path: root/kernel
2011-08-26All Arch: remove linkage for sys_nfsservctl system callNeilBrown
The nfsservctl system call is now gone, so we should remove all linkage for it. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-25kernel/printk: do not turn off bootconsole in printk_late_init() if keep_bootconNishanth Aravamudan
It seems that 7bf693951a8e ("console: allow to retain boot console via boot option keep_bootcon") doesn't always achieve what it aims, as when printk_late_init() runs it unconditionally turns off all boot consoles. With this patch, I am able to see more messages on the boot console in KVM guests than I can without, when keep_bootcon is specified. I think it is appropriate for the relevant -stable trees. However, it's more of an annoyance than a serious bug (ideally you don't need to keep the boot console around as console handover should be working -- I was encountering a situation where the console handover wasn't working and not having the boot console available meant I couldn't see why). Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Cc: David S. Miller <davem@davemloft.net> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Greg KH <gregkh@suse.de> Acked-by: Fabio M. Di Nitto <fdinitto@redhat.com> Cc: <stable@kernel.org> [2.6.39.x, 3.0.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-25Add a personality to report 2.6.x version numbersAndi Kleen
I ran into a couple of programs which broke with the new Linux 3.0 version. Some of those were binary only. I tried to use LD_PRELOAD to work around it, but it was quite difficult and in one case impossible because of a mix of 32bit and 64bit executables. For example, all kind of management software from HP doesnt work, unless we pretend to run a 2.6 kernel. $ uname -a Linux svivoipvnx001 3.0.0-08107-g97cd98f #1062 SMP Fri Aug 12 18:11:45 CEST 2011 i686 i686 i386 GNU/Linux $ hpacucli ctrl all show Error: No controllers detected. $ rpm -qf /usr/sbin/hpacucli hpacucli-8.75-12.0 Another notable case is that Python now reports "linux3" from sys.platform(); which in turn can break things that were checking sys.platform() == "linux2": https://bugzilla.mozilla.org/show_bug.cgi?id=664564 It seems pretty clear to me though it's a bug in the apps that are using '==' instead of .startswith(), but this allows us to unbreak broken programs. This patch adds a UNAME26 personality that makes the kernel report a 2.6.40+x version number instead. The x is the x in 3.x. I know this is somewhat ugly, but I didn't find a better workaround, and compatibility to existing programs is important. Some programs also read /proc/sys/kernel/osrelease. This can be worked around in user space with mount --bind (and a mount namespace) To use: wget ftp://ftp.kernel.org/pub/linux/kernel/people/ak/uname26/uname26.c gcc -o uname26 uname26.c ./uname26 program Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-23Merge branch 'for-linus' of git://oss.sgi.com/xfs/xfsLinus Torvalds
* 'for-linus' of git://oss.sgi.com/xfs/xfs: xfs: fix tracing builds inside the source tree xfs: remove subdirectories xfs: don't expect xfs headers to be in subdirectories
2011-08-23Revert "irq: Always set IRQF_ONESHOT if no primary handler is specified"Linus Torvalds
This reverts commit f3637a5f2e2eb391ff5757bc83fb5de8f9726464. It turns out that this breaks several drivers, one example being OMAP boards which use the on-board OMAP UARTs and the omap-serial driver that will not boot to userspace after the commit. Paul Walmsley reports that enabling CONFIG_DEBUG_SHIRQ reveals 'IRQ handler type mismatch' errors: IRQ handler type mismatch for IRQ 74 current handler: serial idle ... and the reason is that setting IRQF_ONESHOT will now result in those interrupt handlers having different IRQF flags, and thus being unsharable. So the commit log in the reverted commit: "Since it is required for those users and there is no difference for others it makes sense to add this flag unconditionally." is simply not true: there may not be any difference from a "actions at irq time", but there is a *big* difference wrt this flag testing irq management (see __setup_irq() in kernel/irq/manage.c). One solution may be to stop verifying IRQF_ONESHOT in __setup_irq(), but