path: root/kernel
2013-10-10misc: tegra-profiler: kprobes is no longer usedIgor Nabirushkin
Tegra Profiler: kprobes is no longer used Use callbacks from the scheduler instead of kprobes Bug 1343930 Change-Id: I67589dbe972cc5c853addfb6ed82c488529eed55 Signed-off-by: Igor Nabirushkin <inabirushkin@nvidia.com> Reviewed-on: http://git-master/r/281941 Reviewed-by: Daniel Horowitz <dhorowitz@nvidia.com> Reviewed-by: Eric Miao <emiao@nvidia.com> Tested-by: Eric Miao <emiao@nvidia.com> GVS: Gerrit_Virtual_Submit Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
2013-06-11sched,rt: disable rt_runtime borrowing by defaultMike Galbraith
Make the default RT_RUNTIME_SHARE setting reflect the most common throttle role, that of safety mechanism to protect the box. Bug 1269903 Change-Id: Id4ccf0095ea254f2e15fddc7ab02069f7f60a7c0 Signed-off-by: Mike Galbraith <bitbucket@online.de> Reviewed-on: http://git-master/r/234274 (cherry picked from commit be74a12c8d8b987f569cdd0eec2aead3dcbdfa31) Reviewed-on: http://git-master/r/237266 Tested-by: Peter Boonstoppel <pboonstoppel@nvidia.com> Reviewed-by: Peter Boonstoppel <pboonstoppel@nvidia.com> Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com> Reviewed-by: Paul Walmsley <pwalmsley@nvidia.com> GVS: Gerrit_Virtual_Submit
2013-05-16perf: Treat attr.config as u64 in perf_swevent_init()Tommi Rantala
Trinity discovered that we fail to check all 64 bits of attr.config passed by user space, resulting to out-of-bounds access of the perf_swevent_enabled array in sw_perf_event_destroy(). Introduced in commit b0a873ebb ("perf: Register PMU implementations"). Signed-off-by: Tommi Rantala <tt.rantala@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: davej@redhat.com Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Link: http://lkml.kernel.org/r/1365882554-30259-1-git-send-email-tt.rantala@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org> (cherry picked from commit 8176cced706b5e5d15887584150764894e94e02f) Change-Id: I5ecfb388007fba52435b49ac38855d1873ca63db Signed-off-by: Bo Yan <byan@nvidia.com> Signed-off-by: Bharat Nihalani <bnihalani@nvidia.com> Reviewed-on: http://git-master/r/228787 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit
2013-05-06sched: remove redundant update_runtime notifierNeil Zhang
migration_call() will do all the things that update_runtime() does. So it seems update_runtime() is a redundant notifier, remove it. Furthermore, there is potential risk that the current code will catch BUG_ON at line 687 of rt.c when do cpu hotplug while there are realtime threads running because of enable runtime twice. Change-Id: I0fdad8d5a1cebb845d3f308b205dbd6517c3e4de Cc: bitbucket@online.de Signed-off-by: Neil Zhang <zhangwm@marvell.com> Reviewed-on: http://git-master/r/215596 (cherry picked from commit 8f646de983f24361814d9a6ca679845fb2265807) Reviewed-on: http://git-master/r/223067 Reviewed-by: Peter Boonstoppel <pboonstoppel@nvidia.com> Tested-by: Peter Boonstoppel <pboonstoppel@nvidia.com> Reviewed-by: Paul Walmsley <pwalmsley@nvidia.com> Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
2013-04-05nohz: stat: Fix CPU idle time accountingBo Yan
Since cpustat[CPUTIME_IDLE] is never connected to ts->idle_sleeptime, never read from cpustat[CPUTIME_IDLE] when reporting stats in /proc/stat. Note this was rejected by Michal Hocko when it was initially proposed by Martin Schwidefsky in LKML, so if you want to upstream it, better find an alternative (either completely disable cpustat[CPUTIME_IDLE] for CONFIG_NO_HZ or somehow connect them to keep them in sync.) bug 1190321 Change-Id: Idc92488910b826aff850a010016d8326c7ab9e6c Signed-off-by: Bo Yan <byan@nvidia.com> Reviewed-on: http://git-master/r/214638 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Liang Cheng (SW) <licheng@nvidia.com> Tested-by: Liang Cheng (SW) <licheng@nvidia.com>
2013-03-14sched: reinitialize rq->next_balance when a CPU is hot-addedPaul Walmsley
