path: root/kernel
2012-08-12Merge tag 'pm-for-3.6-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management fixes from Rafael J. Wysocki: - Fix for two recent regressions in the generic PM domains framework. - Revert of a commit that introduced a resume regression and is conceptually incorrect in my opinion. - Fix for a return value in pcc-cpufreq.c from Julia Lawall. - RTC wakeup signaling fix from Neil Brown. - Suppression of compiler warnings for CONFIG_PM_SLEEP unset in ACPI, platform/x86 and TPM drivers. * tag 'pm-for-3.6-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: tpm_tis / PM: Fix unused function warning for CONFIG_PM_SLEEP platform / x86 / PM: Fix unused function warnings for CONFIG_PM_SLEEP ACPI / PM: Fix unused function warnings for CONFIG_PM_SLEEP Revert "NMI watchdog: fix for lockup detector breakage on resume" PM: Make dev_pm_get_subsys_data() always return 0 on success drivers/cpufreq/pcc-cpufreq.c: fix error return code RTC: Avoid races between RTC alarm wakeup and suspend.
2012-08-12printk: Fix calculation of length used to discard recordsJeff Mahoney
While tracking down a weird buffer overflow issue in a program that looked to be sane, I started double checking the length returned by syslog(SYSLOG_ACTION_READ_ALL, ...) to make sure it wasn't overflowing the buffer. Sure enough, it was. I saw this in strace: 11339 syslog(SYSLOG_ACTION_READ_ALL, "<5>[244017.708129] REISERFS (dev"..., 8192) = 8279 It turns out that the loops that calculate how much space the entries will take when they're copied don't include the newlines and prefixes that will be included in the final output since prev flags is passed as zero. This patch properly accounts for it and fixes the overflow. CC: stable@kernel.org Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-08-08Revert "NMI watchdog: fix for lockup detector breakage on resume"Rafael J. Wysocki
Revert commit 45226e9 (NMI watchdog: fix for lockup detector breakage on resume) which breaks resume from system suspend on my SH7372 Mackerel board (by causing a NULL pointer dereference to happen) and is generally wrong, because it abuses the CPU hotplug functionality in a shamelessly blatant way. The original issue should be addressed through appropriate syscore resume callback instead. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2012-08-05time: Fix adjustment cleanup bug in timekeeping_adjust()Ingo Molnar
Tetsuo Handa reported that sporadically the system clock starts counting up too quickly which is enough to confuse the hangcheck timer to print a bogus stall warning. Commit 2a8c0883 "time: Move xtime_nsec adjustment underflow handling timekeeping_adjust" overlooked this exit path: } else return; which should really be a proper exit sequence, fixing the bug as a side effect. Also make the flow more readable by properly balancing curly braces. Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> wrote: Tested-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> wrote: Signed-off-by: Ingo Molnar <mingo@kernel.org> Cc: john.stultz@linaro.org Cc: a.p.zijlstra@chello.nl Cc: richardcochran@gmail.com Cc: prarit@redhat.com Link: http://lkml.kernel.org/r/20120804192114.GA28347@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-08-03Merge branch 'core-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull futex fixes from Ingo Molnar: "A couple of futex fixes from Darren Hart: two bugs reported by Dave Jones (found with his trinity test) and Dan Carpenter through static analysis. The third found while debugging the first two." * 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: futex: Forbid uaddr == uaddr2 in futex_wait_requeue_pi() futex: Fix bug in WARN_ON for NULL q.pi_state futex: Test for pi_mutex on fault in futex_wait_requeue_pi()
2012-08-03Merge branch 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer fixes from Ingo Molnar: "One regression fix, and a couple of cleanups that clean up the code flow in areas that had high-profile bugs recently." * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: time: Remove all direct references to timekeeper time: Clean up offs_real/wall_to_mono and offs_boot/total_sleep_time updates time: Clean up stray newlines time/jiffies: Rename ACTHZ to SHIFTED_HZ time/jiffies: Allow CLOCK_TICK_RATE to be undefined time: Fix casting issue in tk_set_xtime and tk_xtime_add
2012-08-03Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fixes from Ingo Molnar: "Fixes and two late cleanups" * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched/cleanups: Add load balance cpumask pointer to 'struct lb_env' sched: Fix comment about PREEMPT_ACTIVE bit location sched: Fix minor code style issues sched: Use task_rq_unlock() in __sched_setscheduler() sched/numa: Add SD_PERFER_SIBLING to CPU domain
2012-08-03Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Fix merge window fallout and fix sleep profiling (this was always broken, so it's not a fix for the merge window - we can skip this one from the head of the tree)." * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf/trace: Add ability to set a target task for events perf/x86: Fix USER/KERNEL tagging of samples properly perf/x86/intel/uncore: Make UNCORE_PMU_HRTIMER_INTERVAL 64-bit
2012-08-03Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq fix from Ingo Molnar. * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: genirq: Allow irq chips to mark themself oneshot safe
