commit 62d3c5439c534b0e6c653fc63e6d8c67be3a57b1 upstream.
This patch (as1519) fixes a bug in the block layer's disk-events
polling. The polling is done by a work routine queued on the
system_nrt_wq workqueue. Since that workqueue isn't freezable, the
polling continues even in the middle of a system sleep transition.
Obviously, polling a suspended drive for media changes and such isn't
a good thing to do; in the case of USB mass-storage devices it can
lead to real problems requiring device resets and even re-enumeration.
The patch fixes things by creating a new system-wide, non-reentrant,
freezable workqueue and using it for disk-events polling.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Acked-by: Tejun Heo <tj@kernel.org>
Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
3.0.21's 603b63484725a6e88e4ae5da58716efd88154b1e directly used
the upstream patch, yet kprobes locking in 3.0.x uses spin_lock...()
rather than raw_spin_lock...().
Signed-off-by: Jan Beulich <jbeulich@suse.com>
commit 52abb700e16a9aa4cbc03f3d7f80206cbbc80680 upstream.
Xommit ac5637611(genirq: Unmask oneshot irqs when thread was not woken)
fails to unmask when a !IRQ_ONESHOT threaded handler is handled by
handle_level_irq.
This happens because thread_mask is or'ed unconditionally in
irq_wake_thread(), but for !IRQ_ONESHOT interrupts never cleared. So
the check for !desc->thread_active fails and keeps the interrupt
disabled.
Keep the thread_mask zero for !IRQ_ONESHOT interrupts.
Document the thread_mask magic while at it.
Reported-and-tested-by: Sven Joachim <svenjoac@gmx.de>
Reported-and-tested-by: Stefan Lippers-Hollmann <s.l-h@gmx.de>
commit d80e731ecab420ddcb79ee9d0ac427acbc187b4b upstream.
This patch is intentionally incomplete to simplify the review.
It ignores ep_unregister_pollwait() which plays with the same wqh.
See the next change.
epoll assumes that the EPOLL_CTL_ADD'ed file controls everything
f_op->poll() needs. In particular it assumes that the wait queue
can't go away until eventpoll_release(). This is not true in case
of signalfd, the task which does EPOLL_CTL_ADD uses its ->sighand
which is not connected to the file.
This patch adds the special event, POLLFREE, currently only for
epoll. It expects that init_poll_funcptr()'ed hook should do the
necessary cleanup. Perhaps it should be defined as EPOLLFREE in
eventpoll.
__cleanup_sighand() is changed to do wake_up_poll(POLLFREE) if
->signalfd_wqh is not empty, we add the new signalfd_cleanup()
helper.
ep_poll_callback(POLLFREE) simply does list_del_init(task_list).
This make this poll entry inconsistent, but we don't care. If you
share epoll fd which contains our sigfd with another process you
should blame yourself. signalfd is "really special". I simply do
not know how we can define the "right" semantics if it used with
epoll.
The main problem is, epoll calls signalfd_poll() once to establish
the connection with the wait queue, after that signalfd_poll(NULL)
returns the different/inconsistent results depending on who does
EPOLL_CTL_MOD/signalfd_read/etc. IOW: apart from sigmask, signalfd
has nothing to do with the file, it works with the current thread.
In short: this patch is the hack which tries to fix the symptoms.
It also assumes that nobody can take tasklist_lock under epoll
locks, this seems to be true.
Note:
- we do not have wake_up_all_poll() but wake_up_poll()
is fine, poll/epoll doesn't use WQ_FLAG_EXCLUSIVE.
- signalfd_cleanup() uses POLLHUP along with POLLFREE,
we need a couple of simple changes in eventpoll.c to
make sure it can't be "lost".
Reported-by: Maxime Bizon <mbizon@freebox.fr>
commit b4bc724e82e80478cba5fe9825b62e71ddf78757 upstream.
An interrupt might be pending when irq_startup() is called, but the
startup code does not invoke the resend logic. In some cases this
prevents the device from issuing another interrupt which renders the
device non functional.
Call the resend function in irq_startup() to keep things going.
Reported-and-tested-by: Russell King <rmk+kernel@arm.linux.org.uk>
commit ac5637611150281f398bb7a47e3fcb69a09e7803 upstream.
When the primary handler of an interrupt which is marked IRQ_ONESHOT
returns IRQ_HANDLED or IRQ_NONE, then the interrupt thread is not
woken and the unmask logic of the interrupt line is never
invoked. This keeps the interrupt masked forever.
This was not noticed as most IRQ_ONESHOT users wake the thread
unconditionally (usually because they cannot access the underlying
device from hard interrupt context). Though this behaviour was nowhere
documented and not necessarily intentional. Some drivers can avoid the
thread wakeup in certain cases and run into the situation where the
interrupt line s kept masked.
Handle it gracefully.
Reported-and-tested-by: Lothar Wassmann <lw@karo-electronics.de>
commit f6302f1bcd75a042df69866d98b8d775a668f8f1 upstream.
"subbuf_size" and "n_subbufs" come from the user and they need to be
capped to prevent an integer overflow.
commit df754e6af2f237a6c020c0daff55a1a609338e31 upstream.
It's unlikely that TAINT_FIRMWARE_WORKAROUND causes false
lockdep messages, so do not disable lockdep in that case.
We still want to keep lockdep disabled in the
TAINT_OOT_MODULE case:
- bin-only modules can cause various instabilities in
their and in unrelated kernel code
- they are impossible to debug for kernel developers
- they also typically do not have the copyright license
permission to link to the GPL-ed lockdep code.
Suggested-by: Ben Hutchings <ben@decadent.org.uk>
Link: http://lkml.kernel.org/n/tip-xopopjjens57r0i13qnyh2yo@git.kernel.org
commit cb297a3e433dbdcf7ad81e0564e7b804c941ff0d upstream.
