* git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-kgdb:
kgdb: always use icache flush for sw breakpoints
kgdb: fix SMP NMI kgdb_handle_exception exit race
kgdb: documentation fixes
kgdb: allow static kgdbts boot configuration
kgdb: add documentation
kgdb: Kconfig fix
kgdb: add kgdb internal test suite
kgdb: fix several kgdb regressions
kgdb: kgdboc pl011 I/O module
kgdb: fix optional arch functions and probe_kernel_*
kgdb: add x86 HW breakpoints
kgdb: print breakpoint removed on exception
kgdb: clocksource watchdog
kgdb: fix NMI hangs
kgdb: fix kgdboc dynamic module configuration
kgdb: document parameters
x86: kgdb support
consoles: polling support, kgdboc
kgdb: core
uaccess: add probe_kernel_write()
git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc
* 'semaphore' of git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc:
Remove DEBUG_SEMAPHORE from Kconfig
Improve semaphore documentation
Simplify semaphore implementation
Add down_timeout and change ACPI to use it
Introduce down_killable()
Generic semaphore implementation
Add semaphore.h to kernel_lock.c
Fix quota.h includes
kgdb core code. Handles the protocol and the arch details.
[ mingo@elte.hu: heavily modified, simplified and cleaned up. ]
[ xemul@openvz.org: use find_task_by_pid_ns ]
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
Signed-off-by: Jan Kiszka <jan.kiszka@web.de>
Alpha and FRV mutexes had an option to print lots of debugging messages
in their semaphore implementation. This feature has not been carried
over to the generic semaphores, so remove the stale Kconfig option.
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
count_partial() is used by both slabinfo and the sysfs proc support. Move
the function directly before the beginning of the sysfs code so that it can
be easily found. Rework the preprocessor conditional to take into account
that slub sysfs support depends on CONFIG_SYSFS *and* CONFIG_SLUB_DEBUG.
Make CONFIG_SLUB_STATS depend on CONFIG_SLUB_DEBUG and CONFIG_SYSFS. There
is no point of keeping statistics if no one can restrive them.
Signed-off-by: Christoph Lameter <clameter@sgi.com>
Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
Make LKDTM depend on BLOCK to prevent build failures with certain configs.
Signed-off-by: Chris Snook <csnook@redhat.com>
We started to see patches enabling this - so explain why
it is disabled and the condition to enable it again.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Other than the defconfigs, remove the entry in compiler-gcc4.h,
Kconfig.debug and feature-removal-schedule.txt.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Add architecture support for the MN10300/AM33 CPUs produced by MEI to the
kernel.
This patch also adds board support for the ASB2303 with the ASB2308 daughter
board, and the ASB2305. The only processor supported is the MN103E010, which
is an AM33v2 core plus on-chip devices.
[akpm@linux-foundation.org: nuke cvs control strings]
Signed-off-by: Masakazu Urade <urade.masakazu@jp.panasonic.com>
Signed-off-by: Koichi Yasutake <yasutake.koichi@jp.panasonic.com>
The statistics provided here allow the monitoring of allocator behavior but
at the cost of some (minimal) loss of performance. Counters are placed in
SLUB's per cpu data structure. The per cpu structure may be extended by the
statistics to grow larger than one cacheline which will increase the cache
footprint of SLUB.
There is a compile option to enable/disable the inclusion of the runtime
statistics and its off by default.
The slabinfo tool is enhanced to support these statistics via two options:
-D Switches the line of information displayed for a slab from size
mode to activity mode.
-A Sorts the slabs displayed by activity. This allows the display of
the slabs most important to the performance of a certain load.
