commit 0ac9b1c21874d2490331233b3242085f8151e166 upstream.
Currently, group entity load-weights are initialized to zero. This
admits some races with respect to the first time they are re-weighted in
earlty use. ( Let g[x] denote the se for "g" on cpu "x". )
Suppose that we have root->a and that a enters a throttled state,
immediately followed by a[0]->t1 (the only task running on cpu[0])
blocking:
put_prev_task(group_cfs_rq(a[0]), t1)
put_prev_entity(..., t1)
check_cfs_rq_runtime(group_cfs_rq(a[0]))
throttle_cfs_rq(group_cfs_rq(a[0]))
Then, before unthrottling occurs, let a[0]->b[0]->t2 wake for the first
time:
enqueue_task_fair(rq[0], t2)
enqueue_entity(group_cfs_rq(b[0]), t2)
enqueue_entity_load_avg(group_cfs_rq(b[0]), t2)
account_entity_enqueue(group_cfs_ra(b[0]), t2)
update_cfs_shares(group_cfs_rq(b[0]))
< skipped because b is part of a throttled hierarchy >
enqueue_entity(group_cfs_rq(a[0]), b[0])
We now have b[0] enqueued, yet group_cfs_rq(a[0])->load.weight == 0
which violates invariants in several code-paths. Eliminate the
possibility of this by initializing group entity weight.
Signed-off-by: Paul Turner <pjt@google.com>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/20131016181627.22647.47543.stgit@sword-of-the-dawn.mtv.corp.google.com
Cc: Chris J Arges <chris.j.arges@canonical.com>
commit 927b54fccbf04207ec92f669dce6806848cbec7d upstream.
__start_cfs_bandwidth calls hrtimer_cancel while holding rq->lock,
waiting for the hrtimer to finish. However, if sched_cfs_period_timer
runs for another loop iteration, the hrtimer can attempt to take
rq->lock, resulting in deadlock.
Fix this by ensuring that cfs_b->timer_active is cleared only if the
_latest_ call to do_sched_cfs_period_timer is returning as idle. Then
__start_cfs_bandwidth can just call hrtimer_try_to_cancel and wait for
that to succeed or timer_active == 1.
Signed-off-by: Ben Segall <bsegall@google.com>
Cc: pjt@google.com
Link: http://lkml.kernel.org/r/20131016181622.22647.16643.stgit@sword-of-the-dawn.mtv.corp.google.com
commit db06e78cc13d70f10877e0557becc88ab3ad2be8 upstream.
hrtimer_expires_remaining does not take internal hrtimer locks and thus
must be guarded against concurrent __hrtimer_start_range_ns (but
returning HRTIMER_RESTART is safe). Use cfs_b->lock to make it safe.
Cc: pjt@google.com
Link: http://lkml.kernel.org/r/20131016181617.22647.73829.stgit@sword-of-the-dawn.mtv.corp.google.com
commit 1ee14e6c8cddeeb8a490d7b54cd9016e4bb900b4 upstream.
When we transition cfs_bandwidth_used to false, any currently
throttled groups will incorrectly return false from cfs_rq_throttled.
While tg_set_cfs_bandwidth will unthrottle them eventually, currently
running code (including at least dequeue_task_fair and
distribute_cfs_runtime) will cause errors.
Fix this by turning off cfs_bandwidth_used only after unthrottling all
cfs_rqs.
Tested: toggle bandwidth back and forth on a loaded cgroup. Caused
crashes in minutes without the patch, hasn't crashed with it.
Cc: pjt@google.com
Link: http://lkml.kernel.org/r/20131016181611.22647.80365.stgit@sword-of-the-dawn.mtv.corp.google.com
commit f9f9ffc237dd924f048204e8799da74f9ecf40cf upstream.
throttle_cfs_rq() doesn't check to make sure that period_timer is running,
and while update_curr/assign_cfs_runtime does, a concurrently running
period_timer on another cpu could cancel itself between this cpu's
update_curr and throttle_cfs_rq(). If there are no other cfs_rqs running
in the tg to restart the timer, this causes the cfs_rq to be stranded
forever.
Fix this by calling __start_cfs_bandwidth() in throttle if the timer is
inactive.
(Also add some sched_debug lines for cfs_bandwidth.)
Tested: make a run/sleep task in a cgroup, loop switching the cgroup
between 1ms/100ms quota and unlimited, checking for timer_active=0 and
throttled=1 as a failure. With the throttle_cfs_rq() change commented out
this fails, with the full patch it passes.
Cc: pjt@google.com
Link: http://lkml.kernel.org/r/20131016181632.22647.84174.stgit@sword-of-the-dawn.mtv.corp.google.com
Signed-off-by: Chris J Arges <chris.j.arges@canonical.com>
commit 757dfcaa41844595964f1220f1d33182dae49976 upstream.
This patch touches the RT group scheduling case.
Functions inc_rt_prio_smp() and dec_rt_prio_smp() change (global) rq's
priority, while rt_rq passed to them may be not the top-level rt_rq.
This is wrong, because changing of priority on a child level does not
guarantee that the priority is the highest all over the rq. So, this
leak makes RT balancing unusable.
The short example: the task having the highest priority among all rq's
RT tasks (no one other task has the same priority) are waking on a
throttle rt_rq. The rq's cpupri is set to the task's priority
equivalent, but real rq->rt.highest_prio.curr is less.
The patch below fixes the problem.
Signed-off-by: Kirill Tkhai <tkhai@yandex.ru>
CC: Steven Rostedt <rostedt@goodmis.org>
Link: http://lkml.kernel.org/r/49231385567953@web4m.yandex.ru
commit c4602c1c818bd6626178d6d3fcc152d9f2f48ac0 upstream.
Ftrace currently initializes only the online CPUs. This implementation has
two problems:
- If we online a CPU after we enable the function profile, and then run the
test, we will lose the trace information on that CPU.
Steps to reproduce:
# echo 0 > /sys/devices/system/cpu/cpu1/online
# cd <debugfs>/tracing/
# echo <some function name> >> set_ftrace_filter
# echo 1 > function_profile_enabled
# echo 1 > /sys/devices/system/cpu/cpu1/online
# run test
- If we offline a CPU before we enable the function profile, we will not clear
the trace information when we enable the function profile. It will trouble
the users.
Steps to reproduce:
# run test
# cat trace_stat/function*
# echo 0 > function_profile_enabled
# run test
So it is better that we initialize the ftrace profiler for each possible cpu
every time we enable the function profile instead of just the online ones.
Link: http://lkml.kernel.org/r/1387178401-10619-1-git-send-email-miaox@cn.fujitsu.com
Signed-off-by: Miao Xie <miaox@cn.fujitsu.com>
commit f12d5bfceb7e1f9051563381ec047f7f13956c3c upstream.
The hugepage code had the exact same bug that regular pages had in
commit 7485d0d3758e ("futexes: Remove rw parameter from
get_futex_key()").
The regular page case was fixed by commit 9ea71503a8ed ("futex: Fix
regression with read only mappings"), but the transparent hugepage case
(added in a5b338f2b0b1: "thp: update futex compound knowledge") case
remained broken.
Found by Dave Jones and his trinity tool.
Reported-and-tested-by: Dave Jones <davej@fedoraproject.org>
Cc: Darren Hart <dvhart@linux.intel.com>
commit ac01810c9d2814238f08a227062e66a35a0e1ea2 upstream.
When the system enters suspend, it disables all interrupts in
suspend_device_irqs(), including the interrupts marked EARLY_RESUME.
On the resume side things are different. The EARLY_RESUME interrupts
are reenabled in sys_core_ops->resume and the non EARLY_RESUME
interrupts are reenabled in the normal system resume path.
When suspend_noirq() failed or suspend is aborted for any other
reason, we might omit the resume side call to sys_core_ops->resume()
and therefor the interrupts marked EARLY_RESUME are not reenabled and
stay disabled forever.
To solve this, enable all irqs unconditionally in irq_resume()
regardless whether interrupts marked EARLY_RESUMEhave been already
enabled or not.
This might try to reenable already enabled interrupts in the non
failure case, but the only affected platform is XEN and it has been
confirmed that it does not cause any side effects.
