commit cef572ad9bd7f85035ba8272e5352040e8be0152 upstream.
When queue_work() is used in irq (not in task context), there is
a potential case that trigger NULL pointer dereference.
worker_thread()
|-spin_lock_irq()
|-process_one_work()
|-worker->current_pwq = pwq
|-spin_unlock_irq()
|-worker->current_func(work)
|-spin_lock_irq()
|-worker->current_pwq = NULL
|-spin_unlock_irq()
//interrupt here
|-irq_handler
|-__queue_work()
//assuming that the wq is draining
|-is_chained_work(wq)
|-current_wq_worker()
//Here, 'current' is the interrupted worker!
|-current->current_pwq is NULL here!
|-schedule()
Avoid it by checking for task context in current_wq_worker(), and
if not in task context, we shouldn't use the 'current' to check the
condition.
Reported-by: Xiaofei Tan <tanxiaofei@huawei.com>
Signed-off-by: Li Bin <huawei.libin@huawei.com>
Reviewed-by: Lai Jiangshan <jiangshanlai@gmail.com>
Fixes: 8d03ecfe4718 ("workqueue: reimplement is_chained_work() using current_wq_worker()")
commit 692b48258dda7c302e777d7d5f4217244478f1f6 upstream.
Josef reported a HARDIRQ-safe -> HARDIRQ-unsafe lock order detected by
lockdep:
[ 1270.472259] WARNING: HARDIRQ-safe -> HARDIRQ-unsafe lock order detected
[ 1270.472783] 4.14.0-rc1-xfstests-12888-g76833e8 #110 Not tainted
[ 1270.473240] -----------------------------------------------------
[ 1270.473710] kworker/u5:2/5157 [HC0[0]:SC0[0]:HE0:SE1] is trying to acquire:
[ 1270.474239] (&(&lock->wait_lock)->rlock){+.+.}, at: [<ffffffff8da253d2>] __mutex_unlock_slowpath+0xa2/0x280
[ 1270.474994]
[ 1270.474994] and this task is already holding:
[ 1270.475440] (&pool->lock/1){-.-.}, at: [<ffffffff8d2992f6>] worker_thread+0x366/0x3c0
[ 1270.476046] which would create a new lock dependency:
[ 1270.476436] (&pool->lock/1){-.-.} -> (&(&lock->wait_lock)->rlock){+.+.}
[ 1270.476949]
[ 1270.476949] but this new dependency connects a HARDIRQ-irq-safe lock:
[ 1270.477553] (&pool->lock/1){-.-.}
[ 1270.488900] to a HARDIRQ-irq-unsafe lock:
[ 1270.489327] (&(&lock->wait_lock)->rlock){+.+.}
[ 1270.494735] Possible interrupt unsafe locking scenario:
[ 1270.494735]
[ 1270.495250] CPU0 CPU1
[ 1270.495600] ---- ----
[ 1270.495947] lock(&(&lock->wait_lock)->rlock);
[ 1270.496295] local_irq_disable();
[ 1270.496753] lock(&pool->lock/1);
[ 1270.497205] lock(&(&lock->wait_lock)->rlock);
[ 1270.497744] <Interrupt>
[ 1270.497948] lock(&pool->lock/1);
, which will cause a irq inversion deadlock if the above lock scenario
happens.
The root cause of this safe -> unsafe lock order is the
mutex_unlock(pool->manager_arb) in manage_workers() with pool->lock
held.
Unlocking mutex while holding an irq spinlock was never safe and this
problem has been around forever but it never got noticed because the
only time the mutex is usually trylocked while holding irqlock making
actual failures very unlikely and lockdep annotation missed the
condition until the recent b9c16a0e1f73 ("locking/mutex: Fix
lockdep_assert_held() fail").
Using mutex for pool->manager_arb has always been a bit of stretch.
It primarily is an mechanism to arbitrate managership between workers
which can easily be done with a pool flag. The only reason it became
a mutex is that pool destruction path wants to exclude parallel
managing operations.
This patch replaces the mutex with a new pool flag POOL_MANAGER_ACTIVE
and make the destruction path wait for the current manager on a wait
queue.
v2: Drop unnecessary flag clearing before pool destruction as
suggested by Boqun.
Reported-by: Josef Bacik <josef@toxicpanda.com>
Cc: Boqun Feng <boqun.feng@gmail.com>
commit 18f649ef344127ef6de23a5a4272dbe2fdb73dde upstream.
The PF_EXITING check in task_wants_autogroup() is no longer needed. Remove
it, but see the next patch.
However the comment is correct in that autogroup_move_group() must always
change task_group() for every thread so the sysctl_ check is very wrong;
we can race with cgroups and even sys_setsid() is not safe because a task
running with task_group() == ag->tg must participate in refcounting:
int main(void)
int sctl = open("/proc/sys/kernel/sched_autogroup_enabled", O_WRONLY);
assert(sctl > 0);
if (fork()) {
wait(NULL); // destroy the child's ag/tg
pause();
assert(pwrite(sctl, "1\n", 2, 0) == 2);
assert(setsid() > 0);
if (fork())
pause();
kill(getppid(), SIGKILL);
sleep(1);
// The child has gone, the grandchild runs with kref == 1
assert(pwrite(sctl, "0\n", 2, 0) == 2);
// runs with the freed ag/tg
for (;;)
sleep(1);
return 0;
crashes the kernel. It doesn't really need sleep(1), it doesn't matter if
autogroup_move_group() actually frees the task_group or this happens later.
Reported-by: Vern Lovejoy <vlovejoy@redhat.com>
Cc: hartsjc@redhat.com
Cc: vbendel@redhat.com
Link: http://lkml.kernel.org/r/20161114184609.GA15965@redhat.com
Signed-off-by: Sumit Semwal <sumit.semwal@linaro.org>
[sumits: submit to 4.4 LTS, post testing on Hikey]
[ Upstream commit 7fb4a2cea6b18dab56d609530d077f168169ed6b ]
Boqun reported that hlock->references can overflow. Add a debug test
for that to generate a clear error when this happens.
Without this, lockdep is likely to report a mysterious failure on
unlock.
Reported-by: Boqun Feng <boqun.feng@gmail.com>
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Nicolai Hähnle <Nicolai.Haehnle@amd.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
[ Upstream commit ec9dd352d591f0c90402ec67a317c1ed4fb2e638 ]
This patch fixes a bug exhibited by the following scenario:
1. fd1 = perf_event_open with attr.config = ID1
2. attach bpf program prog1 to fd1
3. fd2 = perf_event_open with attr.config = ID1
<this will be successful>
4. user program closes fd2 and prog1 is detached from the tracepoint.
5. user program with fd1 does not work properly as tracepoint
no output any more.
The issue happens at step 4. Multiple perf_event_open can be called
successfully, but only one bpf prog pointer in the tp_event. In the
current logic, any fd release for the same tp_event will free
the tp_event->prog.
The fix is to free tp_event->prog only when the closing fd
corresponds to the one which registered the program.
Signed-off-by: Yonghong Song <yhs@fb.com>
[ Upstream commit e67b8a685c7c984e834e3181ef4619cd7025a136 ]
Neither ___bpf_prog_run nor the JITs accept it.
Also adds a new test case.
Fixes: 17a5267067f3 ("bpf: verifier (add verifier core)")
Signed-off-by: Edward Cree <ecree@solarflare.com>
Acked-by: Alexei Starovoitov <ast@kernel.org>
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
commit 28585a832602747cbfa88ad8934013177a3aae38 upstream.
