commit 3a142a0672b48a853f00af61f184c7341ac9c99d upstream.
When the per cpu timer is marked CLOCK_EVT_FEAT_C3STOP, then we only
can switch into oneshot mode, when the backup broadcast device
supports oneshot mode as well. Otherwise we would try to switch the
broadcast device into an unsupported mode unconditionally. This went
unnoticed so far as the current available broadcast devices support
oneshot mode. Seth unearthed this problem while debugging and working
around an hpet related BIOS wreckage.
Add the necessary check to tick_is_oneshot_available().
Reported-and-tested-by: Seth Forshee <seth.forshee@canonical.com>
LKML-Reference: <alpine.LFD.2.00.1102252231200.2701@localhost6.localdomain6>
commit 4fe757dd48a9e95e1a071291f15dda5421dacb66 upstream.
It was possible to call pmu::start() on an already running event. In
particular this lead so some wreckage as the hrtimer events would
re-initialize active timers.
This was due to throttled events being activated again by scheduling.
Scheduling in a context would add and force start events, resulting in
running events with a possible throttle status. The next tick to hit
that task will then try to unthrottle the event and call ->start() on
Reported-by: Jeff Moyer <jmoyer@redhat.com>
LKML-Reference: <new-submission>
commit 6d83f94db95cfe65d2a6359cccdf61cf087c2598 upstream.
With CONFIG_SHIRQ_DEBUG=y we call a newly installed interrupt handler
in request_threaded_irq().
The original implementation (commit a304e1b8) called the handler
_BEFORE_ it was installed, but that caused problems with handlers
calling disable_irq_nosync(). See commit 377bf1e4.
It's braindead in the first place to call disable_irq_nosync in shared
handlers, but ....
Moving this call after we installed the handler looks innocent, but it
is very subtle broken on SMP.
Interrupt handlers rely on the fact, that the irq core prevents
reentrancy.
Now this debug call violates that promise because we run the handler
w/o the IRQ_INPROGRESS protection - which we cannot apply here because
that would result in a possibly forever masked interrupt line.
A concurrent real hardware interrupt on a different CPU results in
handler reentrancy and can lead to complete wreckage, which was
unfortunately observed in reality and took a fricking long time to
debug.
Leave the code here for now. We want this debug feature, but that's
not easy to fix. We really should get rid of those
disable_irq_nosync() abusers and remove that function completely.
Cc: Anton Vorontsov <avorontsov@ru.mvista.com>
Cc: Arjan van de Ven <arjan@infradead.org>
commit c1ee6264280e740a9d3ff3feef38642cf0a57013 upstream.
Lars-Peter Clausen pointed out:
I stumbled upon this while looking through the existing archs using
SPARSE_IRQ. Even with SPARSE_IRQ the NR_IRQS is still the upper
limit for the number of IRQs.
Both PXA and MMP set NR_IRQS to IRQ_BOARD_START, with
IRQ_BOARD_START being the number of IRQs used by the core.
In various machine files the nr_irqs field of the ARM machine
defintion struct is then set to "IRQ_BOARD_START + NR_BOARD_IRQS".
As a result "nr_irqs" will greater then NR_IRQS which then again
causes the "allocated_irqs" bitmap in the core irq code to be
accessed beyond its size overwriting unrelated data.
The core code really misses a sanity check there.
This went unnoticed so far as by chance the compiler/linker places
data behind that bitmap which gets initialized later on those affected
platforms.
So the obvious fix would be to add a sanity check in early_irq_init()
and break all affected platforms. Though that check wants to be
backported to stable as well, which will require to fix all known
problematic platforms and probably some more yet not known ones as
well. Lots of churn.
A way simpler solution is to allocate a slightly larger bitmap and
avoid the whole churn w/o breaking anything. Add a few warnings when
an arch returns utter crap.
Reported-by: Lars-Peter Clausen <lars@metafoo.de>
Cc: Haojian Zhuang <haojian.zhuang@marvell.com>
Cc: Eric Miao <eric.y.miao@gmail.com>
commit 3233cdbd9fa347a6d6897a94cc6ed0302ae83c4f upstream.
