gmail.com> Link: http://lkml.kernel.org/r/20130425143436.431796247@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Kim Phillips <kim.phillips@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-08clockevents: Add module refcountThomas Gleixner
commit ccf33d6880f39a35158fff66db13000ae4943fac upstream. We want to be able to remove clockevent modules as well. Add a refcount so we don't remove a module with an active clock event device. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: John Stultz <john.stultz@linaro.org> Cc: Magnus Damm <magnus.damm@gmail.com> Link: http://lkml.kernel.org/r/20130425143436.307435149@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Kim Phillips <kim.phillips@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-08clockevents: Get rid of the notifier chainThomas Gleixner
commit 7172a286ced0c1f4f239a0fa09db54ed37d3ead2 upstream. 7+ years and still a single user. Kill it. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: John Stultz <john.stultz@linaro.org> Cc: Magnus Damm <magnus.damm@gmail.com> Link: http://lkml.kernel.org/r/20130425143436.098520211@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Kim Phillips <kim.phillips@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-04cgroup: use a dedicated workqueue for cgroup destructionTejun Heo
commit e5fca243abae1445afbfceebda5f08462ef869d3 upstream. Since be44562613851 ("cgroup: remove synchronize_rcu() from cgroup_diput()"), cgroup destruction path makes use of workqueue. css freeing is performed from a work item from that point on and a later commit, ea15f8ccdb430 ("cgroup: split cgroup destruction into two steps"), moves css offlining to workqueue too. As cgroup destruction isn't depended upon for memory reclaim, the destruction work items were put on the system_wq; unfortunately, some controller may block in the destruction path for considerable duration while holding cgroup_mutex. As large part of destruction path is synchronized through cgroup_mutex, when combined with high rate of cgroup removals, this has potential to fill up system_wq's max_active of 256. Also, it turns out that memcg's css destruction path ends up queueing and waiting for work items on system_wq through work_on_cpu(). If such operation happens while system_wq is fully occupied by cgroup destruction work items, work_on_cpu() can't make forward progress because system_wq is full and other destruction work items on system_wq can't make forward progress because the work item waiting for work_on_cpu() is holding cgroup_mutex, leading to deadlock. This can be fixed by queueing destruction work items on a separate workqueue. This patch creates a dedicated workqueue - cgroup_destroy_wq - for this purpose. As these work items shouldn't have inter-dependencies and mostly serialized by cgroup_mutex anyway, giving high concurrency level doesn't buy anything and the workqueue's @max_active is set to 1 so that destruction work items are executed one by one on each CPU. Hugh Dickins: Because cgroup_init() is run before init_workqueues(), cgroup_destroy_wq can't be allocated from cgroup_init(). Do it from a separate core_initcall(). In the future, we probably want to reorder so that workqueue init happens before cgroup_init(). Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Hugh Dickins <hughd@google.com> Reported-by: Shawn Bohrer <shawn.bohrer@gmail.com> Link: http://lkml.kernel.org/r/20131111220626.GA7509@sbohrermbp13-local.rgmadvisors.com Link: http://lkml.kernel.org/g/alpine.LNX.2.00.1310301606080.2333@eggly.anvils Cc: stable@vger.kernel.org # v3.9+ Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-04cpuset: Fix memory allocator deadlockPeter Zijlstra
commit 0fc0287c9ed1ffd3706f8b4d9b314aa102ef1245 upstream. Juri hit the below lockdep report: [ 4.303391] ====================================================== [ 4.303392] [ INFO: SOFTIRQ-safe -> SOFTIRQ-unsafe lock order detected ] [ 4.303394] 3.12.0-dl-peterz+ #144 Not tainted [ 4.303395] ------------------------------------------------------ [ 4.303397] kworker/u4:3/689 [HC0[0]:SC0[0]:HE0:SE1] is trying to acquire: [ 4.303399] (&p->mems_allowed_seq){+.+...}, at: [<ffffffff8114e63c>] new_slab+0x6c/0x290 [ 4.303417] [ 4.303417] and this task is already holding: [ 4.303418] (&(&q->__queue_lock)->rlock){..-...}, at: [<ffffffff812d2dfb>] blk_execute_rq_nowait+0x5b/0x100 [ 4.303431] which would create a new lock dependency: [ 4.303432] (&(&q->__queue_lock)->rlock){..-...} -> (&p->mems_allowed_seq){+.+...} [ 4.303436] [ 4.303898] the dependencies between the lock to be acquired and SOFTIRQ-irq-unsafe lock: [ 4.303918] -> (&p->mems_allowed_seq){+.+...} ops: 2762 { [ 4.303922] HARDIRQ-ON-W at: [ 4.303923] [<ffffffff8108ab9a>] __lock_acquire+0x65a/0x1ff0 [ 4.303926] [<ffffffff8108cbe3>] lock_acquire+0x93/0x140 [ 4.303929] [<ffffffff81063dd6>] kthreadd+0x86/0x180 [ 4.303931] [<ffffffff816ded6c>] ret_from_fork+0x7c/0xb0 [ 4.303933] SOFTIRQ-ON-W at: [ 4.303933] [<ffffffff8108abcc>] __lock_acquire+0x68c/0x1ff0 [ 4.303935] [<ffffffff8108cbe3>] lock_acquire+0x93/0x140 [ 4.303940] [<ffffffff81063dd6>] kthreadd+0x86/0x180 [ 4.303955] [<ffffffff816ded6c>] ret_from_fork+0x7c/0xb0 [ 4.303959] INITIAL USE at: [ 4.303960] [<ffffffff8108a884>] __lock_acquire+0x344/0x1ff0 [ 4.303963] [<ffffffff8108cbe3>] lock_acquire+0x93/0x140 [ 4.303966] [<ffffffff81063dd6>] kthreadd+0x86/0x180 [ 4.303969] [<ffffffff816ded6c>] ret_from_fork+0x7c/0xb0 [ 4.303972] } Which reports that we take mems_allowed_seq with interrupts enabled. A little digging found that this can only be from cpuset_change_task_nodemask(). This is an actual deadlock because an interrupt doing an allocation will hit get_mems_allowed()->...->__read_seqcount_begin(), which will spin forever waiting for the write side to complete. Cc: John Stultz <john.stultz@linaro.org> Cc: Mel Gorman <mgorman@suse.de> Reported-by: Juri Lelli <juri.lelli@gmail.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Tested-by: Juri Lelli <juri.lelli@gmail.com> Acked-by: Li Zefan <lizefan@huawei.com> Acked-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-04workqueue: fix ordered workqueues in NUMA setupsTejun Heo
