path: root/kernel
2015-09-11Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge fourth patch-bomb from Andrew Morton: - sys_membarier syscall - seq_file interface changes - a few misc fixups * emailed patches from Andrew Morton <akpm@linux-foundation.org>: revert "ocfs2/dlm: use list_for_each_entry instead of list_for_each" mm/early_ioremap: add explicit #include of asm/early_ioremap.h fs/seq_file: convert int seq_vprint/seq_printf/etc... returns to void selftests: enhance membarrier syscall test selftests: add membarrier syscall test sys_membarrier(): system-wide memory barrier (generic, x86) MODSIGN: fix a compilation warning in extract-cert
2015-09-11Merge tag 'pm+acpi-4.3-rc1-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull more power management and ACPI updates from Rafael Wysocki: "These are mostly fixes and cleanups on top of the previous PM+ACPI pull request (cpufreq core and drivers, cpuidle, generic power domains framework). Some of them didn't make to that pull request and some fix issues introduced by it. The only really new thing is the support for suspend frequency in the cpufreq-dt driver, but it is needed to fix an issue with Exynos platforms. Specifics: - build fix for the new Mediatek MT8173 cpufreq driver (Guenter Roeck). - generic power domains framework fixes (power on error code path, subdomain removal) and cleanup of a deprecated API user (Geert Uytterhoeven, Jon Hunter, Ulf Hansson). - cpufreq-dt driver fixes including two fixes for bugs related to the new Operating Performance Points Device Tree bindings introduced recently (Viresh Kumar). - suspend frequency support for the cpufreq-dt driver (Bartlomiej Zolnierkiewicz, Viresh Kumar). - cpufreq core cleanups (Viresh Kumar). - intel_pstate driver fixes (Chen Yu, Kristen Carlson Accardi). - additional sanity check in the cpuidle core (Xunlei Pang). - fix for a comment related to CPU power management (Lina Iyer)" * tag 'pm+acpi-4.3-rc1-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: intel_pstate: fix PCT_TO_HWP macro intel_pstate: Fix user input of min/max to legal policy region PM / OPP: Return suspend_opp only if it is enabled cpufreq-dt: add suspend frequency support cpufreq: allow cpufreq_generic_suspend() to work without suspend frequency PM / OPP: add dev_pm_opp_get_suspend_opp() helper staging: board: Migrate away from __pm_genpd_name_add_device() cpufreq: Use __func__ to print function's name cpufreq: staticize cpufreq_cpu_get_raw() PM / Domains: Ensure subdomain is not in use before removing cpufreq: Add ARM_MT8173_CPUFREQ dependency on THERMAL cpuidle/coupled: Add sanity check for safe_state_index PM / Domains: Try power off masters in error path of __pm_genpd_poweron() cpufreq: dt: Tolerance applies on both sides of target voltage cpufreq: dt: Print error on failing to mark OPPs as shared cpufreq: dt: Check OPP count before marking them shared kernel/cpu_pm: fix cpu_cluster_pm_exit comment
2015-09-11sys_membarrier(): system-wide memory barrier (generic, x86)Mathieu Desnoyers
Here is an implementation of a new system call, sys_membarrier(), which executes a memory barrier on all threads running on the system. It is implemented by calling synchronize_sched(). It can be used to distribute the cost of user-space memory barriers asymmetrically by transforming pairs of memory barriers into pairs consisting of sys_membarrier() and a compiler barrier. For synchronization primitives that distinguish between read-side and write-side (e.g. userspace RCU [1], rwlocks), the read-side can be accelerated significantly by moving the bulk of the memory barrier overhead to the write-side. The existing applications of which I am aware that would be improved by this system call are as follows: * Through Userspace RCU library (http://urcu.so) - DNS server (Knot DNS) https://www.knot-dns.cz/ - Network sniffer (http://netsniff-ng.org/) - Distributed object storage (https://sheepdog.github.io/sheepdog/) - User-space tracing (http://lttng.org) - Network storage system (https://www.gluster.org/) - Virtual routers (https://events.linuxfoundation.org/sites/events/files/slides/DPDK_RCU_0MQ.pdf) - Financial software (https://lkml.org/lkml/2015/3/23/189) Those projects use RCU in userspace to increase read-side speed and scalability compared to locking. Especially in the case of RCU used by libraries, sys_membarrier can speed up the read-side by moving the bulk of the memory barrier cost to synchronize_rcu(). * Direct users of sys_membarrier - core dotnet garbage collector (https://github.com/dotnet/coreclr/issues/198) Microsoft core dotnet GC developers are planning to use the mprotect() side-effect of issuing memory barriers through IPIs as a way to implement Windows FlushProcessWriteBuffers() on Linux. They are referring to sys_membarrier in their github thread, specifically stating that sys_membarrier() is what they are looking for. To explain the benefit of this scheme, let's introduce two example threads: Thread A (non-frequent, e.g. executing liburcu synchronize_rcu()) Thread B (frequent, e.g. executing liburcu rcu_read_lock()/rcu_read_unlock()) In a scheme where all smp_mb() in thread A are ordering memory accesses with respect to smp_mb() present in Thread B, we can change each smp_mb() within Thread A into calls to sys_membarrier() and each smp_mb() within Thread B into compiler barriers "barrier()". Before the change, we had, for each smp_mb() pairs: Thread A Thread B previous mem accesses previous mem accesses smp_mb() smp_mb() following mem accesses following mem accesses After the change, these pairs become: Thread A Thread B prev mem accesses prev mem accesses sys_membarrier() barrier() follow mem accesses follow mem accesses As we can see, there are two possible scenarios: either Thread B memory accesses do not happen concurrently with Thread A accesses (1), or they do (2). 1) Non-concurrent Thread A vs Thread B accesses: Thread A Thread B prev mem accesses sys_membarrier() follow mem accesses prev mem accesses barrier() follow mem accesses In this case, thread B accesses will be weakly ordered. This is OK, because at that point, thread A is not particularly interested in ordering them with respect to its own accesses. 2) Concurrent Thread A vs Thread B accesses Thread A Thread B prev mem accesses prev mem accesses sys_membarrier() barrier() follow mem accesses follow mem accesses In this case, thread B accesses, which are ensured to be in program order thanks to the compiler barrier, will be "upgraded" to full smp_mb() by synchronize_sched(). * Benchmarks On Intel Xeon E5405 (8 cores) (one thread is calling sys_membarrier, the other 7 threads are busy looping) 1000 non-expedited sys_membarrier calls in 33s =3D 33 milliseconds/call. * User-space user of this system call: Userspace RCU library Both the signal-based and the sys_membarrier userspace RCU schemes permit us to remove the memory barrier from the userspace RCU rcu_read_lock() and rcu_read_unlock() primitives, thus significantly accelerating them. These memory barriers are replaced by compiler barriers on the read-side, and all matching memory barriers on the write-side are turned into an invocation of a memory barrier on all active threads in the process. By letting the kernel perform this synchronization rather than dumbly sending a signal to every process threads (as we currently do), we diminish the number of unnecessary wake ups and only issue the memory barriers on active threads. Non-running threads do not need to execute such barrier anyway, because these are implied by the scheduler context switches. Results in liburcu: Operations in 10s, 6 readers, 2 writers: memory barriers in reader: 1701557485 