path: root/kernel
2014-07-06tracing: Fix syscall_*regfunc() vs copy_process() raceOleg Nesterov
commit 4af4206be2bd1933cae20c2b6fb2058dbc887f7c upstream. syscall_regfunc() and syscall_unregfunc() should set/clear TIF_SYSCALL_TRACEPOINT system-wide, but do_each_thread() can race with copy_process() and miss the new child which was not added to the process/thread lists yet. Change copy_process() to update the child's TIF_SYSCALL_TRACEPOINT under tasklist. Link: http://lkml.kernel.org/p/20140413185854.GB20668@redhat.com Fixes: a871bd33a6c0 "tracing: Add syscall tracepoints" Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-06tracing: Try again for saved cmdline if failed due to lockingSteven Rostedt (Red Hat)
commit 379cfdac37923653c9d4242d10052378b7563005 upstream. In order to prevent the saved cmdline cache from being filled when tracing is not active, the comms are only recorded after a trace event is recorded. The problem is, a comm can fail to be recorded if the trace_cmdline_lock is held. That lock is taken via a trylock to allow it to happen from any context (including NMI). If the lock fails to be taken, the comm is skipped. No big deal, as we will try again later. But! Because of the code that was added to only record after an event, we may not try again later as the recording is made as a oneshot per event per CPU. Only disable the recording of the comm if the comm is actually recorded. Fixes: 7ffbd48d5cab "tracing: Cache comms only after an event occurred" Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-06kernel/watchdog.c: remove preemption restrictions when restarting lockup ↵Don Zickus
detector commit bde92cf455a03a91badb7046855592d8c008e929 upstream. Peter Wu noticed the following splat on his machine when updating /proc/sys/kernel/watchdog_thresh: BUG: sleeping function called from invalid context at mm/slub.c:965 in_atomic(): 1, irqs_disabled(): 0, pid: 1, name: init 3 locks held by init/1: #0: (sb_writers#3){.+.+.+}, at: [<ffffffff8117b663>] vfs_write+0x143/0x180 #1: (watchdog_proc_mutex){+.+.+.}, at: [<ffffffff810e02d3>] proc_dowatchdog+0x33/0x110 #2: (cpu_hotplug.lock){.+.+.+}, at: [<ffffffff810589c2>] get_online_cpus+0x32/0x80 Preemption disabled at:[<ffffffff810e0384>] proc_dowatchdog+0xe4/0x110 CPU: 0 PID: 1 Comm: init Not tainted 3.16.0-rc1-testing #34 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011 Call Trace: dump_stack+0x4e/0x7a __might_sleep+0x11d/0x190 kmem_cache_alloc_trace+0x4e/0x1e0 perf_event_alloc+0x55/0x440 perf_event_create_kernel_counter+0x26/0xe0 watchdog_nmi_enable+0x75/0x140 update_timers_all_cpus+0x53/0xa0 proc_dowatchdog+0xe4/0x110 proc_sys_call_handler+0xb3/0xc0 proc_sys_write+0x14/0x20 vfs_write+0xad/0x180 SyS_write+0x49/0xb0 system_call_fastpath+0x16/0x1b NMI watchdog: disabled (cpu0): hardware events not enabled What happened is after updating the watchdog_thresh, the lockup detector is restarted to utilize the new value. Part of this process involved disabling preemption. Once preemption was disabled, perf tried to allocate a new event (as part of the restart). This caused the above BUG_ON as you can't sleep with preemption disabled. The preemption restriction seemed agressive as we are not doing anything on that particular cpu, but with all the online cpus (which are protected by the get_online_cpus lock). Remove the restriction and the BUG_ON goes away. Signed-off-by: Don Zickus <dzickus@redhat.com> Acked-by: Michal Hocko <mhocko@suse.cz> Reported-by: Peter Wu <peter@lekensteyn.nl> Tested-by: Peter Wu <peter@lekensteyn.nl> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-30genirq: Sanitize spurious interrupt detection of threaded irqsThomas Gleixner
commit 1e77d0a1ed7417d2a5a52a7b8d32aea1833faa6c upstream. Till reported that the spurious interrupt detection of threaded interrupts is broken in two ways: - note_interrupt() is called for each action thread of a shared interrupt line. That's wrong as we are only interested whether none of the device drivers felt responsible for the interrupt, but by calling multiple times for a single interrupt line we account IRQ_NONE even if one of the drivers felt responsible. - note_interrupt() when called from the thread handler is not serialized. That leaves the members of irq_desc which are used for the spurious detection unprotected. To solve this we need to defer the spurious detection of a threaded interrupt to the next hardware interrupt context where we have implicit serialization. If note_interrupt is called with action_ret == IRQ_WAKE_THREAD, we check whether the previous interrupt requested a deferred check. If not, we request a deferred check for the next hardware interrupt and return. If set, we check whether one of the interrupt threads signaled success. Depending on this information we feed the result into the spurious detector. If one primary handler of a shared interrupt returns IRQ_HANDLED we disable the deferred check of irq threads on the same line, as we have found at least one device driver who cared. Reported-by: Till Straumann <strauman@slac.stanford.edu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Austin Schuh <austin@peloton-tech.com> Cc: Oliver Hartkopp <socketcan@hartkopp.net> Cc: Wolfgang Grandegger <wg@grandegger.com> Cc: Pavel Pisa <pisa@cmp.felk.cvut.cz> Cc: Marc Kleine-Budde <mkl@pengutronix.de> Cc: linux-can@vger.kernel.org Link: http://lkml.kernel.org/r/alpine.LFD.2.02.1303071450130.22263@ionos Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-30rtmutex: Plug slow unlock raceThomas Gleixner
commit 27e35715df54cbc4f2d044f681802ae30479e7fb upstream. When the rtmutex fast path is enabled the slow unlock function can create the following situation: spin_lock(foo->m->wait_lock); foo->m->owner = NULL; rt_mutex_lock(foo->m); <-- fast path free = atomic_dec_and_test(foo->refcnt); rt_mutex_unlock(foo->m); <-- fast path if (free) kfree(foo); spin_unlock(foo->m->wait_lock); <--- Use after free. Plug the race by changing the slow unlock to the following scheme: while (!rt_mutex_has_waiters(m)) { /* Clear the waiters bit in m->owner */ clear_rt_mutex_waiters(m); owner = rt_mutex_owner(m); spin_unlock(m->wait_lock); if (cmpxchg(m->owner, owner, 0) == owner) return; spin_lock(m->wait_lock); } So in case of a new waiter incoming while the owner tries the slow path unlock we have two situations: unlock(wait_lock); lock(wait_lock); cmpxchg(p, owner, 0) == owner mark_rt_mutex_waiters(lock); acquire(lock); Or: unlock(wait_lock); lock(wait_lock); mark_rt_mutex_waiters(lock); cmpxchg(p, owner, 0) != owner enqueue_waiter(); unlock(wait_lock); lock(wait_lock); wakeup_next waiter(); unlock(wait_lock); lock(wait_lock); acquire(lock); If the fast path is disabled, then the simple m->owner = NULL; unlock(m->wait_lock); is sufficient as all access to m->owner is serialized via m->wait_lock; Also document and clarify the wakeup_next_waiter function as suggested by Oleg Nesterov. Reported-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20140611183852.937945560@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-30rtmutex: Handle deadlock detection smarterThomas Gleixner
