commit f362b73244fb16ea4ae127ced1467dd8adaa7733 upstream.
Using a program like the following:
#include <stdlib.h>
#include <unistd.h>
#include <sys/types.h>
#include <sys/wait.h>
int main() {
id_t id;
siginfo_t infop;
pid_t res;
id = fork();
if (id == 0) { sleep(1); exit(0); }
kill(id, SIGSTOP);
alarm(1);
waitid(P_PID, id, &infop, WCONTINUED);
return 0;
to call waitid() on a stopped process results in access to the child task's
credentials without the RCU read lock being held - which may be replaced in the
meantime - eliciting the following warning:
[ INFO: suspicious rcu_dereference_check() usage. ]
kernel/exit.c:1460 invoked rcu_dereference_check() without protection!
rcu_scheduler_active = 1, debug_locks = 1
2 locks held by waitid02/22252:
#0: (tasklist_lock){.?.?..}, at: [<ffffffff81061ce5>] do_wait+0xc5/0x310
#1: (&(&sighand->siglock)->rlock){-.-...}, at: [<ffffffff810611da>]
wait_consider_task+0x19a/0xbe0
stack backtrace:
Pid: 22252, comm: waitid02 Not tainted 2.6.35-323cd+ #3
Call Trace:
[<ffffffff81095da4>] lockdep_rcu_dereference+0xa4/0xc0
[<ffffffff81061b31>] wait_consider_task+0xaf1/0xbe0
[<ffffffff81061d15>] do_wait+0xf5/0x310
[<ffffffff810620b6>] sys_waitid+0x86/0x1f0
[<ffffffff8105fce0>] ? child_wait_callback+0x0/0x70
[<ffffffff81003282>] system_call_fastpath+0x16/0x1b
This is fixed by holding the RCU read lock in wait_task_continued() to ensure
that the task's current credentials aren't destroyed between us reading the
cred pointer and us reading the UID from those credentials.
Furthermore, protect wait_task_stopped() in the same way.
We don't need to keep holding the RCU read lock once we've read the UID from
the credentials as holding the RCU read lock doesn't stop the target task from
changing its creds under us - so the credentials may be outdated immediately
after we've read the pointer, lock or no lock.
Signed-off-by: Daniel J Blueman <daniel.blueman@gmail.com>
Acked-by: Oleg Nesterov <oleg@redhat.com>
commit 6715045ddc7472a22be5e49d4047d2d89b391f45 upstream.
There is a problem in hibernate_preallocate_memory() that it calls
preallocate_image_memory() with an argument that may be greater than
the total number of available non-highmem memory pages. If that's
the case, the OOM condition is guaranteed to trigger, which in turn
can cause significant slowdown to occur during hibernation.
To avoid that, make preallocate_image_memory() adjust its argument
before calling preallocate_image_pages(), so that the total number of
saveable non-highem pages left is not less than the minimum size of
a hibernation image. Change hibernate_preallocate_memory() to try to
allocate from highmem if the number of pages allocated by
preallocate_image_memory() is too low.
Modify free_unnecessary_pages() to take all possible memory
allocation patterns into account.
Reported-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Tested-by: M. Vefa Bicakci <bicave@superonline.com>
commit e75e863dd5c7d96b91ebbd241da5328fc38a78cc upstream.
We have 32-bit variable overflow possibility when multiply in
task_times() and thread_group_times() functions. When the
overflow happens then the scaled utime value becomes erroneously
small and the scaled stime becomes i erroneously big.
Reported here:
https://bugzilla.redhat.com/show_bug.cgi?id=633037
https://bugzilla.kernel.org/show_bug.cgi?id=16559
Reported-by: Michael Chapman <redhat-bugzilla@very.puzzling.org>
Reported-by: Ciriaco Garcia de Celis <sysman@etherpilot.com>
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
Cc: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
LKML-Reference: <20100914143513.GB8415@redhat.com>
commit 950eaaca681c44aab87a46225c9e44f902c080aa upstream.
[ 23.584719]
[ 23.584720] ===================================================
[ 23.585059] [ INFO: suspicious rcu_dereference_check() usage. ]
[ 23.585176] ---------------------------------------------------
[ 23.585176] kernel/pid.c:419 invoked rcu_dereference_check() without protection!
[ 23.585176]
[ 23.585176] other info that might help us debug this:
[ 23.585176]
[ 23.585176]
[ 23.585176] rcu_scheduler_active = 1, debug_locks = 1
[ 23.585176] 1 lock held by rc.sysinit/728:
[ 23.585176] #0: (tasklist_lock){.+.+..}, at: [<ffffffff8104771f>] sys_setpgid+0x5f/0x193
[ 23.585176]
[ 23.585176] stack backtrace:
[ 23.585176] Pid: 728, comm: rc.sysinit Not tainted 2.6.36-rc2 #2
[ 23.585176] Call Trace:
[ 23.585176] [<ffffffff8105b436>] lockdep_rcu_dereference+0x99/0xa2
[ 23.585176] [<ffffffff8104c324>] find_task_by_pid_ns+0x50/0x6a
[ 23.585176] [<ffffffff8104c35b>] find_task_by_vpid+0x1d/0x1f
[ 23.585176] [<ffffffff81047727>] sys_setpgid+0x67/0x193
[ 23.585176] [<ffffffff810029eb>] system_call_fastpath+0x16/0x1b
[ 24.959669] type=1400 audit(1282938522.956:4): avc: denied { module_request } for pid=766 comm="hwclock" kmod="char-major-10-135" scontext=system_u:system_r:hwclock_t:s0 tcontext=system_u:system_r:kernel_t:s0 tclas
It turns out that the setpgid() system call fails to enter an RCU
read-side critical section before doing a PID-to-task_struct translation.
