path: root/lib/Kconfig.debug
2018-02-25kasan: rework Kconfig settingsArnd Bergmann
commit e7c52b84fb18f08ce49b6067ae6285aca79084a8 upstream. We get a lot of very large stack frames using gcc-7.0.1 with the default -fsanitize-address-use-after-scope --param asan-stack=1 options, which can easily cause an overflow of the kernel stack, e.g. drivers/gpu/drm/i915/gvt/handlers.c:2434:1: warning: the frame size of 46176 bytes is larger than 3072 bytes drivers/net/wireless/ralink/rt2x00/rt2800lib.c:5650:1: warning: the frame size of 23632 bytes is larger than 3072 bytes lib/atomic64_test.c:250:1: warning: the frame size of 11200 bytes is larger than 3072 bytes drivers/gpu/drm/i915/gvt/handlers.c:2621:1: warning: the frame size of 9208 bytes is larger than 3072 bytes drivers/media/dvb-frontends/stv090x.c:3431:1: warning: the frame size of 6816 bytes is larger than 3072 bytes fs/fscache/stats.c:287:1: warning: the frame size of 6536 bytes is larger than 3072 bytes To reduce this risk, -fsanitize-address-use-after-scope is now split out into a separate CONFIG_KASAN_EXTRA Kconfig option, leading to stack frames that are smaller than 2 kilobytes most of the time on x86_64. An earlier version of this patch also prevented combining KASAN_EXTRA with KASAN_INLINE, but that is no longer necessary with gcc-7.0.1. All patches to get the frame size below 2048 bytes with CONFIG_KASAN=y and CONFIG_KASAN_EXTRA=n have been merged by maintainers now, so we can bring back that default now. KASAN_EXTRA=y still causes lots of warnings but now defaults to !COMPILE_TEST to disable it in allmodconfig, and it remains disabled in all other defconfigs since it is a new option. I arbitrarily raise the warning limit for KASAN_EXTRA to 3072 to reduce the noise, but an allmodconfig kernel still has around 50 warnings on gcc-7. I experimented a bit more with smaller stack frames and have another follow-up series that reduces the warning limit for 64-bit architectures to 1280 bytes (without CONFIG_KASAN). With earlier versions of this patch series, I also had patches to address the warnings we get with KASAN and/or KASAN_EXTRA, using a "noinline_if_stackbloat" annotation. That annotation now got replaced with a gcc-8 bugfix (see https://gcc.gnu.org/bugzilla/show_bug.cgi?id=81715) and a workaround for older compilers, which means that KASAN_EXTRA is now just as bad as before and will lead to an instant stack overflow in a few extreme cases. This reverts parts of commit 3f181b4d8652 ("lib/Kconfig.debug: disable -Wframe-larger-than warnings with KASAN=y"). Two patches in linux-next should be merged first to avoid introducing warnings in an allmodconfig build: 3cd890dbe2a4 ("media: dvb-frontends: fix i2c access helpers for KASAN") 16c3ada89cff ("media: r820t: fix r820t_write_reg for KASAN") Do we really need to backport this? I think we do: without this patch, enabling KASAN will lead to unavoidable kernel stack overflow in certain device drivers when built with gcc-7 or higher on linux-4.10+ or any version that contains a backport of commit c5caf21ab0cf8. Most people are probably still on older compilers, but it will get worse over time as they upgrade their distros. The warnings we get on kernels older than this should all be for code that uses dangerously large stack frames, though most of them do not cause an actual stack overflow by themselves.The asan-stack option was added in linux-4.0, and commit 3f181b4d8652 ("lib/Kconfig.debug: disable -Wframe-larger-than warnings with KASAN=y") effectively turned off the warning for allmodconfig kernels, so I would like to see this fix backported to any kernels later than 4.0. I have done dozens of fixes for individual functions with stack frames larger than 2048 bytes with asan-stack, and I plan to make sure that all those fixes make it into the stable kernels as well (most are already there). Part of the complication here is that asan-stack (from 4.0) was originally assumed to always require much larger stacks, but that turned out to be a combination of multiple gcc bugs that we have now worked around and fixed, but sanitize-address-use-after-scope (from v4.10) has a much higher inherent stack usage and also suffers from at least three other problems that we have analyzed but not yet fixed upstream, each of them makes the stack usage more severe than it should be. Link: http://lkml.kernel.org/r/20171221134744.2295529-1-arnd@arndb.de Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Mauro Carvalho Chehab <mchehab@kernel.org> Cc: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Alexander Potapenko <glider@google.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Andrey Konovalov <andreyknvl@google.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> [arnd: rebase to v4.9; only re-enable warning] Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-11lib/Kconfig.debug: fix frv build failureSudip Mukherjee
[ Upstream commit da0510c47519fe0999cffe316e1d370e29f952be ] The build of frv allmodconfig was failing with the errors like: /tmp/cc0JSPc3.s: Assembler messages: /tmp/cc0JSPc3.s:1839: Error: symbol `.LSLT0' is already defined /tmp/cc0JSPc3.s:1842: Error: symbol `.LASLTP0' is already defined /tmp/cc0JSPc3.s:1969: Error: symbol `.LELTP0' is already defined /tmp/cc0JSPc3.s:1970: Error: symbol `.LELT0' is already defined Commit 866ced950bcd ("kbuild: Support split debug info v4") introduced splitting the debug info and keeping that in a separate file. Somehow, the frv-linux gcc did not like that and I am guessing that instead of splitting it started copying. The first report about this is at: https://lists.01.org/pipermail/kbuild-all/2015-July/010527.html. I will try and see if this can work with frv and if still fails I will open a bug report with gcc. But meanwhile this is the easiest option to solve build failure of frv. Fixes: 866ced950bcd ("kbuild: Support split debug info v4") Link: http://lkml.kernel.org/r/1482062348-5352-1-git-send-email-sudipm.mukherjee@gmail.com Signed-off-by: Sudip Mukherjee <sudip.mukherjee@codethink.co.uk> Reported-by: Fengguang Wu <fengguang.wu@intel.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-18config: Adding the new config parameter CONFIG_PROVE_LOCKING_SMALL for sparcBabu Moger
This new config parameter limits the space used for "Lock debugging: prove locking correctness" by about 4MB. The current sparc systems have the limitation of 32MB size for kernel size including .text, .data and .bss sections. With PROVE_LOCKING feature, the kernel size could grow beyond this limit and causing system boot-up issues. With this option, kernel limits the size of the entries of lock_chains, stack_trace etc., so that kernel fits in required size limit. This is not visible to user and only used for sparc. Signed-off-by: Babu Moger <babu.moger@oracle.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-10-27latent_entropy: raise CONFIG_FRAME_WARN by defaultKees Cook
When building with the latent_entropy plugin, set the default CONFIG_FRAME_WARN to 2048, since some __init functions have many basic blocks that, when instrumented by the latent_entropy plugin, grow beyond 1024 byte stack size on 32-bit builds. Link: http://lkml.kernel.org/r/20161018211216.GA39687@beast Signed-off-by: Kees Cook <keescook@chromium.org> Reported-by: kbuild test robot <fengguang.wu@intel.com> Cc: Emese Revfy <re.emese@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Michal Marek <mmarek@suse.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Tejun Heo <tj@kernel.org> Cc: Nikolay Aleksandrov <nikolay@cumulusnetworks.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Shuah Khan <shuah@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-14Merge tag 'linux-kselftest-4.9-rc1-update' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest Pull kselftest updates from Shuah Khan: "This update consists of: - Fixes and improvements to existing tests - Moving code from Documentation to selftests, samples, and tools: * Moves dnotify_test, prctl, ptp, vDSO, ia64, watchdog, and networking tests from Documentation to selftests. * Moves mic/mpssd, misc-devices/mei, timers, watchdog, auxdisplay, and blackfin examples from Documentation to samples. * Moves accounting, laptops/dslm, and pcmcia/crc32hash tools from Documentation to tools. * Deletes BUILD_DOCSRC and its dependencies" * tag 'linux-kselftest-4.9-rc1-update' of git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest: (21 commits) selftests/futex: Check ANSI terminal color support Doc: update 00-INDEX files to reflect the runnable code move samples: move blackfin gptimers-example from Documentation tools: move pcmcia crc32hash tool from Documentation tools: move laptops dslm tool from Documentation tools: move accounting tool from Documentation samples: move auxdisplay example code from Documentation samples: move watchdog example code from Documentation samples: move timers example code from Documentation samples: move misc-devices/mei example code from Documentation samples: move mic/mpssd example code from Documentation selftests: Move networking/timestamping from Documentation selftests: move watchdog tests from Documentation/watchdog selftests: move ia64 tests from Documentation/ia64 selftests: move vDSO tests from Documentation/vDSO selftests: move ptp tests from Documentation/ptp selftests: move prctl tests from Documentation/prctl selftests: move dnotify_test from Documentation/filesystems selftests/timers: Add missing error code assignment before test selftests/zram: replace ZRAM_LZ4_COMPRESS ...