commit 3d5c9340d1949733eb37616abd15db36aef9a57c upstream. Even in the case when deadlock detection is not requested by the caller, we can detect deadlocks. Right now the code stops the lock chain walk and keeps the waiter enqueued, even on itself. Silly not to yell when such a scenario is detected and to keep the waiter enqueued. Return -EDEADLK unconditionally and handle it at the call sites. The futex calls return -EDEADLK. The non futex ones dequeue the waiter, throw a warning and put the task into a schedule loop. Tagged for stable as it makes the code more robust. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Brad Mouring <bmouring@ni.com> Link: http://lkml.kernel.org/r/20140605152801.836501969@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-30rtmutex: Detect changes in the pi lock chainThomas Gleixner
commit 82084984383babe728e6e3c9a8e5c46278091315 upstream. When we walk the lock chain, we drop all locks after each step. So the lock chain can change under us before we reacquire the locks. That's harmless in principle as we just follow the wrong lock path. But it can lead to a false positive in the dead lock detection logic: T0 holds L0 T0 blocks on L1 held by T1 T1 blocks on L2 held by T2 T2 blocks on L3 held by T3 T4 blocks on L4 held by T4 Now we walk the chain lock T1 -> lock L2 -> adjust L2 -> unlock T1 -> lock T2 -> adjust T2 -> drop locks T2 times out and blocks on L0 Now we continue: lock T2 -> lock L0 -> deadlock detected, but it's not a deadlock at all. Brad tried to work around that in the deadlock detection logic itself, but the more I looked at it the less I liked it, because it's crystal ball magic after the fact. We actually can detect a chain change very simple: lock T1 -> lock L2 -> adjust L2 -> unlock T1 -> lock T2 -> adjust T2 -> next_lock = T2->pi_blocked_on->lock; drop locks T2 times out and blocks on L0 Now we continue: lock T2 -> if (next_lock != T2->pi_blocked_on->lock) return; So if we detect that T2 is now blocked on a different lock we stop the chain walk. That's also correct in the following scenario: lock T1 -> lock L2 -> adjust L2 -> unlock T1 -> lock T2 -> adjust T2 -> next_lock = T2->pi_blocked_on->lock; drop locks T3 times out and drops L3 T2 acquires L3 and blocks on L4 now Now we continue: lock T2 -> if (next_lock != T2->pi_blocked_on->lock) return; We don't have to follow up the chain at that point, because T2 propagated our priority up to T4 already. [ Folded a cleanup patch from peterz ] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reported-by: Brad Mouring <bmouring@ni.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20140605152801.930031935@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-30ptrace: fix fork event messages across pid namespacesMatthew Dempsky
commit 4e52365f279564cef0ddd41db5237f0471381093 upstream. When tracing a process in another pid namespace, it's important for fork event messages to contain the child's pid as seen from the tracer's pid namespace, not the parent's. Otherwise, the tracer won't be able to correlate the fork event with later SIGTRAP signals it receives from the child. We still risk a race condition if a ptracer from a different pid namespace attaches after we compute the pid_t value. However, sending a bogus fork event message in this unlikely scenario is still a vast improvement over the status quo where we always send bogus fork event messages to debuggers in a different pid namespace than the forking process. Signed-off-by: Matthew Dempsky <mdempsky@chromium.org> Acked-by: Oleg Nesterov <oleg@redhat.com> Cc: Kees Cook <keescook@chromium.org> Cc: Julien Tinnes <jln@chromium.org> Cc: Roland McGrath <mcgrathr@chromium.org> Cc: Jan Kratochvil <jan.kratochvil@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-30kthread: fix return value of kthread_create() upon SIGKILL.Tetsuo Handa
commit 8fe6929cfd43c44834858a53e129ffdc7c166298 upstream. Commit 786235eeba0e ("kthread: make kthread_create() killable") meant for allowing kthread_create() to abort as soon as killed by the OOM-killer. But returning -ENOMEM is wrong if killed by SIGKILL from userspace. Change kthread_create() to return -EINTR upon SIGKILL. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Oleg Nesterov <oleg@redhat.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-30printk/of_serial: fix serial console cessation part way through boot.Stephen Chivers
commit 7fa21dd8bd191564a195291161d6b43db5d9c350 upstream. Commit 5f5c9ae56c38942623f69c3e6dc6ec78e4da2076 "serial_core: Unregister console in uart_remove_one_port()" fixed a crash where a serial port was removed but not deregistered as a console. There is a side effect of that commit for platforms having serial consoles and of_serial configured (CONFIG_SERIAL_OF_PLATFORM). The serial console is disabled midway through the boot process. This cessation of the serial console affects PowerPC computers such as the MVME5100 and SAM440EP. The sequence is: bootconsole [udbg0] enabled .... serial8250/16550 driver initialises and registers its UARTS, one of these is the serial console. console [ttyS0] enabled .... of_serial probes "platform" devices, registering them as it goes. One of these is the serial console. console [ttyS0] disabled. The disabling of the serial console is due to: a. unregister_console in printk not clearing the CONS_ENABLED bit in the console flags, even though it has announced that the console is disabled; and b. of_platform_serial_probe in of_serial not setting the port type before it registers with serial8250_register_8250_port. This patch ensures that the serial console is re-enabled when of_serial registers a serial port that corresponds to the designated console. === The above failure was identified in Linux-3.15-rc2. Tested using MVME5100 and SAM440EP PowerPC computers with kernels built from Linux-3.15-rc5 and tty-next. The continued operation of the serial console is vital for computers such as the MVME5100 as that Single Board Computer does not have any grapical/display hardware. Signed-off-by: Stephen Chivers <schivers@csc.com> Tested-by: Stephen Chivers <schivers@csc.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> [unregister_console] Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-16auditsc: audit_krule mask accesses need bounds checkingAndy Lutomirski
commit a3c54931199565930d6d84f4c3456f6440aefd41 upstream. Fixes an easy DoS and possible information disclosure. This does nothing about the broken state of x32 auditing. eparis: If the admin has enabled auditd and has specifically loaded audit rules. This bug has been around since before git. Wow... Signed-off-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-16fs,userns: Change inode_capable to capable_wrt_inode_uidgidAndy Lutomirski