A number of architecture invoke rcu_irq_enter() on exception entry in
order to allow RCU read-side critical sections in the exception handler
when the exception is from an idle or nohz_full CPU. This works, at
least unless the exception happens in an NMI handler. In that case,
rcu_nmi_enter() would already have exited the extended quiescent state,
which would mean that rcu_irq_enter() would (incorrectly) cause RCU
to think that it is again in an extended quiescent state. This will
in turn result in lockdep splats in response to later RCU read-side
critical sections.
This commit therefore causes rcu_irq_enter() and rcu_irq_exit() to
take no action if there is an rcu_nmi_enter() in effect, thus avoiding
the unscheduled return to RCU quiescent state. This in turn should
make the kernel safe for on-demand RCU voyeurism.
Link: http://lkml.kernel.org/r/20170922211022.GA18084@linux.vnet.ibm.com
Cc: stable@vger.kernel.org
Fixes: 0be964be0 ("module: Sanitize RCU usage and locking")
Reported-by: Steven Rostedt <rostedt@goodmis.org>
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
commit 50e76632339d4655859523a39249dd95ee5e93e7 upstream.
Cpusets vs. suspend-resume is _completely_ broken. And it got noticed
because it now resulted in non-cpuset usage breaking too.
On suspend cpuset_cpu_inactive() doesn't call into
cpuset_update_active_cpus() because it doesn't want to move tasks about,
there is no need, all tasks are frozen and won't run again until after
we've resumed everything.
But this means that when we finally do call into
cpuset_update_active_cpus() after resuming the last frozen cpu in
cpuset_cpu_active(), the top_cpuset will not have any difference with
the cpu_active_mask and this it will not in fact do _anything_.
So the cpuset configuration will not be restored. This was largely
hidden because we would unconditionally create identity domains and
mobile users would not in fact use cpusets much. And servers what do use
cpusets tend to not suspend-resume much.
An addition problem is that we'd not in fact wait for the cpuset work to
finish before resuming the tasks, allowing spurious migrations outside
of the specified domains.
Fix the rebuild by introducing cpuset_force_rebuild() and fix the
ordering with cpuset_wait_for_hotplug().
Reported-by: Andy Lutomirski <luto@kernel.org>
Cc: <stable@vger.kernel.org>
Cc: Rafael J. Wysocki <rjw@rjwysocki.net>
Cc: Tejun Heo <tj@kernel.org>
Fixes: deb7aa308ea2 ("cpuset: reorganize CPU / memory hotplug handling")
Link: http://lkml.kernel.org/r/20170907091338.orwxrqkbfkki3c24@hirez.programming.kicks-ass.net
Signed-off-by: Mike Galbraith <efault@gmx.de>
commit 2b0b8499ae75df91455bbeb7491d45affc384fb0 upstream.
The trampoline allocated by function tracer was overwriten by function_graph
tracer, and caused a memory leak. The save_global_trampoline should have
saved the previous trampoline in register_ftrace_graph() and restored it in
unregister_ftrace_graph(). But as it is implemented, save_global_trampoline was
only used in unregister_ftrace_graph as default value 0, and it overwrote the
previous trampoline's value. Causing the previous allocated trampoline to be
lost.
kmmeleak backtrace:
kmemleak_vmalloc+0x77/0xc0
__vmalloc_node_range+0x1b5/0x2c0
module_alloc+0x7c/0xd0
arch_ftrace_update_trampoline+0xb5/0x290
ftrace_startup+0x78/0x210
register_ftrace_function+0x8b/0xd0
function_trace_init+0x4f/0x80
tracing_set_tracer+0xe6/0x170
tracing_set_trace_write+0x90/0xd0
__vfs_write+0x37/0x170
vfs_write+0xb2/0x1b0
SyS_write+0x55/0xc0
do_syscall_64+0x67/0x180
return_from_SYSCALL_64+0x0/0x6a
Looking further into this, I found that this was left over from when the
function and function graph tracers shared the same ftrace_ops. But in
commit 5f151b2401 ("ftrace: Fix function_profiler and function tracer
together"), the two were separated, and the save_global_trampoline no
longer was necessary (and it may have been broken back then too).
-- Steven Rostedt
Link: http://lkml.kernel.org/r/20170912021454.5976-1-shuwang@redhat.com
Fixes: 5f151b2401 ("ftrace: Fix function_profiler and function tracer together")
Signed-off-by: Shu Wang <shuwang@redhat.com>
commit b94bf594cf8ed67cdd0439e70fa939783471597a upstream.
timer_migration sysctl acts as a boolean switch, so the allowed values
should be restricted to 0 and 1.
Add the necessary extra fields to the sysctl table entry to enforce that.
[ tglx: Rewrote changelog ]
Signed-off-by: Myungho Jung <mhjungk@gmail.com>
Link: http://lkml.kernel.org/r/1492640690-3550-1-git-send-email-mhjungk@gmail.com
Cc: Kazuhiro Hayashi <kazuhiro3.hayashi@toshiba.co.jp>
commit 66a733ea6b611aecf0119514d2dddab5f9d6c01e upstream.
As Chris explains, get_seccomp_filter() and put_seccomp_filter() can end
up using different filters. Once we drop ->siglock it is possible for
task->seccomp.filter to have been replaced by SECCOMP_FILTER_FLAG_TSYNC.
Fixes: f8e529ed941b ("seccomp, ptrace: add support for dumping seccomp filters")
Reported-by: Chris Salls <chrissalls5@gmail.com>
[tycho: add __get_seccomp_filter vs. open coding refcount_inc()]
Signed-off-by: Tycho Andersen <tycho@docker.com>
[kees: tweak commit log]
commit 8dd33bcb7050dd6f8c1432732f930932c9d3a33e upstream.
One convenient way to erase trace is "echo > trace". However, this
is currently broken if the current tracer is irqsoff tracer. This
is because irqsoff tracer use max_buffer as the default trace
buffer.
Set the max_buffer as the one to be cleared when it's the trace
buffer currently in use.
Link: http://lkml.kernel.org/r/1505754215-29411-1-git-send-email-byan@nvidia.com
Cc: <mingo@redhat.com>
Fixes: 4acd4d00f ("tracing: give easy way to clear trace buffer")
Signed-off-by: Bo Yan <byan@nvidia.com>
commit 75df6e688ccd517e339a7c422ef7ad73045b18a2 upstream.
When reading data from trace_pipe, tracing_wait_pipe() performs a
check to see if tracing has been turned off after some data was read.
Currently, this check always looks at global trace state, but it
should be checking the trace instance where trace_pipe is located at.
Because of this bug, cat instances/i1/trace_pipe in the following
script will immediately exit instead of waiting for data:
cd /sys/kernel/debug/tracing
echo 0 > tracing_on
mkdir -p instances/i1
echo 1 > instances/i1/tracing_on
echo 1 > instances/i1/events/sched/sched_process_exec/enable
Link: http://lkml.kernel.org/r/20170917102348.1615-1-tahsin@google.com
Fixes: 10246fa35d4f ("tracing: give easy way to clear trace buffer")
Signed-off-by: Tahsin Erdogan <tahsin@google.com>
commit edb096e00724f02db5f6ec7900f3bbd465c6c76f upstream.