MAYDAY_INITIAL_TIMEOUT is defined as HZ / 100 and depending on
configuration may end up 0 or 1. Even when it's 1, depending on when
the mayday timer is added in the current jiffy interval, it may expire
way before a jiffy has passed.
Make sure MAYDAY_INITIAL_TIMEOUT is at least two to guarantee that at
least a full jiffy has passed before calling rescuers.
Reported-by: Ray Jui <rjui@broadcom.com>
commit 7576958a9d5a4a677ad7dd40901cdbb6c1110c98 upstream.
After executing the matching works, a rescuer leaves the gcwq whether
there are more pending works or not. This may decrease the
concurrency level to zero and stall execution until a new work item is
queued on the gcwq.
Make rescuer wake up a regular worker when it leaves a gcwq if there
are more works to execute, so that execution isn't stalled.
commit 2e725a065b0153f0c449318da1923a120477633d upstream.
Currently we return 0 in swsusp_alloc() when alloc_image_page() fails.
Fix that. Also remove unneeded "error" variable since the only
useful value of error is -ENOMEM.
[rjw: Fixed up the changelog and changed subject.]
Signed-off-by: Stanislaw Gruszka <stf_xl@wp.pl>
commit 6037b715d6fab139742c3df8851db4c823081561 upstream.
Expand security_capable() to include cred, so that it can be usable in a
wider range of call sites.
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Signed-off-by: James Morris <jmorris@namei.org>
commit fb2b2a1d37f80cc818fd4487b510f4e11816e5e1 upstream.
In prepare_kernel_cred() since 2.6.29, put_cred(new) is called without
assigning new->usage when security_prepare_creds() returned an error. As a
result, memory for new and refcount for new->{user,group_info,tgcred} are
leaked because put_cred(new) won't call __put_cred() unless old->usage == 1.
Fix these leaks by assigning new->usage (and new->subscribers which was added
in 2.6.32) before calling security_prepare_creds().
commit 2edeaa34a6e3f2c43b667f6c4f7b27944b811695 upstream.
In cred_alloc_blank() since 2.6.32, abort_creds(new) is called with
new->security == NULL and new->magic == 0 when security_cred_alloc_blank()
returns an error. As a result, BUG() will be triggered if SELinux is enabled
or CONFIG_DEBUG_CREDENTIALS=y.
If CONFIG_DEBUG_CREDENTIALS=y, BUG() is called from __invalid_creds() because
cred->magic == 0. Failing that, BUG() is called from selinux_cred_free()
because selinux_cred_free() is not expecting cred->security == NULL. This does
not affect smack_cred_free(), tomoyo_cred_free() or apparmor_cred_free().
Fix these bugs by
(1) Set new->magic before calling security_cred_alloc_blank().
(2) Handle null cred->security in creds_are_invalid() and selinux_cred_free().
commit 8c6a98b22b750c9eb52653ba643faa17db8d3881 upstream.
Currently sysrq_enabled and __sysrq_enabled are initialised separately
and inconsistently, leading to sysrq being actually enabled by reported
as not enabled in sysfs. The first change to the sysfs configurable
synchronises these two:
static int __read_mostly sysrq_enabled = 1;
static int __sysrq_enabled;
Add a common define to carry the default for these preventing them becoming
out of sync again. Default this to 1 to mirror previous behaviour.
Signed-off-by: Andy Whitcroft <apw@canonical.com>
commit 4135038a582c20ffdadfcf6564852e0b72a20968 upstream.
Passing nowatchdog to kernel disables 2 things: creation of
watchdog threads AND initialization of percpu watchdog_hrtimer.
As hrtimers are initialized only at boot it's not possible to
enable watchdog later - for me all watchdog threads started to
eat 100% of CPU time, but they could just crash.
Additionally, even if these threads would start properly,
watchdog_disable_all_cpus was guarded by no_watchdog check, so
you couldn't disable watchdog.