commit 8a2b75384444488fc4f2cbb9f0921b6a0794838f upstream. An ordered workqueue implements execution ordering by using single pool_workqueue with max_active == 1. On a given pool_workqueue, work items are processed in FIFO order and limiting max_active to 1 enforces the queued work items to be processed one by one. Unfortunately, 4c16bd327c ("workqueue: implement NUMA affinity for unbound workqueues") accidentally broke this guarantee by applying NUMA affinity to ordered workqueues too. On NUMA setups, an ordered workqueue would end up with separate pool_workqueues for different nodes. Each pool_workqueue still limits max_active to 1 but multiple work items may be executed concurrently and out of order depending on which node they are queued to. Fix it by using dedicated ordered_wq_attrs[] when creating ordered workqueues. The new attrs match the unbound ones except that no_numa is always set thus forcing all NUMA nodes to share the default pool_workqueue. While at it, add sanity check in workqueue creation path which verifies that an ordered workqueues has only the default pool_workqueue. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Libin <huawei.libin@huawei.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-04ftrace: Fix function graph with loading of modulesSteven Rostedt (Red Hat)
commit 8a56d7761d2d041ae5e8215d20b4167d8aa93f51 upstream. Commit 8c4f3c3fa9681 "ftrace: Check module functions being traced on reload" fixed module loading and unloading with respect to function tracing, but it missed the function graph tracer. If you perform the following # cd /sys/kernel/debug/tracing # echo function_graph > current_tracer # modprobe nfsd # echo nop > current_tracer You'll get the following oops message: ------------[ cut here ]------------ WARNING: CPU: 2 PID: 2910 at /linux.git/kernel/trace/ftrace.c:1640 __ftrace_hash_rec_update.part.35+0x168/0x1b9() Modules linked in: nfsd exportfs nfs_acl lockd ipt_MASQUERADE sunrpc ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6 ip6table_filter ip6_tables uinput snd_hda_codec_idt CPU: 2 PID: 2910 Comm: bash Not tainted 3.13.0-rc1-test #7 Hardware name: To Be Filled By O.E.M. To Be Filled By O.E.M./To be filled by O.E.M., BIOS SDBLI944.86P 05/08/2007 0000000000000668 ffff8800787efcf8 ffffffff814fe193 ffff88007d500000 0000000000000000 ffff8800787efd38 ffffffff8103b80a 0000000000000668 ffffffff810b2b9a ffffffff81a48370 0000000000000001 ffff880037aea000 Call Trace: [<ffffffff814fe193>] dump_stack+0x4f/0x7c [<ffffffff8103b80a>] warn_slowpath_common+0x81/0x9b [<ffffffff810b2b9a>] ? __ftrace_hash_rec_update.part.35+0x168/0x1b9 [<ffffffff8103b83e>] warn_slowpath_null+0x1a/0x1c [<ffffffff810b2b9a>] __ftrace_hash_rec_update.part.35+0x168/0x1b9 [<ffffffff81502f89>] ? __mutex_lock_slowpath+0x364/0x364 [<ffffffff810b2cc2>] ftrace_shutdown+0xd7/0x12b [<ffffffff810b47f0>] unregister_ftrace_graph+0x49/0x78 [<ffffffff810c4b30>] graph_trace_reset+0xe/0x10 [<ffffffff810bf393>] tracing_set_tracer+0xa7/0x26a [<ffffffff810bf5e1>] tracing_set_trace_write+0x8b/0xbd [<ffffffff810c501c>] ? ftrace_return_to_handler+0xb2/0xde [<ffffffff811240a8>] ? __sb_end_write+0x5e/0x5e [<ffffffff81122aed>] vfs_write+0xab/0xf6 [<ffffffff8150a185>] ftrace_graph_caller+0x85/0x85 [<ffffffff81122dbd>] SyS_write+0x59/0x82 [<ffffffff8150a185>] ftrace_graph_caller+0x85/0x85 [<ffffffff8150a2d2>] system_call_fastpath+0x16/0x1b ---[ end trace 940358030751eafb ]--- The above mentioned commit didn't go far enough. Well, it covered the function tracer by adding checks in __register_ftrace_function(). The problem is that the function graph tracer circumvents that (for a slight efficiency gain when function graph trace is running with a function tracer. The gain was not worth this). The problem came with ftrace_startup() which should always be called after __register_ftrace_function(), if you want this bug to be completely fixed. Anyway, this solution moves __register_ftrace_function() inside of ftrace_startup() and removes the need to call them both. Reported-by: Dave Wysochanski <dwysocha@redhat.com> Fixes: ed926f9b35cd ("ftrace: Use counters to enable functions to trace") Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-04audit: log the audit_names record typeJeff Layton
commit d3aea84a4ace5ff9ce7fb7714cee07bebef681c2 upstream. ...to make it clear what the intent behind each record's operation was. In many cases you can infer this, based on the context of the syscall and the result. In other cases it's not so obvious. For instance, in the case where you have a file being renamed over another, you'll have two different records with the same filename but different inode info. By logging this information we can clearly tell which one was created and which was deleted. This fixes what was broken in commit bfcec708. Commit 79f6530c should also be backported to stable v3.7+. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-04audit: fix mq_open and mq_unlink to add the MQ root as a hidden parent ↵Jeff Layton
audit_names record commit 79f6530cb59e2a0af6953742a33cc29e98ca631c upstream. The old audit PATH records for mq_open looked like this: type=PATH msg=audit(1366282323.982:869): item=1 name=(null) inode=6777 dev=00:0c mode=041777 ouid=0 ogid=0 rdev=00:00 obj=system_u:object_r:tmpfs_t:s15:c0.c1023 type=PATH msg=audit(1366282323.982:869): item=0 name="test_mq" inode=26732 dev=00:0c mode=0100700 ouid=0 ogid=0 rdev=00:00 obj=staff_u:object_r:user_tmpfs_t:s15:c0.c1023 ...with the audit related changes that went into 3.7, they now look like this: type=PATH msg=audit(1366282236.776:3606): item=2 name=(null) inode=66655 dev=00:0c mode=0100700 ouid=0 ogid=0 rdev=00:00 obj=staff_u:object_r:user_tmpfs_t:s15:c0.c1023 type=PATH msg=audit(1366282236.776:3606): item=1 name=(null) inode=6926 dev=00:0c mode=041777 ouid=0 ogid=0 rdev=00:00 obj=system_u:object_r:tmpfs_t:s15:c0.c1023 type=PATH msg=audit(1366282236.776:3606): item=0 name="test_mq" Both of these look wrong to me. As Steve Grubb pointed out: "What we need is 1 PATH record that identifies the MQ. The other PATH records probably should not be there." Fix it to record the mq root as a parent, and flag it such that it should be hidden from view when the names are logged, since the root of the mq filesystem isn't terribly interesting. With this change, we get a single PATH record that looks more like this: type=PATH msg=audit(1368021604.836:484): item=0 name="test_mq" inode=16914 dev=00:0c mode=0100644 ouid=0 ogid=0 rdev=00:00 obj=unconfined_u:object_r:user_tmpfs_t:s0 In order to do this, a new audit_inode_parent_hidden() function is added. If we do it this way, then we avoid having the existing callers of audit_inode needing to do any sort of flag conversion if auditing is inactive. Signed-off-by: Jeff Layton <jlayton@redhat.com> Reported-by: Jiri Jaburek <jjaburek@redhat.com> Cc: Steve Grubb <sgrubb@redhat.com> Cc: Eric Paris <eparis@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-04audit: fix info leak in AUDIT_GET requestsMathias Krause
commit 64fbff9ae0a0a843365d922e0057fc785f23f0e3 upstream. We leak 4 bytes of kernel stack in response to an AUDIT_GET request as we miss to initialize the mask member of status_set. Fix that. Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Eric Paris <eparis@redhat.com> Signed-off-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-04audit: use nlmsg_len() to get message payload lengthMathias Krause
