path: root/kernel
2013-03-31Revert "lockdep: check that no locks held at freeze time"Paul Walmsley
This reverts commit 6aa9707099c4b25700940eb3d016f16c4434360d. Commit 6aa9707099c4 ("lockdep: check that no locks held at freeze time") causes problems with NFS root filesystems. The failures were noticed on OMAP2 and 3 boards during kernel init: [ BUG: swapper/0/1 still has locks held! ] 3.9.0-rc3-00344-ga937536 #1 Not tainted ------------------------------------- 1 lock held by swapper/0/1: #0: (&type->s_umount_key#13/1){+.+.+.}, at: [<c011e84c>] sget+0x248/0x574 stack backtrace: rpc_wait_bit_killable __wait_on_bit out_of_line_wait_on_bit __rpc_execute rpc_run_task rpc_call_sync nfs_proc_get_root nfs_get_root nfs_fs_mount_common nfs_try_mount nfs_fs_mount mount_fs vfs_kern_mount do_mount sys_mount do_mount_root mount_root prepare_namespace kernel_init_freeable kernel_init Although the rootfs mounts, the system is unstable. Here's a transcript from a PM test: http://www.pwsan.com/omap/testlogs/test_v3.9-rc3/20130317194234/pm/37xxevm/37xxevm_log.txt Here's what the test log should look like: http://www.pwsan.com/omap/testlogs/test_v3.8/20130218214403/pm/37xxevm/37xxevm_log.txt Mailing list discussion is here: http://lkml.org/lkml/2013/3/4/221 Deal with this for v3.9 by reverting the problem commit, until folks can figure out the right long-term course of action. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Mandeep Singh Baines <msb@chromium.org> Cc: Jeff Layton <jlayton@redhat.com> Cc: Shawn Guo <shawn.guo@linaro.org> Cc: <maciej.rutecki@gmail.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Ben Chan <benchan@chromium.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Tejun Heo <tj@kernel.org> Cc: Rafael J. Wysocki <rjw@sisk.pl> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull userns fixes from Eric W Biederman: "The bulk of the changes are fixing the worst consequences of the user namespace design oversight in not considering what happens when one namespace starts off as a clone of another namespace, as happens with the mount namespace. The rest of the changes are just plain bug fixes. Many thanks to Andy Lutomirski for pointing out many of these issues." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: userns: Restrict when proc and sysfs can be mounted ipc: Restrict mounting the mqueue filesystem vfs: Carefully propogate mounts across user namespaces vfs: Add a mount flag to lock read only bind mounts userns: Don't allow creation if the user is chrooted yama: Better permission check for ptraceme pid: Handle the exit of a multi-threaded init. scm: Require CAP_SYS_ADMIN over the current pidns to spoof pids.
2013-03-27userns: Restrict when proc and sysfs can be mountedEric W. Biederman
Only allow unprivileged mounts of proc and sysfs if they are already mounted when the user namespace is created. proc and sysfs are interesting because they have content that is per namespace, and so fresh mounts are needed when new namespaces are created while at the same time proc and sysfs have content that is shared between every instance. Respect the policy of who may see the shared content of proc and sysfs by only allowing new mounts if there was an existing mount at the time the user namespace was created. In practice there are only two interesting cases: proc and sysfs are mounted at their usual places, proc and sysfs are not mounted at all (some form of mount namespace jail). Cc: stable@vger.kernel.org Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-03-27userns: Don't allow creation if the user is chrootedEric W. Biederman
Guarantee that the policy of which files may be access that is established by setting the root directory will not be violated by user namespaces by verifying that the root directory points to the root of the mount namespace at the time of user namespace creation. Changing the root is a privileged operation, and as a matter of policy it serves to limit unprivileged processes to files below the current root directory. For reasons of simplicity and comprehensibility the privilege to change the root directory is gated solely on the CAP_SYS_CHROOT capability in the user namespace. Therefore when creating a user namespace we must ensure that the policy of which files may be access can not be violated by changing the root directory. Anyone who runs a processes in a chroot and would like to use user namespace can setup the same view of filesystems with a mount namespace instead. With this result that this is not a practical limitation for using user namespaces. Cc: stable@vger.kernel.org Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Reported-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-03-26pid: Handle the exit of a multi-threaded init.Eric W. Biederman
