path: root/kernel
2011-05-29mm: Fix boot crash in mm_alloc()Linus Torvalds
Thomas Gleixner reports that we now have a boot crash triggered by CONFIG_CPUMASK_OFFSTACK=y: BUG: unable to handle kernel NULL pointer dereference at (null) IP: [<c11ae035>] find_next_bit+0x55/0xb0 Call Trace: [<c11addda>] cpumask_any_but+0x2a/0x70 [<c102396b>] flush_tlb_mm+0x2b/0x80 [<c1022705>] pud_populate+0x35/0x50 [<c10227ba>] pgd_alloc+0x9a/0xf0 [<c103a3fc>] mm_init+0xec/0x120 [<c103a7a3>] mm_alloc+0x53/0xd0 which was introduced by commit de03c72cfce5 ("mm: convert mm->cpu_vm_cpumask into cpumask_var_t"), and is due to wrong ordering of mm_init() vs mm_init_cpumask Thomas wrote a patch to just fix the ordering of initialization, but I hate the new double allocation in the fork path, so I ended up instead doing some more radical surgery to clean it all up. Reported-by: Thomas Gleixner <tglx@linutronix.de> Reported-by: Ingo Molnar <mingo@elte.hu> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-29Merge branch 'idle-release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6 * 'idle-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6: x86 idle: deprecate mwait_idle() and "idle=mwait" cmdline param x86 idle: deprecate "no-hlt" cmdline param x86 idle APM: deprecate CONFIG_APM_CPU_IDLE x86 idle floppy: deprecate disable_hlt() x86 idle: EXPORT_SYMBOL(default_idle, pm_idle) only when APM demands it x86 idle: clarify AMD erratum 400 workaround idle governor: Avoid lock acquisition to read pm_qos before entering idle cpuidle: menu: fixed wrapping timers at 4.294 seconds
2011-05-29idle governor: Avoid lock acquisition to read pm_qos before entering idleTim Chen
Thanks to the reviews and comments by Rafael, James, Mark and Andi. Here's version 2 of the patch incorporating your comments and also some update to my previous patch comments. I noticed that before entering idle state, the menu idle governor will look up the current pm_qos target value according to the list of qos requests received. This look up currently needs the acquisition of a lock to access the list of qos requests to find the qos target value, slowing down the entrance into idle state due to contention by multiple cpus to access this list. The contention is severe when there are a lot of cpus waking and going into idle. For example, for a simple workload that has 32 pair of processes ping ponging messages to each other, where 64 cpu cores are active in test system, I see the following profile with 37.82% of cpu cycles spent in contention of pm_qos_lock: - 37.82% swapper [kernel.kallsyms] [k] _raw_spin_lock_irqsave - _raw_spin_lock_irqsave - 95.65% pm_qos_request menu_select cpuidle_idle_call - cpu_idle 99.98% start_secondary A better approach will be to cache the updated pm_qos target value so reading it does not require lock acquisition as in the patch below. With this patch the contention for pm_qos_lock is removed and I saw a 2.2X increase in throughput for my message passing workload. cc: stable@kernel.org Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Acked-by: Andi Kleen <ak@linux.intel.com> Acked-by: James Bottomley <James.Bottomley@suse.de> Acked-by: mark gross <markgross@thegnar.org> Signed-off-by: Len Brown <len.brown@intel.com>
2011-05-28Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: cpuset: Fix cpuset_cpus_allowed_fallback(), don't update tsk->rt.nr_cpus_allowed sched: Fix ->min_vruntime calculation in dequeue_entity() sched: Fix ttwu() for __ARCH_WANT_INTERRUPTS_ON_CTXSW sched: More sched_domain iterations fixes
2011-05-28Merge branch 'core-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: rcu: Start RCU kthreads in TASK_INTERRUPTIBLE state rcu: Remove waitqueue usage for cpu, node, and boost kthreads rcu: Avoid acquiring rcu_node locks in timer functions atomic: Add atomic_or() Documentation: Add statistics about nested locks rcu: Decrease memory-barrier usage based on semi-formal proof rcu: Make rcu_enter_nohz() pay attention to nesting rcu: Don't do reschedule unless in irq rcu: Remove old memory barriers from rcu_process_callbacks() rcu: Add memory barriers rcu: Fix unpaired rcu_irq_enter() from locking selftests
2011-05-28Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (25 commits) perf: Fix SIGIO handling perf top: Don't stop if no kernel symtab is found perf top: Handle kptr_restrict perf top: Remove unused macro perf events: initialize fd array to -1 instead of 0 perf tools: Make sure kptr_restrict warnings fit 80 col terms perf tools: Fix build on older systems perf symbols: Handle /proc/sys/kernel/kptr_restrict perf: Remove duplicate headers ftrace: Add internal recursive checks tracing: Update btrfs's tracepoints to use u64 interface tracing: Add __print_symbolic_u64 to avoid warnings on 32bit machine ftrace: Set ops->flag to enabled even on static function tracing tracing: Have event with function tracer check error return ftrace: Have ftrace_startup() return failure code jump_label: Check entries limit in __jump_label_update ftrace/recordmcount: Avoid STT_FUNC symbols as base on ARM scripts/tags.sh: Add magic for trace-events for etags too scripts/tags.sh: Fix ctags for DEFINE_EVENT() x86/ftrace: Fix compiler warning in ftrace.c ...