reads, 2202847 writes signal-based scheme: 9830061167 reads, 6700 writes sys_membarrier: 9952759104 reads, 425 writes sys_membarrier (dyn. check): 7970328887 reads, 425 writes The dynamic sys_membarrier availability check adds some overhead to the read-side compared to the signal-based scheme, but besides that, sys_membarrier slightly outperforms the signal-based scheme. However, this non-expedited sys_membarrier implementation has a much slower grace period than signal and memory barrier schemes. Besides diminishing the number of wake-ups, one major advantage of the membarrier system call over the signal-based scheme is that it does not need to reserve a signal. This plays much more nicely with libraries, and with processes injected into for tracing purposes, for which we cannot expect that signals will be unused by the application. An expedited version of this system call can be added later on to speed up the grace period. Its implementation will likely depend on reading the cpu_curr()->mm without holding each CPU's rq lock. This patch adds the system call to x86 and to asm-generic. [1] http://urcu.so membarrier(2) man page: MEMBARRIER(2) Linux Programmer's Manual MEMBARRIER(2) NAME membarrier - issue memory barriers on a set of threads SYNOPSIS #include <linux/membarrier.h> int membarrier(int cmd, int flags); DESCRIPTION The cmd argument is one of the following: MEMBARRIER_CMD_QUERY Query the set of supported commands. It returns a bitmask of supported commands. MEMBARRIER_CMD_SHARED Execute a memory barrier on all threads running on the system. Upon return from system call, the caller thread is ensured that all running threads have passed through a state where all memory accesses to user-space addresses match program order between entry to and return from the system call (non-running threads are de facto in such a state). This covers threads from all pro=E2=80=90 cesses running on the system. This command returns 0. The flags argument needs to be 0. For future extensions. All memory accesses performed in program order from each targeted thread is guaranteed to be ordered with respect to sys_membarrier(). If we use the semantic "barrier()" to represent a compiler barrier forcing memory accesses to be performed in program order across the barrier, and smp_mb() to represent explicit memory barriers forcing full memory ordering across the barrier, we have the following ordering table for each pair of barrier(), sys_membarrier() and smp_mb(): The pair ordering is detailed as (O: ordered, X: not ordered): barrier() smp_mb() sys_membarrier() barrier() X X O smp_mb() X O O sys_membarrier() O O O RETURN VALUE On success, these system calls return zero. On error, -1 is returned, and errno is set appropriately. For a given command, with flags argument set to 0, this system call is guaranteed to always return the same value until reboot. ERRORS ENOSYS System call is not implemented. EINVAL Invalid arguments. Linux 2015-04-15 MEMBARRIER(2) Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Nicholas Miell <nmiell@comcast.net> Cc: Ingo Molnar <mingo@redhat.com> Cc: Alan Cox <gnomes@lxorguk.ukuu.org.uk> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Stephen Hemminger <stephen@networkplumber.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: David Howells <dhowells@redhat.com> Cc: Pranith Kumar <bobby.prani@gmail.com> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Shuah Khan <shuahkh@osg.samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-11Merge branches 'pm-cpu', 'pm-cpuidle' and 'pm-domains'Rafael J. Wysocki
* pm-cpu: kernel/cpu_pm: fix cpu_cluster_pm_exit comment * pm-cpuidle: cpuidle/coupled: Add sanity check for safe_state_index * pm-domains: staging: board: Migrate away from __pm_genpd_name_add_device() PM / Domains: Ensure subdomain is not in use before removing PM / Domains: Try power off masters in error path of __pm_genpd_poweron()
2015-09-10Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge third patch-bomb from Andrew Morton: - even more of the rest of MM - lib/ updates - checkpatch updates - small changes to a few scruffy filesystems - kmod fixes/cleanups - kexec updates - a dma-mapping cleanup series from hch * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (81 commits) dma-mapping: consolidate dma_set_mask dma-mapping: consolidate dma_supported dma-mapping: cosolidate dma_mapping_error dma-mapping: consolidate dma_{alloc,free}_noncoherent dma-mapping: consolidate dma_{alloc,free}_{attrs,coherent} mm: use vma_is_anonymous() in create_huge_pmd() and wp_huge_pmd() mm: make sure all file VMAs have ->vm_ops set mm, mpx: add "vm_flags_t vm_flags" arg to do_mmap_pgoff() mm: mark most vm_operations_struct const namei: fix warning while make xmldocs caused by namei.c ipc: convert invalid scenarios to use WARN_ON zlib_deflate/deftree: remove bi_reverse() lib/decompress_unlzma: Do a NULL check for pointer lib/decompressors: use real out buf size for gunzip with kernel fs/affs: make root lookup from blkdev logical size sysctl: fix int -> unsigned long assignments in INT_MIN case kexec: export KERNEL_IMAGE_SIZE to vmcoreinfo kexec: align crash_notes allocation to make it be inside one physical page kexec: remove unnecessary test in kimage_alloc_crash_control_pages() kexec: split kexec_load syscall from kexec core code ...
2015-09-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Fix out-of-bounds array access in netfilter ipset, from Jozsef Kadlecsik. 2) Use correct free operation on netfilter conntrack templates, from Daniel Borkmann. 3) Fix route leak in SCTP, from Marcelo Ricardo Leitner. 4) Fix sizeof(pointer) in mac80211, from Thierry Reding. 5) Fix cache pointer comparison in ip6mr leading to missed unlock of mrt_lock. From Richard Laing. 6) rds_conn_lookup() needs to consider network namespace in key comparison, from Sowmini Varadhan. 7) Fix deadlock in TIPC code wrt broadcast link wakeups, from Kolmakov Dmitriy. 8) Fix fd leaks in bpf syscall, from Daniel Borkmann. 9) Fix error recovery when installing ipv6 multipath routes, we would delete the old route before we would know if we could fully commit to the new set of nexthops. Fix from Roopa Prabhu. 10) Fix run-time suspend problems in r8152, from Hayes Wang. 11) In fec, don't program the MAC address into the chip when the clocks are gated off. From Fugang Duan. 12) Fix poll behavior for netlink sockets when using rx ring mmap, from Daniel Borkmann. 13) Don't allocate memory with GFP_KERNEL from get_stats64 in r8169 driver, from Corinna Vinschen. 14) In TCP Cubic congestion control, handle idle periods better where we are application limited, in order to keep cwnd from growing out of control. From Eric Dumzet. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (65 commits) tcp_cubic: better follow cubic curve after idle period tcp: generate CA_EVENT_TX_START on data frames xen-netfront: respect user provided max_queues xen-netback: respect user provided max_queues r8169: Fix sleeping function called during get_stats64, v2 ether: add IEEE 1722 ethertype - TSN netlink, mmap: fix edge-case leakages in nf queue zero-copy netlink, mmap: don't walk rx ring on poll if receive queue non-empty cxgb4: changes for new firmware 1.14.4.0 net: fec: add netif status check before set mac address r8152: fix the runtime suspend issues r8152: split DRIVER_VERSION ipv6: fix ifnullfree.cocci warnings add microchip LAN88xx phy driver stmmac: fix check for phydev being open net: qlcnic: delete redundant memsets net: mv643xx_eth: use kzalloc net: jme: use kzalloc() instead of kmalloc+memset net: cavium: liquidio: use kzalloc in setup_glist() net: ipv6: use common fib_default_rule_pref ...