[ tglx: Massaged changelog. ]
Acked-by-and-tested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Acked-by: Heiko Stuebner <heiko@sntech.de>
Reviewed-by: Pavel Machek <pavel@ucw.cz>
Cc: <ian.campbell@citrix.com>
Cc: <rjw@rjwysocki.net>
Cc: <len.brown@intel.com>
Cc: <gregkh@linuxfoundation.org>
Link: http://lkml.kernel.org/r/1385388587-16442-1-git-send-email-ldewangan@nvidia.com
commit 8a56d7761d2d041ae5e8215d20b4167d8aa93f51 upstream.
Commit 8c4f3c3fa9681 "ftrace: Check module functions being traced on reload"
fixed module loading and unloading with respect to function tracing, but
it missed the function graph tracer. If you perform the following
# cd /sys/kernel/debug/tracing
# echo function_graph > current_tracer
# modprobe nfsd
# echo nop > current_tracer
You'll get the following oops message:
WARNING: CPU: 2 PID: 2910 at /linux.git/kernel/trace/ftrace.c:1640 __ftrace_hash_rec_update.part.35+0x168/0x1b9()
Modules linked in: nfsd exportfs nfs_acl lockd ipt_MASQUERADE sunrpc ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6 ip6table_filter ip6_tables uinput snd_hda_codec_idt
CPU: 2 PID: 2910 Comm: bash Not tainted 3.13.0-rc1-test #7
Hardware name: To Be Filled By O.E.M. To Be Filled By O.E.M./To be filled by O.E.M., BIOS SDBLI944.86P 05/08/2007
0000000000000668 ffff8800787efcf8 ffffffff814fe193 ffff88007d500000
0000000000000000 ffff8800787efd38 ffffffff8103b80a 0000000000000668
ffffffff810b2b9a ffffffff81a48370 0000000000000001 ffff880037aea000
Call Trace:
[<ffffffff814fe193>] dump_stack+0x4f/0x7c
[<ffffffff8103b80a>] warn_slowpath_common+0x81/0x9b
[<ffffffff810b2b9a>] ? __ftrace_hash_rec_update.part.35+0x168/0x1b9
[<ffffffff8103b83e>] warn_slowpath_null+0x1a/0x1c
[<ffffffff810b2b9a>] __ftrace_hash_rec_update.part.35+0x168/0x1b9
[<ffffffff81502f89>] ? __mutex_lock_slowpath+0x364/0x364
[<ffffffff810b2cc2>] ftrace_shutdown+0xd7/0x12b
[<ffffffff810b47f0>] unregister_ftrace_graph+0x49/0x78
[<ffffffff810c4b30>] graph_trace_reset+0xe/0x10
[<ffffffff810bf393>] tracing_set_tracer+0xa7/0x26a
[<ffffffff810bf5e1>] tracing_set_trace_write+0x8b/0xbd
[<ffffffff810c501c>] ? ftrace_return_to_handler+0xb2/0xde
[<ffffffff811240a8>] ? __sb_end_write+0x5e/0x5e
[<ffffffff81122aed>] vfs_write+0xab/0xf6
[<ffffffff8150a185>] ftrace_graph_caller+0x85/0x85
[<ffffffff81122dbd>] SyS_write+0x59/0x82
[<ffffffff8150a2d2>] system_call_fastpath+0x16/0x1b
---[ end trace 940358030751eafb ]---
The above mentioned commit didn't go far enough. Well, it covered the
function tracer by adding checks in __register_ftrace_function(). The
problem is that the function graph tracer circumvents that (for a slight
efficiency gain when function graph trace is running with a function
tracer. The gain was not worth this).
The problem came with ftrace_startup() which should always be called after
__register_ftrace_function(), if you want this bug to be completely fixed.
Anyway, this solution moves __register_ftrace_function() inside of
ftrace_startup() and removes the need to call them both.
Reported-by: Dave Wysochanski <dwysocha@redhat.com>
Fixes: ed926f9b35cd ("ftrace: Use counters to enable functions to trace")
commit 0fc0287c9ed1ffd3706f8b4d9b314aa102ef1245 upstream.
Juri hit the below lockdep report:
[ 4.303391] ======================================================
[ 4.303392] [ INFO: SOFTIRQ-safe -> SOFTIRQ-unsafe lock order detected ]
[ 4.303394] 3.12.0-dl-peterz+ #144 Not tainted
[ 4.303395] ------------------------------------------------------
[ 4.303397] kworker/u4:3/689 [HC0[0]:SC0[0]:HE0:SE1] is trying to acquire:
[ 4.303399] (&p->mems_allowed_seq){+.+...}, at: [<ffffffff8114e63c>] new_slab+0x6c/0x290
[ 4.303417]
[ 4.303417] and this task is already holding:
[ 4.303418] (&(&q->__queue_lock)->rlock){..-...}, at: [<ffffffff812d2dfb>] blk_execute_rq_nowait+0x5b/0x100
[ 4.303431] which would create a new lock dependency:
[ 4.303432] (&(&q->__queue_lock)->rlock){..-...} -> (&p->mems_allowed_seq){+.+...}
[ 4.303436]
[ 4.303898] the dependencies between the lock to be acquired and SOFTIRQ-irq-unsafe lock:
[ 4.303918] -> (&p->mems_allowed_seq){+.+...} ops: 2762 {
[ 4.303922] HARDIRQ-ON-W at:
[ 4.303923] [<ffffffff8108ab9a>] __lock_acquire+0x65a/0x1ff0
[ 4.303926] [<ffffffff8108cbe3>] lock_acquire+0x93/0x140
[ 4.303929] [<ffffffff81063dd6>] kthreadd+0x86/0x180
[ 4.303931] [<ffffffff816ded6c>] ret_from_fork+0x7c/0xb0
[ 4.303933] SOFTIRQ-ON-W at:
[ 4.303933] [<ffffffff8108abcc>] __lock_acquire+0x68c/0x1ff0
[ 4.303935] [<ffffffff8108cbe3>] lock_acquire+0x93/0x140
[ 4.303940] [<ffffffff81063dd6>] kthreadd+0x86/0x180
[ 4.303955] [<ffffffff816ded6c>] ret_from_fork+0x7c/0xb0
[ 4.303959] INITIAL USE at:
[ 4.303960] [<ffffffff8108a884>] __lock_acquire+0x344/0x1ff0
[ 4.303963] [<ffffffff8108cbe3>] lock_acquire+0x93/0x140
[ 4.303966] [<ffffffff81063dd6>] kthreadd+0x86/0x180
[ 4.303969] [<ffffffff816ded6c>] ret_from_fork+0x7c/0xb0
[ 4.303972] }
Which reports that we take mems_allowed_seq with interrupts enabled. A
little digging found that this can only be from
cpuset_change_task_nodemask().
This is an actual deadlock because an interrupt doing an allocation will
hit get_mems_allowed()->...->__read_seqcount_begin(), which will spin
forever waiting for the write side to complete.
Cc: John Stultz <john.stultz@linaro.org>
Reported-by: Juri Lelli <juri.lelli@gmail.com>
Tested-by: Juri Lelli <juri.lelli@gmail.com>
Acked-by: Li Zefan <lizefan@huawei.com>
commit 64fbff9ae0a0a843365d922e0057fc785f23f0e3 upstream.
We leak 4 bytes of kernel stack in response to an AUDIT_GET request as
we miss to initialize the mask member of status_set. Fix that.
Cc: Eric Paris <eparis@redhat.com>
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Signed-off-by: Richard Guy Briggs <rgb@redhat.com>
Signed-off-by: Eric Paris <eparis@redhat.com>
commit 4d8fe7376a12bf4524783dd95cbc00f1fece6232 upstream.
Using the nlmsg_len member of the netlink header to test if the message
is valid is wrong as it includes the size of the netlink header itself.
Thereby allowing to send short netlink messages that pass those checks.
Use nlmsg_len() instead to test for the right message length. The result
of nlmsg_len() is guaranteed to be non-negative as the netlink message
already passed the checks of nlmsg_ok().
Also switch to min_t() to please checkpatch.pl.
commit 0868a5e150bc4c47e7a003367cd755811eb41e0b upstream.
When the audit=1 kernel parameter is absent and auditd is not running,
AUDIT_USER_AVC messages are being silently discarded.
