commit 3c00cb5e68dc719f2fc73a33b1b230aadfcb1309 upstream.
This function can leak kernel stack data when the user siginfo_t has a
positive si_code value. The top 16 bits of si_code descibe which fields
in the siginfo_t union are active, but they are treated inconsistently
between copy_siginfo_from_user32, copy_siginfo_to_user32 and
copy_siginfo_to_user.
copy_siginfo_from_user32 is called from rt_sigqueueinfo and
rt_tgsigqueueinfo in which the user has full control overthe top 16 bits
of si_code.
This fixes the following information leaks:
x86: 8 bytes leaked when sending a signal from a 32-bit process to
itself. This leak grows to 16 bytes if the process uses x32.
(si_code = __SI_CHLD)
x86: 100 bytes leaked when sending a signal from a 32-bit process to
a 64-bit process. (si_code = -1)
sparc: 4 bytes leaked when sending a signal from a 32-bit process to a
64-bit process. (si_code = any)
parsic and s390 have similar bugs, but they are not vulnerable because
rt_[tg]sigqueueinfo have checks that prevent sending a positive si_code
to a different process. These bugs are also fixed for consistency.
Signed-off-by: Amanieu d'Antras <amanieu@gmail.com>
Cc: Chris Metcalf <cmetcalf@ezchip.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
commit 26135022f85105ad725cda103fa069e29e83bd16 upstream.
This function may copy the si_addr_lsb, si_lower and si_upper fields to
user mode when they haven't been initialized, which can leak kernel
stack data to user mode.
Just checking the value of si_code is insufficient because the same
si_code value is shared between multiple signals. This is solved by
checking the value of si_signo in addition to si_code.
commit 75a06189fc508a2acf470b0b12710362ffb2c4b1 upstream.
The resend mechanism happily calls the interrupt handler of interrupts
which are marked IRQ_NESTED_THREAD from softirq context. This can
result in crashes because the interrupt handler is not the proper way
to invoke the device handlers. They must be invoked via
handle_nested_irq.
Prevent the resend even if the interrupt has no valid parent irq
set. Its better to have a lost interrupt than a crashing machine.
Reported-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
commit 6224beb12e190ff11f3c7d4bf50cb2922878f600 upstream.
Fengguang Wu's tests triggered a bug in the branch tracer's start up
test when CONFIG_DEBUG_PREEMPT set. This was because that config
adds some debug logic in the per cpu field, which calls back into
the branch tracer.
The branch tracer has its own recursive checks, but uses a per cpu
variable to implement it. If retrieving the per cpu variable calls
back into the branch tracer, you can see how things will break.
Instead of using a per cpu variable, use the trace_recursion field
of the current task struct. Simply set a bit when entering the
branch tracing and clear it when leaving. If the bit is set on
entry, just don't do the tracing.
There's also the case with lockdep, as the local_irq_save() called
before the recursion can also trigger code that can call back into
the function. Changing that to a raw_local_irq_save() will protect
that as well.
This prevents the recursion and the inevitable crash that follows.
Link: http://lkml.kernel.org/r/20150630141803.GA28071@wfg-t540p.sh.intel.com
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Tested-by: Fengguang Wu <fengguang.wu@intel.com>
commit 6b88f44e161b9ee2a803e5b2b1fbcf4e20e8b980 upstream.
While debugging a WARN_ON() for filtering, I found that it is possible
for the filter string to be referenced after its end. With the filter:
# echo '>' > /sys/kernel/debug/events/ext4/ext4_truncate_exit/filter
The filter_parse() function can call infix_get_op() which calls
infix_advance() that updates the infix filter pointers for the cnt
and tail without checking if the filter is already at the end, which
will put the cnt to zero and the tail beyond the end. The loop then calls
infix_next() that has
ps->infix.cnt--;
return ps->infix.string[ps->infix.tail++];
The cnt will now be below zero, and the tail that is returned is
already passed the end of the filter string. So far the allocation
of the filter string usually has some buffer that is zeroed out, but
if the filter string is of the exact size of the allocated buffer
there's no guarantee that the charater after the nul terminating
character will be zero.
Luckily, only root can write to the filter.
commit b4875bbe7e68f139bd3383828ae8e994a0df6d28 upstream.
When testing the fix for the trace filter, I could not come up with
a scenario where the operand count goes below zero, so I added a
WARN_ON_ONCE(cnt < 0) to the logic. But there is legitimate case
that it can happen (although the filter would be wrong).
That is, a single operation without any operands will hit the path
where the WARN_ON_ONCE() can trigger. Although this is harmless,
and the filter is reported as a error. But instead of spitting out
a warning to the kernel dmesg, just fail nicely and report it via
the proper channels.
Link: http://lkml.kernel.org/r/558C6082.90608@oracle.com
Reported-by: Vince Weaver <vincent.weaver@maine.edu>
Reported-by: Sasha Levin <sasha.levin@oracle.com>
commit 73af963f9f3036dffed55c3a2898598186db1045 upstream.
__ptrace_may_access() checks get_dumpable/ptrace_has_cap/etc if task !=
current, this can can lead to surprising results.
For example, a sub-thread can't readlink("/proc/self/exe") if the
executable is not readable. setup_new_exec()->would_dump() notices that
inode_permission(MAY_READ) fails and then it does
set_dumpable(suid_dumpable). After that get_dumpable() fails.
(It is not clear why proc_pid_readlink() checks get_dumpable(), perhaps we
could add PTRACE_MODE_NODUMPABLE)
Change __ptrace_may_access() to use same_thread_group() instead of "task
== current". Any security check is pointless when the tasks share the
same ->mm.
Signed-off-by: Mark Grondona <mgrondona@llnl.gov>
Signed-off-by: Ben Woodard <woodard@redhat.com>
commit 2cf30dc180cea808077f003c5116388183e54f9e upstream.
When the following filter is used it causes a warning to trigger:
# cd /sys/kernel/debug/tracing
# echo "((dev==1)blocks==2)" > events/ext4/ext4_truncate_exit/filter
-bash: echo: write error: Invalid argument
# cat events/ext4/ext4_truncate_exit/filter
((dev==1)blocks==2)
parse_error: No error
WARNING: CPU: 2 PID: 1223 at kernel/trace/trace_events_filter.c:1640 replace_preds+0x3c5/0x990()
Modules linked in: bnep lockd grace bluetooth ...