2016-10-10samples: move blackfin gptimers-example from DocumentationShuah Khan
Move blackfin gptimers-example to samples and remove it from Documentation Makefile. Update samples Kconfig and Makefile to build gptimers-example. blackfin is the last CONFIG_BUILD_DOCSRC target in Documentation/Makefile. Hence this patch also includes changes to remove CONFIG_BUILD_DOCSRC from Makefile and lib/Kconfig.debug and updates VIDEO_PCI_SKELETON dependency on BUILD_DOCSRC. Documentation/Makefile is not deleted to avoid braking make htmldocs and make distclean. Acked-by: Michal Marek <mmarek@suse.com> Acked-by: Jonathan Corbet <corbet@lwn.net> Reviewed-by: Kees Cook <keescook@chromium.org> Reported-by: Valentin Rothberg <valentinrothberg@gmail.com> Reported-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
2016-10-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial updates from Jiri Kosina: "The usual rocket science from the trivial tree" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: tracing/syscalls: fix multiline in error message text lib/Kconfig.debug: fix DEBUG_SECTION_MISMATCH description doc: vfs: fix fadvise() sycall name x86/entry: spell EBX register correctly in documentation securityfs: fix securityfs_create_dir comment irq: Fix typo in tracepoint.xml
2016-09-29lib/Kconfig.debug: fix DEBUG_SECTION_MISMATCH descriptionUwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2016-09-23locking/hung_task: Fix typo in CONFIG_DETECT_HUNG_TASK help textVivien Didelot
Fix the indefinitiley -> indefinitely typo in Kconfig.debug. Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20160922205513.17821-1-vivien.didelot@savoirfairelinux.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-08-30mm/usercopy: get rid of CONFIG_DEBUG_STRICT_USER_COPY_CHECKSJosh Poimboeuf
There are three usercopy warnings which are currently being silenced for gcc 4.6 and newer: 1) "copy_from_user() buffer size is too small" compile warning/error This is a static warning which happens when object size and copy size are both const, and copy size > object size. I didn't see any false positives for this one. So the function warning attribute seems to be working fine here. Note this scenario is always a bug and so I think it should be changed to *always* be an error, regardless of CONFIG_DEBUG_STRICT_USER_COPY_CHECKS. 2) "copy_from_user() buffer size is not provably correct" compile warning This is another static warning which happens when I enable __compiletime_object_size() for new compilers (and CONFIG_DEBUG_STRICT_USER_COPY_CHECKS). It happens when object size is const, but copy size is *not*. In this case there's no way to compare the two at build time, so it gives the warning. (Note the warning is a byproduct of the fact that gcc has no way of knowing whether the overflow function will be called, so the call isn't dead code and the warning attribute is activated.) So this warning seems to only indicate "this is an unusual pattern, maybe you should check it out" rather than "this is a bug". I get 102(!) of these warnings with allyesconfig and the __compiletime_object_size() gcc check removed. I don't know if there are any real bugs hiding in there, but from looking at a small sample, I didn't see any. According to Kees, it does sometimes find real bugs. But the false positive rate seems high. 3) "Buffer overflow detected" runtime warning This is a runtime warning where object size is const, and copy size > object size. All three warnings (both static and runtime) were completely disabled for gcc 4.6 with the following commit: 2fb0815c9ee6 ("gcc4: disable __compiletime_object_size for GCC 4.6+") That commit mistakenly assumed that the false positives were caused by a gcc bug in __compiletime_object_size(). But in fact, __compiletime_object_size() seems to be working fine. The false positives were instead triggered by #2 above. (Though I don't have an explanation for why the warnings supposedly only started showing up in gcc 4.6.) So remove warning #2 to get rid of all the false positives, and re-enable warnings #1 and #3 by reverting the above commit. Furthermore, since #1 is a real bug which is detected at compile time, upgrade it to always be an error. Having done all that, CONFIG_DEBUG_STRICT_USER_COPY_CHECKS is no longer needed. Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Kees Cook <keescook@chromium.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@kernel.org> Cc: "H . Peter Anvin" <hpa@zytor.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Brian Gerst <brgerst@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Byungchul Park <byungchul.park@lge.com> Cc: Nilay Vaish <nilayvaish@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-02Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge yet more updates from Andrew Morton: - the rest of ocfs2 - various hotfixes, mainly MM - quite a bit of misc stuff - drivers, fork, exec, signals, etc. - printk updates - firmware - checkpatch - nilfs2 - more kexec stuff than usual - rapidio updates - w1 things * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (111 commits) ipc: delete "nr_ipc_ns" kcov: allow more fine-grained coverage instrumentation init/Kconfig: add clarification for out-of-tree modules config: add android config fragments init/Kconfig: ban CONFIG_LOCALVERSION_AUTO with allmodconfig relay: add global mode support for buffer-only channels init: allow blacklisting of module_init functions w1:omap_hdq: fix regression w1: add helper macro module_w1_family w1: remove need for ida and use PLATFORM_DEVID_AUTO rapidio/switches: add driver for IDT gen3 switches powerpc/fsl_rio: apply changes for RIO spec rev 3 rapidio: modify for rev.3 specification changes rapidio: change inbound window size type to u64 rapidio/idt_gen2: fix locking warning rapidio: fix error handling in mbox request/release functions rapidio/tsi721_dma: advance queue processing from transfer submit call rapidio/tsi721: add messaging mbox selector parameter rapidio/tsi721: add PCIe MRRS override parameter rapidio/tsi721_dma: add channel mask and queue size parameters ...
