path: root/kernel
2008-06-23Merge branch 'linus' into tracing/ftracetip-tracing-ftrace-2008-06-23_09.11_MonIngo Molnar
2008-06-20Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: softlockup: fix NMI hangs due to lock race - 2.6.26-rc regression rcupreempt: remove export of rcu_batches_completed_bh cpuset: limit the input of cpuset.sched_relax_domain_level
2008-06-19sched, delay accounting: fix incorrect delay time when constantly waiting on ↵Bharath Ravi
runqueue This patch corrects the incorrect value of per process run-queue wait time reported by delay statistics. The anomaly was due to the following reason. When a process leaves the CPU and immediately starts waiting for CPU on the runqueue (which means it remains in the TASK_RUNNABLE state), the time of re-entry into the run-queue is never recorded. Due to this, the waiting time on the runqueue from this point of re-entry upto the next time it hits the CPU is not accounted for. This is solved by recording the time of re-entry of a process leaving the CPU in the sched_info_depart() function IF the process will go back to waiting on the run-queue. This IF condition is verified by checking whether the process is still in the TASK_RUNNABLE state. The patch was tested on 2.6.26-rc6 using two simple CPU hog programs. The values noted prior to the fix did not account for the time spent on the runqueue waiting. After the fix, the correct values were reported back to user space. Signed-off-by: Bharath Ravi <bharathravi1@gmail.com> Signed-off-by: Madhava K R <madhavakr@gmail.com> Cc: dhaval@linux.vnet.ibm.com Cc: vatsa@in.ibm.com Cc: balbir@in.ibm.com Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-19softlockup: fix NMI hangs due to lock race - 2.6.26-rc regressionJason Wessel
The touch_nmi_watchdog() routine on x86 ultimately calls touch_softlockup_watchdog(). The problem is that to touch the softlockup watchdog, the cpu_clock code has to be called which could involve multiple cpu locks and can lead to a hard hang if one of the locks is held by a processor that is not going to return anytime soon (such as could be the case with kgdb or perhaps even with some other kind of exception). This patch causes the public version of the touch_softlockup_watchdog() to defer the cpu clock access to a later point. The test case for this problem is to use the following kernel config options: CONFIG_KGDB_TESTS=y CONFIG_KGDB_TESTS_ON_BOOT=y CONFIG_KGDB_TESTS_BOOT_STRING="V1F100I100000" It should be noted that kgdb test suite and these options were not available until 2.6.26-rc2, so it was necessary to patch the kgdb test suite during the bisection. I would consider this patch a regression fix because the problem first appeared in commit 27ec4407790d075c325e1f4da0a19c56953cce23 when some logic was added to try to periodically sync the clocks. It was possible to work around this particular problem by simply not performing the sync anytime the system was in a critical context. This was ok until commit 3e51f33fcc7f55e6df25d15b55ed10c8b4da84cd, which added config option CONFIG_HAVE_UNSTABLE_SCHED_CLOCK and some multi-cpu locks to sync the clocks. It became clear that accessing this code from an nmi was the source of the lockups. Avoiding the access to the low level clock code from an code inside the NMI processing also fixed the problem with the 27ec44... commit. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-19rcupreempt: remove export of rcu_batches_completed_bhSteven Rostedt
In rcupreempt, rcu_batches_completed_bh is defined as a static inline in the header file. This does not need to be exported, and not only that, this breaks my PPC build. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: paulus@samba.org Cc: linuxppc-dev@ozlabs.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-06-19cpuset: limit the input of cpuset.sched_relax_domain_levelLi Zefan
We allow the inputs to be [-1 ... SD_LV_MAX), and return -EINVAL for inputs outside this range. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Paul Menage <menage@google.com> Acked-by: Paul Jackson <pj@sgi.com> Acked-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-06-19sched: CPU hotplug events must not destroy scheduler domains created by the ↵Max Krasnyansky