To fix this, remove no_watchdog variable and use already
existing watchdog_enabled variable.
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com>
[ removed another no_watchdog instance ]
Signed-off-by: Don Zickus <dzickus@redhat.com>
Cc: Stephane Eranian <eranian@google.com>
LKML-Reference: <1296230433-6261-1-git-send-email-dzickus@redhat.com>
commit 6dc19899958e420a931274b94019e267e2396d3e upstream.
I noticed a failure where we hit the following WARN_ON in
generic_smp_call_function_interrupt:
if (!cpumask_test_and_clear_cpu(cpu, data->cpumask))
continue;
data->csd.func(data->csd.info);
refs = atomic_dec_return(&data->refs);
WARN_ON(refs < 0); <-------------------------
We atomically tested and cleared our bit in the cpumask, and yet the
number of cpus left (ie refs) was 0. How can this be?
It turns out commit 54fdade1c3332391948ec43530c02c4794a38172
("generic-ipi: make struct call_function_data lockless") is at fault. It
removes locking from smp_call_function_many and in doing so creates a
rather complicated race.
The problem comes about because:
- The smp_call_function_many interrupt handler walks call_function.queue
without any locking.
- We reuse a percpu data structure in smp_call_function_many.
- We do not wait for any RCU grace period before starting the next
Imagine a scenario where CPU A does two smp_call_functions back to back,
and CPU B does an smp_call_function in between. We concentrate on how CPU
C handles the calls:
CPU A CPU B CPU C CPU D
smp_call_function
walks
call_function.queue sees
data from CPU A on list
smp_call_function
walks
(stale) CPU A on list
smp_call_function int
clears last ref on A
list_del_rcu, unlock
smp_call_function reuses
percpu *data A
data->cpumask sees and
clears bit in cpumask
might be using old or new fn!
decrements refs below 0
set data->refs (too late!)
The important thing to note is since the interrupt handler walks a
potentially stale call_function.queue without any locking, then another
cpu can view the percpu *data structure at any time, even when the owner
is in the process of initialising it.
The following test case hits the WARN_ON 100% of the time on my PowerPC
box (having 128 threads does help :)
#include <linux/module.h>
#include <linux/init.h>
#define ITERATIONS 100
static void do_nothing_ipi(void *dummy)
static void do_ipis(struct work_struct *dummy)
int i;
for (i = 0; i < ITERATIONS; i++)
smp_call_function(do_nothing_ipi, NULL, 1);
printk(KERN_DEBUG "cpu %d finished\n", smp_processor_id());
static struct work_struct work[NR_CPUS];
static int __init testcase_init(void)
int cpu;
for_each_online_cpu(cpu) {
INIT_WORK(&work[cpu], do_ipis);
schedule_work_on(cpu, &work[cpu]);
return 0;
static void __exit testcase_exit(void)
module_init(testcase_init)
module_exit(testcase_exit)
MODULE_LICENSE("GPL");
MODULE_AUTHOR("Anton Blanchard");
I tried to fix it by ordering the read and the write of ->cpumask and
->refs. In doing so I missed a critical case but Paul McKenney was able
to spot my bug thankfully :) To ensure we arent viewing previous
iterations the interrupt handler needs to read ->refs then ->cpumask then
->refs _again_.
Thanks to Milton Miller and Paul McKenney for helping to debug this issue.
[miltonm@bga.com: add WARN_ON and BUG_ON, remove extra read of refs before initial read of mask that doesn't help (also noted by Peter Zijlstra), adjust comments, hopefully clarify scenario ]
[miltonm@bga.com: remove excess tests]
Signed-off-by: Milton Miller <miltonm@bga.com>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
commit 66832eb4baaaa9abe4c993ddf9113a79e39b9915 upstream.
Starting from perf_event_alloc()->perf_init_event(), the kernel
assumes that event->cpu is either -1 or the valid CPU number.
Change perf_event_alloc() to validate this argument early. This
also means we can remove the similar check in
find_get_context().