This commit therefore does rcu_read_lock() before the translation, and
also does rcu_read_unlock() after the last use of the returned pointer.
Reported-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Jiri Slaby <jslaby@suse.cz>
commit 068e35eee9ef98eb4cab55181977e24995d273be upstream.
Hardware breakpoints can't be registered within pid namespaces
because tsk->pid is passed rather than the pid in the current
namespace.
(See https://bugzilla.kernel.org/show_bug.cgi?id=17281 )
This is a quick fix demonstrating the problem but is not the
best method of solving the problem since passing pids internally
is not the best way to avoid pid namespace bugs. Subsequent patches
will show a better solution.
Much thanks to Frederic Weisbecker <fweisbec@gmail.com> for doing
the bulk of the work finding this bug.
Reported-by: Robin Green <greenrd@greenrd.org>
Signed-off-by: Matt Helsley <matthltc@us.ibm.com>
Cc: Prasad <prasad@linux.vnet.ibm.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Mahesh Salgaonkar <mahesh@linux.vnet.ibm.com>
LKML-Reference: <f63454af09fb1915717251570423eb9ddd338340.1284407762.git.matthltc@us.ibm.com>
commit c41d68a513c71e35a14f66d71782d27a79a81ea6 upstream.
compat_alloc_user_space() expects the caller to independently call
access_ok() to verify the returned area. A missing call could
introduce problems on some architectures.
This patch incorporates the access_ok() check into
compat_alloc_user_space() and also adds a sanity check on the length.
The existing compat_alloc_user_space() implementations are renamed
arch_compat_alloc_user_space() and are used as part of the
implementation of the new global function.
This patch assumes NULL will cause __get_user()/__put_user() to either
fail or access userspace on all architectures. This should be
followed by checking the return value of compat_access_user_space()
for NULL in the callers, at which time the access_ok() in the callers
can also be removed.
Reported-by: Ben Hawkes <hawkes@sota.gen.nz>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Acked-by: Chris Metcalf <cmetcalf@tilera.com>
Acked-by: Tony Luck <tony.luck@intel.com>
Cc: Helge Deller <deller@gmx.de>
Cc: James Bottomley <jejb@parisc-linux.org>
Cc: Kyle McMartin <kyle@mcmartin.ca>
commit 1c24de60e50fb19b94d94225458da17c720f0729 upstream.
gid_t is a unsigned int. If group_info contains a gid greater than
MAX_INT, groups_search() function may look on the wrong side of the search
tree.
This solves some unfair "permission denied" problems.
Signed-off-by: Jerome Marchand <jmarchan@redhat.com>
commit 85a0fdfd0f967507f3903e8419bc7e408f5a59de upstream.
The gcov-kernel infrastructure expects that each object file is loaded
only once. This may not be true, e.g. when loading multiple kernel
modules which are linked to the same object file. As a result, loading
such kernel modules will result in incorrect gcov results while unloading
will cause a null-pointer dereference.
This patch fixes these problems by changing the gcov-kernel infrastructure
so that multiple profiling data sets can be associated with one debugfs
entry. It applies to 2.6.36-rc1.
Signed-off-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com>
Reported-by: Werner Spies <werner.spies@thalesgroup.com>
commit df09162550fbb53354f0c88e85b5d0e6129ee9cc upstream.
Be sure to avoid entering t_show() with FTRACE_ITER_HASH set without
having properly started the iterator to iterate the hash. This case is
degenerate and, as discovered by Robert Swiecki, can cause t_hash_show()
to misuse a pointer. This causes a NULL ptr deref with possible security
implications. Tracked as CVE-2010-3079.
Cc: Robert Swiecki <swiecki@google.com>
Cc: Eugene Teo <eugene@redhat.com>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
commit 9c55cb12c1c172e2d51e85fbb5a4796ca86b77e7 upstream.
Reading the file set_ftrace_filter does three things.
1) shows whether or not filters are set for the function tracer
2) shows what functions are set for the function tracer
3) shows what triggers are set on any functions
3 is independent from 1 and 2.
The way this file currently works is that it is a state machine,
and as you read it, it may change state. But this assumption breaks
when you use lseek() on the file. The state machine gets out of sync
and the t_show() may use the wrong pointer and cause a kernel oops.