cpusets First issue is not related to the cpusets. We're simply leaking doms_cur. It's allocated in arch_init_sched_domains() which is called for every hotplug event. So we just keep reallocation doms_cur without freeing it. I introduced free_sched_domains() function that cleans things up. Second issue is that sched domains created by the cpusets are completely destroyed by the CPU hotplug events. For all CPU hotplug events scheduler attaches all CPUs to the NULL domain and then puts them all into the single domain thereby destroying domains created by the cpusets (partition_sched_domains). The solution is simple, when cpusets are enabled scheduler should not create default domain and instead let cpusets do that. Which is exactly what the patch does. Signed-off-by: Max Krasnyansky <maxk@qualcomm.com> Cc: pj@sgi.com Cc: menage@google.com Cc: rostedt@goodmis.org Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-06-19sched: rt-group: fix RR bugletPeter Zijlstra
In tick_task_rt() we first call update_curr_rt() which can dequeue a runqueue due to it running out of runtime, and then we try to requeue it, of it also having exhausted its RR quota. Obviously requeueing something that is no longer on the runqueue will not have the expected result. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Tested-by: Daniel K. <dk@uw.no> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-19sched: rt-group: heirarchy aware throttlePeter Zijlstra
The bandwidth throttle code dequeues a group when it runs out of quota, and re-queues it once the period rolls over and the quota gets refreshed. Sadly it failed to take the hierarchy into consideration. Share more of the enqueue/dequeue code with regular task opterations. Also, some operations like sched_setscheduler() can dequeue/enqueue tasks that are in throttled runqueues, we should not inadvertly re-enqueue empty runqueues so check for that. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Tested-by: Daniel K. <dk@uw.no> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-19sched: rt-group: fix hierarchyPeter Zijlstra
Don't re-set the entity's runqueue to the wrong rq after we've set it to the right one. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Tested-by: Daniel K. <dk@uw.no> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-19sched: NULL pointer dereference while setting sched_rt_period_usDario Faggioli
When CONFIG_RT_GROUP_SCHED and CONFIG_CGROUP_SCHED are enabled, with: echo 10000 > /proc/sys/kernel/sched_rt_period_us We get this: BUG: unable to handle kernel NULL pointer dereference at 0000008c [ 947.682233] IP: [<c0216b72>] __rt_schedulable+0x12/0x160 [ 947.683123] *pde = 00000000=20 [ 947.683782] Oops: 0000 [#1] [ 947.684307] Modules linked in: [ 947.684308] [ 947.684308] Pid: 2359, comm: bash Not tainted (2.6.26-rc6 #8) [ 947.684308] EIP: 0060:[<c0216b72>] EFLAGS: 00000246 CPU: 0 [ 947.684308] EIP is at __rt_schedulable+0x12/0x160 [ 947.684308] EAX: 00000000 EBX: 00000000 ECX: 00000000 EDX: 00000001 [ 947.684308] ESI: c0521db4 EDI: 00000001 EBP: c6cc9f00 ESP: c6cc9ed0 [ 947.684308] DS: 007b ES: 007b FS: 0000 GS: 0033 SS: 0068 [ 947.684308] Process bash (pid: 2359, tiÆcc8000 taskÇa54f00=20 task.tiÆcc8000) [ 947.684308] Stack: c0222790 00000000 080f8c08 c0521db4 c6cc9f00 00000001 00000000 00000000 [ 947.684308] c6cc9f9c 00000000 c0521db4 00000001 c6cc9f28 c0216d40 00000000 00000000 [ 947.684308] c6cc9f9c 000f4240 000e7ef0 ffffffff c0521db4 c79dfb60 c6cc9f58 c02af2cc [ 947.684308] Call Trace: [ 947.684308] [<c0222790>] ? do_proc_dointvec_conv+0x0/0x50 [ 947.684308] [<c0216d40>] ? sched_rt_handler+0x80/0x110 [ 947.684308] [<c02af2cc>] ? proc_sys_call_handler+0x9c/0xb0 [ 947.684308] [<c02af2fa>] ? proc_sys_write+0x1a/0x20 [ 947.684308] [<c0273c36>] ? vfs_write+0x96/0x160 [ 947.684308] [<c02af2e0>] ? proc_sys_write+0x0/0x20 [ 947.684308] [<c027423d>] ? sys_write+0x3d/0x70 [ 947.684308] [<c0202ef5>] ? sysenter_past_esp+0x6a/0x91 [ 947.684308] ======================= [ 947.684308] Code: 24 04 e8 62 b1 0e 00 89 c7 89 f8 8b 5d f4 8b 75 f8 8b 7d fc 89 ec 5d c3 90 55 89 e5 57 56 53 83 ec 24 89 45 ec 89 55 e4 89 4d e8 <8b> b8 8c 00 00 00 85 ff 0f 84 c9 00 00 00 8b 57 24 39 55 e8 8b [ 947.684308] EIP: [<c0216b72>] __rt_schedulable+0x12/0x160 SS:ESP 0068:c6cc9ed0 We think the following patch solves the issue. Signed-off-by: Dario Faggioli <raistlin@linux.it> Signed-off-by: Michael Trimarchi <trimarchimichael@yahoo.it> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-17sched: fix defined-but-unused warningRabin Vincent
Fix this warning, which appears with !CONFIG_SMP: kernel/sched.c:1216: warning: `init_hrtick' defined but not used Signed-off-by: Rabin Vincent <rabin@rab.in> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-16namespacecheck: fixesIngo Molnar
2008-06-16Merge branch 'linus' into tracing/ftracetip-tracing-ftrace-2008-06-16_09.26_Montip-tracing-ftrace-2008-06-16_09.16_MonIngo Molnar
2008-06-14ftrace: fix "notrace" filtering priorityAbhishek Sagar
This is a fix to give notrace filter rules priority over "set_ftrace_filter" rules. This fix ensures that functions which are set to be filtered and are concurrently marked as "notrace" don't get recorded. As of now, if a record is marked as FTRACE_FL_FILTER and is enabled, then the notrace flag is not checked. Tested on x86-32. Signed-off-by: Abhishek Sagar <sagar.abhishek@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-12kprobes: fix error checking of batch registrationMasami Hiramatsu
Fix error checking routine to catch an error which occurs in first __register_*probe(). Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: David Miller <davem@davemloft.net> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-12Merge branch 'sched-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: 64-bit: fix arithmetics overflow sched: fair group: fix overflow(was: fix divide by zero) sched: fix TASK_WAKEKILL vs SIGKILL race
2008-06-12sched: 64-bit: fix arithmetics overflowLai Jiangshan
(overflow means weight >= 2^32 here, because inv_weigh = 2^32/weight) A weight of a cfs_rq is the sum of weights of which entities are queued on this cfs_rq, so it will overflow when there are too many entities. Although, overflow occurs very rarely, but it break fairness when it occurs. 64-bits systems have more memory than 32-bit systems and 64-bit systems can create more process usually, so overflow may occur more frequently. This patch guarantees fairness when overflow happens on 64-bit systems. Thanks to the optimization of compiler, it changes nothing on 32-bit. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-12sched: fair group: fix overflow(was: fix divide by zero)Lai Jiangshan
I found a bug which can be reproduced by this way:(linux-2.6.26-rc5, x86-64) (use 2^32, 2^33, ...., 2^63 as shares value) # mkdir /dev/cpuctl # mount -t cgroup -o cpu cpuctl /dev/cpuctl # cd /dev/cpuctl # mkdir sub # echo 0x8000000000000000 > sub/cpu.shares # echo $$ > sub/tasks oops here! divide by zero. This is because do_div() expects the 2th parameter to be 32 bits, but unsigned long is 64 bits in x86_64. Peter Zijstra pointed it out that the sane thing to do is limit the shares value to something smaller instead of using an even more expensive divide. Also, I found another bug about "the shares value is too large": pid1 and pid2 are set affinity to cpu#0 pid1 is attached to cg1 and pid2 is attached to cg2 if cg1/cpu.shares = 1024 cg2/cpu.shares = 2000000000 then pid2 got 100% usage of cpu, and pid1 0% if cg1/cpu.shares = 1024 cg2/cpu.shares = 20000000000 then pid2 got 0% usage of cpu, and pid1 100% And a weight of a cfs_rq is the sum of weights of which entities are queued on this cfs_rq, so the shares value should be limited to a smaller value. I think that (1UL << 18) is a good limited value: 1) it's not too large, we can create a lot of group before overflow 2) it's several times the weight value for nice=-19 (not too small) Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-12ftrace: fix printoutJiri Slaby