2011-05-28rcu: Start RCU kthreads in TASK_INTERRUPTIBLE statePaul E. McKenney
Upon creation, kthreads are in TASK_UNINTERRUPTIBLE state, which can result in softlockup warnings. Because some of RCU's kthreads can legitimately be idle indefinitely, start them in TASK_INTERRUPTIBLE state in order to avoid those warnings. Suggested-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Tested-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-05-28rcu: Remove waitqueue usage for cpu, node, and boost kthreadsPeter Zijlstra
It is not necessary to use waitqueues for the RCU kthreads because we always know exactly which thread is to be awakened. In addition, wake_up() only issues an actual wakeup when there is a thread waiting on the queue, which was why there was an extra explicit wake_up_process() to get the RCU kthreads started. Eliminating the waitqueues (and wake_up()) in favor of wake_up_process() eliminates the need for the initial wake_up_process() and also shrinks the data structure size a bit. The wakeup logic is placed in a new rcu_wait() macro. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-05-28rcu: Avoid acquiring rcu_node locks in timer functionsPaul E. McKenney
This commit switches manipulations of the rcu_node ->wakemask field to atomic operations, which allows rcu_cpu_kthread_timer() to avoid acquiring the rcu_node lock. This should avoid the following lockdep splat reported by Valdis Kletnieks: [ 12.872150] usb 1-4: new high speed USB device number 3 using ehci_hcd [ 12.986667] usb 1-4: New USB device found, idVendor=413c, idProduct=2513 [ 12.986679] usb 1-4: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [ 12.987691] hub 1-4:1.0: USB hub found [ 12.987877] hub 1-4:1.0: 3 ports detected [ 12.996372] input: PS/2 Generic Mouse as /devices/platform/i8042/serio1/input/input10 [ 13.071471] udevadm used greatest stack depth: 3984 bytes left [ 13.172129] [ 13.172130] ======================================================= [ 13.172425] [ INFO: possible circular locking dependency detected ] [ 13.172650] 2.6.39-rc6-mmotm0506 #1 [ 13.172773] ------------------------------------------------------- [ 13.172997] blkid/267 is trying to acquire lock: [ 13.173009] (&p->pi_lock){-.-.-.}, at: [<ffffffff81032d8f>] try_to_wake_up+0x29/0x1aa [ 13.173009] [ 13.173009] but task is already holding lock: [ 13.173009] (rcu_node_level_0){..-...}, at: [<ffffffff810901cc>] rcu_cpu_kthread_timer+0x27/0x58 [ 13.173009] [ 13.173009] which lock already depends on the new lock. [ 13.173009] [ 13.173009] [ 13.173009] the existing dependency chain (in reverse order) is: [ 13.173009] [ 13.173009] -> #2 (rcu_node_level_0){..-...}: [ 13.173009] [<ffffffff810679b9>] check_prevs_add+0x8b/0x104 [ 13.173009] [<ffffffff81067da1>] validate_chain+0x36f/0x3ab [ 13.173009] [<ffffffff8106846b>] __lock_acquire+0x369/0x3e2 [ 13.173009] [<ffffffff81068a0f>] lock_acquire+0xfc/0x14c [ 13.173009] [<ffffffff815697f1>] _raw_spin_lock+0x36/0x45 [ 13.173009] [<ffffffff81090794>] rcu_read_unlock_special+0x8c/0x1d5 [ 13.173009] [<ffffffff8109092c>] __rcu_read_unlock+0x4f/0xd7 [ 13.173009] [<ffffffff81027bd3>] rcu_read_unlock+0x21/0x23 [ 13.173009] [<ffffffff8102cc34>] cpuacct_charge+0x6c/0x75 [ 13.173009] [<ffffffff81030cc6>] update_curr+0x101/0x12e [ 13.173009] [<ffffffff810311d0>] check_preempt_wakeup+0xf7/0x23b [ 13.173009] [<ffffffff8102acb3>] check_preempt_curr+0x2b/0x68 [ 13.173009] [<ffffffff81031d40>] ttwu_do_wakeup+0x76/0x128 [ 13.173009] [<ffffffff81031e49>] ttwu_do_activate.constprop.63+0x57/0x5c [ 13.173009] [<ffffffff81031e96>] scheduler_ipi+0x48/0x5d [ 13.173009] [<ffffffff810177d5>] smp_reschedule_interrupt+0x16/0x18 [ 13.173009] [<ffffffff815710f3>] reschedule_interrupt+0x13/0x20 [ 13.173009] [<ffffffff810b66d1>] rcu_read_unlock+0x21/0x23 [ 13.173009] [<ffffffff810b739c>] find_get_page+0xa9/0xb9 [ 13.173009] [<ffffffff810b8b48>] filemap_fault+0x6a/0x34d [ 13.173009] [<ffffffff810d1a25>] __do_fault+0x54/0x3e6 [ 13.173009] [<ffffffff810d447a>] handle_pte_fault+0x12c/0x1ed [ 13.173009] [<ffffffff810d48f7>] handle_mm_fault+0x1cd/0x1e0 [ 13.173009] [<ffffffff8156cfee>] do_page_fault+0x42d/0x5de [ 13.173009] [<ffffffff8156a75f>] page_fault+0x1f/0x30 [ 13.173009] [ 13.173009] -> #1 (&rq->lock){-.-.-.}: [ 13.173009] [<ffffffff810679b9>] check_prevs_add+0x8b/0x104 [ 13.173009] [<ffffffff81067da1>] validate_chain+0x36f/0x3ab [ 13.173009] [<ffffffff8106846b>] __lock_acquire+0x369/0x3e2 [ 13.173009] [<ffffffff81068a0f>] lock_acquire+0xfc/0x14c [ 13.173009] [<ffffffff815697f1>] _raw_spin_lock+0x36/0x45 [ 13.173009] [<ffffffff81027e19>] __task_rq_lock+0x8b/0xd3 [ 13.173009] [<ffffffff81032f7f>] wake_up_new_task+0x41/0x108 [ 13.173009] [<ffffffff810376c3>] do_fork+0x265/0x33f [ 13.173009] [<ffffffff81007d02>] kernel_thread+0x6b/0x6d [ 13.173009] [<ffffffff8153a9dd>] rest_init+0x21/0xd2 [ 13.173009] [<ffffffff81b1db4f>] start_kernel+0x3bb/0x3c6 [ 13.173009] [<ffffffff81b1d29f>] x86_64_start_reservations+0xaf/0xb3 [ 13.173009] [<ffffffff81b1d393>] x86_64_start_kernel+0xf0/0xf7 [ 13.173009] [ 13.173009] -> #0 (&p->pi_lock){-.