CPU: 3 PID: 1223 Comm: bash Tainted: G W 4.1.0-rc3-test+ #450
Hardware name: Hewlett-Packard HP Compaq Pro 6300 SFF/339A, BIOS K01 v02.05 05/07/2012
0000000000000668 ffff8800c106bc98 ffffffff816ed4f9 ffff88011ead0cf0
0000000000000000 ffff8800c106bcd8 ffffffff8107fb07 ffffffff8136b46c
ffff8800c7d81d48 ffff8800d4c2bc00 ffff8800d4d4f920 00000000ffffffea
Call Trace:
[<ffffffff816ed4f9>] dump_stack+0x4c/0x6e
[<ffffffff8107fb07>] warn_slowpath_common+0x97/0xe0
[<ffffffff8136b46c>] ? _kstrtoull+0x2c/0x80
[<ffffffff8107fb6a>] warn_slowpath_null+0x1a/0x20
[<ffffffff81159065>] replace_preds+0x3c5/0x990
[<ffffffff811596b2>] create_filter+0x82/0xb0
[<ffffffff81159944>] apply_event_filter+0xd4/0x180
[<ffffffff81152bbf>] event_filter_write+0x8f/0x120
[<ffffffff811db2a8>] __vfs_write+0x28/0xe0
[<ffffffff811dda43>] ? __sb_start_write+0x53/0xf0
[<ffffffff812e51e0>] ? security_file_permission+0x30/0xc0
[<ffffffff811dc408>] vfs_write+0xb8/0x1b0
[<ffffffff811dc72f>] SyS_write+0x4f/0xb0
[<ffffffff816f5217>] system_call_fastpath+0x12/0x6a
---[ end trace e11028bd95818dcd ]---
Worse yet, reading the error message (the filter again) it says that
there was no error, when there clearly was. The issue is that the
code that checks the input does not check for balanced ops. That is,
having an op between a closed parenthesis and the next token.
This would only cause a warning, and fail out before doing any real
harm, but it should still not caues a warning, and the error reported
should work:
((dev==1)blocks==2)
parse_error: Meaningless filter expression
And give no kernel warning.
Link: http://lkml.kernel.org/r/20150615175025.7e809215@gandalf.local.home
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Tested-by: Vince Weaver <vincent.weaver@maine.edu>
[ luis: backported to 3.16:
- unconditionally decrement cnt as the OP_NOT logic was introduced only
by e12c09cf3087 ("tracing: Add NOT to filtering logic") ]
Signed-off-by: Luis Henriques <luis.henriques@canonical.com>
commit 108029323910c5dd1ef8fa2d10da1ce5fbce6e12 upstream.
The producer should be used producer_fifo as its sched_priority,
so correct it.
Link: http://lkml.kernel.org/r/1433923957-67842-1-git-send-email-long.wanglong@huawei.com
Signed-off-by: Wang Long <long.wanglong@huawei.com>
commit fc21c0cff2f425891b28ff6fb6b03b325c977428 upstream.
This commit was incomplete in that code to remove items from the per-cpu
lists was missing and never acquired a user in the 5 years it has been in
the tree. We're going to implement what it seems to try to archive in a
simpler way, and this code is in the way of doing so.
Cc: Jan Kara <jack@suse.cz>
Cc: Pan Xinhui <xinhuix.pan@intel.com>
commit 28423ad283d5348793b0c45cc9b1af058e776fd6 upstream.
While debugging an issue with excessive softirq usage, I encountered the
following note in commit 3e339b5dae24a706 ("softirq: Use hotplug thread
infrastructure"):
[ paulmck: Call rcu_note_context_switch() with interrupts enabled. ]
...but despite this note, the patch still calls RCU with IRQs disabled.
This seemingly innocuous change caused a significant regression in softirq
CPU usage on the sending side of a large TCP transfer (~1 GB/s): when
introducing 0.01% packet loss, the softirq usage would jump to around 25%,
spiking as high as 50%. Before the change, the usage would never exceed 5%.
Moving the call to rcu_note_context_switch() after the cond_sched() call,
as it was originally before the hotplug patch, completely eliminated this
problem.
Signed-off-by: Calvin Owens <calvinowens@fb.com>
Signed-off-by: Mike Galbraith <mgalbraith@suse.de>
commit b72c186999e689cb0b055ab1c7b3cd8fffbeb5ed upstream.
ptrace_resume() is called when the tracee is still __TASK_TRACED. We set
tracee->exit_code and then wake_up_state() changes tracee->state. If the
tracer's sub-thread does wait() in between, task_stopped_code(ptrace => T)
wrongly looks like another report from tracee.
This confuses debugger, and since wait_task_stopped() clears ->exit_code
the tracee can miss a signal.
Test-case:
#include <stdio.h>
#include <unistd.h>
#include <sys/wait.h>
#include <sys/ptrace.h>
#include <pthread.h>
#include <assert.h>
int pid;
void *waiter(void *arg)
int stat;
for (;;) {
assert(pid == wait(&stat));
assert(WIFSTOPPED(stat));
if (WSTOPSIG(stat) == SIGHUP)
continue;
assert(WSTOPSIG(stat) == SIGCONT);
printf("ERR! extra/wrong report:%x\n", stat);
int main(void)
pthread_t thread;
pid = fork();
if (!pid) {
assert(ptrace(PTRACE_TRACEME, 0,0,0) == 0);
for (;;)
kill(getpid(), SIGHUP);
assert(pthread_create(&thread, NULL, waiter, NULL) == 0);
for (;;)
ptrace(PTRACE_CONT, pid, 0, SIGCONT);
return 0;
Note for stable: the bug is very old, but without 9899d11f6544 "ptrace:
ensure arch_ptrace/ptrace_request can never race with SIGKILL" the fix
should use lock_task_sighand(child).
Reported-by: Pavel Labath <labath@google.com>
Tested-by: Pavel Labath <labath@google.com>
commit 80a9b64e2c156b6523e7a01f2ba6e5d86e722814 upstream.
It has come to my attention that this_cpu_read/write are horrible on
architectures other than x86. Worse yet, they actually disable
preemption or interrupts! This caused some unexpected tracing results
on ARM.
101.356868: preempt_count_add <-ring_buffer_lock_reserve
101.356870: preempt_count_sub <-ring_buffer_lock_reserve
The ring_buffer_lock_reserve has recursion protection that requires
accessing a per cpu variable. But since preempt_disable() is traced, it
too got traced while accessing the variable that is suppose to prevent
recursion like this.
The generic version of this_cpu_read() and write() are:
#define this_cpu_generic_read(pcp) \
({ typeof(pcp) ret__; \
preempt_disable(); \
ret__ = *this_cpu_ptr(&(pcp)); \
preempt_enable(); \
ret__; \
#define this_cpu_generic_to_op(pcp, val, op) \
do { \
unsigned long flags; \
raw_local_irq_save(flags); \
*__this_cpu_ptr(&(pcp)) op val; \
raw_local_irq_restore(flags); \
} while (0)
Which is unacceptable for locations that know they are within preempt
disabled or interrupt disabled locations.
Paul McKenney stated that __this_cpu_() versions produce much better code on
other architectures than this_cpu_() does, if we know that the call is done in
a preempt disabled location.
I also changed the recursive_unlock() to use two local variables instead
of accessing the per_cpu variable twice.
Link: http://lkml.kernel.org/r/20150317114411.GE3589@linux.vnet.ibm.com
Link: http://lkml.kernel.org/r/20150317104038.312e73d1@gandalf.local.home
Acked-by: Christoph Lameter <cl@linux.com>
Reported-by: Uwe Kleine-Koenig <u.kleine-koenig@pengutronix.de>
Tested-by: Uwe Kleine-Koenig <u.kleine-koenig@pengutronix.de>
commit 946e51f2bf37f1656916eb75bd0742ba33983c28 upstream.