Do not print loglevel before "entries of %ld bytes". Move it to the previous pr_info. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-10ftrace: disable tracing when current_tracer is set to "none"Ankita Garg
Found that inspite of setting the current_tracer to "none", trace from the previous trace type continued to be collected. The patch below fixes this and causes the trace to be disabled when the "none" type is selected. Compile and boot tested the patch for functionality. Signed-off-by: Ankita Garg <ankita@in.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-10sched: sched_clock() lockdep fixIngo Molnar
Sitsofe Wheeler bisected the following commit to cause a lockdep to warn about itself and turn itself off: > commit c6531cce6e6e4b99bcda46b6268d6f2d9e30aea4 > Author: Ingo Molnar <mingo@elte.hu> > Date: Mon May 12 21:21:14 2008 +0200 > > sched: do not trace sched_clock do not use raw irq flags in cpu_clock() as it causes lockdep to lose track of the true state of the IRQ flag. Reported-and-bisected-by: Sitsofe Wheeler <sitsofe@yahoo.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2008-06-10ftrace: prevent freeing of all failed updatesAbhishek Sagar
Steven Rostedt wrote: > If we unload a module and reload it, will it ever get converted again? The intent was always to filter core kernel functions to prevent their freeing. Here's a fix which should allow re-recording of module call-sites. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-10ftrace: add debugfs entry 'failures'Abhishek Sagar
Identify functions which had their mcount call-site updates failed. This can help us track functions which ftrace shouldn't fiddle with, and are thus not being traced. If there is no race with any external agent which is modifying the mcount call-site, then this file displays no entries (normal case). Signed-off-by: Abhishek Sagar <sagar.abhishek@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-10ftrace: remove ftrace_ip_converted()Abhishek Sagar
Remove the unneeded function ftrace_ip_converted(). Signed-off-by: Abhishek Sagar <sagar.abhishek@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
Prevent freeing of records which cause problems and correspond to function from core kernel text. A new flag, FTRACE_FL_CONVERTED is used to mark a record as "converted". All other records are patched lazily to NOPs. Failed records now also remain on frace_hash table. Each invocation of ftrace_record_ip now checks whether the traced function has ever been recorded (including past failures) and doesn't re-record it again. Signed-off-by: Abhishek Sagar <sagar.abhishek@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-10sched: fix TASK_WAKEKILL vs SIGKILL raceOleg Nesterov
schedule() has the special "TASK_INTERRUPTIBLE && signal_pending()" case, this allows us to do current->state = TASK_INTERRUPTIBLE; schedule(); without fear to sleep with pending signal. However, the code like current->state = TASK_KILLABLE; schedule(); is not right, schedule() doesn't take TASK_WAKEKILL into account. This means that mutex_lock_killable(), wait_for_completion_killable(), down_killable(), schedule_timeout_killable() can miss SIGKILL (and btw the second SIGKILL has no effect). Introduce the new helper, signal_pending_state(), and change schedule() to use it. Hopefully it will have more users, that is why the task's state is passed separately. Note this "__TASK_STOPPED | __TASK_TRACED" check in signal_pending_state(). This is needed to preserve the current behaviour (ptrace_notify). I hope this check will be removed soon, but this (afaics good) change needs the separate discussion. The fast path is "(state & (INTERRUPTIBLE | WAKEKILL)) + signal_pending(p)", basically the same that schedule() does now. However, this patch of course bloats schedule(). Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-06Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/chrisw/lsm-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/chrisw/lsm-2.6: capabilities: remain source compatible with 32-bit raw legacy capability support. LSM: remove stale web site from MAINTAINERS