commit 23adbe12ef7d3d4195e80800ab36b37bee28cd03 upstream. The kernel has no concept of capabilities with respect to inodes; inodes exist independently of namespaces. For example, inode_capable(inode, CAP_LINUX_IMMUTABLE) would be nonsense. This patch changes inode_capable to check for uid and gid mappings and renames it to capable_wrt_inode_uidgid, which should make it more obvious what it does. Fixes CVE-2014-4014. Cc: Theodore Ts'o <tytso@mit.edu> Cc: Serge Hallyn <serge.hallyn@ubuntu.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Dave Chinner <david@fromorbit.com> Signed-off-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-06Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fixes from Ingo Molnar: "Four misc fixes: each was deemed serious enough to warrant v3.15 inclusion" * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched/fair: Fix tg_set_cfs_bandwidth() deadlock on rq->lock sched/dl: Fix race in dl_task_timer() sched: Fix sched_policy < 0 comparison sched/numa: Fix use of spin_{un}lock_irq() when interrupts are disabled
2014-06-05Merge branch 'futex-fixes' (futex fixes from Thomas Gleixner)Linus Torvalds
Merge futex fixes from Thomas Gleixner: "So with more awake and less futex wreckaged brain, I went through my list of points again and came up with the following 4 patches. 1) Prevent pi requeueing on the same futex I kept Kees check for uaddr1 == uaddr2 as a early check for private futexes and added a key comparison to both futex_requeue and futex_wait_requeue_pi. Sebastian, sorry for the confusion yesterday night. I really misunderstood your question. You are right the check is pointless for shared futexes where the same physical address is mapped to two different virtual addresses. 2) Sanity check atomic acquisiton in futex_lock_pi_atomic That's basically what Darren suggested. I just simplified it to use futex_top_waiter() to find kernel internal state. If state is found return -EINVAL and do not bother to fix up the user space variable. It's corrupted already. 3) Ensure state consistency in futex_unlock_pi The code is silly versus the owner died bit. There is no point to preserve it on unlock when the user space thread owns the futex. What's worse is that it does not update the user space value when the owner died bit is set. So the kernel itself creates observable inconsistency. Another "optimization" is to retry an atomic unlock. That's pointless as in a sane environment user space would not call into that code if it could have unlocked it atomically. So we always check whether there is kernel state around and only if there is none, we do the unlock by setting the user space value to 0. 4) Sanitize lookup_pi_state lookup_pi_state is ambigous about TID == 0 in the user space value. This can be a valid state even if there is kernel state on this uaddr, but we miss a few corner case checks. I tried to come up with a smaller solution hacking the checks into the current cruft, but it turned out to be ugly as hell and I got more confused than I was before. So I rewrote the sanity checks along the state documentation with awful lots of commentry" * emailed patches from Thomas Gleixner <tglx@linutronix.de>: futex: Make lookup_pi_state more robust futex: Always cleanup owner tid in unlock_pi futex: Validate atomic acquisition in futex_lock_pi_atomic() futex-prevent-requeue-pi-on-same-futex.patch futex: Forbid uaddr == uaddr2 in futex_requeue(..., requeue_pi=1)
2014-06-05futex: Make lookup_pi_state more robustThomas Gleixner
The current implementation of lookup_pi_state has ambigous handling of the TID value 0 in the user space futex. We can get into the kernel even if the TID value is 0, because either there is a stale waiters bit or the owner died bit is set or we are called from the requeue_pi path or from user space just for fun. The current code avoids an explicit sanity check for pid = 0 in case that kernel internal state (waiters) are found for the user space address. This can lead to state leakage and worse under some circumstances. Handle the cases explicit: Waiter | pi_state | pi->owner | uTID | uODIED | ? [1] NULL | --- | --- | 0 | 0/1 | Valid [2] NULL | --- | --- | >0 | 0/1 | Valid [3] Found | NULL | -- | Any | 0/1 | Invalid [4] Found | Found | NULL | 0 | 1 | Valid [5] Found | Found | NULL | >0 | 1 | Invalid [6] Found | Found | task | 0 | 1 | Valid [7] Found | Found | NULL | Any | 0 | Invalid [8] Found | Found | task | ==taskTID | 0/1 | Valid [9] Found | Found | task | 0 | 0 | Invalid [10] Found | Found | task | !=taskTID | 0/1 | Invalid [1] Indicates that the kernel can acquire the futex atomically. We came came here due to a stale FUTEX_WAITERS/FUTEX_OWNER_DIED bit. [2] Valid, if TID does not belong to a kernel thread. If no matching thread is found then it indicates that the owner TID has died. [3] Invalid. The waiter is queued on a non PI futex [4] Valid state after exit_robust_list(), which sets the user space value to FUTEX_WAITERS | FUTEX_OWNER_DIED. [5] The user space value got manipulated between exit_robust_list() and exit_pi_state_list() [6] Valid state after exit_pi_state_list() which sets the new owner in the pi_state but cannot access the user space value. [7] pi_state->owner can only be NULL when the OWNER_DIED bit is set. [8] Owner and user space value match [9] There is no transient state which sets the user space TID to 0 except exit_robust_list(), but this is indicated by the FUTEX_OWNER_DIED bit. See [4] [10] There is no transient state which leaves owner and user space TID out of sync. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Kees Cook <keescook@chromium.org> Cc: Will Drewry <wad@chromium.org> Cc: Darren Hart <dvhart@linux.intel.com> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-05futex: Always cleanup owner tid in unlock_piThomas Gleixner
If the owner died bit is set at futex_unlock_pi, we currently do not cleanup the user space futex. So the owner TID of the current owner (the unlocker) persists. That's observable inconsistant state, especially when the ownership of the pi state got transferred. Clean it up unconditionally. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Kees Cook <keescook@chromium.org> Cc: Will Drewry <wad@chromium.org> Cc: Darren Hart <dvhart@linux.intel.com> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-05futex: Validate atomic acquisition in futex_lock_pi_atomic()Thomas Gleixner
We need to protect the atomic acquisition in the kernel against rogue user space which sets the user space futex to 0, so the kernel side acquisition succeeds while there is existing state in the kernel associated to the real owner. Verify whether the futex has waiters associated with kernel state. If it has, return -EINVAL. The state is corrupted already, so no point in cleaning it up. Subsequent calls will fail as well. Not our problem. [ tglx: Use futex_top_waiter() and explain why we do not need to try restoring the already corrupted user space state. ] Signed-off-by: Darren Hart <dvhart@linux.intel.com> Cc: Kees Cook <keescook@chromium.org> Cc: Will Drewry <wad@chromium.org> Cc: stable@vger.kernel.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-05futex-prevent-requeue-pi-on-same-futex.patch futex: Forbid uaddr == uaddr2 ↵Thomas Gleixner