2012-08-03Merge tag 'for_linux-3.6-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/kgdb Pull KGDB/KDB/usb-dbgp fixes and cleanups from Jason Wessel: "There are no new features, those will be delayed to the 3.7 window. There are only fixes/cleanup against the usual kernel churn and we are removing more lines than we add: - usb-dbgp - increase the controller wait time to come out of halt. - kdb - Remove unused KDB_FLAG_ONLY_DO_DUMP code and cpu in more prompt - debug core - pass NMI type on archs that provide NMI types" * tag 'for_linux-3.6-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/kgdb: USB: echi-dbgp: increase the controller wait time to come out of halt. kernel/debug: Make use of KGDB_REASON_NMI kdb: Remove cpu from the more prompt kdb: Remove unused KDB_FLAG_ONLY_DO_DUMP
2012-08-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull second vfs pile from Al Viro: "The stuff in there: fsfreeze deadlock fixes by Jan (essentially, the deadlock reproduced by xfstests 068), symlink and hardlink restriction patches, plus assorted cleanups and fixes. Note that another fsfreeze deadlock (emergency thaw one) is *not* dealt with - the series by Fernando conflicts a lot with Jan's, breaks userland ABI (FIFREEZE semantics gets changed) and trades the deadlock for massive vfsmount leak; this is going to be handled next cycle. There probably will be another pull request, but that stuff won't be in it." Fix up trivial conflicts due to unrelated changes next to each other in drivers/{staging/gdm72xx/usb_boot.c, usb/gadget/storage_common.c} * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (54 commits) delousing target_core_file a bit Documentation: Correct s_umount state for freeze_fs/unfreeze_fs fs: Remove old freezing mechanism ext2: Implement freezing btrfs: Convert to new freezing mechanism nilfs2: Convert to new freezing mechanism ntfs: Convert to new freezing mechanism fuse: Convert to new freezing mechanism gfs2: Convert to new freezing mechanism ocfs2: Convert to new freezing mechanism xfs: Convert to new freezing code ext4: Convert to new freezing mechanism fs: Protect write paths by sb_start_write - sb_end_write fs: Skip atime update on frozen filesystem fs: Add freezing handling to mnt_want_write() / mnt_drop_write() fs: Improve filesystem freezing handling switch the protection of percpu_counter list to spinlock nfsd: Push mnt_want_write() outside of i_mutex btrfs: Push mnt_want_write() outside of i_mutex fat: Push mnt_want_write() outside of i_mutex ...
2012-07-31Merge tag 'irqdomain-for-linus' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
Pull irqdomain changes from Grant Likely: "Round of refactoring and enhancements to irq_domain infrastructure. This series starts the process of simplifying irqdomain. The ultimate goal is to merge LEGACY, LINEAR and TREE mappings into a single system, but had to back off from that after some last minute bugs. Instead it mainly reorganizes the code and ensures that the reverse map gets populated when the irq is mapped instead of the first time it is looked up. Merging of the irq_domain types is deferred to v3.7 In other news, this series adds helpers for creating static mappings on a linear or tree mapping." * tag 'irqdomain-for-linus' of git://git.secretlab.ca/git/linux-2.6: irqdomain: Improve diagnostics when a domain mapping fails irqdomain: eliminate slow-path revmap lookups irqdomain: Fix irq_create_direct_mapping() to test irq_domain type. irqdomain: Eliminate dedicated radix lookup functions irqdomain: Support for static IRQ mapping and association. irqdomain: Always update revmap when setting up a virq irqdomain: Split disassociating code into separate function irq_domain: correct a minor wrong comment for linear revmap irq_domain: Standardise legacy/linear domain selection irqdomain: Make ops->map hook optional irqdomain: Remove unnecessary test for IRQ_DOMAIN_MAP_LEGACY irqdomain: Simple NUMA awareness. devicetree: add helper inline for retrieving a node's full name
2012-07-31Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge Andrew's second set of patches: - MM - a few random fixes - a couple of RTC leftovers * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (120 commits) rtc/rtc-88pm80x: remove unneed devm_kfree rtc/rtc-88pm80x: assign ret only when rtc_register_driver fails mm: hugetlbfs: close race during teardown of hugetlbfs shared page tables tmpfs: distribute interleave better across nodes mm: remove redundant initialization mm: warn if pg_data_t isn't initialized with zero mips: zero out pg_data_t when it's allocated memcg: gix memory accounting scalability in shrink_page_list mm/sparse: remove index_init_lock mm/sparse: more checks on mem_section number mm/sparse: optimize sparse_index_alloc memcg: add mem_cgroup_from_css() helper memcg: further prevent OOM with too many dirty pages memcg: prevent OOM with too many dirty pages mm: mmu_notifier: fix freed page still mapped in secondary MMU mm: memcg: only check anon swapin page charges for swap cache mm: memcg: only check swap cache pages for repeated charging mm: memcg: split swapin charge function into private and public part mm: memcg: remove needless !mm fixup to init_mm when charging mm: memcg: remove unneeded shmem charge type ...