-.-.}: [ 13.173009] [<ffffffff81067788>] check_prev_add+0x68/0x20e [ 13.173009] [<ffffffff810679b9>] check_prevs_add+0x8b/0x104 [ 13.173009] [<ffffffff81067da1>] validate_chain+0x36f/0x3ab [ 13.173009] [<ffffffff8106846b>] __lock_acquire+0x369/0x3e2 [ 13.173009] [<ffffffff81068a0f>] lock_acquire+0xfc/0x14c [ 13.173009] [<ffffffff815698ea>] _raw_spin_lock_irqsave+0x44/0x57 [ 13.173009] [<ffffffff81032d8f>] try_to_wake_up+0x29/0x1aa [ 13.173009] [<ffffffff81032f3c>] wake_up_process+0x10/0x12 [ 13.173009] [<ffffffff810901e9>] rcu_cpu_kthread_timer+0x44/0x58 [ 13.173009] [<ffffffff81045286>] call_timer_fn+0xac/0x1e9 [ 13.173009] [<ffffffff8104556d>] run_timer_softirq+0x1aa/0x1f2 [ 13.173009] [<ffffffff8103e487>] __do_softirq+0x109/0x26a [ 13.173009] [<ffffffff8157144c>] call_softirq+0x1c/0x30 [ 13.173009] [<ffffffff81003207>] do_softirq+0x44/0xf1 [ 13.173009] [<ffffffff8103e8b9>] irq_exit+0x58/0xc8 [ 13.173009] [<ffffffff81017f5a>] smp_apic_timer_interrupt+0x79/0x87 [ 13.173009] [<ffffffff81570fd3>] apic_timer_interrupt+0x13/0x20 [ 13.173009] [<ffffffff810bd51a>] get_page_from_freelist+0x2aa/0x310 [ 13.173009] [<ffffffff810bdf03>] __alloc_pages_nodemask+0x178/0x243 [ 13.173009] [<ffffffff8101fe2f>] pte_alloc_one+0x1e/0x3a [ 13.173009] [<ffffffff810d27fe>] __pte_alloc+0x22/0x14b [ 13.173009] [<ffffffff810d48a8>] handle_mm_fault+0x17e/0x1e0 [ 13.173009] [<ffffffff8156cfee>] do_page_fault+0x42d/0x5de [ 13.173009] [<ffffffff8156a75f>] page_fault+0x1f/0x30 [ 13.173009] [ 13.173009] other info that might help us debug this: [ 13.173009] [ 13.173009] Chain exists of: [ 13.173009] &p->pi_lock --> &rq->lock --> rcu_node_level_0 [ 13.173009] [ 13.173009] Possible unsafe locking scenario: [ 13.173009] [ 13.173009] CPU0 CPU1 [ 13.173009] ---- ---- [ 13.173009] lock(rcu_node_level_0); [ 13.173009] lock(&rq->lock); [ 13.173009] lock(rcu_node_level_0); [ 13.173009] lock(&p->pi_lock); [ 13.173009] [ 13.173009] *** DEADLOCK *** [ 13.173009] [ 13.173009] 3 locks held by blkid/267: [ 13.173009] #0: (&mm->mmap_sem){++++++}, at: [<ffffffff8156cdb4>] do_page_fault+0x1f3/0x5de [ 13.173009] #1: (&yield_timer){+.-...}, at: [<ffffffff810451da>] call_timer_fn+0x0/0x1e9 [ 13.173009] #2: (rcu_node_level_0){..-...}, at: [<ffffffff810901cc>] rcu_cpu_kthread_timer+0x27/0x58 [ 13.173009] [ 13.173009] stack backtrace: [ 13.173009] Pid: 267, comm: blkid Not tainted 2.6.39-rc6-mmotm0506 #1 [ 13.173009] Call Trace: [ 13.173009] <IRQ> [<ffffffff8154a529>] print_circular_bug+0xc8/0xd9 [ 13.173009] [<ffffffff81067788>] check_prev_add+0x68/0x20e [ 13.173009] [<ffffffff8100c861>] ? save_stack_trace+0x28/0x46 [ 13.173009] [<ffffffff810679b9>] check_prevs_add+0x8b/0x104 [ 13.173009] [<ffffffff81067da1>] validate_chain+0x36f/0x3ab [ 13.173009] [<ffffffff8106846b>] __lock_acquire+0x369/0x3e2 [ 13.173009] [<ffffffff81032d8f>] ? try_to_wake_up+0x29/0x1aa [ 13.173009] [<ffffffff81068a0f>] lock_acquire+0xfc/0x14c [ 13.173009] [<ffffffff81032d8f>] ? try_to_wake_up+0x29/0x1aa [ 13.173009] [<ffffffff810901a5>] ? rcu_check_quiescent_state+0x82/0x82 [ 13.173009] [<ffffffff815698ea>] _raw_spin_lock_irqsave+0x44/0x57 [ 13.173009] [<ffffffff81032d8f>] ? try_to_wake_up+0x29/0x1aa [ 13.173009] [<ffffffff81032d8f>] try_to_wake_up+0x29/0x1aa [ 13.173009] [<ffffffff810901a5>] ? rcu_check_quiescent_state+0x82/0x82 [ 13.173009] [<ffffffff81032f3c>] wake_up_process+0x10/0x12 [ 13.173009] [<ffffffff810901e9>] rcu_cpu_kthread_timer+0x44/0x58 [ 13.173009] [<ffffffff810901a5>] ? rcu_check_quiescent_state+0x82/0x82 [ 13.173009] [<ffffffff81045286>] call_timer_fn+0xac/0x1e9 [ 13.173009] [<ffffffff810451da>] ? del_timer+0x75/0x75 [ 13.173009] [<ffffffff810901a5>] ? rcu_check_quiescent_state+0x82/0x82 [ 13.173009] [<ffffffff8104556d>] run_timer_softirq+0x1aa/0x1f2 [ 13.173009] [<ffffffff8103e487>] __do_softirq+0x109/0x26a [ 13.173009] [<ffffffff8106365f>] ? tick_dev_program_event+0x37/0xf6 [ 13.173009] [<ffffffff810a0e4a>] ? time_hardirqs_off+0x1b/0x2f [ 13.173009] [<ffffffff8157144c>] call_softirq+0x1c/0x30 [ 13.173009] [<ffffffff81003207>] do_softirq+0x44/0xf1 [ 13.173009] [<ffffffff8103e8b9>] irq_exit+0x58/0xc8 [ 13.173009] [<ffffffff81017f5a>] smp_apic_timer_interrupt+0x79/0x87 [ 13.173009] [<ffffffff81570fd3>] apic_timer_interrupt+0x13/0x20 [ 13.173009] <EOI> [<ffffffff810bd384>] ? get_page_from_freelist+0x114/0x310 [ 13.173009] [<ffffffff810bd51a>] ? get_page_from_freelist+0x2aa/0x310 [ 13.173009] [<ffffffff812220e7>] ? clear_page_c+0x7/0x10 [ 13.173009] [<ffffffff810bd1ef>] ? prep_new_page+0x14c/0x1cd [ 