Reinitialize rq->next_balance when a CPU is hot-added. Otherwise, scheduler domain rebalancing may be skipped if rq->next_balance was set to a future time when the CPU was last active, and the newly-re-added CPU is in idle_balance(). As a result, the newly-re-added CPU will remain idle with no tasks scheduled until the softlockup watchdog runs - potentially 4 seconds later. This can waste energy and reduce performance. This behavior can be observed in some SoC kernels, which use CPU hotplug to dynamically remove and add CPUs in response to load. In one case that triggered this behavior, 0. the system started with all cores enabled, running multi-threaded CPU-bound code; 1. the system entered some single-threaded code; 2. a CPU went idle and was hot-removed; 3. the system started executing a multi-threaded CPU-bound task; 4. the CPU from event 2 was re-added, to respond to the load. The time interval between events 2 and 4 was approximately 300 milliseconds. Of course, ideally CPU hotplug would not be used in this manner, but this patch does appear to fix a real bug. Nvidia folks: this patch is submitted as at least a partial fix for bug 1243368 ("[sched] Load-balancing not happening correctly after cores brought online") Change-Id: Iabac21e110402bb581b7db40c42babc951d378d0 Signed-off-by: Paul Walmsley <pwalmsley@nvidia.com> Cc: Peter Boonstoppel <pboonstoppel@nvidia.com> Reviewed-on: http://git-master/r/208927 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Peter Zu <pzu@nvidia.com> Reviewed-by: Peter Boonstoppel <pboonstoppel@nvidia.com> GVS: Gerrit_Virtual_Submit Tested-by: Peter Zu <pzu@nvidia.com> Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
2013-01-30timekeeping: Fix time moving backwardsAjay Nandakumar
Changed the calculation logic that sometimes calculates the time wrong. Sometimes there is an overflow when the tv_nsec field in the timespec structure is being added since it is 32-bit. To resolve this issue nsec variable is being added first so that the addition is performed in 64 bit signed format. Bug 1217429 Change-Id: I9c65da88f02596ba73c47be6342ed909e650db22 Signed-off-by: Ajay Nandakumar <anandakumarm@nvidia.com> Reviewed-on: http://git-master/r/195092 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Prashant Gaikwad <pgaikwad@nvidia.com> Reviewed-by: Shridhar Rasal <srasal@nvidia.com> Reviewed-by: Bo Yan <byan@nvidia.com> GVS: Gerrit_Virtual_Submit Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com> Tested-by: Shridhar Rasal <srasal@nvidia.com>
2012-11-30Revert "Revert "cpuquiet: Update averaging of nr_runnables""Peter Boonstoppel
This reverts commit 3bca5808dcc371ea4e1d6ce555e3eae76fbe0e7e. Bug 1050445 Bug 1050721 Change-Id: I6d51de129a10236e43c9ce262f879aa0f8361c77 Signed-off-by: Peter Boonstoppel <pboonstoppel@nvidia.com> Reviewed-on: http://git-master/r/163096 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Ilan Aelion <iaelion@nvidia.com> GVS: Gerrit_Virtual_Submit Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
2012-11-14gcov-kernel: Make gcov work on vanilla gcc again.Tuomas Tynkkynen
Commit "gcov-kernel: patch for Android toolchain 4.4.x support" broke support for gcov on vanilla gcc. Introduce #ifdefs to make it work on both of them. Since the gcov ABI for Android gcc is different, the build system must set CONFIG_GCOV_TOOLCHAIN_IS_ANDROID when compiling with an Android toolchain. Also remove a few magic numbers from the original gcov code and fix a unused function warning. Bug 1155439 Change-Id: I7c18938e5503df4ee1c3f8de2b6f5a99ceef7f71 Signed-off-by: Tuomas Tynkkynen <ttynkkynen@nvidia.com> Reviewed-on: http://git-master/r/162711 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
2012-11-12Revert "sched :Notify users that tickless-timer is enabled"Puneet Saxena
bug 1040355 This reverts commit 84b80bb4d3db3ef5a58660cbfb37a6a4b8b3f267. Change-Id: I40d7ef8b28673355116b677ac4abffae58d5f5c5 Signed-off-by: Puneet Saxena <puneets@nvidia.com> Reviewed-on: http://git-master/r/161899 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Antti Miettinen <amiettinen@nvidia.com> Tested-by: Antti Miettinen <amiettinen@nvidia.com> Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com> Reviewed-by: Peter Boonstoppel <pboonstoppel@nvidia.com>
2012-10-31sched :Notify users that tickless-timer is enabledpdabade
Notify users that tickless-timer is enabled. Bug 1049943 Change-Id: If178c85f21d804b88e91b9430ba5576cfc95cbed Signed-off-by: Pankaj Dabade <pdabade@nvidia.com> Reviewed-on: http://git-master/r/147884 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Venkata Jagadish <vjagadish@nvidia.com> GVS: Gerrit_Virtual_Submit Reviewed-by: Laxman Dewangan <ldewangan@nvidia.com>
