Tegra Profiler: kprobes is no longer used
Use callbacks from the scheduler instead of kprobes
Bug 1343930
Change-Id: I67589dbe972cc5c853addfb6ed82c488529eed55
Signed-off-by: Igor Nabirushkin <inabirushkin@nvidia.com>
Reviewed-on: http://git-master/r/324049
(cherry picked from commit b61817c8d9ad5e45ca17dfd47cb3f9ee864b744e)
Reviewed-on: http://git-master/r/340004
Reviewed-by: Harry Hong <hhong@nvidia.com>
Tested-by: Harry Hong <hhong@nvidia.com>
Added EMC frequency min/max as PM QoS parameters.
Bug 1346293
Signed-off-by: Jinyoung Park <jinyoungp@nvidia.com>
Reviewed-on: http://git-master/r/263783
(cherry picked from commit bdb8424de563a01dd37e53486c2297b4aa183cc7)
Change-Id: Ib9eb6977edd56420d8518231d06749b2fbf5c34c
Reviewed-on: http://git-master/r/301036
Bug 1348440
Change-Id: If25c49f027dc2a69642f7ed4733e965962b2a5a2
Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
commit 9c5da09d266ca9b32eb16cf940f8161d949c2fe5 upstream.
An rmdir pushes css's ref count to zero. However, if the associated
directory is open at the time, the dentry ref count is non-zero. If
the fd for this directory is then passed into perf_event_open, it
does a css_get(). This bounces the ref count back up from zero. This
is a problem by itself. But what makes it turn into a crash is the
fact that we end up doing an extra dput, since we perform a dput
when css_put sees the ref count go down to zero.
css_tryget() does not fall into that trap. So, we use that instead.
Reproduction test-case for the bug:
#include <unistd.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <linux/unistd.h>
#include <linux/perf_event.h>
#include <string.h>
#include <errno.h>
#include <stdio.h>
#define PERF_FLAG_PID_CGROUP (1U << 2)
int perf_event_open(struct perf_event_attr *hw_event_uptr,
pid_t pid, int cpu, int group_fd, unsigned long flags) {
return syscall(__NR_perf_event_open,hw_event_uptr, pid, cpu,
group_fd, flags);
* Directly poke at the perf_event bug, since it's proving hard to repro
* depending on where in the kernel tree. what moved?
int main(int argc, char **argv)
int fd;
struct perf_event_attr attr;
memset(&attr, 0, sizeof(attr));
attr.exclude_kernel = 1;
attr.size = sizeof(attr);
mkdir("/dev/cgroup/perf_event/blah", 0777);
fd = open("/dev/cgroup/perf_event/blah", O_RDONLY);
perror("open");
rmdir("/dev/cgroup/perf_event/blah");
sleep(2);
perf_event_open(&attr, fd, 0, -1, PERF_FLAG_PID_CGROUP);
perror("perf_event_open");
close(fd);
return 0;
Signed-off-by: Salman Qazi <sqazi@google.com>
Acked-by: Tejun Heo <tj@kernel.org>
Link: http://lkml.kernel.org/r/20120614223108.1025.2503.stgit@dungbeetle.mtv.corp.google.com
Cc: Li Zefan <lizefan@huawei.com>
commit 0231bb5336758426b44ccd798ccd3c5419c95d58 upstream.
When we have group with mixed events (hw/sw) we want to end up
with group leader being in hw context. So if group leader is
initialy sw event, we move all the events under hw context.
The move is done for each event by removing it from its context
and adding it back into proper one. As a part of the removal the
event is automatically disabled, which is not what we want at
this stage of creating groups.
The fix is to initialize event state after removal from sw
context.
This fix resulted from the following discussion:
http://thread.gmane.org/gmane.linux.kernel.perf.user/1144
Reported-by: Andreas Hollmann <hollmann@in.tum.de>
Signed-off-by: Jiri Olsa <jolsa@redhat.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Vince Weaver <vince@deater.net>
Link: http://lkml.kernel.org/r/1359714225-4231-1-git-send-email-jolsa@redhat.com
commit a59f4e079d19464eebb9b06513a1d4f55fdae5ba upstream.
The caller of sched_sliced() should pass se.cfs_rq and se as the
arguments, however in sched_rr_get_interval() we gave it
rq.cfs_rq and se, which made the following computation obviously
wrong.
The change was introduced by commit:
77034937dc45 sched: fix crash in sys_sched_rr_get_interval()
... 5 years ago, while it had been the correct 'cfs_rq_of' before
the commit. The change seems to be irrelevant to the commit
msg, which was to return a 0 timeslice for tasks that are on an
idle runqueue. So I believe that was just a plain typo.
Signed-off-by: Zhu Yanhai <gaoyang.zyh@taobao.com>
Cc: Paul Turner <pjt@google.com>
Link: http://lkml.kernel.org/r/1357621012-15039-1-git-send-email-gaoyang.zyh@taobao.com
[ Since this is an ABI and an old bug, we'll test this via a
slow upstream route, to hopefully discover any app breakage. ]
commit 11034ae9c20f4057a6127fc965906417978e69b2 upstream
Initialization of variable irq_flags and pc was missed when backport
11034ae9c to linux-3.0.y and linux-3.4.y, my fault.
Signed-off-by: zhangwei(Jovi) <jovi.zhangwei@huawei.com>
commit 5ec2481b7b47a4005bb446d176e5d0257400c77d upstream.
smp_call_function_* must not be called from softirq context.
But clock_was_set() which calls on_each_cpu() is called from softirq
context to implement a delayed clock_was_set() for the timer interrupt
handler. Though that almost never gets invoked. A recent change in the
resume code uses the softirq based delayed clock_was_set to support
Xens resume mechanism.
linux-next contains a new warning which warns if smp_call_function_*
is called from softirq context which gets triggered by that Xen
change.
Fix this by moving the delayed clock_was_set() call to a work context.
Reported-and-tested-by: Artem Savkov <artem.savkov@gmail.com>
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Cc: David Vrabel <david.vrabel@citrix.com>
Cc: H. Peter Anvin <hpa@zytor.com>,
Cc: Konrad Wilk <konrad.wilk@oracle.com>
Cc: John Stultz <john.stultz@linaro.org>
Cc: xen-devel@lists.xen.org
Cc: stable@vger.kernel.org
commit 11034ae9c20f4057a6127fc965906417978e69b2 upstream.
All syscall tracing irqs-off tags are wrong, the syscall enter entry doesn't
disable irqs.
[root@jovi tracing]#echo "syscalls:sys_enter_open" > set_event
[root@jovi tracing]# cat trace
# tracer: nop
# entries-in-buffer/entries-written: 13/13 #P:2
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
irqbalance-513 [000] d... 56115.496766: sys_open(filename: 804e1a6, flags: 0, mode: 1b6)
irqbalance-513 [000] d... 56115.497008: sys_open(filename: 804e1bb, flags: 0, mode: 1b6)
sendmail-771 [000] d... 56115.827982: sys_open(filename: b770e6d1, flags: 0, mode: 1b6)
The reason is syscall tracing doesn't record irq_flags into buffer.