-r Report option will report detailed statistics on
Example (tbench load):
slabinfo -AD ->Shows the most active slabs
Name Objects Alloc Free %Fast
skbuff_fclone_cache 33 111953835 111953835 99 99
:0000192 2666 5283688 5281047 99 99
:0001024 849 5247230 5246389 83 83
vm_area_struct 1349 119642 118355 91 22
:0004096 15 66753 66751 98 98
:0000064 2067 25297 23383 98 78
dentry 10259 28635 18464 91 45
:0000080 11004 18950 8089 98 98
:0000096 1703 12358 10784 99 98
:0000128 762 10582 9875 94 18
:0000512 184 9807 9647 95 81
:0002048 479 9669 9195 83 65
anon_vma 777 9461 9002 99 71
kmalloc-8 6492 9981 5624 99 97
:0000768 258 7174 6931 58 15
So the skbuff_fclone_cache is of highest importance for the tbench load.
Pretty high load on the 192 sized slab. Look for the aliases
slabinfo -a | grep 000192
:0000192 <- xfs_btree_cur filp kmalloc-192 uid_cache tw_sock_TCP
request_sock_TCPv6 tw_sock_TCPv6 skbuff_head_cache xfs_ili
Likely skbuff_head_cache.
Looking into the statistics of the skbuff_fclone_cache is possible through
slabinfo skbuff_fclone_cache ->-r option implied if cache name is mentioned
.... Usual output ...
Slab Perf Counter Alloc Free %Al %Fr
Fastpath 111953360 111946981 99 99
Slowpath 1044 7423 0 0
Page Alloc 272 264 0 0
Add partial 25 325 0 0
Remove partial 86 264 0 0
RemoteObj/SlabFrozen 350 4832 0 0
Total 111954404 111954404
Flushes 49 Refill 0
Deactivate Full=325(92%) Empty=0(0%) ToHead=24(6%) ToTail=1(0%)
Looks good because the fastpath is overwhelmingly taken.
skbuff_head_cache:
Fastpath 5297262 5259882 99 99
Slowpath 4477 39586 0 0
Page Alloc 937 824 0 0
Add partial 0 2515 0 0
Remove partial 1691 824 0 0
RemoteObj/SlabFrozen 2621 9684 0 0
Total 5301739 5299468
Deactivate Full=2620(100%) Empty=0(0%) ToHead=0(0%) ToTail=0(0%)
Descriptions of the output:
Total: The total number of allocation and frees that occurred for a
slab
Fastpath: The number of allocations/frees that used the fastpath.
Slowpath: Other allocations
Page Alloc: Number of calls to the page allocator as a result of slowpath
processing
Add Partial: Number of slabs added to the partial list through free or
alloc (occurs during cpuslab flushes)
Remove Partial: Number of slabs removed from the partial list as a result of
allocations retrieving a partial slab or by a free freeing
the last object of a slab.
RemoteObj/Froz: How many times were remotely freed object encountered when a
slab was about to be deactivated. Frozen: How many times was
free able to skip list processing because the slab was in use
as the cpuslab of another processor.
Flushes: Number of times the cpuslab was flushed on request
(kmem_cache_shrink, may result from races in __slab_alloc)
Refill: Number of times we were able to refill the cpuslab from
remotely freed objects for the same slab.
Deactivate: Statistics how slabs were deactivated. Shows how they were
put onto the partial list.
In general fastpath is very good. Slowpath without partial list processing is
also desirable. Any touching of partial list uses node specific locks which
may potentially cause list lock contention.
Including additional fixes from Randy Dunlap <randy.dunlap@oracle.com>
Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
We have too many section mismatches detected at the moment.
So silence modpost and prevent the option from being
set in a typical allyesconfig build.
Tell the user how to see all the deteils in the summary
message from modpost.
Change latencytop Kconfig entry so it doesn't list the archictectures
that support it. Instead introduce HAVE_LATENCY_SUPPORT which any
architecture can set. Should reduce patch conflicts.