When a multi-threaded init exits and the initial thread is not the last thread to exit the initial thread hangs around as a zombie until the last thread exits. In that case zap_pid_ns_processes needs to wait until there are only 2 hashed pids in the pid namespace not one. v2. Replace thread_pid_vnr(me) == 1 with the test thread_group_leader(me) as suggested by Oleg. Cc: stable@vger.kernel.org Cc: Oleg Nesterov <oleg@redhat.com> Reported-by: Caj Larsson <caj@omnicloud.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-03-25Merge branch 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer fix from Thomas Gleixner: "A single bugfix which prevents that a non functional timer device is selected to provide the fallback device, which is supposed to serve timer interrupts on behalf of non functional devices ..." * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: clockevents: Don't allow dummy broadcast timers
2013-03-22poweroff: change orderly_poweroff() to use schedule_work()Oleg Nesterov
David said: Commit 6c0c0d4d1080 ("poweroff: fix bug in orderly_poweroff()") apparently fixes one bug in orderly_poweroff(), but introduces another. The comments on orderly_poweroff() claim it can be called from any context - and indeed we call it from interrupt context in arch/powerpc/platforms/pseries/ras.c for example. But since that commit this is no longer safe, since call_usermodehelper_fns() is not safe in interrupt context without the UMH_NO_WAIT option. orderly_poweroff() can be used from any context but UMH_WAIT_EXEC is sleepable. Move the "force" logic into __orderly_poweroff() and change orderly_poweroff() to use the global poweroff_work which simply calls __orderly_poweroff(). While at it, remove the unneeded "int argc" and change argv_split() to use GFP_KERNEL. We use the global "bool poweroff_force" to pass the argument, this can obviously affect the previous request if it is pending/running. So we only allow the "false => true" transition assuming that the pending "true" should succeed anyway. If schedule_work() fails after that we know that work->func() was not called yet, it must see the new value. This means that orderly_poweroff() becomes async even if we do not run the command and always succeeds, schedule_work() can only fail if the work is already pending. We can export __orderly_poweroff() and change the non-atomic callers which want the old semantics. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Reported-by: David Gibson <david@gibson.dropbear.id.au> Cc: Lucas De Marchi <lucas.demarchi@profusion.mobi> Cc: Feng Hong <hongfeng@marvell.com> Cc: Kees Cook <keescook@chromium.org> Cc: Serge Hallyn <serge.hallyn@canonical.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-22printk: Provide a wake_up_klogd() off-caseFrederic Weisbecker
wake_up_klogd() is useless when CONFIG_PRINTK=n because neither printk() nor printk_sched() are in use and there are actually no waiter on log_wait waitqueue. It should be a stub in this case for users like bust_spinlocks(). Otherwise this results in this warning when CONFIG_PRINTK=n and CONFIG_IRQ_WORK=n: kernel/built-in.o In function `wake_up_klogd': (.text.wake_up_klogd+0xb4): undefined reference to `irq_work_queue' To fix this, provide an off-case for wake_up_klogd() when CONFIG_PRINTK=n. There is much more from console_unlock() and other console related code in printk.c that should be moved under CONFIG_PRINTK. But for now, focus on a minimal fix as we passed the merged window already. [akpm@linux-foundation.org: include printk.h in bust_spinlocks.c] Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Reported-by: James Hogan <james.hogan@imgtec.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-21Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "A fair chunk of the linecount comes from a fix for a tracing bug that corrupts latency tracing buffers when the overwrite mode is changed on the fly - the rest is mostly assorted fewliner fixlets." * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf/x86: Add SNB/SNB-EP scheduling constraints for cycle_activity event kprobes/x86: Check Interrupt Flag modifier when registering probe kprobes: Make hash_64() as always inlined perf: Generate EXIT event only once per task context perf: Reset hwc->last_period on sw clock events tracing: Prevent buffer overwrite disabled for latency tracers tracing: Keep overwrite in sync between regular and snapshot buffers tracing: Protect tracer flags with trace_types_lock perf tools: Fix LIBNUMA build with glibc 2.12 and older. tracing: Fix free of probe entry by calling call_rcu_sched() perf/POWER7: Create a sysfs format entry for Power7 events perf probe: Fix segfault libtraceevent: Remove hard coded include to /usr/local/include in Makefile perf record: Fix -C option perf tools: check if -DFORTIFY_SOURCE=2 is allowed perf report: Fix build with NO_NEWT=1 perf annotate: Fix build with NO_NEWT=1 tracing: Fix race in snapshot swapping
2013-03-18Merge branch 'for-3.9-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq Pull workqueue fix from Tejun Heo: "Lai's patch to fix highly unlikely but still possible workqueue stall during CPU hotunplug." * 'for-3.9-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: workqueue: fix possible pool stall bug in wq_unbind_fn()