2015-09-10sysctl: fix int -> unsigned long assignments in INT_MIN caseIlya Dryomov
The following if (val < 0) *lvalp = (unsigned long)-val; is incorrect because the compiler is free to assume -val to be positive and use a sign-extend instruction for extending the bit pattern. This is a problem if val == INT_MIN: # echo -2147483648 >/proc/sys/dev/scsi/logging_level # cat /proc/sys/dev/scsi/logging_level -18446744071562067968 Cast to unsigned long before negation - that way we first sign-extend and then negate an unsigned, which is well defined. With this: # cat /proc/sys/dev/scsi/logging_level -2147483648 Signed-off-by: Ilya Dryomov <idryomov@gmail.com> Cc: Mikulas Patocka <mikulas@twibright.com> Cc: Robert Xiao <nneonneo@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Kees Cook <keescook@chromium.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10kexec: export KERNEL_IMAGE_SIZE to vmcoreinfoBaoquan He
In x86_64, since v2.6.26 the KERNEL_IMAGE_SIZE is changed to 512M, and accordingly the MODULES_VADDR is changed to 0xffffffffa0000000. However, in v3.12 Kees Cook introduced kaslr to randomise the location of kernel. And the kernel text mapping addr space is enlarged from 512M to 1G. That means now KERNEL_IMAGE_SIZE is variable, its value is 512M when kaslr support is not compiled in and 1G when kaslr support is compiled in. Accordingly the MODULES_VADDR is changed too to be: #define MODULES_VADDR (__START_KERNEL_map + KERNEL_IMAGE_SIZE) So when kaslr is compiled in and enabled, the kernel text mapping addr space and modules vaddr space need be adjusted. Otherwise makedumpfile will collapse since the addr for some symbols is not correct. Hence KERNEL_IMAGE_SIZE need be exported to vmcoreinfo and got in makedumpfile to help calculate MODULES_VADDR. Signed-off-by: Baoquan He <bhe@redhat.com> Acked-by: Kees Cook <keescook@chromium.org> Acked-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10kexec: align crash_notes allocation to make it be inside one physical pageBaoquan He
People reported that crash_notes in /proc/vmcore were corrupted and this cause crash kdump failure. With code debugging and log we got the root cause. This is because percpu variable crash_notes are allocated in 2 vmalloc pages. Currently percpu is based on vmalloc by default. Vmalloc can't guarantee 2 continuous vmalloc pages are also on 2 continuous physical pages. So when 1st kernel exports the starting address and size of crash_notes through sysfs like below: /sys/devices/system/cpu/cpux/crash_notes /sys/devices/system/cpu/cpux/crash_notes_size kdump kernel use them to get the content of crash_notes. However the 2nd part may not be in the next neighbouring physical page as we expected if crash_notes are allocated accross 2 vmalloc pages. That's why nhdr_ptr->n_namesz or nhdr_ptr->n_descsz could be very huge in update_note_header_size_elf64() and cause note header merging failure or some warnings. In this patch change to call __alloc_percpu() to passed in the align value by rounding crash_notes_size up to the nearest power of two. This makes sure the crash_notes is allocated inside one physical page since sizeof(note_buf_t) in all ARCHS is smaller than PAGE_SIZE. Meanwhile add a BUILD_BUG_ON to break compile if size is bigger than PAGE_SIZE since crash_notes definitely will be in 2 pages. That need be avoided, and need be reported if it's unavoidable. [akpm@linux-foundation.org: use correct comment layout] Signed-off-by: Baoquan He <bhe@redhat.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Dave Young <dyoung@redhat.com> Cc: Lisa Mitchell <lisa.mitchell@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10kexec: remove unnecessary test in kimage_alloc_crash_control_pages()Minfei Huang
Transforming PFN(Page Frame Number) to struct page is never failure, so we can simplify the code logic to do the image->control_page assignment directly in the loop, and remove the unnecessary conditional judgement. Signed-off-by: Minfei Huang <mnfhuang@gmail.com> Acked-by: Dave Young <dyoung@redhat.com> Acked-by: Vivek Goyal <vgoyal@redhat.com> Cc: Simon Horman <horms@verge.net.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10kexec: split kexec_load syscall from kexec core codeDave Young
There are two kexec load syscalls, kexec_load another and kexec_file_load. kexec_file_load has been splited as kernel/kexec_file.c. In this patch I split kexec_load syscall code to kernel/kexec.c. And add a new kconfig option KEXEC_CORE, so we can disable kexec_load and use kexec_file_load only, or vice verse. The original requirement is from Ted Ts'o, he want kexec kernel signature being checked with CONFIG_KEXEC_VERIFY_SIG enabled. But kexec-tools use kexec_load syscall can bypass the checking. Vivek Goyal proposed to create a common kconfig option so user can compile in only one syscall for loading kexec kernel. KEXEC/KEXEC_FILE selects KEXEC_CORE so that old config files still work. Because there's general code need CONFIG_KEXEC_CORE, so I updated all the architecture Kconfig with a new option KEXEC_CORE, and let KEXEC selects KEXEC_CORE in arch Kconfig. Also updated general kernel code with to kexec_load syscall. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Dave Young <dyoung@redhat.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Petr Tesarik <ptesarik@suse.cz> Cc: Theodore Ts'o <tytso@mit.edu> Cc: Josh Boyer <jwboyer@fedoraproject.org> Cc: David Howells <dhowells@redhat.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10kexec: split kexec_file syscall code to kexec_file.cDave Young
Split kexec_file syscall related code to another file kernel/kexec_file.c so that the #ifdef CONFIG_KEXEC_FILE in kexec.c can be dropped. Sharing variables and functions are moved to kernel/kexec_internal.h per suggestion from Vivek and Petr. [akpm@linux-foundation.org: fix bisectability] [akpm@linux-foundation.org: declare the various arch_kexec functions] [akpm@linux-foundation.org: fix build] Signed-off-by: Dave Young <dyoung@redhat.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Petr Tesarik <ptesarik@suse.cz> Cc: Theodore Ts'o <tytso@mit.edu> Cc: Josh Boyer <jwboyer@fedoraproject.org> Cc: David Howells <dhowells@redhat.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10kmod: handle UMH_WAIT_PROC from system unbound workqueueFrederic Weisbecker
The UMH_WAIT_PROC handler runs in its own thread in order to make sure that waiting for the exec kernel thread completion won't block other usermodehelper queued jobs. On older workqueue implementations, worklets couldn't sleep without blocking the rest of the queue. But now the workqueue subsystem handles that. Khelper still had the older limitation due to its singlethread properties but we replaced it to system unbound workqueues. Those are affine to the current node and can block up to some number of instances. They are a good candidate to handle UMH_WAIT_PROC assuming that we have enough system unbound workers to handle lots of parallel usermodehelper jobs. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Rik van Riel <riel@redhat.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Cc: Christoph Lameter <cl@linux.com> Cc: Tejun Heo <tj@kernel.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10kmod: use system_unbound_wq instead of khelperFrederic Weisbecker
We need to launch the usermodehelper kernel threads with the widest affinity and this is partly why we use khelper. This workqueue has unbound properties and thus a wide affinity inherited by all its children. Now khelper also has special properties that we aren't much interested in: ordered and singlethread. There is really no need about ordering as all we do is creating kernel threads. This can be done concurrently. And singlethread is a useless limitation as well. The workqueue engine already proposes generic unbound workqueues that don't share these useless properties and handle well parallel jobs. The only worrysome specific is their affinity to the node of the current CPU. It's fine for creating the usermodehelper kernel threads but those inherit this affinity for longer jobs such as requesting modules. This patch proposes to use these node affine unbound workqueues assuming that a node is sufficient to handle several parallel usermodehelper requests. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Rik van Riel <riel@redhat.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Cc: Christoph Lameter <cl@linux.com> Cc: Tejun Heo <tj@kernel.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10kmod: add up-to-date explanations on the purpose of each asynchronous levelsFrederic Weisbecker
There seem to be quite some confusions on the comments, likely due to changes that came after them. Now since it's very non obvious why we have 3 levels of asynchronous code to implement usermodehelpers, it's important to comment in detail the reason of this layout. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Rik van Riel <riel@redhat.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Cc: Christoph Lameter <cl@linux.com> Cc: Tejun Heo <tj@kernel.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10kmod: remove unecessary explicit wide CPU affinity settingFrederic Weisbecker
Khelper is affine to all CPUs. Now since it creates the call_usermodehelper_exec_[a]sync() kernel threads, those inherit the wide affinity. As such explicitly forcing a wide affinity from those kernel threads is like a no-op. Just remove it. It's needless and it breaks CPU isolation users who rely on workqueue affinity tuning. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Rik van Riel <riel@redhat.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Cc: Christoph Lameter <cl@linux.com> Cc: Tejun Heo <tj@kernel.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10kmod: bunch of internal functions renamesFrederic Weisbecker
This patchset does a bunch of cleanups and converts khelper to use system unbound workqueues. The 3 first patches should be uncontroversial. The last 2 patches are debatable. Kmod creates kernel threads that perform userspace jobs and we want those to have a large affinity in order not to contend busy CPUs. This is (partly) why we use khelper which has a wide affinity that the kernel threads it create can inherit from. Now khelper is a dedicated workqueue that has singlethread properties which we aren't interested in. Hence those two debatable changes: _ We would like to use generic workqueues. System unbound workqueues are a very good candidate but they are not wide affine, only node affine. Now probably a node is enough to perform many parallel kmod jobs. _ We would like to remove the wait_for_helper kernel thread (UMH_WAIT_PROC handler) to use the workqueue. It means that if the workqueue blocks, and no other worker can take pending kmod request, we can be screwed. Now if we have 512 threads, this should be enough. This patch (of 5): Underscores on function names aren't much verbose to explain the purpose of a function. And kmod has interesting such flavours. Lets rename the following functions: * __call_usermodehelper -> call_usermodehelper_exec_work * ____call_usermodehelper -> call_usermodehelper_exec_async * wait_for_helper -> call_usermodehelper_exec_sync Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Rik van Riel <riel@redhat.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Cc: Christoph Lameter <cl@linux.com> Cc: Tejun Heo <tj@kernel.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10kmod: correct documentation of return status of request_moduleNeilBrown