13.173009] [<ffffffff810bd51a>] get_page_from_freelist+0x2aa/0x310 [ 13.173009] [<ffffffff810bdf03>] __alloc_pages_nodemask+0x178/0x243 [ 13.173009] [<ffffffff810d46b9>] ? __pmd_alloc+0x87/0x99 [ 13.173009] [<ffffffff8101fe2f>] pte_alloc_one+0x1e/0x3a [ 13.173009] [<ffffffff810d46b9>] ? __pmd_alloc+0x87/0x99 [ 13.173009] [<ffffffff810d27fe>] __pte_alloc+0x22/0x14b [ 13.173009] [<ffffffff810d48a8>] handle_mm_fault+0x17e/0x1e0 [ 13.173009] [<ffffffff8156cfee>] do_page_fault+0x42d/0x5de [ 13.173009] [<ffffffff810d915f>] ? sys_brk+0x32/0x10c [ 13.173009] [<ffffffff810a0e4a>] ? time_hardirqs_off+0x1b/0x2f [ 13.173009] [<ffffffff81065c4f>] ? trace_hardirqs_off_caller+0x3f/0x9c [ 13.173009] [<ffffffff812235dd>] ? trace_hardirqs_off_thunk+0x3a/0x3c [ 13.173009] [<ffffffff8156a75f>] page_fault+0x1f/0x30 [ 14.010075] usb 5-1: new full speed USB device number 2 using uhci_hcd Reported-by: Valdis Kletnieks <Valdis.Kletnieks@vt.edu> Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-05-28Merge branch 'rcu/urgent' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-2.6-rcu into core/urgent
2011-05-28perf: Fix SIGIO handlingPeter Zijlstra
Vince noticed that unless we mmap() a buffer, SIGIO gets lost. So explicitly push the wakeup (including signals) when requested. Reported-by: Vince Weaver <vweaver1@eecs.utk.edu> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: <stable@kernel.org> Link: http://lkml.kernel.org/n/tip-2euus3f3x3dyvdk52cjxw8zu@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-05-28cpuset: Fix cpuset_cpus_allowed_fallback(), don't update tsk->rt.nr_cpus_allowedKOSAKI Motohiro
The rule is, we have to update tsk->rt.nr_cpus_allowed if we change tsk->cpus_allowed. Otherwise RT scheduler may confuse. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/4DD4B3FA.5060901@jp.fujitsu.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-05-28sched: Fix ->min_vruntime calculation in dequeue_entity()Peter Zijlstra
Dima Zavin <dima@android.com> reported: "After pulling the thread off the run-queue during a cgroup change, the cfs_rq.min_vruntime gets recalculated. The dequeued thread's vruntime then gets normalized to this new value. This can then lead to the thread getting an unfair boost in the new group if the vruntime of the next task in the old run-queue was way further ahead." Reported-by: Dima Zavin <dima@android.com> Signed-off-by: John Stultz <john.stultz@linaro.org> Recalls-having-tested-once-upon-a-time-by: Mike Galbraith <efault@gmx.de> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1305674470-23727-1-git-send-email-john.stultz@linaro.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-05-28sched: Fix ttwu() for __ARCH_WANT_INTERRUPTS_ON_CTXSWPeter Zijlstra
Marc reported that e4a52bcb9 (sched: Remove rq->lock from the first half of ttwu()) broke his ARM-SMP machine. Now ARM is one of the few __ARCH_WANT_INTERRUPTS_ON_CTXSW users, so that exception in the ttwu() code was suspect. Yong found that the interrupt could hit after context_switch() changes current but before it clears p->on_cpu, if that interrupt were to attempt a wake-up of p we would indeed find ourselves spinning in IRQ context. Fix this by reverting to the old behaviour for this situation and perform a full remote wake-up. Cc: Frank Rowand <frank.rowand@am.sony.com> Cc: Yong Zhang <yong.zhang0@gmail.com> Cc: Oleg Nesterov <oleg@redhat.com> Reported-by: Marc Zyngier <Marc.Zyngier@arm.com> Tested-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-05-28sched: More sched_domain iterations fixesXiaotian Feng
sched_domain iterations needs to be protected by rcu_read_lock() now, this patch adds another two places which needs the rcu lock, which is spotted by following suspicious rcu_dereference_check() usage warnings. kernel/sched_rt.c:1244 invoked rcu_dereference_check() without protection! kernel/sched_stats.h:41 invoked rcu_dereference_check() without protection! Signed-off-by: Xiaotian Feng <dfeng@redhat.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1303469634-11678-1-git-send-email-dfeng@redhat.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-05-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6: PM: Fix PM QOS's user mode interface to work with ASCII input PM / Hibernate: Update kerneldoc comments in hibernate.c PM / Hibernate: Remove arch_prepare_suspend() PM / Hibernate: Update some comments in core hibernate code
2011-05-27Merge branch 'docs-move' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rdunlap/linux-docs * 'docs-move' of git://git.kernel.org/pub/scm/linux/kernel/git/rdunlap/linux-docs: Create Documentation/security/, move LSM-, credentials-, and keys-related files from Documentation/ to Documentation/security/, add Documentation/security/00-INDEX, and update all occurrences of Documentation/<moved_file> to Documentation/security/<moved_file>.