The proper display is:
# tracer: nop
# entries-in-buffer/entries-written: 14/14 #P:2
# _-----=> irqs-off
# ||| / delay
irqbalance-514 [001] .... 46.213921: sys_open(filename: 804e1a6, flags: 0, mode: 1b6)
irqbalance-514 [001] .... 46.214160: sys_open(filename: 804e1bb, flags: 0, mode: 1b6)
<...>-920 [001] .... 47.307260: sys_open(filename: 4e82a0c5, flags: 80000, mode: 0)
Link: http://lkml.kernel.org/r/1365564393-10972-3-git-send-email-jovi.zhangwei@huawei.com
Cc: stable@vger.kernel.org # 2.6.35
commit 058ebd0eba3aff16b144eabf4510ed9510e1416e upstream.
Jiri managed to trigger this warning:
[] [ INFO: possible circular locking dependency detected ]
[] 3.10.0+ #228 Tainted: G W
[] p/6613 is trying to acquire lock:
[] (rcu_node_0){..-...}, at: [<ffffffff810ca797>] rcu_read_unlock_special+0xa7/0x250
[] but task is already holding lock:
[] (&ctx->lock){-.-...}, at: [<ffffffff810f2879>] perf_lock_task_context+0xd9/0x2c0
[] which lock already depends on the new lock.
[] the existing dependency chain (in reverse order) is:
[] -> #4 (&ctx->lock){-.-...}:
[] -> #3 (&rq->lock){-.-.-.}:
[] -> #2 (&p->pi_lock){-.-.-.}:
[] -> #1 (&rnp->nocb_gp_wq[1]){......}:
[] -> #0 (rcu_node_0){..-...}:
Paul was quick to explain that due to preemptible RCU we cannot call
rcu_read_unlock() while holding scheduler (or nested) locks when part
of the read side critical section was preemptible.
Therefore solve it by making the entire RCU read side non-preemptible.
Also pull out the retry from under the non-preempt to play nice with RT.
Reported-by: Jiri Olsa <jolsa@redhat.com>
Helped-out-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
commit 06f417968beac6e6b614e17b37d347aa6a6b1d30 upstream.
The '!ctx->is_active' check has a valid scenario, so
there's no need for the warning.
The reason is that there's a time window between the
'ctx->is_active' check in the perf_event_enable() function
and the __perf_event_enable() function having:
- IRQs on
- ctx->lock unlocked
where the task could be killed and 'ctx' deactivated by
perf_event_exit_task(), ending up with the warning below.
So remove the WARN_ON_ONCE() check and add comments to
explain it all.
This addresses the following warning reported by Vince Weaver:
[ 324.983534] ------------[ cut here ]------------
[ 324.984420] WARNING: at kernel/events/core.c:1953 __perf_event_enable+0x187/0x190()
[ 324.984420] Modules linked in:
[ 324.984420] CPU: 19 PID: 2715 Comm: nmi_bug_snb Not tainted 3.10.0+ #246
[ 324.984420] Hardware name: Supermicro X8DTN/X8DTN, BIOS 4.6.3 01/08/2010
[ 324.984420] 0000000000000009 ffff88043fce3ec8 ffffffff8160ea0b ffff88043fce3f00
[ 324.984420] ffffffff81080ff0 ffff8802314fdc00 ffff880231a8f800 ffff88043fcf7860
[ 324.984420] 0000000000000286 ffff880231a8f800 ffff88043fce3f10 ffffffff8108103a
[ 324.984420] Call Trace:
[ 324.984420] <IRQ> [<ffffffff8160ea0b>] dump_stack+0x19/0x1b
[ 324.984420] [<ffffffff81080ff0>] warn_slowpath_common+0x70/0xa0
[ 324.984420] [<ffffffff8108103a>] warn_slowpath_null+0x1a/0x20
[ 324.984420] [<ffffffff81134437>] __perf_event_enable+0x187/0x190
[ 324.984420] [<ffffffff81130030>] remote_function+0x40/0x50
[ 324.984420] [<ffffffff810e51de>] generic_smp_call_function_single_interrupt+0xbe/0x130
[ 324.984420] [<ffffffff81066a47>] smp_call_function_single_interrupt+0x27/0x40
[ 324.984420] [<ffffffff8161fd2f>] call_function_single_interrupt+0x6f/0x80
[ 324.984420] <EOI> [<ffffffff816161a1>] ? _raw_spin_unlock_irqrestore+0x41/0x70
[ 324.984420] [<ffffffff8113799d>] perf_event_exit_task+0x14d/0x210
[ 324.984420] [<ffffffff810acd04>] ? switch_task_namespaces+0x24/0x60
[ 324.984420] [<ffffffff81086946>] do_exit+0x2b6/0xa40
[ 324.984420] [<ffffffff8161615c>] ? _raw_spin_unlock_irq+0x2c/0x30
[ 324.984420] [<ffffffff81087279>] do_group_exit+0x49/0xc0
[ 324.984420] [<ffffffff81096854>] get_signal_to_deliver+0x254/0x620
[ 324.984420] [<ffffffff81043057>] do_signal+0x57/0x5a0
[ 324.984420] [<ffffffff8161a164>] ? __do_page_fault+0x2a4/0x4e0
[ 324.984420] [<ffffffff8161665c>] ? retint_restore_args+0xe/0xe
[ 324.984420] [<ffffffff816166cd>] ? retint_signal+0x11/0x84
[ 324.984420] [<ffffffff81043605>] do_notify_resume+0x65/0x80
[ 324.984420] [<ffffffff81616702>] retint_signal+0x46/0x84
[ 324.984420] ---[ end trace 442ec2f04db3771a ]---
Reported-by: Vince Weaver <vincent.weaver@maine.edu>
Suggested-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Link: http://lkml.kernel.org/r/1373384651-6109-2-git-send-email-jolsa@redhat.com
commit 734df5ab549ca44f40de0f07af1c8803856dfb18 upstream.
Currently when the child context for inherited events is
created, it's based on the pmu object of the first event
of the parent context.
This is wrong for the following scenario:
- HW context having HW and SW event
- HW event got removed (closed)
- SW event stays in HW context as the only event
and its pmu is used to clone the child context
The issue starts when the cpu context object is touched
based on the pmu context object (__get_cpu_context). In
this case the HW context will work with SW cpu context
ending up with following WARN below.
Fixing this by using parent context pmu object to clone
from child context.