2012-07-31Merge tag 'random_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/random Pull random subsystem patches from Ted Ts'o: "This patch series contains a major revamp of how we collect entropy from interrupts for /dev/random and /dev/urandom. The goal is to addresses weaknesses discussed in the paper "Mining your Ps and Qs: Detection of Widespread Weak Keys in Network Devices", by Nadia Heninger, Zakir Durumeric, Eric Wustrow, J. Alex Halderman, which will be published in the Proceedings of the 21st Usenix Security Symposium, August 2012. (See https://factorable.net for more information and an extended version of the paper.)" Fix up trivial conflicts due to nearby changes in drivers/{mfd/ab3100-core.c, usb/gadget/omap_udc.c} * tag 'random_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/random: (33 commits) random: mix in architectural randomness in extract_buf() dmi: Feed DMI table to /dev/random driver random: Add comment to random_initialize() random: final removal of IRQF_SAMPLE_RANDOM um: remove IRQF_SAMPLE_RANDOM which is now a no-op sparc/ldc: remove IRQF_SAMPLE_RANDOM which is now a no-op [ARM] pxa: remove IRQF_SAMPLE_RANDOM which is now a no-op board-palmz71: remove IRQF_SAMPLE_RANDOM which is now a no-op isp1301_omap: remove IRQF_SAMPLE_RANDOM which is now a no-op pxa25x_udc: remove IRQF_SAMPLE_RANDOM which is now a no-op omap_udc: remove IRQF_SAMPLE_RANDOM which is now a no-op goku_udc: remove IRQF_SAMPLE_RANDOM which was commented out uartlite: remove IRQF_SAMPLE_RANDOM which is now a no-op drivers: hv: remove IRQF_SAMPLE_RANDOM which is now a no-op xen-blkfront: remove IRQF_SAMPLE_RANDOM which is now a no-op n2_crypto: remove IRQF_SAMPLE_RANDOM which is now a no-op pda_power: remove IRQF_SAMPLE_RANDOM which is now a no-op i2c-pmcmsp: remove IRQF_SAMPLE_RANDOM which is now a no-op input/serio/hp_sdc.c: remove IRQF_SAMPLE_RANDOM which is now a no-op mfd: remove IRQF_SAMPLE_RANDOM which is now a no-op ...
2012-07-31mm: allow PF_MEMALLOC from softirq contextMel Gorman
This is needed to allow network softirq packet processing to make use of PF_MEMALLOC. Currently softirq context cannot use PF_MEMALLOC due to it not being associated with a task, and therefore not having task flags to fiddle with - thus the gfp to alloc flag mapping ignores the task flags when in interrupts (hard or soft) context. Allowing softirqs to make use of PF_MEMALLOC therefore requires some trickery. This patch borrows the task flags from whatever process happens to be preempted by the softirq. It then modifies the gfp to alloc flags mapping to not exclude task flags in softirq context, and modify the softirq code to save, clear and restore the PF_MEMALLOC flag. The save and clear, ensures the preempted task's PF_MEMALLOC flag doesn't leak into the softirq. The restore ensures a softirq's PF_MEMALLOC flag cannot leak back into the preempted process. This should be safe due to the following reasons Softirqs can run on multiple CPUs sure but the same task should not be executing the same softirq code. Neither should the softirq handler be preempted by any other softirq handler so the flags should not leak to an unrelated softirq. Softirqs re-enable hardware interrupts in __do_softirq() so can be preempted by hardware interrupts so PF_MEMALLOC is inherited by the hard IRQ. However, this is similar to a process in reclaim being preempted by a hardirq. While PF_MEMALLOC is set, gfp_to_alloc_flags() distinguishes between hard and soft irqs and avoids giving a hardirq the ALLOC_NO_WATERMARKS flag. If the softirq is deferred to ksoftirq then its flags may be used instead of a normal tasks but as the softirq cannot be preempted, the PF_MEMALLOC flag does not leak to other code by accident. [davem@davemloft.net: Document why PF_MEMALLOC is safe] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: David Miller <davem@davemloft.net> Cc: Neil Brown <neilb@suse.de> Cc: Mike Christie <michaelc@cs.wisc.edu> Cc: Eric B Munson <emunson@mgebm.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Cc: Mel Gorman <mgorman@suse.de> Cc: Christoph Lameter <cl@linux.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31mm/hotplug: correctly setup fallback zonelists when creating new pgdatJiang Liu