Cc: Ben Hutchings <ben@decadent.org.uk>
[hujianyang: Backported to 3.10 refer to the work of Ben Hutchings in 3.2:
- Apply name changes in all the different places we use d_alias and d_child
- Move the WARN_ON() in __d_free() to d_free() as we don't have dentry_free()]
Signed-off-by: hujianyang <hujianyang@huawei.com>
commit 30a22c215a0007603ffc08021f2e8b64018517dd upstream.
commit 6ae9200f2cab7 ("enlarge console.name") increased the storage
for the console name to 16 bytes, but not the corresponding
struct console_cmdline::name storage. Console names longer than
8 bytes cause read beyond end-of-string and failure to match
console; I'm not sure if there are other unexpected consequences.
Signed-off-by: Peter Hurley <peter@hurleysoftware.com>
commit d525211f9d1be8b523ec7633f080f2116f5ea536 upstream.
Vince reported a watchdog lockup like:
[<ffffffff8115e114>] perf_tp_event+0xc4/0x210
[<ffffffff810b4f8a>] perf_trace_lock+0x12a/0x160
[<ffffffff810b7f10>] lock_release+0x130/0x260
[<ffffffff816c7474>] _raw_spin_unlock_irqrestore+0x24/0x40
[<ffffffff8107bb4d>] do_send_sig_info+0x5d/0x80
[<ffffffff811f69df>] send_sigio_to_task+0x12f/0x1a0
[<ffffffff811f71ce>] send_sigio+0xae/0x100
[<ffffffff811f72b7>] kill_fasync+0x97/0xf0
[<ffffffff8115d0b4>] perf_event_wakeup+0xd4/0xf0
[<ffffffff8115d103>] perf_pending_event+0x33/0x60
[<ffffffff8114e3fc>] irq_work_run_list+0x4c/0x80
[<ffffffff8114e448>] irq_work_run+0x18/0x40
[<ffffffff810196af>] smp_trace_irq_work_interrupt+0x3f/0xc0
[<ffffffff816c99bd>] trace_irq_work_interrupt+0x6d/0x80
Which is caused by an irq_work generating new irq_work and therefore
not allowing forward progress.
This happens because processing the perf irq_work triggers another
perf event (tracepoint stuff) which in turn generates an irq_work ad
infinitum.
Avoid this by raising the recursion counter in the irq_work -- which
effectively disables all software events (including tracepoints) from
actually triggering again.
Cc: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/r/20150219170311.GH21418@twins.programming.kicks-ass.net
PREEMPT_NONE
commit 8603e1b30027f943cc9c1eef2b291d42c3347af1 upstream.
cancel[_delayed]_work_sync() are implemented using
__cancel_work_timer() which grabs the PENDING bit using
try_to_grab_pending() and then flushes the work item with PENDING set
to prevent the on-going execution of the work item from requeueing
itself.
try_to_grab_pending() can always grab PENDING bit without blocking
except when someone else is doing the above flushing during
cancelation. In that case, try_to_grab_pending() returns -ENOENT. In
this case, __cancel_work_timer() currently invokes flush_work(). The
assumption is that the completion of the work item is what the other
canceling task would be waiting for too and thus waiting for the same
condition and retrying should allow forward progress without excessive
busy looping
Unfortunately, this doesn't work if preemption is disabled or the
latter task has real time priority. Let's say task A just got woken
up from flush_work() by the completion of the target work item. If,
before task A starts executing, task B gets scheduled and invokes
__cancel_work_timer() on the same work item, its try_to_grab_pending()
will return -ENOENT as the work item is still being canceled by task A
and flush_work() will also immediately return false as the work item
is no longer executing. This puts task B in a busy loop possibly
preventing task A from executing and clearing the canceling state on
the work item leading to a hang.
task A task B worker
executing work
set work CANCELING
flush_work()
block for work completion
completion, wakes up A
while (forever) {
-ENOENT as work is being canceled
flush_work()
false as work is no longer executing
This patch removes the possible hang by updating __cancel_work_timer()
to explicitly wait for clearing of CANCELING rather than invoking
flush_work() after try_to_grab_pending() fails with -ENOENT.
Link: http://lkml.kernel.org/g/20150206171156.GA8942@axis.com
v3: bit_waitqueue() can't be used for work items defined in vmalloc
area. Switched to custom wake function which matches the target
work item and exclusive wait and wakeup.
v2: v1 used wake_up() on bit_waitqueue() which leads to NULL deref if
the target bit waitqueue has wait_bit_queue's on it. Use
DEFINE_WAIT_BIT() and __wake_up_bit() instead. Reported by Tomeu
Vizoso.
Reported-by: Rabin Vincent <rabin.vincent@axis.com>
Cc: Tomeu Vizoso <tomeu.vizoso@gmail.com>
Tested-by: Jesper Nilsson <jesper.nilsson@axis.com>
Tested-by: Rabin Vincent <rabin.vincent@axis.com>
In 3.10.y backport patch 1dba303727f52ea062580b0a9b3f0c3b462769cf,
the logic to call pm_qos_update_target was moved to __pm_qos_update_request.
However, the original code was left in function pm_qos_update_request.
Currently, if pm_qos_update_request is called where new_value !=
req->node.prio then pm_qos_update_target will be called twice in a row.
Once in pm_qos_update_request and then again in the following call to
Removing the left over code from pm_qos_update_request stops this second
call to pm_qos_update_target where the work of removing / re-adding the
new_value in the constraints list would be duplicated.
Signed-off-by: Michael Scott <michael.scott@linaro.org>
commit 29183a70b0b828500816bd794b3fe192fce89f73 upstream.
Additional validation of adjtimex freq values to avoid
potential multiplication overflows were added in commit
5e5aeb4367b (time: adjtimex: Validate the ADJ_FREQUENCY values)
Unfortunately the patch used LONG_MAX/MIN instead of
LLONG_MAX/MIN, which was fine on 64-bit systems, but being
much smaller on 32-bit systems caused false positives
resulting in most direct frequency adjustments to fail w/
EINVAL.
ntpd only does direct frequency adjustments at startup, so
the issue was not as easily observed there, but other time
sync applications like ptpd and chrony were more effected by
the bug.
See bugs:
https://bugzilla.kernel.org/show_bug.cgi?id=92481
https://bugzilla.redhat.com/show_bug.cgi?id=1188074
This patch changes the checks to use LLONG_MAX for
clarity, and additionally the checks are disabled
on 32-bit systems since LLONG_MAX/PPM_SCALE is always
larger then the 32-bit long freq value, so multiplication
overflows aren't possible there.