2008-06-06cpusets: fix bug when adding nonexistent cpu or memLai Jiangshan
Adding a nonexistent cpu to a cpuset will be omitted quietly. It should return -EINVAL. Example: (real_nr_cpus <= 4 < NR_CPUS or cpu#4 was just offline) # cat cpus 0-1 # /bin/echo 4 > cpus # /bin/echo $? 0 # cat cpus # The same occurs when add a nonexistent mem. This patch will fix this bug. And when *buf == "", the check is unneeded. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: Paul Jackson <pj@sgi.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-04Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb: kgdbts: Use HW breakpoints with CONFIG_DEBUG_RODATA kgdb: use common ascii helpers and put_unaligned_be32 helper
2008-06-02ftrace: user update and disable dynamic ftrace daemonSteven Rostedt
In dynamic ftrace, the mcount function starts off pointing to a stub function that just returns. On start up, the call to the stub is modified to point to a "record_ip" function. The job of the record_ip function is to add the function to a pre-allocated hash list. If the function is already there, it simply is ignored, otherwise it is added to the list. Later, a ftraced daemon wakes up and calls kstop_machine if any functions have been recorded, and changes the calls to the recorded functions to a simple nop. If no functions were recorded, the daemon goes back to sleep. The daemon wakes up once a second to see if it needs to update any newly recorded functions into nops. Usually it does not, but if a lot of code has been executed for the first time in the kernel, the ftraced daemon will call kstop_machine to update those into nops. The problem currently is that there's no way to stop the daemon from doing this, and it can cause unneeded latencies (800us which for some is bothersome). This patch adds a new file /debugfs/tracing/ftraced_enabled. If the daemon is active, reading this will return "enabled\n" and "disabled\n" when the daemon is not running. To disable the daemon, the user can echo "0" or "disable" into this file, and "1" or "enable" to re-enable the daemon. Since the daemon is used to convert the functions into nops to increase the performance of the system, I also added that anytime something is written into the ftraced_enabled file, kstop_machine will run if there are new functions that have been detected that need to be converted. This way the user can disable the daemon but still be able to control the conversion of the mcount calls to nops by simply, "echo 0 > /debugfs/tracing/ftraced_enabled" when they need to do more conversions. To see the number of converted functions: "cat /debugfs/tracing/dyn_ftrace_total_info" Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-02ftrace: distinguish kretprobe'd functions in trace logsAbhishek Sagar
Tracing functions via ftrace which have a kretprobe installed on them, can produce misleading output in their trace logs. E.g, consider the correct trace of the following sequence: do_IRQ() { ~ irq_enter(); ~ } Trace log (sample): <idle>-0 [00] 4154504455.781616: irq_enter <- do_IRQ But if irq_enter() has a kretprobe installed on it, the return value stored on the stack at each invocation is modified to divert the return to a kprobe trampoline function called kretprobe_trampoline(). So with this the trace would (currently) look like: <idle>-0 [00] 4154504455.781616: irq_enter <- kretprobe_trampoline Now this is quite misleading to the end user, as it suggests something that didn't actually happen. So just to avoid such misinterpretations, the inlined patch aims to output such a log as: <idle>-0 [00] 4154504455.781616: irq_enter <- [unknown/kretprobe'd] Signed-off-by: Abhishek Sagar <sagar.abhishek@gmail.com> Acked-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-31capabilities: remain source compatible with 32-bit raw legacy capability ↵Andrew G. Morgan