right now the safe course of action is to revert the change. Let's revisit this in a later merge window. Reported-by: Paul Walmsley <paul@pwsan.com> Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Requested-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Acked-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-19Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-block: (23 commits) Revert "cfq: Remove special treatment for metadata rqs." block: fix flush machinery for stacking drivers with differring flush flags block: improve rq_affinity placement blktrace: add FLUSH/FUA support Move some REQ flags to the common bio/request area allow blk_flush_policy to return REQ_FSEQ_DATA independent of *FLUSH xen/blkback: Make description more obvious. cfq-iosched: Add documentation about idling block: Make rq_affinity = 1 work as expected block: swim3: fix unterminated of_device_id table block/genhd.c: remove useless cast in diskstats_show() drivers/cdrom/cdrom.c: relax check on dvd manufacturer value drivers/block/drbd/drbd_nl.c: use bitmap_parse instead of __bitmap_parse bsg-lib: add module.h include cfq-iosched: Reduce linked group count upon group destruction blk-throttle: correctly determine sync bio loop: fix deadlock when sysfs and LOOP_CLR_FD race against each other loop: add BLK_DEV_LOOP_MIN_COUNT=%i to allow distros 0 pre-allocated loop devices loop: add management interface for on-demand device allocation loop: replace linked list of allocated devices with an idr index ...
2011-08-18irqdesc: fix new kernel-doc warningRandy Dunlap
Fix kernel-doc warning in irqdesc.c: Warning(kernel/irq/irqdesc.c:353): No description found for parameter 'owner' Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-17Merge branch 'pm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm * 'pm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: PM / Domains: Fix build for CONFIG_PM_RUNTIME unset
2011-08-17Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: lockdep: Fix wrong assumption in match_held_lock
2011-08-17Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: irq: Track the owner of irq descriptor irq: Always set IRQF_ONESHOT if no primary handler is specified genirq: Fix wrong bit operation
2011-08-14PM / Domains: Fix build for CONFIG_PM_RUNTIME unsetRafael J. Wysocki
Function genpd_queue_power_off_work() is not defined for CONFIG_PM_RUNTIME, so pm_genpd_poweroff_unused() causes a build error to happen in that case. Fix the problem by making pm_genpd_poweroff_unused() depend on CONFIG_PM_RUNTIME too. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-08-12xfs: remove subdirectoriesChristoph Hellwig
Use the move from Linux 2.6 to Linux 3.x as an excuse to kill the annoying subdirectories in the XFS source code. Besides the large amount of file rename the only changes are to the Makefile, a few files including headers with the subdirectory prefix, and the binary sysctl compat code that includes a header under fs/xfs/ from kernel/. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-08-11move RLIMIT_NPROC check from set_user() to do_execve_common()Vasiliy Kulikov
The patch http://lkml.org/lkml/2003/7/13/226 introduced an RLIMIT_NPROC check in set_user() to check for NPROC exceeding via setuid() and similar functions. Before the check there was a possibility to greatly exceed the allowed number of processes by an unprivileged user if the program relied on rlimit only. But the check created new security threat: many poorly written programs simply don't check setuid() return code and believe it cannot fail if executed with root privileges. So, the check is removed in this patch because of too often privilege escalations related to buggy programs. The NPROC can still be enforced in the common code flow of daemons spawning user processes. Most of daemons do fork()+setuid()+execve(). The check introduced in execve() (1) enforces the same limit as in setuid() and (2) doesn't create similar security issues. Neil Brown suggested to track what specific process has exceeded the limit by setting PF_NPROC_EXCEEDED process flag. With the change only this process would fail on execve(), and other processes' execve() behaviour is not changed. Solar Designer suggested