2013-03-18Merge branch 'tip/perf/urgent-2' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace into perf/urgent Pull tracing fixes from Steven Rostedt. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-03-18perf: Generate EXIT event only once per task contextNamhyung Kim
perf_event_task_event() iterates pmu list and generate events for each eligible pmu context. But if task_event has task_ctx like in EXIT it'll generate events even though the pmu doesn't have an eligible one. Fix it by moving the code to proper places. Before this patch: $ perf record -n true [ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.006 MB perf.data (~248 samples) ] $ perf report -D | tail Aggregated stats: TOTAL events: 73 MMAP events: 67 COMM events: 2 EXIT events: 4 cycles stats: TOTAL events: 73 MMAP events: 67 COMM events: 2 EXIT events: 4 After this patch: $ perf report -D | tail Aggregated stats: TOTAL events: 70 MMAP events: 67 COMM events: 2 EXIT events: 1 cycles stats: TOTAL events: 70 MMAP events: 67 COMM events: 2 EXIT events: 1 Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1363332433-7637-1-git-send-email-namhyung@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-03-18perf: Reset hwc->last_period on sw clock eventsNamhyung Kim
When cpu/task clock events are initialized, their sampling frequencies are converted to have a fixed value. However it missed to update the hwc->last_period which was set to 1 for initial sampling frequency calibration. Because this hwc->last_period value is used as a period in perf_swevent_ hrtime(), every recorded sample will have an incorrected period of 1. $ perf record -e task-clock noploop 1 [ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.158 MB perf.data (~6919 samples) ] $ perf report -n --show-total-period --stdio # Samples: 4K of event 'task-clock' # Event count (approx.): 4000 # # Overhead Samples Period Command Shared Object Symbol # ........ ............ ............ ....... ............. .................. # 99.95% 3998 3998 noploop noploop [.] main 0.03% 1 1 noploop libc-2.15.so [.] init_cacheinfo 0.03% 1 1 noploop ld-2.15.so [.] open_verify Note that it doesn't affect the non-sampling event so that the perf stat still gets correct value with or without this patch. $ perf stat -e task-clock noploop 1 Performance counter stats for 'noploop 1': 1000.272525 task-clock # 1.000 CPUs utilized 1.000560605 seconds time elapsed Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1363574507-18808-1-git-send-email-namhyung@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-03-14tracing: Prevent buffer overwrite disabled for latency tracersSteven Rostedt (Red Hat)
The latency tracers require the buffers to be in overwrite mode, otherwise they get screwed up. Force the buffers to stay in overwrite mode when latency tracers are enabled. Added a flag_changed() method to the tracer structure to allow the tracers to see what flags are being changed, and also be able to prevent the change from happing. Cc: stable@vger.kernel.org Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2013-03-14tracing: Keep overwrite in sync between regular and snapshot buffersSteven Rostedt (Red Hat)
Changing the overwrite mode for the ring buffer via the trace option only sets the normal buffer. But the snapshot buffer could swap with it, and then the snapshot would be in non overwrite mode and the normal buffer would be in overwrite mode, even though the option flag states otherwise. Keep the two buffers overwrite modes in sync. Cc: stable@vger.kernel.org Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2013-03-14tracing: Protect tracer flags with trace_types_lockSteven Rostedt (Red Hat)
Seems that the tracer flags have never been protected from synchronous writes. Luckily, admins don't usually modify the tracing flags via two different tasks. But if scripts were to be used to modify them, then they could get corrupted. Move the trace_types_lock that protects against tracers changing to also protect the flags being set. Cc: stable@vger.kernel.org Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2013-03-14Merge branch 'tip/perf/urgent-2' of ↵Ingo Molnar
2013-03-13Merge branch 'akpm' (fixes from Andrew)Linus Torvalds
Merge misc fixes from Andrew Morton: - A bunch of fixes - Finish off the idr API conversions before someone starts to use the old interfaces again. * emailed patches from Andrew Morton <akpm@linux-foundation.org>: idr: idr_alloc() shouldn't trigger lowmem warning when preloaded UAPI: fix endianness conditionals in M32R's asm/stat.h UAPI: fix endianness conditionals in linux/raid/md_p.h UAPI: fix endianness conditionals in linux/acct.h UAPI: fix endianness conditionals in linux/aio_abi.h decompressors: fix typo "POWERPC" mm/fremap.c: fix oops on error path idr: deprecate idr_pre_get() and idr_get_new[_above]() tidspbridge: convert to idr_alloc() zcache: convert to idr_alloc() mlx4: remove leftover idr_pre_get() call workqueue: convert to idr_alloc() nfsd: convert to idr_alloc() nfsd: remove unused get_new_stid() kernel/signal.c: use __ARCH_HAS_SA_RESTORER instead of SA_RESTORER signal: always clear sa_restorer on execve mm: remove_memory(): fix end_pfn setting include/linux/res_counter.h needs errno.h