Addresses the following warning reported by Vince Weaver:
[ 2716.472065] ------------[ cut here ]------------
[ 2716.476035] WARNING: at kernel/events/core.c:2122 task_ctx_sched_out+0x3c/0x)
[ 2716.476035] Modules linked in: nfsd auth_rpcgss oid_registry nfs_acl nfs locn
[ 2716.476035] CPU: 0 PID: 3164 Comm: perf_fuzzer Not tainted 3.10.0-rc4 #2
[ 2716.476035] Hardware name: AOpen DE7000/nMCP7ALPx-DE R1.06 Oct.19.2012, BI2
[ 2716.476035] 0000000000000000 ffffffff8102e215 0000000000000000 ffff88011fc18
[ 2716.476035] ffff8801175557f0 0000000000000000 ffff880119fda88c ffffffff810ad
[ 2716.476035] ffff880119fda880 ffffffff810af02a 0000000000000009 ffff880117550
[ 2716.476035] Call Trace:
[ 2716.476035] [<ffffffff8102e215>] ? warn_slowpath_common+0x5b/0x70
[ 2716.476035] [<ffffffff810ab2bd>] ? task_ctx_sched_out+0x3c/0x5f
[ 2716.476035] [<ffffffff810af02a>] ? perf_event_exit_task+0xbf/0x194
[ 2716.476035] [<ffffffff81032a37>] ? do_exit+0x3e7/0x90c
[ 2716.476035] [<ffffffff810cd5ab>] ? __do_fault+0x359/0x394
[ 2716.476035] [<ffffffff81032fe6>] ? do_group_exit+0x66/0x98
[ 2716.476035] [<ffffffff8103dbcd>] ? get_signal_to_deliver+0x479/0x4ad
[ 2716.476035] [<ffffffff810ac05c>] ? __perf_event_task_sched_out+0x230/0x2d1
[ 2716.476035] [<ffffffff8100205d>] ? do_signal+0x3c/0x432
[ 2716.476035] [<ffffffff810abbf9>] ? ctx_sched_in+0x43/0x141
[ 2716.476035] [<ffffffff810ac2ca>] ? perf_event_context_sched_in+0x7a/0x90
[ 2716.476035] [<ffffffff810ac311>] ? __perf_event_task_sched_in+0x31/0x118
[ 2716.476035] [<ffffffff81050dd9>] ? mmdrop+0xd/0x1c
[ 2716.476035] [<ffffffff81051a39>] ? finish_task_switch+0x7d/0xa6
[ 2716.476035] [<ffffffff81002473>] ? do_notify_resume+0x20/0x5d
[ 2716.476035] [<ffffffff813654f5>] ? retint_signal+0x3d/0x78
[ 2716.476035] ---[ end trace 827178d8a5966c3d ]---
Link: http://lkml.kernel.org/r/1373384651-6109-1-git-send-email-jolsa@redhat.com
commit f17a5194859a82afe4164e938b92035b86c55794 upstream.
The irqsoff tracer records the max time that interrupts are disabled.
There are hooks in the assembly code that calls back into the tracer when
interrupts are disabled or enabled.
When they are enabled, the tracer checks if the amount of time they
were disabled is larger than the previous recorded max interrupts off
time. If it is, it creates a snapshot of the currently running trace
to store where the last largest interrupts off time was held and how
it happened.
During testing, this RCU lockdep dump appeared:
[ 1257.829021] ===============================
[ 1257.829021] [ INFO: suspicious RCU usage. ]
[ 1257.829021] 3.10.0-rc1-test+ #171 Tainted: G W
[ 1257.829021] -------------------------------
[ 1257.829021] /home/rostedt/work/git/linux-trace.git/include/linux/rcupdate.h:780 rcu_read_lock() used illegally while idle!
[ 1257.829021]
[ 1257.829021] other info that might help us debug this:
[ 1257.829021]
[ 1257.829021]
[ 1257.829021] RCU used illegally from idle CPU!
[ 1257.829021] rcu_scheduler_active = 1, debug_locks = 0
[ 1257.829021] RCU used illegally from extended quiescent state!
[ 1257.829021] 2 locks held by trace-cmd/4831:
[ 1257.829021] #0: (max_trace_lock){......}, at: [<ffffffff810e2b77>] stop_critical_timing+0x1a3/0x209
[ 1257.829021] #1: (rcu_read_lock){.+.+..}, at: [<ffffffff810dae5a>] __update_max_tr+0x88/0x1ee
[ 1257.829021]
[ 1257.829021] stack backtrace:
[ 1257.829021] CPU: 3 PID: 4831 Comm: trace-cmd Tainted: G W 3.10.0-rc1-test+ #171
[ 1257.829021] Hardware name: To Be Filled By O.E.M. To Be Filled By O.E.M./To be filled by O.E.M., BIOS SDBLI944.86P 05/08/2007
[ 1257.829021] 0000000000000001 ffff880065f49da8 ffffffff8153dd2b ffff880065f49dd8
[ 1257.829021] ffffffff81092a00 ffff88006bd78680 ffff88007add7500 0000000000000003
[ 1257.829021] ffff88006bd78680 ffff880065f49e18 ffffffff810daebf ffffffff810dae5a
[ 1257.829021] Call Trace:
[ 1257.829021] [<ffffffff8153dd2b>] dump_stack+0x19/0x1b
[ 1257.829021] [<ffffffff81092a00>] lockdep_rcu_suspicious+0x109/0x112
[ 1257.829021] [<ffffffff810daebf>] __update_max_tr+0xed/0x1ee
[ 1257.829021] [<ffffffff810dae5a>] ? __update_max_tr+0x88/0x1ee
[ 1257.829021] [<ffffffff811002b9>] ? user_enter+0xfd/0x107
[ 1257.829021] [<ffffffff810dbf85>] update_max_tr_single+0x11d/0x12d
[ 1257.829021] [<ffffffff810e2b15>] stop_critical_timing+0x141/0x209
[ 1257.829021] [<ffffffff8109569a>] ? trace_hardirqs_on+0xd/0xf
[ 1257.829021] [<ffffffff810e3057>] time_hardirqs_on+0x2a/0x2f
[ 1257.829021] [<ffffffff8109550c>] trace_hardirqs_on_caller+0x16/0x197
[ 1257.829021] [<ffffffff8109569a>] trace_hardirqs_on+0xd/0xf
[ 1257.829021] [<ffffffff811002b9>] user_enter+0xfd/0x107
[ 1257.829021] [<ffffffff810029b4>] do_notify_resume+0x92/0x97
[ 1257.829021] [<ffffffff8154bdca>] int_signal+0x12/0x17
What happened was entering into the user code, the interrupts were enabled
and a max interrupts off was recorded. The trace buffer was saved along with
various information about the task: comm, pid, uid, priority, etc.
The uid is recorded with task_uid(tsk). But this is a macro that uses rcu_read_lock()
to retrieve the data, and this happened to happen where RCU is blind (user_enter).