If function tracing is disabled by the user via the function-trace option or
the proc sysctl file, and a ftrace_ops that was allocated on the heap is
unregistered, then the shutdown code exits out without doing the proper
clean up. This was found via kmemleak and running the ftrace selftests, as
one of the tests unregisters with function tracing disabled.
# cat kmemleak
unreferenced object 0xffffffffa0020000 (size 4096):
comm "swapper/0", pid 1, jiffies 4294668889 (age 569.209s)
hex dump (first 32 bytes):
55 ff 74 24 10 55 48 89 e5 ff 74 24 18 55 48 89 U.t$.UH...t$.UH.
e5 48 81 ec a8 00 00 00 48 89 44 24 50 48 89 4c .H......H.D$PH.L
backtrace:
[<ffffffff81d64665>] kmemleak_vmalloc+0x85/0xf0
[<ffffffff81355631>] __vmalloc_node_range+0x281/0x3e0
[<ffffffff8109697f>] module_alloc+0x4f/0x90
[<ffffffff81091170>] arch_ftrace_update_trampoline+0x160/0x420
[<ffffffff81249947>] ftrace_startup+0xe7/0x300
[<ffffffff81249bd2>] register_ftrace_function+0x72/0x90
[<ffffffff81263786>] trace_selftest_ops+0x204/0x397
[<ffffffff82bb8971>] trace_selftest_startup_function+0x394/0x624
[<ffffffff81263a75>] run_tracer_selftest+0x15c/0x1d7
[<ffffffff82bb83f1>] init_trace_selftests+0x75/0x192
[<ffffffff81002230>] do_one_initcall+0x90/0x1e2
[<ffffffff82b7d620>] kernel_init_freeable+0x350/0x3fe
[<ffffffff81d61ec3>] kernel_init+0x13/0x122
[<ffffffff81d72c6a>] ret_from_fork+0x2a/0x40
[<ffffffffffffffff>] 0xffffffffffffffff
Fixes: 12cce594fa ("ftrace/x86: Allow !CONFIG_PREEMPT dynamic ops to use allocated trampolines")
commit 170b3b1050e28d1ba0700e262f0899ffa4fccc52 upstream.
Currently trace_clock timestamps are applied to both regular and max
buffers only for global trace. For instance trace, trace_clock
timestamps are applied only to regular buffer. But, regular and max
buffers can be swapped, for example, following a snapshot. So, for
instance trace, bad timestamps can be seen following a snapshot.
Let's apply trace_clock timestamps to instance max buffer as well.
Link: http://lkml.kernel.org/r/ebdb168d0be042dcdf51f81e696b17fabe3609c1.1504642143.git.tom.zanussi@linux.intel.com
Fixes: 277ba0446 ("tracing: Add interface to allow multiple trace buffers")
Signed-off-by: Baohong Liu <baohong.liu@intel.com>
commit 46320a6acc4fb58f04bcf78c4c942cc43b20f986 upstream.
In the second iteration of trace_selftest_ops(), the error goto label is
wrong in the case where trace_selftest_test_global_cnt is off. In the
case of error, it leaks the dynamic ops that was allocated.
Fixes: 95950c2e ("ftrace: Add self-tests for multiple function trace users")
commit f4dbba591945dc301c302672adefba9e2ec08dc5 upstream.
When running locktorture module with the below commands with kmemleak enabled:
$ modprobe locktorture torture_type=rw_lock_irq
$ rmmod locktorture
The below kmemleak got caught:
root@10:~# echo scan > /sys/kernel/debug/kmemleak
[ 323.197029] kmemleak: 2 new suspected memory leaks (see /sys/kernel/debug/kmemleak)
root@10:~# cat /sys/kernel/debug/kmemleak
unreferenced object 0xffffffc07592d500 (size 128):
comm "modprobe", pid 368, jiffies 4294924118 (age 205.824s)
00 00 00 00 00 00 00 00 c3 7b 02 00 00 00 00 00 .........{......
00 00 00 00 00 00 00 00 d7 9b 02 00 00 00 00 00 ................
backtrace:
[<ffffff80081e5a88>] create_object+0x110/0x288
[<ffffff80086c6078>] kmemleak_alloc+0x58/0xa0
[<ffffff80081d5acc>] __kmalloc+0x234/0x318
[<ffffff80006fa130>] 0xffffff80006fa130
[<ffffff8008083ae4>] do_one_initcall+0x44/0x138
[<ffffff800817e28c>] do_init_module+0x68/0x1cc
[<ffffff800811c848>] load_module+0x1a68/0x22e0
[<ffffff800811d340>] SyS_finit_module+0xe0/0xf0
[<ffffff80080836f0>] el0_svc_naked+0x24/0x28
unreferenced object 0xffffffc07592d480 (size 128):
00 00 00 00 00 00 00 00 3b 6f 01 00 00 00 00 00 ........;o......
00 00 00 00 00 00 00 00 23 6a 01 00 00 00 00 00 ........#j......
backtrace:
[<ffffff80006fa22c>] 0xffffff80006fa22c
It is because cxt.lwsa and cxt.lrsa don't get freed in module_exit, so free
them in lock_torture_cleanup() and free writer_tasks if reader_tasks is
failed at memory allocation.
Signed-off-by: Yang Shi <yang.shi@linaro.org>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Cc: 石洋 <yang.s@alibaba-inc.com>
commit 1c08c22c874ac88799cab1f78c40f46110274915 upstream.
The memory_pressure control file was incorrectly set up without
a private value (0, by default). As a result, this control
file was treated like memory_migrate on read. By adding back the
FILE_MEMORY_PRESSURE private value, the correct memory pressure value
will be returned.
Signed-off-by: Waiman Long <longman@redhat.com>
Fixes: 7dbdb199d3bf ("cgroup: replace cftype->mode with CFTYPE_WORLD_WRITABLE")
commit 05384213436ab690c46d9dfec706b80ef8d671ab upstream.
Starting from GCC 7.1, __gcov_exit is a new symbol expected to be
implemented in a profiling runtime.
[mliska@suse.cz: v2]
Link: http://lkml.kernel.org/r/e63a3c59-0149-c97e-4084-20ca8f146b26@suse.cz
Link: http://lkml.kernel.org/r/8c4084fa-3885-29fe-5fc4-0d4ca199c785@suse.cz
Signed-off-by: Martin Liska <mliska@suse.cz>
Acked-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com>
commit d02038f972538b93011d78c068f44514fbde0a8c upstream.
Link: http://lkml.kernel.org/r/20160701130914.GA23225@styxhp
Signed-off-by: Florian Meier <Florian.Meier@informatik.uni-erlangen.de>
Reviewed-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com>
Tested-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com>
commit 64aee2a965cf2954a038b5522f11d2cd2f0f8f3e upstream.
Regardless of which events form a group, it does not make sense for the
events to target different tasks and/or CPUs, as this leaves the group
inconsistent and impossible to schedule. The core perf code assumes that
these are consistent across (successfully intialised) groups.
Core perf code only verifies this when moving SW events into a HW
context. Thus, we can violate this requirement for pure SW groups and
pure HW groups, unless the relevant PMU driver happens to perform this
verification itself. These mismatched groups subsequently wreak havoc
elsewhere.
For example, we handle watchpoints as SW events, and reserve watchpoint
HW on a per-CPU basis at pmu::event_init() time to ensure that any event
that is initialised is guaranteed to have a slot at pmu::add() time.