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: Holger Wolf <wolf@linux.vnet.ibm.com>
This patch adds a new configuration option, which adds support for a new
early_param which gets checked in arch/x86/kernel/setup_{32,64}.c:setup_arch()
to decide wether OHCI-1394 FireWire controllers should be initialized and
enabled for physical DMA access to allow remote debugging of early problems
like issues ACPI or other subsystems which are executed very early.
If the config option is not enabled, no code is changed, and if the boot
paramenter is not given, no new code is executed, and independent of that,
all new code is freed after boot, so the config option can be even enabled
in standard, non-debug kernels.
With specialized tools, it is then possible to get debugging information
from machines which have no serial ports (notebooks) such as the printk
buffer contents, or any data which can be referenced from global pointers,
if it is stored below the 4GB limit and even memory dumps of of the physical
RAM region below the 4GB limit can be taken without any cooperation from the
CPU of the host, so the machine can be crashed early, it does not matter.
In the extreme, even kernel debuggers can be accessed in this way. I wrote
a small kgdb module and an accompanying gdb stub for FireWire which allows
to gdb to talk to kgdb using remote remory reads and writes over FireWire.
An version of the gdb stub fore FireWire is able to read all global data
from a system which is running a a normal kernel without any kernel debugger,
without any interruption or support of the system's CPU. That way, e.g. the
task struct and so on can be read and even manipulated when the physical DMA
access is granted.
A HOWTO is included in this patch, in Documentation/debugging-via-ohci1394.txt
and I've put a copy online at
ftp://ftp.suse.de/private/bk/firewire/docs/debugging-via-ohci1394.txt
It also has links to all the tools which are available to make use of it
another copy of it is online at:
ftp://ftp.suse.de/private/bk/firewire/kernel/ohci1394_dma_early-v2.diff
Signed-Off-By: Bernhard Kaindl <bk@suse.de>
Tested-By: Thomas Renninger <trenn@suse.de>
During the work on the x86 32 and 64 bit backtrace code I found it useful
to have a simple test module to test a process and irq context backtrace.
Since the existing backtrace code was buggy, I figure it might be useful
to have such a test module in the kernel so that maybe we can even
detect such bugs earlier..
[ mingo@elte.hu: build fix ]
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Here is a quick and naive smoke test for kprobes. This is intended to
just verify if some unrelated change broke the *probes subsystem. It is
self contained, architecture agnostic and isn't of any great use by itself.
This needs to be built in the kernel and runs a basic set of tests to
verify if kprobes, jprobes and kretprobes run fine on the kernel. In case
of an error, it'll print out a message with a "BUG" prefix.
This is a start; we intend to add more tests to this bucket over time.
Thanks to Jim Keniston and Masami Hiramatsu for comments and suggestions.
Tested on x86 (32/64) and powerpc.
Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Acked-by: Masami Hiramatsu <mhiramat@redhat.com>
If the config option CONFIG_SECTION_MISMATCH is not set and
we see a Section mismatch present the following to the user:
modpost: Found 1 section mismatch(es).
To see additional details select "Enable full Section mismatch analysis"
in the Kernel Hacking menu (CONFIG_SECTION_MISMATCH).
If the option CONFIG_SECTION_MISMATCH is selected
then be verbose in the Section mismatch reporting from mdopost.
Sample outputs:
WARNING: o-x86_64/vmlinux.o(.text+0x7396): Section mismatch in reference from the function discover_ebda() to the variable .init.data:ebda_addr
The function discover_ebda() references
the variable __initdata ebda_addr.
This is often because discover_ebda lacks a __initdata
annotation or the annotation of ebda_addr is wrong.
WARNING: o-x86_64/vmlinux.o(.data+0x74d58): Section mismatch in reference from the variable pci_serial_quirks to the function .devexit.text:pci_plx9050_exit()
The variable pci_serial_quirks references
the function __devexit pci_plx9050_exit()
If the reference is valid then annotate the
variable with __exit* (see linux/init.h) or name the variable:
*driver, *_template, *_timer, *_sht, *_ops, *_probe, *_probe_one, *_console,
WARNING: o-x86_64/vmlinux.o(__ksymtab+0x630): Section mismatch in reference from the variable __ksymtab_arch_register_cpu to the function .cpuinit.text:arch_register_cpu()
The symbol arch_register_cpu is exported and annotated __cpuinit
Fix this by removing the __cpuinit annotation of arch_register_cpu or drop the export.
