commit d78c9300c51d6ceed9f6d078d4e9366f259de28c upstream.
timeval_to_jiffies tried to round a timeval up to an integral number
of jiffies, but the logic for doing so was incorrect: intervals
corresponding to exactly N jiffies would become N+1. This manifested
itself particularly repeatedly stopping/starting an itimer:
setitimer(ITIMER_PROF, &val, NULL);
setitimer(ITIMER_PROF, NULL, &val);
would add a full tick to val, _even if it was exactly representable in
terms of jiffies_ (say, the result of a previous rounding.) Doing
this repeatedly would cause unbounded growth in val. So fix the math.
Here's what was wrong with the conversion: we essentially computed
(eliding seconds)
jiffies = usec * (NSEC_PER_USEC/TICK_NSEC)
by using scaling arithmetic, which took the best approximation of
NSEC_PER_USEC/TICK_NSEC with denominator of 2^USEC_JIFFIE_SC =
x/(2^USEC_JIFFIE_SC), and computed:
jiffies = (usec * x) >> USEC_JIFFIE_SC
and rounded this calculation up in the intermediate form (since we
can't necessarily exactly represent TICK_NSEC in usec.) But the
scaling arithmetic is a (very slight) *over*approximation of the true
value; that is, instead of dividing by (1 usec/ 1 jiffie), we
effectively divided by (1 usec/1 jiffie)-epsilon (rounding
down). This would normally be fine, but we want to round timeouts up,
and we did so by adding 2^USEC_JIFFIE_SC - 1 before the shift; this
would be fine if our division was exact, but dividing this by the
slightly smaller factor was equivalent to adding just _over_ 1 to the
final result (instead of just _under_ 1, as desired.)
In particular, with HZ=1000, we consistently computed that 10000 usec
was 11 jiffies; the same was true for any exact multiple of
TICK_NSEC.
We could possibly still round in the intermediate form, adding
something less than 2^USEC_JIFFIE_SC - 1, but easier still is to
convert usec->nsec, round in nanoseconds, and then convert using
time*spec*_to_jiffies. This adds one constant multiplication, and is
not observably slower in microbenchmarks on recent x86 hardware.
Tested: the following program:
int main() {
struct itimerval zero = {{0, 0}, {0, 0}};
/* Initially set to 10 ms. */
struct itimerval initial = zero;
initial.it_interval.tv_usec = 10000;
setitimer(ITIMER_PROF, &initial, NULL);
/* Save and restore several times. */
for (size_t i = 0; i < 10; ++i) {
struct itimerval prev;
setitimer(ITIMER_PROF, &zero, &prev);
/* on old kernels, this goes up by TICK_USEC every iteration */
printf("previous value: %ld %ld %ld %ld\n",
prev.it_interval.tv_sec, prev.it_interval.tv_usec,
prev.it_value.tv_sec, prev.it_value.tv_usec);
setitimer(ITIMER_PROF, &prev, NULL);
return 0;
Cc: Paul Turner <pjt@google.com>
Cc: Richard Cochran <richardcochran@gmail.com>
Cc: Prarit Bhargava <prarit@redhat.com>
Reviewed-by: Paul Turner <pjt@google.com>
Reported-by: Aaron Jacobs <jacobsa@google.com>
Signed-off-by: Andrew Hunter <ahh@google.com>
[jstultz: Tweaked to apply to 3.17-rc]
Signed-off-by: John Stultz <john.stultz@linaro.org>
[bwh: Backported to 3.16: adjust filename]
commit 24607f114fd14f2f37e3e0cb3d47bce96e81e848 upstream.
Commit 651e22f2701b "ring-buffer: Always reset iterator to reader page"
fixed one bug but in the process caused another one. The reset is to
update the header page, but that fix also changed the way the cached
reads were updated. The cache reads are used to test if an iterator
needs to be updated or not.
A ring buffer iterator, when created, disables writes to the ring buffer
but does not stop other readers or consuming reads from happening.
Although all readers are synchronized via a lock, they are only
synchronized when in the ring buffer functions. Those functions may
be called by any number of readers. The iterator continues down when
its not interrupted by a consuming reader. If a consuming read
occurs, the iterator starts from the beginning of the buffer.
The way the iterator sees that a consuming read has happened since
its last read is by checking the reader "cache". The cache holds the
last counts of the read and the reader page itself.
Commit 651e22f2701b changed what was saved by the cache_read when
the rb_iter_reset() occurred, making the iterator never match the cache.
Then if the iterator calls rb_iter_reset(), it will go into an
infinite loop by checking if the cache doesn't match, doing the reset
and retrying, just to see that the cache still doesn't match! Which
should never happen as the reset is suppose to set the cache to the
current value and there's locks that keep a consuming reader from
having access to the data.
Fixes: 651e22f2701b "ring-buffer: Always reset iterator to reader page"
commit 6c72e3501d0d62fc064d3680e5234f3463ec5a86 upstream.
Oleg noticed that a cleanup by Sylvain actually uncovered a bug; by
calling perf_event_free_task() when failing sched_fork() we will not yet
have done the memset() on ->perf_event_ctxp[] and will therefore try and
'free' the inherited contexts, which are still in use by the parent
process. This is bad..
Suggested-by: Oleg Nesterov <oleg@redhat.com>
Reported-by: Oleg Nesterov <oleg@redhat.com>
Reported-by: Sylvain 'ythier' Hitier <sylvain.hitier@gmail.com>
commit 0c740d0afc3bff0a097ad03a1c8df92757516f5c upstream.
while_each_thread() and next_thread() should die, almost every lockless
usage is wrong.
1. Unless g == current, the lockless while_each_thread() is not safe.
while_each_thread(g, t) can loop forever if g exits, next_thread()
can't reach the unhashed thread in this case. Note that this can
happen even if g is the group leader, it can exec.
2. Even if while_each_thread() itself was correct, people often use
it wrongly.
It was never safe to just take rcu_read_lock() and loop unless
you verify that pid_alive(g) == T, even the first next_thread()
can point to the already freed/reused memory.
This patch adds signal_struct->thread_head and task->thread_node to
create the normal rcu-safe list with the stable head. The new
for_each_thread(g, t) helper is always safe under rcu_read_lock() as
long as this task_struct can't go away.
Note: of course it is ugly to have both task_struct->thread_node and the
old task_struct->thread_group, we will kill it later, after we change
the users of while_each_thread() to use for_each_thread().
Perhaps we can kill it even before we convert all users, we can
reimplement next_thread(t) using the new thread_head/thread_node. But
we can't do this right now because this will lead to subtle behavioural
changes. For example, do/while_each_thread() always sees at least one
task, while for_each_thread() can do nothing if the whole thread group
has died. Or thread_group_empty(), currently its semantics is not clear
unless thread_group_leader(p) and we need to audit the callers before we
can change it.
So this patch adds the new interface which has to coexist with the old
one for some time, hopefully the next changes will be more or less
straightforward and the old one will go away soon.
Reviewed-by: Sergey Dyasly <dserrg@gmail.com>
Tested-by: Sergey Dyasly <dserrg@gmail.com>
Reviewed-by: Sameer Nanda <snanda@chromium.org>
Acked-by: David Rientjes <rientjes@google.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Mandeep Singh Baines <msb@chromium.org>
Cc: "Ma, Xindong" <xindong.ma@intel.com>
Cc: "Tu, Xiaobing" <xiaobing.tu@intel.com>
Cc: Li Zefan <lizefan@huawei.com>
commit 80628ca06c5d42929de6bc22c0a41589a834d151 upstream.
Cleanup and preparation for the next changes.
Move the "if (clone_flags & CLONE_THREAD)" code down under "if
(likely(p->pid))" and turn it into into the "else" branch. This makes the
process/thread initialization more symmetrical and removes one check.
Cc: Pavel Emelyanov <xemul@parallels.com>
Cc: Sergey Dyasly <dserrg@gmail.com>
commit 43e8317b0bba1d6eb85f38a4a233d82d7c20d732 upstream.
Use the observation that, for platform-dependent sleep states
(PM_SUSPEND_STANDBY, PM_SUSPEND_MEM), a given state is either
always supported or always unsupported and store that information
in pm_states[] instead of calling valid_state() every time we
need to check it.
Also do not use valid_state() for PM_SUSPEND_FREEZE, which is always
valid, and move the pm_test_level validity check for PM_SUSPEND_FREEZE
directly into enter_state().
Cc: Brian Norris <computersforpeace@gmail.com>
commit 27ddcc6596e50cb8f03d2e83248897667811d8f6 upstream.
To allow sleep states corresponding to the "mem", "standby" and
"freeze" lables to be different from the pm_states[] indexes of
those strings, introduce struct pm_sleep_state, consisting of
a string label and a state number, and turn pm_states[] into an
array of objects of that type.