Luckily, this will only kill the app that does the lseek, but the app
dies while holding a mutex. This prevents anyone else from using the
set_ftrace_filter file (or any other function tracing file for that matter).
A real fix for this is to rewrite the code, but that is too much for
a -rc release or stable. This patch simply disables llseek on the
set_ftrace_filter() file for now, and we can do the proper fix for the
next major release.
Reported-by: Robert Swiecki <swiecki@google.com>
Cc: Chris Wright <chrisw@sous-sol.org>
Cc: Tavis Ormandy <taviso@google.com>
Cc: vendor-sec@lst.de
commit 3aaba20f26f58843e8f20611e5c0b1c06954310f upstream.
While we are reading trace_stat/functionX and someone just
disabled function_profile at that time, we can trigger this:
divide error: 0000 [#1] PREEMPT SMP
EIP is at function_stat_show+0x90/0x230
This fix just takes the ftrace_profile_lock and checks if
rec->counter is 0. If it's 0, we know the profile buffer
has been reset.
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
LKML-Reference: <4C723644.4040708@cn.fujitsu.com>
commit 9d0f4dcc5c4d1c5dd01172172684a45b5f49d740 upstream.
There is a scalability issue for current implementation of optimistic
mutex spin in the kernel. It is found on a 8 node 64 core Nehalem-EX
system (HT mode).
The intention of the optimistic mutex spin is to busy wait and spin on a
mutex if the owner of the mutex is running, in the hope that the mutex
will be released soon and be acquired, without the thread trying to
acquire mutex going to sleep. However, when we have a large number of
threads, contending for the mutex, we could have the mutex grabbed by
other thread, and then another ……, and we will keep spinning, wasting cpu
cycles and adding to the contention. One possible fix is to quit
spinning and put the current thread on wait-list if mutex lock switch to
a new owner while we spin, indicating heavy contention (see the patch
included).
I did some testing on a 8 socket Nehalem-EX system with a total of 64
cores. Using Ingo's test-mutex program that creates/delete files with 256
threads (http://lkml.org/lkml/2006/1/8/50) , I see the following speed up
after putting in the mutex spin fix:
./mutex-test V 256 10
Ops/sec
2.6.34 62864
With fix 197200
Repeating the test with Aim7 fserver workload, again there is a speed up
with the fix:
Jobs/min
2.6.34 91657
With fix 149325
To look at the impact on the distribution of mutex acquisition time, I
collected the mutex acquisition time on Aim7 fserver workload with some
instrumentation. The average acquisition time is reduced by 48% and
number of contentions reduced by 32%.
#contentions Time to acquire mutex (cycles)
2.6.34 72973 44765791
With fix 49210 23067129
The histogram of mutex acquisition time is listed below. The acquisition
time is in 2^bin cycles. We see that without the fix, the acquisition
time is mostly around 2^26 cycles. With the fix, we the distribution get
spread out a lot more towards the lower cycles, starting from 2^13.
However, there is an increase of the tail distribution with the fix at
2^28 and 2^29 cycles. It seems a small price to pay for the reduced
average acquisition time and also getting the cpu to do useful work.
Mutex acquisition time distribution (acq time = 2^bin cycles):
2.6.34 With Fix
bin #occurrence % #occurrence %
11 2 0.00% 120 0.24%
12 10 0.01% 790 1.61%
13 14 0.02% 2058 4.18%
14 86 0.12% 3378 6.86%
15 393 0.54% 4831 9.82%
16 710 0.97% 4893 9.94%
17 815 1.12% 4667 9.48%
18 790 1.08% 5147 10.46%
19 580 0.80% 6250 12.70%
20 429 0.59% 6870 13.96%
21 311 0.43% 1809 3.68%
22 255 0.35% 2305 4.68%
23 317 0.44% 916 1.86%
24 610 0.84% 233 0.47%
25 3128 4.29% 95 0.19%
26 63902 87.69% 122 0.25%
27 619 0.85% 286 0.58%
28 0 0.00% 3536 7.19%
29 0 0.00% 903 1.83%
30 0 0.00% 0 0.00%
I've done similar experiments with 2.6.35 kernel on smaller boxes as
well. One is on a dual-socket Westmere box (12 cores total, with HT).
Another experiment is on an old dual-socket Core 2 box (4 cores total, no
HT)
On the 12-core Westmere box, I see a 250% increase for Ingo's mutex-test
program with my mutex patch but no significant difference in aim7's
fserver workload.
On the 4-core Core 2 box, I see the difference with the patch for both
mutex-test and aim7 fserver are negligible.
So far, it seems like the patch has not caused regression on smaller
systems.
Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
LKML-Reference: <1282168827.9542.72.camel@schen9-DESK>
commit c7dcf87a6881bf796faee83003163eb3de41a309 upstream.
Early 4.3 versions of gcc apparently aggressively optimize the raw
time accumulation loop, replacing it with a divide.
On 32bit systems, this causes the following link errors:
undefined reference to `__umoddi3'
undefined reference to `__udivdi3'
The gcc issue has been fixed in 4.4 and greater.