2016-08-02kcov: allow more fine-grained coverage instrumentationVegard Nossum
For more targeted fuzzing, it's better to disable kernel-wide instrumentation and instead enable it on a per-subsystem basis. This follows the pattern of UBSAN and allows you to compile in the kcov driver without instrumenting the whole kernel. To instrument a part of the kernel, you can use either # for a single file in the current directory KCOV_INSTRUMENT_filename.o := y or # for all the files in the current directory (excluding subdirectories) KCOV_INSTRUMENT := y or # (same as above) ccflags-y += $(CFLAGS_KCOV) or # for all the files in the current directory (including subdirectories) subdir-ccflags-y += $(CFLAGS_KCOV) Link: http://lkml.kernel.org/r/1464008380-11405-1-git-send-email-vegard.nossum@oracle.com Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-02Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild updates from Michal Marek: - GCC plugin support by Emese Revfy from grsecurity, with a fixup from Kees Cook. The plugins are meant to be used for static analysis of the kernel code. Two plugins are provided already. - reduction of the gcc commandline by Arnd Bergmann. - IS_ENABLED / IS_REACHABLE macro enhancements by Masahiro Yamada - bin2c fix by Michael Tautschnig - setlocalversion fix by Wolfram Sang * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: gcc-plugins: disable under COMPILE_TEST kbuild: Abort build on bad stack protector flag scripts: Fix size mismatch of kexec_purgatory_size kbuild: make samples depend on headers_install Kbuild: don't add obj tree in additional includes Kbuild: arch: look for generated headers in obtree Kbuild: always prefix objtree in LINUXINCLUDE Kbuild: avoid duplicate include path Kbuild: don't add ../../ to include path vmlinux.lds.h: replace config_enabled() with IS_ENABLED() kconfig.h: allow to use IS_{ENABLE,REACHABLE} in macro expansion kconfig.h: use already defined macros for IS_REACHABLE() define export.h: use __is_defined() to check if __KSYM_* is defined kconfig.h: use __is_defined() to check if MODULE is defined kbuild: setlocalversion: print error to STDERR Add sancov plugin Add Cyclomatic complexity GCC plugin GCC plugin infrastructure Shared library support
2016-07-26mm/page_owner: use stackdepot to store stacktraceJoonsoo Kim
Currently, we store each page's allocation stacktrace on corresponding page_ext structure and it requires a lot of memory. This causes the problem that memory tight system doesn't work well if page_owner is enabled. Moreover, even with this large memory consumption, we cannot get full stacktrace because we allocate memory at boot time and just maintain 8 stacktrace slots to balance memory consumption. We could increase it to more but it would make system unusable or change system behaviour. To solve the problem, this patch uses stackdepot to store stacktrace. It obviously provides memory saving but there is a drawback that stackdepot could fail. stackdepot allocates memory at runtime so it could fail if system has not enough memory. But, most of allocation stack are generated at very early time and there are much memory at this time. So, failure would not happen easily. And, one failure means that we miss just one page's allocation stacktrace so it would not be a big problem. In this patch, when memory allocation failure happens, we store special stracktrace handle to the page that is failed to save stacktrace. With it, user can guess memory usage properly even if failure happens. Memory saving looks as following. (4GB memory system with page_owner) (before the patch -> after the patch) static allocation: 92274688 bytes -> 25165824 bytes dynamic allocation after boot + kernel build: 0 bytes -> 327680 bytes total: 92274688 bytes -> 25493504 bytes 72% reduction in total. Note that implementation looks complex than someone would imagine because there is recursion issue. stackdepot uses page allocator and page_owner is called at page allocation. Using stackdepot in page_owner could re-call page allcator and then page_owner. That is a recursion. To detect and avoid it, whenever we obtain stacktrace, recursion is checked and page_owner is set to dummy information if found. Dummy information means that this page is allocated for page_owner feature itself (such as stackdepot) and it's understandable behavior for user. [iamjoonsoo.kim@lge.com: mm-page_owner-use-stackdepot-to-store-stacktrace-v3] Link: http://lkml.kernel.org/r/1464230275-25791-6-git-send-email-iamjoonsoo.kim@lge.com Link: http://lkml.kernel.org/r/1466150259-27727-7-git-send-email-iamjoonsoo.kim@lge.com Link: http://lkml.kernel.org/r/1464230275-25791-6-git-send-email-iamjoonsoo.kim@lge.com Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Minchan Kim <minchan@kernel.org> Cc: Alexander Potapenko <glider@google.com> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-27gcc-plugins: disable under COMPILE_TESTKees Cook
Since adding the gcc plugin development headers is required for the gcc plugin support, we should ease into this new kernel build dependency more slowly. For now, disable the gcc plugins under COMPILE_TEST so that all*config builds will skip it. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Michal Marek <mmarek@suse.com>
2016-06-14torture: Remove CONFIG_RCU_TORTURE_TEST_RUNNABLE, simplify codePaul E. McKenney
This commit removes CONFIG_RCU_TORTURE_TEST_RUNNABLE in favor of the already-existing rcutorture.torture_runnable kernel boot parameter. It also converts an #ifdef into IS_ENABLED(), saving a few lines of code. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2016-06-14torture: Simplify code, eliminate RCU_PERF_TEST_RUNNABLEPaul E. McKenney
This commit applies the infamous IS_ENABLED() macro to eliminate a #ifdef. It also eliminates the RCU_PERF_TEST_RUNNABLE Kconfig option in favor of the already-existing rcuperf.perf_runnable kernel boot parameter. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2016-06-07Add sancov pluginEmese Revfy
The sancov gcc plugin inserts a __sanitizer_cov_trace_pc() call at the start of basic blocks. This plugin is a helper plugin for the kcov feature. It supports all gcc versions with plugin support (from gcc-4.5 on). It is based on the gcc commit "Add fuzzing coverage support" by Dmitry Vyukov (https://gcc.gnu.org/viewcvs/gcc?limit_changes=0&view=revision&revision=231296). Signed-off-by: Emese Revfy <re.emese@gmail.com> Acked-by: Kees Cook <keescook@chromium.org> Signed-off-by: Michal Marek <mmarek@suse.com>
2016-05-30lib/uuid: add a test moduleAndy Shevchenko
It appears that somehow I missed a test of the latest UUID rework which landed in the kernel. Present a small test module to avoid such cases in the future. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-28Merge branch 'hash' of git://ftp.sciencehorizons.net/linuxLinus Torvalds
Pull string hash improvements from George Spelvin: "This series does several related things: - Makes the dcache hash (fs/namei.c) useful for general kernel use. (Thanks to Bruce for noticing the zero-length corner case) - Converts the string hashes in <linux/sunrpc/svcauth.h> to use the above. - Avoids 64-bit multiplies in hash_64() on 32-bit platforms. Two 32-bit multiplies will do well enough. - Rids the world of the bad hash multipliers in hash_32. This finishes the job started in commit 689de1d6ca95 ("Minimal fix-up of bad hashing behavior of hash_64()") The vast majority of Linux architectures have hardware support for 32x32-bit multiply and so derive no benefit from "simplified" multipliers. The few processors that do not (68000, h8/300 and some models of Microblaze) have arch-specific implementations added. Those patches are last in the series. - Overhauls the dcache hash mixing. The patch in commit 0fed3ac866ea ("namei: Improve hash mixing if CONFIG_DCACHE_WORD_ACCESS") was an off-the-cuff suggestion. Replaced with a much more careful design that's simultaneously faster and better. (My own invention, as there was noting suitable in the literature I could find. Comments welcome!) - Modify the hash_name() loop to skip the initial HASH_MIX(). This would let us salt the hash if we ever wanted to. - Sort out partial_name_hash(). The hash function is declared as using a long state, even though it's truncated to 32 bits at the end and the extra internal state contributes nothing to the result. And some callers do odd things: - fs/hfs/string.c only allocates 32 bits of state - fs/hfsplus/unicode.c uses it to hash 16-bit unicode symbols not bytes - Modify bytemask_from_count to handle inputs of 1..sizeof(long) rather than 0..sizeof(long)-1. This would simplify users other than full_name_hash" Special thanks to Bruce Fields for testing and finding bugs in v1. (I learned some humbling lessons about "obviously correct" code.) On the arch-specific front, the m68k assembly has been tested in a standalone test harness, I've been in contact with the Microblaze maintainers who mostly don't care, as the hardware multiplier is never omitted in real-world applications, and I haven't heard anything from the H8/300 world" * 'hash' of git://ftp.sciencehorizons.net/linux: h8300: Add <asm/hash.h> microblaze: Add <asm/hash.h> m68k: Add <asm/hash.h> <linux/hash.h>: Add support for architecture-specific functions fs/namei.c: Improve dcache hash function Eliminate bad hash multipliers from hash_32() and hash_64() Change hash_64() return value to 32 bits <linux/sunrpc/svcauth.h>: Define hash_str() in terms of hashlen_string() fs/namei.c: Add hashlen_string() function Pull out string hash to <linux/stringhash.h>
2016-05-28<linux/hash.h>: Add support for architecture-specific functionsGeorge Spelvin
This is just the infrastructure; there are no users yet. This is modelled on CONFIG_ARCH_RANDOM; a CONFIG_ symbol declares the existence of <asm/hash.h>. That file may define its own versions of various functions, and define HAVE_* symbols (no CONFIG_ prefix!) to suppress the generic ones. Included is a self-test (in lib/test_hash.c) that verifies the basics. It is NOT in general required that the arch-specific functions compute the same thing as the generic, but if a HAVE_* symbol is defined with the value 1, then equality is tested. Signed-off-by: George Spelvin <linux@sciencehorizons.net> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Greg Ungerer <gerg@linux-m68k.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Cc: Philippe De Muyter <phdm@macq.eu> Cc: linux-m68k@lists.linux-m68k.org Cc: Alistair Francis <alistai@xilinx.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: uclinux-h8-devel@lists.sourceforge.jp
2016-05-20Merge tag 'driver-core-4.7-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core updates from Greg KH: "Here's the "big" driver core update for 4.7-rc1. Mostly just debugfs changes, the long-known and messy races with removing debugfs files should be fixed thanks to the great work of Nicolai Stange. We also have some isa updates in here (the x86 maintainers told me to take it through this tree), a new warning when we run out of dynamic char major numbers, and a few other assorted changes, details in the shortlog. All have been in linux-next for some time with no reported issues" * tag 'driver-core-4.7-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (32 commits) Revert "base: dd: don't remove driver_data in -EPROBE_DEFER case" gpio: ws16c48: Utilize the ISA bus driver gpio: 104-idio-16: Utilize the ISA bus driver gpio: 104-idi-48: Utilize the ISA bus driver gpio: 104-dio-48e: Utilize the ISA bus driver watchdog: ebc-c384_wdt: Utilize the ISA bus driver iio: stx104: Utilize the module_isa_driver and max_num_isa_dev macros iio: stx104: Add X86 dependency to STX104 Kconfig option Documentation: Add ISA bus driver documentation isa: Implement the max_num_isa_dev macro isa: Implement the module_isa_driver macro pnp: pnpbios: Add explicit X86_32 dependency to PNPBIOS isa: Decouple X86_32 dependency from the ISA Kconfig option driver-core: use 'dev' argument in dev_dbg_ratelimited stub base: dd: don't remove driver_data in -EPROBE_DEFER case kernfs: Move faulting copy_user operations outside of the mutex devcoredump: add scatterlist support debugfs: unproxify files created through debugfs_create_u32_array() debugfs: unproxify files created through debugfs_create_blob() debugfs: unproxify files created through debugfs_create_bool() ...