If request_module() successfully runs modprobe, but modprobe exits with a non-zero status, then the return value from request_module() will be that (positive) error status. So the return from request_module can be: negative errno zero for success positive exit code. Signed-off-by: NeilBrown <neilb@suse.com> Cc: Goldwyn Rodrigues <rgoldwyn@suse.de> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Tejun Heo <tj@kernel.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10kernel/cred.c: remove unnecessary kdebug atomic readsJoe Perches
Commit e0e817392b9a ("CRED: Add some configurable debugging [try #6]") added the kdebug mechanism to this file back in 2009. The kdebug macro calls no_printk which always evaluates arguments. Most of the kdebug uses have an unnecessary call of atomic_read(&cred->usage) Make the kdebug macro do nothing by defining it with do { if (0) no_printk(...); } while (0) when not enabled. $ size kernel/cred.o* (defconfig x86-64) text data bss dec hex filename 2748 336 8 3092 c14 kernel/cred.o.new 2788 336 8 3132 c3c kernel/cred.o.old Miscellanea: o Neaten the #define kdebug macros while there Signed-off-by: Joe Perches <joe@perches.com> Cc: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10kernel/extable.c: remove duplicated includeWei Yongjun
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-09bpf: fix out of bounds access in verifier logAlexei Starovoitov
when the verifier log is enabled the print_bpf_insn() is doing bpf_alu_string[BPF_OP(insn->code) >> 4] and bpf_jmp_string[BPF_OP(insn->code) >> 4] where BPF_OP is a 4-bit instruction opcode. Malformed insns can cause out of bounds access. Fix it by sizing arrays appropriately. The bug was found by clang address sanitizer with libfuzzer. Reported-by: Yonghong Song <yhs@plumgrid.com> Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-09ebpf: fix fd refcount leaks related to maps in bpf syscallDaniel Borkmann
We may already have gotten a proper fd struct through fdget(), so whenever we return at the end of an map operation, we need to call fdput(). However, each map operation from syscall side first probes CHECK_ATTR() to verify that unused fields in the bpf_attr union are zero. In case of malformed input, we return with error, but the lookup to the map_fd was already performed at that time, so that we return without an corresponding fdput(). Fix it by performing an fdget() only right before bpf_map_get(). The fdget() invocation on maps in the verifier is not affected. Fixes: db20fd2b0108 ("bpf: add lookup/update/delete/iterate methods to BPF maps") Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-08Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge second patch-bomb from Andrew Morton: "Almost all of the rest of MM. There was an unusually large amount of MM material this time" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (141 commits) zpool: remove no-op module init/exit mm: zbud: constify the zbud_ops mm: zpool: constify the zpool_ops mm: swap: zswap: maybe_preload & refactoring zram: unify error reporting zsmalloc: remove null check from destroy_handle_cache() zsmalloc: do not take class lock in zs_shrinker_count() zsmalloc: use class->pages_per_zspage zsmalloc: consider ZS_ALMOST_FULL as migrate source zsmalloc: partial page ordering within a fullness_list zsmalloc: use shrinker to trigger auto-compaction zsmalloc: account the number of compacted pages zsmalloc/zram: introduce zs_pool_stats api zsmalloc: cosmetic compaction code adjustments zsmalloc: introduce zs_can_compact() function zsmalloc: always keep per-class stats zsmalloc: drop unused variable `nr_to_migrate' mm/memblock.c: fix comment in __next_mem_range() mm/page_alloc.c: fix type information of memoryless node memory-hotplug: fix comments in zone_spanned_pages_in_node() and zone_spanned_pages_in_node() ...
2015-09-08mm: rename alloc_pages_exact_node() to __alloc_pages_node()Vlastimil Babka
alloc_pages_exact_node() was introduced in commit 6484eb3e2a81 ("page allocator: do not check NUMA node ID when the caller knows the node is valid") as an optimized variant of alloc_pages_node(), that doesn't fallback to current node for nid == NUMA_NO_NODE. Unfortunately the name of the function can easily suggest that the allocation is restricted to the given node and fails otherwise. In truth, the node is only preferred, unless __GFP_THISNODE is passed among the gfp flags. The misleading name has lead to mistakes in the past, see for example commits 5265047ac301 ("mm, thp: really limit transparent hugepage allocation to local node") and b360edb43f8e ("mm, mempolicy: migrate_to_node should only migrate to node"). Another issue with the name is that there's a family of alloc_pages_exact*() functions where 'exact' means exact size (instead of page order), which leads to more confusion. To prevent further mistakes, this patch effectively renames alloc_pages_exact_node() to __alloc_pages_node() to better convey that it's an optimized variant of alloc_pages_node() not intended for general usage. Both functions get described in comments. It has been also considered to really provide a convenience function for allocations restricted to a node, but the major opinion seems to be that __GFP_THISNODE already provides that functionality and we shouldn't duplicate the API needlessly. The number of users would be small anyway. Existing callers of alloc_pages_exact_node() are simply converted to call __alloc_pages_node(), with the exception of sba_alloc_coherent() which open-codes the check for NUMA_NO_NODE, so it is converted to use alloc_pages_node() instead. This means it no longer performs some VM_BUG_ON checks, and since the current check for nid in alloc_pages_node() uses a 'nid < 0' comparison (which includes NUMA_NO_NODE), it may hide wrong values which would be previously exposed. Both differences will be rectified by the next patch. To sum up, this patch makes no functional changes, except temporarily hiding potentially buggy callers. Restricting the checks in alloc_pages_node() is left for the next patch which can in turn expose more existing buggy callers. Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Robin Holt <robinmholt@gmail.com> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Christoph Lameter <cl@linux.com> Acked-by: Michael Ellerman <mpe@ellerman.id.au> Cc: Mel Gorman <mgorman@suse.de> Cc: David Rientjes <rientjes@google.com> Cc: Greg Thelen <gthelen@google.com> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Gleb Natapov <gleb@kernel.org> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Cliff Whickman <cpw@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-08cgroup: fix seq_show_option merge with legacy_nameKees Cook
When seq_show_option (commit a068acf2ee77: "fs: create and use seq_show_option for escaping") was merged, it did not correctly collide with cgroup's addition of legacy_name (commit 3e1d2eed39d8: "cgroup: introduce cgroup_subsys->legacy_name") changes. This fixes the reported name. Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-08Merge tag 'libnvdimm-for-4.3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm Pull libnvdimm updates from Dan Williams: "This update has successfully completed a 0day-kbuild run and has appeared in a linux-next release. The changes outside of the typical drivers/nvdimm/ and drivers/acpi/nfit.[ch] paths are related to the removal of IORESOURCE_CACHEABLE, the introduction of memremap(), and the introduction of ZONE_DEVICE + devm_memremap_pages(). Summary: - Introduce ZONE_DEVICE and devm_memremap_pages() as a generic mechanism for adding device-driver-discovered memory regions to the kernel's direct map. This facility is used by the pmem driver to enable pfn_to_page() operations on the page frames returned by DAX ('direct_access' in 'struct block_device_operations'). For now, the 'memmap' allocation for these "device" pages comes from "System RAM". Support for allocating the memmap from device memory will arrive in a later kernel. - Introduce memremap() to replace usages of ioremap_cache() and ioremap_wt(). memremap() drops the __iomem annotation for these mappings to memory that do not have i/o side effects. The replacement of ioremap_cache() with memremap() is limited to the pmem driver to ease merging the api change in v4.3. Completion of the conversion is targeted for v4.4. - Similar to the usage of memcpy_to_pmem() + wmb_pmem() in the pmem driver, update the VFS DAX implementation and PMEM api to provide persistence guarantees for kernel operations on a DAX mapping. - Convert the ACPI NFIT 'BLK' driver to map the block apertures as cacheable to improve performance. - Miscellaneous updates and fixes to libnvdimm including support for issuing "address range scrub" commands, clarifying the optimal 'sector size' of pmem devices, a clarification of the usage of the ACPI '_STA' (status) property for DIMM devices, and other minor fixes" * tag 'libnvdimm-for-4.3' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm: (34 commits) libnvdimm, pmem: direct map legacy pmem by default libnvdimm, pmem: 'struct page' for pmem libnvdimm, pfn: 'struct page' provider infrastructure x86, pmem: clarify that ARCH_HAS_PMEM_API implies PMEM mapped WB add devm_memremap_pages mm: ZONE_DEVICE for "device memory" mm: move __phys_to_pfn and __pfn_to_phys to asm/generic/memory_model.h dax: drop size parameter to ->direct_access() nd_blk: change aperture mapping from WC to WB nvdimm: change to use generic kvfree() pmem, dax: have direct_access use __pmem annotation dax: update I/O path to do proper PMEM flushing pmem: add copy_from_iter_pmem() and clear_pmem() pmem, x86: clean up conditional pmem includes pmem: remove layer when calling arch_has_wmb_pmem() pmem, x86: move x86 PMEM API to new pmem.h header libnvdimm, e820: make CONFIG_X86_PMEM_LEGACY a tristate option pmem: switch to devm_ allocations devres: add devm_memremap libnvdimm, btt: write and validate parent_uuid ...