Setting the option DEBUG_SECTION_MISMATCH will
report additional section mismatch'es but this
should in the end makes it possible to get rid of
all of them.
See help text in lib/Kconfig.debug for details.
LatencyTOP kernel infrastructure; it measures latencies in the
scheduler and tracks it system wide and per process.
Signed-off-by: Mike Frysinger <michael.frysinger@analog.com>
Signed-off-by: Bryan Wu <bryan.wu@analog.com>
The __deprecated marker is quite useful in highlighting the remnants of
old APIs that want removing.
However, it is quite normal for one or more years to pass, before the
(usually ancient, bitrotten) code in question is either updated or
deleted.
Thus, like __must_check, add a Kconfig option that permits the silencing
of this compiler warning.
This change mimics the ifdef-ery and Kconfig defaults of MUST_CHECK as
closely as possible.
Add a Kconfig entry which will toggle some sanity checks on the sg
entry and tables.
Begin infrastructure for kernel code samples in the samples/ directory.
Add its Kconfig and Kbuild files.
Source its Kconfig file in all arch/ Kconfigs.
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
Optionally add a boot delay after each kernel printk() call, crudely
measured in milliseconds, with a maximum delay of 10 seconds per printk.
Enable CONFIG_BOOT_PRINTK_DELAY=y and then add (e.g.):
"lpj=loops_per_jiffy boot_delay=100"
to the kernel command line.
It has been useful in cases like "during boot, my machine just reboots or the
screen goes black" by slowing down printk, (and adding initcall_debug), we can
usually see the last thing that happened before the lights went out which is
usually a valuable clue.
[akpm@linux-foundation.org: not all architectures implement CONFIG_HZ]
[akpm@linux-foundation.org: fix lots of stuff]
[bunk@stusta.de: kernel/printk.c: make 2 variables static]
[heiko.carstens@de.ibm.com: fix slow down printk on boot compile error]
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Signed-off-by: Dave Jones <davej@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc
* 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (408 commits)
[POWERPC] Add memchr() to the bootwrapper
[POWERPC] Implement logging of unhandled signals
[POWERPC] Add legacy serial support for OPB with flattened device tree
[POWERPC] Use 1TB segments
[POWERPC] XilinxFB: Allow fixed framebuffer base address
[POWERPC] XilinxFB: Add support for custom screen resolution
[POWERPC] XilinxFB: Use pdata to pass around framebuffer parameters
[POWERPC] PCI: Add 64-bit physical address support to setup_indirect_pci
[POWERPC] 4xx: Kilauea defconfig file
[POWERPC] 4xx: Kilauea DTS
[POWERPC] 4xx: Add AMCC Kilauea eval board support to platforms/40x
[POWERPC] 4xx: Add AMCC 405EX support to cputable.c
[POWERPC] Adjust TASK_SIZE on ppc32 systems to 3GB that are capable
[POWERPC] Use PAGE_OFFSET to tell if an address is user/kernel in SW TLB handlers
[POWERPC] 85xx: Enable FP emulation in MPC8560 ADS defconfig
[POWERPC] 85xx: Killed <asm/mpc85xx.h>
[POWERPC] 85xx: Add cpm nodes for 8541/8555 CDS
[POWERPC] 85xx: Convert mpc8560ads to the new CPM binding.
[POWERPC] mpc8272ads: Remove muram from the CPM reg property.
[POWERPC] Make clockevents work on PPC601 processors
Fixed up conflict in Documentation/powerpc/booting-without-of.txt manually.