in futex_requeue(..., requeue_pi=1) If uaddr == uaddr2, then we have broken the rule of only requeueing from a non-pi futex to a pi futex with this call. If we attempt this, then dangling pointers may be left for rt_waiter resulting in an exploitable condition. This change brings futex_requeue() in line with futex_wait_requeue_pi() which performs the same check as per commit 6f7b0a2a5c0f ("futex: Forbid uaddr == uaddr2 in futex_wait_requeue_pi()") [ tglx: Compare the resulting keys as well, as uaddrs might be different depending on the mapping ] Fixes CVE-2014-3153. Reported-by: Pinkie Pie Signed-off-by: Will Drewry <wad@chromium.org> Signed-off-by: Kees Cook <keescook@chromium.org> Cc: stable@vger.kernel.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Darren Hart <dvhart@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-05sched/fair: Fix tg_set_cfs_bandwidth() deadlock on rq->lockRoman Gushchin
tg_set_cfs_bandwidth() sets cfs_b->timer_active to 0 to force the period timer restart. It's not safe, because can lead to deadlock, described in commit 927b54fccbf0: "__start_cfs_bandwidth calls hrtimer_cancel while holding rq->lock, waiting for the hrtimer to finish. However, if sched_cfs_period_timer runs for another loop iteration, the hrtimer can attempt to take rq->lock, resulting in deadlock." Three CPUs must be involved: CPU0 CPU1 CPU2 take rq->lock period timer fired ... take cfs_b lock ... ... tg_set_cfs_bandwidth() throttle_cfs_rq() release cfs_b lock take cfs_b lock ... distribute_cfs_runtime() timer_active = 0 take cfs_b->lock wait for rq->lock ... __start_cfs_bandwidth() {wait for timer callback break if timer_active == 1} So, CPU0 and CPU1 are deadlocked. Instead of resetting cfs_b->timer_active, tg_set_cfs_bandwidth can wait for period timer callbacks (ignoring cfs_b->timer_active) and restart the timer explicitly. Signed-off-by: Roman Gushchin <klamm@yandex-team.ru> Reviewed-by: Ben Segall <bsegall@google.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/87wqdi9g8e.wl\%klamm@yandex-team.ru Cc: pjt@google.com Cc: chris.j.arges@canonical.com Cc: gregkh@linuxfoundation.org Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-06-05sched/dl: Fix race in dl_task_timer()Kirill Tkhai
Throttled task is still on rq, and it may be moved to other cpu if user is playing with sched_setaffinity(). Therefore, unlocked task_rq() access makes the race. Juri Lelli reports he got this race when dl_bandwidth_enabled() was not set. Other thing, pointed by Peter Zijlstra: "Now I suppose the problem can still actually happen when you change the root domain and trigger a effective affinity change that way". To fix that we do the same as made in __task_rq_lock(). We do not use __task_rq_lock() itself, because it has a useful lockdep check, which is not correct in case of dl_task_timer(). We do not need pi_lock locked here. This case is an exception (PeterZ): "The only reason we don't strictly need ->pi_lock now is because we're guaranteed to have p->state == TASK_RUNNING here and are thus free of ttwu races". Signed-off-by: Kirill Tkhai <tkhai@yandex.ru> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: <stable@vger.kernel.org> # v3.14+ Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/3056991400578422@web14g.yandex.ru Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-06-05sched: Fix sched_policy < 0 comparisonRichard Weinberger
attr.sched_policy is u32, therefore a comparison against < 0 is never true. Fix this by casting sched_policy to int. This issue was reported by coverity CID 1219934. Fixes: dbdb22754fde ("sched: Disallow sched_attr::sched_policy < 0") Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/1401741514-7045-1-git-send-email-richard@nod.at Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-06-05sched/numa: Fix use of spin_{un}lock_irq() when interrupts are disabledSteven Rostedt
As Peter Zijlstra told me, we have the following path: do_exit() exit_itimers() itimer_delete() spin_lock_irqsave(&timer->it_lock, &flags); timer_delete_hook(timer); kc->timer_del(timer) := posix_cpu_timer_del() put_task_struct() __put_task_struct() task_numa_free() spin_lock(&grp->lock); Which means that task_numa_free() can be called with interrupts disabled, which means that we should not be using spin_lock_irq() but spin_lock_irqsave() instead. Otherwise we are enabling interrupts while holding an interrupt unsafe lock! Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner<tglx@linutronix.de> Cc: Mike Galbraith <umgwanakikbuti@gmail.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/20140527182541.GH11096@twins.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-06-03kernfs: move the last knowledge of sysfs out from kernfsJianyu Zhan
There is still one residue of sysfs remaining: the sb_magic SYSFS_MAGIC. However this should be kernfs user specific, so this patch moves it out. Kerrnfs user should specify their magic number while mouting. Signed-off-by: Jianyu Zhan <nasa4836@gmail.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-01Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fixes from Ingo Molnar: "Various fixlets, mostly related to the (root-only) SCHED_DEADLINE policy, but also a hotplug bug fix and a fix for a NR_CPUS related overallocation bug causing a suspend/resume regression" * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched: Fix hotplug vs. set_cpus_allowed_ptr() sched/cpupri: Replace NR_CPUS arrays sched/deadline: Replace NR_CPUS arrays sched/deadline: Restrict user params max value to 2^63 ns sched/deadline: Change sched_getparam() behaviour vs SCHED_DEADLINE sched: Disallow sched_attr::sched_policy < 0 sched: Make sched_setattr() correctly return -EFBIG
2014-05-31Merge branch 'core-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull core futex/rtmutex fixes from Thomas Gleixner: "Three fixlets for long standing issues in the futex/rtmutex code unearthed by Dave Jones syscall fuzzer: - Add missing early deadlock detection checks in the futex code - Prevent user space from attaching a futex to kernel threads - Make the deadlock detector of rtmutex work again Looks large, but is more comments than code change" * 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: rtmutex: Fix deadlock detector for real futex: Prevent attaching to kernel threads futex: Add another early deadlock detection check
2014-05-28rtmutex: Fix deadlock detector for realThomas Gleixner