Reported-by: Josh Boyer <jwboyer@fedoraproject.org>
Reported-by: George Joseph <george.joseph@fairview5.com>
Tested-by: George Joseph <george.joseph@fairview5.com>
Signed-off-by: John Stultz <john.stultz@linaro.org>
Cc: Sasha Levin <sasha.levin@oracle.com>
Link: http://lkml.kernel.org/r/1423553436-29747-1-git-send-email-john.stultz@linaro.org
[ Prettified the changelog and the comments a bit. ]
commit 146755923262037fc4c54abc28c04b1103f3cc51 upstream.
The output of KDB 'summary' command should report MemTotal, MemFree
and Buffers output in kB. Current codes report in unit of pages.
A define of K(x) as
is defined in the code, but not used.
This patch would apply the define to convert the values to kB.
Please include me on Cc on replies. I do not subscribe to linux-kernel.
Signed-off-by: Jay Lan <jlan@sgi.com>
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
commit 7215853e985a4bef1a6c14e00e89dfec84f1e457 upstream.
Commit 6edb2a8a385f0cdef51dae37ff23e74d76d8a6ce introduced
an array map_pages that contains the addresses returned by
kmap_atomic. However, when unmapping those pages, map_pages[0]
is unmapped before map_pages[1], breaking the nesting requirement
as specified in the documentation for kmap_atomic/kunmap_atomic.
This was caught by the highmem debug code present in kunmap_atomic.
Fix the loop to do the unmapping properly.
Link: http://lkml.kernel.org/r/1418871056-6614-1-git-send-email-markivx@codeaurora.org
Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
Reported-by: Lime Yang <limey@codeaurora.org>
Signed-off-by: Vikram Mulukutla <markivx@codeaurora.org>
commit 4bee96860a65c3a62d332edac331b3cf936ba3ad upstream.
The following race exists in the smpboot percpu threads management:
CPU0 CPU1
cpu_up(2)
get_online_cpus();
smpboot_create_threads(2);
smpboot_register_percpu_thread();
for_each_online_cpu();
__smpboot_create_thread();
__cpu_up(2);
This results in a missing per cpu thread for the newly onlined cpu2 and
in a NULL pointer dereference on a consecutive offline of that cpu.
Proctect smpboot_register_percpu_thread() with get_online_cpus() to
prevent that.
[ tglx: Massaged changelog and removed the change in
smpboot_unregister_percpu_thread() because that's an
optimization and therefor not stable material. ]
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/1406777421-12830-1-git-send-email-laijs@cn.fujitsu.com
commit 29187a9eeaf362d8422e62e17a22a6e115277a49 upstream.
A worker_pool's forward progress is guaranteed by the fact that the
last idle worker assumes the manager role to create more workers and
summon the rescuers if creating workers doesn't succeed in timely
manner before proceeding to execute work items.
This manager role is implemented in manage_workers(), which indicates
whether the worker may proceed to work item execution with its return
value. This is necessary because multiple workers may contend for the
manager role, and, if there already is a manager, others should
proceed to work item execution.
Unfortunately, the function also indicates that the worker may proceed
to work item execution if need_to_create_worker() is false at the head
of the function. need_to_create_worker() tests the following
conditions.
pending work items && !nr_running && !nr_idle
The first and third conditions are protected by pool->lock and thus
won't change while holding pool->lock; however, nr_running can change
asynchronously as other workers block and resume and while it's likely
to be zero, as someone woke this worker up in the first place, some
other workers could have become runnable inbetween making it non-zero.
If this happens, manage_worker() could return false even with zero
nr_idle making the worker, the last idle one, proceed to execute work
items. If then all workers of the pool end up blocking on a resource
which can only be released by a work item which is pending on that
pool, the whole pool can deadlock as there's no one to create more
workers or summon the rescuers.
This patch fixes the problem by removing the early exit condition from
maybe_create_worker() and making manage_workers() return false iff
there's already another manager, which ensures that the last worker
doesn't start executing work items.
We can leave the early exit condition alone and just ignore the return
value but the only reason it was put there is because the
manage_workers() used to perform both creations and destructions of
workers and thus the function may be invoked while the pool is trying
to reduce the number of workers. Now that manage_workers() is called
only when more workers are needed, the only case this early exit
condition is triggered is rare race conditions rendering it pointless.
Tested with simulated workload and modified workqueue code which
trigger the pool deadlock reliably without this patch.
Reported-by: Eric Sandeen <sandeen@sandeen.net>
Link: http://lkml.kernel.org/g/54B019F4.8030009@sandeen.net
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
commit 5e5aeb4367b450a28f447f6d5ab57d8f2ab16a5f upstream.
Verify that the frequency value from userspace is valid and makes sense.
Unverified values can cause overflows later on.
[jstultz: Fix up bug for negative values and drop redunent cap check]
commit 6ada1fc0e1c4775de0e043e1bd3ae9d065491aa5 upstream.
An unvalidated user input is multiplied by a constant, which can result in
an undefined behaviour for large values. While this is validated later,
we should avoid triggering undefined behaviour.
[jstultz: include trivial milisecond->microsecond correction noticed
by Andy]
commit 9fc81d87420d0d3fd62d5e5529972c0ad9eab9cc upstream.
We allow PMU driver to change the cpu on which the event
should be installed to. This happened in patch:
e2d37cd213dc ("perf: Allow the PMU driver to choose the CPU on which to install events")
This patch also forces all the group members to follow
the currently opened events cpu if the group happened
to be moved.
This and the change of event->cpu in perf_install_in_context()
function introduced in:
0cda4c023132 ("perf: Introduce perf_pmu_migrate_context()")
forces group members to change their event->cpu,
if the currently-opened-event's PMU changed the cpu
and there is a group move.
Above behaviour causes problem for breakpoint events,
which uses event->cpu to touch cpu specific data for
breakpoints accounting. By changing event->cpu, some
breakpoints slots were wrongly accounted for given
cpu.
Vinces's perf fuzzer hit this issue and caused following
WARN on my setup:
WARNING: CPU: 0 PID: 20214 at arch/x86/kernel/hw_breakpoint.c:119 arch_install_hw_breakpoint+0x142/0x150()
Can't find any breakpoint slot
This patch changes the group moving code to keep the event's
original cpu.
Reported-by: Vince Weaver <vince@deater.net>
Signed-off-by: Jiri Olsa <jolsa@redhat.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Vince Weaver <vince@deater.net>
Cc: Yan, Zheng <zheng.z.yan@intel.com>
Link: http://lkml.kernel.org/r/1418243031-20367-3-git-send-email-jolsa@kernel.org
commit 24c037ebf5723d4d9ab0996433cee4f96c292a4d upstream.
alloc_pid() does get_pid_ns() beforehand but forgets to put_pid_ns() if it
fails because disable_pid_allocation() was called by the exiting
child_reaper.
We could simply move get_pid_ns() down to successful return, but this fix
tries to be as trivial as possible.
Reviewed-by: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Aaron Tomlin <atomlin@redhat.com>
Cc: Pavel Emelyanov <xemul@parallels.com>
Cc: Serge Hallyn <serge.hallyn@ubuntu.com>
Cc: Sterling Alexander <stalexan@redhat.com>
commit 66d2f338ee4c449396b6f99f5e75cd18eb6df272 upstream.