2016-04-12debugfs: prevent access to possibly dead file_operations at file openNicolai Stange
Nothing prevents a dentry found by path lookup before a return of __debugfs_remove() to actually get opened after that return. Now, after the return of __debugfs_remove(), there are no guarantees whatsoever regarding the memory the corresponding inode's file_operations object had been kept in. Since __debugfs_remove() is seldomly invoked, usually from module exit handlers only, the race is hard to trigger and the impact is very low. A discussion of the problem outlined above as well as a suggested solution can be found in the (sub-)thread rooted at http://lkml.kernel.org/g/20130401203445.GA20862@ZenIV.linux.org.uk ("Yet another pipe related oops.") Basically, Greg KH suggests to introduce an intermediate fops and Al Viro points out that a pointer to the original ones may be stored in ->d_fsdata. Follow this line of reasoning: - Add SRCU as a reverse dependency of DEBUG_FS. - Introduce a srcu_struct object for the debugfs subsystem. - In debugfs_create_file(), store a pointer to the original file_operations object in ->d_fsdata. - Make debugfs_remove() and debugfs_remove_recursive() wait for a SRCU grace period after the dentry has been delete()'d and before they return to their callers. - Introduce an intermediate file_operations object named "debugfs_open_proxy_file_operations". It's ->open() functions checks, under the protection of a SRCU read lock, whether the dentry is still alive, i.e. has not been d_delete()'d and if so, tries to acquire a reference on the owning module. On success, it sets the file object's ->f_op to the original file_operations and forwards the ongoing open() call to the original ->open(). - For clarity, rename the former debugfs_file_operations to debugfs_noop_file_operations -- they are in no way canonical. The choice of SRCU over "normal" RCU is justified by the fact, that the former may also be used to protect ->i_private data from going away during the execution of a file's readers and writers which may (and do) sleep. Finally, introduce the fs/debugfs/internal.h header containing some declarations internal to the debugfs implementation. Signed-off-by: Nicolai Stange <nicstange@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-31rcutorture: Add RCU grace-period performance testsPaul E. McKenney
This commit adds a new rcuperf module that carries out simple performance tests of RCU grace periods. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2016-03-23parisc,metag: Implement CONFIG_DEBUG_STACK_USAGE optionHelge Deller
On parisc and metag the stack grows upwards, so for those we need to scan the stack downwards in order to calculate how much stack a process has used. Tested on a 64bit parisc kernel. Signed-off-by: Helge Deller <deller@gmx.de>
2016-03-22kernel: add kcov code coverageDmitry Vyukov
kcov provides code coverage collection for coverage-guided fuzzing (randomized testing). Coverage-guided fuzzing is a testing technique that uses coverage feedback to determine new interesting inputs to a system. A notable user-space example is AFL (http://lcamtuf.coredump.cx/afl/). However, this technique is not widely used for kernel testing due to missing compiler and kernel support. kcov does not aim to collect as much coverage as possible. It aims to collect more or less stable coverage that is function of syscall inputs. To achieve this goal it does not collect coverage in soft/hard interrupts and instrumentation of some inherently non-deterministic or non-interesting parts of kernel is disbled (e.g. scheduler, locking). Currently there is a single coverage collection mode (tracing), but the API anticipates additional collection modes. Initially I also implemented a second mode which exposes coverage in a fixed-size hash table of counters (what Quentin used in his original patch). I've dropped the second mode for simplicity. This patch adds the necessary support on kernel side. The complimentary compiler support was added in gcc revision 231296. We've used this support to build syzkaller system call fuzzer, which has found 90 kernel bugs in just 2 months: https://github.com/google/syzkaller/wiki/Found-Bugs We've also found 30+ bugs in our internal systems with syzkaller. Another (yet unexplored) direction where kcov coverage would greatly help is more traditional "blob mutation". For example, mounting a random blob as a filesystem, or receiving a random blob over wire. Why not gcov. Typical fuzzing loop looks as follows: (1) reset coverage, (2) execute a bit of code, (3) collect coverage, repeat. A typical coverage can be just a dozen of basic blocks (e.g. an invalid input). In such context gcov becomes prohibitively expensive as reset/collect coverage steps depend on total number of basic blocks/edges in program (in case of kernel it is about 2M). Cost of kcov depends only on number of executed basic blocks/edges. On top of that, kernel requires per-thread coverage because there are always background threads and unrelated processes that also produce coverage. With inlined gcov instrumentation per-thread coverage is not possible. kcov exposes kernel PCs and control flow to user-space which is insecure. But debugfs should not be mapped as user accessible. Based on a patch by Quentin Casasnovas. [akpm@linux-foundation.org: make task_struct.kcov_mode have type `enum kcov_mode'] [akpm@linux-foundation.org: unbreak allmodconfig] [akpm@linux-foundation.org: follow x86 Makefile layout standards] Signed-off-by: Dmitry Vyukov <dvyukov@google.com> Reviewed-by: Kees Cook <keescook@chromium.org> Cc: syzkaller <syzkaller@googlegroups.com> Cc: Vegard Nossum <vegard.nossum@oracle.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Tavis Ormandy <taviso@google.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com> Cc: Kostya Serebryany <kcc@google.com> Cc: Eric Dumazet <edumazet@google.com> Cc: Alexander Potapenko <glider@google.com> Cc: Kees Cook <keescook@google.