2011-05-27Merge branch 'tip/perf/urgent' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into perf/urgent
2011-05-26kernel/profile.c: remove some duplicate code from profile_hits()Rakib Mullick
profile_hits() has a common check for prof_on and prof_buffer regardless of SMP or !SMP. So, remove some duplicate code by splitting profile_hits into two. [akpm@linux-foundation.org: make do_profile_hits static] Signed-off-by: Rakib Mullick <rakib.mullick@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26mm: extract exe_file handling from procfsJiri Slaby
Setup and cleanup of mm_struct->exe_file is currently done in fs/proc/. This was because exe_file was needed only for /proc/<pid>/exe. Since we will need the exe_file functionality also for core dumps (so core name can contain full binary path), built this functionality always into the kernel. To achieve that move that out of proc FS to the kernel/ where in fact it should belong. By doing that we can make dup_mm_exe_file static. Also we can drop linux/proc_fs.h inclusion in fs/exec.c and kernel/fork.c. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26cgroup: remove the ns_cgroupDaniel Lezcano
The ns_cgroup is an annoying cgroup at the namespace / cgroup frontier and leads to some problems: * cgroup creation is out-of-control * cgroup name can conflict when pids are looping * it is not possible to have a single process handling a lot of namespaces without falling in a exponential creation time * we may want to create a namespace without creating a cgroup The ns_cgroup was replaced by a compatibility flag 'clone_children', where a newly created cgroup will copy the parent cgroup values. The userspace has to manually create a cgroup and add a task to the 'tasks' file. This patch removes the ns_cgroup as suggested in the following thread: https://lists.linux-foundation.org/pipermail/containers/2009-June/018616.html The 'cgroup_clone' function is removed because it is no longer used. This is a userspace-visible change. Commit 45531757b45c ("cgroup: notify ns_cgroup deprecated") (merged into 2.6.27) caused the kernel to emit a printk warning users that the feature is planned for removal. Since that time we have heard from XXX users who were affected by this. Signed-off-by: Daniel Lezcano <daniel.lezcano@free.fr> Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Jamal Hadi Salim <hadi@cyberus.ca> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Paul Menage <menage@google.com> Acked-by: Matt Helsley <matthltc@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26cgroups: use flex_array in attach_procBen Blum
Convert cgroup_attach_proc to use flex_array. The cgroup_attach_proc implementation requires a pre-allocated array to store task pointers to atomically move a thread-group, but asking for a monolithic array with kmalloc() may be unreliable for very large groups. Using flex_array provides the same functionality with less risk of failure. This is a post-patch for cgroup-procs-write.patch. Signed-off-by: Ben Blum <bblum@andrew.cmu.edu> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Matt Helsley <matthltc@us.ibm.com> Reviewed-by: Paul Menage <menage@google.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: David Rientjes <rientjes@google.com> Cc: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26cgroups: make procs file writableBen Blum
Make procs file writable to move all threads by tgid at once. Add functionality that enables users to move all threads in a threadgroup at once to a cgroup by writing the tgid to the 'cgroup.procs' file. This current implementation makes use of a per-threadgroup rwsem that's taken for reading in the fork() path to prevent newly forking threads within the threadgroup from "escaping" while the move is in progress. Signed-off-by: Ben Blum <bblum@andrew.cmu.edu> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Matt Helsley <matthltc@us.ibm.com> Reviewed-by: Paul Menage <menage@google.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: David Rientjes <rientjes@google.com> Cc: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26cgroups: add per-thread subsystem callbacksBen Blum
Add cgroup subsystem callbacks for per-thread attachment in atomic contexts Add can_attach_task(), pre_attach(), and attach_task() as new callbacks for cgroups's subsystem interface. Unlike can_attach and attach, these are for per-thread operations, to be called potentially many times when attaching an entire threadgroup. Also, the old "bool threadgroup" interface is removed, as replaced by this. All subsystems are modified for the new interface - of note is cpuset, which requires from/to nodemasks for attach to be globally scoped (though per-cpuset would work too) to persist from its pre_attach to attach_task and attach. This is a pre-patch for cgroup-procs-writable.patch. Signed-off-by: Ben Blum <bblum@andrew.cmu.edu> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Matt Helsley <matthltc@us.ibm.com> Reviewed-by: Paul Menage <menage@google.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: David Rientjes <rientjes@google.com> Cc: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26cgroups: read-write lock CLONE_THREAD forking per threadgroupBen Blum
Adds functionality to read/write lock CLONE_THREAD fork()ing per-threadgroup Add an rwsem that lives in a threadgroup's signal_struct that's taken for reading in the fork path, under CONFIG_CGROUPS. If another part of the kernel later wants to use such a locking mechanism, the CONFIG_CGROUPS ifdefs should be changed to a higher-up flag that CGROUPS and the other system would both depend on. This is a pre-patch for cgroup-procs-write.patch. Signed-off-by: Ben Blum <bblum@andrew.cmu.edu> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Matt Helsley <matthltc@us.ibm.com> Reviewed-by: Paul Menage <menage@google.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: David Rientjes <rientjes@google.com> Cc: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-27PM: Fix PM QOS's user mode interface to work with ASCII inputRafael J. Wysocki
Make pm_qos_power_write() accept values passed to it in the ASCII hex format either with or without an ending newline. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Mark Gross <markgross@thegnar.org>
2011-05-26rcu: Decrease memory-barrier usage based on semi-formal proofPaul E. McKenney