However, the core code only checks the group leader's cpu filter (via
event_filter_match()), and can thus install follower events onto CPUs
violating thier (mismatched) CPU filters, potentially installing them
into a CPU without sufficient reserved slots.
This can be triggered with the below test case, resulting in warnings
from arch backends.
#define _GNU_SOURCE
#include <linux/hw_breakpoint.h>
#include <linux/perf_event.h>
#include <sched.h>
#include <stdio.h>
#include <sys/prctl.h>
#include <sys/syscall.h>
#include <unistd.h>
static int perf_event_open(struct perf_event_attr *attr, pid_t pid, int cpu,
int group_fd, unsigned long flags)
return syscall(__NR_perf_event_open, attr, pid, cpu, group_fd, flags);
char watched_char;
struct perf_event_attr wp_attr = {
.type = PERF_TYPE_BREAKPOINT,
.bp_type = HW_BREAKPOINT_RW,
.bp_addr = (unsigned long)&watched_char,
.bp_len = 1,
.size = sizeof(wp_attr),
int main(int argc, char *argv[])
int leader, ret;
cpu_set_t cpus;
* Force use of CPU0 to ensure our CPU0-bound events get scheduled.
CPU_ZERO(&cpus);
CPU_SET(0, &cpus);
ret = sched_setaffinity(0, sizeof(cpus), &cpus);
if (ret) {
printf("Unable to set cpu affinity\n");
return 1;
/* open leader event, bound to this task, CPU0 only */
leader = perf_event_open(&wp_attr, 0, 0, -1, 0);
if (leader < 0) {
printf("Couldn't open leader: %d\n", leader);
return 1;
* Open a follower event that is bound to the same task, but a
* different CPU. This means that the group should never be possible to
* schedule.
ret = perf_event_open(&wp_attr, 0, 1, leader, 0);
if (ret < 0) {
printf("Couldn't open mismatched follower: %d\n", ret);
return 1;
} else {
printf("Opened leader/follower with mismastched CPUs\n");
* Open as many independent events as we can, all bound to the same
* task, CPU0 only.
do {
ret = perf_event_open(&wp_attr, 0, 0, -1, 0);
} while (ret >= 0);
* Force enable/disble all events to trigger the erronoeous
* installation of the follower event.
printf("Opened all events. Toggling..\n");
for (;;) {
prctl(PR_TASK_PERF_EVENTS_DISABLE, 0, 0, 0, 0);
prctl(PR_TASK_PERF_EVENTS_ENABLE, 0, 0, 0, 0);
return 0;
Fix this by validating this requirement regardless of whether we're
moving events.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Cc: Zhou Chengming <zhouchengming1@huawei.com>
Link: http://lkml.kernel.org/r/1498142498-15758-1-git-send-email-mark.rutland@arm.com
commit 8b0db1a5bdfcee0dbfa89607672598ae203c9045 upstream.
Performing the following task with kmemleak enabled:
# cd /sys/kernel/tracing/events/irq/irq_handler_entry/
# echo 'enable_event:kmem:kmalloc:3 if irq >' > trigger
# echo 'enable_event:kmem:kmalloc:3 if irq > 31' > trigger
unreferenced object 0xffff8800b9290308 (size 32):
comm "bash", pid 1114, jiffies 4294848451 (age 141.139s)
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
backtrace:
[<ffffffff81cef5aa>] kmemleak_alloc+0x4a/0xa0
[<ffffffff81357938>] kmem_cache_alloc_trace+0x158/0x290
[<ffffffff81261c09>] create_filter_start.constprop.28+0x99/0x940
[<ffffffff812639c9>] create_filter+0xa9/0x160
[<ffffffff81263bdc>] create_event_filter+0xc/0x10
[<ffffffff812655e5>] set_trigger_filter+0xe5/0x210
[<ffffffff812660c4>] event_enable_trigger_func+0x324/0x490
[<ffffffff812652e2>] event_trigger_write+0x1a2/0x260
[<ffffffff8138cf87>] __vfs_write+0xd7/0x380
[<ffffffff8138f421>] vfs_write+0x101/0x260
[<ffffffff8139187b>] SyS_write+0xab/0x130
[<ffffffff81cfd501>] entry_SYSCALL_64_fastpath+0x1f/0xbe
The function create_filter() is passed a 'filterp' pointer that gets
allocated, and if "set_str" is true, it is up to the caller to free it, even
on error. The problem is that the pointer is not freed by create_filter()
when set_str is false. This is a bug, and it is not up to the caller to free
the filter on error if it doesn't care about the string.
Link: http://lkml.kernel.org/r/1502705898-27571-2-git-send-email-chuhu@redhat.com
Fixes: 38b78eb85 ("tracing: Factorize filter creation")
Reported-by: Chunyu Hu <chuhu@redhat.com>
Tested-by: Chunyu Hu <chuhu@redhat.com>
commit dd1c1f2f2028a7b851f701fc6a8ebe39dcb95e7c upstream.
This was reported many times, and this was even mentioned in commit
52ee2dfdd4f5 ("pids: refactor vnr/nr_ns helpers to make them safe") but
somehow nobody bothered to fix the obvious problem: task_tgid_nr_ns() is
not safe because task->group_leader points to nowhere after the exiting
task passes exit_notify(), rcu_read_lock() can not help.
We really need to change __unhash_process() to nullify group_leader,
parent, and real_parent, but this needs some cleanups. Until then we
can turn task_tgid_nr_ns() into another user of __task_pid_nr_ns() and
fix the problem.
Reported-by: Troy Kensinger <tkensinger@google.com>
commit d76036ab47eafa6ce52b69482e91ca3ba337d6d6 upstream.
audit_remove_watch_rule() drops watch's reference to parent but then
continues to work with it. That is not safe as parent can get freed once
we drop our reference. The following is a trivial reproducer:
mount -o loop image /mnt
touch /mnt/file
auditctl -w /mnt/file -p wax
umount /mnt
auditctl -D
<crash in fsnotify_destroy_mark()>
Grab our own reference in audit_remove_watch_rule() earlier to make sure
mark does not get freed under us.
Reported-by: Tony Jones <tonyj@suse.de>
Tested-by: Tony Jones <tonyj@suse.de>
Signed-off-by: Paul Moore <paul@paul-moore.com>
commit 89affbf5d9ebb15c6460596822e8857ea2f9e735 upstream.
In codepaths that use the begin/retry interface for reading
mems_allowed_seq with irqs disabled, there exists a race condition that
stalls the patch process after only modifying a subset of the
static_branch call sites.
This problem manifested itself as a deadlock in the slub allocator,
inside get_any_partial. The loop reads mems_allowed_seq value (via
read_mems_allowed_begin), performs the defrag operation, and then
verifies the consistency of mem_allowed via the read_mems_allowed_retry
and the cookie returned by xxx_begin.
The issue here is that both begin and retry first check if cpusets are
enabled via cpusets_enabled() static branch. This branch can be
rewritted dynamically (via cpuset_inc) if a new cpuset is created. The
x86 jump label code fully synchronizes across all CPUs for every entry
it rewrites. If it rewrites only one of the callsites (specifically the
one in read_mems_allowed_retry) and then waits for the
smp_call_function(do_sync_core) to complete while a CPU is inside the
begin/retry section with IRQs off and the mems_allowed value is changed,
we can hang.
This is because begin() will always return 0 (since it wasn't patched
yet) while retry() will test the 0 against the actual value of the seq
counter.