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: David Drysdale <drysdale@google.com> Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org> Cc: Andrey Ryabinin <ryabinin.a.a@gmail.com> Cc: Kirill A. Shutemov <kirill@shutemov.name> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-20Merge branch 'core-objtool-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull 'objtool' stack frame validation from Ingo Molnar: "This tree adds a new kernel build-time object file validation feature (ONFIG_STACK_VALIDATION=y): kernel stack frame correctness validation. It was written by and is maintained by Josh Poimboeuf. The motivation: there's a category of hard to find kernel bugs, most of them in assembly code (but also occasionally in C code), that degrades the quality of kernel stack dumps/backtraces. These bugs are hard to detect at the source code level. Such bugs result in incorrect/incomplete backtraces most of time - but can also in some rare cases result in crashes or other undefined behavior. The build time correctness checking is done via the new 'objtool' user-space utility that was written for this purpose and which is hosted in the kernel repository in tools/objtool/. The tool's (very simple) UI and source code design is shaped after Git and perf and shares quite a bit of infrastructure with tools/perf (which tooling infrastructure sharing effort got merged via perf and is already upstream). Objtool follows the well-known kernel coding style. Objtool does not try to check .c or .S files, it instead analyzes the resulting .o generated machine code from first principles: it decodes the instruction stream and interprets it. (Right now objtool supports the x86-64 architecture.) From tools/objtool/Documentation/stack-validation.txt: "The kernel CONFIG_STACK_VALIDATION option enables a host tool named objtool which runs at compile time. It has a "check" subcommand which analyzes every .o file and ensures the validity of its stack metadata. It enforces a set of rules on asm code and C inline assembly code so that stack traces can be reliable. Currently it only checks frame pointer usage, but there are plans to add CFI validation for C files and CFI generation for asm files. For each function, it recursively follows all possible code paths and validates the correct frame pointer state at each instruction. It also follows code paths involving special sections, like .altinstructions, __jump_table, and __ex_table, which can add alternative execution paths to a given instruction (or set of instructions). Similarly, it knows how to follow switch statements, for which gcc sometimes uses jump tables." When this new kernel option is enabled (it's disabled by default), the tool, if it finds any suspicious assembly code pattern, outputs warnings in compiler warning format: warning: objtool: rtlwifi_rate_mapping()+0x2e7: frame pointer state mismatch warning: objtool: cik_tiling_mode_table_init()+0x6ce: call without frame pointer save/setup warning: objtool:__schedule()+0x3c0: duplicate frame pointer save warning: objtool:__schedule()+0x3fd: sibling call from callable instruction with changed frame pointer ... so that scripts that pick up compiler warnings will notice them. All known warnings triggered by the tool are fixed by the tree, most of the commits in fact prepare the kernel to be warning-free. Most of them are bugfixes or cleanups that stand on their own, but there are also some annotations of 'special' stack frames for justified cases such entries to JIT-ed code (BPF) or really special boot time code. There are two other long-term motivations behind this tool as well: - To improve the quality and reliability of kernel stack frames, so that they can be used for optimized live patching. - To create independent infrastructure to check the correctness of CFI stack frames at build time. CFI debuginfo is notoriously unreliable and we cannot use it in the kernel as-is without extra checking done both on the kernel side and on the build side. The quality of kernel stack frames matters to debuggability as well, so IMO we can merge this without having to consider the live patching or CFI debuginfo angle" * 'core-objtool-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (52 commits) objtool: Only print one warning per function objtool: Add several performance improvements tools: Copy hashtable.h into tools directory objtool: Fix false positive warnings for functions with multiple switch statements objtool: Rename some variables and functions objtool: Remove superflous INIT_LIST_HEAD objtool: Add helper macros for traversing instructions objtool: Fix false positive warnings related to sibling calls objtool: Compile with debugging symbols objtool: Detect infinite recursion objtool: Prevent infinite recursion in noreturn detection objtool: Detect and warn if libelf is missing and don't break the build tools: Support relative directory path for 'O=' objtool: Support CROSS_COMPILE x86/asm/decoder: Use explicitly signed chars objtool: Enable stack metadata validation on 64-bit x86 objtool: Add CONFIG_STACK_VALIDATION option objtool: Add tool to perform compile-time stack metadata validation x86/kprobes: Mark kretprobe_trampoline() stack frame as non-standard sched: Always inline context_switch() ...
2016-03-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Highlights: 1) Support more Realtek wireless chips, from Jes Sorenson. 2) New BPF types for per-cpu hash and arrap maps, from Alexei Starovoitov. 3) Make several TCP sysctls per-namespace, from Nikolay Borisov. 4) Allow the use of SO_REUSEPORT in order to do per-thread processing of incoming TCP/UDP connections. The muxing can be done using a BPF program which hashes the incoming packet. From Craig Gallek. 5) Add a multiplexer for TCP streams, to provide a messaged based interface. BPF programs can be used to determine the message boundaries. From Tom Herbert. 6) Add 802.1AE MACSEC support, from Sabrina Dubroca. 7) Avoid factorial complexity when taking down an inetdev interface with lots of configured addresses. We were doing things like traversing the entire address less for each address removed, and flushing the entire netfilter conntrack table for every address as well. 8) Add and use SKB bulk free infrastructure, from Jesper Brouer. 9) Allow offloading u32 classifiers to hardware, and implement for ixgbe, from John Fastabend. 10) Allow configuring IRQ coalescing parameters on a per-queue basis, from Kan Liang. 11) Extend ethtool so that larger link mode masks can be supported. From David Decotigny. 12) Introduce devlink, which can be used to configure port link types (ethernet vs Infiniband, etc.), port splitting, and switch device level attributes as a whole. From Jiri Pirko. 13) Hardware offload support for flower classifiers, from Amir Vadai. 14) Add "Local Checksum Offload". Basically, for a tunneled packet the checksum of the outer header is 'constant' (because with the checksum field filled into the inner protocol header, the payload of the outer frame checksums to 'zero'), and we can take advantage of that in various ways. From Edward Cree" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1548 commits) bonding: fix bond_get_stats() net: bcmgenet: fix dma api length mismatch net/mlx4_core: Fix backward compatibility on VFs phy: mdio-thunder: Fix some Kconfig typos lan78xx: add ndo_get_stats64 lan78xx: handle statistics counter rollover RDS: TCP: Remove unused constant RDS: TCP: Add sysctl tunables for sndbuf/rcvbuf on rds-tcp socket net: smc911x: convert pxa dma to dmaengine team: remove duplicate set of flag IFF_MULTICAST bonding: remove duplicate set of flag IFF_MULTICAST net: fix a comment typo ethernet: micrel: fix some error codes ip_tunnels, bpf: define IP_TUNNEL_OPTS_MAX and use it bpf, dst: add and use dst_tclassid helper bpf: make skb->tc_classid also readable net: mvneta: bm: clarify dependencies cls_bpf: reset class and reuse major in da ldmvsw: Checkpatch sunvnet.c and sunvnet_common.c ldmvsw: Add ldmvsw.c driver code ...