2015-09-08Merge tag 'trace-v4.3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull tracing update from Steven Rostedt: "Mostly this is just clean ups and micro optimizations. The changes with more meat are: - Allowing the trace event filters to filter on CPU number and process ids - Two new markers for trace output latency were added (10 and 100 msec latencies) - Have tracing_thresh filter function profiling time I also worked on modifying the ring buffer code for some future work, and moved the adding of the timestamp around. One of my changes caused a regression, and since other changes were built on top of it and already tested, I had to operate a revert of that change. Instead of rebasing, this change set has the code that caused a regression as well as the code to revert that change without touching the other changes that were made on top of it" * tag 'trace-v4.3' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: ring-buffer: Revert "ring-buffer: Get timestamp after event is allocated" tracing: Don't make assumptions about length of string on task rename tracing: Allow triggers to filter for CPU ids and process names ftrace: Format MCOUNT_ADDR address as type unsigned long tracing: Introduce two additional marks for delay ftrace: Fix function_graph duration spacing with 7-digits ftrace: add tracing_thresh to function profile tracing: Clean up stack tracing and fix fentry updates ring-buffer: Reorganize function locations ring-buffer: Make sure event has enough room for extend and padding ring-buffer: Get timestamp after event is allocated ring-buffer: Move the adding of the extended timestamp out of line ring-buffer: Add event descriptor to simplify passing data ftrace: correct the counter increment for trace_buffer data tracing: Fix for non-continuous cpu ids tracing: Prefer kcalloc over kzalloc with multiply
2015-09-08Merge branch 'upstream' of git://git.infradead.org/users/pcmoore/auditLinus Torvalds
Pull audit update from Paul Moore: "This is one of the larger audit patchsets in recent history, consisting of eight patches and almost 400 lines of changes. The bulk of the patchset is the new "audit by executable" functionality which allows admins to set an audit watch based on the executable on disk. Prior to this, admins could only track an application by PID, which has some obvious limitations. Beyond the new functionality we also have some refcnt fixes and a few minor cleanups" * 'upstream' of git://git.infradead.org/users/pcmoore/audit: fixup: audit: implement audit by executable audit: implement audit by executable audit: clean simple fsnotify implementation audit: use macros for unset inode and device values audit: make audit_del_rule() more robust audit: fix uninitialized variable in audit_add_rule() audit: eliminate unnecessary extra layer of watch parent references audit: eliminate unnecessary extra layer of watch references
2015-09-08Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "Highlights: - PKCS#7 support added to support signed kexec, also utilized for module signing. See comments in 3f1e1bea. ** NOTE: this requires linking against the OpenSSL library, which must be installed, e.g. the openssl-devel on Fedora ** - Smack - add IPv6 host labeling; ignore labels on kernel threads - support smack labeling mounts which use binary mount data - SELinux: - add ioctl whitelisting (see http://kernsec.org/files/lss2015/vanderstoep.pdf) - fix mprotect PROT_EXEC regression caused by mm change - Seccomp: - add ptrace options for suspend/resume" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (57 commits) PKCS#7: Add OIDs for sha224, sha284 and sha512 hash algos and use them Documentation/Changes: Now need OpenSSL devel packages for module signing scripts: add extract-cert and sign-file to .gitignore modsign: Handle signing key in source tree modsign: Use if_changed rule for extracting cert from module signing key Move certificate handling to its own directory sign-file: Fix warning about BIO_reset() return value PKCS#7: Add MODULE_LICENSE() to test module Smack - Fix build error with bringup unconfigured sign-file: Document dependency on OpenSSL devel libraries PKCS#7: Appropriately restrict authenticated attributes and content type KEYS: Add a name for PKEY_ID_PKCS7 PKCS#7: Improve and export the X.509 ASN.1 time object decoder modsign: Use extract-cert to process CONFIG_SYSTEM_TRUSTED_KEYS extract-cert: Cope with multiple X.509 certificates in a single file sign-file: Generate CMS message as signature instead of PKCS#7 PKCS#7: Support CMS messages also [RFC5652] X.509: Change recorded SKID & AKID to not include Subject or Issuer PKCS#7: Check content type and versions MAINTAINERS: The keyrings mailing list has moved ...
2015-09-05Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: "In this one: - d_move fixes (Eric Biederman) - UFS fixes (me; locking is mostly sane now, a bunch of bugs in error handling ought to be fixed) - switch of sb_writers to percpu rwsem (Oleg Nesterov) - superblock scalability (Josef Bacik and Dave Chinner) - swapon(2) race fix (Hugh Dickins)" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (65 commits) vfs: Test for and handle paths that are unreachable from their mnt_root dcache: Reduce the scope of i_lock in d_splice_alias dcache: Handle escaped paths in prepend_path mm: fix potential data race in SyS_swapon inode: don't softlockup when evicting inodes inode: rename i_wb_list to i_io_list sync: serialise per-superblock sync operations inode: convert inode_sb_list_lock to per-sb inode: add hlist_fake to avoid the inode hash lock in evict writeback: plug writeback at a high level change sb_writers to use percpu_rw_semaphore shift percpu_counter_destroy() into destroy_super_work() percpu-rwsem: kill CONFIG_PERCPU_RWSEM percpu-rwsem: introduce percpu_rwsem_release() and percpu_rwsem_acquire() percpu-rwsem: introduce percpu_down_read_trylock() document rwsem_release() in sb_wait_write() fix the broken lockdep logic in __sb_start_write() introduce __sb_writers_{acquired,release}() helpers ufs_inode_get{frag,block}(): get rid of 'phys' argument ufs_getfrag_block(): tidy up a bit ...
2015-09-05Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge patch-bomb from Andrew Morton: - a few misc things - Andy's "ambient capabilities" - fs/nofity updates - the ocfs2 queue - kernel/watchdog.c updates and feature work. - some of MM. Includes Andrea's userfaultfd feature. [ Hadn't noticed that userfaultfd was 'default y' when applying the patches, so that got fixed in this merge instead. We do _not_ mark new features that nobody uses yet 'default y' - Linus ] * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (118 commits) mm/hugetlb.c: make vma_has_reserves() return bool mm/madvise.c: make madvise_behaviour_valid() return bool mm/memory.c: make tlb_next_batch() return bool mm/dmapool.c: change is_page_busy() return from int to bool mm: remove struct node_active_region mremap: simplify the "overlap" check in mremap_to() mremap: don't do uneccesary checks if new_len == old_len mremap: don't do mm_populate(new_addr) on failure mm: move ->mremap() from file_operations to vm_operations_struct mremap: don't leak new_vma if f_op->mremap() fails mm/hugetlb.c: make vma_shareable() return bool mm: make GUP handle pfn mapping unless FOLL_GET is requested mm: fix status code which move_pages() returns for zero page mm: memcontrol: bring back the VM_BUG_ON() in mem_cgroup_swapout() genalloc: add support of multiple gen_pools per device genalloc: add name arg to gen_pool_get() and devm_gen_pool_create() mm/memblock: WARN_ON when nid differs from overlap region Documentation/features/vm: add feature description and arch support status for batched TLB flush after unmap mm: defer flush of writable TLB entries mm: send one IPI per CPU to TLB flush all entries after unmapping pages ...