AUDIT_USER_AVC messages should be sent to userspace using printk(), as
mentioned in the commit message of 4a4cd633 ("AUDIT: Optimise the
audit-disabled case for discarding user messages").
When audit_enabled is 0, audit_receive_msg() discards all user messages
except for AUDIT_USER_AVC messages. However, audit_log_common_recv_msg()
refuses to allocate an audit_buffer if audit_enabled is 0. The fix is to
special case AUDIT_USER_AVC messages in both functions.
It looks like commit 50397bd1 ("[AUDIT] clean up audit_receive_msg()")
introduced this bug.
Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
Cc: linux-audit@redhat.com
commit fd432b9f8c7c88428a4635b9f5a9c6e174df6e36 upstream.
When system has a lot of highmem (e.g. 16GiB using a 32 bits kernel),
the code to calculate how much memory we need to preallocate in
normal zone may cause overflow. As Leon has analysed:
It looks that during computing 'alloc' variable there is overflow:
alloc = (3943404 - 1970542) - 1978280 = -5418 (signed)
And this function goes to err_out.
Fix this by avoiding that overflow.
References: https://bugzilla.kernel.org/show_bug.cgi?id=60817
Reported-and-tested-by: Leon Drugi <eyak@wp.pl>
Signed-off-by: Aaron Lu <aaron.lu@intel.com>
commit 98d6f4dd84a134d942827584a3c5f67ffd8ec35f upstream.
Fedora Ruby maintainer reported latest Ruby doesn't work on Fedora Rawhide
on ARM. (http://bugs.ruby-lang.org/issues/9008)
Because of, commit 1c6b39ad3f (alarmtimers: Return -ENOTSUPP if no
RTC device is present) intruduced to return ENOTSUPP when
clock_get{time,res} can't find a RTC device. However this is incorrect.
First, ENOTSUPP isn't exported to userland (ENOTSUP or EOPNOTSUP are the
closest userland equivlents).
Second, Posix and Linux man pages agree that clock_gettime and
clock_getres should return EINVAL if clk_id argument is invalid.
While the arugment that the clockid is valid, but just not supported
on this hardware could be made, this is just a technicality that
doesn't help userspace applicaitons, and only complicates error
handling.
Thus, this patch changes the code to use EINVAL.
Reported-by: Vit Ondruch <v.ondruch@tiscali.cz>
[jstultz: Tweaks to commit message to include full rational]
Signed-off-by: John Stultz <john.stultz@linaro.org>
commit d049f74f2dbe71354d43d393ac3a188947811348 upstream.
The get_dumpable() return value is not boolean. Most users of the
function actually want to be testing for non-SUID_DUMP_USER(1) rather than
SUID_DUMP_DISABLE(0). The SUID_DUMP_ROOT(2) is also considered a
protected state. Almost all places did this correctly, excepting the two
places fixed in this patch.
Wrong logic:
if (dumpable == SUID_DUMP_DISABLE) { /* be protective */ }
or
if (dumpable == 0) { /* be protective */ }
or
if (!dumpable) { /* be protective */ }
Correct logic:
if (dumpable != SUID_DUMP_USER) { /* be protective */ }
or
if (dumpable != 1) { /* be protective */ }
Without this patch, if the system had set the sysctl fs/suid_dumpable=2, a
user was able to ptrace attach to processes that had dropped privileges to
that user. (This may have been partially mitigated if Yama was enabled.)
The macros have been moved into the file that declares get/set_dumpable(),
which means things like the ia64 code can see them too.
CVE-2013-2929
Reported-by: Vasily Kulikov <segoon@openwall.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
commit 12ae030d54ef250706da5642fc7697cc60ad0df7 upstream.
The current default perf paranoid level is "1" which has
"perf_paranoid_kernel()" return false, and giving any operations that
use it, access to normal users. Unfortunately, this includes function
tracing and normal users should not be allowed to enable function
tracing by default.
The proper level is defined at "-1" (full perf access), which
"perf_paranoid_tracepoint_raw()" will only give access to. Use that
check instead for enabling function tracing.
Reported-by: Dave Jones <davej@redhat.com>
Reported-by: Vince Weaver <vincent.weaver@maine.edu>
Tested-by: Vince Weaver <vincent.weaver@maine.edu>
Cc: Jiri Olsa <jolsa@redhat.com>
CVE: CVE-2013-2930
Fixes: ced39002f5ea ("ftrace, perf: Add support to use function tracepoint in perf")
commit 057db8488b53d5e4faa0cedb2f39d4ae75dfbdbb upstream.
Andrey reported the following report:
ERROR: AddressSanitizer: heap-buffer-overflow on address ffff8800359c99f3
ffff8800359c99f3 is located 0 bytes to the right of 243-byte region [ffff8800359c9900, ffff8800359c99f3)
Accessed by thread T13003:
#0 ffffffff810dd2da (asan_report_error+0x32a/0x440)
#1 ffffffff810dc6b0 (asan_check_region+0x30/0x40)
#2 ffffffff810dd4d3 (__tsan_write1+0x13/0x20)
#3 ffffffff811cd19e (ftrace_regex_release+0x1be/0x260)
#4 ffffffff812a1065 (__fput+0x155/0x360)
#5 ffffffff812a12de (____fput+0x1e/0x30)
#6 ffffffff8111708d (task_work_run+0x10d/0x140)
#7 ffffffff810ea043 (do_exit+0x433/0x11f0)
#8 ffffffff810eaee4 (do_group_exit+0x84/0x130)
#9 ffffffff810eafb1 (SyS_exit_group+0x21/0x30)
#10 ffffffff81928782 (system_call_fastpath+0x16/0x1b)
Allocated by thread T5167:
#0 ffffffff810dc778 (asan_slab_alloc+0x48/0xc0)
#1 ffffffff8128337c (__kmalloc+0xbc/0x500)
#2 ffffffff811d9d54 (trace_parser_get_init+0x34/0x90)
#3 ffffffff811cd7b3 (ftrace_regex_open+0x83/0x2e0)
#4 ffffffff811cda7d (ftrace_filter_open+0x2d/0x40)
#5 ffffffff8129b4ff (do_dentry_open+0x32f/0x430)
#6 ffffffff8129b668 (finish_open+0x68/0xa0)
#7 ffffffff812b66ac (do_last+0xb8c/0x1710)
#8 ffffffff812b7350 (path_openat+0x120/0xb50)
#9 ffffffff812b8884 (do_filp_open+0x54/0xb0)
#10 ffffffff8129d36c (do_sys_open+0x1ac/0x2c0)
#11 ffffffff8129d4b7 (SyS_open+0x37/0x50)
#12 ffffffff81928782 (system_call_fastpath+0x16/0x1b)
Shadow bytes around the buggy address:
ffff8800359c9700: fd fd fd fd fd fd fd fd fd fd fd fd fd fd fd fd
ffff8800359c9780: fd fd fd fd fd fd fd fd fa fa fa fa fa fa fa fa
ffff8800359c9800: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
ffff8800359c9880: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
ffff8800359c9900: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
=>ffff8800359c9980: 00 00 00 00 00 00 00 00 00 00 00 00 00 00[03]fb
ffff8800359c9a00: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
ffff8800359c9a80: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
ffff8800359c9b00: fa fa fa fa fa fa fa fa 00 00 00 00 00 00 00 00
ffff8800359c9b80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ffff8800359c9c00: 00 00 00 00 00 00 00 00 fa fa fa fa fa fa fa fa
Shadow byte legend (one shadow byte represents 8 application bytes):
Addressable: 00
Partially addressable: 01 02 03 04 05 06 07
Heap redzone: fa
Heap kmalloc redzone: fb
Freed heap region: fd
Shadow gap: fe
The out-of-bounds access happens on 'parser->buffer[parser->idx] = 0;'
Although the crash happened in ftrace_regex_open() the real bug
occurred in trace_get_user() where there's an incrementation to
parser->idx without a check against the size. The way it is triggered
is if userspace sends in 128 characters (EVENT_BUF_SIZE + 1), the loop
that reads the last character stores it and then breaks out because
there is no more characters. Then the last character is read to determine
what to do next, and the index is incremented without checking size.
Then the caller of trace_get_user() usually nulls out the last character
with a zero, but since the index is equal to the size, it writes a nul
character after the allocated space, which can corrupt memory.