2013-03-13workqueue: convert to idr_alloc()Tejun Heo
idr_get_new*() and friends are about to be deprecated. Convert to the new idr_alloc() interface. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-13kernel/signal.c: use __ARCH_HAS_SA_RESTORER instead of SA_RESTORERAndrew Morton
__ARCH_HAS_SA_RESTORER is the preferred conditional for use in 3.9 and later kernels, per Kees. Cc: Emese Revfy <re.emese@gmail.com> Cc: Emese Revfy <re.emese@gmail.com> Cc: PaX Team <pageexec@freemail.hu> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Oleg Nesterov <oleg@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Serge Hallyn <serge.hallyn@canonical.com> Cc: Julien Tinnes <jln@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-13signal: always clear sa_restorer on execveKees Cook
When the new signal handlers are set up, the location of sa_restorer is not cleared, leaking a parent process's address space location to children. This allows for a potential bypass of the parent's ASLR by examining the sa_restorer value returned when calling sigaction(). Based on what should be considered "secret" about addresses, it only matters across the exec not the fork (since the VMAs haven't changed until the exec). But since exec sets SIG_DFL and keeps sa_restorer, this is where it should be fixed. Given the few uses of sa_restorer, a "set" function was not written since this would be the only use. Instead, we use __ARCH_HAS_SA_RESTORER, as already done in other places. Example of the leak before applying this patch: $ cat /proc/$$/maps ... 7fb9f3083000-7fb9f3238000 r-xp 00000000 fd:01 404469 .../libc-2.15.so ... $ ./leak ... 7f278bc74000-7f278be29000 r-xp 00000000 fd:01 404469 .../libc-2.15.so ... 1 0 (nil) 0x7fb9f30b94a0 2 4000000 (nil) 0x7f278bcaa4a0 3 4000000 (nil) 0x7f278bcaa4a0 4 0 (nil) 0x7fb9f30b94a0 ... [akpm@linux-foundation.org: use SA_RESTORER for backportability] Signed-off-by: Kees Cook <keescook@chromium.org> Reported-by: Emese Revfy <re.emese@gmail.com> Cc: Emese Revfy <re.emese@gmail.com> Cc: PaX Team <pageexec@freemail.hu> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Oleg Nesterov <oleg@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Serge Hallyn <serge.hallyn@canonical.com> Cc: Julien Tinnes <jln@google.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-13userns: Don't allow CLONE_NEWUSER | CLONE_FSEric W. Biederman
Don't allowing sharing the root directory with processes in a different user namespace. There doesn't seem to be any point, and to allow it would require the overhead of putting a user namespace reference in fs_struct (for permission checks) and incrementing that reference count on practically every call to fork. So just perform the inexpensive test of forbidding sharing fs_struct acrosss processes in different user namespaces. We already disallow other forms of threading when unsharing a user namespace so this should be no real burden in practice. This updates setns, clone, and unshare to disallow multiple user namespaces sharing an fs_struct. Cc: stable@vger.kernel.org Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-13tracing: Fix free of probe entry by calling call_rcu_sched()Steven Rostedt (Red Hat)
Because function tracing is very invasive, and can even trace calls to rcu_read_lock(), RCU access in function tracing is done with preempt_disable_notrace(). This requires a synchronize_sched() for updates and not a synchronize_rcu(). Function probes (traceon, traceoff, etc) must be freed after a synchronize_sched() after its entry has been removed from the hash. But call_rcu() is used. Fix this by using call_rcu_sched(). Also fix the usage to use hlist_del_rcu() instead of hlist_del(). Cc: stable@vger.kernel.org Cc: Paul McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2013-03-12futex: fix kernel-doc notation and spelloRandy Dunlap
Fix kernel-doc warning in futex.c and convert 'Returns' to the new Return: kernel-doc notation format. Warning(kernel/futex.c:2286): Excess function parameter 'clockrt' description in 'futex_wait_requeue_pi' Fix one spello. Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-12signals: fix new kernel-doc warningsRandy Dunlap
Fix new kernel-doc warnings in kernel/signal.c: Warning(kernel/signal.c:2689): No description found for parameter 'uset' Warning(kernel/signal.c:2689): Excess function parameter 'set' description in 'sys_rt_sigpending' Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-12tracing: Fix race in snapshot swappingSteven Rostedt (Red Hat)