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Prasad <prasad@linux.vnet.ibm.com>
Cc: Roland McGrath <roland@redhat.com>
LKML-Reference: <20110118161032.GC693@redhat.com>
commit 22a4ec729017ba613337a28f306f94ba5023fe2e upstream.
If task == NULL, find_get_context() should always check that cpu
is correct.
Afaics, the bug was introduced by 38a81da2 "perf events: Clean
up pid passing", but even before that commit "&& cpu != -1" was
not exactly right, -ESRCH from find_task_by_vpid() is not
accurate.
LKML-Reference: <20110118161008.GB693@redhat.com>
commit 88d4f0db7fa8785859c1d637f9aac210932b6216 upstream.
Commit 927c7a9e92c4 ("perf: Fix race in callchains") introduced
a mismatch in the sizing of struct callchain_cpus_entries.
nr_cpu_ids must be used instead of num_possible_cpus(), or we
might get out of bound memory accesses on some machines.
LKML-Reference: <1295980851.3588.351.camel@edumazet-laptop>
commit 9ffdc6c37df131f89d52001e0ef03091b158826f upstream.
[ add {}'s to fix a warning ]
LKML-Reference: <1296230433-6261-3-git-send-email-dzickus@redhat.com>
commit 397357666de6b5b6adb5fa99f9758ec8cf30ac34 upstream.
If it was not possible to enable watchdog for any cpu, switch
watchdog_enabled back to 0, because it's visible via
kernel.watchdog sysctl.
LKML-Reference: <1296230433-6261-2-git-send-email-dzickus@redhat.com>
commit e159489baa717dbae70f9903770a6a4990865887 upstream.
Currently, the lockdep annotation in flush_work() requires exclusive
access on the workqueue the target work is queued on and triggers
warning if a work is trying to flush another work on the same
workqueue; however, this is no longer true as workqueues can now
execute multiple works concurrently.
This patch adds lock_map_acquire_read() and make process_one_work()
hold read access to the workqueue while executing a work and
start_flush_work() check for write access if concurrnecy level is one
or the workqueue has a rescuer (as only one execution resource - the
rescuer - is guaranteed to be available under memory pressure), and
read access if higher.
This better represents what's going on and removes spurious lockdep
warnings which are triggered by fake dependency chain created through
flush_work().
* Peter pointed out that flushing another work from a WQ_MEM_RECLAIM
wq breaks forward progress guarantee under memory pressure.
Condition check accordingly updated.
Reported-by: "Rafael J. Wysocki" <rjw@sisk.pl>
Tested-by: "Rafael J. Wysocki" <rjw@sisk.pl>
commit 06c3bc655697b19521901f9254eb0bbb2c67e7e8 upstream.
cpu_stopper_thread()
migration_cpu_stop()
__migrate_task()
deactivate_task()
dequeue_task()
dequeue_task_rq()
update_curr_rt()
Will call update_curr_rt() on rq->curr, which at that time is
rq->stop. The problem is that rq->stop.prio matches an RT prio and
thus falsely assumes its a rt_sched_class task.
Reported-Debuged-Tested-Acked-by: Thomas Gleixner <tglx@linutronix.de>
commit 068c5cc5ac7414a8e9eb7856b4bf3cc4d4744267 upstream.
By not notifying the controller of the on-exit move back to
init_css_set, we fail to move the task out of the previous
cgroup's cfs_rq. This leads to an opportunity for a
cgroup-destroy to come in and free the cgroup (there are no
active tasks left in it after all) to which the not-quite dead
task is still enqueued.
Reported-by: Miklos Vajna <vmiklos@frugalware.org>
Fixed-by: Mike Galbraith <efault@gmx.de>
LKML-Reference: <1293206353.29444.205.camel@laptop>
commit 6bf4123760a5aece6e4829ce90b70b6ffd751d65 upstream.
wait_for_completion_*_timeout() can return:
0: if the wait timed out
-ve: if the wait was interrupted
+ve: if the completion was completed.