2015-09-05task_work: remove fifo ordering guaranteeEric Dumazet
In commit f341861fb0b ("task_work: add a scheduling point in task_work_run()") I fixed a latency problem adding a cond_resched() call. Later, commit ac3d0da8f329 added yet another loop to reverse a list, bringing back the latency spike : I've seen in some cases this loop taking 275 ms, if for example a process with 2,000,000 files is killed. We could add yet another cond_resched() in the reverse loop, or we can simply remove the reversal, as I do not think anything would depend on order of task_work_add() submitted works. Fixes: ac3d0da8f329 ("task_work: Make task_work_add() lockless") Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Maciej Żenczykowski <maze@google.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-04userfaultfd: activate syscallAndrea Arcangeli
This activates the userfaultfd syscall. [sfr@canb.auug.org.au: activate syscall fix] [akpm@linux-foundation.org: don't enable userfaultfd on powerpc] Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Pavel Emelyanov <xemul@parallels.com> Cc: Sanidhya Kashyap <sanidhya.gatech@gmail.com> Cc: zhang.zhanghailiang@huawei.com Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Cc: Andres Lagar-Cavilla <andreslc@google.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Hugh Dickins <hughd@google.com> Cc: Peter Feiner <pfeiner@google.com> Cc: "Dr. David Alan Gilbert" <dgilbert@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: "Huangpeng (Peter)" <peter.huangpeng@huawei.com> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-04userfaultfd: add VM_UFFD_MISSING and VM_UFFD_WPAndrea Arcangeli
These two flags gets set in vma->vm_flags to tell the VM common code if the userfaultfd is armed and in which mode (only tracking missing faults, only tracking wrprotect faults or both). If neither flags is set it means the userfaultfd is not armed on the vma. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Pavel Emelyanov <xemul@parallels.com> Cc: Sanidhya Kashyap <sanidhya.gatech@gmail.com> Cc: zhang.zhanghailiang@huawei.com Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Cc: Andres Lagar-Cavilla <andreslc@google.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Hugh Dickins <hughd@google.com> Cc: Peter Feiner <pfeiner@google.com> Cc: "Dr. David Alan Gilbert" <dgilbert@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: "Huangpeng (Peter)" <peter.huangpeng@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-04userfaultfd: add vm_userfaultfd_ctx to the vm_area_structAndrea Arcangeli
This adds the vm_userfaultfd_ctx to the vm_area_struct. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Pavel Emelyanov <xemul@parallels.com> Cc: Sanidhya Kashyap <sanidhya.gatech@gmail.com> Cc: zhang.zhanghailiang@huawei.com Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Cc: Andres Lagar-Cavilla <andreslc@google.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Hugh Dickins <hughd@google.com> Cc: Peter Feiner <pfeiner@google.com> Cc: "Dr. David Alan Gilbert" <dgilbert@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: "Huangpeng (Peter)" <peter.huangpeng@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-04userfaultfd: waitqueue: add nr wake parameter to __wake_up_locked_keyAndrea Arcangeli
userfaultfd needs to wake all waitqueues (pass 0 as nr parameter), instead of the current hardcoded 1 (that would wake just the first waitqueue in the head list). Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Pavel Emelyanov <xemul@parallels.com> Cc: Sanidhya Kashyap <sanidhya.gatech@gmail.com> Cc: zhang.zhanghailiang@huawei.com Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Cc: Andres Lagar-Cavilla <andreslc@google.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Hugh Dickins <hughd@google.com> Cc: Peter Feiner <pfeiner@google.com> Cc: "Dr. David Alan Gilbert" <dgilbert@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: "Huangpeng (Peter)" <peter.huangpeng@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-04watchdog: rename watchdog_suspend() and watchdog_resume()Ulrich Obergfell
Rename watchdog_suspend() to lockup_detector_suspend() and watchdog_resume() to lockup_detector_resume() to avoid confusion with the watchdog subsystem and to be consistent with the existing name lockup_detector_init(). Also provide comment blocks to explain the watchdog_running and watchdog_suspended variables and their relationship. Signed-off-by: Ulrich Obergfell <uobergfe@redhat.com> Reviewed-by: Aaron Tomlin <atomlin@redhat.com> Cc: Guenter Roeck <linux@roeck-us.net> Cc: Don Zickus <dzickus@redhat.com> Cc: Ulrich Obergfell <uobergfe@redhat.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Stephane Eranian <eranian@google.com> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Ingo Molnar <mingo@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-04watchdog: use suspend/resume interface in fixup_ht_bug()Ulrich Obergfell
Remove watchdog_nmi_disable_all() and watchdog_nmi_enable_all() since these functions are no longer needed. If a subsystem has a need to deactivate the watchdog temporarily, it should utilize the watchdog_suspend() and watchdog_resume() functions. [akpm@linux-foundation.org: fix build with CONFIG_LOCKUP_DETECTOR=m] Signed-off-by: Ulrich Obergfell <uobergfe@redhat.com> Reviewed-by: Aaron Tomlin <atomlin@redhat.com> Cc: Guenter Roeck <linux@roeck-us.net> Cc: Don Zickus <dzickus@redhat.com> Cc: Ulrich Obergfell <uobergfe@redhat.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Stephane Eranian <eranian@google.com> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Ingo Molnar <mingo@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-04watchdog: use park/unpark functions in update_watchdog_all_cpus()Ulrich Obergfell
Remove update_watchdog() and restart_watchdog_hrtimer() since these functions are no longer needed. Changes of parameters such as the sample period are honored at the time when the watchdog threads are being unparked. Signed-off-by: Ulrich Obergfell <uobergfe@redhat.com> Reviewed-by: Aaron Tomlin <atomlin@redhat.com> Cc: Guenter Roeck <linux@roeck-us.net> Cc: Don Zickus <dzickus@redhat.com> Cc: Ulrich Obergfell <uobergfe@redhat.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Stephane Eranian <eranian@google.com> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Ingo Molnar <mingo@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-04watchdog: introduce watchdog_suspend() and watchdog_resume()Ulrich Obergfell
This interface can be utilized to deactivate the hard and soft lockup detector temporarily. Callers are expected to minimize the duration of deactivation. Multiple deactivations are allowed to occur in parallel but should be rare in practice. [akpm@linux-foundation.org: remove unneeded static initialization] Signed-off-by: Ulrich Obergfell <uobergfe@redhat.com> Reviewed-by: Aaron Tomlin <atomlin@redhat.com> Cc: Guenter Roeck <linux@roeck-us.net> Cc: Don Zickus <dzickus@redhat.com> Cc: Ulrich Obergfell <uobergfe@redhat.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Stephane Eranian <eranian@google.com> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Ingo Molnar <mingo@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-04watchdog: introduce watchdog_park_threads() and watchdog_unpark_threads()Ulrich Obergfell
Originally watchdog_nmi_enable(cpu) and watchdog_nmi_disable(cpu) were only called in watchdog thread context. However, the following commits utilize these functions outside of watchdog thread context too. commit 9809b18fcf6b8d8ec4d3643677345907e6b50eca Author: Michal Hocko <mhocko@suse.cz> Date: Tue Sep 24 15:27:30 2013 -0700 watchdog: update watchdog_thresh properly commit b3738d29323344da3017a91010530cf3a58590fc Author: Stephane Eranian <eranian@google.com> Date: Mon Nov 17 20:07:03 2014 +0100 watchdog: Add watchdog enable/disable all functions Hence, it is now possible that these functions execute concurrently with the same 'cpu' argument. This concurrency is problematic because per-cpu 'watchdog_ev' can be accessed/modified without adequate synchronization. The patch series aims to address the above problem. However, instead of introducing locks to protect per-cpu 'watchdog_ev' a different approach is taken: Invoke these functions by parking and unparking the watchdog threads (to ensure they are always called in watchdog thread context). static struct smp_hotplug_thread watchdog_threads = { ... .park = watchdog_disable, // calls watchdog_nmi_disable() .unpark = watchdog_enable, // calls watchdog_nmi_enable() }; Both previously mentioned commits call these functions in a similar way and thus in principle contain some duplicate code. The patch series also avoids this duplication by providing a commonly usable mechanism. - Patch 1/4 introduces the watchdog_{park|unpark}_threads functions that park/unpark all watchdog threads specified in 'watchdog_cpumask'. They are intended to be called inside of kernel/watchdog.c only. - Patch 2/4 introduces the watchdog_{suspend|resume} functions which can be utilized by external callers to deactivate the hard and soft lockup detector temporarily. - Patch 3/4 utilizes watchdog_{park|unpark}_threads to replace some code that was introduced by commit 9809b18fcf6b8d8ec4d3643677345907e6b50eca. - Patch 4/4 utilizes watchdog_{suspend|resume} to replace some code that was introduced by commit b3738d29323344da3017a91010530cf3a58590fc. A few corner cases should be mentioned here for completeness. - kthread_park() of watchdog/N could hang if cpu N is already locked up. However, if watchdog is enabled the lockup will be detected anyway. - kthread_unpark() of watchdog/N could hang if cpu N got locked up after kthread_park(). The occurrence of this scenario should be _very_ rare in practice, in particular because it is not expected that temporary deactivation will happen frequently, and if it happens at all it is expected that the duration of deactivation will be short. This patch (of 4): introduce watchdog_park_threads() and watchdog_unpark_threads() These functions are intended to be used only from inside kernel/watchdog.c to park/unpark all watchdog threads that are specified in watchdog_cpumask. Signed-off-by: Ulrich Obergfell <uobergfe@redhat.com> Reviewed-by: Aaron Tomlin <atomlin@redhat.com> Cc: Guenter Roeck <linux@roeck-us.net> Cc: Don Zickus <dzickus@redhat.com> Cc: Ulrich Obergfell <uobergfe@redhat.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Stephane Eranian <eranian@google.com> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Ingo Molnar <mingo@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-04kernel/watchdog: move NMI function header declarations from watchdog.h to nmi.hGuenter Roeck