This issue happens under the following conditions:
1. preemption is off
2. __ARCH_WANT_INTERRUPTS_ON_CTXSW is defined
3. RT scheduling class
4. SMP system
Sequence is as follows:
1.suppose current task is A. start schedule()
2.task A is enqueued pushable task at the entry of schedule()
__schedule
prev = rq->curr;
put_prev_task
put_prev_task_rt
enqueue_pushable_task
4.pick the task B as next task.
next = pick_next_task(rq);
3.rq->curr set to task B and context_switch is started.
rq->curr = next;
4.At the entry of context_swtich, release this cpu's rq->lock.
context_switch
prepare_task_switch
prepare_lock_switch
raw_spin_unlock_irq(&rq->lock);
5.Shortly after rq->lock is released, interrupt is occurred and start IRQ context
6.try_to_wake_up() which called by ISR acquires rq->lock
try_to_wake_up
ttwu_remote
rq = __task_rq_lock(p)
ttwu_do_wakeup(rq, p, wake_flags);
task_woken_rt
7.push_rt_task picks the task A which is enqueued before.
task_woken_rt
push_rt_tasks(rq)
next_task = pick_next_pushable_task(rq)
8.At find_lock_lowest_rq(), If double_lock_balance() returns 0,
lowest_rq can be the remote rq.
(But,If preemption is on, double_lock_balance always return 1 and it
does't happen.)
push_rt_task
find_lock_lowest_rq
if (double_lock_balance(rq, lowest_rq))..
9.find_lock_lowest_rq return the available rq. task A is migrated to
the remote cpu/rq.
push_rt_task
deactivate_task(rq, next_task, 0);
set_task_cpu(next_task, lowest_rq->cpu);
activate_task(lowest_rq, next_task, 0);
10. But, task A is on irq context at this cpu.
So, task A is scheduled by two cpus at the same time until restore from IRQ.
Task A's stack is corrupted.
To fix it, don't migrate an RT task if it's still running.
Signed-off-by: Chanho Min <chanho.min@lge.com>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Link: http://lkml.kernel.org/r/CAOAMb1BHA=5fm7KTewYyke6u-8DP0iUuJMpgQw54vNeXFsGpoQ@mail.gmail.com
commit 55ca6140e9bb307efc97a9301a4f501de02a6fd6 upstream.
In function pre_handler_kretprobe(), the allocated kretprobe_instance
object will get leaked if the entry_handler callback returns non-zero.
This may cause all the preallocated kretprobe_instance objects exhausted.
This issue can be reproduced by changing
samples/kprobes/kretprobe_example.c to probe "mutex_unlock". And the fix
is straightforward: just put the allocated kretprobe_instance object back
onto the free_instances list.
[akpm@linux-foundation.org: use raw_spin_lock/unlock]
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
Acked-by: Jim Keniston <jkenisto@us.ibm.com>
Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com>
commit f2c0d0266cc5eb36a4aa44944b4096ec121490aa upstream.
syslog-ng versions before 3.3.0beta1 (2011-05-12) assume that
CAP_SYS_ADMIN is sufficient to access syslog, so ever since CAP_SYSLOG
was introduced (2010-11-25) they have triggered a warning.
Commit ee24aebffb75 ("cap_syslog: accept CAP_SYS_ADMIN for now")
improved matters a little by making syslog-ng work again, just keeping
the WARN_ONCE(). But still, this is a warning that writes a stack trace
we don't care about to syslog, sets a taint flag, and alarms sysadmins
when nothing worse has happened than use of an old userspace with a
recent kernel.
Convert the WARN_ONCE to a printk_once to avoid that while continuing to
give userspace developers a hint that this is an unwanted
backward-compatibility feature and won't be around forever.
Reported-by: Ralf Hildebrandt <ralf.hildebrandt@charite.de>
Reported-by: Niels <zorglub_olsen@hotmail.com>
Reported-by: Paweł Sikora <pluto@agmk.net>
Signed-off-by: Jonathan Nieder <jrnieder@gmail.com>
Liked-by: Gergely Nagy <algernon@madhouse-project.org>
Acked-by: Serge Hallyn <serge@hallyn.com>
Acked-by: James Morris <jmorris@namei.org>
Cc: Christoph Biedl <linux-kernel.bfrz@manchmal.in-ulm.de>
commit 30fb6aa74011dcf595f306ca2727254d708b786e upstream.
Multiple users of the function tracer can register their functions
with the ftrace_ops structure. The accounting within ftrace will
update the counter on each function record that is being traced.
When the ftrace_ops filtering adds or removes functions, the
function records will be updated accordingly if the ftrace_ops is
still registered.
When a ftrace_ops is removed, the counter of the function records,
that the ftrace_ops traces, are decremented. When they reach zero
the functions that they represent are modified to stop calling the
mcount code.
When changes are made, the code is updated via stop_machine() with
a command passed to the function to tell it what to do. There is an
ENABLE and DISABLE command that tells the called function to enable
or disable the functions. But the ENABLE is really a misnomer as it
should just update the records, as records that have been enabled
and now have a count of zero should be disabled.
The DISABLE command is used to disable all functions regardless of
their counter values. This is the big off switch and is not the
complement of the ENABLE command.
To make matters worse, when a ftrace_ops is unregistered and there
is another ftrace_ops registered, neither the DISABLE nor the
ENABLE command are set when calling into the stop_machine() function
and the records will not be updated to match their counter. A command
is passed to that function that will update the mcount code to call
the registered callback directly if it is the only one left. This
means that the ftrace_ops that is still registered will have its callback
called by all functions that have been set for it as well as the ftrace_ops
that was just unregistered.
Here's a way to trigger this bug. Compile the kernel with
CONFIG_FUNCTION_PROFILER set and with CONFIG_FUNCTION_GRAPH not set:
CONFIG_FUNCTION_PROFILER=y
# CONFIG_FUNCTION_GRAPH is not set
This will force the function profiler to use the function tracer instead
of the function graph tracer.