The fix is to use two different static keys: one for begin
(pre_enable_key) and one for retry (enable_key). In cpuset_inc(), we
first bump the pre_enable key to ensure that cpuset_mems_allowed_begin()
always return a valid seqcount if are enabling cpusets. Similarly, when
disabling cpusets via cpuset_dec(), we first ensure that callers of
cpuset_mems_allowed_retry() will start ignoring the seqcount value
before we let cpuset_mems_allowed_begin() return 0.
The relevant stack traces of the two stuck threads:
CPU: 1 PID: 1415 Comm: mkdir Tainted: G L 4.9.36-00104-g540c51286237 #4
Hardware name: Default string Default string/Hardware, BIOS 4.29.1-20170526215256 05/26/2017
task: ffff8817f9c28000 task.stack: ffffc9000ffa4000
RIP: smp_call_function_many+0x1f9/0x260
Call Trace:
smp_call_function+0x3b/0x70
on_each_cpu+0x2f/0x90
text_poke_bp+0x87/0xd0
arch_jump_label_transform+0x93/0x100
__jump_label_update+0x77/0x90
jump_label_update+0xaa/0xc0
static_key_slow_inc+0x9e/0xb0
cpuset_css_online+0x70/0x2e0
online_css+0x2c/0xa0
cgroup_apply_control_enable+0x27f/0x3d0
cgroup_mkdir+0x2b7/0x420
kernfs_iop_mkdir+0x5a/0x80
vfs_mkdir+0xf6/0x1a0
SyS_mkdir+0xb7/0xe0
entry_SYSCALL_64_fastpath+0x18/0xad
CPU: 2 PID: 1 Comm: init Tainted: G L 4.9.36-00104-g540c51286237 #4
task: ffff8818087c0000 task.stack: ffffc90000030000
RIP: int3+0x39/0x70
Call Trace:
<#DB> ? ___slab_alloc+0x28b/0x5a0
<EOE> ? copy_process.part.40+0xf7/0x1de0
__slab_alloc.isra.80+0x54/0x90
kmem_cache_alloc_node+0x8a/0x280
_do_fork+0xe7/0x6c0
_raw_spin_unlock_irq+0x2d/0x60
trace_hardirqs_on_caller+0x136/0x1d0
entry_SYSCALL_64_fastpath+0x5/0xad
do_syscall_64+0x27/0x350
SyS_clone+0x19/0x20
do_syscall_64+0x60/0x350
entry_SYSCALL64_slow_path+0x25/0x25
Link: http://lkml.kernel.org/r/20170731040113.14197-1-dmitriyz@waymo.com
Fixes: 46e700abc44c ("mm, page_alloc: remove unnecessary taking of a seqlock when cpusets are disabled")
Signed-off-by: Dima Zavin <dmitriyz@waymo.com>
Reported-by: Cliff Spradlin <cspradlin@waymo.com>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Christopher Lameter <cl@linux.com>
Cc: Li Zefan <lizefan@huawei.com>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Mel Gorman <mgorman@techsingularity.net>
commit 0a94efb5acbb6980d7c9ab604372d93cd507e4d8 upstream.
5c0338c68706 ("workqueue: restore WQ_UNBOUND/max_active==1 to be
ordered") automatically enabled ordered attribute for unbound
workqueues w/ max_active == 1. Because ordered workqueues reject
max_active and some attribute changes, this implicit ordered mode
broke cases where the user creates an unbound workqueue w/ max_active
== 1 and later explicitly changes the related attributes.
This patch distinguishes explicit and implicit ordered setting and
overrides from attribute changes if implict.
Fixes: 5c0338c68706 ("workqueue: restore WQ_UNBOUND/max_active==1 to be ordered")
Cc: Holger Hoffstätte <holger@applied-asynchrony.com>
[ Upstream commit 2d39b3cd34e6d323720d4c61bd714f5ae202c022 ]
Since commit 00cd5c37afd5 ("ptrace: permit ptracing of /sbin/init") we
can now trace init processes. init is initially protected with
SIGNAL_UNKILLABLE which will prevent fatal signals such as SIGSTOP, but
there are a number of paths during tracing where SIGNAL_UNKILLABLE can
be implicitly cleared.
This can result in init becoming stoppable/killable after tracing. For
example, running:
while true; do kill -STOP 1; done &
strace -p 1
and then stopping strace and the kill loop will result in init being
left in state TASK_STOPPED. Sending SIGCONT to init will resume it, but
init will now respond to future SIGSTOP signals rather than ignoring
them.
Make sure that when setting SIGNAL_STOP_CONTINUED/SIGNAL_STOP_STOPPED
that we don't clear SIGNAL_UNKILLABLE.
Link: http://lkml.kernel.org/r/20170104122017.25047-1-jamie.iles@oracle.com
Signed-off-by: Jamie Iles <jamie.iles@oracle.com>
Acked-by: Oleg Nesterov <oleg@redhat.com>
commit 5c0338c68706be53b3dc472e4308961c36e4ece1 upstream.
The combination of WQ_UNBOUND and max_active == 1 used to imply
ordered execution. After NUMA affinity 4c16bd327c74 ("workqueue:
implement NUMA affinity for unbound workqueues"), this is no longer
true due to per-node worker pools.
While the right way to create an ordered workqueue is
alloc_ordered_workqueue(), the documentation has been misleading for a
long time and people do use WQ_UNBOUND and max_active == 1 for ordered
workqueues which can lead to subtle bugs which are very difficult to
trigger.
It's unlikely that we'd see noticeable performance impact by enforcing
ordering on WQ_UNBOUND / max_active == 1 workqueues. Let's
automatically set __WQ_ORDERED for those workqueues.
Reported-by: Christoph Hellwig <hch@infradead.org>
Reported-by: Alexei Potashnik <alexei@purestorage.com>
Fixes: 4c16bd327c74 ("workqueue: implement NUMA affinity for unbound workqueues")
commit 3d89e5478bf550a50c99e93adf659369798263b0 upstream.
Commit:
e9532e69b8d1 ("sched/cputime: Fix steal time accounting vs. CPU hotplug")
... set rq->prev_* to 0 after a CPU hotplug comes back, in order to
fix the case where (after CPU hotplug) steal time is smaller than
rq->prev_steal_time.
However, this should never happen. Steal time was only smaller because of the
KVM-specific bug fixed by the previous patch. Worse, the previous patch
triggers a bug on CPU hot-unplug/plug operation: because
rq->prev_steal_time is cleared, all of the CPU's past steal time will be
accounted again on hot-plug.
Since the root cause has been fixed, we can just revert commit e9532e69b8d1.
Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com>
Acked-by: Paolo Bonzini <pbonzini@redhat.com>
Cc: Radim Krčmář <rkrcmar@redhat.com>
Fixes: 'commit e9532e69b8d1 ("sched/cputime: Fix steal time accounting vs. CPU hotplug")'
Link: http://lkml.kernel.org/r/1465813966-3116-3-git-send-email-wanpeng.li@hotmail.com
Signed-off-by: Andres Oportus <andresoportus@google.com>
commit 51d7b120418e99d6b3bf8df9eb3cc31e8171dee4 upstream.
In commit c4004b02f8e5b ("x86: remove the kernel code/data/bss resources
from /proc/iomem") I was hoping to remove the phyiscal kernel address
data from /proc/iomem entirely, but that had to be reverted because some
system programs actually use it.
This limits all the detailed resource information to properly
credentialed users instead.