This modification should not lead to any functional changes.
commit 3577af70a2ce4853d58e57d832e687d739281479 upstream.
We saw a kernel soft lockup in perf_remove_from_context(),
it looks like the `perf` process, when exiting, could not go
out of the retry loop. Meanwhile, the target process was forking
a child. So either the target process should execute the smp
function call to deactive the event (if it was running) or it should
do a context switch which deactives the event.
It seems we optimize out a context switch in perf_event_context_sched_out(),
and what's more important, we still test an obsolete task pointer when
retrying, so no one actually would deactive that event in this situation.
Fix it directly by reloading the task pointer in perf_remove_from_context().
This should cure the above soft lockup.
Signed-off-by: Cong Wang <cwang@twopensource.com>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Link: http://lkml.kernel.org/r/1409696840-843-1-git-send-email-xiyou.wangcong@gmail.com
commit 474e941bed9262f5fa2394f9a4a67e24499e5926 upstream.
Locks the k_itimer's it_lock member when handling the alarm timer's
expiry callback.
The regular posix timers defined in posix-timers.c have this lock held
during timout processing because their callbacks are routed through
posix_timer_fn(). The alarm timers follow a different path, so they
ought to grab the lock somewhere else.
Cc: Sharvil Nanavati <sharvil@google.com>
Signed-off-by: Richard Larocque <rlarocque@google.com>
commit 265b81d23a46c39df0a735a3af4238954b41a4c2 upstream.
Avoids sending a signal to alarm timers created with sigev_notify set to
SIGEV_NONE by checking for that special case in the timeout callback.
The regular posix timers avoid sending signals to SIGEV_NONE timers by
not scheduling any callbacks for them in the first place. Although it
would be possible to do something similar for alarm timers, it's simpler
to handle this as a special case in the timeout.
Prior to this patch, the alarm timer would ignore the sigev_notify value
and try to deliver signals to the process anyway. Even worse, the
sanity check for the value of sigev_signo is skipped when SIGEV_NONE was
specified, so the signal number could be bogus. If sigev_signo was an
unitialized value (as it often would be if SIGEV_NONE is used), then
it's hard to predict which signal will be sent.
commit acbbe6fbb240a927ee1f5994f04d31267d422215 upstream.
The C operator <= defines a perfectly fine total ordering on the set of
values representable in a long. However, unlike its namesake in the
integers, it is not translation invariant, meaning that we do not have
"b <= c" iff "a+b <= a+c" for all a,b,c.
This means that it is always wrong to try to boil down the relationship
between two longs to a question about the sign of their difference,
because the resulting relation [a LEQ b iff a-b <= 0] is neither
anti-symmetric or transitive. The former is due to -LONG_MIN==LONG_MIN
(take any two a,b with a-b = LONG_MIN; then a LEQ b and b LEQ a, but a !=
b). The latter can either be seen observing that x LEQ x+1 for all x,
implying x LEQ x+1 LEQ x+2 ... LEQ x-1 LEQ x; or more directly with the
simple example a=LONG_MIN, b=0, c=1, for which a-b < 0, b-c < 0, but a-c >
0.
Note that it makes absolutely no difference that a transmogrying bijection
has been applied before the comparison is done. In fact, had the
obfuscation not been done, one could probably not observe the bug
(assuming all values being compared always lie in one half of the address
space, the mathematical value of a-b is always representable in a long).
As it stands, one can easily obtain three file descriptors exhibiting the
non-transitivity of kcmp().
Side note 1: I can't see that ensuring the MSB of the multiplier is
set serves any purpose other than obfuscating the obfuscating code.
Side note 2:
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <fcntl.h>
#include <unistd.h>
#include <assert.h>
#include <sys/syscall.h>
enum kcmp_type {
KCMP_FILE,
KCMP_VM,
KCMP_FILES,
KCMP_FS,
KCMP_SIGHAND,
KCMP_IO,
KCMP_SYSVSEM,
KCMP_TYPES,
pid_t pid;
int kcmp(pid_t pid1, pid_t pid2, int type,
unsigned long idx1, unsigned long idx2)
return syscall(SYS_kcmp, pid1, pid2, type, idx1, idx2);
int cmp_fd(int fd1, int fd2)
int c = kcmp(pid, pid, KCMP_FILE, fd1, fd2);
if (c < 0) {
perror("kcmp");
exit(1);
assert(0 <= c && c < 3);
return c;
int cmp_fdp(const void *a, const void *b)
static const int normalize[] = {0, -1, 1};
return normalize[cmp_fd(*(int*)a, *(int*)b)];
#define MAX 100 /* This is plenty; I've seen it trigger for MAX==3 */
int main(int argc, char *argv[])
int r, s, count = 0;
int REL[3] = {0,0,0};
int fd[MAX];
pid = getpid();
while (count < MAX) {
r = open("/dev/null", O_RDONLY);
if (r < 0)
break;
fd[count++] = r;
printf("opened %d file descriptors\n", count);
for (r = 0; r < count; ++r) {
for (s = r+1; s < count; ++s) {
REL[cmp_fd(fd[r], fd[s])]++;
printf("== %d\t< %d\t> %d\n", REL[0], REL[1], REL[2]);
qsort(fd, count, sizeof(fd[0]), cmp_fdp);
memset(REL, 0, sizeof(REL));
return (REL[0] + REL[2] != 0);
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Reviewed-by: Cyrill Gorcunov <gorcunov@openvz.org>
commit 4ce97dbf50245227add17c83d87dc838e7ca79d0 upstream.
Epoll on trace_pipe can sometimes hang in a weird case. If the ring buffer is
empty when we set waiters_pending but an event shows up exactly at that moment
we can miss being woken up by the ring buffers irq work. Since
ring_buffer_empty() is inherently racey we will sometimes think that the buffer
is not empty. So we don't get woken up and we don't think there are any events
even though there were some ready when we added the watch, which makes us hang.
This patch fixes this by making sure that we are actually on the wait list
before we set waiters_pending, and add a memory barrier to make sure
ring_buffer_empty() is going to be correct.
Link: http://lkml.kernel.org/p/1408989581-23727-1-git-send-email-jbacik@fb.com
Cc: Martin Lau <kafai@fb.com>
Signed-off-by: Josef Bacik <jbacik@fb.com>
commit 021de3d904b88b1771a3a2cfc5b75023c391e646 upstream.
After writting a test to try to trigger the bug that caused the
ring buffer iterator to become corrupted, I hit another bug:
WARNING: CPU: 1 PID: 5281 at kernel/trace/ring_buffer.c:3766 rb_iter_peek+0x113/0x238()
Modules linked in: ipt_MASQUERADE sunrpc [...]
CPU: 1 PID: 5281 Comm: grep Tainted: G W 3.16.0-rc3-test+ #143
Hardware name: To Be Filled By O.E.M. To Be Filled By O.E.M./To be filled by O.E.M., BIOS SDBLI944.86P 05/08/2007
0000000000000000 ffffffff81809a80 ffffffff81503fb0 0000000000000000
ffffffff81040ca1 ffff8800796d6010 ffffffff810c138d ffff8800796d6010
ffff880077438c80 ffff8800796d6010 ffff88007abbe600 0000000000000003
Call Trace:
[<ffffffff81503fb0>] ? dump_stack+0x4a/0x75
[<ffffffff81040ca1>] ? warn_slowpath_common+0x7e/0x97
[<ffffffff810c138d>] ? rb_iter_peek+0x113/0x238
[<ffffffff810c14df>] ? ring_buffer_iter_peek+0x2d/0x5c
[<ffffffff810c6f73>] ? tracing_iter_reset+0x6e/0x96
[<ffffffff810c74a3>] ? s_start+0xd7/0x17b
[<ffffffff8112b13e>] ? kmem_cache_alloc_trace+0xda/0xea
[<ffffffff8114cf94>] ? seq_read+0x148/0x361
[<ffffffff81132d98>] ? vfs_read+0x93/0xf1
[<ffffffff81132f1b>] ? SyS_read+0x60/0x8e
[<ffffffff8150bf9f>] ? tracesys+0xdd/0xe2
Debugging this bug, which triggers when the rb_iter_peek() loops too
many times (more than 2 times), I discovered there's a case that can
cause that function to legitimately loop 3 times!
rb_iter_peek() is different than rb_buffer_peek() as the rb_buffer_peek()
only deals with the reader page (it's for consuming reads). The
rb_iter_peek() is for traversing the buffer without consuming it, and as
such, it can loop for one more reason. That is, if we hit the end of
the reader page or any page, it will go to the next page and try again.
