commit a841f8cef4bb124f0f5563314d0beaf2e1249d72 upstream.
It does not get processed because sched_domain_level_max is 0 at the
time that setup_relax_domain_level() is run.
Simply accept the value as it is, as we don't know the value of
sched_domain_level_max until sched domain construction is completed.
Fix sched_relax_domain_level in cpuset. The build_sched_domain() routine calls
the set_domain_attribute() routine prior to setting the sd->level, however,
the set_domain_attribute() routine relies on the sd->level to decide whether
idle load balancing will be off/on.
Signed-off-by: Dimitri Sivanich <sivanich@sgi.com>
Link: http://lkml.kernel.org/r/20120605184436.GA15668@sgi.com
active
commit 544ecf310f0e7f51fa057ac2a295fc1b3b35a9d3 upstream.
worker_enter_idle() has WARN_ON_ONCE() which triggers if nr_running
isn't zero when every worker is idle. This can trigger spuriously
while a cpu is going down due to the way trustee sets %WORKER_ROGUE
and zaps nr_running.
It first sets %WORKER_ROGUE on all workers without updating
nr_running, releases gcwq->lock, schedules, regrabs gcwq->lock and
then zaps nr_running. If the last running worker enters idle
inbetween, it would see stale nr_running which hasn't been zapped yet
and trigger the WARN_ON_ONCE().
Fix it by performing the sanity check iff the trustee is idle.
Reported-by: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
commit b7dafa0ef3145c31d7753be0a08b3cbda51f0209 upstream.
compat_sys_sigprocmask reads a smaller signal mask from userspace than
sigprogmask accepts for setting. So the high word of blocked.sig[0]
will be cleared, releasing any potentially blocked RT signal.
This was discovered via userspace code that relies on get/setcontext.
glibc's i386 versions of those functions use sigprogmask instead of
rt_sigprogmask to save/restore signal mask and caused RT signal
unblocking this way.
As suggested by Linus, this replaces the sys_sigprocmask based compat
version with one that open-codes the required logic, including the merge
of the existing blocked set with the new one provided on SIG_SETMASK.
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
commit 5e2bf0142231194d36fdc9596b36a261ed2b9fe7 upstream.
Fork() failure post namespace creation for a child cloned with
CLONE_NEWPID leaks pid_namespace/mnt_cache due to proc being mounted
during creation, but not unmounted during cleanup. Call
pid_ns_release_proc() during cleanup.
Signed-off-by: Mike Galbraith <efault@gmx.de>
Acked-by: Oleg Nesterov <oleg@redhat.com>
Reviewed-by: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Pavel Emelyanov <xemul@parallels.com>
Cc: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Louis Rilling <louis.rilling@kerlabs.com>
commit c308b56b5398779cd3da0f62ab26b0453494c3d4 upstream.
[ backported to 3.0 by Kerin Millar <kerframil@gmail.com>]
Various people reported nohz load tracking still being wrecked, but Doug
spotted the actual problem. We fold the nohz remainder in too soon,
causing us to loose samples and under-account.
So instead of playing catch-up up-front, always do a single load-fold
with whatever state we encounter and only then fold the nohz remainder
and play catch-up.
Reported-by: Doug Smythies <dsmythies@telus.net>
Reported-by: LesÅ=82aw Kope=C4=87 <leslaw.kopec@nasza-klasa.pl>
Reported-by: Aman Gupta <aman@tmm1.net>
Link: http://lkml.kernel.org/n/tip-4v31etnhgg9kwd6ocgx3rxl8@git.kernel.org
Cc: Kerin Millar <kerframil@gmail.com>
commit bdbb776f882f5ad431aa1e694c69c1c3d6a4a5b8 upstream.
It was possible to extract the robust list head address from a setuid
process if it had used set_robust_list(), allowing an ASLR info leak. This
changes the permission checks to be the same as those used for similar
info that comes out of /proc.
Running a setuid program that uses robust futexes would have had:
cred->euid != pcred->euid
cred->euid == pcred->uid
so the old permissions check would allow it. I'm not aware of any setuid
programs that use robust futexes, so this is just a preventative measure.
(This patch is based on changes from grsecurity.)
Cc: Darren Hart <dvhart@linux.intel.com>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Serge E. Hallyn <serge.hallyn@canonical.com>
Cc: kernel-hardening@lists.openwall.com
Cc: spender@grsecurity.net
Link: http://lkml.kernel.org/r/20120319231253.GA20893@www.outflux.net
commit 6f103929f8979d2638e58d7f7fda0beefcb8ee7e upstream.
Fix tick_nohz_restart() to not use a stale ktime_t "now" value when
calling tick_do_update_jiffies64(now).
If we reach this point in the loop it means that we crossed a tick
boundary since we grabbed the "now" timestamp, so at this point "now"
refers to a time in the old jiffy, so using the old value for "now" is
incorrect, and is likely to give us a stale jiffies value.
In particular, the first time through the loop the
tick_do_update_jiffies64(now) call is always a no-op, since the
caller, tick_nohz_restart_sched_tick(), will have already called
tick_do_update_jiffies64(now) with that "now" value.