As they currently return an 'unsigned long', the last two cases
are not easily distinguished which can easily result in buggy
code, as is the case for the recently added
wait_for_completion_interruptible_timeout() call in
net/sunrpc/cache.c
So change them both to return 'long'. As MAX_SCHEDULE_TIMEOUT
is LONG_MAX, a large +ve return value should never overflow.
Signed-off-by: NeilBrown <neilb@suse.de>
Cc: J. Bruce Fields <bfields@fieldses.org>
LKML-Reference: <20110105125016.64ccab0e@notabene.brown>
commit aa5bd67dcfdf9af34c7fa36ebc87d4e1f7e91873 upstream.
Since check_prlimit_permission always fails in the case of SUID/GUID
processes, such processes are not able to read or set their own limits.
This commit changes this by assuming that process can always read/change
its own limits.
Signed-off-by: Kacper Kornet <kornet@camk.edu.pl>
Acked-by: Jiri Slaby <jslaby@suse.cz>
commit 01e05e9a90b8f4c3997ae0537e87720eb475e532 upstream.
The wake_up_process() call in ptrace_detach() is spurious and not
interlocked with the tracee state. IOW, the tracee could be running or
sleeping in any place in the kernel by the time wake_up_process() is
called. This can lead to the tracee waking up unexpectedly which can be
dangerous.
The wake_up is spurious and should be removed but for now reduce its
toxicity by only waking up if the tracee is in TRACED or STOPPED state.
This bug can possibly be used as an attack vector. I don't think it
will take too much effort to come up with an attack which triggers oops
somewhere. Most sleeps are wrapped in condition test loops and should
be safe but we have quite a number of places where sleep and wakeup
conditions are expected to be interlocked. Although the window of
opportunity is tiny, ptrace can be used by non-privileged users and with
some loading the window can definitely be extended and exploited.
Acked-by: Roland McGrath <roland@redhat.com>
Acked-by: Oleg Nesterov <oleg@redhat.com>
commit f1a06390d013244e721372b3f9b66e39b6429c71 upstream.
move_native_irq() masks and unmasks the interrupt line
unconditionally, but the interrupt line might be masked due to a
threaded oneshot handler in progress. Unmasking the line in that case
can lead to interrupt storms. Observed on PREEMPT_RT.
Originally-from: Ingo Molnar <mingo@elte.hu>
commit 1dbd1951f39e13da579ffe879cce19586d0462de upstream.
While running my ftrace stress test, this showed up:
BUG: sleeping function called from invalid context at mm/mmap.c:233
note: cat[3293] exited with preempt_count 1
The bug was introduced by commit 91e86e560d0b3ce4c5fc64fd2bbb99f856a30a4e
("tracing: Fix recursive user stack trace")
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
LKML-Reference: <4D0089AC.1020802@cn.fujitsu.com>
The error message 'NMI watchdog failed to create perf event...'
does not make it clear that this is a fatal error for the
watchdog. It also currently prints the error value as a
pointer, rather than extracting the error code with PTR_ERR().
Fix that.
Add a note to the description of the 'nowatchdog' kernel
parameter to associate it with this message.
Reported-by: Cesare Leonardi <celeonar@gmail.com>
Cc: 599368@bugs.debian.org
Cc: 608138@bugs.debian.org
Cc: Don Zickus <dzickus@redhat.com>
Cc: <stable@kernel.org> # .37.x and later
LKML-Reference: <1294009362.3167.126.camel@localhost>
When racing on adding into user cache, the new allocated from mm slab
is freed without putting user namespace.
Since the user namespace is already operated by getting, putting has
to be issued.
Signed-off-by: Hillf Danton <dhillf@gmail.com>
Acked-by: Serge Hallyn <serge@hallyn.com>
Cc: stable@kernel.org
* 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
ring_buffer: Off-by-one and duplicate events in ring_buffer_read_page
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu:
percpu: print out alloc information with KERN_DEBUG instead of KERN_INFO
kthread_work: make lockdep happy
Fix two related problems in the event-copying loop of
ring_buffer_read_page.