That is, we have this:
1. iter->head > iter->head_page->page->commit
(rb_inc_iter() which moves the iter to the next page)
try again
2. event = rb_iter_head_event()
event->type_len == RINGBUF_TYPE_TIME_EXTEND
rb_advance_iter()
try again
3. read the event.
But we never get to 3, because the count is greater than 2 and we
cause the WARNING and return NULL.
Up the counter to 3.
Fixes: 69d1b839f7ee "ring-buffer: Bind time extend and data events together"
commit 651e22f2701b4113989237c3048d17337dd2185c upstream.
When performing a consuming read, the ring buffer swaps out a
page from the ring buffer with a empty page and this page that
was swapped out becomes the new reader page. The reader page
is owned by the reader and since it was swapped out of the ring
buffer, writers do not have access to it (there's an exception
to that rule, but it's out of scope for this commit).
When reading the "trace" file, it is a non consuming read, which
means that the data in the ring buffer will not be modified.
When the trace file is opened, a ring buffer iterator is allocated
and writes to the ring buffer are disabled, such that the iterator
will not have issues iterating over the data.
Although the ring buffer disabled writes, it does not disable other
reads, or even consuming reads. If a consuming read happens, then
the iterator is reset and starts reading from the beginning again.
My tests would sometimes trigger this bug on my i386 box:
WARNING: CPU: 0 PID: 5175 at kernel/trace/trace.c:1527 __trace_find_cmdline+0x66/0xaa()
Modules linked in:
CPU: 0 PID: 5175 Comm: grep Not tainted 3.16.0-rc3-test+ #8
Hardware name: /DG965MQ, BIOS MQ96510J.86A.0372.2006.0605.1717 06/05/2006
00000000 00000000 f09c9e1c c18796b3 c1b5d74c f09c9e4c c103a0e3 c1b5154b
f09c9e78 00001437 c1b5d74c 000005f7 c10bd85a c10bd85a c1cac57c f09c9eb0
ed0e0000 f09c9e64 c103a185 00000009 f09c9e5c c1b5154b f09c9e78 f09c9e80^M
Call Trace:
[<c18796b3>] dump_stack+0x4b/0x75
[<c103a0e3>] warn_slowpath_common+0x7e/0x95
[<c10bd85a>] ? __trace_find_cmdline+0x66/0xaa
[<c103a185>] warn_slowpath_fmt+0x33/0x35
[<c10bd85a>] __trace_find_cmdline+0x66/0xaa^M
[<c10bed04>] trace_find_cmdline+0x40/0x64
[<c10c3c16>] trace_print_context+0x27/0xec
[<c10c4360>] ? trace_seq_printf+0x37/0x5b
[<c10c0b15>] print_trace_line+0x319/0x39b
[<c10ba3fb>] ? ring_buffer_read+0x47/0x50
[<c10c13b1>] s_show+0x192/0x1ab
[<c10bfd9a>] ? s_next+0x5a/0x7c
[<c112e76e>] seq_read+0x267/0x34c
[<c1115a25>] vfs_read+0x8c/0xef
[<c112e507>] ? seq_lseek+0x154/0x154
[<c1115ba2>] SyS_read+0x54/0x7f
[<c188488e>] syscall_call+0x7/0xb
---[ end trace 3f507febd6b4cc83 ]---
>>>> ##### CPU 1 buffer started ####
Which was the __trace_find_cmdline() function complaining about the pid
in the event record being negative.
After adding more test cases, this would trigger more often. Strangely
enough, it would never trigger on a single test, but instead would trigger
only when running all the tests. I believe that was the case because it
required one of the tests to be shutting down via delayed instances while
a new test started up.
After spending several days debugging this, I found that it was caused by
the iterator becoming corrupted. Debugging further, I found out why
the iterator became corrupted. It happened with the rb_iter_reset().
As consuming reads may not read the full reader page, and only part
of it, there's a "read" field to know where the last read took place.
The iterator, must also start at the read position. In the rb_iter_reset()
code, if the reader page was disconnected from the ring buffer, the iterator
would start at the head page within the ring buffer (where writes still
happen). But the mistake there was that it still used the "read" field
to start the iterator on the head page, where it should always start
at zero because readers never read from within the ring buffer where
writes occur.
I originally wrote a patch to have it set the iter->head to 0 instead
of iter->head_page->read, but then I questioned why it wasn't always
setting the iter to point to the reader page, as the reader page is
still valid. The list_empty(reader_page->list) just means that it was
successful in swapping out. But the reader_page may still have data.
There was a bug report a long time ago that was not reproducible that
had something about trace_pipe (consuming read) not matching trace
(iterator read). This may explain why that happened.
Anyway, the correct answer to this bug is to always use the reader page
an not reset the iterator to inside the writable ring buffer.
Fixes: d769041f8653 "ring_buffer: implement new locking"
commit 618fde872163e782183ce574c77f1123e2be8887 upstream.
The rarely-executed memry-allocation-failed callback path generates a
WARN_ON_ONCE() when smp_call_function_single() succeeds. Presumably
it's supposed to warn on failures.
Cc: Christoph Lameter <cl@gentwo.org>
Cc: Gilad Ben-Yossef <gilad@benyossef.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Tejun Heo <htejun@gmail.com>
commit 7d8b6c63751cfbbe5eef81a48c22978b3407a3ad upstream.
This is effectively a revert of 7b9a7ec565505699f503b4fcf61500dceb36e744
plus fixing it a different way...
We found, when trying to run an application from an application which
had dropped privs that the kernel does security checks on undefined
capability bits. This was ESPECIALLY difficult to debug as those
undefined bits are hidden from /proc/$PID/status.
Consider a root application which drops all capabilities from ALL 4
capability sets. We assume, since the application is going to set
eff/perm/inh from an array that it will clear not only the defined caps
less than CAP_LAST_CAP, but also the higher 28ish bits which are
undefined future capabilities.
The BSET gets cleared differently. Instead it is cleared one bit at a
time. The problem here is that in security/commoncap.c::cap_task_prctl()
we actually check the validity of a capability being read. So any task
which attempts to 'read all things set in bset' followed by 'unset all
things set in bset' will not even attempt to unset the undefined bits
higher than CAP_LAST_CAP.
So the 'parent' will look something like:
CapInh: 0000000000000000
CapPrm: 0000000000000000
CapEff: 0000000000000000
CapBnd: ffffffc000000000
All of this 'should' be fine. Given that these are undefined bits that
aren't supposed to have anything to do with permissions. But they do...
So lets now consider a task which cleared the eff/perm/inh completely
and cleared all of the valid caps in the bset (but not the invalid caps
it couldn't read out of the kernel). We know that this is exactly what
the libcap-ng library does and what the go capabilities library does.
They both leave you in that above situation if you try to clear all of
you capapabilities from all 4 sets. If that root task calls execve()
the child task will pick up all caps not blocked by the bset. The bset
however does not block bits higher than CAP_LAST_CAP. So now the child
task has bits in eff which are not in the parent. These are
'meaningless' undefined bits, but still bits which the parent doesn't
have.
The problem is now in cred_cap_issubset() (or any operation which does a
subset test) as the child, while a subset for valid cap bits, is not a
subset for invalid cap bits! So now we set durring commit creds that
the child is not dumpable. Given it is 'more priv' than its parent. It
also means the parent cannot ptrace the child and other stupidity.
The solution here:
1) stop hiding capability bits in status
This makes debugging easier!
2) stop giving any task undefined capability bits. it's simple, it you
don't put those invalid bits in CAP_FULL_SET you won't get them in init
and you won't get them in any other task either.
This fixes the cap_issubset() tests and resulting fallout (which
made the init task in a docker container untraceable among other
things)
3) mask out undefined bits when sys_capset() is called as it might use
~0, ~0 to denote 'all capabilities' for backward/forward compatibility.
This lets 'capsh --caps="all=eip" -- -c /bin/bash' run.
4) mask out undefined bit when we read a file capability off of disk as
again likely all bits are set in the xattr for forward/backward
compatibility.