Although the swap is wrapped with a spin_lock, the assignment of the temp buffer used to swap is not within that lock. It needs to be moved into that lock, otherwise two swaps happening on two different CPUs, can end up using the wrong temp buffer to assign in the swap. Luckily, all current callers of the swap function appear to have their own locks. But in case something is added that allows two different callers to call the swap, then there's a chance that this race can trigger and corrupt the buffers. New code is coming soon that will allow for this race to trigger. I've Cc'd stable, so this bug will not show up if someone backports one of the changes that can trigger this bug. Cc: stable@vger.kernel.org Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2013-03-11Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Misc minor fixes mostly related to tracing" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: s390: Fix a header dependencies related build error tracing: update documentation of snapshot utility tracing: Do not return EINVAL in snapshot when not allocated tracing: Add help of snapshot feature when snapshot is empty ftrace: Update the kconfig for DYNAMIC_FTRACE
2013-03-08workqueue: fix possible pool stall bug in wq_unbind_fn()Lai Jiangshan
Since multiple pools per cpu have been introduced, wq_unbind_fn() has a subtle bug which may theoretically stall work item processing. The problem is two-fold. * wq_unbind_fn() depends on the worker executing wq_unbind_fn() itself to start unbound chain execution, which works fine when there was only single pool. With multiple pools, only the pool which is running wq_unbind_fn() - the highpri one - is guaranteed to have such kick-off. The other pool could stall when its busy workers block. * The current code is setting WORKER_UNBIND / POOL_DISASSOCIATED of the two pools in succession without initiating work execution inbetween. Because setting the flags requires grabbing assoc_mutex which is held while new workers are created, this could lead to stalls if a pool's manager is waiting for the previous pool's work items to release memory. This is almost purely theoretical tho. Update wq_unbind_fn() such that it sets WORKER_UNBIND / POOL_DISASSOCIATED, goes over schedule() and explicitly kicks off execution for a pool and then moves on to the next one. tj: Updated comments and description. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: stable@vger.kernel.org
2013-03-08Revert parts of "hlist: drop the node parameter from iterators"Arnd Bergmann
Commit b67bfe0d42ca ("hlist: drop the node parameter from iterators") did a lot of nice changes but also contains two small hunks that seem to have slipped in accidentally and have no apparent connection to the intent of the patch. This reverts the two extraneous changes. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Peter Senna Tschudin <peter.senna@gmail.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-07clockevents: Don't allow dummy broadcast timersMark Rutland
Currently tick_check_broadcast_device doesn't reject clock_event_devices with CLOCK_EVT_FEAT_DUMMY, and may select them in preference to real hardware if they have a higher rating value. In this situation, the dummy timer is responsible for broadcasting to itself, and the core clockevents code may attempt to call non-existent callbacks for programming the dummy, eventually leading to a panic. This patch makes tick_check_broadcast_device always reject dummy timers, preventing this problem. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Cc: linux-arm-kernel@lists.infradead.org Cc: Jon Medhurst (Tixy) <tixy@linaro.org> Cc: stable@vger.kernel.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-03-07tracing: Do not return EINVAL in snapshot when not allocatedSteven Rostedt (Red Hat)
To use the tracing snapshot feature, writing a '1' into the snapshot file causes the snapshot buffer to be allocated if it has not already been allocated and dose a 'swap' with the main buffer, so that the snapshot now contains what was in the main buffer, and the main buffer now writes to what was the snapshot buffer. To free the snapshot buffer, a '0' is written into the snapshot file. To clear the snapshot buffer, any number but a '0' or '1' is written into the snapshot file. But if the file is not allocated it returns -EINVAL error code. This is rather pointless. It is better just to do nothing and return success. Acked-by: Hiraku Toyooka <hiraku.toyooka.gu@hitachi.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2013-03-07tracing: Add help of snapshot feature when snapshot is emptySteven Rostedt (Red Hat)