2016-03-01cpu/hotplug: Make target state writeableThomas Gleixner
Make it possible to write a target state to the per cpu state file, so we can switch between states. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: linux-arch@vger.kernel.org Cc: Rik van Riel <riel@redhat.com> Cc: Rafael Wysocki <rafael.j.wysocki@intel.com> Cc: "Srivatsa S. Bhat" <srivatsa@mit.edu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Sebastian Siewior <bigeasy@linutronix.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Tejun Heo <tj@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Paul McKenney <paulmck@linux.vnet.ibm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul Turner <pjt@google.com> Link: http://lkml.kernel.org/r/20160226182341.022814799@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-02-29objtool: Add CONFIG_STACK_VALIDATION optionJosh Poimboeuf
Add a CONFIG_STACK_VALIDATION option which will run "objtool check" for each .o file to ensure the validity of its stack metadata. Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@kernel.org> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Bernd Petrovitsch <bernd@petrovitsch.priv.at> Cc: Borislav Petkov <bp@alien8.de> Cc: Chris J Arges <chris.j.arges@canonical.com> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Michal Marek <mmarek@suse.cz> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Pedro Alves <palves@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: live-patching@vger.kernel.org Link: http://lkml.kernel.org/r/92baab69a6bf9bc7043af0bfca9fb964a1d45546.1456719558.git.jpoimboe@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-02-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/phy/bcm7xxx.c drivers/net/phy/marvell.c drivers/net/vxlan.c All three conflicts were cases of simple overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2016-02-19test_bitmap: unit tests for lib/bitmap.cDavid Decotigny
This is mainly testing bitmap construction and conversion to/from u32[] for now. Tested: qemu i386, x86_64, ppc, ppc64 BE and LE, ARM. Signed-off-by: David Decotigny <decot@googlers.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-02-09workqueue: implement "workqueue.debug_force_rr_cpu" debug featureTejun Heo
Workqueue used to guarantee local execution for work items queued without explicit target CPU. The guarantee is gone now which can break some usages in subtle ways. To flush out those cases, this patch implements a debug feature which forces round-robin CPU selection for all such work items. The debug feature defaults to off and can be enabled with a kernel parameter. The default can be flipped with a debug config option. If you hit this commit during bisection, please refer to 041bd12e272c ("Revert "workqueue: make sure delayed work run in local cpu"") for more information and ping me. Signed-off-by: Tejun Heo <tj@kernel.org>
2016-01-21Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge third patch-bomb from Andrew Morton: "I'm pretty much done for -rc1 now: - the rest of MM, basically - lib/ updates - checkpatch, epoll, hfs, fatfs, ptrace, coredump, exit - cpu_mask simplifications - kexec, rapidio, MAINTAINERS etc, etc. - more dma-mapping cleanups/simplifications from hch" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (109 commits) MAINTAINERS: add/fix git URLs for various subsystems mm: memcontrol: add "sock" to cgroup2 memory.stat mm: memcontrol: basic memory statistics in cgroup2 memory controller mm: memcontrol: do not uncharge old page in page cache replacement Documentation: cgroup: add memory.swap.{current,max} description mm: free swap cache aggressively if memcg swap is full mm: vmscan: do not scan anon pages if memcg swap limit is hit swap.h: move memcg related stuff to the end of the file mm: memcontrol: replace mem_cgroup_lruvec_online with mem_cgroup_online mm: vmscan: pass memcg to get_scan_count() mm: memcontrol: charge swap to cgroup2 mm: memcontrol: clean up alloc, online, offline, free functions mm: memcontrol: flatten struct cg_proto mm: memcontrol: rein in the CONFIG space madness net: drop tcp_memcontrol.c mm: memcontrol: introduce CONFIG_MEMCG_LEGACY_KMEM mm: memcontrol: allow to disable kmem accounting for cgroup2 mm: memcontrol: account "kmem" consumers in cgroup2 memory controller mm: memcontrol: move kmem accounting code to CONFIG_MEMCG mm: memcontrol: separate kmem code from legacy tcp accounting code ...
2016-01-20Do not enable CONFIG_IO_STRICT_DEVMEM by defaultDan Williams
Larry Finger reports: "My PowerBook G4 Aluminum with a 32-bit PPC processor fails to boot for the 4.4-git series". This is likely due to X still needing /dev/mem access on this platform. CONFIG_IO_STRICT_DEVMEM is not yet safe to turn on when CONFIG_STRICT_DEVMEM=y. Remove the default so that old configurations do not change behavior. Fixes: 90a545e98126 ("restrict /dev/mem to idle io memory ranges") Reported-by: Larry Finger <Larry.Finger@lwfinger.net> Tested-by: Larry Finger <Larry.Finger@lwfinger.net> Link: http://marc.info/?l=linux-kernel&m=145332012023825&w=2 Acked-by: Kees Cook <keescook@chromium.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-20UBSAN: run-time undefined behavior sanity checkerAndrey Ryabinin
UBSAN uses compile-time instrumentation to catch undefined behavior (UB). Compiler inserts code that perform certain kinds of checks before operations that could cause UB. If check fails (i.e. UB detected) __ubsan_handle_* function called to print error message. So the most of the work is done by compiler. This patch just implements ubsan handlers printing errors. GCC has this capability since 4.9.x [1] (see -fsanitize=undefined option and its suboptions). However GCC 5.x has more checkers implemented [2]. Article [3] has a bit more details about UBSAN in the GCC. [1] - https://gcc.gnu.org/onlinedocs/gcc-4.9.0/gcc/Debugging-Options.html [2] - https://gcc.gnu.org/onlinedocs/gcc/Debugging-Options.html [3] - http://developerblog.redhat.com/2014/10/16/gcc-undefined-behavior-sanitizer-ubsan/ Issues which UBSAN has found thus far are: Found bugs: * out-of-bounds access - 97840cb67ff5 ("netfilter: nfnetlink: fix insufficient validation in nfnetlink_bind") undefined shifts: * d48458d4a768 ("jbd2: use a better hash function for the revoke table") * 10632008b9e1 ("clockevents: Prevent shift out of bounds") * 'x << -1' shift in ext4 - http://lkml.kernel.org/r/<5444EF21.8020501@samsung.com> * undefined rol32(0) - http://lkml.kernel.org/r/<1449198241-20654-1-git-send-email-sasha.levin@oracle.com> * undefined dirty_ratelimit calculation - http://lkml.kernel.org/r/<566594E2.3050306@odin.com> * undefined roundown_pow_of_two(0) - http://lkml.kernel.org/r/<1449156616-11474-1-git-send-email-sasha.levin@oracle.com> * [WONTFIX] undefined shift in __bpf_prog_run - http://lkml.kernel.org/r/<CACT4Y+ZxoR3UjLgcNdUm4fECLMx2VdtfrENMtRRCdgHB2n0bJA@mail.gmail.com> WONTFIX here because it should be fixed in bpf program, not in kernel. signed overflows: * 32a8df4e0b33f ("sched: Fix odd values in effective_load() calculations") * mul overflow in ntp - http://lkml.kernel.org/r/<1449175608-1146-1-git-send-email-sasha.levin@oracle.com> * incorrect conversion into rtc_time in rtc_time64_to_tm() - http://lkml.kernel.org/r/<1449187944-11730-1-git-send-email-sasha.levin@oracle.com> * unvalidated timespec in io_getevents() - http://lkml.kernel.org/r/<CACT4Y+bBxVYLQ6LtOKrKtnLthqLHcw-BMp3aqP3mjdAvr9FULQ@mail.gmail.com> * [NOTABUG] signed overflow in ktime_add_safe() - http://lkml.kernel.org/r/<CACT4Y+aJ4muRnWxsUe1CMnA6P8nooO33kwG-c8YZg=0Xc8rJqw@mail.gmail.com> [akpm@linux-foundation.org: fix unused local warning] [akpm@linux-foundation.org: fix __int128 build woes] Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Michal Marek <mmarek@suse.cz> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Yury Gribov <y.gribov@samsung.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Kostya Serebryany <kcc@google.com> Cc: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-16Kconfig: remove HAVE_LATENCYTOP_SUPPORTWill Deacon
As illustrated by commit a3afe70b83fd ("[S390] latencytop s390 support."), HAVE_LATENCYTOP_SUPPORT is defined by an architecture to advertise an implementation of save_stack_trace_tsk. However, as of 9212ddb5eada ("stacktrace: provide save_stack_trace_tsk() weak alias") a dummy implementation is provided if STACKTRACE=y. Given that LATENCYTOP already depends on STACKTRACE_SUPPORT and selects STACKTRACE, we can remove HAVE_LATENCYTOP_SUPPORT altogether. Signed-off-by: Will Deacon <will.deacon@arm.com> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: James Hogan <james.hogan@imgtec.com> Cc: Michal Simek <monstr@monstr.eu> Cc: Helge Deller <deller@gmx.de> Acked-by: Michael Ellerman <mpe@ellerman.id.au> Cc: "David S. Miller" <davem@davemloft.net> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Ingo Molnar <mingo@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-15page-flags: introduce page flags policies wrt compound pagesKirill A. Shutemov