support. Source code out there hard-codes a notion of what the _LINUX_CAPABILITY_VERSION #define means in terms of the semantics of the raw capability system calls capget() and capset(). Its unfortunate, but true. Since the confusing header file has been in a released kernel, there is software that is erroneously using 64-bit capabilities with the semantics of 32-bit compatibilities. These recently compiled programs may suffer corruption of their memory when sys_getcap() overwrites more memory than they are coded to expect, and the raising of added capabilities when using sys_capset(). As such, this patch does a number of things to clean up the situation for all. It 1. forces the _LINUX_CAPABILITY_VERSION define to always retain its legacy value. 2. adopts a new #define strategy for the kernel's internal implementation of the preferred magic. 3. deprecates v2 capability magic in favor of a new (v3) magic number. The functionality of v3 is entirely equivalent to v2, the only difference being that the v2 magic causes the kernel to log a "deprecated" warning so the admin can find applications that may be using v2 inappropriately. [User space code continues to be encouraged to use the libcap API which protects the application from details like this. libcap-2.10 is the first to support v3 capabilities.] Fixes issue reported in https://bugzilla.redhat.com/show_bug.cgi?id=447518. Thanks to Bojan Smojver for the report. [akpm@linux-foundation.org: s/depreciate/deprecate/g] [akpm@linux-foundation.org: be robust about put_user size] [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Andrew G. Morgan <morgan@kernel.org> Cc: Serge E. Hallyn <serue@us.ibm.com> Cc: Bojan Smojver <bojan@rexursive.com> Cc: stable@kernel.org Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2008-05-29Merge branch 'sched-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: re-tune NUMA topologies sched: stop wake_affine from causing serious imbalance sched: fix sched_clock_cpu() revert ("sched: fair-group: SMP-nice for group scheduling") sched: cleanup show_schedstat(): fix memleak sched: unite unlikely pairs in rt_policy() and schedule_debug() revert ("sched: fair: weight calculations")
2008-05-29Merge commit 'linus/master' into sched-fixes-for-linusIngo Molnar
2008-05-29sched: stop wake_affine from causing serious imbalanceMike Galbraith
Prevent short-running wakers of short-running threads from overloading a single cpu via wakeup affinity, and wire up disconnected debug option. Signed-off-by: Mike Galbraith <efault@gmx.de> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-29sched: fix sched_clock_cpu()Peter Zijlstra
Make sched_clock_cpu() return 0 before it has been initialized and avoid corrupting its state due to doing so. This fixes the weird printk timestamp jump reported. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
2008-05-29revert ("sched: fair-group: SMP-nice for group scheduling")Ingo Molnar
Yanmin Zhang reported: Comparing with 2.6.25, volanoMark has big regression with kernel 2.6.26-rc1. It's about 50% on my 8-core stoakley, 16-core tigerton, and Itanium Montecito. With bisect, I located the following patch: | 18d95a2832c1392a2d63227a7a6d433cb9f2037e is first bad commit | commit 18d95a2832c1392a2d63227a7a6d433cb9f2037e | Author: Peter Zijlstra <a.p.zijlstra@chello.nl> | Date: Sat Apr 19 19:45:00 2008 +0200 | | sched: fair-group: SMP-nice for group scheduling Revert it so that we get v2.6.25 behavior. Bisected-by: Yanmin Zhang <yanmin_zhang@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-29sched: cleanupIngo Molnar
2008-05-29show_schedstat(): fix memleakAdrian Bunk
The Coverity checker spotted a memleak introduced by commit 39106dcf85285e78f3b290022122c76f851379b8 (cpumask: use new cpus_scnprintf function). It seems the kfree() got lost between v2 and v3 of this patch... Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Mike Travis <travis@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-29sched: unite unlikely pairs in rt_policy() and schedule_debug()Roel Kluin
Removes obfuscation and may improve assembly. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-29revert ("sched: fair: weight calculations")Ingo Molnar