to re-check whether NPROC limit is still exceeded at the moment of execve(). If the process was sleeping for days between set*uid() and execve(), and the NPROC counter step down under the limit, the defered execve() failure because NPROC limit was exceeded days ago would be unexpected. If the limit is not exceeded anymore, we clear the flag on successful calls to execve() and fork(). The flag is also cleared on successful calls to set_user() as the limit was exceeded for the previous user, not the current one. Similar check was introduced in -ow patches (without the process flag). v3 - clear PF_NPROC_EXCEEDED on successful calls to set_user(). Reviewed-by: James Morris <jmorris@namei.org> Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Acked-by: NeilBrown <neilb@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-11Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf symbols: Check '/tmp/perf-' symbol file ownership perf sched: Usage leftover from trace -> script rename perf sched: Do not delete session object prematurely perf tools: Check $HOME/.perfconfig ownership perf, x86: Add model 45 SandyBridge support perf tools: Add support to install perf python extension perf tools: do not look at ./config for configuration perf tools: Make clean leaves some files perf lock: Dropping unsupported ':r' modifier perf probe: Fix coredump introduced by probe module option jump label: Reduce the cycle count by changing the link order perf report: Use ui__warning in some more places perf python: Add PERF_RECORD_{LOST,READ,SAMPLE} routine tables perf evlist: Introduce 'disable' method trace events: Update version number reference to new 3.x scheme for EVENT_POWER_TRACING_DEPRECATED perf buildid-cache: Zero out buffer of filenames when adding/removing buildid
2011-08-11blktrace: add FLUSH/FUA supportNamhyung Kim
Add FLUSH/FUA support to blktrace. As FLUSH precedes WRITE and/or FUA follows WRITE, use the same 'F' flag for both cases and distinguish them by their (relative) position. The end results look like (other flags might be shown also): - WRITE: W - WRITE_FLUSH: FW - WRITE_FUA: WF - WRITE_FLUSH_FUA: FWF Note that we reuse TC_BARRIER due to lack of bit space of act_mask so that the older versions of blktrace tools will report flush requests as barriers from now on. Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Signed-off-by: Namhyung Kim <namhyung@gmail.com> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-08-09cap_syslog: don't use WARN_ONCE for CAP_SYS_ADMIN deprecation warningJonathan Nieder
syslog-ng versions before 3.3.0beta1 (2011-05-12) assume that CAP_SYS_ADMIN is sufficient to access syslog, so ever since CAP_SYSLOG was introduced (2010-11-25) they have triggered a warning. Commit ee24aebffb75 ("cap_syslog: accept CAP_SYS_ADMIN for now") improved matters a little by making syslog-ng work again, just keeping the WARN_ONCE(). But still, this is a warning that writes a stack trace we don't care about to syslog, sets a taint flag, and alarms sysadmins when nothing worse has happened than use of an old userspace with a recent kernel. Convert the WARN_ONCE to a printk_once to avoid that while continuing to give userspace developers a hint that this is an unwanted backward-compatibility feature and won't be around forever. Reported-by: Ralf Hildebrandt <ralf.hildebrandt@charite.de> Reported-by: Niels <zorglub_olsen@hotmail.com> Reported-by: Paweł Sikora <pluto@agmk.net> Signed-off-by: Jonathan Nieder <jrnieder@gmail.com> Liked-by: Gergely Nagy <algernon@madhouse-project.org> Acked-by: Serge Hallyn <serge@hallyn.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-09lockdep: Fix wrong assumption in match_held_lockPeter Zijlstra
match_held_lock() was assuming it was being called on a lock class that had already seen usage. This condition was true for bug-free code using lockdep_assert_held(), since you're in fact holding the lock when calling it. However the assumption fails the moment you assume the assertion can fail, which is the whole point of having the assertion in the first place. Anyway, now that there's more lockdep_is_held() users, notably __rcu_dereference_check(), its much easier to trigger this since we test for a number of locks and we only need to hold any one of them to be good. Reported-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1312547787.28695.2.camel@twins Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-08-05jump label: Reduce the cycle count by changing the link orderJason Baron