[sumits: this is used in Ubuntu as a fix for CVE-2015-8944]
commit 96b777452d8881480fd5be50112f791c17db4b6b upstream.
Commit:
2f5177f0fd7e ("sched/cgroup: Fix/cleanup cgroup teardown/init")
.. moved sched_online_group() from css_online() to css_alloc().
It exposes half-baked task group into global lists before initializing
generic cgroup stuff.
LTP testcase (third in cgroup_regression_test) written for testing
similar race in kernels 2.6.26-2.6.28 easily triggers this oops:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000008
IP: kernfs_path_from_node_locked+0x260/0x320
CPU: 1 PID: 30346 Comm: cat Not tainted 4.10.0-rc5-test #4
Call Trace:
? kernfs_path_from_node+0x4f/0x60
kernfs_path_from_node+0x3e/0x60
print_rt_rq+0x44/0x2b0
print_rt_stats+0x7a/0xd0
print_cpu+0x2fc/0xe80
? __might_sleep+0x4a/0x80
sched_debug_show+0x17/0x30
seq_read+0xf2/0x3b0
proc_reg_read+0x42/0x70
__vfs_read+0x28/0x130
? security_file_permission+0x9b/0xc0
? rw_verify_area+0x4e/0xb0
vfs_read+0xa5/0x170
SyS_read+0x46/0xa0
entry_SYSCALL_64_fastpath+0x1e/0xad
Here the task group is already linked into the global RCU-protected 'task_groups'
list, but the css->cgroup pointer is still NULL.
This patch reverts this chunk and moves online back to css_online().
Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Fixes: 2f5177f0fd7e ("sched/cgroup: Fix/cleanup cgroup teardown/init")
Link: http://lkml.kernel.org/r/148655324740.424917.5302984537258726349.stgit@buzz
Signed-off-by: Matt Fleming <matt@codeblueprint.co.uk>
Commit ff86bf0c65f1 ("alarmtimer: Rate limit periodic intervals") sets a
minimum bound on the alarm timer interval. This minimum bound shouldn't
be applied if the interval is 0. Otherwise, one-shot timers will be
converted into periodic ones.
Fixes: ff86bf0c65f1 ("alarmtimer: Rate limit periodic intervals")
Reported-by: Ben Fennema <fennema@google.com>
Signed-off-by: Greg Hackmann <ghackmann@google.com>
Cc: John Stultz <john.stultz@linaro.org>
commit db9108e054700c96322b0f0028546aa4e643cf0b upstream.
Hit the kmemleak when executing instance_rmdir, it forgot releasing
mem of tracing_cpumask. With this fix, the warn does not appear any
more.
unreferenced object 0xffff93a8dfaa7c18 (size 8):
comm "mkdir", pid 1436, jiffies 4294763622 (age 9134.308s)
hex dump (first 8 bytes):
ff ff ff ff ff ff ff ff ........
backtrace:
[<ffffffff88b6567a>] kmemleak_alloc+0x4a/0xa0
[<ffffffff8861ea41>] __kmalloc_node+0xf1/0x280
[<ffffffff88b505d3>] alloc_cpumask_var_node+0x23/0x30
[<ffffffff88b5060e>] alloc_cpumask_var+0xe/0x10
[<ffffffff88571ab0>] instance_mkdir+0x90/0x240
[<ffffffff886e5100>] tracefs_syscall_mkdir+0x40/0x70
[<ffffffff886565c9>] vfs_mkdir+0x109/0x1b0
[<ffffffff8865b1d0>] SyS_mkdir+0xd0/0x100
[<ffffffff88403857>] do_syscall_64+0x67/0x150
[<ffffffff88b710e7>] return_from_SYSCALL_64+0x0/0x6a
Link: http://lkml.kernel.org/r/1500546969-12594-1-git-send-email-chuhu@redhat.com
Fixes: ccfe9e42e451 ("tracing: Make tracing_cpumask available for all instances")
Signed-off-by: Chunyu Hu <chuhu@redhat.com>
commit 6a8a75f3235724c5941a33e287b2f98966ad14c5 upstream.
This reverts commit cc1582c231ea041fbc68861dfaf957eaf902b829.
This commit introduced a regression that broke rr-project, which uses sampling
events to receive a signal on overflow (but does not care about the contents
of the sample). These signals are critical to the correct operation of rr.
There's been some back and forth about how to fix it - but to not keep
applications in limbo queue up a revert.
Reported-by: Kyle Huey <me@kylehuey.com>
Acked-by: Kyle Huey <me@kylehuey.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Cc: Jin Yao <yao.jin@linux.intel.com>
Cc: Vince Weaver <vincent.weaver@maine.edu>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/r/20170628105600.GC5981@leverpostej
commit 2e028c4fe12907f226b8221815f16c2486ad3aa7 upstream.
My static checker complains that if "func" is NULL then "clear_filter"
is uninitialized. This seems like it could be true, although it's
possible something subtle is happening that I haven't seen.
kernel/trace/ftrace.c:3844 match_records()
error: uninitialized symbol 'clear_filter'.
Link: http://lkml.kernel.org/r/20170712073556.h6tkpjcdzjaozozs@mwanda
Fixes: f0a3b154bd7 ("ftrace: Clarify code for mod command")
commit c59f29cb144a6a0dfac16ede9dc8eafc02dc56ca upstream.
The 's' flag is supposed to indicate that a softirq is running. This
can be detected by testing the preempt_count with SOFTIRQ_OFFSET.
The current code tests the preempt_count with SOFTIRQ_MASK, which
would be true even when softirqs are disabled but not serving a
softirq.
Link: http://lkml.kernel.org/r/1481300417-3564-1-git-send-email-pkondeti@codeaurora.org
Signed-off-by: Pavankumar Kondeti <pkondeti@codeaurora.org>
Signed-off-by: Amit Pundir <amit.pundir@linaro.org>
commit f32d782e31bf079f600dcec126ed117b0577e85c upstream.
The group mask is always used in intersection with the group CPUs. So,
when building the group mask, we don't have to care about CPUs that are
not part of the group.
Signed-off-by: Lauro Ramos Venancio <lvenanci@redhat.com>
Cc: lwang@redhat.com
Cc: riel@redhat.com
Link: http://lkml.kernel.org/r/1492717903-5195-2-git-send-email-lvenanci@redhat.com
commit 73bb059f9b8a00c5e1bf2f7ca83138c05d05e600 upstream.
The point of sched_group_mask is to select those CPUs from
sched_group_cpus that can actually arrive at this balance domain.
The current code gets it wrong, as can be readily demonstrated with a
topology like:
node 0 1 2 3
0: 10 20 30 20
1: 20 10 20 30
2: 30 20 10 20
3: 20 30 20 10
Where (for example) domain 1 on CPU1 ends up with a mask that includes
CPU0:
[] CPU1 attaching sched-domain:
[] domain 0: span 0-2 level NUMA
[] groups: 1 (mask: 1), 2, 0
[] domain 1: span 0-3 level NUMA
[] groups: 0-2 (mask: 0-2) (cpu_capacity: 3072), 0,2-3 (cpu_capacity: 3072)
This causes sched_balance_cpu() to compute the wrong CPU and
consequently should_we_balance() will terminate early resulting in
missed load-balance opportunities.