Luckily, only root user has write access to this file.
Link: http://lkml.kernel.org/r/20131009222323.04fd1a0d@gandalf.local.home
Reported-by: Andrey Konovalov <andreyknvl@google.com>
commit 97b9410643475d6557d2517c2aff9fd2221141a9 upstream.
Marc Kleine-Budde pointed out, that commit 77cc982 "clocksource: use
clockevents_config_and_register() where possible" caused a regression
for some of the converted subarchs.
The reason is, that the clockevents core code converts the minimal
hardware tick delta to a nanosecond value for core internal
usage. This conversion is affected by integer math rounding loss, so
the backwards conversion to hardware ticks will likely result in a
value which is less than the configured hardware limitation. The
affected subarchs used their own workaround (SIGH!) which got lost in
the conversion.
The solution for the issue at hand is simple: adding evt->mult - 1 to
the shifted value before the integer divison in the core conversion
function takes care of it. But this only works for the case where for
the scaled math mult/shift pair "mult <= 1 << shift" is true. For the
case where "mult > 1 << shift" we can apply the rounding add only for
the minimum delta value to make sure that the backward conversion is
not less than the given hardware limit. For the upper bound we need to
omit the rounding add, because the backwards conversion is always
larger than the original latch value. That would violate the upper
bound of the hardware device.
Though looking closer at the details of that function reveals another
bogosity: The upper bounds check is broken as well. Checking for a
resulting "clc" value greater than KTIME_MAX after the conversion is
pointless. The conversion does:
u64 clc = (latch << evt->shift) / evt->mult;
So there is no sanity check for (latch << evt->shift) exceeding the
64bit boundary. The latch argument is "unsigned long", so on a 64bit
arch the handed in argument could easily lead to an unnoticed shift
overflow. With the above rounding fix applied the calculation before
the divison is:
u64 clc = (latch << evt->shift) + evt->mult - 1;
So we need to make sure, that neither the shift nor the rounding add
is overflowing the u64 boundary.
[ukl: move assignment to rnd after eventually changing mult, fix build
issue and correct comment with the right math]
Cc: Russell King - ARM Linux <linux@arm.linux.org.uk>
Cc: Marc Kleine-Budde <mkl@pengutronix.de>
Cc: nicolas.ferre@atmel.com
Cc: Marc Pignat <marc.pignat@hevs.ch>
Cc: john.stultz@linaro.org
Cc: kernel@pengutronix.de
Cc: Ronald Wahl <ronald.wahl@raritan.com>
Cc: LAK <linux-arm-kernel@lists.infradead.org>
Cc: Ludovic Desroches <ludovic.desroches@atmel.com>
Link: http://lkml.kernel.org/r/1380052223-24139-1-git-send-email-u.kleine-koenig@pengutronix.de
commit 95cf59ea72331d0093010543b8951bb43f262cac upstream.
Jiri reported that he could trigger the WARN_ON_ONCE() in
perf_cgroup_switch() using sw-events. This is because sw-events share
a cpuctx with multiple PMUs.
Use the ->unique_pmu pointer to limit the pmu iteration to unique
cpuctx instances.
Reported-and-Tested-by: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/n/tip-so7wi2zf3jjzrwcutm2mkz0j@git.kernel.org
Cc: Li Zefan <lizefan@huawei.com>
commit 3f1f33206c16c7b3839d71372bc2ac3f305aa802 upstream.
Stephane thought the perf_cpu_context::active_pmu name confusing and
suggested using 'unique_pmu' instead.
This pointer is a pointer to a 'random' pmu sharing the cpuctx
instance, therefore limiting a for_each_pmu loop to those where
cpuctx->unique_pmu matches the pmu we get a loop over unique cpuctx
instances.
Suggested-by: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/n/tip-kxyjqpfj2fn9gt7kwu5ag9ks@git.kernel.org
commit f169007b2773f285e098cb84c74aac0154d65ff7 upstream.
If we pass fd of memory.usage_in_bytes of cgroup A to cgroup.event_control
of cgroup B, then we won't get memory usage notification from A but B!
What's worse, if A and B are in different mount hierarchy, we'll end up
accessing NULL pointer!
Disallow this kind of invalid usage.
Signed-off-by: Li Zefan <lizefan@huawei.com>
Acked-by: Kirill A. Shutemov <kirill@shutemov.name>
Cc: Weng Meiling <wengmeiling.weng@huawei.com>
invalid ones
commit 6c9a27f5da9609fca46cb2b183724531b48f71ad upstream.
There is a small race between copy_process() and cgroup_attach_task()
where child->se.parent,cfs_rq points to invalid (old) ones.
parent doing fork() | someone moving the parent to another cgroup
copy_process()
+ dup_task_struct()
-> parent->se is copied to child->se.
se.parent,cfs_rq of them point to old ones.
+ cgroup_task_migrate()
-> parent->cgroup is updated.
+ cpu_cgroup_attach()
+ sched_move_task()
+ task_move_group_fair()
+- set_task_rq()
-> se.parent,cfs_rq of parent
are updated.
+ cgroup_fork()
-> parent->cgroup is copied to child->cgroup. (*1)
+ sched_fork()
+ task_fork_fair()
-> se.parent,cfs_rq of child are accessed
while they point to old ones. (*2)
In the worst case, this bug can lead to "use-after-free" and cause a panic,
because it's new cgroup's refcount that is incremented at (*1),
so the old cgroup(and related data) can be freed before (*2).
In fact, a panic caused by this bug was originally caught in RHEL6.4.
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<ffffffff81051e3e>] sched_slice+0x6e/0xa0
Call Trace:
[<ffffffff81051f25>] place_entity+0x75/0xa0
[<ffffffff81056a3a>] task_fork_fair+0xaa/0x160
[<ffffffff81063c0b>] sched_fork+0x6b/0x140
[<ffffffff8106c3c2>] copy_process+0x5b2/0x1450
[<ffffffff81063b49>] ? wake_up_new_task+0xd9/0x130
[<ffffffff8106d2f4>] do_fork+0x94/0x460
[<ffffffff81072a9e>] ? sys_wait4+0xae/0x100
[<ffffffff81009598>] sys_clone+0x28/0x30
[<ffffffff8100b393>] stub_clone+0x13/0x20
[<ffffffff8100b072>] ? system_call_fastpath+0x16/0x1b
Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Link: http://lkml.kernel.org/r/039601ceae06$733d3130$59b79390$@mxp.nes.nec.co.jp
commit a2c1c57be8d9fd5b716113c8991d3d702eeacf77 upstream.
To avoid executing the same work item concurrenlty, workqueue hashes
currently busy workers according to their current work items and looks
up the the table when it wants to execute a new work item. If there
already is a worker which is executing the new work item, the new item
is queued to the found worker so that it gets executed only after the
current execution finishes.
Unfortunately, a work item may be freed while being executed and thus
recycled for different purposes. If it gets recycled for a different
work item and queued while the previous execution is still in
progress, workqueue may make the new work item wait for the old one
although the two aren't really related in any way.
In extreme cases, this false dependency may lead to deadlock although
it's extremely unlikely given that there aren't too many self-freeing
work item users and they usually don't wait for other work items.
To alleviate the problem, record the current work function in each
busy worker and match it together with the work item address in
find_worker_executing_work(). While this isn't complete, it ensures
that unrelated work items don't interact with each other and in the
very unlikely case where a twisted wq user triggers it, it's always
onto itself making the culprit easy to spot.
Reported-by: Andrey Isakov <andy51@gmx.ru>
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=51701
[lizf: Backported to 3.4:
- Adjust context
- Incorporate earlier logging cleanup in process_one_work() from
044c782ce3a9 ('workqueue: fix checkpatch issues')]
commit 3aa62497594430ea522050b75c033f71f2c60ee6 upstream.