This lets 'setcap all+pe /bin/bash; /bin/bash' run
Signed-off-by: Eric Paris <eparis@redhat.com>
Cc: Andrew Vagin <avagin@openvz.org>
Cc: Andrew G. Morgan <morgan@kernel.org>
Cc: Serge E. Hallyn <serge.hallyn@canonical.com>
Cc: Steve Grubb <sgrubb@redhat.com>
Cc: Dan Walsh <dwalsh@redhat.com>
Signed-off-by: James Morris <james.l.morris@oracle.com>
commit 504d58745c9ca28d33572e2d8a9990b43e06075d upstream.
clockevents_increase_min_delta() calls printk() from under
hrtimer_bases.lock. That causes lock inversion on scheduler locks because
printk() can call into the scheduler. Lockdep puts it as:
[ INFO: possible circular locking dependency detected ]
3.15.0-rc8-06195-g939f04b #2 Not tainted
trinity-main/74 is trying to acquire lock:
(&port_lock_key){-.....}, at: [<811c60be>] serial8250_console_write+0x8c/0x10c
but task is already holding lock:
(hrtimer_bases.lock){-.-...}, at: [<8103caeb>] hrtimer_try_to_cancel+0x13/0x66
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #5 (hrtimer_bases.lock){-.-...}:
[<8104a942>] lock_acquire+0x92/0x101
[<8142f11d>] _raw_spin_lock_irqsave+0x2e/0x3e
[<8103c918>] __hrtimer_start_range_ns+0x1c/0x197
[<8107ec20>] perf_swevent_start_hrtimer.part.41+0x7a/0x85
[<81080792>] task_clock_event_start+0x3a/0x3f
[<810807a4>] task_clock_event_add+0xd/0x14
[<8108259a>] event_sched_in+0xb6/0x17a
[<810826a2>] group_sched_in+0x44/0x122
[<81082885>] ctx_sched_in.isra.67+0x105/0x11f
[<810828e6>] perf_event_sched_in.isra.70+0x47/0x4b
[<81082bf6>] __perf_install_in_context+0x8b/0xa3
[<8107eb8e>] remote_function+0x12/0x2a
[<8105f5af>] smp_call_function_single+0x2d/0x53
[<8107e17d>] task_function_call+0x30/0x36
[<8107fb82>] perf_install_in_context+0x87/0xbb
[<810852c9>] SYSC_perf_event_open+0x5c6/0x701
[<810856f9>] SyS_perf_event_open+0x17/0x19
[<8142f8ee>] syscall_call+0x7/0xb
-> #4 (&ctx->lock){......}:
[<8142f04c>] _raw_spin_lock+0x21/0x30
[<81081df3>] __perf_event_task_sched_out+0x1dc/0x34f
[<8142cacc>] __schedule+0x4c6/0x4cb
[<8142cae0>] schedule+0xf/0x11
[<8142f9a6>] work_resched+0x5/0x30
-> #3 (&rq->lock){-.-.-.}:
[<81040873>] __task_rq_lock+0x33/0x3a
[<8104184c>] wake_up_new_task+0x25/0xc2
[<8102474b>] do_fork+0x15c/0x2a0
[<810248a9>] kernel_thread+0x1a/0x1f
[<814232a2>] rest_init+0x1a/0x10e
[<817af949>] start_kernel+0x303/0x308
[<817af2ab>] i386_start_kernel+0x79/0x7d
-> #2 (&p->pi_lock){-.-...}:
[<810413dd>] try_to_wake_up+0x1d/0xd6
[<810414cd>] default_wake_function+0xb/0xd
[<810461f3>] __wake_up_common+0x39/0x59
[<81046346>] __wake_up+0x29/0x3b
[<811b8733>] tty_wakeup+0x49/0x51
[<811c3568>] uart_write_wakeup+0x17/0x19
[<811c5dc1>] serial8250_tx_chars+0xbc/0xfb
[<811c5f28>] serial8250_handle_irq+0x54/0x6a
[<811c5f57>] serial8250_default_handle_irq+0x19/0x1c
[<811c56d8>] serial8250_interrupt+0x38/0x9e
[<810510e7>] handle_irq_event_percpu+0x5f/0x1e2
[<81051296>] handle_irq_event+0x2c/0x43
[<81052cee>] handle_level_irq+0x57/0x80
[<81002a72>] handle_irq+0x46/0x5c
[<810027df>] do_IRQ+0x32/0x89
[<8143036e>] common_interrupt+0x2e/0x33
[<8142f23c>] _raw_spin_unlock_irqrestore+0x3f/0x49
[<811c25a4>] uart_start+0x2d/0x32
[<811c2c04>] uart_write+0xc7/0xd6
[<811bc6f6>] n_tty_write+0xb8/0x35e
[<811b9beb>] tty_write+0x163/0x1e4
[<811b9cd9>] redirected_tty_write+0x6d/0x75
[<810b6ed6>] vfs_write+0x75/0xb0
[<810b7265>] SyS_write+0x44/0x77
-> #1 (&tty->write_wait){-.....}:
[<81046332>] __wake_up+0x15/0x3b
-> #0 (&port_lock_key){-.....}:
[<8104a62d>] __lock_acquire+0x9ea/0xc6d
[<8104e402>] call_console_drivers.constprop.31+0x87/0x118
[<8104f5d5>] console_unlock+0x1d7/0x398
[<8104fb70>] vprintk_emit+0x3da/0x3e4
[<81425f76>] printk+0x17/0x19
[<8105bfa0>] clockevents_program_min_delta+0x104/0x116
[<8105c548>] clockevents_program_event+0xe7/0xf3
[<8105cc1c>] tick_program_event+0x1e/0x23
[<8103c43c>] hrtimer_force_reprogram+0x88/0x8f
[<8103c49e>] __remove_hrtimer+0x5b/0x79
[<8103cb21>] hrtimer_try_to_cancel+0x49/0x66
[<8103cb4b>] hrtimer_cancel+0xd/0x18
[<8107f102>] perf_swevent_cancel_hrtimer.part.60+0x2b/0x30
[<81080705>] task_clock_event_stop+0x20/0x64
[<81080756>] task_clock_event_del+0xd/0xf
[<81081350>] event_sched_out+0xab/0x11e
[<810813e0>] group_sched_out+0x1d/0x66
[<81081682>] ctx_sched_out+0xaf/0xbf
[<81081e04>] __perf_event_task_sched_out+0x1ed/0x34f
Chain exists of:
&port_lock_key --> &ctx->lock --> hrtimer_bases.lock
Possible unsafe locking scenario:
CPU0 CPU1
lock(hrtimer_bases.lock);
lock(&ctx->lock);
lock(&port_lock_key);
*** DEADLOCK ***
4 locks held by trinity-main/74:
#0: (&rq->lock){-.-.-.}, at: [<8142c6f3>] __schedule+0xed/0x4cb
#1: (&ctx->lock){......}, at: [<81081df3>] __perf_event_task_sched_out+0x1dc/0x34f
#2: (hrtimer_bases.lock){-.-...}, at: [<8103caeb>] hrtimer_try_to_cancel+0x13/0x66
#3: (console_lock){+.+...}, at: [<8104fb5d>] vprintk_emit+0x3c7/0x3e4
stack backtrace:
CPU: 0 PID: 74 Comm: trinity-main Not tainted 3.15.0-rc8-06195-g939f04b #2
00000000 81c3a310 8b995c14 81426f69 8b995c44 81425a99 8161f671 8161f570
8161f538 8161f559 8161f538 8b995c78 8b142bb0 00000004 8b142fdc 8b142bb0
8b995ca8 8104a62d 8b142fac 000016f2 81c3a310 00000001 00000001 00000003
Call Trace:
[<81426f69>] dump_stack+0x16/0x18
[<81425a99>] print_circular_bug+0x18f/0x19c
[<811c60be>] ? serial8250_console_write+0x8c/0x10c
[<811c6032>] ? wait_for_xmitr+0x76/0x76
[<8104af87>] ? lock_release+0x191/0x223
[<8104416d>] ? __dequeue_entity+0x23/0x27
[<81044505>] ? pick_next_task_fair+0xb1/0x120
[<81047574>] ? trace_hardirqs_off_caller+0xd7/0x108
[<810475b0>] ? trace_hardirqs_off+0xb/0xd
[<81056346>] ? rcu_irq_exit+0x64/0x77
Fix the problem by using printk_deferred() which does not call into the
scheduler.
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
commit aac74dc495456412c4130a1167ce4beb6c1f0b38 upstream.
After learning we'll need some sort of deferred printk functionality in
the timekeeping core, Peter suggested we rename the printk_sched function
so it can be reused by needed subsystems.
This only changes the function name. No logic changes.
Reviewed-by: Steven Rostedt <rostedt@goodmis.org>
Cc: Jan Kara <jack@suse.cz>
Cc: Jiri Bohac <jbohac@suse.cz>
commit 58d4e21e50ff3cc57910a8abc20d7e14375d2f61 upstream.
The "uptime" trace clock added in:
commit 8aacf017b065a805d27467843490c976835eb4a5
tracing: Add "uptime" trace clock that uses jiffies
has wraparound problems when the system has been up more
than 1 hour 11 minutes and 34 seconds. It converts jiffies
to nanoseconds using:
(u64)jiffies_to_usecs(jiffy) * 1000ULL
but since jiffies_to_usecs() only returns a 32-bit value, it
truncates at 2^32 microseconds. An additional problem on 32-bit
systems is that the argument is "unsigned long", so fixing the
return value only helps until 2^32 jiffies (49.7 days on a HZ=1000
system).