2012-09-26Revert "cpuquiet: Update averaging of nr_runnables"Puneet Saxena
This reverts commit 8bd999a85354485af3cbee872816a9921d8bfffc. bug 1050721 Change-Id: I29fcff431e5427dfaa2524a12c5702154037018a Signed-off-by: Puneet Saxena <puneets@nvidia.com> Reviewed-on: http://git-master/r/134307 Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2012-09-18kthread_worker: reimplement flush_kthread_work() to allow freeing the work ↵Tejun Heo
item being executed kthread_worker provides minimalistic workqueue-like interface for users which need a dedicated worker thread (e.g. for realtime priority). It has basic queue, flush_work, flush_worker operations which mostly match the workqueue counterparts; however, due to the way flush_work() is implemented, it has a noticeable difference of not allowing work items to be freed while being executed. While the current users of kthread_worker are okay with the current behavior, the restriction does impede some valid use cases. Also, removing this difference isn't difficult and actually makes the code easier to understand. This patch reimplements flush_kthread_work() such that it uses a flush_work item instead of queue/done sequence numbers. Signed-off-by: Tejun Heo <tj@kernel.org>
2012-09-18kthread_worker: reorganize to prepare for flush_kthread_work() reimplementationTejun Heo
Make the following two non-functional changes. * Separate out insert_kthread_work() from queue_kthread_work(). * Relocate struct kthread_flush_work and kthread_flush_work_fn() definitions above flush_kthread_work(). v2: Added lockdep_assert_held() in insert_kthread_work() as suggested by Andy Walls. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Andy Walls <awalls@md.metrocast.net>
2012-09-18HACK: ARM: disable sleeping while atomic warning in do_signalColin Cross
ARM disables interrupts in do_signal, which triggers a warning in try_to_freeze, see details at https://lkml.org/lkml/2011/8/23/221. To prevent the warnings, add try_to_freeze_nowarn and call it from do_signal. Change-Id: If7482de21c386adc705fa1ac4ecb8c7ece5bb356 Signed-off-by: Colin Cross <ccross@android.com>
2012-09-14cpuquiet: Update averaging of nr_runnablesSai Charan Gurrappadi
Doing a Exponential moving average per nr_running++/-- does not guarantee a fixed sample rate which induces errors if there are lots of threads being enqueued/dequeued from the rq (Linpack mt). Instead of keeping track of the avg, the scheduler now keeps track of the integral of nr_running and allows the readers to perform filtering on top. Implemented a proper exponential moving average for the runnables governor and a straight 100ms average for the balanced governor. Tweaked the thresholds for the runnables governor to minimize latency. Also, decreased sample_rate for the runnables governor to the absolute minimum of 10msecs. Updated to K3.4 Change-Id: Ia25bf8baf2a1a015ba188b2c06e551e89b16c5f8 Signed-off-by: Sai Charan Gurrappadi <sgurrappadi@nvidia.com> Signed-off-by: Peter De Schrijver <pdeschrijver@nvidia.com> Reviewed-on: http://git-master/r/131147 Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
2012-08-24cpuquiet: Runnable threads governorSai Charan Gurrappadi
[perf] The runnable threads governor only looks at the average number of runnables in the system to make a decision when bringing cores offline/online. First pass; tweaks thresholds and delays to reduce decision latency to about ~50-70ms per core (from ~100-150ms per core) Change-Id: Idd3b268a74a8f56ad3fc0e5c7f388174d1b6611f Signed-off-by: Sai Charan Gurrappadi <sgurrappadi@nvidia.com> Reviewed-on: http://git-master/r/124679 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
2012-08-24PM QoS: Add disable parameterAntti P Miettinen
For testing purposes it is useful to be able to disable PM Qos. Bug 1020898 Bug 917572 Reviewed-on: http://git-master/r/124667 Change-Id: I266f5b5730cfe4705197d8b09db7f9eda6766c7c Signed-off-by: Antti P Miettinen <amiettinen@nvidia.com> Signed-off-by: Varun Wadekar <vwadekar@nvidia.com>
2012-08-23Merge commit 'v3.4.9' into android-t114-3.4Varun Wadekar