When cat'ing the snapshot file, instead of showing an empty trace header like the trace file does, show how to use the snapshot feature. Also, this is a good place to show if the snapshot has been allocated or not. Users may want to "pre allocate" the snapshot to have a fast "swap" of the current buffer. Otherwise, a swap would be slow and might fail as it would need to allocate the snapshot buffer, and that might fail under tight memory constraints. Here's what it looked like before: # tracer: nop # # entries-in-buffer/entries-written: 0/0 #P:4 # # _-----=> irqs-off # / _----=> need-resched # | / _---=> hardirq/softirq # || / _--=> preempt-depth # ||| / delay # TASK-PID CPU# |||| TIMESTAMP FUNCTION # | | | |||| | | Here's what it looks like now: # tracer: nop # # # * Snapshot is freed * # # Snapshot commands: # echo 0 > snapshot : Clears and frees snapshot buffer # echo 1 > snapshot : Allocates snapshot buffer, if not already allocated. # Takes a snapshot of the main buffer. # echo 2 > snapshot : Clears snapshot buffer (but does not allocate) # (Doesn't have to be '2' works with any number that # is not a '0' or '1') Acked-by: Hiraku Toyooka <hiraku.toyooka.gu@hitachi.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2013-03-05Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq fixes and cleanups from Thomas Gleixner: "Commit e5ab012c3271 ("nohz: Make tick_nohz_irq_exit() irq safe") is the first commit in the series and the minimal necessary bugfix, which needs to go back into stable. The remanining commits enforce irq disabling in irq_exit(), sanitize the hardirq/softirq preempt count transition and remove a bunch of no longer necessary conditionals." I personally love getting rid of the very subtle and confusing IRQ_EXIT_OFFSET thing. Even apart from the whole "more lines removed than added" thing. * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: irq: Don't re-enable interrupts at the end of irq_exit irq: Remove IRQ_EXIT_OFFSET workaround Revert "nohz: Make tick_nohz_irq_exit() irq safe" irq: Sanitize invoke_softirq irq: Ensure irq_exit() code runs with interrupts disabled nohz: Make tick_nohz_irq_exit() irq safe
2013-03-05Merge branch 'core-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull smpboot bugfix from Thomas Gleixner: "A single bugfix for a regression introduced with the conversion of the stop machine threads to the generic smpboot thread management facility" * 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: stop_machine: Mark per cpu stopper enabled early
2013-03-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more VFS bits from Al Viro: "Unfortunately, it looks like xattr series will have to wait until the next cycle ;-/ This pile contains 9p cleanups and fixes (races in v9fs_fid_add() etc), fixup for nommu breakage in shmem.c, several cleanups and a bit more file_inode() work" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: constify path_get/path_put and fs_struct.c stuff fix nommu breakage in shmem.c cache the value of file_inode() in struct file 9p: if v9fs_fid_lookup() gets to asking server, it'd better have hashed dentry 9p: make sure ->lookup() adds fid to the right dentry 9p: untangle ->lookup() a bit 9p: double iput() in ->lookup() if d_materialise_unique() fails 9p: v9fs_fid_add() can't fail now v9fs: get rid of v9fs_dentry 9p: turn fid->dlist into hlist 9p: don't bother with private lock in ->d_fsdata; dentry->d_lock will do just fine more file_inode() open-coded instances selinux: opened file can't have NULL or negative ->f_path.dentry (In the meantime, the hlist traversal macros have changed, so this required a semantic conflict fixup for the newly hlistified fid->dlist)
2013-03-03Merge tag 'metag-v3.9-rc1-v4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag Pull new ImgTec Meta architecture from James Hogan: "This adds core architecture support for Imagination's Meta processor cores, followed by some later miscellaneous arch/metag cleanups and fixes which I kept separate to ease review: - Support for basic Meta 1 (ATP) and Meta 2 (HTP) core architecture - A few fixes all over, particularly for symbol prefixes - A few privilege protection fixes - Several cleanups (setup.c includes, split out a lot of metag_ksyms.c) - Fix some missing exports - Convert hugetlb to use vm_unmapped_area() - Copy device tree to non-init memory - Provide dma_get_sgtable()" * tag 'metag-v3.9-rc1-v4' of git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag: (61 commits) metag: Provide dma_get_sgtable() metag: prom.h: remove declaration of metag_dt_memblock_reserve() metag: copy devicetree to non-init memory metag: cleanup metag_ksyms.c includes metag: move mm/init.c exports out of metag_ksyms.c metag: move usercopy.c exports out of metag_ksyms.c metag: move setup.c exports out of metag_ksyms.c metag: move kick.c exports out of metag_ksyms.c metag: move traps.c exports out of metag_ksyms.c metag: move irq enable out of irqflags.h on SMP genksyms: fix metag symbol prefix on crc symbols metag: hugetlb: convert to vm_unmapped_area() metag: export clear_page and copy_page metag: export metag_code_cache_flush_all metag: protect more non-MMU memory regions metag: make TXPRIVEXT bits explicit metag: kernel/setup.c: sort includes perf: Enable building perf tools for Meta metag: add boot time LNKGET/LNKSET check metag: add __init to metag_cache_probe() ...