Avoid these problems by using jiffies_64 as our basis, and
not converting to nanoseconds (we do convert to clock_t because
user facing API must not be dependent on internal kernel
HZ values).
Link: http://lkml.kernel.org/p/99d63c5bfe9b320a3b428d773825a37095bf6a51.1405708254.git.tony.luck@intel.com
Fixes: 8aacf017b065 "tracing: Add "uptime" trace clock that uses jiffies"
Signed-off-by: Tony Luck <tony.luck@intel.com>
commit b0ab99e7736af88b8ac1b7ae50ea287fffa2badc upstream.
proc_sched_show_task() does:
if (nr_switches)
do_div(avg_atom, nr_switches);
nr_switches is unsigned long and do_div truncates it to 32 bits, which
means it can test non-zero on e.g. x86-64 and be truncated to zero for
division.
Fix the problem by using div64_ul() instead.
As a side effect calculations of avg_atom for big nr_switches are now correct.
Signed-off-by: Mateusz Guzik <mguzik@redhat.com>
Link: http://lkml.kernel.org/r/1402750809-31991-1-git-send-email-mguzik@redhat.com
commit 4badad352a6bb202ec68afa7a574c0bb961e5ebc upstream.
The optimistic spin code assumes regular stores and cmpxchg() play nice;
this is found to not be true for at least: parisc, sparc32, tile32,
metag-lock1, arc-!llsc and hexagon.
There is further wreckage, but this in particular seemed easy to
trigger, so blacklist this.
Opt in for known good archs.
Reported-by: Mikulas Patocka <mpatocka@redhat.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Cc: James Bottomley <James.Bottomley@hansenpartnership.com>
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Jason Low <jason.low2@hp.com>
Cc: Waiman Long <waiman.long@hp.com>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Paul McKenney <paulmck@linux.vnet.ibm.com>
Cc: John David Anglin <dave.anglin@bell.net>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: Davidlohr Bueso <davidlohr@hp.com>
Cc: linuxppc-dev@lists.ozlabs.org
Cc: sparclinux@vger.kernel.org
Link: http://lkml.kernel.org/r/20140606175316.GV13930@laptop.programming.kicks-ass.net
commit 4320f6b1d9db4ca912c5eb6ecb328b2e090e1586 upstream.
The commit [247bc037: PM / Sleep: Mitigate race between the freezer
and request_firmware()] introduced the finer state control, but it
also leads to a new bug; for example, a bug report regarding the
firmware loading of intel BT device at suspend/resume:
https://bugzilla.novell.com/show_bug.cgi?id=873790
The root cause seems to be a small window between the process resume
and the clear of usermodehelper lock. The request_firmware() function
checks the UMH lock and gives up when it's in UMH_DISABLE state. This
is for avoiding the invalid f/w loading during suspend/resume phase.
The problem is, however, that usermodehelper_enable() is called at the
end of thaw_processes(). Thus, a thawed process in between can kick
off the f/w loader code path (in this case, via btusb_setup_intel())
even before the call of usermodehelper_enable(). Then
usermodehelper_read_trylock() returns an error and request_firmware()
spews WARN_ON() in the end.
This oneliner patch fixes the issue just by setting to UMH_FREEZING
state again before restarting tasks, so that the call of
request_firmware() will be blocked until the end of this function
instead of returning an error.
Fixes: 247bc0374254 (PM / Sleep: Mitigate race between the freezer and request_firmware())
Link: https://bugzilla.novell.com/show_bug.cgi?id=873790
commit 16927776ae757d0d132bdbfabbfe2c498342bd59 upstream.
Sharvil noticed with the posix timer_settime interface, using the
CLOCK_REALTIME_ALARM or CLOCK_BOOTTIME_ALARM clockid, if the users
tried to specify a relative time timer, it would incorrectly be
treated as absolute regardless of the state of the flags argument.
This patch corrects this, properly checking the absolute/relative flag,
as well as adds further error checking that no invalid flag bits are set.
Reported-by: Sharvil Nanavati <sharvil@google.com>
Link: http://lkml.kernel.org/r/1404767171-6902-1-git-send-email-john.stultz@linaro.org
commit 97b8ee845393701edc06e27ccec2876ff9596019 upstream.
ring_buffer_poll_wait() should always put the poll_table to its wait_queue
even there is immediate data available. Otherwise, the following epoll and
read sequence will eventually hang forever:
1. Put some data to make the trace_pipe ring_buffer read ready first
2. epoll_ctl(efd, EPOLL_CTL_ADD, trace_pipe_fd, ee)
3. epoll_wait()
4. read(trace_pipe_fd) till EAGAIN
5. Add some more data to the trace_pipe ring_buffer
6. epoll_wait() -> this epoll_wait() will block forever
~ During the epoll_ctl(efd, EPOLL_CTL_ADD,...) call in step 2,
ring_buffer_poll_wait() returns immediately without adding poll_table,
which has poll_table->_qproc pointing to ep_poll_callback(), to its
wait_queue.
~ During the epoll_wait() call in step 3 and step 6,
ring_buffer_poll_wait() cannot add ep_poll_callback() to its wait_queue
because the poll_table->_qproc is NULL and it is how epoll works.
~ When there is new data available in step 6, ring_buffer does not know
it has to call ep_poll_callback() because it is not in its wait queue.
Hence, block forever.
Other poll implementation seems to call poll_wait() unconditionally as the very
first thing to do. For example, tcp_poll() in tcp.c.
Link: http://lkml.kernel.org/p/20140610060637.GA14045@devbig242.prn2.facebook.com
Fixes: 2a2cc8f7c4d0 "ftrace: allow the event pipe to be polled"
Reviewed-by: Chris Mason <clm@fb.com>
Signed-off-by: Martin Lau <kafai@fb.com>
commit 8abfb8727f4a724d31f9ccfd8013fbd16d539445 upstream.
Currently trace option stacktrace is not applicable for
trace_printk with constant string argument, the reason is
in __trace_puts/__trace_bputs ftrace_trace_stack is missing.
In contrast, when using trace_printk with non constant string
argument(will call into __trace_printk/__trace_bprintk), then
trace option stacktrace is workable, this inconstant result
will confuses users a lot.
Link: http://lkml.kernel.org/p/51E7A7C9.9040401@huawei.com
Signed-off-by: zhangwei(Jovi) <jovi.zhangwei@huawei.com>
commit 5f8bf2d263a20b986225ae1ed7d6759dc4b93af9 upstream.
Running my ftrace tests on PowerPC, it failed the test that checks
if function_graph tracer is affected by the stack tracer. It was.
Looking into this, I found that the update_function_graph_func()
must be called even if the trampoline function is not changed.
This is because archs like PowerPC do not support ftrace_ops being
passed by assembly and instead uses a helper function (what the
trampoline function points to). Since this function is not changed
even when multiple ftrace_ops are added to the code, the test that
falls out before calling update_function_graph_func() will miss that
the update must still be done.
Call update_function_graph_function() for all calls to
update_ftrace_function()
commit 27e35715df54cbc4f2d044f681802ae30479e7fb upstream.
When the rtmutex fast path is enabled the slow unlock function can
create the following situation:
spin_lock(foo->m->wait_lock);
foo->m->owner = NULL;
rt_mutex_lock(foo->m); <-- fast path
free = atomic_dec_and_test(foo->refcnt);
rt_mutex_unlock(foo->m); <-- fast path
if (free)
kfree(foo);
spin_unlock(foo->m->wait_lock); <--- Use after free.
Plug the race by changing the slow unlock to the following scheme:
while (!rt_mutex_has_waiters(m)) {
/* Clear the waiters bit in m->owner */
clear_rt_mutex_waiters(m);
owner = rt_mutex_owner(m);
spin_unlock(m->wait_lock);
if (cmpxchg(m->owner, owner, 0) == owner)
return;
spin_lock(m->wait_lock);
So in case of a new waiter incoming while the owner tries the slow
path unlock we have two situations:
unlock(wait_lock);
lock(wait_lock);
cmpxchg(p, owner, 0) == owner
mark_rt_mutex_waiters(lock);
acquire(lock);
Or:
unlock(wait_lock);
lock(wait_lock);
cmpxchg(p, owner, 0) != owner
enqueue_waiter();
unlock(wait_lock);
lock(wait_lock);
wakeup_next waiter();
unlock(wait_lock);
lock(wait_lock);
acquire(lock);
If the fast path is disabled, then the simple
m->owner = NULL;
is sufficient as all access to m->owner is serialized via
m->wait_lock;
Also document and clarify the wakeup_next_waiter function as suggested
by Oleg Nesterov.