Note that tick_nohz_stop_sched_tick() already uses the correct
approach: when we notice we cross a jiffy boundary, grab a new
timestamp with ktime_get(), and *then* update jiffies.
Signed-off-by: Neal Cardwell <ncardwell@google.com>
Cc: Ben Segall <bsegall@google.com>
Link: http://lkml.kernel.org/r/1332875377-23014-1-git-send-email-ncardwell@google.com
commit 79549c6dfda0603dba9a70a53467ce62d9335c33 upstream.
keyctl_session_to_parent(task) sets ->replacement_session_keyring,
it should be processed and cleared by key_replace_session_keyring().
However, this task can fork before it notices TIF_NOTIFY_RESUME and
the new child gets the bogus ->replacement_session_keyring copied by
dup_task_struct(). This is obviously wrong and, if nothing else, this
leads to put_cred(already_freed_cred).
change copy_creds() to clear this member. If copy_process() fails
before this point the wrong ->replacement_session_keyring doesn't
matter, exit_creds() won't be called.
commit 620f6e8e855d6d447688a5f67a4e176944a084e8 upstream.
Commit bfdc0b4 adds code to restrict access to dmesg_restrict,
however, it incorrectly alters kptr_restrict rather than
dmesg_restrict.
The original patch from Richard Weinberger
(https://lkml.org/lkml/2011/3/14/362) alters dmesg_restrict as
expected, and so the patch seems to have been misapplied.
This adds the CAP_SYS_ADMIN check to both dmesg_restrict and
kptr_restrict, since both are sensitive.
Reported-by: Phillip Lougher <plougher@redhat.com>
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Acked-by: Richard Weinberger <richard@nod.at>
Signed-off-by: James Morris <james.l.morris@oracle.com>
commit 98b54aa1a2241b59372468bd1e9c2d207bdba54b upstream.
There is extra state information that needs to be exposed in the
kgdb_bpt structure for tracking how a breakpoint was installed. The
debug_core only uses the the probe_kernel_write() to install
breakpoints, but this is not enough for all the archs. Some arch such
as x86 need to use text_poke() in order to install a breakpoint into a
read only page.
Passing the kgdb_bpt structure to kgdb_arch_set_breakpoint() and
kgdb_arch_remove_breakpoint() allows other archs to set the type
variable which indicates how the breakpoint was installed.
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
commit 01de982abf8c9e10fc3089e10585cd2cc914bdab upstream.
8 hex characters tell only half the tale for 64 bit CPUs,
so use the appropriate length.
Link: http://lkml.kernel.org/r/1332411501-8059-2-git-send-email-wolfgang.mauerer@siemens.com
Signed-off-by: Wolfgang Mauerer <wolfgang.mauerer@siemens.com>
commit f5cb92ac82d06cb583c1f66666314c5c0a4d7913 upstream.
irq_move_masked_irq() checks the return code of
chip->irq_set_affinity() only for 0, but IRQ_SET_MASK_OK_NOCOPY is
also a valid return code, which is there to avoid a redundant copy of
the cpumask. But in case of IRQ_SET_MASK_OK_NOCOPY we not only avoid
the redundant copy, we also fail to adjust the thread affinity of an
eventually threaded interrupt handler.
Handle IRQ_SET_MASK_OK (==0) and IRQ_SET_MASK_OK_NOCOPY(==1) return
values correctly by checking the valid return values seperately.
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
Cc: Jiang Liu <liuj97@gmail.com>
Cc: Keping Chen <chenkeping@huawei.com>
Link: http://lkml.kernel.org/r/1333120296-13563-2-git-send-email-jiang.liu@huawei.com
commit f946eeb9313ff1470758e171a60fe7438a2ded3f upstream.
Module size was limited to 64MB, this was legacy limitation due to vmalloc()
which was removed a while ago.
Limiting module size to 64MB is both pointless and affects real world use
cases.
Cc: Tim Abbott <tim.abbott@oracle.com>
commit 05b4877f6a4f1ba4952d1222213d262bf8c132b7 upstream.
If create_basic_memory_bitmaps() fails, usermodehelpers are not re-enabled
before returning. Fix this. And while at it, reword the goto labels so that
they look more meaningful.
Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
commit 540b60e24f3f4781d80e47122f0c4486a03375b8 upstream.
We do not want a bitwise AND between boolean operands
Signed-off-by: Alexander Gordeev <agordeev@redhat.com>
Link: http://lkml.kernel.org/r/20120309135912.GA2114@dhcp-26-207.brq.redhat.com
commit a09b659cd68c10ec6a30cb91ebd2c327fcd5bfe5 upstream.
In 2008, commit 0c5d1eb77a8be ("genirq: record trigger type") modified the
way set_irq_type() handles the 'no trigger' condition. However, this has
an adverse effect on PCMCIA support on Intel StrongARM and probably PXA
platforms.