Currently, when try_to_grab_pending() grabs a delayed work item, it
leaves its linked work items alone on the delayed_works. The linked
work items are always NO_COLOR and will cause future
cwq_activate_first_delayed() increase cwq->nr_active incorrectly, and
may cause the whole cwq to stall. For example,
state: cwq->max_active = 1, cwq->nr_active = 1
one work in cwq->pool, many in cwq->delayed_works.
step1: try_to_grab_pending() removes a work item from delayed_works
but leaves its NO_COLOR linked work items on it.
step2: Later on, cwq_activate_first_delayed() activates the linked
work item increasing ->nr_active.
step3: cwq->nr_active = 1, but all activated work items of the cwq are
NO_COLOR. When they finish, cwq->nr_active will not be
decreased due to NO_COLOR, and no further work items will be
activated from cwq->delayed_works. the cwq stalls.
Fix it by ensuring the target work item is activated before stealing
PENDING in try_to_grab_pending(). This ensures that all the linked
work items are activated without incorrectly bumping cwq->nr_active.
tj: Updated comment and description.
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
[lizf: backported to 3.4: adjust context]
commit 13d60f4b6ab5b702dc8d2ee20999f98a93728aec upstream.
The futex_keys of process shared futexes are generated from the page
offset, the mapping host and the mapping index of the futex user space
address. This should result in an unique identifier for each futex.
Though this is not true when futexes are located in different subpages
of an hugepage. The reason is, that the mapping index for all those
futexes evaluates to the index of the base page of the hugetlbfs
mapping. So a futex at offset 0 of the hugepage mapping and another
one at offset PAGE_SIZE of the same hugepage mapping have identical
futex_keys. This happens because the futex code blindly uses
page->index.
Steps to reproduce the bug:
1. Map a file from hugetlbfs. Initialize pthread_mutex1 at offset 0
and pthread_mutex2 at offset PAGE_SIZE of the hugetlbfs
mapping.
The mutexes must be initialized as PTHREAD_PROCESS_SHARED because
PTHREAD_PROCESS_PRIVATE mutexes are not affected by this issue as
their keys solely depend on the user space address.
2. Lock mutex1 and mutex2
3. Create thread1 and in the thread function lock mutex1, which
results in thread1 blocking on the locked mutex1.
4. Create thread2 and in the thread function lock mutex2, which
results in thread2 blocking on the locked mutex2.
5. Unlock mutex2. Despite the fact that mutex2 got unlocked, thread2
still blocks on mutex2 because the futex_key points to mutex1.
To solve this issue we need to take the normal page index of the page
which contains the futex into account, if the futex is in an hugetlbfs
mapping. In other words, we calculate the normal page mapping index of
the subpage in the hugetlbfs mapping.
Mappings which are not based on hugetlbfs are not affected and still
use page->index.
Thanks to Mel Gorman who provided a patch for adding proper evaluation
functions to the hugetlbfs code to avoid exposing hugetlbfs specific
details to the futex code.
[ tglx: Massaged changelog ]
Signed-off-by: Zhang Yi <zhang.yi20@zte.com.cn>
Reviewed-by: Jiang Biao <jiang.biao2@zte.com.cn>
Tested-by: Ma Chenggong <ma.chenggong@zte.com.cn>
Reviewed-by: 'Mel Gorman' <mgorman@suse.de>
Acked-by: 'Darren Hart' <dvhart@linux.intel.com>
Cc: 'Peter Zijlstra' <peterz@infradead.org>
Link: http://lkml.kernel.org/r/000101ce71a6%24a83c5880%24f8b50980%24@com
Cc: Mike Galbraith <mgalbraith@suse.de>
commit ed5467da0e369e65b247b99eb6403cb79172bcda upstream.
tracing_read_pipe zeros all fields bellow "seq". The declaration contains
a comment about that, but it doesn't help.
The first field is "snapshot", it's true when current open file is
snapshot. Looks obvious, that it should not be zeroed.
The second field is "started". It was converted from cpumask_t to
cpumask_var_t (v2.6.28-4983-g4462344), in other words it was
converted from cpumask to pointer on cpumask.
Currently the reference on "started" memory is lost after the first read
from tracing_read_pipe and a proper object will never be freed.
The "started" is never dereferenced for trace_pipe, because trace_pipe
can't have the TRACE_FILE_ANNOTATE options.
Link: http://lkml.kernel.org/r/1375463803-3085183-1-git-send-email-avagin@openvz.org
Signed-off-by: Andrew Vagin <avagin@openvz.org>
commit 9c5da09d266ca9b32eb16cf940f8161d949c2fe5 upstream.
An rmdir pushes css's ref count to zero. However, if the associated
directory is open at the time, the dentry ref count is non-zero. If
the fd for this directory is then passed into perf_event_open, it
does a css_get(). This bounces the ref count back up from zero. This
is a problem by itself. But what makes it turn into a crash is the
fact that we end up doing an extra dput, since we perform a dput
when css_put sees the ref count go down to zero.
css_tryget() does not fall into that trap. So, we use that instead.
Reproduction test-case for the bug:
#include <unistd.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <linux/unistd.h>
#include <linux/perf_event.h>
#include <string.h>
#include <errno.h>
#include <stdio.h>
#define PERF_FLAG_PID_CGROUP (1U << 2)
int perf_event_open(struct perf_event_attr *hw_event_uptr,
pid_t pid, int cpu, int group_fd, unsigned long flags) {
return syscall(__NR_perf_event_open,hw_event_uptr, pid, cpu,
group_fd, flags);
* Directly poke at the perf_event bug, since it's proving hard to repro
* depending on where in the kernel tree. what moved?
int main(int argc, char **argv)
int fd;
struct perf_event_attr attr;
memset(&attr, 0, sizeof(attr));
attr.exclude_kernel = 1;
attr.size = sizeof(attr);
mkdir("/dev/cgroup/perf_event/blah", 0777);
fd = open("/dev/cgroup/perf_event/blah", O_RDONLY);
perror("open");
rmdir("/dev/cgroup/perf_event/blah");
sleep(2);
perf_event_open(&attr, fd, 0, -1, PERF_FLAG_PID_CGROUP);
perror("perf_event_open");
close(fd);
return 0;
Signed-off-by: Salman Qazi <sqazi@google.com>
Acked-by: Tejun Heo <tj@kernel.org>
Link: http://lkml.kernel.org/r/20120614223108.1025.2503.stgit@dungbeetle.mtv.corp.google.com
commit 0231bb5336758426b44ccd798ccd3c5419c95d58 upstream.
When we have group with mixed events (hw/sw) we want to end up
with group leader being in hw context. So if group leader is
initialy sw event, we move all the events under hw context.
The move is done for each event by removing it from its context
and adding it back into proper one. As a part of the removal the
event is automatically disabled, which is not what we want at
this stage of creating groups.
The fix is to initialize event state after removal from sw
context.
This fix resulted from the following discussion:
http://thread.gmane.org/gmane.linux.kernel.perf.user/1144
Reported-by: Andreas Hollmann <hollmann@in.tum.de>
Signed-off-by: Jiri Olsa <jolsa@redhat.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Vince Weaver <vince@deater.net>
Link: http://lkml.kernel.org/r/1359714225-4231-1-git-send-email-jolsa@redhat.com
commit a59f4e079d19464eebb9b06513a1d4f55fdae5ba upstream.
The caller of sched_sliced() should pass se.cfs_rq and se as the
arguments, however in sched_rr_get_interval() we gave it
rq.cfs_rq and se, which made the following computation obviously
wrong.
The change was introduced by commit:
77034937dc45 sched: fix crash in sys_sched_rr_get_interval()
... 5 years ago, while it had been the correct 'cfs_rq_of' before
the commit. The change seems to be irrelevant to the commit
msg, which was to return a 0 timeslice for tasks that are on an
idle runqueue. So I believe that was just a plain typo.
Signed-off-by: Zhu Yanhai <gaoyang.zyh@taobao.com>
Cc: Paul Turner <pjt@google.com>
Link: http://lkml.kernel.org/r/1357621012-15039-1-git-send-email-gaoyang.zyh@taobao.com
[ Since this is an ABI and an old bug, we'll test this via a
slow upstream route, to hopefully discover any app breakage. ]
commit 11034ae9c20f4057a6127fc965906417978e69b2 upstream
Initialization of variable irq_flags and pc was missed when backport
11034ae9c to linux-3.0.y and linux-3.4.y, my fault.
Signed-off-by: zhangwei(Jovi) <jovi.zhangwei@huawei.com>
commit 5ec2481b7b47a4005bb446d176e5d0257400c77d upstream.
smp_call_function_* must not be called from softirq context.