Reported-by: Steven Rostedt <rostedt@goodmis.org>
Link: http://lkml.kernel.org/r/20140611183852.937945560@linutronix.de
Signed-off-by: Mike Galbraith <umgwanakikbuti@gmail.com>
commit 3d5c9340d1949733eb37616abd15db36aef9a57c upstream.
Even in the case when deadlock detection is not requested by the
caller, we can detect deadlocks. Right now the code stops the lock
chain walk and keeps the waiter enqueued, even on itself. Silly not to
yell when such a scenario is detected and to keep the waiter enqueued.
Return -EDEADLK unconditionally and handle it at the call sites.
The futex calls return -EDEADLK. The non futex ones dequeue the
waiter, throw a warning and put the task into a schedule loop.
Tagged for stable as it makes the code more robust.
Cc: Brad Mouring <bmouring@ni.com>
Link: http://lkml.kernel.org/r/20140605152801.836501969@linutronix.de
commit 82084984383babe728e6e3c9a8e5c46278091315 upstream.
When we walk the lock chain, we drop all locks after each step. So the
lock chain can change under us before we reacquire the locks. That's
harmless in principle as we just follow the wrong lock path. But it
can lead to a false positive in the dead lock detection logic:
T0 holds L0
T0 blocks on L1 held by T1
T1 blocks on L2 held by T2
T2 blocks on L3 held by T3
T4 blocks on L4 held by T4
Now we walk the chain
lock T1 -> lock L2 -> adjust L2 -> unlock T1 ->
lock T2 -> adjust T2 -> drop locks
T2 times out and blocks on L0
Now we continue:
lock T2 -> lock L0 -> deadlock detected, but it's not a deadlock at all.
Brad tried to work around that in the deadlock detection logic itself,
but the more I looked at it the less I liked it, because it's crystal
ball magic after the fact.
We actually can detect a chain change very simple:
lock T1 -> lock L2 -> adjust L2 -> unlock T1 -> lock T2 -> adjust T2 ->
next_lock = T2->pi_blocked_on->lock;
drop locks
Now we continue:
lock T2 ->
if (next_lock != T2->pi_blocked_on->lock)
return;
So if we detect that T2 is now blocked on a different lock we stop the
chain walk. That's also correct in the following scenario:
drop locks
T3 times out and drops L3
T2 acquires L3 and blocks on L4 now
Now we continue:
lock T2 ->
return;
We don't have to follow up the chain at that point, because T2
propagated our priority up to T4 already.
[ Folded a cleanup patch from peterz ]
Reported-by: Brad Mouring <bmouring@ni.com>
Link: http://lkml.kernel.org/r/20140605152801.930031935@linutronix.de
commit 397335f004f41e5fcf7a795e94eb3ab83411a17c upstream.
The current deadlock detection logic does not work reliably due to the
following early exit path:
* Drop out, when the task has no waiters. Note,
* top_waiter can be NULL, when we are in the deboosting
* mode!
if (top_waiter && (!task_has_pi_waiters(task) ||
top_waiter != task_top_pi_waiter(task)))
goto out_unlock_pi;
So this not only exits when the task has no waiters, it also exits
unconditionally when the current waiter is not the top priority waiter
of the task.
So in a nested locking scenario, it might abort the lock chain walk
and therefor miss a potential deadlock.
Simple fix: Continue the chain walk, when deadlock detection is
enabled.
We also avoid the whole enqueue, if we detect the deadlock right away
(A-A). It's an optimization, but also prevents that another waiter who
comes in after the detection and before the task has undone the damage
observes the situation and detects the deadlock and returns
-EDEADLOCK, which is wrong as the other task is not in a deadlock
situation.
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
Link: http://lkml.kernel.org/r/20140522031949.725272460@linutronix.de
commit 8b8b36834d0fff67fc8668093f4312dd04dcf21d upstream.
The per_cpu buffers are created one per possible CPU. But these do
not mean that those CPUs are online, nor do they even exist.
With the addition of the ring buffer polling, it assumes that the
caller polls on an existing buffer. But this is not the case if
the user reads trace_pipe from a CPU that does not exist, and this
causes the kernel to crash.
Simple fix is to check the cpu against buffer bitmask against to see
if the buffer was allocated or not and return -ENODEV if it is
not.
More updates were done to pass the -ENODEV back up to userspace.
Link: http://lkml.kernel.org/r/5393DB61.6060707@oracle.com
Reported-by: Sasha Levin <sasha.levin@oracle.com>
commit 5a6024f1604eef119cf3a6fa413fe0261a81a8f3 upstream.
When hot-adding and onlining CPU, kernel panic occurs, showing following
call trace.
BUG: unable to handle kernel paging request at 0000000000001d08
IP: [<ffffffff8114acfd>] __alloc_pages_nodemask+0x9d/0xb10
PGD 0
Oops: 0000 [#1] SMP
Call Trace:
[<ffffffff812b8745>] ? cpumask_next_and+0x35/0x50
[<ffffffff810a3283>] ? find_busiest_group+0x113/0x8f0
[<ffffffff81193bc9>] ? deactivate_slab+0x349/0x3c0
[<ffffffff811926f1>] new_slab+0x91/0x300
[<ffffffff815de95a>] __slab_alloc+0x2bb/0x482
[<ffffffff8105bc1c>] ? copy_process.part.25+0xfc/0x14c0
[<ffffffff810a3c78>] ? load_balance+0x218/0x890
[<ffffffff8101a679>] ? sched_clock+0x9/0x10
[<ffffffff81105ba9>] ? trace_clock_local+0x9/0x10
[<ffffffff81193d1c>] kmem_cache_alloc_node+0x8c/0x200
[<ffffffff8105bc1c>] copy_process.part.25+0xfc/0x14c0
[<ffffffff81114d0d>] ? trace_buffer_unlock_commit+0x4d/0x60
[<ffffffff81085a80>] ? kthread_create_on_node+0x140/0x140
[<ffffffff8105d0ec>] do_fork+0xbc/0x360
[<ffffffff8105d3b6>] kernel_thread+0x26/0x30
[<ffffffff81086652>] kthreadd+0x2c2/0x300
[<ffffffff81086390>] ? kthread_create_on_cpu+0x60/0x60
[<ffffffff815f20ec>] ret_from_fork+0x7c/0xb0
In my investigation, I found the root cause is wq_numa_possible_cpumask.
All entries of wq_numa_possible_cpumask is allocated by
alloc_cpumask_var_node(). And these entries are used without initializing.
So these entries have wrong value.
When hot-adding and onlining CPU, wq_update_unbound_numa() is called.
wq_update_unbound_numa() calls alloc_unbound_pwq(). And alloc_unbound_pwq()
calls get_unbound_pool(). In get_unbound_pool(), worker_pool->node is set
as follow:
3592 /* if cpumask is contained inside a NUMA node, we belong to that node */
3593 if (wq_numa_enabled) {
3594 for_each_node(node) {
3595 if (cpumask_subset(pool->attrs->cpumask,
3596 wq_numa_possible_cpumask[node])) {
3597 pool->node = node;
3598 break;
3599 }
3600 }
3601 }
But wq_numa_possible_cpumask[node] does not have correct cpumask. So, wrong
node is selected. As a result, kernel panic occurs.
By this patch, all entries of wq_numa_possible_cpumask are allocated by
zalloc_cpumask_var_node to initialize them. And the panic disappeared.
Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Fixes: bce903809ab3 ("workqueue: add wq_numa_tbl_len and wq_numa_possible_cpumask[]")
commit 391acf970d21219a2a5446282d3b20eace0c0d7a upstream.
When runing with the kernel(3.15-rc7+), the follow bug occurs:
[ 9969.258987] BUG: sleeping function called from invalid context at kernel/locking/mutex.c:586
[ 9969.359906] in_atomic(): 1, irqs_disabled(): 0, pid: 160655, name: python
[ 9969.441175] INFO: lockdep is turned off.