The current deadlock detection logic does not work reliably due to the following early exit path: /* * Drop out, when the task has no waiters. Note, * top_waiter can be NULL, when we are in the deboosting * mode! */ if (top_waiter && (!task_has_pi_waiters(task) || top_waiter != task_top_pi_waiter(task))) goto out_unlock_pi; So this not only exits when the task has no waiters, it also exits unconditionally when the current waiter is not the top priority waiter of the task. So in a nested locking scenario, it might abort the lock chain walk and therefor miss a potential deadlock. Simple fix: Continue the chain walk, when deadlock detection is enabled. We also avoid the whole enqueue, if we detect the deadlock right away (A-A). It's an optimization, but also prevents that another waiter who comes in after the detection and before the task has undone the damage observes the situation and detects the deadlock and returns -EDEADLOCK, which is wrong as the other task is not in a deadlock situation. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Reviewed-by: Steven Rostedt <rostedt@goodmis.org> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: stable@vger.kernel.org Link: http://lkml.kernel.org/r/20140522031949.725272460@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-05-28Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull two powerpc fixes from Ben Herrenschmidt: "Here's a pair of powerpc fixes for 3.15 which are also going to stable. One's a fix for building with newer binutils (the problem currently only affects the BookE kernels but the affected macro might come back into use on BookS platforms at any time). Unfortunately, the binutils maintainer did a backward incompatible change to a construct that we use so we have to add Makefile check. The other one is a fix for CPUs getting stuck in kexec when running single threaded. Since we routinely use kexec on power (including in our newer bootloaders), I deemed that important enough" * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc, kexec: Fix "Processor X is stuck" issue during kexec from ST mode powerpc: Fix 64 bit builds with binutils 2.24
2014-05-28powerpc, kexec: Fix "Processor X is stuck" issue during kexec from ST modeSrivatsa S. Bhat
If we try to perform a kexec when the machine is in ST (Single-Threaded) mode (ppc64_cpu --smt=off), the kexec operation doesn't succeed properly, and we get the following messages during boot: [ 0.089866] POWER8 performance monitor hardware support registered [ 0.089985] power8-pmu: PMAO restore workaround active. [ 5.095419] Processor 1 is stuck. [ 10.097933] Processor 2 is stuck. [ 15.100480] Processor 3 is stuck. [ 20.102982] Processor 4 is stuck. [ 25.105489] Processor 5 is stuck. [ 30.108005] Processor 6 is stuck. [ 35.110518] Processor 7 is stuck. [ 40.113369] Processor 9 is stuck. [ 45.115879] Processor 10 is stuck. [ 50.118389] Processor 11 is stuck. [ 55.120904] Processor 12 is stuck. [ 60.123425] Processor 13 is stuck. [ 65.125970] Processor 14 is stuck. [ 70.128495] Processor 15 is stuck. [ 75.131316] Processor 17 is stuck. Note that only the sibling threads are stuck, while the primary threads (0, 8, 16 etc) boot just fine. Looking closer at the previous step of kexec, we observe that kexec tries to wakeup (bring online) the sibling threads of all the cores, before performing kexec: [ 9464.131231] Starting new kernel [ 9464.148507] kexec: Waking offline cpu 1. [ 9464.148552] kexec: Waking offline cpu 2. [ 9464.148600] kexec: Waking offline cpu 3. [ 9464.148636] kexec: Waking offline cpu 4. [ 9464.148671] kexec: Waking offline cpu 5. [ 9464.148708] kexec: Waking offline cpu 6. [ 9464.148743] kexec: Waking offline cpu 7. [ 9464.148779] kexec: Waking offline cpu 9. [ 9464.148815] kexec: Waking offline cpu 10. [ 9464.148851] kexec: Waking offline cpu 11. [ 9464.148887] kexec: Waking offline cpu 12. [ 9464.148922] kexec: Waking offline cpu 13. [ 9464.148958] kexec: Waking offline cpu 14. [ 9464.148994] kexec: Waking offline cpu 15. [ 9464.149030] kexec: Waking offline cpu 17. Instrumenting this piece of code revealed that the cpu_up() operation actually fails with -EBUSY. Thus, only the primary threads of all the cores are online during kexec, and hence this is a sure-shot receipe for disaster, as explained in commit e8e5c2155b (powerpc/kexec: Fix orphaned offline CPUs across kexec), as well as in the comment above wake_offline_cpus(). It turns out that cpu_up() was returning -EBUSY because the variable 'cpu_hotplug_disabled' was set to 1; and this disabling of CPU hotplug was done by migrate_to_reboot_cpu() inside kernel_kexec(). Now, migrate_to_reboot_cpu() was originally written with the assumption that any further code will not need to perform CPU hotplug, since we are anyway in the reboot path. However, kexec is clearly not such a case, since we depend on onlining CPUs, atleast on powerpc. So re-enable cpu-hotplug after returning from migrate_to_reboot_cpu() in the kexec path, to fix this regression in kexec on powerpc. Also, wrap the cpu_up() in powerpc kexec code within a WARN_ON(), so that we can catch such issues more easily in the future. Fixes: c97102ba963 (kexec: migrate to reboot cpu) Cc: stable@vger.kernel.org Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2014-05-23Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fixes from Ingo Molnar: "The biggest commit is an irqtime accounting loop latency fix, the rest are misc fixes all over the place: deadline scheduling, docs, numa, balancer and a bad to-idle latency fix" * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched/numa: Initialize newidle balance stats in sd_numa_init() sched: Fix updating rq->max_idle_balance_cost and rq->next_balance in idle_balance() sched: Skip double execution of pick_next_task_fair() sched: Use CPUPRI_NR_PRIORITIES instead of MAX_RT_PRIO in cpupri check sched/deadline: Fix memory leak sched/deadline: Fix sched_yield() behavior sched: Sanitize irq accounting madness sched/docbook: Fix 'make htmldocs' warnings caused by missing description
2014-05-23Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "The biggest changes are fixes for races that kept triggering Trinity crashes, plus liblockdep build fixes and smaller misc fixes. The liblockdep bits in perf/urgent are a pull mistake - they should have been in locking/urgent - but by the time I noticed other commits were added and testing was done :-/ Sorry about that" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf: Fix a race between ring_buffer_detach() and ring_buffer_attach() perf: Prevent false warning in perf_swevent_add perf: Limit perf_event_attr::sample_period to 63 bits tools/liblockdep: Remove all build files when doing make clean tools/liblockdep: Build liblockdep from tools/Makefile perf/x86/intel: Fix Silvermont's event constraints perf: Fix perf_event_init_context() perf: Fix race in removing an event
2014-05-22sched: Fix hotplug vs. set_cpus_allowed_ptr()Lai Jiangshan
Lai found that: WARNING: CPU: 1 PID: 13 at arch/x86/kernel/smp.c:124 native_smp_send_reschedule+0x2d/0x4b() ... migration_cpu_stop+0x1d/0x22 was caused by set_cpus_allowed_ptr() assuming that cpu_active_mask is always a sub-set of cpu_online_mask. This isn't true since 5fbd036b552f ("sched: Cleanup cpu_active madness"). So set active and online at the same time to avoid this particular problem. Fixes: 5fbd036b552f ("sched: Cleanup cpu_active madness") Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Gautham R. Shenoy <ego@linux.vnet.ibm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Michael wang <wangyun@linux.vnet.ibm.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Toshi Kani <toshi.kani@hp.com> Link: http://lkml.kernel.org/r/53758B12.8060609@cn.fujitsu.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-05-22sched/cpupri: Replace NR_CPUS arraysPeter Zijlstra