As only the preempt and irqs off tracers can have this happen, and they both
only have the tsk == current, if tsk == current, use current_uid() instead of
task_uid(), as current_uid() does not use RCU as only current can change its uid.
This fixes the RCU suspicious splat.
commit 1f73a9806bdd07a5106409bbcab3884078bd34fe upstream.
When the system switches from periodic to oneshot mode, the broadcast
logic causes a possibility that a CPU which has not yet switched to
oneshot mode puts its own clock event device into oneshot mode without
updating the state and the timer handler.
CPU0 CPU1
per cpu tickdev is in periodic mode
and switched to broadcast
Switch to oneshot mode
tick_broadcast_switch_to_oneshot()
cpumask_copy(tick_oneshot_broacast_mask,
tick_broadcast_mask);
broadcast device mode = oneshot
Timer interrupt
irq_enter()
tick_check_oneshot_broadcast()
dev->set_mode(ONESHOT);
tick_handle_periodic()
if (dev->mode == ONESHOT)
dev->next_event += period;
FAIL.
We fail, because dev->next_event contains KTIME_MAX, if the device was
in periodic mode before the uncontrolled switch to oneshot happened.
We must copy the broadcast bits over to the oneshot mask, because
otherwise a CPU which relies on the broadcast would not been woken up
anymore after the broadcast device switched to oneshot mode.
So we need to verify in tick_check_oneshot_broadcast() whether the CPU
has already switched to oneshot mode. If not, leave the device
untouched and let the CPU switch controlled into oneshot mode.
This is a long standing bug, which was never noticed, because the main
user of the broadcast x86 cannot run into that scenario, AFAICT. The
nonarchitected timer mess of ARM creates a gazillion of differently
broken abominations which trigger the shortcomings of that broadcast
code, which better had never been necessary in the first place.
Reported-and-tested-by: Stehle Vincent-B46079 <B46079@freescale.com>
Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
Cc: John Stultz <john.stultz@linaro.org>,
Cc: Mark Rutland <mark.rutland@arm.com>
Link: http://lkml.kernel.org/r/alpine.DEB.2.02.1307012153060.4013@ionos.tec.linutronix.de
commit 9e04d3804d3ac97d8c03a41d78d0f0674b5d01e1 upstream.
Direct compare of jiffies related values does not work in the wrap
around case. Replace it with time_is_after_jiffies().
Signed-off-by: Bart Van Assche <bvanassche@acm.org>
Cc: Arjan van de Ven <arjan@infradead.org>
Link: http://lkml.kernel.org/r/519BC066.5080600@acm.org
commit 2779db8d37d4b542d9ca2575f5f178dbeaca6c86 upstream.
Commit 02725e7471b8 ('genirq: Use irq_get/put functions'),
inadvertently changed can_request_irq() to return 0 for IRQs that have
no action. This causes pcibios_lookup_irq() to select only IRQs that
already have an action with IRQF_SHARED set, or to fail if there are
none. Change can_request_irq() to return 1 for IRQs that have no
action (if the first two conditions are met).
Reported-by: Bjarni Ingi Gislason <bjarniig@rhi.hi.is>
Tested-by: Bjarni Ingi Gislason <bjarniig@rhi.hi.is> (against 3.2)
Cc: 709647@bugs.debian.org
Link: http://bugs.debian.org/709647
Link: http://lkml.kernel.org/r/1372383630.23847.40.camel@deadeye.wl.decadent.org.uk
%ll is not legal format for printk - use %lld
Change-Id: Ie59783dfbd6558e2fe833c76b2ba96cd52bbac76
Signed-off-by: Philip Rakity <prakity@nvidia.com>
Reviewed-on: http://git-master/r/246096
Reviewed-by: Scott Peterson <speterson@nvidia.com>
warning is bogus but since code is not used frequently
just set ret to avoid warning.
Change-Id: Icd3b47f2e95982cea2019e93c5fc1c69c64852dd
Reviewed-on: http://git-master/r/246102
Reviewed-by: Eric Miao <emiao@nvidia.com>
This reverts commit 48f0f14ffb6ff4852922994d11fbda418d40100e which was
commit 749c8814f08f12baa4a9c2812a7c6ede7d69507d upstream.
It seems to be misapplied, and not needed for 3.4-stable
Reported-by: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Charles Wang <muming.wq@taobao.com>
commit 9bb5d40cd93c9dd4be74834b1dcb1ba03629716b upstream.
Vince's fuzzer once again found holes. This time it spotted a leak in
the locked page accounting.
When an event had redirected output and its close() was the last
reference to the buffer we didn't have a vm context to undo accounting.
Change the code to destroy the buffer on the last munmap() and detach
all redirected events at that time. This provides us the right context
to undo the vm accounting.
[Backporting for 3.4-stable.
VM_RESERVED flag was replaced with pair 'VM_DONTEXPAND | VM_DONTDUMP' in
314e51b9 since 3.7.0-rc1, and 314e51b9 comes from a big patchset, we didn't
backport the patchset, so I restored 'VM_DNOTEXPAND | VM_DONTDUMP' as before:
- vma->vm_flags |= VM_DONTCOPY | VM_DONTEXPAND | VM_DONTDUMP;
+ vma->vm_flags |= VM_DONTCOPY | VM_RESERVED;
-- zliu]
Reported-and-tested-by: Vince Weaver <vincent.weaver@maine.edu>
Link: http://lkml.kernel.org/r/20130604084421.GI8923@twins.programming.kicks-ass.net
Cc: <stable@kernel.org>
Signed-off-by: Zhouping Liu <zliu@redhat.com>
commit 26cb63ad11e04047a64309362674bcbbd6a6f246 upstream.
Vince reported a problem found by his perf specific trinity
fuzzer.
Al noticed 2 problems with perf's mmap():
- it has issues against fork() since we use vma->vm_mm for accounting.
- it has an rb refcount leak on double mmap().
We fix the issues against fork() by using VM_DONTCOPY; I don't
think there's code out there that uses this; we didn't hear
about weird accounting problems/crashes. If we do need this to
work, the previously proposed VM_PINNED could make this work.
Aside from the rb reference leak spotted by Al, Vince's example
prog was indeed doing a double mmap() through the use of
perf_event_set_output().
This exposes another problem, since we now have 2 events with
one buffer, the accounting gets screwy because we account per
event. Fix this by making the buffer responsible for its own
accounting.
-- zliu]
Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Link: http://lkml.kernel.org/r/20130528085548.GA12193@twins.programming.kicks-ass.net
commit c790b0ad23f427c7522ffed264706238c57c007e upstream.
fetch_bp_busy_slots() and toggle_bp_slot() use
for_each_online_cpu(), this is obviously wrong wrt cpu_up() or
cpu_down(), we can over/under account the per-cpu numbers.