This patch replaces the accumulation loop with a do_div, as suggested
by Linus.
Signed-off-by: John Stultz <johnstul@us.ibm.com>
CC: Jason Wessel <jason.wessel@windriver.com>
CC: Larry Finger <Larry.Finger@lwfinger.net>
CC: Ingo Molnar <mingo@elte.hu>
CC: Linus Torvalds <torvalds@linux-foundation.org>
commit deda2e81961e96be4f2c09328baca4710a2fd1a0 upstream.
The tv_nsec is a long and when added to the shifted interval it can wrap
and become negative which later causes looping problems in the
getrawmonotonic(). The edge case occurs when the system has slept for
a short period of time of ~2 seconds.
A trace printk of the values in this patch illustrate the problem:
ftrace time stamp: log
43.716079: logarithmic_accumulation: raw: 3d0913 tv_nsec d687faa
43.718513: logarithmic_accumulation: raw: 3d0913 tv_nsec da588bd
43.722161: logarithmic_accumulation: raw: 3d0913 tv_nsec de291d0
46.349925: logarithmic_accumulation: raw: 7a122600 tv_nsec e1f9ae3
46.349930: logarithmic_accumulation: raw: 1e848980 tv_nsec 8831c0e3
The kernel starts looping at 46.349925 in the getrawmonotonic() due to
the negative value from adding the raw value to tv_nsec.
A simple solution is to accumulate into a u64, and then normalize it
to a timespec_t.
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
[ Reworked variable names and simplified some of the code. - John ]
commit 297c5eee372478fc32fec5fe8eed711eedb13f3d upstream.
It's a really simple list, and several of the users want to go backwards
in it to find the previous vma. So rather than have to look up the
previous entry with 'find_vma_prev()' or something similar, just make it
doubly linked instead.
Tested-by: Ian Campbell <ijc@hellion.org.uk>
commit 18fab912d4fa70133df164d2dcf3310be0c38c34 upstream.
With the configuration: CONFIG_DEBUG_PAGEALLOC=y and Shaohua's patch:
[PATCH]x86: make spurious_fault check correct pte bit
Function call graph trace with the following will trigger a page fault.
# cd /sys/kernel/debug/tracing/
# echo function_graph > current_tracer
# cat per_cpu/cpu1/trace_pipe_raw > /dev/null
BUG: unable to handle kernel paging request at ffff880006e99000
IP: [<ffffffff81085572>] rb_event_length+0x1/0x3f
PGD 1b19063 PUD 1b1d063 PMD 3f067 PTE 6e99160
Oops: 0000 [#1] SMP DEBUG_PAGEALLOC
last sysfs file: /sys/devices/virtual/net/lo/operstate
CPU 1
Modules linked in:
Pid: 1982, comm: cat Not tainted 2.6.35-rc6-aes+ #300 /Bochs
RIP: 0010:[<ffffffff81085572>] [<ffffffff81085572>] rb_event_length+0x1/0x3f
RSP: 0018:ffff880006475e38 EFLAGS: 00010006
RAX: 0000000000000ff0 RBX: ffff88000786c630 RCX: 000000000000001d
RDX: ffff880006e98000 RSI: 0000000000000ff0 RDI: ffff880006e99000
RBP: ffff880006475eb8 R08: 000000145d7008bd R09: 0000000000000000
R10: 0000000000008000 R11: ffffffff815d9336 R12: ffff880006d08000
R13: ffff880006e605d8 R14: 0000000000000000 R15: 0000000000000018
FS: 00007f2b83e456f0(0000) GS:ffff880002100000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: ffff880006e99000 CR3: 00000000064a8000 CR4: 00000000000006e0
Process cat (pid: 1982, threadinfo ffff880006474000, task ffff880006e40770)
Stack:
ffff880006475eb8 ffffffff8108730f 0000000000000ff0 000000145d7008bd
<0> ffff880006e98010 ffff880006d08010 0000000000000296 ffff88000786c640
<0> ffffffff81002956 0000000000000000 ffff8800071f4680 ffff8800071f4680
Call Trace:
[<ffffffff8108730f>] ? ring_buffer_read_page+0x15a/0x24a
[<ffffffff81002956>] ? return_to_handler+0x15/0x2f
[<ffffffff8108a575>] tracing_buffers_read+0xb9/0x164
[<ffffffff810debfe>] vfs_read+0xaf/0x150
[<ffffffff81002941>] return_to_handler+0x0/0x2f
[<ffffffff810248b0>] __bad_area_nosemaphore+0x17e/0x1a1
[<ffffffff810248e6>] bad_area_nosemaphore+0x13/0x15
Code: 80 25 b2 16 b3 00 fe c9 c3 55 48 89 e5 f0 80 0d a4 16 b3 00 02 c9 c3 55 31 c0 48 89 e5 48 83 3d 94 16 b3 00 01 c9 0f 94 c0 c3 55 <8a> 0f 48 89 e5 83 e1 1f b8 08 00 00 00 0f b6 d1 83 fa 1e 74 27
RIP [<ffffffff81085572>] rb_event_length+0x1/0x3f
RSP <ffff880006475e38>
---[ end trace a6877bb92ccb36bb ]---
The root cause is that ring_buffer_read_page() may read out of page
boundary, because the boundary checking is done after reading. This is
fixed via doing boundary checking before reading.