2013-03-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull sigprocmask compat fix from Al Viro: "generic compat_sys_rt_sigprocmask() had a very dumb braino; I'd spent quite a while staring at the offending commit before finally managing to spot the idiocy ;-/" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: fix compat_sys_rt_sigprocmask()
2013-03-02fix compat_sys_rt_sigprocmask()Al Viro
Converting bitmask to 32bit granularity is fine, but we'd better _do_ something with the result. Such as "copy it to userland"... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-03-02trace/ring_buffer: handle 64bit aligned structsJames Hogan
Some 32 bit architectures require 64 bit values to be aligned (for example Meta which has 64 bit read/write instructions). These require 8 byte alignment of event data too, so use !CONFIG_HAVE_64BIT_ALIGNED_ACCESS instead of !CONFIG_64BIT || CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS to decide alignment, and align buffer_data_page::data accordingly. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> (previous version subtly different)
2013-03-02Merge tag 'for_linux-3.9' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/kgdb Pull KGDB/KDB fixes and cleanups from Jason Wessel: "For a change we removed more code than we added. If people aren't using it we shouldn't be carrying it. :-) Cleanups: - Remove kdb ssb command - there is no in kernel disassembler to support it - Remove kdb ll command - Always caused a kernel oops and there were no bug reports so no one was using this command - Use kernel ARRAY_SIZE macro instead of array computations Fixes: - Stop oops in kdb if user executes kdb_defcmd with args - kdb help command truncated text - ppc64 support for kgdbts - Add missing kconfig option from original kdb port for dealing with catastrophic kernel crashes such that you can reboot automatically on continue from kdb" * tag 'for_linux-3.9' of git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/kgdb: kdb: Remove unhandled ssb command kdb: Prevent kernel oops with kdb_defcmd kdb: Remove the ll command kdb_main: fix help print kdb: Fix overlap in buffers with strcpy Fixed dead ifdef block by adding missing Kconfig option. kdb: Setup basic kdb state before invoking commands via kgdb kdb: use ARRAY_SIZE where possible kgdb/kgdbts: support ppc64 kdb: A fix for kdb command table expansion
2013-03-02Merge tag 'arc-v3.9-rc1-late' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc Pull new ARC architecture from Vineet Gupta: "Initial ARC Linux port with some fixes on top for 3.9-rc1: I would like to introduce the Linux port to ARC Processors (from Synopsys) for 3.9-rc1. The patch-set has been discussed on the public lists since Nov and has received a fair bit of review, specially from Arnd, tglx, Al and other subsystem maintainers for DeviceTree, kgdb... The arch bits are in arch/arc, some asm-generic changes (acked by Arnd), a minor change to PARISC (acked by Helge). The series is a touch bigger for a new port for 2 main reasons: 1. It enables a basic kernel in first sub-series and adds ptrace/kgdb/.. later 2. Some of the fallout of review (DeviceTree support, multi-platform- image support) were added on top of orig series, primarily to record the revision history. This updated pull request additionally contains - fixes due to our GNU tools catching up with the new syscall/ptrace ABI - some (minor) cross-arch Kconfig updates." * tag 'arc-v3.9-rc1-late' of git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc: (82 commits) ARC: split elf.h into uapi and export it for userspace ARC: Fixup the current ABI version ARC: gdbserver using regset interface possibly broken ARC: Kconfig cleanup tracking cross-arch Kconfig pruning in merge window ARC: make a copy of flat DT ARC: [plat-arcfpga] DT arc-uart bindings change: "baud" => "current-speed" ARC: Ensure CONFIG_VIRT_TO_BUS is not enabled ARC: Fix pt_orig_r8 access ARC: [3.9] Fallout of hlist iterator update ARC: 64bit RTSC timestamp hardware issue ARC: Don't fiddle with non-existent caches ARC: Add self to MAINTAINERS ARC: Provide a default serial.h for uart drivers needing BASE_BAUD ARC: [plat-arcfpga] defconfig for fully loaded ARC Linux ARC: [Review] Multi-platform image #8: platform registers SMP callbacks ARC: [Review] Multi-platform image #7: SMP common code to use callbacks ARC: [Review] Multi-platform image #6: cpu-to-dma-addr optional ARC: [Review] Multi-platform image #5: NR_IRQS defined by ARC core ARC: [Review] Multi-platform image #4: Isolate platform headers ARC: [Review] Multi-platform image #3: switch to board callback ...