This patch adds a third argument to macros which create function definitions for page flags. This argument defines how page-flags helpers behave on compound functions. For now we define four policies: - PF_ANY: the helper function operates on the page it gets, regardless if it's non-compound, head or tail. - PF_HEAD: the helper function operates on the head page of the compound page if it gets tail page. - PF_NO_TAIL: only head and non-compond pages are acceptable for this helper function. - PF_NO_COMPOUND: only non-compound pages are acceptable for this helper function. For now we use policy PF_ANY for all helpers, which matches current behaviour. We do not enforce the policy for TESTPAGEFLAG, because we have flags checked for random pages all over the kernel. Noticeable exception to this is PageTransHuge() which triggers VM_BUG_ON() for tail page. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Christoph Lameter <cl@linux.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Steve Capper <steve.capper@linaro.org> Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Jerome Marchand <jmarchan@redhat.com> Cc: Jérôme Glisse <jglisse@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-13Merge tag 'libnvdimm-for-4.5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm Pull libnvdimm updates from Dan Williams: "The bulk of this has appeared in -next and independently received a build success notification from the kbuild robot. The 'for-4.5/block- dax' topic branch was rebased over the weekend to drop the "block device end-of-life" rework that Al would like to see re-implemented with a notifier, and to address bug reports against the badblocks integration. There is pending feedback against "libnvdimm: Add a poison list and export badblocks" received last week. Linda identified some localized fixups that we will handle incrementally. Summary: - Media error handling: The 'badblocks' implementation that originated in md-raid is up-levelled to a generic capability of a block device. This initial implementation is limited to being consulted in the pmem block-i/o path. Later, 'badblocks' will be consulted when creating dax mappings. - Raw block device dax: For virtualization and other cases that want large contiguous mappings of persistent memory, add the capability to dax-mmap a block device directly. - Increased /dev/mem restrictions: Add an option to treat all io-memory as IORESOURCE_EXCLUSIVE, i.e. disable /dev/mem access while a driver is actively using an address range. This behavior is controlled via the new CONFIG_IO_STRICT_DEVMEM option and can be overridden by the existing "iomem=relaxed" kernel command line option. - Miscellaneous fixes include a 'pfn'-device huge page alignment fix, block device shutdown crash fix, and other small libnvdimm fixes" * tag 'libnvdimm-for-4.5' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm: (32 commits) block: kill disk_{check|set|clear|alloc}_badblocks libnvdimm, pmem: nvdimm_read_bytes() badblocks support pmem, dax: disable dax in the presence of bad blocks pmem: fail io-requests to known bad blocks libnvdimm: convert to statically allocated badblocks libnvdimm: don't fail init for full badblocks list block, badblocks: introduce devm_init_badblocks block: clarify badblocks lifetime badblocks: rename badblocks_free to badblocks_exit libnvdimm, pmem: move definition of nvdimm_namespace_add_poison to nd.h libnvdimm: Add a poison list and export badblocks nfit_test: Enable DSMs for all test NFITs md: convert to use the generic badblocks code block: Add badblock management for gendisks badblocks: Add core badblock management code block: fix del_gendisk() vs blkdev_ioctl crash block: enable dax for raw block devices block: introduce bdev_file_inode() restrict /dev/mem to idle io memory ranges arch: consolidate CONFIG_STRICT_DEVM in lib/Kconfig.debug ...
2016-01-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from Davic Miller: 1) Support busy polling generically, for all NAPI drivers. From Eric Dumazet. 2) Add byte/packet counter support to nft_ct, from Floriani Westphal. 3) Add RSS/XPS support to mvneta driver, from Gregory Clement. 4) Implement IPV6_HDRINCL socket option for raw sockets, from Hannes Frederic Sowa. 5) Add support for T6 adapter to cxgb4 driver, from Hariprasad Shenai. 6) Add support for VLAN device bridging to mlxsw switch driver, from Ido Schimmel. 7) Add driver for Netronome NFP4000/NFP6000, from Jakub Kicinski. 8) Provide hwmon interface to mlxsw switch driver, from Jiri Pirko. 9) Reorganize wireless drivers into per-vendor directories just like we do for ethernet drivers. From Kalle Valo. 10) Provide a way for administrators "destroy" connected sockets via the SOCK_DESTROY socket netlink diag operation. From Lorenzo Colitti. 11) Add support to add/remove multicast routes via netlink, from Nikolay Aleksandrov. 12) Make TCP keepalive settings per-namespace, from Nikolay Borisov. 13) Add forwarding and packet duplication facilities to nf_tables, from Pablo Neira Ayuso. 14) Dead route support in MPLS, from Roopa Prabhu. 15) TSO support for thunderx chips, from Sunil Goutham. 16) Add driver for IBM's System i/p VNIC protocol, from Thomas Falcon. 17) Rationalize, consolidate, and more completely document the checksum offloading facilities in the networking stack. From Tom Herbert. 18) Support aborting an ongoing scan in mac80211/cfg80211, from Vidyullatha Kanchanapally. 19) Use per-bucket spinlock for bpf hash facility, from Tom Leiming. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1375 commits) net: bnxt: always return values from _bnxt_get_max_rings net: bpf: reject invalid shifts phonet: properly unshare skbs in phonet_rcv() dwc_eth_qos: Fix dma address for multi-fragment skbs phy: remove an unneeded condition mdio: remove an unneed condition mdio_bus: NULL dereference on allocation error net: Fix typo in netdev_intersect_features net: freescale: mac-fec: Fix build error from phy_device API change net: freescale: ucc_geth: Fix build error from phy_device API change bonding: Prevent IPv6 link local address on enslaved devices IB/mlx5: Add flow steering support net/mlx5_core: Export flow steering API net/mlx5_core: Make ipv4/ipv6 location more clear net/mlx5_core: Enable flow steering support for the IB driver net/mlx5_core: Initialize namespaces only when supported by device net/mlx5_core: Set priority attributes net/mlx5_core: Connect flow tables net/mlx5_core: Introduce modify flow table command net/mlx5_core: Managing root flow table ...
2016-01-11Merge tag 'mmc-v4.5' of git://git.linaro.org/people/ulf.hansson/mmcLinus Torvalds
Pull MMC updates from Ulf Hansson: "MMC core: - Optimize boot time by detecting cards simultaneously - Make runtime resume default behavior for MMC/SD - Enable MMC/SD/SDIO devices to suspend/resume asynchronously - Allow more than 8 partitions per card - Introduce MMC_CAP2_NO_SDIO to prevent unsupported SDIO commands - Support the standard DT wakeup-source property - Fix driver strength switching for HS200 and HS400 - Fix switch command timeout - Fix invalid vdd in voltage switch power cycle for SDIO MMC host: - sdhci: Restore behavior when setting VDD via external regulator - sdhci: A couple of changes/fixes related to the dma support - sdhci-tegra: Add Tegra210 support - sdhci-tegra: Support for UHS-I cards including tuning support - sdhci-of-at91: Add PM support - sh_mmcif: Rework dma channel handling - mvsdio: Delete platform data code path" * tag 'mmc-v4.5' of git://git.linaro.org/people/ulf.hansson/mmc: (52 commits) mmc: dw_mmc: remove the unused quirks mmc: sdhci-pci: use to_pci_dev() mmc: cb710: use to_platform_device() mmc: tegra: use correct accessor for misc ctrl register mmc: tegra: enable UHS-I modes mmc: tegra: implement UHS tuning mmc: tegra: disable SPI_MODE_CLKEN mmc: tegra: implement module external clock change mmc: sdhci: restore behavior when setting VDD via external regulator mmc: It is not an error for the card to be removed while suspended mmc: block: Allow more than 8 partitions per card mmc: core: Optimize boot time by detecting cards simultaneously mmc: dw_mmc: use resource_size_t to store physical address mmc: core: fix __mmc_switch timeout caused by preempt mmc: usdhi6rol0: handle NULL data in timeout mmc: of_mmc_spi: Add IRQF_ONESHOT to interrupt flags mmc: mediatek: change some dev_err to dev_dbg mmc: enable MMC/SD/SDIO device to suspend/resume asynchronously mmc: sdhci: Fix sdhci_runtime_pm_bus_on/off() mmc: sdhci: 64-bit DMA actually has 4-byte alignment ...