# cd /sys/kernel/debug/tracing
# echo schedule > set_ftrace_filter
# echo function > current_tracer
# cat set_ftrace_filter
schedule
# cat trace
# tracer: nop
# entries-in-buffer/entries-written: 692/68108025 #P:4
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/0:2-909 [000] .... 531.235574: schedule <-worker_thread
<idle>-0 [001] .N.. 531.235575: schedule <-cpu_idle
kworker/0:2-909 [000] .... 531.235597: schedule <-worker_thread
sshd-2563 [001] .... 531.235647: schedule <-schedule_hrtimeout_range_clock
# echo 1 > function_profile_enabled
# echo 0 > function_porfile_enabled
schedule
# cat trace
# tracer: function
# entries-in-buffer/entries-written: 159701/118821262 #P:4
# _-----=> irqs-off
# ||| / delay
<idle>-0 [002] ...1 604.870655: local_touch_nmi <-cpu_idle
<idle>-0 [002] d..1 604.870655: enter_idle <-cpu_idle
<idle>-0 [002] d..1 604.870656: atomic_notifier_call_chain <-enter_idle
<idle>-0 [002] d..1 604.870656: __atomic_notifier_call_chain <-atomic_notifier_call_chain
The same problem could have happened with the trace_probe_ops,
but they are modified with the set_frace_filter file which does the
update at closure of the file.
The simple solution is to change ENABLE to UPDATE and call it every
time an ftrace_ops is unregistered.
Link: http://lkml.kernel.org/r/1323105776-26961-3-git-send-email-jolsa@redhat.com
Signed-off-by: Jiri Olsa <jolsa@redhat.com>
commit 072126f4529196f71a97960248bca54fd4554c2d upstream.
Currently, if set_ftrace_filter() is called when the ftrace_ops is
active, the function filters will not be updated. They will only be updated
when tracing is disabled and re-enabled.
Update the functions immediately during set_ftrace_filter().
commit 41fb61c2d08107ce96a5dcb3a6289b2afd3e135c upstream.
Whenever the hash of the ftrace_ops is updated, the record counts
must be balance. This requires disabling the records that are set
in the original hash, and then enabling the records that are set
in the updated hash.
Moving the update into ftrace_hash_move() removes the bug where the
hash was updated but the records were not, which results in ftrace
triggering a warning and disabling itself because the ftrace_ops filter
is updated while the ftrace_ops was registered, and then the failure
happens when the ftrace_ops is unregistered.
The current code will not trigger this bug, but new code will.
commit d496aab567e7e52b3e974c9192a5de6e77dce32c upstream.
Commit ef53d9c5e ("kprobes: improve kretprobe scalability with hashed
locking") introduced a bug where we can potentially leak
kretprobe_instances since we initialize a hlist head after having used
it.
Initialize the hlist head before using it.
Reported by: Jim Keniston <jkenisto@us.ibm.com>
Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: Srinivasa D S <srinivasa@in.ibm.com>
commit 79cfbdfa87e84992d509e6c1648a18e1d7e68c20 upstream.
The CPU hotplug notifications sent out by the _cpu_up() and _cpu_down()
functions depend on the value of the 'tasks_frozen' argument passed to them
(which indicates whether tasks have been frozen or not).
(Examples for such CPU hotplug notifications: CPU_ONLINE, CPU_ONLINE_FROZEN,
CPU_DEAD, CPU_DEAD_FROZEN).
Thus, it is essential that while the callbacks for those notifications are
running, the state of the system with respect to the tasks being frozen or
not remains unchanged, *throughout that duration*. Hence there is a need for
synchronizing the CPU hotplug code with the freezer subsystem.
Since the freezer is involved only in the Suspend/Hibernate call paths, this
patch hooks the CPU hotplug code to the suspend/hibernate notifiers
PM_[SUSPEND|HIBERNATE]_PREPARE and PM_POST_[SUSPEND|HIBERNATE] to prevent
the race between CPU hotplug and freezer, thus ensuring that CPU hotplug
notifications will always be run with the state of the system really being
what the notifications indicate, _throughout_ their execution time.
Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
commit 0d19ea866562e46989412a0676412fa0983c9ce7 upstream.
If we mount a hierarchy with a specified name, the name is unique,
and we can use it to mount the hierarchy without specifying its
set of subsystem names. This feature is documented is
Documentation/cgroups/cgroups.txt section 2.3
Here's an example:
# mount -t cgroup -o cpuset,name=myhier xxx /cgroup1
# mount -t cgroup -o name=myhier xxx /cgroup2
But it was broken by commit 32a8cf235e2f192eb002755076994525cdbaa35a
(cgroup: make the mount options parsing more accurate)
This fixes the regression.
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
commit 50b8d257486a45cba7b65ca978986ed216bbcc10 upstream.
Test-case:
int main(void)
int pid, status;
pid = fork();
if (!pid) {
for (;;) {
if (!fork())
return 0;
if (waitpid(-1, &status, 0) < 0) {
printf("ERR!! wait: %m\n");
return 0;
assert(ptrace(PTRACE_ATTACH, pid, 0,0) == 0);
assert(waitpid(-1, NULL, 0) == pid);
assert(ptrace(PTRACE_SETOPTIONS, pid, 0,
PTRACE_O_TRACEFORK) == 0);
do {
ptrace(PTRACE_CONT, pid, 0, 0);
pid = waitpid(-1, NULL, 0);
} while (pid > 0);
return 1;
It fails because ->real_parent sees its child in EXIT_DEAD state
while the tracer is going to change the state back to EXIT_ZOMBIE
in wait_task_zombie().
The offending commit is 823b018e which moved the EXIT_DEAD check,
but in fact we should not blame it. The original code was not
correct as well because it didn't take ptrace_reparented() into
account and because we can't really trust ->ptrace.
This patch adds the additional check to close this particular
race but it doesn't solve the whole problem. We simply can't
rely on ->ptrace in this case, it can be cleared if the tracer
is multithreaded by the exiting ->parent.
I think we should kill EXIT_DEAD altogether, we should always
remove the soon-to-be-reaped child from ->children or at least
we should never do the DEAD->ZOMBIE transition. But this is too
complex for 3.2.