commit 4d8fe7376a12bf4524783dd95cbc00f1fece6232 upstream. Using the nlmsg_len member of the netlink header to test if the message is valid is wrong as it includes the size of the netlink header itself. Thereby allowing to send short netlink messages that pass those checks. Use nlmsg_len() instead to test for the right message length. The result of nlmsg_len() is guaranteed to be non-negative as the netlink message already passed the checks of nlmsg_ok(). Also switch to min_t() to please checkpatch.pl. Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Eric Paris <eparis@redhat.com> Signed-off-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-04audit: printk USER_AVC messages when audit isn't enabledTyler Hicks
commit 0868a5e150bc4c47e7a003367cd755811eb41e0b upstream. When the audit=1 kernel parameter is absent and auditd is not running, AUDIT_USER_AVC messages are being silently discarded. AUDIT_USER_AVC messages should be sent to userspace using printk(), as mentioned in the commit message of 4a4cd633 ("AUDIT: Optimise the audit-disabled case for discarding user messages"). When audit_enabled is 0, audit_receive_msg() discards all user messages except for AUDIT_USER_AVC messages. However, audit_log_common_recv_msg() refuses to allocate an audit_buffer if audit_enabled is 0. The fix is to special case AUDIT_USER_AVC messages in both functions. It looks like commit 50397bd1 ("[AUDIT] clean up audit_receive_msg()") introduced this bug. Signed-off-by: Tyler Hicks <tyhicks@canonical.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Eric Paris <eparis@redhat.com> Cc: linux-audit@redhat.com Acked-by: Kees Cook <keescook@chromium.org> Signed-off-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-04PM / hibernate: Avoid overflow in hibernate_preallocate_memory()Aaron Lu
commit fd432b9f8c7c88428a4635b9f5a9c6e174df6e36 upstream. When system has a lot of highmem (e.g. 16GiB using a 32 bits kernel), the code to calculate how much memory we need to preallocate in normal zone may cause overflow. As Leon has analysed: It looks that during computing 'alloc' variable there is overflow: alloc = (3943404 - 1970542) - 1978280 = -5418 (signed) And this function goes to err_out. Fix this by avoiding that overflow. References: https://bugzilla.kernel.org/show_bug.cgi?id=60817 Reported-and-tested-by: Leon Drugi <eyak@wp.pl> Signed-off-by: Aaron Lu <aaron.lu@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-04alarmtimer: return EINVAL instead of ENOTSUPP if rtcdev doesn't existKOSAKI Motohiro
commit 98d6f4dd84a134d942827584a3c5f67ffd8ec35f upstream. Fedora Ruby maintainer reported latest Ruby doesn't work on Fedora Rawhide on ARM. (http://bugs.ruby-lang.org/issues/9008) Because of, commit 1c6b39ad3f (alarmtimers: Return -ENOTSUPP if no RTC device is present) intruduced to return ENOTSUPP when clock_get{time,res} can't find a RTC device. However this is incorrect. First, ENOTSUPP isn't exported to userland (ENOTSUP or EOPNOTSUP are the closest userland equivlents). Second, Posix and Linux man pages agree that clock_gettime and clock_getres should return EINVAL if clk_id argument is invalid. While the arugment that the clockid is valid, but just not supported on this hardware could be made, this is just a technicality that doesn't help userspace applicaitons, and only complicates error handling. Thus, this patch changes the code to use EINVAL. Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Frederic Weisbecker <fweisbec@gmail.com> Reported-by: Vit Ondruch <v.ondruch@tiscali.cz> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> [jstultz: Tweaks to commit message to include full rational] Signed-off-by: John Stultz <john.stultz@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-29exec/ptrace: fix get_dumpable() incorrect testsKees Cook
commit d049f74f2dbe71354d43d393ac3a188947811348 upstream. The get_dumpable() return value is not boolean. Most users of the function actually want to be testing for non-SUID_DUMP_USER(1) rather than SUID_DUMP_DISABLE(0). The SUID_DUMP_ROOT(2) is also considered a protected state. Almost all places did this correctly, excepting the two places fixed in this patch. Wrong logic: if (dumpable == SUID_DUMP_DISABLE) { /* be protective */ } or if (dumpable == 0) { /* be protective */ } or if (!dumpable) { /* be protective */ } Correct logic: if (dumpable != SUID_DUMP_USER) { /* be protective */ } or if (dumpable != 1) { /* be protective */ } Without this patch, if the system had set the sysctl fs/suid_dumpable=2, a user was able to ptrace attach to processes that had dropped privileges to that user. (This may have been partially mitigated if Yama was enabled.) The macros have been moved into the file that declares get/set_dumpable(), which means things like the ia64 code can see them too. CVE-2013-2929 Reported-by: Vasily Kulikov <segoon@openwall.com> Signed-off-by: Kees Cook <keescook@chromium.org> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-29perf/ftrace: Fix paranoid level for enabling function tracerSteven Rostedt
commit 12ae030d54ef250706da5642fc7697cc60ad0df7 upstream. The current default perf paranoid level is "1" which has "perf_paranoid_kernel()" return false, and giving any operations that use it, access to normal users. Unfortunately, this includes function tracing and normal users should not be allowed to enable function tracing by default. The proper level is defined at "-1" (full perf access), which "perf_paranoid_tracepoint_raw()" will only give access to. Use that check instead for enabling function tracing. Reported-by: Dave Jones <davej@redhat.com> Reported-by: Vince Weaver <vincent.weaver@maine.edu> Tested-by: Vince Weaver <vincent.weaver@maine.edu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> CVE: CVE-2013-2930 Fixes: ced39002f5ea ("ftrace, perf: Add support to use function tracepoint in perf") Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-29sched, idle: Fix the idle polling state logicPeter Zijlstra
commit ea8117478918a4734586d35ff530721b682425be upstream. Mike reported that commit 7d1a9417 ("x86: Use generic idle loop") regressed several workloads and caused excessive reschedule interrupts. The patch in question failed to notice that the x86 code had an inverted sense of the polling state versus the new generic code (x86: default polling, generic: default !polling). Fix the two prominent x86 mwait based idle drivers and introduce a few new generic polling helpers (fixing the wrong smp_mb__after_clear_bit usage). Also switch the idle routines to using tif_need_resched() which is an immediate TIF_NEED_RESCHED test as opposed to need_resched which will end up being slightly different. Reported-by: Mike Galbraith <bitbucket@online.de> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: lenb@kernel.org Cc: tglx@linutronix.de Link: http://lkml.kernel.org/n/tip-nc03imb0etuefmzybzj7sprf@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-20perf: Fix perf ring buffer memory orderingPeter Zijlstra