Now that setgroups can be disabled and not reenabled, setting gid_map
without privielge can now be enabled when setgroups is disabled.
This restores most of the functionality that was lost when unprivileged
setting of gid_map was removed. Applications that use this functionality
will need to check to see if they use setgroups or init_groups, and if they
don't they can be fixed by simply disabling setgroups before writing to
gid_map.
Reviewed-by: Andy Lutomirski <luto@amacapital.net>
commit 9cc46516ddf497ea16e8d7cb986ae03a0f6b92f8 upstream.
- Expose the knob to user space through a proc file /proc/<pid>/setgroups
A value of "deny" means the setgroups system call is disabled in the
current processes user namespace and can not be enabled in the
future in this user namespace.
A value of "allow" means the segtoups system call is enabled.
- Descendant user namespaces inherit the value of setgroups from
their parents.
- A proc file is used (instead of a sysctl) as sysctls currently do
not allow checking the permissions at open time.
- Writing to the proc file is restricted to before the gid_map
for the user namespace is set.
This ensures that disabling setgroups at a user namespace
level will never remove the ability to call setgroups
from a process that already has that ability.
A process may opt in to the setgroups disable for itself by
creating, entering and configuring a user namespace or by calling
setns on an existing user namespace with setgroups disabled.
Processes without privileges already can not call setgroups so this
is a noop. Prodcess with privilege become processes without
privilege when entering a user namespace and as with any other path
to dropping privilege they would not have the ability to call
setgroups. So this remains within the bounds of what is possible
without a knob to disable setgroups permanently in a user namespace.
commit f0d62aec931e4ae3333c797d346dc4f188f454ba upstream.
Generalize id_map_mutex so it can be used for more state of a user namespace.
commit f95d7918bd1e724675de4940039f2865e5eec5fe upstream.
If you did not create the user namespace and are allowed
to write to uid_map or gid_map you should already have the necessary
privilege in the parent user namespace to establish any mapping
you want so this will not affect userspace in practice.
Limiting unprivileged uid mapping establishment to the creator of the
user namespace makes it easier to verify all credentials obtained with
the uid mapping can be obtained without the uid mapping without
privilege.
Limiting unprivileged gid mapping establishment (which is temporarily
absent) to the creator of the user namespace also ensures that the
combination of uid and gid can already be obtained without privilege.
This is part of the fix for CVE-2014-8989.
commit 80dd00a23784b384ccea049bfb3f259d3f973b9d upstream.
setresuid allows the euid to be set to any of uid, euid, suid, and
fsuid. Therefor it is safe to allow an unprivileged user to map
their euid and use CAP_SETUID privileged with exactly that uid,
as no new credentials can be obtained.
I can not find a combination of existing system calls that allows setting
uid, euid, suid, and fsuid from the fsuid making the previous use
of fsuid for allowing unprivileged mappings a bug.
This is part of a fix for CVE-2014-8989.
commit be7c6dba2332cef0677fbabb606e279ae76652c3 upstream.
As any gid mapping will allow and must allow for backwards
compatibility dropping groups don't allow any gid mappings to be
established without CAP_SETGID in the parent user namespace.
For a small class of applications this change breaks userspace
and removes useful functionality. This small class of applications
includes tools/testing/selftests/mount/unprivilged-remount-test.c
Most of the removed functionality will be added back with the addition
of a one way knob to disable setgroups. Once setgroups is disabled
setting the gid_map becomes as safe as setting the uid_map.
For more common applications that set the uid_map and the gid_map
with privilege this change will have no affect.
commit 273d2c67c3e179adb1e74f403d1e9a06e3f841b5 upstream.
setgroups is unique in not needing a valid mapping before it can be called,
in the case of setgroups(0, NULL) which drops all supplemental groups.
The design of the user namespace assumes that CAP_SETGID can not actually
be used until a gid mapping is established. Therefore add a helper function
to see if the user namespace gid mapping has been established and call
that function in the setgroups permission check.
This is part of the fix for CVE-2014-8989, being able to drop groups
without privilege using user namespaces.
commit 0542f17bf2c1f2430d368f44c8fcf2f82ec9e53e upstream.
The rule is simple. Don't allow anything that wouldn't be allowed
without unprivileged mappings.
It was previously overlooked that establishing gid mappings would
allow dropping groups and potentially gaining permission to files and
directories that had lesser permissions for a specific group than for
all other users.
This is the rule needed to fix CVE-2014-8989 and prevent any other
security issues with new_idmap_permitted.
The reason for this rule is that the unix permission model is old and
there are programs out there somewhere that take advantage of every
little corner of it. So allowing a uid or gid mapping to be
established without privielge that would allow anything that would not
be allowed without that mapping will result in expectations from some
code somewhere being violated. Violated expectations about the
behavior of the OS is a long way to say a security issue.
commit 7ff4d90b4c24a03666f296c3d4878cd39001e81e upstream.
Today there are 3 instances of setgroups and due to an oversight their
permission checking has diverged. Add a common function so that
they may all share the same permission checking code.
This corrects the current oversight in the current permission checks
and adds a helper to avoid this in the future.
A user namespace security fix will update this new helper, shortly.
commit 82975bc6a6df743b9a01810fb32cb65d0ec5d60b upstream.
x86 call do_notify_resume on paranoid returns if TIF_UPROBE is set but
not on non-paranoid returns. I suspect that this is a mistake and that
the code only works because int3 is paranoid.
Setting _TIF_NOTIFY_RESUME in the uprobe code was probably a workaround
for the x86 bug. With that bug fixed, we can remove _TIF_NOTIFY_RESUME
from the uprobes code.
Reported-by: Oleg Nesterov <oleg@redhat.com>
Acked-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Acked-by: Borislav Petkov <bp@suse.de>
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
commit b3f207855f57b9c8f43a547a801340bb5cbc59e5 upstream.
When running a 32-bit userspace on a 64-bit kernel (eg. i386
application on x86_64 kernel or 32-bit arm userspace on arm64
kernel) some of the perf ioctls must be treated with special
care, as they have a pointer size encoded in the command.
For example, PERF_EVENT_IOC_ID in 32-bit world will be encoded
as 0x80042407, but 64-bit kernel will expect 0x80082407. In
result the ioctl will fail returning -ENOTTY.
This patch solves the problem by adding code fixing up the
size as compat_ioctl file operation.
Reported-by: Drew Richardson <drew.richardson@arm.com>
Signed-off-by: Pawel Moll <pawel.moll@arm.com>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/1402671812-9078-1-git-send-email-pawel.moll@arm.com
Signed-off-by: David Ahern <daahern@cisco.com>
commit 799b601451b21ebe7af0e6e8f6e2ccd4683c5064 upstream.
Audit rules disappear when an inode they watch is evicted from the cache.
This is likely not what we want.
The guilty commit is "fsnotify: allow marks to not pin inodes in core",
which didn't take into account that audit_tree adds watches with a zero
mask.
Adding any mask should fix this.