PCMCIA has several status signals on the socket which can trigger
interrupts; some of these status signals depend on the card's mode
(whether it is configured in memory or IO mode). For example, cards have
a 'Ready/IRQ' signal: in memory mode, this provides an indication to
PCMCIA that the card has finished its power up initialization. In IO
mode, it provides the device interrupt signal. Other status signals
switch between on-board battery status and loud speaker output.
In classical PCMCIA implementations, where you have a specific socket
controller, the controller provides a method to mask interrupts from the
socket, and importantly ignore any state transitions on the pins which
correspond with interrupts once masked. This masking prevents unwanted
events caused by the removal and application of socket power being
forwarded.
However, on platforms where there is no socket controller, the PCMCIA
status and interrupt signals are routed to standard edge-triggered GPIOs.
These GPIOs can be configured to interrupt on rising edge, falling edge,
or never. This is where the problems start.
Edge triggered interrupts are required to record events while disabled via
the usual methods of {free,request,disable,enable}_irq() to prevent
problems with dropped interrupts (eg, the 8390 driver uses disable_irq()
to defer the delivery of interrupts). As a result, these interfaces can
not be used to implement the desired behaviour.
The side effect of this is that if the 'Ready/IRQ' GPIO is disabled via
disable_irq() on suspend, and enabled via enable_irq() after resume, we
will record the state transitions caused by powering events as valid
interrupts, and foward them to the card driver, which may attempt to
access a card which is not powered up.
This leads delays resume while drivers spin in their interrupt handlers,
and complaints from drivers before they realize what's happened.
Moreover, in the case of the 'Ready/IRQ' signal, this is requested and
freed by the card driver itself; the PCMCIA core has no idea whether the
interrupt is requested, and, therefore, whether a call to disable_irq()
would be valid. (We tried this around 2.4.17 / 2.5.1 kernel era, and
ended up throwing it out because of this problem.)
Therefore, it was decided back in around 2002 to disable the edge
triggering instead, resulting in all state transitions on the GPIO being
ignored. That's what we actually need the hardware to do.
The commit above changes this behaviour; it explicitly prevents the 'no
trigger' state being selected.
The reason that request_irq() does not accept the 'no trigger' state is
for compatibility with existing drivers which do not provide their desired
triggering configuration. The set_irq_type() function is 'new' and not
used by non-trigger aware drivers.
Therefore, revert this change, and restore previously working platforms
back to their former state.
Cc: linux@arm.linux.org.uk
commit a078c6d0e6288fad6d83fb6d5edd91ddb7b6ab33 upstream.
'long secs' is passed as divisor to div_s64, which accepts a 32bit
divisor. On 64bit machines that value is trimmed back from 8 bytes
back to 4, causing a divide by zero when the number is bigger than
(1 << 32) - 1 and all 32 lower bits are 0.
Use div64_long() instead.
Signed-off-by: Sasha Levin <levinsasha928@gmail.com>
Cc: johnstul@us.ibm.com
Link: http://lkml.kernel.org/r/1331829374-31543-2-git-send-email-levinsasha928@gmail.com
commit 59263b513c11398cd66a52d4c5b2b118ce1e0359 upstream.
Some of the newer futex PI opcodes do not check the cmpxchg enabled
variable and call unconditionally into the handling functions. Cover
all PI opcodes in a separate check.
commit 62d3c5439c534b0e6c653fc63e6d8c67be3a57b1 upstream.
This patch (as1519) fixes a bug in the block layer's disk-events
polling. The polling is done by a work routine queued on the
system_nrt_wq workqueue. Since that workqueue isn't freezable, the
polling continues even in the middle of a system sleep transition.
Obviously, polling a suspended drive for media changes and such isn't
a good thing to do; in the case of USB mass-storage devices it can
lead to real problems requiring device resets and even re-enumeration.
The patch fixes things by creating a new system-wide, non-reentrant,
freezable workqueue and using it for disk-events polling.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Acked-by: Tejun Heo <tj@kernel.org>
Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
3.0.21's 603b63484725a6e88e4ae5da58716efd88154b1e directly used
the upstream patch, yet kprobes locking in 3.0.x uses spin_lock...()
rather than raw_spin_lock...().
Signed-off-by: Jan Beulich <jbeulich@suse.com>
commit 52abb700e16a9aa4cbc03f3d7f80206cbbc80680 upstream.
Xommit ac5637611(genirq: Unmask oneshot irqs when thread was not woken)
fails to unmask when a !IRQ_ONESHOT threaded handler is handled by
handle_level_irq.
This happens because thread_mask is or'ed unconditionally in
irq_wake_thread(), but for !IRQ_ONESHOT interrupts never cleared. So
the check for !desc->thread_active fails and keeps the interrupt
disabled.
Keep the thread_mask zero for !IRQ_ONESHOT interrupts.
Document the thread_mask magic while at it.
Reported-and-tested-by: Sven Joachim <svenjoac@gmx.de>
Reported-and-tested-by: Stefan Lippers-Hollmann <s.l-h@gmx.de>
commit d80e731ecab420ddcb79ee9d0ac427acbc187b4b upstream.