commit bf378d341e4873ed928dc3c636252e6895a21f50 upstream. The PPC64 people noticed a missing memory barrier and crufty old comments in the perf ring buffer code. So update all the comments and add the missing barrier. When the architecture implements local_t using atomic_long_t there will be double barriers issued; but short of introducing more conditional barrier primitives this is the best we can do. Reported-by: Victor Kaplansky <victork@il.ibm.com> Tested-by: Victor Kaplansky <victork@il.ibm.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: michael@ellerman.id.au Cc: Paul McKenney <paulmck@linux.vnet.ibm.com> Cc: Michael Neuling <mikey@neuling.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: anton@samba.org Cc: benh@kernel.crashing.org Link: http://lkml.kernel.org/r/20131025173749.GG19466@laptop.lan Signed-off-by: Ingo Molnar <mingo@kernel.org> Cc: Michael Neuling <mikey@neuling.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-20tracing: Fix potential out-of-bounds in trace_get_user()Steven Rostedt
commit 057db8488b53d5e4faa0cedb2f39d4ae75dfbdbb upstream. Andrey reported the following report: ERROR: AddressSanitizer: heap-buffer-overflow on address ffff8800359c99f3 ffff8800359c99f3 is located 0 bytes to the right of 243-byte region [ffff8800359c9900, ffff8800359c99f3) Accessed by thread T13003: #0 ffffffff810dd2da (asan_report_error+0x32a/0x440) #1 ffffffff810dc6b0 (asan_check_region+0x30/0x40) #2 ffffffff810dd4d3 (__tsan_write1+0x13/0x20) #3 ffffffff811cd19e (ftrace_regex_release+0x1be/0x260) #4 ffffffff812a1065 (__fput+0x155/0x360) #5 ffffffff812a12de (____fput+0x1e/0x30) #6 ffffffff8111708d (task_work_run+0x10d/0x140) #7 ffffffff810ea043 (do_exit+0x433/0x11f0) #8 ffffffff810eaee4 (do_group_exit+0x84/0x130) #9 ffffffff810eafb1 (SyS_exit_group+0x21/0x30) #10 ffffffff81928782 (system_call_fastpath+0x16/0x1b) Allocated by thread T5167: #0 ffffffff810dc778 (asan_slab_alloc+0x48/0xc0) #1 ffffffff8128337c (__kmalloc+0xbc/0x500) #2 ffffffff811d9d54 (trace_parser_get_init+0x34/0x90) #3 ffffffff811cd7b3 (ftrace_regex_open+0x83/0x2e0) #4 ffffffff811cda7d (ftrace_filter_open+0x2d/0x40) #5 ffffffff8129b4ff (do_dentry_open+0x32f/0x430) #6 ffffffff8129b668 (finish_open+0x68/0xa0) #7 ffffffff812b66ac (do_last+0xb8c/0x1710) #8 ffffffff812b7350 (path_openat+0x120/0xb50) #9 ffffffff812b8884 (do_filp_open+0x54/0xb0) #10 ffffffff8129d36c (do_sys_open+0x1ac/0x2c0) #11 ffffffff8129d4b7 (SyS_open+0x37/0x50) #12 ffffffff81928782 (system_call_fastpath+0x16/0x1b) Shadow bytes around the buggy address: ffff8800359c9700: fd fd fd fd fd fd fd fd fd fd fd fd fd fd fd fd ffff8800359c9780: fd fd fd fd fd fd fd fd fa fa fa fa fa fa fa fa ffff8800359c9800: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa ffff8800359c9880: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa ffff8800359c9900: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 =>ffff8800359c9980: 00 00 00 00 00 00 00 00 00 00 00 00 00 00[03]fb ffff8800359c9a00: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa ffff8800359c9a80: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa ffff8800359c9b00: fa fa fa fa fa fa fa fa 00 00 00 00 00 00 00 00 ffff8800359c9b80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ffff8800359c9c00: 00 00 00 00 00 00 00 00 fa fa fa fa fa fa fa fa Shadow byte legend (one shadow byte represents 8 application bytes): Addressable: 00 Partially addressable: 01 02 03 04 05 06 07 Heap redzone: fa Heap kmalloc redzone: fb Freed heap region: fd Shadow gap: fe The out-of-bounds access happens on 'parser->buffer[parser->idx] = 0;' Although the crash happened in ftrace_regex_open() the real bug occurred in trace_get_user() where there's an incrementation to parser->idx without a check against the size. The way it is triggered is if userspace sends in 128 characters (EVENT_BUF_SIZE + 1), the loop that reads the last character stores it and then breaks out because there is no more characters. Then the last character is read to determine what to do next, and the index is incremented without checking size. Then the caller of trace_get_user() usually nulls out the last character with a zero, but since the index is equal to the size, it writes a nul character after the allocated space, which can corrupt memory. Luckily, only root user has write access to this file. Link: http://lkml.kernel.org/r/20131009222323.04fd1a0d@gandalf.local.home Reported-by: Andrey Konovalov <andreyknvl@google.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-13clockevents: Sanitize ticks to nsec conversionThomas Gleixner
commit 97b9410643475d6557d2517c2aff9fd2221141a9 upstream. Marc Kleine-Budde pointed out, that commit 77cc982 "clocksource: use clockevents_config_and_register() where possible" caused a regression for some of the converted subarchs. The reason is, that the clockevents core code converts the minimal hardware tick delta to a nanosecond value for core internal usage. This conversion is affected by integer math rounding loss, so the backwards conversion to hardware ticks will likely result in a value which is less than the configured hardware limitation. The affected subarchs used their own workaround (SIGH!) which got lost in the conversion. The solution for the issue at hand is simple: adding evt->mult - 1 to the shifted value before the integer divison in the core conversion function takes care of it. But this only works for the case where for the scaled math mult/shift pair "mult <= 1 << shift" is true. For the case where "mult > 1 << shift" we can apply the rounding add only for the minimum delta value to make sure that the backward conversion is not less than the given hardware limit. For the upper bound we need to omit the rounding add, because the backwards conversion is always larger than the original latch value. That would violate the upper bound of the hardware device. Though looking closer at the details of that function reveals another bogosity: The upper bounds check is broken as well. Checking for a resulting "clc" value greater than KTIME_MAX after the conversion is pointless. The conversion does: u64 clc = (latch << evt->shift) / evt->mult; So there is no sanity check for (latch << evt->shift) exceeding the 64bit boundary. The latch argument is "unsigned long", so on a 64bit arch the handed in argument could easily lead to an unnoticed shift overflow. With the above rounding fix applied the calculation before the divison is: u64 clc = (latch << evt->shift) + evt->mult - 1; So we need to make sure, that neither the shift nor the rounding add is overflowing the u64 boundary. [ukl: move assignment to rnd after eventually changing mult, fix build issue and correct comment with the right math] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Russell King - ARM Linux <linux@arm.linux.org.uk> Cc: Marc Kleine-Budde <mkl@pengutronix.de> Cc: nicolas.ferre@atmel.com Cc: Marc Pignat <marc.pignat@hevs.ch> Cc: john.stultz@linaro.org Cc: kernel@pengutronix.de Cc: Ronald Wahl <ronald.wahl@raritan.com> Cc: LAK <linux-arm-kernel@lists.infradead.org> Cc: Ludovic Desroches <ludovic.desroches@atmel.com> Link: http://lkml.kernel.org/r/1380052223-24139-1-git-send-email-u.kleine-koenig@pengutronix.de Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-13cgroup: fix to break the while loop in cgroup_attach_task() correctlyAnjana V Kumar