Linux v3.4.9 Conflicts: arch/arm/kernel/smp.c arch/arm/vfp/entry.S Change-Id: I731e815ed35ba9280374a5a3e5a6a8b6b805d695 Signed-off-by: Varun Wadekar <vwadekar@nvidia.com>
2012-08-16workqueue: CPU hotplug keep idle workersMitch Luban
This change merges two patchsets. The first set, containing 6 patches, reimplements WQ_HIGHPRI to use a seperate worker_pool. gcwq->pools[0] is used for normal priority work and pools[1] for high priority. The second patchset contains 9 patches and reimplements CPU hotplug to keep idle workers. Updates workqueue CPU hotplug path to use a disassociated global_cwq, which runs as an unbound one (WQ_UNBOUND). While this requires rebinding idle workers, overall hotplug path is much simpler. Original patchset: http://thread.gmane.org/gmane.linux.kernel/1329164 Bug 978010 Change-Id: Ic66ec8848a8d111b5278e63ef6a410846dfd8fcc Signed-off-by: Mitch Luban <mluban@nvidia.com> Reviewed-on: http://git-master/r/118387 Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com> Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Peter Boonstoppel <pboonstoppel@nvidia.com> GVS: Gerrit_Virtual_Submit Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2012-08-15random: remove rand_initialize_irq()Theodore Ts'o
commit c5857ccf293968348e5eb4ebedc68074de3dcda6 upstream. With the new interrupt sampling system, we are no longer using the timer_rand_state structure in the irq descriptor, so we can stop initializing it now. [ Merged in fixes from Sedat to find some last missing references to rand_initialize_irq() ] Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Sedat Dilek <sedat.dilek@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15random: make 'add_interrupt_randomness()' do something saneTheodore Ts'o
commit 775f4b297b780601e61787b766f306ed3e1d23eb upstream. We've been moving away from add_interrupt_randomness() for various reasons: it's too expensive to do on every interrupt, and flooding the CPU with interrupts could theoretically cause bogus floods of entropy from a somewhat externally controllable source. This solves both problems by limiting the actual randomness addition to just once a second or after 64 interrupts, whicever comes first. During that time, the interrupt cycle data is buffered up in a per-cpu pool. Also, we make sure the the nonblocking pool used by urandom is initialized before we start feeding the normal input pool. This assures that /dev/urandom is returning unpredictable data as soon as possible. (Based on an original patch by Linus, but significantly modified by tytso.) Tested-by: Eric Wustrow <ewust@umich.edu> Reported-by: Eric Wustrow <ewust@umich.edu> Reported-by: Nadia Heninger <nadiah@cs.ucsd.edu> Reported-by: Zakir Durumeric <zakir@umich.edu> Reported-by: J. Alex Halderman <jhalderm@umich.edu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-13Merge commit 'v3.4.8' into android-t114-3.4-rebasedVarun Wadekar
Linux v3.4.8 Conflicts: drivers/net/tun.c kernel/power/suspend.c Change-Id: Ia26546425cd20f127dbf4dd58cfca41bda47d23d Signed-off-by: Varun Wadekar <vwadekar@nvidia.com>
2012-08-13alarmtimer: implement minimum alarm interval for allowing suspendTodd Poynor
alarmtimer suspend return -EBUSY if the next alarm will fire in less than 2 seconds. This allows one RTC seconds tick to occur subsequent to this check before the alarm wakeup time is set, ensuring the wakeup time is still in the future (assuming the RTC does not tick one more second prior to setting the alarm). If suspend is rejected, hold a wakeup source for 2 seconds to process the alarm prior to reattempting suspend. Change-Id: If38e2568da0ea01dfee6e00323ce7e2c00f2f110 Signed-off-by: Todd Poynor <toddpoynor@google.com>
2012-08-09futex: Forbid uaddr == uaddr2 in futex_wait_requeue_pi()Darren Hart
commit 6f7b0a2a5c0fb03be7c25bd1745baa50582348ef upstream. If uaddr == uaddr2, then we have broken the rule of only requeueing from a non-pi futex to a pi futex with this call. If we attempt this, as the trinity test suite manages to do, we miss early wakeups as q.key is equal to key2 (because they are the same uaddr). We will then attempt to dereference the pi_mutex (which would exist had the futex_q been properly requeued to a pi futex) and trigger a NULL pointer dereference. Signed-off-by: Darren Hart <dvhart@linux.intel.com> Cc: Dave Jones <davej@redhat.com> Link: http://lkml.kernel.org/r/ad82bfe7f7d130247fbe2b5b4275654807774227.1342809673.git.dvhart@linux.intel.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-09futex: Fix bug in WARN_ON for NULL q.pi_stateDarren Hart