Reported-and-tested-by: Denys Vlasenko <vda.linux@googlemail.com>
Tested-by: Lukasz Michalik <lmi@ift.uni.wroc.pl>
commit f9fab10bbd768b0e5254e53a4a8477a94bfc4b96 upstream.
vfork parent uninterruptibly and unkillably waits for its child to
exec/exit. This wait is of unbounded length. Ignore such waits
in the hung_task detector.
Signed-off-by: Mandeep Singh Baines <msb@chromium.org>
Reported-by: Sasha Levin <levinsasha928@gmail.com>
LKML-Reference: <1325344394.28904.43.camel@lappy>
Cc: John Kacur <jkacur@redhat.com>
commit e6780f7243eddb133cc20ec37fa69317c218b709 upstream.
It was found (by Sasha) that if you use a futex located in the gate
area we get stuck in an uninterruptible infinite loop, much like the
ZERO_PAGE issue.
While looking at this problem, PeterZ realized you'll get into similar
trouble when hitting any install_special_pages() mapping. And are there
still drivers setting up their own special mmaps without page->mapping,
and without special VM or pte flags to make get_user_pages fail?
In most cases, if page->mapping is NULL, we do not need to retry at all:
Linus points out that even /proc/sys/vm/drop_caches poses no problem,
because it ends up using remove_mapping(), which takes care not to
interfere when the page reference count is raised.
But there is still one case which does need a retry: if memory pressure
called shmem_writepage in between get_user_pages_fast dropping page
table lock and our acquiring page lock, then the page gets switched from
filecache to swapcache (and ->mapping set to NULL) whatever the refcount.
Fault it back in to get the page->mapping needed for key->shared.inode.
commit e0197aae59e55c06db172bfbe1a1cdb8c0e1cab3 upstream.
There is a BUG when migrating a PF_EXITING proc. Since css_set_prefetch()
is not called for the PF_EXITING case, find_existing_css_set() will return
NULL inside cgroup_task_migrate() causing a BUG.
This bug is easy to reproduce. Create a zombie and echo its pid to
cgroup.procs.
$ cat zombie.c
\#include <unistd.h>
int main()
if (fork())
pause();
return 0;
We are hitting this bug pretty regularly on ChromeOS.
This bug is already fixed by Tejun Heo's cgroup patchset which is
targetted for the next merge window:
https://lkml.org/lkml/2011/11/1/356
I've create a smaller patch here which just fixes this bug so that a
fix can be merged into the current release and stable.
Downstream-Bug-Report: http://crosbug.com/23953
Reviewed-by: Li Zefan <lizf@cn.fujitsu.com>
Cc: containers@lists.linux-foundation.org
Cc: cgroups@vger.kernel.org
Cc: Paul Menage <paul@paulmenage.org>
Cc: Olof Johansson <olofj@chromium.org>
commit 3d3c8f93a237b64580c5c5e138edeb1377e98230 upstream.
binary_sysctl() calls sysctl_getname() which allocates from names_cache
slab usin __getname()
The matching function to free the name is __putname(), and not putname()
which should be used only to match getname() allocations.
This is because when auditing is enabled, putname() calls audit_putname
*instead* (not in addition) to __putname(). Then, if a syscall is in
progress, audit_putname does not release the name - instead, it expects
the name to get released when the syscall completes, but that will happen
only if audit_getname() was called previously, i.e. if the name was
allocated with getname() rather than the naked __getname(). So,
__getname() followed by putname() ends up leaking memory.
Signed-off-by: Michel Lespinasse <walken@google.com>
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
Cc: Eric Paris <eparis@redhat.com>
commit 3b87487ac5008072f138953b07505a7e3493327f upstream.
This reverts commit de28f25e8244c7353abed8de0c7792f5f883588c.
It results in resume problems for various people. See for example
http://thread.gmane.org/gmane.linux.kernel/1233033
http://thread.gmane.org/gmane.linux.kernel/1233389
http://thread.gmane.org/gmane.linux.kernel/1233159
http://thread.gmane.org/gmane.linux.kernel/1227868/focus=1230877
and the fedora and ubuntu bug reports
https://bugzilla.redhat.com/show_bug.cgi?id=767248
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/904569
which got bisected down to the stable version of this commit.
Reported-by: Jonathan Nieder <jrnieder@gmail.com>
Reported-by: Phil Miller <mille121@illinois.edu>
Reported-by: Philip Langdale <philipl@overt.org>
Reported-by: Tim Gardner <tim.gardner@canonical.com>
commit 1a51410abe7d0ee4b1d112780f46df87d3621043 upstream.
Ok, this isn't optimal, since it means that 'iotop' needs admin
capabilities, and we may have to work on this some more. But at the
same time it is very much not acceptable to let anybody just read
anybody elses IO statistics quite at this level.
Use of the GENL_ADMIN_PERM suggested by Johannes Berg as an alternative
to checking the capabilities by hand.
Reported-by: Vasiliy Kulikov <segoon@openwall.com>
Cc: Johannes Berg <johannes.berg@intel.com>
Acked-by: Balbir Singh <bsingharora@gmail.com>
Cc: Moritz Mühlenhoff <jmm@inutil.org>
commit c9c024b3f3e07d087974db4c0dc46217fff3a6c0 upstream.
The expiry function compares the timer against current time and does
not expire the timer when the expiry time is >= now. That's wrong. If
the timer is set for now, then it must expire.
Make the condition expiry > now for breaking out the loop.
Acked-by: John Stultz <john.stultz@linaro.org>
commit de28f25e8244c7353abed8de0c7792f5f883588c upstream.
If a device is shutdown, then there might be a pending interrupt,
which will be processed after we reenable interrupts, which causes the
original handler to be run. If the old handler is the (broadcast)
periodic handler the shutdown state might hang the kernel completely.
commit b1f919664d04a8d0ba29cb76673c7ca3325a2006 upstream.
In order to leave a margin of 12.5% we should >> 3 not >> 5.