Reported-by: Shaohua Li <shaohua.li@intel.com>
Signed-off-by: Huang Ying <ying.huang@intel.com>
LKML-Reference: <1280297641.2771.307.camel@yhuang-dev>
commit 575570f02761bd680ba5731c1dfd4701062e7fb2 upstream.
With CONFIG_DEBUG_PAGEALLOC, I observed an unallocated memory access in
function_graph trace. It appears we find a small size entry in ring buffer,
but we access it as a big size entry. The access overflows the page size
and touches an unallocated page.
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
LKML-Reference: <1280217994.32400.76.camel@sli10-desk.sh.intel.com>
[ Added a comment to explain the problem - SDR ]
commit 685fd0b4ea3f0f1d5385610b0d5b57775a8d5842 upstream.
A small number of users of IRQF_TIMER are using it for the implied no
suspend behaviour on interrupts which are not timer interrupts.
Therefore add a new IRQF_NO_SUSPEND flag, rename IRQF_TIMER to
__IRQF_TIMER and redefine IRQF_TIMER in terms of these new flags.
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: xen-devel@lists.xensource.com
Cc: linux-input@vger.kernel.org
Cc: linuxppc-dev@ozlabs.org
Cc: devicetree-discuss@lists.ozlabs.org
LKML-Reference: <1280398595-29708-1-git-send-email-ian.campbell@citrix.com>
commit 396e894d289d69bacf5acd983c97cd6e21a14c08 upstream.
Norbert reported that nohz_ratelimit() causes his laptop to burn about
4W (40%) extra. For now back out the change and see if we can adjust
the power management code to make better decisions.
Reported-by: Norbert Preining <preining@logic.at>
Acked-by: Mike Galbraith <efault@gmx.de>
Cc: Arjan van de Ven <arjan@infradead.org>
LKML-Reference: <new-submission>
commit 694f690d27dadccc8cb9d90532e76593b61fe098 upstream.
Commit 8f92054e7ca1 ("CRED: Fix __task_cred()'s lockdep check and banner
comment") fixed the lockdep checks on __task_cred(). This has shown up
a place in the signalling code where a lock should be held - namely that
check_kill_permission() requires its callers to hold the RCU lock.
Fix group_send_sig_info() to get the RCU read lock around its call to
check_kill_permission().
Without this patch, the following warning can occur:
kernel/signal.c:660 invoked rcu_dereference_check() without protection!
Reported-by: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp>
It's possible for get_task_cred() as it currently stands to 'corrupt' a set of
credentials by incrementing their usage count after their replacement by the
task being accessed.
What happens is that get_task_cred() can race with commit_creds():
TASK_1 TASK_2 RCU_CLEANER
-->get_task_cred(TASK_2)
rcu_read_lock()
__cred = __task_cred(TASK_2)
-->commit_creds()
old_cred = TASK_2->real_cred
TASK_2->real_cred = ...
put_cred(old_cred)
call_rcu(old_cred)
[__cred->usage == 0]
get_cred(__cred)
[__cred->usage == 1]
rcu_read_unlock()
-->put_cred_rcu()
panic()
However, since a tasks credentials are generally not changed very often, we can
reasonably make use of a loop involving reading the creds pointer and using
atomic_inc_not_zero() to attempt to increment it if it hasn't already hit zero.
If successful, we can safely return the credentials in the knowledge that, even
if the task we're accessing has released them, they haven't gone to the RCU
cleanup code.
We then change task_state() in procfs to use get_task_cred() rather than
calling get_cred() on the result of __task_cred(), as that suffers from the
same problem.
Without this change, a BUG_ON in __put_cred() or in put_cred_rcu() can be
tripped when it is noticed that the usage count is not zero as it ought to be,
for example:
kernel BUG at kernel/cred.c:168!