commit f27071cb7fe3e1d37a9dbe6c0dfc5395cd40fa43 upstream. The WARN_ON in futex_wait_requeue_pi() for a NULL q.pi_state was testing the address (&q.pi_state) of the pointer instead of the value (q.pi_state) of the pointer. Correct it accordingly. Signed-off-by: Darren Hart <dvhart@linux.intel.com> Cc: Dave Jones <davej@redhat.com> Link: http://lkml.kernel.org/r/1c85d97f6e5f79ec389a4ead3e367363c74bd09a.1342809673.git.dvhart@linux.intel.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-09futex: Test for pi_mutex on fault in futex_wait_requeue_pi()Darren Hart
commit b6070a8d9853eda010a549fa9a09eb8d7269b929 upstream. If fixup_pi_state_owner() faults, pi_mutex may be NULL. Test for pi_mutex != NULL before testing the owner against current and possibly unlocking it. Signed-off-by: Darren Hart <dvhart@linux.intel.com> Cc: Dave Jones <davej@redhat.com> Cc: Dan Carpenter <dan.carpenter@oracle.com> Link: http://lkml.kernel.org/r/dc59890338fc413606f04e5c5b131530734dae3d.1342809673.git.dvhart@linux.intel.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-09posix_types.h: Cleanup stale __NFDBITS and related definitionsJosh Boyer
commit 8ded2bbc1845e19c771eb55209aab166ef011243 upstream. Recently, glibc made a change to suppress sign-conversion warnings in FD_SET (glibc commit ceb9e56b3d1). This uncovered an issue with the kernel's definition of __NFDBITS if applications #include <linux/types.h> after including <sys/select.h>. A build failure would be seen when passing the -Werror=sign-compare and -D_FORTIFY_SOURCE=2 flags to gcc. It was suggested that the kernel should either match the glibc definition of __NFDBITS or remove that entirely. The current in-kernel uses of __NFDBITS can be replaced with BITS_PER_LONG, and there are no uses of the related __FDELT and __FDMASK defines. Given that, we'll continue the cleanup that was started with commit 8b3d1cda4f5f ("posix_types: Remove fd_set macros") and drop the remaining unused macros. Additionally, linux/time.h has similar macros defined that expand to nothing so we'll remove those at the same time. Reported-by: Jeff Law <law@redhat.com> Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Josh Boyer <jwboyer@redhat.com> [ .. and fix up whitespace as per akpm ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-09workqueue: perform cpu down operations from low priority cpu_notifier()Tejun Heo
commit 6575820221f7a4dd6eadecf7bf83cdd154335eda upstream. Currently, all workqueue cpu hotplug operations run off CPU_PRI_WORKQUEUE which is higher than normal notifiers. This is to ensure that workqueue is up and running while bringing up a CPU before other notifiers try to use workqueue on the CPU. Per-cpu workqueues are supposed to remain working and bound to the CPU for normal CPU_DOWN_PREPARE notifiers. This holds mostly true even with workqueue offlining running with higher priority because workqueue CPU_DOWN_PREPARE only creates a bound trustee thread which runs the per-cpu workqueue without concurrency management without explicitly detaching the existing workers. However, if the trustee needs to create new workers, it creates unbound workers which may wander off to other CPUs while CPU_DOWN_PREPARE notifiers are in progress. Furthermore, if the CPU down is cancelled, the per-CPU workqueue may end up with workers which aren't bound to the CPU. While reliably reproducible with a convoluted artificial test-case involving scheduling and flushing CPU burning work items from CPU down notifiers, this isn't very likely to happen in the wild, and, even when it happens, the effects are likely to be hidden by the following successful CPU down. Fix it by using different priorities for up and down notifiers - high priority for up operations and low priority for down operations. Workqueue cpu hotplug operations will soon go through further cleanup. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-09ftrace: Disable function tracing during suspend/resume and hibernation, againSrivatsa S. Bhat