Fixes: 90b1e7a57880 ("fsnotify: allow marks to not pin inodes in core")
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Signed-off-by: Paul Moore <pmoore@redhat.com>
commit 6891c4509c792209c44ced55a60f13954cb50ef4 upstream.
If userland creates a timer without specifying a sigevent info, we'll
create one ourself, using a stack local variable. Particularly will we
use the timer ID as sival_int. But as sigev_value is a union containing
a pointer and an int, that assignment will only partially initialize
sigev_value on systems where the size of a pointer is bigger than the
size of an int. On such systems we'll copy the uninitialized stack bytes
from the timer_create() call to userland when the timer actually fires
and we're going to deliver the signal.
Initialize sigev_value with 0 to plug the stack info leak.
Found in the PaX patch, written by the PaX Team.
Fixes: 5a9fa7307285 ("posix-timers: kill ->it_sigev_signo and...")
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Cc: Brad Spengler <spender@grsecurity.net>
Cc: PaX Team <pageexec@freemail.hu>
Link: http://lkml.kernel.org/r/1412456799-32339-1-git-send-email-minipli@googlemail.com
commit 94fb823fcb4892614f57e59601bb9d4920f24711 upstream.
If a device's dev_pm_ops::freeze callback fails during the QUIESCE
phase, we don't rollback things correctly calling the thaw and complete
callbacks. This could leave some devices in a suspended state in case of
an error during resuming from hibernation.
Signed-off-by: Imre Deak <imre.deak@intel.com>
commit 5695be142e203167e3cb515ef86a88424f3524eb upstream.
PM freezer relies on having all tasks frozen by the time devices are
getting frozen so that no task will touch them while they are getting
frozen. But OOM killer is allowed to kill an already frozen task in
order to handle OOM situtation. In order to protect from late wake ups
OOM killer is disabled after all tasks are frozen. This, however, still
keeps a window open when a killed task didn't manage to die by the time
freeze_processes finishes.
Reduce the race window by checking all tasks after OOM killer has been
disabled. This is still not race free completely unfortunately because
oom_killer_disable cannot stop an already ongoing OOM killer so a task
might still wake up from the fridge and get killed without
freeze_processes noticing. Full synchronization of OOM and freezer is,
however, too heavy weight for this highly unlikely case.
Introduce and check oom_kills counter which gets incremented early when
the allocator enters __alloc_pages_may_oom path and only check all the
tasks if the counter changes during the freezing attempt. The counter
is updated so early to reduce the race window since allocator checked
oom_killer_disabled which is set by PM-freezing code. A false positive
will push the PM-freezer into a slow path but that is not a big deal.
Changes since v1
- push the re-check loop out of freeze_processes into
check_frozen_processes and invert the condition to make the code more
readable as per Rafael
Fixes: f660daac474c6f (oom: thaw threads if oom killed thread is frozen before deferring)
commit 51fae6da640edf9d266c94f36bc806c63c301991 upstream.
Since f660daac474c6f (oom: thaw threads if oom killed thread is frozen
before deferring) OOM killer relies on being able to thaw a frozen task
to handle OOM situation but a3201227f803 (freezer: make freezing() test
freeze conditions in effect instead of TIF_FREEZE) has reorganized the
code and stopped clearing freeze flag in __thaw_task. This means that
the target task only wakes up and goes into the fridge again because the
freezing condition hasn't changed for it. This reintroduces the bug
fixed by f660daac474c6f.
Fix the issue by checking for TIF_MEMDIE thread flag in
freezing_slow_path and exclude the task from freezing completely. If a
task was already frozen it would get woken by __thaw_task from OOM killer
and get out of freezer after rechecking freezing().
Changes since v1
- put TIF_MEMDIE check into freezing_slowpath rather than in __refrigerator
as per Oleg
- return __thaw_task into oom_scan_process_thread because
oom_kill_process will not wake task in the fridge because it is
sleeping uninterruptible
[mhocko@suse.cz: rewrote the changelog]
Fixes: a3201227f803 (freezer: make freezing() test freeze conditions in effect instead of TIF_FREEZE)
Acked-by: Oleg Nesterov <oleg@redhat.com>
commit d3051b489aa81ca9ba62af366149ef42b8dae97c upstream.
A panic was seen in the following sitation.
There are two threads running on the system. The first thread is a system
monitoring thread that is reading /proc/modules. The second thread is
loading and unloading a module (in this example I'm using my simple
dummy-module.ko). Note, in the "real world" this occurred with the qlogic
driver module.
When doing this, the following panic occurred:
kernel BUG at kernel/module.c:3739!
invalid opcode: 0000 [#1] SMP
Modules linked in: binfmt_misc sg nfsv3 rpcsec_gss_krb5 nfsv4 dns_resolver nfs fscache intel_powerclamp coretemp kvm_intel kvm crct10dif_pclmul crc32_pclmul crc32c_intel ghash_clmulni_intel aesni_intel lrw igb gf128mul glue_helper iTCO_wdt iTCO_vendor_support ablk_helper ptp sb_edac cryptd pps_core edac_core shpchp i2c_i801 pcspkr wmi lpc_ich ioatdma mfd_core dca ipmi_si nfsd ipmi_msghandler auth_rpcgss nfs_acl lockd sunrpc xfs libcrc32c sr_mod cdrom sd_mod crc_t10dif crct10dif_common mgag200 syscopyarea sysfillrect sysimgblt i2c_algo_bit drm_kms_helper ttm isci drm libsas ahci libahci scsi_transport_sas libata i2c_core dm_mirror dm_region_hash dm_log dm_mod [last unloaded: dummy_module]
CPU: 37 PID: 186343 Comm: cat Tainted: GF O-------------- 3.10.0+ #7
Hardware name: Intel Corporation S2600CP/S2600CP, BIOS RMLSDP.86I.00.29.D696.1311111329 11/11/2013
task: ffff8807fd2d8000 ti: ffff88080fa7c000 task.ti: ffff88080fa7c000
RIP: 0010:[<ffffffff810d64c5>] [<ffffffff810d64c5>] module_flags+0xb5/0xc0
RSP: 0018:ffff88080fa7fe18 EFLAGS: 00010246
RAX: 0000000000000003 RBX: ffffffffa03b5200 RCX: 0000000000000000
RDX: 0000000000001000 RSI: ffff88080fa7fe38 RDI: ffffffffa03b5000
RBP: ffff88080fa7fe28 R08: 0000000000000010 R09: 0000000000000000
R10: 0000000000000000 R11: 000000000000000f R12: ffffffffa03b5000
R13: ffffffffa03b5008 R14: ffffffffa03b5200 R15: ffffffffa03b5000
FS: 00007f6ae57ef740(0000) GS:ffff88101e7a0000(0000) knlGS:0000000000000000
CR2: 0000000000404f70 CR3: 0000000ffed48000 CR4: 00000000001407e0
Stack:
ffffffffa03b5200 ffff8810101e4800 ffff88080fa7fe70 ffffffff810d666c
ffff88081e807300 000000002e0f2fbf 0000000000000000 ffff88100f257b00
ffffffffa03b5008 ffff88080fa7ff48 ffff8810101e4800 ffff88080fa7fee0
Call Trace:
[<ffffffff810d666c>] m_show+0x19c/0x1e0
[<ffffffff811e4d7e>] seq_read+0x16e/0x3b0
[<ffffffff812281ed>] proc_reg_read+0x3d/0x80
[<ffffffff811c0f2c>] vfs_read+0x9c/0x170
[<ffffffff811c1a58>] SyS_read+0x58/0xb0
[<ffffffff81605829>] system_call_fastpath+0x16/0x1b
Code: 48 63 c2 83 c2 01 c6 04 03 29 48 63 d2 eb d9 0f 1f 80 00 00 00 00 48 63 d2 c6 04 13 2d 41 8b 0c 24 8d 50 02 83 f9 01 75 b2 eb cb <0f> 0b 66 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 55 48 89 e5 41
RIP [<ffffffff810d64c5>] module_flags+0xb5/0xc0
RSP <ffff88080fa7fe18>
Consider the two processes running on the system.