When hotadd_new_pgdat() is called to create new pgdat for a new node, a fallback zonelist should be created for the new node. There's code to try to achieve that in hotadd_new_pgdat() as below: /* * The node we allocated has no zone fallback lists. For avoiding * to access not-initialized zonelist, build here. */ mutex_lock(&zonelists_mutex); build_all_zonelists(pgdat, NULL); mutex_unlock(&zonelists_mutex); But it doesn't work as expected. When hotadd_new_pgdat() is called, the new node is still in offline state because node_set_online(nid) hasn't been called yet. And build_all_zonelists() only builds zonelists for online nodes as: for_each_online_node(nid) { pg_data_t *pgdat = NODE_DATA(nid); build_zonelists(pgdat); build_zonelist_cache(pgdat); } Though we hope to create zonelist for the new pgdat, but it doesn't. So add a new parameter "pgdat" the build_all_zonelists() to build pgdat for the new pgdat too. Signed-off-by: Jiang Liu <liuj97@gmail.com> Signed-off-by: Xishi Qiu <qiuxishi@huawei.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Michal Hocko <mhocko@suse.cz> Cc: Minchan Kim <minchan@kernel.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Tony Luck <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: Keping Chen <chenkeping@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31memcg: rename config variablesAndrew Morton
Sanity: CONFIG_CGROUP_MEM_RES_CTLR -> CONFIG_MEMCG CONFIG_CGROUP_MEM_RES_CTLR_SWAP -> CONFIG_MEMCG_SWAP CONFIG_CGROUP_MEM_RES_CTLR_SWAP_ENABLED -> CONFIG_MEMCG_SWAP_ENABLED CONFIG_CGROUP_MEM_RES_CTLR_KMEM -> CONFIG_MEMCG_KMEM [mhocko@suse.cz: fix missed bits] Cc: Glauber Costa <glommer@parallels.com> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hugh Dickins <hughd@google.com> Cc: Tejun Heo <tj@kernel.org> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: David Rientjes <rientjes@google.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31mm: prepare for removal of obsolete /proc/sys/vm/nr_pdflush_threadsWanpeng Li
Since per-BDI flusher threads were introduced in 2.6, the pdflush mechanism is not used any more. But the old interface exported through /proc/sys/vm/nr_pdflush_threads still exists and is obviously useless. For back-compatibility, printk warning information and return 2 to notify the users that the interface is removed. Signed-off-by: Wanpeng Li <liwp@linux.vnet.ibm.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31mm: account the total_vm in the vm_stat_account()Huang Shijie
vm_stat_account() accounts the shared_vm, stack_vm and reserved_vm now. But we can also account for total_vm in the vm_stat_account() which makes the code tidy. Even for mprotect_fixup(), we can get the right result in the end. Signed-off-by: Huang Shijie <shijie8@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf updates from Ingo Molnar: "The biggest changes are Intel Nehalem-EX PMU uncore support, uprobes updates/cleanups/fixes from Oleg and diverse tooling updates (mostly fixes) now that Arnaldo is back from vacation." * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (40 commits) uprobes: __replace_page() needs munlock_vma_page() uprobes: Rename vma_address() and make it return "unsigned long" uprobes: Fix register_for_each_vma()->vma_address() check uprobes: Introduce vaddr_to_offset(vma, vaddr) uprobes: Teach build_probe_list() to consider the range uprobes: Remove insert_vm_struct()->uprobe_mmap() uprobes: Remove copy_vma()->uprobe_mmap() uprobes: Fix overflow in vma_address()/find_active_uprobe() uprobes: Suppress uprobe_munmap() from mmput() uprobes: Uprobe_mmap/munmap needs list_for_each_entry_safe() uprobes: Clean up and document write_opcode()->lock_page(old_page) uprobes: Kill write_opcode()->lock_page(new_page) uprobes: __replace_page() should not use page_address_in_vma() uprobes: Don't recheck vma/f_mapping in write_opcode() perf/x86: Fix missing struct before structure name perf/x86: Fix format definition of SNB-EP uncore QPI box perf/x86: Make bitfield unsigned perf/x86: Fix LLC-* and node-* events on Intel SandyBridge perf/x86: Add Intel Nehalem-EX uncore support perf/x86: Fix typo in format definition of uncore PCU filter ...