The kernel's NMI watchdog has nothing to do with the watchdog subsystem. Its header declarations should be in linux/nmi.h, not linux/watchdog.h. The code provided two sets of dummy functions if HARDLOCKUP_DETECTOR is not configured, one in the include file and one in kernel/watchdog.c. Remove the dummy functions from kernel/watchdog.c and use those from the include file. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Cc: Stephane Eranian <eranian@google.com> Cc: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Don Zickus <dzickus@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-04watchdog: simplify housekeeping affinity with the appropriate maskFrederic Weisbecker
housekeeping_mask gathers all the CPUs that aren't part of the nohz_full set. This is exactly what we want the watchdog to be affine to without the need to use complicated cpumask operations. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Reviewed-by: Chris Metcalf <cmetcalf@ezchip.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ulrich Obergfell <uobergfe@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-04smpboot: allow passing the cpumask on per-cpu thread registrationFrederic Weisbecker
It makes the registration cheaper and simpler for the smpboot per-cpu kthread users that don't need to always update the cpumask after threads creation. [sfr@canb.auug.org.au: fix for allow passing the cpumask on per-cpu thread registration] Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Reviewed-by: Chris Metcalf <cmetcalf@ezchip.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ulrich Obergfell <uobergfe@redhat.com> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-04smpboot: make cleanup to mirror setupFrederic Weisbecker
The per-cpu kthread cleanup() callback is the mirror of the setup() callback. When the per-cpu kthread is started, it first calls setup() to initialize the resources which are then released by cleanup() when the kthread exits. Now since the introduction of a per-cpu kthread cpumask, the kthreads excluded by the cpumask on boot may happen to be parked immediately after their creation without taking the setup() stage, waiting to be asked to unpark to do so. Then when smpboot_unregister_percpu_thread() is later called, the kthread is stopped without having ever called setup(). But this triggers a bug as the kthread unconditionally calls cleanup() on exit but this doesn't mirror any setup(). Thus the kernel crashes because we try to free resources that haven't been initialized, as in the watchdog case: WATCHDOG disable 0 WATCHDOG disable 1 WATCHDOG disable 2 BUG: unable to handle kernel NULL pointer dereference at (null) IP: hrtimer_active+0x26/0x60 [...] Call Trace: hrtimer_try_to_cancel+0x1c/0x280 hrtimer_cancel+0x1d/0x30 watchdog_disable+0x56/0x70 watchdog_cleanup+0xe/0x10 smpboot_thread_fn+0x23c/0x2c0 kthread+0xf8/0x110 ret_from_fork+0x3f/0x70 This bug is currently masked with explicit kthread unparking before kthread_stop() on smpboot_destroy_threads(). This forces a call to setup() and then unpark(). We could fix this by unconditionally calling setup() on kthread entry. But setup() isn't always cheap. In the case of watchdog it launches hrtimer, perf events, etc... So we may as well like to skip it if there are chances the kthread will never be used, as in a reduced cpumask value. So let's simply do a state machine check before calling cleanup() that makes sure setup() has been called before mirroring it. And remove the nasty hack workaround. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Reviewed-by: Chris Metcalf <cmetcalf@ezchip.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ulrich Obergfell <uobergfe@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-04smpboot: fix memory leak on error handlingFrederic Weisbecker
The cpumask is allocated before threads get created. If the latter step fails, we need to free the cpumask. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Reviewed-by: Chris Metcalf <cmetcalf@ezchip.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ulrich Obergfell <uobergfe@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-04fs: create and use seq_show_option for escapingKees Cook
Many file systems that implement the show_options hook fail to correctly escape their output which could lead to unescaped characters (e.g. new lines) leaking into /proc/mounts and /proc/[pid]/mountinfo files. This could lead to confusion, spoofed entries (resulting in things like systemd issuing false d-bus "mount" notifications), and who knows what else. This looks like it would only be the root user stepping on themselves, but it's possible weird things could happen in containers or in other situations with delegated mount privileges. Here's an example using overlay with setuid fusermount trusting the contents of /proc/mounts (via the /etc/mtab symlink). Imagine the use of "sudo" is something more sneaky: $ BASE="ovl" $ MNT="$BASE/mnt" $ LOW="$BASE/lower" $ UP="$BASE/upper" $ WORK="$BASE/work/ 0 0 none /proc fuse.pwn user_id=1000" $ mkdir -p "$LOW" "$UP" "$WORK" $ sudo mount -t overlay -o "lowerdir=$LOW,upperdir=$UP,workdir=$WORK" none /mnt $ cat /proc/mounts none /root/ovl/mnt overlay rw,relatime,lowerdir=ovl/lower,upperdir=ovl/upper,workdir=ovl/work/ 0 0 none /proc fuse.pwn user_id=1000 0 0 $ fusermount -u /proc $ cat /proc/mounts cat: /proc/mounts: No such file or directory This fixes the problem by adding new seq_show_option and seq_show_option_n helpers, and updating the vulnerable show_option handlers to use them as needed. Some, like SELinux, need to be open coded due to unusual existing escape mechanisms. [akpm@linux-foundation.org: add lost chunk, per Kees] [keescook@chromium.org: seq_show_option should be using const parameters] Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Acked-by: Jan Kara <jack@suse.com> Acked-by: Paul Moore <paul@paul-moore.com> Cc: J. R. Okajima <hooanon05g@gmail.com> Signed-off-by: Kees Cook <keescook@chromium.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-04capabilities: ambient capabilitiesAndy Lutomirski
Credit where credit is due: this idea comes from Christoph Lameter with a lot of valuable input from Serge Hallyn. This patch is heavily based on Christoph's patch. ===== The status quo ===== On Linux, there are a number of capabilities defined by the kernel. To perform various privileged tasks, processes can wield capabilities that they hold. Each task has four capability masks: effective (pE), permitted (pP), inheritable (pI), and a bounding set (X). When the kernel checks for a capability, it checks pE. The other capability masks serve to modify what capabilities can be in pE. Any task can remove capabilities from pE, pP, or pI at any time. If a task has a capability in pP, it can add that capability to pE and/or pI. If a task has CAP_SETPCAP, then it can add any capability to pI, and it can remove capabilities from X. Tasks are not the only things that can have capabilities; files can also have capabilities. A file can have no capabilty information at all [1]. If a file has capability information, then it has a permitted mask (fP) and an inheritable mask (fI) as well as a single effective bit (fE) [2]. File capabilities modify the capabilities of tasks that execve(2) them. A task that successfully calls execve has its capabilities modified for the file ultimately being excecuted (i.e. the binary itself if that binary is ELF or for the interpreter if the binary is a script.) [3] In the capability evolution rules, for each mask Z, pZ represents the old value and pZ' represents the new value. The rules are: pP' = (X & fP) | (pI & fI) pI' = pI pE' = (fE ? pP' : 0) X is unchanged For setuid binaries, fP, fI, and fE are modified by a moderately complicated set of rules that emulate POSIX behavior. Similarly, if euid == 0 or ruid == 0, then fP, fI, and fE are modified differently (primary, fP and fI usually end up being the full set). For nonroot users executing binaries with neither setuid nor file caps, fI and fP are empty and fE is false. As an extra complication, if you execute a process as nonroot and fE is set, then the "secure exec" rules are in effect: AT_SECURE gets set, LD_PRELOAD doesn't work, etc. This is rather messy. We've learned that making any changes is dangerous, though: if a new kernel version allows an unprivileged program to change its security state in a way that persists cross execution of a setuid program or a program with file caps, this persistent state is surprisingly likely to allow setuid or file-capped programs to be exploited for privilege escalation. ===== The problem ===== Capability inheritance is basically useless. If you aren't root and you execute an ordinary binary, fI is zero, so your capabilities have no effect whatsoever on pP'. This means that you can't usefully execute a helper process or a shell command with elevated capabilities if you aren't root. On current kernels, you can sort of work around this by setting fI to the full set for most or all non-setuid executable files. This causes pP' = pI for nonroot, and inheritance works. No one does this because it's a PITA and it isn't even supported on most filesystems. If you try this, you'll discover that every nonroot program ends up with secure exec rules, breaking many things. This is a problem that has bitten many people who have tried to use capabilities for anything useful. ===== The proposed change ===== This patch adds a fifth capability mask called the ambient mask (pA). pA does what most people expect pI to do. pA obeys the invariant that no bit can ever be set in pA if it is not set in both pP and pI. Dropping a bit from pP or pI drops that bit from pA. This ensures that existing programs that try to drop capabilities still do so, with a complication. Because capability inheritance is so broken, setting KEEPCAPS, using setresuid to switch to nonroot uids, and then calling execve effectively drops capabilities. Therefore, setresuid from root to nonroot conditionally clears pA unless SECBIT_NO_SETUID_FIXUP is set. Processes that don't like this can re-add bits to pA afterwards. The capability evolution rules are changed: pA' = (file caps or setuid or setgid ? 