commit 443772d408a25af62498793f6f805ce3c559309a upstream. If function tracing is enabled for some of the low-level suspend/resume functions, it leads to triple fault during resume from suspend, ultimately ending up in a reboot instead of a resume (or a total refusal to come out of suspended state, on some machines). This issue was explained in more detail in commit f42ac38c59e0a03d (ftrace: disable tracing for suspend to ram). However, the changes made by that commit got reverted by commit cbe2f5a6e84eebb (tracing: allow tracing of suspend/resume & hibernation code again). So, unfortunately since things are not yet robust enough to allow tracing of low-level suspend/resume functions, suspend/resume is still broken when ftrace is enabled. So fix this by disabling function tracing during suspend/resume & hibernation. Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-06kthread: disable preemption during complete()Peter Boonstoppel
After a kthread is created it signals the requester using complete() and enters TASK_UNINTERRUPTIBLE. However, since complete() wakes up the requesting thread this can cause a preemption. The preemption will not remove the task from the runqueue (for that schedule() has to be invoked directly). This is a problem if directly after kthread creation you try to do a kthread_bind(), which will block in HZ steps until the thread is off the runqueue. This patch disables preemption during complete(), since we call schedule() directly afterwards, so it will correctly enter TASK_UNINTERRUPTIBLE. This speeds up kthread creation/binding during cpu hotplug significantly. Change-Id: I856ddd4e01ebdb198ba90f343b4a0c5933fd2b23 Signed-off-by: Peter Boonstoppel <pboonstoppel@nvidia.com>
2012-07-29ntp: Fix STA_INS/DEL clearing bugJohn Stultz
commit 6b1859dba01c7d512b72d77e3fd7da8354235189 upstream. In commit 6b43ae8a619d17c4935c3320d2ef9e92bdeed05d, I introduced a bug that kept the STA_INS or STA_DEL bit from being cleared from time_status via adjtimex() without forcing STA_PLL first. Usually once the STA_INS is set, it isn't cleared until the leap second is applied, so its unlikely this affected anyone. However during testing I noticed it took some effort to cancel a leap second once STA_INS was set. Signed-off-by: John Stultz <johnstul@us.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Richard Cochran <richardcochran@gmail.com> Cc: Prarit Bhargava <prarit@redhat.com> Link: http://lkml.kernel.org/r/1342156917-25092-2-git-send-email-john.stultz@linaro.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-25Merge commit 'v3.4.6' into android-t114-3.4Varun Wadekar
Linux v3.4.6 Change-Id: I4518a173ca2852188ebd48121723c8be29d0c682 Signed-off-by: Varun Wadekar <vwadekar@nvidia.com>
2012-07-23power: Add option to log time spent in suspendColin Cross
Prints the time spent in suspend in the kernel log, and keeps statistics on the time spent in suspend in /sys/kernel/debug/suspend_time Change-Id: Ia6b9ebe4baa0f7f5cd211c6a4f7e813aefd3fa1d Signed-off-by: Colin Cross <ccross@android.com> Signed-off-by: Todd Poynor <toddpoynor@google.com>
2012-07-23PM / Hibernate: Use get_gendisk to verify partition if resume_file is ↵Minho Ban
integer format Sometimes resume= parameter comes in integer style (e.g. major:minor) and then name_to_dev_t can not detect partition properly. (especially async device like usb, mmc). This patch calls get_gendisk() if resumewait is true and resume_file is in integer format to work around this problem. Signed-off-by: Minho Ban <mhban@samsung.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2012-07-23PM / Sleep: User space wakeup sources garbage collector Kconfig optionRafael J. Wysocki
Make it possible to configure out the user space wakeup sources garbage collector for debugging and default Android builds. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Arve Hjønnevåg <arve@android.com>
2012-07-23PM / Sleep: Make the limit of user space wakeup sources configurableRafael J. Wysocki
Make it possible to configure out the check against the limit of user space wakeup sources for debugging and default Android builds. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Arve Hjønnevåg <arve@android.com>
2012-07-23PM / Sleep: Fix a mistake in a conditional in autosleep_store()Arve Hjønnevåg