(Note: this was reverted, and is now being re-applied in pieces, with this being the fifth and final piece. See below for the reason that it is now felt to be safe to re-apply this.) Commit d09b62d fixed grace-period synchronization, but left some smp_mb() invocations in rcu_process_callbacks() that are no longer needed, but sheer paranoia prevented them from being removed. This commit removes them and provides a proof of correctness in their absence. It also adds a memory barrier to rcu_report_qs_rsp() immediately before the update to rsp->completed in order to handle the theoretical possibility that the compiler or CPU might move massive quantities of code into a lock-based critical section. This also proves that the sheer paranoia was not entirely unjustified, at least from a theoretical point of view. In addition, the old dyntick-idle synchronization depended on the fact that grace periods were many milliseconds in duration, so that it could be assumed that no dyntick-idle CPU could reorder a memory reference across an entire grace period. Unfortunately for this design, the addition of expedited grace periods breaks this assumption, which has the unfortunate side-effect of requiring atomic operations in the functions that track dyntick-idle state for RCU. (There is some hope that the algorithms used in user-level RCU might be applied here, but some work is required to handle the NMIs that user-space applications can happily ignore. For the short term, better safe than sorry.) This proof assumes that neither compiler nor CPU will allow a lock acquisition and release to be reordered, as doing so can result in deadlock. The proof is as follows: 1. A given CPU declares a quiescent state under the protection of its leaf rcu_node's lock. 2. If there is more than one level of rcu_node hierarchy, the last CPU to declare a quiescent state will also acquire the ->lock of the next rcu_node up in the hierarchy, but only after releasing the lower level's lock. The acquisition of this lock clearly cannot occur prior to the acquisition of the leaf node's lock. 3. Step 2 repeats until we reach the root rcu_node structure. Please note again that only one lock is held at a time through this process. The acquisition of the root rcu_node's ->lock must occur after the release of that of the leaf rcu_node. 4. At this point, we set the ->completed field in the rcu_state structure in rcu_report_qs_rsp(). However, if the rcu_node hierarchy contains only one rcu_node, then in theory the code preceding the quiescent state could leak into the critical section. We therefore precede the update of ->completed with a memory barrier. All CPUs will therefore agree that any updates preceding any report of a quiescent state will have happened before the update of ->completed. 5. Regardless of whether a new grace period is needed, rcu_start_gp() will propagate the new value of ->completed to all of the leaf rcu_node structures, under the protection of each rcu_node's ->lock. If a new grace period is needed immediately, this propagation will occur in the same critical section that ->completed was set in, but courtesy of the memory barrier in #4 above, is still seen to follow any pre-quiescent-state activity. 6. When a given CPU invokes __rcu_process_gp_end(), it becomes aware of the end of the old grace period and therefore makes any RCU callbacks that were waiting on that grace period eligible for invocation. If this CPU is the same one that detected the end of the grace period, and if there is but a single rcu_node in the hierarchy, we will still be in the single critical section. In this case, the memory barrier in step #4 guarantees that all callbacks will be seen to execute after each CPU's quiescent state. On the other hand, if this is a different CPU, it will acquire the leaf rcu_node's ->lock, and will again be serialized after each CPU's quiescent state for the old grace period. On the strength of this proof, this commit therefore removes the memory barriers from rcu_process_callbacks() and adds one to rcu_report_qs_rsp(). The effect is to reduce the number of memory barriers by one and to reduce the frequency of execution from about once per scheduling tick per CPU to once per grace period. This was reverted do to hangs found during testing by Yinghai Lu and Ingo Molnar. Frederic Weisbecker supplied Yinghai with tracing that located the underlying problem, and Frederic also provided the fix. The underlying problem was that the HARDIRQ_ENTER() macro from lib/locking-selftest.c invoked irq_enter(), which in turn invokes rcu_irq_enter(), but HARDIRQ_EXIT() invoked __irq_exit(), which does not invoke rcu_irq_exit(). This situation resulted in calls to rcu_irq_enter() that were not balanced by the required calls to rcu_irq_exit(). Therefore, after these locking selftests completed, RCU's dyntick-idle nesting count was a large number (for example, 72), which caused RCU to to conclude that the affected CPU was not in dyntick-idle mode when in fact it was. RCU would therefore incorrectly wait for this dyntick-idle CPU, resulting in hangs. In contrast, with Frederic's patch, which replaces the irq_enter() in HARDIRQ_ENTER() with an __irq_enter(), these tests don't ever call either rcu_irq_enter() or rcu_irq_exit(), which works because the CPU running the test is already marked as not being in dyntick-idle mode. This means that the rcu_irq_enter() and rcu_irq_exit() calls and RCU then has no problem working out which CPUs are in dyntick-idle mode and which are not. The reason that the imbalance was not noticed before the barrier patch was applied is that the old implementation of rcu_enter_nohz() ignored the nesting depth. This could still result in delays, but much shorter ones. Whenever there was a delay, RCU would IPI the CPU with the unbalanced nesting level, which would eventually result in rcu_enter_nohz() being called, which in turn would force RCU to see that the CPU was in dyntick-idle mode. The reason that very few people noticed the problem is that the mismatched irq_enter() vs. __irq_exit() occured only when the kernel was built with CONFIG_DEBUG_LOCKING_API_SELFTESTS. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-05-26rcu: Make rcu_enter_nohz() pay attention to nestingPaul E. McKenney
The old version of rcu_enter_nohz() forced RCU into nohz mode even if the nesting count was non-zero. This change causes rcu_enter_nohz() to hold off for non-zero nesting counts. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2011-05-26rcu: Don't do reschedule unless in irqPaul E. McKenney
Condition the set_need_resched() in rcu_irq_exit() on in_irq(). This should be a no-op, because rcu_irq_exit() should only be called from irq. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2011-05-26rcu: Remove old memory barriers from rcu_process_callbacks()Paul E. McKenney
Second step of partitioning of commit e59fb3120b. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2011-05-26rcu: Add memory barriersPaul E. McKenney
Add the memory barriers added by e59fb3120b. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2011-05-26Merge branch 'linus' into perf/urgentIngo Molnar