The loop condition for copying events is off-by-one.
"len" is the remaining space in the caller-supplied page.
"size" is the size of the next event (or two events).
If len == size, then there is just enough space for the next event.
size was set to rb_event_ts_length, which may include the size of two
events if the first event is a time-extend, in order to assure time-
extends are kept together with the event after it. However,
rb_advance_reader always advances by one event. This would result in the
event after any time-extend being duplicated. Instead, get the size of
a single event for the memcpy, but use rb_event_ts_length for the loop
condition.
Signed-off-by: David Sharp <dhsharp@google.com>
LKML-Reference: <1293064704-8101-1-git-send-email-dhsharp@google.com>
LKML-Reference: <AANLkTin7nLrRPc9qGjdjHbeVDDWiJjAiYyb-L=gH85bx@mail.gmail.com>
The taskstats structure is internally aligned on 8 byte boundaries but the
layout of the aggregrate reply, with two NLA headers and the pid (each 4
bytes), actually force the entire structure to be unaligned. This causes
the kernel to issue unaligned access warnings on some architectures like
ia64. Unfortunately, some software out there doesn't properly unroll the
NLA packet and assumes that the start of the taskstats structure will
always be 20 bytes from the start of the netlink payload. Aligning the
start of the taskstats structure breaks this software, which we don't
want. So, for now the alignment only happens on architectures that
require it and those users will have to update to fixed versions of those
packages. Space is reserved in the packet only when needed. This ifdef
should be removed in several years e.g. 2012 once we can be confident
that fixed versions are installed on most systems. We add the padding
before the aggregate since the aggregate is already a defined type.
Commit 85893120 ("delayacct: align to 8 byte boundary on 64-bit systems")
previously addressed the alignment issues by padding out the pid field.
This was supposed to be a compatible change but the circumstances
described above mean that it wasn't. This patch backs out that change,
since it was a hack, and introduces a new NULL attribute type to provide
the padding. Padding the response with 4 bytes avoids allocating an
aligned taskstats structure and copying it back. Since the structure
weighs in at 328 bytes, it's too big to do it on the stack.
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
Reported-by: Brian Rogers <brian@xyzw.org>
Cc: Jeff Mahoney <jeffm@suse.com>
Cc: Guillaume Chazarain <guichaz@gmail.com>
Cc: Balbir Singh <balbir@in.ibm.com>
spinlock in kthread_worker and wait_queue_head in kthread_work both
should be lockdep sensible, so change the interface to make it
suiltable for CONFIG_LOCKDEP.
tj: comment update
Reported-by: Nicolas <nicolas.mailhot@laposte.net>
Signed-off-by: Yong Zhang <yong.zhang0@gmail.com>
Signed-off-by: Andy Walls <awalls@md.metrocast.net>
Tested-by: Andy Walls <awalls@md.metrocast.net>
Cc: Tejun Heo <tj@kernel.org>
* 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
sched: Remove debugging check
Linus reported that the new warning introduced by commit f26f9aff6aaf
"Sched: fix skip_clock_update optimization" triggers. The need_resched
flag can be set by other CPUs asynchronously so this debug check is
bogus - remove it.