For example:
# echo 0 >> /sys/devices/system/cpu/cpu1/online
# perf record -e mem:0x10 -p 1 &
# echo 1 >> /sys/devices/system/cpu/cpu1/online
# perf record -e mem:0x10,mem:0x10,mem:0x10,mem:0x10 -C1 -a &
# taskset -p 0x2 1
triggers the same WARN_ONCE("Can't find any breakpoint slot") in
arch_install_hw_breakpoint().
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
Link: http://lkml.kernel.org/r/20130620155009.GA6327@redhat.com
Adding bool prompt and help description for CONFIG_WAKELOCK
and CONFIG_HAS_WAKELOCK options in Kconfig file to ease
menuconfig operations
Bug 1314808
Change-Id: I5c450ef0994a08c1bf51e8c9849bb96c69c69081
Signed-off-by: Naveen Kumar S <nkumars@nvidia.com>
Reviewed-on: http://git-master/r/243459
GVS: Gerrit_Virtual_Submit
Reviewed-by: Allen Martin <amartin@nvidia.com>
commit cf7df378aa4ff7da3a44769b7ff6e9eef1a9f3db upstream.
We recently noticed that reboot of a 1024 cpu machine takes approx 16
minutes of just stopping the cpus. The slowdown was tracked to commit
f96972f2dc63 ("kernel/sys.c: call disable_nonboot_cpus() in
kernel_restart()").
The current implementation does all the work of hot removing the cpus
before halting the system. We are switching to just migrating to the
boot cpu and then continuing with shutdown/reboot.
This also has the effect of not breaking x86's command line parameter
for specifying the reboot cpu. Note, this code was shamelessly copied
from arch/x86/kernel/reboot.c with bits removed pertaining to the
reboot_cpu command line parameter.
Signed-off-by: Robin Holt <holt@sgi.com>
Tested-by: Shawn Guo <shawn.guo@linaro.org>
Cc: "Srivatsa S. Bhat" <srivatsa.bhat@linux.vnet.ibm.com>
Cc: Russ Anderson <rja@sgi.com>
Cc: Robin Holt <holt@sgi.com>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
commit 16e53dbf10a2d7e228709a7286310e629ede5e45 upstream.
There are instances in the kernel where we would like to disable CPU
hotplug (from sysfs) during some important operation. Today the freezer
code depends on this and the code to do it was kinda tailor-made for
that.
Restructure the code and make it generic enough to be useful for other
usecases too.
Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
Cc: Shawn Guo <shawn.guo@linaro.org>
commit 7f49ef69db6bbf756c0abca7e9b65b32e999eec8 upstream.
As ftrace_filter_lseek is now used with ftrace_pid_fops, it needs to
be moved out of the #ifdef CONFIG_DYNAMIC_FTRACE section as the
ftrace_pid_fops is defined when DYNAMIC_FTRACE is not.
[ lizf: adjust context ]
Signed-off-by: Li Zefan <lizefan@huawei.com>
commit 6a76f8c0ab19f215af2a3442870eeb5f0e81998d upstream.
Currently set_ftrace_pid and set_graph_function files use seq_lseek
for their fops. However seq_open() is called only for FMODE_READ in
the fops->open() so that if an user tries to seek one of those file
when she open it for writing, it sees NULL seq_file and then panic.
It can be easily reproduced with following command:
$ cd /sys/kernel/debug/tracing
$ echo 1234 | sudo tee -a set_ftrace_pid
In this example, GNU coreutils' tee opens the file with fopen(, "a")
and then the fopen() internally calls lseek().
Link:
http://lkml.kernel.org/r/1365663302-2170-1-git-send-email-namhyung@kernel.org
Signed-off-by: Namhyung Kim <namhyung@kernel.org>
Cc: Namhyung Kim <namhyung.kim@lge.com>
When system enters into suspend, it disable all irqs in single
function call. This disables EARLY_RESUME irqs also along with
normal irqs.
The EARLY_RESUME irqs get enabled in sys_core_ops->resume and
non-EARLY_RESUME irqs get enabled in normal system resume path.
When suspend_noirq failed or suspend is aborted for any reason,
the EARLY_RESUME irqs do not get enabled as sys_core_ops->resume()
call did not happen. It only enables the non-EARLY_RESUME irqs in normal
system resume path. This makes the EARLY_RESUME irqs interrupt to be
disable for remaining life of system.
Add checks on normal irq_resume() whether EARLY_RESUME irqs have been
enabled or not and if not then enable it forcefully.
bug 1282448
Change-Id: I7ffffd725675ca635310eb4913a1f885d2e42e37
Reviewed-on: http://git-master/r/235000
Reviewed-by: Thomas Cherry <tcherry@nvidia.com>
Tested-by: Mark Kuo <mkuo@nvidia.com>
commit 264b83c07a84223f0efd0d1db9ccc66d6f88288f upstream.
argv_split(empty_or_all_spaces) happily succeeds, it simply returns
argc == 0 and argv[0] == NULL. Change call_usermodehelper_exec() to
check sub_info->path != NULL to avoid the crash.
This is the minimal fix, todo:
- perhaps we should change argv_split() to return NULL or change the
callers.
- kill or justify ->path[0] check
- narrow the scope of helper_lock()
Acked-By: Lucas De Marchi <lucas.demarchi@intel.com>
commit 60705c89460fdc7227f2d153b68b3f34814738a4 upstream.
Special preds are created when folding a series of preds that
can be done in serial. These are allocated in an ops field of
the pred structure. But they were never freed, causing memory
leaks.
This was discovered using the kmemleak checker:
unreferenced object 0xffff8800797fd5e0 (size 32):
comm "swapper/0", pid 1, jiffies 4294690605 (age 104.608s)
hex dump (first 32 bytes):
00 00 01 00 03 00 05 00 07 00 09 00 0b 00 0d 00 ................
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
backtrace:
[<ffffffff814b52af>] kmemleak_alloc+0x73/0x98
[<ffffffff8111ff84>] kmemleak_alloc_recursive.constprop.42+0x16/0x18
[<ffffffff81120e68>] __kmalloc+0xd7/0x125
[<ffffffff810d47eb>] kcalloc.constprop.24+0x2d/0x2f
[<ffffffff810d4896>] fold_pred_tree_cb+0xa9/0xf4
[<ffffffff810d3781>] walk_pred_tree+0x47/0xcc
[<ffffffff810d5030>] replace_preds.isra.20+0x6f8/0x72f
[<ffffffff810d50b5>] create_filter+0x4e/0x8b
[<ffffffff81b1c30d>] ftrace_test_event_filter+0x5a/0x155
[<ffffffff8100028d>] do_one_initcall+0xa0/0x137
[<ffffffff81afbedf>] kernel_init_freeable+0x14d/0x1dc
[<ffffffff814b24b7>] kernel_init+0xe/0xdb
[<ffffffff814d539c>] ret_from_fork+0x7c/0xb0
[<ffffffffffffffff>] 0xffffffffffffffff
Cc: Tom Zanussi <tzanussi@gmail.com>
commit 4b0c0f294f60abcdd20994a8341a95c8ac5eeb96 upstream.