The condition check in autosleep_store() is incorrect and prevents /sys/power/autosleep from working as advertised. Fix that. [rjw: Added the changelog.] Signed-off-by: Arve Hjønnevåg <arve@android.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2012-07-23PM / Sleep: Add user space interface for manipulating wakeup sources, v3Rafael J. Wysocki
Android allows user space to manipulate wakelocks using two sysfs file located in /sys/power/, wake_lock and wake_unlock. Writing a wakelock name and optionally a timeout to the wake_lock file causes the wakelock whose name was written to be acquired (it is created before is necessary), optionally with the given timeout. Writing the name of a wakelock to wake_unlock causes that wakelock to be released. Implement an analogous interface for user space using wakeup sources. Add the /sys/power/wake_lock and /sys/power/wake_unlock files allowing user space to create, activate and deactivate wakeup sources, such that writing a name and optionally a timeout to wake_lock causes the wakeup source of that name to be activated, optionally with the given timeout. If that wakeup source doesn't exist, it will be created and then activated. Writing a name to wake_unlock causes the wakeup source of that name, if there is one, to be deactivated. Wakeup sources created with the help of wake_lock that haven't been used for more than 5 minutes are garbage collected and destroyed. Moreover, there can be only WL_NUMBER_LIMIT wakeup sources created with the help of wake_lock present at a time. The data type used to track wakeup sources created by user space is called "struct wakelock" to indicate the origins of this feature. This version of the patch includes an rbtree manipulation fix from John Stultz. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Reviewed-by: NeilBrown <neilb@suse.de>
2012-07-23PM / Sleep: Add "prevent autosleep time" statistics to wakeup sourcesRafael J. Wysocki
Android uses one wakelock statistics that is only necessary for opportunistic sleep. Namely, the prevent_suspend_time field accumulates the total time the given wakelock has been locked while "automatic suspend" was enabled. Add an analogous field, prevent_sleep_time, to wakeup sources and make it behave in a similar way. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-23PM / Sleep: Implement opportunistic sleep, v2Rafael J. Wysocki
Introduce a mechanism by which the kernel can trigger global transitions to a sleep state chosen by user space if there are no active wakeup sources. It consists of a new sysfs attribute, /sys/power/autosleep, that can be written one of the strings returned by reads from /sys/power/state, an ordered workqueue and a work item carrying out the "suspend" operations. If a string representing the system's sleep state is written to /sys/power/autosleep, the work item triggering transitions to that state is queued up and it requeues itself after every execution until user space writes "off" to /sys/power/autosleep. That work item enables the detection of wakeup events using the functions already defined in drivers/base/power/wakeup.c (with one small modification) and calls either pm_suspend(), or hibernate() to put the system into a sleep state. If a wakeup event is reported while the transition is in progress, it will abort the transition and the "system suspend" work item will be queued up again. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Reviewed-by: NeilBrown <neilb@suse.de>
2012-07-23PM / Hibernate: Hibernate/thaw fixes/improvementsBojan Smojver
1. Do not allocate memory for buffers from emergency pools, unless absolutely required. Do not warn about and do not retry non-essential failed allocations. 2. Do not check the amount of free pages left on every single page write, but wait until one map is completely populated and then check. 3. Set maximum number of pages for read buffering consistently, instead of inadvertently depending on the size of the sector type. 4. Fix copyright line, which I missed when I submitted the hibernation threading patch. 5. Dispense with bit shifting arithmetic to improve readability. 6. Really recalculate the number of pages required to be free after all allocations have been done. 7. Fix calculation of pages required for read buffering. Only count in pages that do not belong to high memory. Signed-off-by: Bojan Smojver <bojan@rexursive.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2012-07-23Revert "PM: Add user-space wake lock api."Varun Wadekar