Tejun reported that his resume was failing due to order-3 allocations from sched_domain building. Replace the NR_CPUS arrays in there with a dynamically allocated array. Reported-by: Tejun Heo <tj@kernel.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/n/tip-7cysnkw1gik45r864t1nkudh@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-05-22sched/deadline: Replace NR_CPUS arraysPeter Zijlstra
Tejun reported that his resume was failing due to order-3 allocations from sched_domain building. Replace the NR_CPUS arrays in there with a dynamically allocated array. Reported-by: Tejun Heo <tj@kernel.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Juri Lelli <juri.lelli@gmail.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/n/tip-kat4gl1m5a6dwy6nzuqox45e@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-05-22sched/deadline: Restrict user params max value to 2^63 nsJuri Lelli
Michael Kerrisk noticed that creating SCHED_DEADLINE reservations with certain parameters (e.g, a runtime of something near 2^64 ns) can cause a system freeze for some amount of time. The problem is that in the interface we have u64 sched_runtime; while internally we need to have a signed runtime (to cope with budget overruns) s64 runtime; At the time we setup a new dl_entity we copy the first value in the second. The cast turns out with negative values when sched_runtime is too big, and this causes the scheduler to go crazy right from the start. Moreover, considering how we deal with deadlines wraparound (s64)(a - b) < 0 we also have to restrict acceptable values for sched_{deadline,period}. This patch fixes the thing checking that user parameters are always below 2^63 ns (still large enough for everyone). It also rewrites other conditions that we check, since in __checkparam_dl we don't have to deal with deadline wraparounds and what we have now erroneously fails when the difference between values is too big. Reported-by: Michael Kerrisk <mtk.manpages@gmail.com> Suggested-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Juri Lelli <juri.lelli@gmail.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: <stable@vger.kernel.org> Cc: Dario Faggioli<raistlin@linux.it> Cc: Dave Jones <davej@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/20140513141131.20d944f81633ee937f256385@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-05-22sched/deadline: Change sched_getparam() behaviour vs SCHED_DEADLINEPeter Zijlstra
The way we read POSIX one should only call sched_getparam() when sched_getscheduler() returns either SCHED_FIFO or SCHED_RR. Given that we currently return sched_param::sched_priority=0 for all others, extend the same behaviour to SCHED_DEADLINE. Requested-by: Michael Kerrisk <mtk.manpages@gmail.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Dario Faggioli <raistlin@linux.it> Cc: linux-man <linux-man@vger.kernel.org> Cc: "Michael Kerrisk (man-pages)" <mtk.manpages@gmail.com> Cc: Juri Lelli <juri.lelli@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: <stable@vger.kernel.org> Link: http://lkml.kernel.org/r/20140512205034.GH13467@laptop.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-05-22sched: Disallow sched_attr::sched_policy < 0Peter Zijlstra
The scheduler uses policy=-1 to preserve the current policy state to implement sys_sched_setparam(), this got exposed to userspace by accident through sys_sched_setattr(), cure this. Reported-by: Michael Kerrisk <mtk.manpages@gmail.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Cc: <stable@vger.kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/20140509085311.GJ30445@twins.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-05-22sched: Make sched_setattr() correctly return -EFBIGMichael Kerrisk
The documented[1] behavior of sched_attr() in the proposed man page text is: sched_attr::size must be set to the size of the structure, as in sizeof(struct sched_attr), if the provided structure is smaller than the kernel structure, any additional fields are assumed '0'. If the provided structure is larger than the kernel structure, the kernel verifies all additional fields are '0' if not the syscall will fail with -E2BIG. As currently implemented, sched_copy_attr() returns -EFBIG for for this case, but the logic in sys_sched_setattr() converts that error to -EFAULT. This patch fixes the behavior. [1] http://thread.gmane.org/gmane.linux.kernel/1615615/focus=1697760 Signed-off-by: Michael Kerrisk <mtk.manpages@gmail.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: <stable@vger.kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/536CEC17.9070903@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-05-21Merge branch 'for-3.15-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull more cgroup fixes from Tejun Heo: "Three more patches to fix cgroup_freezer breakage due to the recent cgroup internal locking changes - an operation cgroup_freezer was using now requires sleepable context and cgroup_freezer was invoking that while holding a spin lock. cgroup_freezer was using an overly elaborate hierarchical locking scheme. While it's possible to convert the hierarchical spinlocks directly to mutexes, this patch simplifies the overall locking so that it uses a global mutex. This has the added benefit of avoiding iterating potentially huge number of tasks under a spinlock. While the patch is on the larger side in the devel cycle, the changes made are mostly straight-forward and the locking logic is a lot simpler afterwards" * 'for-3.15-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: cgroup: fix rcu_read_lock() leak in update_if_frozen() cgroup_freezer: replace freezer->lock with freezer_mutex cgroup: introduce task_css_is_root()
2014-05-20Merge branch 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer fix from Thomas Gleixner: "A single bug fix for a long standing issue: - Updating the expiry value of a relative timer _after_ letting the idle logic select a target cpu for the timer based on its stale expiry value is outright stupid. Thanks to Viresh for spotting the brainfart" * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: hrtimer: Set expiry time before switch_hrtimer_base()
2014-05-19perf: Fix a race between ring_buffer_detach() and ring_buffer_attach()Peter Zijlstra