This patch is intentionally incomplete to simplify the review.
It ignores ep_unregister_pollwait() which plays with the same wqh.
See the next change.
epoll assumes that the EPOLL_CTL_ADD'ed file controls everything
f_op->poll() needs. In particular it assumes that the wait queue
can't go away until eventpoll_release(). This is not true in case
of signalfd, the task which does EPOLL_CTL_ADD uses its ->sighand
which is not connected to the file.
This patch adds the special event, POLLFREE, currently only for
epoll. It expects that init_poll_funcptr()'ed hook should do the
necessary cleanup. Perhaps it should be defined as EPOLLFREE in
eventpoll.
__cleanup_sighand() is changed to do wake_up_poll(POLLFREE) if
->signalfd_wqh is not empty, we add the new signalfd_cleanup()
helper.
ep_poll_callback(POLLFREE) simply does list_del_init(task_list).
This make this poll entry inconsistent, but we don't care. If you
share epoll fd which contains our sigfd with another process you
should blame yourself. signalfd is "really special". I simply do
not know how we can define the "right" semantics if it used with
epoll.
The main problem is, epoll calls signalfd_poll() once to establish
the connection with the wait queue, after that signalfd_poll(NULL)
returns the different/inconsistent results depending on who does
EPOLL_CTL_MOD/signalfd_read/etc. IOW: apart from sigmask, signalfd
has nothing to do with the file, it works with the current thread.
In short: this patch is the hack which tries to fix the symptoms.
It also assumes that nobody can take tasklist_lock under epoll
locks, this seems to be true.
Note:
- we do not have wake_up_all_poll() but wake_up_poll()
is fine, poll/epoll doesn't use WQ_FLAG_EXCLUSIVE.
- signalfd_cleanup() uses POLLHUP along with POLLFREE,
we need a couple of simple changes in eventpoll.c to
make sure it can't be "lost".
Reported-by: Maxime Bizon <mbizon@freebox.fr>
commit b4bc724e82e80478cba5fe9825b62e71ddf78757 upstream.
An interrupt might be pending when irq_startup() is called, but the
startup code does not invoke the resend logic. In some cases this
prevents the device from issuing another interrupt which renders the
device non functional.
Call the resend function in irq_startup() to keep things going.
Reported-and-tested-by: Russell King <rmk+kernel@arm.linux.org.uk>
commit ac5637611150281f398bb7a47e3fcb69a09e7803 upstream.
When the primary handler of an interrupt which is marked IRQ_ONESHOT
returns IRQ_HANDLED or IRQ_NONE, then the interrupt thread is not
woken and the unmask logic of the interrupt line is never
invoked. This keeps the interrupt masked forever.
This was not noticed as most IRQ_ONESHOT users wake the thread
unconditionally (usually because they cannot access the underlying
device from hard interrupt context). Though this behaviour was nowhere
documented and not necessarily intentional. Some drivers can avoid the
thread wakeup in certain cases and run into the situation where the
interrupt line s kept masked.
Handle it gracefully.
Reported-and-tested-by: Lothar Wassmann <lw@karo-electronics.de>
commit f6302f1bcd75a042df69866d98b8d775a668f8f1 upstream.
"subbuf_size" and "n_subbufs" come from the user and they need to be
capped to prevent an integer overflow.
commit df754e6af2f237a6c020c0daff55a1a609338e31 upstream.
It's unlikely that TAINT_FIRMWARE_WORKAROUND causes false
lockdep messages, so do not disable lockdep in that case.
We still want to keep lockdep disabled in the
TAINT_OOT_MODULE case:
- bin-only modules can cause various instabilities in
their and in unrelated kernel code
- they are impossible to debug for kernel developers
- they also typically do not have the copyright license
permission to link to the GPL-ed lockdep code.
Suggested-by: Ben Hutchings <ben@decadent.org.uk>
Link: http://lkml.kernel.org/n/tip-xopopjjens57r0i13qnyh2yo@git.kernel.org
commit cb297a3e433dbdcf7ad81e0564e7b804c941ff0d upstream.
This issue happens under the following conditions:
1. preemption is off
2. __ARCH_WANT_INTERRUPTS_ON_CTXSW is defined
3. RT scheduling class
4. SMP system
Sequence is as follows:
1.suppose current task is A. start schedule()
2.task A is enqueued pushable task at the entry of schedule()
__schedule
prev = rq->curr;
put_prev_task
put_prev_task_rt
enqueue_pushable_task
4.pick the task B as next task.
next = pick_next_task(rq);
3.rq->curr set to task B and context_switch is started.
rq->curr = next;
4.At the entry of context_swtich, release this cpu's rq->lock.
context_switch
prepare_task_switch
prepare_lock_switch
raw_spin_unlock_irq(&rq->lock);
5.Shortly after rq->lock is released, interrupt is occurred and start IRQ context
6.try_to_wake_up() which called by ISR acquires rq->lock
try_to_wake_up
ttwu_remote
rq = __task_rq_lock(p)
ttwu_do_wakeup(rq, p, wake_flags);
task_woken_rt
7.push_rt_task picks the task A which is enqueued before.
task_woken_rt
push_rt_tasks(rq)
next_task = pick_next_pushable_task(rq)
8.At find_lock_lowest_rq(), If double_lock_balance() returns 0,
lowest_rq can be the remote rq.