This reverts commit 4a17311edfa17c502d4f5a64c569d0c4ec129f44 and commit 4d09c863239d323e34a8e59cc738f126d7ed3382. Signed-off-by: Varun Wadekar <vwadekar@nvidia.com>
2012-07-23Revert "PM: Enable partial support for FB earlysuspend"Varun Wadekar
This reverts commit 8ceec9456c21f55785c751bf76e080599cf508f3. Signed-off-by: Varun Wadekar <vwadekar@nvidia.com>
2012-07-23Revert "HACK: PM: Port early suspend functionality"Varun Wadekar
This reverts commit 228af00b84919ab817b619b13327fe36027ccdaf. Change-Id: I2ec45ca0bf42fac6d2ac754f1a1b2019ce90f20f Signed-off-by: Varun Wadekar <vwadekar@nvidia.com>
2012-07-23Revert "power: earlysuspend: suspend if user space is still asleep after resume"Varun Wadekar
This reverts commit afe26e084f0058a3fa4b98fb2cb8a56f1f94e0f8. Signed-off-by: Varun Wadekar <vwadekar@nvidia.com>
2012-07-23Revert "PM: Abort suspend if wake_lock is acquired"Varun Wadekar
This reverts commit d97f537d271166209261ff364b64b35f0ca98ced. Signed-off-by: Varun Wadekar <vwadekar@nvidia.com>
2012-07-20Merge remote-tracking branch 'origin/dev/android-t114-3.4-nv-3.1-merge' into ↵varun colbert
work
2012-07-19timekeeping: Add missing update call in timekeeping_resume()Thomas Gleixner
This is a backport of 3e997130bd2e8c6f5aaa49d6e3161d4d29b43ab0 The leap second rework unearthed another issue of inconsistent data. On timekeeping_resume() the timekeeper data is updated, but nothing calls timekeeping_update(), so now the update code in the timer interrupt sees stale values. This has been the case before those changes, but then the timer interrupt was using stale data as well so this went unnoticed for quite some time. Add the missing update call, so all the data is consistent everywhere. Reported-by: Andreas Schwab <schwab@linux-m68k.org> Reported-and-tested-by: "Rafael J. Wysocki" <rjw@sisk.pl> Reported-and-tested-by: Martin Steigerwald <Martin@lichtvoll.de> Cc: John Stultz <johnstul@us.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl>, Cc: Prarit Bhargava <prarit@redhat.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Prarit Bhargava <prarit@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-19hrtimer: Update hrtimer base offsets each hrtimer_interruptJohn Stultz
This is a backport of 5baefd6d84163443215f4a99f6a20f054ef11236 The update of the hrtimer base offsets on all cpus cannot be made atomically from the timekeeper.lock held and interrupt disabled region as smp function calls are not allowed there. clock_was_set(), which enforces the update on all cpus, is called either from preemptible process context in case of do_settimeofday() or from the softirq context when the offset modification happened in the timer interrupt itself due to a leap second. In both cases there is a race window for an hrtimer interrupt between dropping timekeeper lock, enabling interrupts and clock_was_set() issuing the updates. Any interrupt which arrives in that window will see the new time but operate on stale offsets. So we need to make sure that an hrtimer interrupt always sees a consistent state of time and offsets. ktime_get_update_offsets() allows us to get the current monotonic time and update the per cpu hrtimer base offsets from hrtimer_interrupt() to capture a consistent state of monotonic time and the offsets. The function replaces the existing ktime_get() calls in hrtimer_interrupt(). The overhead of the new function vs. ktime_get() is minimal as it just adds two store operations. This ensures that any changes to realtime or boottime offsets are noticed and stored into the per-cpu hrtimer base structures, prior to any hrtimer expiration and guarantees that timers are not expired early. Signed-off-by: John Stultz <johnstul@us.ibm.com> Reviewed-by: Ingo Molnar <mingo@kernel.org> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Prarit Bhargava <prarit@redhat.com> Link: http://lkml.kernel.org/r/1341960205-56738-8-git-send-email-johnstul@us.ibm.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Prarit Bhargava <prarit@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