Yanmin Zhang reported: Comparing with kernel 2.6.25, sysbench+mysql(oltp, readonly) has many regressions with 2.6.26-rc1: 1) 8-core stoakley: 28%; 2) 16-core tigerton: 20%; 3) Itanium Montvale: 50%. Bisect located this patch: | 8f1bc385cfbab474db6c27b5af1e439614f3025c is first bad commit | commit 8f1bc385cfbab474db6c27b5af1e439614f3025c | Author: Peter Zijlstra <a.p.zijlstra@chello.nl> | Date: Sat Apr 19 19:45:00 2008 +0200 | | sched: fair: weight calculations Revert it to the 2.6.25 state. Bisected-by: Yanmin Zhang <yanmin_zhang@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-28kgdb: use common ascii helpers and put_unaligned_be32 helperHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2008-05-28splice: fix sendfile() issue with relayTom Zanussi
Splice isn't always incrementing the ppos correctly, which broke relay splice. Signed-off-by: Tom Zanussi <zanussi@comcast.net> Tested-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-05-26ftrace: fix updating of ftrace_update_cntAbhishek Sagar
Hi Ingo/Steven, Ftrace currently maintains an update count which includes false updates, i.e, updates which failed. If anything, such failures should be tracked by some separate variable, but this patch provides a minimal fix. Signed-off-by: Abhishek Sagar <sagar.abhishek@gmail.com> Cc: rostedt@goodmis.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-26ftrace: safe traversal of ftrace_hash hlistAbhishek Sagar
Hi Steven, I noticed that concurrent instances of ftrace_record_ip() have a race between ftrace_hash list traversal during ftrace_ip_in_hash() (before acquiring ftrace_shutdown_lock) and ftrace_add_hash(). If it's so then this should fix it. Signed-off-by: Abhishek Sagar <sagar.abhishek@gmail.com> Cc: rostedt@goodmis.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-26ftrace: fix up cmdline recordingSteven Rostedt
The new work with converting the trace hooks over to markers broke the command line recording of ftrace. This patch fixes it again. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-26ftrace: set_ftrace_notrace featureSteven Rostedt
While debugging latencies in the RT kernel, I found that it would be nice to be able to filter away functions from the trace than just to filter on functions. I added a new interface to the debugfs tracing directory called set_ftrace_notrace When dynamic frace is enabled, this lets you filter away functions that will not be recorded in the trace. It is similar to adding 'notrace' to those functions but by doing it without recompiling the kernel. Here's how set_ftrace_filter and set_ftrace_notrace interact. Remember, if set_ftrace_filter is set, it removes all functions from the trace execpt for those listed in the set_ftrace_filter. set_ftrace_notrace will prevent those functions from being traced. If you were to set one function in both set_ftrace_filter and set_ftrace_notrace and that function was the same, then you would end up with an empty trace. the set of functions to trace is: set_ftrace_filter == empty then all functions not in set_ftrace_notrace else set of the set_ftrace_filter and not in set of set_ftrace_notrace. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-26ftrace: remove printks from irqsoff traceSteven Rostedt
Printing out new max latencies was fine for the old RT tracer. But for mainline it is a bit messy. We also need to test if the run queue is locked before we can do the print. This means that we may not be printing out latencies if the run queue is locked on another CPU. This produces inconsistencies in the output. This patch simply removes the print altogether. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Cc: pq@iki.fi Cc: proski@gnu.org Cc: sandmann@redhat.com Cc: a.p.zijlstra@chello.nl Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-26ftrace: add function tracing to wake up tracingSteven Rostedt
This patch adds function tracing to the functions that are called on the CPU of the task being traced. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Cc: pq@iki.fi Cc: proski@gnu.org Cc: sandmann@redhat.com Cc: a.p.zijlstra@chello.nl Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