invalid opcode: 0000 [#1] SMP
last sysfs file: /sys/kernel/mm/ksm/run
CPU 0
Pid: 2436, comm: master Not tainted 2.6.33.3-85.fc13.x86_64 #1 0HR330/OptiPlex
745
RIP: 0010:[<ffffffff81069881>] [<ffffffff81069881>] __put_cred+0xc/0x45
RSP: 0018:ffff88019e7e9eb8 EFLAGS: 00010202
RAX: 0000000000000001 RBX: ffff880161514480 RCX: 00000000ffffffff
RDX: 00000000ffffffff RSI: ffff880140c690c0 RDI: ffff880140c690c0
RBP: ffff88019e7e9eb8 R08: 00000000000000d0 R09: 0000000000000000
R10: 0000000000000001 R11: 0000000000000040 R12: ffff880140c690c0
R13: ffff88019e77aea0 R14: 00007fff336b0a5c R15: 0000000000000001
FS: 00007f12f50d97c0(0000) GS:ffff880007400000(0000) knlGS:0000000000000000
CR2: 00007f8f461bc000 CR3: 00000001b26ce000 CR4: 00000000000006f0
Process master (pid: 2436, threadinfo ffff88019e7e8000, task ffff88019e77aea0)
Stack:
ffff88019e7e9ec8 ffffffff810698cd ffff88019e7e9ef8 ffffffff81069b45
<0> ffff880161514180 ffff880161514480 ffff880161514180 0000000000000000
<0> ffff88019e7e9f28 ffffffff8106aace 0000000000000001 0000000000000246
Call Trace:
[<ffffffff810698cd>] put_cred+0x13/0x15
[<ffffffff81069b45>] commit_creds+0x16b/0x175
[<ffffffff8106aace>] set_current_groups+0x47/0x4e
[<ffffffff8106ac89>] sys_setgroups+0xf6/0x105
[<ffffffff81009b02>] system_call_fastpath+0x16/0x1b
Code: 48 8d 71 ff e8 7e 4e 15 00 85 c0 78 0b 8b 75 ec 48 89 df e8 ef 4a 15 00
48 83 c4 18 5b c9 c3 55 8b 07 8b 07 48 89 e5 85 c0 74 04 <0f> 0b eb fe 65 48 8b
04 25 00 cc 00 00 48 3b b8 58 04 00 00 75
RIP [<ffffffff81069881>] __put_cred+0xc/0x45
RSP <ffff88019e7e9eb8>
---[ end trace df391256a100ebdd ]---
Acked-by: Jiri Olsa <jolsa@redhat.com>
The command
echo "file ec.c +p" >/sys/kernel/debug/dynamic_debug/control
causes an oops.
Move the call to ddebug_remove_module() down into free_module(). In this
way it should be called from all error paths. Currently, we are missing
the remove if the module init routine fails.
Signed-off-by: Jason Baron <jbaron@redhat.com>
Reported-by: Thomas Renninger <trenn@suse.de>
Tested-by: Thomas Renninger <trenn@suse.de>
Cc: <stable@kernel.org> [2.6.32+]
The kdb code should not toggle the sysrq state in case an end user
wants to try and resume the normal kernel execution.
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Immediately following an exit from the kdb shell the kgdb_connected
variable should be set to zero, unless there are breakpoints planted.
If the kgdb_connected variable is not zeroed out with kdb, it is
impossible to turn off kdb.
This patch is merely a work around for now, the real fix will check
for the breakpoints.
In the process of merging kdb to the mainline, the kdb lsmod command
stopped printing the base load address of kernel modules. This is
needed for using kdb in conjunction with external tools such as gdb.
Simply restore the functionality by adding a kdb_printf for the base
load address of the kernel modules.
The gdbserial protocol handler should return an empty packet instead
of an error string when ever it responds to a command it does not
implement.
The problem cases come from a debugger client sending
qTBuffer, qTStatus, qSearch, qSupported.
The incorrect response from the gdbstub leads the debugger clients to
not function correctly. Recent versions of gdb will not detach correctly as a result of this behavior.
Signed-off-by: Dongdong Deng <dongdong.deng@windriver.com>
Without this patch the "ll" linked-list traversal command won't
terminate when you hit q/Q.
Signed-off-by: Martin Hicks <mort@sgi.com>
With commits 08677214 and 59be5a8e, alloc_bootmem()/free_bootmem() and
friends use the early_res functions for memory management when
NO_BOOTMEM is enabled. This patch adds the kmemleak calls in the
corresponding code paths for bootmem allocations.
Acked-by: Pekka Enberg <penberg@cs.helsinki.fi>
Acked-by: Yinghai Lu <yinghai@kernel.org>
Cc: stable@kernel.org
We should initialize the module dynamic debug datastructures
only after determining that the module is not loaded yet. This
fixes a bug that introduced in 2.6.35-rc2, where when a trying
to load a module twice, we also load it's dynamic printing data
twice which causes all sorts of nasty issues. Also handle
the dynamic debug cleanup later on failure.
Signed-off-by: Yehuda Sadeh <yehuda@hq.newdream.net>
Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (removed a #ifdef)
* 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
sched: Cure nr_iowait_cpu() users
init: Fix comment
init, sched: Fix race between init and kthreadd
Commit 0224cf4c5e (sched: Intoduce get_cpu_iowait_time_us())
broke things by not making sure preemption was indeed disabled
by the callers of nr_iowait_cpu() which took the iowait value of
the current cpu.
This resulted in a heap of preempt warnings. Cure this by making
nr_iowait_cpu() take a cpu number and fix up the callers to pass
in the right number.
Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Cc: Rafael J. Wysocki <rjw@sisk.pl>
Cc: Maxim Levitsky <maximlevitsky@gmail.com>
Cc: Len Brown <len.brown@intel.com>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: linux-pm@lists.linux-foundation.org
LKML-Reference: <1277968037.1868.120.camel@laptop>
futex_find_get_task is currently used (through lookup_pi_state) from two
contexts, futex_requeue and futex_lock_pi_atomic. None of the paths
looks it needs the credentials check, though. Different (e)uids
shouldn't matter at all because the only thing that is important for
shared futex is the accessibility of the shared memory.
The credentail check results in glibc assert failure or process hang (if
glibc is compiled without assert support) for shared robust pthread
mutex with priority inheritance if a process tries to lock already held
lock owned by a process with a different euid:
pthread_mutex_lock.c:312: __pthread_mutex_lock_full: Assertion `(-(e)) != 3 || !robust' failed.
The problem is that futex_lock_pi_atomic which is called when we try to
lock already held lock checks the current holder (tid is stored in the
futex value) to get the PI state. It uses lookup_pi_state which in turn
gets task struct from futex_find_get_task. ESRCH is returned either
when the task is not found or if credentials check fails.
futex_lock_pi_atomic simply returns if it gets ESRCH. glibc code,
however, doesn't expect that robust lock returns with ESRCH because it
should get either success or owner died.
Acked-by: Darren Hart <dvhltc@us.ibm.com>
Cc: Nick Piggin <npiggin@suse.de>
Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
When crashkernel is not enabled, "echo 0 > /sys/kernel/kexec_crash_size"
OOPSes the kernel in crash_shrink_memory. This happens when
crash_shrink_memory tries to release the 'crashk_res' resource which are
not reserved. Also value of "/sys/kernel/kexec_crash_size" shows as 1,
which should be 0.
This patch fixes the OOPS in crash_shrink_memory and shows
"/sys/kernel/kexec_crash_size" as 0 when crash kernel memory is not
reserved.
Signed-off-by: Pavan Naregundi <pavan@linux.vnet.ibm.com>
Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com>
Cc: Simon Horman <horms@verge.net.au>
Cc: Vivek Goyal <vgoyal@redhat.com>
* 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
tracing: Fix undeclared ENOSYS in include/linux/tracepoint.h
perf record: prevent kill(0, SIGTERM);
perf session: Remove threads from tree on PERF_RECORD_EXIT
perf/tracing: Fix regression of perf losing kprobe events
perf_events: Fix Intel Westmere event constraints
perf record: Don't call newt functions when not initialized
* 'irq-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
genirq: Deal with desc->set_type() changing desc->chip
sched: Prevent compiler from optimising the sched_avg_update() loop
sched: Fix over-scheduling bug
sched: Fix PROVE_RCU vs cpu_cgroup
* 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
nohz: Fix nohz ratelimit
* 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
sched: silence PROVE_RCU in sched_fork()
idr: fix RCU lockdep splat in idr_get_next()
rcu: apply RCU protection to wake_affine()
GCC 4.4.1 on ARM has been observed to replace the while loop in
sched_avg_update with a call to uldivmod, resulting in the
following build failure at link-time:
kernel/built-in.o: In function `sched_avg_update':
kernel/sched.c:1261: undefined reference to `__aeabi_uldivmod'
make: *** [.tmp_vmlinux1] Error 1
This patch introduces a fake data hazard to the loop body to
prevent the compiler optimising the loop away.
Acked-by: Peter Zijlstra <peterz@infradead.org>
Because cgroup_fork() is ran before sched_fork() [ from copy_process() ]
and the child's pid is not yet visible the child is pinned to its
cgroup. Therefore we can silence this warning.
A nicer solution would be moving cgroup_fork() to right after
dup_task_struct() and exclude PF_STARTING from task_subsys_state().
Reviewed-by: Li Zefan <lizf@cn.fujitsu.com>
The task_group() function returns a pointer that must be protected
by either RCU, the ->alloc_lock, or the cgroup lock (see the
rcu_dereference_check() in task_subsys_state(), which is invoked by
task_group()). The wake_affine() function currently does none of these,
which means that a concurrent update would be within its rights to free
the structure returned by task_group(). Because wake_affine() uses this
structure only to compute load-balancing heuristics, there is no reason
to acquire either of the two locks.
Therefore, this commit introduces an RCU read-side critical section that
starts before the first call to task_group() and ends after the last use
of the "tg" pointer returned from task_group(). Thanks to Li Zefan for
pointing out the need to extend the RCU read-side critical section from
that proposed by the original patch.
Commit e70971591 ("sched: Optimize unused cgroup configuration") introduced
an imbalanced scheduling bug.
If we do not use CGROUP, function update_h_load won't update h_load. When the
system has a large number of tasks far more than logical CPU number, the
incorrect cfs_rq[cpu]->h_load value will cause load_balance() to pull too
many tasks to the local CPU from the busiest CPU. So the busiest CPU keeps
going in a round robin. That will hurt performance.
The issue was found originally by a scientific calculation workload that
developed by Yanmin. With that commit, the workload performance drops
about 40%.