Prarit reported a crash on CPU offline/online. The reason is that on
CPU down the NOHZ related per cpu data of the dead cpu is not cleaned
up. If at cpu online an interrupt happens before the per cpu tick
device is registered the irq_enter() check potentially sees stale data
and dereferences a NULL pointer.
Cleanup the data after the cpu is dead.
Reported-by: Prarit Bhargava <prarit@redhat.com>
Cc: Mike Galbraith <bitbucket@online.de>
Link: http://lkml.kernel.org/r/alpine.LFD.2.02.1305031451561.2886@ionos
commit 42a5cf46cd56f46267d2a9fcf2655f4078cd3042 upstream.
An inactive timer's base can refer to a offline cpu's base.
In the current code, cpu_base's lock is blindly reinitialized each
time a CPU is brought up. If a CPU is brought online during the period
that another thread is trying to modify an inactive timer on that CPU
with holding its timer base lock, then the lock will be reinitialized
under its feet. This leads to following SPIN_BUG().
<0> BUG: spinlock already unlocked on CPU#3, kworker/u:3/1466
<0> lock: 0xe3ebe000, .magic: dead4ead, .owner: kworker/u:3/1466, .owner_cpu: 1
<4> [<c0013dc4>] (unwind_backtrace+0x0/0x11c) from [<c026e794>] (do_raw_spin_unlock+0x40/0xcc)
<4> [<c026e794>] (do_raw_spin_unlock+0x40/0xcc) from [<c076c160>] (_raw_spin_unlock+0x8/0x30)
<4> [<c076c160>] (_raw_spin_unlock+0x8/0x30) from [<c009b858>] (mod_timer+0x294/0x310)
<4> [<c009b858>] (mod_timer+0x294/0x310) from [<c00a5e04>] (queue_delayed_work_on+0x104/0x120)
<4> [<c00a5e04>] (queue_delayed_work_on+0x104/0x120) from [<c04eae00>] (sdhci_msm_bus_voting+0x88/0x9c)
<4> [<c04eae00>] (sdhci_msm_bus_voting+0x88/0x9c) from [<c04d8780>] (sdhci_disable+0x40/0x48)
<4> [<c04d8780>] (sdhci_disable+0x40/0x48) from [<c04bf300>] (mmc_release_host+0x4c/0xb0)
<4> [<c04bf300>] (mmc_release_host+0x4c/0xb0) from [<c04c7aac>] (mmc_sd_detect+0x90/0xfc)
<4> [<c04c7aac>] (mmc_sd_detect+0x90/0xfc) from [<c04c2504>] (mmc_rescan+0x7c/0x2c4)
<4> [<c04c2504>] (mmc_rescan+0x7c/0x2c4) from [<c00a6a7c>] (process_one_work+0x27c/0x484)
<4> [<c00a6a7c>] (process_one_work+0x27c/0x484) from [<c00a6e94>] (worker_thread+0x210/0x3b0)
<4> [<c00a6e94>] (worker_thread+0x210/0x3b0) from [<c00aad9c>] (kthread+0x80/0x8c)
<4> [<c00aad9c>] (kthread+0x80/0x8c) from [<c000ea80>] (kernel_thread_exit+0x0/0x8)
As an example, this particular crash occurred when CPU #3 is executing
mod_timer() on an inactive timer whose base is refered to offlined CPU
#2. The code locked the timer_base corresponding to CPU #2. Before it
could proceed, CPU #2 came online and reinitialized the spinlock
corresponding to its base. Thus now CPU #3 held a lock which was
reinitialized. When CPU #3 finally ended up unlocking the old cpu_base
corresponding to CPU #2, we hit the above SPIN_BUG().
CPU #0 CPU #3 CPU #2
..... ...... <Offline>
mod_timer()
lock_timer_base
spin_lock_irqsave(&base->lock)
cpu_up(2) ..... ......
init_timers_cpu()
.... ..... spin_lock_init(&base->lock)
..... spin_unlock_irqrestore(&base->lock) ......
<spin_bug>
Allocation of per_cpu timer vector bases is done only once under
"tvec_base_done[]" check. In the current code, spinlock_initialization
of base->lock isn't under this check. When a CPU is up each time the
base lock is reinitialized. Move base spinlock initialization under
the check.
Signed-off-by: Tirupathi Reddy <tirupath@codeaurora.org>
Link: http://lkml.kernel.org/r/1368520142-4136-1-git-send-email-tirupath@codeaurora.org
Maxim code drop to export pm_qos_update_request_timeout. The maxim touch driver needs this if it's compiled as a module.
Bug 1270691
Change-Id: I1fbc5fc045a6892d8eeb7e810b806793589b7273
Signed-off-by: David Jung <djung@nvidia.com>
Reviewed-on: http://git-master/r/227705
Reviewed-by: Paul Walmsley <pwalmsley@nvidia.com>
Trinity discovered that we fail to check all 64 bits of
attr.config passed by user space, resulting to out-of-bounds
access of the perf_swevent_enabled array in
sw_perf_event_destroy().
Introduced in commit b0a873ebb ("perf: Register PMU
implementations").
Signed-off-by: Tommi Rantala <tt.rantala@gmail.com>
Cc: davej@redhat.com
Link: http://lkml.kernel.org/r/1365882554-30259-1-git-send-email-tt.rantala@gmail.com
(cherry picked from commit 8176cced706b5e5d15887584150764894e94e02f)
Change-Id: Ie1dd9b0d40980fbbf8499528964c01cc71efd46c
Signed-off-by: Bo Yan <byan@nvidia.com>
Reviewed-on: http://git-master/r/228455
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
audit_trim_trees()
commit 12b2f117f3bf738c1a00a6f64393f1953a740bd4 upstream.
audit_trim_trees() calls get_tree(). If a failure occurs we must call
put_tree().
[akpm@linux-foundation.org: run put_tree() before mutex_lock() for small scalability improvement]
Signed-off-by: Chen Gang <gang.chen@asianux.com>
Cc: Eric Paris <eparis@redhat.com>
Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com>
commit 7fe70b579c9e3daba71635e31b6189394e7b79d3 upstream.
ftrace_dump() had a lot of issues. What ftrace_dump() does, is when
ftrace_dump_on_oops is set (via a kernel parameter or sysctl), it
will dump out the ftrace buffers to the console when either a oops,
panic, or a sysrq-z occurs.
This was written a long time ago when ftrace was fragile to recursion.
But it wasn't written well even for that.