In the course of testing jump labels for use with the CFS bandwidth controller, Paul Turner, discovered that using jump labels reduced the branch count and the instruction count, but did not reduce the cycle count or wall time. I noticed that having the jump_label.o included in the kernel but not used in any way still caused this increase in cycle count and wall time. Thus, I moved jump_label.o in the kernel/Makefile, thus changing the link order, and presumably moving it out of hot icache areas. This brought down the cycle count/time as expected. In addition to Paul's testing, I've tested the patch using a single 'static_branch()' in the getppid() path, and basically running tight loops of calls to getppid(). Here are my results for the branch disabled case: With jump labels turned on (CONFIG_JUMP_LABEL), branch disabled: Performance counter stats for 'bash -c /tmp/getppid;true' (50 runs): 3,969,510,217 instructions # 0.864 IPC ( +-0.000% ) 4,592,334,954 cycles ( +- 0.046% ) 751,634,470 branches ( +- 0.000% ) 1.722635797 seconds time elapsed ( +- 0.046% ) Jump labels turned off (CONFIG_JUMP_LABEL not set), branch disabled: Performance counter stats for 'bash -c /tmp/getppid;true' (50 runs): 4,009,611,846 instructions # 0.867 IPC ( +-0.000% ) 4,622,210,580 cycles ( +- 0.012% ) 771,662,904 branches ( +- 0.000% ) 1.734341454 seconds time elapsed ( +- 0.022% ) Signed-off-by: Jason Baron <jbaron@redhat.com> Cc: rth@redhat.com Cc: a.p.zijlstra@chello.nl Cc: rostedt@goodmis.org Link: http://lkml.kernel.org/r/20110805204040.GG2522@redhat.com Signed-off-by: Ingo Molnar <mingo@elte.hu> Tested-by: Paul Turner <pjt@google.com>
2011-08-05Merge branch 'linus' into perf/urgentIngo Molnar
Merge reason: Include most of the merge window trees, to do fixes on top. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-08-04Merge branch 'core-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: slab, lockdep: Annotate the locks before using them lockdep: Clear whole lockdep_map on initialization slab, lockdep: Annotate slab -> rcu -> debug_object -> slab lockdep: Fix up warning lockdep: Fix trace_hardirqs_on_caller() futex: Fix regression with read only mappings
2011-08-04lockdep: Clear whole lockdep_map on initializationTejun Heo
lockdep_init_map() only initializes parts of lockdep_map and triggers kmemcheck warning when it is copied as a whole. There isn't anything to be gained by clearing selectively. memset() the whole structure and remove loop for ->class_cache[] clearing. Addresses https://bugzilla.kernel.org/show_bug.cgi?id=35532 Signed-off-by: Tejun Heo <tj@kernel.org> Reported-and-tested-by: Christian Casteyde <casteyde.christian@free.fr> Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=35532 Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20110714131909.GJ3455@htj.dyndns.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-08-04lockdep: Fix up warningPeter Zijlstra
On Sun, 2011-07-24 at 21:06 -0400, Arnaud Lacombe wrote: > /src/linux/linux/kernel/lockdep.c: In function 'mark_held_locks': > /src/linux/linux/kernel/lockdep.c:2471:31: warning: comparison of > distinct pointer types lacks a cast The warning is harmless in this case, but the below makes it go away. Reported-by: Arnaud Lacombe <lacombar@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1311588599.2617.56.camel@laptop Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-08-04lockdep: Fix trace_hardirqs_on_caller()Peter Zijlstra
Commit dd4e5d3ac4a ("lockdep: Fix trace_[soft,hard]irqs_[on,off]() recursion") made a bit of a mess of the various checks and error conditions. In particular it moved the check for !irqs_disabled() before the spurious enable test, resulting in some warnings. Reported-by: Arnaud Lacombe <lacombar@gmail.com> Reported-by: Dave Jones <davej@redhat.com> Reported-and-tested-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1311679697.24752.28.camel@twins Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-08-03Boot up with usermodehelper disabledLinus Torvalds