But clock_was_set() which calls on_each_cpu() is called from softirq
context to implement a delayed clock_was_set() for the timer interrupt
handler. Though that almost never gets invoked. A recent change in the
resume code uses the softirq based delayed clock_was_set to support
Xens resume mechanism.
linux-next contains a new warning which warns if smp_call_function_*
is called from softirq context which gets triggered by that Xen
change.
Fix this by moving the delayed clock_was_set() call to a work context.
Reported-and-tested-by: Artem Savkov <artem.savkov@gmail.com>
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Cc: David Vrabel <david.vrabel@citrix.com>
Cc: H. Peter Anvin <hpa@zytor.com>,
Cc: Konrad Wilk <konrad.wilk@oracle.com>
Cc: xen-devel@lists.xen.org
Cc: stable@vger.kernel.org
commit 11034ae9c20f4057a6127fc965906417978e69b2 upstream.
All syscall tracing irqs-off tags are wrong, the syscall enter entry doesn't
disable irqs.
[root@jovi tracing]#echo "syscalls:sys_enter_open" > set_event
[root@jovi tracing]# cat trace
# tracer: nop
# entries-in-buffer/entries-written: 13/13 #P:2
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
irqbalance-513 [000] d... 56115.496766: sys_open(filename: 804e1a6, flags: 0, mode: 1b6)
irqbalance-513 [000] d... 56115.497008: sys_open(filename: 804e1bb, flags: 0, mode: 1b6)
sendmail-771 [000] d... 56115.827982: sys_open(filename: b770e6d1, flags: 0, mode: 1b6)
The reason is syscall tracing doesn't record irq_flags into buffer.
The proper display is:
# tracer: nop
# entries-in-buffer/entries-written: 14/14 #P:2
# _-----=> irqs-off
# ||| / delay
irqbalance-514 [001] .... 46.213921: sys_open(filename: 804e1a6, flags: 0, mode: 1b6)
irqbalance-514 [001] .... 46.214160: sys_open(filename: 804e1bb, flags: 0, mode: 1b6)
<...>-920 [001] .... 47.307260: sys_open(filename: 4e82a0c5, flags: 80000, mode: 0)
Link: http://lkml.kernel.org/r/1365564393-10972-3-git-send-email-jovi.zhangwei@huawei.com
Cc: stable@vger.kernel.org # 2.6.35
commit 058ebd0eba3aff16b144eabf4510ed9510e1416e upstream.
Jiri managed to trigger this warning:
[] [ INFO: possible circular locking dependency detected ]
[] 3.10.0+ #228 Tainted: G W
[] p/6613 is trying to acquire lock:
[] (rcu_node_0){..-...}, at: [<ffffffff810ca797>] rcu_read_unlock_special+0xa7/0x250
[] but task is already holding lock:
[] (&ctx->lock){-.-...}, at: [<ffffffff810f2879>] perf_lock_task_context+0xd9/0x2c0
[] which lock already depends on the new lock.
[] the existing dependency chain (in reverse order) is:
[] -> #4 (&ctx->lock){-.-...}:
[] -> #3 (&rq->lock){-.-.-.}:
[] -> #2 (&p->pi_lock){-.-.-.}:
[] -> #1 (&rnp->nocb_gp_wq[1]){......}:
[] -> #0 (rcu_node_0){..-...}:
Paul was quick to explain that due to preemptible RCU we cannot call
rcu_read_unlock() while holding scheduler (or nested) locks when part
of the read side critical section was preemptible.
Therefore solve it by making the entire RCU read side non-preemptible.
Also pull out the retry from under the non-preempt to play nice with RT.
Reported-by: Jiri Olsa <jolsa@redhat.com>
Helped-out-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
commit 06f417968beac6e6b614e17b37d347aa6a6b1d30 upstream.
The '!ctx->is_active' check has a valid scenario, so
there's no need for the warning.
The reason is that there's a time window between the
'ctx->is_active' check in the perf_event_enable() function
and the __perf_event_enable() function having:
- IRQs on
- ctx->lock unlocked
where the task could be killed and 'ctx' deactivated by
perf_event_exit_task(), ending up with the warning below.
So remove the WARN_ON_ONCE() check and add comments to
explain it all.
This addresses the following warning reported by Vince Weaver:
[ 324.983534] ------------[ cut here ]------------
[ 324.984420] WARNING: at kernel/events/core.c:1953 __perf_event_enable+0x187/0x190()
[ 324.984420] Modules linked in:
[ 324.984420] CPU: 19 PID: 2715 Comm: nmi_bug_snb Not tainted 3.10.0+ #246
[ 324.984420] Hardware name: Supermicro X8DTN/X8DTN, BIOS 4.6.3 01/08/2010
[ 324.984420] 0000000000000009 ffff88043fce3ec8 ffffffff8160ea0b ffff88043fce3f00
[ 324.984420] ffffffff81080ff0 ffff8802314fdc00 ffff880231a8f800 ffff88043fcf7860
[ 324.984420] 0000000000000286 ffff880231a8f800 ffff88043fce3f10 ffffffff8108103a
[ 324.984420] Call Trace:
[ 324.984420] <IRQ> [<ffffffff8160ea0b>] dump_stack+0x19/0x1b
[ 324.984420] [<ffffffff81080ff0>] warn_slowpath_common+0x70/0xa0
[ 324.984420] [<ffffffff8108103a>] warn_slowpath_null+0x1a/0x20
[ 324.984420] [<ffffffff81134437>] __perf_event_enable+0x187/0x190
[ 324.984420] [<ffffffff81130030>] remote_function+0x40/0x50
[ 324.984420] [<ffffffff810e51de>] generic_smp_call_function_single_interrupt+0xbe/0x130
[ 324.984420] [<ffffffff81066a47>] smp_call_function_single_interrupt+0x27/0x40
[ 324.984420] [<ffffffff8161fd2f>] call_function_single_interrupt+0x6f/0x80
[ 324.984420] <EOI> [<ffffffff816161a1>] ? _raw_spin_unlock_irqrestore+0x41/0x70
[ 324.984420] [<ffffffff8113799d>] perf_event_exit_task+0x14d/0x210
[ 324.984420] [<ffffffff810acd04>] ? switch_task_namespaces+0x24/0x60
[ 324.984420] [<ffffffff81086946>] do_exit+0x2b6/0xa40
[ 324.984420] [<ffffffff8161615c>] ? _raw_spin_unlock_irq+0x2c/0x30
[ 324.984420] [<ffffffff81087279>] do_group_exit+0x49/0xc0
[ 324.984420] [<ffffffff81096854>] get_signal_to_deliver+0x254/0x620
[ 324.984420] [<ffffffff81043057>] do_signal+0x57/0x5a0
[ 324.984420] [<ffffffff8161a164>] ? __do_page_fault+0x2a4/0x4e0
[ 324.984420] [<ffffffff8161665c>] ? retint_restore_args+0xe/0xe
[ 324.984420] [<ffffffff816166cd>] ? retint_signal+0x11/0x84
[ 324.984420] [<ffffffff81043605>] do_notify_resume+0x65/0x80
[ 324.984420] [<ffffffff81616702>] retint_signal+0x46/0x84
[ 324.984420] ---[ end trace 442ec2f04db3771a ]---
Suggested-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Link: http://lkml.kernel.org/r/1373384651-6109-2-git-send-email-jolsa@redhat.com
commit 734df5ab549ca44f40de0f07af1c8803856dfb18 upstream.
Currently when the child context for inherited events is
created, it's based on the pmu object of the first event
of the parent context.
This is wrong for the following scenario:
- HW context having HW and SW event
- HW event got removed (closed)
- SW event stays in HW context as the only event
and its pmu is used to clone the child context
The issue starts when the cpu context object is touched
based on the pmu context object (__get_cpu_context). In
this case the HW context will work with SW cpu context
ending up with following WARN below.
Fixing this by using parent context pmu object to clone
from child context.