There's a possible deadlock that can occur if a ftrace_dump() is happening
and an NMI triggers another dump. This is because it grabs a lock
before checking if the dump ran.
It also totally disables ftrace, and tracing for no good reasons.
As the ring_buffer now checks if it is read via a oops or NMI, where
there's a chance that the buffer gets corrupted, it will disable
itself. No need to have ftrace_dump() do the same.
ftrace_dump() is now cleaned up where it uses an atomic counter to
make sure only one dump happens at a time. A simple atomic_inc_return()
is enough that is needed for both other CPUs and NMIs. No need for
a spinlock, as if one CPU is running the dump, no other CPU needs
to do it too.
The tracing_on variable is turned off and not turned on. The original
code did this, but it wasn't pretty. By just disabling this variable
we get the result of not seeing traces that happen between crashes.
For sysrq-z, it doesn't get turned on, but the user can always write
a '1' to the tracing_on file. If they are using sysrq-z, then they should
know about tracing_on.
The new code is much easier to read and less error prone. No more
deadlock possibility when an NMI triggers here.
Reported-by: zhangwei(Jovi) <jovi.zhangwei@huawei.com>
25511a4776 "workqueue: reimplement CPU online rebinding to handle idle
workers" added CPU locality sanity check in process_one_work(). It
triggers if a worker is executing on a different CPU without UNBOUND
or REBIND set.
This works for all normal workers but rescuers can trigger this
spuriously when they're serving the unbound or a disassociated
global_cwq - rescuers don't have either flag set and thus its
gcwq->cpu can be a different value including %WORK_CPU_UNBOUND.
Fix it by additionally testing %GCWQ_DISASSOCIATED.
bug 1237774
Change-Id: I7ac841fb02f97c354f096df1715669acca0265b5
Reported-by: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
LKML-Refence: <20120721213656.GA7783@linux.vnet.ibm.com>
Reviewed-on: http://git-master/r/226758
commit 6f7a05d7018de222e40ca003721037a530979974 upstream.
Vitaliy reported that a per cpu HPET timer interrupt crashes the
system during hibernation. What happens is that the per cpu HPET timer
gets shut down when the nonboot cpus are stopped. When the nonboot
cpus are onlined again the HPET code sets up the MSI interrupt which
fires before the clock event device is registered. The event handler
is still set to hrtimer_interrupt, which then crashes the machine due
to highres mode not being active.
See http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=700333
There is no real good way to avoid that in the HPET code. The HPET
code alrady has a mechanism to detect spurious interrupts when event
handler == NULL for a similar reason.
We can handle that in the clockevent/tick layer and replace the
previous functional handler with a dummy handler like we do in
tick_setup_new_device().
The original clockevents code did this in clockevents_exchange_device(),
but that got removed by commit 7c1e76897 (clockevents: prevent
clockevent event_handler ending up handler_noop) which forgot to fix
it up in tick_shutdown(). Same issue with the broadcast device.
Reported-by: Vitaliy Fillipov <vitalif@yourcmc.ru>
Cc: Ben Hutchings <ben@decadent.org.uk>
Cc: 700333@bugs.debian.org
commit 3ac1707a13a3da9cfc8f242a15b2fae6df2c5f88 upstream.
The 3rd parameter of flex_array_prealloc() is the number of elements,
not the index of the last element.
The effect of the bug is, when opening cgroup.procs, a flex array will
be allocated and all elements of the array is allocated with
GFP_KERNEL flag, but the last one is GFP_ATOMIC, and if we fail to
allocate memory for it, it'll trigger a BUG_ON().
commit 8f294b5a139ee4b75e890ad5b443c93d1e558a8b upstream.
The settimeofday01 test in the LTP testsuite effectively does
gettimeofday(current time);
settimeofday(Jan 1, 1970 + 100 seconds);
settimeofday(current time);
This test causes a stack trace to be displayed on the console during the
setting of timeofday to Jan 1, 1970 + 100 seconds:
[ 131.066751] ------------[ cut here ]------------
[ 131.096448] WARNING: at kernel/time/clockevents.c:209 clockevents_program_event+0x135/0x140()
[ 131.104935] Hardware name: Dinar
[ 131.108150] Modules linked in: sg nfsv3 nfs_acl nfsv4 auth_rpcgss nfs dns_resolver fscache lockd sunrpc nf_conntrack_netbios_ns nf_conntrack_broadcast ipt_MASQUERADE ip6table_mangle ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6 iptable_nat nf_nat_ipv4 nf_nat iptable_mangle ipt_REJECT nf_conntrack_ipv4 nf_defrag_ipv4 xt_conntrack nf_conntrack ebtable_filter ebtables ip6table_filter ip6_tables iptable_filter ip_tables kvm_amd kvm sp5100_tco bnx2 i2c_piix4 crc32c_intel k10temp fam15h_power ghash_clmulni_intel amd64_edac_mod pcspkr serio_raw edac_mce_amd edac_core microcode xfs libcrc32c sr_mod sd_mod cdrom ata_generic crc_t10dif pata_acpi radeon i2c_algo_bit drm_kms_helper ttm drm ahci pata_atiixp libahci libata usb_storage i2c_core dm_mirror dm_region_hash dm_log dm_mod
[ 131.176784] Pid: 0, comm: swapper/28 Not tainted 3.8.0+ #6
[ 131.182248] Call Trace:
[ 131.184684] <IRQ> [<ffffffff810612af>] warn_slowpath_common+0x7f/0xc0
[ 131.191312] [<ffffffff8106130a>] warn_slowpath_null+0x1a/0x20
[ 131.197131] [<ffffffff810b9fd5>] clockevents_program_event+0x135/0x140
[ 131.203721] [<ffffffff810bb584>] tick_program_event+0x24/0x30
[ 131.209534] [<ffffffff81089ab1>] hrtimer_interrupt+0x131/0x230
[ 131.215437] [<ffffffff814b9600>] ? cpufreq_p4_target+0x130/0x130
[ 131.221509] [<ffffffff81619119>] smp_apic_timer_interrupt+0x69/0x99
[ 131.227839] [<ffffffff8161805d>] apic_timer_interrupt+0x6d/0x80
[ 131.233816] <EOI> [<ffffffff81099745>] ? sched_clock_cpu+0xc5/0x120
[ 131.240267] [<ffffffff814b9ff0>] ? cpuidle_wrap_enter+0x50/0xa0
[ 131.246252] [<ffffffff814b9fe9>] ? cpuidle_wrap_enter+0x49/0xa0
[ 131.252238] [<ffffffff814ba050>] cpuidle_enter_tk+0x10/0x20
[ 131.257877] [<ffffffff814b9c89>] cpuidle_idle_call+0xa9/0x260
[ 131.263692] [<ffffffff8101c42f>] cpu_idle+0xaf/0x120
[ 131.268727] [<ffffffff815f8971>] start_secondary+0x255/0x257
[ 131.274449] ---[ end trace 1151a50552231615 ]---
When we change the system time to a low value like this, the value of
timekeeper->offs_real will be a negative value.