(But,If preemption is on, double_lock_balance always return 1 and it
does't happen.)
push_rt_task
find_lock_lowest_rq
if (double_lock_balance(rq, lowest_rq))..
9.find_lock_lowest_rq return the available rq. task A is migrated to
the remote cpu/rq.
push_rt_task
deactivate_task(rq, next_task, 0);
set_task_cpu(next_task, lowest_rq->cpu);
activate_task(lowest_rq, next_task, 0);
10. But, task A is on irq context at this cpu.
So, task A is scheduled by two cpus at the same time until restore from IRQ.
Task A's stack is corrupted.
To fix it, don't migrate an RT task if it's still running.
Signed-off-by: Chanho Min <chanho.min@lge.com>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Link: http://lkml.kernel.org/r/CAOAMb1BHA=5fm7KTewYyke6u-8DP0iUuJMpgQw54vNeXFsGpoQ@mail.gmail.com
commit 55ca6140e9bb307efc97a9301a4f501de02a6fd6 upstream.
In function pre_handler_kretprobe(), the allocated kretprobe_instance
object will get leaked if the entry_handler callback returns non-zero.
This may cause all the preallocated kretprobe_instance objects exhausted.
This issue can be reproduced by changing
samples/kprobes/kretprobe_example.c to probe "mutex_unlock". And the fix
is straightforward: just put the allocated kretprobe_instance object back
onto the free_instances list.
[akpm@linux-foundation.org: use raw_spin_lock/unlock]
Acked-by: Jim Keniston <jkenisto@us.ibm.com>
Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com>
commit f2c0d0266cc5eb36a4aa44944b4096ec121490aa upstream.
syslog-ng versions before 3.3.0beta1 (2011-05-12) assume that
CAP_SYS_ADMIN is sufficient to access syslog, so ever since CAP_SYSLOG
was introduced (2010-11-25) they have triggered a warning.
Commit ee24aebffb75 ("cap_syslog: accept CAP_SYS_ADMIN for now")
improved matters a little by making syslog-ng work again, just keeping
the WARN_ONCE(). But still, this is a warning that writes a stack trace
we don't care about to syslog, sets a taint flag, and alarms sysadmins
when nothing worse has happened than use of an old userspace with a
recent kernel.
Convert the WARN_ONCE to a printk_once to avoid that while continuing to
give userspace developers a hint that this is an unwanted
backward-compatibility feature and won't be around forever.
Reported-by: Ralf Hildebrandt <ralf.hildebrandt@charite.de>
Reported-by: Niels <zorglub_olsen@hotmail.com>
Reported-by: Paweł Sikora <pluto@agmk.net>
Signed-off-by: Jonathan Nieder <jrnieder@gmail.com>
Liked-by: Gergely Nagy <algernon@madhouse-project.org>
Acked-by: Serge Hallyn <serge@hallyn.com>
Acked-by: James Morris <jmorris@namei.org>
Cc: Christoph Biedl <linux-kernel.bfrz@manchmal.in-ulm.de>
commit 30fb6aa74011dcf595f306ca2727254d708b786e upstream.
Multiple users of the function tracer can register their functions
with the ftrace_ops structure. The accounting within ftrace will
update the counter on each function record that is being traced.
When the ftrace_ops filtering adds or removes functions, the
function records will be updated accordingly if the ftrace_ops is
still registered.
When a ftrace_ops is removed, the counter of the function records,
that the ftrace_ops traces, are decremented. When they reach zero
the functions that they represent are modified to stop calling the
mcount code.
When changes are made, the code is updated via stop_machine() with
a command passed to the function to tell it what to do. There is an
ENABLE and DISABLE command that tells the called function to enable
or disable the functions. But the ENABLE is really a misnomer as it
should just update the records, as records that have been enabled
and now have a count of zero should be disabled.
The DISABLE command is used to disable all functions regardless of
their counter values. This is the big off switch and is not the
complement of the ENABLE command.
To make matters worse, when a ftrace_ops is unregistered and there
is another ftrace_ops registered, neither the DISABLE nor the
ENABLE command are set when calling into the stop_machine() function
and the records will not be updated to match their counter. A command
is passed to that function that will update the mcount code to call
the registered callback directly if it is the only one left. This
means that the ftrace_ops that is still registered will have its callback
called by all functions that have been set for it as well as the ftrace_ops
that was just unregistered.
Here's a way to trigger this bug. Compile the kernel with
CONFIG_FUNCTION_PROFILER set and with CONFIG_FUNCTION_GRAPH not set:
CONFIG_FUNCTION_PROFILER=y
# CONFIG_FUNCTION_GRAPH is not set
This will force the function profiler to use the function tracer instead
of the function graph tracer.