Provide some documentation for CONFIG_LOCK_STAT.
Cc: "Randy.Dunlap" <rdunlap@xenotime.net>
Cc: Rob Landley <rob@landley.net>
Add CONFIG_DEBUG_PREEMPT support to ppc64: it was useful for testing
get_paca() preemption. Cheat a little, just use debug_smp_processor_id()
in the debug version of get_paca(): it contains all the right checks and
reporting, though get_paca() doesn't really use smp_processor_id().
Use local_paca for what might have been called __raw_get_paca().
Silence harmless warnings from io.h and lparcfg.c with local_paca -
it is okay for iseries_lparcfg_data to be referencing shared_proc
with preemption enabled: all cpus should show the same value for
shared_proc.
Why do other architectures need TRACE_IRQFLAGS_SUPPORT for DEBUG_PREEMPT?
I don't know, ppc64 appears to get along fine without it.
Signed-off-by: Hugh Dickins <hugh@veritas.com>
The arm26 port has been in a state where it was far from even compiling
for quite some time.
Ian Molton agreed with the removal.
Cc: Ian Molton <spyro@f2s.com>
Introduce the core lock statistics code.
Lock statistics provides lock wait-time and hold-time (as well as the count
of corresponding contention and acquisitions events). Also, the first few
call-sites that encounter contention are tracked.
Lock wait-time is the time spent waiting on the lock. This provides insight
into the locking scheme, that is, a heavily contended lock is indicative of
a too coarse locking scheme.
Lock hold-time is the duration the lock was held, this provides a reference for
the wait-time numbers, so they can be put into perspective.
1)
lock
2)
... do stuff ..
unlock
3)
The time between 1 and 2 is the wait-time. The time between 2 and 3 is the
hold-time.
The lockdep held-lock tracking code is reused, because it already collects locks
into meaningful groups (classes), and because it is an existing infrastructure
for lock instrumentation.
Currently lockdep tracks lock acquisition with two hooks:
lock()
lock_acquire()
_lock()
... code protected by lock ...
unlock()
lock_release()
_unlock()
We need to extend this with two more hooks, in order to measure contention.
lock_contended() - used to measure contention events
lock_acquired() - completion of the contention
These are then placed the following way:
lock()
lock_acquire()
if (!_try_lock())
lock_contended()
_lock()
lock_acquired()
... do locked stuff ...
unlock()
lock_release()
_unlock()
(Note: the try_lock() 'trick' is used to avoid instrumenting all platform
dependent lock primitive implementations.)
It is also possible to toggle the two lockdep features at runtime using:
/proc/sys/kernel/prove_locking
/proc/sys/kernel/lock_stat
(esp. turning off the O(n^2) prove_locking functionaliy can help)
[akpm@linux-foundation.org: build fixes]
[akpm@linux-foundation.org: nuke unneeded ifdefs]
Acked-by: Jason Baron <jbaron@redhat.com>
Add a new configuration variable
CONFIG_SLUB_DEBUG_ON
If set then the kernel will be booted by default with slab debugging
switched on. Similar to CONFIG_SLAB_DEBUG. By default slab debugging
is available but must be enabled by specifying "slub_debug" as a
kernel parameter.
Also add support to switch off slab debugging for a kernel that was
built with CONFIG_SLUB_DEBUG_ON. This works by specifying
slub_debug=-
as a kernel parameter.
Dave Jones wanted this feature.
http://marc.info/?l=linux-kernel&m=118072189913045&w=2
[akpm@linux-foundation.org: clean up switch statement]
enable CONFIG_SCHED_DEBUG in lib/Kconfig.debug.
the runtime overhead of this option is very small.
Make timer-stats have almost zero overhead when enabled in the config but
not used. (this way distros can enable it more easily)
Also update the documentation about overhead of timer_stats - it was
written for the first version which had a global lock and a linear list
walk based lookup ;-)
There have been a number of instances where people have accidentally compiled
rcutorture into the kernel (CONFIG_RCU_TORTURE_TEST=y), which has never been
useful, and has often resulted in great frustration.