[ 9969.488184] CPU: 26 PID: 160655 Comm: python Tainted: G A 3.15.0-rc7+ #85
[ 9969.581032] Hardware name: FUJITSU-SV PRIMEQUEST 1800E/SB, BIOS PRIMEQUEST 1000 Series BIOS Version 1.39 11/16/2012
[ 9969.706052] ffffffff81a20e60 ffff8803e941fbd0 ffffffff8162f523 ffff8803e941fd18
[ 9969.795323] ffff8803e941fbe0 ffffffff8109995a ffff8803e941fc58 ffffffff81633e6c
[ 9969.884710] ffffffff811ba5dc ffff880405c6b480 ffff88041fdd90a0 0000000000002000
[ 9969.974071] Call Trace:
[ 9970.003403] [<ffffffff8162f523>] dump_stack+0x4d/0x66
[ 9970.065074] [<ffffffff8109995a>] __might_sleep+0xfa/0x130
[ 9970.130743] [<ffffffff81633e6c>] mutex_lock_nested+0x3c/0x4f0
[ 9970.200638] [<ffffffff811ba5dc>] ? kmem_cache_alloc+0x1bc/0x210
[ 9970.272610] [<ffffffff81105807>] cpuset_mems_allowed+0x27/0x140
[ 9970.344584] [<ffffffff811b1303>] ? __mpol_dup+0x63/0x150
[ 9970.409282] [<ffffffff811b1385>] __mpol_dup+0xe5/0x150
[ 9970.471897] [<ffffffff811b1303>] ? __mpol_dup+0x63/0x150
[ 9970.536585] [<ffffffff81068c86>] ? copy_process.part.23+0x606/0x1d40
[ 9970.613763] [<ffffffff810bf28d>] ? trace_hardirqs_on+0xd/0x10
[ 9970.683660] [<ffffffff810ddddf>] ? monotonic_to_bootbased+0x2f/0x50
[ 9970.759795] [<ffffffff81068cf0>] copy_process.part.23+0x670/0x1d40
[ 9970.834885] [<ffffffff8106a598>] do_fork+0xd8/0x380
[ 9970.894375] [<ffffffff81110e4c>] ? __audit_syscall_entry+0x9c/0xf0
[ 9970.969470] [<ffffffff8106a8c6>] SyS_clone+0x16/0x20
[ 9971.030011] [<ffffffff81642009>] stub_clone+0x69/0x90
[ 9971.091573] [<ffffffff81641c29>] ? system_call_fastpath+0x16/0x1b
The cause is that cpuset_mems_allowed() try to take
mutex_lock(&callback_mutex) under the rcu_read_lock(which was hold in
__mpol_dup()). And in cpuset_mems_allowed(), the access to cpuset is
under rcu_read_lock, so in __mpol_dup, we can reduce the rcu_read_lock
protection region to protect the access to cpuset only in
current_cpuset_is_being_rebound(). So that we can avoid this bug.
This patch is a temporary solution that just addresses the bug
mentioned above, can not fix the long-standing issue about cpuset.mems
rebinding on fork():
"When the forker's task_struct is duplicated (which includes
->mems_allowed) and it races with an update to cpuset_being_rebound
in update_tasks_nodemask() then the task's mems_allowed doesn't get
updated. And the child task's mems_allowed can be wrong if the
cpuset's nodemask changes before the child has been added to the
cgroup's tasklist."
Signed-off-by: Gu Zheng <guz.fnst@cn.fujitsu.com>
Acked-by: Li Zefan <lizefan@huawei.com>
commit bddbceb688c6d0decaabc7884fede319d02f96c8 upstream.
Uevents are suppressed during attributes registration, but never
restored, so kobject_uevent() does nothing.
Signed-off-by: Maxime Bizon <mbizon@freebox.fr>
Fixes: 226223ab3c4118ddd10688cc2c131135848371ab
commit 099ed151675cd1d2dbeae1dac697975f6a68716d upstream.
Disabling reading and writing to the trace file should not be able to
disable all function tracing callbacks. There's other users today
(like kprobes and perf). Reading a trace file should not stop those
from happening.
Reviewed-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
commit 4af4206be2bd1933cae20c2b6fb2058dbc887f7c upstream.
syscall_regfunc() and syscall_unregfunc() should set/clear
TIF_SYSCALL_TRACEPOINT system-wide, but do_each_thread() can race
with copy_process() and miss the new child which was not added to
the process/thread lists yet.
Change copy_process() to update the child's TIF_SYSCALL_TRACEPOINT
under tasklist.
Link: http://lkml.kernel.org/p/20140413185854.GB20668@redhat.com
Fixes: a871bd33a6c0 "tracing: Add syscall tracepoints"
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
commit 379cfdac37923653c9d4242d10052378b7563005 upstream.
In order to prevent the saved cmdline cache from being filled when
tracing is not active, the comms are only recorded after a trace event
is recorded.
The problem is, a comm can fail to be recorded if the trace_cmdline_lock
is held. That lock is taken via a trylock to allow it to happen from
any context (including NMI). If the lock fails to be taken, the comm
is skipped. No big deal, as we will try again later.
But! Because of the code that was added to only record after an event,
we may not try again later as the recording is made as a oneshot per
event per CPU.
Only disable the recording of the comm if the comm is actually recorded.
Fixes: 7ffbd48d5cab "tracing: Cache comms only after an event occurred"
commit 1e77d0a1ed7417d2a5a52a7b8d32aea1833faa6c upstream.
Till reported that the spurious interrupt detection of threaded
interrupts is broken in two ways:
- note_interrupt() is called for each action thread of a shared
interrupt line. That's wrong as we are only interested whether none
of the device drivers felt responsible for the interrupt, but by
calling multiple times for a single interrupt line we account
IRQ_NONE even if one of the drivers felt responsible.
- note_interrupt() when called from the thread handler is not
serialized. That leaves the members of irq_desc which are used for
the spurious detection unprotected.
To solve this we need to defer the spurious detection of a threaded
interrupt to the next hardware interrupt context where we have
implicit serialization.
If note_interrupt is called with action_ret == IRQ_WAKE_THREAD, we
check whether the previous interrupt requested a deferred check. If
not, we request a deferred check for the next hardware interrupt and
return.
If set, we check whether one of the interrupt threads signaled
success. Depending on this information we feed the result into the
spurious detector.
If one primary handler of a shared interrupt returns IRQ_HANDLED we
disable the deferred check of irq threads on the same line, as we have
found at least one device driver who cared.
Reported-by: Till Straumann <strauman@slac.stanford.edu>
Tested-by: Austin Schuh <austin@peloton-tech.com>
Cc: Oliver Hartkopp <socketcan@hartkopp.net>
Cc: Wolfgang Grandegger <wg@grandegger.com>
Cc: Pavel Pisa <pisa@cmp.felk.cvut.cz>
Cc: Marc Kleine-Budde <mkl@pengutronix.de>
Cc: linux-can@vger.kernel.org
Link: http://lkml.kernel.org/r/alpine.LFD.2.02.1303071450130.22263@ionos
commit 4e52365f279564cef0ddd41db5237f0471381093 upstream.
When tracing a process in another pid namespace, it's important for fork
event messages to contain the child's pid as seen from the tracer's pid
namespace, not the parent's. Otherwise, the tracer won't be able to
correlate the fork event with later SIGTRAP signals it receives from the
child.
We still risk a race condition if a ptracer from a different pid
namespace attaches after we compute the pid_t value. However, sending a
bogus fork event message in this unlikely scenario is still a vast
improvement over the status quo where we always send bogus fork event
messages to debuggers in a different pid namespace than the forking
process.
Signed-off-by: Matthew Dempsky <mdempsky@chromium.org>
Acked-by: Oleg Nesterov <oleg@redhat.com>
Cc: Julien Tinnes <jln@chromium.org>
Cc: Roland McGrath <mcgrathr@chromium.org>
Cc: Jan Kratochvil <jan.kratochvil@redhat.com>
commit 0e576acbc1d9600cf2d9b4a141a2554639959d50 upstream.
If CONFIG_NO_HZ=n tick_nohz_get_sleep_length() returns NSEC_PER_SEC/HZ.
If CONFIG_NO_HZ=y and the nohz functionality is disabled via the
command line option "nohz=off" or not enabled due to missing hardware
support, then tick_nohz_get_sleep_length() returns 0. That happens
because ts->sleep_length is never set in that case.
Set it to NSEC_PER_SEC/HZ when the NOHZ mode is inactive.
Reported-by: Michal Hocko <mhocko@suse.cz>
Reported-by: Borislav Petkov <bp@alien8.de>
Cc: Rui Xiang <rui.xiang@huawei.com>
[ Upstream commit 90f62cf30a78721641e08737bda787552428061e ]
It is possible by passing a netlink socket to a more privileged
executable and then to fool that executable into writing to the socket
data that happens to be valid netlink message to do something that
privileged executable did not intend to do.
To keep this from happening replace bare capable and ns_capable calls
with netlink_capable, netlink_net_calls and netlink_ns_capable calls.
Which act the same as the previous calls except they verify that the
opener of the socket had the desired permissions as well.
Reported-by: Andy Lutomirski <luto@amacapital.net>
commit a3c54931199565930d6d84f4c3456f6440aefd41 upstream.
Fixes an easy DoS and possible information disclosure.
This does nothing about the broken state of x32 auditing.
eparis: If the admin has enabled auditd and has specifically loaded
audit rules. This bug has been around since before git. Wow...
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
commit 23adbe12ef7d3d4195e80800ab36b37bee28cd03 upstream.
The kernel has no concept of capabilities with respect to inodes; inodes
exist independently of namespaces. For example, inode_capable(inode,
CAP_LINUX_IMMUTABLE) would be nonsense.