# cd /sys/kernel/debug/tracing
# echo schedule > set_ftrace_filter
# echo function > current_tracer
# cat set_ftrace_filter
schedule
# cat trace
# tracer: nop
# entries-in-buffer/entries-written: 692/68108025 #P:4
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/0:2-909 [000] .... 531.235574: schedule <-worker_thread
<idle>-0 [001] .N.. 531.235575: schedule <-cpu_idle
kworker/0:2-909 [000] .... 531.235597: schedule <-worker_thread
sshd-2563 [001] .... 531.235647: schedule <-schedule_hrtimeout_range_clock
# echo 1 > function_profile_enabled
# echo 0 > function_porfile_enabled
schedule
# cat trace
# tracer: function
# entries-in-buffer/entries-written: 159701/118821262 #P:4
# _-----=> irqs-off
# ||| / delay
<idle>-0 [002] ...1 604.870655: local_touch_nmi <-cpu_idle
<idle>-0 [002] d..1 604.870655: enter_idle <-cpu_idle
<idle>-0 [002] d..1 604.870656: atomic_notifier_call_chain <-enter_idle
<idle>-0 [002] d..1 604.870656: __atomic_notifier_call_chain <-atomic_notifier_call_chain
The same problem could have happened with the trace_probe_ops,
but they are modified with the set_frace_filter file which does the
update at closure of the file.
The simple solution is to change ENABLE to UPDATE and call it every
time an ftrace_ops is unregistered.
Link: http://lkml.kernel.org/r/1323105776-26961-3-git-send-email-jolsa@redhat.com
Signed-off-by: Jiri Olsa <jolsa@redhat.com>
commit 072126f4529196f71a97960248bca54fd4554c2d upstream.
Currently, if set_ftrace_filter() is called when the ftrace_ops is
active, the function filters will not be updated. They will only be updated
when tracing is disabled and re-enabled.
Update the functions immediately during set_ftrace_filter().
commit 41fb61c2d08107ce96a5dcb3a6289b2afd3e135c upstream.
Whenever the hash of the ftrace_ops is updated, the record counts
must be balance. This requires disabling the records that are set
in the original hash, and then enabling the records that are set
in the updated hash.
Moving the update into ftrace_hash_move() removes the bug where the
hash was updated but the records were not, which results in ftrace
triggering a warning and disabling itself because the ftrace_ops filter
is updated while the ftrace_ops was registered, and then the failure
happens when the ftrace_ops is unregistered.
The current code will not trigger this bug, but new code will.
commit d496aab567e7e52b3e974c9192a5de6e77dce32c upstream.
Commit ef53d9c5e ("kprobes: improve kretprobe scalability with hashed
locking") introduced a bug where we can potentially leak
kretprobe_instances since we initialize a hlist head after having used
it.
Initialize the hlist head before using it.
Reported by: Jim Keniston <jkenisto@us.ibm.com>
Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: Srinivasa D S <srinivasa@in.ibm.com>
commit 79cfbdfa87e84992d509e6c1648a18e1d7e68c20 upstream.
The CPU hotplug notifications sent out by the _cpu_up() and _cpu_down()
functions depend on the value of the 'tasks_frozen' argument passed to them
(which indicates whether tasks have been frozen or not).
(Examples for such CPU hotplug notifications: CPU_ONLINE, CPU_ONLINE_FROZEN,
CPU_DEAD, CPU_DEAD_FROZEN).
Thus, it is essential that while the callbacks for those notifications are
running, the state of the system with respect to the tasks being frozen or
not remains unchanged, *throughout that duration*. Hence there is a need for
synchronizing the CPU hotplug code with the freezer subsystem.
Since the freezer is involved only in the Suspend/Hibernate call paths, this
patch hooks the CPU hotplug code to the suspend/hibernate notifiers
PM_[SUSPEND|HIBERNATE]_PREPARE and PM_POST_[SUSPEND|HIBERNATE] to prevent
the race between CPU hotplug and freezer, thus ensuring that CPU hotplug
notifications will always be run with the state of the system really being
what the notifications indicate, _throughout_ their execution time.
commit 0d19ea866562e46989412a0676412fa0983c9ce7 upstream.
If we mount a hierarchy with a specified name, the name is unique,
and we can use it to mount the hierarchy without specifying its
set of subsystem names. This feature is documented is
Documentation/cgroups/cgroups.txt section 2.3
Here's an example:
# mount -t cgroup -o cpuset,name=myhier xxx /cgroup1
# mount -t cgroup -o name=myhier xxx /cgroup2
But it was broken by commit 32a8cf235e2f192eb002755076994525cdbaa35a
(cgroup: make the mount options parsing more accurate)
This fixes the regression.
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
commit 50b8d257486a45cba7b65ca978986ed216bbcc10 upstream.