The core device layer sends tons of uevent notifications for each device it finds, and if the kernel has been built with a non-empty CONFIG_UEVENT_HELPER_PATH that will make us try to execute the usermode helper binary for all these events very early in the boot. Not only won't the root filesystem even be mounted at that point, we literally won't have necessarily even initialized all the process handling data structures at that point, which causes no end of silly problems even when the usermode helper doesn't actually succeed in executing. So just use our existing infrastructure to disable the usermodehelpers to make the kernel start out with them disabled. We enable them when we've at least initialized stuff a bit. Problems related to an uninitialized init_ipc_ns.ids[IPC_SHM_IDS].rw_mutex reported by various people. Reported-by: Manuel Lauss <manuel.lauss@googlemail.com> Reported-by: Richard Weinberger <richard@nod.at> Reported-by: Marc Zyngier <maz@misterjones.org> Acked-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Vasiliy Kulikov <segoon@openwall.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-04Merge branch 'linus' into core/urgentIngo Molnar
2011-08-03taskstats: add_del_listener() should ignore !valid listenersOleg Nesterov
When send_cpu_listeners() finds the orphaned listener it marks it as !valid and drops listeners->sem. Before it takes this sem for writing, s->pid can be reused and add_del_listener() can wrongly try to re-use this entry. Change add_del_listener() to check ->valid = T. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Reviewed-by: Vasiliy Kulikov <segoon@openwall.com> Acked-by: Balbir Singh <bsingharora@gmail.com> Cc: Jerome Marchand <jmarchan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-03taskstats: add_del_listener() shouldn't use the wrong nodeOleg Nesterov
1. Commit 26c4caea9d69 "don't allow duplicate entries in listener mode" changed add_del_listener(REGISTER) so that "next_cpu:" can reuse the listener allocated for the previous cpu, this doesn't look exactly right even if minor. Change the code to kfree() in the already-registered case, this case is unlikely anyway so the extra kmalloc_node() shouldn't hurt but looke more correct and clean. 2. use the plain list_for_each_entry() instead of _safe() to scan listeners->list. 3. Remove the unneeded INIT_LIST_HEAD(&s->list), we are going to list_add(&s->list). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Reviewed-by: Vasiliy Kulikov <segoon@openwall.com> Cc: Balbir Singh <bsingharora@gmail.com> Reviewed-by: Jerome Marchand <jmarchan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-01Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb: kdb,kgdb: Allow arbitrary kgdb magic knock sequences kdb: Remove all references to DOING_KGDB2 kdb,kgdb: Implement switch and pass buffer from kdb -> gdb kdb: cleanup unused variables missed in the original kdb merge
2011-08-01kdb,kgdb: Allow arbitrary kgdb magic knock sequencesJason Wessel
The first packet that gdb sends when the kernel is in kdb mode seems to change with every release of gdb. Instead of continuing to add many different gdb packets, change kdb to automatically look for any thing that looks like a gdb packet. Example 1 cold start test: echo g > /proc/sysrq-trigger $D#44+ Example 2 cold start test: echo g > /proc/sysrq-trigger $3#33 The second one should re-enter kdb's shell right away and is purely a test. Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2011-08-01kdb: Remove all references to DOING_KGDB2Jason Wessel
The DOING_KGDB2 was originally a state variable for one of the two ways to automatically transition from kdb to kgdb. Purge all these variables and just use one single state for the transition. Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2011-08-01kdb,kgdb: Implement switch and pass buffer from kdb -> gdbJason Wessel
When switching from kdb mode to kgdb mode packets were getting lost depending on the size of the fifo queue of the serial chip. When gdb initially connects if it is in kdb mode it should entirely send any character buffer over to the gdbstub when switching connections. Previously kdb was zero'ing out the character buffer and this could lead to gdb failing to connect at all, or a lengthy pause could occur on the initial connect. Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2011-08-01kdb: cleanup unused variables missed in the original kdb mergeJason Wessel