2012-07-31time: Remove all direct references to timekeeperJohn Stultz
Ingo noted that the numerous timekeeper.value references made the timekeeping code ugly and caused many long lines that had to be broken up. He recommended replacing timekeeper.value references with tk->value. This patch provides a local tk value for all top level time functions and sets it to &timekeeper. Then all timekeeper access is done via a tk pointer. Signed-off-by: John Stultz <john.stultz@linaro.org> Cc: Prarit Bhargava <prarit@redhat.com> Link: http://lkml.kernel.org/r/1343414893-45779-6-git-send-email-john.stultz@linaro.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-07-31time: Clean up offs_real/wall_to_mono and offs_boot/total_sleep_time updatesJohn Stultz
For performance reasons, we maintain ktime_t based duplicates of wall_to_monotonic (offs_real) and total_sleep_time (offs_boot). Since large problems could occur (such as the resume regression on 3.5-rc7, or the leapsecond hrtimer issue) if these value pairs were to be inconsistently updated, this patch this cleans up how we modify these value pairs to ensure we are always consistent. As a side-effect this is also more efficient as we only caulculate the duplicate values when they are changed, rather then every update_wall_time call. This also provides WARN_ONs to detect if future changes break the invariants. Signed-off-by: John Stultz <john.stultz@linaro.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Richard Cochran <richardcochran@gmail.com> Cc: Prarit Bhargava <prarit@redhat.com> Link: http://lkml.kernel.org/r/1343414893-45779-5-git-send-email-john.stultz@linaro.org [ Cleaned up minor style issues. ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-07-31time: Clean up stray newlinesJohn Stultz
Ingo noted inconsistent newline usage between functions. This patch cleans those up. Signed-off-by: John Stultz <john.stultz@linaro.org> Cc: Prarit Bhargava <prarit@redhat.com> Link: http://lkml.kernel.org/r/1343414893-45779-4-git-send-email-john.stultz@linaro.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-07-31time/jiffies: Rename ACTHZ to SHIFTED_HZJohn Stultz
Ingo noted that ACTHZ is a confusing name, and requested it be renamed, so this patch renames ACTHZ to SHIFTED_HZ to better describe it. Signed-off-by: John Stultz <john.stultz@linaro.org> Cc: Prarit Bhargava <prarit@redhat.com> Link: http://lkml.kernel.org/r/1343414893-45779-3-git-send-email-john.stultz@linaro.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-07-31Merge branch 'linus' into timers/urgentIngo Molnar
Merge in Linus's branch which already has timers/core merged. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-07-31perf/trace: Add ability to set a target task for eventsAndrew Vagin
A few events are interesting not only for a current task. For example, sched_stat_* events are interesting for a task which wakes up. For this reason, it will be good if such events will be delivered to a target task too. Now a target task can be set by using __perf_task(). The original idea and a draft patch belongs to Peter Zijlstra. I need these events for profiling sleep times. sched_switch is used for getting callchains and sched_stat_* is used for getting time periods. These events are combined in user space, then it can be analyzed by perf tools. Inspired-by: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Arun Sharma <asharma@fb.com> Signed-off-by: Andrew Vagin <avagin@openvz.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1342016098-213063-1-git-send-email-avagin@openvz.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-07-31sched/cleanups: Add load balance cpumask pointer to 'struct lb_env'Michael Wang
With this patch struct ld_env will have a pointer of the load balancing cpumask and we don't need to pass a cpumask around anymore. Signed-off-by: Michael Wang <wangyun@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/4FFE8665.3080705@linux.vnet.ibm.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-07-31kernel/debug: Make use of KGDB_REASON_NMIAnton Vorontsov
Currently kernel never set KGDB_REASON_NMI. We do now, when we enter KGDB/KDB from an NMI. This is not to be confused with kgdb_nmicallback(), NMI callback is an entry for the slave CPUs during CPUs roundup, but REASON_NMI is the entry for the master CPU. Signed-off-by: Anton Vorontsov <anton.vorontsov@linaro.org> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2012-07-31kdb: Remove cpu from the more promptJason Wessel
Having the CPU in the more prompt is completely redundent vs the standard kdb prompt, and it also wastes 32 bytes on the stack. Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2012-07-31kdb: Remove unused KDB_FLAG_ONLY_DO_DUMPJason Wessel
This code cleanup was missed in the original kdb merge, and this code is simply not used at all. The code that was previously used to set the KDB_FLAG_ONLY_DO_DUMP was removed prior to the initial kdb merge. Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2012-07-30resource: make sure requested range is included in the root rangeOctavian Purdila