Signed-off-by: Yang Honggang (Joseph) <eagle.rtlinux@gmail.com>
[jstultz: Modified commit subject]
Signed-off-by: John Stultz <john.stultz@linaro.org>
commit bbbf7af4bf8fc69bc751818cf30521080fa47dcb upstream.
If cpu A calls jump_label_inc() just after atomic_add_return() is
called by cpu B, atomic_inc_not_zero() will return value greater then
zero and jump_label_inc() will return to a caller before jump_label_update()
finishes its job on cpu B.
Link: http://lkml.kernel.org/r/20111018175551.GH17571@redhat.com
Acked-by: Jason Baron <jbaron@redhat.com>
Signed-off-by: Gleb Natapov <gleb@redhat.com>
commit c1be84309c58b1e7c6d626e28fba41a22b364c3d upstream.
When a better rated broadcast device is installed, then the current
active device is not disabled, which results in two running broadcast
devices.
commit cb59974742aea24adf6637eb0c4b8e7b48bca6fb upstream.
Fix a bug introduced by e9dbfae5, which prevents event_subsystem from
ever being released.
Ref_count was added to keep track of subsystem users, not for counting
events. Subsystem is created with ref_count = 1, so there is no need to
increment it for every event, we have nr_events for that. Fix this by
touching ref_count only when we actually have a new user -
subsystem_open().
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
Link: http://lkml.kernel.org/r/1320052062-7846-1-git-send-email-idryomov@gmail.com
ftrace_event_call->filter
commit d3d9acf646679c1981032b0985b386d12fccc60c upstream.
ftrace_event_call->filter is sched RCU protected but didn't use
rcu_assign_pointer(). Use it.
TODO: Add proper __rcu annotation to call->filter and all its users.
-v2: Use RCU_INIT_POINTER() for %NULL clearing as suggested by Eric.
Link: http://lkml.kernel.org/r/20111123164949.GA29639@google.com
Cc: Jiri Olsa <jolsa@redhat.com>
commit 550acb19269d65f32e9ac4ddb26c2b2070e37f1c upstream.
In irq_wait_for_interrupt(), the should_stop member is verified before
setting the task's state to TASK_INTERRUPTIBLE and calling schedule().
In case kthread_stop sets should_stop and wakes up the process after
should_stop is checked by the irq thread but before the task's state
is changed, the irq thread might never exit:
kthread_stop irq_wait_for_interrupt
... while (!kthread_should_stop()) {
kthread->should_stop = 1;
wake_up_process(k);
wait_for_completion(&kthread->exited);
set_current_state(TASK_INTERRUPTIBLE);
schedule();
Fix this by checking if the thread should stop after modifying the
task's state.
[ tglx: Simplified it a bit ]
Signed-off-by: Ido Yariv <ido@wizery.com>
Link: http://lkml.kernel.org/r/1322740508-22640-1-git-send-email-ido@wizery.com
commit 27c9cd7e601632b3794e1c3344d37b86917ffb43 upstream.
__remove_hrtimer() attempts to reprogram the clockevent device when
the timer being removed is the next to expire. However,
__remove_hrtimer() reprograms the clockevent *before* removing the
timer from the timerqueue and thus when hrtimer_force_reprogram()
finds the next timer to expire it finds the timer we're trying to
remove.
This is especially noticeable when the system switches to NOHz mode
and the system tick is removed. The timer tick is removed from the
system but the clockevent is programmed to wakeup in another HZ
anyway.
Silence the extra wakeup by removing the timer from the timerqueue
before calling hrtimer_force_reprogram() so that we actually program
the clockevent for the next timer to expire.
This was broken by 998adc3 "hrtimers: Convert hrtimers to use
timerlist infrastructure".
Signed-off-by: Jeff Ohlstein <johlstei@codeaurora.org>
Link: http://lkml.kernel.org/r/1321660030-8520-1-git-send-email-johlstei@codeaurora.org
commit d004e024058a0eaca097513ce62cbcf978913e0a upstream.
ktime_get and ktime_get_ts were calling timekeeping_get_ns()
but later they were not calling arch_gettimeoffset() so architectures
using this mechanism returned 0 ns when calling these functions.
This happened for example when running Busybox's ping which calls
syscall(__NR_clock_gettime, CLOCK_MONOTONIC, ts) which eventually
calls ktime_get. As a result the returned ping travel time was zero.
Signed-off-by: Hector Palacios <hector.palacios@digi.com>
commit 884a45d964dd395eda945842afff5e16bcaedf56 upstream.
2d3cbf8b (cgroup_freezer: update_freezer_state() does incorrect state
transitions) removed is_task_frozen_enough and replaced it with a simple
frozen call. This, however, breaks freezing for a group with stopped tasks
because those cannot be frozen and so the group remains in CGROUP_FREEZING
state (update_if_frozen doesn't count stopped tasks) and never reaches
CGROUP_FROZEN.
Let's add is_task_frozen_enough back and use it at the original locations
(update_if_frozen and try_to_freeze_cgroup). Semantically we consider
stopped tasks as frozen enough so we should consider both cases when
testing frozen tasks.
Testcase:
mkdir /dev/freezer
mount -t cgroup -o freezer none /dev/freezer
mkdir /dev/freezer/foo
sleep 1h &
pid=$!
kill -STOP $pid
echo $pid > /dev/freezer/foo/tasks
echo FROZEN > /dev/freezer/foo/freezer.state
while true
do
cat /dev/freezer/foo/freezer.state
[ "`cat /dev/freezer/foo/freezer.state`" = "FROZEN" ] && break
sleep 1
done
echo OK
Acked-by: Li Zefan <lizf@cn.fujitsu.com>
Cc: Tomasz Buchert <tomasz.buchert@inria.fr>
Signed-off-by: Tejun Heo <htejun@gmail.com>
commit 52553ddffad76ccf192d4dd9ce88d5818f57f62a upstream.
Commit fa27271bc8d2("genirq: Fixup poll handling") introduced a
regression that broke irqfixup/irqpoll for some hardware configurations.