Merge reason: Linus applied an overlapping commit: 5f2e8e2b0bf0: kernel/watchdog.c: Use proper ANSI C prototypes So merge it in to make sure we can iterate the file without conflicts. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-05-26irq: Remove smp_affinity_list when unregister irq procYinghai Lu
commit 4b06042(bitmap, irq: add smp_affinity_list interface to /proc/irq) causes the following warning: [ 274.239500] WARNING: at fs/proc/generic.c:850 remove_proc_entry+0x24c/0x27a() [ 274.251761] remove_proc_entry: removing non-empty directory 'irq/184', leaking at least 'smp_affinity_list' Remove the new file in the exit path. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Cc: Mike Travis <travis@sgi.com> Link: http://lkml.kernel.org/r/4DDDE094.6050505@kernel.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-05-25ftrace: Add internal recursive checksSteven Rostedt
Witold reported a reboot caused by the selftests of the dynamic function tracer. He sent me a config and I used ktest to do a config_bisect on it (as my config did not cause the crash). It pointed out that the problem config was CONFIG_PROVE_RCU. What happened was that if multiple callbacks are attached to the function tracer, we iterate a list of callbacks. Because the list is managed by synchronize_sched() and preempt_disable, the access to the pointers uses rcu_dereference_raw(). When PROVE_RCU is enabled, the rcu_dereference_raw() calls some debugging functions, which happen to be traced. The tracing of the debug function would then call rcu_dereference_raw() which would then call the debug function and then... well you get the idea. I first wrote two different patches to solve this bug. 1) add a __rcu_dereference_raw() that would not do any checks. 2) add notrace to the offending debug functions. Both of these patches worked. Talking with Paul McKenney on IRC, he suggested to add recursion detection instead. This seemed to be a better solution, so I decided to implement it. As the task_struct already has a trace_recursion to detect recursion in the ring buffer, and that has a very small number it allows, I decided to use that same variable to add flags that can detect the recursion inside the infrastructure of the function tracer. I plan to change it so that the task struct bit can be checked in mcount, but as that requires changes to all archs, I will hold that off to the next merge window. Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/1306348063.1465.116.camel@gandalf.stny.rr.com Reported-by: Witold Baryluk <baryluk@smp.if.uj.edu.pl> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-05-25tracing: Add __print_symbolic_u64 to avoid warnings on 32bit machineliubo
Filesystem, like Btrfs, has some "ULL" macros, and when these macros are passed to tracepoints'__print_symbolic(), there will be 64->32 truncate WARNINGS during compiling on 32bit box. Signed-off-by: Liu Bo <liubo2009@cn.fujitsu.com> Link: http://lkml.kernel.org/r/4DACE6E0.7000507@cn.fujitsu.com Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-05-25ftrace: Set ops->flag to enabled even on static function tracingSteven Rostedt
When dynamic ftrace is not configured, the ops->flags still needs to have its FTRACE_OPS_FL_ENABLED bit set in ftrace_startup(). Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-05-25tracing: Have event with function tracer check error returnSteven Rostedt
The self tests for event tracer does not check if the function tracing was successfully activated. It needs to before it continues the tests, otherwise the wrong errors may be reported. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-05-25ftrace: Have ftrace_startup() return failure codeSteven Rostedt
The register_ftrace_function() returns an error code on failure except if the call to ftrace_startup() fails. Add a error return to ftrace_startup() if it fails to start, allowing register_ftrace_funtion() to return a proper error value. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-05-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/linux-2.6-nsfdLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/linux-2.6-nsfd: net: fix get_net_ns_by_fd for !CONFIG_NET_NS ns proc: Return -ENOENT for a nonexistent /proc/self/ns/ entry. ns: Declare sys_setns in syscalls.h net: Allow setting the network namespace by fd ns proc: Add support for the ipc namespace ns proc: Add support for the uts namespace ns proc: Add support for the network namespace. ns: Introduce the setns syscall ns: proc files for namespace naming policy.
2011-05-25jump_label: Check entries limit in __jump_label_updateJiri Olsa
When iterating the jump_label entries array (core or modules), the __jump_label_update function peeks over the last entry. The reason is that the end of the for loop depends on the key value of the processed entry. Thus when going through the last array entry, we will touch the memory behind the array limit. This bug probably will never be triggered, since most likely the memory behind the jump_label entries will be accesable and the entry->key will be different than the expected value. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Acked-by: Jason Baron <jbaron@redhat.com> Link: http://lkml.kernel.org/r/20110510104346.GC1899@jolsa.brq.redhat.com Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-05-25Merge branch 'for-2.6.40' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/oleg/misc * 'for-2.6.40' of git://git.kernel.org/pub/scm/linux/kernel/git/oleg/misc: signal: sys_pause() should check signal_pending() ptrace: ptrace_resume() shouldn't wake up !TASK_TRACED thread
2011-05-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tileLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: (26 commits) arch/tile: prefer "tilepro" as the name of the 32-bit architecture compat: include aio_abi.h for aio_context_t arch/tile: cleanups for tilegx compat mode arch/tile: allocate PCI IRQs later in boot arch/tile: support signal "exception-trace" hook arch/tile: use better definitions of xchg() and cmpxchg() include/linux/compat.h: coding-style fixes tile: add an RTC driver for the Tilera hypervisor arch/tile: finish enabling support for TILE-Gx 64-bit chip compat: fixes to allow working with tile arch arch/tile: update defconfig file to something more useful tile: do_hardwall_trap: do not play with task->sighand tile: replace mm->cpu_vm_mask with mm_cpumask() tile,mn10300: add device parameter to dma_cache_sync() audit: support the "standard" <asm-generic/unistd.h> arch/tile: clarify flush_buffer()/finv_buffer() function names arch/tile: kernel-related cleanups from removing static page size arch/tile: various header improvements for building drivers arch/tile: disable GX prefetcher during cache flush arch/tile: tolerate disabling CONFIG_BLK_DEV_INITRD ...