The BTARGS and BTSYMARG variables do not have any function in the mainline version of kdb. Reported-by: Tim Bird <tim.bird@am.sony.com> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2011-07-31Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k: m68k/math-emu: Remove unnecessary code m68k/math-emu: Remove commented out old code m68k: Kill warning in setup_arch() when compiling for Sun3 m68k/atari: Prefix GPIO_{IN,OUT} with CODEC_ sparc: iounmap() and *_free_coherent() - Use lookup_resource() m68k/atari: Reserve some ST-RAM early on for device buffer use m68k/amiga: Chip RAM - Use lookup_resource() resources: Add lookup_resource() sparc: _sparc_find_resource() should check for exact matches m68k/amiga: Chip RAM - Offset resource end by CHIP_PHYSADDR m68k/amiga: Chip RAM - Use resource_size() to fix off-by-one error m68k/amiga: Chip RAM - Change chipavail to an atomic_t m68k/amiga: Chip RAM - Always allocate from the start of memory m68k/amiga: Chip RAM - Convert from printk() to pr_*() m68k/amiga: Chip RAM - Use tabs for indentation
2011-07-30resources: Add lookup_resource()Geert Uytterhoeven
Add a function to find an existing resource by a resource start address. This allows to implement simple allocators (with a malloc/free-alike API) on top of the resource system. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-07-30Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (430 commits) [media] ir-mce_kbd-decoder: include module.h for its facilities [media] ov5642: include module.h for its facilities [media] em28xx: Fix DVB-C maxsize for em2884 [media] tda18271c2dd: Fix saw filter configuration for DVB-C @6MHz [media] v4l: mt9v032: Fix Bayer pattern [media] V4L: mt9m111: rewrite set_pixfmt [media] V4L: mt9m111: fix missing return value check mt9m111_reg_clear [media] V4L: initial driver for ov5642 CMOS sensor [media] V4L: sh_mobile_ceu_camera: fix Oops when USERPTR mapping fails [media] V4L: soc-camera: remove soc-camera bus and devices on it [media] V4L: soc-camera: un-export the soc-camera bus [media] V4L: sh_mobile_csi2: switch away from using the soc-camera bus notifier [media] V4L: add media bus configuration subdev operations [media] V4L: soc-camera: group struct field initialisations together [media] V4L: soc-camera: remove now unused soc-camera specific PM hooks [media] V4L: pxa-camera: switch to using standard PM hooks [media] NetUP Dual DVB-T/C CI RF: force card hardware revision by module param [media] Don't OOPS if videobuf_dvb_get_frontend return NULL [media] NetUP Dual DVB-T/C CI RF: load firmware according card revision [media] omap3isp: Support configurable HS/VS polarities ... Fix up conflicts: - arch/arm/mach-omap2/board-rx51-peripherals.c: cleanup regulator supply definitions in mach-omap2 vs OMAP3: RX-51: define vdds_csib regulator supply - drivers/staging/tm6000/tm6000-alsa.c (trivial)
2011-07-29Merge branch 'next/dt' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (21 commits) arm/dt: tegra devicetree support arm/versatile: Add device tree support dt/irq: add irq_domain_generate_simple() helper irq: add irq_domain translation infrastructure dmaengine: imx-sdma: add device tree probe support dmaengine: imx-sdma: sdma_get_firmware does not need to copy fw_name dmaengine: imx-sdma: use platform_device_id to identify sdma version mmc: sdhci-esdhc-imx: add device tree probe support mmc: sdhci-pltfm: dt device does not pass parent to sdhci_alloc_host mmc: sdhci-esdhc-imx: get rid of the uses of cpu_is_mx() mmc: sdhci-esdhc-imx: do not reference platform data after probe mmc: sdhci-esdhc-imx: extend card_detect and write_protect support for mx5 net/fec: add device tree probe support net: ibm_newemac: convert it to use of_get_phy_mode dt/net: add helper function of_get_phy_mode net/fec: gasket needs to be enabled for some i.mx serial/imx: add device tree probe support serial/imx: get rid of the uses of cpu_is_mx1() arm/dt: Add dtb make rule arm/dt: Add skeleton dtsi file ...