Amidst reorganizing 'try_one_irq', that patch removed a test that
checked for 'action->handler' returning IRQ_HANDLED, before acting on
the interrupt. Restoring this test back returns the functionality lost
since 2.6.39. In the current set of tests, after 'action' is set, it
must precede '!action->next' to take effect.
With this and my previous patch to irq/spurious.c, c75d720fca8a, all
IRQ regressions that I have encountered are fixed.
Signed-off-by: Edward Donovan <edward.donovan@numble.net>
Reported-and-tested-by: Rogério Brito <rbrito@ime.usp.br>
commit c75d720fca8a91ce99196d33adea383621027bf2 upstream.
commit d05c65fff0 ("genirq: spurious: Run only one poller at a time")
introduced a regression, leaving the boot options 'irqfixup' and
'irqpoll' non-functional. The patch placed tests in each function, to
exit if the function is already running. The test in 'misrouted_irq'
exited when it should have proceeded, effectively disabling
'misrouted_irq' and 'poll_spurious_irqs'.
The check for an already running poller needs to be "!= 1" not "== 1"
as "1" is the value when the first poller starts running.
Cc: maciej.rutecki@gmail.com
Link: http://lkml.kernel.org/r/1320175784-6745-1-git-send-email-edward.donovan@numble.net
commit 528f7ce6e439edeac38f6b3f8561f1be129b5e91 upstream.
In enter_state() we use "state" as an offset for the pm_states[]
array. The pm_states[] array only has PM_SUSPEND_MAX elements so
this test is off by one.
[This does not correspond to any specific patch in the upstream tree as it was
fixed accidentally by rewriting the code in the 3.1 release]
https://bugzilla.redhat.com/show_bug.cgi?id=740121
1. Luke Macken triggered WARN_ON(!(group_stop & GROUP_STOP_SIGMASK))
in do_signal_stop().
This is because do_signal_stop() clears GROUP_STOP_SIGMASK part
unconditionally but doesn't update it if task_is_stopped().
2. Looking at this problem I noticed that WARN_ON_ONCE(!ptrace) is
not right, a stopped-but-resumed tracee can clone the untraced
thread in the SIGNAL_STOP_STOPPED group, the new thread can start
another group-stop.
Remove this warning, we need more fixes to make it true.
Reported-by: Luke Macken <lmacken@redhat.com>
commit 9bab0b7fbaceec47d32db51cd9e59c82fb071f5a upstream.
This adds a mechanism to resume selected IRQs during syscore_resume
instead of dpm_resume_noirq.
Under Xen we need to resume IRQs associated with IPIs early enough
that the resched IPI is unmasked and we can therefore schedule
ourselves out of the stop_machine where the suspend/resume takes
place.
This issue was introduced by 676dc3cf5bc3 "xen: Use IRQF_FORCE_RESUME".
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Cc: Rafael J. Wysocki <rjw@sisk.pl>
Cc: Jeremy Fitzhardinge <Jeremy.Fitzhardinge@citrix.com>
Cc: xen-devel <xen-devel@lists.xensource.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Link: http://lkml.kernel.org/r/1318713254.11016.52.camel@dagon.hellion.org.uk
commit 436fc280261dcfce5af38f08b89287750dc91cd2 upstream.
The trace_pipe_raw handler holds a cached page from the time the file
is opened to the time it is closed. The cached page is used to handle
the case of the user space buffer being smaller than what was read from
the ring buffer. The left over buffer is held in the cache so that the
next read will continue where the data left off.
After EOF is returned (no more data in the buffer), the index of
the cached page is set to zero. If a user app reads the page again
after EOF, the check in the buffer will see that the cached page
is less than page size and will return the cached page again. This
will cause reading the trace_pipe_raw again after EOF to return
duplicate data, making the output look like the time went backwards
but instead data is just repeated.
The fix is to not reset the index right after all data is read
from the cache, but to reset it after all data is read and more
data exists in the ring buffer.
Reported-by: Jeremy Eder <jeder@redhat.com>
commit cbbc719fccdb8cbd87350a05c0d33167c9b79365 upstream.
The parameter's origin type is long. On an i386 architecture, it can
easily be larger than 0x80000000, causing this function to convert it
to a sign-extended u64 type.
Change the type to unsigned long so we get the correct result.
Signed-off-by: hank <pyu@redhat.com>
Cc: John Stultz <john.stultz@linaro.org>
[ build fix ]
commit 37252db6aa576c34fd794a5a54fb32d7a8b3a07a upstream.
Due to post-increment in condition of kmod_loop_msg in __request_module(),
the system log can be spammed by much more than 5 instances of the 'runaway
loop' message if the number of events triggering it makes the kmod_loop_msg
to overflow.
Fix that by making sure we never increment it past the threshold.
commit bcd5cff7216f9b2de0a148cc355eac199dc6f1cf upstream.
There's a lock inversion between the cputimer->lock and rq->lock;
notably the two callchains involved are:
update_rlimit_cpu()
sighand->siglock
set_process_cpu_timer()
cpu_timer_sample_group()
thread_group_cputimer()
cputimer->lock
thread_group_cputime()
task_sched_runtime()
->pi_lock
rq->lock
scheduler_tick()
rq->lock
task_tick_fair()
update_curr()
account_group_exec()
cputimer->lock
Where the first one is enabling a CLOCK_PROCESS_CPUTIME_ID timer, and
the second one is keeping up-to-date.
This problem was introduced by e8abccb7193 ("posix-cpu-timers: Cure
SMP accounting oddities").
Cure the problem by removing the cputimer->lock and rq->lock nesting,
this leaves concurrent enablers doing duplicate work, but the time
wasted should be on the same order otherwise wasted spinning on the
lock and the greater-than assignment filter should ensure we preserve
monotonicity.
Reported-by: Dave Jones <davej@redhat.com>
Reported-by: Simon Kirby <sim@hostway.ca>
Link: http://lkml.kernel.org/r/1318928713.21167.4.camel@twins
commit a84a79e4d369a73c0130b5858199e949432da4c6 upstream.