The attached patch prohibits rcutorture from being compiled into the
kernel. It may be excluded altogether or compiled as a module. People
wishing to have rcutorture hammer their machine immediately upon boot
are free to hand-edit lib/Kconfig.debug to remove the "depends on m"
line.
Thanks to Randy Dunlap for the trick that makes this work.
Acked-by: Josh Triplett <josh@kernel.org>
Disable stacktrace filter support for x86-64 for now. Will be enable when we
can get the dwarf2 unwinder back.
Acked-by: Andi Kleen <ak@suse.de>
Several people have observed that perhaps LOG_BUF_SHIFT should be in a more
obvious place than under DEBUG_KERNEL. Under some circumstances (such as the
PARISC architecture), DEBUG_KERNEL can increase kernel size, which is an
undesirable trade off for something as trivial as increasing the kernel log
buffer size.
Instead, move LOG_BUF_SHIFT into "General Setup", so that people are more
likely to be able to change it such a circumstance that the default buffer
size is insufficient.
Signed-off-by: Alistair John Strachan <s0348365@sms.ed.ac.uk>
Remove the Kconfig selection of semaphore debugging from the ALPHA and FRV
Kconfig files, and centralize it in lib/Kconfig.debug.
There doesn't seem to be much point in letting individual architectures
independently define the same Kconfig option when it can just as easily be
put in a single Kconfig file and made dependent on a subset of
architectures. that way, at least the option shows up in the same relative
location in the menu each time.
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Richard Henderson <rth@twiddle.net>
This adds support for the Analog Devices Blackfin processor architecture, and
currently supports the BF533, BF532, BF531, BF537, BF536, BF534, and BF561
(Dual Core) devices, with a variety of development platforms including those
avaliable from Analog Devices (BF533-EZKit, BF533-STAMP, BF537-STAMP,
BF561-EZKIT), and Bluetechnix! Tinyboards.
The Blackfin architecture was jointly developed by Intel and Analog Devices
Inc. (ADI) as the Micro Signal Architecture (MSA) core and introduced it in
December of 2000. Since then ADI has put this core into its Blackfin
processor family of devices. The Blackfin core has the advantages of a clean,
orthogonal,RISC-like microprocessor instruction set. It combines a dual-MAC
(Multiply/Accumulate), state-of-the-art signal processing engine and
single-instruction, multiple-data (SIMD) multimedia capabilities into a single
instruction-set architecture.
The Blackfin architecture, including the instruction set, is described by the
ADSP-BF53x/BF56x Blackfin Processor Programming Reference
http://blackfin.uclinux.org/gf/download/frsrelease/29/2549/Blackfin_PRM.pdf
The Blackfin processor is already supported by major releases of gcc, and
there are binary and source rpms/tarballs for many architectures at:
http://blackfin.uclinux.org/gf/project/toolchain/frs There is complete
documentation, including "getting started" guides available at:
http://docs.blackfin.uclinux.org/ which provides links to the sources and
patches you will need in order to set up a cross-compiling environment for
bfin-linux-uclibc
This patch, as well as the other patches (toolchain, distribution,
uClibc) are actively supported by Analog Devices Inc, at:
We have tested this on LTP, and our test plan (including pass/fails) can
be found at:
http://docs.blackfin.uclinux.org/doku.php?id=testing_the_linux_kernel
[m.kozlowski@tuxland.pl: balance parenthesis in blackfin header files]
Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl>
Signed-off-by: Aubrey Li <aubrey.li@analog.com>
Signed-off-by: Jie Zhang <jie.zhang@analog.com>
The following patch adds some extra clarification to the CONFIG_DEBUG_INFO
Kconfig help text. The current text is mostly a recursive definition and
doesn't really say much of anything. When I first read this I thought it
was going to enable extra verbosity in debug messages or something, but it
is only enabling the "gcc -g" compile option in the Makefile.