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
LKML-Reference: <AANLkTinJ8hAG1TpyC+CSYPR47p48+1=E7fiC45hMXT_1@mail.gmail.com>
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86-32: Make sure we can map all of lowmem if we need to
x86, vt-d: Handle previous faults after enabling fault handling
x86: Enable the intr-remap fault handling after local APIC setup
x86, vt-d: Fix the vt-d fault handling irq migration in the x2apic mode
x86, vt-d: Quirk for masking vtd spec errors to platform error handling logic
x86, xsave: Use alloc_bootmem_align() instead of alloc_bootmem()
bootmem: Add alloc_bootmem_align()
x86, gcc-4.6: Use gcc -m options when building vdso
x86: HPET: Chose a paranoid safe value for the ETIME check
x86: io_apic: Avoid unused variable warning when CONFIG_GENERIC_PENDING_IRQ=n
perf: Fix off by one in perf_swevent_init()
perf: Fix duplicate events with multiple-pmu vs software events
ftrace: Have recordmcount honor endianness in fn_ELF_R_INFO
scripts/tags.sh: Add magic for trace-events
tracing: Fix panic when lseek() called on "trace" opened for writing
sched: Fix the irqtime code for 32bit
sched: Fix the irqtime code to deal with u64 wraps
nohz: Fix get_next_timer_interrupt() vs cpu hotplug
sched: Cure more NO_HZ load average woes
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6:
x86: avoid high BIOS area when allocating address space
x86: avoid E820 regions when allocating address space
x86: avoid low BIOS area when allocating address space
resources: add arch hook for preventing allocation in reserved areas
Revert "resources: support allocating space within a region from the top down"
Revert "PCI: allocate bus resources from the top down"
Revert "x86/PCI: allocate space from the end of a region, not the beginning"
Revert "x86: allocate space within a region top-down"
Revert "PCI: fix pci_bus_alloc_resource() hang, prefer positive decode"
PCI: Update MCP55 quirk to not affect non HyperTransport variants
This adds arch_remove_reservations(), which an arch can implement if it
needs to protect part of the address space from allocation.
Sometimes that can be done by just putting a region in the resource tree,
but there are cases where that doesn't work well. For example, x86 BIOS
E820 reservations are not related to devices, so they may overlap part of,
all of, or more than a device resource, so they may not end up at the
correct spot in the resource tree.
Acked-by: H. Peter Anvin <hpa@zytor.com>
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
This reverts commit e7f8567db9a7f6b3151b0b275e245c1cef0d9c70.
Commit 3624eb0 (PM / Hibernate: Modify signature used to mark swap)
attempted to modify hibernate signature used to mark swap partitions
containing hibernation images, so that old kernels don't try to
handle compressed images. However, this change broke resume from
hibernation on Fedora 14 that apparently doesn't pass the resume=
argument to the kernel and tries to trigger resume from early user
space. This doesn't work, because the signature is now different,
so the old signature has to be restored to avoid the problem.
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=22732 .
Reported-by: Dr. David Alan Gilbert <linux@treblig.org>
Reported-by: Zhang Rui <rui.zhang@intel.com>
Reported-by: Pascal Chapperon <pascal.chapperon@wanadoo.fr>
The user-space hibernation sends a wrong notification after the image
restoration because of thinko for the file flag check. RDONLY
corresponds to hibernation and WRONLY to restoration, confusingly.
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into perf/urgent
Since the irqtime accounting is using non-atomic u64 and can be read
from remote cpus (writes are strictly cpu local, reads are not) we
have to deal with observing partial updates.
When we do observe partial updates the clock movement (in particular,
->clock_task movement) will go funny (in either direction), a
subsequent clock update (observing the full update) will make it go
funny in the oposite direction.
Since we rely on these clocks to be strictly monotonic we cannot
suffer backwards motion. One possible solution would be to simply
ignore all backwards deltas, but that will lead to accounting
artefacts, most notable: clock_task + irq_time != clock, this
inaccuracy would end up in user visible stats.
Therefore serialize the reads using a seqcount.
Reviewed-by: Venkatesh Pallipadi <venki@google.com>
Reported-by: Mikael Pettersson <mikpe@it.uu.se>
Tested-by: Mikael Pettersson <mikpe@it.uu.se>
LKML-Reference: <1292242434.6803.200.camel@twins>
Some ARM systems have a short sched_clock() [ which needs to be fixed
too ], but this exposed a bug in the irq_time code as well, it doesn't
deal with wraps at all.
Fix the irq_time code to deal with u64 wraps by re-writing the code to
only use delta increments, which avoids the whole issue.
LKML-Reference: <1292242433.6803.199.camel@twins>
The perf_swevent_enabled[] array has PERF_COUNT_SW_MAX elements.