Alexander noticed that we use RCU iteration on rb->event_list but do not use list_{add,del}_rcu() to add,remove entries to that list, nor do we observe proper grace periods when re-using the entries. Merge ring_buffer_detach() into ring_buffer_attach() such that attaching to the NULL buffer is detaching. Furthermore, ensure that between any 'detach' and 'attach' of the same event we observe the required grace period, but only when strictly required. In effect this means that only ioctl(.request = PERF_EVENT_IOC_SET_OUTPUT) will wait for a grace period, while the normal initial attach and final detach will not be delayed. This patch should, I think, do the right thing under all circumstances, the 'normal' cases all should never see the extra grace period, but the two cases: 1) PERF_EVENT_IOC_SET_OUTPUT on an event which already has a ring_buffer set, will now observe the required grace period between removing itself from the old and attaching itself to the new buffer. This case is 'simple' in that both buffers are present in perf_event_set_output() one could think an unconditional synchronize_rcu() would be sufficient; however... 2) an event that has a buffer attached, the buffer is destroyed (munmap) and then the event is attached to a new/different buffer using PERF_EVENT_IOC_SET_OUTPUT. This case is more complex because the buffer destruction does: ring_buffer_attach(.rb = NULL) followed by the ioctl() doing: ring_buffer_attach(.rb = foo); and we still need to observe the grace period between these two calls due to us reusing the event->rb_entry list_head. In order to make 2 happen we use Paul's latest cond_synchronize_rcu() call. Cc: Paul Mackerras <paulus@samba.org> Cc: Stephane Eranian <eranian@google.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Reported-by: Alexander Shishkin <alexander.shishkin@linux.intel.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20140507123526.GD13658@twins.programming.kicks-ass.net Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-05-19perf: Prevent false warning in perf_swevent_addJiri Olsa
The perf cpu offline callback takes down all cpu context events and releases swhash->swevent_hlist. This could race with task context software event being just scheduled on this cpu via perf_swevent_add while cpu hotplug code already cleaned up event's data. The race happens in the gap between the cpu notifier code and the cpu being actually taken down. Note that only cpu ctx events are terminated in the perf cpu hotplug code. It's easily reproduced with: $ perf record -e faults perf bench sched pipe while putting one of the cpus offline: # echo 0 > /sys/devices/system/cpu/cpu1/online Console emits following warning: WARNING: CPU: 1 PID: 2845 at kernel/events/core.c:5672 perf_swevent_add+0x18d/0x1a0() Modules linked in: CPU: 1 PID: 2845 Comm: sched-pipe Tainted: G W 3.14.0+ #256 Hardware name: Intel Corporation Montevina platform/To be filled by O.E.M., BIOS AMVACRB1.86C.0066.B00.0805070703 05/07/2008 0000000000000009 ffff880077233ab8 ffffffff81665a23 0000000000200005 0000000000000000 ffff880077233af8 ffffffff8104732c 0000000000000046 ffff88007467c800 0000000000000002 ffff88007a9cf2a0 0000000000000001 Call Trace: [<ffffffff81665a23>] dump_stack+0x4f/0x7c [<ffffffff8104732c>] warn_slowpath_common+0x8c/0xc0 [<ffffffff8104737a>] warn_slowpath_null+0x1a/0x20 [<ffffffff8110fb3d>] perf_swevent_add+0x18d/0x1a0 [<ffffffff811162ae>] event_sched_in.isra.75+0x9e/0x1f0 [<ffffffff8111646a>] group_sched_in+0x6a/0x1f0 [<ffffffff81083dd5>] ? sched_clock_local+0x25/0xa0 [<ffffffff811167e6>] ctx_sched_in+0x1f6/0x450 [<ffffffff8111757b>] perf_event_sched_in+0x6b/0xa0 [<ffffffff81117a4b>] perf_event_context_sched_in+0x7b/0xc0 [<ffffffff81117ece>] __perf_event_task_sched_in+0x43e/0x460 [<ffffffff81096f1e>] ? put_lock_stats.isra.18+0xe/0x30 [<ffffffff8107b3c8>] finish_task_switch+0xb8/0x100 [<ffffffff8166a7de>] __schedule+0x30e/0xad0 [<ffffffff81172dd2>] ? pipe_read+0x3e2/0x560 [<ffffffff8166b45e>] ? preempt_schedule_irq+0x3e/0x70 [<ffffffff8166b45e>] ? preempt_schedule_irq+0x3e/0x70 [<ffffffff8166b464>] preempt_schedule_irq+0x44/0x70 [<ffffffff816707f0>] retint_kernel+0x20/0x30 [<ffffffff8109e60a>] ? lockdep_sys_exit+0x1a/0x90 [<ffffffff812a4234>] lockdep_sys_exit_thunk+0x35/0x67 [<ffffffff81679321>] ? sysret_check+0x5/0x56 Fixing this by tracking the cpu hotplug state and displaying the WARN only if current cpu is initialized properly. Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: stable@vger.kernel.org Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1396861448-10097-1-git-send-email-jolsa@redhat.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-05-19perf: Limit perf_event_attr::sample_period to 63 bitsPeter Zijlstra
Vince reported that using a large sample_period (one with bit 63 set) results in wreckage since while the sample_period is fundamentally unsigned (negative periods don't make sense) the way we implement things very much rely on signed logic. So limit sample_period to 63 bits to avoid tripping over this. Reported-by: Vince Weaver <vincent.weaver@maine.edu> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: stable@vger.kernel.org Link: http://lkml.kernel.org/n/tip-p25fhunibl4y3qi0zuqmyf4b@git.kernel.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-05-19futex: Prevent attaching to kernel threadsThomas Gleixner
We happily allow userspace to declare a random kernel thread to be the owner of a user space PI futex. Found while analysing the fallout of Dave Jones syscall fuzzer. We also should validate the thread group for private futexes and find some fast way to validate whether the "alleged" owner has RW access on the file which backs the SHM, but that's a separate issue. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Dave Jones <davej@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Darren Hart <darren@dvhart.com> Cc: Davidlohr Bueso <davidlohr@hp.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Clark Williams <williams@redhat.com> Cc: Paul McKenney <paulmck@linux.vnet.ibm.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Roland McGrath <roland@hack.frob.com> Cc: Carlos ODonell <carlos@redhat.com> Cc: Jakub Jelinek <jakub@redhat.com> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Link: http://lkml.kernel.org/r/20140512201701.194824402@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: stable@vger.kernel.org
2014-05-19futex: Add another early deadlock detection checkThomas Gleixner
Dave Jones trinity syscall fuzzer exposed an issue in the deadlock detection code of rtmutex: http://lkml.kernel.org/r/20140429151655.GA14277@redhat.com That underlying issue has been fixed with a patch to the rtmutex code, but the futex code must not call into rtmutex in that case because - it can detect that issue early - it avoids a different and more complex fixup for backing out If the user space variable got manipulated to 0x80000000 which means no lock holder, but the waiters bit set and an active pi_state in the kernel is found we can figure out the recursive locking issue by looking at the pi_state owner. If that is the current task, then we can safely return -EDEADLK. The check should have been added in commit 59fa62451 (futex: Handle futex_pi OWNER_DIED take over correctly) already, but I did not see the above issue caused by user space manipulation back then. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Dave Jones <davej@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Darren Hart <darren@dvhart.com> Cc: Davidlohr Bueso <davidlohr@hp.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Clark Williams <williams@redhat.com> Cc: Paul McKenney <paulmck@linux.vnet.ibm.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Roland McGrath <roland@hack.frob.com> Cc: Carlos ODonell <carlos@redhat.com> Cc: Jakub Jelinek <jakub@redhat.com> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Link: http://lkml.kernel.org/r/20140512201701.097349971@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: stable@vger.kernel.org