2011-05-25hrtimers: Fix typo causing erratic timersThomas Gleixner
commit 9ec2690758a5 ("timerfd: Manage cancelable timers in timerfd") introduced a CONFIG_HIGHRES_TIMERS (should be CONFIG_HIGH_RES_TIMERS) typo, which caused applications depending on CLOCK_REALTIME timers to become sluggy due to the fact that the time base of the realtime timers was not updated when the wall clock time was set. This causes anything from 100% CPU use for some applications to odd delays and hickups. Reported-bisected-and-tested-by: Anca Emanuel <anca.emanuel@gmail.com> Tested-by: Linus Torvalds <torvalds@linux-foundation.org> Fatfingered-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25signal: sys_pause() should check signal_pending()Oleg Nesterov
ERESTART* is always wrong without TIF_SIGPENDING. Teach sys_pause() to handle the spurious wakeup correctly. Signed-off-by: Oleg Nesterov <oleg@redhat.com>
2011-05-25ptrace: ptrace_resume() shouldn't wake up !TASK_TRACED threadOleg Nesterov
It is not clear why ptrace_resume() does wake_up_process(). Unless the caller is PTRACE_KILL the tracee should be TASK_TRACED so we can use wake_up_state(__TASK_TRACED). If sys_ptrace() races with SIGKILL we do not need the extra and potentionally spurious wakeup. If the caller is PTRACE_KILL, wake_up_process() is even more wrong. The tracee can sleep in any state in any place, and if we have a buggy code which doesn't handle a spurious wakeup correctly PTRACE_KILL can be used to exploit it. For example: int main(void) { int child, status; child = fork(); if (!child) { int ret; assert(ptrace(PTRACE_TRACEME, 0,0,0) == 0); ret = pause(); printf("pause: %d %m\n", ret); return 0x23; } sleep(1); assert(ptrace(PTRACE_KILL, child, 0,0) == 0); assert(child == wait(&status)); printf("wait: %x\n", status); return 0; } prints "pause: -1 Unknown error 514", -ERESTARTNOHAND leaks to the userland. In this case sys_pause() is buggy as well and should be fixed. I do not know what was the original rationality behind PTRACE_KILL. The man page is simply wrong and afaics it was always wrong. Imho it should be deprecated, or may be it should do send_sig(SIGKILL) as Denys suggests, but in any case I do not think that the current behaviour was intentional. Note: there is another problem, ptrace_resume() changes ->exit_code and this can race with SIGKILL too. Eventually we should change ptrace to not use ->exit_code. Signed-off-by: Oleg Nesterov <oleg@redhat.com>
2011-05-25Merge branch 'timers-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: posix-timers: RCU conversion
2011-05-25printk: allocate kernel log buffer earlierMike Travis
On larger systems, because of the numerous ACPI, Bootmem and EFI messages, the static log buffer overflows before the larger one specified by the log_buf_len param is allocated. Minimize the overflow by allocating the new log buffer as soon as possible. On kernels without memblock, a later call to setup_log_buf from kernel/init.c is the fallback. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix CONFIG_PRINTK=n build] Signed-off-by: Mike Travis <travis@sgi.com> Cc: Yinghai Lu <yhlu.kernel@gmail.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Jack Steiner <steiner@sgi.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25bitmap, irq: add smp_affinity_list interface to /proc/irqMike Travis
Manually adjusting the smp_affinity for IRQ's becomes unwieldy when the cpu count is large. Setting smp affinity to cpus 256 to 263 would be: echo 000000ff,00000000,00000000,00000000,00000000,00000000,00000000,00000000 > smp_affinity instead of: echo 256-263 > smp_affinity_list Think about what it looks like for cpus around say, 4088 to 4095. We already have many alternate "list" interfaces: /sys/devices/system/cpu/cpuX/indexY/shared_cpu_list /sys/devices/system/cpu/cpuX/topology/thread_siblings_list /sys/devices/system/cpu/cpuX/topology/core_siblings_list /sys/devices/system/node/nodeX/cpulist /sys/devices/pci***/***/local_cpulist Add a companion interface, smp_affinity_list to use cpu lists instead of cpu maps. This conforms to other companion interfaces where both a map and a list interface exists. This required adding a bitmap_parselist_user() function in a manner similar to the bitmap_parse_user() function. [akpm@linux-foundation.org: make __bitmap_parselist() static] Signed-off-by: Mike Travis <travis@sgi.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Jack Steiner <steiner@sgi.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Andy Shevchenko <andy.shevchenko@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: convert mm->cpu_vm_cpumask into cpumask_var_tKOSAKI Motohiro
cpumask_t is very big struct and cpu_vm_mask is placed wrong position. It might lead to reduce cache hit ratio. This patch has two change. 1) Move the place of cpumask into last of mm_struct. Because usually cpumask is accessed only front bits when the system has cpu-hotplug capability 2) Convert cpu_vm_mask into cpumask_var_t. It may help to reduce memory footprint if cpumask_size() will use nr_cpumask_bits properly in future. In addition, this patch change the name of cpu_vm_mask with cpu_vm_mask_var. It may help to detect out of tree cpu_vm_mask users. This patch has no functional change. [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: David Howells <dhowells@redhat.com> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Hugh Dickins <hughd@google.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: Convert i_mmap_lock to a mutexPeter Zijlstra
Straightforward conversion of i_mmap_lock to a mutex. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Hugh Dickins <hughd@google.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Miller <davem@davemloft.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Tony Luck <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