LKML-Reference: <20101024195041.GT5985@bicker>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq:
workqueue: It is likely that WORKER_NOT_RUNNING is true
MAINTAINERS: Add workqueue entry
workqueue: check the allocation of system_unbound_wq
Running the annotate branch profiler on three boxes, including my
main box that runs firefox, evolution, xchat, and is part of the distcc farm,
showed this with the likelys in the workqueue code:
correct incorrect % Function File Line
96 996253 99 wq_worker_sleeping workqueue.c 703
96 996247 99 wq_worker_waking_up workqueue.c 677
The likely()s in this case were assuming that WORKER_NOT_RUNNING will
most likely be false. But this is not the case. The reason is
(and shown by adding trace_printks and testing it) that most of the time
WORKER_PREP is set.
In worker_thread() we have:
worker_clr_flags(worker, WORKER_PREP);
[ do work stuff ]
worker_set_flags(worker, WORKER_PREP, false);
(that 'false' means not to wake up an idle worker)
The wq_worker_sleeping() is called from schedule when a worker thread
is putting itself to sleep. Which happens most of the time outside
of that [ do work stuff ].
The wq_worker_waking_up is called by the wakeup worker code, which
is also callod outside that [ do work stuff ].
Thus, the likely and unlikely used by those two functions are actually
backwards.
Remove the annotation and let gcc figure it out.
Acked-by: Tejun Heo <tj@kernel.org>
This fixes a bug as seen on 2.6.32 based kernels where timers got
enqueued on offline cpus.
If a cpu goes offline it might still have pending timers. These will
be migrated during CPU_DEAD handling after the cpu is offline.
However while the cpu is going offline it will schedule the idle task
which will then call tick_nohz_stop_sched_tick().
That function in turn will call get_next_timer_intterupt() to figure
out if the tick of the cpu can be stopped or not. If it turns out that
the next tick is just one jiffy off (delta_jiffies == 1)
tick_nohz_stop_sched_tick() incorrectly assumes that the tick should
not stop and takes an early exit and thus it won't update the load
balancer cpu.
Just afterwards the cpu will be killed and the load balancer cpu could
be the offline cpu.
On 2.6.32 based kernel get_nohz_load_balancer() gets called to decide
on which cpu a timer should be enqueued (see __mod_timer()). Which
leads to the possibility that timers get enqueued on an offline cpu.
These will never expire and can cause a system hang.
This has been observed 2.6.32 kernels. On current kernels
__mod_timer() uses get_nohz_timer_target() which doesn't have that
problem. However there might be other problems because of the too
early exit tick_nohz_stop_sched_tick() in case a cpu goes offline.
The easiest and probably safest fix seems to be to let
get_next_timer_interrupt() just lie and let it say there isn't any
pending timer if the current cpu is offline.
I also thought of moving migrate_[hr]timers() from CPU_DEAD to
CPU_DYING, but seeing that there already have been fixes at least in
the hrtimer code in this area I'm afraid that this could add new
subtle bugs.
LKML-Reference: <20101201091109.GA8984@osiris.boeblingen.de.ibm.com>
idle_balance() drops/retakes rq->lock, leaving the previous task
vulnerable to set_tsk_need_resched(). Clear it after we return
from balancing instead, and in setup_thread_stack() as well, so
no successfully descheduled or never scheduled task has it set.
Need resched confused the skip_clock_update logic, which assumes
that the next call to update_rq_clock() will come nearly immediately
after being set. Make the optimization robust against the waking
a sleeper before it sucessfully deschedules case by checking that
the current task has not been dequeued before setting the flag,
since it is that useless clock update we're trying to save, and
clear unconditionally in schedule() proper instead of conditionally
in put_prev_task().
Signed-off-by: Mike Galbraith <efault@gmx.de>
Reported-by: Bjoern B. Brandenburg <bbb.lst@gmail.com>
Tested-by: Yong Zhang <yong.zhang0@gmail.com>
LKML-Reference: <1291802742.1417.9.camel@marge.simson.net>