2011-07-28Merge branch 'imx/dt' into next/dtArnd Bergmann
2011-07-28irq: Track the owner of irq descriptorSebastian Andrzej Siewior
Interrupt descriptors can be allocated from modules. The interrupts are used by other modules, but we have no refcount on the module which provides the interrupts and there is no way to establish one on the device level as the interrupt using module is agnostic to the fact that the interrupt is provided by a module rather than by some builtin interrupt controller. To prevent removal of the interrupt providing module, we can track the owner of the interrupt descriptor, which also provides the relevant irq chip functions in the irq descriptor. request/setup_irq() can now acquire a refcount on the owner module to prevent unloading. free_irq() drops the refcount. Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Link: http://lkml.kernel.org/r/20110711101731.GA13804@Chamillionaire.breakpoint.cc Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-07-28irq: Always set IRQF_ONESHOT if no primary handler is specifiedSebastian Andrzej Siewior
If no primary handler is specified then a default one is assigned which always returns IRQ_WAKE_THREAD. This handler requires the IRQF_ONESHOT flag on LEVEL / EIO typed irqs because the source of interrupt is not disabled. Since it is required for those users and there is no difference for others it makes sense to add this flag unconditionally. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Link: http://lkml.kernel.org/r/1310070737-18514-1-git-send-email-bigeasy@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-07-28dt/irq: add irq_domain_generate_simple() helperGrant Likely
irq_domain_generate_simple() is an easy way to generate an irq translation domain for simple irq controllers. It assumes a flat 1:1 mapping from hardware irq number to an offset of the first linux irq number assigned to the controller Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-28irq: add irq_domain translation infrastructureGrant Likely
This patch adds irq_domain infrastructure for translating from hardware irq numbers to linux irqs. This is particularly important for architectures adding device tree support because the current implementation (excluding PowerPC and SPARC) cannot handle translation for more than a single interrupt controller. irq_domain supports device tree translation for any number of interrupt controllers. This patch converts x86, Microblaze, ARM and MIPS to use irq_domain for device tree irq translation. x86 is untested beyond compiling it, irq_domain is enabled for MIPS and Microblaze, but the old behaviour is preserved until the core code is modified to actually register an irq_domain yet. On ARM it works and is required for much of the new ARM device tree board support. PowerPC has /not/ been converted to use this new infrastructure. It is still missing some features before it can replace the virq infrastructure already in powerpc (see documentation on irq_domain_map/unmap for details). Followup patches will add the missing pieces and migrate PowerPC to use irq_domain. SPARC has its own method of managing interrupts from the device tree and is unaffected by this change. Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (54 commits) tpm_nsc: Fix bug when loading multiple TPM drivers tpm: Move tpm_tis_reenable_interrupts out of CONFIG_PNP block tpm: Fix compilation warning when CONFIG_PNP is not defined TOMOYO: Update kernel-doc. tpm: Fix a typo tpm_tis: Probing function for Intel iTPM bug tpm_tis: Fix the probing for interrupts tpm_tis: Delay ACPI S3 suspend while the TPM is busy tpm_tis: Re-enable interrupts upon (S3) resume tpm: Fix display of data in pubek sysfs entry tpm_tis: Add timeouts sysfs entry tpm: Adjust interface timeouts if they are too small tpm: Use interface timeouts returned from the TPM tpm_tis: Introduce durations sysfs entry tpm: Adjust the durations if they are too small tpm: Use durations returned from TPM TOMOYO: Enable conditional ACL. TOMOYO: Allow using argv[]/envp[] of execve() as conditions. TOMOYO: Allow using executable's realpath and symlink's target as conditions. TOMOYO: Allow using owner/group etc. of file objects as conditions. ... Fix up trivial conflict in security/tomoyo/realpath.c
2011-07-27[media] v4l2-compat-ioctl32: add VIDIOC_DQEVENT supportHans Verkuil
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27signals: sys_ssetmask/sys_rt_sigsuspend should use set_current_blocked()Oleg Nesterov
sys_ssetmask(), sys_rt_sigsuspend() and compat_sys_rt_sigsuspend() change ->blocked directly. This is not correct, see the changelog in e6fa16ab "signal: sigprocmask() should do retarget_shared_pending()" Change them to use set_current_blocked(). Another change is that now we are doing ->saved_sigmask = ->blocked lockless, it doesn't make any sense to do this under ->siglock. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Reviewed-by: Matt Fleming <matt.fleming@linux.intel.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26panic: panic=-1 for immediate rebootHugh Dickins