This patch changes inode_capable to check for uid and gid mappings and
renames it to capable_wrt_inode_uidgid, which should make it more
obvious what it does.
Fixes CVE-2014-4014.
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Serge Hallyn <serge.hallyn@ubuntu.com>
commit 723478c8a471403c53cf144999701f6e0c4bbd11 upstream.
/proc/sys/kernel/perf_event_max_sample_rate will accept
negative values as well as 0.
Negative values are unreasonable, and 0 causes a
divide by zero exception in perf_proc_update_handler.
This patch enforces a lower limit of 1.
Signed-off-by: Knut Petersen <Knut_Petersen@t-online.de>
Link: http://lkml.kernel.org/r/5242DB0C.4070005@t-online.de
Cc: Weng Meiling <wengmeiling.weng@huawei.com>
commit e5302920da9ef23f9d19d4e9ac85704cc25bee7a upstream.
This patch fixes a serious bug in:
14c63f17b1fd perf: Drop sample rate when sampling is too slow
There was an misunderstanding on the API of the do_div()
macro. It returns the remainder of the division and this
was not what the function expected leading to disabling the
interrupt latency watchdog.
This patch also remove a duplicate assignment in
perf_sample_event_took().
Signed-off-by: Stephane Eranian <eranian@google.com>
Cc: peterz@infradead.org
Cc: dave.hansen@linux.intel.com
Cc: ak@linux.intel.com
Cc: jolsa@redhat.com
Link: http://lkml.kernel.org/r/20130704223010.GA30625@quad
commit 14c63f17b1fde5a575a28e96547a22b451c71fb5 upstream.
This patch keeps track of how long perf's NMI handler is taking,
and also calculates how many samples perf can take a second. If
the sample length times the expected max number of samples
exceeds a configurable threshold, it drops the sample rate.
This way, we don't have a runaway sampling process eating up the
CPU.
This patch can tend to drop the sample rate down to level where
perf doesn't work very well. *BUT* the alternative is that my
system hangs because it spends all of its time handling NMIs.
I'll take a busted performance tool over an entire system that's
busted and undebuggable any day.
BTW, my suspicion is that there's still an underlying bug here.
Using the HPET instead of the TSC is definitely a contributing
factor, but I suspect there are some other things going on.
But, I can't go dig down on a bug like that with my machine
hanging all the time.
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Cc: paulus@samba.org
Cc: acme@ghostprotocols.net
Cc: Dave Hansen <dave@sr71.net>
[ Prettified it a bit. ]
commit 6acbfb96976fc3350e30d964acb1dbbdf876d55e upstream.
Lai found that:
WARNING: CPU: 1 PID: 13 at arch/x86/kernel/smp.c:124 native_smp_send_reschedule+0x2d/0x4b()
migration_cpu_stop+0x1d/0x22
was caused by set_cpus_allowed_ptr() assuming that cpu_active_mask is
always a sub-set of cpu_online_mask.
This isn't true since 5fbd036b552f ("sched: Cleanup cpu_active madness").
So set active and online at the same time to avoid this particular
problem.
Fixes: 5fbd036b552f ("sched: Cleanup cpu_active madness")
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: Gautham R. Shenoy <ego@linux.vnet.ibm.com>
Cc: Michael wang <wangyun@linux.vnet.ibm.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
Cc: Toshi Kani <toshi.kani@hp.com>
Link: http://lkml.kernel.org/r/53758B12.8060609@cn.fujitsu.com
commit 46ce0fe97a6be7532ce6126bb26ce89fed81528c upstream.
When removing a (sibling) event we do:
raw_spin_lock_irq(&ctx->lock);
perf_group_detach(event);
raw_spin_unlock_irq(&ctx->lock);
<hole>
perf_remove_from_context(event);
Now, assuming the event is a sibling, it will be 'unreachable' for
things like ctx_sched_out() because that iterates the
groups->siblings, and we just unhooked the sibling.
So, if during <hole> we get ctx_sched_out(), it will miss the event
and not call event_sched_out() on it, leaving it programmed on the
PMU.
The subsequent perf_remove_from_context() call will find the ctx is
inactive and only call list_del_event() to remove the event from all
other lists.
Hereafter we can proceed to free the event; while still programmed!
Close this hole by moving perf_group_detach() inside the same
ctx->lock region(s) perf_remove_from_context() has.
The condition on inherited events only in __perf_event_exit_task() is
likely complete crap because non-inherited events are part of groups
too and we're tearing down just the same. But leave that for another
patch.
Most-likely-Fixes: e03a9a55b4e ("perf: Change close() semantics for group events")
Reported-by: Vince Weaver <vincent.weaver@maine.edu>
Tested-by: Vince Weaver <vincent.weaver@maine.edu>
Much-staring-at-traces-by: Vince Weaver <vincent.weaver@maine.edu>
Much-staring-at-traces-by: Thomas Gleixner <tglx@linutronix.de>
Link: http://lkml.kernel.org/r/20140505093124.GN17778@laptop.programming.kicks-ass.net
commit 0819b2e30ccb93edf04876237b6205eef84ec8d2 upstream.
Vince reported that using a large sample_period (one with bit 63 set)
results in wreckage since while the sample_period is fundamentally
unsigned (negative periods don't make sense) the way we implement
things very much rely on signed logic.
So limit sample_period to 63 bits to avoid tripping over this.
Link: http://lkml.kernel.org/n/tip-p25fhunibl4y3qi0zuqmyf4b@git.kernel.org
commit 39af6b1678afa5880dda7e375cf3f9d395087f6d upstream.
The perf cpu offline callback takes down all cpu context
events and releases swhash->swevent_hlist.
This could race with task context software event being just
scheduled on this cpu via perf_swevent_add while cpu hotplug
code already cleaned up event's data.
The race happens in the gap between the cpu notifier code
and the cpu being actually taken down. Note that only cpu
ctx events are terminated in the perf cpu hotplug code.
It's easily reproduced with:
$ perf record -e faults perf bench sched pipe
while putting one of the cpus offline:
# echo 0 > /sys/devices/system/cpu/cpu1/online
Console emits following warning:
WARNING: CPU: 1 PID: 2845 at kernel/events/core.c:5672 perf_swevent_add+0x18d/0x1a0()
Modules linked in:
CPU: 1 PID: 2845 Comm: sched-pipe Tainted: G W 3.14.0+ #256
Hardware name: Intel Corporation Montevina platform/To be filled by O.E.M., BIOS AMVACRB1.86C.0066.B00.0805070703 05/07/2008
0000000000000009 ffff880077233ab8 ffffffff81665a23 0000000000200005
0000000000000000 ffff880077233af8 ffffffff8104732c 0000000000000046
ffff88007467c800 0000000000000002 ffff88007a9cf2a0 0000000000000001
Call Trace:
[<ffffffff81665a23>] dump_stack+0x4f/0x7c
[<ffffffff8104732c>] warn_slowpath_common+0x8c/0xc0
[<ffffffff8104737a>] warn_slowpath_null+0x1a/0x20
[<ffffffff8110fb3d>] perf_swevent_add+0x18d/0x1a0
[<ffffffff811162ae>] event_sched_in.isra.75+0x9e/0x1f0
[<ffffffff8111646a>] group_sched_in+0x6a/0x1f0
[<ffffffff81083dd5>] ? sched_clock_local+0x25/0xa0
[<ffffffff811167e6>] ctx_sched_in+0x1f6/0x450
[<ffffffff8111757b>] perf_event_sched_in+0x6b/0xa0
[<ffffffff81117a4b>] perf_event_context_sched_in+0x7b/0xc0
[<ffffffff81117ece>] __perf_event_task_sched_in+0x43e/0x460
[<ffffffff81096f1e>] ? put_lock_stats.isra.18+0xe/0x30
[<ffffffff8107b3c8>] finish_task_switch+0xb8/0x100
[<ffffffff8166a7de>] __schedule+0x30e/0xad0
[<ffffffff81172dd2>] ? pipe_read+0x3e2/0x560
[<ffffffff8166b45e>] ? preempt_schedule_irq+0x3e/0x70
[<ffffffff8166b464>] preempt_schedule_irq+0x44/0x70
[<ffffffff816707f0>] retint_kernel+0x20/0x30
[<ffffffff8109e60a>] ? lockdep_sys_exit+0x1a/0x90
[<ffffffff812a4234>] lockdep_sys_exit_thunk+0x35/0x67
[<ffffffff81679321>] ? sysret_check+0x5/0x56
Fixing this by tracking the cpu hotplug state and displaying
the WARN only if current cpu is initialized properly.
Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Signed-off-by: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/r/1396861448-10097-1-git-send-email-jolsa@redhat.com