0 : pA) pP' = (X & fP) | (pI & fI) | pA' pI' = pI pE' = (fE ? pP' : pA') X is unchanged If you are nonroot but you have a capability, you can add it to pA. If you do so, your children get that capability in pA, pP, and pE. For example, you can set pA = CAP_NET_BIND_SERVICE, and your children can automatically bind low-numbered ports. Hallelujah! Unprivileged users can create user namespaces, map themselves to a nonzero uid, and create both privileged (relative to their namespace) and unprivileged process trees. This is currently more or less impossible. Hallelujah! You cannot use pA to try to subvert a setuid, setgid, or file-capped program: if you execute any such program, pA gets cleared and the resulting evolution rules are unchanged by this patch. Users with nonzero pA are unlikely to unintentionally leak that capability. If they run programs that try to drop privileges, dropping privileges will still work. It's worth noting that the degree of paranoia in this patch could possibly be reduced without causing serious problems. Specifically, if we allowed pA to persist across executing non-pA-aware setuid binaries and across setresuid, then, naively, the only capabilities that could leak as a result would be the capabilities in pA, and any attacker *already* has those capabilities. This would make me nervous, though -- setuid binaries that tried to privilege-separate might fail to do so, and putting CAP_DAC_READ_SEARCH or CAP_DAC_OVERRIDE into pA could have unexpected side effects. (Whether these unexpected side effects would be exploitable is an open question.) I've therefore taken the more paranoid route. We can revisit this later. An alternative would be to require PR_SET_NO_NEW_PRIVS before setting ambient capabilities. I think that this would be annoying and would make granting otherwise unprivileged users minor ambient capabilities (CAP_NET_BIND_SERVICE or CAP_NET_RAW for example) much less useful than it is with this patch. ===== Footnotes ===== [1] Files that are missing the "security.capability" xattr or that have unrecognized values for that xattr end up with has_cap set to false. The code that does that appears to be complicated for no good reason. [2] The libcap capability mask parsers and formatters are dangerously misleading and the documentation is flat-out wrong. fE is *not* a mask; it's a single bit. This has probably confused every single person who has tried to use file capabilities. [3] Linux very confusingly processes both the script and the interpreter if applicable, for reasons that elude me. The results from thinking about a script's file capabilities and/or setuid bits are mostly discarded. Preliminary userspace code is here, but it needs updating: https://git.kernel.org/cgit/linux/kernel/git/luto/util-linux-playground.git/commit/?h=cap_ambient&id=7f5afbd175d2 Here is a test program that can be used to verify the functionality (from Christoph): /* * Test program for the ambient capabilities. This program spawns a shell * that allows running processes with a defined set of capabilities. * * (C) 2015 Christoph Lameter <cl@linux.com> * Released under: GPL v3 or later. * * * Compile using: * * gcc -o ambient_test ambient_test.o -lcap-ng * * This program must have the following capabilities to run properly: * Permissions for CAP_NET_RAW, CAP_NET_ADMIN, CAP_SYS_NICE * * A command to equip the binary with the right caps is: * * setcap cap_net_raw,cap_net_admin,cap_sys_nice+p ambient_test * * * To get a shell with additional caps that can be inherited by other processes: * * ./ambient_test /bin/bash * * * Verifying that it works: * * From the bash spawed by ambient_test run * * cat /proc/$$/status * * and have a look at the capabilities. */ #include <stdlib.h> #include <stdio.h> #include <errno.h> #include <cap-ng.h> #include <sys/prctl.h> #include <linux/capability.h> /* * Definitions from the kernel header files. These are going to be removed * when the /usr/include files have these defined. */ #define PR_CAP_AMBIENT 47 #define PR_CAP_AMBIENT_IS_SET 1 #define PR_CAP_AMBIENT_RAISE 2 #define PR_CAP_AMBIENT_LOWER 3 #define PR_CAP_AMBIENT_CLEAR_ALL 4 static void set_ambient_cap(int cap) { int rc; capng_get_caps_process(); rc = capng_update(CAPNG_ADD, CAPNG_INHERITABLE, cap); if (rc) { printf("Cannot add inheritable cap\n"); exit(2); } capng_apply(CAPNG_SELECT_CAPS); /* Note the two 0s at the end. Kernel checks for these */ if (prctl(PR_CAP_AMBIENT, PR_CAP_AMBIENT_RAISE, cap, 0, 0)) { perror("Cannot set cap"); exit(1); } } int main(int argc, char **argv) { int rc; set_ambient_cap(CAP_NET_RAW); set_ambient_cap(CAP_NET_ADMIN); set_ambient_cap(CAP_SYS_NICE); printf("Ambient_test forking shell\n"); if (execv(argv[1], argv + 1)) perror("Cannot exec"); return 0; } Signed-off-by: Christoph Lameter <cl@linux.com> # Original author Signed-off-by: Andy Lutomirski <luto@kernel.org> Acked-by: Serge E. Hallyn <serge.hallyn@ubuntu.com> Acked-by: Kees Cook <keescook@chromium.org> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Aaron Jones <aaronmdjones@gmail.com> Cc: Ted Ts'o <tytso@mit.edu> Cc: Andrew G. Morgan <morgan@kernel.org> Cc: Mimi Zohar <zohar@linux.vnet.ibm.com> Cc: Austin S Hemmelgarn <ahferroin7@gmail.com> Cc: Markku Savela <msa@moth.iki.fi> Cc: Jarkko Sakkinen <jarkko.sakkinen@linux.intel.com> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: James Morris <james.l.morris@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-04kernel/kthread.c:kthread_create_on_node(): clarify documentationAndrew Morton
- Make it clear that the `node' arg refers to memory allocations only: kthread_create_on_node() does not pin the new thread to that node's CPUs. - Encourage the use of NUMA_NO_NODE. [nzimmer@sgi.com: use NUMA_NO_NODE in kthread_create() also] Cc: Nathan Zimmer <nzimmer@sgi.com> Cc: Tejun Heo <tj@kernel.org> Cc: Eric Dumazet <edumazet@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-03Merge branch 'locking-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull locking and atomic updates from Ingo Molnar: "Main changes in this cycle are: - Extend atomic primitives with coherent logic op primitives (atomic_{or,and,xor}()) and deprecate the old partial APIs (atomic_{set,clear}_mask()) The old ops were incoherent with incompatible signatures across architectures and with incomplete support. Now every architecture supports the primitives consistently (by Peter Zijlstra) - Generic support for 'relaxed atomics': - _acquire/release/relaxed() flavours of xchg(), cmpxchg() and {add,sub}_return() - atomic_read_acquire() - atomic_set_release() This came out of porting qwrlock code to arm64 (by Will Deacon) - Clean up the fragile static_key APIs that were causing repeat bugs, by introducing a new one: DEFINE_STATIC_KEY_TRUE(name); DEFINE_STATIC_KEY_FALSE(name); which define a key of different types with an initial true/false value. Then allow: static_branch_likely() static_branch_unlikely() to take a key of either type and emit the right instruction for the case. To be able to know the 'type' of the static key we encode it in the jump entry (by Peter Zijlstra) - Static key self-tests (by Jason Baron) - qrwlock optimizations (by Waiman Long) - small futex enhancements (by Davidlohr Bueso) - ... and misc other changes" * 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (63 commits) jump_label/x86: Work around asm build bug on older/backported GCCs locking, ARM, atomics: Define our SMP atomics in terms of _relaxed() operations locking, include/llist: Use linux/atomic.h instead of asm/cmpxchg.h locking/qrwlock: Make use of _{acquire|release|relaxed}() atomics locking/qrwlock: Implement queue_write_unlock() using smp_store_release() locking/lockref: Remove homebrew cmpxchg64_relaxed() macro definition locking, asm-generic: Add _{relaxed|acquire|release}() variants for 'atomic_long_t' locking, asm-generic: Rework atomic-long.h to avoid bulk code duplication locking/atomics: Add _{acquire|release|relaxed}() variants of some atomic operations locking, compiler.h: Cast away attributes in the WRITE_ONCE() magic locking/static_keys: Make verify_keys() static jump label, locking/static_keys: Update docs locking/static_keys: Provide a selftest jump_label: Provide a self-test s390/uaccess, locking/static_keys: employ static_branch_likely() x86, tsc, locking/static_keys: Employ static_branch_likely() locking/static_keys: Add selftest locking/static_keys: Add a new static_key interface locking/static_keys: Rework update logic locking/static_keys: Add static_key_{en,dis}able() helpers ...