The fixed topology looks like:
[] groups: 0-2 (mask: 1) (cpu_capacity: 3072), 0,2-3 (cpu_capacity: 3072)
(note: this relies on OVERLAP domains to always have children, this is
true because the regular topology domains are still here -- this is
before degenerate trimming)
Debugged-by: Lauro Ramos Venancio <lvenanci@redhat.com>
Fixes: e3589f6c81e4 ("sched: Allow for overlapping sched_domain spans")
commit c0d80ddab89916273cb97114889d3f337bc370ae upstream.
core_kernel_text is used by MIPS in its function graph trace processing,
so having this method traced leads to an infinite set of recursive calls
such as:
Call Trace:
ftrace_return_to_handler+0x50/0x128
core_kernel_text+0x10/0x1b8
prepare_ftrace_return+0x6c/0x114
ftrace_graph_caller+0x20/0x44
return_to_handler+0x10/0x30
return_to_handler+0x0/0x30
ftrace_ops_no_ops+0x114/0x1bc
Mark the function notrace to avoid it being traced.
Link: http://lkml.kernel.org/r/1498028607-6765-1-git-send-email-marcin.nowakowski@imgtec.com
Signed-off-by: Marcin Nowakowski <marcin.nowakowski@imgtec.com>
Reviewed-by: Masami Hiramatsu <mhiramat@kernel.org>
Cc: Thomas Meyer <thomas@m3y3r.de>
Cc: Daniel Borkmann <daniel@iogearbox.net>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
commit 6bdf6abc56b53103324dfd270a86580306e1a232 upstream.
Leaking kernel addresses on unpriviledged is generally disallowed,
for example, verifier rejects the following:
0: (b7) r0 = 0
1: (18) r2 = 0xffff897e82304400
3: (7b) *(u64 *)(r1 +48) = r2
R2 leaks addr into ctx
Doing pointer arithmetic on them is also forbidden, so that they
don't turn into unknown value and then get leaked out. However,
there's xadd as a special case, where we don't check the src reg
for being a pointer register, e.g. the following will pass:
0: (b7) r0 = 0
1: (7b) *(u64 *)(r1 +48) = r0
2: (18) r2 = 0xffff897e82304400 ; map
4: (db) lock *(u64 *)(r1 +48) += r2
5: (95) exit
We could store the pointer into skb->cb, loose the type context,
and then read it out from there again to leak it eventually out
of a map value. Or more easily in a different variant, too:
0: (bf) r6 = r1
1: (7a) *(u64 *)(r10 -8) = 0
2: (bf) r2 = r10
3: (07) r2 += -8
4: (18) r1 = 0x0
6: (85) call bpf_map_lookup_elem#1
7: (15) if r0 == 0x0 goto pc+3
R0=map_value(ks=8,vs=8,id=0),min_value=0,max_value=0 R6=ctx R10=fp
8: (b7) r3 = 0
9: (7b) *(u64 *)(r0 +0) = r3
10: (db) lock *(u64 *)(r0 +0) += r6
11: (b7) r0 = 0
12: (95) exit
from 7 to 11: R0=inv,min_value=0,max_value=0 R6=ctx R10=fp
11: (b7) r0 = 0
12: (95) exit
Prevent this by checking xadd src reg for pointer types. Also
add a couple of test cases related to this.
Fixes: 1be7f75d1668 ("bpf: enable non-root eBPF programs")
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Acked-by: Martin KaFai Lau <kafai@fb.com>
Acked-by: Edward Cree <ecree@solarflare.com>
commit 425fffd886bae3d127a08fa6a17f2e31e24ed7ff upstream.
Currently, inputting the following command will succeed but actually the
value will be truncated:
# echo 0x12ffffffff > /proc/sys/net/ipv4/tcp_notsent_lowat
This is not friendly to the user, so instead, we should report error
when the value is larger than UINT_MAX.
Fixes: e7d316a02f68 ("sysctl: handle error writing UINT_MAX to u32 fields")
Signed-off-by: Liping Zhang <zlpnobody@gmail.com>
Cc: Subash Abhinov Kasiviswanathan <subashab@codeaurora.org>
Cc: Eric W. Biederman <ebiederm@xmission.com>
commit 5380e5644afbba9e3d229c36771134976f05c91e upstream.
I saw some very confusing sysctl output on my system:
# cat /proc/sys/net/core/xfrm_aevent_rseqth
-2
# cat /proc/sys/net/core/xfrm_aevent_etime
-10
# cat /proc/sys/net/ipv4/tcp_notsent_lowat
-4294967295
Because we forget to set the *negp flag in proc_douintvec, so it will
become a garbage value.
Since the value related to proc_douintvec is always an unsigned integer,
so we can set *negp to false explictily to fix this issue.
commit 9e52b32567126fe146f198971364f68d3bc5233f upstream.
Always try to parse an address, since kstrtoul() will safely fail when
given a symbol as input. If that fails (which will be the case for a
symbol), try to parse a symbol instead.
This allows creating a probe such as:
p:probe/vlan_gro_receive 8021q:vlan_gro_receive+0
Which is necessary for this command to work:
perf probe -m 8021q -a vlan_gro_receive
Link: http://lkml.kernel.org/r/fd72d666f45b114e2c5b9cf7e27b91de1ec966f1.1498122881.git.sd@queasysnail.net
Fixes: 413d37d1e ("tracing: Add kprobe-based event tracer")
Acked-by: Masami Hiramatsu <mhiramat@kernel.org>
Signed-off-by: Sabrina Dubroca <sd@queasysnail.net>
commit 6e5f32f7a43f45ee55c401c0b9585eb01f9629a8 upstream.
If we crossed a sample window while in NO_HZ we will add LOAD_FREQ to
the pending sample window time on exit, setting the next update not
one window into the future, but two.
This situation on exiting NO_HZ is described by:
this_rq->calc_load_update < jiffies < calc_load_update
In this scenario, what we should be doing is:
this_rq->calc_load_update = calc_load_update [ next window ]
But what we actually do is:
this_rq->calc_load_update = calc_load_update + LOAD_FREQ [ next+1 window ]
This has the effect of delaying load average updates for potentially
up to ~9seconds.
This can result in huge spikes in the load average values due to
per-cpu uninterruptible task counts being out of sync when accumulated
across all CPUs.
It's safe to update the per-cpu active count if we wake between sample
windows because any load that we left in 'calc_load_idle' will have
been zero'd when the idle load was folded in calc_global_load().
This issue is easy to reproduce before,
commit 9d89c257dfb9 ("sched/fair: Rewrite runnable load and utilization average tracking")
just by forking short-lived process pipelines built from ps(1) and
grep(1) in a loop. I'm unable to reproduce the spikes after that
commit, but the bug still seems to be present from code review.
Cc: Mike Galbraith <umgwanakikbuti@gmail.com>
Cc: Morten Rasmussen <morten.rasmussen@arm.com>
Cc: Vincent Guittot <vincent.guittot@linaro.org>
Fixes: commit 5167e8d ("sched/nohz: Rewrite and fix load-avg computation -- again")
Link: http://lkml.kernel.org/r/20170217120731.11868-2-matt@codeblueprint.co.uk
[ Upstream commit ff7a28a074ccbea999dadbb58c46212cf90984c6 ]
When a system panics, the "Rebooting in X seconds.." message is never
printed because it lacks a new line. Fix it.
Link: http://lkml.kernel.org/r/20170119114751.2724-1-jslaby@suse.cz
commit 41662f5cc55335807d39404371cfcbb1909304c4 upstream.