CPU 0 (/proc/modules reader)
CPU 1 (loading/unloading module)
CPU 0 opens /proc/modules, and starts displaying data for each module by
traversing the modules list via fs/seq_file.c:seq_open() and
fs/seq_file.c:seq_read(). For each module in the modules list, seq_read
does
op->start() <-- this is a pointer to m_start()
op->show() <- this is a pointer to m_show()
op->stop() <-- this is a pointer to m_stop()
The m_start(), m_show(), and m_stop() module functions are defined in
kernel/module.c. The m_start() and m_stop() functions acquire and release
the module_mutex respectively.
ie) When reading /proc/modules, the module_mutex is acquired and released
for each module.
m_show() is called with the module_mutex held. It accesses the module
struct data and attempts to write out module data. It is in this code
path that the above BUG_ON() warning is encountered, specifically m_show()
calls
static char *module_flags(struct module *mod, char *buf)
int bx = 0;
BUG_ON(mod->state == MODULE_STATE_UNFORMED);
The other thread, CPU 1, in unloading the module calls the syscall
delete_module() defined in kernel/module.c. The module_mutex is acquired
for a short time, and then released. free_module() is called without the
module_mutex. free_module() then sets mod->state = MODULE_STATE_UNFORMED,
also without the module_mutex. Some additional code is called and then the
module_mutex is reacquired to remove the module from the modules list:
/* Now we can delete it from the lists */
mutex_lock(&module_mutex);
stop_machine(__unlink_module, mod, NULL);
mutex_unlock(&module_mutex);
This is the sequence of events that leads to the panic.
CPU 1 is removing dummy_module via delete_module(). It acquires the
module_mutex, and then releases it. CPU 1 has NOT set dummy_module->state to
MODULE_STATE_UNFORMED yet.
CPU 0, which is reading the /proc/modules, acquires the module_mutex and
acquires a pointer to the dummy_module which is still in the modules list.
CPU 0 calls m_show for dummy_module. The check in m_show() for
MODULE_STATE_UNFORMED passed for dummy_module even though it is being
torn down.
Meanwhile CPU 1, which has been continuing to remove dummy_module without
holding the module_mutex, now calls free_module() and sets
dummy_module->state to MODULE_STATE_UNFORMED.
CPU 0 now calls module_flags() with dummy_module and ...
int bx = 0;
and BOOM.
Acquire and release the module_mutex lock around the setting of
MODULE_STATE_UNFORMED in the teardown path, which should resolve the
problem.
Testing: In the unpatched kernel I can panic the system within 1 minute by
doing
while (true) do insmod dummy_module.ko; rmmod dummy_module.ko; done
and
while (true) do cat /proc/modules; done
in separate terminals.
In the patched kernel I was able to run just over one hour without seeing
any issues. I also verified the output of panic via sysrq-c and the output
of /proc/modules looks correct for all three states for the dummy_module.
dummy_module 12661 0 - Unloading 0xffffffffa03a5000 (OE-)
dummy_module 12661 0 - Live 0xffffffffa03bb000 (OE)
dummy_module 14015 1 - Loading 0xffffffffa03a5000 (OE+)
Signed-off-by: Prarit Bhargava <prarit@redhat.com>
Reviewed-by: Oleg Nesterov <oleg@redhat.com>
commit 086ba77a6db00ed858ff07451bedee197df868c9 upstream.
ARM has some private syscalls (for example, set_tls(2)) which lie
outside the range of NR_syscalls. If any of these are called while
syscall tracing is being performed, out-of-bounds array access will
occur in the ftrace and perf sys_{enter,exit} handlers.
# trace-cmd record -e raw_syscalls:* true && trace-cmd report
true-653 [000] 384.675777: sys_enter: NR 192 (0, 1000, 3, 4000022, ffffffff, 0)
true-653 [000] 384.675812: sys_exit: NR 192 = 1995915264
true-653 [000] 384.675971: sys_enter: NR 983045 (76f74480, 76f74000, 76f74b28, 76f74480, 76f76f74, 1)
true-653 [000] 384.675988: sys_exit: NR 983045 = 0
# trace-cmd record -e syscalls:* true
[ 17.289329] Unable to handle kernel paging request at virtual address aaaaaace
[ 17.289590] pgd = 9e71c000
[ 17.289696] [aaaaaace] *pgd=00000000
[ 17.289985] Internal error: Oops: 5 [#1] PREEMPT SMP ARM
[ 17.290169] Modules linked in:
[ 17.290391] CPU: 0 PID: 704 Comm: true Not tainted 3.18.0-rc2+ #21
[ 17.290585] task: 9f4dab00 ti: 9e710000 task.ti: 9e710000
[ 17.290747] PC is at ftrace_syscall_enter+0x48/0x1f8
[ 17.290866] LR is at syscall_trace_enter+0x124/0x184
Fix this by ignoring out-of-NR_syscalls-bounds syscall numbers.
Commit cd0980fc8add "tracing: Check invalid syscall nr while tracing syscalls"
added the check for less than zero, but it should have also checked
for greater than NR_syscalls.
Link: http://lkml.kernel.org/p/1414620418-29472-1-git-send-email-rabin@rab.in
Fixes: cd0980fc8add "tracing: Check invalid syscall nr while tracing syscalls"
Signed-off-by: Rabin Vincent <rabin@rab.in>
commit d78c9300c51d6ceed9f6d078d4e9366f259de28c upstream.
timeval_to_jiffies tried to round a timeval up to an integral number
of jiffies, but the logic for doing so was incorrect: intervals
corresponding to exactly N jiffies would become N+1. This manifested
itself particularly repeatedly stopping/starting an itimer:
setitimer(ITIMER_PROF, &val, NULL);
setitimer(ITIMER_PROF, NULL, &val);
would add a full tick to val, _even if it was exactly representable in
terms of jiffies_ (say, the result of a previous rounding.) Doing
this repeatedly would cause unbounded growth in val. So fix the math.