Test-case:
int main(void)
int pid, status;
pid = fork();
if (!pid) {
for (;;) {
if (!fork())
return 0;
if (waitpid(-1, &status, 0) < 0) {
printf("ERR!! wait: %m\n");
return 0;
assert(ptrace(PTRACE_ATTACH, pid, 0,0) == 0);
assert(waitpid(-1, NULL, 0) == pid);
assert(ptrace(PTRACE_SETOPTIONS, pid, 0,
PTRACE_O_TRACEFORK) == 0);
do {
ptrace(PTRACE_CONT, pid, 0, 0);
pid = waitpid(-1, NULL, 0);
} while (pid > 0);
return 1;
It fails because ->real_parent sees its child in EXIT_DEAD state
while the tracer is going to change the state back to EXIT_ZOMBIE
in wait_task_zombie().
The offending commit is 823b018e which moved the EXIT_DEAD check,
but in fact we should not blame it. The original code was not
correct as well because it didn't take ptrace_reparented() into
account and because we can't really trust ->ptrace.
This patch adds the additional check to close this particular
race but it doesn't solve the whole problem. We simply can't
rely on ->ptrace in this case, it can be cleared if the tracer
is multithreaded by the exiting ->parent.
I think we should kill EXIT_DEAD altogether, we should always
remove the soon-to-be-reaped child from ->children or at least
we should never do the DEAD->ZOMBIE transition. But this is too
complex for 3.2.
Reported-and-tested-by: Denys Vlasenko <vda.linux@googlemail.com>
Tested-by: Lukasz Michalik <lmi@ift.uni.wroc.pl>
commit f9fab10bbd768b0e5254e53a4a8477a94bfc4b96 upstream.
vfork parent uninterruptibly and unkillably waits for its child to
exec/exit. This wait is of unbounded length. Ignore such waits
in the hung_task detector.
Signed-off-by: Mandeep Singh Baines <msb@chromium.org>
Reported-by: Sasha Levin <levinsasha928@gmail.com>
LKML-Reference: <1325344394.28904.43.camel@lappy>
Cc: John Kacur <jkacur@redhat.com>
commit e6780f7243eddb133cc20ec37fa69317c218b709 upstream.
It was found (by Sasha) that if you use a futex located in the gate
area we get stuck in an uninterruptible infinite loop, much like the
ZERO_PAGE issue.
While looking at this problem, PeterZ realized you'll get into similar
trouble when hitting any install_special_pages() mapping. And are there
still drivers setting up their own special mmaps without page->mapping,
and without special VM or pte flags to make get_user_pages fail?
In most cases, if page->mapping is NULL, we do not need to retry at all:
Linus points out that even /proc/sys/vm/drop_caches poses no problem,
because it ends up using remove_mapping(), which takes care not to
interfere when the page reference count is raised.
But there is still one case which does need a retry: if memory pressure
called shmem_writepage in between get_user_pages_fast dropping page
table lock and our acquiring page lock, then the page gets switched from
filecache to swapcache (and ->mapping set to NULL) whatever the refcount.
Fault it back in to get the page->mapping needed for key->shared.inode.
commit e0197aae59e55c06db172bfbe1a1cdb8c0e1cab3 upstream.
There is a BUG when migrating a PF_EXITING proc. Since css_set_prefetch()
is not called for the PF_EXITING case, find_existing_css_set() will return
NULL inside cgroup_task_migrate() causing a BUG.
This bug is easy to reproduce. Create a zombie and echo its pid to
cgroup.procs.
$ cat zombie.c
\#include <unistd.h>
int main()
if (fork())
pause();
return 0;
We are hitting this bug pretty regularly on ChromeOS.
This bug is already fixed by Tejun Heo's cgroup patchset which is
targetted for the next merge window:
https://lkml.org/lkml/2011/11/1/356
I've create a smaller patch here which just fixes this bug so that a
fix can be merged into the current release and stable.
Downstream-Bug-Report: http://crosbug.com/23953
Reviewed-by: Li Zefan <lizf@cn.fujitsu.com>
Cc: containers@lists.linux-foundation.org
Cc: cgroups@vger.kernel.org
Cc: Paul Menage <paul@paulmenage.org>
Cc: Olof Johansson <olofj@chromium.org>
commit 3d3c8f93a237b64580c5c5e138edeb1377e98230 upstream.
binary_sysctl() calls sysctl_getname() which allocates from names_cache
slab usin __getname()
The matching function to free the name is __putname(), and not putname()
which should be used only to match getname() allocations.
This is because when auditing is enabled, putname() calls audit_putname
*instead* (not in addition) to __putname(). Then, if a syscall is in
progress, audit_putname does not release the name - instead, it expects
the name to get released when the syscall completes, but that will happen
only if audit_getname() was called previously, i.e. if the name was
allocated with getname() rather than the naked __getname(). So,
__getname() followed by putname() ends up leaking memory.
Signed-off-by: Michel Lespinasse <walken@google.com>
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
Cc: Eric Paris <eparis@redhat.com>
commit 3b87487ac5008072f138953b07505a7e3493327f upstream.
This reverts commit de28f25e8244c7353abed8de0c7792f5f883588c.