Addresses the following warning reported by Vince Weaver:
[ 2716.472065] ------------[ cut here ]------------
[ 2716.476035] WARNING: at kernel/events/core.c:2122 task_ctx_sched_out+0x3c/0x)
[ 2716.476035] Modules linked in: nfsd auth_rpcgss oid_registry nfs_acl nfs locn
[ 2716.476035] CPU: 0 PID: 3164 Comm: perf_fuzzer Not tainted 3.10.0-rc4 #2
[ 2716.476035] Hardware name: AOpen DE7000/nMCP7ALPx-DE R1.06 Oct.19.2012, BI2
[ 2716.476035] 0000000000000000 ffffffff8102e215 0000000000000000 ffff88011fc18
[ 2716.476035] ffff8801175557f0 0000000000000000 ffff880119fda88c ffffffff810ad
[ 2716.476035] ffff880119fda880 ffffffff810af02a 0000000000000009 ffff880117550
[ 2716.476035] Call Trace:
[ 2716.476035] [<ffffffff8102e215>] ? warn_slowpath_common+0x5b/0x70
[ 2716.476035] [<ffffffff810ab2bd>] ? task_ctx_sched_out+0x3c/0x5f
[ 2716.476035] [<ffffffff810af02a>] ? perf_event_exit_task+0xbf/0x194
[ 2716.476035] [<ffffffff81032a37>] ? do_exit+0x3e7/0x90c
[ 2716.476035] [<ffffffff810cd5ab>] ? __do_fault+0x359/0x394
[ 2716.476035] [<ffffffff81032fe6>] ? do_group_exit+0x66/0x98
[ 2716.476035] [<ffffffff8103dbcd>] ? get_signal_to_deliver+0x479/0x4ad
[ 2716.476035] [<ffffffff810ac05c>] ? __perf_event_task_sched_out+0x230/0x2d1
[ 2716.476035] [<ffffffff8100205d>] ? do_signal+0x3c/0x432
[ 2716.476035] [<ffffffff810abbf9>] ? ctx_sched_in+0x43/0x141
[ 2716.476035] [<ffffffff810ac2ca>] ? perf_event_context_sched_in+0x7a/0x90
[ 2716.476035] [<ffffffff810ac311>] ? __perf_event_task_sched_in+0x31/0x118
[ 2716.476035] [<ffffffff81050dd9>] ? mmdrop+0xd/0x1c
[ 2716.476035] [<ffffffff81051a39>] ? finish_task_switch+0x7d/0xa6
[ 2716.476035] [<ffffffff81002473>] ? do_notify_resume+0x20/0x5d
[ 2716.476035] [<ffffffff813654f5>] ? retint_signal+0x3d/0x78
[ 2716.476035] ---[ end trace 827178d8a5966c3d ]---
Link: http://lkml.kernel.org/r/1373384651-6109-1-git-send-email-jolsa@redhat.com
commit f17a5194859a82afe4164e938b92035b86c55794 upstream.
The irqsoff tracer records the max time that interrupts are disabled.
There are hooks in the assembly code that calls back into the tracer when
interrupts are disabled or enabled.
When they are enabled, the tracer checks if the amount of time they
were disabled is larger than the previous recorded max interrupts off
time. If it is, it creates a snapshot of the currently running trace
to store where the last largest interrupts off time was held and how
it happened.
During testing, this RCU lockdep dump appeared:
[ 1257.829021] ===============================
[ 1257.829021] [ INFO: suspicious RCU usage. ]
[ 1257.829021] 3.10.0-rc1-test+ #171 Tainted: G W
[ 1257.829021] -------------------------------
[ 1257.829021] /home/rostedt/work/git/linux-trace.git/include/linux/rcupdate.h:780 rcu_read_lock() used illegally while idle!
[ 1257.829021]
[ 1257.829021] other info that might help us debug this:
[ 1257.829021]
[ 1257.829021]
[ 1257.829021] RCU used illegally from idle CPU!
[ 1257.829021] rcu_scheduler_active = 1, debug_locks = 0
[ 1257.829021] RCU used illegally from extended quiescent state!
[ 1257.829021] 2 locks held by trace-cmd/4831:
[ 1257.829021] #0: (max_trace_lock){......}, at: [<ffffffff810e2b77>] stop_critical_timing+0x1a3/0x209
[ 1257.829021] #1: (rcu_read_lock){.+.+..}, at: [<ffffffff810dae5a>] __update_max_tr+0x88/0x1ee
[ 1257.829021]
[ 1257.829021] stack backtrace:
[ 1257.829021] CPU: 3 PID: 4831 Comm: trace-cmd Tainted: G W 3.10.0-rc1-test+ #171
[ 1257.829021] Hardware name: To Be Filled By O.E.M. To Be Filled By O.E.M./To be filled by O.E.M., BIOS SDBLI944.86P 05/08/2007
[ 1257.829021] 0000000000000001 ffff880065f49da8 ffffffff8153dd2b ffff880065f49dd8
[ 1257.829021] ffffffff81092a00 ffff88006bd78680 ffff88007add7500 0000000000000003
[ 1257.829021] ffff88006bd78680 ffff880065f49e18 ffffffff810daebf ffffffff810dae5a
[ 1257.829021] Call Trace:
[ 1257.829021] [<ffffffff8153dd2b>] dump_stack+0x19/0x1b
[ 1257.829021] [<ffffffff81092a00>] lockdep_rcu_suspicious+0x109/0x112
[ 1257.829021] [<ffffffff810daebf>] __update_max_tr+0xed/0x1ee
[ 1257.829021] [<ffffffff810dae5a>] ? __update_max_tr+0x88/0x1ee
[ 1257.829021] [<ffffffff811002b9>] ? user_enter+0xfd/0x107
[ 1257.829021] [<ffffffff810dbf85>] update_max_tr_single+0x11d/0x12d
[ 1257.829021] [<ffffffff810e2b15>] stop_critical_timing+0x141/0x209
[ 1257.829021] [<ffffffff8109569a>] ? trace_hardirqs_on+0xd/0xf
[ 1257.829021] [<ffffffff810e3057>] time_hardirqs_on+0x2a/0x2f
[ 1257.829021] [<ffffffff8109550c>] trace_hardirqs_on_caller+0x16/0x197
[ 1257.829021] [<ffffffff8109569a>] trace_hardirqs_on+0xd/0xf
[ 1257.829021] [<ffffffff811002b9>] user_enter+0xfd/0x107
[ 1257.829021] [<ffffffff810029b4>] do_notify_resume+0x92/0x97
[ 1257.829021] [<ffffffff8154bdca>] int_signal+0x12/0x17
What happened was entering into the user code, the interrupts were enabled
and a max interrupts off was recorded. The trace buffer was saved along with
various information about the task: comm, pid, uid, priority, etc.
The uid is recorded with task_uid(tsk). But this is a macro that uses rcu_read_lock()
to retrieve the data, and this happened to happen where RCU is blind (user_enter).
As only the preempt and irqs off tracers can have this happen, and they both
only have the tsk == current, if tsk == current, use current_uid() instead of
task_uid(), as current_uid() does not use RCU as only current can change its uid.
This fixes the RCU suspicious splat.
commit 1f73a9806bdd07a5106409bbcab3884078bd34fe upstream.
When the system switches from periodic to oneshot mode, the broadcast
logic causes a possibility that a CPU which has not yet switched to
oneshot mode puts its own clock event device into oneshot mode without
updating the state and the timer handler.
CPU0 CPU1
per cpu tickdev is in periodic mode
and switched to broadcast
Switch to oneshot mode
tick_broadcast_switch_to_oneshot()
cpumask_copy(tick_oneshot_broacast_mask,
tick_broadcast_mask);
broadcast device mode = oneshot
Timer interrupt
irq_enter()
tick_check_oneshot_broadcast()
dev->set_mode(ONESHOT);
tick_handle_periodic()
if (dev->mode == ONESHOT)
dev->next_event += period;
FAIL.
We fail, because dev->next_event contains KTIME_MAX, if the device was
in periodic mode before the uncontrolled switch to oneshot happened.
We must copy the broadcast bits over to the oneshot mask, because
otherwise a CPU which relies on the broadcast would not been woken up
anymore after the broadcast device switched to oneshot mode.
So we need to verify in tick_check_oneshot_broadcast() whether the CPU
has already switched to oneshot mode. If not, leave the device
untouched and let the CPU switch controlled into oneshot mode.