CPU before after
00 : 2 : 7
01 : 1 : 7
02 : 11 : 6
03 : 12 : 7
04 : 6 : 6
05 : 11 : 7
06 : 10 : 6
07 : 12 : 7
08 : 11 : 6
09 : 12 : 6
10 : 1 : 6
11 : 1 : 6
12 : 6 : 6
13 : 2 : 6
14 : 2 : 6
15 : 1 : 6
Reviewed-by: Yanmin zhang <yanmin.zhang@intel.com>
Signed-off-by: Alex Shi <alex.shi@intel.com>
LKML-Reference: <1276754893.9452.5442.camel@debian>
Chris Wedgwood reports that 39c0cbe (sched: Rate-limit nohz) causes a
serial console regression, unresponsiveness, and indeed it does. The
reason is that the nohz code is skipped even when the tick was already
stopped before the nohz_ratelimit(cpu) condition changed.
Move the nohz_ratelimit() check to the other conditions which prevent
long idle sleeps.
Reported-by: Chris Wedgwood <cw@f00f.org>
Tested-by: Brian Bloniarz <bmb@athenacr.com>
Signed-off-by: Mike Galbraith <efault@gmx.de>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Greg KH <gregkh@suse.de>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Cc: Jef Driesen <jefdriesen@telenet.be>
LKML-Reference: <1276790557.27822.516.camel@twins>
drivers/acpi/sleep.c
Signed-off-by: Len Brown <len.brown@intel.com>
With the addition of the code to shrink the kernel tracepoint
infrastructure, we lost kprobes being traced by perf. The reason
is that I tested if the "tp_event->class->perf_probe" existed before
enabling it. This prevents "ftrace only" events (like the function
trace events) from being enabled by perf.
Unfortunately, kprobe events do not use perf_probe. This causes
kprobes to be missed by perf. To fix this, we add the test to
see if "tp_event->class->reg" exists as well as perf_probe.
Normal trace events have only "perf_probe" but no "reg" function,
and kprobes and syscalls have the "reg" but no "perf_probe".
The ftrace unique events do not have either, so this is a valid
test. If a kprobe or syscall is not to be probed by perf, the
"reg" function is called anyway, and will return a failure and
prevent perf from probing it.
Reported-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Tested-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
tracing: Fix null pointer deref with SEND_SIG_FORCED
perf: Fix signed comparison in perf_adjust_period()
powerpc/oprofile: fix potential buffer overrun in op_model_cell.c
perf symbols: Set the DSO long name when using symbol_conf.vmlinux_name
Saving platform non-volatile state may be required for suspend to RAM as
well as hibernation. Move it to more generic code.
Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
Tested-by: Maxim Levitsky <maximlevitsky@gmail.com>
The set_type() function can change the chip implementation when the
trigger mode changes. That might result in using an non-initialized
irq chip when called from __setup_irq() or when called via
set_irq_type() on an already enabled irq.
The set_irq_type() function should not be called on an enabled irq,
but because we forgot to put a check into it, we have a bunch of users
which grew the habit of doing that and it never blew up as the
function is serialized via desc->lock against all users of desc->chip
and they never hit the non-initialized irq chip issue.
The easy fix for the __setup_irq() issue would be to move the
irq_chip_set_defaults(desc->chip) call after the trigger setting to
make sure that a chip change is covered.
But as we have already users, which do the type setting after
request_irq(), the safe fix for now is to call irq_chip_set_defaults()
from __irq_set_trigger() when desc->set_type() changed the irq chip.
It needs a deeper analysis whether we should refuse to change the chip
on an already enabled irq, but that'd be a large scale change to fix
all the existing users. So that's neither stable nor 2.6.35 material.
Reported-by: Esben Haabendal <eha@doredevelopment.dk>
Cc: linuxppc-dev <linuxppc-dev@ozlabs.org>
PROVE_RCU has a few issues with the cpu_cgroup because the scheduler
typically holds rq->lock around the css rcu derefs but the generic
cgroup code doesn't (and can't) know about that lock.
Provide means to add extra checks to the css dereference and use that
in the scheduler to annotate its users.
The addition of rq->lock to these checks is correct because the
cgroup_subsys::attach() method takes the rq->lock for each task it
moves, therefore by holding that lock, we ensure the task is pinned to
the current cgroup and the RCU derefence is valid.
That leaves one genuine race in __sched_setscheduler() where we used
task_group() without holding any of the required locks and thus raced
with the cgroup code. Solve this by moving the check under the
appropriate lock.
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Frederic reported that frequency driven swevents didn't work properly
and even caused a division-by-zero error.
It turns out there are two bugs, the division-by-zero comes from a
failure to deal with that in perf_calculate_period().
The other was more interesting and turned out to be a wrong comparison
in perf_adjust_period(). The comparison was between an s64 and u64 and
got implicitly converted to an unsigned comparison. The problem is
that period_left is typically < 0, so it ended up being always true.
Cure this by making the local period variables s64.
Reported-by: Frederic Weisbecker <fweisbec@gmail.com>
Tested-by: Frederic Weisbecker <fweisbec@gmail.com>