commit ea84753c98a7ac6b74e530b64c444a912b3835ca upstream. Both Anjana and Eunki reported a stall in the while_each_thread loop in cgroup_attach_task(). It's because, when we attach a single thread to a cgroup, if the cgroup is exiting or is already in that cgroup, we won't break the loop. If the task is already in the cgroup, the bug can lead to another thread being attached to the cgroup unexpectedly: # echo 5207 > tasks # cat tasks 5207 # echo 5207 > tasks # cat tasks 5207 5215 What's worse, if the task to be attached isn't the leader of the thread group, we might never exit the loop, hence cpu stall. Thanks for Oleg's analysis. This bug was introduced by commit 081aa458c38ba576bdd4265fc807fa95b48b9e79 ("cgroup: consolidate cgroup_attach_task() and cgroup_attach_proc()") [ lizf: - fixed the first continue, pointed out by Oleg, - rewrote changelog. ] Reported-by: Eunki Kim <eunki_kim@samsung.com> Reported-by: Anjana V Kumar <anjanavk12@gmail.com> Signed-off-by: Anjana V Kumar <anjanavk12@gmail.com> Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13irq: Force hardirq exit's softirq processing on its own stackFrederic Weisbecker
commit ded797547548a5b8e7b92383a41e4c0e6b0ecb7f upstream. The commit facd8b80c67a3cf64a467c4a2ac5fb31f2e6745b ("irq: Sanitize invoke_softirq") converted irq exit calls of do_softirq() to __do_softirq() on all architectures, assuming it was only used there for its irq disablement properties. But as a side effect, the softirqs processed in the end of the hardirq are always called on the inline current stack that is used by irq_exit() instead of the softirq stack provided by the archs that override do_softirq(). The result is mostly safe if the architecture runs irq_exit() on a separate irq stack because then softirqs are processed on that same stack that is near empty at this stage (assuming hardirq aren't nesting). Otherwise irq_exit() runs in the task stack and so does the softirq too. The interrupted call stack can be randomly deep already and the softirq can dig through it even further. To add insult to the injury, this softirq can be interrupted by a new hardirq, maximizing the chances for a stack overrun as reported in powerpc for example: do_IRQ: stack overflow: 1920 CPU: 0 PID: 1602 Comm: qemu-system-ppc Not tainted 3.10.4-300.1.fc19.ppc64p7 #1 Call Trace: [c0000000050a8740] .show_stack+0x130/0x200 (unreliable) [c0000000050a8810] .dump_stack+0x28/0x3c [c0000000050a8880] .do_IRQ+0x2b8/0x2c0 [c0000000050a8930] hardware_interrupt_common+0x154/0x180 --- Exception: 501 at .cp_start_xmit+0x3a4/0x820 [8139cp] LR = .cp_start_xmit+0x390/0x820 [8139cp] [c0000000050a8d40] .dev_hard_start_xmit+0x394/0x640 [c0000000050a8e00] .sch_direct_xmit+0x110/0x260 [c0000000050a8ea0] .dev_queue_xmit+0x260/0x630 [c0000000050a8f40] .br_dev_queue_push_xmit+0xc4/0x130 [bridge] [c0000000050a8fc0] .br_dev_xmit+0x198/0x270 [bridge] [c0000000050a9070] .dev_hard_start_xmit+0x394/0x640 [c0000000050a9130] .dev_queue_xmit+0x428/0x630 [c0000000050a91d0] .ip_finish_output+0x2a4/0x550 [c0000000050a9290] .ip_local_out+0x50/0x70 [c0000000050a9310] .ip_queue_xmit+0x148/0x420 [c0000000050a93b0] .tcp_transmit_skb+0x4e4/0xaf0 [c0000000050a94a0] .__tcp_ack_snd_check+0x7c/0xf0 [c0000000050a9520] .tcp_rcv_established+0x1e8/0x930 [c0000000050a95f0] .tcp_v4_do_rcv+0x21c/0x570 [c0000000050a96c0] .tcp_v4_rcv+0x734/0x930 [c0000000050a97a0] .ip_local_deliver_finish+0x184/0x360 [c0000000050a9840] .ip_rcv_finish+0x148/0x400 [c0000000050a98d0] .__netif_receive_skb_core+0x4f8/0xb00 [c0000000050a99d0] .netif_receive_skb+0x44/0x110 [c0000000050a9a70] .br_handle_frame_finish+0x2bc/0x3f0 [bridge] [c0000000050a9b20] .br_nf_pre_routing_finish+0x2ac/0x420 [bridge] [c0000000050a9bd0] .br_nf_pre_routing+0x4dc/0x7d0 [bridge] [c0000000050a9c70] .nf_iterate+0x114/0x130 [c0000000050a9d30] .nf_hook_slow+0xb4/0x1e0 [c0000000050a9e00] .br_handle_frame+0x290/0x330 [bridge] [c0000000050a9ea0] .__netif_receive_skb_core+0x34c/0xb00 [c0000000050a9fa0] .netif_receive_skb+0x44/0x110 [c0000000050aa040] .napi_gro_receive+0xe8/0x120 [c0000000050aa0c0] .cp_rx_poll+0x31c/0x590 [8139cp] [c0000000050aa1d0] .net_rx_action+0x1dc/0x310 [c0000000050aa2b0] .__do_softirq+0x158/0x330 [c0000000050aa3b0] .irq_exit+0xc8/0x110 [c0000000050aa430] .do_IRQ+0xdc/0x2c0 [c0000000050aa4e0] hardware_interrupt_common+0x154/0x180 --- Exception: 501 at .bad_range+0x1c/0x110 LR = .get_page_from_freelist+0x908/0xbb0 [c0000000050aa7d0] .list_del+0x18/0x50 (unreliable) [c0000000050aa850] .get_page_from_freelist+0x908/0xbb0 [c0000000050aa9e0] .__alloc_pages_nodemask+0x21c/0xae0 [c0000000050aaba0] .alloc_pages_vma+0xd0/0x210 [c0000000050aac60] .handle_pte_fault+0x814/0xb70 [c0000000050aad50] .__get_user_pages+0x1a4/0x640 [c0000000050aae60] .get_user_pages_fast+0xec/0x160 [c0000000050aaf10] .__gfn_to_pfn_memslot+0x3b0/0x430 [kvm] [c0000000050aafd0] .kvmppc_gfn_to_pfn+0x64/0x130 [kvm] [c0000000050ab070] .kvmppc_mmu_map_page+0x94/0x530 [kvm] [c0000000050ab190] .kvmppc_handle_pagefault+0x174/0x610 [kvm] [c0000000050ab270] .kvmppc_handle_exit_pr+0x464/0x9b0 [kvm] [c0000000050ab320] kvm_start_lightweight+0x1ec/0x1fc [kvm] [c0000000050ab4f0] .kvmppc_vcpu_run_pr+0x168/0x3b0 [kvm] [c0000000050ab9c0] .kvmppc_vcpu_run+0xc8/0xf0 [kvm] [c0000000050aba50] .kvm_arch_vcpu_ioctl_run+0x5c/0x1a0 [kvm] [c0000000050abae0] .kvm_vcpu_ioctl+0x478/0x730 [kvm] [c0000000050abc90] .do_vfs_ioctl+0x4ec/0x7c0 [c0000000050abd80] .SyS_ioctl+0xd4/0xf0 [c0000000050abe30] syscall_exit+0x0/0x98 Since this is a regression, this patch proposes a minimalistic and low-risk solution by blindly forcing the hardirq exit processing of softirqs on the softirq stack. This way we should reduce significantly the opportunities for task stack overflow dug by softirqs. Longer term solutions may involve extending the hardirq stack coverage to irq_exit(), etc... Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@au1.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul Mackerras <paulus@au1.ibm.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: James E.J. Bottomley <jejb@parisc-linux.org> Cc: Helge Deller <deller@gmx.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: David S. Miller <davem@davemloft.net> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-01audit: fix endless wait in audit_log_start()Konstantin Khlebnikov