Signed-off-by: Andreas Dilger <adilger@clusterfs.com>
Stacktrace support on MIPS doesn't use frame pointers. Since this option
considerably increases the size of the kernel code, force lockdep to not
use it.
Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com>
There is no prompt for CONFIG_STACKTRACE, so FAULT_INJECTION cannot be
selected without LOCKDEP enabled. (found by Paolo 'Blaisorblade'
Giarrusso)
In order to fix such broken Kconfig dependency, this patch splits up the
stacktrace filter support for fault injection by new Kconfig option, which
enables to use fault injection on the architecture which doesn't have
general stacktrace support.
Cc: "Paolo 'Blaisorblade' Giarrusso" <blaisorblade@yahoo.it>
Add /proc/timer_stats support: debugging feature to profile timer expiration.
Both the starting site, process/PID and the expiration function is captured.
This allows the quick identification of timer event sources in a system.
Sample output:
# echo 1 > /proc/timer_stats
# cat /proc/timer_stats
Timer Stats Version: v0.1
Sample period: 4.010 s
24, 0 swapper hrtimer_stop_sched_tick (hrtimer_sched_tick)
11, 0 swapper sk_reset_timer (tcp_delack_timer)
6, 0 swapper hrtimer_stop_sched_tick (hrtimer_sched_tick)
2, 1 swapper queue_delayed_work_on (delayed_work_timer_fn)
17, 0 swapper hrtimer_restart_sched_tick (hrtimer_sched_tick)
4, 2050 pcscd do_nanosleep (hrtimer_wakeup)
5, 4179 sshd sk_reset_timer (tcp_write_timer)
4, 2248 yum-updatesd schedule_timeout (process_timeout)
18, 0 swapper hrtimer_restart_sched_tick (hrtimer_sched_tick)
3, 0 swapper sk_reset_timer (tcp_delack_timer)
1, 1 swapper neigh_table_init_no_netlink (neigh_periodic_timer)
2, 1 swapper e1000_up (e1000_watchdog)
1, 1 init schedule_timeout (process_timeout)
100 total events, 25.24 events/sec
[ cleanups and hrtimers support from Thomas Gleixner <tglx@linutronix.de> ]
[bunk@stusta.de: nr_entries can become static]
Cc: john stultz <johnstul@us.ibm.com>
Cc: Roman Zippel <zippel@linux-m68k.org>
Cc: Andi Kleen <ak@suse.de>
Drivers registering IRQ handlers with SA_SHIRQ really ought to be able to
handle an interrupt happening before request_irq() returns. They also
ought to be able to handle an interrupt happening during the start of their
call to free_irq(). Let's test that hypothesis....
[bunk@stusta.de: Kconfig fixes]
Cc: Arjan van de Ven <arjan@infradead.org>
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
Remove the few references to the obsolete kernel config option
DEBUG_RWSEMS.
It has caused more problems than it ever really solved, and is
apparently not getting cleaned up and fixed. We can put it back when
it's stable and isn't likely to make warning or bug events worse.
In the meantime, enable frame pointers for more readable stack traces.
Refactor Kconfig content to maximize nesting of menus by menuconfig and
xconfig.
Tested by simultaneously running `make xconfig` with and without
patch, and comparing displays.
Signed-off-by: Don Mullis <dwm@meer.net>
`select' doesn't work very well. With alpha `make allmodconfig' we end up
with CONFIG_STACKTRACE enabled, so we end up with undefined save_stacktrace()
at link time.
Cc: Akinobu Mita <akinobu.mita@gmail.com>
Cc: Don Mullis <dwm@meer.net>
- Fix some spelling and grammatical errors
- Make the Kconfig menu more conventional. First you select
fault-injection, then under that you select particular clients of it.