The size is always valid, but variable-length arrays generate worse code
for no good reason (unless the function happens to be inlined and the
compiler sees the length for the simple constant it is).
Also, there seems to be some code generation problem on POWER, where
Henrik Bakken reports that register r28 can get corrupted under some
subtle circumstances (interrupt happening at the wrong time?). That all
indicates some seriously broken compiler issues, but since variable
length arrays are bad regardless, there's little point in trying to
chase it down.
"Just don't do that, then".
Reported-by: Henrik Grindal Bakken <henribak@cisco.com>
commit f7bc8b61f65726ff98f52e286b28e294499d7a08 upstream.
Enabling function tracer to trace all functions, then load a module and
then disable function tracing will cause ftrace to fail.
This can also happen by enabling function tracing on the command line:
ftrace=function
and during boot up, modules are loaded, then you disable function tracing
with 'echo nop > current_tracer' you will trigger a bug in ftrace that
will shut itself down.
The reason is, the new ftrace code keeps ref counts of all ftrace_ops that
are registered for tracing. When one or more ftrace_ops are registered,
all the records that represent the functions that the ftrace_ops will
trace have a ref count incremented. If this ref count is not zero,
when the code modification runs, that function will be enabled for tracing.
If the ref count is zero, that function will be disabled from tracing.
To make sure the accounting was working, FTRACE_WARN_ON()s were added
to updating of the ref counts.
If the ref count hits its max (> 2^30 ftrace_ops added), or if
the ref count goes below zero, a FTRACE_WARN_ON() is triggered which
disables all modification of code.
Since it is common for ftrace_ops to trace all functions in the kernel,
instead of creating > 20,000 hash items for the ftrace_ops, the hash
count is just set to zero, and it represents that the ftrace_ops is
to trace all functions. This is where the issues arrise.
If you enable function tracing to trace all functions, and then add
a module, the modules function records do not get the ref count updated.
When the function tracer is disabled, all function records ref counts
are subtracted. Since the modules never had their ref counts incremented,
they go below zero and the FTRACE_WARN_ON() is triggered.
The solution to this is rather simple. When modules are loaded, and
their functions are added to the the ftrace pool, look to see if any
ftrace_ops are registered that trace all functions. And for those,
update the ref count for the module function records.
Reported-by: Thomas Gleixner <tglx@linutronix.de>
commit 43dd61c9a09bd413e837df829e6bfb42159be52a upstream.
The new code that allows different utilities to pick and choose
what functions they trace broke the :mod: hook that allows users
to trace only functions of a particular module.
The reason is that the :mod: hook bypasses the hash that is setup
to allow individual users to trace their own functions and uses
the global hash directly. But if the global hash has not been
set up, it will cause a bug:
echo '*:mod:radeon' > /sys/kernel/debug/set_ftrace_filter
produces:
[drm:drm_mode_getfb] *ERROR* invalid framebuffer id
[drm:radeon_crtc_page_flip] *ERROR* failed to reserve new rbo buffer before flip
BUG: unable to handle kernel paging request at ffffffff8160ec90
IP: [<ffffffff810d9136>] add_hash_entry+0x66/0xd0
PGD 1a05067 PUD 1a09063 PMD 80000000016001e1
Oops: 0003 [#1] SMP Jul 7 04:02:28 phyllis kernel: [55303.858604] CPU 1
Modules linked in: cryptd aes_x86_64 aes_generic binfmt_misc rfcomm bnep ip6table_filter hid radeon r8169 ahci libahci mii ttm drm_kms_helper drm video i2c_algo_bit intel_agp intel_gtt
Pid: 10344, comm: bash Tainted: G WC 3.0.0-rc5 #1 Dell Inc. Inspiron N5010/0YXXJJ
RIP: 0010:[<ffffffff810d9136>] [<ffffffff810d9136>] add_hash_entry+0x66/0xd0
RSP: 0018:ffff88003a96bda8 EFLAGS: 00010246
RAX: ffff8801301735c0 RBX: ffffffff8160ec80 RCX: 0000000000306ee0
RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffff880137c92940
RBP: ffff88003a96bdb8 R08: ffff880137c95680 R09: 0000000000000000
R10: 0000000000000001 R11: 0000000000000000 R12: ffffffff81c9df78
R13: ffff8801153d1000 R14: 0000000000000000 R15: 0000000000000000
FS: 00007f329c18a700(0000) GS:ffff880137c80000(0000) knlGS:0000000000000000
CR2: ffffffff8160ec90 CR3: 000000003002b000 CR4: 00000000000006e0
Process bash (pid: 10344, threadinfo ffff88003a96a000, task ffff88012fcfc470)
Stack:
0000000000000fd0 00000000000000fc ffff88003a96be38 ffffffff810d92f5
ffff88011c4c4e00 ffff880000000000 000000000b69f4d0 ffffffff8160ec80
ffff8800300e6f06 0000000081130295 0000000000000282 ffff8800300e6f00
Call Trace:
[<ffffffff810d92f5>] match_records+0x155/0x1b0
[<ffffffff810d940c>] ftrace_mod_callback+0xbc/0x100
[<ffffffff810dafdf>] ftrace_regex_write+0x16f/0x210
[<ffffffff810db09f>] ftrace_filter_write+0xf/0x20
[<ffffffff81166e48>] vfs_write+0xc8/0x190
[<ffffffff81167001>] sys_write+0x51/0x90
[<ffffffff815c7e02>] system_call_fastpath+0x16/0x1b
Code: 48 8b 33 31 d2 48 85 f6 75 33 49 89 d4 4c 03 63 08 49 8b 14 24 48 85 d2 48 89 10 74 04 48 89 42 08 49 89 04 24 4c 89 60 08 31 d2
RIP [<ffffffff810d9136>] add_hash_entry+0x66/0xd0
RSP <ffff88003a96bda8>
---[ end trace a5d031828efdd88e ]---
Reported-by: Brian Marete <marete@toshnix.com>
commit d670ec13178d0fd8680e6742a2bc6e04f28f87d8 upstream.