commit 8ac1c8d5deba65513b6a82c35e89e73996c8e0d6 upstream. After commit 829199197a43 ("kernel/audit.c: avoid negative sleep durations") audit emitters will block forever if userspace daemon cannot handle backlog. After the timeout the waiting loop turns into busy loop and runs until daemon dies or returns back to work. This is a minimal patch for that bug. Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Luiz Capitulino <lcapitulino@redhat.com> Cc: Richard Guy Briggs <rgb@redhat.com> Cc: Eric Paris <eparis@redhat.com> Cc: Chuck Anderson <chuck.anderson@oracle.com> Cc: Dan Duval <dan.duval@oracle.com> Cc: Dave Kleikamp <dave.kleikamp@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jonghwan Choi <jhbird.choi@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-01sched/fair: Fix small race where child->se.parent,cfs_rq might point to ↵Daisuke Nishimura
invalid ones commit 6c9a27f5da9609fca46cb2b183724531b48f71ad upstream. There is a small race between copy_process() and cgroup_attach_task() where child->se.parent,cfs_rq points to invalid (old) ones. parent doing fork() | someone moving the parent to another cgroup -------------------------------+--------------------------------------------- copy_process() + dup_task_struct() -> parent->se is copied to child->se. se.parent,cfs_rq of them point to old ones. cgroup_attach_task() + cgroup_task_migrate() -> parent->cgroup is updated. + cpu_cgroup_attach() + sched_move_task() + task_move_group_fair() +- set_task_rq() -> se.parent,cfs_rq of parent are updated. + cgroup_fork() -> parent->cgroup is copied to child->cgroup. (*1) + sched_fork() + task_fork_fair() -> se.parent,cfs_rq of child are accessed while they point to old ones. (*2) In the worst case, this bug can lead to "use-after-free" and cause a panic, because it's new cgroup's refcount that is incremented at (*1), so the old cgroup(and related data) can be freed before (*2). In fact, a panic caused by this bug was originally caught in RHEL6.4. BUG: unable to handle kernel NULL pointer dereference at (null) IP: [<ffffffff81051e3e>] sched_slice+0x6e/0xa0 [...] Call Trace: [<ffffffff81051f25>] place_entity+0x75/0xa0 [<ffffffff81056a3a>] task_fork_fair+0xaa/0x160 [<ffffffff81063c0b>] sched_fork+0x6b/0x140 [<ffffffff8106c3c2>] copy_process+0x5b2/0x1450 [<ffffffff81063b49>] ? wake_up_new_task+0xd9/0x130 [<ffffffff8106d2f4>] do_fork+0x94/0x460 [<ffffffff81072a9e>] ? sys_wait4+0xae/0x100 [<ffffffff81009598>] sys_clone+0x28/0x30 [<ffffffff8100b393>] stub_clone+0x13/0x20 [<ffffffff8100b072>] ? system_call_fastpath+0x16/0x1b Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/039601ceae06$733d3130$59b79390$@mxp.nes.nec.co.jp Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-01sched/cputime: Do not scale when utime == 0Stanislaw Gruszka
commit 5a8e01f8fa51f5cbce8f37acc050eb2319d12956 upstream. scale_stime() silently assumes that stime < rtime, otherwise when stime == rtime and both values are big enough (operations on them do not fit in 32 bits), the resulting scaling stime can be bigger than rtime. In consequence utime = rtime - stime results in negative value. User space visible symptoms of the bug are overflowed TIME values on ps/top, for example: $ ps aux | grep rcu root 8 0.0 0.0 0 0 ? S 12:42 0:00 [rcuc/0] root 9 0.0 0.0 0 0 ? S 12:42 0:00 [rcub/0] root 10 62422329 0.0 0 0 ? R 12:42 21114581:37 [rcu_preempt] root 11 0.1 0.0 0 0 ? S 12:42 0:02 [rcuop/0] root 12 62422329 0.0 0 0 ? S 12:42 21114581:35 [rcuop/1] root 10 62422329 0.0 0 0 ? R 12:42 21114581:37 [rcu_preempt] or overflowed utime values read directly from /proc/$PID/stat Reference: https://lkml.org/lkml/2013/8/20/259 Reported-and-tested-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Cc: stable@vger.kernel.org Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Borislav Petkov <bp@alien8.de> Link: http://lkml.kernel.org/r/20130904131602.GC2564@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-01timekeeping: Fix HRTICK related deadlock from ntp lock changesJohn Stultz
commit 7bd36014460f793c19e7d6c94dab67b0afcfcb7f upstream. Gerlando Falauto reported that when HRTICK is enabled, it is possible to trigger system deadlocks. These were hard to reproduce, as HRTICK has been broken in the past, but seemed to be connected to the timekeeping_seq lock. Since seqlock/seqcount's aren't supported w/ lockdep, I added some extra spinlock based locking and triggered the following lockdep output: [ 15.849182] ntpd/4062 is trying to acquire lock: [ 15.849765] (&(&pool->lock)->rlock){..-...}, at: [<ffffffff810aa9b5>] __queue_work+0x145/0x480 [ 15.850051] [ 15.850051] but task is already holding lock: [ 15.850051] (timekeeper_lock){-.-.-.}, at: [<ffffffff810df6df>] do_adjtimex+0x7f/0x100 <snip> [ 15.850051] Chain exists of: &(&pool->lock)->rlock --> &p->pi_lock --> timekeeper_lock [ 15.850051] Possible unsafe locking scenario: [ 15.850051] [ 15.850051] CPU0 CPU1 [ 15.850051] ---- ---- [ 15.850051] lock(timekeeper_lock); [ 15.850051] lock(&p->pi_lock); [ 15.850051] lock(timekeeper_lock); [ 15.850051] lock(&(&pool->lock)->rlock); [ 15.850051] [ 15.850051] *** DEADLOCK *** The deadlock was introduced by 06c017fdd4dc48451a ("timekeeping: Hold timekeepering locks in do_adjtimex and hardpps") in 3.10 This patch avoids this deadlock, by moving the call to schedule_delayed_work() outside of the timekeeper lock critical section. Reported-by: Gerlando Falauto <gerlando.falauto@keymile.com> Tested-by: Lin Ming <minggr@gmail.com> Signed-off-by: John Stultz <john.stultz@linaro.org> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Link: http://lkml.kernel.org/r/1378943457-27314-1-git-send-email-john.stultz@linaro.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26pidns: fix vfork() after unshare(CLONE_NEWPID)Oleg Nesterov