2014-05-13cgroup: fix rcu_read_lock() leak in update_if_frozen()Tejun Heo
While updating cgroup_freezer locking, 68fafb77d827 ("cgroup_freezer: replace freezer->lock with freezer_mutex") introduced a bug in update_if_frozen() where it returns with rcu_read_lock() held. Fix it by adding rcu_read_unlock() before returning. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: kbuild test robot <fengguang.wu@intel.com>
2014-05-13cgroup_freezer: replace freezer->lock with freezer_mutexTejun Heo
After 96d365e0b86e ("cgroup: make css_set_lock a rwsem and rename it to css_set_rwsem"), css task iterators requires sleepable context as it may block on css_set_rwsem. I missed that cgroup_freezer was iterating tasks under IRQ-safe spinlock freezer->lock. This leads to errors like the following on freezer state reads and transitions. BUG: sleeping function called from invalid context at /work /os/work/kernel/locking/rwsem.c:20 in_atomic(): 0, irqs_disabled(): 0, pid: 462, name: bash 5 locks held by bash/462: #0: (sb_writers#7){.+.+.+}, at: [<ffffffff811f0843>] vfs_write+0x1a3/0x1c0 #1: (&of->mutex){+.+.+.}, at: [<ffffffff8126d78b>] kernfs_fop_write+0xbb/0x170 #2: (s_active#70){.+.+.+}, at: [<ffffffff8126d793>] kernfs_fop_write+0xc3/0x170 #3: (freezer_mutex){+.+...}, at: [<ffffffff81135981>] freezer_write+0x61/0x1e0 #4: (rcu_read_lock){......}, at: [<ffffffff81135973>] freezer_write+0x53/0x1e0 Preemption disabled at:[<ffffffff81104404>] console_unlock+0x1e4/0x460 CPU: 3 PID: 462 Comm: bash Not tainted 3.15.0-rc1-work+ #10 Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011 ffff88000916a6d0 ffff88000e0a3da0 ffffffff81cf8c96 0000000000000000 ffff88000e0a3dc8 ffffffff810cf4f2 ffffffff82388040 ffff880013aaf740 0000000000000002 ffff88000e0a3de8 ffffffff81d05974 0000000000000246 Call Trace: [<ffffffff81cf8c96>] dump_stack+0x4e/0x7a [<ffffffff810cf4f2>] __might_sleep+0x162/0x260 [<ffffffff81d05974>] down_read+0x24/0x60 [<ffffffff81133e87>] css_task_iter_start+0x27/0x70 [<ffffffff8113584d>] freezer_apply_state+0x5d/0x130 [<ffffffff81135a16>] freezer_write+0xf6/0x1e0 [<ffffffff8112eb88>] cgroup_file_write+0xd8/0x230 [<ffffffff8126d7b7>] kernfs_fop_write+0xe7/0x170 [<ffffffff811f0756>] vfs_write+0xb6/0x1c0 [<ffffffff811f121d>] SyS_write+0x4d/0xc0 [<ffffffff81d08292>] system_call_fastpath+0x16/0x1b freezer->lock used to be used in hot paths but that time is long gone and there's no reason for the lock to be IRQ-safe spinlock or even per-cgroup. In fact, given the fact that a cgroup may contain large number of tasks, it's not a good idea to iterate over them while holding IRQ-safe spinlock. Let's simplify locking by replacing per-cgroup freezer->lock with global freezer_mutex. This also makes the comments explaining the intricacies of policy inheritance and the locking around it as the states are protected by a common mutex. The conversion is mostly straight-forward. The followings are worth mentioning. * freezer_css_online() no longer needs double locking. * freezer_attach() now performs propagation simply while holding freezer_mutex. update_if_frozen() race no longer exists and the comment is removed. * freezer_fork() now tests whether the task is in root cgroup using the new task_css_is_root() without doing rcu_read_lock/unlock(). If not, it grabs freezer_mutex and performs the operation. * freezer_read() and freezer_change_state() grab freezer_mutex across the whole operation and pin the css while iterating so that each descendant processing happens in sleepable context. Fixes: 96d365e0b86e ("cgroup: make css_set_lock a rwsem and rename it to css_set_rwsem") Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com>
2014-05-13cgroup: introduce task_css_is_root()Tejun Heo
Determining the css of a task usually requires RCU read lock as that's the only thing which keeps the returned css accessible till its reference is acquired; however, testing whether a task belongs to the root can be performed without dereferencing the returned css by comparing the returned pointer against the root one in init_css_set[] which never changes. Implement task_css_is_root() which can be invoked in any context. This will be used by the scheduled cgroup_freezer change. v2: cgroup no longer supports modular controllers. No need to export init_css_set. Pointed out by Li. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com>
2014-05-13Merge branch 'for-3.15-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq Pull workqueue fixes from Tejun Heo: "Fixes for two bugs in workqueue. One is exiting with internal mutex held in a failure path of wq_update_unbound_numa(). The other is a subtle and unlikely use-after-possible-last-put in the rescuer logic. Both have been around for quite some time now and are unlikely to have triggered noticeably often. All patches are marked for -stable backport" * 'for-3.15-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: workqueue: fix a possible race condition between rescuer and pwq-release workqueue: make rescuer_thread() empty wq->maydays list before exiting workqueue: fix bugs in wq_update_unbound_numa() failure path
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup fixes from Tejun Heo: "During recent restructuring, device_cgroup unified config input check and enforcement logic; unfortunately, it turned out to share too much. Aristeu's patches fix the breakage and marked for -stable backport. The other two patches are fallouts from kernfs conversion. The blkcg change is temporary and will go away once kernfs internal locking gets simplified (patches pending)" * 'for-3.15-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: blkcg: use trylock on blkcg_pol_mutex in blkcg_reset_stats() device_cgroup: check if exception removal is allowed device_cgroup: fix the comment format for recently added functions device_cgroup: rework device access check and exception checking cgroup: fix the retry path of cgroup_mount()
2014-05-12hrtimer: Set expiry time before switch_hrtimer_base()Viresh Kumar
switch_hrtimer_base() calls hrtimer_check_target() which ensures that we do not migrate a timer to a remote cpu if the timer expires before the current programmed expiry time on that remote cpu. But __hrtimer_start_range_ns() calls switch_hrtimer_base() before the new expiry time is set. So the sanity check in hrtimer_check_target() is operating on stale or even uninitialized data. Update expiry time before calling switch_hrtimer_base(). [ tglx: Rewrote changelog once again ] Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Cc: linaro-kernel@lists.linaro.org Cc: linaro-networking@linaro.org Cc: fweisbec@gmail.com Cc: arvind.chauhan@arm.com Link: http://lkml.kernel.org/r/81999e148745fc51bbcd0615823fbab9b2e87e23.1399882253.git.viresh.kumar@linaro.org Cc: stable@vger.kernel.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