SYSCTL_WRITES_WARN was added in commit f4aacea2f5d1 ("sysctl: allow for
strict write position handling"), and released in v3.16 in August of
2014. Since then I can find only 1 instance of non-zero offset
writing[1], and it was fixed immediately in CRIU[2]. As such, it
appears safe to flip this to the strict state now.
[1] https://www.google.com/search?q="when%20file%20position%20was%20not%200"
[2] http://lists.openvz.org/pipermail/criu/2015-April/019819.html
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Sumit Semwal <sumit.semwal@linaro.org>
commit ceea5e3771ed2378668455fa21861bead7504df5 upstream.
In tests, which excercise switching of clocksources, a NULL
pointer dereference can be observed on AMR64 platforms in the
clocksource read() function:
u64 clocksource_mmio_readl_down(struct clocksource *c)
return ~(u64)readl_relaxed(to_mmio_clksrc(c)->reg) & c->mask;
This is called from the core timekeeping code via:
cycle_now = tkr->read(tkr->clock);
tkr->read is the cached tkr->clock->read() function pointer.
When the clocksource is changed then tkr->clock and tkr->read
are updated sequentially. The code above results in a sequential
load operation of tkr->read and tkr->clock as well.
If the store to tkr->clock hits between the loads of tkr->read
and tkr->clock, then the old read() function is called with the
new clock pointer. As a consequence the read() function
dereferences a different data structure and the resulting 'reg'
pointer can point anywhere including NULL.
This problem was introduced when the timekeeping code was
switched over to use struct tk_read_base. Before that, it was
theoretically possible as well when the compiler decided to
reload clock in the code sequence:
now = tk->clock->read(tk->clock);
Add a helper function which avoids the issue by reading
tk_read_base->clock once into a local variable clk and then issue
the read function via clk->read(clk). This guarantees that the
read() function always gets the proper clocksource pointer handed
in.
Since there is now no use for the tkr.read pointer, this patch
also removes it, and to address stopping the fast timekeeper
during suspend/resume, it introduces a dummy clocksource to use
rather then just a dummy read function.
Signed-off-by: John Stultz <john.stultz@linaro.org>
Acked-by: Ingo Molnar <mingo@kernel.org>
Cc: Prarit Bhargava <prarit@redhat.com>
Cc: Richard Cochran <richardcochran@gmail.com>
Cc: Stephen Boyd <stephen.boyd@linaro.org>
Cc: Miroslav Lichvar <mlichvar@redhat.com>
Cc: Daniel Mentz <danielmentz@google.com>
Link: http://lkml.kernel.org/r/1496965462-20003-2-git-send-email-john.stultz@linaro.org
commit 57db7e4a2d92c2d3dfbca4ef8057849b2682436b upstream.
Thomas Gleixner wrote:
> The CRIU support added a 'feature' which allows a user space task to send
> arbitrary (kernel) signals to itself. The changelog says:
> The kernel prevents sending of siginfo with positive si_code, because
> these codes are reserved for kernel. I think we can allow a task to
> send such a siginfo to itself. This operation should not be dangerous.
> Quite contrary to that claim, it turns out that it is outright dangerous
> for signals with info->si_code == SI_TIMER. The following code sequence in
> a user space task allows to crash the kernel:
> id = timer_create(CLOCK_XXX, ..... signo = SIGX);
> timer_set(id, ....);
> info->si_signo = SIGX;
> info->si_code = SI_TIMER:
> info->_sifields._timer._tid = id;
> info->_sifields._timer._sys_private = 2;
> rt_[tg]sigqueueinfo(..., SIGX, info);
> sigemptyset(&sigset);
> sigaddset(&sigset, SIGX);
> rt_sigtimedwait(sigset, info);
> For timers based on CLOCK_PROCESS_CPUTIME_ID, CLOCK_THREAD_CPUTIME_ID this
> results in a kernel crash because sigwait() dequeues the signal and the
> dequeue code observes:
> info->si_code == SI_TIMER && info->_sifields._timer._sys_private != 0
> which triggers the following callchain:
> do_schedule_next_timer() -> posix_cpu_timer_schedule() -> arm_timer()
> arm_timer() executes a list_add() on the timer, which is already armed via
> the timer_set() syscall. That's a double list add which corrupts the posix
> cpu timer list. As a consequence the kernel crashes on the next operation
> touching the posix cpu timer list.
> Posix clocks which are internally implemented based on hrtimers are not
> affected by this because hrtimer_start() can handle already armed timers
> nicely, but it's a reliable way to trigger the WARN_ON() in
> hrtimer_forward(), which complains about calling that function on an
> already armed timer.
This problem has existed since the posix timer code was merged into
2.5.63. A few releases earlier in 2.5.60 ptrace gained the ability to
inject not just a signal (which linux has supported since 1.0) but the
full siginfo of a signal.
The core problem is that the code will reschedule in response to
signals getting dequeued not just for signals the timers sent but
for other signals that happen to a si_code of SI_TIMER.
Avoid this confusion by testing to see if the queued signal was
preallocated as all timer signals are preallocated, and so far
only the timer code preallocates signals.
Move the check for if a timer needs to be rescheduled up into
collect_signal where the preallocation check must be performed,
and pass the result back to dequeue_signal where the code reschedules
timers. This makes it clear why the code cares about preallocated
timers.
Reported-by: Thomas Gleixner <tglx@linutronix.de>
History Tree: https://git.kernel.org/pub/scm/linux/kernel/git/tglx/history.git
Reference: 66dd34ad31e5 ("signal: allow to send any siginfo to itself")
Reference: 1669ce53e2ff ("Add PTRACE_GETSIGINFO and PTRACE_SETSIGINFO")
Fixes: db8b50ba75f2 ("[PATCH] POSIX clocks & timers")
commit ff86bf0c65f14346bf2440534f9ba5ac232c39a0 upstream.
The alarmtimer code has another source of potentially rearming itself too
fast. Interval timers with a very samll interval have a similar CPU hog
effect as the previously fixed overflow issue.
The reason is that alarmtimers do not implement the normal protection
against this kind of problem which the other posix timer use:
timer expires -> queue signal -> deliver signal -> rearm timer
This scheme brings the rearming under scheduler control and prevents
permanently firing timers which hog the CPU.
Bringing this scheme to the alarm timer code is a major overhaul because it
lacks all the necessary mechanisms completely.
So for a quick fix limit the interval to one jiffie. This is not
problematic in practice as alarmtimers are usually backed by an RTC for
suspend which have 1 second resolution. It could be therefor argued that
the resolution of this clock should be set to 1 second in general, but
that's outside the scope of this fix.
Cc: Kostya Serebryany <kcc@google.com>
Cc: syzkaller <syzkaller@googlegroups.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Link: http://lkml.kernel.org/r/20170530211655.896767100@linutronix.de
commit f4781e76f90df7aec400635d73ea4c35ee1d4765 upstream.
Andrey reported a alartimer related RCU stall while fuzzing the kernel with
syzkaller.
The reason for this is an overflow in ktime_add() which brings the
resulting time into negative space and causes immediate expiry of the
timer. The following rearm with a small interval does not bring the timer
back into positive space due to the same issue.
This results in a permanent firing alarmtimer which hogs the CPU.
Use ktime_add_safe() instead which detects the overflow and clamps the
result to KTIME_SEC_MAX.
Reported-by: Andrey Konovalov <andreyknvl@google.com>
Link: http://lkml.kernel.org/r/20170530211655.802921648@linutronix.de