commit e79f525e99b04390ca4d2366309545a836c03bf1 upstream. Commit 8382fcac1b81 ("pidns: Outlaw thread creation after unshare(CLONE_NEWPID)") nacks CLONE_VM if the forking process unshared pid_ns, this obviously breaks vfork: int main(void) { assert(unshare(CLONE_NEWUSER | CLONE_NEWPID) == 0); assert(vfork() >= 0); _exit(0); return 0; } fails without this patch. Change this check to use CLONE_SIGHAND instead. This also forbids CLONE_THREAD automatically, and this is what the comment implies. We could probably even drop CLONE_SIGHAND and use CLONE_THREAD, but it would be safer to not do this. The current check denies CLONE_SIGHAND implicitely and there is no reason to change this. Eric said "CLONE_SIGHAND is fine. CLONE_THREAD would be even better. Having shared signal handling between two different pid namespaces is the case that we are fundamentally guarding against." Signed-off-by: Oleg Nesterov <oleg@redhat.com> Reported-by: Colin Walters <walters@redhat.com> Acked-by: Andy Lutomirski <luto@amacapital.net> Reviewed-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26pidns: Fix hang in zap_pid_ns_processes by sending a potentially extra wakeupEric W. Biederman
commit a606488513543312805fab2b93070cefe6a3016c upstream. Serge Hallyn <serge.hallyn@ubuntu.com> writes: > Since commit af4b8a83add95ef40716401395b44a1b579965f4 it's been > possible to get into a situation where a pidns reaper is > <defunct>, reparented to host pid 1, but never reaped. How to > reproduce this is documented at > > https://bugs.launchpad.net/ubuntu/+source/lxc/+bug/1168526 > (and see > https://bugs.launchpad.net/ubuntu/+source/lxc/+bug/1168526/comments/13) > In short, run repeated starts of a container whose init is > > Process.exit(0); > > sysrq-t when such a task is playing zombie shows: > > [ 131.132978] init x ffff88011fc14580 0 2084 2039 0x00000000 > [ 131.132978] ffff880116e89ea8 0000000000000002 ffff880116e89fd8 0000000000014580 > [ 131.132978] ffff880116e89fd8 0000000000014580 ffff8801172a0000 ffff8801172a0000 > [ 131.132978] ffff8801172a0630 ffff88011729fff0 ffff880116e14650 ffff88011729fff0 > [ 131.132978] Call Trace: > [ 131.132978] [<ffffffff816f6159>] schedule+0x29/0x70 > [ 131.132978] [<ffffffff81064591>] do_exit+0x6e1/0xa40 > [ 131.132978] [<ffffffff81071eae>] ? signal_wake_up_state+0x1e/0x30 > [ 131.132978] [<ffffffff8106496f>] do_group_exit+0x3f/0xa0 > [ 131.132978] [<ffffffff810649e4>] SyS_exit_group+0x14/0x20 > [ 131.132978] [<ffffffff8170102f>] tracesys+0xe1/0xe6 > > Further debugging showed that every time this happened, zap_pid_ns_processes() > started with nr_hashed being 3, while we were expecting it to drop to 2. > Any time it didn't happen, nr_hashed was 1 or 2. So the reaper was > waiting for nr_hashed to become 2, but free_pid() only wakes the reaper > if nr_hashed hits 1. The issue is that when the task group leader of an init process exits before other tasks of the init process when the init process finally exits it will be a secondary task sleeping in zap_pid_ns_processes and waiting to wake up when the number of hashed pids drops to two. This case waits forever as free_pid only sends a wake up when the number of hashed pids drops to 1. To correct this the simple strategy of sending a possibly unncessary wake up when the number of hashed pids drops to 2 is adopted. Sending one extraneous wake up is relatively harmless, at worst we waste a little cpu time in the rare case when a pid namespace appropaches exiting. We can detect the case when the pid namespace drops to just two pids hashed race free in free_pid. Dereferencing pid_ns->child_reaper with the pidmap_lock held is safe without out the tasklist_lock because it is guaranteed that the detach_pid will be called on the child_reaper before it is freed and detach_pid calls __change_pid which calls free_pid which takes the pidmap_lock. __change_pid only calls free_pid if this is the last use of the pid. For a thread that is not the thread group leader the threads pid will only ever have one user because a threads pid is not allowed to be the pid of a process, of a process group or a session. For a thread that is a thread group leader all of the other threads of that process will be reaped before it is allowed for the thread group leader to be reaped ensuring there will only be one user of the threads pid as a process pid. Furthermore because the thread is the init process of a pid namespace all of the other processes in the pid namespace will have also been already freed leading to the fact that the pid will not be used as a session pid or a process group pid for any other running process. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Tested-by: Serge Hallyn <serge.hallyn@canonical.com> Reported-by: Serge Hallyn <serge.hallyn@ubuntu.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26uprobes: Fix utask->depth accounting in handle_trampoline()Oleg Nesterov
commit 878b5a6efd38030c7a90895dc8346e8fb1e09b4c upstream. Currently utask->depth is simply the number of allocated/pending return_instance's in uprobe_task->return_instances list. handle_trampoline() should decrement this counter every time we handle/free an instance, but due to typo it does this only if ->chained == T. This means that in the likely case this counter is never decremented and the probed task can't report more than MAX_URETPROBE_DEPTH events. Reported-by: Mikhail Kulemin <Mikhail.Kulemin@ru.ibm.com> Reported-by: Hemant Kumar Shaw <hkshaw@linux.vnet.ibm.com> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Anton Arapov <anton@redhat.com> Cc: masami.hiramatsu.pt@hitachi.com Cc: srikar@linux.vnet.ibm.com Cc: systemtap@sourceware.org Link: http://lkml.kernel.org/r/20130911154726.GA8093@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-07workqueue: cond_resched() after processing each work itemTejun Heo
commit b22ce2785d97423846206cceec4efee0c4afd980 upstream. If !PREEMPT, a kworker running work items back to back can hog CPU. This becomes dangerous when a self-requeueing work item which is waiting for something to happen races against stop_machine. Such self-requeueing work item would requeue itself indefinitely hogging the kworker and CPU it's running on while stop_machine would wait for that CPU to enter stop_machine while preventing anything else from happening on all other CPUs. The two would deadlock. Jamie Liu reports that this deadlock scenario exists around scsi_requeue_run_queue() and libata port multiplier support, where one port may exclude command processing from other ports. With the right timing, scsi_requeue_run_queue() can end up requeueing itself trying to execute an IO which is asked to be retried while another device has an exclusive access, which in turn can't make forward progress due to stop_machine. Fix it by invoking cond_resched() after executing each work item. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Jamie Liu <jamieliu@google.com> References: http://thread.gmane.org/gmane.linux.kernel/1552567 Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-07timer_list: correct the iterator for timer_listNathan Zimmer