David reported:
Attached below is a watered-down version of rt/tst-cpuclock2.c from
GLIBC. Just build it with "gcc -o test test.c -lpthread -lrt" or
similar.
Run it several times, and you will see cases where the main thread
will measure a process clock difference before and after the nanosleep
which is smaller than the cpu-burner thread's individual thread clock
difference. This doesn't make any sense since the cpu-burner thread
is part of the top-level process's thread group.
I've reproduced this on both x86-64 and sparc64 (using both 32-bit and
64-bit binaries).
For example:
[davem@boricha build-x86_64-linux]$ ./test
process: before(0.001221967) after(0.498624371) diff(497402404)
thread: before(0.000081692) after(0.498316431) diff(498234739)
self: before(0.001223521) after(0.001240219) diff(16698)
The diff of 'process' should always be >= the diff of 'thread'.
I make sure to wrap the 'thread' clock measurements the most tightly
around the nanosleep() call, and that the 'process' clock measurements
are the outer-most ones.
#include <unistd.h>
#include <stdio.h>
#include <stdlib.h>
#include <time.h>
#include <fcntl.h>
#include <string.h>
#include <errno.h>
#include <pthread.h>
static pthread_barrier_t barrier;
static void *chew_cpu(void *arg)
pthread_barrier_wait(&barrier);
while (1)
__asm__ __volatile__("" : : : "memory");
return NULL;
int main(void)
clockid_t process_clock, my_thread_clock, th_clock;
struct timespec process_before, process_after;
struct timespec me_before, me_after;
struct timespec th_before, th_after;
struct timespec sleeptime;
unsigned long diff;
pthread_t th;
int err;
err = clock_getcpuclockid(0, &process_clock);
if (err)
return 1;
err = pthread_getcpuclockid(pthread_self(), &my_thread_clock);
if (err)
return 1;
pthread_barrier_init(&barrier, NULL, 2);
err = pthread_create(&th, NULL, chew_cpu, NULL);
if (err)
return 1;
err = pthread_getcpuclockid(th, &th_clock);
if (err)
return 1;
err = clock_gettime(process_clock, &process_before);
if (err)
return 1;
err = clock_gettime(my_thread_clock, &me_before);
if (err)
return 1;
err = clock_gettime(th_clock, &th_before);
if (err)
return 1;
sleeptime.tv_sec = 0;
sleeptime.tv_nsec = 500000000;
nanosleep(&sleeptime, NULL);
err = clock_gettime(th_clock, &th_after);
if (err)
return 1;
err = clock_gettime(my_thread_clock, &me_after);
if (err)
return 1;
err = clock_gettime(process_clock, &process_after);
if (err)
return 1;
diff = process_after.tv_nsec - process_before.tv_nsec;
printf("process: before(%lu.%.9lu) after(%lu.%.9lu) diff(%lu)\n",
process_before.tv_sec, process_before.tv_nsec,
process_after.tv_sec, process_after.tv_nsec, diff);
diff = th_after.tv_nsec - th_before.tv_nsec;
printf("thread: before(%lu.%.9lu) after(%lu.%.9lu) diff(%lu)\n",
th_before.tv_sec, th_before.tv_nsec,
th_after.tv_sec, th_after.tv_nsec, diff);
diff = me_after.tv_nsec - me_before.tv_nsec;
printf("self: before(%lu.%.9lu) after(%lu.%.9lu) diff(%lu)\n",
me_before.tv_sec, me_before.tv_nsec,
me_after.tv_sec, me_after.tv_nsec, diff);
return 0;
This is due to us using p->se.sum_exec_runtime in
thread_group_cputime() where we iterate the thread group and sum all
data. This does not take time since the last schedule operation (tick
or otherwise) into account. We can cure this by using
task_sched_runtime() at the cost of having to take locks.
This also means we can (and must) do away with
thread_group_sched_runtime() since the modified thread_group_cputime()
is now more accurate and would deadlock when called from
thread_group_sched_runtime().
Aside of that it makes the function safe on 32 bit systems. The old
code added t->se.sum_exec_runtime unprotected. sum_exec_runtime is a
64bit value and could be changed on another cpu at the same time.
Reported-by: David Miller <davem@davemloft.net>
Link: http://lkml.kernel.org/r/1314874459.7945.22.camel@twins
Tested-by: David Miller <davem@davemloft.net>
commit 6ebbe7a07b3bc40b168d2afc569a6543c020d2e3 upstream.
Commit c259e01a1ec ("sched: Separate the scheduler entry for
preemption") contained a boo-boo wrecking wchan output. It forgot to
put the new schedule() function in the __sched section and thereby
doesn't get properly ignored for things like wchan.
Tested-by: Simon Kirby <sim@hostway.ca>
Link: http://lkml.kernel.org/r/20110923000346.GA25425@hostway.ca
commit 3be209a8e22cedafc1b6945608b7bb8d9887ab61 upstream.
Commit 43fa5460fe60dea5c610490a1d263415419c60f6 ("sched: Try not to
migrate higher priority RT tasks") also introduced a change in behavior
which keeps RT tasks on the same CPU if there is an equal priority RT
task currently running even if there are empty CPUs available.
This can cause unnecessary wakeup latencies, and can prevent the
scheduler from balancing all RT tasks across available CPUs.
This change causes an RT task to search for a new CPU if an equal
priority RT task is already running on wakeup. Lower priority tasks
will still have to wait on higher priority tasks, but the system should
still balance out because there is always the possibility that if there
are both a high and low priority RT tasks on a given CPU that the high
priority task could wakeup while the low priority task is running and
force it to search for a better runqueue.
Signed-off-by: Shawn Bohrer <sbohrer@rgmadvisors.com>
Tested-by: Steven Rostedt <rostedt@goodmis.org>
Link: http://lkml.kernel.org/r/1315837684-18733-1-git-send-email-sbohrer@rgmadvisors.com