When the requested range is outside of the root range the logic in __reserve_region_with_split will cause an infinite recursion which will overflow the stack as seen in the warning bellow. This particular stack overflow was caused by requesting the (100000000-107ffffff) range while the root range was (0-ffffffff). In this case __request_resource would return the whole root range as conflict range (i.e. 0-ffffffff). Then, the logic in __reserve_region_with_split would continue the recursion requesting the new range as (conflict->end+1, end) which incidentally in this case equals the originally requested range. This patch aborts looking for an usable range when the request does not intersect with the root range. When the request partially overlaps with the root range, it ajust the request to fall in the root range and then continues with the new request. When the request is modified or aborted errors and a stack trace are logged to allow catching the errors in the upper layers. [ 5.968374] WARNING: at kernel/sched.c:4129 sub_preempt_count+0x63/0x89() [ 5.975150] Modules linked in: [ 5.978184] Pid: 1, comm: swapper Not tainted 3.0.22-mid27-00004-gb72c817 #46 [ 5.985324] Call Trace: [ 5.987759] [<c1039dfc>] ? console_unlock+0x17b/0x18d [ 5.992891] [<c1039620>] warn_slowpath_common+0x48/0x5d [ 5.998194] [<c1031758>] ? sub_preempt_count+0x63/0x89 [ 6.003412] [<c1039644>] warn_slowpath_null+0xf/0x13 [ 6.008453] [<c1031758>] sub_preempt_count+0x63/0x89 [ 6.013499] [<c14d60c4>] _raw_spin_unlock+0x27/0x3f [ 6.018453] [<c10c6349>] add_partial+0x36/0x3b [ 6.022973] [<c10c7c0a>] deactivate_slab+0x96/0xb4 [ 6.027842] [<c14cf9d9>] __slab_alloc.isra.54.constprop.63+0x204/0x241 [ 6.034456] [<c103f78f>] ? kzalloc.constprop.5+0x29/0x38 [ 6.039842] [<c103f78f>] ? kzalloc.constprop.5+0x29/0x38 [ 6.045232] [<c10c7dc9>] kmem_cache_alloc_trace+0x51/0xb0 [ 6.050710] [<c103f78f>] ? kzalloc.constprop.5+0x29/0x38 [ 6.056100] [<c103f78f>] kzalloc.constprop.5+0x29/0x38 [ 6.061320] [<c17b45e9>] __reserve_region_with_split+0x1c/0xd1 [ 6.067230] [<c17b4693>] __reserve_region_with_split+0xc6/0xd1 ... [ 7.179057] [<c17b4693>] __reserve_region_with_split+0xc6/0xd1 [ 7.184970] [<c17b4779>] reserve_region_with_split+0x30/0x42 [ 7.190709] [<c17a8ebf>] e820_reserve_resources_late+0xd1/0xe9 [ 7.196623] [<c17c9526>] pcibios_resource_survey+0x23/0x2a [ 7.202184] [<c17cad8a>] pcibios_init+0x23/0x35 [ 7.206789] [<c17ca574>] pci_subsys_init+0x3f/0x44 [ 7.211659] [<c1002088>] do_one_initcall+0x72/0x122 [ 7.216615] [<c17ca535>] ? pci_legacy_init+0x3d/0x3d [ 7.221659] [<c17a27ff>] kernel_init+0xa6/0x118 [ 7.226265] [<c17a2759>] ? start_kernel+0x334/0x334 [ 7.231223] [<c14d7482>] kernel_thread_helper+0x6/0x10 Signed-off-by: Octavian Purdila <octavian.purdila@intel.com> Signed-off-by: Ram Pai <linuxram@us.ibm.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30taskstats: check nla_reserve() returnAlan Cox
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=44621 Reported-by: <rucsoftsec@gmail.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30sysctl: suppress kmemleak messagesSteven Rostedt
register_sysctl_table() is a strange function, as it makes internal allocations (a header) to register a sysctl_table. This header is a handle to the table that is created, and can be used to unregister the table. But if the table is permanent and never unregistered, the header acts the same as a static variable. Unfortunately, this allocation of memory that is never expected to be freed fools kmemleak in thinking that we have leaked memory. For those sysctl tables that are never unregistered, and have no pointer referencing them, kmemleak will think that these are memory leaks: unreferenced object 0xffff880079fb9d40 (size 192): comm "swapper/0", pid 0, jiffies 4294667316 (age 12614.152s) hex dump (first 32 bytes): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ backtrace: [<ffffffff8146b590>] kmemleak_alloc+0x73/0x98 [<ffffffff8110a935>] kmemleak_alloc_recursive.constprop.42+0x16/0x18 [<ffffffff8110b852>] __kmalloc+0x107/0x153 [<ffffffff8116fa72>] kzalloc.constprop.8+0xe/0x10 [<ffffffff811703c9>] __register_sysctl_paths+0xe1/0x160 [<ffffffff81170463>] register_sysctl_paths+0x1b/0x1d [<ffffffff8117047d>] register_sysctl_table+0x18/0x1a [<ffffffff81afb0a1>] sysctl_init+0x10/0x14 [<ffffffff81b05a6f>] proc_sys_init+0x2f/0x31 [<ffffffff81b0584c>] proc_root_init+0xa5/0xa7 [<ffffffff81ae5b7e>] start_kernel+0x3d0/0x40a [<ffffffff81ae52a7>] x86_64_start_reservations+0xae/0xb2 [<ffffffff81ae53ad>] x86_64_start_kernel+0x102/0x111 [<ffffffffffffffff>] 0xffffffffffffffff The sysctl_base_table used by sysctl itself is one such instance that registers the table to never be unregistered. Use kmemleak_not_leak() to suppress the kmemleak false positive. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30kdump: append newline to the last lien of vmcoreinfo noteVivek Goyal
The last line of vmcoreinfo note does not end with \n. Parsing all the lines in note becomes easier if all lines end with \n instead of trying to special case the last line. I know at least one tool, vmcore-dmesg in kexec-tools tree which made the assumption that all lines end with \n. I think it is a good idea to fix it. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Atsushi Kumagai <kumagai-atsushi@mxc.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30fork: fix error handling in dup_task()Akinobu Mita