Here's what was wrong with the conversion: we essentially computed
(eliding seconds)
jiffies = usec * (NSEC_PER_USEC/TICK_NSEC)
by using scaling arithmetic, which took the best approximation of
NSEC_PER_USEC/TICK_NSEC with denominator of 2^USEC_JIFFIE_SC =
x/(2^USEC_JIFFIE_SC), and computed:
jiffies = (usec * x) >> USEC_JIFFIE_SC
and rounded this calculation up in the intermediate form (since we
can't necessarily exactly represent TICK_NSEC in usec.) But the
scaling arithmetic is a (very slight) *over*approximation of the true
value; that is, instead of dividing by (1 usec/ 1 jiffie), we
effectively divided by (1 usec/1 jiffie)-epsilon (rounding
down). This would normally be fine, but we want to round timeouts up,
and we did so by adding 2^USEC_JIFFIE_SC - 1 before the shift; this
would be fine if our division was exact, but dividing this by the
slightly smaller factor was equivalent to adding just _over_ 1 to the
final result (instead of just _under_ 1, as desired.)
In particular, with HZ=1000, we consistently computed that 10000 usec
was 11 jiffies; the same was true for any exact multiple of
TICK_NSEC.
We could possibly still round in the intermediate form, adding
something less than 2^USEC_JIFFIE_SC - 1, but easier still is to
convert usec->nsec, round in nanoseconds, and then convert using
time*spec*_to_jiffies. This adds one constant multiplication, and is
not observably slower in microbenchmarks on recent x86 hardware.
Tested: the following program:
int main() {
struct itimerval zero = {{0, 0}, {0, 0}};
/* Initially set to 10 ms. */
struct itimerval initial = zero;
initial.it_interval.tv_usec = 10000;
setitimer(ITIMER_PROF, &initial, NULL);
/* Save and restore several times. */
for (size_t i = 0; i < 10; ++i) {
struct itimerval prev;
setitimer(ITIMER_PROF, &zero, &prev);
/* on old kernels, this goes up by TICK_USEC every iteration */
printf("previous value: %ld %ld %ld %ld\n",
prev.it_interval.tv_sec, prev.it_interval.tv_usec,
prev.it_value.tv_sec, prev.it_value.tv_usec);
setitimer(ITIMER_PROF, &prev, NULL);
return 0;
Cc: Paul Turner <pjt@google.com>
Cc: Richard Cochran <richardcochran@gmail.com>
Cc: Prarit Bhargava <prarit@redhat.com>
Reviewed-by: Paul Turner <pjt@google.com>
Reported-by: Aaron Jacobs <jacobsa@google.com>
Signed-off-by: Andrew Hunter <ahh@google.com>
[jstultz: Tweaked to apply to 3.17-rc]
[bwh: Backported to 3.16: adjust filename]
commit 24607f114fd14f2f37e3e0cb3d47bce96e81e848 upstream.
Commit 651e22f2701b "ring-buffer: Always reset iterator to reader page"
fixed one bug but in the process caused another one. The reset is to
update the header page, but that fix also changed the way the cached
reads were updated. The cache reads are used to test if an iterator
needs to be updated or not.
A ring buffer iterator, when created, disables writes to the ring buffer
but does not stop other readers or consuming reads from happening.
Although all readers are synchronized via a lock, they are only
synchronized when in the ring buffer functions. Those functions may
be called by any number of readers. The iterator continues down when
its not interrupted by a consuming reader. If a consuming read
occurs, the iterator starts from the beginning of the buffer.
The way the iterator sees that a consuming read has happened since
its last read is by checking the reader "cache". The cache holds the
last counts of the read and the reader page itself.
Commit 651e22f2701b changed what was saved by the cache_read when
the rb_iter_reset() occurred, making the iterator never match the cache.
Then if the iterator calls rb_iter_reset(), it will go into an
infinite loop by checking if the cache doesn't match, doing the reset
and retrying, just to see that the cache still doesn't match! Which
should never happen as the reset is suppose to set the cache to the
current value and there's locks that keep a consuming reader from
having access to the data.
Fixes: 651e22f2701b "ring-buffer: Always reset iterator to reader page"
commit 6c72e3501d0d62fc064d3680e5234f3463ec5a86 upstream.
Oleg noticed that a cleanup by Sylvain actually uncovered a bug; by
calling perf_event_free_task() when failing sched_fork() we will not yet
have done the memset() on ->perf_event_ctxp[] and will therefore try and
'free' the inherited contexts, which are still in use by the parent
process. This is bad..
Suggested-by: Oleg Nesterov <oleg@redhat.com>
Reported-by: Sylvain 'ythier' Hitier <sylvain.hitier@gmail.com>
commit 0c740d0afc3bff0a097ad03a1c8df92757516f5c upstream.
while_each_thread() and next_thread() should die, almost every lockless
usage is wrong.
1. Unless g == current, the lockless while_each_thread() is not safe.
while_each_thread(g, t) can loop forever if g exits, next_thread()
can't reach the unhashed thread in this case. Note that this can
happen even if g is the group leader, it can exec.
2. Even if while_each_thread() itself was correct, people often use
it wrongly.
It was never safe to just take rcu_read_lock() and loop unless
you verify that pid_alive(g) == T, even the first next_thread()
can point to the already freed/reused memory.
This patch adds signal_struct->thread_head and task->thread_node to
create the normal rcu-safe list with the stable head. The new
for_each_thread(g, t) helper is always safe under rcu_read_lock() as
long as this task_struct can't go away.
Note: of course it is ugly to have both task_struct->thread_node and the
old task_struct->thread_group, we will kill it later, after we change
the users of while_each_thread() to use for_each_thread().
Perhaps we can kill it even before we convert all users, we can
reimplement next_thread(t) using the new thread_head/thread_node. But
we can't do this right now because this will lead to subtle behavioural
changes. For example, do/while_each_thread() always sees at least one
task, while for_each_thread() can do nothing if the whole thread group
has died. Or thread_group_empty(), currently its semantics is not clear
unless thread_group_leader(p) and we need to audit the callers before we
can change it.
So this patch adds the new interface which has to coexist with the old
one for some time, hopefully the next changes will be more or less
straightforward and the old one will go away soon.
Reviewed-by: Sergey Dyasly <dserrg@gmail.com>
Tested-by: Sergey Dyasly <dserrg@gmail.com>
Reviewed-by: Sameer Nanda <snanda@chromium.org>
Acked-by: David Rientjes <rientjes@google.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Mandeep Singh Baines <msb@chromium.org>
Cc: "Ma, Xindong" <xindong.ma@intel.com>
Cc: "Tu, Xiaobing" <xiaobing.tu@intel.com>
Cc: Li Zefan <lizefan@huawei.com>
commit 80628ca06c5d42929de6bc22c0a41589a834d151 upstream.
Cleanup and preparation for the next changes.
Move the "if (clone_flags & CLONE_THREAD)" code down under "if
(likely(p->pid))" and turn it into into the "else" branch. This makes the
process/thread initialization more symmetrical and removes one check.
Cc: Sergey Dyasly <dserrg@gmail.com>