commit 84a78a6504f5c5394a8e558702e5b54131f01d14 upstream. Correct an issue with /proc/timer_list reported by Holger. When reading from the proc file with a sufficiently small buffer, 2k so not really that small, there was one could get hung trying to read the file a chunk at a time. The timer_list_start function failed to account for the possibility that the offset was adjusted outside the timer_list_next. Signed-off-by: Nathan Zimmer <nzimmer@sgi.com> Reported-by: Holger Hans Peter Freyther <holger@freyther.de> Cc: John Stultz <john.stultz@linaro.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Berke Durak <berke.durak@xiphos.com> Cc: Jeff Layton <jlayton@redhat.com> Tested-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-29ftrace: Check module functions being traced on reloadSteven Rostedt (Red Hat)
commit 8c4f3c3fa9681dc549cd35419b259496082fef8b upstream. There's been a nasty bug that would show up and not give much info. The bug displayed the following warning: WARNING: at kernel/trace/ftrace.c:1529 __ftrace_hash_rec_update+0x1e3/0x230() Pid: 20903, comm: bash Tainted: G O 3.6.11+ #38405.trunk Call Trace: [<ffffffff8103e5ff>] warn_slowpath_common+0x7f/0xc0 [<ffffffff8103e65a>] warn_slowpath_null+0x1a/0x20 [<ffffffff810c2ee3>] __ftrace_hash_rec_update+0x1e3/0x230 [<ffffffff810c4f28>] ftrace_hash_move+0x28/0x1d0 [<ffffffff811401cc>] ? kfree+0x2c/0x110 [<ffffffff810c68ee>] ftrace_regex_release+0x8e/0x150 [<ffffffff81149f1e>] __fput+0xae/0x220 [<ffffffff8114a09e>] ____fput+0xe/0x10 [<ffffffff8105fa22>] task_work_run+0x72/0x90 [<ffffffff810028ec>] do_notify_resume+0x6c/0xc0 [<ffffffff8126596e>] ? trace_hardirqs_on_thunk+0x3a/0x3c [<ffffffff815c0f88>] int_signal+0x12/0x17 ---[ end trace 793179526ee09b2c ]--- It was finally narrowed down to unloading a module that was being traced. It was actually more than that. When functions are being traced, there's a table of all functions that have a ref count of the number of active tracers attached to that function. When a function trace callback is registered to a function, the function's record ref count is incremented. When it is unregistered, the function's record ref count is decremented. If an inconsistency is detected (ref count goes below zero) the above warning is shown and the function tracing is permanently disabled until reboot. The ftrace callback ops holds a hash of functions that it filters on (and/or filters off). If the hash is empty, the default means to filter all functions (for the filter_hash) or to disable no functions (for the notrace_hash). When a module is unloaded, it frees the function records that represent the module functions. These records exist on their own pages, that is function records for one module will not exist on the same page as function records for other modules or even the core kernel. Now when a module unloads, the records that represents its functions are freed. When the module is loaded again, the records are recreated with a default ref count of zero (unless there's a callback that traces all functions, then they will also be traced, and the ref count will be incremented). The problem is that if an ftrace callback hash includes functions of the module being unloaded, those hash entries will not be removed. If the module is reloaded in the same location, the hash entries still point to the functions of the module but the module's ref counts do not reflect that. With the help of Steve and Joern, we found a reproducer: Using uinput module and uinput_release function. cd /sys/kernel/debug/tracing modprobe uinput echo uinput_release > set_ftrace_filter echo function > current_tracer rmmod uinput modprobe uinput # check /proc/modules to see if loaded in same addr, otherwise try again echo nop > current_tracer [BOOM] The above loads the uinput module, which creates a table of functions that can be traced within the module. We add uinput_release to the filter_hash to trace just that function. Enable function tracincg, which increments the ref count of the record associated to uinput_release. Remove uinput, which frees the records including the one that represents uinput_release. Load the uinput module again (and make sure it's at the same address). This recreates the function records all with a ref count of zero, including uinput_release. Disable function tracing, which will decrement the ref count for uinput_release which is now zero because of the module removal and reload, and we have a mismatch (below zero ref count). The solution is to check all currently tracing ftrace callbacks to see if any are tracing any of the module's functions when a module is loaded (it already does that with callbacks that trace all functions). If a callback happens to have a module function being traced, it increments that records ref count and starts tracing that function. There may be a strange side effect with this, where tracing module functions on unload and then reloading a new module may have that new module's functions being traced. This may be something that confuses the user, but it's not a big deal. Another approach is to disable all callback hashes on module unload, but this leaves some ftrace callbacks that may not be registered, but can still have hashes tracing the module's function where ftrace doesn't know about it. That situation can cause the same bug. This solution solves that case too. Another benefit of this solution, is it is possible to trace a module's function on unload and load. Link: http://lkml.kernel.org/r/20130705142629.GA325@redhat.com Reported-by: Jörn Engel <joern@logfs.org> Reported-by: Dave Jones <davej@redhat.com> Reported-by: Steve Hodgson <steve@purestorage.com> Tested-by: Steve Hodgson <steve@purestorage.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-29tracing/uprobes: Fail to unregister if probe event files are in useSteven Rostedt (Red Hat)
commit c6c2401d8bbaf9edc189b4c35a8cb2780b8b988e upstream. Uprobes suffer the same problem that kprobes have. There's a race between writing to the "enable" file and removing the probe. The probe checks for it being in use and if it is not, goes about deleting the probe and the event that represents it. But the problem with that is, after it checks if it is in use it can be enabled, and the deletion of the event (access to the probe) will fail, as it is in use. But the uprobe will still be deleted. This is a problem as the event can reference the uprobe that was deleted. The fix is to remove the event first, and check to make sure the event removal succeeds. Then it is safe to remove the probe. When the event exists, either ftrace or perf can enable the probe and prevent the event from being removed. Link: http://lkml.kernel.org/r/20130704034038.991525256@goodmis.org Acked-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