The function dup_task() may fail at the following function calls in the following order. 0) alloc_task_struct_node() 1) alloc_thread_info_node() 2) arch_dup_task_struct() Error by 0) is not a matter, it can just return. But error by 1) requires releasing task_struct allocated by 0) before it returns. Likewise, error by 2) requires releasing task_struct and thread_info allocated by 0) and 1). The existing error handling calls free_task_struct() and free_thread_info() which do not only release task_struct and thread_info, but also call architecture specific arch_release_task_struct() and arch_release_thread_info(). The problem is that task_struct and thread_info are not fully initialized yet at this point, but arch_release_task_struct() and arch_release_thread_info() are called with them. For example, x86 defines its own arch_release_task_struct() that releases a task_xstate. If alloc_thread_info_node() fails in dup_task(), arch_release_task_struct() is called with task_struct which is just allocated and filled with garbage in this error handling. This actually happened with tools/testing/fault-injection/failcmd.sh # env FAILCMD_TYPE=fail_page_alloc \ ./tools/testing/fault-injection/failcmd.sh --times=100 \ --min-order=0 --ignore-gfp-wait=0 \ -- make -C tools/testing/selftests/ run_tests In order to fix this issue, make free_{task_struct,thread_info}() not to call arch_release_{task_struct,thread_info}() and call arch_release_{task_struct,thread_info}() implicitly where needed. Default arch_release_task_struct() and arch_release_thread_info() are defined as empty by default. So this change only affects the architectures which implement their own arch_release_task_struct() or arch_release_thread_info() as listed below. arch_release_task_struct(): x86, sh arch_release_thread_info(): mn10300, tile Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: David Howells <dhowells@redhat.com> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Salman Qazi <sqazi@google.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30revert "sched: Fix fork() error path to not crash"Andrew Morton
To make way for "fork: fix error handling in dup_task()", which fixes the errors more completely. Cc: Salman Qazi <sqazi@google.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Ingo Molnar <mingo@elte.hu> Cc: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30fork: use vma_pages() to simplify the codeHuang Shijie
The current code can be replaced by vma_pages(). So use it to simplify the code. [akpm@linux-foundation.org: initialise `len' at its definition site] Signed-off-by: Huang Shijie <shijie8@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30kmod: avoid deadlock from recursive kmod callTetsuo Handa
The system deadlocks (at least since 2.6.10) when call_usermodehelper(UMH_WAIT_EXEC) request triggers call_usermodehelper(UMH_WAIT_PROC) request. This is because "khelper thread is waiting for the worker thread at wait_for_completion() in do_fork() since the worker thread was created with CLONE_VFORK flag" and "the worker thread cannot call complete() because do_execve() is blocked at UMH_WAIT_PROC request" and "the khelper thread cannot start processing UMH_WAIT_PROC request because the khelper thread is waiting for the worker thread at wait_for_completion() in do_fork()". The easiest example to observe this deadlock is to use a corrupted /sbin/hotplug binary (like shown below). # : > /tmp/dummy # chmod 755 /tmp/dummy # echo /tmp/dummy > /proc/sys/kernel/hotplug # modprobe whatever call_usermodehelper("/tmp/dummy", UMH_WAIT_EXEC) is called from kobject_uevent_env() in lib/kobject_uevent.c upon loading/unloading a module. do_execve("/tmp/dummy") triggers a call to request_module("binfmt-0000") from search_binary_handler() which in turn calls call_usermodehelper(UMH_WAIT_PROC). In order to avoid deadlock, as a for-now and easy-to-backport solution, do not try to call wait_for_completion() in call_usermodehelper_exec() if the worker thread was created by khelper thread with CLONE_VFORK flag. Future and fundamental solution might be replacing singleton khelper thread with some workqueue so that recursive calls up to max_active dependency loop can be handled without deadlock. [akpm@linux-foundation.org: add comment to kmod_thread_locker] Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Tejun Heo <tj@kernel.org> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30kernel/kmod.c: document call_usermodehelper_fns() a bitAndrew Morton
This function's interface is, uh, subtle. Attempt to apologise for it. Cc: WANG Cong <xiyou.wangcong@gmail.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Kees Cook <keescook@chromium.org> Cc: Serge Hallyn <serge.hallyn@canonical.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30printk: only look for prefix levels in kernel messagesJoe Perches
vprintk_emit() prefix parsing should only be done for internal kernel messages. This allows existing behavior to be kept in all cases. Signed-off-by: Joe Perches <joe@perches.com> Cc: Kay Sievers <kay@vrfy.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30printk: add generic functions to find KERN_<LEVEL> headersJoe Perches
The current form of a KERN_<LEVEL> is "<.>". Add printk_get_level and printk_skip_level functions to handle these formats. These functions centralize tests of KERN_<LEVEL> so a future modification can change the KERN_<LEVEL> style and shorten the number of bytes consumed by these headers. [akpm@linux-foundation.org: fix build error and warning] Signed-off-by: Joe Perches <joe@perches.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Wu Fengguang <wfg@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30kmsg: /dev/kmsg - properly return possible copy_from_user() failureKay Sievers
Reported-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Kay Sievers <kay@vrfy.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30kernel/sys.c: avoid argv_free(NULL)Andrew Morton
If argv_split() failed, the code will end up calling argv_free(NULL). Fix it up and clean things up a bit. Addresses Coverity report 703573. Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Kees Cook <keescook@chromium.org> Cc: Serge Hallyn <serge.hallyn@canonical.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: WANG Cong <xiyou.wangcong@gmail.com> Cc: Alan Cox <alan@linux.intel.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30NMI watchdog: fix for lockup detector breakage on resumeSameer Nanda