2013-03-02kdb: Remove unhandled ssb commandVincent
The 'ssb' command can only be handled when we have a disassembler, to check for branches, so remove the 'ssb' command for now. Signed-off-by: Vincent Stehlé <vincent.stehle@laposte.net> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2013-03-02kdb: Prevent kernel oops with kdb_defcmdJason Wessel
The kdb_defcmd can only be used to display the available command aliases while using the kernel debug shell. If you try to define a new macro while the kernel debugger is active it will oops. The debug shell macros must use pre-allocated memory set aside at the time kdb_init() is run, and the kdb_defcmd is restricted to only working at the time that the kdb_init sequence is being run, which only occurs if you actually activate the kernel debugger. Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2013-03-02kdb: Remove the ll commandJason Wessel
Recently some code inspection was done after fixing a problem with kmalloc used while in the kernel debugger context (which is not legal), and it turned up the fact that kdb ll command will oops the kernel. Given that there have been zero bug reports on the command combined with the fact it will oops the kernel it is clearly not being used. Instead of fixing it, it will be removed. Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2013-03-02kdb_main: fix help printJason Wessel
The help command was chopping all the usage instructions such that they were not readable. Example: bta [D|R|S|T|C|Z|E|U|I| Backtrace all processes matching state flag per_cpu <sym> [<bytes>] [<c Display per_cpu variables Where as it should look like: bta [D|R|S|T|C|Z|E|U|I|M|A] Backtrace all processes matching state flag per_cpu <sym> [<bytes>] [<cpu>] Display per_cpu variables All that is needed is to check the how long the cmd_usage is and jump to the next line when appropriate. Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2013-03-02kdb: Fix overlap in buffers with strcpyJason Wessel
Maxime reported that strcpy(s->usage, s->usage+1) has no definitive guarantee that it will work on all archs the same way when you have overlapping memory. The fix is simple for the kdb code because we still have the original string memory in the function scope, so we just have to use that as the argument instead. Reported-by: Maxime Villard <rustyBSD@gmx.fr> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2013-03-02kdb: Setup basic kdb state before invoking commands via kgdbMatt Klein
Although invasive kdb commands are not supported via kgdb, some useful non-invasive commands like bt* require basic kdb state to be setup before calling into the kdb code. Factor out some of this code and call it before and after executing kdb commands via kgdb. Signed-off-by: Matt Klein <mklein@twitter.com> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2013-03-02kdb: use ARRAY_SIZE where possibleSasha Levin
Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2013-03-02kdb: A fix for kdb command table expansionJohn Blackwood
When locally adding in some additional kdb commands, I stumbled across an issue with the dynamic expansion of the kdb command table. When the number of kdb commands exceeds the size of the statically allocated kdb_base_commands[] array, additional space is allocated in the kdb_register_repeat() routine. The unused portion of the newly allocated array was not being initialized to zero properly and this would result in segfaults when help '?' was executed or when a search for a non-existing command would traverse the command table beyond the end of valid command entries and then attempt to use the non-zeroed area as actual command entries. Signed-off-by: John Blackwood <john.blackwood@ccur.com> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2013-02-28Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux Pull thermal management updates from Zhang Rui: "Highlights: - introduction of Dove thermal sensor driver. - introduction of Kirkwood thermal sensor driver. - introduction of intel_powerclamp thermal cooling device driver. - add interrupt and DT support for rcar thermal driver. - add thermal emulation support which allows platform thermal driver to do software/hardware emulation for thermal issues." * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux: (36 commits) thermal: rcar: remove __devinitconst thermal: return an error on failure to register thermal class Thermal: rename thermal governor Kconfig option to avoid generic naming thermal: exynos: Use the new thermal trend type for quick cooling action. Thermal: exynos: Add support for temperature falling interrupt. Thermal: Dove: Add Themal sensor support for Dove. thermal: Add support for the thermal sensor on Kirkwood SoCs thermal: rcar: add Device Tree support thermal: rcar: remove machine_power_off() from rcar_thermal_notify() thermal: rcar: add interrupt support thermal: rcar: add read/write functions for common/priv data thermal: rcar: multi channel support thermal: rcar: use mutex lock instead of spin lock thermal: rcar: enable CPCTL to use hardware TSC deciding thermal: rcar: use parenthesis on macro Thermal: fix a build warning when CONFIG_THERMAL_EMULATION cleared Thermal: fix a wrong comment thermal: sysfs: Add a new sysfs node emul_temp for thermal emulation PM: intel_powerclamp: off by one in start_power_clamp() thermal: exynos: Miscellaneous fixes to support falling threshold interrupt ...