It results in resume problems for various people. See for example
http://thread.gmane.org/gmane.linux.kernel/1233033
http://thread.gmane.org/gmane.linux.kernel/1233389
http://thread.gmane.org/gmane.linux.kernel/1233159
http://thread.gmane.org/gmane.linux.kernel/1227868/focus=1230877
and the fedora and ubuntu bug reports
https://bugzilla.redhat.com/show_bug.cgi?id=767248
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/904569
which got bisected down to the stable version of this commit.
Reported-by: Jonathan Nieder <jrnieder@gmail.com>
Reported-by: Phil Miller <mille121@illinois.edu>
Reported-by: Philip Langdale <philipl@overt.org>
Reported-by: Tim Gardner <tim.gardner@canonical.com>
commit 1a51410abe7d0ee4b1d112780f46df87d3621043 upstream.
Ok, this isn't optimal, since it means that 'iotop' needs admin
capabilities, and we may have to work on this some more. But at the
same time it is very much not acceptable to let anybody just read
anybody elses IO statistics quite at this level.
Use of the GENL_ADMIN_PERM suggested by Johannes Berg as an alternative
to checking the capabilities by hand.
Reported-by: Vasiliy Kulikov <segoon@openwall.com>
Cc: Johannes Berg <johannes.berg@intel.com>
Acked-by: Balbir Singh <bsingharora@gmail.com>
Cc: Moritz Mühlenhoff <jmm@inutil.org>
commit c9c024b3f3e07d087974db4c0dc46217fff3a6c0 upstream.
The expiry function compares the timer against current time and does
not expire the timer when the expiry time is >= now. That's wrong. If
the timer is set for now, then it must expire.
Make the condition expiry > now for breaking out the loop.
Acked-by: John Stultz <john.stultz@linaro.org>
commit de28f25e8244c7353abed8de0c7792f5f883588c upstream.
If a device is shutdown, then there might be a pending interrupt,
which will be processed after we reenable interrupts, which causes the
original handler to be run. If the old handler is the (broadcast)
periodic handler the shutdown state might hang the kernel completely.
commit b1f919664d04a8d0ba29cb76673c7ca3325a2006 upstream.
In order to leave a margin of 12.5% we should >> 3 not >> 5.
Signed-off-by: Yang Honggang (Joseph) <eagle.rtlinux@gmail.com>
[jstultz: Modified commit subject]
Signed-off-by: John Stultz <john.stultz@linaro.org>
commit bbbf7af4bf8fc69bc751818cf30521080fa47dcb upstream.
If cpu A calls jump_label_inc() just after atomic_add_return() is
called by cpu B, atomic_inc_not_zero() will return value greater then
zero and jump_label_inc() will return to a caller before jump_label_update()
finishes its job on cpu B.
Link: http://lkml.kernel.org/r/20111018175551.GH17571@redhat.com
Acked-by: Jason Baron <jbaron@redhat.com>
Signed-off-by: Gleb Natapov <gleb@redhat.com>
commit c1be84309c58b1e7c6d626e28fba41a22b364c3d upstream.
When a better rated broadcast device is installed, then the current
active device is not disabled, which results in two running broadcast
devices.
commit cb59974742aea24adf6637eb0c4b8e7b48bca6fb upstream.
Fix a bug introduced by e9dbfae5, which prevents event_subsystem from
ever being released.
Ref_count was added to keep track of subsystem users, not for counting
events. Subsystem is created with ref_count = 1, so there is no need to
increment it for every event, we have nr_events for that. Fix this by
touching ref_count only when we actually have a new user -
subsystem_open().
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
Link: http://lkml.kernel.org/r/1320052062-7846-1-git-send-email-idryomov@gmail.com
ftrace_event_call->filter
commit d3d9acf646679c1981032b0985b386d12fccc60c upstream.
ftrace_event_call->filter is sched RCU protected but didn't use
rcu_assign_pointer(). Use it.
TODO: Add proper __rcu annotation to call->filter and all its users.
-v2: Use RCU_INIT_POINTER() for %NULL clearing as suggested by Eric.
Link: http://lkml.kernel.org/r/20111123164949.GA29639@google.com
Cc: Jiri Olsa <jolsa@redhat.com>
commit 550acb19269d65f32e9ac4ddb26c2b2070e37f1c upstream.
In irq_wait_for_interrupt(), the should_stop member is verified before
setting the task's state to TASK_INTERRUPTIBLE and calling schedule().
In case kthread_stop sets should_stop and wakes up the process after
should_stop is checked by the irq thread but before the task's state
is changed, the irq thread might never exit:
kthread_stop irq_wait_for_interrupt
... while (!kthread_should_stop()) {
kthread->should_stop = 1;
wake_up_process(k);
wait_for_completion(&kthread->exited);
set_current_state(TASK_INTERRUPTIBLE);
schedule();
Fix this by checking if the thread should stop after modifying the
task's state.
[ tglx: Simplified it a bit ]
Signed-off-by: Ido Yariv <ido@wizery.com>
Link: http://lkml.kernel.org/r/1322740508-22640-1-git-send-email-ido@wizery.com