This is a long standing bug, which was never noticed, because the main
user of the broadcast x86 cannot run into that scenario, AFAICT. The
nonarchitected timer mess of ARM creates a gazillion of differently
broken abominations which trigger the shortcomings of that broadcast
code, which better had never been necessary in the first place.
Reported-and-tested-by: Stehle Vincent-B46079 <B46079@freescale.com>
Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
Cc: John Stultz <john.stultz@linaro.org>,
Cc: Mark Rutland <mark.rutland@arm.com>
Link: http://lkml.kernel.org/r/alpine.DEB.2.02.1307012153060.4013@ionos.tec.linutronix.de
commit 9e04d3804d3ac97d8c03a41d78d0f0674b5d01e1 upstream.
Direct compare of jiffies related values does not work in the wrap
around case. Replace it with time_is_after_jiffies().
Signed-off-by: Bart Van Assche <bvanassche@acm.org>
Cc: Arjan van de Ven <arjan@infradead.org>
Link: http://lkml.kernel.org/r/519BC066.5080600@acm.org
commit 2779db8d37d4b542d9ca2575f5f178dbeaca6c86 upstream.
Commit 02725e7471b8 ('genirq: Use irq_get/put functions'),
inadvertently changed can_request_irq() to return 0 for IRQs that have
no action. This causes pcibios_lookup_irq() to select only IRQs that
already have an action with IRQF_SHARED set, or to fail if there are
none. Change can_request_irq() to return 1 for IRQs that have no
action (if the first two conditions are met).
Reported-by: Bjarni Ingi Gislason <bjarniig@rhi.hi.is>
Tested-by: Bjarni Ingi Gislason <bjarniig@rhi.hi.is> (against 3.2)
Cc: 709647@bugs.debian.org
Link: http://bugs.debian.org/709647
Link: http://lkml.kernel.org/r/1372383630.23847.40.camel@deadeye.wl.decadent.org.uk
This reverts commit 48f0f14ffb6ff4852922994d11fbda418d40100e which was
commit 749c8814f08f12baa4a9c2812a7c6ede7d69507d upstream.
It seems to be misapplied, and not needed for 3.4-stable
Reported-by: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Charles Wang <muming.wq@taobao.com>
commit 9bb5d40cd93c9dd4be74834b1dcb1ba03629716b upstream.
Vince's fuzzer once again found holes. This time it spotted a leak in
the locked page accounting.
When an event had redirected output and its close() was the last
reference to the buffer we didn't have a vm context to undo accounting.
Change the code to destroy the buffer on the last munmap() and detach
all redirected events at that time. This provides us the right context
to undo the vm accounting.
[Backporting for 3.4-stable.
VM_RESERVED flag was replaced with pair 'VM_DONTEXPAND | VM_DONTDUMP' in
314e51b9 since 3.7.0-rc1, and 314e51b9 comes from a big patchset, we didn't
backport the patchset, so I restored 'VM_DNOTEXPAND | VM_DONTDUMP' as before:
- vma->vm_flags |= VM_DONTCOPY | VM_DONTEXPAND | VM_DONTDUMP;
+ vma->vm_flags |= VM_DONTCOPY | VM_RESERVED;
-- zliu]
Reported-and-tested-by: Vince Weaver <vincent.weaver@maine.edu>
Link: http://lkml.kernel.org/r/20130604084421.GI8923@twins.programming.kicks-ass.net
Cc: <stable@kernel.org>
Signed-off-by: Zhouping Liu <zliu@redhat.com>
commit 26cb63ad11e04047a64309362674bcbbd6a6f246 upstream.
Vince reported a problem found by his perf specific trinity
fuzzer.
Al noticed 2 problems with perf's mmap():
- it has issues against fork() since we use vma->vm_mm for accounting.
- it has an rb refcount leak on double mmap().
We fix the issues against fork() by using VM_DONTCOPY; I don't
think there's code out there that uses this; we didn't hear
about weird accounting problems/crashes. If we do need this to
work, the previously proposed VM_PINNED could make this work.
Aside from the rb reference leak spotted by Al, Vince's example
prog was indeed doing a double mmap() through the use of
perf_event_set_output().
This exposes another problem, since we now have 2 events with
one buffer, the accounting gets screwy because we account per
event. Fix this by making the buffer responsible for its own
accounting.
-- zliu]
Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Link: http://lkml.kernel.org/r/20130528085548.GA12193@twins.programming.kicks-ass.net
commit c790b0ad23f427c7522ffed264706238c57c007e upstream.
fetch_bp_busy_slots() and toggle_bp_slot() use
for_each_online_cpu(), this is obviously wrong wrt cpu_up() or
cpu_down(), we can over/under account the per-cpu numbers.
For example:
# echo 0 >> /sys/devices/system/cpu/cpu1/online
# perf record -e mem:0x10 -p 1 &
# echo 1 >> /sys/devices/system/cpu/cpu1/online
# perf record -e mem:0x10,mem:0x10,mem:0x10,mem:0x10 -C1 -a &
# taskset -p 0x2 1
triggers the same WARN_ONCE("Can't find any breakpoint slot") in
arch_install_hw_breakpoint().
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
Link: http://lkml.kernel.org/r/20130620155009.GA6327@redhat.com
commit cf7df378aa4ff7da3a44769b7ff6e9eef1a9f3db upstream.
We recently noticed that reboot of a 1024 cpu machine takes approx 16
minutes of just stopping the cpus. The slowdown was tracked to commit
f96972f2dc63 ("kernel/sys.c: call disable_nonboot_cpus() in
kernel_restart()").
The current implementation does all the work of hot removing the cpus
before halting the system. We are switching to just migrating to the
boot cpu and then continuing with shutdown/reboot.
This also has the effect of not breaking x86's command line parameter
for specifying the reboot cpu. Note, this code was shamelessly copied
from arch/x86/kernel/reboot.c with bits removed pertaining to the
reboot_cpu command line parameter.
Signed-off-by: Robin Holt <holt@sgi.com>
Tested-by: Shawn Guo <shawn.guo@linaro.org>
Cc: "Srivatsa S. Bhat" <srivatsa.bhat@linux.vnet.ibm.com>
Cc: Russ Anderson <rja@sgi.com>
Cc: Robin Holt <holt@sgi.com>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
commit 16e53dbf10a2d7e228709a7286310e629ede5e45 upstream.
There are instances in the kernel where we would like to disable CPU
hotplug (from sysfs) during some important operation. Today the freezer
code depends on this and the code to do it was kinda tailor-made for
that.
Restructure the code and make it generic enough to be useful for other
usecases too.
Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
Cc: Shawn Guo <shawn.guo@linaro.org>
commit 7f49ef69db6bbf756c0abca7e9b65b32e999eec8 upstream.
As ftrace_filter_lseek is now used with ftrace_pid_fops, it needs to
be moved out of the #ifdef CONFIG_DYNAMIC_FTRACE section as the
ftrace_pid_fops is defined when DYNAMIC_FTRACE is not.
[ lizf: adjust context ]
commit 6a76f8c0ab19f215af2a3442870eeb5f0e81998d upstream.
Currently set_ftrace_pid and set_graph_function files use seq_lseek
for their fops. However seq_open() is called only for FMODE_READ in
the fops->open() so that if an user tries to seek one of those file
when she open it for writing, it sees NULL seq_file and then panic.
It can be easily reproduced with following command:
$ cd /sys/kernel/debug/tracing
$ echo 1234 | sudo tee -a set_ftrace_pid
In this example, GNU coreutils' tee opens the file with fopen(, "a")
and then the fopen() internally calls lseek().
Link:
http://lkml.kernel.org/r/1365663302-2170-1-git-send-email-namhyung@kernel.org
Signed-off-by: Namhyung Kim <namhyung@kernel.org>
Cc: Namhyung Kim <namhyung.kim@lge.com>
commit 264b83c07a84223f0efd0d1db9ccc66d6f88288f upstream.
argv_split(empty_or_all_spaces) happily succeeds, it simply returns
argc == 0 and argv[0] == NULL. Change call_usermodehelper_exec() to
check sub_info->path != NULL to avoid the crash.
This is the minimal fix, todo:
- perhaps we should change argv_split() to return NULL or change the
callers.
- kill or justify ->path[0] check
- narrow the scope of helper_lock()
Acked-By: Lucas De Marchi <lucas.demarchi@intel.com>