When a kernel BUG or oops occurs, ChromeOS intends to panic and immediately reboot, with stacktrace and other messages preserved in RAM across reboot. But the longer we delay, the more likely the user is to poweroff and lose the info. panic_timeout (seconds before rebooting) is set by panic= boot option or sysctl or /proc/sys/kernel/panic; but 0 means wait forever, so at present we have to delay at least 1 second. Let a negative number mean reboot immediately (with the small cosmetic benefit of suppressing that newline-less "Rebooting in %d seconds.." message). Signed-off-by: Hugh Dickins <hughd@chromium.org> Signed-off-by: Mandeep Singh Baines <msb@chromium.org> Cc: Huang Ying <ying.huang@intel.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Hugh Dickins <hughd@google.com> Cc: Olaf Hering <olaf@aepfle.de> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Dave Airlie <airlied@gmail.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26gcov: disable CONSTRUCTORS for UMLVitaliy Ivanov
Selecting GCOV for UML causing configuration mismatch: warning: (GCOV_KERNEL) selects CONSTRUCTORS which has unmet direct dependencies (!UML) Constructors are not needed for UML. Signed-off-by: Vitaliy Ivanov <vitalivanov@gmail.com> Cc: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Acked-by: Richard Weinberger <richard@nod.at> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26ipc: introduce shm_rmid_forced sysctlVasiliy Kulikov
Add support for the shm_rmid_forced sysctl. If set to 1, all shared memory objects in current ipc namespace will be automatically forced to use IPC_RMID. The POSIX way of handling shmem allows one to create shm objects and call shmdt(), leaving shm object associated with no process, thus consuming memory not counted via rlimits. With shm_rmid_forced=1 the shared memory object is counted at least for one process, so OOM killer may effectively kill the fat process holding the shared memory. It obviously breaks POSIX - some programs relying on the feature would stop working. So set shm_rmid_forced=1 only if you're sure nobody uses "orphaned" memory. Use shm_rmid_forced=0 by default for compatability reasons. The feature was previously impemented in -ow as a configure option. [akpm@linux-foundation.org: fix documentation, per Randy] [akpm@linux-foundation.org: fix warning] [akpm@linux-foundation.org: readability/conventionality tweaks] [akpm@linux-foundation.org: fix shm_rmid_forced/shm_forced_rmid confusion, use standard comment layout] Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: "Serge E. Hallyn" <serge.hallyn@canonical.com> Cc: Daniel Lezcano <daniel.lezcano@free.fr> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Tejun Heo <tj@kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Solar Designer <solar@openwall.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26kernel/fork.c: fix a few coding style issuesDaniel Rebelo de Oliveira
Signed-off-by: Daniel Rebelo de Oliveira <psykon@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26cpusets: randomize node rotor used in cpuset_mem_spread_node()Michal Hocko
[ This patch has already been accepted as commit 0ac0c0d0f837 but later reverted (commit 35926ff5fba8) because it itroduced arch specific __node_random which was defined only for x86 code so it broke other archs. This is a followup without any arch specific code. Other than that there are no functional changes.] Some workloads that create a large number of small files tend to assign too many pages to node 0 (multi-node systems). Part of the reason is that the rotor (in cpuset_mem_spread_node()) used to assign nodes starts at node 0 for newly created tasks. This patch changes the rotor to be initialized to a random node number of the cpuset. [akpm@linux-foundation.org: fix layout] [Lee.Schermerhorn@hp.com: Define stub numa_random() for !NUMA configuration] [mhocko@suse.cz: Make it arch independent] [akpm@linux-foundation.org: fix CONFIG_NUMA=y, MAX_NUMNODES>1 build] Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Michal Hocko <mhocko@suse.cz> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Paul Menage <menage@google.com> Cc: Jack Steiner <steiner@sgi.com> Cc: Robin Holt <holt@sgi.com> Cc: David Rientjes <rientjes@google.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: David Rientjes <rientjes@google.com> Cc: Jack Steiner <steiner@sgi.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Paul Menage <menage@google.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Robin Holt <holt@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