2016-01-09restrict /dev/mem to idle io memory rangesDan Williams
This effectively promotes IORESOURCE_BUSY to IORESOURCE_EXCLUSIVE semantics by default. If userspace really believes it is safe to access the memory region it can also perform the extra step of disabling an active driver. This protects device address ranges with read side effects and otherwise directs userspace to use the driver. Persistent memory presents a large "mistake surface" to /dev/mem as now accidental writes can corrupt a filesystem. In general if a device driver is busily using a memory region it already informs other parts of the kernel to not touch it via request_mem_region(). /dev/mem should honor the same safety restriction by default. Debugging a device driver from userspace becomes more difficult with this enabled. Any application using /dev/mem or mmap of sysfs pci resources will now need to perform the extra step of either: 1/ Disabling the driver, for example: echo <device id> > /dev/bus/<parent bus>/drivers/<driver name>/unbind 2/ Rebooting with "iomem=relaxed" on the command line 3/ Recompiling with CONFIG_IO_STRICT_DEVMEM=n Traditional users of /dev/mem like dosemu are unaffected because the first 1MB of memory is not subject to the IO_STRICT_DEVMEM restriction. Legacy X configurations use /dev/mem to talk to graphics hardware, but that functionality has since moved to kernel graphics drivers. Cc: Arnd Bergmann <arnd@arndb.de> Cc: Russell King <linux@arm.linux.org.uk> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Kees Cook <keescook@chromium.org> Acked-by: Ingo Molnar <mingo@redhat.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2016-01-09arch: consolidate CONFIG_STRICT_DEVM in lib/Kconfig.debugDan Williams
Let all the archs that implement devmem_is_allowed() opt-in to a common definition of CONFIG_STRICT_DEVM in lib/Kconfig.debug. Cc: Kees Cook <keescook@chromium.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Will Deacon <will.deacon@arm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> [heiko: drop 'default y' for s390] Acked-by: Ingo Molnar <mingo@redhat.com> Suggested-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2015-12-22mmc: kconfig: replace FAULT_INJECTION with FAULT_INJECTION_DEBUG_FSAdrien Schildknecht
Fault-injection capability for MMC IO uses debugfs entries to configure the attributes. FAULT_INJECTION_DEBUG_FS must be enabled to use FAIL_MMC_REQUEST. Replace FAULT_INJECTION with FAULT_INJECTION_DEBUG_FS. Also remove 'select DEBUG_FS' since FAULT_INJECTION_DEBUG_FS depends on it. Signed-off-by: Adrien Schildknecht <adrien+dev@schischi.me> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
2015-12-08workqueue: implement lockup detectorTejun Heo
Workqueue stalls can happen from a variety of usage bugs such as missing WQ_MEM_RECLAIM flag or concurrency managed work item indefinitely staying RUNNING. These stalls can be extremely difficult to hunt down because the usual warning mechanisms can't detect workqueue stalls and the internal state is pretty opaque. To alleviate the situation, this patch implements workqueue lockup detector. It periodically monitors all worker_pools periodically and, if any pool failed to make forward progress longer than the threshold duration, triggers warning and dumps workqueue state as follows. BUG: workqueue lockup - pool cpus=0 node=0 flags=0x0 nice=0 stuck for 31s! Showing busy workqueues and worker pools: workqueue events: flags=0x0 pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=17/256 pending: monkey_wrench_fn, e1000_watchdog, cache_reap, vmstat_shepherd, release_one_tty, release_one_tty, release_one_tty, release_one_tty, release_one_tty, release_one_tty, release_one_tty, release_one_tty, release_one_tty, release_one_tty, release_one_tty, release_one_tty, cgroup_release_agent workqueue events_power_efficient: flags=0x80 pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=2/256 pending: check_lifetime, neigh_periodic_work workqueue cgroup_pidlist_destroy: flags=0x0 pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=1/1 pending: cgroup_pidlist_destroy_work_fn ... The detection mechanism is controller through kernel parameter workqueue.watchdog_thresh and can be updated at runtime through the sysfs module parameter file. v2: Decoupled from softlockup control knobs. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Don Zickus <dzickus@redhat.com> Cc: Ulrich Obergfell <uobergfe@redhat.com> Cc: Michal Hocko <mhocko@suse.com> Cc: Chris Mason <clm@fb.com> Cc: Andrew Morton <akpm@linux-foundation.org>
2015-12-01net: add support for netdev notifier error injectionNikolay Aleksandrov
This module allows to insert errors in some of netdevice's notifier events. All network drivers use these notifiers to signal various events and to check if they are allowed, e.g. PRECHANGEMTU and CHANGEMTU afterwards. Until recently I had to run failure tests by injecting a custom module, but now this infrastructure makes it trivial to test these failure paths. Some of the recent bugs I fixed were found using this module. Here's an example: $ cd /sys/kernel/debug/notifier-error-inject/netdev $ echo -22 > actions/NETDEV_CHANGEMTU/error $ ip link set eth0 mtu 1024 RTNETLINK answers: Invalid argument CC: Akinobu Mita <akinobu.mita@gmail.com> CC: "David S. Miller" <davem@davemloft.net> CC: netdev <netdev@vger.kernel.org> Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-09Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module updates from Rusty Russell: "Nothing exciting, minor tweaks and cleanups" * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: scripts: [modpost] add new sections to white list modpost: Add flag -E for making section mismatches fatal params: don't ignore the rest of cmdline if parse_one() fails modpost: abort if a module symbol is too long
2015-11-06test_printf: test printf family at runtimeRasmus Villemoes
This adds a simple module for testing the kernel's printf facilities. Previously, some %p extensions have caused a wrong return value in case the entire output didn't fit and/or been unusable in kasprintf(). This should help catch such issues. Also, it should help ensure that changes to the formatting algorithms don't break anything. I'm not sure if we have a struct dentry or struct file lying around at boot time or if we can fake one, but most %p extensions should be testable, as should the ordinary number and string formatting. The nature of vararg functions means we can't use a more conventional table-driven approach. For now, this is mostly a skeleton; contributions are very welcome. Some tests are/will be slightly annoying to write, since the expected output depends on stuff like CONFIG_*, sizeof(long), runtime values etc. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Reviewed-by: Kees Cook <keescook@chromium.org> Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Martin Kletzander <mkletzan@redhat.com> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-10-23lib/Kconfig.debug: disable -Wframe-larger-than warnings with KASAN=yAndrey Ryabinin
When the kernel compiled with KASAN=y, GCC adds redzones for each variable on stack. This enlarges function's stack frame and causes: 'warning: the frame size of X bytes is larger than Y bytes' The worst case I've seen for now is following: ../net/wireless/nl80211.c: In function `nl80211_send_wiphy': ../net/wireless/nl80211.c:1731:1: warning: the frame size of 5448 bytes is larger than 2048 bytes [-Wframe-larger-than=] That kind of warning becomes useless with KASAN=y. It doesn't necessarily indicate that there is some problem in the code, thus we should turn it off. (The KASAN=y stack size in increased from 16k to 32k for this reason) Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Reported-by: Fengguang Wu <fengguang.wu@intel.com> Acked-by: Abylay Ospan <aospan@netup.ru> Cc: Andi Kleen <andi@firstfloor.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Mauro Carvalho Chehab <m.chehab@samsung.com> Cc: Kozlov Sergey <serjk@netup.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-10-06modpost: Add flag -E for making section mismatches fatalNicolas Boichat
The section mismatch warning can be easy to miss during the kernel build process. Allow it to be marked as fatal to be easily caught and prevent bugs from slipping in. Setting CONFIG_SECTION_MISMATCH_WARN_ONLY=y causes these warnings to be non-fatal, since there are a number of section mismatches when using allmodconfig on some architectures, and we do not want to break these builds by default. Signed-off-by: Nicolas Boichat <drinkcat@chromium.org> Change-Id: Ic346706e3297c9f0d790e3552aa94e5cff9897a6 Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