On the suspend/resume path the boot CPU does not go though an offline->online transition. This breaks the NMI detector post-resume since it depends on PMU state that is lost when the system gets suspended. Fix this by forcing a CPU offline->online transition for the lockup detector on the boot CPU during resume. To provide more context, we enable NMI watchdog on Chrome OS. We have seen several reports of systems freezing up completely which indicated that the NMI watchdog was not firing for some reason. Debugging further, we found a simple way of repro'ing system freezes -- issuing the command 'tasket 1 sh -c "echo nmilockup > /proc/breakme"' after the system has been suspended/resumed one or more times. With this patch in place, the system freeze result in panics, as expected. These panics provide a nice stack trace for us to debug the actual issue causing the freeze. [akpm@linux-foundation.org: fiddle with code comment] [akpm@linux-foundation.org: make lockup_detector_bootcpu_resume() conditional on CONFIG_SUSPEND] [akpm@linux-foundation.org: fix section errors] Signed-off-by: Sameer Nanda <snanda@chromium.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Don Zickus <dzickus@redhat.com> Cc: Mandeep Singh Baines <msb@chromium.org> Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Anshuman Khandual <khandual@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30panic: fix a possible deadlock in panic()Vikram Mulukutla
panic_lock is meant to ensure that panic processing takes place only on one cpu; if any of the other cpus encounter a panic, they will spin waiting to be shut down. However, this causes a regression in this scenario: 1. Cpu 0 encounters a panic and acquires the panic_lock and proceeds with the panic processing. 2. There is an interrupt on cpu 0 that also encounters an error condition and invokes panic. 3. This second invocation fails to acquire the panic_lock and enters the infinite while loop in panic_smp_self_stop. Thus all panic processing is stopped, and the cpu is stuck for eternity in the while(1) inside panic_smp_self_stop. To address this, disable local interrupts with local_irq_disable before acquiring the panic_lock. This will prevent interrupt handlers from executing during the panic processing, thus avoiding this particular problem. Signed-off-by: Vikram Mulukutla <markivx@codeaurora.org> Reviewed-by: Stephen Boyd <sboyd@codeaurora.org> Cc: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30coredump: warn about unsafe suid_dumpable / core_pattern comboKees Cook
When suid_dumpable=2, detect unsafe core_pattern settings and warn when they are seen. Signed-off-by: Kees Cook <keescook@chromium.org> Suggested-by: Andrew Morton <akpm@linux-foundation.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Alan Cox <alan@linux.intel.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Doug Ledford <dledford@redhat.com> Cc: Serge Hallyn <serge.hallyn@canonical.com> Cc: James Morris <james.l.morris@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30prctl: remove redunant assignment of "error" to zeroSasikantha babu
Just setting the "error" to error number is enough on failure and It doesn't require to set "error" variable to zero in each switch case, since it was already initialized with zero. And also removed return 0 in switch case with break statement Signed-off-by: Sasikantha babu <sasikanth.v19@gmail.com> Acked-by: Kees Cook <keescook@chromium.org> Acked-by: Serge E. Hallyn <serge@hallyn.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30uprobes: __replace_page() needs munlock_vma_page()Oleg Nesterov
Like do_wp_page(), __replace_page() should do munlock_vma_page() for the case when the old page still has other !VM_LOCKED mappings. Unfortunately this needs mm/internal.h. Also, move put_page() outside of ptl lock. This doesn't really matter but looks a bit better. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Srikar Dronamraju <srikar.vnet.ibm.com> Cc: Anton Arapov <anton@redhat.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/20120729182249.GA20372@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-07-30uprobes: Rename vma_address() and make it return "unsigned long"Oleg Nesterov
1. vma_address() returns loff_t, this looks confusing and this is unnecessary after the previous change. Make it return "ulong", all callers truncate the result anyway. 2. Its name conflicts with mm/rmap.c:vma_address(), rename it to offset_to_vaddr(), this matches vaddr_to_offset(). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Srikar Dronamraju <srikar.vnet.ibm.com> Cc: Anton Arapov <anton@redhat.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/20120729182247.GA20365@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-07-30uprobes: Fix register_for_each_vma()->vma_address() checkOleg Nesterov
1. register_for_each_vma() checks that vma_address() == vaddr, but this is not enough. We should also ensure that vaddr >= vm_start, find_vma() guarantees "vaddr < vm_end" only. 2. After the prevous changes, register_for_each_vma() is the only reason why vma_address() has to return loff_t, all other users know that we have the valid mapping at this offset and thus the overflow is not possible. Change the code to use vaddr_to_offset() instead, imho this looks more clean/understandable and now we can change vma_address(). 3. While at it, remove the unnecessary type-cast. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Srikar Dronamraju <srikar.vnet.ibm.com> Cc: Anton Arapov <anton@redhat.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/20120729182244.GA20362@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