It seems that the WARN occurs because an hrtimer has been started in the time
between the releasing of the timekeeper lock and the IPI call (via a call to
on_each_cpu) in clock_was_set() in the do_settimeofday() code. The end result
is that a REALTIME_CLOCK timer has been added with softexpires = expires =
KTIME_MAX. The hrtimer_interrupt() fires/is called and the loop at
kernel/hrtimer.c:1289 is executed. In this loop the code subtracts the
clock base's offset (which was set to timekeeper->offs_real in
do_settimeofday()) from the current hrtimer_cpu_base->expiry value (which
was KTIME_MAX):
KTIME_MAX - (a negative value) = overflow
A simple check for an overflow can resolve this problem. Using KTIME_MAX
instead of the overflow value will result in the hrtimer function being run,
and the reprogramming of the timer after that.
Signed-off-by: Prarit Bhargava <prarit@redhat.com>
[jstultz: Tweaked commit subject]
Signed-off-by: John Stultz <john.stultz@linaro.org>
commit 51fd36f3fad8447c487137ae26b9d0b3ce77bb25 upstream.
One can trigger an overflow when using ktime_add_ns() on a 32bit
architecture not supporting CONFIG_KTIME_SCALAR.
When passing a very high value for u64 nsec, e.g. 7881299347898368000
the do_div() function converts this value to seconds (7881299347) which
is still to high to pass to the ktime_set() function as long. The result
in is a negative value.
The problem on my system occurs in the tick-sched.c,
tick_nohz_stop_sched_tick() when time_delta is set to
timekeeping_max_deferment(). The check for time_delta < KTIME_MAX is
valid, thus ktime_add_ns() is called with a too large value resulting in
a negative expire value. This leads to an endless loop in the ticker code:
time_delta: 7881299347898368000
expires = ktime_add_ns(last_update, time_delta)
expires: negative value
This fix caps the value to KTIME_MAX.
This error doesn't occurs on 64bit or architectures supporting
CONFIG_KTIME_SCALAR (e.g. ARM, x86-32).
Signed-off-by: David Engraf <david.engraf@sysgo.com>
[jstultz: Minor tweaks to commit message & header]
commit 9f50afccfdc15d95d7331acddcb0f7703df089ae upstream.
The ftrace_graph_count can be decreased with a "!" pattern, so that
the enabled flag should be updated too.
Link: http://lkml.kernel.org/r/1365663698-2413-1-git-send-email-namhyung@kernel.org
commit ed6f1c996bfe4b6e520cf7a74b51cd6988d84420 upstream.
Check return value and bail out if it's NULL.
Link: http://lkml.kernel.org/r/1365553093-10180-2-git-send-email-namhyung@kernel.org
commit 39e30cd1537937d3c00ef87e865324e981434e5b upstream.
The first page was allocated separately, so no need to start from 0.
Link: http://lkml.kernel.org/r/1364820385-32027-2-git-send-email-namhyung@kernel.org
commit 4df297129f622bdc18935c856f42b9ddd18f9f28 upstream.
Currently, the depth reported in the stack tracer stack_trace file
does not match the stack_max_size file. This is because the stack_max_size
includes the overhead of stack tracer itself while the depth does not.
The first time a max is triggered, a calculation is not performed that
figures out the overhead of the stack tracer and subtracts it from
the stack_max_size variable. The overhead is stored and is subtracted
from the reported stack size for comparing for a new max.
Now the stack_max_size corresponds to the reported depth:
# cat stack_max_size
4640
# cat stack_trace
Depth Size Location (48 entries)
0) 4640 32 _raw_spin_lock+0x18/0x24
1) 4608 112 ____cache_alloc+0xb7/0x22d
2) 4496 80 kmem_cache_alloc+0x63/0x12f
3) 4416 16 mempool_alloc_slab+0x15/0x17
While testing against and older gcc on x86 that uses mcount instead
of fentry, I found that pasing in ip + MCOUNT_INSN_SIZE let the
stack trace show one more function deep which was missing before.
commit d4ecbfc49b4b1d4b597fb5ba9e4fa25d62f105c5 upstream.
When gcc 4.6 on x86 is used, the function tracer will use the new
option -mfentry which does a call to "fentry" at every function
instead of "mcount". The significance of this is that fentry is
called as the first operation of the function instead of the mcount
usage of being called after the stack.
This causes the stack tracer to show some bogus results for the size
of the last function traced, as well as showing "ftrace_call" instead
of the function. This is due to the stack frame not being set up
by the function that is about to be traced.
# cat stack_trace
0) 4824 216 ftrace_call+0x5/0x2f
The 216 size for ftrace_call includes both the ftrace_call stack
(which includes the saving of registers it does), as well as the
stack size of the parent.
To fix this, if CC_USING_FENTRY is defined, then the stack_tracer
will reserve the first item in stack_dump_trace[] array when
calling save_stack_trace(), and it will fill it in with the parent ip.
Then the code will look for the parent pointer on the stack and
give the real size of the parent's stack pointer:
# cat stack_trace
Depth Size Location (14 entries)
0) 2640 48 update_group_power+0x26/0x187
1) 2592 224 update_sd_lb_stats+0x2a5/0x4ac
2) 2368 160 find_busiest_group+0x31/0x1f1
3) 2208 256 load_balance+0xd9/0x662
I'm Cc'ing stable, although it's not urgent, as it only shows bogus
size for item #0, the rest of the trace is legit. It should still be
corrected in previous stable releases.
commit 87889501d0adfae10e3b0f0e6f2d7536eed9ae84 upstream.
Use the stack of stack_trace_call() instead of check_stack() as
the test pointer for max stack size. It makes it a bit cleaner
and a little more accurate.
Adding stable, as a later fix depends on this patch.
This reverts commit 846c314fd6124b5bd3a3db2624818f29616874a1.
Change-Id: Id0e9d586dfba4eb5743a6b07975d8d6667a478a6
Reviewed-on: http://git-master/r/222732
commit 8176cced706b5e5d15887584150764894e94e02f upstream.
implementations").
commit 383efcd00053ec40023010ce5034bd702e7ab373 upstream.
try_to_wake_up_local() should only be invoked to wake up another
task in the same runqueue and BUG_ON()s are used to enforce the
rule. Missing try_to_wake_up_local() can stall workqueue
execution but such stalls are likely to be finite either by
another work item being queued or the one blocked getting
unblocked. There's no reason to trigger BUG while holding rq
lock crashing the whole system.
Convert BUG_ON()s in try_to_wake_up_local() to WARN_ON_ONCE()s.
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Link: http://lkml.kernel.org/r/20130318192234.GD3042@htj.dyndns.org
